XJ PARTS CATALOG, SECTION K: STEERING and SUSPENSION
Discussion in 'XJ4Ever - Supporting Vendor' started by chacal, Oct 11, 2013.
Thread Status:
Not open for further replies.
  1. chacal
    SECTION K:
    STEERING/SUSPENSION:
    --Steering: Handlebars, crowns, head bearings, etc.
    STEERING COMPONENTS:
    HANDLEBARS AND HARDWARE:
    hb22) OEM original style HANDLEBARS bring back the original shine and appearance to your bike.
    NOTE: due to the size of these items, the free or reduced shipping charges offer will not apply to shipments including these parts.
    Many people wish to change from their stock handlebars to flatter, "cafe" or "drag" style handlebars. Although such bars look very racy, and will certainly give your bike a different feel and riding style, there are some issues to consider when considering such a change.
    The OEM handlebars from either the XJ550 models, XJ650RJ Seca models, XJ650 Turbo models, XJ700 models, and XJ750 Seca models are pretty flat, and should clear the fuel tank properly at full lock (something that certain "drag bars" may not be able to do) on almost every XJ model that they are fitted to.....excepting the 1982 XJ750 Maxim, the XJ900RK Seca, and the XJ1100 models, which use adjustable "stub" handlebars that mount in a completely different manner from the round handlebars used on all other models.
    Obviously, the Seca models used "flatter and straighter" bars than the other models, as did the XJ650 Turbo models.
    Also, be aware that when you go from those hi-rise stock bars to flat bars, you're probably going to have to also change your master cylinder and clutch lever bracket, and may also have to acquire much shorter control cables (clutch and throttle) and possibly the master cylinder brake hose.
    Finally, beware of handlebar-to-tank clearance issues when going to flatter bars. One aspect of stock bars that is overlooked is that they have enough "rise" to make prevent the bars from contacting the forward sides of the fuel tank in "full lock" positions. AFTERMARKET BARS WITH A LOW "RISE" MAY HIT THE TANK AT FULL LOCK, OR, PREVENT YOU FROM REACHING FULL LOCK WITHOUT TRAPPING YOUR HANDS BETWEEN THE BARS AND THE TANK. Although this issue can then be "solved" by rotating the bars "upwards" (to get more rise out of the bars), this can typically result in an uncomfortable riding position.
    For comparison, below are the dimensions for stock handlebars. Notice that while the XJ550 handlebars have the same "rise" when measured to the grip, that they are much flatter bars than the XJ650 Maxim models (which have the same amount of rise), since the 650 Maxim bars go way "up" and then curve back down, thus ending up at the same relative position as the 550 bars, but without that big "buckhorn" styling.
    The XJ650RJ Seca and the XJ650 Turbo bars are the "flattest" and "straightest" of the bunch; the XJ550 and XJ700 bars have some curves to them.
    The dimensions specified below have the following meanings. If you remember basic geometry, then in a 3-dimensional diagram, the WIDTH dimension is the x-axis, the RISE is the y-axis, and the PULLBACK is the z-axis. Note that when handlebars are actually installed into their typical position on a bike, the actual (on the bike) RISE and the PULLBACK dimensions will likely differ, as handlebars are rarely installed (or can/will be changed to suit an individual rider) with the bars in a perfectly perpendicular orientation to the steering crown (which is how RISE and PULLBACK are specified for a bar for measurement purposes, i.e. off a bike, sitting on a tabletop, etc.). The WIDTH dimension, of course, is always true, on or off the bike, and that dimensions is not affected by any rotational position within the handlebar holders.
    OVERALL WIDTH = the overall width; the widest possible straight-line measurement, measured to the very outer ends of the handlebar.
    RISE AT GRIP ENDS: the overall height; measured with the straight center section of the handlebars laying flat on a surface, and then the tallest straight-line "upwards" measurement with the grip ends of the handlebars being horizontally level. Note that on many types of handlebars that raise to a peak and then turn back "down" to the rider, the handlebars are actually "taller" (if laid flat on a surface) than the "rise" dimension indicates......this is because "rise" is calculated at the grip position, not at the tallest point of the bars.
    PULLBACK AT GRIP ENDS: the overall depth of the handlebars; measured with the straight center section of the handlebars laying flat on a surface, and with the grip ends of the handlebars being horizontally level, this is the deepest straight-line "rearwards" measurements back to the grip ends of the handlebar.
    1981-83 XJ550 all models:
    overall width = 28-1/2"
    rise at grip ends = 4"
    pullback at grip ends = 6-1/4"
    1980-83 XJ650 Maxim and Midnight Maxim:
    overall width = 28"
    pullback at grip ends = 10-3/4"
    1982 XJ650RJ Seca models:
    overall width = 26"
    rise at grip ends = 1"
    pullback at grip ends = 4-1/4"
    1982-3 XJ650 Turbo models:
    overall width = 26"
    rise at grip ends = 3"
    pullback at grip ends = 5-1/2"
    NOTE: black chrome.
    1985-6 XJ700 models:
    overall width = 29"
    rise at grip ends = 1-1/4"
    1981-83 XJ750 Seca models:
    overall width = 29"
    rise at grip ends = 9.5"
    pullback at grip ends = 7"
    NOTE: the XH750 Seca bars have numerous handlebar shrouding "tabs" welded onto them along their length, designed to hold the soft vinyl handlebar upper and lower covers, and do not look very attractive when they are un-shrouded, i.e. "naked".
    1978-81 XS1100 all Special models:
    overall width = 29"
    rise at grip ends = 6"
    pullback at grip ends = 11-3/4"
    When swapping out the "hi-rise" roto-tiller style bars as used on the XJ650 Maxim or Midnight Maxim, 1983 XJ750 Maxim or Midnight Maxim, or XS1100 Special models to flatter bars, you will also need to make two other changes:
    http://www.xjbikes.com/forums/threads/handlebar-swap-ditching-the-horns.94195/#post-523008
    a) substitute an appropriate "horizontally level" style master cylinder. The master cylinder on the above models mounts at about a 40-degree "down-tilted" angle in order to keep the fluid reservoir more-or-less level. On all other models, the master cylinder is completely level with the horizontal when mounted on their (flat) handlebars.....and so if you substitute flat style bars on the XJ650 or XJ750 Maxim models, you'll also have to use the appropriate "flatter-bars" type of master cylinder.
    b) the left side clutch lever bracket will also need to be changed, as the left mirror screws into this bracket, and on the "buckhorn bars" style bikes, this bracket has the mirror-mounting boss cast into it at a "tilted" angle, to compensate for the tilt of the bars.......and re-using that bracket on "flat bars" will leave your left-side mirror sticking outwards at a really strange (and very non-useful) angle. You should choose a mirror bracket that is correct for the handlebar that you are using. In most case you should be able to re-use your original clutch hand lever and hardware.
    Original Handlebars:
    HCP4407 OEM original HANDLEBARS, bright chrome plated, fits all XJ550 models. NOTE: unlike the original bars, these replacement versions have internal bar stiffener rods welded insider of them, which prevents the use of aftermarket style “bar-end” mirrors.
    $ 199.95
    HCP9183 OEM plastic handlebar SPACER RING, the thin round ring that fits on the right side, between the control switch and the master cylinder, use 1 per bike on all XJ550 Seca, XJ750P (24L), and XJ750P (37H) models.
    $ 6.95
    HCP4406 OEM original HANDLEBARS, bright chrome plated, fits all XJ650 Maxim models. NOTE: XJ650 Midnight Maxim models used this same shape and configuration bar, but it was black-chromed. NOTE: the HCP28062 handlebars below (for the XS1100 Special models are an acceptable substitute for the original XJ650 Maxim handlebars; the HCP28062 have the same bends and dimensions except that the straight “ends” of the bars (where the grips attach) are approximately 1” longer on the XS1100 bars (as compared to the XJ650 Maxim bars), and the overall spread (or WIDTH dimension) is also approximately 1” wider than stock XJ650 Maxim bars.
    $ discontinued
    HCP4408 OEM original HANDLEBARS, bright chrome plated, fits all XJ650RJ Seca models. NOTE: unlike the original bars, these replacement versions have internal bar stiffener rods welded insider of them, which prevents the use of aftermarket style “bar-end” mirrors.
    $ discontinued
    HCP4415 OEM original HANDLEBARS, bright chrome plated, fits all XJ700 and XJ750-X models.
    $ 189.95
    HCP28062 Aftermarket reproduction of the original HANDLEBARS, bright chrome plated, fits all XS1100 Special and Midnight Special models. Note that these are chrome-plated bars, so not truly correct for the Midnight models. NOTE: these handlebars are an acceptable substitute for the original XJ650 Maxim handlebars; these HCP28062 have the same bends and dimensions except that the straight “ends” of the bars (where the grips attach) are approximately 1” longer on the XS1100 bars (as compared to the XJ650 Maxim bars), and the overall spread (or WIDTH dimension) is also approximately 1” wider than stock XJ650 Maxim bars. NOTE: due to the size of these handlebars, the reduced-cost shipping fees offer will not apply to this item.
    $ 89.95
    Steering Crowns, Handlebar Risers, and Hardware:
    The steering CROWN BRACKET is the cast aluminum piece that your handlebars actually bolt onto, while the RISERS and their associated HOLDER CAPS actually cinch the handlebar to the crown (note: on most models, the risers are actually cast as part of the steering crown bracket itself).
    The above pieces rarely every "wear out", but the crown bracket may become damaged in an accident or bike drop, and it is possible to strip out or fracture off a fork tube mounting ear in certain situations.
    HCP4510 OEM steering CROWN BRACKET, finished in the original low-gloss black. Fits all XJ550 Seca models only.
    $ 199.95
    HCP4538 OEM original HANDLEBAR RISER-CLAMP, original low-gloss black finish, fits all XJ550 Seca, XJ650 Maxim, XJ650 Midnight Maxim, XJ650RJ Seca models, and 1983 XJ750 Maxim and Midnight Maxim models. Fits left or right side. Each:
    $ 34.95
    HCP4539 OEM original HANDLEBAR RISER-CLAMP, original polished natural finish, fits all XJ550 Maxim, all XJ700, and XJ750-X models. Fits left or right side. Each:
    $ 34.95
    HCP505 OEM handlebar riser-clamp BOLT, dark finish as original. Use 2 per clamp on all XJ550, XJ650, 1983 XJ750 Maxim and Midnight Maxim, and all XS1100 models. Each:
    $ 7.95
    HCP505SET2 OEM handlebar riser-clamp BOLTS, set of 2:
    $ 14.95
    HCP505SET4 OEM handlebar riser-clamp BOLTS, set of 4:
    $ 27.95
    HCP4956 OEM handlebar riser-clamp BOLT, alloy steel, socket head cap screw with a bright finish, Use 2 per clamp on all XJ550, XJ650, all XJ700, 1983 XJ750 Maxim and Midnight Maxim, XJ750-X, and all XS1100 models. Each:
    $ 2.95
    HCP21942 Aftermarket handlebar riser-clamp BOLT, alloy steel socket head cap screw with a bright finish, Use 2 per clamp on all XJ550, XJ650, all XJ700, 1983 XJ750 Maxim and Midnight Maxim, XJ750-X, and all XS1100 models. Each:
    $ 1.95
    HCP23282 Aftermarket handlebar riser-clamp BOLT, 18-8 stainless steel socket head cap screw with a bright finish, Use 2 per clamp on all XJ550, XJ650, all XJ700, 1983 XJ750 Maxim and Midnight Maxim, XJ750-X, and all XS1100 models. Each:
    $ 2.95
    HCP22203 Aftermarket handlebar riser-clamp BOLT, 316 stainless steel socket head cap screw with a bright finish, Use 2 per clamp on all XJ550, XJ650, all XJ700, 1983 XJ750 Maxim and Midnight Maxim, XJ750-X, and all XS1100 models. Each:
    $ 3.95
    HCP23283 Aftermarket handlebar riser-clamp BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel socket head cap screw. Use 2 per clamp on all XJ550, XJ650, all XJ700, 1983 XJ750 Maxim and Midnight Maxim, XJ750-X, and all XS1100 models. Each:
    $ 3.95
    HCP21944 Aftermarket handlebar riser-clamp BOLT, alloy steel socket head cap screw with a black finish, Use 2 per clamp on all XJ550, XJ650, all XJ700, 1983 XJ750 Maxim and Midnight Maxim, XJ750-X, and all XS1100 models. Each:
    $ 1.95
    HCP2130 OEM handlebar riser-clamp BOLT, alloy steel socket head cap screw with a black finish. Use 2 per clamp on all XJ750 Seca and XJ750 Euro models. Each:
    $ 8.95
    HCP22192 Aftermarket handlebar riser-clamp BOLT, alloy steel socket head cap screw with a bright finish. Use 2 per clamp on all XJ750 Seca and XJ750 Euro models. Each:
    $ 1.95
    HCP22193 Aftermarket handlebar riser-clamp BOLT, alloy steel socket head cap screw with a black finish. Use 2 per clamp on all XJ750 Seca and XJ750 Euro models. Each:
    $ 1.95
    HCP23280 Aftermarket handlebar riser-clamp BOLT, bright 18-8 stainless steel. Use 2 per clamp on all XJ750 Seca and XJ750 Euro models. Each:
    $ 2.95
    HCP22194 Aftermarket handlebar riser-clamp BOLT, 316 stainless steel socket head cap screw with a bright finish. Use 2 per clamp on all XJ750 Seca and XJ750 Euro models. Each:
    $ 3.95
    HCP23281 Aftermarket handlebar riser-clamp BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel. Use 2 per clamp on all XJ750 Seca and XJ750 Euro models. Each:
    $ 4.95
    HCP4551 OEM handlebar riser-clamp bolt decorative CAP, use 1 per riser cap (it covers both of the riser cap bolts). For all XJ550 Maxim models. Each:
    $ 16.95
    HCP4962 OEM handlebar riser cap bolt head DECORATIVE BLACK CAP, this push-in black plastic cap (“cover”) fits into the socket head of the bolt, and makes for a nice pretty finished appearance. Use 1 per riser cap bolt (each cap only covers a single bolt head) on all XJ550 Seca, all XJ650 models (except Turbo), all XJ750 Seca and XJ750 Euro models, 1983 XJ750 Maxim and Midnight Maxim models, XJ1100, and all XS1100 models. Each:
    $ 7.95
    HCP4962SET4 OEM handlebar riser cap bolt decorative DECORATIVE BLACK CAPS, set of 4:
    $ 29.95
    HCP26235 Aftermarket handlebar riser cap bolt head DECORATIVE BLACK CAP, this push-in black plastic cap (“cover”) fits into the socket head of the bolt, and makes for a nice pretty finished appearance. Use 1 per riser cap bolt (each cap only covers a single bolt head) on all XJ550 Seca, all XJ650 models (except Turbo), all XJ750 Seca and XJ750 Euro models, 1983 XJ750 Maxim and Midnight Maxim models, XJ1100, and all XS1100 models. Each:
    $ 10.95
    HCP26235SET4 Aftermarket handlebar riser cap bolt decorative DECORATIVE BLACK CAPS, set of 4:
    $ 41.95
    HCP4957 OEM handlebar riser cap bolt head DECORATIVE CHROME CAP, this push-in chrome-plated cap (“cover”) fits into the socket head of the bolt, and makes for a nice pretty finished appearance. Use 1 per riser cap bolt (each cap only covers a single bolt head) on all XJ700 and XJ750-X models. Each:
    $ 4.95
    HCP4957SET4 OEM handlebar riser cap bolt head DECORATIVE CHROME CAPS, set of 4:
    $ 16.95
    Handlebar Riser Knurled Stem Installation Hardware:
    Models with adjustable handlebars----1982 XJ750 Maxim, XJ900, and XJ1100 models-----used additional fasteners in the handlebar area to locate the lower steering "stem" or riser, and the adjustable mechanisms for the actual handlebars themselves.
    XJ750 Seca models, while not using the "infinitely adjustable" handlebar design like the bikes above, also used a lower riser that was not integral to the steering crown, and thus has its own set of special fasteners used to secure the lower stem riser to the steering crown.
    HCP4553 OEM handlebar riser cap BOLT, use 1 per riser stem. For all 1982 XJ750 Maxim models. This is the special button-headed bolt that retains the handlebars to the splined stem. Each:
    $ 39.95
    HCP11753 OEM handlebar riser cap bolt FLAT WASHER, use 1 per bolt. For all 1982 XJ750 Maxim models. This is the special thick washer used under the HCP4553 button-headed bolt that. Each:
    $ 17.95
    HCP4552 OEM handlebar stem bolt decorative CAP, use 1 per HCP4553 bolt . For all 1982 XJ750 Maxim models. Each:
    $ 11.95
    HCP10126 OEM handlebar stem ADJUSTER ADAPTER, use 1 per side, adapts the handlebar studs attaches to the bars themselves and allows the angle of the bars to be adjusted to different positions and then locked in place. Fits both left and right sides. For all XJ900RK and RL models. Each:
    $ 89.95
    HCP10130 OEM handlebar riser cap bolt WASHER, use 1 per riser stem. For all FJ600 and XJ900RK and RL models. Each:
    $ 7.95
    HCP10127 OEM handlebar stem bolt decorative CAP, use 1 per bolt where the stem attaches to the crown (each cap only covers a single bolt head). This is for the vertically-oriented bolts. For all FJ600 and XJ900RK, RL, FN, and F models. Each:
    $ 19.95
    HCP13684 OEM handlebar stem bolt decorative CAP, use 1 per bolt where the handlebar attaches to the stem (each cap only covers a single bolt head). This is for the horizontally-oriented bolts. For all XJ900RK and RL models. Each:
    $ 17.95
    HCP3925 OEM handlebar lower stem BOLT, alloy steel hex-head bolt with a bright finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 7.95
    HCP17143 Aftermarket handlebar lower stem BOLT, steel hex-head bolt with a bright silver-zinc finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 1.95
    HCP22195 Aftermarket handlebar lower stem BOLT, alloy steel hex-head bolt with a bright yellow-zinc finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 1.95
    HCP17144 Aftermarket handlebar lower stem BOLT, alloy steel hex-head bolt with a black finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 1.95
    HCP17145 Aftermarket handlebar lower stem BOLT, 18-8 stainless steel hex-head bolt with a bright finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 2.95
    HCP22198 Aftermarket handlebar lower stem BOLT, 316 stainless steel hex-head bolt with a bright finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 3.95
    HCP22200 Aftermarket handlebar lower stem BOLT, high-strength alloy steel socket head (hex-key) bolt with a black finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 3.95
    HCP22201 Aftermarket handlebar lower stem BOLT, alloy steel socket head (hex-key) bolt with a bright finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 1.95
    HCP22202 Aftermarket handlebar lower stem BOLT, 18-8 stainless steel socket head (hex-key) bolt with a bright finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 2.95
    HCP24125 Aftermarket handlebar lower stem BOLT, 316 stainless steel socket head (hex-key) bolt with a bright finish, use 1 per lower stem, retains the lower "riser" (stem) to the top of the crown bracket. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 3.95
    HCP2185 OEM handlebar lower stem bolt LOCK WASHER, use 1 per lower stem along with the HCP3925 bolt above. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 6.95
    HCP16209 Aftermarket handlebar lower stem bolt LOCK WASHER, zinc-plated alloy steel, use 1 per lower stem along with the HCP3925 bolt above. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 2.95
    HCP16100 Aftermarket handlebar lower stem bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per lower stem along with the HCP3925 bolt above. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 3.95
    HCP16102 Aftermarket handlebar lower stem bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per lower stem along with the HCP3925 bolt above. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 3.95
    HCP4542 OEM handlebar lower stem stud FLAT WASHER, use 1 per riser (each stem stud uses this washer where it passes through the crown bracket, beneath the crown bracket). For all 1982 XJ750 Maxim and all XJ1100 models. Each:
    $ 0.95
    HCP2258 OEM handlebar lower stem stud FLAT WASHER, bright zinc-plated alloy steel. Use 2 per riser (each stem stud uses this washer both above and below where it passes through the crown bracket). For all XJ750 Seca models. Each:
    $ 8.95
    HCP29101 Aftermarket handlebar lower stem stud FLAT WASHER, bright 18-8 stainless steel. Use 2 per riser (each stem stud uses this washer both above and below where it passes through the crown bracket). For all XJ750 Seca models. Each:
    $ 5.95
    HCP29103 Aftermarket handlebar lower stem stud FLAT WASHER, black 18-8 stainless steel. Use 2 per riser (each stem stud uses this washer both above and below where it passes through the crown bracket). For all XJ750 Seca models. Each:
    $ 4.95
    HCP29102 Aftermarket handlebar lower stem stud FLAT WASHER, bright 316 stainless steel. Use 2 per riser (each stem stud uses this washer both above and below where it passes through the crown bracket). For all XJ750 Seca models. Each:
    $ 8.95
    HCP3497 OEM handlebar lower stem stud LOCK WASHER, use 1 per riser (each stem stud uses this lock washer where it passes through the crown bracket, beneath the crown bracket). For all 1982 XJ750 Maxim and all XJ1100 models. Each:
    $ 7.95
    HCP22226 Aftermarket handlebar lower stem stud LOCK WASHER, black finish. Use 1 per riser (each stem stud uses this lock washer where it passes through the crown bracket, beneath the crown bracket). For all 1982 XJ750 Maxim and all XJ1100 models. Each:
    $ 2.95
    HCP2230 OEM handlebar lower stem stud LOCK WASHER, use 1 per riser (each stem stud uses this lock washer where it passes through the crown bracket, beneath the crown bracket). For all XJ750 Seca and XJ750 Euro models. Each:
    $ 7.95
    HCP22225 Aftermarket handlebar lower stem stud LOCK WASHER, zinc-plated alloy steel. Use 1 per riser (each stem stud uses this lock washer where it passes through the crown bracket, beneath the crown bracket). For all XJ750 Seca and XJ750 Euro models. Each:
    $ 2.95
    HCP22227 Aftermarket handlebar lower stem stud LOCK WASHER, 18/8 stainless steel. Use 1 per riser (each stem stud uses this lock washer where it passes through the crown bracket, beneath the crown bracket). For all XJ750 Seca and XJ750 Euro models. Each:
    $ 3.95
    HCP2557 OEM handlebar lower stem stud NUT, use 1 per riser. For all 1982 XJ750 Maxim models, and all XJ750 Seca models. Each:
    $ 6.95
    HCP3976 OEM handlebar lower stem stud NUT, use 1 per riser. For all XJ1100 models. Each:
    $ 7.95
    HCP4549 OEM handlebar lower stem stud nut RETAINING CLIP, use 1 per riser. For all 1982 XJ750 Maxim models, and all XJ750 Seca models. Each:
    $ 7.95
    HCP4548 OEM handlebar lower stem stud nut RETAINING CLIP, use 1 per riser. For all XJ1100 models. Each:
    $ 7.95
    Handlebar Adjuster Installation Hardware:
    Models with adjustable handlebars----1982 XJ750 Maxim, XJ900RK, and XJ1100 models-----use these fasteners to attach the uprights, or vertical risers, to the actual round "handlebars" (the part that you actually hold onto).
    HCP4455 OEM handlebar vertical riser CINCH BOLT, at the lower end of the riser where they attach to the steering crown splined stem. Use 1 per riser on all 1982 XJ750 Maxim and XJ1100 models. Each:
    $ 7.95
    HCP3546 OEM handlebar vertical riser-to-handlebar BOLT, at the upper end of the riser, to attach the round handlebar. Use 1 per riser on all 1982 XJ750 Maxim and XJ1100 models. Each:
    $ 1.50
    HCP4457 OEM handlebar vertical riser-to-handlebar FLAT WASHER, at the upper end of the riser, to attach the round handlebar. Use with the HCP3546 bolt above, 1 per riser on all 1982 XJ750 Maxim and XJ1100 models. Each:
    $ 4.95
    HCP168 OEM handlebar riser plate SCREW, use 2 per riser to secure the rectangular wire and cable routing "plate" to the outside of the risers. For all 1982 XJ750 Maxim models and all XJ1100 models. Each:
    $ 1.00
    HCP10124 OEM handlebar vertical riser-to-handlebar ADAPTER, the round "toothed" boss at the lower end of the riser, adapting the riser to the crown bracket. Use 1 per riser on all XJ900RK models, fits the left side. Each:
    $ 79.95
    HCP10125 OEM handlebar vertical riser-to-handlebar ADAPTER, the round "toothed" boss at the lower end of the riser, adapting the riser to the crown bracket. Use 1 per riser on all XJ900RK models, fits the right side. Each:
    $ discontinued
    HCP10126 OEM handlebar vertical riser-to-handlebar ADAPTER, the round "toothed" boss at the upper end of the riser, adapting the riser to the round handlebar. Use 1 per riser on all XJ900RK models, fits left or right side. Each:
    $ 89.95
    Handlebar Covers:
    All XJ750 Seca and XJ900 models used black plastic decorative covers surrounding the exposed sections of the handlebars. Although the covers are no longer available, we do have the mounting hardware that is used with them.
    HCP3633 OEM handlebar cover SCREW, use 3 per side to attach the upper to the lower cover on either the left or right side covers. Fits XJ750 Seca models. Each:
    $ 2.95
    HCP23024 Aftermarket handlebar cover SCREW, use 3 per side to attach the upper to the lower cover on either the left or right side covers. Fits XJ750 Seca models. Zinc-plated alloy steel as original, each:
    $ 1.95
    HCP23025 Aftermarket handlebar cover SCREW, use 3 per side to attach the upper to the lower cover on either the left or right side covers. Fits XJ750 Seca models. 18-8 stainless steel, each:
    $ 2.95
    HCP4458 OEM handlebar cover screw FLAT WASHER, bright zinc-plated alloy steel. Use 1 per screw to attach the upper to the lower cover on either the left or right side covers. Fits XJ750 Seca models. Each:
    $ 2.95
    HCP924 Aftermarket handlebar cover screw FLAT WASHER. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP338 Aftermarket handlebar cover screw FLAT WASHER. Bright 18-8 stainless-steel. Each:
    $ 2.95
    HCP28050 Aftermarket handlebar cover screw FLAT WASHER. Bright grade 316 stainless-steel. Each:
    $ 3.95
    HCP1356 Aftermarket handlebar cover screw FLAT WASHER. Black oxide-coated steel. Each:
    $ 1.95
    HCP3926 OEM steering central plastic cover SCREW, alloy steel, panhead, phillips-drive, black finish. Use 2 per unit, retains the plastic cover to the upper bracket. Fits all XJ750 Seca models. Each:
    $ 7.95
    HCP3114 Aftermarket steering central plastic cover SCREW, alloy steel, panhead, phillips-drive, bright finish. Use 2 per unit, retains the plastic cover to the upper bracket. Fits all XJ750 Seca models. Each:
    $ 1.95
    HCP3115 Aftermarket steering central plastic cover SCREW, 18-8 stainless steel, panhead, phillips-drive, bright finish. Use 2 per unit, retains the plastic cover to the upper bracket. Fits all XJ750 Seca models. Each:
    $ 3.95
    HCP26199 Aftermarket steering central plastic cover SCREW, 316 stainless steel, panhead, phillips-drive, black finish. Use 2 per unit, retains the plastic cover to the upper bracket. Fits all XJ750 Seca models. Each:
    $ 3.95
    HCP1903 OEM steering bracket plastic cover screw FLAT WASHER, use 2 on all XJ750 Seca models. Each:
    $ 3.95
    HCP25872 Aftermarket steering bracket plastic cover screw FLAT WASHER, bright zinc-plated alloy steel, use 2 on all XJ750 Seca models. Each:
    $ 1.25
    HCP25873 Aftermarket steering bracket plastic cover screw FLAT WASHER, bright 18/8 stainless steel, use 2 on all XJ750 Seca models. Each:
    $ 1.75
    HCP25875 Aftermarket steering bracket plastic cover screw FLAT WASHER, black oxide-coated 18/8 stainless steel, use 2 on all XJ750 Seca models. Each:
    $ 1.95
    HCP25874 Aftermarket steering bracket plastic cover screw FLAT WASHER, bright 316 stainless steel, use 2 on all XJ750 Seca models. Each:
    $ 2.95
    HCP4252 OEM handlebar cover SCREW, use 2 per side to attach the center crown cover. Fits XJ900RL, RL, FN, and F models. Each:
    $ 1.00
    HCP1869 OEM handlebar cover screw FLAT WASHER, use 1 per HCP4252 screw to attach the center crown cover. Fits XJ900RL, RL, FN, and F models, black-oxide finish, each:
    $ 2.95
    HCP6642 Aftermarket zinc-plated alloy steel with a natural finish, handlebar cover screw FLAT WASHER, use 1 per HCP4252 screw to attach the center crown cover. Fits XJ900RL, RL, FN, and F models. Each:
    $ 1.95
    HCP6643 Aftermarket 18-8 stainless steel handlebar cover screw FLAT WASHER, use 1 per HCP4252 screw to attach the center crown cover. Fits XJ900RL, RL, FN, and F models. Each:
    $ 2.95
    HCP25756 Aftermarket 316 stainless steel handlebar cover screw FLAT WASHER, use 1 per HCP4252 screw to attach the center crown cover. Fits XJ900RL, RL, FN, and F models. Each:
    $ 3.95
    HCP14285 Aftermarket black oxide-coated 18-8 stainless steel handlebar cover screw FLAT WASHER, use 1 per HCP4252 screw to attach the center crown cover. Fits XJ900RL, RL, FN, and F models. Each:
    $ 2.95
    HCP1902 OEM handlebar cover screw LOCK WASHER, black oxide-coated alloy steel, use 1 per HCP4252 screw to attach the center crown cover. Alloy streel with a dark finish. Fits XJ900RL, RL, FN, and F models. Each:
    $ 6.95
    HCP916 Aftermarket handlebar cover screw LOCK WASHER, use 1 per HCP4252 screw to attach the center crown cover. Zinc-plated alloy steel with a bright finish. Fits XJ900RL, RL, FN, and F models. Each:
    $ 1.95
    HCP319 Aftermarket handlebar cover screw LOCK WASHER, use 1 per HCP4252 screw to attach the center crown cover. 18-8 stainless steel with a bright finish. : . Fits XJ900RL, RL, FN, and F models. Each
    $ 2.95
    HCP321 Aftermarket handlebar cover screw LOCK WASHER, use 1 per HCP4252 screw to attach the center crown cover. Black oxide-coated alloy steel. Fits XJ900RL, RL, FN, and F models. Each:
    $ 1.95
    HANDLEBAR GRIPS:
    hb23) OEM and aftermarket HANDLEBAR GRIPS restore that like-new feel to your steering, and gives your bike that "brand-new" look.
    All original replacement OEM grips use a soft textured rubber pattern that is identical to the original pattern used, and the right side grip includes the plastic throttle tube.
    Aftermarket grips come in a variety of textures and styles as described below, and all are packaged as matched right and left sets. The right grip does not include the throttle tube, and your original tube must be re-used and typically must be modified to accept the replacement grip (the raised nibs on the outer end of the tube will need to be shaved down flat).
    Besides being more comfortable and, depending on the style selected, more colorful!-----aftermarket grips are available in a variety of different lengths. Stock lengths for original grips are listed below, and the length of the grip determines how far "onto" (length-wise) that the handlebar disappears into the grip inner tube----which also determines, on some models, the placement of the control switches, the master cylinder, and the clutch lever perch. On many models it is possible to use "deeper" (longer) grips than original; it will require either that the switches, etc. be pushed further "inward" on the handlebars (if possible and desired), or, that the grip is not fully driven onto the handlebar. Since the differences in length are rarely over 1/2", the lack of the handlebar being embedded fully into the grip for that short of a distance make no real meaningful difference in performance, although the unsupported part of the grip may feel a little "loose" . Longer grips are sometime preferred by people with extra-large sized hands.
    NOTE: if you intend to use the type of bar-end mirrors whose mounting post fits inside of the end of the handlebar tube, be aware that the ends of the grips (original or aftermarket) must be removed so that the mirror clamp can fit inside the handlebar, or, the grips listed below which have "open ends" should be used.
    Original Handlebar Grip Depths:
    These measurements are the total depth inside the original grip tubes, and thus determined the "fully-flush" distance that the inner end of the grip will be occupy from the end of the handlebar. You can use these measurements to compare against any possible fitment (overhang) issues when using aftermarket grips. Note that less than 5mm (less than 1/4") of difference will not be noticeable, at all, while differences of 10mm or more can be, and differences of 20mm or greater are generally not recommended.
    Original grips with a 121mm tube depth (4-3/4"):
    XJ550 all models left and right sides
    XJ650 all models (except Turbo) left and right sides
    XJ650 Turbo right side
    1982-83 XJ750 Maxim and Midnight Maxim right side
    1981 XJ750 Seca on and before frame number 002949, right side
    Original grips with a 124mm tube depth (4-7/8"):
    XJ650 Turbo left side
    1982-83 XJ750 Maxim and Midnight Maxim left side
    1981 XJ750 Seca on and before frame number 002949, left side
    Original grips with a 130mm tube depth (5-1/8"):
    1981 XJ750 Seca after frame number 002949, left side and right side
    1982-3 XJ750 Seca left side and right side
    XJ1100 left side and right side
    Original grips with a 134mm tube depth (5-1/4"):
    FJ600 left and right side
    XJ750RL left side and right side
    XJ900RK left side and right side
    Original grips with a 136mm tube depth (5-3/8"):
    XJ700 all models left side and right side
    XJ750-X all models left side and right side
    NOTE: the above models also use a separate chrome end cap that extends the overall outer length of the grip + cap to 140mm
    The installation of a new grip (original or aftermarket) is pretty straight-forward: you cut (with a sharp razor blade, x-acto knife, etc.) the old grips off----VERY CAREFULLY on the right side, so as to not damage the plastic throttle tube that is underneath it!----and then clean off all the old goo, adhesive, or debris from the handlebar itself (on the left side) or the plastic throttle tube (on the right side), and then lube up (silicone spray, etc.) the new ones and gently pound them into place!
    If you want to add a little adhesive to the left side grip, the best product to use is an aerosol hair spray, it remains slick for a moment or two and then dries very sticky!
    A couple of thoughts to consider when purchasing grips:
    a) original or aftermarket rubber grips will have the longest life.
    b) aftermarket foam grips can be quite comfortable, and will reduce vibration-induced "numbness" of the hands that can occur on longer rides; however, the foam tends to deteriorate after a few years, especially if the bike is left outside or in the weather.
    c) CLOSED END grips have their ends closed off (similar to the stock grips on all models except XJ700's and XJ900's, which used OPEN-END grips along with DECORATIVE END CAPS to "tidy-up" their open ends). These grips can have their ends "opened" with the careful use of a razor knife, etc. After such surgery, decorative end caps or bar-end mirrors can be used with these style grips.
    d) OPEN-END grips have their ends open (similar to the stock grips used on XJ700's and XJ900's) and traditionally are used with DECORATIVE END CAPS to "tidy-up" their open ends, or with bar-end mirrors.
    e) some handlebars have internal "end weights" installed in them that must be removed before any decorative end caps (or post-type bar-end mirrors) can be used. If the ends of your handlebars are not "hollow", then some type of efforts will need to be made to remove or otherwise allow an adequate amount of entry depth into the ends of the handlebars (about 2-3" or so) before decorative end caps or bar-end mirrors can be used.
    f) most aftermarket grips can present a challenge to install on the right side throttle tube............it can be an extremely tight fit. The original plastic throttle tube must be re-used, and typically must be modified to accept the replacement grip (the raised nibs on the outer end of the tube will need to be shaved down flat). A coating with some type of silicone spray or a smear of dishwashing liquid soap makes a good lubricant to allow the grip to be installed more easily.
    g) although they look (and feel) very nice, be aware that any aftermarket grips that have leather inserts will tend to be extremely slippery when wet, and therefore may present possible safety issues.
    Throttle tubes:
    HCP7373 OEM right side handlebar THROTTLE TUBE ONLY, if you're going to be replacing your original grips with aftermarket ones, you'll need to either salvage your original tube (not that easy) or replace it with this new tube. Fits all XJ550 models, all XJ650 models, all XJ750 Maxim and Midnight Maxim models, 1981 XJ750 Seca (through frame number 002949) models, and all XS1100 models. Also fits the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models. NOTE: can be used on all other models, but other models used a tube that was approximately 1/2" (11mm) longer. Use of this shorter tube may require that the control switch be moved "outwards" on the handlebar, from its normal position, by a similar amount.
    $ 29.95
    HCP29028 Aftermarket right side handlebar THROTTLE TUBE ONLY, if you're going to be replacing your original grips, you'll need to either salvage your original tube (not that easy) or replace it with this tube. Fits all XJ550 models, all XJ650 models, all XJ750 Maxim and Midnight Maxim models, 1981 XJ750 Seca (through frame number 002949) models, and all XS1100 models. Also fits the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models. NOTE: this tube does not have the raised “ribs” along the length of the tube as the original, and thus the tube would need to be sprayed with some type of adhesive (hair spray works well) before the rubber grip is installed onto the tube..
    $ 21.95
    HCP17499 Aftermarket throttle tube black plastic SPACER WASHER, acts as a bearing for the throttle tube, fitting in-between it and the control switch housing. Fits all XJ550, all XJ650, all XJ700, all XJ750, XJ900, XJ1100, and all XS1100 models. Use 1 per tube.
    $ 6.95
    Original Grips:
    Original factory grips duplicate the factory grip pattern and size. The right side grip comes with the throttle tube already installed inside the grip.
    HCP4428 OEM left side HANDLEBAR GRIP. Fits all XJ550 models, all XJ650 models (except Turbo), and all XS1100 models, as well as all of the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1978-81 SR500, 2015-17 SR400, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models.
    $ 16.95
    HCP28675LH Aftermarket left side HANDLEBAR GRIP, very close reproduction of the original. Fits all XJ550 models, all XJ650 models (except Turbo), and all XS1100 models, as well as all of the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1978-81 SR500, 2015-17 SR400, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models.
    $ 14.95
    HCP4429 OEM right side HANDLEBAR GRIP ASSEMBLY, includes the throttle tube. Fits all XJ550 models, all XJ650 models (except Turbo), and all XS1100 models, as well as all of the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1978-81 SR500, 2015-17 SR400, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models.
    $ 22.95
    HCP28675RH OEM right side HANDLEBAR GRIP, rubber grip only; does not include the throttle tube. Fits all XJ550 models, all XJ650 models (except Turbo), and all XS1100 models, as well as all of the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1978-81 SR500, 2015-17 SR400, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models.
    $ 16.95
    HCP28675SET Aftermarket left and right side HANDLEBAR GRIPS, very close reproduction of the original. Left and right set; note that the right side is the rubber grip only, and does not include the throttle tube. Fits all XJ550 models, all XJ650 models (except Turbo), and all XS1100 models, as well as all of the following models: 1978-79 XS400, 1977-81 XS650 Standards, 1978-83 XS650 Specials, 1978-79 XS750 all models, 1980-81 XS850 all models, 1981-82 SR185, 1980-82 SR250, 1978-81 SR500, 2015-17 SR400, 1983 XV500, 1987-88 XV535 Virago, 1981-83 XV750 Virago (including 1983 Midnight model), and 1981-82 XV920RH/RJ models.
    $ 29.95
    HCP4430 OEM left side HANDLEBAR GRIP ASSEMBLY. Fits all XJ650 Turbo models, all XJ750 Maxim and Midnight Maxim models, XJ750P (24L and 37H) models, and all 1981 XJ750 Seca models through frame number 002949.
    $ 59.95
    HCP4431 OEM right side HANDLEBAR GRIP ASSEMBLY, includes the throttle tube. Fits all XJ650 Turbo models, all XJ750 Maxim and Midnight Maxim models, XJ750P (24L and 37H) models, and all 1981 XJ750 Seca models through frame number 002949.
    $ 79.95
    HCP4437 OEM left or right side handlebar GRIP PLUG RING. Fits all XJ650 Turbo models. Each:
    $ 7.95
    HCP4438 OEM left side HANDLEBAR GRIP ASSEMBLY. Fits all XJ700 models, XJ750-X, 1986-89 YX600 Radian, 1984-87 XV700 Virago, 1986-87 FZX700 Fazer, 1988-89 XV750 Virago, 1984-88 XV1000 Virago, and 1985-89 VMX12 V-Max models.
    $ 57.95
    HCP4439 OEM right side HANDLEBAR GRIP ASSEMBLY, includes the throttle tube. Fits all XJ700 models, XJ750-X, 1986-89 YX600 Radian, 1984-87 XV700 Virago, 1986-87 FZX700 Fazer, 1988-89 XV750 Virago, 1984-88 XV1000 Virago, and 1985-89 VMX12 V-Max models.
    $ 79.95
    HCP4440 OEM left or right side handlebar grip END CAP. Fits all XJ700 and XJ750-X models, as well as all of the following models: 1986-90 YX600 Radian, 1986-87 FZX700 Fazer, 1984-87 XV700 Virago, 1988-89 XV750 Virago,
    1984-85 XV1000 Virago, 1986-89 XV1100 Virago, 1983-85 and 1989 XVZ12, 1985-86 and 1988-89 VMX12 V-Max, and 1986-93 XVZ13 models. Each:
    $ 11.95
    HCP4432 OEM left side HANDLEBAR GRIP ASSEMBLY. Fits all 1981 XJ750 Seca models after frame number 002949, all 1982-83 XJ750 Seca models, and all XJ1100 models.
    $ 39.95
    HCP4433 OEM right side HANDLEBAR GRIP ASSEMBLY, includes the throttle tube. Fits all 1981 XJ750 Seca models after frame number 002949, all 1982-83 XJ750 Seca models, and all XJ1100 models.
    $ 79.95
    HCP4434 OEM left side HANDLEBAR GRIP. Fits all 1984-85 FJ600, 1992-98 XJ600 Seca II, 1984 XJ750RL, and XJ900RK, RL, N/FN, and F models, as well as all of the following bikes: 1984-85 RZ350, 1985 RZ350NCII, 1987 FZ700, 1985-86 and 1988 FZ750, 1984-85 FJ1100, and 1986-93 FJ1200 models.
    $ 34.95
    HCP4435WO OEM right side HANDLEBAR GRIP, without the throttle tube. Fits all 1984-85 FJ600, 1992-98 XJ600 Seca II, 1984 XJ750RL, and XJ900RK, RL, N/FN, and F models, as well as all of the following bikes: 1984-85 RZ350, 1985 RZ350NCII, 1987 FZ700, 1985-86 and 1988 FZ750, 1984-85 FJ1100, and 1986-93 FJ1200 models..
    $ 44.95
    HCP4435 OEM right side HANDLEBAR GRIP ASSEMBLY, includes the throttle tube. Fits FJ600, XJ750RL, and all XJ900RK, RL, N/FN, and F models, as well as 1987 FZ700 and 1985-86 FZ750 models.
    $ 109.95
    HCP29750 OEM right side HANDLEBAR GRIP ASSEMBLY, includes the throttle tube. Fits 1992-98 XJ600 Seca II, 1988 FZ750, 1984-85 FJ1100, 1986-87 and 1989-93 FJ1200 models.
    $ 54.95
    HCP4436 OEM right or left side HANDLEBAR WEIGHT, chrome-plated heavy “knob” that threads into the end of the handlebar section. Fits 1984 XJ750RL and all XJ900RK, RL, N/FN, and F models. Each:
    $ 99.95
    HCP20020 OEM HANDLEBAR GRIP END PLUG, tapered dome cap that finishes off the end of the grip. Fits left or right side on 1984-85 FJ600 and 1992-94 XJ600 Seca II models, each:
    $ 74.95
    Aftermarket Grips:
    Aftermarket grips come in a variety of different material compositions, colors, and lengths. The right side grip does not include the throttle tube (you should re-use your original tube). All grips are designed to fit bikes with 7/8" OD handlebars (all XJ models of this era use 7/8" OD handlebars). NOTE: all "Internal Depth" measurements are for the right side grip; the left side grip will be the same depth, or very similar (sometimes a bit less than the right side).
    Grips are typically not marked with a left or right designation, but the right side grip (that must be fitted over the throttle tube) has a larger inside diameter than the left side grip.
    All-Foam Comfort Grips:
    NOTE: while foam grips are surely comfortable during regular use, they can become very "squishy" feeling when they get wet.........."like holding onto a set of sea cucumbers" as one user noted.
    HCP11761 Aftermarket set of ALL-FOAM HANDLEBAR GRIPS. Soft, black all-foam grip is quite comfortable. Open ends.....comes with black rubber "end caps" to close off the open ends of the handlebars. Overall length: 130mm (5-1/8"). Internal depth: 129mm (5-1/16"). Fits all XJ-series handlebars. Pair:
    $ 17.95
    HCP17495 Aftermarket set of ALL-FOAM HANDLEBAR GRIPS. Soft, black all-foam grip is quite comfortable. Open ends.....comes with black rubber "end caps" to close off the open ends of the handlebars. Overall length: 130mm (5-1/8"). Internal depth: 127mm (5"). Fits all XJ-series handlebars. Pair:
    $ 17.95
    HCP17496 Aftermarket set of ALL-FOAM HANDLEBAR GRIPS. Soft, black all-foam grip is quite comfortable. Open ends.....comes with black rubber "end caps" to close off the open ends of the handlebars. Overall length: 144mm (5-5/8"). Internal depth: 140mm (5-1/2"). Fits all XJ-series handlebars. Pair:
    $ 16.95
    Foam-and-Chrome Comfort Grips:
    HCP11755 Aftermarket set of FOAM-AND-CHROME HANDLEBAR GRIPS. Soft, black foam insert with highly polished chrome end caps. Very nice looking and very comfortable. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 131mm (5-1/4"). Internal depth: 125mm (4-7/8"). Fits all XJ-series handlebars. Pair:
    $ 24.95
    HCP11760 Aftermarket set of FOAM-AND-CHROME HANDLEBAR GRIPS. Soft, black foam insert with highly polished chrome end caps. Very nice looking and very comfortable. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 139mm (5-1/2"). Internal depth: 130mm (5-1/8"). Fits all XJ-series handlebars. Pair:
    $ 27.95
    HCP1693 Aftermarket set of FOAM-AND-CHROME HANDLEBAR GRIPS. Soft, black foam insert with highly polished chrome end caps. Very nice looking and very comfortable. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 158mm (6-1/4"). Internal depth: 148mm (5-7/8"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    price changes done below:
    Rubber-and-Chrome Grips:
    HCP11758 Aftermarket set of RUBBER-AND-CHROME HANDLEBAR GRIPS. Rough, black "tire-tread" insert with highly polished chrome end caps. Good grip texture and attractive. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 142mm (5-9/16"). Internal depth: 137mm (5-3/8"). Fits all XJ-series handlebars. Pair:
    $ 27.95
    HCP11756 Aftermarket set of RUBBER-AND-CHROME HANDLEBAR GRIPS. Rough, black "tire-tread" insert with highly polished SKULL HEAD chrome end caps. Good grip texture and the skull heads have a certain, ummm, "appeal". Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 155mm (6-1/8"). Internal depth: 137mm (5-3/8"). Fits all XJ-series handlebars. Pair:
    $ 27.95
    Dual-Density, All-Rubber Grips:
    HCP11770 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, black "X' slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 123mm (4-7/8"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ discontinued
    HCP17511 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, black "X' slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 125mm (5"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17502 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting grey "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 123mm (4-7/8"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP11771 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting grey "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 125mm (5"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17503 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting red "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 123mm (4-7/8"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17512 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting red "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 125mm (5"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17504 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting blue "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 123mm (4-7/8"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17513 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting blue "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 125mm (5"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17514 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting yellow "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 125mm (5"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 26.95
    HCP17531 Aftermarket set of DUAL-DENSITY DECORATIVE "X-SLOT" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting green "X' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 125mm (5"). Internal depth: 120mm (4-3/4"). Fits all XJ-series handlebars. Pair:
    $ 60.95
    HCP11764 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, black "Nike Swoosh' slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11810 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, black "Nike Swoosh' slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP17506 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting grey "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11766 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting grey "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11767 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting red "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11804 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting red "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11765 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting blue "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP17507 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting blue "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11768 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting yellow "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP17508 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting yellow "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP11769 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting green "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP17509 Aftermarket set of DUAL-DENSITY DECORATIVE "SWOOSH" RUBBER HANDLEBAR GRIPS. Tough, "diamond-point" black rubber grips have decorative, color-contrasting green "Nike Swoosh' relief slots to provide sweaty-palm cooling relief, great grip control, and a splurge of color to the end of your bars. Open ends.....note that these style grips can be used with bar-end mirrors "as-is", or for use with decorative bar end caps. Overall length: 120mm (4-3/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Pair:
    $ 29.95
    HCP17671 Aftermarket set of DUAL-DENSITY RUBBER COMFORT-HEEL HANDLEBAR GRIPS. Dual-color grips feature a stippled black rubber grip area using a "diamond-point" central grip surface along with a grey, smooth section with a specially shaped "swollen" area at the outer ends which allow the heel of your hand to rest more comfortably and be used to exert force on the grip, thus aiding in throttle position control ----- especially on long, steady-speed rides. Closed ends.....note that these style grips can have their ends sliced off to "open up" the ends, but you really don't want to do so, since that defeats their purpose and design! Overall length: 126mm (5"). Internal depth: 124mm (4-7/8"). Fits all XJ-series handlebars. NOTE: extremely tight fit! These grips are very difficult to install without the generous use of some type of lubricant. Pair:
    $ 39.95
    Heavy Metal: Chrome-and-Rubber Grips:
    HCP11759 Aftermarket set of CHROME-PLATED METAL HANDLEBAR GRIPS. Highly polished, heavy-duty industrial strength chrome metal grip with multiple raised, horizontal black rubber inserts. Good grip texture and very cool looking. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 130mm (5-1/8"). Internal depth: 128mm (5"). Fits all XJ-series handlebars. Pair:
    $ 39.95
    HCP18059 Aftermarket set of CHROME-PLATED METAL HANDLEBAR GRIPS. Highly polished, heavy-duty industrial strength chrome metal grip with multiple raised, horizontal black rubber inserts and highly polished SKULL HEAD chrome end caps. Good grip texture and the skull heads have a certain, ummm, "appeal". Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 160mm (6-1/4"). Internal depth: 140mm (5-1/2"). Fits all XJ-series handlebars. Pair:
    $ 39.95
    HCP17672 Aftermarket set of CHROME-PLATED METAL HANDLEBAR GRIPS. Highly polished, heavy-duty industrial strength chrome metal grip with multiple raised, diamond-shaped black rubber inserts. Good grip texture and very cool looking. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 155mm (6-1/8"). Internal depth: 144mm (5-5/8"). Fits all XJ-series handlebars. Pair:
    $ 49.95
    Heated All-Rubber Grips:
    HCP17509 Aftermarket set of HEATED RUBBER HANDLEBAR GRIPS. Black textured rubber grips have variable thermal heating elements that can be regulated (switch included). Keeps your hands toasty warm during off-season riding escapades. Closed ends.....note that it is not possible to "open up" the ends of these type of grips. Overall length: 133mm (5-1/4"). Internal depth: 116mm (4-9/16"). Fits all XJ-series handlebars. Comes complete with wiring instructions, wiring, and an OFF-LOW-HI setting thermostat switch. Pair:
    $ 129.95
    Decorative Handlebar End Caps:
    These knurled, anodized aluminum end caps insert into the hollow end of your bars and provide a decorative look to this area. It is recommended that the open end style grips from the choices above be used, or, you can modify ("cut open") the ends of your stock and most aftermarket style "closed end" grips.
    The end caps have a rubber jacket "expansion bolt" that slips into the internal hollow end of the handlebars (about 1-3/8" deep). A supplied hex tool allows you to "tighten" (expand) this internal bolt and secure the end cap tightly (no, it's not going anywhere!) to the bar end.....a simple, 2-minute installation.
    Dual-knurled external rings and a polished, domed end cap makes these a very easy way to add a little bling to your bike! You can choose from a variety of colors to match or contrast with the color scheme of your grips.
    End caps protrude out about 1" (total length) from the end of the bars, and are 28mm in diameter.
    NOTE: you should check the ends of your handlebars before ordering these caps. Although all stock XJ bars have "hollow" bar ends, some aftermarket bars do not, and over the years, many products have been offered (and many "backyard" products used) to create anti-vibrational "stiffness" to handlebars via the insertion of a semi-rigid metal tube into the handlebars. Obviously, such tubes will interfere, or not allow, the installation of the end caps if the tubes are "flush" with the end of the handlebars.
    HCP17515 Aftermarket aluminum DECORATIVE HANDLEBAR END CAPS, set of two does one handlebar. Gloss Black anodized finish.
    $ 17.95
    HCP17516 Aftermarket aluminum DECORATIVE HANDLEBAR END CAPS, set of two does one handlebar. Black Carbon Fiber look, anodized finish.
    $ 18.95
    HCP17519 Aftermarket aluminum DECORATIVE HANDLEBAR END CAPS, set of two does one handlebar. Polished "Chrome" silver anodized finish.
    $ 17.95
    HCP17520 Aftermarket aluminum DECORATIVE HANDLEBAR END CAPS, set of two does one handlebar. Polished Golden anodized finish.
    $ 17.95
    HCP17517 Aftermarket aluminum DECORATIVE HANDLEBAR END CAPS, set of two does one handlebar. Bright "Metallic" Red anodized finish.
    $ 17.95
    HCP17518 Aftermarket aluminum DECORATIVE HANDLEBAR END CAPS, set of two does one handlebar. Bright "Metallic" Blue anodized finish.
    $ 17.95
  2. chacal
    STEERING HEAD BEARINGS:
    OEM and aftermarket steering neck or "tube" replacement bearings bring that brand-new feeling back to your bike, improving handling, braking, and steering performance that has been reduced over the year by wear and tear on the bearings and related parts. We offer both the original Ball Bearings and parts for models so equipped, as well as aftermarket Tapered Roller Bearing Kits needed to upgrade this critical area to the most modern design.
    Does your bike need new steering head bearings?:
    Is this you?:
    - "Basically, I am getting a nasty death-wobble at speed on my bike. How can I tell if the steering head bearings are bad? Head shake?"
    Here's how to check your steering head bearings:
    a) Place the bike on the centerstand, and have a helper sit on the rear of the seat to put the front wheel in the air.
    b) Crouch in front of the bike and grab both front forks toward the bottom.
    c) Try to "wiggle" the forks fore and aft; there should be no play.
    d) With the wheel still elevated, slowly turn the handlebars lock-to-lock. You should feel no binding, looseness, or "bumpity-bumping" in the bars while turning; it should be free and smooth.
    e) From a completely centered position, give the handlebars a gentle push to one side. It should fall to full lock smoothly, without binding. Return the bars to straight (centered) and repeat this test in the other direction. If there is a "detent" or looseness at the center, you probably need new bearings
    f) If your steering (forks) "lock" in the centered position, and take a good amount of pressure to get them off of the centered position, then your steering head bearings are either over-torqued, or, more likely, worn out.
    NOTE: the factory service interval for the re-packing of the steering head bearings with grease is every 10,000 miles (all XJ550, XJ650, XJ750, and XJ1100 models) and every 16,000 miles on the XJ700 and XJ900RK models. The bearings should be inspected every 2,500 - 4,000 miles for looseness, and adjusted as necessary.
    NOTE: all 1992-98 XJ600 Seca II, XJ700, XJ750-X, XJ750RL, XJ900, XJ1100, and all XS1100 models used tapered roller bearings originally; all other XJ models used ball bearings from the factory.
    NOTE2: always use a high-quality, waterproof grease when installing any style of steering neck bearings!
    Ball Bearings and Associated Parts:
    Although we do offer a full selection of original components to rebuild your stock ball-bearing style steering neck system, we highly recommend that you upgrade to the tapered roller bearing style bearing system with one of our Roller Bearings and Seals Kits listed further below.
    The only items that interchange when upgrading from the ball bearings system to tapered bearings are the MAIN CROWN BOLT or NUT, the adjuster RING NUT(S), and the UPPER RACE COVER.
    HCP4533 OEM upper steering crown MAIN BOLT, large flanged bolt that secures the upper steering crown bracket to the bearing shaft stem from the lower steering bracket. Fits all XJ550 models, all XJ650 models, 1983 XJ750 Maxim and Midnight Maxim models, XJ1100, and all XS1100 Special models. NOTE: currently supplied with a bright finish, original bolt could have been bright or black, depending on model.
    $ 7.95
    HCP4535 OEM upper steering crown MAIN BOLT, large flanged bolt that secures the upper steering crown bracket to the bearing shaft stem from the lower steering bracket. Fits all 1984-85 FJ600 and 1982 XJ750 Maxim models.
    $ discontinued
    HCP12951 Aftermarket upper steering crown CHROME-PLATED MAIN BOLT, this is the large bolt that secures the upper steering crown bracket to the bearing shaft stem from the lower steering bracket. Fits all XJ550, 1984-85 FJ600, XJ650, 1982-83 XJ750 Maxim and Midnight Maxim, and XJ1100 models. This two-piece design replacement bolt and separate washer are chrome plated and mirror-polished, and replace the original style flanged bolt correctly. NOTE: this bolt has no provision for the central screw used on the FJ600 and 1982 XJ750 models.
    $ 24.95
    HCP4534 OEM upper steering crown main bolt SCREW, flathead screw that goes through the center head of the HCP4535 main bolt above. Fits all 1984-85 FJ600 and 1982 XJ750 Maxim models.
    $ 1.25
    HCP4514 OEM upper steering crown MAIN NUT, large bolt that secures the upper steering crown bracket to the bearing shaft stem from the lower steering bracket. Fits all XJ700, XJ750-X, and XJ900N models.
    $ 15.95
    HCP4515 OEM upper steering crown MAIN NUT, large bolt that secures the upper steering crown bracket to the bearing shaft stem from the lower steering bracket. Fits all XJ900RK, RL, FN, and F models.
    $ 21.95
    HCP4532 OEM upper steering crown CINCH BOLT, rear, where the steering stem passes through the crown bracket. Use 1 per bike on all XJ650 Maxim and Midnight Maxim models, 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models.
    $ 6.95
    HCP4531 OEM upper steering crown CINCH BOLT, rear, where the steering stem passes through the crown bracket. Use 1 per bike on all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models.
    $ 7.95
    HCP4491 OEM steering neck adjuster RING NUT, the castellated nut used to adjust the tightness of the bearings. XJ550 and FJ600 models used one ring nut, while all other models used two. Fits all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750, XJ900, XJ1100, and all XS1100 models. These nuts require the use of a special ring-nut tool to tighten and remove, and those tools are listed further below. Each:
    $ 27.95
    HCP16438 Aftermarket steering neck adjuster RING NUT, the castellated nut used to adjust the tightness of the bearings. XJ550 and FJ600 models used one ring nut, while all other models used two. Fits all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750, XJ900, XJ1100, and all XS1100 models. These nuts require the use of a special ring-nut tool to tighten and remove, and those tools are listed further below. Each:
    $ 19.95
    HCP4496 OEM upper ball bearing RACE COVER, goes directly above the upper bearing set. Use 1 per bike, for all XJ550, 1984-85 FJ600, XJ650, and XJ750 models.
    $ 10.95
    HCP4495 OEM upper ball bearing TOP RACE. Use 1 per bike, for all XJ550 and 1984-85 FJ600 models.
    $ 11.95
    HCP4487 OEM upper ball bearing BOTTOM RACE. Use 1 per bike, for all XJ550 and FJ600 models.
    $ 6.95
    HCP4494 OEM upper ball bearing TOP RACE. Use 1 per bike, for all XJ650 and XJ750 models.
    $ 65.95
    HCP4486 OEM upper ball bearing BOTTOM RACE. Use 1 per bike, for all XJ650 and XJ750 models.
    $ 65.95
    HCP508 OEM steel BALL BEARING, use 19 per upper and lower bearing set, 38 total per bike. For all XJ550, 1984-85 FJ600, XJ650, and XJ750 models. Each ball bearing:
    $ 9.95
    HCP508SET19 OEM steel BALL BEARINGS, set of 19:
    $ 89.95
    HCP508SET38 OEM steel BALL BEARINGS, set of 38:
    $ 187.95
    HCP1639 Aftermarket steel BALL BEARING, use 19 per upper and lower bearing set, 38 total per bike. For all XJ550, 1984-85 FJ600, XJ650, and XJ750 models. Each ball bearing:
    $ 5.95
    HCP1639SET19 Aftermarket steel BALL BEARINGS, set of 19:
    $ 82.95
    HCP1639SET38 Aftermarket steel BALL BEARINGS, set of 38:
    $ 139.95
    HCP4493 OEM lower ball bearing TOP RACE. Use 1 per bike, for all XJ550 and 1984-85 FJ600 models.
    $ 16.95
    HCP4485 OEM lower ball bearing BOTTOM RACE. Use 1 per bike, for all XJ550 and 1984-85 FJ600 models.
    $ 10.95
    HCP4492 OEM lower ball bearing TOP RACE. Use 1 per bike, for all XJ650 and XJ750 models.
    $ 65.95
    HCP4484 OEM lower ball bearing BOTTOM RACE. Use 1 per bike, for all XJ650 and XJ750 models.
    $ 64.95
    HCP4483 OEM lower bearing DUST SEAL, goes at the very bottom of the shaft. Use 1 per bike, for all XJ550, 1984-85 FJ600, XJ650, and XJ750 models.
    $ 8.95
    HCP20695 Aftermarket upper or lower bearing DUST SEAL, goes at the very bottom of the shaft. Use 1 per bike, for all XJ550, 1984-85 FJ600, XJ650, and XJ750 models.
    $ 6.95
    Tapered Roller Bearings and Associated Parts:
    Both original roller bearings (1992-98 XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models) and kits to upgrade all other models to this improved style tapered bearings are offered. The aftermarket kits that we offer use only the highest quality, precision ground and assembled high-speed bearings available, and include both upper and lower dust seals.
    Tapered bearings offer a vast improvement in performance and durability as compared to stock ball bearings. Additionally, you can increase the ring nut torque value to a slightly higher (25-30 foot-pounds) as opposed to original, thus even further reducing slop and play in your steering. ALWAYS MAKE SURE THAT YOU CHECK FOR BINDING AT ALL POSITIONS, INCLUDING FULL LOCK POSITIONS, WHEN CONVERTING FROM BALL BEARINGS TO TAPERED BEARINGS!
