yx600 radian fuel tank is moaning
Discussion in 'XJ Technical Chat' started by Jake750, Sep 29, 2020.
  1. Jake750
    Jake750 Member
    Detroit
    86 yx600. My fuel tank appears to be "moaning" after it runs. The noise seems to be coming from the coming from the fuel cap. Air is escaping through the cap assembly.
    Can anyone provide some guidance on how to remedy this?
    Thanks in advance
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Scroll down the link to the HRC fuel cap mod. I've done this on my XJR1200.
    http://www.fj1200.info/Home.htm
    It's in the Carb tuning section for some reason.
  3. Jake750
    Jake750 Member
    Detroit
    I'm not at home right now so I can not confirm, but the tank cap assembly from your website looks different from the cap assembly on my radian 600. Are you sure this will work on a Radian 600?
  4. FJ111200
  5. Jake750
    Jake750 Member
    Detroit
    On second thought, they seem to be compatible.
  6. Simmy
    Why are you concerned with this?
    Isn't it doing what it's supposed to do?
    k-moe and Franz like this.
  7. Jake750
    Jake750 Member
    Detroit
    ... I did not consider that it may be working as intended. I assumed that the gas tank cap assembly was supposed to create a seal. Is this not the case?
  8. Franz
    I had an old MZ in the 1970's to get to work on and it kept stuttering to a stop. The hole on the fuel tank cap was blocked creating a partial vaccum above the fuel in the tank and starving the engine of fuel. It had a clear plastic fuel line. When I slackened the cap the line filled with fuel. Air needs to get into the tank so you have nothing to worry about.
  9. Jake750
    Jake750 Member
    Detroit
    What do you mean by slackened the cap?
  10. Franz
    I had to turn the cap to remove it.
  11. Jake750
    Jake750 Member
    Detroit
    I have no common sense today
  12. Jake750
    Jake750 Member
    Detroit
    Thanks for all the help so far, guys. Just so I am clear on this, the fuel cap is in fact supposed to breathe a little bit?
  13. XJ550H
    it should have a vent if vent is clogged it may be forcing air out the seal
    air in and out
    out as fuel expands in heat, air in as fuel is drawn into motor
  14. Jake750
    Jake750 Member
    Detroit
    Okay now I am starting to catch on. So the squealing may be caused by the vent, that FJ111200 reference near the top of this thread, being partially clogged?
  15. bigfitz52
    YES. Most likely the fuel cap vent is partly plugged; the fuel tank has to "breathe" or it would vapor lock and stop allowing fuel to flow. Although yours is markedly different than the ones on most XJs the principle is the same. If it can be at least partially disassembled and cleaned, start there. I wish I could provide more specific answers but I've never dealt with that style before.
    Jake750 and k-moe like this.
  16. Franz
    On some machines the vents can be offset to help prevent the ingress of water.
  17. Jake750
    Jake750 Member
    Detroit
    This is a dead thread, but I just figured out my problem. The previous owner removed the plastic or rubber fitting thing that fits into the bottom of the cap. It doesnt seal too well without it.
    Dave in Ireland likes this.
