XJ PARTS CATALOG, SECTION D: ELECTRICAL SYSTEM
Discussion in 'XJ4Ever - Supporting Vendor' started by chacal, Oct 12, 2013.
Thread Status:
Not open for further replies.
  1. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Electrical System Overview.
    ELECTRICAL SYSTEM OVERVIEW:
    Electrical problems can be terribly difficult to diagnose properly. Electrical and fuel-related problems manifest themselves in the same ways: hard starting, mis-firing, poor performance, back-firing, etc.
    Although the electrical systems on XJ bikes are fairly durable, there are a number of known, common problem areas on these bikes, which are compounded by the fact that these bikes are 25+ years old.
    The fusebox is the most critical area: the stock one may have been adequate in 1981, but it's now old, outdated, and ready for the dust-bin of history. We carry replacement ATC-style fuseboxes and in-line fuse holders which allow you to easily upgrade your original.
    The generator brushes wear down over time, change their electrical characteristics as they age, and need periodic replacement. They are available as complete brushes with holder assemblies, or brushes only. By the way, in a technical sense, your bike is really equipped with an Alternator, not a Generator (as Yamaha calls it), since the output of that electrical-generating device is an alternating (AC) electrical current, which is then rectified into a direct (DC) current via---you guessed it---the rectifier section of your Regulator box......
    Anyway: finally, in a general electrical system sense, the wiring harness on your bike is getting old---and like most vehicle wiring harnesses from this era, they aren't (and never were) the most robust things ever made. Corrosion, weak connectors, and other assorted issues will cause you all sorts of headaches and the agony of electrical troubleshooting nightmares if not addressed and remedied.
    An exceptional write-up on the electrical system on XJ-series bikes---the good, the bad, and the ugly---can be found at:
    http://web.archive.org/web/20071214...ies.com/MotorCity/Speedway/7795/xjfaqbig.html
    I highly recommend that you visit that site and PRINT OUT the FAQ (you never know when a web page might disappear from the web), as it is the "Electrical Bible" for XJ owners!
    And understanding the importance of (and how to measure) voltage drops in circuits will go a long way to helping you successfully diagnose and solve electrical problems on your bike:
    http://www.motorcycleproject.com/text/volt_drop_test.html
    and here’s an easy-to-understand guide to how to perform a voltage-drop test:
    http://www.agcoauto.com/content/news/p2_articleid/330
    Corrosion on wires (the greenish "skin" that forms on exposed wire) is a real deal-killer when it comes to transmitting electricity properly...............and here's how to make it go away:
    www.instructables.com/id/How-to-perfectly-clean-wires-in-minutes
  2. chacal
    SECTION D:
    ELECTRICAL SYSTEM TOOLS:
    Electrical System Tools:
    et1) Aftermarket electrical test MULTIMETERS, the most useful tool you'll ever own for working on electrical systems. High quality test instruments make your life easier, and give you the accurate measurements needed to diagnose and track down electrical system issues.
    http://nadp.sws.uiuc.edu/cal/PDF/MulltimeterUse.pdf
    https://learn.sparkfun.com/tutorials/how-to-use-a-multimeter?_ga=1.238289411.262114863.1436923213
    http://www.masonmonitoring.com/pdf/support/UsingMultimeter.pdf
    https://learn.sparkfun.com/tutorials/how-to-read-a-schematic
    HCP7135 Aftermarket ANALOG (moving needle) MULTIMETER, more accurate than digital meters but a bit less user-friendly. These 6-function meters measure DC voltages (0-100), AC voltages (0-750), Resistance (0-10 megaohms), DC Current (0-10A), and has a small battery testing dial. NOTE: this multimeter does NOT have the capability to perform diode-checking, which can be a useful function when working on these bikes (although, to be honest, a diode failure is a rare event).
    $ 89.95
    HCP7136 Aftermarket DIGITAL (numerical LCD display) MULTIMETER, less accurate than analog meters but a bit more user-friendly. This 5-function meters measure DC voltages (0-1000), AC voltages (0-700), Resistance (0-2 megaohms), DC Current (0-10A), and Diode Checking. NOTE: this multimeter DOES have the capability to perform diode-checking, which can be a useful function when working on these bikes (although, to be honest, a diode failure is a rare event). Accuracy: DC voltage +/- 0.7%, AC voltage +/- 1.2%, DC current +/- 1%, Resistance +/-1%.
    $ 89.95
    HCP10589 Aftermarket TIMING LIGHT, inductive pickup 12V powered stroboscopic timing light is used to check the proper functioning of your ignition system at the pick-up coils. Alligator clips for easy power hook-up to the battery, and a clamp-over inductive feed clips over the #1 plug wire. Super-bright xenon-bulb makes daytime use possible.
    $ 49.95
    Battery Tools, Testers, Chargers, and Hardware:
    HCP10448 Aftermarket battery testing HYDROMETER. This is a real hydrometer, not the cheapo 4-dollar special you usually see at the auto parts store. It measure the specific gravity of the electrolytic fluid, which is the proper way to test its condition. Those little "floating balls" testers are barely worth the plastic that they're made of! This professional hydrometer gives you temperature-adjusted specific gravity readings, which is the only accurate method of measurement. And yes, you can use these on your car or tractor or boat battery, too........
    $ 18.95
    HCP10542 Aftermarket battery testing MINI-HYDROMETER. This is a cheapy, "floating ball" style hydrometer, but it's small size makes it easier to use on motorcycle batteries. It's better than not having one at all! And yes, you can use these on your car or tractor or boat battery, too........
    $ 14.95
    fbc3) Aftermarket automatic BATTERY CHARGERS. A fully automatic battery charger is the best type to use to provide "trickle charge" to deep-cycle batteries, as it prevents the overcharge conditions that dramatically reduce the life of a battery.
    HCP9962 Aftermarket automatic BATTERY CHARGER, standard bench-top style. Features that a 1.5A charger rate can be used to re-charge a dead battery quickly or maintain a trickle-charge for batteries that see infrequent use. Automatically changes from full-charge to float-mode monitoring for the extended battery life and no worries about over-charging. Reverse-hookup protection, LED power-on/charging/charged indicator lights, CSA-certified, and comes with both 50A standard spring clamps or the easy-to-use permanent plug-in connector to permanently attach a charging "pigtail" connector to the battery for instant access. Can be safely used on conventional and AGM style batteries; not recommended for gel-cell batteries.
    $ 79.95
    HCP28172 Aftermarket fully automatic BATTERY MAINTAINER-CHARGER. This compact wall-transformer style 6V and 12V charger features the latest solid-state, intelligent technology that allows quick, safe, and efficient charging of all battery types: conventional lead acid, maintenance-free lead acid, marine deep-cycle, AGM, gel-cell, and even lithium-ion. Features include: will safely charge even a fully dead battery (one that reads 0 volts), an automatic “de-sulphation” mode that can rescue and extend the life of older batteries, a thermal compensation sensor to prevent under- or over-charging, short-circuit protection, open-circuit protection, over-heat protection, over-charge protection, reverse-hookup protection, and spark protection. Can be hooked directly to the battery terminals with included ring terminals (a water-proof disconnect port is built into the 9-foot long lead wires), or you can use it with the included thin, “needle-nose” style clamps. Automatically changes from full-charge to float-mode monitoring for extended battery life and no worries about over-charging…..you can actually leave this charger hooked up to your battery 24/7 for as long as you want (like, all winter long……..) without risking battery damage (in fact, for all conventional lead-acid batteries, you should attempt to maintain it at 100% charge to maximize the battery life). Works on 110-240V AC current, 1-amp (max.15W) charging current, water-proof housing, 3-year warranty. This is most affordable and best “home-use” battery charger on the market/
    $ 49.95
    HCP28173 Aftermarket fully automatic BATTERY SUPER-CHARGER, all the same features as the HCP28172 above, but this charger feature more power output (2A, max. 30W charging current) and is a “mini-tabletop” design…..about 5.5” x 2.5”….no bigger than a typical computer mouse!
    $ 79.95
    HCP10449 Aftermarket automatic BATTERY CHARGER, compact wall-transformer style. Features that a 1.3A "pulse-mode" charger that can be used to re-charge a dead battery or maintain a trickle-charge for batteries that see infrequent use. Automatically changes from full-charge to float-mode monitoring for the extended battery life and no worries about over-charging. Comes with both alligator clips or the easy-to-use permanent plug-in connector to permanently attach a charging "pigtail" connector to the battery for instant access. Can be safely used on conventional and AGM style batteries; not recommended for gel-cell batteries.
    $ 89.95
    HCP10451 Aftermarket automatic BATTERY MAINTENANCE CHARGER, compact wall-transformer style. Features that a 800ma (0.8A) charger rate, perfect for maintaining a trickle-charge for batteries that see infrequent use. Automatically changes from full-charge to float-mode monitoring for the extended battery life and no worries about over-charging. Reverse-hookup and short-circuit protection, LED power-on/charging/charged indicator lights, waterproof, and comes with both alligator clips or the easy-to-use permanent plug-in connector to permanently attach a charging "pigtail" connector to the battery for instant access. No bigger than a typical computer "mouse"! Can be safely used on conventional and AGM style batteries; not recommended for gel-cell batteries.
    $ 69.95
    HCP10452 Aftermarket battery charger EXTENSION CABLE, 12-foot length. Don't want to bring your bike over to your charger? Then this set of 12-foot long charger-to-battery leads extender cable allows you to leave the battery charger close to a wall outlet, and extend the power leads to wherever your bike is located! Quick-connect feature allows plug-and-play installation with all of the above chargers. Very convenient.
