1982 Yamaha 750 Maxim Drive Shaft Installation
Discussion in 'XJ DIY How-To Videos' started by Tim White, May 25, 2018.
  1. Tim White
    Tim White New Member
    Round Rock
    When I replaced the rear tire on my xj, the drive shaft came out with the hub, and now I have the damndest time getting it back into the u-joint, does anyone have any tips or tricks on how to reinstall the drive shaft?
  3. Polock
    you did it the hard way, but anyhow. the splines should have a spring in a groove, that has to pop into the u joint. hold it in then hit it with the heel of your hand.
    grease it up real good first
    Yep. Lube it, and then stick it in the hole.
