Carb jetting
Discussion in 'XJ DIY How-To Videos' started by MiiYeti, Mar 28, 2024.
  1. MiiYeti
    MiiYeti New Member
    USA
    So I got a 82’ xj650 last year and worked through electrical issues (aftermarket fuses and chaffed wiring) finally got it started last week and it was running on cylinders 2-4 each at various temperatures at the exhaust. So I figured I’d take the carbs off and clean/rebuild them seeing as it has 35k miles on it and the last owner parked it in 2016 due to the tank rusting through. Upon taking the carbs apart I noticed the air jets in the top half were all different sizes. Does anyone know where I can get the air jets? I’m looking for the factory 50 and 205 jets for a hitachi HSC32 carb. Any direction would be appreciated. I have 2 of each currently but if available I’d like to redo everything. Pics in order 1-4 of the current air jets
  2. Melnic
    Melnic Active Member
    xj4ever for the parts. plus note the pilot/main air jets are swapped in some of them.
    Middle is the main air jet and should be 50
    End is the Air jet and should be 205 but 195 in the older bikes I think are not worth replacing IMO.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Time to pull all the jets to check whats where by the looks of it...