    $ 24.95
    et3) Aftermarket motorcycle-sized BATTERY JUMPER CABLES. Small sized end clips more easily reach into the cramped areas where your battery lives, making it somewhat easier to jump-start a dead bike. NOTE: NEVER attach jumper cables to your battery unless your ignition key is OFF......or your risk frying a lot of expensive electrical components!
    HCP1608 Aftermarket 5-foot long standard duty JUMPER CABLES, with alligator clip ends.
    $ 37.95
    Electrical System Chemicals and Supplies:
    NOTE: it’s important to understand the difference between the two types of greases used with electrical connectors. Di-electric grease acts as an electrical insulator: it does not allow current to flow through it easily, and is basically used to “waterproof” a connector assembly. Although it is an insulator, the act of engaging two electrical connectors together (i.e. pushing a male connector into a female connector) will push away the grease on the metal-to-metal contact portion of the terminals, so those remain electrically conductive (good) while also insulating all the other surfaces against moisture and oxygen intrusion (very good). This insulating property of di-electric grease makes it great for use in connector shells, etc. as terminal corrosion is one of the greatest contributors to electrical system problems in vehicles (especially older ones)……this is why most modern vehicles use “sealed” connector shells (the most popular is the Delphi Automotive brand called “weather pack” or “weatherpak”) to keep oxygen and moisture away from the metal terminals. Although you can retrofit these style connectors to older harnesses, it takes a LOT of time, money, and effort to do so.
    Now, contrast the insulating properties of di-electric grease to the electrically conductive properties of Conductive Grease, which, as its name implies, the grease itself (which contains many fine carbon particles) conducts electricity. Of course, being a “grease”, it too will also protect and insulate a terminal coated with it from moisture, corrosion, etc…..same as di-electric grease. But…it’s conductive, and if the terminal it coats is electrically “hot”, so is the grease (i.e. touching the grease alone will shock you!).
    So a conductive grease is great when you need protection plus current flow……ideal for frame (or battery) grounds to the frame, etc. You could---if you are totally anally-retentive---coat (for instance) a battery post internally with conductive grease, and then cover all of that with di-electric grease.
    So, think of these grease as two different electrical system “tools”, and use accordingly.
    et2) Aftermarket electrical connector DI-ELECTRIC GREASE coats, insulates, and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Smear some of this goo on each and every one of your electrical connectors (after you've cleaned them with some sandpaper or terminal cleaner) and you'll be doing yourself a big favor!
    HCP14059 Aftermarket packet of DI-ELECTRIC GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc.
    $ 4.95
    HCP7528 Aftermarket tube of DI-ELECTRIC GREASE, big 3-ounce squeeze tube.
    $ 21.95
    NOTE: the following 2 product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP20940 Aftermarket tube of DI-ELECTRIC GREASE, 3.3-ounce aerosol can of marine grade grease, with adjustable nozzle size to tailor the grease output bead size to minimize slop and waste and making application much easier. 1-2 cans will do all connectors on an entire bike harness.
    $ 24.95
    et14) Aftermarket electrical connector CONDUCTIVE GREASE coats and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Unlike the di-electric grease listed above, which is an insulator (non-conductive), this carbon-based grease is electrically conductive and has multiple applications (such as battery terminal posts (internally), frame grounds, etc.).
    HCP27923 Aftermarket packet of CONDUCTIVE GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc. Even tiny amounts (that you can barely see) will create minimal electrical resistance, so be careful with this stuff around capacitors and such. It gets everywhere, will stain your hands and clothing and take three days to wash off, and smells like some of the worst goop you've ever smelled. Use a toothpick for application. Don't eat it. Wear gloves. 2-gram pouch goes a long way.
    $ 6.95
    cps2) Aftermarket high-quality CROCUS CLOTH. Unlike sandpaper or emery paper, crocus cloth is a super-fine, cloth-backed soft abrasive that doesn’t “shed” particles during use, and is just the thing for burnishing and polishing of copper electrical contact, like the alternator rotor and starter motor commutators. Sold in a 2” wide x 1-foot long strip, enough for polishing many a commutator or contact.
    HCP21378 Aftermarket strip of CROCUS CLOTH, measures 12” x 2”. Each:
    $ 4.95
    NOTE: the following 3 product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10493 Aftermarket battery post TERMINAL SEALER helps keep corrosion from forming on the battery terminals. Fast drying and leaves no residue. Comes in a 6-ounce aerosol can.
    $ 12.95
    HCP9762 Aftermarket miracle-goo black LIQUID ELECTRICAL TAPE is easier to use than traditional tape products, especially in close-in locations. Great for sealing crimped wire terminal ends to the wire and serves as a good alternative or supplement to shrink tubing. Just brush it on and let it dry! Comes in a 4-ounces brush-top can.
    $ 12.95
    HCP10508 Aftermarket electrical CONTACT CLEANER is a good general purpose cleaner and de-greaser. Will not harm plastic terminal connector blocks. Fast drying and leaves no residue. Comes in a 16-ounce aerosol can.
    $ 14.95
    HCP12923 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 20-foot roll.
    $ 8.95
    HCP13134 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 66-foot roll, almost enough to do one complete harness.
    $ 16.95
    Additionally, most harnesses had a few short turns of COLORED VINYL ELECTRICAL TAPE WRAP to provide visual identification of "what connector goes where?" during harness assembly and installation. Always located just by the connector shell, about 3-4 turns of this tape was used to both tape off any vinyl sleeve and to properly identify what the connector plugged into. Used primarily at the TCI connector (from the pick-up coils) and at the various small "cube" style relays (headlight relays, sidestand safety switch relays, etc.). Since all of these harness connector shells are the same style and type (4-position, horizontally oriented 2-over-2), this small tape wrap served as a way of indicating which of these many identical connectors went to which component.
    HCP13130 Aftermarket harness bundle YELLOW VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on XJ700-X and XJ750-X models, and at the headlight relay connector on all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models.
    $ 7.95
    HCP13131 Aftermarket harness bundle RED VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on 1982-83 XJ650 Maxim models, all '81-83 XJ750 models, and all XJ700 non-X models, and at the fuel pump relay connector on all XJ650 Turbo models.
    $ 7.95
    HCP13132 Aftermarket harness bundle BLUE VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ550 models, at the emergency stop switch relay connector on all XJ650 Turbo models, and for the sidestand safety switch relay connector on all XJ550 models, all '82-83 XJ650 models, all XJ750 models, XJ900RK and XJ1100 models.
    $ 7.95
    HCP13133 Aftermarket harness bundle GREEN VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ650RJ Seca and XJ1100 models.
    $ 7.95
    et26) Aftermarket electrical device SWITCH LUBRICANT is a specially formulated, electrically non-conductive penetrating lube that is recommended on control switch turn signal contacts and headlight switching contacts. 10-gram squeeze tube has applicator tip for precision use.
    HCP14066 Aftermarket tube of electrical SWITCH LUBRICANT.
    $ 16.95
    et27) Aftermarket electrical INSTRUMENT OIL is a highly refined light oil for use on speedometer heads, tachometers, gauges, mechanical clocks, etc. Will not congeal even at 50-below-zero! Extra-slow rate of evaporation makes sure that it provides lubrication for a long, long time. 1-ounce pen has an applicator needle tip for precision use.
    HCP20852 Aftermarket hi-performance INSTRUMENT OIL, comes in a handy applicator pen. Oil-based triple-processed lubricant eliminates contaminants that would cause gumming or corrosion product is what we use and recommend for freeing stuck fork tube cap bolts.
    $ 37.95
    HCP10540 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery box with a sharp knife or a pair of scissors. For all XJ550, XJ650, XJ700, XJ750, and XJ900RK models.
    $ 9.95
    HCP10541 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery tray with a sharp knife or a pair of scissors. For all XJ1100 models.
    $ 13.95
    HCP10580 Aftermarket acid-neutralizing BATTERY TERMINAL PROTECTORS, thin, round felt mat circles are pressure-treated with a battery-acid neutralizing chemical. Placed under the battery terminal posts, they help prevents any spills or discharge from the battery from creating terminal corrosion. Trim and size to fit your battery posts with a sharp knife or a pair of scissors. Order 1 per terminal, 2 per battery. Each:
    $ 3.95
  3. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Electrical System Wiring: Fuseboxes
    WIRING SYSTEM:
    FUSEBOXES, FUSEHOLDERS, AND FUSES:
    COMMENTS: your stock fusebox was marginal, at best, and that was 20+ years ago. Replacing it with a modern style fuse panel or in-line fuse holders such as the styles listed below in the Replacement Fuseboxes section will prevent frustrating, expensive, and potentially dangerous electrical system problems for years to come.
    The following models used a fusebox utilizing four "glass tube" AGC fuses with one 20A main fuse, and three 10A fuses for the ignition, turn signal, and headlight circuits: all XJ550 models, all XJ650 models, 1983 XJ750 Maxim and XJ750 Midnight Maxim models, and the main fusebox on XJ1100 models.
    These models used a fusebox utilizing four "glass tube" AGC fuses that contained one 30A main fuse, and three 10A fuses for the ignition, turn signal, and headlight circuits: 1982 XJ750 Maxim model, all XJ750 Seca models, and the XJ900RK Seca.
    In addition, the following models used a separate single "glass tube" 5A AGC fuse, within its own small in-line holder, for the computerized gauge cluster: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. This fuseholder is certainly a candidate for updating with the 10A ATO style in-line fuse holder HCP7122 listed below.
