Yamaha XJ 550 4V8 Trouble Starting Motorcycle (Philipp's ongoing troubleshoot)
Discussion in 'XJ Technical Chat' started by PHIdet, Oct 13, 2019.
  1. hogfiddles
    1. Brakes-there is an adjustment screw on the bottom/back/inside of the brake handle. Turn it in a bit
    2.worn tire?
    3. Seized link
    4. sounds like you’re missing a ground wire somewhere, or a wire is off in the bucket. You may have to open things back up and look closer
  2. PHIdet
    PHIdet Member
    Saarland, Germany
    1. Great, thanks :D
    2. They're completely new, but I put them on end of last year. Most the bike stood umoved in one spot were maybe 4 months, but even then it was on the main stand, so I kinda doubt it's a flat spot.
    3. I did lube it properly, but the seized link is possible. Should I ride the bike a bit and keep the chain well-lubed in order to free it up, or should I definitely clean it first? Any good method of doing that while the chain is installed?
    4. That might be, though I wonder how the high beam for example works but the high beam indicator doesn't. As far as I can see, they're running off the same wire. You're right though, I guess I'm gonna have to check again.
  3. hogfiddles
    Seized link——-loosen the chain so it is very slack. Then go through the whole chain and check every link and pivot point. Time-consuming? Yup.
  4. XJ550H
    oil would be full of gas and above the sight glass. I think it is just moisture. just keep an eye on oil level
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    What fun is that? Fire=fun.
  6. XJ550H
    huffing fuel may fun for some but i like fire
  7. PHIdet
    PHIdet Member
    Saarland, Germany
    I've got one more question concerning the oil pressure light: How likely is it that the actual oil level switch is broken? That would be a pain to get off.
    What's an easy way to test if the bulb and all the wires leading to it are working?
  8. a100man
    a100man Well-Known Member
    Bedford, UK
    Tyre not 'centred' properly. i found it very hard to get a tubeless tyre centre on a rim with a tube (if that makes sense). Riding will help you discover any stability issues
    1-2mm wont make much difference IMHO.
  9. PHIdet
    PHIdet Member
    Saarland, Germany
    I see what you mean, I feared as much. I didn't do the tyres myself, an acquaintance of mine did that, he's got his own workshop and usually does things spotlessly.
    Is there anything I could do to fix that without any special tools or experience? I've never worked on tyres.
    I'd prefer to have this sorted out, I don't think I'd feel comfortable riding, knowing that there's something off.
  10. XJ550H
    When you press the starter button the oil light should light up. that is the test for the bulb. To test oil switch which is on the bottom of the motor in the oil pan when you drain the oil turn the key on and the oil light should come on. Then when you fill the bike with oil to the spec turn the key on and oil light should be off.
  11. PHIdet
    PHIdet Member
    Saarland, Germany
    Guys I'm currently working on the indicator problem, and I noticed that there's a thread without any wire connected to it.
    Do you guys know if there's something supposed to be connected to the second most left connector, so the one just below the red line?
    https://www.directupload.net/file/d/5812/bo6vxmuh_jpg.htm
    Also, what wires would I have to hotwire in order for the oil light to come on?
  12. PHIdet
    PHIdet Member
    Saarland, Germany
    Little update:
    I figured out all the indicators, so that's working.
    I've got a new problem now:
    Suddenly, while the bike is running, the battery has a voltage of only 12,2V. When accelerating, the voltage goes up to the 13-14 Volt (but not above 14,5V) and the light gets brighter, but when it's decelerating it goes back down to 12,2V.
    Afaik, that wasn't the case yesterday.
    What do you guys think?
  13. PHIdet
    PHIdet Member
    Saarland, Germany
    Fyi, here's a little video about what I mean. I'm sorry if you have trouble seeing the voltmeter, I had to do that all by myself.
  14. SQLGuy
    SQLGuy Well-Known Member
    Accelerating or decelerating shouldn't make a difference. 12.2V at idle sounds OK. 13 to 14 above 2500RPM or so, is OK.
  15. PHIdet
    PHIdet Member
    Saarland, Germany
    So this is all ok?
    Huh okay, thanks for clearing that up for me. I was under the impression that the little voltmeter in the bike dash used to show 13-14 V while idling.
    Still, is it normal that the brightness of the headlight changes depending on the rpm?
  16. XJ550H
    the oil light comes on when the oil level switch goes low and switches connecting the ground. or when the blue/white wire for starter button makes ground when button is pushed
    so if you add a ground to the oil switch wire light will come on
    if you press starter button light will come on.
  17. a100man
    Bedford, UK
    You should be able to see if it is off centre by the markers and text on the tyre.. I spoke to a mech yesterday who suggested deflate and thoroughly soap tyre walls/rims. the inflate high (70-80 psi (5 bar)) then reduce to normal pressure of course. Not tried this myself!
  18. PHIdet
    PHIdet Member
    Saarland, Germany
    That's interesting, I might try that. What do you mean by soaping tyre walls/rims? Like, lube them so it's all sliding into place when inflating?
  19. XJ550H
    I use my caliper to measure from end of frame to end of chain adjuster. measure on both sides untill even . I use the part that slides out from the arm and the end of the arm
  20. XJ550H
    yes
  21. a100man
    Bedford, UK
    Special soap/lube is available but dishes liquid will do, some say it contains salt which can corrode but Im not sure how true that is.
