Mazzmo Engineering - XJ650 Project
Discussion in 'XJ DIY How-To Videos' started by DaygloDavid, Oct 10, 2020.
  1. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Whilst searching for XJ650 exhausts, came across a series of videos where Mazzmo Engineering do a project on an XJ650 including an 820cc "Big-Bore" engine.
    Here is the first of the series of videos,
    If you've got the time, IMO, they are all well worth viewing.
    big bore = big vibraton.
    Better to swap in an XJ 900 engine IMO.
  3. JBurch
    JBurch Active Member
    Owego, NY
    You could always have it balanced
  4. dkavanagh
    Rochester, NY
    I found those a while ago and now he stops by here from time to time. He does some really nice work!
    StarGeneral likes this.
  5. k-moe
    Which would require welding blobs to the crank weights, and a a number of reiterations. Fiddly, and expesive if done by a shop. Still fiddly if done in-house.
  6. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Putting bigger pistons in a 4 inline does not require a rebalance, provided the pistons and rods all weigh the same. Will likely make less power than a 900 though, and given the 900 is the same physical size....
  7. k-moe
    That's the key. And in this case they don't weigh the same. Everyone who I've contacted that used any of the big-bore kits for the XJ series had increased vibration afterwards.
  8. Minimutly
    West Wales, uk
    Sorry, I meant all the replacement rods and pistons weigh the same. Balancing the crank wont change anything. Adding weight to it to compensate for heavier pistons - why would you?
  9. Mezzmo
    Mezzmo Active Member
    Hi Guys,
    There is no vibration issue with my engine. I have used a stock 750 crank, rods and barrels with a set of pistons. Check the video below on how I balance rods and pistons. Its really no different for any set of pistons. Generally there are pretty close anyway...
    Kweb1889 and Franz like this.
  10. k-moe
    I would not assume so given the reports I've read about the aftermarket big-bore kits thus far. Yamaha pistons and custom-made (not from a kit provider) pistons are another matter.
  11. Kweb1889
    Kweb1889 Member
    Traverse city mi
    I loved your videos they were full of useful info and I also bought a sand blaster and soda blasted my stuff to clean it and it worked great.
    Mezzmo likes this.