    XJ700 models used two separate fuse panels: one that contained the four secondary circuits, including two 10A fuses, and two 15A fuses, which is located within the instrument warning lights panel; and a separate 30A main circuit in-line fuse holder was located under the seat. These bikes used the later push-in style ATC fuses in the dash fuse panel from the factory; the 30A main circuit fuses were still the older "glass tube" AGC style fuse, and that is certainly a candidate for updating with the 30A ATC style in-line fuse holder HCP6833 or HCP16777 listed below.
    1978-79 XS1100 models use a single fusebox utilizing four "glass tube" AGC fuses with one 30A main fuse, one 20A signals circuit fuse, and two 10A fuses for the ignition and headlight circuits. These models also used a small “accessory terminal” which held a single 10A fuse, and which allowed the for easy installation of any accessory circuit that the owner which to create (or, for use with the factory optional front fairing).
    XJ1100 an 1980-81 XS1100 models also used two separate fuse panels: one that contained four secondary circuits, which is located behind the right side frame panel; along with a 30A main fuse in a separate in-line fuse holder that uses the old glass-style fuse, and both are certainly candidates for updating with the ATC style fusebox and fuseholder. These models also used a small “accessory terminal” which held a single 10A fuse, and which allowed the for easy installation of any accessory circuit that the owner which to create (or, for use with the factory optional front fairing).
    ORIGINAL STYLE "GLASS-TUBE" FUSEBOXES:
    If you're doing a "museum-quality" restoration, where every detail has to be period-correct, then you'll want to consider using an original reproduction FUSEBOX that is faithful to the original design, style, and appearance, right down to the included glass fuses!
    These fuseboxes come with an already-installed 8-position plastic terminal block on the fusebox lead wires----and matching connector block and terminals for the harness side wires----which makes installation and maintenance tasks much easier. The entire fusebox can be easily removed from the bike, (or the entire airbox filter lid can be removed, on models that have the fuse panel screwed to the lid) since it's on its own little stub-harness now! If the original direct-wired method is desired, you can always remove the connector block, and tie into your original harness wires, using the butt connectors listed below. You will need 6 of the 18-22 gauge connectors and 2 of the 14-16 gauge connectors in order to convert these fuseboxes to a direct-wire application.
    HCP11182 Aftermarket ORIGINAL STYLE FUSEBOX, with installed stub harness and connector block, proper orientation for all XJ550, all XJ650 (except Turbo), and all 1983 XJ750 Maxim and Midnight Maxim models. Comes with original glass fuses (1 x 20A and 3 x 10A).
    $ 59.95
    HCP10444 Aftermarket ORIGINAL STYLE FUSEBOX, with installed stub harness and connector block, proper orientation for all 1984-85 FJ600, XJ650 Turbo, and XJ1100 models. Comes with original glass fuses (1 x 20A and 3 x 10A).
    $ 52.95
    HCP24652 Aftermarket ORIGINAL STYLE FUSEBOX, with installed stub harness and connector block, proper orientation for 1982 XJ750 Maxim, all 1981-83 XJ750 Seca and XJ750 Euro models, and all XJ900 models. Comes with original glass fuses (1 x 30A and 3 x 10A).
    $ 59.95
    HCP24654 Aftermarket ORIGINAL STYLE FUSEBOX, with installed stub harness and connector block, proper orientation for 1984 XJ750RL Seca models. Comes with original glass fuses (1 x 30A, 1 x 20A, and 2 x 10A).
    $ 59.95
    HCP13045 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 18-22 gauge. Each:
    $ 1.95
    HCP13045SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTORS, for wires that are both 18-22 gauge. Set of 10:
    $ 16.95
    HCP13046 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 14-16 gauge. Each:
    $ 1.95
    HCP13046SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTORS, for wires that are both 14-16 gauge. Set of 10:
    $ 16.95
    HCP14606 OEM original fusebox FUSEHOLDER CLIP TERMINAL, fits into stock factory fuseboxes, crimp-on, open-barrel style tin-plated brass terminals fits all stock XJ-series fuseboxes that use glass fuses. Use 2 per circuit, a total of 8 per fusebox. Each:
    $ 12.95
    HCP24811 Aftermarket fusebox FUSEHOLDER CLIP TERMINAL, fits into stock factory fuseboxes, crimp-on, open-barrel style brass terminals fits all stock XJ-series fuseboxes that use glass fuses. Use 2 per circuit, a total of 8 per fusebox. Each:
    $ 8.95
    HCP23089 Aftermarket original-style fusebox FUSEHOLDER CLIP TERMINALS WITH WIRES, fits into stock factory fuseboxes. This set of terminals with attached wire leads will perfectly replace your commonly broken original fuseholder clips. This set of 2 clips with attached wire leads are for the MAIN CIRCUIT and has the proper 14-gauge solid red wire leads attached. Fuse not included. Fits all XJ models except XJ700, XJ750-X, and XJ1100 models. Wire leads will need to be spliced, soldered, or otherwise attached to your original wire leads (such as with the butt connectors listed above). Each set:
    $ 23.95
    HCP23090 Aftermarket original-style fusebox FUSEHOLDER CLIP TERMINALS WITH WIRES, fits into stock factory fuseboxes. This set of terminals with attached wire leads will perfectly replace your commonly broken original fuseholder clips. This set of 2 clips with attached wire leads are for the SIGNALS CIRCUIT and has the proper 18-gauge solid brown wire leads attached. Fuse not included. Fits all XJ models except XJ700, XJ750-X, and XJ1100 models. Wire leads will need to be spliced, soldered, or otherwise attached to your original wire leads (such as with the butt connectors listed above). Each set:
    $ 23.95
    HCP23091 Aftermarket original-style fusebox FUSEHOLDER CLIP TERMINALS WITH WIRES, fits into stock factory fuseboxes. This set of terminals with attached wire leads will perfectly replace your commonly broken original fuseholder clips. This set of 2 clips with attached wire leads are for the IGNITION CIRCUIT and has the proper 18-gauge red with white tracer stripe wire leads attached. Fuse not included. Fits all XJ models except XJ700, XJ750-X, and XJ1100 models. Wire leads will need to be spliced, soldered, or otherwise attached to your original wire leads (such as with the butt connectors listed above). NOTE: some models used solid brown wires for the ignition circuit, in which case you can either use these (which we recommend doing), or, you can use the HCP23090 set above. Each set:
    $ 23.95
    HCP23092 Aftermarket original-style fusebox FUSEHOLDER CLIP TERMINALS WITH WIRES, fits into stock factory fuseboxes. This set of terminals with attached wire leads will perfectly replace your commonly broken original fuseholder clips. This set of 2 clips with attached wire leads are for the HEADLIGHT CIRCUIT and has the proper 16-gauge red with yellow tracer stripe wire leads attached. Fuse not included. Fits all XJ models except XJ700, XJ750-X, and XJ1100 models. Wire leads will need to be spliced, soldered, or otherwise attached to your original wire leads (such as with the butt connectors listed above). NOTE: some models used solid brown wires for the headlight circuit, in which case you can either use these (which we recommend doing), or, you can use the HCP23090 set above. Each set:
    $ 23.95
    rf3) Aftermarket replacement GLASS AGC FUSES for use with the stock original fuseboxes or fuse holders.
    NOTE: the following replacement fuses are slightly longer than the stock, original fuses (you still have those in there????!) but the additional length will not cause any problems with use.
    HCP7144 Aftermarket glass tube 5-AMP AGC FUSE, each:
    $ 1.25
    HCP7144SET5 Aftermarket glass tube 5-AMP AGC FUSES, set of 5:
    $ 4.95
    HCP1276 Aftermarket glass tube 10-AMP AGC FUSE, each:
    $ 1.25
    HCP1276SET5 Aftermarket glass tube 10-AMP AGC FUSES, set of 5:
    $ 4.95
    HCP7145 Aftermarket glass tube 15-AMP AGC FUSE, each:
    $ 1.25
    HCP7145SET5 Aftermarket glass tube 15-AMP AGC FUSES, set of 5:
    $ 4.95
    HCP1275 Aftermarket glass tube 20-AMP AGC FUSE, each:
    $ 1.25
    HCP1275SET5 Aftermarket glass tube 20-AMP AGC FUSES, set of 5:
    $ 4.95
    HCP7143 Aftermarket glass tube 30-AMP AGC FUSE, each:
    $ 1.25
    HCP7143SET5 Aftermarket glass tube 30-AMP AGC FUSES, set of 5:
    $ 4.95
    rf3a)The following fuses are the original “short” style fuses, and will certainly get your bike to the 11th level! Note that these fuses are current manufacturer (not 30 year-old fuses!):
    HCP23094 Aftermarket glass tube 10-AMP ORIGINAL FUSE, each:
    $ 3.95
    HCP23095 Aftermarket glass tube 20-AMP ORIGINAL FUSE, each:
    $ 3.95
    HCP24653 Aftermarket glass tube 30-AMP ORIGINAL FUSE, each:
    $ 3.95
    Original Fusebox Hardware:
    HCP23087 Aftermarket original-style fusebox plastic LID, black plastic snap-on lid fits and appears just like original.
    $ 21.95
    HCP23088 Aftermarket original-style fusebox plastic BASE, black plastic base accepts the original fuseholder clips just like the original.
    $ 18.95
    HCP787 OEM original fusebox rubber BOOT, covers the bottom edge of the stock fusebox and acts as an anti-vibration damper. Fits all original XJ-series fuseboxes (except XJ700 models), but was only used originally on XJ650RJ Seca, 1982 XJ650 Turbo, and all XJ750 models. NOTE: you will need to use the HCP2520 screws, the HCP2519 collar, and the HCP306 washers with this boot.
