YamaGPZ 650 Project
Discussion in 'XJ Modifications' started by uhoh, May 23, 2010.
  1. uhoh
    uhoh Member
    BC, Canada
    Gauges all set up and working! Slowly getting there, just need to figure out a paint scheme now.
  2. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Looking great I can't wait to see the end result!
  3. IvarNelson
    IvarNelson Member
    Sweden
    Any updates?!
    Its a very inspiring thread.
    Did the virago rear wheel fit with the xj drive or did you have to do anythinf to it?
  4. silverdollar
    silverdollar Member
    Chesapeake, VA
  5. vic_romano
    vic_romano New Member
    Wish my wife would let me bring my bike in the house :)
  6. uhoh
    uhoh Member
    BC, Canada
    Thanks for the kind words guys! I will try and get some updates asap. Got a new job so that has been taking up a lot of my time. :?
    Never used a Virago Rear wheel, the wheel I'm using is a Divvy wheel! It mated up fine except will require you to fabricate a spacer to work with the old axle.
    Haha, it didn't last long, I'll tell you that!
  7. skylrk62
    skylrk62 Active Member
    Illinois
    I love this rear setup! I'm going to locate the wheel. Looks like they are all in the UK. FZ1 brackets are plentiful here in the states. I wonder how the 150/70-17 wheel will fit in the maxim swingarm? Do you guys think it will have to be notched? I looked up a few tires that size, avg tread width is 6.38" under load vs 5.59" on 130/90-16 under load. I know some mod might have to be done? I was going with the '83 wheel, but this looks way hotter! I'm going to do some homework. Any word on the specs for that bearing that was made for the FZ1 bracket?
  8. skylrk62
    Illinois
    I just received the FZ1 bracket w/ caliper today. It was only $40 on Ebay. The XJ900S Wheel was another story. I had to search overseas and the cheapest I could find over the last two weeks was one in Germany for 159 Euros + shipping. This was a little steep, but to have a 150/70-17 rear wheel on a Maxim will be very unique. It did not come with a disc brake. I'm searching online and I found that the Diversion rear disc is 245mm diameter, while the FZ1 is 267mm. My question is, do they have the same bolt spacing? I feel that I should have the FZ1 caliper to match up with the caliper? The wheel was shipped today. Any thoughts out there?
  9. skylrk62
    Illinois
    So any Ideas?? uhoh, What disc did you use??
  10. uhoh
    uhoh Member
    BC, Canada
    I'll have to double check my disc size (It came with the diversion rear wheel, and I'm pretty sure its 245). The problem I ran into is that the bracket collides with the disc bolts on the rear diversion wheel. I have notched the bracket a bit but am not satisfied with the result so far. As I don't have a FZ disc, I wouldn't be able to help you out with the bolt spacing.
  11. uhoh
    uhoh Member
    BC, Canada
    The bushing was made at a local machine shop. Make sure they know that the axle tapers slightly so you are able to get it on!
  12. broberg
    broberg Member
    Sweden, Östergötland
    This build looks awesome!
    And I really really love the gpz tank, just another bike to add to my got-to-have-list, right after a Harley Davidson XR750 Replica :D
  13. skylrk62
    Illinois
    Thanks for the tip! Would it be possible if you took some more detailed photos of the rear? The tire clearance, the rear caliper setup, etc..? It would help me out.
  14. uhoh
    uhoh Member
    BC, Canada
    Couple modifications later...
    [​IMG][/URL]
  15. farmer
    farmer Member
    microsquirt?
  16. bendoza
    bendoza Member
    portland, or
    looking very nice.
  17. guami007
    guami007 New Member
    Minnesota
    Greetings.
    I have a question around the Diversion 900 rear wheel and other possible alternatives that could fit that I can source from a US Domestic Market model motorcycle? As I understand, Diversion 900 was made for European market. I've looked on local CL here in Minneapolis on off chance that a Diversion 900 rear wheel will pop up but it doesn't look good. I am looking at doing a similar build such as this one. So far, I have a complete running motorcycle, and a complete 1995 FZR front end. What I really need is the rear Diversion type wheel to allow me to move on to the next step. Any feedback on possible alternatives would be greatly appreciated.
    Happy trails all.
  18. uhoh
    uhoh Member
    BC, Canada
    As you correctly guessed you will not find the wheel in North America. I had to source it from Italy off of eBay. There appears to be one available right now from the UK but in rough shape. http://www.ebay.com/sch/i.html?_odk...r+wheel+900+-bearing+-bearings+-disc&_sacat=0
  19. a100man
    a100man Well-Known Member
    Bedford, UK
    You should get one cheaper than that - I bought two (admittedly rough ) FZ750 wheels for 25 quid. Try searching for 'XJ900 breaking' - our term for parting out - and then message the seller.
  20. zap2504
    zap2504 Member
    Middletown, PA
    If you don't mind miss-matched wheels, remember that the Seca 750 rear wheel will bolt directly on to the Maxim 650/750 hub to give you an 18" wheel (but not as wide as the Diversion 750/900).
