YICS Tool Rental?
Discussion in 'XJ Technical Chat' started by NACHOMAN, Mar 23, 2006.
  1. RickCoMatic
    You need to come down more on the Idle.
    1,500 is slightly Off-Idle drawing a little bit of Main Jet Fuel.
    Keep the Idle at below 1,050 if you can do it.
    You might have to adjust the Throttle Cable Tension Adjustment to get the Throttle Plates to close completely.
    Then, when the Carbs are actually dependent on the Idle Adjustment Rod ... use the Idle Adjustment Rod to sneak down the Idle as you do the Sync.
    Otherwise, the aamixture is going to be too Rich, and you'll get a "Too Rich Hole" coming off Idle that will cause the Bike to hesitate before it "Catches-up with the right amount of Air needed to sustain performance getting out-of-the-hole!
  2. MyXJ750
    MyXJ750 New Member
    Bolingbrook, IL
    After reading through most of this tread I have some questions:
    Will the homemade YICS tool work if adapted to seal the outside of the engine on #1?
    Has anyone actually seen the fuel line rubber of the DIY model melt?
    Rick, have you found the thread where you give the precise measurements of the dealer model YICS tool?
    Thanks for all the helpful info!
    -Rich
  3. RickCoMatic
    No. I haven't got the thread figured out.
    I lost all the stuff I wrote when my Dell Died and I switched-over to this new Mac.
    Having a YICS Tool with the proper spacing eliminates the need for an end plug to stop air from getting in while tuning.
    The Factory spacing closes-off the individual Ports and seals any place that air could get in to the passage while the tool is expanded.
  4. Captainkirk
    Captainkirk Member
    Northeast Illinois
  5. RickCoMatic
    I looked for the thread and couldn't find it.
    When I can, I'll measure my home-made tool; because I used the Factory measurements making it.
    I'll Post those measurements on here tonight.
  6. Injuhneer
    Injuhneer Member
    SE Arizona
    Yes, there are many who have used fuel line and found a gooey mess after it melted. The mess can be cleaned. The real issue is the melted rubber getting to the YICS ports and blocking them.
    The exact dimensions:
    The three compressible seals are 10mm BEFORE compressing.
    The large seal is 13mm wide.
    The long sections are the same and are 122mm in length.
    The smallest section is 21mm.
    The latch end section is 40mm.
    Diameter cannot exceed 9.5mm. Otherwise the tool will bind (the passage is 10mm) and you will have no fun extracting it.
  7. sim37
    sim37 Member
    St. George, UT
    would 1/4" all thread work
  8. paulg
    paulg New Member
    British COlumbia
    Has anyone found silicon tubing in Canada?
    ---p
  9. ahs437
    ahs437 New Member
    Hello...
    I've bought and built the tool and have negative experiences with both. Basically, the area gets too hot for the rubber and you can spend a lot of time degunking the passage with a bent piece of wire, trying to remove the tool and recovering bits of rubber. I've used silicone high temp tubing also. It get TOO hot. It's tough to get a good seal.
    I don't even screw with the blanking off the passage. My approach is to balance the carbs with mercury carb-stick (home made) and then use color-tune to adjust each cylinder. Re-balance with carb-stick, temp probe the exhaust and then read the plugs.
  10. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Would anyone have the part number for the original yamaha YICS tool? I'd like to see if I can find one out there somewhere. Thanks.
  11. bigfitz52
    umm...you do know that chacal sells an aftermarket version of the tool for not a lot of money, right? And that it works?
  12. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Didn't know that, but I was going to PM him about it. Thanks Fitz
  13. BikeRanger
    BikeRanger Member
    Dundas, Ontario
    ok stupid question but what is this tool used for?
  14. bill
    bill Active Member
    Raleigh, NC
    If you have a YICS engine it blocks the ports so you can sync the carbs. The YICS (in simplest terms) is a passage that allows the carbs to share vacuum.
  15. BikeRanger
    BikeRanger Member
    Dundas, Ontario
    ok very interesting because i have a yics engine. i think i might try to fabricate one of these tools then, i have a guy with a lathe also il have to takea closer look at the the diagram to see if he can build me one. :)
  16. dpawl31
    dpawl31 Member
    NH, USA
    Is it me or did everyone in here miss Rick saying to stuff it with mystery-oil-soaked t-shirt and plug it up?