    $ 21.95
    HCP314 OEM original fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. Zinc-plated alloy steel, panhead, phillips-drive. Fits all XJ550 models, use 2 per fusebox, each:
    $ 3.95
    HCP5335 OEM fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. Black alloy steel, panhead, phillips-drive. Fits all XJ550 models, use 2 per fusebox, each:
    $ 8.95
    HCP915 Aftermarket fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. Zinc-plated alloy steel, panhead, phillips-drive. Fits all XJ550 models, use 2 per fusebox, each:
    $ 1.95
    HCP316 Aftermarket fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. 18-8 stainless steel, panhead, phillips-drive. Fits all XJ550 models, use 2 per fusebox, each:
    $ 2.95
    HCP317 Aftermarket fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. 18-8 stainless steel with a polished button head, hex-drive. Fits all XJ550 models, use 2 per fusebox, each:
    $ 2.95
    HCP318 Aftermarket fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. 18-8 stainless steel with a smooth, polished socket head, hex-drive. Fits all XJ550 models, use 2 per fusebox, each:
    $ 2.95
    HCP320 Aftermarket fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. Black-oxide coated alloy steel with a ribbed socket head. Fits all XJ550 models, use 2 per fusebox, each:
    $ 1.95
    HCP2940 OEM original fusebox MOUNTING SCREW, black, phillips-drive, panhead, alloy steel screw. For all 1984-85 FJ600 models, use 2 per fusebox, each:
    $ 4.95
    HCP2643 Aftermarket original fusebox MOUNTING SCREW, zinc-plated alloy steel, panhead, phillips drive. For all 1984-85 FJ600 models, use 2 per fusebox, each:
    $ 1.95
    HCP302 Aftermarket original fusebox MOUNTING SCREW, 18-8 stainless steel, panhead, phillips-drive. For all 1984-85 FJ600 models, use 2 per fusebox, each:
    $ 2.95
    HCP303 Aftermarket original fusebox MOUNTING SCREW, 18-8 stainless-steel, polished button head, hex-drive. For all 1984-85 FJ600 models, use 2 per fusebox, each:
    $ 2.95
    HCP56 Aftermarket original fusebox MOUNTING SCREW, 18-8 stainless steel, smooth polished socket head, hex-drive. For all 1984-85 FJ600 models, use 2 per fusebox, each:
    $ 2.95
    HCP58 Aftermarket original fusebox MOUNTING SCREW, black oxide-coated alloy steel, ribbed socket head, hex-drive For all 1984-85 FJ600 models, use 2 per fusebox, each:
    $ 1.95
    HCP383 OEM original fusebox-to-filter lid RETAINING SCREW, bright zinc-plated alloy steel, secures the fusebox to the filter lid on the airbox. Fits all XJ650 Maxim, Midnight Maxim, and 1982 XJ650 Turbo models, use 2 per fusebox, each:
    $ 3.95
    HCP21390 Aftermarket original fusebox-to-filter lid RETAINING SCREW, bright 18-8 stainless steel. Secures the fusebox to the filter lid on the airbox. Fits all XJ650 Maxim, Midnight Maxim, and 1982 XJ650 Turbo models, use 2 per fusebox. NOTE: original screws may have had a blunt tip or a sharp, pointed tip. These replacement screws have a pointed tip. Each:
    $ 2.95
    HCP2520 OEM original fusebox-to-filter lid RETAINING SCREW, bright zinc-plated alloy steel, secures the fusebox to the filter lid on the airbox. Fits all XJ650RJ Seca, 1983 XJ650 Turbo, and all XJ750 models, use 2 per fusebox, each:
    $ 3.95
    HCP25893 Aftermarket original fusebox-to-filter lid RETAINING SCREW, bright 18-8 stainless steel, secures the fusebox to the filter lid on the airbox. Fits all XJ650RJ Seca, 1983 XJ650 Turbo, and all XJ750 models, use 2 per fusebox, each:
    $ 2.95
    HCP4168 OEM original fusebox-to-filter lid RETAINING SCREW, bright zinc-plated alloy steel. Secures the fusebox to the filter lid on the airbox. Fits all XJ900RK, RL, N/FN, and F models, use 2 per fusebox, each:
    $ 5.95
    HCP25892 Aftermarket original fusebox-to-filter lid RETAINING SCREW, bright 18-8 stainless steel. Secures the fusebox to the filter lid on the airbox. Fits all XJ900RK, RL, N/FN, and F models, use 2 per fusebox, each:
    $ 3.95
    HCP2519 OEM original fusebox-to-filter lid retaining screw COLLAR, hollow metal sleeve used with the HCP2520 screw above. Fits all XJ650RJ Seca, 1983 XJ650 Turbo, and all XJ750 models, use 2 per fusebox, each:
    $ 2.95
    HCP2173 OEM original fusebox-to-filter lid retaining screw FLAT WASHER, used with the HCP314 screw above. Fits all XJ550 models, use 2 per fusebox, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket original fusebox-to-filter lid retaining screw FLAT WASHER, zinc-plated alloy steel with a natural finish, used with the HCP314 screw above. Fits all XJ550 models, use 2 per fusebox, each:
    $ 1.95
    HCP6643 Aftermarket original fusebox-to-filter lid retaining screw FLAT WASHER, 18-8 stainless steel with a natural finish, used with the HCP314 screw above. Fits all XJ550 models, use 2 per fusebox, each:
    $ 2.95
    HCP25756 Aftermarket original fusebox-to-filter lid retaining screw FLAT WASHER, 316 stainless steel with a natural finish, used with the HCP314 screw above. Fits all XJ550 models, use 2 per fusebox, each:
    $ 3.95
    HCP14285 Aftermarket original fusebox-to-filter lid retaining screw FLAT WASHER, black oxide-coated 18-8 stainless steel, used with the HCP314 screw above. Fits all XJ550 models, use 2 per fusebox, each:
    $ 2.95
    HCP14284 Aftermarket original fusebox-to-filter lid retaining screw FLAT WASHER, black oxide-coated hardened alloy steel, used with the HCP314 screw above. Fits all XJ550 models, use 2 per fusebox, each:
    $ 2.95
    HCP306 OEM original fusebox-to-filter lid retaining screw FLAT WASHER, bright zinc-plated alloy steel, used with the HCP2520, HCP2940, and HCP4168 screws above. Fits all FJ600, XJ650 models (except 1983 XJ650 Turbo), all XJ750 models, and XJ900RK, RL, and N/FN models. Use 2 per fusebox, each:
    $ 2.95
    HCP914 Aftermarket fusebox-to-filter lid retaining screw FLAT WASHER, bright zinc-plated alloy steel, used with the HCP2520, HCP2940, and HCP4168 screws above. Fits all FJ600, XJ650 models (except 1983 XJ650 Turbo), all XJ750 models, and XJ900RK, RL, and N/FN models. Use 2 per fusebox, each:
    $ 1.95
    HCP1353 Aftermarket fusebox-to-filter lid retaining screw FLAT WASHER, bright 18/8 stainless steel, used with the HCP2520, HCP2940, and HCP4168 screws above. Fits all FJ600, XJ650 models (except 1983 XJ650 Turbo), all XJ750 models, and XJ900RK, RL, and N/FN models. Use 2 per fusebox, each:
    $ 2.95
    HCP65 Aftermarket fusebox-to-filter lid retaining screw FLAT WASHER, black oxide-coated stainless steel, used with the HCP2520, HCP2940, and HCP4168 screws above. Fits all FJ600, XJ650 models (except 1983 XJ650 Turbo), all XJ750 models, and XJ900RK, RL, and N/FN models. Use 2 per fusebox, each:
    $ 2.95
    HCP55 OEM original fusebox mounting screw LOCK WASHER. For all FJ600 models, use 2 per fusebox, each:
    $ 1.95
    HCP913 Aftermarket original fusebox mounting screw LOCK WASHER. Zinc-plated alloy steel with a bright finish. For all FJ600 models, use 2 per fusebox, each:
    $ 1.75
    HCP57 Aftermarket original fusebox mounting screw LOCK WASHER. 18-8 stainless steel with a bright finish. For all FJ600 models, use 2 per fusebox, each:
    $ 2.95
    HCP59 Aftermarket original fusebox mounting screw LOCK WASHER. Black-oxide coated alloy steel with a dark finish. For all FJ600 models, use 2 per fusebox, each:
    $ 1.95
    HCP2940 OEM original accessory fuse terminal assembly MOUNTING SCREW, black, phillips-drive, panhead, alloy steel screw. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 4.95
    HCP2643 Aftermarket original accessory fuse terminal assembly MOUNTING SCREW, zinc-plated alloy steel, panhead, phillips drive. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 1.95
    HCP302 Aftermarket original accessory fuse terminal assembly MOUNTING SCREW, 18-8 stainless steel, panhead, phillips-drive. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP303 Aftermarket original accessory fuse terminal assembly MOUNTING SCREW, 18-8 stainless-steel, polished button head, hex-drive. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP56 Aftermarket original accessory fuse terminal assembly MOUNTING SCREW, 18-8 stainless steel, smooth polished socket head, hex-drive. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP58 Aftermarket original accessory fuse terminal assembly MOUNTING SCREW, black oxide-coated alloy steel, ribbed socket head, hex-drive. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 1.95
    HCP306 OEM original accessory fuse terminal assembly retaining screw FLAT WASHER, bright zinc-plated alloy steel, used with the screws above. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP914 Aftermarket original accessory fuse terminal assembly retaining screw FLAT WASHER, bright zinc-plated alloy steel, used with the screws above. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 1.95
    HCP1353 Aftermarket original accessory fuse terminal assembly retaining screw FLAT WASHER, bright 18/8 stainless steel, used with the screws above. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP65 Aftermarket original accessory fuse terminal assembly retaining screw FLAT WASHER, black oxide-coated stainless steel, used with the screws above. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP55 OEM original accessory fuse terminal assembly retaining screw mounting screw LOCK WASHER. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 1.95
    HCP913 Aftermarket original accessory fuse terminal assembly retaining screw LOCK WASHER. Zinc-plated alloy steel with a bright finish. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 1.75
    HCP57 Aftermarket original accessory fuse terminal assembly retaining screw LOCK WASHER. 18-8 stainless steel with a bright finish. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 2.95
    HCP59 Aftermarket original accessory fuse terminal assembly retaining screw LOCK WASHER. Black-oxide coated alloy steel with a dark finish. For all XJ1100 and XS1100 models, use 3 per terminal assembly, each:
    $ 1.95
    REPLACEMENT FUSEBOXES AND ACCESSORIES:
    Upgrading your electrical system couldn't be simpler with one of our aftermarket style enclosed, waterproof fuse panels.....bringing your bike a long way up to 21st century standards of electrical wiring, and helping to prevent and eliminate annoying, frustrating, and down-right dangerous electrical issues that worn out stock fuseboxes suffer from.
