Year id please
Discussion in 'XJ Technical Chat' started by justin_schroyer, Jan 14, 2020.
  1. justin_schroyer
    justin_schroyer New Member
    Markleysburg PA
    I recently got a maxim 650 from my brother but I'm not sure if its a 81 or 82 please help me figure it out so I can start restoring it its my first bike and I'd like to do it right
  2. Toomanybikes
    Tsawwassen bc
    Has to be 82 with yics head
  3. justin_schroyer
    Markleysburg PA
    Thanks that's what I was thinkng
  4. XJ550H
    justin_schroyer likes this.
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    Are you confused because the title says 82 but the VIN sticker shows an 81 date? The sticker shows the date of manufacture which can be earlier than the model year. Yours is most likely and 82/83 because of the YICS cover but people haves swapped motors before. Post up your VIN to be sure.
    You have a common bike with lots of parts availability and knowledge, good luck with your project!
  6. justin_schroyer
    Markleysburg PA
    No the frame and motor vins match but it was manufactured in late 81 and I don't have the title yet i figured it was a 82 but I was just trying to make sure before I started buying parts, thanks everyone for the help
  7. hogfiddles
    It’s an ‘82. YICS valve cover was not on the 80-81
  8. Matthew Ryan
    Matthew Ryan New Member
    North Carolina
    I just acquired what appears to be a n XJ with no title. Other than the fact it's a 4cyl, shaft drive, mfr 5/80...I have no idea of what model it is.
    My search for VIN decoder has been fruitless.
    4H7010134
  9. hogfiddles
    Show us a pic
  10. Matthew Ryan
    North Carolina
    Thanks.
    It appears to be a 1981 XJ650 Maxim.
    Though it was assembled in May 1980, the low serial number indicates its a VERY early 1981.
  11. k-moe
    '81 serial numbers start at 100101
    You have a 1980, just as the build date says.
    hogfiddles likes this.
  12. XJ550H
    TECH TOPIC: Model ID and VIN's
    short vin says
    4H700 = 1980 XJ650 Maxim USA
    your bike would be a short vin only bike being a 1980
    http://www.dissingermoto.com
    Prior to 1981, manufacturers could use a VIN number length of their choice, and Yamaha was no exception in this regard. In fact, because of the difficulty encountered with implementing this required 1981 changeover, Yamaha (and some other manufacturers) were granted a 9-month "stay of execution" for their 1981 model-year offerings, where they could still use their older (shorter) version VIN numbers to identify their products.
    Thus 1980, 1981, and perhaps even some very early production 1982 model-year bikes use a shorter VIN number that appears on the frame of the bike (more about this later), and may also include a printed paper decal that lists a different (longer) VIN number that is the "extended", 17-posiiton version of the original, shorter VIN number.
    all info from
    thread posted above . vin decoder is in that thread
  13. hogfiddles
    Has the Dissingermoto decoder been fixed?
  14. k-moe
    Definately some of the early production 1982 bikes used the short VIN.
    I have one.
  15. XJ550H
    what was wrong with it?
    I know once you entersomething wrong you have to close it before reentering anything.
  16. XJ550H
    4H7010134
    sn starts at 000101 for your year so your bike is 10133 bike off of the line not that early
  17. Matthew Ryan
    North Carolina
    Ah. I think I misread the serial part of the code. In that case rd likely a....1980?
  18. XJ550H
    it is a 1980 as i posted above
  19. k-moe
    It was returning the wrong year and sometimes model for some of the shorty vins.
