Yamaha xj750 running issues,
Discussion in 'XJ Technical Chat' started by Alex miller, Jun 17, 2026.
  1. Alex miller
    Alex miller New Member
    Hershey PA
    Hello, I have a 1982 Yamaha xj750 seca and it backfires occasionally and just cranks, now it doesn’t even backfire. To give some context I bought the bike without it starting cleaned the carbs and a new battery and it would idle super rough and wouldn’t rev up at all, so I cleaned the carbs again a little more thoroughly and checked my diaphragms 3 are good one is bad, I then tried to start it again with some starting fluid and it almost idled on it so I checked my floats fixed them and it idled and revved pretty rough after that, I noticed it was running pretty rich and that only 2 exhaust pipes were warm so I know it’s missing on two cylinders, so I pulled the spark plugs and 2 were wet on the missing cylinders. Now when I jump it just cranks backfires a little or doesn’t backfire at all and the weirdest part is that it won’t even sputter on starting fluid.
  2. Alex miller
    Hershey PA
    My best theory is that I was cranking it to much and the battery got low so the cylinders weren’t firing and the spark plugs got wet and won’t fire now.
  3. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    First, if a diaphragm is bad, how bad? If it has a pinhole, it needs to be patched. If it can't be patched, it needs to be replaced. You can't expect the engine to run well with one or more bad ones. Which cylinders are not firing? It could be a bad coil that is connected to those cylinders. No spark = no firing. More info is needed.
  4. Alex miller
    Hershey PA
    Yeah, I’m not sure how bad the diaphragm is I can’t find any holes I know the ring on top was broken so I did my best to glue it back together, cylinders 2-4 are not firing.
  5. Huntchuks
    East Rochester, NY
    You can stretch the material with a light on the back side to see if any pinholes show up. One coil connects to cylinders 1 and 4 and the other connects to 2 and 3. Could be a bad wire on each coil, maybe.
  6. Alex miller
    Hershey PA
    Yeah, I think for right now I’m gonna let the cylinders and spark plugs air out and cross my fingers for tomorrow morning
  7. Huntchuks
    East Rochester, NY
    You can at least unscrew the caps from wires 2 and 4 and inspect the ends for corrosion. if there is any, clip off about a 1/4 inch and also inspect the screw-like part in the cap that screws into the wire. Clean it if corroded. Reassemble and test.
  8. Alex miller
    Hershey PA
    I will also try that tomorrow morning unfortunately I’ve got to be at work shortly. Thanks for the advice so far!
  9. Alex miller
    Hershey PA
    So, bike ran again but would hardly idle and throttle. After a like 30 seconds it wouldn’t stay running without almost full throttle, also cylinder 1 exhaust was super hot and cylinder 4 was warm 2-3 were ice cold. I checked spark prior to this and it looked like every plug except 3 was firing. Also now it runs with the choke closed and throttle at like 1/2 but if I drop the throttle it dies and if I open the choke the rpm’s drop and it almost dies
