700x efi conversion
Discussion in 'XJ Technical Chat' started by Troy Mccall, May 9, 2020.
  1. Troy Mccall
    Troy Mccall New Member
    florida
    So im going to be doing a complete rebuild on s 700x and i was wandering if converting to efi could be done ive seen people do it with the air cooled motors but never the x models if someone could point me in the right direction i would appreciate it
    You have come to the right place as we have a member who has done the conversion to EFI, and it looks like it is defenitaly one of his skill sets.
    @SQLGuy
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    You can't just buy a bike kit - but there are car kits that might do it. It needs to be compact, and most car kits have added so many features over the years they've got big. SQL guy is an electronics expert - are you?
  4. Troy Mccall
    florida
    Ive seen the air cooled modlles using gsxr throttle bodies and a micro squirt ecu would that also work got the water cooled x model ill be doing a complete engine rebuild to go along with major changes to the entire bike
  5. Troy Mccall
    florida
    Have any in mind ?
  6. XJ550H
    I do not think that it would matter if bike is water or air cooled start a conversation with SQLGuy and ask him about efi he should be able to point you in the correct direction.
  7. Minimutly
    West Wales, uk
    No, not fully up to date with the latest stuff. Water cooled is better - temperature, or coolant temp compensation is an essential correction - @SQLGuy would have embedded a sensor in the head somewhere I guess?
  8. XJ550H
  9. XJ550H
  10. XJ550H
  11. jayrodoh
    jayrodoh YimYam
    Cleveland
    Even when fuel injected and turboed that XJ idle is unmistakeable.
  12. SQLGuy
    SQLGuy Well-Known Member
    Water cooled is a bit easier, since there's a lot more choice of temperature sensors for coolant. I used a Porsche 914 block temp sensor for my setup.
    I'm not actually sure what your best choice is for a current ECU. I used a Microsquirt v1 - one of the very first ones to be made. Microsquirt is a weather-sealed case with an ECU that can do two channels of ignition and two channels of injection. It has a lot of options for different sensor inputs, and can run with a wide variety of engine setups.
    However, when they came to v2 of Microsquirt, they removed the ignition drivers. I'm not sure exactly why. So, in my setup, I have the Microsquirt mounted where the TCI used to be, and it runs fuel injection and ignition with coils from a Saturn (SC, I think), but, in a Microsquirt v2 install, you would need either external ignition drivers, or coils with built-in ignition drivers. It is possible to do sequential ignition with Microsquirt by repurposing a couple of the LED outputs to drive coils, so, running four logic-level coils would be an option. MS3 allows for fully sequential without customization, but it's a bigger ECU. The Microsquirt module is easier to modify for fully sequential, but I'm not sure what it has for a case or how the connector arrangement will work for an installation like mine... you may be able to build a more customizeable Microsquirt using a module and a Microsquirt case and connector.
    Typically, what people do for MC conversions, is to get throttle body / injector sets used from eBay, from a Hayabusa or some other four cylinder transverse FI bike. Car kits are not a good idea, as the injectors will be often be too big, the ECU will usually be too big, and they won't do anything about induction.
    My whole setup looks like this:
    Microsquirt 1.0 modified internally to add Bluetooth and two additional injector channels (also uses a replacement NCV1124 VR conditioner)
    36-1 crank wheel using one of the stock VR sensors (pickups) for crank position and primary timing
    Extra "tooth" welded to intake cam end and a BMW cam position sensor for additional timing of intake/exhaust stroke
    Saab/Bosch fuel pump installed in the tank; petcock replaced with fuel return tap; fuel supply tap added to other side of the tank
    Additional relays for ECU power and fuel pump
    Custom intake manifold
    Ford Escort throttle body with attached idle air valve - welded tab on the frame to allow a custom length throttle cable to connect to it
    Custom fuel rail, with Hyundai 40PSI fuel pressure regulator
    Ford injectors (not sure the original application) - Bosch style with four holes and rated at about 14lb/hr
    One MAP sensor for manifold pressure, and a second one for ambient baro
    GM inlet air temp sensor in the air box - air box cut down and modified with a cover plate and an flexible air hose into the throttle body
    Porsche 914 block temp sensor screwed into the back of the block
    LC-1 wideband O2 sensor
    Golan Products fuel filter
    Saturn two-tower Hitachi coils with driver wires soldered to their drive tabs, and custom 7mm spark plug wires and NipponDenso caps
    This allows me to run fully sequential fuel injection with wasted spark ignition and speed density fueling. Warm up is controlled based on block temp. Idle is controlled via PWM of the Ford IAV. This allows a slightly higher idle when the engine is really cold, and good return to idle under all conditions. The second MAP sensor allows adjusting fueling as elevation changes during a ride. The wideband allows auto tuning of the VE table and some amount of quick correction where the VE table isn't correct for conditions - a newer wideband, like an LC-2, would be better for this.
