Bench sync difficulty carb 2 and 3
Discussion in 'XJ DIY How-To Videos' started by bobcat5540, Feb 28, 2025.
  1. bobcat5540
    bobcat5540 Member
    Mount Sidney,Virginia
    82 XJ 750 J
    I replaced O rings on fuel line pipes between carbs. And I’ve had carbs off before a few years ago , but after bench Syncing this time it appears that carb #3 butterfly stays closed. Carbs 1/2/4 are set up with a seamstress straight pin.
    Could the bottoms pins in the sync adjusters be different between the 3 ? The springs are put back they way I disassembled. Thanks in advance
  2. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Are you saying #3 doesn't move when you move the rest? Something doesn't sound right, but weird that #4 would still move if #3 was not.
    Here's a photo of the linkages on my spare set for my '83. I don't believe they have been touched since I swapped them out of the running bike, so they should be set correctly.
  3. bobcat5540
    bobcat5540 Member
    thanks for the photo co. Dirtbiker
    it appears to be the same. would you be able to take an image from an upper view point? Specifically the spring perch on all 4
  4. co.dirtbiker
    Colorado, USA
    Any of these help?
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    Is the idle adjustment knob backed out too far? One of the center carbs (I can’t recall which one) needs to be adjusted with the idle adjustment first.
    if you search there are some really good threads on the sync process.
  6. bobcat5540
    bobcat5540 Member
    Yes thanks , I fiddled some more on them today. I Was able to get them a lot closer than before . But I had to idle adjustment knob damn near all the way in. That can’t be right.
  7. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    3 is where you start syncing. 2 is synced to 3, 1 is synced to 2, 4 is synced to 3. If you have idle screw in alot, how far is throttle plate open?
  8. chacal
    hogfiddles likes this.
  9. bobcat5540
    bobcat5540 Member
    I completed the bench sync Then on bike with gauges ad YCIS blank off tool. (reference Chacal). I won’t mention my Freudian Slip. Lol. All is good now.
    thank to all who helped!
  10. hogfiddles
    This is how I do it, too, with one SLIGHT difference……..I like to do 3/4 first, then 1/2….then of course the 1/2 - 3/4 combo