    Here is a great video that shows the installation process for these tapered bearing sets:
    https://www.xjbikes.com/forums/threads/xj750j-refurb.120254/page-2#post-609965
    or, directly on youtube at:
    And the races on models originally equipped with tapered roller bearings (1992-98 XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models) can be especially tricky-tricky to remove, page 2 of this thread shows a creative way of removing them:
    https://www.xjbikes.com/forums/threads/tapered-roller-bearing-insert-removal.130432
    By the way, the rubber seals are installed with their “flat” side against the bearing:
    www.xjbikes.com/forums/threads/triple-tree-dust-seal-which-way.117179/#post-586281
    HCP1911 Aftermarket tapered roller bearings STEERING HEAD BEARINGS AND SEALS KIT, for all XJ550, 1984-85 FJ600, and 1986-90 YX600 Radian models. Contains upper and lower tapered roller bearings, matching races, and an upper and lower dust seal. Note that, originally, no upper dust seals were used on these models, and we feel it is a worthy upgrade to install these seals! NOTE: on some models, the upper bearing race may protrude out of the steering neck tube by 3mm, but this will not affect the operation or performance of the bearings or the steering performance of the bike. By the way, the proper orientation of the dust seal is for the "cup" side of the seal to sit over the bearing face. Also fits all of the following models: 1974-76 RD200, 1973-75 RD250, 1980-82 SR250 Exciter, 1981 SR250 Exciter II, 1987 SRX250, 1988-90 XV250 Route 66, 1995-2007 XV250 Virago, 2008-2012 XV250 V-Star, 1976-77 XS360, 1976-79 RD400, all 1977-83 XS400 models, 1983 XV500 Virago, and 1987-2001 XV535 Virago models.
    $ 59.95
    HCP1912 Aftermarket tapered roller bearings STEERING HEAD BEARINGS AND SEALS KIT, for all XJ650 models and all 1981-83 XJ750 Seca, all XJ750 Euro, and all 1981-84 XJ750 Maxim/Midnight Maxim models. Contains upper and lower tapered roller bearings, matching races, and an upper and lower dust seal. Note that, originally, no upper dust seals were used on these models, and we feel it is a worthy upgrade to install these seals! NOTE: on some models, the upper bearing race may protrude out of the steering neck tube by 1-2mm, but this will not affect the operation or performance of the bearings or the steering performance of the bike. By the way, the proper orientation of the dust seal is for the "cup" side of the seal to sit over the bearing face. Also fits all of the following models: 1973-74 TX500, 1975-78 XS500, 1982-83 XZ550, 1986-88 FZ600, 1986 SRX600, 1973-74 TX650, all 1975-83 XS650 models, 1973-74 TX750, all 1981-83 XV750 Virago, and all 1981-83 XV920 Virago models.
    $ 62.95
    HCP1913 Aftermarket tapered roller bearings STEERING HEAD BEARINGS AND SEALS KIT, fits all 1992-98 XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Contains upper and lower tapered roller bearings, matching races, and an upper and lower dust seal. Note that, originally, no upper dust seals were used on these models, and we feel it is a worthy upgrade to install these seals! By the way, the proper orientation of the dust seal is for the "cup" side of the seal to sit over the bearing face. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-99 FZR600, 1995-07 YZF600, 1998-13 XVS650 V-Star, 1987 FZ700, 1986-87 FZX700 Fazer, 1984-87 XV700 Virago, 1985-88 FZ750, 1987-88 FZR750, 1977-79 XS750 all models, 1988-99 XV750 Virago, 1992-93 TDM850, all 1980-81 XS850 models, 1987-95 FZR1000, 1984-85 XV1000, 1984-85 FJ1100, 1986-2009 XV1100 and XVS1100 Virago, 1986-93 FJ1200, 1985-07 VMX12 V-Max, 1983-84 XVZ12 Venture and Venture Royal, and 1984-93 XVZ13 Venture Royale models.
    $ 59.95
    HCP4488 OEM steering neck upper bearing TANG WASHER, use 1 per bike, for all 1992-98 XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models. This is the uppermost washer used on the steering head shaft assembly.
    $ 13.95
    $ 23.95
    $ 16.95
    HCP4482 OEM steering neck upper bearing FLAT WASHER, use 1 per bike, for all 1992-98 XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models.
    $ 8.95
    HCP4497 OEM upper roller bearing RACE COVER, goes directly above the upper bearing. Use 1 per bike, for all XJ700, XJ750-X, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models.
    $ 8.95
    HCP509 OEM upper tapered roller STEERING HEAD BEARING, fits all XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-99 FZR600, 1995-07 YZF600, 1998-13 XVS650 V-Star, 1987 FZ700, 1986-87 FZX700 Fazer, 1984-87 XV700 Virago, 1985-88 FZ750, 1987-88 FZR750, 1977-79 XS750 all models, 1988-99 XV750 Virago, 1992-93 TDM850, all 1980-81 XS850 models, 1987-95 FZR1000, 1984-85 XV1000, 1984-85 FJ1100, 1986-2009 XV1100 and XVS1100 Virago, 1986-93 FJ1200, 1985-07 VMX12 V-Max, 1983-84 XVZ12 Venture and Venture Royal, and 1984-93 XVZ13 Venture Royale models.
    $ 49.95
    HCP4490 OEM lower tapered roller STEERING HEAD BEARING, fits all XJ600 Seca II, XJ700, XJ750-X, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-99 FZR600, 1995-07 YZF600, 1998-13 XVS650 V-Star, 1987 FZ700, 1986-87 FZX700 Fazer, 1984-87 XV700 Virago, 1985-88 FZ750, 1987-88 FZR750, 1977-79 XS750 all models, 1988-99 XV750 Virago, 1992-93 TDM850, all 1980-81 XS850 models, 1987-95 FZR1000, 1984-85 XV1000, 1984-85 FJ1100, 1986-2009 XV1100 and XVS1100 Virago, 1986-93 FJ1200, 1985-07 VMX12 V-Max, 1983-84 XVZ12 Venture and Venture Royal, and 1984-93 XVZ13 Venture Royale models.
    $ 39.95
    BEARING TOOLS:
    NOTE: SOME OF THE FOLLOWING TOOLS ARE AVAILABLE FOR RENTAL!!: some tools are a one-time or infrequent use tool, so it may be more economical for you to rent them from us, rather than to purchase outright. Please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    A cheap and simple method for bearing removal and installation involves heating the bearing (so the ID of the race grows fractionally) while also cooling the shaft (so its OD shrinks). The combination of these two methods can make bearing work amazingly easier:
    heating:
    shrinking:
    These tricks work well for steering head bearing replacement, wheel bearing replacement, tranny gears, etc.
    Steering Bearings Tools:
    HCP1692 Aftermarket steering head tube BEARING RACE REMOVAL TOOL. This very high quality, split flared-shaft bearing race removal device grasps the edges of the bearing races at four positions and pops them out with ease. Makes a sometimes very frustrating task simple.
    $ 54.95
    HCP7863 Aftermarket steering stem ring nut and shock absorber ADJUSTER TOOL, heavy-duty chrome plated spanner "wrench" is the correct size to work with all XJ-series bike steering stem ring nuts, as well as fitting the adjuster tab on rear shock absorbers (for those models that have non-air adjustable rear shocks). Very high quality, versatile tool to have in your box.
    $ 39.95
    HCP28446 Aftermarket steering stem ring nut and shock absorber ADJUSTER SOCKET, heavy-duty aluminum seep-well spanner socket (1/2” drive) makes tightening and proper torqueing of the upper ring nut a breeze (since this is a socket, rather than a "flat wrench", you can attach it to your torque wrench). Works with all XJ-series bike steering stem ring nuts, and probably many other makes/models as well. This is similar to the Motion Pro # 08-0570 spanner nut socket, but it is deep enough to be used on XJ models (since the steering stem protrudes a much greater distance than what the MP tool is designed to be used with). Very high quality, versatile tool to have in your box. This tool is available for rental.
    $ 69.95
    HCP8041 Aftermarket steering stem Ring Nut ADJUSTER WRENCH, special tanged wrench properly grabs the castellations in the ring nuts and holds firm, preventing the rounding-off of the ring nut when trying to loosen or install them using incorrect tools (such as channel lock pliers). Adjusts to a wide range of sizes to fit most bikes. A professional grade tool.
    $ 99.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    HCP8608 Aftermarket gear and bearing synthetic RED MOLY GREASE. High temperature, water resistant, extreme pressure and high-load strength synthetic organic moly grease is far superior to black moly disulfide (petroleum-based) products. Use on steering neck bearings, wheel bearings, starter motor gears, and swingarm bearings. 14 oz. tube.
    $ 29.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95[/b][/b][/b][/b]
  3. chacal
    SECTION K:
    STEERING/SUSPENSION:
    --Front Suspension: Front suspension Overview.
    FRONT SUSPENSION:
    FORK TUBE PARTS OVERVIEW:
    Your front suspension is called on to do a lot of different tasks, sometimes all at the same time: steering and braking are the two most critical ones that come to mind. Thus the proper operation and integrity of your front forks, and all their parts and pieces, is vital to the proper operation, handling, and safety of your bike. And worn front forks are the primary reason why your front tires wear out quickly, or in an uneven pattern.
    Although your front forks are pretty simple devices....a spring, inside a fluid-filled tube, that serves to soak up road imperfections while maintaining positive-yet-smooth road feel and control....there are quite a few items that need attention and periodic replacement in order to get the proper lifetime and performance out of your system.
    We offer a variety of OEM and aftermarket products and tools needed to properly maintain and service your forks and keep them firmly planted on the road beneath you.
    NOTE: The process of rebuilding your forks seems mystical and difficult to many first-timers, mainly because all of the internal parts are normally hidden from view.....and thus the "fear of the unknown" takes over. The fork mechanisms on most of the XJ-series bikes are really pretty simple, and the entire process of removing your forks from the bike is more time-consuming and involved than the actual re-building procedure. HOWEVER, this is one procedure that we strongly recommend that you have a factory or aftermarket service manual at-the-ready, because there are certain diagrams, specifications, and various "tricks of the trade" that you'll want to know about and follow when doing fork surgery.
    Forks on these bikes generally fall into one of two categories: simple and more-difficult. The simplest forks are the ones that are not encumbered by any additional "enhancements", such as air-assistance or anti-dive features. Here's the scorecard:
    SIMPLE: XJ550 Maxim, XJ550 Seca, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, and XJ700 non-X.
    SIMPLE-PLUS: due to the air-assist function, these forks have a few additional parts (mainly o-rings) that must be attended to, but again, these forks could just as easily fall under the "simple" category above: 1982-83 XJ650 Maxim, XJ650 Turbo, XJ700-X, XJ750-X, XJ750 Maxim and Midnight Maxim, and XJ1100 models.
    INVOLVED: due to both their air-assist and anti-dive functions, these forks are the most difficult to work on.....mainly due to the addition of the anti-dive function, which introduces quite a few additional parts into the internal fork mechanism. You will definitely want a service manual handy while working on these forks, and pay very close attention to the order and orientation of all the small parts during dis-assembly: XJ750 Seca and XJ900RK Seca models.
    The following discussion has some very good pointers, tips, and photographs that detail the fork rebuild process on a 1981 XJ650 Maxim model (one of the "simple" fork systems), and is a good point of reference to help you decide whether the task is something that you wish to attempt yourself or leave to a qualified shop:
    http://xjbikes.com/forums/index.php?threads/8355
    and
    www.youtube.com/watch?v=iO8Lv6a-2Cw
    and
    That last video above gives you very nice 3D views, allows you to brush up on your Urdu (or is it Hindi?), and makes me lust for that lower tube seal puller shown at about 1:45 in the presentation.
    And thanks to user Tabaka45 for his expose of the XJ700 fork system with this great visual review of the procedures needed for rebuilding these forks, which can be seen at:
    http://www.xjbikes.com/forums/threads/fork-seals-85-xj700n-picture-heavy.78389/
    A slightly more complicated type of forking system can be found on the XJ750 Seca and XJ900RK models, due to the use of the anti-dive system. An XJ750 Seca fork system goes under the knife, here:
    http://xjbikes.com/forums/index.php?threads/18730
    and
    http://xjbikes.com/forums/index.php?threads/41895
    and owner "Alive" also has two great image-documentaries in regards to these more "complicated" fork systems. This first one shows the XJ900 (with the anti-dive system) while the second link shows the guts on the later XJ900 models (without the anti-dive system). Note that these images can also be used as a guide for any model front forking system that use the lower bushing on the chrome fork tubes:
    http://xjbikes.com/forums/index.php?threads/44997
    and
    http://xjbikes.com/forums/index.php?threads/4067
    while this photo-journal details the secret, inner workings of the "anti-dive" units found on XJ750 Seca and XJ900RK Seca models:
    http://xjbikes.com/forums/index.php?threads/1860
    And finally, for all you XJ750 Seca owners, here's the secrets to that funny and unique "oil lock valve assembly" used only on these models, and the proper orientation of all of those special washers:
    http://xjbikes.com/Forums/viewtopic/p=159288.html
    and
    And these incredible 3-D renderings of the inner workings of a forking system gives a great visualization of the internal components (it is based on the 1982-83 XJ650 Maxim forks):
    http://xjbikes.com/forums/index.php?threads/29616
    While many people may simply need to replace the OIL SEAL, SEAL CLIP, AND DUST BOOT (sometimes called a DUST WIPER"), we also recommend that whenever you have your forks apart, that you also replace the upper CAP BOLT CIRCLIP or SNAP RING, the cap bolt O-RING or GASKET, the fork oil drain screw GASKET, the damper rod retaining bolt SEAL, and, on air-fork-equipped models, the AIR VALVE O-RINGS.
    Replacing these items now, while the forks are apart, can help prevent leaks and problems from developing down the road.
    On high-mileage bikes, you should also replace the metal slider bushings, taper spindles, and other items.
    Almost all forks usually require the use of a DAMPER ROD RETAINING TOOL to hold the damper rod in place while the lower damper rod retaining screw (in the bottom of the lower fork tube) is being loosened or tighten; otherwise, the damper rod will spin and freely and make removal and installation difficult if not impossible.
    While the basic servicing and rebuilding of your forks is not a specialized skill, it can be somewhat confusing and daunting to people who have never performed such a task before. Since the procedures vary (sometimes greatly) between the different model bikes, we can give no real instructions or recommendations besides this: refer to your factory or aftermarket service manual for the proper procedures and techniques, and if you don't already have such a manual, please purchase one!
    And here’s a couple of other good tips for exceptional fork rebuilding success and performance:
    http://www.motorcycleproject.com/text/stiction_tuning.html
    and:
    http://www.motorcycleproject.com/text/shucking.html
    The general layout of your forks (some models have more or less pieces than others), from the very top of the UPPER (also called the inner or chrome) TUBE moving downwards, is as follows. Note that the items underlined are the ones that we strongly recommend replacing during a fork rebuild procedure.
    - Top Cap (rubber or plastic)
    - Snap Ring, sometimes called a Stopper Ring
    - Cap Bolt
    - O-Ring for cap bolt
    - Spacer (if used)
    - Upper Spring Seat (if used)
    - Fork Spring
    - Damper Rod, with a plastic piston ring in the head
    - Damper Rod Rebound Spring
    - Oil Lock Valve Assembly (XJ750 Seca)
    The following items may need replacing on high-mileage or neglected (dirty oil) bikes, as these items wear quickly if the fork oil was not refreshed regularly and thus was allowed to accumulate grit and abrasive particles:
    - Taper Spindle
    - Metal Slide Bushing #2, a split-ring bushing on the bottom of the chrome tube, not used on all models.
    Air-assisted front forks (1982-3 XJ650 Maxim and Turbo, all XJ750, XJ900RK, and XJ1100 models) also included some or all of the following parts. Note that the items underlined are the ones that we strongly recommend replacing during a fork rebuild procedure.
    - Schrader Valve(s) and their protective screw-on Caps.
    - O-Rings for the schrader valve(s)
    - Air joints (used on XJ650 Turbo, 1982 XJ750 Maxim, XJ900RK, and XJ1100).
    - Cushion Gasket for air joint
    - O-Rings internal to the air joints.
    - Air Hose that connects the air joints.
    - O-Rings for the end fittings of the air joint connecting hose.
    - Stopper Ring on models using air joints.
    Additionally, all XJ650 and XJ750 Midnight Maxim models, and XJ1100 models, had upper tube covers, their related guides and associated gaskets.
    The LOWER (outer) FORK TUBE is populated as follows. Note that the items underlined are the ones that we strongly recommend replacing during a fork rebuild or seal replacement procedure.
    - Dust boot
    - Oil Seal Clip
    - Oil seal Washer (XJ750 Seca, XJ900)
    - Oil Seal
    - Oil seal Spacer (XJ750 Seca, XJ1100)
    - Fluid drain plug and gasket
    - Damper rod retaining bolt and gasket
    - Fork Oil
    The following item may need replacing on high-mileage or poorly-maintained bikes:
    - Metal Slide Bushing #1, a split-ring metal bushing near the top of the lower tube, just below the oil seal.
    Finally, as part of any fork system service you should take the time to check the fork tube alignment.....an often over-looked part of fork system maintenance:
    FORK TUBE ALIGNMENT CHECKING:
    One feature of front fork systems that is typically overlooked is assuring that the two fork tubes are properly aligned with each other........that they are precisely spaced apart from each other, and also exactly aligned with each other in their "rake angles", and not "twisted" in relation to each other. Hitting large objects or deep holes with the front wheel, dropping the bike, slight bending or fatigue of the steering crown or lower bracket, or any other sort of injuries can result in fork tubes that are not perfectly in synch with each other, and that can cause both annoying and dangerous steering, handling, and braking problems.
    Therefore it will be worth your while to check your fork tube alignment periodically, especially after you've had them out for a rebuild.......this will be the most time-efficient opportunity you'll have for this procedure, since it requires removal of the front wheel, headlight, and other assorted front-end components.
    Although the following step-by-step guide was written for BMW owners, the same techniques and guidelines will apply on your bike:
    http://w6rec.com/duane/bmw/fork/title.html
    If you choose not to go through the above process, you can perform the following "poor-man's" fork alignment techniques as described in the following sections:
    http://xjbikes.com/forums/index.php?threads/16145
    and
    http://xjbikes.com/forums/index.php?threads/9323
    and
    and
    http://www.xjbikes.com/forums/threads/dropped-bike-need-help.97887/#post-533302
    and a good video:
    Listed in the following sections you will find our complete list of fork tube rebuild and service parts, arranged BY BIKE MODEL. The description of what each individual fork component part is, and its characteristics, is first review immediately below, and then the list of items by model follows.
    GOING OVERBOARD: FORK SYSTEM SWAPPING:
    Suppose you are adventurous and want to upgrade the entire front end to another model (probably a more modern bike with an upgraded forking system)? What other forks will fit? Here’s a great list of compatible models:
    https://www.xjbikes.com/forums/threads/fork-compatibility.36399/#post-317441
    Here’s a GSXR front end adapted to an XJ550:
    https://www.xjbikes.com/forums/threads/xj-550-with-gsxr750-front-end.85240
    Woo-hoo! An R1 front end swap onto a XJ650 Maxim:
    https://www.xjbikes.com/forums/threads/r1-front-end-slowly-but-surely.127462
    One of the tricky parts of doing a “some other model” fork swap is achieving steering head bearing compatibility…..as it may be necessary to use the donor bike’s upper and lower steering brackets and the bearing shaft “stem” to get things to work properly:
    http://www.allballsracing.com/index.php/forkconversion
    A wheel and brake system swap may also be needed. So…..proceed with caution when attempting such an upgrade.
    UPPER (INNER) FORK TUBES AND PARTS:
    Chrome Inner Fork Tubes:
    ift3) Reproduction UPPER (INNER) (chrome) FORK TUBE, exactly replaces bent or rusted and pitted original tubes. Beautiful hard-chrome plating will last as long as original.
    All fork tubes are precision made from centerless ground, cold-rolled steel tubing, and are then machined to proper tolerances and specifications as original. All inner tubes will fit either the left or right side. Stock length tubes are listed below. Shorter or longer length tubes are available by special order, but are non-returnable or refundable, and must be inquired about directly with us specifying the length desired.
    NOTE: Used upper (inner) chrome fork tubes should always be checked for straightness using V-blocks and a run-out gauge (a local machine shop should be able to do this for your inexpensively), or using a professional quality straight-edge, or roll the tubes along a known flat surface such as a 30" x 12" wide piece of 1/4" thick plate glass (you can buy a cheap piece of scrap plate glass at Home Depot, etc.). Regardless of what anyone tells you, do NOT attempt to straighten bent tubes; they must be replaced!
    Also, you should carefully inspect these chrome tubes for RUSTING or PITS in the area where the fork tube slides through the lower fork tube seal area. If there is only very minor surface rusting in this area, it may be possible to polish it out; however, if the rust has pitted or eaten into or below the surface of the metal, then you will need replace the tubes, as pitting in this area will very quickly chew up any new oil seals, and you'll have leaking seals again in no time! A good image of the type of damage that you need to check for can be seen (one the 2nd page) over at:
    http://xjbikes.com/forums/index.php?threads/42966
    And if you want to (or need to) fix injuries to the tubes (especially in the critical area where the tube slides past the oil seal), well then here's the way to do it properly:
    Inner Tube Gaiter Boots:
    Although not originally used on any XJ-series bikes, these accordion-pleated thick rubber boots fit into the area between the bottom of the steering underbracket and the top of the lower (outer) fork boots, covering and protecting this area from damage, while providing an "old-school" or cafe-racer type look. They are retained to the chrome tube itself (at their top end) via spring clips, and to the top of the lower fork tube via metal screw-clamps.
    For a great visual of how these boots appear when installed properly, see the images at:
    http://xjbikes.com/forums/index.php?threads/16019
    Inner Tube Top Cover/Cap:
    The very top part of your fork tube is rubber or plastic cap, that serves to seal the chrome inner tube from dirt and moisture, as well as providing a decorative look.
    Inner Fork Tube Cap Bolt Circlip, Snap Ring, or Stopper Ring:
    These rings, located at the very top of the chrome legs, underneath the top Cap/Cover, are what hold all the rest of the internal goodies in. They are usually pretty corroded after years of inattention, and it is recommended that they be replaced during any fork renewal process. Be careful when removing these items, they are under spring pressure!
    Inner Fork Tube Cap Bolts and Related:
    This is the rather solid upper "plug" that retains the innards of the fork tube (the spring sits just below it). Some models may incorporate an o-ring onto this cap bolt; other use a gasket below it. Although these cap "bolts" normally don't wear out, their corresponding o-rings or gaskets should always be replaced. Some models with air-adjustable forks have the air valve threaded into this cap bolt, and the o-ring around that air valve should also be replaced during a fork service or rebuild. Always use a liberal coating of pure silicone grease (HCP1714, HCP28407, or HCP20861) when installed these o-rings onto their cap bolts.
    Cap bolts that are retained via a circlip (all XJ550 models, all XJ650 models (except Turbo), and the XJ750 Seca models) should have the circlip replaced. All other models use a threaded cap bolt that screws into the top of the fork tube, and these threads inside the fork tube should be inspected carefully and cleaned up if signs of deterioration or rust, etc. are noted.
    HINT #1: the area where the CAP BOLT seals (at the top of the inner fork tubes) is very susceptible to rust from water accumulation and migration into this area. Rust and pitting in this area will not allow the upper cap bolt o-ring or gasket to seal properly.....a real problem! BE SURE TO INSPECT THIS AREA THOROUGHLY WHEN YOUR TUBES ARE APART. For proper oil and air sealing abilities (on those models equipped with air-assisted forks), you want this area to be as perfectly smooth as is possible.
    If there is only surface rust, you can polish it away on fork tubes that use non-threaded cap bolts (all XJ550 models, all XJ650 models (except Turbo), and the XJ750 Seca models) using either bristle-wire brush HCP10222 or HCP10223, or our HCP9955 cylinder hone, chucked into a drill, and then follow-up with some 600- and 800-grit FINISHING PAPERS (these items are listed further below in the FORK TOOLS section).
    Models using threaded fork cap bolts (XJ650 Turbo, all XJ700 models, all XJ750 models, XJ900RK, and XJ1100 models), should use the butterfly brush HCP10223, chucked into a drill,on the threaded portions and finishing paper on the smooth area above the threads.
    If there are DEEP PITS in this area on the non-threaded style fork tubes, you can try polishing them out using the above method; however, if they have eaten into or below the surface of the metal, then you will either need to "rebuild" the surface (using JB Weld or some type of gel Super Glue formula to fill in the depression, and then sanding and/or honing any "high spots" back down to level).
    It's always a good idea to use a strong smear of pure silicone grease (HCP1714, HCP28407, or HCP20861) on the top edge of the cap bolts after they are installed; this will help to seal that area as much as possible from water migration into the fork tubes and contaminating the fork oil.
    HINT #2: the surfaces where the DAMPER ROD PISTON RING seals (along the entire inner diameter of the inner fork tubes, below the top cap bolt) is also prone to rust from water absorption and accumulation in the fork oil (another great reason to change the fork oil regularly!). Rust and pitting in this area will not allow the damper rod upper plastic piston ring to seal properly.....another real problem! BE SURE TO INSPECT THIS AREA THOROUGHLY WHEN YOUR TUBES ARE APART (a strong flashlight and good eyes are needed, as it will be a "looking down the barrel of a rifle" type of view). For proper oil management abilities and thus fork function, you want this area to be as perfectly smooth as is possible.
    If there is only minor surface rust, you might be able to polish it away using our HCP9255 cylinder hone with the 400-grit stones (listed further below in the FORK TOOLS section) attached to a long extension.
    If there are PITS in this area, there is no real cure for them, and the fork tube should be replaced.
    And what happens when the cap bolt gets stuck (rusted, seized) in place and won't come out? Lots of penetrating oil, lots of tapping (and sometime a few dead blows from a hammer) etc. are about the only simple solutions.
    Heat and cold can also be used: heat on the outer chrome tube in that area, and then some “freezing spray” applied to the cap bolt, and then hammer blows. Don’t worry (too much) about driving the cap bolt down into the tube by an 1/4" or so (and then have the PB Blaster ready to spray along the inside of the fork tube where the plug used to reside). But….be careful, once the plug breaks free the spring pressure behind it will drive it out like a grenade,
    Another method is to rig up a mini “press” across the top of the tube (this is normally done with the fork tube still attached to the steering brackets and installed on the bike. The idea is to screw a bolt down onto the top of the plug, pushing it in, breaking the seizure, etc. Here' a good example of this procedure:
    https://www.xjbikes.com/forums/threads/top-fork-plug-is-stuck.31377/#post-679719
    Inner Tube Fork Springs:
    Top-quality aftermarket progressively wound FRONT FORK COIL SPRINGS don't just "restore" the performance to your front forks, they actually improve it over the original equipment. Spring and suspension technology has come a long way in the 30 years since the XJ model bikes were designed and built, and our line of performance front coil springs will not only get rid of the sags and "mush" in your front end, but will give your bike a crisper, more controllable and predictable ride and handling quality due to their superior design, engineering, and manufacturing.
    Original coil springs are what are known as "dual rate springs"........they have one fixed spring rate until a certain level of compression is reached, and then a firmer, stiffer rate (stronger resistance to compression) takes over (soft, soft, soft, soft, boom! stiff, stiff, stiff.......).
    Replacement springs are what are known as a "progressive rate springs".........meaning that as the load on them increases, they get progressively firmer (softest, softest, soft, less soft, firm, firmer, firmer, really firm), rather than the "all or nothing" transition that takes places with the stock springs. Progressive rate springs tends to give both a smoother, less harsh ride, as well as increasing the performance of the front suspension during enthusiastic driving and the suspension action that it creates.
    One pair of front springs does both front forks. Please note that some models will require the use, re-use, modification of the original, or the fabrication of the front spring spacers (and some models do not require the use of spacers at all).
    NOTE: the more tightly coiled area of your fork springs (whether original or aftermarket) should be towards the TOP of the fork tube.
    Inner Fork Tube Spring Spacers, Rebound Springs, and Spring Seats:
    Used along with the coils springs, these various pieces allow for the proper pre-load and spring placement within the upper fork tube. Note that not all models used spring spacers.
    Inner Tube Metal Slider Bushings:
    These split-ring bushings fit over into a recess at the bottom of the inner chrome tube, and along with the lower tube slider bushing, serves as a both a tube guide and absorbs the majority of the side loading of the inner tube as it passes through the lower tube. If the fork oil hasn't been changed regularly, grit and moisture in the oil eventually wear down these slides, and thus require their replacement.
    Inner Fork Tube Damper Rod:
    Called a "compression cylinder" in Yamaha-engineering-speak, this precisely machined tube manages the oil flow within the fork system via oil bleed holes and passages. The top "head" of this damper rod rides within a flanged area of the upper (inner) fork tube and is also the lower spring seat for the coil spring, while the bottom of this rod is internally-threaded and bolted to the bottom end of the lower (outer) fork tube----and thus this rod is what actually makes the mechanical connection and physically "joins together" the upper and lower fork tubes.
    HINT: check your the damper rod for straightness using a run-out gauge or a straightedge (or the edge of a machine-cut piece of flat glass).
    The damper rod head has a plastic split-ring "piston ring" that should be inspected and replaced during a fork rebuild.
    Inner Fork Tube Taper Spindle:
    This oddly-named part is actually a tapered metal bushing that surrounds the lower shaft of the damper rod. If your taper spindle shows signs of wear (flat spots, gouges, scoring, etc.) then it should be replaced.
    Inner Fork Tube Air System Parts:
    Air Joint O-Rings:
    These rubber o-rings provide and air-tight seal among the various component pieces used in air-assisted fork systems. These seals and o-rings should always be replaced during a fork rebuild procedure. And always use a generous coating of pure silicone grease (HCP1714, HCP28407, or HCP20861) when installed these o-rings onto their cap bolts.
    Air Inflation Valves and O-Rings:
    NOTE: the top caps that are used on all of the air valves listed below are NOT the same as those used on tire valves, as the ones used on the fork air valves are much shorter.
    Inner Fork Tube Retaining Hardware:
    Your chrome fork tubes (properly called the "inner" fork tubes) are held to your bike via the upper and lower steering brackets. The upper bracket is called the "crown bracket" and your handlebars bolt to this bracket, while the lower bracket is called, quite logically, the under-bracket. The under-bracket has the large diameter stem that goes up through the steering neck tube (that is part of the frame), and within that tube are the steering Neck (or "Head") Bearings. This stem is then bolted to the crown bracket after it has emerged from the top side of the frame steering neck tube.
    The inner fork tubes are located in round bores on both sides of the upper crown bracket and the lower under-bracket. These bore are "split" and via proper tightening of the special Cinch Bolts, the proper tension is applied to firmly locate the fork tubes to the rest of the bike.
    HINTS:
    a) there may be oxidation on the triple tree clamps so it might be necessary to clean the inner diameter of these upper and lower bracket clamp bores using a rotary tool with a brass wire brush wheel.
    b) do NOT grease or lubricate the inner diameter of these upper and lower bracket clamp bores or put any anti-seize or other protective coatings inside these clamps, as such products will impair the effectiveness of their grip.
    Crown Bracket Inner Fork Tube Retaining Hardware:
    For the upper (crown) bracket, the various cinch bolts, washer, and nuts that retain the fork tube to this bracket.
    Under-bracket Inner Fork Tube Retaining Hardware:
    For the lower (under) bracket, the various cinch bolts, washer, and nuts that retain the fork tube to this bracket.
    LOWER (OUTER) FORK TUBE PARTS:
    Dust Wiper Seals:
    ft1) OEM and aftermarket lower fork tube Dust Wiper Seals will stop grit and moisture from entering the lower tube cavity and chewing up the oil seals. These dust wiper seals are the things you see at the very top of the lower fork tube.
    Oil Seals:
    ft1) OEM and aftermarket lower fork tube Oil Seals will stop those leaks and restore the performance to your front suspension and braking system. We offer three different grades of seals to satisfy everyone's needs:
    a) OEM original equipment double-lip rubber seals provide the same quality and life expectancy as the originals. Although these are not the least expensive seals, no one ever went wrong with using original manufacturer products. Oil seals come with the internal tension spring when they were originally equipped as such.
    NOTE: all oil seals install with the sharp, tapered "point" of the oil seal internal wiper lips pointing "down", so that these lips can wipe the oil from the chrome tube as it exits the lower tube.
    b) Standard grade aftermarket double-lip BLACK OIL SEALS are the same or better quality than the OEM seals, but normally at a better price.
    c) Premium grade aftermarket seals are a significant development in fork seal technology and feature a specially designed lip and spring tensions that result in a much lower sliding friction between the seal and the fork tube. Lower friction prevents un-wanted fork movement resistance from occurring, for instance, when initially entering a corner, or braking. Ideally, you want the inner forks to move smoothly and without any "choppiness" past the lower tube seal, rather than a "starting and stopping" motion due to tube-to-seal "stiction". These seals deliver the lowest possible friction coefficient of any of our seals, and are well worth the extra cost!
    HINT: the areas in the lower fork tube where the OIL SEAL and the SLIDER BUSHING are located (at the top of the lower fork tubes) should be inspected carefully after dis-assembly and seal/bushing removal for any nicks, gouges, or imperfections. For proper oil seal slider bushing seating and fitment, you want this area to be as perfectly smooth as is possible.
    It is recommended that you polish these areas using some 200-, 400-, 600-, and 800-grit FINISHING PAPERS.
    ALSO---it's never a bad idea to use some of the 100% Silicone Grease as an "assembly lube" when installing any of these oil seals:
    HCP28407 Aftermarket o-ring, oil seal, and gasket installation pure SILICONE GREASE. This small 5-gram (1/6-oz) snap-open "pillow packet" is enough for a few small oil seals, dozens of o-rings, and the like. Each:
    $ 4.95
    HCP1714 Aftermarket o-ring, oil seal, and gasket installation pure SILICONE GREASE. This generous 14-gram (1/2-oz.) tub goes a long way, because just like Brylcreem, "just a little dab will do ya'!" Each:
    $ 9.95
    HCP20861 Aftermarket industrial-strength SILICONE LUBE, in a large 16-ounce aerosol can. Concentrated silicone sprays on wet, and then dries to a super-slick, clear, non-greasy, non-staining finish. Resists moisture, stops squeeks, prevents binding on all types of surfaces (wood, metal, plastic, rubber, even fabrics). Won't wash away, protect against rust and corrosion, stable from -100 degrees up to 500-F. This fluid is also a great choice for use as installation lubricant for o-rings, oil seals, etc. (similar to our HCP1714 or HCP28407 silicone grease paste) or wherever petroleum-based lubricants are not recommended.
    $ 44.95
    c) If needed, in addition to all of the above, you can gently heat (heat gun or even a 1500W hair dryer) the area of the fork tube where the seal fits.....this will expand that area a tiny bit, enough to make seal install a bit easier.
    d) make sure you drive the seal in with a proper seal driver, or one that is fabricated correctly to push ONLY on the seal.....a proper sized OD flat washer can be a big help in this regard. The seal needs to be driven fully in place so that it "bottoms out" against the flat ledge in the fork tube......otherwise, it will be extremely difficult (if not impossible) to re-install the seal retaining clips.
    Although fork seals can be installed without removing the inner chrome fork tube from the lower tubes, the proper procedure is to dis-assemble the forks completely, removing the inner tube from the lower tube. Trying to remove the oil seal from the lower tube while the inner tube is still installed risks damaging the lower tube, since it is very difficult to remove the old oil seals from the lower tube while the chrome upper tube is still in place.
    Here is a good video on the entire process:
    Oil Seal Retaining Clips:
    These C-shaped metal clips retain the lower tube Oil Seals and should be replaced along with the oil seals.
    Lower Tube Metal Slider Bushings:
    These split-ring bushings press into the lower tube, below the oil seal, and serves as a both a tube guide and absorbs the majority of the side loading of the inner tube as it passes through the lower tube. If the fork oil hasn't been changed regularly, grit and moisture in the oil eventually wear down these slides, which have a teflon-like coating on their inner bearing surface to eliminate resistance.
    Lower Fork Tube Oil Drain Screw and Gasket:
    These small phillips-head screws, near the bottom of the lower tubes, allows you to drain the tubes prior to doing an oil change, or before tube removal and dis-assembly for seal replacement or other service work. The gasket that goes behind this screw should always be replaced in order to prevent oil leaks.
    HINT: this gasket has a very small, very fine recessed area around its inner diameter on one side only..........and that side fits against the bottom of the drain screw. The perfectly flat side of the gasket goes against the fork tube drain port opening. We suggest that all pressure be taken off of the front forks (put the bike on its centerstand, and lift the front wheels off the ground) before you open the drain screw); otherwise, pressurized oil can squirt out at a significant rate and force!
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    These large socket-head cap screws, on the very bottom of the lower tubes, retains the inner tube damper rods to the lower tubes, and must be removed before the chrome inner tube can be separated from the lower tube for dis-assembly for seal replacement or other service work.
    This screw is held in tight!----but it must be removed in order to take the fork upper and lower tubes apart in order to replace the lower tube seals, or any other internal parts.
    The gasket that goes under this bolt should always be replaced in order to prevent oil leaks. These bolts, when re-installed, should be treated with a low-strength thread-locking compound.
    The HCP4402 Damper Rod Retaining Tool, listed further below in the "Fork Tools" section of parts, is needed on some models to hold the damper rod itself (to prevent it from spinning freely) while this damper rod retaining screw is loosened and removed.
    Lower Fork Tube Axle Retaining Hardware:
    A variety of fasteners were used to cinch the front axle shaft to the lower fork tubes. Note that models with the front axle in a leading position to the fork tubes only used one retaining bolt (on the right side lower fork tube), while models with the front axle along the lower fork tube centerline (BELOW the fork tubes) used two retaining bolts (one on each lower fork tube).
  4. chacal
    SECTION K:
    --Front Suspension: Forks, seals, springs, hardware, etc.
    FORK TUBE REBUILD PARTS BY BIKE MODEL:
    XJ550 and XZ550R Vision MODELS FORK TUBE PARTS:
    NOTE: items marked below in red are the parts typically needed when doing a basic fork system rebuild.
    A good visual review of the procedures needed for rebuilding these forks can be seen at:
    XJ550 Maxim and XJ600 Seca II owners may also wish to note the procedure needed to separate the inner tubes from the lower tubes (the "battering ram" procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    XJ550 and XZ550R Vision FORK TUBE REBUILD PARTS KITS:
    XJ550 Maxim and Seca models:
    We now offer both a BASIC FORK REBUILD KIT and PERFORMANCE FOR TUBE REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike.
    NOTE: the lower tube “dust boots” (sometimes called dust seals) are not included in the basic fork tube rebuild kits, but are available separate and can be found further below.
    Basic fork rebuild kit contains at least the following items:
    - cap bolt o-rings.
    - cap bolt retaining rings.
    - standard quality lower fork tube oil seals.
    - oil seal retaining clips.
    - oil drain screws and gaskets.
    - damper rod bolts and crush washers.
    - damper rod head piston rings
    HCP20611 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all XJ550 Maxim, 1980-81 XJ650 Maxim and Midnight Maxim models, 1982 XJ650RJ Seca, and XJ650 Euro models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 89.95
    HCP20611DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all XJ550 Maxim, 1980-81 XJ650 Maxim and Midnight Maxim models, 1982 XJ650RJ Seca, and XJ650 Euro models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 127.95
    HCP20603 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all XJ550 Seca models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 109.95
    HCP20603DB Aftermarket fork tubes BASIC+FORK REBUILD KIT. For all XJ550 Seca models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 139.95
    Performance fork rebuild kits contain all of the basic rebuild kit components, along with:
    - performance fork springs (and related springs seats and pre-cut spring spacers in the XJ550 Maxim kit).
    - upgraded, high-performance lower fork tube oil seals.
    - lower fork tube dust boots.
    HCP20602 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all XJ550 Maxim models. One kit does both front tubes.
    $ 399.95
    HCP20604 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all XJ550 Seca models. One kit does both front tubes.
    $ discontinued
    We now offer these BASIC FORK REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike.
    - cap bolt o-rings.
    - air system o-rings and air valve cores (as used on 1983 models)
    HCP30035 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1982-83 XZ550R Vision models. One kit does both front tubes. NOTE: this set includes the cap bolt Schraeder (air) valve o-ring as used on 1983 models only. This set does not include the lower fork tube dust boots.
    $ 109.95
    HCP30035DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1982-83 XZ550R Vision models. One kit does both front tubes. NOTE: this set includes the cap bolt Schraeder (air) valve o-ring as used on 1983 models only. This set includes the lower fork tube dust boots.
    $ 139.95
    Of course, all of the component pieces can be ordered as individual pieces from the selections listed below, as well as non-typical wear items (inner tubes, damper rod piston rings, taper spindles, cap bolts, etc.), as well as the fork oil and specialty tools needed to properly restore or enhance your front suspension performance.
    HCP8522 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ550 Maxim models, each:
    $ 299.95
    HCP8522SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8523 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1981-1983 XJ550 Seca models. NOTE: these tubes use a circlip-retained upper cap bolt (HCP8255); some models may have used threaded upper cap bolt, in which case you should order the HCP8524 fork tubes listed below. Please verify which style you have before ordering! Each:
    $ 299.95
    HCP8523SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8524 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1981-83 XJ550 Seca models. NOTE: these tubes use a threaded upper cap bolt; most models used the circlip-retained cap bolt fork tubes HCP8523 listed above. Please verify which style you have before ordering! Each:
    $ 299.95
    HCP8524SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP10806 Aftermarket front fork tube GAITER BOOT, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models. Does not include attaching hardware. Heavy-duty design has equal spacing between each accordion pleat. Each:
    $ 99.95
    HCP10806SET2 Aftermarket front fork tube GAITER BOOTS, set of 2:
    $ 179.95
    HCP10941 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10942 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10943 Aftermarket front fork tube GAITER BOOTS, red pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10938 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP10939 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP11420 Aftermarket fork tube gaiter boot LOWER RETAINING SPRING-CLAMP. Black powdercoated wire-spring type clamp has that old-time look and feel to it. Secure the lower end of the gaiter boot to the top of the lower (outer) fork tube. Fits all XJ-series models. Use 1 per tube, each:
    $ 14.95
    NOTE: gaiter boots normally do not require any type of retainer at their upper end, as the tight friction fit between the boot opening and the chrome tube prevents migration of the boot. If movement seems to occur, then we recommend the use of thin, black electrical wire ties to cinch the boot flange tightly to the tube.
    HCP8252 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: XJ550 all, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, the 1982 XJ650RJ Seca, and 1981 XJ750 Seca models. Each:
    $ discontinued
    HCP22882 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: XJ550 all, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, the 1982 XJ650RJ Seca, and 1981 XJ750 Seca models. Each:
    $ 19.95
    Inner Fork Tube Cap Bolts and Related Hardware:
    HCP8255 OEM inner fork tube CAP BOLT, fits either side. Used on all XJ550 models with circlip-retained cap bolts, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 59.95
    HCP8294 OEM inner fork tube CAP BOLT, fits either side. Used on all XJ650 Turbo, XJ750-D, and XJ750-P (24L model), and 1982 XZ550R Vision models. NOTE: these cap bolts require a special inverse-hex tool HCP9238 to properly remove and install. Each:
    $ 69.95
    HCP9238 Aftermarket fork upper cap bolt REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive cap bolt used on the top of the inner fork tubes on all 1984 FJ600, XJ650 Turbo, XJ700 non-X, XJ750-D, XJ750P (37H) model, all XJ900RK, RL, N/FN, and F, and 1982 XZ550R Vision models.
    $ 19.95
    HCP2323 OEM inner fork tube top cap bolt RETAINING RING, fits either the left or right side tube of the following models: all XJ550 models, all XJ650 Euro models, XJ650 Maxim, Midnight Maxim, and XJ650RJ Seca models. Each:
    $ 8.95
    HCP20715 Aftermarket inner fork tube top cap bolt RETAINING RING, fits either the left or right side tube of the following models: all XJ550 models, all XJ650 Euro models, XJ650 Maxim, Midnight Maxim, and XJ650RJ Seca models. Each:
    $ 5.95
    HCP2324 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ550 models, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 7.95
    HCP20699 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ550 models, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 5.95
    HCP8241 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 14.95
    HCP20707 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 9.95
    HCP22248 Aftermarket inner fork tube cap bolt Air Valve O-RING, fits the following models: 1980-81 XS1100 Standard models and 1983 XZ550R Vision models. Use 1 per tube. Each:
    $ 7.95
    HCP9434 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ550 Seca models. Front spring spacers are not required with these springs. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 4 cc's more fork oil (for a total of 234cc's per tube) when installing these springs. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ discontinued
    HCP9433 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ550 Maxim models. Front spring spacers are not included with these springs, and you will need the installation of an HCP8239 spring seat (one for each spring) and the fabrication of a 31.50mm long spacer when replacing stock springs. You can use the HCP8284 spring spacer tube (stock for 1982-83 XJ650 Maxim models) and cut it down to the proper length; one tube will provide enough material to do both springs and fork tubes…..or you can order the HCP21018 spacers tubes which are already cut to the correct length. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 13 cc's more fork oil (for a total of 285cc's per tube) when installing these springs and using the stock thin-wall metal spacer tubes as recommended above. The use of other type of spacers (thick-wall PVC pipe, for instance) will change this recommended fork oil volume by an unknown amount. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 239.95
    HCP8239 OEM inner fork tube SPRING SEAT, fits either side. Use on all XJ550 Maxim models when installing the HCP9433 replacement springs above. Each:
    $ 19.95
    HCP20994 Aftermarket inner fork tube SPRING SEAT, fits either side. Use on all XJ550 Maxim models when installing the HCP9433 replacement springs above. Each:
    $ 14.95
    HCP8284 OEM inner fork tube SPRING SPACER TUBE, fits either side. Use on all XJ550 Maxim models when installing the HCP9433 replacement springs above. One spacer tube will provide enough material to do both springs.
    $ 14.95
    HCP21018 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all XJ550 Maxim models when installing the HCP9433 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9433 springs; use 1 spacer per tube.
    $ 19.95
    HCP21018SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    Inner Fork Tube Spring Spacers, Rebound Springs, Damper Rods, and Spring Seats:
    HCP8253 OEM inner fork tube damper rod REBOUND SPRING, fits either side. Used on all XJ550 models, all XJ650 models (except Turbo), all 1983-84 XJ750 Maxim and Midnight Maxims, 1978-79 XS1100 Standard models, 1980 XS1100 (3X0) Euro model, 1989 and 1995-2008 XV250 Virago, 2008-2020 XV250 V-Star, 1983 XZ550RK, 1983 XV500, 1983-92 YZ80, 1980-81 YZ100, 1976-78 YZ250, and 1976 YZ400 models. Use 1 per tube, each:
    $ 39.95
    HCP13656 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all XJ550, XJ650, all XJ750 (except XJ750 Seca and XJ750-X models), and 1978-79 XS1100 Standard models. Use 1 per fork tube. Each:
    $ 17.95
    HCP3085 OEM upper (inner) fork tube TAPER SPINDLE, fits either side. Fits all XJ550 models, 1984 FJ600, all XJ650 models, all XJ700 and XJ750-X models, all XJ750 Maxim and Midnight Maxim models, XJ900 N/FN and F models, all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 31.95
    HCP10702C Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: all XJ550 Maxim and 1982 XJ650 Turbo models. One slider does one tube. Each:
    $ 59.95
    HCP10702CSET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 114.95
    INNER FORK TUBE RETAINING HARDWARE:
    HCP4529 OEM crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP21973 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright yellow-zinc finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP21974 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP21975 Aftermarket crown bracket fork tube CINCH BOLT, 18-8 stainless steel, hex-head bolt with a bright finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP4960 OEM under-bracket fork tube CINCH BOLT, alloy steel, socket head cap screw with a bright finish. Use 2 per side on all 1981-83 XJ550 Seca models, and 1 per side on all 1984-85 FJ600 models. This bolt also secures the horn bracket to the under-bracket. Each:
    $ discontinued
    HCP21945 Aftermarket under-bracket fork tube CINCH BOLT, alloy steel, socket head cap screw with a bright finish. Unlike the original fastener, this bolt does not have a captive lock-washer, and a separate lock-washer should be used. Use 2 per side on all 1981-83 XJ550 Seca models, and 1 per side on all 1984-85 FJ600 models. This bolt also secures the horn bracket to the under-bracket. Each:
    $ 4.95
    HCP21946 Aftermarket under-bracket fork tube cinch bolt LOCK WASHER, zinc-plated alloy steel with a bright finish. Use 1 per bolt on all 1981-83 XJ550 Seca and 1984-85 FJ600 models. Each:
    $ 1.25
    HCP21947 Aftermarket under-bracket fork tube cinch bolt LOCK WASHER, 18/8 stainless steel with a bright finish. Use 1 per bolt on all 1981-83 XJ550 Seca and 1984-85 FJ600 models. Each:
    $ 1.25
    HCP21948 Aftermarket under-bracket fork tube cinch bolt LOCK WASHER, black oxide-coated alloy steel. Use 1 per bolt on all 1981-83 XJ550 Seca and 1984-85 FJ600 models. Each:
    $ 1.25
    HCP2537 OEM crown bracket fork tube FLAT WASHER, alloy steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 3.95
    HCP26192 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 1.95
    HCP26193 Aftermarket crown bracket fork tube FLAT WASHER, 18/8 stainless steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 2.95
    HCP17110 Aftermarket crown bracket fork tube FLAT WASHER, 316 stainless steel, dull finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 3.95
    HCP26189 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, black finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 3.95
    HCP4528 OEM crown bracket fork tube CROWN NUT, alloy steel, bright finish. For the following models: use 1 per fork tube (2 per bike) on all XJ550, 1980 XJ650 Maxim, and 1979-1980 XS1100 Special models. Use 1 per tube cinch bolt and 1 on the rear lateral stem pinch bolt (total of 3 per bike) on all 1978-80 XS1100 Standard models. Each:
    $ 8.95
    HCP10959 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, alloy steel, bright finish, same height as the HCP4240 and HCP4528 crown nuts. Each:
    $ 3.95
    HCP21940 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 5.95
    HCP21941 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, chromed steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 8.95
    HCP18011 Aftermarket cinch bolt head protective CAP. Smooth, black plastic cap snaps over the head of the fork tube cinch bolts, giving them a very "modern" look, protecting the head from rust. Fits all OEM or aftermarket bolts with a 12mm hex or socket head. Each:
    $ 4.95
    HCP3652 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all XJ550 models, all XJ650 models, XJ750-D, all 1982-83 XJ750 Maxim models, and XJ900 N/FN and F models. Each:
    $ 9.95
    $ 4.95
    LOWER (OUTER) FORK TUBES AND PARTS:
    Dust Wiper Seals:
    HCP1820 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ550 Maxim, all XJ650 Euro models, and XJ650RJ Seca models. One seal does one tube. Each:
    $ 49.95
    HCP21555 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ550 Maxim, all XJ650 Euro models, and XJ650RJ Seca models. One seal does one tube. Each:
    $ 29.95
    HCP1821 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ550 Seca and 1982-83 XZ550R Vision models. One seal does one tube. Each:
    $ 27.95
    HCP21556 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ550 Seca and 1982-83 XZ550R Vision models. One seal does one tube. Each:
    $ 21.95
    Oil Seals:
    NOTE: when installing oil seals, make sure that the area where the seal will fit into is clean, free of any nicks and burrs, and that the lower tube metal slide bushing is fully seated. Oil seals install with the large opening facing down, into the tube, and on most seals, the small cast lettering and numbering on the seal faces upwards.
    Seals are designed to be installed with a seal driver of some type, although a properly sized piece of hard plastic tubing, perhaps with a proper sized metal washer on top of the seal to "spread the load", works as well. Always make sure that oil seals are fully seated and not damaged or installed in a crooked or cocked manner.
    HCP1814 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago. One seal does one tube. Each:
    $ 21.95
    HCP20643 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 32.95
    HCP1716 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 39.95
    HCP20112 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. NOTE: these seals feature a specially design lip and spring tensions that result in a much lower sliding friction between the seal and the fork tube. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 44.95
    HCP1815 OEM lower fork tube OEM OIL SEAL, fits either left or right tube on the following models: : all XJ550 Seca and 1982-83 XZ550R Vision models. One seal does one tube. Each:
    $ 29.95
    HCP20642 Aftermarket standard quality lower fork tube BLACK OIL SEALS, fits all of the following models: all XJ550 Seca and 1982-83 XZ550R Vision models. Comes packaged as a pair of seals, enough to do both forks.
    $ discontinued
    HCP1717 Aftermarket premium-quality lower fork tube BLACK OIL SEALS, fits all of the following models: all XJ550 Seca and 1982-83 XZ550R Vision models. Comes packaged as a pair of seals, enough to do both forks.
    $ discontinued
    HCP1827 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, all XJ650 Euro, XJ650 Maxim, and XJ650 Midnight Maxim models, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim models. All fits the following no-XJ models: 1983 XV920 K/MK, 1980-81 XS850 LH/SH/SG, 1982-83 XZ550RK, and 1983 XV750MK models: One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 9.95
    HCP20716 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, all XJ650 Euro, XJ650 Maxim, and XJ650 Midnight Maxim models, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim models. All fits the following no-XJ models: 1983 XV920 K/MK, 1980-81 XS850 LH/SH/SG, 1982-83 XZ550RK, and 1983 XV750MK models: One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    HCP19996 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 49.95
    HCP19996SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10706 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 39.95
    HCP10706SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    HCP10707C Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Seca and all XJ550 Euro models. One slider does one tube. Each:
    $ 39.95
    HCP10707CSET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    HCP5187 OEM lower fork tube oil DRAIN SCREW, use one per tube. Panhead, phillips-drive, alloy steel with a black finish. Note that the black screw was used on models with black lower fork tubes (1982-83 XJ550 Seca, FJ600, 1995 XJ600 Seca II, XJ650 Midnight Maxim, XJ650 Turbo, XJ750 Midnight Maxim, 1981-83 XJ750 Seca and XJ750 Euro models, and some XJ750P models 37H). All other models with natural aluminum lower fork tubes used a screw with a bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 4.95
    HCP29817 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead, phillips-drive, alloy steel with a black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29005 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive zinc-plated alloy steel. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29006 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6710 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ discontinued
    HCP6712 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6711 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP7111 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 8.95
    HCP7111SET2 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 16.95
    HCP21320 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 5.95
    HCP21320SET2 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 10.95
    HCP8233 OEM fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 9.95
    HCP28069 Aftermarket fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 6.95
    HCP8234 OEM fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 16.95
    HCP12950 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 10.95
    w) Lower Fork Tube DAMPER ROD RETAINING TOOL. This long aluminum tool, with proper sized nuts on each end, is used to retain the top of the fork damper rod (in the bottom of the chrome tube) when removing or installing the damper rod retaining screw. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ-series bikes except XJ600 Seca II, 1981-83 XJ750 Seca, XJ1100, and all XS1100 Special and Midnight Special models. This tool will make the disassembly of your upper tube from the lower tube much easier! NOTE: this tool is available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP4402 Aftermarket DAMPER ROD RETAINING TOOL.
    $ 44.95
    Lower Fork Tube Speedometer Cable Hardware:
    HCP2182 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 6.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP315 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, bright finish, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models.
    $ 3.95
    HCP1902 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, black finish, use 1 per bike on the following models: XJ650 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, XJ750 Midnight Maxim, and XS1100 Midnight Special models.
    $ 6.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP4827 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ550 Maxim, XJ650 Maxim, and 1983 XJ750 Maxim models.
    $ 11.95
    HCP4828 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per tube (2 per bike) on both the left and right side lower fork tube. For all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), and XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
    HCP2537 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all 1981 XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP3945 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all 1982-83 XJ550 Seca models. Use 2 per tube (4 per bike) on both the left and right side lower fork tube. Each:
    $ 4.95
    HCP26192 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 1.95
    HCP26193 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 18/8 stainless steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 2.95
    HCP17110 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP26189 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP2185 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 6.95
    HCP2391 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 2 per bike on the following models: all 1982-83 XJ550 Seca, all XJ650 Turbo models. Use 1 per bike on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 7.95
    HCP16209 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 2.95
    HCP16100 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    Lower Tube ID Decal:
    HCP8500 Aftermarket suspension ID DECAL, small black rectangular decal with silver lettering "KYB", used as follows:
    - mounts directly above the lower fork tube drain screw and faces the rear of the bike. Use 1 on the left side fork tube on XJ550 Maxim, all XJ650 (except Turbo) models, all XJ700 and XJ750-X models, use 1 on the right side fork tube on XJ550 Seca (Noth American) models, and 1 on the left side fork tube on XJ550 Euro models.
    - mounts directly above the lower fork tube hose routing bracket boss and faces the rear of the bike. Use 1 on the left side fork tube on all YX600 Radian models.
    - mounts directly below the lower vertical adjuster stop peg on the rear shock absorbers. Use 1 per shock on all XJ550 models and all XJ650 (except Turbo) models original rear shocks.
    Each:
    $ 12.95
    HCP25301 Aftermarket AIR SUSPENSION WARNING DECAL, small clear rectangular decal with white lettering, graphics, and border, mounts directly above the left lower fork tube drain screw and faces “outward” (top edge of the decal is aligned just above the centerline of the upper mounting hole for the brake caliper). Used on XJ550 non-North American models (with air-assisted forks) and all XJ650 Turbo models. NOTE: this decal is identical to the HCP10774 decal above, except this decal does not have/ the small “air pressure” diagram on it. Either one is “correct” for the XJ650 Turbo model bikes, although we suspect that this version (without the air fill diagram) is an earlier-production version.
    $ 12.95
    FORK SYSTEM SERVICE TOOLS:
    Assembly and Dis-assembly Tools:
    NOTE: many of these tools are available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    $ 44.95
    HCP26093 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 35-36mm fork tubes: XJ550 Seca, FJ600, XJ600 Euro, all XJ650 (except 1983 Turbo), all XJ750 air-cooled (except XJ750P (37H Police) and X750-D models), and XJ900 N/FN models.
    $ 47.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Fork Tube Cleaning and Polishing:
    HCP28489 Fork Tubes DEEP REACH CLEANING BRUSH. This 36" long brush features polyester bristles that will reach deep inside the forks tubes to clean away grit and oil sludge residue that cannot otherwise be reached or disturbed. Has a comfortable easy-grip plastic handle and flexible twisted-wire shaft. Use with your favorite cleaning solvents to get the insides of the fork tubes free of contaminants.
    $ 52.95
    ft4) These stainless-steel, bristle-wire DE-BURRING BRUSHES will work wonders on the upper cap bolt area on both the threaded and the non-threaded style of fork tubes. Tubes that use threaded cap bolt (all XJ650 Turbo, all XJ700 models, XJ750-X models, XJ750 Maxim and Midnight Maxim, XJ900RK, and XJ1100 models) should use the HCP10223 butterfly brush; non-threaded tubes can use either the HCP10222 spiral brush or the HCP10223 butterfly brush. Both style brushes have stems that are designed to be used in a standard power drill, and should be used at 850 rpm's or less. These brushes will make quick and meaningful work of the cleaning and polishing of this critical area on your upper fork tubes.
    HCP10222 Aftermarket stainless-steel double-density spiral DE-BURRING BRUSH, for use on fork tubes without a threaded cap bolt.
    $ 13.95
    HCP10223 Aftermarket stainless-steel high-density "butterfly-wings" DE-BURRING BRUSH, for use on fork tubes with or without threaded cap bolts.
    $ 14.95
    FORK OIL:
    Unlike motor oil or gear oil, fork oil's major purpose is not lubrication.....rather, it acts as part of the suspension system, providing both damping and rebound control functions. The different "weight" or viscosity of fork oils allows you to modify the ride and handling characteristics of your bike in a fairly simple way.
    And yes, it IS a lubricant also!
    Although many people----including, unbelievably, Yamaha itself----recommends the use of engine motor oil as a substitute for fork oil, this is not a very good idea. Engine oils (or any multi-viscosity oil) uses additives and detergents that, while wonderful in for their intended purposes inside an engine block, tranny case, or rear drive unit, are not such a good idea inside forks. Forks operate at a much lower temperature and temperature RANGE than engine and drivetrains do, and thus do not need all those additives. And fork oil also tends to contain higher percentages of molybdenum disulfide and anti-foaming agents than engine or gear oil, both of which are very important to proper fork operation.
    As a small example.......most motor oils are of a multi-viscosity nature (such as 10W30) which change their viscosity in relation to their temperature (thin when cool, thicker as they warm). A very necessary and useful feature for an engine, where you do not want your oil thinning out as the engine warms up. Not such a good idea for your suspension----unless for some reason you WANT your handling characteristics to change (get stiffer) as the forks heat up!
    Proper fork oil levels and scheduled change intervals are important for fork performance and fork part longevity.....water contamination, as well as particulate wear will accumulate in fork oil, and since there is no oil filtering mechanism within your forks, the only way to get the grit and gunk out (before it chews up your oil seals and slider bearings!) is to change your fork fluid regularly. Yamaha recommends a fork fluid change every 10,000 miles or 24 months (all models except XJ700's), or every 16,000 miles or 24 months (all XJ700 and XJ750-X models). If you just bought a used bike, we recommend you do a fluid change as soon as possible, because just like other routine maintenance tasks (besides engine oil changes), this is one that has very likely been ignored for the last 10-12 years!
    HINT: there’s a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it’s brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won’t mix and the water will “ball up”; brake fluid will integrate with water and absorb the water.
    Fork oil capacities and recommended weights are as follows. The amounts listed are per fork tube:
    XJ550 Maxim: 272cc or 9.20 fluid ounces. 10W fork oil.
    XJ550 Seca: 230cc or 7.78 fluid ounces. 10W fork oil.
    1980-81 XJ650 Maxim and Midnight Maxim: 262cc or 8.86 fluid ounces. 10W fork oil.
    1982-84 XJ650 Maxim: 278cc or 9.40 fluid ounces. 10W fork oil.
    1982 XJ650RJ Seca: 236cc or 7.98 fluid ounces. 10W fork oil. Fork oil level is specified as 400mm (15.75") below the top of the tube without the spring installed, forks fully collapsed.
    1982 XJ650LJ Turbo: 238cc or 8.04 fluid ounces. 10W fork oil. Fork oil level is specified as 180mm (7.09") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ650LK Turbo: unknown.
    1985-86 XJ700 non-X: 383cc or 12.96 fluid ounces. 10W fork oil.
    1985-86 XJ700-X: 389cc or 13.16 fluid ounces. 10W fork oil.
    1982 XJ750 Maxim: 257cc or 8.69 fluid ounces. 10W fork oil.
    1983 XJ750 Maxim and Midnight Maxim: 257cc or 8.69 fluid ounces. 10W fork oil. NOTE: owner's manual states that the fork oil capacity is 278cc (9.40 fluid ounces). It is unknown which measurement is correct.
    1981-83 XJ750 Seca: 309cc or 10.45 fluid ounces. 20W fork oil.
    1983 XJ750 E-II Seca or 1984 XJ750RL Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 168mm (6.61") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ900RK Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 164mm (6.46") below the top of the tube without the spring installed, forks fully collapsed.
    1982-84 XJ1100 Maxim and Midnight Maxim: 210cc or 7.10 fluid ounces. 10W fork oil. Fork oil level is specified as 210mm (8.27") below the top of the tube without the spring installed, forks fully collapsed.
    IMPORTANT NOTE: the above fork oil VOLUMES are for use only when using the stock fork springs. The use of aftermarket performance front fork coil springs will change those volumes, since aftermarket springs are thicker than stock----and thus displace more oil. Using the stock oil fluid VOLUME with aftermarket fork springs is a sure way to OVERFILL your forks, with the very real possibility of blowing out fork seals.
