Xj900 rear end
Discussion in 'XJ Modifications' started by Ribi71, May 23, 2023.
  1. Ribi71
    Ribi71 New Member
    Somerset
    Has anyone put or tried to fit a fjr 1300 rear end to the xj900.
  2. Simmy
    Doesn't look compatible to me.
    Even if it did fit, mono-shock swingarms are typically longer as the shock nestles between the wheel and the swingarm pivot.
    Unless you're going for the drag racer/hill-climber look, it's not going to look very good.
    An XJ900 Diversion wheel can be fit to your existing swingarm and a 150 wide tire fitted.
    @Mezzmo has videos showing this.
    swing-arm-yamaha-fjr-1300-967287680.jpg 15t3-228d66dddc8f56be9702b221465fdac7.jpg
    Ribi71 likes this.
  3. tobar
    tobar Member
    england
    and mezzmo's build on youtube was a superb watch
  4. hogfiddles
    Pivot width is different and the ‘shaft/cross joint is in the way
