Xj750j
Discussion in 'XJ Technical Chat' started by Rocket900rr2, Sep 7, 2019.
  1. Rocket900rr2
    Rocket900rr2 New Member
    Spartanburg South Carolina
    I need a link for service Manual badly my bike will intermediately lock up then I I can put it in 5th and rock it back and forth and it will turn over again
  2. Rocket900rr2
    Any help would be appreciated
  3. k-moe
  4. XJ550H
    had that happen when starting my new purchase 650 fuel flooded the cylinder hydro lock pulled the plugs turned it over and fuel shot out of cylinders 1 and 2
    carb rebuild time
    but yes we need more info on exactly what is going on with your bike.
    locks up when riding? check the rear brake shoes. if you haven't DO IT or you may die.
    SAFETY ALERT Drum rear brake bike owners please take a look
    cant down load but manuals http://www.xjcd.org/Service_Manuals
    if it is your shifter locking up
    http://www.xjcd.org/emergency_guidectomy
  5. Rocket900rr2
    Ok let me start by I have to pull off bike starter is out the motor has been gone through but didn't break cases put it back to gether it hit once then slid back tire ok in 3 4 5 if I stop and leave in gear rock it back and forth it will turn for about 10 or 15 feet then lock so I pulled oil pan to look and on the big wide chain on the crank has slip in it I thinking it has something to do with it
  6. XJ550H
  7. k-moe
    Sounds like the alternator chain guide is no more.
    emergency guidectomy
    That link will tell you how to check, and the solution therein is temporary. If the guide is broken, it must be replaced or expensive parts (including the engine cases) will be damaged.