    Unlike with your engine oil, where a bit too much or too little oil volume in the crankcase is not really a significant concern, with fork oil, too much or too little can cause real problems (too much oil can result in blown oil seals and a stiff, harsh ride, while too little oil volume results in excessive foaming, a soft mushy ride with possible bottoming, and erratic fork performance and lots of front end "dive" upon braking).
    A better way to determine the amount of fork oil that is needed and necessary is via the measurement of the fork oil LEVEL within the tubes.....sort of like measuring the oil level with a dipstick. Yamaha does not specify this level for all models; and in any case, if using aftermarket springs, the factory oil level recommendation is not always useful. The maximum oil level should be 5-1/2" (140mm) below the top of the inner fork tube, measured with all internal fork tube components installed EXCEPT FOR THE SPRINGS, and with the inner fork tube fully collapsed into the lower (outer) tube.
    In order to be as accurate as possible, we recommend the use of a suitable measuring device, such as the HCP1728 oil level syringe listed further below.
    And finally, the fork oil viscosity can be changed from the factory recommendations to give a softer or firmer ride.......the lower the viscosity, the thinner the oil, and the softer the ride (i.e. 5W oil is thinner than 10W which is thinner than 20W, etc.) In this regard, you would certainly be correct in thinking of fork oil as a suspension "tuning tool"! Note that a thicker oil viscosity will have much more effect on the fork "rebound" characteristics than it will on the fork compression dampening function.
    A great primer on "tuning" your forks via adjusting the oil levels can be seen at:
    http://www.thumpertalk.com/forum/archive/index.php/t-89918.html
    while the theory and science and practical applications of tuning your suspension via using differing viscosities of fork oil can is revealed at:
    http://www.peterverdone.com/archive/lowspeed.htm
    ffo3) Red Line Oil products line of SYNTHETIC FORK OILS are some of the best, highest-performance fork oils developed specifically for this purpose. They provide exceptional shear lubrication, are highly resistant to any viscosity changes, and provide excellent seal lubrication as well as very high anti-foaming properties. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    Also, do not mix different brands, styles, or types of oils........you can only safely mix forks oils together from one manufacturer!
    HCP1563 Red Line high-performance SYNTHETIC FORK OIL 0W (zero weight, "like water"), 16 ounce bottle (473cc), clear. Each bottle:
    $ 27.95
    HCP1564 Red Line high-performance SYNTHETIC FORK OIL 2.5W, 16 ounce bottle (473cc), blue. Each bottle:
    $ 27.95
    HCP1258 Red Line high-performance SYNTHETIC FORK OIL 5W, 16 ounce bottle (473cc), amber. Each bottle:
    $ 27.95
    HCP1259 Red Line high-performance SYNTHETIC FORK OIL 10W, 16 ounce bottle (473cc), red. Each bottle:
    $ 27.95
    HCP1263 Red Line high-performance SYNTHETIC FORK OIL 30W, 16 ounce bottle (473cc), orange. NOTE: this oil is similar in viscosity to what most other oil manufacturers call "20W" oil. Each bottle:
    $ 27.95
    ffo4) PJ1 products line of TUNER FORK OILS are exceptional quality, value-priced fork oils developed specifically for motorcycle suspensions. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    HCP10360 PJ1 products TUNER FORK OIL 2.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10362 PJ1 products TUNER FORK OIL 5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10364 PJ1 products TUNER FORK OIL 7.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10366 PJ1 products TUNER FORK OIL 10W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10368 PJ1 products TUNER FORK OIL 15W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10370 PJ1 products TUNER FORK OIL 20W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10372 PJ1 products TUNER FORK OIL 30W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    Fork Tube Oil Level Gauges:
    HCP1728 Fork tube oil fluid level measurement GAUGE AND SYRINGE. This handy tool makes the measurement of the fork oil level easy and accurate. NOTE: the proper amount of fork oil is determined via the measurement of the fork oil LEVEL (distance below the very top of the inner tube) rather than a volume AMOUNT of oil specification. Too little oil will make the ride mushy, while too much oil makes the ride harsh (and can blow out the oil seals!)
    $ 39.95
    ffl4) Aftermarket fork oil measurement GRADUATED CYLINDERS. The best way to measure the precise amount of fork oil fluid is via the use of these lab-quality measurement cylinders. Available in either transparent (clear) or translucent (cloudy) durable plastic construction, they all have easy-to-read scale numerals (milliliters) and feature a "non-wetting" inner surface coating that prevents the concave "meniscus" from forming at the top of the fluid, thus insuring a much more accurate level reading. Large bases insure stability while large spouts make "the pour" easy and prevent messy drips. Very useful device to have for front fork oil changes.
    HCP10741 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, translucent (cloudy).
    $ 24.95
    HCP10744 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, transparent (clear).
    $ 49.95
    HCP10742 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, translucent (cloudy).
    $ 29.95
    HCP10745 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, transparent (clear).
    $ 69.95
    HCP10743 Aftermarket fork oil GRADUATED CYLINDER, super-sized 1000ml capacity, translucent (cloudy), with convenient side handle to insure steady pouring.
    $ 89.95
  5. chacal
    1984-85 FJ600 MODELS FORK TUBE PARTS:
    NOTE: items marked below in red are the parts typically needed when doing a basic fork system rebuild.
    A good visual review of the procedures needed for rebuilding these forks can be seen at:
    http://xjbikes.com/forums/index.php?threads/8355
    And these incredible 3-D renderings of the inner workings of a forking system gives a great visualization of the internal components (it is based on the 1982-83 XJ650 Maxim forks):
    http://xjbikes.com/forums/index.php?threads/29616
    FORK TUBE REBUILD PARTS KITS:
    We now offer both a BASIC FORK REBUILD KIT and PERFORMANCE FOR TUBE REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike.
    - NOTE: the lower tube “dust boots” (sometimes called dust seals) are not included in the basic fork tube rebuild kits, but are available separate and can be found further below.
    Basic fork rebuild kit contains at least the following items:
    - cap bolt o-rings.
    - standard quality lower fork tube oil seals.
    - oil seal retaining clips.
    - oil drain screws and gaskets.
    - damper rod bolts and crush washers.
    - damper rod head piston rings.
    - air system o-rings and air valve cores (in the 1985 model kits).
    - NOTE: 1984 owners may wish to purchase the HCP9238 cap bolt removal tool, as it is not included in the HCP20710 kit!
    HCP20710 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1984 FJ600 models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 99.95
    HCP20710DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1984 FJ600 models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 139.95
    HCP20605 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1985 FJ600 models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 99.95
    HCP20605DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1985 FJ600 models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 139.95
    Performance fork rebuild kit contain all of the basic rebuild kit components, along with:
    - performance fork springs.
    - upgraded, high-performance lower fork tube oil seals.
    - lower fork tube dust boots.
    - air valve core stem tool (in the 1985 model kit).
    - NOTE: 1984 owners may wish to purchase the HCP9238 cap bolt removal tool (listed further below), as it is not included in the HCP20711 kit.
    HCP20711 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1984 FJ600 models. One kit does both front tubes.
    $ 399.95
    HCP20606 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1985 FJ600 models. One kit does both front tubes.
    $ 399.95
    Of course, all of the component pieces can be ordered as individual pieces from the selections listed below, as well as non-typical wear items (inner tubes, damper rod piston rings, taper spindles, cap bolts, etc.), as well as the fork oil and specialty tools needed to properly restore or enhance your front suspension performance.
    UPPER (INNER) FORK TUBES AND PARTS:
    Chrome Inner Fork Tubes:
    HCP20354 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1984 (non air-assisted forks) FJ600 Maxim models, each:
    $ 299.95
    HCP203542SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP19810 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1985 (air-assisted forks) FJ600 Maxim models, each:
    $ 299.95
    HCP198102SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    Inner Tube Top Cover/Cap:
    HCP8289 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 28.95
    HCP22880 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 19.95
    Inner Fork Tube Cap Bolts and Related Hardware:
    HCP8292 OEM inner fork tube CAP BOLT, fits either side. Used on all 1984 FJ600, XJ700 non-X, XJ750RL, and XJ900RK, RL, and N/FN Seca models. NOTE: these cap bolts require a special inverse-hex tool HCP9238 to properly remove and install. Each:
    $ 49.95
    HCP9238 Aftermarket fork upper cap bolt REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive cap bolt used on the top of the inner fork tubes on all 1984 FJ600, XJ650 Turbo, XJ700 non-X, XJ750-D, XJ750P (37H) model, all XJ900RK, RL, N/FN, and F, and 1982 XZ550R Vision models.
    $ 19.95
    HCP8286 OEM inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 7.95
    HCP20708 Aftermarket inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 5.95
    Inner Tube Fork Springs:
    HCP9437 Aftermarket front suspension PROGRESSIVE-WOUND COIL SPRINGS, one pair does both forks. For all 1984-85 FJ600, all XJ700, and XJ750-X models. No spacers are needed on FJ600 models when using these springs. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 249.95
    HCP8280 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1985 FJ600 models, XJ700, XJ750-X, and XJ900 F models. Each:
    $ 37.95
    HCP20353 OEM inner fork tube SPRING SPACER TUBE, fits either side. Used on all 1985 FJ600 Maxim models. Each:
    $ discontinued
    HCP13657 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1984-85 FJ600, all XJ700, XJ750-X, XJ750RL Canadian (44X model), and XJ900 models. Use 1 per fork tube. Each:
    $ 17.95
    Inner Fork Tube Taper Spindle:
    $ 31.95
    INNER FORK TUBE AIR SYSTEM PARTS:
    Air Inflation Valves and O-Rings:
    HCP20350 OEM inner fork tube air joint AIR VALVE, comes complete the internal stem core, its o-ring, and black cap. Use 1 per tube. Fits the following models: 1985 FJ600 models. Each:
    $ 64.95
    HCP2322 OEM inner fork tube air joint air valve and air hose-to-joint O-RING, fits the following models: 1985 FJ600 models (use 1 per tube), 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 3 per bike), XJ750-P (24L and 37H models, use 2 per bike), XJ750-D (use 3 per bike), 1982 XJ750 Maxim (use 3 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 3 per bike), and XJ900RK and RL models (use 3 per bike). Each:
    $ 7.95
    HCP14020 Aftermarket inner fork tube air joint air valve and air hose-to-joint O-RING, fits the following models: 1985 FJ600 models (use 1 per tube), 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 3 per bike), XJ750-P (24L and 37H models, use 2 per bike), XJ750-D (use 3 per bike), 1982 XJ750 Maxim (use 3 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 3 per bike), and XJ900RK and RL models (use 3 per bike). Each:
    $ 5.95
    HCP9194 Aftermarket fork tube AIR VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all 1985 FJ600 models, 1982-83 XJ650 Maxim and Turbo models, XJ700-X models, all XJ750 models, the XJ900RK model, XJ1100, and all XS1100 Special and Midnight Special models. If your stem is leaking air, this is the inexpensive way to fix it. Each:
    $ 3.95
    HCP9194SET2 Aftermarket fork tube AIR VALVE STEM CORES, set of 2:
    $ 6.95
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 5.95
    HCP20351 OEM fork tube air fill valve CAP. Used on all 1985 FJ600 models, one on each valve. Each:
    $ 7.95
    Crown Bracket Inner Fork Tube Retaining Hardware:
    $ discontinued
    $ 4.95
    $ 1.25
    $ 1.25
    $ 1.25
    HCP3945 OEM crown bracket fork tube FLAT WASHER, alloy steel, black finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 4.95
    HCP26192 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, bright finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 1.95
    HCP26193 Aftermarket crown bracket fork tube FLAT WASHER, 18/8 stainless steel, bright finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 2.95
    HCP17110 Aftermarket crown bracket fork tube FLAT WASHER, 316 stainless steel, dull finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 3.95
    HCP26189 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, black finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 3.95
    HCP2391 OEM crown bracket fork tube LOCK WASHER, for use on all 1984-85 FJ600 models. Use 1 per side. Each:
    $ 7.95
    HCP16209 Aftermarket crown bracket fork tube LOCK WASHER, zinc-plated alloy steel, for use on all 1984-85 FJ600 models. Use 1 per side. Each:
    $ 2.95
    HCP16100 Aftermarket crown bracket fork tube LOCK WASHER, 18-8 stainless-steel with a bright finish, for use on all 1984-85 FJ600 models. Use 1 per side. Each:
    $ 3.95
    HCP16102 Aftermarket crown bracket fork tube LOCK WASHER, black-oxide coated alloy steel, for use on all 1984-85 FJ600 models. Use 1 per side. Each:
    $ 3.95
    Dust Wiper Seals:
    HCP1823 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984-85 FJ600, all XJ650 Maxim and Midnight Maxim, 1982 XJ650 Turbo, XJ750-P (24L model), and XJ750 Maxim and Midnight Maxim models. One seal does one tube. Each:
    $ 32.95
    HCP21557 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984-85 FJ600, all XJ650 Maxim and Midnight Maxim, 1982 XJ650 Turbo, XJ750-P (24L model), and XJ750 Maxim and Midnight Maxim models. One seal does one tube. Each:
    $ 24.95
    Oil Seals:
    $ 21.95
    $ 32.95
    $ 39.95
    $ 44.95
    Oil Seal Retaining Clips:
    $ 9.95
    $ 6.95
    Oil Seal Spacer Washer:
    HCP19997 OEM lower fork tube OIL SEAL SPACER WASHER, fits either left or right tube on the following models: all 1984-85 FJ600 models. One washer does one tube. This washer goes below the oil seal, and above the metal slider bushing! Each:
    $ 8.95
    HCP19997SET2 OEM lower fork tube OIL SEAL SPACER WASHERS, one pair does both forks.
    $ 16.95
    Lower Tube Metal Slider Bushings:
    $ 49.95
    $ 89.95
    $ 39.95
    $ 74.95
    Lower Fork Tube Oil Drain Screw and Gasket:
    $ 4.95
    $ 1.95
    $ 1.95
    $ 2.95
    $ discontinued
    $ 2.95
    $ 1.95
    $ 8.95
    $ 16.95
    $ 5.95
    $ 10.95
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    $ 9.95
    $ 6.95
    $ 16.95
    $ 10.95
    $ 44.95
    Fork Tube Brace and Hardware:
    HCP8480 OEM lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Bright finish, alloy steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP2424 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Black oxide coated alloy steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 1.95
    HCP80 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Black oxide coated alloy steel socket head, allen-drive. Features a small nylon thread patch, making this a self-locking bolt. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP2423 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Bright 18-8 stainless steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    Lower Fork Tube Axle Retaining Hardware:
    $ 12.95
    $ 3.95
    $ 1.95
    $ 2.95
    $ 3.95
    $ 3.95
    $ 6.95
    $ 2.95
    $ 3.95
    $ 3.95
    $ 3.95
    $ 2.95
    $ 44.95
    $ 19.95
    $ 47.95
    $ 44.95
    $ 46.95
    $ 47.95
    Anti-Seize Paste:
    $ 8.95
    $ 3.95
    $ 9.95
    $ 13.95
    $ 13.95
    $ 19.95
    $ 11.95
    $ 11.95
    $ 4.95
    $ 11.95
    $ 11.95
    $ 41.95
    $ 44.95
    $ 42.95
    $ 52.95
    $ 13.95
    $ 14.95
    FORK OIL:
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 39.95
    $ 24.95
    $ 49.95
    $ 29.95
    $ 69.95
    $ 89.95
    Fork Tube Air Pressure Tool and Gauge:
    $ 6.95
    HCP9108 Aftermarket air-assisted forks LOW PRESSURE AIR GAUGE, heavy-duty 0-20 psi pencil (stick) pressure gauge marked in 1/2-psi increments, perfect for checking fork air pressures on models so equipped. Very high quality and much more accurate than standard tire pressure gauges, which is very important on the fork pressures as an imbalance between the fork pressure can lead to steering and stability issues, while too much pressure will blow out the lower tube oil seals!
    $ 9.95
  6. chacal
    1992-98 XJ600 SECA II and 1988-90 FZR400 MODELS FORK TUBE PARTS:
    XJ600 owners may also wish to note the procedure needed to separate the inner tubes from the lower tubes (the “battering ram” procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    http://xjbikes.com/forums/index.php?threads/4067
    1992-98 XJ600 Seca II FORK TUBE REBUILD PARTS KITS:
    - cap bolt o-rings.
    HCP20607 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1992-97 XJ600 Seca II models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 89.95
    HCP20607DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1992-97 XJ600 Seca II models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 129.95
    HCP20678 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1998 XJ600 Seca II models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 89.95
    HCP20678DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1998 XJ600 Seca II models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 129.95
    HCP20608 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1992-97 XJ600 Seca II models. One kit does both front tubes.
    $ 239.95
    HCP20839 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1998 XJ600 Seca II models. One kit does both front tubes.
    $ 279.95
    1988-90 FZR400 FORK TUBE REBUILD PARTS KITS:
    We now offer both a BASIC FORK REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike.
    - cap bolt o-rings.
    HCP30036 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1988-90 FZR400 models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 89.95
    HCP30036DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1988-90 FZR400 models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 132.95
    HCP22892 OEM chrome INNER FORK TUBE, fits left or right side, for all 1992-97 XJ600 Seca II models, each:
    $ 329.95
    HCP19811 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1992-97 XJ600 Seca II models, each:
    $ 299.95
    HCP19811SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP20334 OEM chrome INNER FORK TUBE, fits left or right side, for all 1998 XJ600 Seca II models, each:
    $ 329.95
    HCP19812 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1998 XJ600 Seca II models, each:
    $ 299.95
    HCP19812SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP20320 OEM inner fork tube CAP BOLT, fits either side. Used on all 1992-98 XJ600 Seca II, 1988-90 FZR400, 1989-99 FZR600, and 1986 FZ750 models. Each:
    $ 59.95
    HCP20321 OEM inner fork tube top cap bolt O-RING, fits either side on all 1992-98 XJ600 Seca II and 1988-90 FZR400 models. Each:
    $ 8.95
    HCP20753 Aftermarket inner fork tube top cap bolt O-RING, fits either side on all 1992-98 XJ600 Seca II and 1988-90 FZR400 models. Each:
    $ 5.95
    HCP20317 OEM front suspension COIL SPRINGS. For all XJ600 Seca II models. Your original front spring spacers and seats are required to be re-used with these springs. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube. Each:
    $ 89.95
    HCP19477 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ600 Seca II models . NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube. Your original front spring spacers and seats are required to be re-used with these springs.
    $ 139.95
    Inner Fork Tube Spring Spacers, Rebound Springs, Damper Rods, and Spring Seats:
    HCP20318 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1992-94 XJ600 Seca II models. Each:
    $ 19.95
    HCP20336 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1995-98 XJ600 Seca II models. Each:
    $ discontinued
    HCP25229 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1992-98 XJ600 Seca II models. Use 1 per fork tube. Each:
    $ 17.95
    HCP20315 OEM inner fork tube DAMPER ROD, fits either side. Used on all 1992-98 XJ600 Seca II models. Each:
    $ 139.95
    HCP20316 OEM upper (inner) fork tube TAPER SPINDLE, fits either side. Used on all 1992-98 XJ600 Seca II, 1988-90 FZR400, and 1989-99 FZR600 models. Each:
    $ 33.95
    Inner Tube Metal Slider Bushings:
    HCP10703 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1992-93 XJ600 Seca II, and all XJ700 and XJ750-X models. One slider does one tube. Each:
    $ 29.95
    HCP10703SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 57.95
    HCP22894 OEM inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1998 XJ600 Seca II model. One slider does one tube. Each:
    $ discontinued
    HCP22894SET2 OEM inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ discontinued
    INNER FORK TUBE RETAINING HARDWARE:
    HCP505 OEM crown bracket fork tube CINCH BOLT. Use 1 per side on all 1995-96 XJ600 Seca models. Each:
    $ 7.95
    HCP505SET2 OEM crown bracket fork tube CINCH BOLTS, use 1 per side. Set of 2:
    $ 14.95
    HCP23283 Aftermarket crown bracket fork tube CINCH BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel. Use 1 per side on all 1995-96 XJ600 Seca models. Each:
    $ 3.95
    HCP23283SET2 Aftermarket crown bracket fork tube BOLTS, set of 2:
    $ 6.95
    HCP23282 Aftermarket crown bracket fork tube CINCH BOLT, bright 18-8 stainless steel. Use 1 per side on all 1995-96 XJ600 Seca models. Each:
    $ 2.95
    HCP23282SET2 Aftermarket crown bracket fork tube BOLTS, set of 2:
    $ 4.95
    Under-bracket Inner Fork Tube Retaining Hardware:
    HCP4956 OEM under-bracket fork tube CINCH BOLT, alloy steel, socket head cap screw with a bright finish. Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP21942 Aftermarket under-bracket fork tube CINCH BOLT, alloy steel socket head cap screw with a bright finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP23282 Aftermarket under-bracket fork tube CINCH BOLT, 18-8 stainless steel socket head cap screw with a bright finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP22203 Aftermarket under-bracket fork tube CINCH BOLT, 316 stainless steel socket head cap screw with a bright finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP23283 Aftermarket under-bracket fork tube CINCH BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel socket head cap screw. Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP21944 Aftermarket under-bracket fork tube CINCH BOLT, alloy steel socket head cap screw with a black finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP20326 OEM under-bracket fork tube CINCH BOLTS, use 1 per side, for all 1992-96 XJ600 Seca II models. Each:
    $ 14.95
    HCP20331 OEM under-bracket fork tube CINCH BOLTS, use 1 per side, for all 1997-98 XJ600 Seca II models. Each:
    $ discontinued
    LOWER (OUTER) FORK TUBE PARTS:
    Dust Wiper Seals:
    HCP20312 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on all 1992-97 Seca II models. One seal does one tube. Each:
    $ 24.95
    HCP20337 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on all 1998 Seca II models. One seal does one tube. Each:
    $ 24.95
    Oil Seals:
    NOTE: when installing oil seals, make sure that the area where the seal will fit into is clean, free of any nicks and burrs, and that the lower tube metal slide bushing is fully seated. Oil seals install with the large opening facing down, into the tube, and on most seals, the small cast lettering and numbering on the seal faces upwards.
    Seals are designed to be installed with a seal driver of some type, although a properly sized piece of hard plastic tubing, perhaps with a proper sized metal washer on top of the seal to "spread the load", works as well. Always make sure that oil seals are fully seated and not damaged or installed in a crooked or cocked manner.
    HCP1817 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. One seal does one tube. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago. Each:
    $ 27.95
    HCP20647 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. Comes packaged as a pair of seals, enough to do both forks. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago.
    $ 42.95
    HCP1719 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. Comes packaged as a pair of seals, enough to do both forks. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago.
    $ 47.95
    HCP20342 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1998 XJ600 Seca II, 1988-89 FZR600, and 1998-99 XV1100 models. One seal does one tube. Each:
    $ 27.95
    HCP19456 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1998 XJ600 Seca II, 1988-89 FZR600, and 1998-99 XV1100 models. Comes packaged as a pair of seals, enough to do both forks.
    $ 22.95
    Oil Seal & Dust Seal Kits:
    HCP19457 Aftermarket standard quality lower fork tube OIL & DUST SEALS KIT, fits all of the following models: all 1992-97 XJ600 Seca II models. Comes with a pair of both the oil seals and the dust seals, enough to do both forks. Also fits the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1995-97 XV750 Virago, and 1995-97 XV1100 Virago.
    $ 79.95
    HCP19458 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: all 1992-97 XJ600 Seca II models. Comes with an oil seal, the dust wiper seal, the lower tube oil seal retaining clip, and both metal slide bushings (upper and lower tubes), enough to do one fork tube. NOTE: this kit does not contain the following items which we also recommend that you also purchase: upper tube top cap bolt O-RINGS, lower tube damper rod BOLTS AND CRUSH WASHERS, and the lower tube fork oil drain screw SCREWS AND GASKETS. Also fits the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1995-97 XV750 Virago, and 1995-97 XV1100 Virago.
    $ 79.95
    HCP19458SET2 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, two sets are enough to rebuild one bike.
    $ 149.95
    HCP1828 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 8.95
    HCP20717 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    Oil Seal Lower Washer:
    HCP3093 OEM lower fork tube oil seal WASHER, fits either left or right tube on the following models: all 1992-98 XJ600 Seca II, XJ700, and XJ750-X models. One washer does one tube, fits directly below the oil seal and above the lower tube metal slider bushing. Each:
    $ 26.95
    HCP3087 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1992-93 XJ600 Seca II models, all XJ700, XJ750-X, and 1988-90 FZR400 models. One slider does one tube. Each:
    $ 44.95
    HCP3087SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 84.95
    HCP10708 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1992-97 XJ600 Seca II models, XJ700, XJ750-X, and 1988-90 FZR400 models. One slider does one tube. One slider does one tube. NOTE: although the factory lists different part numbers for these lower bushings (1992-93 and 1994-97), the bushings are actually identical in size for all 1992-97 Seca II models. Each:
    $ 34.95
    HCP10708SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 59.95
    HCP20341 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1994-97 XJ600 Seca II models. One slider does one tube. Each:
    $ 27.95
    HCP20341SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 54.95
    HCP20340 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1998 XJ600 Seca II models. One slider does one tube. Each:
    $ 22.95
    HCP20340SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 42.95
    HCP10708 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1992-97 XJ600 Seca II models, XJ700, and XJ750-X models. One slider does one tube. NOTE: although the factory lists different part numbers for these lower bushings (1992-93 and 1994-97), the bushings are actually identical in size for all 1992-97 Seca II models. Each:
    $ 29.95
    $ 54.95
    HCP5187 OEM lower fork tube oil DRAIN SCREW, use one per tube. Panhead, phillips-drive, alloy steel with a black finish. Note that the black screw was used on models with black lower fork tubes (1982-83 XJ550 Seca, FJ600, 1995 XJ600 Seca II, XJ650 Midnight Maxim, XJ650 Turbo, XJ750 Midnight Maxim, 1981-83 XJ750 Seca and XJ750 Euro models, and some XJ750P models 37H). All other models with natural aluminum lower fork tubes used a screw with a bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 4.95
    HCP29817 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead, phillips-drive, alloy steel with a black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29005 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive zinc-plated alloy steel. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29006 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6710 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ discontinued
    HCP6712 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6711 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP7111 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 8.95
    HCP7111SET2 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 16.95
    HCP21320 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 5.95
    HCP21320SET2 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 10.95
    HCP8233 OEM fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 9.95
    HCP28069 Aftermarket fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 6.95
    HCP8234 OEM fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 16.95
    HCP12950 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 10.95
    HCP7273 OEM front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. Class 10.9 alloy steel sockethead cap screw with a bright finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 4.95
    HCP29771 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. Alloy steel sockethead cap screw with a black oxide finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 1.95
    HCP29772 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. Alloy steel sockethead cap screw with a bright zinc-flake finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 2.95
    HCP29773 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. 18/8 stainless steel sockethead cap screw with a bright finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 2.95
    HCP29774 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. 316 stainless steel sockethead cap screw with a bright finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 3.95
    HCP20338 OEM front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. For all 1996 XJ600 Seca II models.
    $ 7.95
    HCP20322 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, for all 1992-94 XJ600 Seca II models. Use 1 per retaining bolt (2 per bike) on the left side lower fork tube.
    $ 7.95
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP26095 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 38mm fork tubes: XJ600 Seca II thru 1997, XJ700 all models, and XJ750-X water-cooled models.
    $ 47.95
    $ 44.95
    $ 46.95
    $ 47.95
    Anti-Seize Paste:
    $ 8.95
    $ 3.95
    $ 9.95
    $ 13.95
    $ 13.95
    $ 19.95
    $ 11.95
    $ 11.95
    $ 4.95
    $ 11.95
    $ 11.95
    $ 41.95
    $ 44.95
    $ 42.95
    $ 52.95
    $ 13.95
    $ 14.95
    FORK OIL:
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 39.95
    $ 24.95
    $ 49.95
    $ 29.95
    $ 69.95
    $ 89.95
  7. chacal
    XJ650 MODELS FORK TUBE PARTS:
    XJ650 Turbo owners may also wish to note the procedure needed to separate the inner tubes from the lower tubes (the “battering ram” procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    NOTE: XJ750 Police (24L, 33V, and 39Y models) used the XJ650 Turbo master cylinder with XJ750 Seca calipers and rotors, and XJ650 Turbo style forks.
    - cap bolt o-rings.
    - cap bolt retaining rings (in all kits except XJ650 Turbo models).
    - air joint cushions, o-rings, and retaining rings (in all XJ650 Turbo kits).
    - air system o-rings and valve cores (in all kits except HCP20611).
    HCP20611 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all XJ550 Maxim, 1980-81 XJ650 Maxim and Midnight Maxim models, 1982 XJ650RJ Seca, and XJ650 Euro models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 89.95
    HCP20611DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all XJ550 Maxim, 1982 XJ650RJ Seca, and XJ650 Euro models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 127.95
    HCP30011DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1980-81 XJ650 Maxim and Midnight Maxim models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 124.95
    HCP20613 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1982-83 XJ650 Maxim models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 99.95
    HCP20613DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1982-83 XJ650 Maxim models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 137.95
    HCP20617 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1982 XJ650 Turbo and 1982 XJ750 Maxim models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 149.95
    HCP20617DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1982 XJ650 Turbo and 1982 XJ750 Maxim models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 184.95
    HCP20619 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1983 XJ650 Turbo models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 149.95
    HCP20619DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1983 XJ650 Turbo models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 199.95
    - performance fork springs (and related spring seats and spacers, when needed).
    - air valve core stem tool (in all kits using air-assisted forks).
    HCP20612 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1980-81 XJ650 Maxim and Midnight Maxim models. One kit does both front tubes. Includes a pair of pre-cut spring spacers.
    $ discontinued
    HCP20614 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1982-83 XJ650 Maxim models. One kit does both front tubes.
    $ discontinued
    HCP20616 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1982 XJ650RJ Seca and XJ650 Euro models. One kit does both front tubes. Includes a pair of pre-cut spring spacers.
    $ discontinued
    HCP20618 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1982 XJ650 Turbo models. One kit does both front tubes.
    $ discontinued
    HCP20620 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1983 XJ650 Turbo models. One kit does both front tubes.
    $ discontinued
    HCP8525 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ650 Maxim and Midnight Maxim models, each:
    $ 299.95
    HCP8525SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8528 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ650 Euro models, and 1982 XJ650RJ and RJC Seca models, each:
    $ 299.95
    HCP85288SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8526 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1982 XJ650 Turbo models, each:
    $ 299.95
    HCP8526SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8527 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1983 XJ650 Turbo models, each:
    $ 299.95
    HCP85276SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    Inner Tube Gaiter Boots:
    Although not originally used on any XJ-series bikes, these accordion-pleated thick rubber boots fit into the area between the bottom of the steering underbracket and the top of the lower (outer) fork boots, covering and protecting this area from damage, while providing an "old-school" or cafe-racer type look. They are retained to the chrome tube itself (at their top end) via spring clips, and to the top of the lower fork tube via metal screw-clamps.
    HCP10806 Aftermarket front fork tube GAITER BOOT, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models. Does not include attaching hardware. Heavy-duty design has equal spacing between each accordion pleat. Each:
    $ 99.95
    HCP10806SET2 Aftermarket front fork tube GAITER BOOTS, set of 2:
    $ 179.95
    HCP10941 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10942 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10943 Aftermarket front fork tube GAITER BOOTS, red pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10938 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP10939 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP11420 Aftermarket fork tube gaiter boot LOWER RETAINING SPRING-CLAMP. Black powdercoated wire-spring type clamp has that old-time look and feel to it. Secure the lower end of the gaiter boot to the top of the lower (outer) fork tube. Fits all XJ-series models. Use 1 per tube, each:
    $ 14.95
    NOTE: gaiter boots normally do not require any type of retainer at their upper end, as the tight friction fit between the boot opening and the chrome tube prevents migration of the boot. If movement seems to occur, then we recommend the use of thin, black electrical wire ties to cinch the boot flange tightly to the tube.
    HCP8252 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: XJ550 all, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, the 1982 XJ650RJ Seca, and 1981 XJ750 Seca models. Each:
    $ discontinued
    HCP22882 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: XJ550 all, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, the 1982 XJ650RJ Seca, and 1981 XJ750 Seca models. Each:
    $ 19.95
    HCP8254 OEM inner fork tube black plastic top CAP, fits either the left or right side tube of the following models: 1982-83 XJ650 Maxim and 1983 XJ750 Maxim and Midnight Maxim models. Has the words AIR ADJUSTABLE cast into as original. This cap screws directly onto the brass air valve on these models. Each:
    $ 39.95
    $ 28.95
    $ 19.95
    HCP8255 OEM inner fork tube CAP BOLT, fits either side. Used on all XJ550 models, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 59.95
    HCP9882 Aftermarket inner fork tube CAP BOLT, fits either side. Used on all 1982-83 XJ650 Maxim models with air-assisted forks. These cap bolts have the drilled and threaded central hole where the HCP8274 air valve screws in (air valve is NOT included with the cap bolt). Each:
    $ 59.95
    HCP8294 OEM inner fork tube CAP BOLT, fits either side. Used on all XJ650 Turbo, XJ750-D, and XJ750-P (24L model), and 1982 XZ550R Vision models. NOTE: these cap bolts require a special inverse-hex tool HCP9238 to properly remove and install. Each:
    $ 69.95
    $ 19.95
    HCP2323 OEM inner fork tube top cap bolt RETAINING RING, fits either the left or right side tube of the following models: all XJ550 models, all XJ650 Euro models, XJ650 Maxim, Midnight Maxim, and XJ650RJ Seca models. Each:
    $ 8.95
    HCP20715 Aftermarket inner fork tube top cap bolt RETAINING RING, fits either the left or right side tube of the following models: all XJ550 models, all XJ650 Euro models, XJ650 Maxim, Midnight Maxim, and XJ650RJ Seca models. Each:
    $ 5.95
    HCP2324 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ550 models, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 7.95
    HCP20699 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ550 models, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 5.95
    HCP8241 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 14.95
    HCP20707 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 9.95
    HCP8242 OEM inner fork tube decorative cover RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap and the top of the lower steering bracket. Use 1 or 2 per fork tube (depending on model) on all on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 all Special models, 1983 XV750MK Midnight Virago, 1983 XV920MK Midnight Virago, and all XS1100 Standard models. Each:
    $ 10.95
    HCP8242SET2 OEM inner fork tube decorative cover RUBBER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket inner fork tube decorative cover rubber RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap and the top of the lower steering bracket. Use 1 or 2 per fork tube (depending on model) on all on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 all Special models, 1983 XV750MK Midnight Virago, 1983 XV920MK Midnight Virago, and all XS1100 Standard models. Each:
    $ 7.95
    HCP15647SET2 Aftermarket inner fork tube decorative cover rubber RUBBER CUSHION GASKETS, set of 2:
    $ 14.95
    HCP9436 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ650 models. Front spring spacers are not included with these springs, and you'll need to note the following changes needed by model when installing them. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ discontinued
    1980-81 XJ650 Maxim or Midnight Maxim models will need the installation of an HCP8239 spring seat (one for each spring) and the fabrication of a 46.40mm long spacer when replacing stock springs. You can use the HCP8284 spring spacer tube (stock for 1982-83 XJ650 Maxim models) and cut it down to the proper length; one tube will provide enough material to do both springs and fork tubes.....or you can order the HCP21019 spacers tubes which are already cut to the correct length. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 24 cc's more fork oil (for a total of 286cc's per tube) when installing these springs and using the stock thin-wall metal spacer tubes as recommended above. The use of other type of spacers (thick-wall PVC pipe, for instance) will change this recommended fork oil volume by an unknown amount.
    1982-83 XJ650 Maxim will require the stock spacers to be shortened to 88.90mm (or you can order the HCP21020 spacers tubes which are already cut to the correct length), and the re-use the original spring seats. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 15 cc's more fork oil (for a total of 293cc's per tube) when installing these springs and using the modified stock thin-wall metal spacer tubes as recommended above. The use of other type of spacers (thick-wall PVC pipe, for instance) will change this recommended fork oil volume by an unknown amount.
    1982 XJ650RJ Seca and all XJ650 Euro models will need the installation of an HCP8239 spring seat (one for each spring) and the fabrication of a 36.40mm long spacer when replacing stock springs, and the re-use of the original spring seats. For a more precise feel, use only a 12.50mm spacer:
    http://www.totalmotorcycle.com/pdf/savi ... ndards.pdf
    You can use the HCP8284 spring spacer tube (stock for 1982-83 XJ650 Maxim models) and cut it down to the proper length; one tube will provide enough material to do both springs and fork tubes......or you can order the HCP21021 spacers tubes which are already cut to the correct length. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 7 cc's more fork oil (for a total of 243cc's per tube) when installing these springs and using the modified stock thin-wall metal spacer tubes as recommended above. The use of other type of spacers (thick-wall PVC pipe, for instance) will change this recommended fork oil volume by an unknown amount.
    1982-83 XJ650 Turbo models will require the stock spacers to be shortened to 38.10mm (or you can order the HCP21023 spacers tubes which are already cut to the correct length) and the re-use the original spring seats. No change in the amount of fork oil used (238cc per tube) is needed on the 1982 models, and the amount of difference needed on the 1983 models, if any, is not known.
    HCP8284 OEM inner fork tube SPRING SPACER TUBE, fits either side. Used on all 1982-83 XJ650 Maxim and 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 14.95
    HCP8303 OEM inner fork tube SPRING SPACER TUBE, fits either side. Used on all XJ650 Turbo and 1982 XJ750 Maxim models. Each:
    $ 14.95
    HCP21019 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all 1980-81 XJ650 Maxim and Midnight Maxim models when installing the HCP9436 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9436 springs; use 1 spacer per tube.
    $ 19.95
    HCP21019SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    HCP21020 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all 1982-83 XJ650 Maxim models when installing the HCP9436 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9436 springs; use 1 spacer per tube.
    $ 19.95
    HCP21020SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    HCP21021 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all 1982 XJ650RJ Seca models when installing the HCP9436 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9436 springs; use 1 spacer per tube.
    $ 19.95
    HCP21021SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    HCP21023 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all 1982-83 XJ650 Turbo models when installing the HCP9436 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9436 springs; use 1 spacer per tube.
    $ 19.95
    HCP21023SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    HCP8239 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1982-83 XJ650 Maxim, 1982 XJ650 Turbo, XJ750-D, XJ750-P (24L and 37H models), and all XJ750 Maxim and Midnight Maxim models. Each:
    $ 19.95
    HCP20994 Aftermarket inner fork tube SPRING SEAT, fits either side. Used on all 1982-83 XJ650 Maxim, 1982 XJ650 Turbo, XJ750-D, XJ750-P (24L and 37H models), and all XJ750 Maxim and Midnight Maxim models. Each:
    $ 14.95
    HCP8253 OEM inner fork tube damper rod REBOUND SPRING, fits either side. Used on all XJ550 models, all XJ650 models (except Turbo), all 1983-84 XJ750 Maxim and Midnight Maxims, 1978-79 XS1100 Standard models, 1980 XS1100 (3X0) Euro model, 1989 and 1995-2008 XV250 Virago, 2008-2020 XV250 V-Star, 1983 XZ550RK, 1983 XV500, 1983-92 YZ80, 1980-81 YZ100, 1976-78 YZ250, and 1976 YZ400 models. Use 1 per tube, each:
    $ 39.95
    HCP13656 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all XJ550, XJ650, all XJ750 (except XJ750 Seca and XJ750-X models), and 1978-79 XS1100 Standard models. Use 1 per fork tube. Each:
    $ 17.95
    HCP3085 OEM upper (inner) fork tube TAPER SPINDLE, fits either side. Fits all XJ550 models, 1984 FJ600, all XJ650 models, all XJ700 and XJ750-X models, all XJ750 Maxim and Midnight Maxim models, XJ900 N/FN and F models, all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 31.95
    HCP10702C Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: all XJ550 Maxim and 1982 XJ650 Turbo models. One slider does one tube. Each:
    $ 59.95
    HCP10702CSET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 114.95
    HCP8481 OEM inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1983 (only) XJ650 Turbo (with 37mm fork tubes), all 1981-83 XJ750 Seca and Euro models, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. Each:
    $ 99.95
    HCP8481SET2 OEM inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 189.95
    HCP10702 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1983 (only) XJ650 Turbo (with 37mm fork tubes), all 1981-83 XJ750 Seca and Euro models, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. NOTE: these bushings are a bit thinner than the original bushings, but will fit and perform properly. Each:
    $ 69.95
    HCP10702SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 119.95
    Air Joint Cushions, O-Rings, and Retainers:
    HCP8242 OEM air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 10.95
    HCP8242SET2 OEM air joint rubber UPPER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint, and cushions the top of the air joint from the bottom of the crown bracket. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 7.95
    HCP15647SET2 Aftermarket air joint rubber UPPER CUSHION GASKETS, fits either side. Set of two:
    $ 14.95
    HCP8238 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1982 XJ650 Turbo, XJ750-P (24L model), 1982 XJ750 Maxim, and 1983 XV920 K/MK models. Uses 2 o-rings per joint. Each:
    $ 14.95
    HCP8238SET2 OEM inner fork tube air joint INNER O-RINGS, set of 2:
    $ 27.95
    HCP8238SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ 49.95
    HCP14015 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1982 XJ650 Turbo, XJ750-P (24L model), 1982 XJ750 Maxim, and 1983 XV920 K/MK models. Uses 2 o-rings per joint. Each:
    $ 9.95
    HCP14015SET2 Aftermarket inner fork tube air joint INNER O-RING, set of 2:
    $ 17.95
    HCP14015SET4 Aftermarket inner fork tube air joint INNER O-RING, set of 4:
    $ 29.95
    HCP8341 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, and XJ900RK and RL models. Uses 2 o-rings per joint. Each:
    $ discontinued
    HCP8341SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ discontinued
    HCP20701 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, XJ900RK and RL models, and XJ1100 models. Uses 2 o-rings per joint. Each:
    $ 8.95
    HCP20701SET4 Aftermarket inner fork tube air joint INNER O-RINGS, set of 4:
    $ 27.95
    HCP8283 OEM inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: XJ650 Turbo, 1982 XJ750 Maxim, XJ750-D, XJ750-P (24L model), XJ900RK and RL, and 1983 XV920K Virago models. Each:
    $ discontinued
    HCP12315 Aftermarket inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: XJ650 Turbo, 1982 XJ750 Maxim, XJ750-D, XJ750-P (24L model), XJ900RK and RL, and 1983 XV920K Virago models. Each:
    $ 7.95
    HCP8274 OEM inner fork tube air joint AIR VALVE WITH CAP, comes complete the internal stem core, its o-ring, and chrome cap. Fits the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and the included protective cap is much smaller than the huge caps used on those models, and due to the length difference, those large original caps will not fit properly on this shorter valve. This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 57.95
    HCP11890 OEM inner fork tube air joint brass AIR VALVE ONLY, comes complete the internal stem core and its o-ring. The chrome cap is not included. Fits the following models: 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. Each:
    $ 39.95
    HCP11876 OEM inner fork tube air joint air valve CHROME CAP, ribbed, dome-head style. Correct for all of the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This cap can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is much smaller than the large original caps used on those models. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 19.95
    $ 7.95
    $ 5.95
    $ 3.95
    $ 6.95
    $ 5.95
    HCP4529 OEM crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP21973 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright yellow-zinc finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP21974 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP21975 Aftermarket crown bracket fork tube CINCH BOLT, 18-8 stainless steel, hex-head bolt with a bright finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP4522 OEM crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP21973 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright yellow-zinc finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 1.95
    HCP21974 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 1.95
    HCP21975 Aftermarket crown bracket fork tube CINCH BOLT, 18-8 stainless steel, hex-head bolt with a bright finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 2.95
    HCP4531 OEM crown bracket fork tube CINCH BOLT, use 1 per side. For the following models: XJ650 Turbo, 1982 XJ750 Maxim, and all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 7.95
    HCP4531SET2 OEM crown bracket fork tube CINCH BOLTS, use 1 per side. Pair:
    $ 14.95
    HCP21911 Aftermarket crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XJ650RJ Seca and 1979-81 XS1100 Standard models. NOTE: this hex-head is made from alloy steel and has a slightly larger head than the original, and has a bright zinc-plated finish rather than the original black bolt. Each:
    $ 2.95
    HCP24111 Aftermarket crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XJ650RJ Seca and 1979-81 XS1100 Standard models. NOTE: this hex-head is made from 18/8 stainless steel and has a slightly larger head than the original, and has a bright zinc-plated finish rather than the original black bolt. Each:
    $ 1.95
    HCP24112 Aftermarket crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XJ650RJ Seca and 1979-81 XS1100 Standard models. NOTE: this hex-head is made from 316 stainless steel and has a slightly larger head than the original, and has a bright zinc-plated finish rather than the original black bolt. Each:
    $ 3.95
    HCP2537 OEM crown bracket fork tube FLAT WASHER, alloy steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 3.95
    HCP26192 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 1.95
    HCP26193 Aftermarket crown bracket fork tube FLAT WASHER, 18/8 stainless steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 2.95
    HCP17110 Aftermarket crown bracket fork tube FLAT WASHER, 316 stainless steel, dull finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 3.95
    HCP26189 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, black finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 models. Each:
    $ 3.95
    $ 4.95
    $ 1.95
    $ 2.95
    $ 3.95
    $ 3.95
    HCP4240 OEM crown bracket fork tube cinch bolt CROWN NUT, alloy steel, dark finish. For the following models: use 1 per tube cinch bolt (2 per bike) on all 1981-83 XJ650 Maxim and Midnight Maxim models, 1983 XJ750 Maxim and Midnight Maxim models, 1980-81 XS1100 Midnight Special, and 1981 XS1100 Special models. Use 1 per tube cinch bolt and 1 on the rear lateral stem pinch bolt (total of 3 per bike) on all XJ650 Euro, XJ650RJ Seca, XJ650 Turbo, and 1980 XS1100 Standard models. Each:
    $ 6.95
    HCP4528 OEM crown bracket fork tube CROWN NUT, alloy steel, bright finish. For the following models: use 1 per fork tube (2 per bike) on all XJ550, 1980 XJ650 Maxim, and 1979-1980 XS1100 Special models. Use 1 per tube cinch bolt and 1 on the rear lateral stem pinch bolt (total of 3 per bike) on all 1978-80 XS1100 Standard models. Each:
    $ 8.95
    HCP10959 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, alloy steel, bright finish, same height as the HCP4240 and HCP4528 crown nuts. Each:
    $ 3.95
    HCP21940 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 5.95
    HCP21941 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, chromed steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 8.95
    HCP18011 Aftermarket cinch bolt head protective CAP. Smooth, black plastic cap snaps over the head of the fork tube cinch bolts, giving them a very "modern" look, protecting the head from rust. Fits all OEM or aftermarket bolts with a 12mm hex or socket head. Each:
    $ 4.95
    HCP3652 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all XJ550 models, all XJ650 models, XJ750-D, all 1982-83 XJ750 Maxim models, and XJ900 N/FN and F models. Each:
    $ 9.95
    $ 4.95
    Dust Wiper Seals:
    HCP1820 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ550 Maxim, all XJ650 Euro models, and XJ650RJ Seca models. One seal does one tube. Each:
    $ 49.95
    HCP21555 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ550 Maxim, all XJ650 Euro models, and XJ650RJ Seca models. One seal does one tube. Each:
    $ 29.95
    $ 32.95
    $ 24.95
    HCP1824 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750P (37H), and XS1100 Standard models. One seal does one tube. Each:
    $ 37.95
    HCP21558 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750P (37H), and XS1100 Standard models. One seal does one tube. Each:
    $ 27.95
    Oil Seals:
    HCP1814 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago. One seal does one tube. Each:
    $ 21.95
    HCP20643 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 32.95
    HCP1716 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 39.95
    HCP20112 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. NOTE: these seals feature a specially design lip and spring tensions that result in a much lower sliding friction between the seal and the fork tube. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 44.95
    HCP1816 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, 1984 XJ750RL Seca (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. One seal does one tube. Each:
    $ 33.95
    HCP20646 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. Comes packaged as a pair of seals, enough to do both forks.
    $ 49.95
    HCP1718 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. Comes packaged as a pair of seals, enough to do both forks.
    $ 54.95
    Oil Seal Retaining Clips:
    HCP1827 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, all XJ650 Euro, XJ650 Maxim, and XJ650 Midnight Maxim models, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim models. All fits the following no-XJ models: 1983 XV920 K/MK, 1980-81 XS850 LH/SH/SG, 1982-83 XZ550RK, and 1983 XV750MK models: One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 9.95
    HCP20716 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, all XJ650 Euro, XJ650 Maxim, and XJ650 Midnight Maxim models, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim models. All fits the following no-XJ models: 1983 XV920 K/MK, 1980-81 XS850 LH/SH/SG, 1982-83 XZ550RK, and 1983 XV750MK models: One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    $ 8.95
    $ 6.95
    Lower Tube Metal Slider Bushings:
    HCP19996 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 49.95
    HCP19996SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10706 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 39.95
    HCP10706SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    HCP10710 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ650 Maxim and Midnight Maxim models, XJ750-P (24L model), and all 1982 XJ750 Maxim models. One slider does one tube. NOTE: owners of these bikes may wish to use the taller (and thus heavy-duty) HCP19996 or HCP10706 bushing above, which will also fit properly in these lower tubes. Each:
    $ 59.95
    HCP10710SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 114.95
    HCP10549C Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: 1983 XJ650 Turbo, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. Each:
    $ 59.95
    HCP10549CSET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 114.95
    Lower Fork Tube Oil Drain Screw and Gasket:
    $ 4.95
    $ 1.95
    $ 1.95
    $ 2.95
    $ discontinued
    $ 2.95
    $ 1.95
    $ 8.95
    $ 16.95
    $ 5.95
    $ 10.95
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    $ 9.95
    $ 6.95
    $ 16.95
    $ 10.95
    w) Lower Fork Tube DAMPER ROD RETAINING TOOL. This long aluminum tool, with proper sized nuts on each end, is used to retain the top of the fork damper rod (in the bottom of the chrome tube) when removing or installing the damper rod retaining screw. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ-series bikes except XJ600 Seca II, 1981-83 XJ750 Seca, XJ1100, and all XS1100 Special and Midnight Special models. This tool will make the disassembly of your upper tube from the lower tube much easier! NOTE: this tool is available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    HCP4402 Aftermarket DAMPER ROD RETAINING TOOL.
    $ 44.95
    Lower Fork Tube Speedometer Cable Hardware:
    HCP2182 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 6.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP3933 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 3.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish. Fitted on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 2.95
    HCP315 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, bright finish, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models.
    $ 3.95
    HCP1902 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, black finish, use 1 per bike on the following models: XJ650 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, XJ750 Midnight Maxim, and XS1100 Midnight Special models.
    $ 6.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    Lower Fork Tube Axle Retaining Hardware:
    HCP4827 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ550 Maxim, XJ650 Maxim, and 1983 XJ750 Maxim models.
    $ 11.95
    HCP4822 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ650 Midnight Maxim, 1983 XJ750 Midnight Maxim, XJ1100, and all XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP4828 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per tube (2 per bike) on both the left and right side lower fork tube. For all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), and XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
    HCP2537 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all 1981 XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike).
    $ 3.95
    HCP26192 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 1.95
    HCP26193 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 18/8 stainless steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 2.95
    HCP17110 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP26189 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP2185 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 6.95
    HCP2391 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 2 per bike on the following models: all 1982-83 XJ550 Seca, all XJ650 Turbo models. Use 1 per bike on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 7.95
    HCP16209 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 2.95
    HCP16100 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP3495 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ650 Midnight Maxim and all XJ750 Midnight Maxim models. Each:
    $ 8.95
    HCP24038 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ650 Midnight Maxim and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    Lower Tube ID Decals:
    HCP15185 Aftermarket AIR SUSPENSION WARNING DECAL, small rectangular decal has a brushed aluminum background with black lettering and border. Correct for all 1982-83 XJ650 Maxim models and 1983 XJ900RK Seca forks. On the XJ650 Maxim fork tube, it mounts on the left lower fork tube directly above the fork tube drain screw and faces to the rear of the bike. On XJ900RK models, it mounts on the left lower fork tube directly above the anti-dive housing and faces “outward”.
    $ 12.95
    HCP10774 Aftermarket AIR SUSPENSION WARNING DECAL, small clear rectangular decal with white lettering, graphics, and border, mounts directly above the left lower fork tube drain screw and faces “outward” (top edge of the decal is aligned just above the centerline of the upper mounting hole for the brake caliper). Used on XJ650 Turbo models. NOTE: this decal is identical to the HCP25301 decal below, except this decal has/ the small “air pressure” diagram on it. Either one is “correct” for the Turbo model bikes, although we suspect that this version (with the air fill diagram) is a later-production “revised / upgraded” version.
    $ 12.95
    HCP25301 Aftermarket AIR SUSPENSION WARNING DECAL, small clear rectangular decal with white lettering, graphics, and border, mounts directly above the left lower fork tube drain screw and faces “outward” (top edge of the decal is aligned just above the centerline of the upper mounting hole for the brake caliper). Used on XJ550 non-North American models (with air-assisted forks) and all XJ650 Turbo models. NOTE: this decal is identical to the HCP10774 decal above, except this decal does not have/ the small “air pressure” diagram on it. Either one is “correct” for the XJ650 Turbo model bikes, although we suspect that this version (without the air fill diagram) is an earlier-production version.
    $ 12.95
    HCP8500 Aftermarket suspension ID DECAL, small black rectangular decal with silver lettering "KYB", used as follows:
    - mounts directly above the lower fork tube drain screw and faces the rear of the bike. Use 1 on the left side fork tube on XJ550 Maxim, all XJ650 (except Turbo) models, all XJ700 and XJ750-X models, use 1 on the right side fork tube on XJ550 Seca (Noth American) models, and 1 on the left side fork tube on XJ550 Euro models.
    - mounts directly above the lower fork tube hose routing bracket boss and faces the rear of the bike. Use 1 on the left side fork tube on all YX600 Radian models.
    - mounts directly below the lower vertical adjuster stop peg on the rear shock absorbers. Use 1 per shock on all XJ550 models and all XJ650 (except Turbo) models original rear shocks.
    Each:
    $ 12.95
    FORK SYSTEM SERVICE TOOLS:
    Assembly and Dis-assembly Tools:
    NOTE: many of these tools are available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    $ 44.95
    HCP9238 Aftermarket fork upper cap bolt REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive cap bolt used on the top of the inner fork tubes on all 1984 FJ600, XJ650 Turbo, XJ700 non-X, XJ750-D, XJ750P (37H) model, all XJ900RK, RL, N/FN, and F, and 1982 XZ550R Vision models.
    $ 19.95
    HCP26093 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 35-36mm fork tubes: XJ550 Seca, FJ600, XJ600 Euro, all XJ650 (except 1983 Turbo), all XJ750 air-cooled (except XJ750P (37H Police) and X750-D models), and XJ900 N/FN models.
    $ 47.95
    HCP26094 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 37mm fork tubes: 1983 XJ650 Turbo, XJ750 Police (37H) model, XJ750-D, XJ900 RK, RL, and F models, XJ1100, and all XS1100 models.
    $ 47.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Fork Tube Cleaning and Polishing:
    HCP28489 Fork Tubes DEEP REACH CLEANING BRUSH. This 36" long brush features polyester bristles that will reach deep inside the forks tubes to clean away grit and oil sludge residue that cannot otherwise be reached or disturbed. Has a comfortable easy-grip plastic handle and flexible twisted-wire shaft. Use with your favorite cleaning solvents to get the insides of the fork tubes free of contaminants.
    $ 52.95
    ft4) These stainless-steel, bristle-wire DE-BURRING BRUSHES will work wonders on the upper cap bolt area on both the threaded and the non-threaded style of fork tubes. Tubes that use threaded cap bolt (all XJ650 Turbo, all XJ700 models, XJ750-X models, XJ750 Maxim and Midnight Maxim, XJ900RK, and XJ1100 models) should use the HCP10223 butterfly brush; non-threaded tubes can use either the HCP10222 spiral brush or the HCP10223 butterfly brush. Both style brushes have stems that are designed to be used in a standard power drill, and should be used at 850 rpm's or less. These brushes will make quick and meaningful work of the cleaning and polishing of this critical area on your upper fork tubes.
    HCP10222 Aftermarket stainless-steel double-density spiral DE-BURRING BRUSH, for use on fork tubes without a threaded cap bolt.
    $ 13.95
    HCP10223 Aftermarket stainless-steel high-density "butterfly-wings" DE-BURRING BRUSH, for use on fork tubes with or without threaded cap bolts.
    $ 14.95
    FORK OIL:
    Unlike motor oil or gear oil, fork oil's major purpose is not lubrication.....rather, it acts as part of the suspension system, providing both damping and rebound control functions. The different "weight" or viscosity of fork oils allows you to modify the ride and handling characteristics of your bike in a fairly simple way.
    And yes, it IS a lubricant also!
    Although many people----including, unbelievably, Yamaha itself----recommends the use of engine motor oil as a substitute for fork oil, this is not a very good idea. Engine oils (or any multi-viscosity oil) uses additives and detergents that, while wonderful in for their intended purposes inside an engine block, tranny case, or rear drive unit, are not such a good idea inside forks. Forks operate at a much lower temperature and temperature RANGE than engine and drivetrains do, and thus do not need all those additives. And fork oil also tends to contain higher percentages of molybdenum disulfide and anti-foaming agents than engine or gear oil, both of which are very important to proper fork operation.
    As a small example.......most motor oils are of a multi-viscosity nature (such as 10W30) which change their viscosity in relation to their temperature (thin when cool, thicker as they warm). A very necessary and useful feature for an engine, where you do not want your oil thinning out as the engine warms up. Not such a good idea for your suspension----unless for some reason you WANT your handling characteristics to change (get stiffer) as the forks heat up!
    Proper fork oil levels and scheduled change intervals are important for fork performance and fork part longevity.....water contamination, as well as particulate wear will accumulate in fork oil, and since there is no oil filtering mechanism within your forks, the only way to get the grit and gunk out (before it chews up your oil seals and slider bearings!) is to change your fork fluid regularly. Yamaha recommends a fork fluid change every 10,000 miles or 24 months (all models except XJ700's), or every 16,000 miles or 24 months (all XJ700 and XJ750-X models). If you just bought a used bike, we recommend you do a fluid change as soon as possible, because just like other routine maintenance tasks (besides engine oil changes), this is one that has very likely been ignored for the last 10-12 years!
    HINT: there’s a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it’s brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won’t mix and the water will “ball up”; brake fluid will integrate with water and absorb the water.
    Fork oil capacities and recommended weights are as follows. The amounts listed are per fork tube:
    XJ550 Maxim: 272cc or 9.20 fluid ounces. 10W fork oil.
    XJ550 Seca: 230cc or 7.78 fluid ounces. 10W fork oil.
    1980-81 XJ650 Maxim and Midnight Maxim: 262cc or 8.86 fluid ounces. 10W fork oil.
    1982-84 XJ650 Maxim: 278cc or 9.40 fluid ounces. 10W fork oil.
    1982 XJ650RJ Seca: 236cc or 7.98 fluid ounces. 10W fork oil. Fork oil level is specified as 400mm (15.75") below the top of the tube without the spring installed, forks fully collapsed.
    1982 XJ650LJ Turbo: 238cc or 8.04 fluid ounces. 10W fork oil. Fork oil level is specified as 180mm (7.09") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ650LK Turbo: unknown.
    1985-86 XJ700 non-X: 383cc or 12.96 fluid ounces. 10W fork oil.
    1985-86 XJ700-X: 389cc or 13.16 fluid ounces. 10W fork oil.
    1982 XJ750 Maxim: 257cc or 8.69 fluid ounces. 10W fork oil.
    1983 XJ750 Maxim and Midnight Maxim: 257cc or 8.69 fluid ounces. 10W fork oil. NOTE: owner's manual states that the fork oil capacity is 278cc (9.40 fluid ounces). It is unknown which measurement is correct.
    1981-83 XJ750 Seca: 309cc or 10.45 fluid ounces. 20W fork oil.
    1983 XJ750 E-II Seca or 1984 XJ750RL Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 168mm (6.61") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ900RK Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 164mm (6.46") below the top of the tube without the spring installed, forks fully collapsed.
    1982-84 XJ1100 Maxim and Midnight Maxim: 210cc or 7.10 fluid ounces. 10W fork oil. Fork oil level is specified as 210mm (8.27") below the top of the tube without the spring installed, forks fully collapsed.
    IMPORTANT NOTE: the above fork oil VOLUMES are for use only when using the stock fork springs. The use of aftermarket performance front fork coil springs will change those volumes, since aftermarket springs are thicker than stock----and thus displace more oil. Using the stock oil fluid VOLUME with aftermarket fork springs is a sure way to OVERFILL your forks, with the very real possibility of blowing out fork seals.
    Unlike with your engine oil, where a bit too much or too little oil volume in the crankcase is not really a significant concern, with fork oil, too much or too little can cause real problems (too much oil can result in blown oil seals and a stiff, harsh ride, while too little oil volume results in excessive foaming, a soft mushy ride with possible bottoming, and erratic fork performance and lots of front end "dive" upon braking).
    A better way to determine the amount of fork oil that is needed and necessary is via the measurement of the fork oil LEVEL within the tubes.....sort of like measuring the oil level with a dipstick. Yamaha does not specify this level for all models; and in any case, if using aftermarket springs, the factory oil level recommendation is not always useful. The maximum oil level should be 5-1/2" (140mm) below the top of the inner fork tube, measured with all internal fork tube components installed EXCEPT FOR THE SPRINGS, and with the inner fork tube fully collapsed into the lower (outer) tube.
    In order to be as accurate as possible, we recommend the use of a suitable measuring device, such as the HCP1728 oil level syringe listed further below.
    And finally, the fork oil viscosity can be changed from the factory recommendations to give a softer or firmer ride.......the lower the viscosity, the thinner the oil, and the softer the ride (i.e. 5W oil is thinner than 10W which is thinner than 20W, etc.) In this regard, you would certainly be correct in thinking of fork oil as a suspension "tuning tool"! Note that a thicker oil viscosity will have much more effect on the fork "rebound" characteristics than it will on the fork compression dampening function.
    A great primer on "tuning" your forks via adjusting the oil levels can be seen at:
    http://www.thumpertalk.com/forum/archive/index.php/t-89918.html
    while the theory and science and practical applications of tuning your suspension via using differing viscosities of fork oil can is revealed at:
    http://www.peterverdone.com/archive/lowspeed.htm
    ffo3) Red Line Oil products line of SYNTHETIC FORK OILS are some of the best, highest-performance fork oils developed specifically for this purpose. They provide exceptional shear lubrication, are highly resistant to any viscosity changes, and provide excellent seal lubrication as well as very high anti-foaming properties. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    Also, do not mix different brands, styles, or types of oils........you can only safely mix forks oils together from one manufacturer!