    In addition, I converted most everything to LEDs, to have more current available to run the fuel pump, ECU, IAV, EGO, and injectors.
    Previously I had been running batch injection, and then semi-sequential. I found that fully sequential made the idle smoother and the engine more responsive to tuning changes.\
    I had problems keeping crank position synch above 5000 RPM. B&G (the Mega and Microsquirt people) had issues with their initial Microsquirt VR circuit. I think these are largely fixed in later versions, but switching to an NCV1124 fixed mine well.
    A welder, an angle grinder, a mini-lathe, a drill press, a timing light, and some thread tapping tools are all pretty helpful here, as are a meter, maybe an oscilloscope, soldering equipment and skills.
    RideAlong420 and Dave in Ireland like this.
  13. Troy Mccall
    florida
    S
    So the micro squirt ecu dose not run 4 ignition plugs?
  14. SQLGuy
    It can, if you repurpose the LED outputs, and use coils with their own drives/igniters.
    But, with wasted spark, you only need two ignition coils.
  15. Minimutly
    West Wales, uk
    @SQLGuy - have you not thought about going individual throttle bodies?
  16. SQLGuy
    Thought about it a bit, yeah, but didn't like the lack of closed loop idle control or some other trade-offs I would have to make. I'm quite happy with the result I have now, so, no need to replace it.
  17. Troy Mccall
    florida
    @SQLGuy so ive never converted anything to efi just dealt with things that already have it so whats waisted spark?
  18. SQLGuy
    You already have wasted spark. That's how ignition works without a distributor or cam sensor. The 1 and 4 spark plugs fire in series from the secondary of one coil, and the 2 and 3 from the secondary of the other coil. Timing is based on crank position, so each cylinder gets spark near the top of compression and near the top of exhaust. Each coil fires once per crank rev.
    Franz likes this.
  19. Troy Mccall
    florida
    So if i connected the ecu to the existing coils it would work ?
  20. SQLGuy
    Yes, you could drive the existing coils with Microsquirt. I went with the Saturn coils because I wanted something with a bit more energy, and, since I can set the dwell as needed, I had more flexibility on replacements than I would with the TCI.
  21. Troy Mccall
    florida
    I
    dont have the experience to go tampering with other coils so ig the stock ones will do ....that said could i use the throttle bodies from a gsxr600 ive seen talk about it before
  22. Troy Mccall
    florida
    @SQLGuy by the way are there any other ecu options by any chance
  23. SQLGuy
    Maybe you could use the GSXR ECU?
    Ecotrons makes small engine FI stuff, but only one or two cylinder. Not sure if the ECU they use for the EX250 could be adapted for four cylinder use. Their software is horrible, though, so I wouldn't really recommend it.
  24. Troy Mccall
    florida
    Ill look into the gsxr ecu then wander if theres an difference in firing order
  25. SQLGuy
    Why would firing order matter? You just wire it so it fires correctly. If Suzuki isn't doing sequential injection, then it problem doesn't matter anyway... pretty sure every transverse four is going to have 1/4 up at the same time that 2/3 are down.
    The bigger concern is more likely how Suzuki's sensors - especially their crank position sensor - can be mounted to your engine.
    There's also the question of whether they're using Kettering coils or CDI...
  26. Troy Mccall
    florida
  27. SQLGuy
    No. You would also need to figure out all the other sensors, and the air box, and the fuel pump, and whatever Suzuki uses for a "choke", and maybe an O2 sensor, and then there's the question of how well the GSXR tune will work on an XJ700X, and whether it can be modified.
  28. Troy Mccall
    florida
    Other then the cps the o2 collant temp and mas air flow what else would i need
  29. SQLGuy
    The fuel pump is probably going to be the most complicated piece to fit.
    I doubt Suzuki is using a MAF. They are probably running speed density or Alpha N. If it were a MAF it would be easier, since that would likely self-tune to a large extent.
    There's also IAT (inlet air temperature).
  30. SQLGuy
    After reading around a bit, it looks like the GSXR 600 uses sequential fuel injection, so you would also need a cam position sensor.
  31. Troy Mccall
    florida
    Oof so that takes the gsxr ecu out because i have no idea how i would make that work i wander if any other bike has similarly sized throttle bodies
  32. SQLGuy
    I'm not sure I understand your conclusion. You were confident you could attach the crank position sensor setup of a GXSR to your XJ, but not the cam position sensor? And why does that mean you couldn't use GSXR throttle bodies? They don't have to be used with GXSR ECU. They don't even have to be fired sequentially. If they're batch fired, though, idle will probably be richer and rougher.
  33. Troy Mccall
    florida
    Oh ...well i guess its still worth a shot ill look into other parts for this Frankenstein bike im building then but the reason i said something about the throttle bodies is because i want to see if any other bikes have cheaper throttle bodies
  34. SQLGuy
