Tach Gear Housing Oil Seal replacement w/pics
Discussion in 'XJ DIY How-To Instructions' started by bigfitz52, Jul 12, 2009.
  1. bigfitz52
    AS REQUESTED:
    Here's a common problem on XJs with mechanical tachometers:
    We need to get it apart and replace seal #4 as well as the (#2) o-ring:
    First, disconnect the tachometer cable and push it out of the way, or remove it altogether if you plan to do anything to it.
    Remove the one retaining bolt and the little yoke, and pull the unit out of the front of the motor.
    I had the best results grabbing it with a big pair of pliers lined with cardboard and twist/wiggling it out.
    Unscrew the "adapter" (#5 in the diagram) from the housing body. It may require Kroil, or heat from a propane torch, or both, or nothing at all. I just did TWO; one needed Kroil AND heat, one unscrewed by hand.
    The old seal; With the adapter out, we can now get to the old seal. you'll need to dig it out. Don't tear up the housing in the process.
    Note: It's a "real" oil seal, with a metal "frame" just like bigger ones; I use a spring hook myself.
    Success!
    Discard the o-ring and the old seal.
    Now is a good time to clean everything. Use a small chunk of Scotchbrite if necessary to get the inside of the housing where the seal goes CLEAN.
    *tip* drop the retaining yoke and its screw into white vinegar to soak for a while, it will come out looking new.
    NOTE the new seal: It has two different sides, the "lips" go down, or toward the motor.
    Install the new seal Apply a light smear of silicone grease to the outside of the seal, ensure it is positioned correctly ("lips" down or toward the motor) and press into place. I used a 9mm deepwell socket.
    The new seal in place:
    Fit a new o-ring IMPORTANT NOTE ABOUT THIS PART: Beware of shoddy aftermarket parts. The o-ring is NOT a "conventional" o-ring, but is in fact, "D-shaped" in cross section, the portion that fits against the housing body is flat. Our buddy chacal carries the correct o-ring as does Yamaha themselves; others may offer a conventional o-ring. That is incorrect for this application.
    A smear of silicone grease helps...
    REASSEMBLE. Be sure to thouroughly lube the gear shaft with clean motor oil, and be sure the housing is well lubed, put a few drops down the bore before you plug in the gear.
    Reinstall on the bike. Smear the housing with oil and plug it into place; the square "locating block" should be in the 8:eek:'clock position; reinstall the yoke. Torque the retaining screw to 7.2ft/lbs.
    ALL BETTER!
    Clean up, lube or otherwise service your tach cable and reconnect.
    Andrew Nichols likes this.
  2. bill
    bill Active Member
    Raleigh, NC
    Another great how to Fitz Thanks!
  3. ASHMan
    ASHMan New Member
    Phoenix, Arizona
    Fitz, it's like you just knew my bike was leaking from there!
  4. bigfitz52
    It's the odds... BOTH of mine were, I got to do it twice yesterday.
    That poor little oil seal has a pretty hard life; it doesn't get "pressure fed" or anything even close so it's not cooled by fresh oil all the time; and it gets pretty blasted hot right above the exhaust ports there. Once it's baked hard, it's doomed. I've put about 4K on my '81 since I resurrected it, and it just started leaking big time.
  5. ASHMan
    ASHMan New Member
    Phoenix, Arizona
    I only can have one right now, so sayith the wife. But there is this cb I have my eyes on...
  6. OnTheStorm
    OnTheStorm Member
    Los Angeles, CA
    Mine had another rubber seal between the #5 on your diagram, and the housing on the cable. the screw on the cable end also did not screw all the way in. Is this necessary? either end of the tach cable is not screwed in all the way...another screw-up by the P.O.?
    any chance you could give me the part numbers from chacal for those replacement parts as well? I can't seem to find them in the catalog.
  7. bigfitz52
    Yep. I encountered the same on my '83. I suspect the PO bought the parts, and couldn't figure out where the seal went (since it's hiding) so he just jammed it in between the cable and the housing.
    It's supposed to be the way I show it.
    From Page 5 of Len's catalog:
    HCP3539 OEM tachometer cable drive gear (on cylinder head) OIL SEAL. If you're leaking oil where the tach cable attaches to the drive housing on the drive adapter housing, it's because this oil seal (and/or the drive gear O-ring) is bad and need to be replaced. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model.