    HCP1563 Red Line high-performance SYNTHETIC FORK OIL 0W (zero weight, "like water"), 16 ounce bottle (473cc), clear. Each bottle:
    $ 27.95
    HCP1564 Red Line high-performance SYNTHETIC FORK OIL 2.5W, 16 ounce bottle (473cc), blue. Each bottle:
    $ 27.95
    HCP1258 Red Line high-performance SYNTHETIC FORK OIL 5W, 16 ounce bottle (473cc), amber. Each bottle:
    $ 27.95
    HCP1259 Red Line high-performance SYNTHETIC FORK OIL 10W, 16 ounce bottle (473cc), red. Each bottle:
    $ 27.95
    HCP1263 Red Line high-performance SYNTHETIC FORK OIL 30W, 16 ounce bottle (473cc), orange. NOTE: this oil is similar in viscosity to what most other oil manufacturers call "20W" oil. Each bottle:
    $ 27.95
    ffo4) PJ1 products line of TUNER FORK OILS are exceptional quality, value-priced fork oils developed specifically for motorcycle suspensions. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    HCP10360 PJ1 products TUNER FORK OIL 2.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10362 PJ1 products TUNER FORK OIL 5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10364 PJ1 products TUNER FORK OIL 7.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10366 PJ1 products TUNER FORK OIL 10W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10368 PJ1 products TUNER FORK OIL 15W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10370 PJ1 products TUNER FORK OIL 20W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10372 PJ1 products TUNER FORK OIL 30W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    Fork Tube Oil Level Gauges:
    HCP1728 Fork tube oil fluid level measurement GAUGE AND SYRINGE. This handy tool makes the measurement of the fork oil level easy and accurate. NOTE: the proper amount of fork oil is determined via the measurement of the fork oil LEVEL (distance below the very top of the inner tube) rather than a volume AMOUNT of oil specification. Too little oil will make the ride mushy, while too much oil makes the ride harsh (and can blow out the oil seals!)
    $ 39.95
    ffl4) Aftermarket fork oil measurement GRADUATED CYLINDERS. The best way to measure the precise amount of fork oil fluid is via the use of these lab-quality measurement cylinders. Available in either transparent (clear) or translucent (cloudy) durable plastic construction, they all have easy-to-read scale numerals (milliliters) and feature a "non-wetting" inner surface coating that prevents the concave "meniscus" from forming at the top of the fluid, thus insuring a much more accurate level reading. Large bases insure stability while large spouts make "the pour" easy and prevent messy drips. Very useful device to have for front fork oil changes.
    HCP10741 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, translucent (cloudy).
    $ 24.95
    HCP10744 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, transparent (clear).
    $ 49.95
    HCP10742 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, translucent (cloudy).
    $ 29.95
    HCP10745 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, transparent (clear).
    $ 69.95
    HCP10743 Aftermarket fork oil GRADUATED CYLINDER, super-sized 1000ml capacity, translucent (cloudy), with convenient side handle to insure steady pouring.
    $ 89.95
    Fork Tube Air Pressure Tool and Gauge:
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 6.95
    HCP9108 Aftermarket air-assisted forks LOW PRESSURE AIR GAUGE, heavy-duty 0-20 psi pencil (stick) pressure gauge marked in 1/2-psi increments, perfect for checking fork air pressures on models so equipped. Very high quality and much more accurate than standard tire pressure gauges, which is very important on the fork pressures as an imbalance between the fork pressure can lead to steering and stability issues, while too much pressure will blow out the lower tube oil seals!
    $ 9.95
  8. chacal
    XJ700 and XJ750-X MODELS FORK TUBE PARTS:
    NOTE: items marked below in red are the parts typically needed when doing a basic fork system rebuild.
    Thanks to user Tabaka45 for his expose of the XJ700 fork system with this great visual review of the procedures needed for rebuilding these forks, which can be seen at:
    http://www.xjbikes.com/forums/threads/fork-seals-85-xj700n-picture-heavy.78389/
    And these incredible 3-D renderings of the inner workings of a forking system gives a great visualization of the internal components (it is based on the 1982-83 XJ650 Maxim forks):
    http://xjbikes.com/forums/index.php?threads/29616
    XJ700 and XJ750-X owners may also wish to note the procedure needed to separate the inner tubes from the lower tubes (the "battering ram" procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    http://xjbikes.com/forums/index.php?threads/4067
    FORK TUBE REBUILD PARTS KITS:
    We now offer both a BASIC FORK REBUILD KIT and PERFORMANCE FOR TUBE REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike.
    - NOTE: the lower tube “dust boots” (sometimes called dust seals) are not included in the basic fork tube rebuild kits, but are available separate and can be found further below.
    Basic fork rebuild kit contains at least the following items:
    - cap bolt o-rings.
    - standard quality lower fork tube oil seals.
    - oil seal retaining clips.
    - oil drain screws and gaskets.
    - damper rod bolts and crush washers.
    - damper rod head piston rings.
    - air system valve cores (in the XJ700-X kit).
    HCP20621 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all XJ700 air-cooled models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 99.95
    HCP20621DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all XJ700 air-cooled models. One kit does both front tubes. This set includes the lower fork tube dust boots (but not the chrome caps for the dust boots).
    $ 134.95
    HCP20623 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all XJ700-X and XJ750-X water-cooled models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 94.95
    HCP20623DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all XJ700-X and XJ750-X water-cooled models. One kit does both front tubes. This set includes the lower fork tube dust boots (but not the chrome caps for the dust boots).
    $ 129.95
    Performance fork rebuild kit contain all of the basic rebuild kit components, along with:
    - performance fork springs.
    - upgraded, high-performance lower fork tube oil seals.
    - lower fork tube dust boots (chrome boot caps not included and should be saved for re-use from your current boots).
    - air valve core stem tool (in the XJ700-X kit).
    HCP20622 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all XJ700 air-cooled models. One kit does both front tubes.
    $ 369.95
    HCP20624 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all XJ700-X and XJ750-X water-cooled models. One kit does both front tubes.
    $ 379.95
    Of course, all of the component pieces can be ordered as individual pieces from the selections listed below, as well as non-typical wear items (inner tubes, damper rod piston rings, taper spindles, cap bolts, etc.), as well as the fork oil and specialty tools needed to properly restore or enhance your front suspension performance.
    UPPER (INNER) FORK TUBES AND PARTS:
    Chrome Inner Fork Tubes:
    HCP8529 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ700 non-X models, each:
    $ 299.95
    HCP8529SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8530 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ700-X and XJ750-X models, each:
    $ 299.95
    HCP8530SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    Inner Tube Top Cover/Cap:
    HCP8287 OEM inner fork tube top CAP, fits either the left or right side tube of the following models: all XJ700 non-X models. Has the polished chrome decorative surface as original. Each:
    $ 12.95
    Inner Fork Tube Cap Bolts and Related:
    HCP8292 OEM inner fork tube CAP BOLT, fits either side. Used on all 1984 FJ600, XJ700 non-X, XJ750RL, and XJ900RK, RL, and N/FN Seca models. NOTE: these cap bolts require a special inverse-hex tool HCP9238 to properly remove and install. Each:
    $ 49.95
    $ 19.95
    HCP8286 OEM inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 7.95
    HCP20708 Aftermarket inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 5.95
    Inner Tube Fork Springs:
    HCP9437 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all 1984-85 FJ600, XJ700, and XJ750-X models. Your original front spring spacers and seats are required to be re-used with these springs. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 18 cc's less fork oil (for a total of 365cc's per tube) when installing these springs on XJ700 non-X models, and use approximately 38 cc's less fork oil (for a total of 351cc's per tube) when installing these springs on XJ700-X or XJ750-X models. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 249.95
    Inner Fork Tube Spring Spacers, Rebound Springs, Damper Rods, and Spring Seats:
    HCP8302 OEM inner fork tube SPRING SPACER TUBE, fits either side. Used on all 1985 XJ700 non-X and all 1986 XJ700 models. Each:
    $ 14.95
    HCP8280 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1985 FJ600 models, XJ700, XJ750-X, and XJ900 F models. Each:
    $ 37.95
    HCP13657 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1984-85 FJ600, all XJ700, XJ750-X, XJ750RL Canadian (44X model), and XJ900 models. Use 1 per fork tube. Each:
    $ 17.95
    Inner Fork Tube Taper Spindle:
    HCP3085 OEM upper (inner) fork tube TAPER SPINDLE, fits either side. Fits all XJ550 models, 1984 FJ600, all XJ650 models, all XJ700 and XJ750-X models, all XJ750 Maxim and Midnight Maxim models, XJ900 N/FN and F models, all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 31.95
    Inner Tube Metal Slider Bushings:
    HCP10703 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1992-93 XJ600 Seca II, and all XJ700 and XJ750-X models. One slider does one tube. Each:
    $ 29.95
    HCP10703SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 57.95
    Air Inflation Valves:
    HCP9194 Aftermarket fork tube AIR VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all 1985 FJ600 models, 1982-83 XJ650 Maxim and Turbo models, XJ700-X models, all XJ750 models, the XJ900RK model, XJ1100, and all XS1100 Special and Midnight Special models. If your stem is leaking air, this is the inexpensive way to fix it. Each:
    $ 3.95
    HCP9194SET2 Aftermarket fork tube AIR VALVE STEM CORES, set of 2:
    $ 6.95
    $ 5.95
    INNER FORK TUBE RETAINING HARDWARE:
    Crown Bracket Inner Fork Tube Retaining Hardware:
    HCP4946 OEM crown bracket fork tube CINCH BOLT, use 1 per side. For the following models: all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP2537 OEM crown bracket fork tube FLAT WASHER, alloy steel, bright finish. Use 2 per side. For the following models: all XJ550 models, 1980 XJ650 models, and all XJ700 and XJ750-X models. Each:
    $ 3.95
    $ 1.95
    $ 2.95
    $ 3.95
    $ 3.95
    HCP2185 OEM crown bracket fork tube LOCK WASHER, use 1 per side. For the following models: all XJ700 and XJ750-X models. Each:
    $ 6.95
    HCP16209 Aftermarket crown bracket fork tube LOCK WASHER, zinc-plated alloy steel, use 1 per side. For the following models: all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP16100 Aftermarket crown bracket fork tube LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per side. For the following models: all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP16102 Aftermarket crown bracket fork tube LOCK WASHER, black-oxide coated alloy steel, use 1 per side. For the following models: all XJ700 and XJ750-X models. Each:
    $ 3.95
    $ 4.95
    Under-bracket Inner Fork Tube Retaining Hardware:
    HCP4956 OEM under-bracket fork tube CINCH BOLT, alloy steel, socket head cap screw with a bright finish. Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 4.95
    HCP21942 Aftermarket under-bracket fork tube CINCH BOLT, alloy steel socket head cap screw with a bright finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 1.75
    HCP23282 Aftermarket under-bracket fork tube CINCH BOLT, 18/8 stainless steel socket head cap screw with a bright finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP22203 Aftermarket under-bracket fork tube CINCH BOLT, 316 stainless steel socket head cap screw with a bright finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP23283 Aftermarket under-bracket fork tube CINCH BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel. Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP21944 Aftermarket under-bracket fork tube CINCH BOLT, alloy steel socket head cap screw with a black finish, Use 1 per side on all 1992-94 and 1997-98 XJ600 Seca models, and 2 per side on all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP4957 OEM bolt head DECORATIVE CHROME CAP, this push-in chrome-plated cap (“cover”) fits into the socket head of the bolt, and makes for a nice pretty finished appearance. For the following models: Use 2 per side (4 total) on all XJ700 and XJ750-X models for the lower steering under-bracket fork tube cinch bolts, use 2 per side (4 total) for the handlebar riser clamps on all XJ700 and XJ750-X models, and 2 per side (4 total) for the optional tall backrest pad retaining bolts on all XJ700 and XJ750-X models. Each:
    $ 4.95
    HCP4957SET4 OEM bolt head DECORATIVE CHROME CAPS, set of 4:
    $ 16.95
    LOWER (OUTER) FORK TUBE PARTS:
    Dust Wiper Seals:
    HCP1825 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ700 and XJ750-X models, chrome-capped as original. One seal does one tube. Each:
    $ 42.95
    HCP21559 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ700 and XJ750-X models, seal only. Does not include the chrome cap, which you will need to remove (pop off) and re-use if you wish to retain. The cap can be glued in place onto the seal with weatherstrip adhesive, gasket maker compound, etc. One seal does one tube. Each:
    $ 24.95
    Oil Seals:
    NOTE: when installing oil seals, make sure that the area where the seal will fit into is clean, free of any nicks and burrs, and that the lower tube metal slide bushing is fully seated. Oil seals install with the large opening facing down, into the tube, and on most seals, the small cast lettering and numbering on the seal faces upwards.
    Seals are designed to be installed with a seal driver of some type, although a properly sized piece of hard plastic tubing, perhaps with a proper sized metal washer on top of the seal to "spread the load", works as well. Always make sure that oil seals are fully seated and not damaged or installed in a crooked or cocked manner.
    HCP1817 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. One seal does one tube. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago. Each:
    $ 27.95
    HCP20647 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. Comes packaged as a pair of seals, enough to do both forks. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago.
    $ 42.95
    HCP1719 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. Comes packaged as a pair of seals, enough to do both forks. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago.
    $ 47.95
    Oil Seal & Dust Seal Kits:
    HCP1721 Aftermarket standard quality lower fork tube BLACK OIL SEALS & DUST WIPER SEALS KIT, fits all of the following models: all XJ700 and XJ750-X models. Also fits the following non-XJ models: 1984-87 XV700 Virago, 1988-94 XV750 Virago,1984-85 XV1000 Virago, and 1989-94 XV1100 Virago. Comes with one pair of both the oil and dust seals, enough to do both forks.
    $ 89.95
    HCP1715 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: all XJ700 and XJ750-X models. Comes with one black oil seal, one chrome-capped dust wiper seal, the lower tube oil seal retaining clip, and both metal slide bushings (upper and lower tubes), enough to do one fork tube. NOTE: this kit does not contain the following items which we also recommend that you also purchase: upper tube top cap bolt O-RINGS, lower tube damper rod CRUSH WASHERS, and the lower tube fork oil drain screw GASKETS. Also fits the following non-XJ models: 1984-87 XV700 Virago, 1988-94 XV750 Virago,1984-85 XV1000 Virago, and 1989-94 XV1100 Virago.
    $ 109.95
    HCP1715SET2 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: all XJ700 and XJ750-X models. Two sets are enough to rebuild one bike.
    $ 199.95
    HCP1828 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 8.95
    HCP20717 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    Oil Seal Lower Washer:
    HCP3093 OEM lower fork tube oil seal WASHER, fits either left or right tube on the following models: all 1992-98 XJ600 Seca II, XJ700, and XJ750-X models. One washer does one tube, fits directly below the oil seal and above the lower tube metal slider bushing. Each:
    $ 26.95
    HCP3087 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1992-93 XJ600 Seca II models, all XJ700, XJ750-X, and 1988-90 FZR400 models. One slider does one tube. Each:
    $ 44.95
    HCP3087SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 84.95
    HCP10708 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1992-97 XJ600 Seca II models, XJ700, XJ750-X, and 1988-90 FZR400 models. One slider does one tube. One slider does one tube. NOTE: although the factory lists different part numbers for these lower bushings (1992-93 and 1994-97), the bushings are actually identical in size for all 1992-97 Seca II models. Each:
    $ 34.95
    HCP10708SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 59.95
    HCP5187 OEM lower fork tube oil DRAIN SCREW, use one per tube. Panhead, phillips-drive, alloy steel with a black finish. Note that the black screw was used on models with black lower fork tubes (1982-83 XJ550 Seca, FJ600, 1995 XJ600 Seca II, XJ650 Midnight Maxim, XJ650 Turbo, XJ750 Midnight Maxim, 1981-83 XJ750 Seca and XJ750 Euro models, and some XJ750P models 37H). All other models with natural aluminum lower fork tubes used a screw with a bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 4.95
    HCP29817 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead, phillips-drive, alloy steel with a black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29005 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive zinc-plated alloy steel. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29006 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6710 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ discontinued
    HCP6712 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6711 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP7111 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 8.95
    HCP7111SET2 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 16.95
    HCP21320 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 5.95
    HCP21320SET2 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 10.95
    HCP8233 OEM fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 9.95
    HCP28069 Aftermarket fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 6.95
    HCP8234 OEM fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 16.95
    HCP12950 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 10.95
    w) Lower Fork Tube DAMPER ROD RETAINING TOOL. This long aluminum tool, with proper sized nuts on each end, is used to retain the top of the fork damper rod (in the bottom of the chrome tube) when removing or installing the damper rod retaining screw. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ-series bikes except XJ600 Seca II, 1981-83 XJ750 Seca, XJ1100, and all XS1100 Special and Midnight Special models. This tool will make the disassembly of your upper tube from the lower tube much easier! NOTE: this tool is available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP4402 Aftermarket DAMPER ROD RETAINING TOOL.
    $ 44.95
    Fork Tube Brace and Hardware:
    HCP4481 OEM lower fork tube STIFFENING BRACE, attaches to the upper "ears" of the lower forks tubes and provides additional rigidity to the fork system. For all XJ700 and XJ750-X models.
    $ 69.95
    HCP3966 OEM lower fork tube brace polished, domed-head flanged RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. For all XJ700 and XJ750-X models. Each:
    $ 7.95
    HCP2325 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For 1982 XJ750 Maxim and all XJ700 and XJ750-X models. Each:
    $ 3.95
    $ 3.95
    $ 1.95
    $ 2.95
    $ 3.95
    $ 3.95
    $ 6.95
    $ 2.95
    $ 3.95
    $ 3.95
    $ 3.95
    $ 2.95
    HCP4821 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ700-X and XJ750-X models. Each:
    $ 8.95
    Lower Fork Tube Warning Decals:
    Note that the XJ700-X and XJ750-X models used both the HCP8500 and the HCP8105 decals on the left lower fork tube.
    Each:
    $ 12.95
    HCP8105 Aftermarket AIR SUSPENSION WARNING DECAL, small clear rectangular decal with black lettering and border, mounts directly above the right lower fork tube drain screw and faces the rear of the bike on XJ750 Maxim and Midnight Maxim forks tubes, on the left lower fork tube facing outwards (between the lower caliper mounting bolt and the front axle hole) on all XJ700-X and XJ750-X models, and is also used on XJ650 Turbo and XJ1100 rear air shock absorbers.
    $ 11.95
    $ 44.95
    $ 19.95
    HCP26095 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 38mm fork tubes: XJ600 Seca II thru 1997, XJ700 all models, and XJ750-X water-cooled models.
    $ 47.95
    $ 44.95
    $ 46.95
    $ 47.95
    Anti-Seize Paste:
    $ 8.95
    $ 3.95
    $ 9.95
    $ 13.95
    $ 13.95
    $ 19.95
    $ 11.95
    $ 11.95
    $ 4.95
    $ 11.95
    $ 11.95
    $ 41.95
    $ 44.95
    $ 42.95
    $ 52.95
    $ 13.95
    $ 14.95
    FORK OIL:
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 39.95
    $ 24.95
    $ 49.95
    $ 29.95
    $ 69.95
    $ 89.95
    $ 6.95
    $ 9.95
  9. chacal
    XJ750 Maxim and Midnight Maxim MODELS FORK TUBE PARTS:
    NOTE: all XJ750-X model fork tube parts are found in the "XJ700" fork tube parts section above.
    NOTE: all 1981-84 XJ750 Seca and XJ750 Euro model fork tube parts are found in the "XJ750 Seca" fork tube parts section below.
    NOTE: XJ750 Police (24L, 33V, and 39Y models) used the XJ650 Turbo master cylinder with XJ750 Seca calipers and rotors, and XJ650 Turbo style forks.
    NOTE: XJ750 Police (37H models) used the XJ650 Turbo master cylinder with XJ650 Turbo/XJ750 Maxim/Midnight Maxim calipers, XJ650 Turbo rotors, and XJ900 style forks with anti-dive.
    A good visual review of the procedures needed for rebuilding these forks can be seen at:
    http://xjbikes.com/forums/index.php?threads/8355
    - cap bolt o-rings.
    - air system o-rings and air valve cores.
    - air joint cushions, o-rings, and retaining rings (in the 1982 XJ750 Maxim kit).
    HCP20617 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1982 XJ650 Turbo and 1982 XJ750 Maxim models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 149.95
    HCP20617DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1982 XJ650 Turbo and 1982 XJ750 Maxim models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 184.95
    HCP20627 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1983-84 XJ750 Maxim and Midnight Maxim models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 99.95
    HCP20627DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1983-84 XJ750 Maxim and Midnight Maxim models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 134.95
    - upgraded, high-performance lower tube oil seals.
    - lower fork tube dust boots.
    - air valve core stem tool.
    HCP20626 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1982 XJ750 Maxim models. One kit does both front tubes.
    $ discontinued
    HCP20628 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1983-84 XJ750 Maxim and Midnight Maxim models. One kit does both front tubes.
    $ discontinued
    HCP8531 Aftermarket chrome INNER FORK TUBE, fits left or right side, for 1982 XJ750 Maxim models, each:
    $ 299.95
    HCP8531SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP8532 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1983 XJ750 Maxim and Midnight Maxim models, each:
    $ 299.95
    HCP8532SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP13409 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ750P (37H police model). Each:
    $ 299.95
    HCP13409SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    Inner Tube Gaiter Boots:
    Although not originally used on any XJ-series bikes, these accordion-pleated thick rubber boots fit into the area between the bottom of the steering underbracket and the top of the lower (outer) fork boots, covering and protecting this area from damage, while providing an "old-school" or cafe-racer type look. They are retained to the chrome tube itself (at their top end) via spring clips, and to the top of the lower fork tube via metal screw-clamps.
    HCP10806 Aftermarket front fork tube GAITER BOOT, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models. Does not include attaching hardware. Heavy-duty design has equal spacing between each accordion pleat. Each:
    $ 99.95
    HCP10806SET2 Aftermarket front fork tube GAITER BOOTS, set of 2:
    $ 179.95
    HCP10941 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10942 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10943 Aftermarket front fork tube GAITER BOOTS, red pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10938 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP10939 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP11420 Aftermarket fork tube gaiter boot LOWER RETAINING SPRING-CLAMP. Black powdercoated wire-spring type clamp has that old-time look and feel to it. Secure the lower end of the gaiter boot to the top of the lower (outer) fork tube. Fits all XJ-series models. Use 1 per tube, each:
    $ 14.95
    NOTE: gaiter boots normally do not require any type of retainer at their upper end, as the tight friction fit between the boot opening and the chrome tube prevents migration of the boot. If movement seems to occur, then we recommend the use of thin, black electrical wire ties to cinch the boot flange tightly to the tube.
    HCP8254 OEM inner fork tube black plastic top CAP, fits either the left or right side tube of the following models: 1982-83 XJ650 Maxim and 1983 XJ750 Maxim and Midnight Maxim models. Has the words AIR ADJUSTABLE cast into the top face as original. This cap screws directly onto the brass air valve on these models. Each:
    $ 39.95
    HCP8290 OEM inner fork tube black plastic top CAP, fits either the left or right side tube of the following models: 1982 XJ750 Maxim models. Has the words 1-2-3-4 numbers cast into the top surface as original. Each:
    $ discontinued
    HCP8240 OEM inner fork tube black plastic top cap SCREW, retains the HCP8290 plastic top cap to the adjuster rod. Fits 1982 XJ750 Maxim models. Use 1 per tube, each:
    $ 6.95
    HCP8289 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 28.95
    HCP22880 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 19.95
    Inner Fork Tube Cap Bolts and Related Hardware:
    NOTE: 1982 XJ750 Maxim owners may wish to review this information regarding the proper installation of the oil control rod into the forks:
    http://xjbikes.com/forums/index.php?threads/32271
    HCP8242 OEM inner fork tube decorative cover RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap and the top of the lower steering bracket. Use 1 or 2 per fork tube (depending on model) on all on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 all Special models, 1983 XV750MK Midnight Virago, 1983 XV920MK Midnight Virago, and all XS1100 Standard models. Each:
    $ 10.95
    HCP8242SET2 OEM inner fork tube decorative cover RUBBER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket inner fork tube decorative cover rubber RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap and the top of the lower steering bracket. Use 1 or 2 per fork tube (depending on model) on all on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 all Special models, 1983 XV750MK Midnight Virago, 1983 XV920MK Midnight Virago, and all XS1100 Standard models. Each:
    $ 7.95
    HCP15647SET2 Aftermarket inner fork tube decorative cover rubber RUBBER CUSHION GASKETS, set of 2:
    $ 14.95
    HCP8241 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 14.95
    HCP20707 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 9.95
    $ 19.95
    HCP9435 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ750 Maxim and Midnight Maxim models. Your original front spring spacers and spring seats are required to be re-used with these springs. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 36 cc's less fork oil (for a total of 221cc's per tube) when installing these springs on 1982 XJ750 Maxim models, and use approximately 35 cc's less fork oil (for a total of 243cc's per tube) when installing these springs on 1983 XJ750 Maxim or Midnight Maxim models. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ discontinued
    HCP8284 OEM inner fork tube SPRING SPACER TUBE, fits either side. Used on all 1982-83 XJ650 Maxim and 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 10.95
    HCP8303 OEM inner fork tube SPRING SPACER TUBE, fits either side. Used on all XJ650 Turbo and 1982 XJ750 Maxim models. Each:
    $ 14.95
    HCP8239 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1982-83 XJ650 Maxim, 1982 XJ650 Turbo, XJ750-D, XJ750-P (24L and 37H models), and all XJ750 Maxim and Midnight Maxim models. Each:
    $ 19.95
    HCP20994 Aftermarket inner fork tube SPRING SEAT, fits either side. Used on all 1982-83 XJ650 Maxim, 1982 XJ650 Turbo, XJ750-D, XJ750-P (24L and 37H models), and all XJ750 Maxim and Midnight Maxim models. Each:
    $ 14.95
    HCP8253 OEM inner fork tube damper rod REBOUND SPRING, fits either side. Used on all XJ550 models, all XJ650 models (except Turbo), all 1983-84 XJ750 Maxim and Midnight Maxims, 1978-79 XS1100 Standard models, 1980 XS1100 (3X0) Euro model, 1989 and 1995-2008 XV250 Virago, 2008-2020 XV250 V-Star, 1983 XZ550RK, 1983 XV500, 1983-92 YZ80, 1980-81 YZ100, 1976-78 YZ250, and 1976 YZ400 models. Use 1 per tube, each:
    $ 39.95
    HCP13656 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all XJ550, XJ650, all XJ750 (except XJ750 Seca and XJ750-X models), and 1978-79 XS1100 Standard models. Use 1 per fork tube. Each:
    $ 17.95
    Inner Fork Tube Taper Spindle and Oil Lock Valve Parts:
    $ 31.95
    HCP8344 OEM inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 2 per tube, each:
    $ discontinued
    HCP19355 Aftermarket inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 2 per tube, each:
    $ 19.95
    HCP19356 Aftermarket inner fork tube oil lock valve FLAT WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 1 per tube, each:
    $ 17.95
    NOTE: the order of installation for the above washers is as follows (and only applies to bikes with anti-dive front fork systems, i.e. the XJ750RL, XJ750P (37H model), and XJ900RK and RL models):
    Order of assembly of 1984 XJ750RL, XJ750P (37H model, and XJ900RK/RL Seca oil lock valve assembly components onto damper rod:
    NOTE: the Yamaha factory service manual has an incorrect written description and an incorrect image showing the assembly order of the “oil lock valve” components onto the damper rod, showing the two wave washers being adjacent to each other. The correct assembly sequence --- as shown below --- is for the wave washers to be separated by the flat shim washer:
    TOP (HEAD) OF DAMPER ROD
    DAMPER ROD REBOUND SPRING
    Above fitted thru bottom of inner/upper (chrome) fork tube.
    On thinner, lower end of damper rod:
    WAVE WASHER (HCP19355) goes onto the damper rod shaft first
    FLAT WASHER (HCP19356) goes onto the damper rod shaft next
    WAVE WASHER (HCP19355) goes onto the damper rod shaft third
    Finally the TAPER SPINDLE (HCP3085) goes on last.
    INNER FORK TUBE AIR SYSTEM PARTS:
    Air Joint Cushions, O-Rings, and Retainers:
    HCP8242 OEM air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 10.95
    HCP8242SET2 OEM air joint rubber UPPER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint, and cushions the top of the air joint from the bottom of the crown bracket. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 7.95
    HCP15647SET2 Aftermarket air joint rubber UPPER CUSHION GASKETS, fits either side. Set of two:
    $ 14.95
    HCP8238 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1982 XJ650 Turbo, XJ750-P (24L model), 1982 XJ750 Maxim, and 1983 XV920 K/MK models. Uses 2 o-rings per joint. Each:
    $ 14.95
    HCP8238SET2 OEM inner fork tube air joint INNER O-RINGS, set of 2:
    $ 27.95
    HCP8238SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ 49.95
    HCP14015 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1982 XJ650 Turbo, XJ750-P (24L model), 1982 XJ750 Maxim, and 1983 XV920 K/MK models. Uses 2 o-rings per joint. Each:
    $ 9.95
    HCP14015SET2 Aftermarket inner fork tube air joint INNER O-RING, set of 2:
    $ 17.95
    HCP14015SET4 Aftermarket inner fork tube air joint INNER O-RING, set of 4:
    $ 29.95
    HCP8341 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, and XJ900RK and RL models. Uses 2 o-rings per joint. Each:
    $ discontinued
    HCP8341SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ discontinued
    HCP20701 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, XJ900RK and RL models, and XJ1100 models. Uses 2 o-rings per joint. Each:
    $ 8.95
    HCP20701SET4 Aftermarket inner fork tube air joint INNER O-RINGS, set of 4:
    $ 27.95
    HCP8283 OEM inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: XJ650 Turbo, 1982 XJ750 Maxim, XJ750-D, XJ750-P (24L model), XJ900RK and RL, and 1983 XV920K Virago models. Each:
    $ discontinued
    HCP12315 Aftermarket inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: XJ650 Turbo, 1982 XJ750 Maxim, XJ750-D, XJ750-P (24L model), XJ900RK and RL, and 1983 XV920K Virago models. Each:
    $ 7.95
    Air Inflation Valves and O-Rings:
    HCP8274 OEM inner fork tube air joint AIR VALVE WITH CAP, comes complete the internal stem core, its o-ring, and chrome cap. Fits the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and the included protective cap is much smaller than the huge caps used on those models, and due to the length difference, those large original caps will not fit properly on this shorter valve. This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 57.95
    HCP11890 OEM inner fork tube air joint brass AIR VALVE ONLY, comes complete the internal stem core and its o-ring. The chrome cap is not included. Fits the following models: 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. Each:
    $ 39.95
    HCP11876 OEM inner fork tube air joint air valve CHROME CAP, ribbed, dome-head style. Correct for all of the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This cap can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is much smaller than the large original caps used on those models. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 19.95
    HCP13698 OEM inner fork tube air joint AIR VALVE, comes complete the internal stem core, its o-ring, and chrome cap. Fits the following models: XJ750-P (37H model, use 1 per tube). Each:
    $ discontinued
    HCP2322 OEM inner fork tube air joint air valve and air hose-to-joint O-RING, fits the following models: 1985 FJ600 models (use 1 per tube), 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 3 per bike), XJ750-P (24L and 37H models, use 2 per bike), XJ750-D (use 3 per bike), 1982 XJ750 Maxim (use 3 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 3 per bike), and XJ900RK and RL models (use 3 per bike). Each:
    $ 7.95
    HCP14020 Aftermarket inner fork tube air joint air valve and air hose-to-joint O-RING, fits the following models: 1985 FJ600 models (use 1 per tube), 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 3 per bike), XJ750-P (24L and 37H models, use 2 per bike), XJ750-D (use 3 per bike), 1982 XJ750 Maxim (use 3 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 3 per bike), and XJ900RK and RL models (use 3 per bike). Each:
    $ 5.95
    $ 3.95
    $ 6.95
    $ 5.95
    HCP4522 OEM crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP21973 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright yellow-zinc finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 1.95
    HCP21974 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 1.95
    HCP21975 Aftermarket crown bracket fork tube CINCH BOLT, 18-8 stainless steel, hex-head bolt with a bright finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 2.95
    HCP4531 OEM crown bracket fork tube CINCH BOLT, use 1 per side. For the following models: XJ650 Turbo, 1982 XJ750 Maxim, and all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 7.95
    HCP4531SET2 OEM crown bracket fork tube CINCH BOLTS, use 1 per side. Pair:
    $ 14.95
    HCP3945 OEM crown bracket fork tube FLAT WASHER, alloy steel, black finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 4.95
    HCP26192 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, bright finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 1.95
    HCP26193 Aftermarket crown bracket fork tube FLAT WASHER, 18/8 stainless steel, bright finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 2.95
    HCP17110 Aftermarket crown bracket fork tube FLAT WASHER, 316 stainless steel, dull finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 3.95
    HCP26189 Aftermarket crown bracket fork tube FLAT WASHER, alloy steel, black finish, for use on all of the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 3.95
    HCP4240 OEM crown bracket fork tube cinch bolt CROWN NUT, alloy steel, dark finish. For the following models: use 1 per tube cinch bolt (2 per bike) on all 1981-83 XJ650 Maxim and Midnight Maxim models, 1983 XJ750 Maxim and Midnight Maxim models, 1980-81 XS1100 Midnight Special, and 1981 XS1100 Special models. Use 1 per tube cinch bolt and 1 on the rear lateral stem pinch bolt (total of 3 per bike) on all XJ650 Euro, XJ650RJ Seca, XJ650 Turbo, and 1980 XS1100 Standard models. Each:
    $ 6.95
    HCP10959 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, alloy steel, bright finish, same height as the HCP4240 and HCP4528 crown nuts. Each:
    $ 3.95
    HCP21940 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 5.95
    HCP21941 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, chromed steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 8.95
    HCP18011 Aftermarket cinch bolt head protective CAP. Smooth, black plastic cap snaps over the head of the fork tube cinch bolts, giving them a very "modern" look, protecting the head from rust. Fits all OEM or aftermarket bolts with a 12mm hex or socket head. Each:
    $ 4.95
    HCP3652 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all XJ550 models, all XJ650 models, XJ750-D, all 1982-83 XJ750 Maxim models, and XJ900 N/FN and F models. Each:
    $ 9.95
    $ 4.95
    Dust Wiper Seals:
    HCP1823 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984-85 FJ600, all XJ650 Maxim and Midnight Maxim, 1982 XJ650 Turbo, XJ750-P (24L model), and XJ750 Maxim and Midnight Maxim models. One seal does one tube. Each:
    $ 32.95
    HCP21557 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984-85 FJ600, all XJ650 Maxim and Midnight Maxim, 1982 XJ650 Turbo, XJ750-P (24L model), and XJ750 Maxim and Midnight Maxim models. One seal does one tube. Each:
    $ 24.95
    HCP1824 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750P (37H), and XS1100 Standard models. One seal does one tube. Each:
    $ 37.95
    HCP21558 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750P (37H), and XS1100 Standard models. One seal does one tube. Each:
    $ 27.95
    Oil Seals:
    HCP1814 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago. One seal does one tube. Each:
    $ 21.95
    HCP20643 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 32.95
    HCP1716 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 39.95
    HCP20112 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. NOTE: these seals feature a specially design lip and spring tensions that result in a much lower sliding friction between the seal and the fork tube. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 44.95
    HCP1816 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. One seal does one tube. Each:
    $ 33.95
    HCP20646 Aftermarket standard quality lower fork tube BLACK OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. Comes packaged as a pair of seals, enough to do both forks.
    $ 49.95
    HCP1718 Aftermarket premium quality lower fork tube BLACK OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. Comes packaged as a pair of seals, enough to do both forks.
    $ 54.95
    Oil Seal Retaining Clips:
    HCP1827 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, all XJ650 Euro, XJ650 Maxim, and XJ650 Midnight Maxim models, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim models. All fits the following no-XJ models: 1983 XV920 K/MK, 1980-81 XS850 LH/SH/SG, 1982-83 XZ550RK, and 1983 XV750MK models: One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 9.95
    HCP20716 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, all XJ650 Euro, XJ650 Maxim, and XJ650 Midnight Maxim models, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim models. All fits the following no-XJ models: 1983 XV920 K/MK, 1980-81 XS850 LH/SH/SG, 1982-83 XZ550RK, and 1983 XV750MK models: One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    $ 8.95
    $ 6.95
    Lower Tube Metal Slider Bushings:
    HCP19996 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 49.95
    HCP19996SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10706 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 39.95
    HCP10706SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    HCP10710 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ650 Maxim and Midnight Maxim models, XJ750-P (24L model), and all 1982 XJ750 Maxim models. One slider does one tube. NOTE: owners of these bikes may wish to use the taller (and thus heavy-duty) HCP19996 or HCP10706 bushing above, which will also fit properly in these lower tubes. Each:
    $ 59.95
    HCP10710SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 114.95
    HCP4259 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H models), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 49.95
    HCP4259SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10709 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 39.95
    HCP10709SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    Lower Fork Tube Oil Drain Screw and Gasket:
    $ 4.95
    $ 1.95
    $ 1.95
    $ 2.95
    $ discontinued
    $ 2.95
    $ 1.95
    $ 8.95
    $ 16.95
    $ 5.95
    $ 10.95
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    $ 9.95
    $ 6.95
    $ 16.95
    $ 10.95
    $ 44.95
    Lower Fork Tube Speedometer Cable Hardware:
    HCP2182 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 6.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP3933 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 3.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish. Fitted on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 2.95
    HCP315 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, bright finish, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models.
    $ 3.95
    HCP1902 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, black finish, use 1 per bike on the following models: XJ650 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, XJ750 Midnight Maxim, and XS1100 Midnight Special models.
    $ 6.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    Lower Fork Tube Axle Retaining Hardware:
    $ 3.95
    HCP4827 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ550 Maxim, XJ650 Maxim, and 1983 XJ750 Maxim models.
    $ 11.95
    HCP4822 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ650 Midnight Maxim, 1983 XJ750 Midnight Maxim, XJ1100, and all XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP4828 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per tube (2 per bike) on both the left and right side lower fork tube. For all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), and XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
    HCP2537 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all 1981 XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike).
    $ 3.95
    HCP26192 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 1.95
    HCP26193 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 18/8 stainless steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 2.95
    HCP17110 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP26189 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP2185 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 6.95
    HCP2391 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 2 per bike on the following models: all 1982-83 XJ550 Seca, all XJ650 Turbo models. Use 1 per bike on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 7.95
    HCP16209 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 2.95
    HCP16100 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP3495 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ650 Midnight Maxim and all XJ750 Midnight Maxim models. Each:
    $ 8.95
    HCP24038 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ650 Midnight Maxim and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    $ 11.95
    FORK SYSTEM SERVICE TOOLS:
    Assembly and Dis-assembly Tools:
    NOTE: many of these tools are available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    $ 44.95
    HCP9238 Aftermarket fork upper cap bolt REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive cap bolt used on the top of the inner fork tubes on all 1984 FJ600, XJ650 Turbo, XJ700 non-X, XJ750-D, XJ750P (37H) model, all XJ900RK, RL, N/FN, and F, and 1982 XZ550R Vision models.
    $ 19.95
    HCP26093 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 35-36mm fork tubes: XJ550 Seca, FJ600, XJ600 Euro, all XJ650 (except 1983 Turbo), all XJ750 air-cooled (except XJ750P (37H Police) and X750-D models), and XJ900 N/FN models.
    $ 47.95
    HCP26094 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 37mm fork tubes: 1983 XJ650 Turbo, XJ750 Police (37H) model, XJ750-D, XJ900 RK, RL, and F models, XJ1100, and all XS1100 models.
    $ 47.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Fork Tube Cleaning and Polishing:
    HCP28489 Fork Tubes DEEP REACH CLEANING BRUSH. This 36" long brush features polyester bristles that will reach deep inside the forks tubes to clean away grit and oil sludge residue that cannot otherwise be reached or disturbed. Has a comfortable easy-grip plastic handle and flexible twisted-wire shaft. Use with your favorite cleaning solvents to get the insides of the fork tubes free of contaminants.
    $ 52.95
    ft4) These stainless-steel, bristle-wire DE-BURRING BRUSHES will work wonders on the upper cap bolt area on both the threaded and the non-threaded style of fork tubes. Tubes that use threaded cap bolt (all XJ650 Turbo, all XJ700 models, XJ750-X models, XJ750 Maxim and Midnight Maxim, XJ900RK, and XJ1100 models) should use the HCP10223 butterfly brush; non-threaded tubes can use either the HCP10222 spiral brush or the HCP10223 butterfly brush. Both style brushes have stems that are designed to be used in a standard power drill, and should be used at 850 rpm's or less. These brushes will make quick and meaningful work of the cleaning and polishing of this critical area on your upper fork tubes.
    HCP10222 Aftermarket stainless-steel double-density spiral DE-BURRING BRUSH, for use on fork tubes without a threaded cap bolt.
    $ 13.95
    HCP10223 Aftermarket stainless-steel high-density "butterfly-wings" DE-BURRING BRUSH, for use on fork tubes with or without threaded cap bolts.
    $ 14.95
    Anti-Dive System Tools:
    HCP12230 Aftermarket anti-dive brake plunger PISTON POPPER, for all models using an anti-dive system.
    $ 13.95
    HCP16049 Aftermarket fork anti-dive brake plunger assembly REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive plug used on the top of the anti-dive units on all XJ750-D, XJ750P (37H model), XJ900RK, and XJ900RL models.
    $ 19.95
    FORK OIL:
    Unlike motor oil or gear oil, fork oil's major purpose is not lubrication.....rather, it acts as part of the suspension system, providing both damping and rebound control functions. The different "weight" or viscosity of fork oils allows you to modify the ride and handling characteristics of your bike in a fairly simple way.
    And yes, it IS a lubricant also!
    Although many people----including, unbelievably, Yamaha itself----recommends the use of engine motor oil as a substitute for fork oil, this is not a very good idea. Engine oils (or any multi-viscosity oil) uses additives and detergents that, while wonderful in for their intended purposes inside an engine block, tranny case, or rear drive unit, are not such a good idea inside forks. Forks operate at a much lower temperature and temperature RANGE than engine and drivetrains do, and thus do not need all those additives. And fork oil also tends to contain higher percentages of molybdenum disulfide and anti-foaming agents than engine or gear oil, both of which are very important to proper fork operation.
    As a small example.......most motor oils are of a multi-viscosity nature (such as 10W30) which change their viscosity in relation to their temperature (thin when cool, thicker as they warm). A very necessary and useful feature for an engine, where you do not want your oil thinning out as the engine warms up. Not such a good idea for your suspension----unless for some reason you WANT your handling characteristics to change (get stiffer) as the forks heat up!
    Proper fork oil levels and scheduled change intervals are important for fork performance and fork part longevity.....water contamination, as well as particulate wear will accumulate in fork oil, and since there is no oil filtering mechanism within your forks, the only way to get the grit and gunk out (before it chews up your oil seals and slider bearings!) is to change your fork fluid regularly. Yamaha recommends a fork fluid change every 10,000 miles or 24 months (all models except XJ700's), or every 16,000 miles or 24 months (all XJ700 and XJ750-X models). If you just bought a used bike, we recommend you do a fluid change as soon as possible, because just like other routine maintenance tasks (besides engine oil changes), this is one that has very likely been ignored for the last 10-12 years!
    HINT: there’s a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it’s brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won’t mix and the water will “ball up”; brake fluid will integrate with water and absorb the water.
    Fork oil capacities and recommended weights are as follows. The amounts listed are per fork tube:
    XJ550 Maxim: 272cc or 9.20 fluid ounces. 10W fork oil.
    XJ550 Seca: 230cc or 7.78 fluid ounces. 10W fork oil.
    1980-81 XJ650 Maxim and Midnight Maxim: 262cc or 8.86 fluid ounces. 10W fork oil.
    1982-84 XJ650 Maxim: 278cc or 9.40 fluid ounces. 10W fork oil.
    1982 XJ650RJ Seca: 236cc or 7.98 fluid ounces. 10W fork oil. Fork oil level is specified as 400mm (15.75") below the top of the tube without the spring installed, forks fully collapsed.
    1982 XJ650LJ Turbo: 238cc or 8.04 fluid ounces. 10W fork oil. Fork oil level is specified as 180mm (7.09") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ650LK Turbo: unknown.
    1985-86 XJ700 non-X: 383cc or 12.96 fluid ounces. 10W fork oil.
    1985-86 XJ700-X: 389cc or 13.16 fluid ounces. 10W fork oil.
    1982 XJ750 Maxim: 257cc or 8.69 fluid ounces. 10W fork oil.
    1983 XJ750 Maxim and Midnight Maxim: 257cc or 8.69 fluid ounces. 10W fork oil. NOTE: owner's manual states that the fork oil capacity is 278cc (9.40 fluid ounces). It is unknown which measurement is correct.
    1981-83 XJ750 Seca: 309cc or 10.45 fluid ounces. 20W fork oil.
    1983 XJ750 E-II Seca or 1984 XJ750RL Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 168mm (6.61") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ900RK Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 164mm (6.46") below the top of the tube without the spring installed, forks fully collapsed.
    1982-84 XJ1100 Maxim and Midnight Maxim: 210cc or 7.10 fluid ounces. 10W fork oil. Fork oil level is specified as 210mm (8.27") below the top of the tube without the spring installed, forks fully collapsed.
    IMPORTANT NOTE: the above fork oil VOLUMES are for use only when using the stock fork springs. The use of aftermarket performance front fork coil springs will change those volumes, since aftermarket springs are thicker than stock----and thus displace more oil. Using the stock oil fluid VOLUME with aftermarket fork springs is a sure way to OVERFILL your forks, with the very real possibility of blowing out fork seals.
    Unlike with your engine oil, where a bit too much or too little oil volume in the crankcase is not really a significant concern, with fork oil, too much or too little can cause real problems (too much oil can result in blown oil seals and a stiff, harsh ride, while too little oil volume results in excessive foaming, a soft mushy ride with possible bottoming, and erratic fork performance and lots of front end "dive" upon braking).
    A better way to determine the amount of fork oil that is needed and necessary is via the measurement of the fork oil LEVEL within the tubes.....sort of like measuring the oil level with a dipstick. Yamaha does not specify this level for all models; and in any case, if using aftermarket springs, the factory oil level recommendation is not always useful. The maximum oil level should be 5-1/2" (140mm) below the top of the inner fork tube, measured with all internal fork tube components installed EXCEPT FOR THE SPRINGS, and with the inner fork tube fully collapsed into the lower (outer) tube.
    In order to be as accurate as possible, we recommend the use of a suitable measuring device, such as the HCP1728 oil level syringe listed further below.
    And finally, the fork oil viscosity can be changed from the factory recommendations to give a softer or firmer ride.......the lower the viscosity, the thinner the oil, and the softer the ride (i.e. 5W oil is thinner than 10W which is thinner than 20W, etc.) In this regard, you would certainly be correct in thinking of fork oil as a suspension "tuning tool"! Note that a thicker oil viscosity will have much more effect on the fork "rebound" characteristics than it will on the fork compression dampening function.
    A great primer on "tuning" your forks via adjusting the oil levels can be seen at:
    http://www.thumpertalk.com/forum/archive/index.php/t-89918.html
    while the theory and science and practical applications of tuning your suspension via using differing viscosities of fork oil can is revealed at:
    http://www.peterverdone.com/archive/lowspeed.htm
    ffo3) Red Line Oil products line of SYNTHETIC FORK OILS are some of the best, highest-performance fork oils developed specifically for this purpose. They provide exceptional shear lubrication, are highly resistant to any viscosity changes, and provide excellent seal lubrication as well as very high anti-foaming properties. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    Also, do not mix different brands, styles, or types of oils........you can only safely mix forks oils together from one manufacturer!
    HCP1563 Red Line high-performance SYNTHETIC FORK OIL 0W (zero weight, "like water"), 16 ounce bottle (473cc), clear. Each bottle:
    $ 27.95
    HCP1564 Red Line high-performance SYNTHETIC FORK OIL 2.5W, 16 ounce bottle (473cc), blue. Each bottle:
    $ 27.95
    HCP1258 Red Line high-performance SYNTHETIC FORK OIL 5W, 16 ounce bottle (473cc), amber. Each bottle:
    $ 27.95
    HCP1259 Red Line high-performance SYNTHETIC FORK OIL 10W, 16 ounce bottle (473cc), red. Each bottle:
    $ 27.95
    HCP1263 Red Line high-performance SYNTHETIC FORK OIL 30W, 16 ounce bottle (473cc), orange. NOTE: this oil is similar in viscosity to what most other oil manufacturers call "20W" oil. Each bottle:
    $ 27.95
    ffo4) PJ1 products line of TUNER FORK OILS are exceptional quality, value-priced fork oils developed specifically for motorcycle suspensions. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    HCP10360 PJ1 products TUNER FORK OIL 2.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10362 PJ1 products TUNER FORK OIL 5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10364 PJ1 products TUNER FORK OIL 7.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10366 PJ1 products TUNER FORK OIL 10W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10368 PJ1 products TUNER FORK OIL 15W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10370 PJ1 products TUNER FORK OIL 20W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10372 PJ1 products TUNER FORK OIL 30W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    Fork Tube Oil Level Gauges:
    HCP1728 Fork tube oil fluid level measurement GAUGE AND SYRINGE. This handy tool makes the measurement of the fork oil level easy and accurate. NOTE: the proper amount of fork oil is determined via the measurement of the fork oil LEVEL (distance below the very top of the inner tube) rather than a volume AMOUNT of oil specification. Too little oil will make the ride mushy, while too much oil makes the ride harsh (and can blow out the oil seals!)
    $ 39.95
    ffl4) Aftermarket fork oil measurement GRADUATED CYLINDERS. The best way to measure the precise amount of fork oil fluid is via the use of these lab-quality measurement cylinders. Available in either transparent (clear) or translucent (cloudy) durable plastic construction, they all have easy-to-read scale numerals (milliliters) and feature a "non-wetting" inner surface coating that prevents the concave "meniscus" from forming at the top of the fluid, thus insuring a much more accurate level reading. Large bases insure stability while large spouts make "the pour" easy and prevent messy drips. Very useful device to have for front fork oil changes.
    HCP10741 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, translucent (cloudy).
    $ 24.95
    HCP10744 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, transparent (clear).
    $ 49.95
    HCP10742 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, translucent (cloudy).
    $ 29.95
    HCP10745 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, transparent (clear).
    $ 69.95
    HCP10743 Aftermarket fork oil GRADUATED CYLINDER, super-sized 1000ml capacity, translucent (cloudy), with convenient side handle to insure steady pouring.
    $ 89.95
    Fork Tube Air Pressure Tool and Gauge:
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 6.95
    HCP9108 Aftermarket air-assisted forks LOW PRESSURE AIR GAUGE, heavy-duty 0-20 psi pencil (stick) pressure gauge marked in 1/2-psi increments, perfect for checking fork air pressures on models so equipped. Very high quality and much more accurate than standard tire pressure gauges, which is very important on the fork pressures as an imbalance between the fork pressure can lead to steering and stability issues, while too much pressure will blow out the lower tube oil seals!
    $ 9.95
  10. chacal
    XJ750 Seca and XJ750 Euro MODELS FORK TUBE PARTS:
    NOTE: items marked below in red are the parts typically needed when doing a basic fork system rebuild.
    A good visual review of the procedures needed for rebuilding the 1981-83 forks can be seen at:
    http://xjbikes.com/forums/index.php?threads/18730
    And here's the secrets to that funny and unique "oil lock valve assembly" used only on these models, and the proper orientation of all of those special washers:
    http://xjbikes.com/forums/index.php?threads/41895
    Owners of the 1984 XJ750RL models should follow the XJ900 rebuild procedures:
    http://xjbikes.com/forums/index.php?threads/44997
    and
    http://xjbikes.com/forums/index.php?threads/4067
    All XJ750 Seca owners should also wish to note the procedure needed to separate the inner tubes from the lower tubes (the "battering ram" procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    And these incredible 3-D renderings of the inner workings of a forking system gives a great visualization of the internal components (it is based on the 1982-83 XJ650 Maxim forks):
    http://xjbikes.com/forums/index.php?threads/29616
    FORK TUBE REBUILD KITS:
    We now offer both a BASIC FORK REBUILD KIT and PERFORMANCE FOR TUBE REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike. NOTE: fork rebuild kits do not include any of the items used in rebuilding the anti-dive units; a separate kit to rebuild those is available as part HCP22001 and is listed in the anti-dive parts section further below.
    - NOTE: the lower tube “dust boots” (sometimes called dust seals) are not included in the basic fork tube rebuild kits, but are available separate and can be found further below.
    Basic fork rebuild kit contains at least the following items:
    - cap bolt o-rings.
    - cap bolt retaining rings.
    - standard quality lower fork tube oil seals.
    - oil seal retaining clips.
    - oil drain screws and gaskets.
    - damper rod head piston rings.
    - damper rod bolts and crush washers.
    - air joint o-rings, cushions, and retainer rings (all except 1984 XJ750RL kits).
    - air valve o-rings and valve cores (all except 1984 XJ750RL kits).
    - anti-dive housing to fork tube o-rings
    HCP20712 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1981-83 XJ750 Seca and XJ750 Euro models. NOTE: the oil seals that are included with this kit are 11mm tall, unlike the short (7mm tall) original oil seals, and thus you will need to discard both the original upper and lower oil seal spacer washers that may still be present in your fork system. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 179.95
    HCP20712DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1981-83 XJ750 Seca and XJ750 Euro models. NOTE: the oil seals that are included with this kit are 11mm tall, unlike the short (7mm tall) original oil seals, and thus you will need to discard both the original upper and lower oil seal spacer washers that may still be present in your fork system. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 217.95
    HCP20635 Aftermarket fork tubes BASIC FORK REBUILD KIT. Fits 1984 XJ750RL (44X Canadian model) and all 1985-1991 XJ900 F, N, and FN models (without the anti-dive fork system). One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 109.95
    HCP20635DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. Fits 1984 XJ750RL (44X Canadian model) and all 1985-1991 XJ900 F, N, and FN models (without the anti-dive fork system). One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 137.95
    Performance fork rebuild kit contain all of the basic rebuild kit components, along with:
    - performance fork springs and related spring seats and plastic spacers.
    - upgraded, high-performance lower fork tube oil seals.
    - lower fork tube dust boots.
    - air valve core stem tool (all except 1984 XJ750RL kits).
    HCP20713 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1981-83 XJ750 Seca and XJ750 Euro models. One kit does both front tubes. NOTE: the oil seals that are included with this kit are 11mm tall, unlike the short (7mm tall) original oil seals, and thus you will need to discard both the upper and lower oil seal spacer washers that may still be present in your fork system.
    $ 499.95
    HCP20636 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. Fits 1984 XJ750RL (44X Canadian model) and all 1985-1991 XJ900 F, N, and FN models (without the anti-dive fork system). One kit does both front tubes.
    $ 379.95
    Of course, all of the component pieces can be ordered as individual pieces from the selections listed below, as well as non-typical wear items (inner tubes, damper rod piston rings, taper spindles, cap bolts, etc.), as well as the fork oil and specialty tools needed to properly restore or enhance your front suspension performance.
    UPPER (INNER) FORK TUBES AND PARTS:
    Chrome Inner Fork Tubes:
    HCP8533 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1981-83 XJ750 Seca and XJ750 Euro models, each. NOTE: due to slight differences in manufacturing techniques used on these reproduction tubes (versus the originals), we highly suggest that XJ models which use the anti-dive front suspension ALWAYS replace both front tubes rather than just a single tube.
    $ 299.95
    HCP8533SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP9948 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ750RL, XJ900N, and XJ900FN models. Each:
    $ 219.95
    HCP9948SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 419.95
    Inner Tube Gaiter Boots:
    Although not originally used on any XJ-series bikes, these accordion-pleated thick rubber boots fit into the area between the bottom of the steering underbracket and the top of the lower (outer) fork boots, covering and protecting this area from damage, while providing an "old-school" or cafe-racer type look. They are retained to the chrome tube itself (at their top end) via spring clips, and to the top of the lower fork tube via metal screw-clamps.
    HCP10941 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10942 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10943 Aftermarket front fork tube GAITER BOOTS, red pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10938 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP10939 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP11420 Aftermarket fork tube gaiter boot LOWER RETAINING SPRING-CLAMP. Black powdercoated wire-spring type clamp has that old-time look and feel to it. Secure the lower end of the gaiter boot to the top of the lower (outer) fork tube. Fits all XJ-series models. Use 1 per tube, each:
    $ 14.95
    NOTE: gaiter boots normally do not require any type of retainer at their upper end, as the tight friction fit between the boot opening and the chrome tube prevents migration of the boot. If movement seems to occur, then we recommend the use of thin, black electrical wire ties to cinch the boot flange tightly to the tube.
    Inner Tube Top Cover/Cap:
    HCP8252 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: XJ550 all, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, the 1982 XJ650RJ Seca, and 1981 XJ750 Seca models. Each:
    $ discontinued
    HCP22882 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: XJ550 all, all XJ650 Euro models, 1980-81 XJ650 Maxim and Midnight Maxim, the 1982 XJ650RJ Seca, and 1981 XJ750 Seca models. Each:
    $ 19.95
    HCP8291 OEM inner fork tube top black rubber CAP, fits either the left or right side tube of the following models: all 1982-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 29.95
    HCP22881 Aftermarket inner fork tube top black rubber CAP, fits either the left or right side tube of the following models: all 1982-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 19.95
    HCP8289 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 28.95
    HCP22880 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 19.95
    Inner Fork Tube Cap Bolts and Related Hardware:
    HCP8292 OEM inner fork tube CAP BOLT, fits either side. Used on all 1984 FJ600, XJ700 non-X, XJ750RL, and XJ900RK, RL, and N/FN Seca models. NOTE: these cap bolts require a special inverse-hex tool HCP9238 to properly remove and install. Each:
    $ 49.95
    $ 19.95
    HCP13688 Aftermarket inner fork tube top cap bolt RETAINING RING, fits either the left or right side tube of the following models: all 1982-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 12.95
    HCP8248 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 2.50
    HCP14012 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 1.25
    HCP8286 OEM inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 7.95
    HCP20708 Aftermarket inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 5.95
    Inner Tube Fork Springs:
    HCP9438 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all 1981-83 XJ750 Seca and XJ750 Euro models. Front spring spacers are required to be used with these springs and a pair of "thick-wall PVC pipe" spacers are included and you can use them instead of the HCP8284 spacer tube and the HCP8239 spring seats. These plastic spacers will still need to be cut to length. Optionally, you could use a pair of the HCP8239 spring seats (one for each spring) and the fabrication of a 42.80mm long spacer when replacing stock springs…..or you can order the HCP21024 spacers tubes which are already cut to the correct length. Optionally, you can use the HCP8284 spring spacer tube (stock for 1982-83 XJ650 Maxim models) and cut it down to the proper length; one tube will provide enough material to do both springs and fork tubes). NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 12 cc's less fork oil (for a total of 297cc's per tube) when installing these springs and using the stock thin-wall metal spacer tubes as recommended above. The use of other type of spacers (thick-wall PVC pipe, for instance) will change this recommended fork oil volume by an unknown amount. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 269.95
    Inner Fork Tube Spring Spacers, Rebound Springs, Damper Rods, and Spring Seats:
    HCP8239 OEM inner fork tube SPRING SEAT, fits either side. Use on all 1981-83 XJ750 Seca and XJ750 Euro models when installing the HCP9438 replacement springs above. Each:
    $ 19.95
    HCP20994 Aftermarket inner fork tube SPRING SEAT, fits either side. Use on all 1981-83 XJ750 Seca and XJ750 Euro models when installing the HCP9438 replacement springs above. Each:
    $ 14.95
    HCP8284 OEM inner fork tube SPRING SPACER TUBE, Use on all 1981-83 XJ750 Seca and XJ750 Euro models when installing the HCP9438 replacement springs above; one tube will provide enough material to do both springs and fork tubes.
    $ 14.95
    HCP21024 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all 1981-83 XJ750 Seca and XJ750 Euro models when installing the HCP9438 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9438 springs; use 1 spacer per tube.
    $ 19.95
    HCP21024SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    HCP8246 OEM inner fork tube damper rod PISTON RING, fits either side. Used on all 1981-83 XJ750 Seca models, XJ750 Euro, XJ1100, 1980-81 XS1100 Standard models, and all XS1100 Special and Midnight Special models. Use 1 per fork tube. Each:
    $ 29.95
    HCP13658 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1981-83 XJ750 Seca models, XJ750 Euro, XJ1100, 1980-81 XS1100 Standard models, and all XS1100 Special and Midnight Special models. Use 1 per fork tube. Each:
    $ 17.95
    HCP13657 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1984-85 FJ600, all XJ700, XJ750-X, XJ750RL Canadian (44X model), and XJ900 models. Use 1 per fork tube. Each:
    $ 17.95
    Inner Fork Tube Oil Lock Valve Parts:
    HCP24632 Aftermarket inner fork tube oil lock valve white plastic PISTON RING, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models with anti-dive forking system Use 1 per tube, each:
    $ 17.95
    HCP19354 Aftermarket inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models with anti-dive forking system. Use 1 per tube, each:
    $ 19.95
    HCP19353 Aftermarket inner fork tube oil lock valve FLAT WASHER, fits either side. Used on all 1981-83 XJ750 Seca and XJ750 Euro models with anti-dive forking system. Use 1 per tube, each:
    $ 16.95
    Order of assembly of 1981-83 XJ750R Seca and XJ750 Euro models for the oil lock valve assembly components onto the damper rod:
    TOP (HEAD) OF DAMPER ROD
    DAMPER ROD REBOUND SPRING
    Above fitted thru bottom of inner/upper (chrome) fork tube.
    On thinner, lower end of damper rod:
    FLAT WASHER (HCP19353)
    WAVE WASHER (HCP19354)
    THICK TAPERED WASHER (“Collar”), narrower end "up"
    OPEN END OF OIL LOCK VALVE with PISTON RING (HCP24632)
    https://www.xjbikes.com/forums/threads/doing-the-750-secas-forks-rebuild-now-a-how-to.18730
    HCP8344 OEM inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 2 per tube, each:
    $ discontinued
    HCP19355 Aftermarket inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 2 per tube, each:
    $ 19.95
    HCP19356 Aftermarket inner fork tube oil lock valve FLAT WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 1 per tube, each:
    $ 17.95
    NOTE: the order of installation for the above washers is as follows (and only applies to bikes with anti-dive front fork systems, i.e. the XJ750RL, XJ750P (37H model), and XJ900RK and RL models):
    Order of assembly of 1984 XJ750RL, XJ750P (37H model, and XJ900RK/RL Seca oil lock valve assembly components onto damper rod:
    NOTE: the Yamaha factory service manual has an incorrect written description and an incorrect image showing the assembly order of the “oil lock valve” components onto the damper rod, showing the two wave washers being adjacent to each other. The correct assembly sequence --- as shown below --- is for the wave washers to be separated by the flat shim washer:
    WAVE WASHER (HCP19355) goes onto the damper rod shaft first
    FLAT WASHER (HCP19356) goes onto the damper rod shaft next
    WAVE WASHER (HCP19355) goes onto the damper rod shaft third
    Finally the TAPER SPINDLE (HCP3085) goes on last.
