XJ750RH Seca, want shift lever on the splined shaft, source?
Discussion in 'XJ Modifications' started by sebwiers, Nov 25, 2012.
  1. sebwiers
    sebwiers Active Member
    I'm moving the pegs on my Seca rearwards a bit, enough that it makes more sense to have the shifter directly on the splined shaft rather than linkage activated.
    Seems like those levers come in a bajilion varieties and you can't just buy a generic one. The XJ650's run this style of shifter and have the same spline (or should- the service manual shows the same internals for both bikes) so I figured I'd get one of those and modify the arm if it bumped against something.
    However, I'm having a hard time finding a source on one. Anybody know a place that sells em, preferably in steel and for under $30?
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Chacal/xj4ever/Len has them in his catalog and there are used one on ebay most of the time for around $10
  3. sebwiers
    How do I get that catalog? Following the link at the top of the page that says "click here for catalog" only takes me to a forum.
    The catalog is a thread in that forum. Pats Catalog
  5. fintip
    fintip Member
    Austin
    It's often out of date, though. Best to just send chacal a PM.
  6. sebwiers
    Seriously? Its a big text dump in a forum? Yikes. Has the dude never heard of a database driven website? I'm almost willing to set up a magento or drupal site for him to avoid pulling my hair reading that thing.
  7. iwingameover
    iwingameover Active Member
    Just PM or email him what you want and he sends back the options he has. I rarely read the catalog.
  8. TIMEtoRIDE
    Sebweirs - - If you look at your side cover, there's a nub 2 1/2 inches back from your shifter shaft. Thats where the shaft comes out on a Maxim.
    You buy a shifter off E-Bay from just about ANY Yamaha of the era and the splines will be correct. You pay $10.00 or so. You mount it pointing backwards and it will shift normally. (1 down, 4 up)
    You'll have to get clever to match the brake side.
  9. sebwiers
    Re: XJ750RH Seca, want shift lever on the splined shaft, sou
    TIMEtoRIDE -
    Ah, cool. Yep, that's ecactly what I was planning to do. The brake lever I'm just gonna chop and weld, then move the back end connection to preserve the same basic toe-movement to brake-application ratio.
    Come to think, if I'm planning to chop the brake lever I have, I might as well chop the shifter I have as well. If I ever restore it to shock, I'd have to buy both, but that's not much worse than shopping for just the brake lever.
