Rear brake drums (plus a little on wheel bearings)
Discussion in 'XJ DIY How-To Videos' started by turpentyne, Jul 3, 2018.
  1. turpentyne
    turpentyne Active Member
    Desert SW
    I had the day off today, but it was just too damned hot out there to do much on the bike. Soooo... I stayed inside and cobbled together some video shots from last year, redoing the rear brakes.
    Pretty basic stuff, but what the heck! I'm no teacher or motorcycle genius... and definitely not a broadcaster, so here's hoping it isn't horrendously bad!
    The video...
    Jetfixer likes this.
  2. turpentyne
    Desert SW
    Something dawned on me, after posting this video. For any newbies that come along, I should add that, once everything is back together - Don't just set the rear brake pedal. Spin the back tire in neutral and make sure the brake pads aren't dragging on the drum when not being pressed down.
    k-moe and Aisaakh99 like this.
  3. Aisaakh99
    Aisaakh99 Member
    Valley, AL
    Very helpful video. Is there any way you could make a video one day of replacing or rebuilding your front calipers and brake lines?
  4. turpentyne
    Desert SW
    It was in the middle of a nasty hot summer, when I did those brakes. I think I got bored of fussing with the camera, so I'm not sure yet if I got enough clips to make anything useful for the front brakes.
    In the meantime, I found enough from redoing the master cylinder to maybe be worth a little help, here:
    Aisaakh99 likes this.
  5. Aisaakh99
    Aisaakh99 Member
    Valley, AL
    Great! Thanks for the helpful video. I’m trying to rebuild an XJ750R Seca almost from scratch and have been trying to find as much helpful things as I can. The toughest part has been finding videos about the brake lines and calipers.
  6. turpentyne
    Desert SW
    Ah... there wouldve been some differences. My bike doesn’t have the anti dive
  7. Aisaakh99
    Aisaakh99 Member
    Valley, AL
    Yeah. Yours is a maxim correct? But rebuilding ( or replacing) the caliper and pads process would be similar, right? Or no? I just haven’t been able to find any videos or how to’s for replacing a 750R brake lines.
  8. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Sorry to dig up an older thread but this is an awesome how to on the rear drum brakes.
    Can I ask what both of those pins are called that you remove and replace on the rear wheel?
    I've cant quite catch what you're calling them in the video
  9. turpentyne
    Desert SW
    are you talking about the cotter pin?
  10. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    That's the one, thank you... I couldn't quite catch what you were saying
  11. XJ550H
    if you put your bearings in the freezer they go in easier.
  12. kerriskandiesinc
    NY
    I call 'em cotter pins too.....or split pins, increasingly difficult to find ( bike....pedal bike shops used to carry them...last time I asked, they had NO idea, because modern pushbikes dont use 'em!!)
  13. XJ550H
    I get them at my local hardware stores
  14. Timbox
    HF selling them by the box of multi sizes for cheep too.
  15. kerriskandiesinc
    NY
  16. Timbox
    Harbor Freight...if you have one in the area
    kerriskandiesinc likes this.
  17. Polock
    i call them small finish nails :)