    Inner Tube Metal Slider Bushings:
    NOTE: the following items (for XJ750 Seca/Euro models) are part #3 in the Haynes 650/750 manual, called a “bush”, and are fitted at the very bottom end of the upper (inner / chrome) fork tube…..and while the image in the Haynes manual for this item seemingly locates it at the top of the inner (chrome) fork tube, in reality they are fitted at the bottom of the chrome tube.
    HCP8481 OEM inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1983 (only) XJ650 Turbo (with 37mm fork tubes), all 1981-83 XJ750 Seca and Euro models, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. Each:
    $ 99.95
    HCP8481SET2 OEM inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 189.95
    HCP10702 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1983 (only) XJ650 Turbo (with 37mm fork tubes), all 1981-83 XJ750 Seca and Euro models, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. NOTE: these bushings are a bit thinner than the original bushings, but will fit and perform properly. Each:
    $ 69.95
    HCP10702SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 119.95
    HCP10705 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: XJ750RL (45T Australian model), XJ900RK, RL, and N/FN models. One slider does one tube. Each:
    $ 49.95
    HCP10705SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 89.95
    INNER FORK TUBE AIR SYSTEM PARTS:
    Air Joint Cushions, O-Rings, and Retainers:
    HCP8242 OEM air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 10.95
    HCP8242SET2 OEM air joint rubber UPPER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint, and cushions the top of the air joint from the bottom of the crown bracket. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 7.95
    HCP15647SET2 Aftermarket air joint rubber UPPER CUSHION GASKETS, fits either side. Set of two:
    $ 14.95
    HCP8268 OEM air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint. Used on all 1981-83 XJ750 Seca, XJ750 Euro, and 1982 XV920J Virago models. Slightly firmer than original material. Use 1 per tube. Each:
    $ discontinued
    HCP8268SET2 OEM air joint rubber UPPER CUSHION GASKETS, fits either side. Set of two:
    $ discontinued
    HCP15652 Aftermarket air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint. Used on all 1981-83 XJ750 Seca, XJ750 Euro, and 1982 XV920J Virago models. Slightly firmer than original material. Use 1 per tube. Each:
    $ 7.95
    HCP15652SET2 Aftermarket air joint rubber UPPER CUSHION GASKETS, fits either side. Set of two:
    $ 13.95
    HCP8279 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1981-83 XJ750 Seca, XJ750 Euro, and 1982 XV920J Virago models. Use 2 o-rings per air joint. Each:
    $ discontinued
    HCP8279SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ discontinued
    HCP14016 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1981-83 XJ750 Seca, XJ750 Euro, and 1982 XV920J Virago models. Use 2 o-rings per air joint. Each:
    $ 9.95
    HCP14016SET4 Aftermarket inner fork tube air joint INNER O-RINGS, set of 4:
    $ 32.95
    HCP8341 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, and XJ900RK and RL models. Uses 2 o-rings per joint. Each:
    $ discontinued
    HCP8341SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ discontinued
    HCP20701 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, XJ900RK and RL models, and XJ1100 models. Uses 2 o-rings per joint. Each:
    $ 8.95
    HCP20701SET4 Aftermarket inner fork tube air joint INNER O-RINGS, set of 4:
    $ 27.95
    HCP8259 OEM inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and 1982 XV920J Virago models. Each:
    $ discontinued
    HCP12316 Aftermarket inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and 1982 XV920J Virago models. Each:
    $ 8.95
    Air Inflation Valves and O-Rings:
    HCP8274 OEM inner fork tube air joint AIR VALVE WITH CAP, comes complete the internal stem core, its o-ring, and chrome cap. Fits the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and the included protective cap is much smaller than the huge caps used on those models, and due to the length difference, those large original caps will not fit properly on this shorter valve. This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 57.95
    HCP25157 OEM inner fork tube air joint AIR VALVE, comes complete the internal stem core and o-ring. Chrome cap is not included. Use 1 per tube on the following models: 1981-83 XJ750 Seca, XJ750 Euro, and all XS1100 Special and Midnight Special models. Use 1 per bike (on the air joint) on XJ1100 models. Each:
    $ 47.95
    HCP11890 OEM inner fork tube air joint brass AIR VALVE ONLY, comes complete the internal stem core and its o-ring. The chrome cap is not included. Fits the following models: 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. Each:
    $ 39.95
    HCP11876 OEM inner fork tube air joint air valve CHROME CAP, ribbed, dome-head style. Correct for all of the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This cap can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is much smaller than the large original caps used on those models. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 19.95
    HCP8271 OEM inner fork tube air joint Air Valve and Hose O-RING, fits the following models: all 1981-83 XJ750 Seca and XJ750 Euro models, (use 1 per tube), XJ1100 models (use 3 per bike), and all XS1100 Special and Midnight Special models (use 1 per tube). Each:
    $ 7.95
    HCP14020 Aftermarket inner fork tube air joint Air Valve and Hose O-RING, fits the following models: all 1981-83 XJ750 Seca and XJ750 Euro models, (use 1 per tube), XJ1100 models (use 3 per bike), and all XS1100 Special and Midnight Special models (use 1 per tube). Each:
    $ 5.95
    HCP9194 Aftermarket fork tube AIR VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all 1985 FJ600 models, 1982-83 XJ650 Maxim and Turbo models, XJ700-X models, all XJ750 models, the XJ900RK model, and XJ1100 models. If your stem is leaking air, this is the inexpensive way to fix it. Each:
    $ 3.95
    HCP9194SET2 Aftermarket fork tube AIR VALVE STEM CORES, set of 2:
    $ 6.95
    $ 5.95
    INNER FORK TUBE RETAINING HARDWARE:
    Crown Bracket Inner Fork Tube Retaining Hardware:
    HCP4531 OEM crown bracket fork tube CINCH BOLT, use 1 per side. For the following models: XJ650 Turbo, 1982 XJ750 Maxim, and all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 7.95
    HCP4531SET2 OEM crown bracket fork tube CINCH BOLTS, use 1 per side. Pair:
    $ 14.95
    HCP18011 Aftermarket cinch bolt head protective CAP. Smooth, black plastic cap snaps over the head of the fork tube cinch bolts, giving them a very "modern" look, protecting the head from rust. Fits all OEM or aftermarket bolts with a 12mm hex or socket head. Each:
    $ 4.95
    Under-bracket Inner Fork Tube Retaining Hardware:
    HCP3656 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 795
    HCP2185 OEM under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 6.95
    HCP16209 Aftermarket zinc-plated, alloy steel, under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP16100 Aftermarket 18-8 stainless-steel, under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP16102 Aftermarket black-oxide coated finish, under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 3.95
    $ 4.95
    Steering Stabilizer and Hardware:
    HCP4543 OEM rotary steering stabilization DAMPER UNIT. Fitted only to 1983 XJ750 Seca models, this round “shimmy-eliminator” unit is fitted to the underside of the lower steering bracket, and interacts against the forward “finger” of the oil cooler mounting loop bracket which is welded to the front frame gusset……and thus provides a resistance, stiffening, and counteraction to fork movement. Mounts simply via a splined shaft and a retention bolt. NOTE: will not fit 1981-82 models, as they do not have the splined shaft receiver nor have proper locating tab or clearance for this device. Although these units are brand new, they should be filled with the proper viscosity of oil and all of the air should be bled out of them (using the two “center” screws). The recommended fluid to use is 15W or 20W fork oil, although you could use a thinner or thicker weight oil is desired…….just like with the forks themselves, the higher the viscosity, the more “dampening” (or resistance to rotary movement) you will obtain. NOTE: 1983 models could have been fitted with this rotary damper unit pr a more traditional fork-tube mounted “piston” style steering stabilizer. The piston stabilizer is normally seen only on bikes with the larger front fairing (“touring package” option).
    $ 299.95
    HCP25926 Aftermarket rotary steering stabilization DAMPER UNIT REBUILD KIT[/u]. After all of these years these rotary dampers typically require rebuilding (a cleaning, “oil change” and new seals). Our complete rebuild kits contains both the shaft and housing o-rings, the air bleed screws and their sealing gaskets, and a complete set of the housing cinch screws (buttonhead style) and their lock washers. For all 1983 XJ750 Seca models using the rotary steering damper.
    $ 59.95
    HCP25897 OEM steering stabilization damper unit MOUNTING BOLT, use1 per damper unit. Fits all 1983 XJ750 Seca models using the rotary steering damper. Requires the use of a lockwasher listed below, each:
    $ discontinued
    HCP1902 OEM steering stabilization damper unit mounting bolt LOCK WASHER, black oxide-coated alloy steel, used with the bolt above on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 6.95
    HCP916 Aftermarket steering stabilization damper unit mounting bolt LOCK WASHER, bright zinc-plated alloy steel, used with the bolt above on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 1.95
    HCP319 Aftermarket steering stabilization damper unit mounting bolt LOCK WASHER, bright 18-8 stainless steel, used with the bolt above on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 2.95
    HCP321 Aftermarket steering stabilization damper unit mounting bolt LOCK WASHER, black oxide-coated alloy steel, used with the bolt above on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 1.95
    HCP25910 Aftermarket steering stabilization damper unit O-RING, fits over the splined shaft and seals the upper housing. Unit must be dis-assembled for replacement. Fits 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 7.95
    HCP25909 Aftermarket steering stabilization damper unit O-RING, fits between the upper and lower housings. Unit must be dis-assembled for replacement. Fits 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 14.95
    HCP322 OEM steering stabilization damper oil fill/air bleed SCREW, panhead phillips drive, bright zinc-plated alloy steel. Fits into the upper housing. Use 2 per damper assembly on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 6.95
    HCP918 Aftermarket steering stabilization damper oil fill/air bleed SCREW, panhead phillips drive, bright zinc-plated alloy steel. Fits into the upper housing. Use 2 per damper assembly on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 1.95
    HCP25913 Aftermarket steering stabilization damper oil fill/air bleed SCREW, panhead phillips drive, bright zinc-plated alloy steel, JIS small-head design as original. Fits all 1978 and 1980 XS1100 Standard models. Each:
    $ 3.95
    HCP1355 Aftermarket steering stabilization damper oil fill/air bleed SCREW, panhead phillips drive, bright 18-8 stainless-steel. Fits all 1978 and 1980 XS1100 Standard models. Each:
    $ 2.95
    HCP7111 OEM steering stabilization damper oil fill/air bleed screw GASKET, use one per screw. Fits 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 8.95
    HCP21320 Aftermarket steering stabilization damper oil fill/air bleed screw GASKET, use one per screw. Fits 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 5.95
    HCP1467 OEM steering stabilization damper upper-to-lower housing SCREW, alloy steel, zinc-plated, panhead phillips drive. Use 6 per damper unit on 1983 XJ750 Seca models using the rotary steering damper. Must be used with the HCP25925 internal-tooth lock washer below. Each:
    $ 8.95
    HCP2746 Aftermarket steering stabilization damper upper-to-lower housing SCREW, alloy steel, zinc-plated, panhead phillips drive. Use 6 per damper unit on 1983 XJ750 Seca models using the rotary steering damper. Must be used with the HCP25925 internal-tooth lock washer below. Each:
    $ 2.95
    HCP2747 Aftermarket steering stabilization damper upper-to-lower housing SCREW, bright 18-8 stainless steel, zinc-plated, panhead phillips drive. Use 6 per damper unit on 1983 XJ750 Seca models using the rotary steering damper. Must be used with the HCP25925 internal-tooth lock washer below. Each.
    $ 3.95
    HCP21431 Aftermarket steering stabilization damper upper-to-lower housing SCREW, bright polished 18-8 stainless steel, buttonhead, hex-drive fastener. Use 6 per damper unit on 1983 XJ750 Seca models using the rotary steering damper. Must be used with the HCP25925 internal-tooth lock washer below. Each:
    $ 2.95
    HCP21432 Aftermarket steering stabilization damper upper-to-lower housing SCREW, black-oxide coated alloy steel, socket head, hex-drive. Use 6 per damper unit on 1983 XJ750 Seca models using the rotary steering damper. Must be used with the HCP25925 internal-tooth lock washer below. Each.
    $ 1.95
    HCP25925 Aftermarket steering stabilization damper upper-to-lower housing screw LOCK WASHER, 18-8 stainless steel, internal-tooth. Use 6 per damper unit on 1983 XJ750 Seca models using the rotary steering damper. Each:
    $ 1.95
    LOWER (OUTER) FORK TUBE PARTS:
    Dust Wiper Seals:
    HCP1839 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. One seal does one tube. Each:
    $ 27.95
    HCP21560 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. One seal does one tube. Each:
    $ 21.95
    HCP1822 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984 XJ750RL Seca (44X Canadian models) and all XJ900RK, RL, F, N, and FN models. One seal does one tube. Each:
    $ 22.95
    HCP21561 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984 XJ750RL Seca (44X Canadian models) and all XJ900RK, RL, F, N, and FN models. One seal does one tube. Each:
    $ 17.95
    Oil Seals:
    NOTE: when installing oil seals, make sure that the area where the seal will fit into is clean, free of any nicks and burrs, and that the lower tube metal slide bushing is fully seated. Oil seals install with the large opening facing down, into the tube, and on most seals, the small cast lettering and numbering on the seal faces upwards.
    Seals are designed to be installed with a seal driver of some type, although a properly sized piece of hard plastic tubing, perhaps with a proper sized metal washer on top of the seal to "spread the load", works as well. Always make sure that oil seals are fully seated and not damaged or installed in a crooked or cocked manner.
    NOTE: HCP1818, HCP1720, and HCP20648 oil seals are 11mm tall, and their use eliminates the need for the lower (HCP3092) spacer washers as originally used on these models. The original oil seals were 7mm tall, and thus required the use of the both upper and lower spacer washers to “shim-up” the original seal to the proper 11mm height.
    HCP1818 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. These seals are a double-spring design, making them less susceptible to leaking and giving them a longer life. Also fits the following non-XJ models: 1987-2000 XV535 Virago, all 1978-79 XS750 models, 1980-81 XS850 Standards, and 1982 XV920J Virago models. One seal does one tube. This seal is 11.05mm tall, and should be used with the original HCP3095 upper spacer washer (1.20mm thick) only. Each:
    $ 32.95
    HCP1720 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Comes packaged as a pair of seals, enough to do both forks. Also fits the following non-XJ models: 1987-2000 XV535 Virago, all 1978-79 XS750 models, 1980-81 XS850 Standards, and 1982 XV920J Virago models. This seal is 11.05mm tall, and should be used with the original HCP3095 upper spacer washer (1.20mm thick) only. This is for a pair of seals, enough to do both fork tubes.
    $ 54.95
    HCP20648 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Comes packaged as a pair of seals, enough to do both forks. Also fits the following non-XJ models: 1987-2000 XV535 Virago, all 1978-79 XS750 models, 1980-81 XS850 Standards, and 1982 XV920J Virago models. This seal is 10.75mm tall, and should be used with your original HCP3095 upper spacer washer (1.20mm thick) or the aftermarket HCP12948 upper spacer washer (1.50mm thick). This is for a pair of seals, enough to do both fork tubes.
    $ 44.95
    HCP1816 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, 1984 XJ750RL Seca (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. One seal does one tube. Each:
    $ 33.95
    HCP20646 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. Comes packaged as a pair of seals, enough to do both forks.
    $ 49.95
    HCP1718 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. Comes packaged as a pair of seals, enough to do both forks.
    $ 54.95
    Oil Seal & Dust Seal Kits:
    HCP1723 Aftermarket premium quality lower fork tube BLACK OIL SEALS & DUST WIPER SEALS KIT, fits the following models: 1984 XJ750RL Seca (44X Canadian models) and all XJ900RK, RL, F, N, and FN models. Comes with one pair of both the oil and dust seals, enough to do both forks.
    $ 64.95
    Oil Seal Retaining Clips:
    HCP1829 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and all XS1100 Special and Midnight Special models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! NOTE: this replacement clip is a thin-wire design, as opposed to the heavy stamped metal clip used originally, but it will fit and operate properly. Each:
    $ 9.95
    HCP20718 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and all XS1100 Special and Midnight Special models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! NOTE: this replacement clip is a thin-wire design, as opposed to the heavy stamped metal clip used originally, but it will fit and operate properly. Each:
    $ 6.95
    HCP1828 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 8.95
    HCP20717 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    Oil Seal Spacer Washer:
    NOTE: both the upper and lower spacer washers are needed when using the original 7mm thick oil seals but only the upper washer is needed when using any of our HCP1818, HCP1720, or HCP20648 oil seals.
    HCP3095 OEM lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and 1980-81 XS1100 Special and Midnight Special models. One washer does one tube. This washer goes above the oil seal, is 1.20mm thick, and should be used only with the HCP1818 or HCP1720 (11mm thick) oil seals. This is the original “cupped edges” design washer. Each:
    $ discontinued
    HCP12948 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and 1980-81 XS1100 Special and Midnight Special models. One washer does one tube. This washer goes above the oil seal, is 1.50mm thick, and should be used only with the aftermarket HCP20648 (10.75mm thick) oil seals. This is the replacement “flat” washer (does not have a “cupped edges” design). Each:
    $ 14.95
    HCP12948SET2 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHERS, one pair does both forks.
    $ 24.95
    HCP3092 OEM lower fork tube OIL SEAL LOWER SPACER WASHER, fits either left or right tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models, 1978-79 XS750 all models, and. 1980-81 XS850 standard models. One washer does one tube. This washer goes below the oil seal, and above the metal slider bushing. NOTE: original spacer washers were "cupped" at the outer edges; these replacements are flat, but fit and perform as original. This washer is 3.10mm thick, and should be used only with original 7mm thick oil seals (not currently available) only. Each:
    $ 29.95
    HCP3092SET2 OEM lower fork tube OIL SEAL LOWER SPACER WASHERS, one pair does both forks.
    $ 57.95
    HCP3094 OEM lower fork tube OIL SEAL LOWER SPACER WASHER, fits either left or right tube on the following models: XJ750RL (44X Canadian model), XJ900RK, RL, N/FN, and F models. One washer does one tube. This washer goes below the oil seal, and above the metal slider bushing! Each:
    $ discontinued
    Lower Tube Metal Slider Bushings:
    NOTE: the following items (for XJ750 Seca/Euro models) are part #24 in the Haynes 650/750 manual, called an “upper bush”, and are fitted at the upper end of the lower (outer) fork tube.
    HCP3089 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. One slider does one tube. Each:
    $ 89.95
    HCP3089SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 169.95
    HCP10711 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. One slider does one tube. Each:
    $ 59.95
    HCP10711SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 114.95
    HCP4259 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H models), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 49.95
    HCP4259SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10709 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 39.95
    HCP10709SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    HCP19996 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 49.95
    HCP19996SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10706 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ550 Maxim, 1984-85 FJ600, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750P (24L models), XJ750RL (44X Canadian model), and 1983 XJ750 Maxim and Midnight Maxim models. One slider does one tube. Each:
    $ 39.95
    HCP10706SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    Lower Tube Anti-Dive Unit Parts:
    The front fork ANTI-DIVE SYSTEM on these models are almost always in need of a complete, thorough cleaning and rebuild. While many people claim that the anti-dive system is a "useless" feature, the real reason may be that the system is so internally fouled and seized that it simply is not operating, at all!
    Anti-dive control units are divided into an "upper" (or "top") section, which is the brake plunger assembly....this upper section is where the brake hose, from the brake caliper, attaches. The brake fluid BLEEDER SCREW and the fluid DRAIN SCREW are located in this upper section, as well as the brake plunger piston unit. The O-RING on the plunger should be replaced during a rebuild procedure, as well as a thorough cleaning and polishing of the piston bore. Additionally, there is a snap-ring that retains the damper plunger piston unit into the housing which should be replaced if it is rusty o deformed. HINT: if this piston unit is seized, the use of the HCP12230 Piston Popper fitting will easily free it up.
    The "lower" (or "main") section of the anti-dive unit is the larger damper piston assembly (which is bolted to the fork tube), and which contains the damper piston spring and piston. Under hard braking, the brake fluid pressure forces the brake plunger (in the top "brake plunger assembly" section) to push down on the damper piston and its spring, restricting the flow of fork oil in the fork tubes, thus "stiffening" the fork system temporarily----and reducing the amount of front end "dive" during hard braking. The O-RING on the plunger should be replaced during a rebuild procedure, as well as a thorough cleaning and polishing of the piston bore. And the housing-to-fork tube O-RINGS should also be renewed. The small fluid DRAIN SCREW and it COPPER GASKET is typically replaced, and finally, the lower spring seat O-RING at the very bottom of the lower housing, should be replaced to prevent any leaks.
    A great picture of the entire XJ750 Seca or XJ750 Euro anti-dive unit can be seen at:
    http://xjbikes.com/forums/index.php?threads/1860
    And here's one of the components of the lower damper piston assembly on the XJ750-D, XJ750P Police (37H model), and XJ900RK and RL models anti-dive unit can be seen at:
    NOTE: if you want to disable your anti-dive system, you will need to remove the hose from the caliper to the anti-dive unit (and replace the caliper end double-depth union bolt with the single-depth union bolt used at the anti-dive unit end of the hose) and block-off the anti-dive fluid port with this plug:
    HCP12991 Aftermarket brake system fluid port BLOCK-OFF PLUG, correct size hex-drive set-screw is used to replace a brake hose union bolt when not in use. Use 1 per anti-dive unit.
    $ 6.95
    or an even more stylish alternative is to use these custom-made BLOCK-OFF PLATES that completely replace the upper section of the anti-dive unit:
    HCP22861 Aftermarket anti-dive upper housing BLOCK-OFF PLATE, beautiful machined aluminum cover plates completely replace the upper portion of your anti-dive units, fully disabling their function. Black-anondized covers come complete with mounting screws. Sold in a matched LH/RH set. Fits all XJ750 Seca and XJ750 Euro models using anti-dive forks.
    $ 79.95
    Anti-Dive Rebuild Kits:
    No need to guess what parts you’re going to need…..our complete ANTI-DIVE REBUILD KITS take all the guesswork out by supplying you with all of the parts necessary. Kits contain all of the rubber and plastic seals, boots, o-rings, circlips, washers, standard bleeder screws, drain screws, and hardware need to do a complete and thorough rebuild of these units. Experience how your anti-dive units should actually perform by rebuilding them correctly!
    HCP22001 Aftermarket complete ANTI-DIVE REBUILD KIT, contains all of the rebuild items needed to overhaul an anti-dive unit used on XJ750 Seca and XJ750 Euro models. One kit services one anti-dive unit. Each:
    $ 129.95
    HCP22001SET2 Aftermarket complete ANTI-DIVE REBUILD KITS, two complete rebuild kits, enough to service one bike:
    $ 219.95
    Anti-Dive Individual Rebuild Components:
    All of the following items are part of the Brake Piston Assembly (the smaller top cap section of the entire anti-dive unit). Items are listed “in order of appearance” as you would observe as you take the component pieces apart.:
    HCP1775 OEM anti-dive brake piston assembly FLUID BLEEDER SCREW, bright finish, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Each screw comes with the protective rubber cap. Each:
    $ 27.95
    HCP1775SET2 OEM anti-dive brake piston assembly FLUID BLEEDER SCREWS, set of 2:
    $ 49.95
    HCP11783 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREW, dark finish, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Protective rubber cap is not included and must be ordered separate. Each:
    $ 19.95
    HCP11783SET2 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREWS, set of 2:
    $ 34.95
    HCP24097 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREW, bright finish, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Protective rubber cap is not included and must be ordered separate. Each:
    $ 19.95
    HCP24097SET2 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREWS, set of 2:
    $ 34.95
    HCP7115 OEM anti-dive brake piston assembly air bleeder valve RUBBER CAP, use 1 per housing on all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models, each:
    $ discontinued
    HCP17790 Aftermarket bleeder screw protective rubber DUST CAP, black, dome-shaped head, no retaining strap, each:
    $ 1.95
    HCP1640 Aftermarket bleeder screw protective rubber DUST CAP, black, dome-shaped head, with retaining strap, no more losing your caps! Each
    $ 2.95
    HCP6852 Aftermarket anti-dive brake piston assembly SPEED-BLEEDER SCREW, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. These screws are 1mm longer (on the nipple end) than the original screw, and are made from standard alloy steel. Each screw comes with the protective rubber cap. NOTE: speed bleeder screws require the use of a thread sealant product to perform properly......otherwise, air can and will get sucked in thru the threads when the bleeder screw is loosened during the bleeding process. We recommend the use of our HCP13492, and you use it very sparingly. Do not use teflon tape; brake fluid will degrade it, and then the melted goo will be sucked into the speed bleeder valve and clog it.....game over! Each:
    $ 8.95
    HCP6852SET2 Aftermarket anti-dive brake piston assembly SPEED-BLEEDER SCREWS, set of 2:
    $ 16.95
    HCP6853 Aftermarket anti-dive brake piston assembly SPEED-BLEEDER SCREW, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. These screws are 6mm longer (on the nipple end) than the original screw, and are made from stainless steel. Each screw comes with the protective rubber cap. NOTE: speed bleeder screws require the use of a thread sealant product to perform properly......otherwise, air can and will get sucked in thru the threads when the bleeder screw is loosened during the bleeding process. We recommend the use of our HCP13492, and you use it very sparingly. Do not use teflon tape; brake fluid will degrade it, and then the melted goo will be sucked into the speed bleeder valve and clog it.....game over! Each:
    $ 15.95
    HCP6853SET2 Aftermarket anti-dive brake piston assembly SPEED-BLEEDER SCREWS, set of 2:
    $ 29.95
    NOTE: speed-bleeders should NEVER be used when first re-filling a "dry" brake system----one where the lines, calipers, or master cylinder has been rebuilt or changed, for example----as the air in the system will compress, and the speed-bleeder valve will prevent fluid from flowing through the system. Always bleed dry systems using standard bleeder screws first, and only then install the speed-bleeders, and re-bleed!
    HCP13492 Aftermarket anti-dive brake plunger assembly bleeder screw THREAD SEALANT PASTE, designed to fill and seal the thread cavities and prevent air or fluid leaks. 6ml squeeze tube is enough to do a whole bunch of fittings!
    $ 7.95
    HCP10555 Aftermarket anti-dive brake piston assembly housing-to-damper assembly housing attaching BOLT, correct black-oxide coated, alloy steel socket head cap screw is used to attach the upper and lower housing to each other. Uses 2 per anti-dive unit on all XJ750 Seca and XJ750 Euro models. Each:
    $ 1.25
    HCP10555SET2 Aftermarket anti-dive brake piston assembly housing-to-damper assembly housing attaching BOLTS, set of 2:
    $ 2.00
    HCP10555SET4 Aftermarket anti-dive brake piston assembly housing-to-damper assembly housing attaching BOLTS, set of 4:
    $ 3.95
    HCP10554 Aftermarket anti-dive brake piston assembly housing-to-damper assembly housing attaching BOLT, bright stainless-steel socket head cap screw is used to attach the upper and lower housing to each other. Uses 2 per anti-dive unit on all XJ750 Seca and XJ750 Euro models. Each:
    $ 1.75
    HCP10554SET2 Aftermarket anti-dive brake piston assembly housing-to-damper assembly housing attaching BOLTS, set of 2:
    $ 2.95
    HCP10554SET4 Aftermarket anti-dive brake piston assembly housing-to-damper assembly housing attaching BOLTS, set of 4:
    $ 5.00
    HCP15904 Aftermarket anti-dive brake piston assembly plunger shaft SHIM WASHER, fits around the plunger shaft and is retained by the HCP15905 circlip. Use 1 per housing on all XJ750 Seca and XJ750 Euro models:
    $ 17.95
    HCP15904SET2 Aftermarket anti-dive brake piston assembly plunger shaft SHIM WASHERS, set of 2:
    $ 29.95
    HCP15905 Aftermarket anti-dive brake piston assembly piston shaft SNAP RING, use 1 per housing on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 4.95
    HCP15905SET2 Aftermarket anti-dive brake piston assembly piston shaft SNAP RINGS, set of 2:
    $ 7.95
    HCP15894 Aftermarket anti-dive brake piston assembly piston shaft O-RING, use 1 per shaft on all 1981-83 XJ750 Seca amd XJ750 Euro models. Each:
    $ 4.95
    HCP15894SET2 Aftermarket anti-dive brake piston assembly piston shaft O-RINGS, set of 2:
    $ 7.95
    HCP21322 Aftermarket anti-dive brake piston assembly PLUNGER CAP, molded flexible cap that fits in-between the (upper) brake plunger shaft and the (lower) damper piston shaft. Use 1 per unit on all XJ750 Seca and XJ750 Euro models:
    $ 24.95
    HCP21322SET2 Aftermarket anti-dive brake piston assembly PLUNGER CAPS, set of 2:
    $ 44.95
    HCP15902 Aftermarket anti-dive brake piston assembly AIR BLEED SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, black-oxide coated hex-drive set screw as original. Each:
    $ 4.95
    HCP15902SET2 Aftermarket anti-dive brake piston assembly AIR BLEED SCREWS, set of 2:
    $ 7.95
    All of the following items are part of the Damper Piston Assembly (the larger section of the entire anti-dive unit). Items are listed “in order of appearance” as you would observe them as you take the component pieces apart, from top to bottom.:
    HCP15910 Aftermarket anti-dive damper piston assembly plunger shaft SHIM WASHER, fits around the plunger shaft and is retained by the HCP2909 e-clip. Use 1 per side on all XJ750 Seca and XJ750 Euro models:
    $ 14.95
    HCP15910SET2 Aftermarket anti-dive damper piston assembly plunger shaft SHIM WASHERS, set of 2:
    $ 27.95
    HCP905 anti-dive damper piston assembly piston shaft retaining E-CLIP,black-phosphate coated spring steel as original, use 1 per side on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 4.95
    HCP905SET2 Aftermarket Hitachi throttle shaft end retaining E-CLIPS, set of 2:
    $ 8.95
    HCP2909 Aftermarket anti-dive damper piston assembly piston shaft retaining E-CLIP, type 420 stainless spring steel, use 1 per side on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 6.95
    HCP2909SET2 Aftermarket anti-dive damper piston assembly piston shaft retaining E-CLIPS, set of 2:
    $ 12.95
    HCP15919 Aftermarket anti-dive damper piston assembly piston shaft O-RING, use 1 per shaft on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 4.95
    HCP15919SET2 Aftermarket anti-dive damper piston assembly piston shaft O-RINGS, set of 2:
    $ 8.95
    HCP21447 Aftermarket anti-dive damper piston assembly plunger shaft (lower end)-to-piston cup-opening polyurethane (hard plastic) OIL SEAL, used at the lower end of the piston shaft (held onto the shaft via a special shouldered torx-drive screw and a metal collar). Durable polyurethane material as original. Use 1 per housing on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 22.95
    HCP21447SET2 Aftermarket anti-dive damper piston assembly plunger shaft (lower end)-to-piston cup-opening polyurethane (hard plastic) OIL SEALS, set of 2:
    $ 41.95
    HCP21522 Aftermarket anti-dive damper piston assembly piston spring RETAINING WIRE CLIP, retains the large spring in the lower section of the housing, use 1 per side on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 12.95
    HCP21522SET2 Aftermarket anti-dive damper piston assembly piston spring RETAINING WIRE CLIPS, set of 2:
    $ 22.95
    HCP15882 OEM anti-dive damper piston assembly FLUID DRAIN SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, phosphate-coated phillips-drive screw as original. Includes the copper gasket. Each:
    $ 9.95
    HCP6708 Aftermarket anti-dive damper piston assembly FLUID DRAIN SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, panhead phillips-drive zinc-plated alloy steel. Each:
    $ 1.95
    HCP6709 Aftermarket anti-dive damper piston assembly FLUID DRAIN SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, panhead phillips-drive 18-8 stainless steel, bright finish. Each:
    $ 2.95
    HCP6710 Aftermarket anti-dive damper piston assembly FLUID DRAIN SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Each:
    $ 1.95
    HCP6712 Aftermarket anti-dive damper piston assembly FLUID DRAIN SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Each:
    $ 2.95
    HCP6711 Aftermarket anti-dive damper piston assembly FLUID DRAIN SCREW, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, socket head cap screw, hex-drive, black-oxide coated finish. Each:
    $ 1.95
    HCP15891 Aftermarket anti-dive damper piston assembly fluid drain screw COPPER GASKET, fits all 1981-83 XJ750 Seca and XJ750 Euro models. Use 1 per unit, this is the copper gasket only. Each:
    $ 4.95
    HCP15891SET2 Aftermarket anti-dive damper piston assembly fluid drain screw COPPER GASKETS, set of 2:
    $ 8.95
    HCP10556 Aftermarket anti-dive damper piston assembly housing-to-fork tube attaching BOLT, correct black-oxide coated, alloy steel socket head cap screw is used to attach the main housing to the lower fork tube. Uses 4 per side on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 2.95
    HCP10556SET4 Aftermarket anti-dive damper piston assembly housing-to-fork tube attaching BOLTS, set of 4:
    $ 10.95
    HCP10556SET8 Aftermarket anti-dive damper piston assembly housing-to-fork tube attaching BOLTS, set of 8:
    $ 17.95
    HCP10558 Aftermarket anti-dive damper piston assembly housing-to-fork tube attaching O-RING, used where the main housing attaches to the lower fork tube. Uses 2 per housing on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 4.95
    HCP10558SET2 Aftermarket anti-dive damper piston assembly housing-to-fork tube attaching O-RINGS, set of 2:
    $ 8.95
    HCP10558SET4 Aftermarket anti-dive damper piston assembly housing-to-fork tube attaching O-RINGS, set of 4:
    $ 17.95
    HCP15890 Aftermarket anti-dive damper piston assembly lower spring seat (adjuster screw) housing O-RING, used where the adjuster screw assembly attaches to the very bottom damper piston assembly housing. Durable Buna-N material as original. Use 1 per housing on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 5.95
    HCP15890SET2 Aftermarket anti-dive damper piston assembly lower spring seat (adjuster screw) housing O-RINGS, set of 2:
    $ 9.95
    HCP15981 Aftermarket anti-dive damper piston assembly lower spring seat (adjuster screw) housing O-RING, used where the adjuster screw assembly attaches to the very bottom damper piston assembly housing. Premium Viton material is more durable than original. Use 1 per housing on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 8.95
    HCP15981SET2 Aftermarket anti-dive damper piston assembly lower spring seat (adjuster screw) housing O-RINGS, set of 2:
    $ 16.95
    HCP21326 Aftermarket anti-dive damper piston assembly adjuster screw RUBBER CAP, covers and protects the adjuster screw at the very bottom damper piston assembly housing. Use 1 per housing on all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 22.95
    HCP21326SET2 Aftermarket anti-dive damper piston assembly adjuster screw RUBBER CAPS, set of 2:
    $ 39.95
    Lower Fork Tube Oil Drain Screw and Gasket:
    HCP5187 OEM lower fork tube oil DRAIN SCREW, use one per tube. Panhead, phillips-drive, alloy steel with a black finish. Note that the black screw was used on models with black lower fork tubes (1982-83 XJ550 Seca, FJ600, 1995 XJ600 Seca II, XJ650 Midnight Maxim, XJ650 Turbo, XJ750 Midnight Maxim, 1981-83 XJ750 Seca and XJ750 Euro models, and some XJ750P models 37H). All other models with natural aluminum lower fork tubes used a screw with a bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 4.95
    HCP29817 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead, phillips-drive, alloy steel with a black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29005 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive zinc-plated alloy steel. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29006 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6710 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ discontinued
    HCP6712 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6711 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP7111 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 8.95
    HCP7111SET2 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 16.95
    HCP21320 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 5.95
    HCP21320SET2 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 10.95
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    HCP8233 OEM fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 9.95
    HCP28069 Aftermarket fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 6.95
    HCP8234 OEM fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 16.95
    HCP12950 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 10.95
    HCP8281 OEM fork tube damper rod RETAINING SCREW. For all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per tube. Comes with the copper crush washer "gasket". Each:
    $ 11.95
    HCP22133 Aftermarket fork tube damper rod RETAINING SCREW. For all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per tube. Gasket is not included. Each:
    $ 4.95
    HCP10028 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per tube. Each:
    $ 4.95
    w) Lower Fork Tube DAMPER ROD RETAINING TOOL. This long aluminum tool, with proper sized nuts on each end, is used to retain the top of the fork damper rod (in the bottom of the chrome tube) when removing or installing the damper rod retaining screw. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ-series bikes except XJ600 Seca II, 1981-83 XJ750 Seca, XJ1100, and all XS1100 Special and Midnight Special models. This tool will make the disassembly of your upper tube from the lower tube much easier! NOTE: this tool is available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    NOTE: the HCP4402 tool does not work with certain forks (the XJ750 Seca being one of them) since the head of the damper rod does not have the internal fluting which the damper rod tool would catch onto (thus locking the damper rod in place, allowing the bolt to be removed). Instead, the damper rod is held via the insertion of a thin, round object (allen wrench of a phillips-drive screwdriver shaft) thru the lower hole in the lower fork tube where the anti-dive housings attach to the lower fork tube. This tool will go thru a drilled hole in the damper rod, thus locking it in place (preventing rotation).
    You can see a good image of this about half-way down the page (during the re-assembly process, although, it will probably also be necessary during the dis-assembly process) on the following page:
    HCP4402 Aftermarket DAMPER ROD RETAINING TOOL, for use on 1984 XJ750RL models (without anti-dive system). Note that all XJ750 Seca models (and XJ750 Euro models) with anti-dive systems do not need nor use this tool.
    $ 44.95
    Lower Fork Tube Speedometer Cable Hardware:
    HCP2182 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 6.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP3933 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 3.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish. Fitted on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 2.95
    HCP315 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, bright finish, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models.
    $ 3.95
    HCP1902 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, black finish, use 1 per bike on the following models: XJ650 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, XJ750 Midnight Maxim, and XS1100 Midnight Special models.
    $ 6.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    Fork Tube Brace and Hardware:
    HCP8480 OEM lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Bright finish, alloy steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP2424 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Black oxide coated alloy steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 1.95
    HCP80 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Black oxide coated alloy steel socket head, allen-drive. Features a small nylon thread patch, making this a self-locking bolt. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP2423 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Bright 18-8 stainless steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    Lower Fork Tube Axle Retaining Hardware:
    HCP4828 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per tube (2 per bike) on both the left and right side lower fork tube. For all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), and XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
    HCP4824 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 9.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated finish, use 1 per bike on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 3.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    Lower Tube ID Decals:
    HCP15136 Aftermarket AIR SUSPENSION WARNING DECAL, this rectangular decal has a black background with silver lettering and border. Correct for all 1981-83 XJ750 Seca and XJ750 Euro models. It mounts on the left lower fork tube almost directly in line with the caliper mounting bosses, and faces “outward”.
    $ 12.95
    FORK SYSTEM SERVICE TOOLS:
    Assembly and Dis-assembly Tools:
    NOTE: many of these tools are available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    $ 44.95
    HCP26093 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 35-36mm fork tubes: XJ550 Seca, FJ600, XJ600 Euro, all XJ650 (except 1983 Turbo), all XJ750 air-cooled (except XJ750P (37H Police) and X750-D models), and XJ900 N/FN models.
    $ 47.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Fork Tube Cleaning and Polishing:
    HCP28489 Fork Tubes DEEP REACH CLEANING BRUSH. This 36" long brush features polyester bristles that will reach deep inside the forks tubes to clean away grit and oil sludge residue that cannot otherwise be reached or disturbed. Has a comfortable easy-grip plastic handle and flexible twisted-wire shaft. Use with your favorite cleaning solvents to get the insides of the fork tubes free of contaminants.
    $ 52.95
    ft4) These stainless-steel, bristle-wire DE-BURRING BRUSHES will work wonders on the upper cap bolt area on both the threaded and the non-threaded style of fork tubes. Tubes that use threaded cap bolt (all XJ650 Turbo, all XJ700 models, XJ750-X models, XJ750 Maxim and Midnight Maxim, XJ900RK, and XJ1100 models) should use the HCP10223 butterfly brush; non-threaded tubes can use either the HCP10222 spiral brush or the HCP10223 butterfly brush. Both style brushes have stems that are designed to be used in a standard power drill, and should be used at 850 rpm's or less. These brushes will make quick and meaningful work of the cleaning and polishing of this critical area on your upper fork tubes.
    HCP10222 Aftermarket stainless-steel double-density spiral DE-BURRING BRUSH, for use on fork tubes without a threaded cap bolt.
    $ 13.95
    HCP10223 Aftermarket stainless-steel high-density "butterfly-wings" DE-BURRING BRUSH, for use on fork tubes with or without threaded cap bolts.
    $ 14.95
    FORK OIL:
    Unlike motor oil or gear oil, fork oil's major purpose is not lubrication.....rather, it acts as part of the suspension system, providing both damping and rebound control functions. The different "weight" or viscosity of fork oils allows you to modify the ride and handling characteristics of your bike in a fairly simple way.
    And yes, it IS a lubricant also!
    Although many people----including, unbelievably, Yamaha itself----recommends the use of engine motor oil as a substitute for fork oil, this is not a very good idea. Engine oils (or any multi-viscosity oil) uses additives and detergents that, while wonderful in for their intended purposes inside an engine block, tranny case, or rear drive unit, are not such a good idea inside forks. Forks operate at a much lower temperature and temperature RANGE than engine and drivetrains do, and thus do not need all those additives. And fork oil also tends to contain higher percentages of molybdenum disulfide and anti-foaming agents than engine or gear oil, both of which are very important to proper fork operation.
    As a small example.......most motor oils are of a multi-viscosity nature (such as 10W30) which change their viscosity in relation to their temperature (thin when cool, thicker as they warm). A very necessary and useful feature for an engine, where you do not want your oil thinning out as the engine warms up. Not such a good idea for your suspension----unless for some reason you WANT your handling characteristics to change (get stiffer) as the forks heat up!
    Proper fork oil levels and scheduled change intervals are important for fork performance and fork part longevity.....water contamination, as well as particulate wear will accumulate in fork oil, and since there is no oil filtering mechanism within your forks, the only way to get the grit and gunk out (before it chews up your oil seals and slider bearings!) is to change your fork fluid regularly. Yamaha recommends a fork fluid change every 10,000 miles or 24 months (all models except XJ700's), or every 16,000 miles or 24 months (all XJ700 and XJ750-X models). If you just bought a used bike, we recommend you do a fluid change as soon as possible, because just like other routine maintenance tasks (besides engine oil changes), this is one that has very likely been ignored for the last 10-12 years!
    HINT: there’s a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it’s brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won’t mix and the water will “ball up”; brake fluid will integrate with water and absorb the water.
    Fork oil capacities and recommended weights are as follows. The amounts listed are per fork tube:
    XJ550 Maxim: 272cc or 9.20 fluid ounces. 10W fork oil.
    XJ550 Seca: 230cc or 7.78 fluid ounces. 10W fork oil.
    1980-81 XJ650 Maxim and Midnight Maxim: 262cc or 8.86 fluid ounces. 10W fork oil.
    1982-84 XJ650 Maxim: 278cc or 9.40 fluid ounces. 10W fork oil.
    1982 XJ650RJ Seca: 236cc or 7.98 fluid ounces. 10W fork oil. Fork oil level is specified as 400mm (15.75") below the top of the tube without the spring installed, forks fully collapsed.
    1982 XJ650LJ Turbo: 238cc or 8.04 fluid ounces. 10W fork oil. Fork oil level is specified as 180mm (7.09") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ650LK Turbo: unknown.
    1985-86 XJ700 non-X: 383cc or 12.96 fluid ounces. 10W fork oil.
    1985-86 XJ700-X: 389cc or 13.16 fluid ounces. 10W fork oil.
    1982 XJ750 Maxim: 257cc or 8.69 fluid ounces. 10W fork oil.
    1983 XJ750 Maxim and Midnight Maxim: 257cc or 8.69 fluid ounces. 10W fork oil. NOTE: owner's manual states that the fork oil capacity is 278cc (9.40 fluid ounces). It is unknown which measurement is correct.
    1981-83 XJ750 Seca: 309cc or 10.45 fluid ounces. 20W fork oil.
    1983 XJ750 E-II Seca or 1984 XJ750RL Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 168mm (6.61") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ900RK Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 164mm (6.46") below the top of the tube without the spring installed, forks fully collapsed.
    1982-84 XJ1100 Maxim and Midnight Maxim: 210cc or 7.10 fluid ounces. 10W fork oil. Fork oil level is specified as 210mm (8.27") below the top of the tube without the spring installed, forks fully collapsed.
    IMPORTANT NOTE: the above fork oil VOLUMES are for use only when using the stock fork springs. The use of aftermarket performance front fork coil springs will change those volumes, since aftermarket springs are thicker than stock----and thus displace more oil. Using the stock oil fluid VOLUME with aftermarket fork springs is a sure way to OVERFILL your forks, with the very real possibility of blowing out fork seals.
    Unlike with your engine oil, where a bit too much or too little oil volume in the crankcase is not really a significant concern, with fork oil, too much or too little can cause real problems (too much oil can result in blown oil seals and a stiff, harsh ride, while too little oil volume results in excessive foaming, a soft mushy ride with possible bottoming, and erratic fork performance and lots of front end "dive" upon braking).
    A better way to determine the amount of fork oil that is needed and necessary is via the measurement of the fork oil LEVEL within the tubes.....sort of like measuring the oil level with a dipstick. Yamaha does not specify this level for all models; and in any case, if using aftermarket springs, the factory oil level recommendation is not always useful. The maximum oil level should be 5-1/2" (140mm) below the top of the inner fork tube, measured with all internal fork tube components installed EXCEPT FOR THE SPRINGS, and with the inner fork tube fully collapsed into the lower (outer) tube.
    In order to be as accurate as possible, we recommend the use of a suitable measuring device, such as the HCP1728 oil level syringe listed further below.
    And finally, the fork oil viscosity can be changed from the factory recommendations to give a softer or firmer ride.......the lower the viscosity, the thinner the oil, and the softer the ride (i.e. 5W oil is thinner than 10W which is thinner than 20W, etc.) In this regard, you would certainly be correct in thinking of fork oil as a suspension "tuning tool"! Note that a thicker oil viscosity will have much more effect on the fork "rebound" characteristics than it will on the fork compression dampening function.
    A great primer on "tuning" your forks via adjusting the oil levels can be seen at:
    http://www.thumpertalk.com/forum/archive/index.php/t-89918.html
    while the theory and science and practical applications of tuning your suspension via using differing viscosities of fork oil can is revealed at:
    http://www.peterverdone.com/archive/lowspeed.htm
    ffo3) Red Line Oil products line of SYNTHETIC FORK OILS are some of the best, highest-performance fork oils developed specifically for this purpose. They provide exceptional shear lubrication, are highly resistant to any viscosity changes, and provide excellent seal lubrication as well as very high anti-foaming properties. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    Also, do not mix different brands, styles, or types of oils........you can only safely mix forks oils together from one manufacturer!
    HCP1563 Red Line high-performance SYNTHETIC FORK OIL 0W (zero weight, "like water"), 16 ounce bottle (473cc), clear. Each bottle:
    $ 27.95
    HCP1564 Red Line high-performance SYNTHETIC FORK OIL 2.5W, 16 ounce bottle (473cc), blue. Each bottle:
    $ 27.95
    HCP1258 Red Line high-performance SYNTHETIC FORK OIL 5W, 16 ounce bottle (473cc), amber. Each bottle:
    $ 27.95
    HCP1259 Red Line high-performance SYNTHETIC FORK OIL 10W, 16 ounce bottle (473cc), red. Each bottle:
    $ 27.95
    HCP1263 Red Line high-performance SYNTHETIC FORK OIL 30W, 16 ounce bottle (473cc), orange. NOTE: this oil is similar in viscosity to what most other oil manufacturers call "20W" oil. Each bottle:
    $ 27.95
    ffo4) PJ1 products line of TUNER FORK OILS are exceptional quality, value-priced fork oils developed specifically for motorcycle suspensions. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    HCP10360 PJ1 products TUNER FORK OIL 2.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10362 PJ1 products TUNER FORK OIL 5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10364 PJ1 products TUNER FORK OIL 7.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10366 PJ1 products TUNER FORK OIL 10W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10368 PJ1 products TUNER FORK OIL 15W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10370 PJ1 products TUNER FORK OIL 20W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10372 PJ1 products TUNER FORK OIL 30W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    Fork Tube Oil Level Gauges:
    HCP1728 Fork tube oil fluid level measurement GAUGE AND SYRINGE. This handy tool makes the measurement of the fork oil level easy and accurate. NOTE: the proper amount of fork oil is determined via the measurement of the fork oil LEVEL (distance below the very top of the inner tube) rather than a volume AMOUNT of oil specification. Too little oil will make the ride mushy, while too much oil makes the ride harsh (and can blow out the oil seals!)
    $ 39.95
    ffl4) Aftermarket fork oil measurement GRADUATED CYLINDERS. The best way to measure the precise amount of fork oil fluid is via the use of these lab-quality measurement cylinders. Available in either transparent (clear) or translucent (cloudy) durable plastic construction, they all have easy-to-read scale numerals (milliliters) and feature a "non-wetting" inner surface coating that prevents the concave "meniscus" from forming at the top of the fluid, thus insuring a much more accurate level reading. Large bases insure stability while large spouts make "the pour" easy and prevent messy drips. Very useful device to have for front fork oil changes.
    HCP10741 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, translucent (cloudy).
    $ 24.95
    HCP10744 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, transparent (clear).
    $ 49.95
    HCP10742 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, translucent (cloudy).
    $ 29.95
    HCP10745 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, transparent (clear).
    $ 69.95
    HCP10743 Aftermarket fork oil GRADUATED CYLINDER, super-sized 1000ml capacity, translucent (cloudy), with convenient side handle to insure steady pouring.
    $ 89.95
    Fork Tube Air Pressure Tool and Gauge:
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 6.95
    HCP9108 Aftermarket air-assisted forks LOW PRESSURE AIR GAUGE, heavy-duty 0-20 psi pencil (stick) pressure gauge marked in 1/2-psi increments, perfect for checking fork air pressures on models so equipped. Very high quality and much more accurate than standard tire pressure gauges, which is very important on the fork pressures as an imbalance between the fork pressure can lead to steering and stability issues, while too much pressure will blow out the lower tube oil seals!
    $ 9.95
  11. chacal
    XJ900 MODELS FORK TUBE PARTS:
    NOTE: items marked below in red are the parts typically needed when doing a basic fork system rebuild.
    A good visual review of the procedures needed for rebuilding these forks can be seen at:
    http://xjbikes.com/forums/index.php?threads/4067
    Note that this link shows the guts on the later XJ900 models fork systems (without the anti-dive system), but is pretty much the same as on the earlier versions with the anti-dive system.
    The secret workings of the anti-dive units can be seen at:
    https://www.xjbikes.com/forums/threads/xj900rk-anti-dive-stripdown-how-to-with-pics.44997
    And these incredible 3-D renderings of the inner workings of a forking system gives a great visualization of the internal components (it is based on the 1982-83 XJ650 Maxim forks):
    http://xjbikes.com/forums/index.php?threads/29616
    NOTE: XJ750 Police (37H models) used the XJ650 Turbo master cylinder with XJ650 Turbo/XJ750 Maxim/Midnight Maxim calipers, XJ650 Turbo rotors, and XJ900 style forks with anti-dive.
    FORK TUBE REBUILD KITS:
    We now offer both a BASIC FORK REBUILD KIT and PERFORMANCE FOR TUBE REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike. NOTE: fork rebuild kits do not include any of the items used in rebuilding the anti-dive units; a separate kit to rebuild those is available as part HCP21992 and is listed in the anti-dive parts section further below.
    - NOTE: the lower tube “dust boots” (sometimes called dust seals) are not included in the basic fork tube rebuild kits, but are available separate and can be found further below.
    Basic fork rebuild kit contains at least the following items:
    - cap bolt o-rings.
    - standard quality lower fork tube oil seals.
    - oil seal retaining clips.
    - oil drain screws and gaskets.
    - damper rod bolts and crush washers.
    - damper rod head piston rings.
    - air joint cushions, o-rings, and retaining rings (in the XJ900RK/RL kit).
    - air valve cores (in the XJ900RK/RL kit).
    - anti-dive housing to fork tube o-rings (1983-84 kits)
    HCP20633 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1983-84 XJ900 RK/RL models (with the anti-dive fork system). One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 199.95
    HCP20633DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1983-84 XJ900 RK/RL models (with the anti-dive fork system). One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 237.95
    HCP20635 Aftermarket fork tubes BASIC FORK REBUILD KIT. Fits 1984 XJ750RL (44X Canadian model) and all 1985-1991 XJ900 F, N, and FN models (without the anti-dive fork system). One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 109.95
    HCP20635DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. Fits 1984 XJ750RL (44X Canadian model) and all 1985-1991 XJ900 F, N, and FN models (without the anti-dive fork system). One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 137.95
    Performance fork rebuild kit contain all of the basic rebuild kit components, along with:
    - performance fork springs.
    - upgraded, high-performance lower fork tube oil seals.
    - lower fork tube dust boots.
    - air valve core stem tool (in the XJ900RK/RL kit).
    HCP20634 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1983-84 XJ900 RK/RL models (with the anti-dive fork system). One kit does both front tubes.
    $ 479.95
    HCP20636 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. Fits 1984 XJ750RL (44X Canadian model) and all 1985-1991 XJ900 F, N, and FN models (without the anti-dive fork system). One kit does both front tubes.
    $ 379.95
    Of course, all of the component pieces can be ordered as individual pieces from the selections listed below, as well as non-typical wear items (inner tubes, damper rod piston rings, taper spindles, cap bolts, etc.), as well as the fork oil and specialty tools needed to properly restore or enhance your front suspension performance.
    UPPER (INNER) FORK TUBES AND PARTS:
    Chrome Inner Fork Tubes:
    HCP8534 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ900RK and XJ900RL models equipped with the anti-dive front suspension. NOTE: due to slight differences in manufacturing techniques used on these reproduction tubes (versus the originals), we highly suggest that XJ models which use the anti-dive front suspension ALWAYS replace both front tubes rather than just a single tube. Each:
    $ 299.95
    HCP8534SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP9948 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all all XJ750RL (45T Australian model), XJ900N, and XJ900FN models. Each:
    $ 299.95
    HCP9948SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    Inner Tube Top Cover/Cap:
    HCP8289 OEM inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 28.95
    HCP22880 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following models: 1984 FJ600, 1982-83 XJ650 Turbo, XJ750RL, XJ750-D, XJ750-P (24L model), and XJ900RK, RL, N/FN, and F Seca models. NOTE: you can substitute the HCP8287 top cap in place of this one for a upgraded appearance! Each:
    $ 19.95
    Inner Fork Tube Cap Bolts and Related:
    HCP8292 OEM inner fork tube CAP BOLT, fits either side. Used on all 1984 FJ600, XJ700 non-X, XJ750RL, and XJ900RK, RL, and N/FN Seca models. NOTE: these cap bolts require a special inverse-hex tool HCP9238 to properly remove and install. Each:
    $ 49.95
    HCP9238 Aftermarket fork upper cap bolt REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive cap bolt used on the top of the inner fork tubes on all 1984 FJ600, XJ650 Turbo, XJ700 non-X, XJ750-D, XJ750P (37H) model, all XJ900RK, RL, N/FN, and F, and 1982 XZ550R Vision models.
    $ 19.95
    HCP8286 OEM inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 7.95
    HCP20708 Aftermarket inner fork tube cap bolt O-RING, fits either side. Used on all 1984-85 FJ600, XJ700, XJ750-X, XJ750RL, and XJ900RK, RL, N/FN, and F Seca models. Each:
    $ 5.95
    Inner Tube Fork Springs:
    NOTE: the following springs are correct for the XJ900RK and RL models, XJ750RL (44X Canadian and 45T Australian models), and will also fit the XJ900 N, FN, and F model fork tubes, but we do not have the information for the non anti-dive forks in regards to spring spacers or oil fluid capacities required. Original non anti-dive fork springs (XJ900N, FN, and F models) are 5mm shorter than anti-dive springs (XJ900RK and RL), so it is safe to assume that a 5mm (or greater) spacer may be needed, and the oil level adjusted to achieve a 168mm height.
    HCP9439 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ900RK, XJ900RL, XJ750RL, XJ1100, and all XS1100 models. No spring spacer is needed when using these springs on the XJ900RK and RL models. NOTE: due to the difference in size of this spring versus stock springs, you will need to use approximately 31 cc's less fork oil (for a total of 255cc's per tube on the RK and RL models, and 276cc on all other XJ900 models) when installing these springs, or adjust to a 164mm oil level. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 259.95
    Inner Fork Tube Spring Spacers, Rebound Springs, Damper Rods, and Spring Seats:
    HCP8280 OEM inner fork tube SPRING SEAT, fits either side. Used on all 1985 FJ600 models, XJ700, XJ750-X, and XJ900 F models. Each:
    $ 37.95
    HCP13657 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1984-85 FJ600, all XJ700, XJ750-X, XJ750RL Canadian (44X model), and XJ900 models. Use 1 per fork tube. Each:
    $ 17.95
    Inner Fork Tube Oil Lock Valve Parts:
    HCP8344 OEM inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 2 per tube, each:
    $ discontinued
    HCP19355 Aftermarket inner fork tube oil lock valve SPRING WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 2 per tube, each:
    $ 19.95
    HCP19356 Aftermarket inner fork tube oil lock valve FLAT WASHER, fits either side. Used on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Use 1 per tube, each:
    $ 17.95
    NOTE: the order of installation for the above washers is as follows (and only applies to bikes with anti-dive front fork systems, i.e. the XJ750RL, XJ750P (37H model), and XJ900RK and RL models):
    Order of assembly of 1984 XJ750RL, XJ750P (37H model, and XJ900RK/RL Seca oil lock valve assembly components onto damper rod:
    NOTE: the Yamaha factory service manual has an incorrect written description and an incorrect image showing the assembly order of the “oil lock valve” components onto the damper rod, showing the two wave washers being adjacent to each other. The correct assembly sequence --- as shown below --- is for the wave washers to be separated by the flat shim washer:
    TOP (HEAD) OF DAMPER ROD
    DAMPER ROD REBOUND SPRING
    Above fitted thru bottom of inner/upper (chrome) fork tube.
    On thinner, lower end of damper rod:
    WAVE WASHER (HCP19355) goes onto the damper rod shaft first
    FLAT WASHER (HCP19356) goes onto the damper rod shaft next
    WAVE WASHER (HCP19355) goes onto the damper rod shaft third
    Finally the TAPER SPINDLE (HCP3085) goes on last.
    Inner Fork Tube Taper Spindle:
    HCP3085 OEM upper (inner) fork tube TAPER SPINDLE, fits either side. Fits all XJ550 models, 1984 FJ600, all XJ650 models, all XJ700 and XJ750-X models, all XJ750 Maxim and Midnight Maxim models, XJ900 N/FN and F models, all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 31.95
    Inner Tube Metal Slider Bushings:
    HCP10705 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: XJ750RL (45T Australian model), XJ900RK, RL, and N/FN models. One slider does one tube. Each:
    $ 49.95
    HCP10705SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 89.95
    INNER FORK TUBE AIR SYSTEM PARTS:
    Air Joint Cushions, O-Rings, and Retainers:
    HCP8242 OEM air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 10.95
    HCP8242SET2 OEM air joint rubber UPPER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket air joint rubber UPPER CUSHION GASKET, fits either side, directly above the air joint, and cushions the top of the air joint from the bottom of the crown bracket. Used on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750-P (24L) models, XJ750-D, 1984 XJ750RL, and XJ900RK and RL models. Use 1 per tube. Also used on these non-XJ models: 1985-86 FZ750, 1983 XV920J Virago, 1984-85 XV1000 Virago, and 1986-94 XV1100 Virago. Each:
    $ 7.95
    HCP15647SET2 Aftermarket air joint rubber UPPER CUSHION GASKETS, fits either side. Set of two:
    $ 14.95
    HCP8341 OEM inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, and XJ900RK and RL models. Uses 2 o-rings per joint. Each:
    $ discontinued
    HCP8341SET4 OEM inner fork tube air joint INNER O-RINGS, set of 4:
    $ discontinued
    HCP20701 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, XJ900RK and RL models, and XJ1100 models. Uses 2 o-rings per joint. Each:
    $ 8.95
    HCP20701SET4 Aftermarket inner fork tube air joint INNER O-RINGS, set of 4:
    $ 27.95
    HCP8283 OEM inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: XJ650 Turbo, 1982 XJ750 Maxim, XJ750-D, XJ750-P (24L model), XJ900RK and RL, and 1983 XV920K Virago models. Each:
    $ discontinued
    HCP12315 Aftermarket inner fork tube air joint RETAINER RING, this narrow, stainless steel wire retainer ring fits in the machined groove on the tube and prevents the air joint from migrating along the tube. Use 1 per tube, fits either left or right air joint on the following models: XJ650 Turbo, 1982 XJ750 Maxim, XJ750-D, XJ750-P (24L model), XJ900RK and RL, and 1983 XV920K Virago models. Each:
    $ 7.95
    Air Inflation Valves and O-Rings:
    HCP8274 OEM inner fork tube air joint AIR VALVE WITH CAP, comes complete the internal stem core, its o-ring, and chrome cap. Fits the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and the included protective cap is much smaller than the huge caps used on those models, and due to the length difference, those large original caps will not fit properly on this shorter valve. This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 57.95
    HCP11890 OEM inner fork tube air joint brass AIR VALVE ONLY, comes complete the internal stem core and its o-ring. The chrome cap is not included. Fits the following models: 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. Each:
    $ 39.95
    HCP11876 OEM inner fork tube air joint air valve CHROME CAP, ribbed, dome-head style. Correct for all of the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This cap can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is much smaller than the large original caps used on those models. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 19.95
    HCP2322 OEM inner fork tube air joint air valve and air hose-to-joint O-RING, fits the following models: 1985 FJ600 models (use 1 per tube), 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 3 per bike), XJ750-P (24L and 37H models, use 2 per bike), XJ750-D (use 3 per bike), 1982 XJ750 Maxim (use 3 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 3 per bike), and XJ900RK and RL models (use 3 per bike). Each:
    $ 7.95
    HCP14020 Aftermarket inner fork tube air joint air valve and air hose-to-joint O-RING, fits the following models: 1985 FJ600 models (use 1 per tube), 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 3 per bike), XJ750-P (24L and 37H models, use 2 per bike), XJ750-D (use 3 per bike), 1982 XJ750 Maxim (use 3 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 3 per bike), and XJ900RK and RL models (use 3 per bike). Each:
    $ 5.95
    HCP9194 Aftermarket fork tube AIR VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all 1985 FJ600 models, 1982-83 XJ650 Maxim and Turbo models, XJ700-X models, all XJ750 models, the XJ900RK model, XJ1100, and all XS1100 Special and Midnight Special models. If your stem is leaking air, this is the inexpensive way to fix it. Each:
    $ 3.95
    HCP9194SET2 Aftermarket fork tube AIR VALVE STEM CORES, set of 2:
    $ 6.95
    $ 5.95
    INNER FORK TUBE RETAINING HARDWARE:
    Crown Bracket Inner Fork Tube Retaining Hardware:
    HCP4530 OEM crown bracket fork tube CINCH BOLT, use 1 per side. For the following models: all XJ900RK Seca models. Each:
    $ 4.95
    HCP4530SET2 OEM crown bracket fork tube CINCH BOLTS, use 1 per side. Pair:
    $ 8.95
    HCP18011 Aftermarket cinch bolt head protective CAP. Smooth, black plastic cap snaps over the head of the fork tube cinch bolts, giving them a very "modern" look, protecting the head from rust. Fits all OEM or aftermarket bolts with a 12mm hex or socket head. Each:
    $ 4.95
    Under-bracket Inner Fork Tube Retaining Hardware:
    HCP3656 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 7.95
    HCP3652 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all XJ550 models, all XJ650 models, XJ750-D, all 1982-83 XJ750 Maxim models, and XJ900 N/FN and F models. Each:
    $ 9.95
    HCP2185 OEM under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 6.95
    HCP16209 Aftermarket zinc-plated, alloy steel, under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP16100 Aftermarket 18-8 stainless-steel, under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP16102 Aftermarket black-oxide coated finish, under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 3.95
    $ 4.95
    LOWER (OUTER) FORK TUBE PARTS:
    Dust Wiper Seals:
    HCP1822 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984 XJ750RL Seca (44X Canadian models) and all XJ900RK, RL, F, N, and FN models. One seal does one tube. Each:
    $ 22.95
    HCP21561 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1984 XJ750RL Seca (44X Canadian models) and all XJ900RK, RL, F, N, and FN models. One seal does one tube. Each:
    $ 17.95
    Oil Seals:
    NOTE: when installing oil seals, make sure that the area where the seal will fit into is clean, free of any nicks and burrs, and that the lower tube metal slide bushing is fully seated. Oil seals install with the large opening facing down, into the tube, and on most seals, the small cast lettering and numbering on the seal faces upwards.
