is it possible to get the air box back in without taking the motor out ?
Discussion in 'XJ DIY How-To Videos' started by k-moe, Apr 28, 2019.
  1. k-moe
    [Note: This is a response to a thread. The subject comes up often enough that I think the answer needs to be easier to find. The video is not mine]
    Yes.
    There's about a gazillion threads about that.
    Here's one with a video.
    http://xjbikes.com/forums/threads/82-xj750-air-box-installation.56434/
    Note: Carbs off, starter out, battery box out.
    He also has the intake boots off. I would recommend against removing yours unless you plan on replacing them anyway. If you do remove give a good soak with penetrating oil and plan on having a few screws snap off. I think you can manage to get the airbox in without removing the boots if you remove the R/R and TCI mounting panel to give you more room to manouver the air box.
    Chitwood likes this.