    Sounds good to me!
    I trust Rick so much, I think I'd trust him to do heart surgery on me.
    Well, maybe not HEART surgery. lol
  17. bill
    bill Active Member
    Raleigh, NC
    Wait until you actually do the stuffing. It is a royal pain. The tool is easier. I tried it and it does indeed work.
  18. TIMEtoRIDE
    And to un-stuff the wadded up tee shirts, I tried picking them out with a litle hook I made, and ended up driving them thru with 2 Chevy push rods
    and a hammer. If you stuff it, tie knots in it.
    I'd like to thank Polock for giving me his YICS tool.
  19. joshua
    joshua Member
    Lake Worth
    ok,stupid question coming on. been reading all bout these carbs and the issues so i could better understand it all but this yics thing is a gray area in my brain at its not brain matter.LOL, anyway where does this tool fit to block the yics ports? that is the only thing i havent figured out yet?
  20. bigfitz52
    On either side of the head, at the rear, just above the joint with the cylinders is a flare-nut bolt head with a copper gasket under it. These are the plugs at the ends of the YICS passage. You remove one or the other to insert the tool; both to clean out the passage.
    In this picture, it's visible at the VERY BOTTOM of the pic, just behind and below the fins on the head:
  21. joshua
    joshua Member
    Lake Worth
    ok now i got it thanks!!!!!!!!
  22. bvpoot
    bvpoot New Member
    Rocky Mountains
    Hi all. Anyone seen this YICS tool on ebay? Any thoughts?
    ebay
    The o-rings are Viton and withstand almost 400 degrees. I wondered if it was worth a look or not?
    Hope you all have a great weekend!
    Poot
  23. TIMEtoRIDE
    Just a logical thought, no experience. . .
    Since the "O" ring only seals while compressed, you are shoving this precision tool in, and the "O" rings are scraping against the sharp edge of the smaller transfer ports, with the possibility of cutting these "O" rings.
    The tools we use/build expand the rubber seals once in place.
    If it doesn't ruin the "O" rings, then it sounds fine.
  24. tcoop
    tcoop Active Member
    South Weber, Utah
    I got one of those it works ok but as TIMEtoRIDE the "O" Rings do get cut and dont always seal. I thinsk thte tool from Chacal is a better buy.
  25. yamchop
    yamchop Member
    Caldwell, Idaho
    Hey guys, I tried Rick's t-shirt method and it worked like a charm. If you have trouble getting it out when you're finished thread a wood screw into the wadding and pull it out. Presto! Unplugged. Just be sure you're threading it into the wadding and not your engine.
  26. shnuffy
    shnuffy Member
    Guelph, Ontario
    Got any more info? How many t-shirts did it take? Did you have to cut it up? What kind of oil did you use? Was it hard to get in? Why am I asking so many questions?
  27. yamchop
    yamchop Member
    Caldwell, Idaho
    I just cut two 1 1/2" x 3' strips, soaked them in motor oil, and packed them in the passage a little at a time with a piece of threaded rod I had laying around. Anything long enough would work. I agree that getting a tool would be easier but if you're not going to use it all the time why not use this method that doesn't cost anything?
  28. TIMEtoRIDE
    I'm renting strips of oily "T" shirts, but I need a big deposit :lol:
  29. shnuffy
    shnuffy Member
    Guelph, Ontario
    TIMEtoRIDE, how much do you want? Do you ship to Canada?
  30. XJ511
    XJ511 Member
    Is this the correct reverse engineer of the YICS tool?
    Sorry to hijak so to speak. Didn't really see the point
    in starting a whole 'nother.
  31. TIMEtoRIDE
    Supposedly, the tool with the "O" rings has very little durability, but I guess would work, since they are doubled up in the pic. If they broke, they would still isolate pretty well.
  32. XJ511
    XJ511 Member
    Thanks bro! 8)
    Curious what the "actual" YICS tool is/was. Read thru
    a couple threads where it's talked about leavin' the tool
    in permanently. 8O Guess I just haven't clicked on the
    theory..?
  33. OldSchoolOtter
    OldSchoolOtter Member
    Towson, Maryland
    That's the one I have. I've only syncd twice but it worked fine both times. I'm sure at some point the rubber washers might need to be replaced, but who knows how long that'll be.