    So, if your fusebox (or the remains of it) look anything like this:
    http://www.xjbikes.com/forums/index.php?threads/photo-of-new-fusebox-install.14200/#post-121673
    or this:
    http://xjbikes.com/forums/index.php?threads/fuse-panel-poll-yes-no-will-wont.9277/page-2#post-87015
    then it's time to solve a number of problems and potential problems, all at once!
    And here is the shocking video that everyone’s talking about, showing the entire install on an XJ650 Maxim model (other models, besides the XJ1100 and XS1100 models, are all basically the same procedure):
    FITMENT: the stock Yamaha fusebox is very flat...less than an inch tall. These aftermarket fuseblocks are quite a bit taller, and therefore may present some challenges and the need for some creative engineering to place them properly. In some cases the small "document holder" under the seat may need to be removed. We offer the following tips:
    XJ550 models (all): the stock fusebox lays on top of the "tool kit caddy", and the forward "arms" of this caddy hold both the TCI (on the right side) and the fusebox (on the left side). These aftermarket fuseboxes will not fit in the same place as the stock fusebox, as the increased height will cause interference with the bottom of the seat pan. The best fit can be obtained by carefully cutting away a portion of the left tool caddy "arm", so that the replacement fusebox can be attached to the top of the air filter housing. Careful positioning of the fusebox will allow you to remove a minimal amount of the tool caddy arm material, thus retaining the structural strength of that arm. The replacement fusebox should them be retaining to the top of the air filter box via two self-tapping screws, or proper sized bolts and nuts. Here is a good image of what it should look like when you're done:
    http://xjbikes.com/forums/index.php?threads/14200
    and
    http://www.xjbikes.com/forums/threads/how-to-install-an-aftermarket-fuse-box.6350/page-2#post-523114
    XJ650 all models (except Turbo) and all 1981-83 XJ750 models: the stock fusebox lays on top of the air cleaner box lid. The replacement fuseblock can go in the same area, but some care must be taken as to positioning to make sure that the bottom of the seat pan does not contact the top of clear cover of the fuseblock. You will have to slightly reposition the fuseblock from the original mounting holes to get everything to line up properly, and you may have to remove the small plastic "document holder" that snaps into the bottom of the seat pan to secure proper clearance. Most clearance issues on these models can be resolved with the use of our FITMENT TEMPLATE and SEAT SPACER KIT listed further below.
    Here are the basic steps needed, shown on an XJ650 Maxim model; XJ650RJ Seca and XJ750 Maxim and Seca models are similar. Although this how-to uses a 4-circuit replace fusebox, our 6-circuit panel installs in the same manner:
    http://xjbikes.com/forums/index.php?threads/6350
    and
    http://www.xjbikes.com/forums/threads/fuse-box-replacement.71502/
    XJ650 Turbo models: the stock fusebox fits into a flat plastic holder "bar" that fits over the air cleaner box. This holder will no longer be used, and the replacement fusebox will need to be screwed directly to the top of the air cleaner box.
    XJ700 and XJ750-X models: these bikes already use the push-in type fuses in a fuse panel (under the gauges) that already comes with ATC style fuses for the auxiliary circuits, and there is no need to upgrade that! Therefore these replacement 6-circuit fuseboxes are not needed on these bikes. However, they also use a 30A main fuse in a separate in-line fuse holder that uses the old glass-style fuse, and that is certainly a candidate for updating with the 30A ATC style in-line fuse holder HCP6833 or HCP16766 listed further below.
    XJ900 (and possibly XJ750RL) models: the stock fusebox sits in the "electrical components compartment" caddy under the seat. The replacement fusebox will fit in place of the original fusebox inside this caddy, but you will need to add the HCP12836 spacers to the frame tubes to space the seat pan up slightly (1/8") to prevent interference between the bottom of the seat pan and the top of the fusebox. Here's a great visual how-to:
    http://xjbikes.com/forums/index.php?threads/3184
    XJ1100 and XS1100 models: these models will require the installation of one of our adapter plates to properly install the enclosed fusebox on these models.
    Also available are harness WIRING EXTENSION KITS that contain all the additional color-coded wiring leads, terminals, and connectors needed to make the installation of these aftermarket fuseboxes an even simpler fix!
    All fuseboxes and component pieces are available individually, or as COMPLETE FUSEBOX UPGRADE KITS, which will give you everything you need to do it right, the first time!
    q) We've developed a number of different COMPLETE FUSEBOX UPGRADE KITS to assist you in performing a professional replacement of the stock 4-circuit fusebox (or whatever other type of hacked wiring mess you inherited). Each kit contains the enclosed fusebox, bottom gasket, mounting screws, circuit ID decal, extension wires set, mounting templates (on some models), and seat spacers kit (on some models). In just a few hours time, you’ll be (electrically-speaking) riding in the modern world again.
    All of our fusebox kits require no soldering and minimal electrical knowledge. With the use of our optional HCP17820 POWER JUMPER WIRE, you can easily add power to the two additional circuits in any of our 6-circuit fusebox kits, and have a conversion that looks professional and is done safely and properly.
    NOTE: all of the following kits comes with a complete set of vinyl insulated butt connectors which are used to attach the ends of the fusebox wires to the original main harness wires. We also have available a set of un-insulated butt connectors and matching dual-wall heat-shrink tube, which is a good alternative for those who wish a more streamlined, weatherproof method of attaching the wires. See part HCP27207 further below.
    XJ550 models:
    https://www.facebook.com/VintageYam...383213023074/2004383213023074/?type=3&theater
    HCP22570KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, installation template, circuit ID decal, and wiring extensions. Fits all XJ550 models.
    $ 69.95
    HCP22571KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, installation template, circuit ID decal, and wiring extensions. Fits all XJ550 models.
    $ 72.95
    XJ650 models:
    HCP22572KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all XJ650 (except Turbo) models. NOTE: XJ650RJ Seca and XJ650 Euro models (with the hinged, “flip-up” style seat) may not require the use of the seat spacers included within this kit.
    $ 69.95
    HCP22573KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all XJ650 (except Turbo) models. NOTE: XJ650RJ Seca and XJ650 Euro models (with the hinged, “flip-up” style seat) may not require the use of the seat spacers included within this kit.
    $ 74.95
    HCP22574KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, circuit ID decal, and wiring extensions. Fits all XJ650 Turbo models. NOTE: can be used on all other XJ650 models but does not include the seat spacers nor the installation template).
    $ 74.95
    HCP22575KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, circuit ID decal, and wiring extensions. Fits all XJ650 Turbo models. NOTE: can be used on all other XJ650 models but does not include the seat spacers nor the installation template).
    $ 79.95
    XJ750 models:
    HCP22576KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all 1982 XJ750 Maxim models.
    $ 69.95
    HCP22577KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all 1982 XJ750 Maxim models.
    $ 74.95
    HCP22578KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all 1983-84 XJ750 Maxim and Midnight Maxim models.
    $ 69.95
    HCP22579KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all 1983-84 XJ750 Maxim and Midnight Maxim models.
    $ 74.95
    HCP22580KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all 1981-83 XJ750 Seca and all XJ750 Euro models.
    $ 79.95
    HCP22581KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, seat spacers, installation template, circuit ID decal, and wiring extensions. Fits all 1981-83 XJ750 Seca and all XJ750 Euro models.
    $ 84.95
    XJ900 models:
    HCP22582KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, with standard (non-glow) push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, circuit ID decal, and wiring extensions. Fits all XJ900RK, RL, F, N, and FN models.
    $ 79.95
    HCP22583KIT Aftermarket COMPLETE FUSEBOX UPGRADE KIT, featuring the glow-when-blown style of push-in ATO fuses. Includes the fusebox, a full set of fuses, gasket, mounting screws, circuit ID decal, and wiring extensions. Fits all XJ900RK, RL, F, N, and FN models.
    $ 84.95
    XJ1100 models:
    NOTE: XJ1100 owners actually have three fuse-holding devices to consider (and thus possibly upgrade):
    1) the main circuit remote fuseholder, which is enclosed all by its lonesome as an appendage to the main wiring harness, and....
    2) the 4-position "accessory circuits" black lastic fusebox, which mounts to the side of the battery box, and….
    3) the 1-position "accessory circuit" terminal block, which mounts under the stock 4-position fusebox. Note that we do not have any “upgrade” option for this (rarely used) terminal block.