    $ 5.95
    HCP3537 OEM tachometer cable drive gear O-RING. If you're leaking oil where the tach cable attaches to the drive housing on the drive adapter housing, it's because this o-ring (and/or the housing oil seal) is bad and need to be replaced. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model.
    $ 4.95
  8. Polock
    is that the first time you used that vise? sure is pretty :)
  9. OnTheStorm
    OnTheStorm Member
    Los Angeles, CA
    cable housing still wont screw in all the way. there is a rubber gasket on the inside of the housing (on the cable). this supposed to be there? It looks like a thick washer, but it is rubber?
  10. bigfitz52
    Sorry just noticed your post. No, it's not. No rubber washer inside cable ferrule, like I said suspect a PO who bought a new seal couldn't figure out where it went and jammed it in.
  11. Rebel51
    Rebel51 New Member
    Centerville, MN
    Many thanks to bigfitz52 for the instructions, and to chacal for having the parts! I bought my '81 Maxim 650 and the PO said the tach wasn't working, "...and I don't know why." Didn't take long to find the tach cable dangling in the wiring harness, and a bolt where the tach gear should be. The bolt wasn't even screwed in, it was held in place by a rubber grommet. Long story short, XJ4Ever had the parts, and bigfitz52 had the instructions. Worked like a charm, so, again, thanks to all!
  12. AutoAndy7
    AutoAndy7 New Member
    Chicago
    LOVE IT! Extremely helpful, great pics! :twisted:
  13. schmuckaholic
    California
    Here, gimme a little bit and I'll package that up for you nice and pretty like...
  14. pbthoe
    pbthoe Member
    Moore, S.C.
    Nice write up fitz. Cheap,easy, quick fix for a messy problem. Now I can tell the difference from where I park the XJ vs. the Harley. It's amazing what a mess a teaspoonful of oil can make at 60 or 70 mph.
  15. bluemiata
    bluemiata New Member
    Ohio
    I have an '82 XJ650RJ that I'm replacing the tach cable on, since the tach was operating erratically - when rev's got up around 5k, the needle would drop back around 4k, even though the engine revs were increasing. I removed the knurled nut at the gear housing, but the cable doesn't want to come out. Is this typical?Thanks!
    micheal wade likes this.
  16. bigfitz52
    No, it's not. Somebody has probably jammed it in there. The stock cable has a flared ferrule that meets up with the gear housing and is held by the knurled nut.
    Your problem may turn out to be the instrument itself. That's covered here: http://xjbikes.com/Forums/viewtopic/t=15303.html however, in your case, some "surgery" will be required to gain access.
  17. extremo
    extremo New Member
    Grand Manan NB
    I just found this thread.
    While my '81 559 Maxim is not leaking oil here, the tach cable knurled nut (plastic?!) keeps working loose with vibration. Sometimes during a ride, the tach will just drop to zero. I pull over and stop reattach it by hand. When I get home, no matter how much I tighten it, it seems to work loose in a week or two.
    What's next? Locktight?, teflon tape?
  18. bigfitz52
    If the tach cable knurled nut at either end is plastic then it's a cheapo aftermarket piece. Collar/nuts at both ends should be alloy.
    The reason the cable nuts (and this applies to the speedo cable too) come loose:
    There are "flats" on the ferrule part of the cable. When tightening the knurled collar/nut, you need to hold the cable sheath from turning with a small wrench when you tighten the nut.
    If you don't hold the cable, what happens is as you tighten the nut, you can end up "winding up" the cable sheath. In other words, you inadvertently apply a rotational "preload" to the cable so that as it tries to straighten itself back out, it applies "unscrewing" force to the nut which then works loose.
    I should probably shoot a couple of additional pics and add that little 'tip' to the article, eh?
  19. broberg
    broberg Member
    Sweden, Östergötland
    Sorry to bump this thread, but I'm removing my tachometer from the 550.
    Is there any ready-made plug that fits this contraption, and when removing the cable should I leave the rod in or remove it. I'm guessing nothing is reliant on the rod being in place for everything else to function properly?
    DenCon509 likes this.
  20. seca550RK
    seca550RK Member
    spring city PA / Trondheim Norway
    I recently bought my bike, and when I got it home i noticed the tach bolt had almost completely unscrewed. I tightened it up but I notice the tach seems to jump or stall when I get over 4000 rpm. any ideas what could be going on? Thanks!
