Yamaha XJ550 Maxim
Discussion in 'XJ Technical Chat' started by old's cool, Nov 18, 2020.
  1. old's cool
    old's cool New Member
    LA
    Hi,
    I need to pick your XJ bikes' owners' and enthusiasts' brains about my XJ550 maxim! :)
    hopefully your expertise would help me with this bike!
    I need you to find out if the engine is making noise(s) which it shouldn't and is NOT supposed to!
    P.S. I can't upload the audio/video file!! :-(
    the valves should be taping like an old sewing machine.
    rpm spec is 1050 rpm but better at 1200rpm due to oil tensioner for the primary chain
    keep posting after a few more posts you can do links and uploads
  3. cgutz
    cgutz Well-Known Member
    SE South Dakota
    If valves are out of spec on an XJ550, they are quiet. If in spec, they "tap" rhythmically like a sewing machine as described.
  4. old's cool
    LA
    would you mind leaving me your email address here or have it send to me by "the admin" so we can discuss this faster and with no obstacles(such as limitations on uploading any link, ....)?!
  5. XJ550H
    click on my avatar and star a conversation with me
  6. XJ550H
    one noise you will want to check out is if it is coming from the clutch . there is a steel pin that needs to be replaced .
  7. cgutz
    SE South Dakota
    You may also hear a sound coming from the top of the engine that I describe as "clattering the end of a coat hanger back and forth inside an empty tin can." As mentioned, that can be the cam chain tensioner. It is apparently hydraulic. Low oil pressure, or the wrong oil, can exacerbate it, as can low rpm idle. I run mine around 1200 rpm to avoid it.
  8. old's cool
    LA
    any tips on how to winterize it in a cold underground parking lot?!
    thanks
  9. XJ550H
    cam chain tensioner is spring loaded and adjustable
    cgutz likes this.
  10. old's cool
    LA
    any idea of the how big of a job and the costs of each and every possible scenario you've all mentioned above?!
  11. cgutz
    SE South Dakota
  12. old's cool
    LA
    this is the moment we've all been waiting for! :)
    finally we can listen to the sound/noise that this engine makes hopefully nothing out of the ordinary! :)
    please help yourselves to it https://we.tl/t-iGViywgueO
  13. cgutz
    SE South Dakota
    Link isn't working for me.
  14. old's cool
    LA
  15. k-moe
    The same way as I winterized in an unheated Kansas garage (it could get below freezing inside the garage on a cold night).
    Stabil in a full tank.
    Ride to make sure it gets into the carbs.
    A post-ride oil change.
    Park it on the center stand.
    Let it sit until Spring.
    Occasional rides when the wheather is warm enough won't do any harm, just make sure that the rides are at least 20 minutes long so the engine gets warm enough to drive off moisture from the crankcase. Top the gas tank off before going home.
    Since your garage is underground it will have a very stable temperature in comparison to an above-ground garage. Condensation should be minimal, even though the humidity is higher there (no matter if LA means Los Angeles or Louisiana).
    cgutz likes this.
  16. cgutz
    SE South Dakota
    The only thing I add to K-moes process is to hook it up to a battery tender (I have a lead acid battery - maybe AGM doesn't need this?)
  17. k-moe
    AGM does need that (AGM is a type of lead-acid battery). So does any other battery stored long-term. Thanks for the reminder.
  18. old's cool
    LA
    still NOT working for you?!!
  19. old's cool
    LA
    what if just starting the bike every now and then(4-5 days) if there's NO power outlets around?!
  20. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Starting will drain the battery a bit and if the bike is not run long enough or at higher RPM's it will not have a chance to charge up. Better to take the battery to an outlet.
    Yammaat likes this.
  21. Yammaat
    Yammaat Active Member
    Netherlands
    Starting up incidently will also deteriorate your exhaust due to condenswater buildup.
  22. k-moe
    Solar battery tender, or pull the battery and tend it where the outlets are.
    Just starting an engine in cool weather without intending to ride is causes a lot of condensation buildup in the crankcase and exhaust system. There will also be an increase in oil acidity.
    Yammaat likes this.
  23. Yammaat
    Netherlands
    I've got a 12V solarcharger of 5 W. With panel (20x15 cm) and regulator around 18 dollar.
    Works fine.
    Made some wiringmods, with a fuse, and presto. It's hooked up in no time.
  24. XJ550H
    bring the battery to somplace you can keep it charged,
  25. old's cool
    LA
    1 oz treats up to 2.5 gallon of fuel, says on the fuel stabilizer! this bike has a 3.5 gal. tank plus 1 gal. reserve! I've put almost 3 oz in the tank so far! is it enough? and is there anything as too much stabilizer?!
    and I had it run more than 5 minutes(which was recommended on the bottle)!
  26. Yammaat
    Netherlands
    use premium etoh free gas and you don't need stabilizer.
    There is even a better trick to keep corrosion at bay: use a squirt of paraffin oil in your full gastank, let it run so it gets into the carbs and presto. The paraffin is greasy, won't affect the gas and lubes all moving components.
    Also very usable for cars with their fuelpumps.