    Seals are designed to be installed with a seal driver of some type, although a properly sized piece of hard plastic tubing, perhaps with a proper sized metal washer on top of the seal to "spread the load", works as well. Always make sure that oil seals are fully seated and not damaged or installed in a crooked or cocked manner.
    HCP1816 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. One seal does one tube. Each:
    $ 33.95
    HCP20646 Aftermarket standard quality lower fork tube BLACK OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. Comes packaged as a pair of seals, enough to do both forks.
    $ 49.95
    HCP1718 Aftermarket premium quality lower fork tube BLACK OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. Comes packaged as a pair of seals, enough to do both forks.
    $ 54.95
    Oil Seal & Dust Seal Kits:
    HCP1723 Aftermarket premium quality lower fork tube BLACK OIL SEALS & DUST WIPER SEALS KIT, fits the following models: 1984 XJ750RL Seca (44X Canadian models) and all XJ900RK, RL, F, N, and FN models. Comes with one pair of both the oil and dust seals, enough to do both forks.
    $ 64.95
    Oil Seal Retaining Clips:
    HCP1828 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 8.95
    HCP20717 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    Oil Seal Spacer Washer:
    HCP3096 OEM lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: XJ900RK and RL models. One washer does one tube. This washer goes above the oil seal, and below the seal retaining clip! Each:
    $ discontinued
    HCP21035 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: XJ900RK and RL models. One washer does one tube. This washer goes above the oil seal, and below the seal retaining clip! Each:
    $ 16.95
    HCP3094 OEM lower fork tube OIL SEAL SPACER WASHER, fits either left or right tube on the following models: XJ750RL (44X Canadian model), XJ900RK, RL, N/FN, and F models. One washer does one tube. This washer goes below the oil seal, and above the metal slider bushing! Each:
    $ discontinued
    Lower Tube Metal Slider Bushings:
    HCP4259 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H models), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 49.95
    HCP4259SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10709 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 39.95
    HCP10709SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    Lower Tube Anti-Dive Unit Parts:
    The front fork ANTI-DIVE SYSTEM on these models are almost always in need of a complete, thorough cleaning and rebuild. While many people claim that the anti-dive system is a "useless" feature, the real reason may be that the system is so internally fouled and seized that it simply is not operating, at all!
    Anti-dive control units are divided into an "upper" (or "top") section, which is the brake plunger assembly....this upper section is where the brake hose, from the brake caliper, attaches. The brake fluid BLEEDER VALVE is located in this upper section, as well as the brake plunger piston unit. The O-RING on the plunger and on the screw-in piston head should be replaced during a rebuild procedure, as well as a thorough cleaning and polishing of the piston bore. The removal of the piston head requires the use of a special reverse-hex tool, part HCP16049.
    The "lower" (or "main") section of the anti-dive unit is the larger damper piston assembly (which is bolted to the fork tube), and which contains the damper actuating piston and spring. Under hard braking, the brake fluid pressure forces the brake plunger (in the top "brake plunger assembly" section) to push down on the damper piston and its spring, restricting the flow of fork oil in the fork tubes, thus "stiffening" the fork system temporarily----and reducing the amount of front end "dive" during hard braking. The O-RING on the plunger should be replaced during a rebuild procedure, as well as a thorough cleaning and polishing of the piston bore. And the housing-to-fork tube O-RINGS should also be renewed.
    Here's a good view of the components of the lower damper piston assembly on the XJ750-D, XJ750P Police (37H model), and XJ900RK and RL models anti-dive unit can be seen at:
    http://xjbikes.com/forums/index.php?threads/44997
    NOTE: to dis-assemble the brake plunger assembly piston for cleaning and replacement of the o-rings, you will need this special tool to extract the threaded plug from the housing:
    HCP16049 Aftermarket fork anti-dive brake plunger assembly REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive plug used on the top of the anti-dive units on all XJ750-D, XJ750P (37H model), XJ900RK, and XJ900RL models.
    $ 19.95
    NOTE: if you want to disable your anti-dive system, you will need to remove the hose from the caliper to the anti-dive unit (and replace the caliper end double-depth union bolt with the single-depth union bolt used at the anti-dive unit end of the hose) and block-off the anti-dive fluid port with this plug:
    HCP12991 Aftermarket brake system fluid port BLOCK-OFF PLUG, correct size hex-drive set-screw is used to replace a brake hose union bolt when not in use. Use 1 per anti-dive unit.
    $ 6.95
    or an even more stylish alternative is to use these custom-made BLOCK-OFF PLATES that completely replace the upper section of the anti-dive unit:
    HCP22862SLV Aftermarket anti-dive upper housing BLOCK-OFF PLATE, beautiful machined aluminum cover plates completely replace the upper portion of your anti-dive units, fully disabling their function. Silver-painted covers come with mounting screws and a pre-load adjuster bolt which allows you to apply a small amount of pre-load (“pressure”) to the lower plunger and create a custom compression/rebound effect to your forks. Sold in a matched LH/RH set. Silver finish is correct for XJ900RK and RL models, but will also work on XJ750-D and XJ750P (37H models) systems.
    $ 89.95
    HCP22862FBL Aftermarket anti-dive upper housing BLOCK-OFF PLATE, beautiful machined aluminum cover plates completely replace the upper portion of your anti-dive units, fully disabling their function. Black-anodized covers come with mounting screws and a pre-load adjuster bolt which allows you to apply a small amount of pre-load (“pressure”) to the lower plunger and create a custom compression/rebound effect to your forks. Sold in a matched LH/RH set. Black finish is correct for most XJ750-D and XJ750P (37H models) systems, but will also work on XJ900RK and RL models.
    $ 89.95
    Anti-Dive Rebuild Kits:
    No need to guess what parts you're going to need......our complete ANTI-DIVE REBUILD KITS take all the guesswork out by supplying you with all of the parts necessary. Kits contain all of the rubber and plastic seals, boots, o-rings, circlips, washers, standard bleeder screws, drain screws, and hardware need to do a complete and thorough rebuild of these units. Experience how your anti-dive units should actually perform by rebuilding them correctly! NOTE: the adjuster screws (HCP23505) are not included in these rebuild kits and should be ordered separately (see listings below) if they need replacement.
    The most difficult part of the rebuild process is is the installation of the thin "wavy" wire clip, which require simultaneously compress the main spring and getting the wavy clip into its retaining groove. Here's a helpful link on this issue:
    https://www.xjbikes.com/forums/threads/xj900-continuing-to-put-up-a-fight-fork-disassembly.132872
    HCP21992 Aftermarket complete ANTI-DIVE REBUILD KIT, contains all of the rebuild items needed to overhaul an anti-dive unit used on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. One kit services one anti-dive unit. Each:
    $ 129.95
    HCP21992SET2 Aftermarket complete ANTI-DIVE REBUILD KITS, two complete rebuild kits, enough to service one bike:
    $ 219.95
    Anti-Dive Individual Rebuild Components:
    NOTE: XJ900 anti-dive units are very similar to those used on 1983-85 XVZ12, 1984-85 FJ1100, and the 1986-87 FJ1200 models, and as such, some of the components listed below may be able to be used on those models, too.....but, we've never dissected any of those units to do direct comparisons, so you would be on your own to determine whether they will fit and operate properly.
    All of the following items are part of the Brake Plunger Assembly (the "upper" or top cap section of the entire anti-dive unit). Items are listed (basically) “in order of appearance” as you would observe as you take the component pieces apart, from bottom to top.:
    HCP7116 OEM anti-dive brake plunger assembly BLEEDER VALVE, use 1 per housing on all XJ900RK and RL models, each:
    $ 24.95
    HCP7116SET2 OEM anti-dive brake plunger assembly BLEEDER VALVES, set of 2:
    $ 46.95
    HCP1775 OEM anti-dive brake piston assembly FLUID BLEEDER SCREW, bright finish, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Each screw comes with the protective rubber cap. Each:
    $ 27.95
    HCP1775SET2 OEM anti-dive brake piston assembly FLUID BLEEDER SCREWS, set of 2:
    $ 49.95
    HCP11783 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREW, dark finish, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Protective rubber cap is not included and must be ordered separate. Each:
    $ 19.95
    HCP11783SET2 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREWS, set of 2:
    $ 34.95
    HCP24097 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREW, bright finish, fits all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. Protective rubber cap is not included and must be ordered separate. Each:
    $ 19.95
    HCP24097SET2 Aftermarket anti-dive brake piston assembly FLUID BLEEDER SCREWS, set of 2:
    $ 34.95
    HCP7115 OEM anti-dive brake piston assembly air bleeder valve RUBBER CAP, use 1 per housing on all 1981-83 XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models, each:
    $ discontinued
    HCP17790 Aftermarket anti-dive brake plunger assembly bleeder screw protective rubber DUST CAP, black, dome-shaped head, no retaining strap, each:
    $ 1.95
    HCP1640 Aftermarket anti-dive brake plunger assembly bleeder screw protective rubber DUST CAP, black, dome-shaped head, with retaining strap, no more losing your caps! Each
    $ 2.95
    HCP6852 Aftermarket anti-dive brake plunger assembly SPEED-BLEEDER SCREW, fits all XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. These screws are 1mm longer (on the nipple end) than the original screw, and are made from standard alloy steel. Each screw comes with the protective rubber cap. NOTE: speed bleeder screws require the use of a thread sealant product to perform properly......otherwise, air can and will get sucked in thru the threads when the bleeder screw is loosened during the bleeding process. We recommend the use of our HCP13492, and you use it very sparingly. Do not use teflon tape; brake fluid will degrade it, and then the melted goo will be sucked into the speed bleeder valve and clog it.....game over! Each:
    $ 8.95
    HCP6852SET2 Aftermarket anti-dive brake plunger assembly SPEED-BLEEDER SCREWS, set of 2:
    $ 16.95
    HCP6853 Aftermarket anti-dive brake plunger assembly SPEED-BLEEDER SCREW, fits all XJ750 Seca, XJ750 Euro, XJ750RL, XJ750P (37H model), and XJ900RK and RL models. These screws are 6mm longer (on the nipple end) than the original screw, and are made from stainless steel. Each screw comes with the protective rubber cap. NOTE: speed bleeder screws require the use of a thread sealant product to perform properly......otherwise, air can and will get sucked in thru the threads when the bleeder screw is loosened during the bleeding process. We recommend the use of our HCP13492, and you use it very sparingly. Do not use teflon tape; brake fluid will degrade it, and then the melted goo will be sucked into the speed bleeder valve and clog it.....game over! Each:
    $ 15.95
    HCP6853SET2 Aftermarket anti-dive brake plunger assembly SPEED-BLEEDER SCREWS, set of 2:
    $ 29.95
    NOTE: speed-bleeders should NEVER be used when first re-filling a "dry" brake system----one where the lines, calipers, or master cylinder has been rebuilt or changed, for example----as the air in the system will compress, and the speed-bleeder valve will prevent fluid from flowing through the system. Always bleed dry systems using standard bleeder screws first, and only then install the speed-bleeders, and re-bleed!
    HCP13492 Aftermarket anti-dive brake plunger assembly bleeder screw THREAD SEALANT PASTE, designed to fill and seal the thread cavities and prevent air or fluid leaks. 6ml squeeze tube is enough to do a whole bunch of fittings!
    $ 7.95
    HCP7109 OEM anti-dive brake plunger assembly housing-to-damper piston assembly housing BOLT, use 2 per housing on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 6.95
    HCP311 Aftermarket anti-dive brake plunger assembly housing-to-damper piston assembly housing BOLT, 18-8 stainless steel material, use 2 per housing on all XJ750RL, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 2.95
    HCP16047 Aftermarket anti-dive brake plunger assembly piston shaft PLATE WASHER, fits around the brake piston plunger shaft and is retained by screw-in aluminum piston head. Use 1 per housing on all XJ750-D, XJ750P (37H), XJ900RK, and XJ900RL models:
    $ 14.95
    HCP16047SET2 Aftermarket anti-dive brake plunger assembly piston shaft PLATE WASHERS, set of 2:
    $ 27.95
    HCP16046 Aftermarket anti-dive brake plunger assembly piston head FLAT RUBBER SEAL, fits into the recess in the top of the aluminum piston; the brake plunger runs thru this seal. Fits directly below the HCP16047 plate washer. Use 1 per side on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 16.95
    HCP16046SET2 Aftermarket anti-dive brake plunger assembly piston head FLAT RUBBER SEALS, set of 2:
    $ 29.95
    HCP16044 Aftermarket anti-dive brake plunger assembly piston head RUBBER D-RING, fits into the recess in the side of the aluminum piston. Use 1 per side on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 14.95
    HCP16044SET2 Aftermarket anti-dive brake plunger assembly piston head RUBBER D-RINGS, set of 2:
    $ 27.95
    All of the following items are part of the Damper Piston Assembly (the "lower" or bottom (larger) section of the entire anti-dive unit) Items are listed “in order of appearance” as you would observe as you take the component pieces apart, from top to bottom.:
    HCP21531 Aftermarket anti-dive damper piston assembly piston shaft CAP SEAL/BOOT, fits at the very top of the housing and acts as a dust deal between the upper and lower housing. Molded rubber seal has integral metal base as original. Replaces a commonly damaged part. Use 1 per housing on all XJ750-D, XJ750P (37H), XJ900RK, and XJ900RL models:
    $ 22.95
    HCP21531SET2 Aftermarket anti-dive damper piston assembly piston shaft CAP SEALS/BOOTS, set of 2:
    $ 39.95
    HCP21414 Aftermarket anti-dive damper piston assembly piston retaining E-CLIP, black alloy steel, use 1 per side on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 3.95
    HCP21414SET2 Aftermarket anti-dive damper piston assembly piston shaft retaining E-CLIPS, set of 2:
    $ 6.95
    HCP16036 Aftermarket anti-dive damper piston assembly actuating piston O-RING, fits into the recess in the side of the aluminum piston. Use 1 per piston on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 7.95
    HCP16036SET2 Aftermarket anti-dive damper piston assembly actuating piston O-RINGS, set of 2:
    $ 13.95
    HCP16025 Aftermarket anti-dive damper piston assembly actuating piston FLAT RUBBER SEAL, fits into the recess in the bottom of the aluminum piston; the plunger shaft runs thru this seal. Fits directly above the HCP21574 plastic collar below. Use 1 per piston on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 19.95
    HCP16025SET2 Aftermarket anti-dive damper piston assembly actuating piston FLAT RUBBER SEALS, set of 2:
    $ 34.95
    HCP21574 Aftermarket anti-dive damper piston assembly actuating piston shaft PLASTIC COLLAR, fits under the piston head and below the HCP16025 rubber seal. Use 1 per piston on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 21.95
    HCP21574SET2 Aftermarket anti-dive damper piston assembly actuating piston PLASTIC COLLARS, set of 2:
    $ 39.95
    HCP21521 Aftermarket anti-dive damper piston assembly piston spring RETAINING WIRE WAVY CLIP, retains the HCP21446 plate seal and the large spring in the lower section of the housing, use 1 per side on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 13.95
    HCP21521SET2 Aftermarket anti-dive damper piston assembly piston spring RETAINING WIRE WAVY CLIPS, set of 2:
    $ 24.95
    HCP21446 Aftermarket anti-dive damper piston assembly piston spring RUBBER SEAL PLATE, sits atop the large spring in the lower section of the housing, and is retained by the HCP21521 wavy clip listed above. Use 1 per side on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 17.95
    HCP21446SET2 Aftermarket anti-dive damper piston assembly piston spring RUBBER SEAL PLATES, set of 2:
    $ 32.95
    HCP7110 OEM anti-dive damper piston assembly housing-to-lower fork tube O-RING, use 2 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 6.95
    HCP7110SET2 OEM anti-dive damper piston assembly housing-to-lower fork tube O-RINGS, set of 2:
    $ 12.95
    HCP7110SET4 OEM anti-dive damper piston assembly housing-to-lower fork tube O-RINGS, set of 4:
    $ 24.95
    HCP10557 Aftermarket anti-dive damper piston assembly housing-to-lower fork tube O-RING, correct size, is used where the main housing attaches to the lower fork tube. Use 2 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 4.95
    HCP10557SET2 Aftermarket anti-dive damper piston assembly housing-to-lower fork tube O-RINGS, set of 2:
    $ 8.95
    HCP10557SET4 Aftermarket anti-dive damper piston assembly housing-to-lower fork tube O-RINGS, set of 4:
    $ 14.95
    HCP7107 OEM anti-dive damper piston assembly housing-to-lower fork tube attaching BOLT, socket head (hex-key drive) alloy steel fastener with a bright zinc-plated finish. Use 2 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 7.95
    HCP6639 Aftermarket anti-dive damper piston assembly housing-to-lower fork tube attaching BOLT, socket head (hex-key drive) 18/8 stainless steel fastener with a bright finish. Use 2 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 2.95
    HCP24075 Aftermarket anti-dive damper piston assembly housing-to-lower fork tube attaching BOLT, socket head (hex-key drive) 316 stainless steel fastener with a bright finish. Use 2 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 2.95
    HCP6640 Aftermarket anti-dive damper piston assembly housing-to-lower fork tube attaching BOLT, socket head (hex-key drive) black oxide-coated alloy steel fastener. Use 2 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 1.95
    HCP23505 Aftermarket anti-dive damper piston assembly ADJUSTER SCREW, stainless steel reproduction of the original. Has correct-width slot for a flat-blade screwdriver as well as the hole for the cotter pin. Perfectly replaces a commonly seized or broken part. HINT: these screws typically fail due to the outer (external to the housing) screw slot becoming broken, thus making it impossible to turn the screw (and thus adjust the dampening). Once the housing is removed from the bike and dis-assembled, this screw also has a flat-blade slot on its internal side, which can be (carefully! use lots of penetrating oil!!) used to remove the screw from the housing. O-ring and cotter pin are not included. all XJ750-D, XJ750P (37H model), and XJ900RK and RL models, each:
    $ 39.95
    HCP16212 Aftermarket anti-dive damper piston assembly adjuster screw O-RING, use 1 per housing on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 8.95
    HCP16150 Aftermarket anti-dive damper piston assembly adjuster screw COTTER PIN, used to secure the firmness adjuster screw in the bottom of the housing. Zinc-plated steel as original. Use 1 per screw on all XJ750-D, XJ750P (37H model), and XJ900RK and RL models. Each:
    $ 1.25
    HCP21325 Aftermarket anti-dive damper piston assembly adjuster screw RUBBER CAP, covers and protects the adjuster screw at the very bottom damper piston assembly housing. Use 1 per housing on all XJ750-D, XJ750P (37H models), and XJ900RK and RL models. Each:
    $ 21.95
    HCP21325SET2 Aftermarket anti-dive damper piston assembly adjuster screw RUBBER CAPS, set of 2:
    $ 39.95
    Lower Fork Tube Oil Drain Screw and Gasket:
    HCP5187 OEM lower fork tube oil DRAIN SCREW, use one per tube. Panhead, phillips-drive, alloy steel with a black finish. Note that the black screw was used on models with black lower fork tubes (1982-83 XJ550 Seca, FJ600, 1995 XJ600 Seca II, XJ650 Midnight Maxim, XJ650 Turbo, XJ750 Midnight Maxim, 1981-83 XJ750 Seca and XJ750 Euro models, and some XJ750P models 37H). All other models with natural aluminum lower fork tubes used a screw with a bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 4.95
    HCP29817 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead, phillips-drive, alloy steel with a black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29005 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive zinc-plated alloy steel. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29006 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6710 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ discontinued
    HCP6712 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6711 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP7111 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 8.95
    HCP7111SET2 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 16.95
    HCP21320 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 5.95
    HCP21320SET2 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 10.95
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    HCP8233 OEM fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 9.95
    HCP28069 Aftermarket fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 6.95
    HCP8234 OEM fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 16.95
    HCP12950 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 10.95
    w) Lower Fork Tube DAMPER ROD RETAINING TOOL. This long aluminum tool, with proper sized nuts on each end, is used to retain the top of the fork damper rod (in the bottom of the chrome tube) when removing or installing the damper rod retaining screw. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ-series bikes except XJ600 Seca II, 1981-83 XJ750 Seca, XJ1100, and all XS1100 Special and Midnight Special models. This tool will make the disassembly of your upper tube from the lower tube much easier! NOTE: this tool is available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP4402 Aftermarket DAMPER ROD RETAINING TOOL.
    $ 44.95
    Fork Tube Brace and Hardware:
    HCP8480 OEM lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Bright finish, alloy steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP2424 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Black oxide coated alloy steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 1.95
    HCP80 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Black oxide coated alloy steel socket head, allen-drive. Features a small nylon thread patch, making this a self-locking bolt. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP2423 Aftermarket lower fork tube brace RETAINING BOLT, use 2 per tube (4 per bike) on both the left and right side lower fork tube. Bright 18-8 stainless steel socket head, allen-drive. For all FJ600, XJ750RL, and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    Lower Fork Tube Axle Retaining Hardware:
    HCP4828 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per tube (2 per bike) on both the left and right side lower fork tube. For all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), and XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
    HCP2537 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all 1981 XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike).
    $ 3.95
    HCP26192 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 1.95
    HCP26193 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 18/8 stainless steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 2.95
    HCP17110 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP26189 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP2185 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 6.95
    HCP16209 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 2.95
    HCP16100 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    Lower Tube ID Decals:
    HCP15185 Aftermarket AIR SUSPENSION WARNING DECAL, small rectangular decal has a brushed aluminum background with black lettering and border. Correct for all 1982-83 XJ650 Maxim models and 1983 XJ900RK Seca forks. On the XJ650 Maxim fork tube, it mounts on the left lower fork tube directly above the fork tube drain screw and faces to the rear of the bike. On XJ900RK models, it mounts on the left lower fork tube directly above the anti-dive housing and faces “outward”.
    $ 12.95
    FORK SYSTEM SERVICE TOOLS:
    Assembly and Dis-assembly Tools:
    NOTE: many of these tools are available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    $ 44.95
    $ 19.95
    HCP26093 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 35-36mm fork tubes: XJ550 Seca, FJ600, XJ600 Euro, all XJ650 (except 1983 Turbo), all XJ750 air-cooled (except XJ750P (37H Police) and X750-D models), and XJ900 N/FN models.
    $ 47.95
    HCP26094 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 37mm fork tubes: 1983 XJ650 Turbo, XJ750 Police (37H) model, XJ750-D, XJ900 RK, RL, and F models, XJ1100, and all XS1100 models.
    $ 47.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Fork Tube Cleaning and Polishing:
    HCP28489 Fork Tubes DEEP REACH CLEANING BRUSH. This 36" long brush features polyester bristles that will reach deep inside the forks tubes to clean away grit and oil sludge residue that cannot otherwise be reached or disturbed. Has a comfortable easy-grip plastic handle and flexible twisted-wire shaft. Use with your favorite cleaning solvents to get the insides of the fork tubes free of contaminants.
    $ 52.95
    ft4) These stainless-steel, bristle-wire DE-BURRING BRUSHES will work wonders on the upper cap bolt area on both the threaded and the non-threaded style of fork tubes. Tubes that use threaded cap bolt (all XJ650 Turbo, all XJ700 models, XJ750-X models, XJ750 Maxim and Midnight Maxim, XJ900RK, and XJ1100 models) should use the HCP10223 butterfly brush; non-threaded tubes can use either the HCP10222 spiral brush or the HCP10223 butterfly brush. Both style brushes have stems that are designed to be used in a standard power drill, and should be used at 850 rpm's or less. These brushes will make quick and meaningful work of the cleaning and polishing of this critical area on your upper fork tubes.
    HCP10222 Aftermarket stainless-steel double-density spiral DE-BURRING BRUSH, for use on fork tubes without a threaded cap bolt.
    $ 13.95
    HCP10223 Aftermarket stainless-steel high-density "butterfly-wings" DE-BURRING BRUSH, for use on fork tubes with or without threaded cap bolts.
    $ 14.95
    Anti-Dive System Tools:
    HCP12230 Aftermarket anti-dive brake plunger PISTON POPPER, for all models using an anti-dive system.
    $ 13.95
    $ 19.95
    FORK OIL:
    Unlike motor oil or gear oil, fork oil's major purpose is not lubrication.....rather, it acts as part of the suspension system, providing both damping and rebound control functions. The different "weight" or viscosity of fork oils allows you to modify the ride and handling characteristics of your bike in a fairly simple way.
    And yes, it IS a lubricant also!
    Although many people----including, unbelievably, Yamaha itself----recommends the use of engine motor oil as a substitute for fork oil, this is not a very good idea. Engine oils (or any multi-viscosity oil) uses additives and detergents that, while wonderful in for their intended purposes inside an engine block, tranny case, or rear drive unit, are not such a good idea inside forks. Forks operate at a much lower temperature and temperature RANGE than engine and drivetrains do, and thus do not need all those additives. And fork oil also tends to contain higher percentages of molybdenum disulfide and anti-foaming agents than engine or gear oil, both of which are very important to proper fork operation.
    As a small example.......most motor oils are of a multi-viscosity nature (such as 10W30) which change their viscosity in relation to their temperature (thin when cool, thicker as they warm). A very necessary and useful feature for an engine, where you do not want your oil thinning out as the engine warms up. Not such a good idea for your suspension----unless for some reason you WANT your handling characteristics to change (get stiffer) as the forks heat up!
    Proper fork oil levels and scheduled change intervals are important for fork performance and fork part longevity.....water contamination, as well as particulate wear will accumulate in fork oil, and since there is no oil filtering mechanism within your forks, the only way to get the grit and gunk out (before it chews up your oil seals and slider bearings!) is to change your fork fluid regularly. Yamaha recommends a fork fluid change every 10,000 miles or 24 months (all models except XJ700's), or every 16,000 miles or 24 months (all XJ700 and XJ750-X models). If you just bought a used bike, we recommend you do a fluid change as soon as possible, because just like other routine maintenance tasks (besides engine oil changes), this is one that has very likely been ignored for the last 10-12 years!
    HINT: there’s a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it’s brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won’t mix and the water will “ball up”; brake fluid will integrate with water and absorb the water.
    Fork oil capacities and recommended weights are as follows. The amounts listed are per fork tube:
    XJ550 Maxim: 272cc or 9.20 fluid ounces. 10W fork oil.
    XJ550 Seca: 230cc or 7.78 fluid ounces. 10W fork oil.
    1980-81 XJ650 Maxim and Midnight Maxim: 262cc or 8.86 fluid ounces. 10W fork oil.
    1982-84 XJ650 Maxim: 278cc or 9.40 fluid ounces. 10W fork oil.
    1982 XJ650RJ Seca: 236cc or 7.98 fluid ounces. 10W fork oil. Fork oil level is specified as 400mm (15.75") below the top of the tube without the spring installed, forks fully collapsed.
    1982 XJ650LJ Turbo: 238cc or 8.04 fluid ounces. 10W fork oil. Fork oil level is specified as 180mm (7.09") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ650LK Turbo: unknown.
    1985-86 XJ700 non-X: 383cc or 12.96 fluid ounces. 10W fork oil.
    1985-86 XJ700-X: 389cc or 13.16 fluid ounces. 10W fork oil.
    1982 XJ750 Maxim: 257cc or 8.69 fluid ounces. 10W fork oil.
    1983 XJ750 Maxim and Midnight Maxim: 257cc or 8.69 fluid ounces. 10W fork oil. NOTE: owner's manual states that the fork oil capacity is 278cc (9.40 fluid ounces). It is unknown which measurement is correct.
    1981-83 XJ750 Seca: 309cc or 10.45 fluid ounces. 20W fork oil.
    1983 XJ750 E-II Seca or 1984 XJ750RL Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 168mm (6.61") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ900RK Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 164mm (6.46") below the top of the tube without the spring installed, forks fully collapsed.
    1982-84 XJ1100 Maxim and Midnight Maxim: 210cc or 7.10 fluid ounces. 10W fork oil. Fork oil level is specified as 210mm (8.27") below the top of the tube without the spring installed, forks fully collapsed.
    IMPORTANT NOTE: the above fork oil VOLUMES are for use only when using the stock fork springs. The use of aftermarket performance front fork coil springs will change those volumes, since aftermarket springs are thicker than stock----and thus displace more oil. Using the stock oil fluid VOLUME with aftermarket fork springs is a sure way to OVERFILL your forks, with the very real possibility of blowing out fork seals.
    Unlike with your engine oil, where a bit too much or too little oil volume in the crankcase is not really a significant concern, with fork oil, too much or too little can cause real problems (too much oil can result in blown oil seals and a stiff, harsh ride, while too little oil volume results in excessive foaming, a soft mushy ride with possible bottoming, and erratic fork performance and lots of front end "dive" upon braking).
    A better way to determine the amount of fork oil that is needed and necessary is via the measurement of the fork oil LEVEL within the tubes.....sort of like measuring the oil level with a dipstick. Yamaha does not specify this level for all models; and in any case, if using aftermarket springs, the factory oil level recommendation is not always useful. The maximum oil level should be 5-1/2" (140mm) below the top of the inner fork tube, measured with all internal fork tube components installed EXCEPT FOR THE SPRINGS, and with the inner fork tube fully collapsed into the lower (outer) tube.
    In order to be as accurate as possible, we recommend the use of a suitable measuring device, such as the HCP1728 oil level syringe listed further below.
    And finally, the fork oil viscosity can be changed from the factory recommendations to give a softer or firmer ride.......the lower the viscosity, the thinner the oil, and the softer the ride (i.e. 5W oil is thinner than 10W which is thinner than 20W, etc.) In this regard, you would certainly be correct in thinking of fork oil as a suspension "tuning tool"! Note that a thicker oil viscosity will have much more effect on the fork "rebound" characteristics than it will on the fork compression dampening function.
    A great primer on "tuning" your forks via adjusting the oil levels can be seen at:
    http://www.thumpertalk.com/forum/archive/index.php/t-89918.html
    while the theory and science and practical applications of tuning your suspension via using differing viscosities of fork oil can is revealed at:
    http://www.peterverdone.com/archive/lowspeed.htm
    ffo3) Red Line Oil products line of SYNTHETIC FORK OILS are some of the best, highest-performance fork oils developed specifically for this purpose. They provide exceptional shear lubrication, are highly resistant to any viscosity changes, and provide excellent seal lubrication as well as very high anti-foaming properties. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    Also, do not mix different brands, styles, or types of oils........you can only safely mix forks oils together from one manufacturer!
    HCP1563 Red Line high-performance SYNTHETIC FORK OIL 0W (zero weight, "like water"), 16 ounce bottle (473cc), clear. Each bottle:
    $ 27.95
    HCP1564 Red Line high-performance SYNTHETIC FORK OIL 2.5W, 16 ounce bottle (473cc), blue. Each bottle:
    $ 27.95
    HCP1258 Red Line high-performance SYNTHETIC FORK OIL 5W, 16 ounce bottle (473cc), amber. Each bottle:
    $ 27.95
    HCP1259 Red Line high-performance SYNTHETIC FORK OIL 10W, 16 ounce bottle (473cc), red. Each bottle:
    $ 27.95
    HCP1263 Red Line high-performance SYNTHETIC FORK OIL 30W, 16 ounce bottle (473cc), orange. NOTE: this oil is similar in viscosity to what most other oil manufacturers call "20W" oil. Each bottle:
    $ 27.95
    ffo4) PJ1 products line of TUNER FORK OILS are exceptional quality, value-priced fork oils developed specifically for motorcycle suspensions. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    HCP10360 PJ1 products TUNER FORK OIL 2.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10362 PJ1 products TUNER FORK OIL 5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10364 PJ1 products TUNER FORK OIL 7.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10366 PJ1 products TUNER FORK OIL 10W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10368 PJ1 products TUNER FORK OIL 15W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10370 PJ1 products TUNER FORK OIL 20W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10372 PJ1 products TUNER FORK OIL 30W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    Fork Tube Oil Level Gauges:
    HCP1728 Fork tube oil fluid level measurement GAUGE AND SYRINGE. This handy tool makes the measurement of the fork oil level easy and accurate. NOTE: the proper amount of fork oil is determined via the measurement of the fork oil LEVEL (distance below the very top of the inner tube) rather than a volume AMOUNT of oil specification. Too little oil will make the ride mushy, while too much oil makes the ride harsh (and can blow out the oil seals!)
    $ 39.95
    ffl4) Aftermarket fork oil measurement GRADUATED CYLINDERS. The best way to measure the precise amount of fork oil fluid is via the use of these lab-quality measurement cylinders. Available in either transparent (clear) or translucent (cloudy) durable plastic construction, they all have easy-to-read scale numerals (milliliters) and feature a "non-wetting" inner surface coating that prevents the concave "meniscus" from forming at the top of the fluid, thus insuring a much more accurate level reading. Large bases insure stability while large spouts make "the pour" easy and prevent messy drips. Very useful device to have for front fork oil changes.
    HCP10741 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, translucent (cloudy).
    $ 24.95
    HCP10744 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, transparent (clear).
    $ 49.95
    HCP10742 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, translucent (cloudy).
    $ 29.95
    HCP10745 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, transparent (clear).
    $ 69.95
    HCP10743 Aftermarket fork oil GRADUATED CYLINDER, super-sized 1000ml capacity, translucent (cloudy), with convenient side handle to insure steady pouring.
    $ 89.95
    Fork Tube Air Pressure Tool and Gauge:
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 6.95
    HCP9108 Aftermarket air-assisted forks LOW PRESSURE AIR GAUGE, heavy-duty 0-20 psi pencil (stick) pressure gauge marked in 1/2-psi increments, perfect for checking fork air pressures on models so equipped. Very high quality and much more accurate than standard tire pressure gauges, which is very important on the fork pressures as an imbalance between the fork pressure can lead to steering and stability issues, while too much pressure will blow out the lower tube oil seals!
    $ 9.95
  12. chacal
    XJ1100 MODELS FORK TUBE PARTS:
    NOTE: items marked below in red are the parts typically needed when doing a basic fork system rebuild.
    A good visual review of the procedures needed for rebuilding these forks can be seen at:
    http://xjbikes.com/forums/index.php?threads/8355
    And these incredible 3-D renderings of the inner workings of a forking system gives a great visualization of the internal components (it is based on the 1982-83 XJ650 Maxim forks):
    http://xjbikes.com/forums/index.php?threads/29616
    XJ1100 owners may also wish to note the procedure needed to separate the inner tubes from the lower tubes (the "battering ram" procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    http://xjbikes.com/forums/index.php?threads/4067
    FORK TUBE REBUILD KITS:
    We now offer both a BASIC FORK REBUILD KIT and PERFORMANCE FOR TUBE REBUILD KITS so that you can get all the typically-needed rebuild parts under one simple part number. Each kit is specifically assembled and correct for your particular model bike.
    - NOTE: the lower tube “dust boots” (sometimes called dust seals) are not included in the basic fork tube rebuild kits, but are available separate and can be found further below.
    Basic fork rebuild kit contains at least the following items:
    - cap bolt o-rings.
    - standard quality lower fork tube oil seals.
    - oil seal retaining clips.
    - oil drain screws and gaskets.
    - damper rod bolts and crush washers.
    - damper rod head piston rings.
    - air joint o-rings, air valve o-rings, and air valve cores
    HCP20637 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1982-84 XJ1100 Maxim and Midnight Maxim models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 109.95
    HCP20637DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1982-84 XJ1100 Maxim and Midnight Maxim models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 159.95
    Performance fork rebuild kit contain all of the basic rebuild kit components, along with:
    - performance fork springs and related spring seats and pre-cut spring spacers.
    - upgraded, high-performance lower fork tube oil seals.
    - lower fork tube dust boots.
    - air valve core tool.
    HCP20638 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1982-84 XJ1100 Maxim and Midnight Maxim models. One kit does both front tubes.
    $ 489.95
    Of course, all of the component pieces can be ordered as individual pieces from the selections listed below, as well as non-typical wear items (inner tubes, damper rod piston rings, taper spindles, cap bolts, etc.), as well as the fork oil and specialty tools needed to properly restore or enhance your front suspension performance.
    UPPER (INNER) FORK TUBES AND PARTS:
    Chrome Inner Fork Tubes:
    HCP8535 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all XJ1100 models, each:
    $ 299.95
    HCP8535SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    Inner Tube Gaiter Boots:
    Although not originally used on any XJ-series bikes, these accordion-pleated thick rubber boots fit into the area between the bottom of the steering underbracket and the top of the lower (outer) fork boots, covering and protecting this area from damage, while providing an "old-school" or cafe-racer type look. They are retained to the chrome tube itself (at their top end) via spring clips, and to the top of the lower fork tube via metal screw-clamps.
    HCP10941 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10942 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10943 Aftermarket front fork tube GAITER BOOTS, red pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat. Pair:
    $ 39.95
    HCP10938 Aftermarket front fork tube GAITER BOOTS, black pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP10939 Aftermarket front fork tube GAITER BOOTS, royal blue pleated rubber boot is the correct length and diameter to fit all of the following models: all XJ550 models, all XJ650 models, and all XJ750 Maxim and Midnight Maxim models, all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and XS1100 Special and Midnight Special models. Does not include attaching hardware. Light-duty design has equal spacing between each accordion pleat, and each bellows gets wider as the boot extends from top to bottom. Pair:
    $ 39.95
    HCP11420 Aftermarket fork tube gaiter boot LOWER RETAINING SPRING-CLAMP. Black powdercoated wire-spring type clamp has that old-time look and feel to it. Secure the lower end of the gaiter boot to the top of the lower (outer) fork tube. Fits all XJ-series models. Use 1 per tube, each:
    $ 14.95
    NOTE: gaiter boots normally do not require any type of retainer at their upper end, as the tight friction fit between the boot opening and the chrome tube prevents migration of the boot. If movement seems to occur, then we recommend the use of thin, black electrical wire ties to cinch the boot flange tightly to the tube.
    Inner Fork Tube Cap Bolts and Related:
    HCP8299 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ1100 and all XS1100 Special and Midnight Special models. Each:
    $ 14.95
    HCP20709 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ1100 and all XS1100 Special and Midnight Special models. This o-ring fits very tightly and you should "poke" the o-ring into the top of the tube just before the cap bolt forces it into the top of the tube. Each:
    $ 8.95
    HCP22009 Aftermarket inner fork tube decorative chrome cover RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap (XJ1100 models) or the fork emblem cover (XS1100 Special and Midnight Special models) and the top of the lower steering bracket. Use 1 per fork tube, 2 per bike on all XJ1100 Maxim and XS1100 Special and Midnight Special models. Each:
    $ 13.95
    HCP22009SET2 Aftermarket inner fork tube decorative chrome cover UPPER CUSHION GASKETS, set of 2:
    $ 24.95
    Inner Tube Fork Springs:
    HCP9439 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ1100 and XS1100 models. XS1100 Standard models do not require the use of a spacer or spring seat. All XJ1100 models and the XS1100 Special models will require the use of front spring spacer (which are not included with these springs), and you will need an HCP8239 spring seat (one for each spring) and the fabrication of a 87.20mm long spacer when replacing stock springs on these models. You can use the HCP8284 spring spacer tube (stock for 1982-83 XJ650 Maxim models) and cut it down to the proper length on XJ1100 and XS1100 Special models.....one tube will provide enough material to do one spring.....or you can order the HCP21025 spacers tubes which are already cut to the correct length. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 259.95
    Inner Fork Tube Spring Spacers, Rebound Springs, Damper Rods, and Spring Seats:
    HCP8239 OEM inner fork tube SPRING SEAT, fits either side. Use on all XJ1100 and XS1100 Special models when installing the HCP9439 replacement springs above. Each:
    $ 19.95
    HCP20994 Aftermarket inner fork tube SPRING SEAT, fits either side. Use on all XJ1100 and XS1100 Special models when installing the HCP9439 replacement springs above. Each:
    $ 14.95
    HCP8284 OEM inner fork tube SPRING SPACER TUBE, fits either side. Use on all XJ1100 Maxim and the XS1100 Special models when installing the HCP9439 replacement springs above. One spacer tube will provide enough material to do both springs.
    $ 14.95
    HCP21025 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Use on all XJ1100 models and the XS1100 Special models when installing the HCP9439 replacement springs above. Each spacer tube is pre-cut to the correct length for use with the HCP9439 springs; use 1 spacer per tube.
    $ 19.95
    HCP21025SET2 Aftermarket inner fork tube SPRING SPACER TUBE, fits either side. Set of 2 spacers:
    $ 34.95
    HCP8246 OEM inner fork tube damper rod PISTON RING, fits either side. Used on all 1981-83 XJ750 Seca models, XJ750 Euro, XJ1100, 1980-81 XS1100 Standard models, and all XS1100 Special and Midnight Special models. Use 1 per fork tube. Each:
    $ 29.95
    HCP13658 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all 1981-83 XJ750 Seca models, XJ750 Euro, XJ1100, 1980-81 XS1100 Standard models, and all XS1100 Special and Midnight Special models. Use 1 per fork tube. Each:
    $ 17.95
    Inner Tube Metal Slider Bushings:
    HCP8481 OEM inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1983 (only) XJ650 Turbo (with 37mm fork tubes), all 1981-83 XJ750 Seca and Euro models, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. Each:
    $ 99.95
    HCP8481SET2 OEM inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 189.95
    HCP10702 Aftermarket inner fork tube METAL SLIDER BUSHING, fits either left or right tube on the following models: 1983 (only) XJ650 Turbo (with 37mm fork tubes), all 1981-83 XJ750 Seca and Euro models, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. NOTE: these bushings are a bit thinner than the original bushings, but will fit and perform properly. Each:
    $ 69.95
    HCP10702SET2 Aftermarket inner fork tube METAL SLIDER BUSHINGS, set of 2:
    $ 119.95
    INNER FORK TUBE AIR SYSTEM PARTS:
    Air Inflation Valves and O-Rings:
    HCP8274 OEM inner fork tube air joint AIR VALVE WITH CAP, comes complete the internal stem core, its o-ring, and chrome cap. Fits the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and the included protective cap is much smaller than the huge caps used on those models, and due to the length difference, those large original caps will not fit properly on this shorter valve. This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 57.95
    HCP25157 OEM inner fork tube air joint AIR VALVE, comes complete the internal stem core and o-ring. Chrome cap is not included. Use 1 per tube on the following models: 1981-83 XJ750 Seca, XJ750 Euro, and all XS1100 Special and Midnight Special models. Use 1 per bike (on the air joint) on XJ1100 models. Each:
    $ 47.95
    HCP11890 OEM inner fork tube air joint brass AIR VALVE ONLY, comes complete the internal stem core and its o-ring. The chrome cap is not included. Fits the following models: 1982-83 XJ650 Maxim (use 1 per tube), XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube), and XJ900RK and RL Seca models (use 1 per bike). This valve can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is almost 2mm shorter than the original, and due to the length difference, the large original caps used on those models will not fit properly on this shorter valve. Each:
    $ 39.95
    HCP11876 OEM inner fork tube air joint air valve CHROME CAP, ribbed, dome-head style. Correct for all of the following models: XJ650 Turbo models (use 1 per bike), 1982 XJ750 Maxim (use 1 per bike), XJ750-P (24L model, use 1 per tube), XJ750-D (use 1 per bike), and XJ900RK and RL Seca models (use 1 per bike). This cap can also be used on all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models, but it is much smaller than the large original caps used on those models. It can also be used on the following models, but, it will eliminate the possibility of fitting the stock black plastic AIR ADJUSTABLE cap (HCP8254) which is unique to these models: 1982-83 XJ650 Maxim (use 1 per tube), and 1983 XJ750 Maxim and Midnight Maxim models (use 1 per tube). Each:
    $ 19.95
    HCP8271 OEM inner fork tube air joint Air Valve and Hose O-RING, fits the following models: all 1981-83 XJ750 Seca and XJ750 Euro models, (use 1 per tube), XJ1100 models (use 3 per bike), and all XS1100 Special and Midnight Special models (use 1 per tube). Each:
    $ 7.95
    HCP14020 Aftermarket inner fork tube air joint Air Valve and Hose O-RING, fits the following models: all 1981-83 XJ750 Seca and XJ750 Euro models, (use 1 per tube), XJ1100 models (use 3 per bike), and all XS1100 Special and Midnight Special models (use 1 per tube). Each:
    $ 5.95
    HCP20701 Aftermarket inner fork tube air joint INNER O-RING, fits either left or right air joint on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750RL, XJ900RK and RL models, and XJ1100 models. Uses 2 o-rings per joint. Each:
    $ 6.95
    INNER FORK TUBE RETAINING HARDWARE:
    Crown Bracket Inner Fork Tube Retaining Hardware:
    HCP4532 OEM crown bracket fork tube CINCH BOLT, use 3 per bracket (both sides and rear) on all XJ1100 models. Each:
    $ 6.95
    HCP4962 OEM crown bracket fork tube cinch bolt DECORATIVE BLACK CAP, this push-in black plastic cap (“cover”) fits into the socket head of the bolt, and makes for a nice pretty finished appearance. Used on all 3 crown bracket cinch bolts on all XJ1100 models, and on the rear lateral crown bracket cinch bolt (only) on all XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP4962SET4 OEM crown bracket fork tube cinch bolt DECORATIVE BLACK CAPS, set of 4:
    $ 29.95
    HCP26235 Aftermarket crown bracket fork tube cinch bolt DECORATIVE BLACK CAP, this push-in black plastic cap (“cover”) fits into the socket head of the bolt, and makes for a nice pretty finished appearance. Used on all 3 crown bracket cinch bolts on all XJ1100 models, and on the rear lateral crown bracket cinch bolt (only) on all XS1100 Special and Midnight Special models. Each:
    $ 10.95
    HCP26235SET4 Aftermarket crown bracket fork tube cinch bolt DECORATIVE BLACK CAPS, set of 4:
    $ 41.95
    Under-bracket Inner Fork Tube Retaining Hardware:
    HCP4955 OEM under-bracket fork tube CINCH BOLT, use 2 per side. For the following models: all XJ1100 models. Each:
    $ discontinued
    HCP21904 Aftermarket under-bracket fork tube CINCH BOLT, use 2 per side, a total of 4 per bracket, on all XJ1100 and XS1100 Special and Midnight Special models. Each:
    $ 2.95
    HCP2185 OEM under-bracket fork tube cinch bolt LOCK WASHER, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 6.95
    HCP16209 Aftermarket under-bracket fork tube cinch bolt LOCK WASHER, zinc-plated alloy steel, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP16100 Aftermarket under-bracket fork tube cinch bolt LOCK WASHER, 18-8 stainless steel with a bright finish, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP16102 Aftermarket under-bracket fork tube cinch bolt LOCK WASHER, black-oxide coated alloy steel, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, XJ1100, all XS1100 Standard, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP18011 Aftermarket cinch bolt head protective CAP. Smooth, black plastic cap snaps over the head of the fork tube cinch bolts, giving them a very "modern" look, protecting the head from rust. Fits all OEM or aftermarket bolts with a 12mm hex or socket head. Each:
    $ 4.95
    LOWER (OUTER) FORK TUBE PARTS:
    Dust Wiper Seals:
    HCP1826 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ1100, XS1100 Special, and XS1100 Midnight Special models. One seal does one tube. Each:
    $ 49.95
    HCP21562 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: all XJ1100, XS1100 Special, and XS1100 Midnight Special models. One seal does one tube. Each:
    $ 29.95
    Oil Seals:
    NOTE: when installing oil seals, make sure that the area where the seal will fit into is clean, free of any nicks and burrs, and that the lower tube metal slide bushing is fully seated. Oil seals install with the large opening facing down, into the tube, and on most seals, the small cast lettering and numbering on the seal faces upwards.
    Seals are designed to be installed with a seal driver of some type, although a properly sized piece of hard plastic tubing, perhaps with a proper sized metal washer on top of the seal to "spread the load", works as well. Always make sure that oil seals are fully seated and not damaged or installed in a crooked or cocked manner.
    HCP1819 OEM standard quality lower fork tube BLACK OIL SEALS, fits all of the following models: all XJ1100, 1986-87 FZX700, and 1988 FZX750 models. Sold as an individual seal, .does one fork leg. Each:
    $ 27.95
    HCP20641 Aftermarket standard quality lower fork tube BLACK OIL SEALS, fits all of the following models: all XJ1100, 1986-87 FZX700, and 1988 FZX750 models. Comes packaged as a pair of seals, enough to do both forks.
    $ 19.95
    HCP1910 Aftermarket premium quality lower fork tube OIL SEALS, fits the following models: all XJ1100 models. Comes packaged as a pair of seals, enough to do both forks. NOTE: these seals can be more difficult to install that standard OEM or aftermarket seals, as the additional spring pressure resists the flexing and "give" that normally occurs with standard seals. Make sure that the inside diameter of the lower fork tube seal seat is clean and free of nicks or gouges (it's not a bad idea to "polish" this seat with some very fine finishing paper), and then generously lubricate both the outer diameter of these seals and the lower tube seal seat area with fork oil or silicone grease. Install with the "hollow" channel of the oil seal facing down, into the lower fork tube.
    $ 24.95
    Oil Seal Retaining Clips:
    HCP20692 Aftermarket lower fork tube OIL SEAL RETAINING CLIPS, fits either left or right tube on the following models: XJ1100 models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 11.95
    Lower Tube Metal Slider Bushings:
    HCP10549C Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: 1983 XJ650 Turbo, XJ1100, and all XS1100 Special and Midnight Special models. One slider does one tube. Each:
    $ 59.95
    HCP10549CSET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 114.95
    HCP20672 Aftermarket lower fork tube oil DRAIN BOLT, use one per tube. Natural finish. Fits all XJ1100 models. Each:
    $ 1.95
    HCP20671 OEM lower fork tube oil drain plug copper CRUSH WASHER, use one per tube. Fits all XJ1100 and 1979-81 XS1100 Special and Midnight Special models. Each:
    $ 1.75
    HCP8281 OEM fork tube damper rod RETAINING SCREW. For all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per tube. Comes with the copper crush washer "gasket". Each:
    $ 11.95
    HCP22133 Aftermarket fork tube damper rod RETAINING SCREW. For all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per tube. Gasket is not included. Each:
    $ 4.95
    HCP10028 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all 1981-83 XJ750 Seca, XJ750 Euro, XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per tube. Each:
    $ 4.95
    Lower Fork Tube Speedometer Cable Hardware:
    HCP2182 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 6.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish, on the left fork tube only, use 1 on all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, 1981 XJ750 Seca, XJ1100, and XS1100 Standard and Special models. Bright plating. Use with the HCP315, HCP916, or HCP319 lock washer below. Each:
    $ 2.95
    HCP3933 OEM lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 3.95
    HCP22180 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener with a dark finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 1.95
    HCP22182 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each:
    $ 2.95
    HCP22183 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 3.95
    HCP22181 Aftermarket lower fork tube speedometer cable bracket mounting BOLT, 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish. Fitted on the left fork tube only, use 1 on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, and XS1100 Midnight Special models. Use with the HCP1902 or the HCP321 lock washer below. Each.
    $ 2.95
    HCP315 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, bright finish, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models.
    $ 3.95
    HCP1902 OEM lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, black finish, use 1 per bike on the following models: XJ650 Midnight Maxim, 1982-83 XJ750 Seca, XJ750 Euro, XJ750 Midnight Maxim, and XS1100 Midnight Special models.
    $ 6.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel lower fork tube speedometer cable bracket mounting bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 Maxim and Midnight Maxim models, all XJ750 Maxim models, 1981 XJ750 Seca models, XJ1100, and XS1100 models:
    $ 1.95
    HCP4822 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ650 Midnight Maxim, 1983 XJ750 Midnight Maxim, XJ1100, and all XS1100 Special and Midnight Special models. Each:
    $ 7.95
    $ 6.95
    $ 2.95
    $ 3.95
    $ 3.95
    $ 3.95
    $ 2.95
    Lower Fork Tube Warning Decals:
    HCP15137 Aftermarket AIR SUSPENSION WARNING DECAL, brushed silver rectangular decal with black lettering and border, mounts directly above the right lower fork tube drain screw and faces the rear of the bike on XJ1100 model forks tubes.
    $ 11.95
    HCP26094 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 37mm fork tubes (1983 XJ650 Turbo, XJ750 Police (37H) model, XJ750-D, XJ900 RK, RL, and F models, XJ1100, and all XS1100 models).
    $ 47.95
    $ 44.95
    $ 46.95
    $ 47.95
    Anti-Seize Paste:
    $ 8.95
    $ 3.95
    $ 9.95
    $ 13.95
    $ 13.95
    $ 19.95
    $ 11.95
    $ 11.95
    $ 4.95
    $ 11.95
    $ 11.95
    $ 41.95
    $ 44.95
    $ 42.95
    $ 52.95
    $ 13.95
    $ 14.95
    FORK OIL:
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 39.95
    $ 24.95
    $ 49.95
    $ 29.95
    $ 69.95
    $ 89.95
    $ 6.95
    $ 9.95
  13. chacal
    XS1100 MODELS FORK TUBE PARTS:
    http://www.xjbikes.com/Forums/viewtopic/t=8355.html
    http://xjbikes.com/Forums/viewtopic/t=29616.html
    XS1100 owners may also wish to note the procedure needed to separate the inner tubes from the lower tubes (the “battering ram” procedure) since these forks also use the slider bushings on the bottom of the chrome tubes as shown on these XJ900 forks:
    http://xjbikes.com/Forums/viewtopic/t=4067.html
    - cap bolt o-rings.
    - oil seal spacer washers (except 1980-81 Standard models, which did not use them)
    - air joint o-rings, air valve o-rings, and air valve cores. Note that 1978-79 Standard models will not include these items.
    HCP21896 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1978-79 XS1100 Standard models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 139.95
    HCP21896DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1978-79 XS1100 Standard models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 184.95
    HCP21897 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1980-81 XS1100 Standard models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 129.95
    HCP21897DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1980-81 XS1100 Standard models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 174.95
    HCP21898 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1979 XS1100 Special models. One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 134.95
    HCP21898DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1979 XS1100 Special models. One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 184.95
    HCP25290 Aftermarket fork tubes BASIC FORK REBUILD KIT. For all 1980-81 XS1100 Special and Midnight Special models. NOTE: this kit contains a pair of both bright (Specials) and black (Midnight models) fork tube fluid drain screws, use the proper one for your application! One kit does both front tubes. This set does not include the lower fork tube dust boots.
    $ 134.95
    HCP25290DB Aftermarket fork tubes BASIC+ FORK REBUILD KIT. For all 1980-81 XS1100 Special and Midnight Special models. NOTE: this kit contains a pair of both bright (Specials) and black (Midnight models) fork tube fluid drain screws, use the proper one for your application! One kit does both front tubes. This set includes the lower fork tube dust boots.
    $ 184.95
    - air valve core tool. Note that 1978-79 Standard models will not include this item.
    HCP21899 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1978-79 XS1100 Standard models. One kits does both front tubes.
    $ 439.95
    HCP21900 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1980-81 XS1100 Standard models. One kits does both front tubes.
    $ 439.95
    HCP21901 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1979 XS1100 Special models. One kits does both front tubes.
    $ 499.95
    HCP25291 Aftermarket fork tubes PERFORMANCE FORK REBUILD KIT. For all 1980-81 XS1100 Special and Midnight Special models. NOTE: this kit contains a pair of both bright (Specials) and black (Midnight models) fork tube fluid drain screws, use the proper one for your application! One kits does both front tubes.
    $ 499.95
    HCP24244 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1978-79 XS1100 Standard models, each:
    $ 299.95
    HCP24244SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP24245 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1980-81 XS1100 Standard models, each:
    $ 299.95
    HCP24245SET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    HCP24246 Aftermarket chrome INNER FORK TUBE, fits left or right side, for all 1979-81 XS1100 Special and 1980-81 XS1100 Midnight Special models, each:
    $ 299.95
    HCP24246ET2 Aftermarket chrome INNER FORK TUBES, set of 2:
    $ 489.95
    $ 39.95
    $ 39.95
    $ 39.95
    $ 39.95
    $ 39.95
    $ 14.95
    HCP16526 Aftermarket inner fork tube black rubber top CAP, fits either the left or right side tube of the following bikes: 1978-79 XS1100 Standard models. Each:
    $ 9.95
    HCP8241 OEM inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 14.95
    HCP20707 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim models, XJ750-D, XJ750P (37H) model, XJ750-P (24L model), all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 9.95
    $ 14.95
    $ 8.95
    HCP8242 OEM inner fork tube decorative cover RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap and the top of the lower steering bracket. Use 1 or 2 per fork tube (depending on model) on all on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 all Special models, 1983 XV750MK Midnight Virago, 1983 XV920MK Midnight Virago, and all XS1100 Standard models. Each:
    $ 10.95
    HCP8242SET2 OEM inner fork tube decorative cover RUBBER CUSHION GASKETS, set of 2:
    $ 19.95
    HCP15647 Aftermarket inner fork tube decorative cover rubber RUBBER CUSHION GASKET, fits into the lower fork cover end caps, acts as a cushion/spacer between the end cap and the top of the lower steering bracket. Use 1 or 2 per fork tube (depending on model) on all on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 all Special models, 1983 XV750MK Midnight Virago, 1983 XV920MK Midnight Virago, and all XS1100 Standard models. Each:
    $ 7.95
    HCP15647SET2 Aftermarket inner fork tube decorative cover rubber RUBBER CUSHION GASKETS, set of 2:
    $ 14.95
    $ 13.95
    $ 24.95
    HCP9439 Aftermarket front suspension COIL SPRINGS, one pair does both forks. For all XJ1100 and XS1100 models. XS1100 Standard models do not require the use of a spacer or spring seat. All XJ1100 models and the XS1100 Special models will require the use of front spring spacer (which are not included with these springs), and you will need an HCP8239 spring seat (one for each spring) and the fabrication of a 87.20mm long spacer when replacing stock springs on these models. You can use the HCP8284 spring spacer tube (stock for 1982-83 XJ650 Maxim models) and cut it down to the proper length on XJ1100 and XS1100 Special models…..one tube will provide enough material to do one spring….or you can order the HCP21025 spacers tubes which are already cut to the correct length. NOTE: springs should be installed with the tighter (more-closely spaced together) coils towards the top of the fork tube.
    $ 259.95
    HCP8239 OEM inner fork tube SPRING SEAT, fits either side. Stock on 1980-81 XS1100 Standard models, and also for use on all XJ1100 and XS1100 Special models when installing the HCP9439 replacement springs above. Each:
    $ 19.95
    HCP20994 Aftermarket inner fork tube SPRING SEAT, fits either side. Stock on 1980-81 XS1100 Standard models, and also for use on all XJ1100 and XS1100 Special models when installing the HCP9439 replacement springs above. Each:
    $ 14.95
    $ 14.95
    $ 19.95
    $ 34.95
    HCP8253 OEM inner fork tube damper rod REBOUND SPRING, fits either side. Used on all XJ550 models, all XJ650 models (except Turbo), all 1983-84 XJ750 Maxim and Midnight Maxims, 1978-79 XS1100 Standard models, 1980 XS1100 (3X0) Euro model, 1989 and 1995-2008 XV250 Virago, 2008-2020 XV250 V-Star, 1983 XZ550RK, 1983 XV500, 1983-92 YZ80, 1980-81 YZ100, 1976-78 YZ250, and 1976 YZ400 models. Use 1 per tube, each:
    $ 39.95
    HCP13656 Aftermarket inner fork tube damper rod PISTON RING, fits either side. Used on all XJ550, XJ650, all XJ750 (except XJ750 Seca and XJ750-X models), and 1978-79 XS1100 Standard models. Use 1 per fork tube. Each:
    $ 17.95
    $ 29.95
    $ 17.95
    Inner Fork Tube Taper Spindle:
    HCP3085 OEM upper (inner) fork tube TAPER SPINDLE, fits either side. Fits all XJ550 models, 1984 FJ600, all XJ650 models, all XJ700 and XJ750-X models, all XJ750 Maxim and Midnight Maxim models, XJ900 N/FN and F models, all XS1100 Standards, and 1982-83 XZ550R Vision models. Each:
    $ 31.95
    $ 99.95
    $ 189.95
    $ 69.95
    $ 119.95
    $ 57.95
    $ 39.95
    $ 19.95
    HCP22248 Aftermarket inner fork tube cap bolt Air Valve O-RING, fits the following models: 1980-81 XS1100 Standard models and 1983 XZ550R Vision models. Use 1 per tube. Each:
    $ 7.95
    $ 7.95
    $ 5.95
    HCP9194 Aftermarket fork tube AIR VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all 1985 FJ600 models, 1982-83 XJ650 Maxim and Turbo models, XJ700-X models, all XJ750 models, the XJ900RK model, XJ1100, and all XS1100 Special and Midnight Special models. If your stem is leaking air, this is the inexpensive way to fix it. Each:
    $ 3.95
    HCP9194SET2 Aftermarket fork tube AIR VALVE STEM CORES, set of 2:
    $ 6.95
    $ 5.95
    HCP21908 OEM crown bracket fork tube flanged CINCH BOLT, use 1 per side. Fits the 1978 XS1100 Standard models. Each:
    $ 4.95
    HCP16264 Aftermarket crown bracket fork tube flanged CINCH BOLT, use 1 per side. Fits the 1978 XS1100 Standard models. NOTE: this bolt has a slightly larger head and is zinc-plated (bright) rather than the original black bolt. Each:
    $ 3.95
    HCP6349 OEM crown bracket fork tube CINCH BOLT, use 1 per side. Fits the 1979-80 XS1100 Standard models Each:
    $ 8.95
    HCP21909 OEM crown bracket fork tube CINCH BOLT, use 1 per side. Fits the 1981 XS1100 Standard models Each:
    $ 6.95
    HCP4529 OEM crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP21973 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright yellow-zinc finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP21974 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP21975 Aftermarket crown bracket fork tube CINCH BOLT, 18-8 stainless steel, hex-head bolt with a bright finish, use 1 per side. For the following models: all XJ550 models, 1980 XJ650 Maxim, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP4522 OEM crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP21973 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a bright yellow-zinc finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 1.95
    HCP21974 Aftermarket crown bracket fork tube CINCH BOLT, alloy steel, hex-head bolt with a black finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 1.95
    HCP21975 Aftermarket crown bracket fork tube CINCH BOLT, 18-8 stainless steel, hex-head bolt with a bright finish, use 1 per side. For the following models: 1981-3 XJ650 all models except Turbo, 1983 XJ750 Maxim and Midnight Maxim models, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 2.95
    HCP15946 OEM crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all 1978 XS1100 Standard models.