  21. bigfitz52
    -The cable itself needs to be cleaned and lubed. Possibly replaced.
    -The instrument itself may need attention.
    Since you have a 550 Seca, here's the instrument cluster removal and teardown procedure: http://xjbikes.com/Forums/viewtopic/t=14948.html
    Here's what you'll find in there, and how to lube the instruments: http://xjbikes.com/Forums/viewtopic/t=15303.html
    And completely off this topic but since you have a 550 Seca, check this: http://xjbikes.com/Forums/viewtopic/t=31872.html
    More 550 Seca tips: http://xjbikes.com/Forums/viewtopic/t=36235.html
    Check out the "XJ FAQ Suggestions" forum. You'll find valve adjustment, rear wheel bearing, clutch, and Mikuni carb photo "how-tos" mostly all performed on one of my 550 Secas.
    AS WAS THIS, be sure to check it right away: http://xjbikes.com/Forums/viewtopic/t=15874.html
  22. seca550RK
    seca550RK Member
    Thanks so much for the reply. I'm new to riding as well as to this bike, so I'm trying to give it a good check over and make sure its working as it should. I don't really know whats normal for these things so this forum is a great help. I'll make my way through the posts as it seems like a lot of the same problems come up
  23. bigfitz52
    Welcome aboard. What's "normal" is that the people that owned the bike before you likely didn't keep up on the required maintenance; plus things like 30-year old brakes simply have to go.
    Start your own thread in "XJ Chat" when you have any more questions that arise, and we'll be sure you get some assistance.
  24. cg82
    cg82 Member
    Rossland British Columbia
    just used this thread to help replace my seals. Thanks a ton for the info guys!
  25. Alain
    Alain Member
    Thanks for this. I nearly bought a whole new tachometer cable but ran into this article.
    Digging out the original seal #4 was a bitch though. I'm not sure if I actually got the oil seal out... because I dug the seal out to pieces... kinda like breaking your wisdom tooth and extracting it bit by bit.
  26. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    COME BAAAACK FITZ!!!!
  27. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Just replaced my seals.
    Getting the old seal out and cleaning the residue from the housing is the hardest part. That 32 year old seal was essentially 'glued' in place.
  28. DenCon509
    DenCon509 Member
    Central Washington, USA
    I, too, wish to do away with the mech tach (speedo, too); I'm looking for some kind of blanking plug/cap. I see no point in repairing something that I want to delete.
    I want to change instruments to electronic, with the hope of using the stock housings and inserting appropriate bits to retain as much of the stock appearance as possible.
    Is there a kit "how-to" for this?
  29. k-moe
    Start a conversation with Chacal. He sells a blanking plug for the tach drive and includes instructions.
  30. DenCon509
    DenCon509 Member
    Anybody have luck with converting to an electronic tach?
  31. k-moe
    Yamaha did. You wont have the advantage of not machining the casting for a tach cable though, since your's is already done. Chacal sells a blanking plug for the tacho drive hole. After that all you need is a tach and the ability to find the grey coil wire.
  32. dkavanagh
    Rochester, NY
    Achievement Unlocked
  33. Rogan butler
    Rogan butler New Member
    Victoria b.c.
    For some reason i cant see the pics?? Im having this issue and just got my seals but have no clue what im doing.
  34. MattiThundrrr
    3rd party sites no longer allow free image storage, and BigFitz has been away since 2014. Therefore, images are dropping out of old threads. It sucks.
  35. Rogan butler
    Victoria b.c.
    Im wondering how you disconnect the tach drive cable from thr tach drive itself.
  36. k-moe
    It unscrews. Lefty loosey.
  37. MattiThundrrr
    Never understood that mnemonic aid. With rotational movement, one side is always going left, clockwise or counterclockwise. If a screw is turned clockwise (tightey), the 6 o'clock part is going left...
    Matti needs a how-to on tightening screws. Look for "How to screw", it'll be in the Hangout Lounge.
    alFrumpus likes this.
  38. XJ550H
    needed because of digital watches and clocks
  39. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Thanks to bigfitz52 for posting this thread with photos etc., very helpful. After 42 years and 57K miles, have had to replace #4 oil seal as it was leaking quite badly.
    Had previously ordered both #2 o-ring and #4 oil seal but not used the latter. In the UK, great next day service from Fowlers when ordering another #2 o-ring.