    ALL of the above devices originally use the "old tech" type of AGC (“all glass” or “automotive glass”, depending on who you listen to……..) cylindrical glass fuses. AGC fuses are also sometimes referred to as SFE (“Society of Fuse Engineers”…..yes there is such an organization!) fuses.
    We've developed a number of different kits to allow you to replace the stock 4-position accessory circuit fusebox (that's a must!) with a modern 6-circuit fusebox using the modern style ATO "blade" fuses. You then also have the option to choose between leaving the main fuseholder "as is" (remote from the main fusebox, in its own fuseholder), or, leaving it remote but replacing the original AGC fuse and holder with a modern blade-style ATO fuse and fuseholder.......or going fully modern and eliminating the remote main fuseholder entirely and bringing the main fuse circuit "inside" your new upgraded 6-position fusebox (note that this last choice will eliminate one potential "accessory circuit" from your new 6-circuit fusebox, since one of those "accessory circuits" is now populated by the main fuse circuit, which used to be remote from the fusebox).
    Our recommendation: replace the stock remote main circuit fuseholder with a modern version (which uses the blade-style ATO fuse) and, of course, replace the original 4-position fusebox with our upgraded 6-circuit, enclosed, ATO fuseholder. This is what we refer to as “OPTION B” below. This arrangement brings your electrical system (as far as fuses are concerned) fully into the modern era.
    Also note that the use of any of our replacement accessory-circuit fusebox kits will require you to modify or eliminate the accessory circuit terminal block unit, located on the bottom left "corner" of the stock fusebox mounting plate, as it makes for an incredibly tight fit for the routing of the circuit wires.
    All of our fusebox kits require no soldering and minimal electrical knowledge. With the use of our optional HCP18421 mounting plate kit, you can ensure a quick and painless installation process, and have a professional conversion that both properly fits inside the frame side cover and looks factory-installed.
    So here are your options; again, we suggest option B as the more useful and suitable for most owners:
    OPTION A: If you want to keep the stock, remote MAIN CIRCUIT fuseholder as-is, and just upgrade the original accessory-circuits fusebox, then order either the HCP378BC or the HCP378LF 6-circuit fuesbox kits, the HCP16766 harness extension wires, and the HCP18421 installation kit:
    Order either of these fuseboxes:
    HCP378BC Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX KIT, comes with a full set of standard style ATO push-in style fuses (4 x 10A, and 2 x 20A), for all XJ550, all XJ650, 1983 XJ750 Maxim and XJ750 Midnight Maxim, and XJ1100 models. NOTE: XJ1100 owners will not be able to install this fusebox without the use of our HCP18421 mounting plate kit.
    $ 39.95
    HCP378LF Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX KIT, comes with the optional “glow-when-blown” indicator style ATO push-in fuses (4 x 10A, and 2 x 20A), XJ550, all XJ650, 1983 XJ750 Maxim and XJ750 Midnight Maxim, and XJ1100 models. NOTE: XJ1100 owners will not be able to install this fusebox without the use of our HCP18421 mounting plate kit.
    $ 44.95
    and this:
    HCP16766 Aftermarket 6-circuit fusebox HARNESS EXTENSION WIRES KIT. For all XJ1100 and XS1100 models.
    $ 39.95
    and this, which will make installation a breeze!:
    HCP18421 Aftermarket fusebox MOUNTING PLATE KIT, contains a custom designed black steel mounting plate that allows quick and easy installation of the 6-circuit fusebox to your battery tray. Replaces the original stock fusebox mounting plate and retains and moves the turn signal flasher relay "out of harm's way", a necessity when using the larger aftermarket fusebox. Kit contains the mounting bracket, installation hardware, and illustrated instructions.
    $ 59.95
    Option “A” Complete Kits:
    HCP26987-BC-KIT Aftermarket “Option A” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this selection: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, and fusebox wiring kit. For all XJ1100 models.
    $ 99.95
    HCP26987-LF-KIT Aftermarket “Option A” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this selection: an enclosed 6-circuit fusebox with the optional “glow-when-blown” indicator style ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, and fusebox wiring kit. For all XJ1100 models.
    $ 104.95
    OPTION B: If you want to keep the MAIN fuseholder external from the accessory-circuits fusebox, but DO want to replace the stock glass-fuse main fuseholder with a later style "blade" fuse holder, AND upgrade the original accessory-circuits fusebox to a later style "blade" fusebox, then order the HCP16777 main fuseholder replacement kit, either the HCP378BC or the HCP378LF accessory-circuits fusebox kit, the HCP16766 harness extension wires kit, and the HCP18421 installation kit :
    Order this:
    HCP16777 Aftermarket MAIN FUSEHOLDER REPLACEMENT KIT, contains the weatherproof "blade" style HCP6833 main fuse holder with the white plastic connector shell that plugs into your main wiring harness (just like the original main fuseholder does).....no splicing, dicing, or harness chopping required! Includes 2 x 30A blade fuses (1 for use and 1 as a spare). For all XJ1100 and 1980-81 XS1100 models.
    $ 39.95
    and either of these fuseboxes:
    $ 39.95
    $ 44.95
    and this:
    $ 39.95
    $ 59.95
    Option “B” Complete Kits:
    HCP26988-BC-KIT Aftermarket “Option B” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this selection: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the modern-style ATO main circuit remote fuseholder with fuses. For all XJ1100 models.
    $ 104.95
    HCP26988-LF-KIT Aftermarket “Option B” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this selection: an enclosed 6-circuit fusebox with the optional “glow-when-blown” indicator style ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the modern-style ATO main circuit remote fuseholder with fuses. For all XJ1100 models.
    $ 109.95
    OPTION C: If you want to bring the main fuse holder circuit "inside" of the upgraded 6-circuit enclosed fusebox, order either the HCP16769BC or the HCP16769LF fusebox kits below and the HCP16766 wiring harness extension wires kit....note that this eliminates the remote main circuit fuseholder entirely, and moves that circuit into one of the enclosed fusebox circuit positions:
    Order either of these fusebox and main fuseholder kits:
    HCP16769BC Aftermarket enclosed 6-circuit ENCLOSED 6-CIRCUIT FUSEBOX AND MAIN FUSEHOLDER ELIMINATOR KIT, allows for the elimination of the original remote "main circuit" fuseholder and the placement of the 30A main circuit path inside the new fusebox. The adapter wire has the white plastic connector shell that plugs into your main wiring harness just like the original main fuseholder does.....no splicing, dicing, or harness chopping required! Kit includes the enclosed fusebox, the main fuseholder eliminator harness, and a full complement of standard ATO blade type fuses (4 x 10A, 2 x 20A, and 2 x 30A). For all XJ1100 models.
    $ 44.95
    HCP16769LF Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX AND MAIN FUSEHOLDER ELIMINATOR KIT, allows for the elimination of the original remote "main circuit" fuseholder and the placement of the 30A main circuit path inside the new fusebox. The adapter wire has the white plastic connector shell that plugs into your main wiring harness just like the original main fuseholder does.....no splicing, dicing, or harness chopping required! Kit includes the enclosed fusebox, the main fuseholder eliminator harness, and a full complement of the optional ”glow-when-blown” indicator style ATO blade type fuses (4 x 10A, 2 x 20A, and 2 x 30A). For all XJ1100 models.
    $ 49.95
    and this:
    $ 39.95
    $ 59.95
    Option “C” Complete Kits:
    HCP26989-BC-KIT Aftermarket “Option C” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this selection: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the main fuseholder elimination/re-location harness. For all XJ1100 models.
    $ 109.95
    HCP26989-LF-KIT Aftermarket “Option C” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this selection: an enclosed 6-circuit fusebox with the optional “glow-when-blown” indicator style ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the main fuseholder elimination/re-location harness. For all XJ1100 models.
    $ 114.95
    XS1100 models:
    NOTE: on all XS1100 models, when replacing the stock 4-circuit fusebox, the turn signal flasher relay (flasher unit), which is located on the fusebox mounting plate, will cause interference with the the larger 6-circuit fusebox which is provided in our kits, and thus the flasher relay must be relocated. A plug-and-play extension harness and relay mounting bracket is included with our kits to make the relocation of the flasher relay a simple, painless, and professional-looking task (note that what we refer to as the “mounting plate” is the stamped metal plate which is attached to the right side of the battery tray structure, and holds the stock 4-circuit plastic fusebox, the 1-position accessory “terminal block”, the signal flasher relay, and the starter solenoid). However, the mounting “tab” for the flasher relay, which is stamped onto this mounting plate, will need to be removed or folded “out of the way”……..all of this is covered in the illustrated instructions included with the fusebox kit.
    All kits include at least the following components: the enclosed, 6-circuit fusebox with a full supply of ATO blade fuses, a circuit ID decal, a fusebox mounting adapter plate, attaching hardware, a flasher relay re-location harness and mounting bracket, and full instructions.
    All of our fusebox kits require no soldering and minimal electrical knowledge, and the illustrated instructions insure a quick and painless installation process (1-2 hours, depending on your skill level and mood), and will lead to a professional conversion that both properly fits inside the frame side cover and looks factory-installed.
    1978-79 XS1100 models:
    NOTE: 1978-79 XS100 owners actually have two fuse-holding devices:
    1) the 4-position "accessory circuits" black plastic fusebox, which mounts to the side of the battery box, and which can be upgraded to a modern ATO 6-circuit fusebox, and…….
    2) a 1-position "accessory circuit" terminal block, which mounts under the stock 4-position fusebox. Note that we do not have any “upgrade” option for this (rarely used) terminal block.