  34. bigfitz52
    NO, it's not. That's the "leave it in place" type "YICS eliminator" tool; the correct style factory copy has a release lever at one end and a nice big fat SEAL right by the lever where it meets the outside of the passage.
  35. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I've got Chacal's tool, so if anyone in the Kitchener, Stratford, Woodstock area wants to borrow it, they're more than welcome, just come pick it up.
  36. husky
    husky Member
    england
    xj511 i bought one of them, i dont know y they use rubber o rings? is it for vibration, my mate has just made me 2 up, and they work great,as my 550, wont start on the button,without it, and carbs are set up right, but i do have open filters,
  37. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I have both. I didn't care for the eliminator. I think the o-rings are spaced to prevent the fuel in the port from mixing whereas the washers on the yics tool expand to block off the four holes in the top and seal the open end of the port. I could be wrong. Hope this helps.
    Gary H.
  38. hogfiddles
    psssst.....hey-----shhhh, don't tell anybody.....you don't really need to use the YICS tool.
    jayrodoh and Joris like this.
  39. Joris
    Joris Member
    Eindhoven, NL
    Is some-one on this list living near Eindhoven (The Netherlands, Europe) and willing to rent or let me borrow the tools needed to tune my XJ 550?
    I am looking for a YICS tool, a vaccuum measurement tool and a colotune plug for 12 mm plugs.
    The rental arrangement from Chacal does not work for me because of the shipping time and cost.
    Thanks,
    Joris
  40. XJ550H
    I read an articel where you can bench sync the carbs using wire or tiny drillbits to measure and match the throttle plate opening.
    at least i have a use for my used socks now
  41. jayrodoh
    jayrodoh YimYam
    Cleveland
    That's called a "bench sync" and used to get them roughly adjusted before you mount the carbs. Since the vacuum will most likely differ from cylinder to cylinder, you need to do the final adjustments on the bike running.
  42. andrew15
    andrew15 Member
    Montreal, Canada
    Seriously? I was about to post a thread asking this.
    I'm going to be checking my valve clearances and cleaning/syncing my carbs for the first time
    soon and was wondering if i had to use that tool even after balancing them with the homemade bottle sync
    machine if you will.
    It's a 1982 xj650 seca I have with the YICS pasted all over it!
  43. chacal
    Ummm......if the YICS passages (not the large chamber that the tool fits into, but the tiny passages that run off the chamber and to each intake tract) are completely blocked by carbon build-up, then that's probably true. And then it's also probably true that you should un-block them......
    It is physically impossible to correctly synch a YICS-equipped engine, with un-clogged ports, w/o the YICS tool in place (or, at least, SOME way of blocking off the YICS chamber), so that the cylinders do not communicate (and share vacuum signals) with each other during the synch process)!
    rocs82650 likes this.
  44. hogfiddles
    I have one of the tools, bit have never needed to use it, and the passages are very clean. I like to look at the tool. its pretty.
    kwes likes this.
  45. rocs82650
    Middle Tennessee
    A lot of mechanics don't vac synch following the bench synch (i do). Imo the best way to bench synch is to use the holes in the top of each carb. A good bench synch should put the vac on each carb within 1" or less of each other which is within spec and will allow the bike to start and run less the ec (aka choke). Using a yics tool and vac gauge(s) will put them spot on.
    Gary H.
  46. chacal
    It really is, a work of art even....... :)
  47. hogfiddles
    We're not talking about the running sync gauges. We're talking about the YICS tool that would be inserted into the YICS port to block the carbs from each other while you do your running sync. I do use gauges, I LOVE the Morgan Carbtune. It takes only a couple minutes or so to dial them right in.
    At our carb clinics, he look on the faces of people... after they take their bike for a spin....is priceless when they pull back in.
    Dave
  48. chacal
    Yes, until you get:
    a) your valves adjusted
    b) your carbs cleaned
    c) your mixture screws adjusted (Colortune Plug)
    d) your engine synched (Carbtune synch gauge)
    you'll have no idea just how powerful and balanced and reliable these engines are.
    Of course, doing all the above means you'll have to spend the time and $$ to make up for the last 30+ years of previous owners NOT doing such regular maintenance/service, but, if you really want to dance, ya got to pay the fiddler........
  49. hogfiddles
    And THAT is a lot of why there re carb clinics.
    You're absolutely right ..... When these bikes are back in shape, they really have p l e n t y of power!!
    Dave