    Each:
    $ 2.95
    HCP21911 Aftermarket crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XJ650RJ Seca and 1979-81 XS1100 Standard models. NOTE: this hex-head is made from alloy steel and has a slightly larger head than the original, and has a bright zinc-plated finish rather than the original black bolt. Each:
    $ 2.95
    HCP24111 Aftermarket crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XJ650RJ Seca and 1979-81 XS1100 Standard models. NOTE: this hex-head is made from 18/8 stainless steel and has a slightly larger head than the original, and has a bright zinc-plated finish rather than the original black bolt. Each:
    $ 1.95
    HCP24112 Aftermarket crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XJ650RJ Seca and 1979-81 XS1100 Standard models. NOTE: this hex-head is made from 316 stainless steel and has a slightly larger head than the original, and has a bright zinc-plated finish rather than the original black bolt. Each:
    $ 3.95
    HCP4532 OEM crown bracket fork tube lateral (rear) CINCH BOLT, use 1 on all XS1100 Special and Midnight Special models. Each:
    $ 6.95
    $ 7.95
    $ 29.95
    $ 10.95
    $ 41.95
    HCP2537 OEM crown bracket fork tube cinch bolt FLAT WASHER, alloy steel, bright finish. Use 1 per bolt, a total of 3 per bracket, on all 1978-79 XS1100 Standard models, and use 2 per bolt on 1979 XS1100 Special models. Each:
    $ 3.95
    HCP3945 OEM crown bracket fork tube cinch bolt FLAT WASHER, alloy steel, black finish. For the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 4.95
    HCP26192 Aftermarket crown bracket fork tube cinch bolt FLAT WASHER, alloy steel, bright finish. For the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1978-79 XS1100 Standard models (use 1 per bolt, 3 per bike), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 1.95
    HCP26193 Aftermarket crown bracket fork tube cinch bolt FLAT WASHER, 18/8 stainless steel, bright finish. For the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1978-79 XS1100 Standard models (use 1 per bolt, 3 per bike), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 2.95
    HCP17110 Aftermarket crown bracket fork tube cinch bolt FLAT WASHER, 316 stainless steel, dull finish. For the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1978-79 XS1100 Standard models (use 1 per bolt, 3 per bike), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 3.95
    HCP26189 Aftermarket crown bracket fork tube cinch bolt FLAT WASHER, alloy steel, black finish. For the following models: 1984-85 FJ600 (use 2 per side), all 1981-83 XJ650 Maxim and Midnight Maxim models (use 2 for the rear lateral cinch bolt), 1982 XJ650RJ Seca (use 2 per side), 1983 XJ750 Maxim and Midnight Maxim models (use 2 per side), 1978-79 XS1100 Standard models (use 1 per bolt, 3 per bike), 1980-81 XS1100 Standard models (use 2 per bolt, total of 6 per bike), and all XS1100 Special and Midnight Special models (use 2 per bolt). Each:
    $ 3.95
    HCP4240 OEM crown bracket fork tube cinch bolt CROWN NUT, alloy steel, dark finish. For the following models: use 1 per tube cinch bolt (2 per bike) on all 1981-83 XJ650 Maxim and Midnight Maxim models, 1983 XJ750 Maxim and Midnight Maxim models, 1980-81 XS1100 Midnight Special, and 1981 XS1100 Special models. Use 1 per tube cinch bolt and 1 on the rear lateral stem pinch bolt (total of 3 per bike) on all XJ650 Euro, XJ650RJ Seca, XJ650 Turbo, and 1980 XS1100 Standard models. Each:
    $ 6.95
    HCP4528 OEM crown bracket fork tube CROWN NUT, alloy steel, bright finish. For the following models: use 1 per fork tube (2 per bike) on all XJ550, 1980 XJ650 Maxim, and 1979-1980 XS1100 Special models. Use 1 per tube cinch bolt and 1 on the rear lateral stem pinch bolt (total of 3 per bike) on all 1978-80 XS1100 Standard models. Each:
    $ 8.95
    HCP10959 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, alloy steel, bright finish, same height as the HCP4240 and HCP4528 crown nuts. Each:
    $ 3.95
    HCP21940 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 5.95
    HCP21941 Aftermarket crown bracket fork tube cinch bolt CROWN NUT, chromed steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 8.95
    $ discontinued
    $ 2.95
    HCP3656 OEM under-bracket fork tube CINCH BOLT, use 2 per side, a total of 4 per bracket, on all 1981-83 XJ750 Seca, XJ750 Euro, XJ900RK Seca, all XS1100 Standard models, and 1979 XS1100 Special models. Each:
    $ 7.95
    $ 6.95
    $ 2.95
    $ 3.95
    $ 3.95
    Dust Wiper Seals:
    $ 49.95
    $ 29.95
    HCP1824 OEM lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750P (37H), and XS1100 Standard models. One seal does one tube. Each:
    $ 37.95
    HCP21558 Aftermarket lower fork tube DUST WIPER SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, XJ750-D, XJ750P (37H), and XS1100 Standard models. One seal does one tube. Each:
    $ 27.95
    Oil Seals:
    HCP1816 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. One seal does one tube. Each:
    $ 33.95
    HCP20646 Aftermarket standard quality lower fork tube BLACK OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. Comes packaged as a pair of seals, enough to do both forks.
    $ 49.95
    HCP1718 Aftermarket premium quality lower fork tube BLACK OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981-82 XV920 Virago RH and RJ models. Comes packaged as a pair of seals, enough to do both forks.
    $ 54.95
    HCP21815 OEM lower fork tube OIL SEAL, fits either left or right tube on all XS1100 Special and Midnight Special models. One seal does one tube. Each:
    $ 49.95
    HCP20536 Aftermarket standard quality lower fork tube BLACK OIL SEALS, fits all XS1100 Special and Midnight Special models. Comes packaged as a pair of seals, enough to do both forks. NOTE: these seals may require the HCP22174 spacer washers to be placed below this oil seal due to a differing oil seal design, or the inner diameter of this washer would need to be enlarged slightly to clear the sealing “lips” of the oil seal. Pair of seals:
    $ 44.95
    HCP25060 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either the left or right side tube of 1978-79 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 13.95
    HCP1828 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 8.95
    HCP20717 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: 1992-98 XJ600 Seca II, 1983 XJ650 Turbo, all XJ700, XJ750-X, XJ750RL (44X Canadian model), XJ750-D, XJ750-P (37H model), all XJ900RK, RL, N/FN, and F models, and 1980-81 XS1100 Standard models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! Each:
    $ 6.95
    HCP1829 OEM lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and all XS1100 Special and Midnight Special models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! NOTE: this replacement clip is a thin-wire design, as opposed to the heavy stamped metal clip used originally, but it will fit and operate properly. Each:
    $ 9.95
    HCP20718 Aftermarket lower fork tube OIL SEAL RETAINING CLIP, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and all XS1100 Special and Midnight Special models. One clip does one tube. Highly recommended that these be replaced when replacing your oil seals! NOTE: this replacement clip is a thin-wire design, as opposed to the heavy stamped metal clip used originally, but it will fit and operate properly. Each:
    $ 6.95
    Oil Seal Spacer Washer:
    HCP22175 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: 1978-79 XS1100 Standard models. One washer does one tube. This washer goes above the oil seal. Each:
    $ 14.95
    HCP22175SET2 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHERS, one pair does both forks.
    $ 26.95
    HCP3095 OEM lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and 1980-81 XS1100 Special and Midnight Special models. One washer does one tube. This washer goes above the oil seal, is 1.20mm thick, and should be used only with the HCP1818 or HCP1720 (11mm thick) oil seals. This is the original “cupped edges” design washer. Each:
    $ discontinued
    HCP12948 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: all 1981-83 XJ750 Seca, XJ750 Euro, and 1980-81 XS1100 Special and Midnight Special models. One washer does one tube. This washer goes above the oil seal, is 1.50mm thick, and should be used only with the aftermarket HCP20648 (10.75mm thick) oil seals. This is the replacement “flat” washer (does not have a “cupped edges” design). Each:
    $ 14.95
    HCP12948SET2 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHERS, one pair does both forks.
    $ 24.95
    HCP22174 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHER, fits either left or right tube on the following models: 1979 XS1100 Special models. One washer does one tube. This washer goes above the oil seal. NOTE: these washers may need to be placed below the oil seal when using the aftermarket HCP25036 oil seals due to differing oil seal design, or the inner diameter of this washer would need to be enlarged slightly to clear the sealing “lips” of the oil seal. The HCP21815 oil seals have a “flat-top” seal design and therefore this washer will not cause any interference issues when used on top of the oil seal. Each:
    $ 14.95
    HCP22174SET2 Aftermarket lower fork tube OIL SEAL UPPER SPACER WASHERS, one pair does both forks.
    $ 26.95
    HCP4259 OEM lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H models), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 49.95
    HCP4259SET2 OEM lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 89.95
    HCP10709 Aftermarket lower fork tube METAL SLIDE BUSHING, fits either left or right lower tube on the following models: all XJ750RL (45T Australian model), XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. One slider does one tube. Each:
    $ 39.95
    HCP10709SET2 Aftermarket lower fork tube METAL SLIDE BUSHINGS, set of 2:
    $ 74.95
    $ 59.95
    $ 114.95
    Lower Fork Tube Oil Drain Screw and Gasket:
    HCP322 OEM lower fork tube oil DRAIN SCREW, use one per tube. Fits all 1978 and 1980 XS1100 Standard models. Each:
    $ 6.95
    HCP918 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube. Zinc-plated alloy-steel, panhead, phillips-drive. Fits all 1978 and 1980 XS1100 Standard models. Each:
    $ 1.95
    HCP25913 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube. bright zinc-plated alloy steel, panhead, phillips drive, JIS small-head design as original. Fits all 1978 and 1980 XS1100 Standard models. Each:
    $ 3.95
    HCP1355 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube. 18-8 stainless-steel, polished panhead, phillips-drive, Fits all 1978 and 1980 XS1100 Standard models. Each:
    $ 2.95
    HCP5187 OEM lower fork tube oil DRAIN SCREW, use one per tube. Panhead, phillips-drive, alloy steel with a black finish. Note that the black screw was used on models with black lower fork tubes (1982-83 XJ550 Seca, FJ600, 1995 XJ600 Seca II, XJ650 Midnight Maxim, XJ650 Turbo, XJ750 Midnight Maxim, 1981-83 XJ750 Seca and XJ750 Euro models, and some XJ750P models 37H). All other models with natural aluminum lower fork tubes used a screw with a bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 4.95
    HCP29817 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead, phillips-drive, alloy steel with a black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29005 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive zinc-plated alloy steel. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP29006 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6710 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ discontinued
    HCP6712 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 2.95
    HCP6711 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, socket head cap screw, hex-drive, black-oxide coated finish. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 1.95
    HCP7111 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 8.95
    HCP7111SET2 OEM lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 16.95
    HCP21320 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each:
    $ 5.95
    HCP21320SET2 Aftermarket lower fork tube oil drain screw GASKET, use one per tube. Fits all XJ-series bikes (except XJ1100 models), all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Each. Per pair:
    $ 10.95
    HCP22142 OEM lower fork tube oil DRAIN SCREW, use one per tube. Natural finish, was originally black on models with black tubes. Correct bright finish for all 1979-81 XS1100 Special models, will also fit 1980-81 XS1100 Midnight Special models but does not have the correct black finish. Includes the copper crush washer gasket. Each:
    $ 7.95
    HCP22159 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, hex-head zinc-plated alloy steel. Correct bright finish for all 1979-81 XS1100 Special models, will also fit 1980-81 XS1100 Midnight Special models but does not have the correct black finish. The copper crush washer gasket is not included and should be ordered separate Each:
    $ 1.95
    HCP22160 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, hex-head 18-8 stainless steel, bright finish. Correct bright finish for all 1979-81 XS1100 Special models, will also fit 1980-81 XS1100 Midnight Special models but does not have the correct black finish. The copper crush washer gasket is not included and should be ordered separate Each:
    $ 2.95
    HCP22818 Aftermarket lower fork tube oil DRAIN SCREW, use one per tube, hex-head black-phosphate coated alloy steel. Correct black finish for use on all 1980-81 XS1100 Midnight Special models; will also fit 1979-81 XS1100 Special models but does not have the correct bright finish. The copper crush washer gasket is not included and should be ordered separate Each:
    $ 1.95
    $ 1.75
    Lower Fork Tube Damper Rod Retaining Bolt and Gasket:
    HCP8233 OEM fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 9.95
    HCP28069 Aftermarket fork tube damper rod RETAINING SCREW. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 6.95
    HCP8234 OEM fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 16.95
    HCP12950 Aftermarket fork tube damper rod retaining screw copper crush washer GASKET. For all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750 (except 1981-83 XJ750 Seca or XJ750 Euro), XJ750RL, XJ900, all XS1100 Standards, 1988-90 FZR400, and 1982-83 XZ550R Vision models. Use 1 per tube. Each:
    $ 10.95
    $ 11.95
    $ 4.95
    $ 4.95
    w) Lower Fork Tube DAMPER ROD RETAINING TOOL. This long aluminum tool, with proper sized nuts on each end, is used to retain the top of the fork damper rod (in the bottom of the chrome tube) when removing or installing the damper rod retaining screw. One end has a 19mm hex and the other end has a 22mm hex, so it will fit all styles of XJ-series bikes except XJ600 Seca II, 1981-83 XJ750 Seca, XJ1100, and all XS1100 Special and Midnight Special models. This tool will make the disassembly of your upper tube from the lower tube much easier! NOTE: this tool is available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP4402 Aftermarket DAMPER ROD RETAINING TOOL.
    $ 44.95
    $ 6.95
    $ 1.95
    $ 2.95
    $ 3.95
    $ 2.95
    $ 3.95
    $ 1.95
    $ 2.95
    $ 3.95
    $ 2.95
    $ 3.95
    $ 6.95
    $ 1.95
    $ 2.95
    $ 1.95
    Lower Fork Tube Axle Retaining Hardware:
    HCP21818 OEM front axle shaft-to-lower tube CAP BRACKET, use 1 per bike on the left side lower fork tube. For all XS1100 Standard models. Each:
    $ 89.95
    HCP21816 OEM front axle shaft-to-lower tube cap RETAINING STUD, use 2 per bike on the left side lower fork tube. For all XS1100 Standard models. Each:
    $ 6.95
    HCP2537 OEM front axle shaft-to-lower tube retaining stud FLAT WASHER, alloy steel, bright finish, for all XS1100 Standard models. Use 1 per retaining stud (2 per bike) on the left lower fork tubes. Each:
    $ 3.95
    HCP26192 Aftermarket front axle shaft-to-lower tube retaining stud FLAT WASHER, alloy steel, bright finish, for all XS1100 Standard models. Use 1 per retaining stud (2 per bike) on the left lower fork tubes. Each:
    $ 1.95
    HCP26193 Aftermarket front axle shaft-to-lower tube retaining stud FLAT WASHER, 18/8 stainless steel, bright finish, for all XS1100 Standard models. Use 1 per retaining stud (2 per bike) on the left lower fork tubes. Each:
    $ 2.95
    HCP17110 Aftermarket front axle shaft-to-lower tube retaining stud FLAT WASHER, 316 stainless steel, dull finish, for all XS1100 Standard models. Use 1 per retaining stud (2 per bike) on the left lower fork tubes. Each:
    $ 3.95
    HCP26189 Aftermarket front axle shaft-to-lower tube retaining stud FLAT WASHER, alloy steel, black finish, for all XS1100 Standard models. Use 1 per retaining stud (2 per bike) on the left lower fork tubes. Each:
    $ 3.95
    HCP21817 OEM front axle shaft-to-lower tube retaining stud LOCKER NUT, for all XS1100 Standard models. Use 1 per retaining stud (2 per bike) on the left lower fork tubes. Each:
    $ 8.95
    HCP4822 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ650 Midnight Maxim, 1983 XJ750 Midnight Maxim, XJ1100, and all 1980-81 XS1100 Special and Midnight Special models. Each:
    $ 7.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP21893 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on all XS1100 Special and Midnight Special models. Each:
    $ 6.95
    FORK SYSTEM SERVICE TOOLS:
    Assembly and Dis-assembly Tools:
    NOTE: many of these tools are available for short term rental, please see the “rental” section within the THE TOOLBOX section of our catalog at:
    $ 44.95
    $ 47.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Fork Tube Cleaning and Polishing:
    HCP28489 Fork Tubes DEEP REACH CLEANING BRUSH. This 36" long brush features polyester bristles that will reach deep inside the forks tubes to clean away grit and oil sludge residue that cannot otherwise be reached or disturbed. Has a comfortable easy-grip plastic handle and flexible twisted-wire shaft. Use with your favorite cleaning solvents to get the insides of the fork tubes free of contaminants.
    $ 52.95
    ft4) These stainless-steel, bristle-wire DE-BURRING BRUSHES will work wonders on the upper cap bolt area on both the threaded and the non-threaded style of fork tubes. Tubes that use threaded cap bolt (all XJ650 Turbo, all XJ700 models, XJ750-X models, XJ750 Maxim and Midnight Maxim, XJ900RK, and XJ1100 models) should use the HCP10223 butterfly brush; non-threaded tubes can use either the HCP10222 spiral brush or the HCP10223 butterfly brush. Both style brushes have stems that are designed to be used in a standard power drill, and should be used at 850 rpm's or less. These brushes will make quick and meaningful work of the cleaning and polishing of this critical area on your upper fork tubes.
    HCP10222 Aftermarket stainless-steel double-density spiral DE-BURRING BRUSH, for use on fork tubes without a threaded cap bolt.
    $ 13.95
    HCP10223 Aftermarket stainless-steel high-density "butterfly-wings" DE-BURRING BRUSH, for use on fork tubes with or without threaded cap bolts.
    $ 14.95
    FORK OIL:
    Unlike motor oil or gear oil, fork oil's major purpose is not lubrication.....rather, it acts as part of the suspension system, providing both damping and rebound control functions. The different "weight" or viscosity of fork oils allows you to modify the ride and handling characteristics of your bike in a fairly simple way.
    And yes, it IS a lubricant also!
    Although many people----including, unbelievably, Yamaha itself----recommends the use of engine motor oil as a substitute for fork oil, this is not a very good idea. Engine oils (or any multi-viscosity oil) uses additives and detergents that, while wonderful in for their intended purposes inside an engine block, tranny case, or rear drive unit, are not such a good idea inside forks. Forks operate at a much lower temperature and temperature RANGE than engine and drivetrains do, and thus do not need all those additives. And fork oil also tends to contain higher percentages of molybdenum disulfide and anti-foaming agents than engine or gear oil, both of which are very important to proper fork operation.
    As a small example.......most motor oils are of a multi-viscosity nature (such as 10W30) which change their viscosity in relation to their temperature (thin when cool, thicker as they warm). A very necessary and useful feature for an engine, where you do not want your oil thinning out as the engine warms up. Not such a good idea for your suspension----unless for some reason you WANT your handling characteristics to change (get stiffer) as the forks heat up!
    Proper fork oil levels and scheduled change intervals are important for fork performance and fork part longevity.....water contamination, as well as particulate wear will accumulate in fork oil, and since there is no oil filtering mechanism within your forks, the only way to get the grit and gunk out (before it chews up your oil seals and slider bearings!) is to change your fork fluid regularly. Yamaha recommends a fork fluid change every 10,000 miles or 24 months (all models except XJ700's), or every 16,000 miles or 24 months (all XJ700 and XJ750-X models). If you just bought a used bike, we recommend you do a fluid change as soon as possible, because just like other routine maintenance tasks (besides engine oil changes), this is one that has very likely been ignored for the last 10-12 years!
    HINT: there’s a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it’s brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won’t mix and the water will “ball up”; brake fluid will integrate with water and absorb the water.
    Fork oil capacities and recommended weights are as follows. The amounts listed are per fork tube:
    XJ550 Maxim: 272cc or 9.20 fluid ounces. 10W fork oil.
    XJ550 Seca: 230cc or 7.78 fluid ounces. 10W fork oil.
    1980-81 XJ650 Maxim and Midnight Maxim: 262cc or 8.86 fluid ounces. 10W fork oil.
    1982-84 XJ650 Maxim: 278cc or 9.40 fluid ounces. 10W fork oil.
    1982 XJ650RJ Seca: 236cc or 7.98 fluid ounces. 10W fork oil. Fork oil level is specified as 400mm (15.75") below the top of the tube without the spring installed, forks fully collapsed.
    1982 XJ650LJ Turbo: 238cc or 8.04 fluid ounces. 10W fork oil. Fork oil level is specified as 180mm (7.09") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ650LK Turbo: unknown.
    1985-86 XJ700 non-X: 383cc or 12.96 fluid ounces. 10W fork oil.
    1985-86 XJ700-X: 389cc or 13.16 fluid ounces. 10W fork oil.
    1982 XJ750 Maxim: 257cc or 8.69 fluid ounces. 10W fork oil.
    1983 XJ750 Maxim and Midnight Maxim: 257cc or 8.69 fluid ounces. 10W fork oil. NOTE: owner's manual states that the fork oil capacity is 278cc (9.40 fluid ounces). It is unknown which measurement is correct.
    1981-83 XJ750 Seca: 309cc or 10.45 fluid ounces. 20W fork oil.
    1983 XJ750 E-II Seca or 1984 XJ750RL Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 168mm (6.61") below the top of the tube without the spring installed, forks fully collapsed.
    1983 XJ900RK Seca: 286cc or 9.67 fluid ounces. 5W fork oil. Fork oil level is specified as 164mm (6.46") below the top of the tube without the spring installed, forks fully collapsed.
    1982-84 XJ1100 Maxim and Midnight Maxim: 210cc or 7.10 fluid ounces. 10W fork oil. Fork oil level is specified as 210mm (8.27") below the top of the tube without the spring installed, forks fully collapsed.
    IMPORTANT NOTE: the above fork oil VOLUMES are for use only when using the stock fork springs. The use of aftermarket performance front fork coil springs will change those volumes, since aftermarket springs are thicker than stock----and thus displace more oil. Using the stock oil fluid VOLUME with aftermarket fork springs is a sure way to OVERFILL your forks, with the very real possibility of blowing out fork seals.
    Unlike with your engine oil, where a bit too much or too little oil volume in the crankcase is not really a significant concern, with fork oil, too much or too little can cause real problems (too much oil can result in blown oil seals and a stiff, harsh ride, while too little oil volume results in excessive foaming, a soft mushy ride with possible bottoming, and erratic fork performance and lots of front end "dive" upon braking).
    A better way to determine the amount of fork oil that is needed and necessary is via the measurement of the fork oil LEVEL within the tubes.....sort of like measuring the oil level with a dipstick. Yamaha does not specify this level for all models; and in any case, if using aftermarket springs, the factory oil level recommendation is not always useful. The maximum oil level should be 5-1/2" (140mm) below the top of the inner fork tube, measured with all internal fork tube components installed EXCEPT FOR THE SPRINGS, and with the inner fork tube fully collapsed into the lower (outer) tube.
    In order to be as accurate as possible, we recommend the use of a suitable measuring device, such as the HCP1728 oil level syringe listed further below.
    And finally, the fork oil viscosity can be changed from the factory recommendations to give a softer or firmer ride.......the lower the viscosity, the thinner the oil, and the softer the ride (i.e. 5W oil is thinner than 10W which is thinner than 20W, etc.) In this regard, you would certainly be correct in thinking of fork oil as a suspension "tuning tool"! Note that a thicker oil viscosity will have much more effect on the fork "rebound" characteristics than it will on the fork compression dampening function.
    A great primer on "tuning" your forks via adjusting the oil levels can be seen at:
    http://www.thumpertalk.com/forum/archive/index.php/t-89918.html
    while the theory and science and practical applications of tuning your suspension via using differing viscosities of fork oil can is revealed at:
    http://www.peterverdone.com/archive/lowspeed.htm
    ffo3) Red Line Oil products line of SYNTHETIC FORK OILS are some of the best, highest-performance fork oils developed specifically for this purpose. They provide exceptional shear lubrication, are highly resistant to any viscosity changes, and provide excellent seal lubrication as well as very high anti-foaming properties. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    Also, do not mix different brands, styles, or types of oils........you can only safely mix forks oils together from one manufacturer!
    HCP1563 Red Line high-performance SYNTHETIC FORK OIL 0W (zero weight, "like water"), 16 ounce bottle (473cc), clear. Each bottle:
    $ 27.95
    HCP1564 Red Line high-performance SYNTHETIC FORK OIL 2.5W, 16 ounce bottle (473cc), blue. Each bottle:
    $ 27.95
    HCP1258 Red Line high-performance SYNTHETIC FORK OIL 5W, 16 ounce bottle (473cc), amber. Each bottle:
    $ 27.95
    HCP1259 Red Line high-performance SYNTHETIC FORK OIL 10W, 16 ounce bottle (473cc), red. Each bottle:
    $ 27.95
    HCP1263 Red Line high-performance SYNTHETIC FORK OIL 30W, 16 ounce bottle (473cc), orange. NOTE: this oil is similar in viscosity to what most other oil manufacturers call "20W" oil. Each bottle:
    $ 27.95
    ffo4) PJ1 products line of TUNER FORK OILS are exceptional quality, value-priced fork oils developed specifically for motorcycle suspensions. All of these oils are completely compatible with each other, which means that different weights can safely be mixed with each other to create "custom-weights" of fork oil for the utmost in suspension tuning flexibility. NOTE: oils, if mixed for a different viscosity, should be done in a large enough batch to provide enough oil for both front forks. You do NOT want to be running different oil viscosity's in the left and right fork tubes!
    HCP10360 PJ1 products TUNER FORK OIL 2.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10362 PJ1 products TUNER FORK OIL 5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10364 PJ1 products TUNER FORK OIL 7.5W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10366 PJ1 products TUNER FORK OIL 10W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10368 PJ1 products TUNER FORK OIL 15W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10370 PJ1 products TUNER FORK OIL 20W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    HCP10372 PJ1 products TUNER FORK OIL 30W, 16 ounce bottle (473cc). Each bottle:
    $ 29.95
    Fork Tube Oil Level Gauges:
    HCP1728 Fork tube oil fluid level measurement GAUGE AND SYRINGE. This handy tool makes the measurement of the fork oil level easy and accurate. NOTE: the proper amount of fork oil is determined via the measurement of the fork oil LEVEL (distance below the very top of the inner tube) rather than a volume AMOUNT of oil specification. Too little oil will make the ride mushy, while too much oil makes the ride harsh (and can blow out the oil seals!)
    $ 39.95
    ffl4) Aftermarket fork oil measurement GRADUATED CYLINDERS. The best way to measure the precise amount of fork oil fluid is via the use of these lab-quality measurement cylinders. Available in either transparent (clear) or translucent (cloudy) durable plastic construction, they all have easy-to-read scale numerals (milliliters) and feature a "non-wetting" inner surface coating that prevents the concave "meniscus" from forming at the top of the fluid, thus insuring a much more accurate level reading. Large bases insure stability while large spouts make "the pour" easy and prevent messy drips. Very useful device to have for front fork oil changes.
    HCP10741 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, translucent (cloudy).
    $ 24.95
    HCP10744 Aftermarket fork oil GRADUATED CYLINDER, 250ml capacity, transparent (clear).
    $ 49.95
    HCP10742 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, translucent (cloudy).
    $ 29.95
    HCP10745 Aftermarket fork oil GRADUATED CYLINDER, 500ml capacity, transparent (clear).
    $ 69.95
    HCP10743 Aftermarket fork oil GRADUATED CYLINDER, super-sized 1000ml capacity, translucent (cloudy), with convenient side handle to insure steady pouring.
    $ 89.95
    Fork Tube Air Pressure Tool and Gauge:
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 6.95
    HCP9108 Aftermarket air-assisted forks LOW PRESSURE AIR GAUGE, heavy-duty 0-20 psi pencil (stick) pressure gauge marked in 1/2-psi increments, perfect for checking fork air pressures on models so equipped. Very high quality and much more accurate than standard tire pressure gauges, which is very important on the fork pressures as an imbalance between the fork pressure can lead to steering and stability issues, while too much pressure will blow out the lower tube oil seals!
    $ 9.95
    Fork Seals For Other Popular Models:
    HCP26701 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: 1997-04 YZF600R, 1998-11 XVS650 V-Star, 1987 FZR750R, 1996-98 YZF750R, 2009-11 XVS950 V-Star, 1987-88 FZR1000, 1999-09 XVS1100 V-Star, 1984-85 FJ1100, 1992-93 FJ1200 (with ABS), 1986-92 FJ1200, and 2007-11 XVS1300 V-Star. Comes with an oil seal, the dust wiper seal, the lower tube oil seal retaining clip, and both metal slide bushings (upper and lower tubes), enough to do one fork tube..
    $ 69.95
    HCP26701SET2 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, two sets are enough to rebuild one bike.
    $ 134.95
    HCP26702 Aftermarket lower fork tube OIL SEAL, fits either left or right tube on the following models: 1976-77 XS360, 1977-79 XS400, and 1980-8 XS400 Special models. One seal does one tube. Each:
    $ 19.95
    HCP26702SET2 Aftermarket lower fork tube FOIL SEALS, set of 2:
    $ 36.95
    HCP26703 Aftermarket lower fork tube OIL SEAL, fits either left or right tube on the following models: 1973-75 RD250, 1973-75 RD350, 1976-78 RD400, 1973-74 TX500, 1975 XS500, 1970-72 XS1, 1973-74 TX650, and 1975-76 XS650 Standard models. One seal does one tube. Each:
    $ 21.95
    HCP26703SET2 Aftermarket lower fork tube FOIL SEALS, set of 2:
    $ 39.95
    HCP26704 Aftermarket lower fork tube OIL SEAL, fits either left or right tube on the following models: 1976-78 TZ350, 1979 RD400, 1978-81 SR500, 1977-81 XS650 Standards, 1978-83 XS650 Specials, and 1973-74 TX750 models. One seal does one tube. Each:
    $ 21.95
    HCP26704SET2 Aftermarket lower fork tube FOIL SEALS, set of 2:
    $ 39.95
    HCP26705 Aftermarket lower fork tube OIL SEAL, fits either left or right tube on the following models: 1984-85 RZ350, 1982-83 XS400 Maxim and Seca models, 1976-78 XS500, and 1977 XS750 models. One seal does one tube. Each:
    $ 21.95
    $ 39.95
    HCP20342 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1998 XJ600 Seca II, 1988-89 FZR600, and 1998-99 XV1100 models. One seal does one tube. Each:
    $ 27.95
    HCP19456 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1998 XJ600 Seca II, 1988-89 FZR600, and 1998-99 XV1100 models. Comes packaged as a pair of seals, enough to do both forks.
    $ 22.95
    HCP19457 Aftermarket standard quality lower fork tube OIL & DUST SEALS KIT, fits all of the following models: all 1992-97 XJ600 Seca II models. Comes with a pair of both the oil seals and the dust seals, enough to do both forks. Also fits the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1995-97 XV750 Virago, and 1995-97 XV1100 Virago.
    $ 79.95
    HCP19458 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: all 1992-97 XJ600 Seca II models. Comes with an oil seal, the dust wiper seal, the lower tube oil seal retaining clip, and both metal slide bushings (upper and lower tubes), enough to do one fork tube. NOTE: this kit does not contain the following items which we also recommend that you also purchase: upper tube top cap bolt O-RINGS, lower tube damper rod BOLTS AND CRUSH WASHERS, and the lower tube fork oil drain screw SCREWS AND GASKETS. Also fits the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1995-97 XV750 Virago, and 1995-97 XV1100 Virago.
    $ 79.95
    HCP19458SET2 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, two sets are enough to rebuild one bike.
    $ 149.95
    HCP1721 Aftermarket standard quality lower fork tube BLACK OIL SEALS & DUST WIPER SEALS KIT, fits all of the following models: all XJ700 and XJ750-X models. Also fits the following non-XJ models: 1984-87 XV700 Virago, 1988-94 XV750 Virago,1984-85 XV1000 Virago, and 1989-94 XV1100 Virago. Comes with one pair of both the oil and dust seals, enough to do both forks.
    $ 89.95
    HCP1715 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: all XJ700 and XJ750-X models. Comes with one black oil seal, one chrome-capped dust wiper seal, the lower tube oil seal retaining clip, and both metal slide bushings (upper and lower tubes), enough to do one fork tube. NOTE: this kit does not contain the following items which we also recommend that you also purchase: upper tube top cap bolt O-RINGS, lower tube damper rod CRUSH WASHERS, and the lower tube fork oil drain screw GASKETS. Also fits the following non-XJ models: 1984-87 XV700 Virago, 1988-94 XV750 Virago,1984-85 XV1000 Virago, and 1989-94 XV1100 Virago.
    $ 109.95
    HCP1715SET2 Aftermarket standard quality lower fork tube FORK TUBE REBUILD KIT, fits all of the following models: all XJ700 and XJ750-X models. Two sets are enough to rebuild one bike.
    $ 199.95
    HCP1814 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago. One seal does one tube. Each:
    $ 21.95
    HCP20643 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 32.95
    HCP1716 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 39.95
    HCP20112 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: XJ550 Maxim, FJ600, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ650 Turbo, XJ750-P (24L model), and all XJ750 Maxim and Midnight Maxim. NOTE: these seals feature a specially design lip and spring tensions that result in a much lower sliding friction between the seal and the fork tube. Comes packaged as a pair of seals, enough to do both forks. . Also fits the following non-XJ models: 1983 XV500 Virago, 1986 SRX600, 1981-83 XV750 Virago, 1980-81 XS850 all Specials, and all 1983 XV920 Virago.
    $ 44.95
    HCP1817 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. One seal does one tube. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago. Each:
    $ 27.95
    HCP20647 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. Comes packaged as a pair of seals, enough to do both forks. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago.
    $ 42.95
    HCP1719 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: all 1992-97 XJ600 Seca II, XJ700, and XJ750-X models. Comes packaged as a pair of seals, enough to do both forks. Also fits all of the following non-XJ models: 1988-90 FZR400, 1989-97 FZR600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-97 XV1100 Virago.
    $ 47.95
    HCP1818 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. These seals are a double-spring design, making them less susceptible to leaking and giving them a longer life. Also fits the following non-XJ models: 1987-2000 XV535 Virago, all 1978-79 XS750 models, 1980-81 XS850 Standards, and 1982 XV920J Virago models. One seal does one tube. This seal is 11.05mm tall, and should be used with the original HCP3095 upper spacer washer (1.20mm thick) only. Each:
    $ 32.95
    HCP1720 Aftermarket oem-quality lower fork tube OIL SEALS, fits all of the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Comes packaged as a pair of seals, enough to do both forks. Also fits the following non-XJ models: 1987-2000 XV535 Virago, all 1978-79 XS750 models, 1980-81 XS850 Standards, and 1982 XV920J Virago models. This seal is 11.05mm tall, and should be used with the original HCP3095 upper spacer washer (1.20mm thick) only. This is for a pair of seals, enough to do both fork tubes.
    $ 54.95
    HCP20648 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Comes packaged as a pair of seals, enough to do both forks. Also fits the following non-XJ models: 1987-2000 XV535 Virago, all 1978-79 XS750 models, 1980-81 XS850 Standards, and 1982 XV920J Virago models. This seal is 10.75mm tall, and should be used with your original HCP3095 upper spacer washer (1.20mm thick) or the aftermarket HCP12948 upper spacer washer (1.50mm thick). This is for a pair of seals, enough to do both fork tubes.
    $ 44.95
    HCP1816 OEM lower fork tube OIL SEAL, fits either left or right tube on the following models: 1983 XJ650 Turbo, 1984 XJ750RL Seca (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. One seal does one tube. Each:
    $ 33.95
    HCP20646 Aftermarket standard quality lower fork tube OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. Comes packaged as a pair of seals, enough to do both forks.
    $ 49.95
    HCP1718 Aftermarket premium quality lower fork tube OIL SEALS, fits all of the following models: 1983 XJ650 Turbo, 1984 XJ750RL (44X Canadian model), XJ750-D, XJ750P (37H model), all XJ900RK, RL, N/FN, and F models, and all XS1100 Standard models. Also fits 1981 XV920RH and 1982 XV920RJ Virago models. Comes packaged as a pair of seals, enough to do both forks.
    $ 54.95
  14. chacal
    SECTION K:
    STEERING/SUSPENSION:
    --Front Suspension: Fork Oil and Tools.
    FORK OIL:
    HINT: there's a puddle of fluid under your wheel, in the area of the brake caliper. Unless the source of the leak is fully obvious, how can you tell if it's brake fluid of fork oil? Try to mix a few drops of water into the fluid; fork oil (or engine/gear oil) won't mix and the water will "ball up"; brake fluid will integrate with water and absorb the water.
    http://www.thumpertalk.com/forum/archiv ... 89918.html
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 27.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 29.95
    $ 39.95
    $ 24.95
    $ 49.95
    $ 29.95
    $ 69.95
    $ 89.95
    $ 44.95
    HCP9238 Aftermarket fork upper cap bolt REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive cap bolt used on the top of the inner fork tubes on all 1984 FJ600, XJ650 Turbo, XJ700 non-X, XJ750-D, XJ750P (37H) model, all XJ900RK, RL, N/FN, and F, and 1982 XZ550R Vision models.
    $ 19.95
    HCP26093 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 35-36mm fork tubes: XJ550 Seca, FJ600, XJ600 Euro, all XJ650 (except 1983 Turbo), all XJ750 air-cooled (except XJ750P (37H Police) and X750-D models), and XJ900 N/FN models.
    $ 47.95
    HCP26094 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 37mm fork tubes: 1983 XJ650 Turbo, XJ750 Police (37H) model, XJ750-D, XJ900 RK, RL, and F models, XJ1100, and all XS1100 models.
    $ 47.95
    HCP26095 Aftermarket lower fork tube OIL SEAL DRIVER, split “clamshell” heavy duty design allows it to be used properly and safely install the lower tube oil seals and (where applicable) lower tube dust seals on all 38mm fork tubes: XJ600 Seca II thru 1997, XJ700 all models, and XJ750-X water-cooled models.
    $ 47.95
    $ 44.95
    $ 46.95
    $ 47.95
    Anti-Seize Paste:
    $ 8.95
    $ 3.95
    $ 9.95
    $ 13.95
    $ 13.95
    $ 19.95
    $ 11.95
    $ 11.95
    $ 4.95
    $ 11.95
    $ 11.95
    $ 41.95
    $ 44.95
    $ 42.95
    $ 52.95
    $ 13.95
    $ 14.95
    Anti-Dive System Tools:
    HCP12230 Aftermarket anti-dive brake plunger PISTON POPPER, for all models using an anti-dive system.
    $ 13.95
    HCP16049 Aftermarket fork anti-dive brake plunger assembly REVERSE HEX SOCKET TOOL. This tool allows the easy removal and installation of the "inverted/reversed" hex-drive plug used on the top of the anti-dive units on all XJ750-D, XJ750P (37H model), XJ900RK, and XJ900RL models.
    $ 19.95
    $ 6.95
    $ 9.95
  15. chacal
    SECTION K:
    --Rear Suspension: Swingarm parts.
    REAR SUSPENSION:
    REBUILT SWINGARMS:
    Your swingarm takes quite a bit of abuse, being down there “in the dirt” all the time, and having to keep the entire rear suspension in line and marching on the straight -and-narrow. The years take their toll: they get off center due to lack of maintenance/adjustment, and the bushings or bearings wear and get a bit sloppy, and then just lose their ability to keep the rear tire in proper alignment. With such a long distance (lever) between the pivot point of the swingarm to the frame and the rear wheel, almost any movement or wiggle is going to result in a bike that is less than rock-solid predictable, and can also leads to front-end steering shimmy or high-speed shake…..something that you really want to avoid!
    We make attending to the needs of this part easy with both complete rebuilt swingarms or a full complement of rebuild components to properly help you “set your swingarm straight”! NOTE: the replacement of swingarm bushings (XJ550 models) or the swingarm bearings (all shaft-drive models) require proper-sized drifts to remove and install the new components, and in the case of shaft-drive swingarms, a 3-jaw bearing/bushing puller will most likely be required to remove the old races. Do not install new bearings into original races (shaft-drive models), they will wear out quickly!
    HCP2215RF OEM restored, re-finished, and re-built SWINGARM fits all XJ550 models, beautiful and durable powder-coated, low-gloss black finish as original. Completely rebuilt with new (original) plastic bushings, upgraded greaseable pivot bolt, pivot bolt nut, thrust shims, and covers ------ making it ready to bolt-on, adjust, and then ride! Greasable pivot bolt makes yearly maintenance a breeze, and greatly extends bushing life. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, XJ550 swingarm must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 239.95 + $ 50.00 refundable core charge
    HCP2215RF-HP OEM restored, re-finished, and re-built HI-PERFORMANCE SWINGARM fits all XJ550 models, beautiful and durable powder-coated, low-gloss black finish as original. Completely rebuilt with new bronze bushings, upgraded greasable pivot bolt, pivot bolt nut, thrust shims, and covers ------ making it ready to bolt-on, adjust, and then ride! Greasable pivot bolt makes yearly maintenance a breeze, and greatly extends bushing life. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, XJ550 swingarm must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 289.95 + $ 50.00 refundable core charge
    We recommend the following synthetic grease for use on all swingarms. XJ550 swingarms will need to be fully greased before installation!
    HCP8608 Aftermarket gear and bearing synthetic RED MOLY GREASE. High temperature, water resistant, extreme pressure and high-load strength synthetic organic moly grease is far superior to black moly disulfide (petroleum-based) products. Use on steering neck bearings, wheel bearings, starter motor gears, driveshaft splines, swingarm and final drive bearings. 14 oz. tube.
    $ 29.95
    HCP2216RF OEM restored, re-finished, and re-built SWINGARM fits all XJ650 (except Turbo) and 1981-84 XJ750 models. This is the “standard duty” swingarm that does not have the additional rounded cross-brace along the front lateral tube. Beautiful and durable powder-coated, low-gloss black finish as original. Completely rebuilt with new bearings, oil seals, and oil spec decal ------ making it ready to bolt-on, adjust, and then ride! The threaded pivot BOLTS are not included and should be re-used from your original arm. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, same-model swingarm must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 179.95 + $ 50.00 refundable core charge
    HCP13227RF OEM restored, re-finished, and re-built SWINGARM fits all XJ650 Turbo, XJ700, and XJ750-X models. This is the “extra duty” swingarm that has have the additional rounded cross-brace along the front lateral tube, and can be used as a direct substitute for the standard-duty HCP2216RF swingarm above. Beautiful and durable powder-coated, low-gloss black finish as original. Completely rebuilt with new bearings, oil seals, and oil spec decal ------ making it ready to bolt-on, adjust, and then ride! The threaded pivot BOLTS are not included and should be re-used from your original arm. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, same-model swingarm must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 199.95 + $ 50.00 refundable core charge
    HCP2218RF OEM restored, re-finished, and re-built SWINGARM fits all XJ900RK, RL, N/FN, F models. Beautiful and durable powder-coated, medium-gloss silver finish as original. Completely rebuilt with new bearings, oil seals, and oil spec decal ------ making it ready to bolt-on, adjust, and then ride! The threaded pivot BOLTS are not included and should be re-used from your original arm. NOTE: a $ 75.00 core charge applies to this item, and a re-usable, same-model swingarm must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 209.95 + $ 75.00 refundable core charge
    HCP2219RF OEM restored, re-finished, and re-built SWINGARM fits all XJ1100 models. Beautiful and durable powder-coated, low-gloss black finish as original. Completely rebuilt with new bearings, oil seals, and grease fitting ------ making it ready to bolt-on, adjust, and then ride! The threaded pivot BOLTS are not included and should be re-used from your original arm. NOTE: a $ 75.00 core charge applies to this item, and a re-usable, same-model swingarm must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 219.95 + $ 75.00 refundable core charge
    And while you’re replacing your swingarm, you may also want to replace your TENSION BAR and rear caliper MOUNTING BRACKET, just so that everything looks nice and new!
    HCP4812 OEM rear drum brake backing plate TENSION BAR. This is the large tubular rod that runs from the bottom of the brake backing plate forward along the swingarm and holds the brake backing plate in rotational position. Fits all XJ550 models.
    $ 79.95
    HCP4812RF OEM refinished rear drum brake backing plate TENSION BAR. This is the large tubular rod that runs from the bottom of the brake backing plate forward along the swingarm and holds the brake backing plate in rotational position. Beautiful and durable powder-coated, low-gloss black finish as original. NOTE: a $ 10.00 core charge applies to this item, and a re-usable, same-model bar must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting. Fits all XJ550 models.
    $ 59.95 + $ 10.00 refundable core charge
    HCP4811 OEM rear drum brake backing plate TENSION BAR. This is the large tubular rod that runs from the bottom of the brake backing plate forward along the swingarm and holds the brake backing plate in rotational position. Fits all XJ650, XJ700, and XJ750 models.
    $ 79.95
    HCP4811RF OEM refinished rear drum brake backing plate TENSION BAR. This is the large tubular rod that runs from the bottom of the brake backing plate forward along the swingarm and holds the brake backing plate in rotational position. Beautiful and durable powder-coated, low-gloss black finish as original. NOTE: a $ 10.00 core charge applies to this item, and a re-usable, same-model bar must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting. Fits all XJ650, XJ700, and XJ750 models.
    HCP4940RF OEM refinished rear disc brake caliper TENSION BAR. This is the large tubular rod that runs from the brake caliper mounting bracket forward along the swingarm and holds the caliper mounting bracket in rotational position. Beautiful and durable powder-coated, low-gloss black finish as original. NOTE: a $ 20.00 core charge applies to this item, and a re-usable, same-model bar must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting. Fits all XJ900RK, RL, N/FN, F models.
    $ 69.95 + $ 20.00 refundable core charge
    HCP10122RF OEM refinished rear disc brake caliper MOUNTING BRACKET. The HCP4940RF tension bar (above) attaches to this bracket which mounts the rear brake caliper. Beautiful and durable powder-coated, low-gloss black finish as original. NOTE: a $ 20.00 core charge applies to this item, and a re-usable, same-model bracket must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no wallowed-out holes or deep metal pitting. Fits all XJ900RK, RL, N/FN, F models.
    $ 49.95 + $ 20.00 refundable core charge
    HCP4789RF OEM refinished rear disc brake caliper TENSION BRACKET. This is the flat triangular plate that runs from the brake caliper mounting bracket forward along the swingarm and holds the caliper mounting bracket in rotational position. Beautiful and durable powder-coated, low-gloss black finish as original. NOTE: a $ 20.00 core charge applies to this item, and a re-usable, same-model bracket must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting. Fits all XJ1100 and 1981 XS1100 Midnight Special models.
    HCP10123RF OEM refinished rear disc brake caliper MOUNTING BRACKET. The HCP4789RF tension bracket (above) attaches to this bracket which mounts the rear brake caliper. Beautiful and durable powder-coated, low-gloss black finish as original. Does not include the special threaded hex-stud used to attach this bracket to the tension bracket. NOTE: a $ 20.00 core charge applies to this item, and a re-usable, same-model bracket must be returned for the core charge to be refunded. “Re-usable" means it is not bent, damaged, twisted, modified, or dented, and has no wallowed-out holes or deep metal pitting. Fits all XJ1100 and 1981 XS1100 Midnight Special models.
    $ 59.95 + $ 20.00 refundable core charge
    HCP4818 OEM rear disc brake tension bar RETAINING BOLT, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Use one on each end, total 2 per bike. Each:
    $ 29.95
    HCP4791 OEM rear disc brake tension bar RETAINING BOLT, tension bar to the swingarm. Fits all XJ1100 models. Use 1 per bike. Hex-head, black-oxide coated bolt. Each:
    $ 7.95
    HCP6715 Aftermarket rear disc brake tension bar RETAINING BOLT, tension bar to the swingarm. Fits all XJ1100 models. Use 1 per bike. Socket head, hex-drive, black-oxide coated alloy steel, each:
    $ 2.95
    HCP6716 Aftermarket rear disc brake tension bar RETAINING BOLT, tension bar to the swingarm. Fits all XJ1100 models. Use 1 per bike. Socket head, hex-drive, 18/8 stainless steel, each:
    $ 3.95
    HCP3498 OEM rear brake tension bar retaining bolt FLAT WASHER, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Use one on each end, total 2 per bike. Each:
    $ 5.95
    HCP24020 Aftermarket rear brake tension bar retaining bolt FLAT WASHER, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Use one on each end, total 2 per bike. Each:
    $ 1.95
    HCP4034 OEM rear brake tension bar retaining bolt FLANGED NUT, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Bright finish. Use one on each end, total 2 per bike. Each:
    $ 5.95
    HCP16245 Aftermarket rear brake tension bar retaining bolt FLANGED NUT, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Bright finish. Use one on each end, total 2 per bike. Each:
    $ 3.95
    HCP16247 Aftermarket rear brake tension bar retaining bolt FLANGED NUT, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Darl finish. Use one on each end, total 2 per bike. Each:
    $ 2.95
    HCP4112 OEM rear brake tension bar retaining bolt COTTER PIN, tension bar to the caliper bracket or to the swingarm. Fits all XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP16065 Aftermarket rear brake tension bar retaining bolt COTTER PIN, zinc-plated steel, for all XJ900RK, RL, N/FN, and F models. Each:
    $ 1.95
    HCP16066 Aftermarket rear brake tension bar retaining bolt COTTER PIN, stainless steel, for all XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    SWINGARM REBUILD PARTS:
    sa2) Over the years, the swingarm bearings and pivot shaft parts take a beating....when was the last time you (or anyone you know) ever lubricated them or even checked them for wear and play? Well, wear they do, and then they start moving around under load and cornering, leading to vibrations, wandering during straight-line riding, and other unnecessary, unneeded, unwanted, and undesirable (not to mention unsafe) characteristics and conditions. Wow, that a lot of "un's". Oh well.
    In fact, if your bike rides "rock hard stiff" in the rear end, what you may find is not only worn-out rear shock absorbers, but easily overlooked is worn or even partially seized swingarm pivots and bearings. Since swingarm lubrication and maintenance is probably THE most overlooked aspect of preventative maintenance (do you know anyone who has ever done it?), it's a good bet that you swingarm could be silently suffering the same fate, too.....
    The factory service interval for the repacking of the swingarm pivot bearings is every 10,000 miles (XJ550, XJ650, 1981-83 XJ750, and XJ1100 models) or every 16,000 miles (XJ700, XJ750-X, XJ750RL, and XJ900 models)
    Not to worry! We've got all the major and minor parts that you'll need to refresh, restore, rejuvenate, renew, and other properly rebuild your oft-neglected swingarm system.
    NOTE: the replacement of swingarm bushings (XJ550 models) or the swingarm bearings (all shaft-drive models) require proper-sized drifts to remove and install the new components, and in the case of shaft-drive swingarms, a 2- or 3-jaw bearing/bushing puller will most likely be required to remove the old races. Do not install new bearings into old races, they will wear out quickly! Here is one way to perform the race removal task on shaft-drive swingarms:
    https://www.xjbikes.com/forums/threads/swing-arm-bearing-race-replacement.79492
    XJ550 models:
    XJ550 models use a long PIVOT SHAFT BOLT, that runs through a central PIVOT TUBE, which is support by a pair of BUSHING - BEARINGS, each of which are retained by use of a THRUST SHIM and thrust shim COVER PLATE. The whole shooting match is held together by a NUT that threads onto the right side of the pivot bolt.
    XJ550 owners can upgrade their rear swingarm plastic bushings with replacement high-performance bronze bushings or needle roller bearings for a silky smooth, much more stable response.
    HCP2234 OEM swingarm central PIVOT TUBE. For all XJ550 models, use 1 per bike.
    $ 129.95
    HCP11507 Aftermarket swingarm central PIVOT TUBE. For all XJ550 models, use 1 per bike.
    $ 79.95
    HCP2238 OEM swingarm PIVOT SHAFT BOLT. For all XJ550 models, use 1 per bike.
    $ 129.95
    HCP11508C Aftermarket swingarm PIVOT SHAFT BOLT, high-performance design has an internal grease gallery and accepts grease nipples on both ends of the shaft, allowing for the much-needed periodic lubrication of the shaft bushings. To be effective, it should be used with either the current OEM version of the HCP2234 pivot tube (original pivot tubes did not have grease passage holes in them) or the HCP11507 pivot tube. For all XJ550 models, use 1 per bike. Order a pair of the HCP15378 grease nipples (below) to use with this shaft.
    $ 129.95
    HCP15378 Aftermarket swingarm GREASE NIPPLE, for use with the HCP11508C pivot shaft above. For all XJ550 models. Use 2 per shaft, each:
    $ 5.95
    HCP17790 Aftermarket disc brake caliper bleeder screw protective rubber DUST CAP, black, dome-shaped head, no retaining strap, each:
    $ 1.95
    HCP1640 Aftermarket disc brake caliper bleeder screw protective rubber DUST CAP, black, dome-shaped head, with retaining strap, no more losing your caps! Each
    $ 2.95
    NOTE: the swingarm bushings below are supposed to be installed with a hydraulic press, as the OD the bushing is slightly larger than the ID of the swingarm tube (by about 0.3mm,,,,not much, but enough to make just hammering them in difficult and possible damaging the bushing or the swingarm). An alternative method is to freeze the bushings (overnight) to slightly shrink them, and if so inclined, heat the swingarm tube area with a heat gun (to get it to expand slightly). You should then use some bearing grease (or similar) to lubricate the outside of the bushings and/or the inside of the swingarm tube, and then using a small piece of a flat wooden board over the top of the bushing, gently hammer it in place. Small “taps” rather than hard blows should suffice, and will prevent damage to the bushing (especially the stock plastic bushing, which when frozen, could shatter from a hard blow).
    HCP2235 OEM swingarm central pivot tube plastic flanged BUSHING - BEARING. For all XJ550 models, use 2 per bike. Also fits the following non-XJ models: 1977 XS360, 1977-80 XS400, 1973-75 TX650, and all 1976-83 XS650 models. Each:
    $ 37.95
    HCP11506 Aftermarket hi-performance swingarm central pivot tube flanged BRONZE BUSHING - BEARING. Internally grooved for grease retention, low-friction hardened bronze surface results in more precise control and longer life than the stock plastic bushings. Fits all XJ550 models, comes packaged as a pair. Also fits the following non-XJ models: 1977 XS360, 1977-80 XS400, 1973-75 TX650, and all 1976-83 XS650 models
    $ 79.95
    HCP2236 OEM swingarm pivot bushing - bearing THRUST SHIM. For all XJ550 models, use 1 per bike. Each:
    $ 8.95
    HCP2237 OEM swingarm outer THRUST COVER PLATE. For use on all XJ550 models when using the original plastic or the aftermarket bushings or bearings. Use 1 per side, 2 per bike. Each:
    $ 33.95
    HCP22311 Aftermarket swingarm outer THRUST COVER PLATE. For use on all XJ550 models when using the original plastic or aftermarket bushings or bearings. Use 1 per side, 2 per bike. Each:
    $ 24.95
    HCP2239 OEM swingarm pivot shaft RETAINING NUT. For all XJ550 and FJ600 models, use 1 per bike on the right end of the shaft-bolt.
    $ 11.95
    HCP21195 Aftermarket swingarm complete REBUILD KIT contains all the major parts that you'll need to not only refresh the swingarm, but also upgrades your system from the original plastic bushing - bearing to a high-performance bronze-bearing design. Includes the HCP11508C pivot bolt, the HCP21189 locker nut, a pair of the HCP15378 grease fittings, and a pair of the HCP11506 bronze bushings. For all XJ550 models.
    $ 179.95
    HCP11509 Aftermarket swingarm complete REBUILD KIT contains all the major parts that you'll need to not only refresh the swingarm, but also upgrades your system from the original plastic bushing - bearing to a high-performance roller needle bearing design. Includes fine instructions, but they're in German. Hmmm...... Contains the central pivot tube, four high-performance needle roller bearings, and two thrust plates. For all XJ550 models.
    $ 199.95
    HCP11510 Aftermarket swingarm replacement NEEDLE BEARINGS for the HCP11509 kit above, use 2 per side. Each:
    $ 22.95
    FJ600 models:
    HCP20131 OEM swingarm central PIVOT TUBE. For all FJ600 models, use 1 per bike.
    $ 79.95
    HCP20132 OEM swingarm central pivot tube BEARING. For all FJ600 models, use 2 per bike.
    $ 33.95
    HCP20134 OEM swingarm pivot tube bearing THRUST SHIM. For all FJ600 models, use 2 per bike. Each:
    $ 5.95
    HCP20133 OEM swingarm pivot tube outer THRUST COVER PLATE. For use on all FJ600 models. Use 1 per side, 2 per bike. Each:
    $ 12.95
    $ 11.95
    HCP20160 OEM swingarm pivot shaft opening decorative FRAME CAP - COVER. Use on both sides on all FJ600 models. Each:
    $ 16.95
    HCP20139 OEM swingarm hinge arm OIL SEAL, at swingarm. Fits all FJ600 models. Use 2 per bike. Each:
    $ 10.95
    HCP20158 OEM swingarm hinge arm MOUNTING BOLT, at swingarm. Fits all FJ600 models. Use 2 per bike. Each:
    $ 11.95
    HCP20142 OEM swingarm hinge arm pivot NYLON BUSHING, at lower end of each hinge arm where it attaches to the shock lower mount arm. Fits all FJ600 models. Use 2 per bike. Each:
    $ 21.95
    HCP20143 OEM swingarm hinge arm pivot bushing COLLAR, at lower end of each hinge arm where it attaches to the shock lower mount arm. Fits all FJ600 models. Use 2 per bike. Each:
    $ 14.95
    HCP20144 OEM swingarm hinge arm pivot bushing THRUST COVER PLATE, at lower end of each hinge arm where it attaches to the shock lower mount arm. For use on all FJ600 models. Use 1 per side, 2 per bike. Each:
    $ 24.95
    HCP20146 OEM swingarm hinge arm pivot bushing THRUST SHIM, at lower end of each hinge arm where it attaches to the shock lower mount arm. For all FJ600 models, use 1 per bike on the right side. Each:
    $ 5.95
    HCP20147 OEM swingarm hinge arm pivot bushing RETAINING NUT, at lower end of each hinge arm where it attaches to the shock lower mount arm. For all FJ600 models, use 1 per bike on the left end of the shaft-bolt.
    $ 5.95
    HCP20148 OEM swingarm mounting bracket NYLON BUSHING, at the front end of bracket. Fits all FJ600 models. Use 2 per bike. Each:
    $ 39.95
    HCP20149 OEM swingarm mounting bracket OIL SEAL, at the front end of bracket. Fits all FJ600 models. Use 2 per bike. Each:
    $ 11.95
    HCP20151 OEM swingarm mounting bracket COLLAR, at the front end of bracket. Fits all FJ600 models. Use 2 per bike. Each:
    $ 12.95
    HCP20150 OEM swingarm mounting bracket THRUST COVER PLATE, at the front end of bracket. For use on all FJ600 models. Use 1 per side, 2 per bike. Each:
    $ 29.95
    HCP1807 OEM swingarm mounting bracket bolt RETAINING NUT, at the front end of bracket. For all FJ600 models, use 1 per bike on the left end of the shaft-bolt.
    $ 10.95
    XJ650, XJ700, XJ750, XJ900RK, XJ1100, and XS1100 models:
    Unlike the XJ550 models, XJ650 through XJ1100 (and XS1100) models use dual short PIVOT SHAFTS, associated LOCK WASHERS and NUTS, a spacer COLLAR, an OIL SEAL, and a BEARING on each side of the swingarm. A round black or shiny chrome end cap or COVER hides the inner workings from public view. Here are the pieces you'll need, working your way from the outside inwards:
    HCP1521 OEM swingarm pivot shaft opening decorative FRAME CAP - COVER. Bright polished chrome disc snaps into the hole in the frame. Use on both sides on all XJ650, XJ700, XJ750, all XJ900RL, N/FN, and F models, XJ1100, and all XS1100 (except Midnight Special) models. NOTE: XJ650 Midnight Maxim, XJ750 Midnight Maxim, and 1980-81 XS850 Midnight Special,, 1980-81 XS1100 Midnight Special models used this same cover, but finished in gold, while 1982-83 XJ750 Seca models and XJ900RK models used a black version of this cap. Use 1 per side. Each:
    $ 34.95
    HCP21440 OEM swingarm pivot shaft opening decorative FRAME CAP - COVER. Bright polished golden chrome disc snaps into the hole in the frame. This re-plated original unit perfectly restores the gold finish and look on all XJ650 Midnight Maxim, XJ750 Midnight Maxim, 1980-81 XS850 Midnight Special, and 1980-81 XS1100 Midnight Special models. NOTE: this cover will physically fit all XJ650, XJ700, XJ750, XJ900, XJ1100, and XS1100 models. Use 1 per side. Each:
    $ 69.95
    HCP1523 OEM swingarm pivot shaft opening decorative FRAME CAP - COVER. Gloss black painted disc snaps into the hole in the frame. This black-plated covers are only correct for 1982-83 XJ750 Seca models and XJ900RK models. NOTE: this cover will physically fit all XJ650, XJ700, XJ750, XJ900, XJ1100, and XS1100 models. Use 1 per side. Each:
    $ 37.95
    HCP3974 OEM swingarm pivot stud NUT. Use 1 on the right side pivot stud on all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and use 2 (both left and right sides) on all XJ1100 and XS1100 models. Each:
    $ 22.95
    HCP2245 OEM swingarm left side PIVOT SHAFT - BOLT. Fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 1 per bike.