    BOTH of the above devices originally use the "old tech" type of AGC (“all glass” or “automotive glass”, depending on who you listen to……..) cylindrical glass fuses. AGC fuses are also sometimes referred to as SFE (“Society of Fuse Engineers”…..yes there is such an organization!) fuses.
    HCP26996BC Aftermarket FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this upgrade: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, and the fusebox wiring kit. For all 1978-79 XS1100 models.
    $ 109.95
    HCP26996LF Aftermarket FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this upgrade: an enclosed 6-circuit fusebox with optional “glow-when-blown” indicator type ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, and the fusebox wiring kit. For all 1978-79 XS1100 models.
    $ 114.95
    1980-81 XS1100 models:
    NOTE: 1980-81 XS owners actually have three fuse-holding devices to consider (and thus possibly upgrade):
    1) the main power circuit remote fuseholder, which is enclosed all by its lonesome as an appendage to the main wiring harness, and....
    2) the 4-position "accessory circuits" black plastic fusebox, which mounts to the side of the battery box, and which can be upgraded to a modern blade-style ATO 6-circuit fusebox, and…….
    3) a 1-position "accessory circuit" terminal block, which mounts under the stock 4-position fusebox. Note that we do not have any “upgrade” option for this (rarely used) terminal block.
    We've developed a number of different kits to allow you to replace the stock 4-position accessory circuit fusebox (that's a must!) with a modern 6-circuit fusebox using the modern style ATO "blade" fuses. You then also have the option to choose between leaving the main fuseholder "as is" (remote from the main fusebox, in its own fuseholder), or, leaving it remote but replacing the the main fuseholder AGC fuse and holder with a modern blade-style ATO fuse and fuseholder.......or going fully modern and eliminating the remote main fuseholder entirely, and bringing the main fuse circuit "inside" your new upgraded 6-position fusebox (note that this last choice will eliminate one potential "accessory circuit" from your new 6-circuit fusebox, since one of those "accessory circuits" is now populated by the main fuse circuit, which used to be remote from the fusebox).
    OPTION A KITS: If you want to keep the stock, remote MAIN CIRCUIT fuseholder as-is, and just upgrade the original accessory-circuits fusebox, then order either of the fusebox kits below.
    HCP26997BC-KIT Aftermarket “Option A” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this option: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, and fusebox wiring kit. For all 1980-81 XS1100 models.
    $ 99.95
    HCP26997LF-KIT Aftermarket “Option A” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this option: an enclosed 6-circuit fusebox with the optional “glow-when-blown” ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, and fusebox wiring kit. For all 1980-81 XS1100 models.
    $ 104.95
    OPTION B KITS: If you want to keep the MAIN fuseholder external (outside) from the accessory-circuits fusebox, but DO want to replace the stock glass-fuse main fuseholder with a later style "blade" fuse holder, AND upgrade the original accessory-circuits fusebox to a later style "blade" fusebox, then order either of the fusebox kits below.
    HCP26998BC-KIT Aftermarket “Option B” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this option: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the modern-style ATO main circuit remote fuseholder with fuses. For all 1980-81 XS1100 models.
    $ 104.95
    HCP26998LF-KIT Aftermarket “Option B” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this option: an enclosed 6-circuit fusebox with the optional “glow-when-blown” indicator style ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the modern-style ATO main circuit remote fuseholder with fuses. For all 1980-81 XS1100 models.
    $ 109.95
    OPTION C KITS: If you want to bring the stock external MAIN fuse holder circuit "inside" of the upgraded 6-circuit enclosed fusebox, order either of the fusebox kits below……note that this eliminates the remote main circuit fuseholder entirely, and moves that main fuse circuit into one of the enclosed fusebox circuit positions:
    HCP26999BC-KIT Aftermarket “Option C” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this option: an enclosed 6-circuit fusebox with standard ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the main circuit fuseholder elimination/re-location harness. For all 1980-81 XS1100 models.
    $1049.95
    HCP26999LF-KIT Aftermarket “Option C” FUSEBOX UPGRADE KIT, gets you everything you’ll need to do install this option: an enclosed 6-circuit fusebox with the optional “glow-when-blown” indicator style ATO fuses, a fusebox circuit ID decal, the fusebox mounting plate kit, the fusebox wiring kit, and the main circuit fuseholder elimination/re-location harness. For all 1980-81 XS1100 models.
    $1094.95
    Individual Fusebox Components:
    u177) Aftermarket 6-CIRCUIT ENCLOSED FUSEBOX. This small, weatherproof fusebox is the most popular replacement for the stock glass-tube fusebox and use "modern" type ATO push-in blade style fuses. Includes 6 ATO standard fuses, 2 x 20A or 2 x 30A (depending on your model), and 4 x 10A fuses. Two more circuits than a stock fusebox allows you to add extra circuits for heated grips, cigarette lighter, headlight relays, etc. Size: 4" long x 1-1/8" wide (not including spade terminals) x 1-1/2" tall (including the clear, see-through cover). Note that this is a "side-terminal" design...the male wire terminal spades point outwards (away) from the sides of the fusebox. Rated for 30 amps maximum current per circuit, and 70 amps maximum current draw for the entire box.
    NOTE: fuseboxes do not come with mounting screws; you may re-use your original or order new replacements listed further below. Mounting screw locations will differ from original, and it will be necessary to re-locate at least one (and probably both) to get a correct fit. The HCP21390 mounting screw is the shortest, self-tapping screw available, and is the best length to use on all models. The original mounting screws on XJ550 models is slightly larger in diameter than the mounting holes in these replacement fuseboxes, and thus the hole in the fusebox base will need to be enlarged slightly on those models if you re-use the original mounting screws.
    HCP21390 Aftermarket original fusebox-to-filter lid RETAINING SCREW, secures the fusebox to the filter lid on the airbox. For use with any of our aftermarket fuseboxes below on all XJ550 - XJ900 models. Use 2 per fusebox, each:
    $ 2.95
    HCP378 Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX, fusebox base and lid only; no fuses included, can be used on all models except all XJ700 and XJ750-X (water-cooled) bikes. NOTE: XJ1100 owners will not be able to install this fusebox without the use of our HCP18421 mounting plate kit.
    $ 34.95
    $ 39.95
    $ 44.95
    HCP7153BC Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX KIT, comes with a full set of standard style ATO push-in style fuses (4 x 10A, and 2 x 30A), for all XJ750 Seca, 1982 XJ750 Maxim, and XJ900RK, RL, N/FN, and F models.
    $ 39.95
    HCP7153LF Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX KIT, comes with a full set of glow-when-blown indicator style ATO push-in style fuses (4 x 10A, and 2 x 30A), for all XJ750 Seca, 1982 XJ750 Maxim, and XJ900RK, RL, N/FN, and F models.
    $ 44.95
    HCP10488BC Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX KIT, comes with a full set of standard style ATO push-in style fuses (1 x 30A, 1 x 20A, and 4 x 10A), for all 1984-85 FJ600, 1984 XJ750RL Seca, and all XS1100 models.
    $ 39.95
    HCP10488LF Aftermarket ENCLOSED 6-CIRCUIT FUSEBOX KIT, comes with a full set of glow-when-blown indicator style ATO push-in style fuses (1 x 30A, 1 x 20A, and 4 x 10A), for all 1984-85 FJ600, 1984 XJ750RL Seca, and all XS1100 models..
    $ 44.95
    u73) Aftermarket fusebox FITMENT TEMPLATE for the above HCP378xx or HCP7153xx series 6-circuit fuseboxes. These templates show you the proper method of fitting these fuseboxes into the cramped area of the original boxes, with proper placements and alignments for a fool-proof, no-guesswork fit. XJ650 and XJ750 models may also require a separate SEAT SPACER KIT (even with "perfect" fit) in order to prevent rubbing of the bottom of the seat pan against the top of the fusebox lid.
    HCP12833 Aftermarket 6-circuit fusebox FITMENT TEMPLATE, for use with all XJ550 models.
    $ 12.95
    HCP12834 Aftermarket 6-circuit fusebox FITMENT TEMPLATE, for use with all XJ650 (except Turbo) models.
    $ 12.95
    HCP12835 Aftermarket 6-circuit fusebox FITMENT TEMPLATE, for use with all 1981-83 XJ750 models.
    $ 12.95
    HCP12836 Aftermarket 6-circuit fusebox SEAT SPACER KIT, for use with all XJ650 Maxim and Midnight Maxim models, all 1981-83 XJ750 models, and XJ900 models. Contains a set of 4 rubber frame tube "spacers" and a spacer mounting location template. NOTE: depending on your weight, airbox adjustment position, and the condition of your seat pan (they tend to "sag" over time), the use of these spacers may or may not be required on individual bikes.
    $ 11.95
    nnn) Aftermarket CIRCUIT ID DECAL for the above 6-circuit fuseboxes. Printed on a clear adhesive backed long-life decal material, this decal specifies (in white print) the circuit "name" (MAIN, HEAD, TURN, IGN.), the fuse amp rating of each circuit, and the wire lead color code (BLU, RED, R/Y, BRN, R/W) so you can have the same circuit ID info on your replacement fusebox as on your original. Applies to the outside of the clear fusebox cover. The two empty circuit positions are titled "SPARE".
    HCP393 Aftermarket fusebox 6-CIRCUIT ID DECAL, with labeling for 20A main fuse and 10A headlight, ignition, and signal circuits, for all XJ550, all XJ650, and 1983 XJ750 Maxim and XJ750 Midnight Maxim models.
    $ 12.95
    HCP20241 Aftermarket fusebox 6-CIRCUIT ID DECAL, with labeling for 30A main fuse, 20A headlight circuit, and 10A ignition and signal circuits, for all 1984-85 FJ600 models.
