XJ750 with XJ650 carbs
Discussion in 'XJ Technical Chat' started by Erim Tezcan, Mar 4, 2020.
Tags:
  1. Erim Tezcan
    Erim Tezcan New Member
    Illinois
    Hey guys - so back in November I posted on here asking if anyone had an xj750 carburetor and I got a bite and the guy offered me a carburetor for an xj650. He did say they were compatible. I have slowly started putting everything back together. Can anyone tell me if I will be ok with the 650 carb set or did I get tricked?
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
  3. Erim Tezcan
    Illinois
    Thanks mate, didn’t even see that.
  4. XJ550H
    no . the carbs are the same body and set up but jetted different you would need to do a complete rejetting from slide needles , air jets and fuel jets
    http://xjbikes.wikidot.com/carb-specs
    Years & Models: 1982-3 XJ650 Maxim USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 5N800
    Main FUEL Jet Size: #110
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #50
    Pilot AIR Jet Size: #205
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-10
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca Canadian models
    Carb Series: HSC32
    Carb Model ID: 15T00 (Maxim, Midnight Maxim)
    Carb Model ID: 5H200 (Seca)
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #43
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #195
    Main jet NEEDLE ID: #Y-14
    hogfiddles and Timbox like this.
  5. Timbox
    Without the internal changes not going to work the way you want it to. Find the correct carbs from someone on here for a good price.
  6. Erim Tezcan
    Illinois
    Thanks timbox
  7. Toomanybikes
    Tsawwassen bc
    Buddy north of you in Toronto has similar problem. Has a 650 and has a set of 750 carbs you should do a swap
    Timbox and Erim Tezcan like this.
  8. Erim Tezcan
    Illinois
    Could you give me info on that?
  9. Toomanybikes
    Tsawwassen bc
    Sorry he doesn’t have a 750 set to swap. He was going to get a 750 set and rejet to fit his 650. I do have a 750 maxim set that has been to church including new diaphragms , throttle shaft seals that I could sell to you. PM me if you’re interested. Maybe he will buy your 650 set.
    Erim Tezcan likes this.
  10. Erim Tezcan
    Illinois
  11. Erim Tezcan
    Illinois
    I PM’d you - let me know if you got it.
  12. First82maxim
    First82maxim New Member
    Drayton ontario
    Hello everyone ! I know this thread is a couple years old now but i'm trying to get my bike together and am having similar issues. I have a 1982 xj650 with carbs that are filthy, I'm picking up a 81 xj750 seca that hit a curb for a parts bike this coming weekend and am curious on if I could make the xj750 seca carbs work on the xj650. the owner states the engine ran great before the accident. I do have the xj650 carbs complete if I need to steal a jet or 2. Any help would be great ! thanks
    Robert24b likes this.
  13. Dan Gardner
    Minneapolis, MN
    First82maxim likes this.
  14. First82maxim
    Drayton ontario
    Thanks for the quick response ! sounds like I'll just have to slap em on and play around with it see what works for me. I don't have much for specialty tools to work on these bikes as i'm only $200 into the bike so going to trying to keep my costs low as possible lol and thanks for the link it is definitely going to be useful with my trial and errors i'm sure I will face.
  15. XJ550H
    750 caebs on a 650 should start and run may be rich
    you could swap the air jets and fuel jets from your 650 carbs
    Timbox likes this.
  16. hogfiddles
    Just swap literally everything:Jets, needles, etc...... the carb bodies and rails are the same.
    Timbox likes this.
  17. First82maxim
    Drayton ontario
    Awesome thanks for the suggestions ! I'm hopeful to find a decent middle ground between the 650 and 750 carbs lol. i will keep everyone updated on my progress!
  18. hogfiddles
    There’s not a middle ground.
    the bodies are the same. The jetting/internals are the differences.
