Homemade yics tube tool
Discussion in 'Hangout Lounge' started by DennisMaxim, Nov 11, 2019.
  1. DennisMaxim
    DennisMaxim New Member
    Gainesville FL
    I've been reading some of the information you guys put out and I need to sync my carbs some of you guys are talking about a homemade yics tool how do I make one so I can synchronize my carbs
  2. Dave in Ireland
    Ireland
    Get a long, thin piece of rag, and a piece of wire.
    Tie the rag to the wire and feed it through the YICS tunnel.
    Get a long, thin screwdriver and poke the rag into the tunnel from both sides, until you can poke no more.
    Replace the caps.
    Set carbs.
    Don't forget to remove the rag.
    It works.
    Later, I bought a YICS tool, and it works, too.
  3. Wayne Stuart-Cole
    Wayne Stuart-Cole Member
    liverpool
    I got lucky, there was one in the box of spares that came with the bike
  4. XJ550H
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If you use the rag technique soak the rag in oil to keep the rag from burning. I have tuned my bike with and without the blocking tool with good results.
    Maxmid83 likes this.
  6. XJ550H
    the Idea of breaking free 2 bolts that may not have been removed in countless years scares me. crack the head or not use the tool?
    there are a few photos in this site of broken head from trying to remove that bolt.
  7. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I don't use a YICS tool when I synch my carbs. I suppose if I wanted to squeeze every last drop of performance out of my bike, I might use it.