    $ 32.95
    HCP2248 OEM swingarm PIVOT SHAFT - STUD. Use 1 on the right side of all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and use 2 (both left and right sides) on all XJ1100 and XS1100 models. Each:
    $ 23.95
    HCP2225 OEM swingarm left side pivot shaft bolt LOCK WASHER. Fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 1 per bike.
    $ 9.95
    HCP2228 OEM swingarm pivot shaft stud or bolt SPACER COLLAR. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Use 2 per bike. Each:
    $ 14.95
    HCP2227 OEM swingarm pivot shaft stud or bolt OIL SEAL. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Use 2 per bike. Each:
    $ 7.95
    HCP18758 Aftermarket swingarm pivot shaft stud or bolt OIL SEAL. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Use 2 per bike. Each:
    $ 5.95
    HCP19166 Aftermarket swingarm pivot shaft stud or bolt standard-duty TAPERED ROLLER BEARING. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Use 2 per bike. Each:
    $ 27.95
    HCP2226 OEM swingarm pivot shaft stud or bolt medium-duty TAPERED ROLLER BEARING. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Use 2 per bike. Each:
    $ 39.95
    HCP14418 Aftermarket swingarm pivot shaft stud or bolt high-performance TAPERED ROLLER BEARING. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Use 2 per bike. Each:
    $ 44.95
    HCP6552 OEM swingarm GREASE FITTING. Fits all XJ1100 and XS1100 models. Use 1 per bike. Each:
    $ 7.95
    HCP17790 Aftermarket grease fitting protective rubber DUST CAP, black, dome-shaped head, no retaining strap, each:
    $ 1.95
    HCP1640 Aftermarket grease fitting protective rubber DUST CAP, black, dome-shaped head, with retaining strap, no more losing your caps! Each
    $ 2.95
    HCP11334 Aftermarket swingarm complete standard-duty BEARINGS AND SEALS KIT contains a pair of the tapered roller bearings and two of the outer oil seals. The oil seal reducer COLLAR is not included. A rubber o-ring is included which is not used on any of the XJ model bikes and should be discarded. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models.
    $ 59.95
    HCP14420KIT OEM swingarm complete medium-duty BEARINGS AND SEALS KIT contains a pair of the tapered roller bearings and two of the outer oil seals. The oil seal reducer COLLAR is not included. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models.
    $ 92.95
    HCP14421KIT Aftermarket swingarm complete high-performance BEARINGS AND SEALS KIT contains a pair of the tapered roller bearings and two of the outer oil seals. The oil seal reducer COLLAR is not included. Fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models.
    $ 119.95
    Swingarm Hardware:
    HCP2260 OEM swingarm axle shaft retaining PINCH BOLT. Fits all XJ550 models. Use one on each side, total 2 per bike. Each:
    $ 2.95
    HCP3967 OEM swingarm axle shaft retaining pinch bolt LOCKING NUT. Fits all XJ550 models, except 1983 XJ550 Seca. Use one on each side, total 2 per bike. Dark finish. Each:
    $ 8.95
    HCP17108 Aftermarket swingarm axle shaft retaining pinch bolt LOCKING NUT. Fits all XJ550 models, except 1983 XJ550 Seca. Use one on each side, total 2 per bike. Bright 18/8 stainless steel. Each:
    $ 3.95
    HCP1902 OEM swingarm axle shaft retaining pinch bolt LOCK WASHER, black oxide-coated alloy steel. Fits all 1983 XJ550 Seca models. Use one on each side, total 2 per bike. Each:
    $ 6.95
    HCP916 Aftermarket swingarm axle shaft retaining pinch bolt LOCK WASHER. Bright zinc-plated alloy steel. Fits all 1983 XJ550 Seca models. Use one on each side, total 2 per bike. Each:
    $ 1.95
    HCP319 Aftermarket swingarm axle shaft retaining pinch bolt LOCK WASHER. Bright 18-8 stainless steel. Fits all 1983 XJ550 Seca models. Use one on each side, total 2 per bike. Each:
    $ 2.95
    HCP321 Aftermarket swingarm axle shaft retaining pinch bolt LOCK WASHER. Black oxide-coated alloy steel. Fits all 1983 XJ550 Seca models. Use one on each side, total 2 per bike. Each:
    $ 1.95
    HCP3968 OEM swingarm axle shaft retaining pinch bolt NUT. Fits all 1983 XJ550 Seca models. Use one on each side, total 2 per bike. Each:
    $ 2.95
    HCP24059 Aftermarket swingarm axle shaft retaining pinch bolt NUT. Fits all 1983 XJ550 Seca models. Use one on each side, total 2 per bike. Black-oxide coated stainless steel. Each:
    $ 1.95
    HCP2252 OEM swingarm axle shaft retaining PINCH BOLT, hex-head alloy steel with bright plating. Fits all 1980-81 XJ650 models. Use one on the right side only. Each:
    $ 5.95
    HCP2253 OEM swingarm axle shaft retaining PINCH BOLT, hex-head alloy steel with dark plating. . Fits all 1982-83 XJ650 models, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use one on the right side only. Each:
    $ 6.95
    HCP29276 Aftermarket swingarm axle shaft retaining PINCH BOLT, hex-head 18-8 stainless steel with bright finish. Fits all XJ650, XJ700, XJ750, XJ900, and XJ1100 models. Use one on the right side only. This bolt is partially-threaded just like the original. Each:
    $ 3.95
    HCP29278 Aftermarket swingarm axle shaft retaining PINCH BOLT, black-phosphate coated alloy steel. Fits all XJ650, XJ700, XJ750, XJ900, and XJ1100 models. Use one on the right side only. This bolt is partially-threaded just like the original, and has a flanged head unlike the original. Each:
    $ 3.95
    HCP29277 Aftermarket swingarm axle shaft retaining PINCH BOLT, hex-head 316 stainless steel with bright finish. Fits all XJ650, XJ700, XJ750, XJ900, and XJ1100 models. Use one on the right side only. This bolt is partially-threaded just like the original. Each:
    $ 4.95
    HCP2185 OEM swingarm axle shaft retaining pinch bolt LOCK WASHER. Fits all 1980-81 XJ650 Maxim models. Use one on the right side only. Bright finish. Each:
    $ 6.95
    HCP2391 OEM swingarm axle shaft retaining pinch bolt LOCK WASHER. Fits all XJ650 Midnight Maxim, all 1982-84 XJ650 models, all XJ700 models, all XJ750 models, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use one on the right side only. Each:
    $ 7.95
    HCP16209 Aftermarket swingarm axle shaft retaining pinch bolt LOCK WASHER, zinc-plated alloy steel, fits all XJ650 Maxim, all XJ700 models, all XJ750 models, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use one on the right side only. Each:
    $ 2.95
    HCP16100 Aftermarket swingarm axle shaft retaining pinch bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, fits all XJ650 Maxim, all XJ700 models, all XJ750 models, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use one on the right side only. Each:
    $ 3.95
    HCP16102 Aftermarket swingarm axle shaft retaining pinch bolt LOCK WASHER, black-oxide coated alloy steel. Fits all XJ650 Maxim, all XJ700 models, all XJ750 models, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use one on the right side only. Each:
    $ 3.95
    HCP2230 OEM final drive housing-to-swingarm stud LOCK WASHER, use 1 per bolt, for all 1980 XJ650 Maxim, all XJ700, and all XJ750-X models. Each:
    $ 7.95
    HCP22225 Aftermarket final drive housing-to-swingarm stud LOCK WASHER, zinc-plated alloy steel. Use 1 per bolt, for all 1980 XJ650 Maxim, all XJ700, and all XJ750-X models. Each:
    $ 2.95
    HCP22227 Aftermarket final drive housing-to-swingarm stud LOCK WASHER, 18/8 stainless steel. Use 1 per bolt, for all 1980 XJ650 Maxim, all XJ700, and all XJ750-X models. Each:
    $ 3.95
    HCP3497 OEM final drive housing-to-swingarm stud LOCK WASHER, black finish, use 1 per bolt, for all 1981-83 XJ650 Maxim, 1982-83 XJ650 Turbo, all XJ750 non-X, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 7.95
    HCP22226 Aftermarket final drive housing-to-swingarm stud LOCK WASHER, black finish. Use 1 per bolt, for all 1981-83 XJ650 Maxim, 1982-83 XJ650 Turbo, all XJ750 non-X, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 2.95
    HCP6154 OEM final drive housing-to-swingarm stud LOCKING NUT, use 1 per bolt, for all 1980 XJ650 Maxim models. Each:
    $ 4.95
    HCP11678 OEM final drive housing-to-swingarm stud NUT, black finish, use 1 per bolt, for all 1981-83 XJ650 Maxim, 1982-83 XJ650 Turbo, all XJ750 non-X, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 8.95
    HCP4661 OEM final drive housing-to-swingarm stud CROWN NUT, semi-polished bright finish, use 1 per bolt, for all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP16424 Aftermarket final drive housing-to-swingarm stud CROWN NUT, high-polished chrome-plated finish, use 1 per bolt, for all XJ700 and XJ750-X models. This nut is a bit taller (and lacks the flanged base) compared to the original HCP4661 nut, and has a beautiful, highly polished chrome finish compared to the stock OEM nut, and the extra height is visually pleasing. Each:
    $ 9.95
    Swingarm-to-Rear Drum Brake System Hardware:
    $ 79.95
    $ 79.95
    HCP4819 OEM rear drum brake backing plate tension bar RETAINING BOLT, tension bar to the backing plate. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use 1 per bike.
    $ 14.95
    HCP4814 OEM rear drum brake backing plate tension bar RETAINING BOLT, tension bar to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use 1 per bike.
    $ 12.95
    $ 33.95
    $ 11.95
    $ 2.95
    $ 3.95
    HCP2537 OEM rear drum brake backing plate tension bar retaining bolt FLAT WASHER, alloy steel, bright finish, fits at the tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 3.95
    HCP26192 Aftermarket rear drum brake backing plate tension bar retaining bolt FLAT WASHER, alloy steel, bright finish, fits at the tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 1.95
    HCP26193 Aftermarket rear drum brake backing plate tension bar retaining bolt FLAT WASHER, 18/8 stainless steel, bright finish, fits at the tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 2.95
    HCP17110 Aftermarket rear drum brake backing plate tension bar retaining bolt FLAT WASHER, 316 stainless steel, dull finish, fits at the tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 3.95
    HCP26189 Aftermarket rear drum brake backing plate tension bar retaining bolt FLAT WASHER, alloy steel, black finish, fits at the tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 3.95
    $ 5.95
    $ 1.95
    HCP2185 OEM rear drum brake backing plate tension bar retaining bolt LOCK WASHER, tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 6.95
    HCP16209 Aftermarket rear drum brake backing plate tension bar retaining bolt LOCK WASHER, zinc-plated alloy steel, tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 2.95
    HCP16100 Aftermarket rear drum brake backing plate tension bar retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 3.95
    HCP16102 Aftermarket rear drum brake backing plate tension bar retaining bolt LOCK WASHER, black-oxide coated alloy steel, tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 3.95
    HCP2109 OEM rear drum brake backing plate tension bar retaining bolt NUT, tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 4.95
    HCP28541 Aftermarket rear drum brake backing plate tension bar retaining bolt NUT, tension bar to the brake backing plate or to the swingarm. Made from a bright zinc-plated alloy steel. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 1.95
    HCP28539 Aftermarket rear drum brake backing plate tension bar retaining bolt NUT, tension bar to the brake backing plate or to the swingarm. Made from bright 18/8 stainless steel. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 2.95
    HCP28540 Aftermarket rear drum brake backing plate tension bar retaining bolt NUT, tension bar to the brake backing plate or to the swingarm. Made from a black-oxide coated 18/8 stainless steel. Fits all XJ550, XJ650, XJ700, and XJ750 models. Use one on each end, total 2 per bike. Each:
    $ 3.95
    $ 6.95
    $ 3.95
    $ 2.95
    HCP4112 OEM rear drum brake backing plate tension bar retaining bolt COTTER PIN, tension bar to the brake backing plate or to the swingarm. Fits all XJ550, XJ650, XJ700, XJ750, and XJ900 models. Use one on each end, total 2 per bike. Each:
    $ 2.95
    HCP16065 Aftermarket rear drum brake backing plate tension bar retaining bolt COTTER PIN, zinc-plated steel, for all XJ550, XJ650, XJ700, XJ750, and XJ900 models. Use one on each end, total 2 per bike. Each:
    $ 1.95
    HCP16066 Aftermarket rear drum brake backing plate tension bar retaining bolt COTTER PIN, stainless steel, for all XJ550, XJ650, XJ700, XJ750, and XJ900 models. Use one on each end, total 2 per bike. Each:
    $ 2.95
    HCP4941 OEM rear disc brake tension bar STOPPER, this is the rubber “grommet” that goes on the peg where the front of the torque plate attached to the swingarm. Fits all XJ1100, and all XS1100 Special and Midnight Special models. Use 1 per bike.
    $ 29.95
    Swingarm Decals:
    HCP8094 Aftermarket final drive HYPOID OIL DECAL, silver decal with black wording. This foil decal is used on all XJ650, XJ700, and XJ750 models and is located on the top of the swingarm tube just before it is bolted to the final drive housing.
    $ 9.95
    HCP8095 Aftermarket final drive HYPOID OIL DECAL, silver decal with black wording. This foil decal is used on all XJ900 models and is located on the top of the swingarm tube just before it is bolted to the final drive housing.
    $ 11.95
    SWINGARM TOOLS:
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Assembly Fluids and Lubricants:
    HCP8608 Aftermarket gear and bearing synthetic RED MOLY GREASE. High temperature, water resistant, extreme pressure and high-load strength synthetic organic moly grease is far superior to black moly disulfide (petroleum-based) products. Use on steering neck bearings, wheel bearings, starter motor gears, and swingarm bearings. 14 oz. tube.
    $ 29.95
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    https://dfwmachine.com/2026/03/anti-seize-compounds-types-torque-considerations
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    Swingarm Tools:
    HCP11336 Aftermarket standard depth 27mm SOCKET, used to remove your swingarm pivot bolt and nut on all XJ650 - XJ1100 models, and the rear axle castle nut on XJ1100 and XS1100 models. Chrome-plated, 6-point, 1/2" drive.
    $ 28.95
    HCP10300 Aftermarket 3/8"-to-1/2" DRIVE ADAPTER. For use with the HCP10298, HCP11336, or HCP20225 sockets, and the 10mm and 12mm HCP10302 stud extractors included in the HCP10301 tool kit. Most people have the standard 3/8" drive ratchet wrenches in their tool kits already, and the larger 1/2" drive sockets can be used with those ratchets with this converter/adapter. Chrome-plated, 1/2" male drive, 3/8" female receiver.
    $ 13.95[/i]
  16. chacal
    SECTION K:
    --Rear Suspension: Shock Absorbers, hardware, etc.
    SHOCK ABSORBERS:
    Well, let's face it, it's been 25-30 years since your bike was first sold and operated, and your rear SHOCK ABSORBERS:
    a) were not all that great to begin with, and....
    b) pretty much completely worn out by now.
    Factory-installed motorcycle shock absorbers cannot always be considered top-of-the-line from either performance, comfort, or endurance standpoints----and of course, this is a typical situation for most mass-production vehicles, as they end up being a "compromise" product that will (hopefully) suit "all buyers, in all conditions" and are usually selected for production bikes with an eye towards cost efficiency and savings (the exception being the original XJ900RK Seca rear shocks, which ARE a true high-performance design).
    Stock fluid- or gas-filled, spring-assisted shock absorbers are good for about 10,000 to 20,000 miles of typical use before they are ready for that large XJ graveyard in the sky.
    Of course, if you want to go thru the effort, stock shocks can be dis-assembled and rebuilt, here's how:
    https://xs11.club/forum/idle-talk-forum/xs11-xj11-discussion/13783-xj1100-rear-shock-rebuild
    OEM Shock Absorbers:
    HCP25860 OEM rear SHOCK ABSORBER, brand new unit exactly replaces the original. This mono-shock unit includes the upper bushing, both lower bushings, the lower oil seals, black coil spring, and the rubber mud guard. Lower mounting collars and both upper and lower mounting hardware (bolt, washer, nut) are not included. NOTE: this shock has the same valving (and thus performance and road feel) as the original shock, and will leave the rear suspension at the original height. For all 1992-98 XJ600 Seca II models. Each:
    $ 689.95
    HCP25847 Aftermarket standard-performance rear SHOCK ABSORBER, brand new unit will properly replace the original. This mono-shock unit includes the upper bushing, both lower bushings, and the lower oil seals. The lower rubber mud guard, the lower mounting collars, and both upper and lower mounting hardware (bolt, washer, nut) are not included. NOTE: this shock has slightly stiffer valving and spring rate compared to the original shock (and thus offers slightly more performance and control than the original), and will leave the rear suspension at the original height. For all 1992-98 XJ600 Seca II models. Each:
    $ 489.95
    HCP25848 Aftermarket standard-performance rear SHOCK ABSORBER, brand new unit will properly replace the original. This mono-shock unit includes the upper bushing, both lower bushings, the lower oil seals, and the black coil spring. The lower rubber mud guard, the lower mounting collars, and both upper and lower mounting hardware (bolt, washer, nut) are not included. NOTE: this shock has slightly stiffer valving and spring rate compared to the original shock (and thus offers slightly more performance and control than the original), and has a slightly longer length than original and thus will raise the rear suspension by about 5/8” higher than stock. For all 1992-98 XJ600 Seca II models. Each:
    $ 499.95
    HCP25857 Aftermarket high-performance rear SHOCK ABSORBER, brand new unit will properly replace the original. This mono-shock unit includes the upper bushing, both lower bushings, the lower oil seals, and a red coil spring. The lower rubber mud guard, the lower mounting collars, and both upper and lower mounting hardware (bolt, washer, nut) are not included. NOTE: this shock has much stiffer valving and spring rate compared to the original shock (and thus offers a much firmer feel / performance and control than the original), has a slightly longer length, and will allow for more suspension travel than than original. It will raise the rear suspension by about 3/4” to 1" higher than stock. This shock has enough carrying capacity and can be adjusted for both single and 2-up riding (or extra gear) and still maintain its performance. Single riders should initially try setting #3, while 2-up riders may prefer the #6 or #7 setting (your stock adjuster tool can be used, and it’s recommended that you set it to the lowest preload setting before installation to make fitment easier). Adequate ground clearance for the rear tire when on the centerstand is maintained. Due to the aggressiveness of this shock’s performance over stock, it is recommended that you upgrade your front fork springs to our HCP19477 progressive coil springs or increase the viscosity of your fork fluid (to 15W or 20W) to get a balanced front/rear suspension tune when using these shocks. Fits all 1992-98 XJ600 Seca II models. Each:
    $ 449.95
    HCP5692 OEM rear SHOCK ABSORBER, brand new replacement unit exactly replaces the original. Although this shock comes with the lower bushing that is correct for the right side, it can also be used on the left side if the original left lower shock bushing is re-used from your original. Complete, assembled shocks come with the springs and top cap. For all XJ750 Seca models. Each:
    $ discontinued
    HCP5692SET OEM rear SHOCK ABSORBERS, pair:
    $ discontinued
    HCP5716 OEM rear SHOCK ABSORBER, brand new replacement unit exactly replaces the original. Although this shock comes with the lower bushing that is correct for the right side, it can also be used on the left side if the original left lower shock bushing is re-used from your original. This all-aluminum bodies "DeCarbon" remote-reservoir shock is correct for all XJ900RK, RL, and FN models. Each:
    $ discontinued
    HCP5716SET OEM rear SHOCK ABSORBERS, pair:
    $ discontinued
    Original Shock Absorber ID Decals:
    HCP8500 Aftermarket suspension ID DECAL, small black rectangular decal with silver lettering "KYB", used as follows:
    - mounts directly above the lower fork tube drain screw and faces the rear of the bike. Use 1 on the left side fork tube on XJ550 Maxim, all XJ650 (except Turbo) models, all XJ700 and XJ750-X models, use 1 on the right side fork tube on XJ550 Seca (Noth American) models, and 1 on the left side fork tube on XJ550 Euro models.
    - mounts directly above the lower fork tube hose routing bracket boss and faces the rear of the bike. Use 1 on the left side fork tube on all YX600 Radian models.
    - mounts directly below the lower vertical adjuster stop peg on the rear shock absorbers. Use 1 per shock on all XJ550 models and all XJ650 (except Turbo) models original rear shocks.
    Each:
    $ 12.95
    HCP15135 Aftermarket rear shock absorber tube ID DECAL, small chrome rectangular decal with black lettering "SHOWA", mounts directly below the lower vertical adjuster stop peg. Use 1 per shock on all 1982 XJ750 Maxim and 1981-83 XJ750 Seca models original rear shocks. Each:
    $ 8.95
    HCP15139 Aftermarket rear shock absorber ADJUSTER DECAL, long, thin black decal with red "Adjustable Damper" lettering and white 1-2-3-4 adjustment numbers, used on XJ650 Turbo rear shock absorbers. Each:
    $ 6.95
    HCP8105 Aftermarket AIR SUSPENSION WARNING DECAL, small clear rectangular decal with black lettering and border, mounts directly above the right lower fork tube drain screw and faces the rear of the bike on XJ750 Maxim and Midnight Maxim forks tubes, on the left lower fork tube facing outwards (between the lower caliper moutning bolt and the front axle hole) on all XJ700-X and XJ750-X models, and is also used on XJ650 Turbo and XJ1100 rear air shock absorbers.
    $ 11.95
    HCP8576 Aftermarket rear shock absorber ADJUSTER DECAL, black decal with red and silver adjuster position "arrows" and chrome lettering. Used on the bottom rubber damper ring on all XJ900 "DeCarbon" style rear shock absorbers. Use 1 per shock. Each:
    $ 9.95
    HCP8096 Aftermarket rear shock absorber WARNING DECAL, black decal with silver lettering. Used on all XJ900 "DeCarbon" style rear shock absorbers in the recessed area on the reservoir appendage unit. Use 1 per shock. Each:
    $ 11.95
    Original Shock Mounting Hardware:
    rsh2) Original rear shock absorber MOUNTING HARDWARE perfectly replaces the missing, damaged, or rusted originals.
    NOTE: on some models, you may come across the unfortunate situation of finding the upper shock mounting stud damaged, removed, or otherwise rendered un-usuable. Here is a solution to this dilemma:
    HCP28443 Aftermarket shock absorber UPPER MOUNING STUD REPAIR KIT. This threaded stud (and installation tools) allow you to repair a common problem: the upper shock mount threaded studies hopelessly damaged or broken off completely. Kit includes a special, step-down threaded stud, proper size drill bit and thread tap, locking fluid, and complete illustrated instructions. A great view of how and what this repair kit does can be seen at: https://www.xjbikes.com/forums/threads/rear-shock-stud-end-repair.62848 Note that we also have the step-down stud available by itself, so if you already have the tools (or need to repair more than one stud) you don’t have to purchase the rest of the kit contents a second time. Will work on all XJ550, XJ650, XJ700, XJ750, XJ900, XJ1100, and XS1100 models….and many other bikes which use traditional rear shock absorbers, and which use an M10 x 1.25 thread-pitch nut on the shock threaded stud. Each:
    $ 39.95
    HCP28443STUD Aftermarket shock absorber UPPER MOUNING STUD ONLY. Of course this is included in the above kit, but if you need additional studs (for additional repairs), then it is also available separate:
    $ 23.95
    HCP2249 OEM rear shock absorber chrome-plated domed CROWN NUT. Each:
    $ 9.95
    HCP16425 Aftermarket rear shock absorber chrome-plated domed CROWN NUT, more highly polished finish than on the stock OEM nut above. Each:
    $ 11.95
    The above two versions of this crown nuts fit all of the following models in the specified locations.
    XJ650 Maxim and Midnight Maxim models: upper shock mounting, both sides, and left side lower shock absorber mounting.
    XJ650 Seca and Turbo models: left side lower shock absorber mounting.
    XJ700 all models: left side lower shock absorber mounting.
    XJ750 Maxim and Midnight Maxim models: upper shock mounting, both sides, and left side lower shock absorber mounting.
    1981-83 XJ750 Seca models: left side lower shock absorber mounting.
    XJ900RK, RL, N/FN, and F models: left side lower shock absorber mounting.
    XJ1100 models: left side lower shock absorber mounting.
    XS1100 all models: left side lower shock absorber mounting.
    HCP2250 OEM rear shock absorber chrome-plated domed CROWN NUT. Fits all of the following models in the specified locations. Each:
    $ 7.95
    HCP16424 Aftermarket rear shock absorber chrome-plated domed CROWN NUT. Fits all of the following models in the specified locations. This nut is a bit taller compared to the original HCP2250 nut, and has a beautiful, highly polished chrome finish compared to the stock OEM nut, and the extra height is visually pleasing. Each:
    $ 9.95
    XJ550 all models: upper shock mounting, both sides.
    XJ650 Seca and Turbo models: upper shock mounting, both sides.
    XJ750 Seca models: upper shock mounting, both sides.
    XJ900RK, RL, N/FN, and F models: upper shock mounting, both sides.
    XJ1100 models: upper shock mounting, both sides.
    XS1100 all models: upper shock mounting, both sides.
    HCP2250GLD OEM rear shock absorber gold-finish domed CROWN NUT. This nut also retains the front of the grab bar, and is a nice addition to XJ1100 Midnight Maxim and XS1100 Midnight Maxim models. Each:
    $ 29.95
    HCP2229 OEM rear shock absorber polished dome-headed BOLT. Fits all of the following models listed below in the specified locations. Bright plated. NOTE: Midnight Maxim models originally used a black-plated version of this same bolt, which is no longer available. Each:
    $ 24.95
    HCP29091 Aftermarket rear shock absorber polished dome-headed BOLT. Fits all of the following models listed below in the specified locations. Bright plated. NOTE: Midnight Maxim models originally used a black-plated version of this same bolt, which is no longer available. Each:
    $ 14.95
    XJ550 models: lower shock mounting, both sides.
    XJ650 models: right side lower shock absorber mounting.
    XJ700 models: right side lower shock absorber mounting.
    XJ750 models: right side lower shock absorber mounting.
    XJ900RK, RL, N/FN, and F models: right side lower shock absorber mounting.
    XJ1100 models: right side lower shock absorber mounting.
    XS1100 all models except 1981 Midnight Special: right side lower shock absorber mounting.
    HCP3966 OEM rear shock absorber polished, domed-head flanged BOLT. Fits all XJ700 and XJ750-X models for the upper shock mounting, both sides. Each:
    $ 7.95
    HCP7307 OEM rear shock absorber UPPER MOUNTING BOLT black-oxide finish (on some years, this bolt had a bright finish). Fits all 1992-98 XJ600 Seca II models in the upper position. Each:
    $ 13.95
    HCP25850 OEM rear shock absorber LOWER MOUNTING BOLT. Fits all 1992-98 XJ600 Seca II models in the lower position. Each:
    $ 8.95
    HCP25855 OEM rear shock absorber mounting bolt LOCKER NUT. Fits all 1992-98 XJ600 Seca II models in the upper or lower position. Each:
    $ 6.95
    HCP25849 OEM rear shock absorber EYE BUSHING. Fits all 1992-98 XJ600 Seca II models in the upper position. Each:
    $ 34.95
    HCP25851 OEM rear shock absorber COLLAR. Fits all 1992-98 XJ600 Seca II models in the lower position. Use 2 per shock. Each:
    $ 21.95
    HCP25852 OEM rear shock absorber EYE BUSHING. Fits all 1992-98 XJ600 Seca II models in the lower position. Use 2 per shock. Each:
    $ 11.95
    HCP25853 OEM rear shock absorber GREASE SEAL. Fits all 1992-98 XJ600 Seca II models in the lower position. Use 2 per shock. Each:
    $ 13.95
    HCP25856 OEM rear shock absorber MUD GUARD. Fits all 1992-98 XJ600 Seca II models in the lower position. Use12 per shock. Each:
    $ 29.95
    HCP8866 OEM rear shock absorber STUD. Fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models in the left lower position (this stud actually screws into the final drive housing).
    $ 12.95
    HCP2258 OEM rear shock absorber mounting bolt FLAT WASHER, bright zinc-plated alloy steel. Fits all of the following models in the specified locations. Each:
    $ 8.95
    HCP29101 Aftermarket rear shock absorber mounting bolt FLAT WASHER, bright 18-8 stainless steel. Fits all of the following models in the specified locations. Each:
    $ 5.95
    HCP29103 Aftermarket rear shock absorber mounting bolt FLAT WASHER, black 18-8 stainless steel. Fits all of the following models in the specified locations. Each:
    $ 4.95
    HCP29102 Aftermarket rear shock absorber mounting bolt FLAT WASHER, bright 316 stainless steel. Fits all of the following models in the specified locations. Each:
    $ 8.95
    XJ550 Maxim models: lower shock mounting, both sides.
    XJ700 and XJ750-X models: lower shock mounting, left side.
    XS1100 all Special and Midnight Special models: upper shock mounting, both sides, use 2 per shock
    HCP3946 OEM rear shock absorber mounting bolt FLAT WASHER, alloy steel, bright finish. Fits all of the following models in the specified locations. Each:
    $ 7.95
    XS1100 1978-79 Standard models: upper shock mounting, left side.
    XS1100 1978-79 Standard models: lower shock mounting, left side
    HCP26196 Aftermarket rear shock absorber mounting bolt FLAT WASHER, alloy steel, bright finish. Fits 1978-79 XS1100 Standard models on the left side, upper and lower shock mounting positions. Each:
    $ 1.95
    HCP26197 Aftermarket rear shock absorber mounting bolt FLAT WASHER, 18/8 stainless steel, bright finish. Fits 1978-79 XS1100 Standard models on the left side, upper and lower shock mounting positions. Each:
    $ 2.95
    HCP26198 Aftermarket rear shock absorber mounting bolt FLAT WASHER, 316 stainless steel, dull finish. Fits 1978-79 XS1100 Standard models on the left side, upper and lower shock mounting positions. Each:
    $ 3.95
    HCP21864 OEM rear shock absorber mounting bolt FLAT WASHER. Fits all of the following models in the specified locations. Each:
    $ 6.95
    XS1100 1978-79 Standard models (1978-1979): upper shock mounting, right side.
    XS1100 1980-81 all models: lower shock mounting, left side.
    HCP2247 OEM rear shock absorber mounting bolt special THICK FLAT WASHER. Each:
    $ 6.95
    HCP16426 Aftermarket rear shock absorber mounting bolt THICK FLAT WASHER. More highly polished chrome finish than on the stock OEM washer. Each:
    $ 5.95
    The above two versions of this washers fit all of the following models in the specified locations.
    XJ550 models: upper shock mounting, both sides.
    XJ650 models: upper shock mounting, both sides.
    XJ750 air-cooled models: upper shock mounting, both sides.
    XJ1100 models: upper shock mounting, both sides, and left side lower shock mounting
    HCP2246 OEM rear shock absorber mounting bolt FLAT WASHER. Fits all of the following models in the specified locations. Each:
    $ 9.95
    XJ650 models: lower shock mounting, left side.
    XJ750 air-cooled models: lower shock mounting, left side.
    XJ900RK, RL, N/FN, and F models: lower shock mounting, left side.
    HCP9839 OEM rear shock absorber mounting bolt SPACER WASHER. Fits all of the following models in the specified locations. Each:
    $ 23.95
    XJ700 and XJ750-X models: upper shock mounting, both sides.
    HCP2230 OEM rear shock absorber mounting bolt LOCK WASHER, bright finish. Fits all of the following models in the specified locations. Each:
    $ 7.95
    HCP22225 Aftermarket rear shock absorber mounting bolt LOCK WASHER, zinc-plated alloy steel. Fits all of the following models in the specified locations. Each:
    $ 2.95
    HCP22227 Aftermarket rear shock absorber mounting bolt LOCK WASHER, 18/8 stainless steel. Fits all of the following models in the specified locations. Each:
    $ 3.95
    XJ650 all models (except Midnight Maxim): lower shock mounting, right side.
    XJ700 models: lower shock mounting, right side.
    XJ750 models: lower shock mounting, right side.
    XJ900RK, RL, N/FN, and F models: lower shock mounting, right side.
    XJ1100 models: lower shock mounting, right side.
    XJ1100 all models except 1981 Midnight Special: lower shock mounting, right side.
    HCP3497 OEM rear shock absorber mounting bolt LOCK WASHER. Fits all of the following models in the specified locations. Each:
    $ 7.95
    HCP22226 Aftermarket rear shock absorber mounting bolt LOCK WASHER, black finish. Fits all of the following models in the specified locations. Each:
    $ 2.95
    XJ650 Midnight Maxim: lower shock mounting, right side.
    XJ1100 all 1981 Midnight Special: lower shock mounting, right side
    HCP20050 OEM rear shock absorber upper mounting BOLT, use per shock. For the following models: all 1984-85 FJ600 models. Each:
    $ 6.95
    HCP20049 OEM rear shock absorber upper mounting bolt FLAT WASHER, for all 1984-85 FJ600 models. Use 1 per bolt.
    $ 5.95
    HCP3973 OEM rear shock absorber upper mounting bolt NUT, for all 1984-85 FJ600 models. Use 1 per bolt.
    $ 8.95
    HCP20044 OEM rear shock absorber upper mounting COLLAR, use 1 per shock on 1984-85 FJ600 models. Each:
    $ 13.95
    HCP20043 OEM rear shock absorber lower mounting BUSHING, use 2 per shock on 1984-85 FJ600 models. Each:
    $ 9.95
    HCP2130 OEM rear shock absorber timing belt bracket MOUNTING BOLT, alloy steel socket head cap screw with a black finish, use 2 per bracket. For the following models: all 1984-85 FJ600 models. Each:
    $ 8.95
    HCP22192 Aftermarket rear shock absorber timing belt bracket MOUNTING BOLT, alloy steel socket head cap screw with a bright finish, use 2 per bracket. For the following models: all 1984-85 FJ600 models. Each:
    $ 1.95
    HCP22193 Aftermarket rear shock absorber timing belt bracket MOUNTING BOLT, alloy steel socket head cap screw with a black finish, use 2 per bracket. For the following models: all 1984-85 FJ600 models. Each:
    $ 1.95
    HCP23280 Aftermarket rear shock absorber timing belt bracket MOUNTING BOLT, bright 18-8 stainless steel. Use 2 per bracket. For the following models: all 1984-85 FJ600 models. Each:
    $ 2.95
    HCP22194 Aftermarket rear shock absorber timing belt bracket MOUNTING BOLT, 316 stainless steel socket head cap screw with a bright finish, use 2 per bracket. For the following models: all 1984-85 FJ600 models. Each:
    $ 3.95
    HCP23281 Aftermarket rear shock absorber timing belt bracket MOUNTING BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel. Use 2 per bracket. For the following models: all 1984-85 FJ600 models. Each:
    $ 4.95
    HCP4239 OEM rear shock absorber timing belt bracket mounting bolt FLAT WASHER, for all 1984-85 FJ600 models. Use 1 per bolt. Each:
    $ 7.95
    HCP26192 Aftermarket rear shock absorber timing belt bracket mounting bolt FLAT WASHER, bright zinc-plated alloy steel, for all 1984-85 FJ600 models. Use 1 per bolt. Each:
    $ 1.95
    HCP26193 Aftermarket rear shock absorber timing belt bracket mounting bolt FLAT WASHER, bright 18/8 stainless steel, for all 1984-85 FJ600 models. Use 1 per bolt. Each:
    $ 2.95
    HCP17110 Aftermarket rear shock absorber timing belt bracket mounting bolt FLAT WASHER, 316 stainless steel, dull finish, for all 1984-85 FJ600 models. Use 1 per bolt. Each:
    $ 3.95
    HCP26189 Aftermarket rear shock absorber timing belt bracket mounting bolt FLAT WASHER, black oxide-coated alloy steel, for all 1984-85 FJ600 models. Use 1 per bolt. Each:
    $ 3.95
    Air Inflation Valves and O-Rings:
    HCP5676 OEM rear shock absorber air fill valve CAP. Used on all XJ650 Turbo models, one on each shock. Each:
    $ 1.95
    HCP8274 OEM rear shock absorber AIR FILL VALVE, comes complete the internal stem core, its o-ring, and chrome cap. Used on all XJ1100 models, one on the left shock and two on the right shock. Each:
    $ 57.95
    HCP11890 OEM inner fork tube air joint brass AIR VALVE ONLY, comes complete the internal stem core and its o-ring. The chrome cap is not included. Used on all XJ1100 models, one on the left shock and two on the right shock. Each:
    $ 39.95
    HCP11876 OEM inner fork tube air joint air valve CHROME CAP, ribbed, dome-head style. Used on all XJ1100 models, one on the left shock and two on the right shock. Each:
    $ 19.95
    HCP2322 OEM rear shock absorber air valve or air hose O-RING, fits the following models: 1982-83 XJ650 Turbo (use 3 per system) and XJ1100 models (use 3 per system). Each:
    $ 7.95
    HCP14020 Aftermarket rear shock absorber air valve or air hose O-RING, fits the following models: 1982-83 XJ650 Turbo (use 3 per system) and XJ1100 models (use 3 per system). Each:
    $ 5.95
    HCP9194 Aftermarket AIR VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all 1982-83 XJ650 Turbo (use 3 per system) and XJ1100 models (use 3 per system). Each:
    $ 3.95
    HCP9194SET2 Aftermarket AIR VALVE STEM CORES, set of 2:
    $ 6.95
    HCP9196 Aftermarket AIR VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 5.95
    Shock Absorber Adjuster Tool:
    HCP7863 Aftermarket steering stem ring nut and shock absorber ADJUSTER TOOL, heavy-duty chrome plated spanner "wrench" is the correct size to work with all XJ-series bike steering stem ring nuts, as well as fitting the adjuster tab on most original rear shock absorbers (for those models that have non-air adjustable rear shocks). Very high quality, versatile tool to have in your box.
    $ 34.95
    Aftermarket Shock Absorbers:
    Okay, shocks are pretty simple devices----as are coil springs----and although a coil spring wrapped around a shock absorber is still called a "shock absorber" (go figure!), we all realize that although each component "does its own thing", they each work with and complement each other in determining not just the ride quality, but also the performance (handling, braking, and acceleration) characteristics of the bike.
    If it's time for a newly shocking experience, then lucky for you, because shock absorber technology and performance has improved dramatically since these bikes were built.
    SPRINGS: actually come in two basic styles, Linear Resistance and Progressive Resistance. Resistance is merely the ability of the spring to "resist" compression given a load acting on it.
    A spring with linear resistance characteristics will deflect equally in proportion to the load on it: for example, put a hypothetical linear spring under a 100-pound load, and it will compress by 1" in overall length. Put 200-pounds of weight on it, and it compresses a total of 2 inches; 300-pounds, 3" of compression, etc. That's a linear spring, a 1-to-1 straight-line relationship between load (weight) and compression.
    No factory springs are linear though......
    Because although a linear spring has very predictable deflection characteristics, they ride and handle terribly. All factory XJ springs are what are known as "progressive springs", meaning that it takes additional loading for each incremental inch of compression. So for example, a progressively-wound spring may still deflect 1" under the first 100-pounds of weight, but a 200-pound load will only deflect it a total of 1-3/4", while a 300-pound load may only result in a 2-3/8" compression. Equal additional amounts of weight (load) result in less and less compression......in other words, the spring gets PROGRESSIVELY harder to compress as the load increases.
    This increased resistance as the load increases results in a much more usable amount of control as applied to a shock absorber, as well as a much better ride quality. The springs (and combined spring/shock) can be really "soft" for absorbing small dips and bumps, and then get progressively stiffer as the load increases, as happens during spirited cornering, braking, or acceleration. In addition, as long as the progression of the spring resistance is increased in a continual manner---with no great leaps or surges in resistance rates throughout the entire range of spring travel---then it makes for a very predictable response, which is incredibly important for driver safety and confidence.
    Visually, you can look at a spring and tell whether it's a linear or progressive spring by observing the distance between adjacent coil windings: linear springs have equal spacing between all coils, top to bottom, while progressive-resistance springs having a different spacing between adjacent coils as you observe the entire spring. And, the tighter the spacing between the coils, the more the resistance....which is why the coils become much closer together as you approach the ends of a progressively-wound spring.
    SHOCK ABSORBERS: although many people think of a shock absorber as just "another kind of spring"----and although there is some truth to that thought----shock absorbers not only provide a supplementary spring-like quality, but they also perform the unique function of providing an "anti-spring" or "counter-spring" function that helps, once again, to provide a level of control to the suspension that is so important.
    What happens when a spring is compressed? It gains tension, stores the energy, and it resists the load and actually "fights against the load"---it wants to "snap back" to its original (or even past its original) at-rest position. This is NOT an endearing trait of a coil spring when used in a suspension....it makes the suspension into somewhat of a pogo-stick, boing-boing-boing until it finally comes to rest (and since a suspension, when in use while riding on anything except a perfectly flat, smooth surface, with absolutely zero braking or acceleration occurring, is ALWAYS involved in some type of action).
    Shock absorbers to the rescue! By its design, a shock absorber, via a variety of engineering design details, not only resists the compression force (as a spring does), but the shock absorber then "fights back" against the tendency of a coiled, tensed spring to want to snap instantly back into the at-rest spring position. By forcing fluid and sometimes gas through a series of valves and orifices, the shock absorber SLOWS DOWN this "instant rebound" tendency of the spring, again adding the measure of control and predictability that enhances ride quality, performance, and safety.
    TOGETHER, IN PERFECT HARMONY: what "shock absorber" engineers strive for is the balance between these two competing forces and components, in order to provide the best of all worlds. By studying, testing, and tweaking the variables of spring size, progressive spring rates, shock barrel size, types of fluid and valving within the shock, etc., they seek to provide the best overall combination. And as with anything in life, there are compromises, and there are expenses involved when trying to increase the overall performance level of a "shock". A well-designed and performing shock is the result of all these types of efforts and expenses, and is as much of an art as it is science.
    Two common features that can be used to increase the performance of a shock----and, which determines how much you can "custom-tune" the performance of a given shock to your individual bike, riding style, and personal preferences and characteristics----is via the use of spring "pre-load" adjusters and shock "rebound dampening" adjusters.
    Springs can benefit by having their "load" pre-tensioned, rather than being set at a fully at-rest position. The spring pre-load adjuster, at the bottom of the shock tube, allows the user (via a special shock "spanner wrench") to increase or decrease the amount of pre-loaded tension on the spring. ALL original and aftermarket shocks have these pre-load adjusters, although "high performance" shocks normally have more pre-load positions available than less expensive versions.
    Shocks can be enhanced through the addition of a variable, user-adjustable "rebound damper control" mechanism---usually in the form of a small thumbwheel adjuster that clicks into looser or stiffer rebound-resistance positions. Remember, this adjuster on the shock body controls how strongly the internal shock valving "fights back" against a compressed, tensioned spring's attempt to jump back as quickly as possible to its relaxed state.
    Rebound dampening controls are normally only found on higher-performance (and thus more expensive) shock absorbers. For example, all XJ550, all XJ650 (except Turbo), and all XJ700 models did NOT have rebound adjusters on the factory shocks, while all other models did have a user-controllable rebound adjustment mechanism.
    Of course, the more user controllability, the better, but at a price....and not just in the initial purchase price. "Dialing in" a high-performance shock, through trial-and-testing of all the different combinations of spring pre-loads and shock rebound rates, can be a time consuming (but very important and vast-improvement-when-done) type of task. For example, while the 12-Series, 14-Series, and 412-Series of Progressive Suspension shocks all feature a 4-position spring tension pre-load adjuster, they have NO shock rebound dampening adjustment available, at all.
    But the 418-Series of Progressive Suspension shocks have both a 4-position spring pre-load adjuster AND a 5-position shock rebound adjuster....giving a total of (5 x 4 = ) 20 different combinations of spring pre-load and shock rebound characteristics. Sorting through all of them is going to take a full afternoon, adjusting one, then the other, and going out on a repeatable "test-track" type of ride to see how the bike performs under all sorts of different conditions at each setting(s) combination, and which one you like the most.
    But like we said, when you get it "right", you'll know it, you'll feel it, and you'll probably realize that it was well worth your efforts!
    WARNING: although there are a number of extremely low-dollar "generic" shock absorbers that are available at large retailers, we caution you that such shock absorbers are not specifically valved, nor are their springs designed for the characteristics of XJ-series bikes (or, really, for ANY bikes). They are inexpensive because they are generic, and although that keeps their cost down, it also tends to keep their performance and durability way down, too.
    All shock absorbers (except for the 12-Series and 14-Series shocks) are sold as fully assembled pairs, and come with all mounting adapters and bushings, as well as illustrated mounting instructions. You will be pleasantly, and perhaps amazingly surprised, just how much of a difference a set of true performance shock absorbers will make in the ride and handling quality of your bike.
    NOTE: Progressive recommends the use of their HEAVY DUTY shock absorbers for single riders who weigh more than 200 pounds, or if most of your riding is done with a passenger or with heavy loads (such as in saddlebags, etc.).
    TIP: Rear suspension SAG is an important and almost-always overlooked factor in determining ride quality and rear suspension performance (handling and ride quality). Incorrectly set sag not only effects the performance of the shock, but also of your front forks because as the ride height in the rear changes, the amount and rate of how the weight of the bike is transferred to the front forks changes, too. Sag can (and should be) adjusted whenever you install new shocks on your bike, or, if it’s never been checked and adjusted before, now would be a good time to do it!
    http://www.factoryconnection.com/sag/
    Progressive Suspension Shock Absorbers:
    Progressive Suspension has been making motorcycle shock absorbers for over 20 years and is acknowledged as one of the leaders in the industry. We are now offering their line of replacement shock absorbers that not only perform exceptionally well----and are designed specifically for these model bikes----but also come in a variety of performance levels to fit almost any budget.
    14-Series: are the most economical shock in the Progressive Suspension line, and feature small-body "vintage" style shock bodies as used originally on all XJ550 and XJ650 (except Turbo) models. Shock bodies are black, and then you have a choice of either black or chrome springs (in standard or heavy-duty versions) . These classic 14-Series shocks feature a 4-position spring pre-load cam-adjuster, velocity-sensitive multi-stage valving, and come with a full assortment of installation bushings, a packet of adjuster grease, the cam adjuster tool, and complete installation instructions. These shocks provide an affordable alternative to replace your original worn-out shocks with while getting the great quality of the Progressive brand!
    As with the 12-Series shocks below, these 14-Series shock absorbers are just the shock body, so you'll also need to order (and install) the appropriate coil springs to be used with the bodies. Installation is fairly simple, and involves sliding the spring over an extended shock body and then compressing the spring (using your body weight) until the retainer clip can be installed. The heavy-duty springs may require some extra weight to compress enough to install the retainer, or you can use the tried-and-true "tourniquet" technique using some strong clothesline and a straight bar of some type and using the bar to twist the clothesline, thus compressing the spring.
    NOTE: Customer experience and use seems to indicate that use of the 14-Series standard-duty springs on all XJ550 models and the heavy-duty springs on the all XJ650 models seems to provide the best level of performance and handling.
    Shown below are the 12-Series shocks, which are basically identical in appearance to these 14-Series shocks:
    http://xjbikes.com/forums/index.php?threads/18014
    HCP9416 Progressive Suspension 14-Series "vintage-look" SHOCK ABSORBERS, shock bodies only. Springs need to be ordered separately from the choices listed below. Fits all XJ550 and XJ650 (except Turbo) models. Stock height. Pair:
    $ discontinued
    HCP9417 Progressive Suspension 14-Series BLACK STANDARD-DUTY SPRINGS, matched pair. The standard duty springs are recommended for all XJ550 models, and light-duty use on all XJ650 models except the XJ650RJ Seca. Pair:
    $ 129.95
    HCP9419 Progressive Suspension 14-Series CHROME STANDARD-DUTY SPRINGS, matched pair. The standard duty springs are recommended for all XJ550 models, and light-duty use on all XJ650 models except the XJ650RJ Seca. Pair:
    $ 129.95
    HCP9420 Progressive Suspension 14-Series CHROME HEAVY-DUTY SPRINGS, matched pair. These heavy-duty springs are recommended for all XJ550 models ridden primarily 2-up, and performance-oriented or heavy riders on all XJ650 models. Pair:
    $ 129.95
    12-Series: are the 2nd most popular shock in the Progressive Suspension line, and feature BLACK steel shock bodies, your choice of either black or chrome springs (in standard or heavy-duty versions), plastic upper spring cover caps, a 5-position spring pre-load cam-adjuster, and a full assortment of installation bushings, a packet of adjuster grease, the cam adjuster tool, and complete installation instructions. NOTE: these 12-Series shocks feature the same high-quality damper system as used in the more expensive 412-series shocks listed below.
    Unlike the 412-Series and 418-Series shocks, these 12-Series shock absorbers are just the shock body, so you'll also need to order (and install) the appropriate coil springs to be used with the bodies. Installation is fairly simple, and involves sliding the spring over an extended shock body and then compressing the spring (using your body weight) until the retainer clip can be installed. The heavy-duty springs may require some extra weight to compress enough to install the retainer, or you can use the tried-and-true "tourniquet" technique using some strong clothesline and a straight bar of some type and using the bar to twist the clothesline, thus compressing the spring.
    NOTE: Customer experience and use seems to indicate that use of the 12-Series standard-duty springs on all XJ550 models and the heavy-duty springs on almost all XJ650 and larger models seems to provide the best level of performance and handling.
    These style shocks can be seen pictured here on an XJ550 Seca model:
    HCP9405 Progressive Suspension 12-Series SHOCK ABSORBERS, shock bodies only. Springs need to be ordered separately from the choices listed below. Fits all XJ550, XJ650, 1981-83 XJ750, XJ900RK, and XJ1100 models. NOTE: XJ900 models may require the use of the HCP9440 travel limiters listed below. Stock height. Pair:
    $ 299.95
    HCP9406 Progressive Suspension 12-Series SHOCK ABSORBERS, shock bodies only. Springs need to be ordered separately from the choices listed below. Fits all XJ700 and 1985-86 XJ750-X models. Stock height. Pair:
    $ 299.95
    HCP9440 Progressive Suspension shock absorber TRAVEL LIMITER, required for use on all XJ900 and XS1100 models that is using a larger rear tire than stock, or has had rear fender mods done that bring the rear fender closer to the tire. Pair:
    $ 24.95
    HCP9407 Progressive Suspension 12-Series BLACK SPRINGS, matched pair. These standard duty springs are recommended for all XJ550 models, and light-duty use on all XJ650 models except the XJ650RJ Seca. Pair:
    $ 129.95
    HCP9411 Progressive Suspension 12-Series BLACK SPRINGS, matched pair. These springs are recommended for all XJ550 models ridden primarily 2-up, and performance-oriented or heavy riders on all XJ650 models. Pair:
    $ 129.95
    HCP9409 Progressive Suspension 12-Series BLACK SPRINGS, matched pair. These standard duty springs are recommended for all XJ700 non-X models, and light-duty use on all XJ700-X, all XJ750 non-X models, XJ900RK, and XJ1100 models. Pair:
    $ 129.95
    HCP9413 Progressive Suspension 12-Series BLACK SPRINGS, matched pair. These heavy-duty springs are recommended for performance-oriented or primarily 2-up riding on all XJ700-X models, all XJ750-X models, XJ900RK, and XJ1100 models. Pair:
    $ 129.95
    HCP9408 Progressive Suspension 12-Series CHROME SPRINGS, matched pair. These standard duty springs are recommended for all XJ550 models, and light-duty use on all XJ650 models except the XJ650RJ Seca. Pair:
    $ 129.95
    HCP9412 Progressive Suspension 12-Series CHROME SPRINGS, matched pair. These springs are recommended for all XJ550 models ridden primarily 2-up, and performance-oriented or heavy riders on all XJ650 models. Pair:
    $ 129.95
    HCP9410 Progressive Suspension 12-Series CHROME SPRINGS, matched pair. These standard duty springs are recommended for all XJ700 non-X models, and light-duty use on all XJ700-X, all XJ750 non-X models, XJ900RK, and XJ1100 models. Pair:
    $ 129.95
    HCP9514 Progressive Suspension 12-Series CHROME SPRINGS, matched pair. These heavy-duty springs are recommended for performance-oriented or primarily 2-up riding on all XJ700-X models, all XJ750-X models, XJ900RK, and XJ1100 models. Pair:
    $ 129.95
    412-Series: are the most popular shock in the Progressive Suspension line, and feature double-walled BLACK steel shock bodies, chrome springs, chrome upper and lower spring cover caps, a 5-position spring tension pre-load cam-adjuster, black upper and lower shock eyes, and a full assortment of installation bushings, a packet of adjuster grease, the cam adjuster tool, and complete installation instructions.
    NOTE: Customer experience and use seems to indicate that use of the 412-Series heavy-duty shocks on almost all XJ650 and larger models seems to provide a much better level of performance and handling at a minimal sacrifice in comfort.
    These style shocks can be seen pictured here, images at top of page 2:
    http://xjbikes.com/forums/index.php?threads/10875
    HCP9401 Progressive Suspension 412-Series SHOCK ABSORBERS, with chrome springs, STANDARD DUTY application for all XJ550 and XJ650 models, stock height. Pair:
    $ 399.95
    HCP9402 Progressive Suspension 412-Series SHOCK ABSORBERS, with chrome springs, HEAVY DUTY application for all XJ550 and XJ650 models, and STANDARD DUTY application for all XJ750 non-X models, stock height. Pair:
    $ 399.95
    HCP9403 Progressive Suspension 412-Series SHOCK ABSORBERS, with chrome springs, STANDARD DUTY application for all XJ700-X and HEAVY DUTY for all XJ700 non-X models, stock height. Pair:
    $ 399.95
    HCP9414 Progressive Suspension 412-Series SHOCK ABSORBERS, with chrome springs, HEAVY DUTY application for all XJ700-X and XJ750-X models, stock height. Pair:
    $ 399.95
    HCP9404 Progressive Suspension 412-Series SHOCK ABSORBERS, with chrome springs, STANDARD DUTY application for all XJ900RK and XJ1100 models, and HEAVY DUTY for all XJ750 models, stock height. Pair:
    $ 399.95
    HCP9415 Progressive Suspension 412-Series SHOCK ABSORBERS, with chrome springs, HEAVY DUTY application for all XJ900RK and XJ1100 models, stock height. Pair:
    $ 399.95
    NOTE: XJ900RK models may require the use of suspension travel limiters when using any of the above shocks:
    $ 24.95
    416-Series Air Shocks: can be used as stock replacements for the XJ650 Turbo and XJ1100 models, although they differ a bit in appearance compared to stock. These shocks have a heavy-duty BLACK steel shock body, a chrome upper spring cover, and full-length black rubber accordion lower boots. The aluminum air chamber, in conjunction with the heavy-duty spring and combined with their velocity-sensitive, multi-stage damper valving insures precise control and the adjustability to suit your specific needs. These shocks come completely assembled, and with all the air lines, fittings, instructions, and installation bushings needed.
    HCP9421 Progressive Suspension 416-Series AIR SHOCK ABSORBERS, featuring highly polished covers with black lower accordion boots. Although only the XJ650 Turbo and XJ1100 models used rear air suspension originally, these shocks will also fit all of the XJ550, XJ650, and 1981-83 XJ750 bikes, too. Pair:
    $ 599.95
    HCP9442 Progressive Suspension 416-Series AIR SHOCK ABSORBERS, featuring highly polished covers with black lower accordion boots. These shocks will fit all XJ700 and XJ750-X models. Pair:
    $ 599.95
    418-Series: these are not just the "big daddy" of the Progressive Suspension line, they are the 800-pound Gorillas of the aftermarket shock absorber world, and feature ALL the goodies: huge aircraft-grade polished billet aluminum or double-walled CHROME steel shock bodies, gas-charged for fade-free performance, a 5-position adjustable rebound rate damper, a 4-position spring pre-load cam-adjuster, hard-chromed 4130 steel shafts, and a full assortment of installation bushings, a packet of adjuster grease, the cam adjuster tool, and complete installation instructions.
    NOTE: Progressive recommends the use of their HEAVY DUTY shock absorbers for single riders who weight more than 200 pounds, or if most of your riding is done with a passenger or with heavy loads (such as in saddlebags, etc.). However, with these 418-series shocks, their heavy-duty designation is overkill on the smaller XJ550 and XJ650 models, and we do not recommend nor offer them for those applications.
    HCP9429 Progressive Suspension 418-Series SHOCK ABSORBERS, polished billet aluminum bodies with CHROME springs, HEAVY DUTY application for all XJ700-X and XJ750-X models, stock height. Pair:
    $ 599.95
    430-Series: are the latest and greatest "Show-Offs" in the Progressive Suspension line-up.....these are going to turn some heads! Featuring a brilliant chrome-plated steel shock body and mounting ears, they are available with either matching chrome or contrasting black springs and spring top caps, and the incorporate a variety of cutting-edge design techniques to provide the ultimate in appearance and performance:
    - A high pressure gas-charged, mono-tube design features their deflective disk damping to insure high performance ride control.
    - Threaded pre-load adjusters allow for tool-less adjustment, and thus effortless tuning of ride quality.
    - Machined aluminum spring perches and sleek, modern, "street rod" styling.
    - Available in both an all-chrome design (chrome body, springs, and spring top caps), or with contrasting black anodized springs and spring top caps.
    Each pair of shocks comes with a full assortment of installation bushings, a packet of adjuster grease, and complete installation instructions.
    NOTE: Customer experience and use seems to indicate that use of the 430-Series heavy-duty shocks on almost all XJ650 and larger models provides a much better level of performance and handling at a minimal sacrifice in comfort.
    These style shocks can be visualized here:
    http://www.progressivesuspension.com/metric/430series/index.html
    HCP17841 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, all-chrome bodies with chrome springs and spring caps, STANDARD DUTY application for all 1981-83 XJ750 models, and HEAVY DUTY for all XJ550 and XJ650 models. Stock height. Pair:
    $ 599.95
    HCP17840 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, with chrome bodies and black springs and spring caps, STANDARD DUTY application for all 1981-83 XJ750 models, and HEAVY DUTY for all XJ550 and XJ650 models. Stock height. Pair:
    $ 599.95
    HCP17843 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, all-chrome bodies with chrome springs and spring caps, HEAVY DUTY application for all 1981-83 XJ750 models, and STANDARD DUTY for all XJ900, XJ1100, and XS1100 models. Stock height. NOTE: all XJ900 and XS1100 models may require the use of the HCP9440 suspension travel limiters when using any of the above 430-series shocks. Pair:
    $ 599.95
    HCP17842 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, with chrome bodies and black springs and spring caps, HEAVY DUTY application for all 1981-83 XJ750 models, and STANDARD DUTY for all XJ900, XJ1100, and XS1100 models. Stock height. NOTE: all XJ900 and XS1100 models may require the use of the HCP9440 suspension travel limiters when using any of the above 430-series shocks. Pair:
    $ 599.95
    HCP17849 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, all-chrome bodies with chrome springs and spring caps, HEAVY DUTY application for all XJ900, XJ1100, and XS1100 models. Stock height. NOTE: all XJ900 and XS1100 models may require the use of the HCP9440 suspension travel limiters when using any of the above 430-series shocks. Pair:
    $ 599.95
    HCP17848 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS with chrome bodies and black springs and spring caps, HEAVY DUTY application for all XJ900, XJ1100, and XS1100 models. Stock height. NOTE: all XJ900 and XS1100 models may require the use of the HCP9440 suspension travel limiters when using any of the above 430-series shocks. Pair:
    $ 599.95
    $ 24.95
    HCP17845 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, all-chrome bodies with chrome springs and spring caps, STANDARD DUTY application for all XJ700-X models and XJ750-X models, and HEAVY DUTY for all XJ700 non-X models, stock height. Pair:
    $ 599.95
    HCP17844 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, with chrome bodies and black springs and spring caps, STANDARD DUTY application for all XJ700-X and XJ750-X models, and HEAVY DUTY for all XJ700 non-X models, stock height. Pair:
    $ 599.95
    HCP17847 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS, all-chrome bodies with chrome springs and spring caps, HEAVY DUTY application for all XJ700-X and XJ750-X models, stock height. Pair:
    $ 599.95
    HCP17846 Aftermarket Progressive Suspension 430-Series SHOCK ABSORBERS with chrome bodies and black springs and spring caps, HEAVY DUTY application for all XJ700-X and XJ750-X models, stock height. Pair:
    $ 599.95
    Rust Removal and Prevention Fluids:
    rr4) Concentrated RUST REMOVER magically dissolves rust on all iron-based metals. Spray or wipe directly onto rusty parts, or immerse the items in a container full of this solution (diluted), let it work, then rinse off. Highly concentrated, easy to use, leaves the metal surfaces grease-free and ready for further processing or finishing. GREAT FOR DE-RUSTING THE INSIDE OF GAS TANKS!
    HCP12358 Aftermarket RUST DESTROYER FLUID, in a 16-ounce plastic bottle. Best to transfer into an old windex spray bottle (etc.) and use with a spray nozzle. After use, it is recommend that the de-rusted parts be immediately painted (or similar) or coated with fogging oil, lubricant, or other surface finish to prevent flash surface-rusting of the newly cleaned parts. Each:
    $ 39.95
    Here are a few other good ways to de-rust metal products:
    - soak iron (steel) parts in heated vinegar (doesn’t matter what kind) overnight, then rinse with clean water. and finally spray with fogging oil (or similar) to prevent rust from re-forming.
    http://www.mopedarmy.com/wiki/Removing_rust_from_a_gas_tank
    http://www.htpaa.org.au/article-electro.php
    http://xjbikes.com/forums/index.php?threads/32838
    http://xjbikes.com/forums/index.php...val-no-frills-easiest-fastest-cheapest.48196/
    http://www.xjbikes.com/forums/threads/teds-2nd-82-xj750-maxim-bobber-project.47929/#post-478002
    http://www.practicalmachinist.com/vb/general-archive/rust-removal-using-molasses-90452/
    HCP20866 Aftermarket industrial-strength RUST PREVENTION COATING, in a standard 10-ounce aerosol can. This protectant goes on clear and prevents rust from forming on all surfaces (including bare metal) for up to a year, even in an outdoor environment. Can be applied over painted surfaces, or easily removed with mineral spirits. Great way to protect "work in progress" type projects.
    $ 34.95
    HCP20867 Aftermarket industrial-strength RUST PREVENTION COATING, in a standard 10-ounce aerosol can. Heavy-duty formula goes on clear, and then dries to a wax-like finish, prevents rust from forming on all surfaces (including bare metal) for up to a year, even in humid or outdoor environments. Easily removed with mineral spirits. Great way to protect "work in progress" type projects.
    $ 37.95
  17. chacal
    e6
  18. chacal
    e7
  19. chacal
    e8
  20. chacal
    e9
  21. chacal
    e10
Thread Status:
Not open for further replies.
