YICS Tool for sale or rent
Discussion in 'XJ Technical Chat' started by granitize, Aug 1, 2022.
  1. granitize
    granitize Member
    Canada - East Coast - Prince Edward Island
    Anyone got a YICS tool in there garage they want to sell or lend to me?..
    I'll pay for shipping.
    Len rent 'em...
    but that doesn't work for me because daily + shipping takes too long. :)
    Gonna post on FB too.
    I am in East Coast Canada.
  2. JCH
    JCH Active Member
    seattle wash
    I just used a piece of rubber hose and lubed it up well and shoved it though that port and that sealed it up well enough to set my carbs, there is some opinions on this site that it doesn't make much of a difference when setting the carbs with it or without the tool and I tend to agree.
  3. Mototimothy8
    Mototimothy8 Member
    Lewisburg, PA
    I have made mine out of 3/8" all-thread and measured out the ports with a piece of tie wire. Then took high temp electrical tape and wrapped it till it was snug and could still slide in with easy. Made the rod the exact size so you can put the 2 bolts on the end while you sync the carbs. Worked well for me.
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    You can take cotton rags ripped in stripes soaked in engine oil and pack them in the yics passage. Then install the bolt. You now have a block off tool. To remove, remove both bolts and push them out.
  5. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I have never used a YICS tool synching my carbs. Owned the bike for 39 years.
  6. k-moe
    No need for it at all, unless you have to pass an emissions inspection. No U.S. states require motorcycles to be tested for emissions, and IIRC neither does Canada.
  7. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    My YICS tool makes me happy.
    1/4" threaded rod.
    Wing nut
    Copper pipe
    Washers
    Fuel hose (which craps out every now and then)
    Nyloc on one end
    Silicone spray
  8. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I used silicone tubing. I think easier to compress and more resistant to high heat.
    cds1984 likes this.
