YAMAHA tank or fairing badge
Discussion in 'XJ 3D Printing & STL Files' started by BigTex, Jun 23, 2022.
  1. BigTex
    BigTex Member
    Northern Colorado
    Made to the size of fairing badge on the XJ650LJ turbo. Could obviously be resized for others.
    I've printed a couple trying to get the best top surface sanded smooth. Also trying options to get best colors, this one uses mylar wrap film to get the proper chrome finish. Still a work in process.
    Badmofo77, kalinin68 and Dan Gardner like this.
  2. Vern Nelson
    Vern Nelson Member
    Winnipeg
  3. Justa Aussie
    Justa Aussie New Member
    Adelaide, Australia
    well done! I am playing with creating an XJ750 badge, since mine are in terrible condition, might have to work a bit harder on it now.
  4. Melnic
    Melnic Active Member
    There is a plastic coating that 3d Printers use to fill in the gaps. We tried that on a 3D print that was VERY low resolution (large 2ft x 1.5ft part) we ended up using bondo instead.
    You may want to try that 3d printer filler stuff cause it brushes on. I'm suggesting this for the inset parts, not what you chromed.
    This is the stuff:
    https://www.amazon.com/XTC-3D-High-Performance-Print-Coating/dp/B01BKSLI9M
    After using it once I thought that thinned out (with alcohol) slow set epoxy would be just as good.
    Originally we were using ABS, it was harder to print and we had to cover the printer and keep the heat consistant.
    Acetone could melt it which could be used in a vapor form to smoothen it out or even bond it together. But that stuff was not very good outdoors.
    I have been using PETG to print on stuff that I put in an Marine environment and its UV stable and have stuff on a boat for past 3 years and looks new.
