Yamaha xj550 sitting for 10 years
Discussion in 'XJ Technical Chat' started by Wottel, Aug 7, 2015.
  1. Wottel
    Wottel New Member
    Belgium
    hey guys !
    It's like 1 month ago since i posted something. I was realy busy with work...
    I proud to tell u guys that yesterday i started the engine ;) !
    I got a video :
    As u see it was a little hard to get the fuell in the system and not damage the starter.
    Offcourse the engine does not run smooth.
    When its cold with starter it runs amazingly fine.
    When the engine gets warm and the starter is off the engine quits under 3000 RPM.
    Above the 3000 RPM it runs good.
    I'm not an expert on what does this problem means ?
    Oh and btw my electrolysis for my fuell tank does not work at all.... I tried everything but i just dont get an electrical curcuit.
    So now i need to find another solution to clean my fuel tank.
    Any toughts ?
  2. specialk
    specialk Active Member
    Ontario
    I always use electrolysis and it works amazing. Make sure you ground out the negative lead on the battery charger to the tank well, meaning there can't be any paint where you clamp the lead to. Also some battery chargers won't work on the regular "charge" setting, I had to switch my charger to "activate" in order for it to work.
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I gleaned through the last three pages . . .
    Looked like you and your Dad were ready to do the happy dance when she fired up! :D
    Rough running can be a lot of different things . . .
    In regards to your carbs that were cleaned:
    Did you do a bench synch?
    Running synch?
    Colortune?
    Running synch?
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Nice. It doesn't sound bad. By the time you dial it in it should be fine.
    Gary H.
  5. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Nice
    nice find looks great other than the rusty chrome bits. An SOS pad may clean the chrome up,
    I know that windjammer fairing has got to be rare over there , may have some value in that too
  6. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    The first time after cleaning the carbs, it takes many crank revolutions to get fuel in the gas line and the carbs.
    Did you measure and adjust the valve clearances? The perfect time to do this was when you had the gas tank off to take out the carbs.
    You need to vacuum balance the carbs, but, its almost a waste of time until you measure and adjust the valve clearances.
    rocs82650 likes this.
  7. luvmy40
    luvmy40 Member
    Y-Town, OH
    I've had excellent results using white vinegar to clean a rusty gas tank. You may need to do it a couple or three times if the rust is extremely thick. Just fill the tank and seal her up. Let it soak for 8-10 hours flipping it over a couple times during the process. I rinse with gasoline to keep the flash rust to minimum.
    Sounds like it will be a good running bike once you get the valves in spec and do a vacuum sync!
    DreamerXJ550 likes this.
  8. Joshua Olkowski
    Joshua Olkowski Member
    Los Angeles
    I know it's been a while since you posted this thread but I'm just curious how your Seca is doing. I just bought one and I'm particularly interested in the saddlebag rack you have on the back of the bike. Is that an aftermarket item made by Yamaha? I'm also looking for a right side cover panel if you happen to know how to get hold of one. Thanks.
  9. hogfiddles
    Being that the last post is almost 2.5 yrs old.... and there were lost of posts from numerous people in the thread--- who exactly are you directing your comment to?