    $ 12.95
    HCP7152 Aftermarket fusebox 6-CIRCUIT ID DECAL, with labeling for 30A main fuse and 10A headlight, ignition, and signal circuits, for all XJ750 Seca, 1982 XJ750 Maxim, and XJ900RK, RL, N/FN, and F models.
    $ 12.95
    HCP26951 Aftermarket fusebox 6-CIRCUIT ID DECAL, with labeling for 30A main fuse, 10A headlight circuit, 20A signal circuit, and 10A ignition circuit. For all 1978-79 XS1100 models.
    $ 12.95
    HCP13475 Aftermarket fusebox 6-CIRCUIT ID DECAL, with labeling for 10A taillight fuse, 10A headlight circuit, 20A signal circuit, and 10A ignition circuit. For all XJ1100 and 1980-81 XS1100 models in the stock configuration (with the main fuse circuit remaining external to the fusebox).
    $ 12.95
    HCP26952 Aftermarket fusebox 6-CIRCUIT ID DECAL, with labeling for 30A main fuse, 10A taillight fuse, 10A headlight circuit, 20A signal circuit, and 10A ignition circuit. For all XJ1100 and all 1980-81 XS1100 models when the main fuse circuit is brought inside the fusebox. Note that this is not the configuration for these models when maintaining the stock fusebox orientation; for the original configuration use decal HCP13475.
    $ 12.95
    u7) Aftermarket fusebox BOTTOM GASKET for the above HCP378xx or HCP7153xx series 6-circuit fuseboxes. These fuseboxes have an "open" bottom, which would allow moisture and, eventually, corrosion to get into this otherwise sealed fuseblock. This die cut 1/16" thick rubber gasket has pre-punched mounting holes.
    HCP382 Aftermarket 6-circuit fusebox BOTTOM GASKET:
    $ 8.95
    u71) Aftermarket fusebox WIRING EXTENSION KITS for the above HCP378xx or HCP7153xx series 6-circuit fuseboxes. Because the above replacement fuseboxes normally have to be slightly repositioned from the stock fusebox location (to insure adequate seat pan clearance), and due to the fact that the original lead wires coming off the main engine harness are crimped onto the original fusebox terminals (and will have to be cut a bit short during removal), these wiring harness extension kits are highly recommended to greatly simplify the installation of your new fusebox. The extra length of these wires gives you the option to locate your new fusebox in a variety of more suitable positions.
    Each wiring kit comes complete with 12" lengths of the proper color-coded wire leads for each of the four original circuits with insulated female spade terminals (already attached to the fusebox end of each wire) and a full set of the proper size butt connectors for attaching the wire leads to the original main harness wires. The additional wire length allows you to place the fusebox virtually anywhere that you need (or want to), eliminating the frustrating task of cobbling together the additional extra wire leads to install the replacement fusebox.
    HCP8553 Aftermarket WIRING EXTENSION KIT, contains all of the correct gauge and solid- and tracer-striped color wires to allow for the easy installation of any of our aftermarket 6-circuit enclosed fuseboxes in the following bikes: all XJ550, XJ650, XJ750 Maxim and Midnight Maxim, 1984 XJ750RL Seca, and XJ900RK, RL, N/FN, and F models.
    $ 39.95
    HCP8554 Aftermarket WIRING EXTENSION KIT, contains all of the correct gauge and solid- and tracer-striped color wires to allow for the easy installation of any of our aftermarket 6-circuit enclosed fuseboxes in the following bikes: all 1981-83 XJ750 Seca, all XJ750 Euro, and 1978-79 XS1100 models.
    $ 39.95
    HCP16766 Aftermarket WIRING EXTENSION KIT, contains all of the correct gauge and solid- and tracer-striped color wires to allow for the easy installation of any of our aftermarket 6-circuit enclosed fuseboxes in the following bikes: all XJ1100 and 1980-81 XS1100 models.
    $ 39.95
    HCP27207 Aftermarket fusebox wire OPTIONAL INSTALLATION HARDWARE KIT. This kit contains a full set of un-insulated butt connectors and heat-shrink tubing (as well as cable ties and harness clips) that is needed when hooking up the fusebox wires to the main harness wires. NOTE: all of our complete fusebox kits or fusebox wiring harness kits already contain a set of insulated wire connectors; this kit contains (basically) the same type of connectors, but they are the thinner, less-noticable un-insulated connectors, and appropriate lengths of heat-shrink tubing (to cover the un-insulated connectors after they are installed). Not an absolutely necessary kit to have ---- as noted, all of our complete fusebox kits and wiring harness kits already come with the bigger, bulkier insulated butt connectors --- but many people prefer these thinner, more streamlined connectors to create a more professional-looking and weatherproof method of attaching the fusebox wires to the main harness wires when using our aftermarket enclosed ATO fusebox kits. . Can be used with all of our aftermarket enclosed fusebox kits.
    $ 12.95
    HCP17820 Aftermarket fusebox POWER JUMPER WIRE, allows you to power up the two additional circuits in any of our enclosed 6-circuit fusebox kits. This jumper wire replaces the thick (14 gauge) tan wire in our HCP8553 or HCP8554 wire harness extension wire kits, and jumpers the power feed into the fusebox into the two additional "SPARE" circuit terminals. Plug-and-play operation, creates a neat, orderly, and safe power feed system for utilizing the two additional circuits. Includes a pair of 16-gauge female spade wire-end terminals for hooking up the accessory circuits to the outbound side of the fusebox (but no wire is included) NOTE: the wires used for the spare circuit power feeds in this power jumper wire are: HCP9547 (pink with black tracer stripe) for one circuit, and HCP9548 (purple with white tracer stripe) for the other circuit. Both are 16-gauge GXL wire, and can be used for circuits requiring up to 15 amps of current. Additional lengths of each of these wires can be ordered below, for the "outbound" side of your fusebox, so that you can color-code your accessory circuit wire runs with the same color wires.......a very professional touch.
    $ 19.95
    Accessory Color Wire:
    Sometimes, you'll want to add electrical accessory circuits to you bike.....a cigarette lighter, heated grips, perhaps a power port for a GPS unit, etc......and in such situations, it's best to run a separate circuit, with its own unique color-coded wiring, in order to keep things neat and orderly, electrically-speaking. We offer the following unique colors (not used anywhere else on your bike) to help you safely and accurately identify any new circuits that you add.
    HCP9547 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge. Sold per foot:
    $ 2.95
    HCP9547SET5 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge, 5-foot length:
    $ 12.95
    HCP9547SET10 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge, 10-foot length:
    $ 19.95
    HCP9548 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge. Sold per foot:
    $ 2.95
    HCP9548SET5 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge, 5-foot length:
    $ 12.95
    HCP9548SET10 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge, 10-foot length:
    $ 19.95
    Electrical System Chemicals and Supplies:
    NOTE: it’s important to understand the difference between the two types of greases used with electrical connectors. Di-electric grease acts as an electrical insulator: it does not allow current to flow through it easily, and is basically used to “waterproof” a connector assembly. Although it is an insulator, the act of engaging two electrical connectors together (i.e. pushing a male connector into a female connector) will push away the grease on the metal-to-metal contact portion of the terminals, so those remain electrically conductive (good) while also insulating all the other surfaces against moisture and oxygen intrusion (very good). This insulating property of di-electric grease makes it great for use in connector shells, etc. as terminal corrosion is one of the greatest contributors to electrical system problems in vehicles (especially older ones)……this is why most modern vehicles use “sealed” connector shells (the most popular is the Delphi Automotive brand called “weather pack” or “weatherpak”) to keep oxygen and moisture away from the metal terminals. Although you can retrofit these style connectors to older harnesses, it takes a LOT of time, money, and effort to do so.
    Now, contrast the insulating properties of di-electric grease to the electrically conductive properties of Conductive Grease, which, as its name implies, the grease itself (which contains many fine carbon particles) conducts electricity. Of course, being a “grease”, it too will also protect and insulate a terminal coated with it from moisture, corrosion, etc…..same as di-electric grease. But…it’s conductive, and if the terminal it coats is electrically “hot”, so is the grease (i.e. touching the grease alone will shock you!).
    So a conductive grease is great when you need protection plus current flow……ideal for frame (or battery) grounds to the frame, etc. You could---if you are totally anally-retentive---coat (for instance) a battery post internally with conductive grease, and then cover all of that with di-electric grease.
    So, think of these grease as two different electrical system “tools”, and use accordingly.
    et2) Aftermarket electrical connector DI-ELECTRIC GREASE coats, insulates, and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Smear some of this goo on each and every one of your electrical connectors (after you've cleaned them with some sandpaper or terminal cleaner) and you'll be doing yourself a big favor!
    HCP14059 Aftermarket packet of DI-ELECTRIC GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc.
    $ 4.95
    HCP7528 Aftermarket tube of DI-ELECTRIC GREASE, big 3-ounce squeeze tube.
    $ 21.95
    NOTE: the following 2 product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP20940 Aftermarket tube of DI-ELECTRIC GREASE, 3.3-ounce aerosol can of marine grade grease, with adjustable nozzle size to tailor the grease output bead size to minimize slop and waste and making application much easier. 1-2 cans will do all connectors on an entire bike harness.
    $ 24.95
    et14) Aftermarket electrical connector CONDUCTIVE GREASE coats and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Unlike the di-electric grease listed above, which is an insulator (non-conductive), this carbon-based grease is electrically conductive and has multiple applications (such as battery terminal posts (internally), frame grounds, etc.).
    HCP27923 Aftermarket packet of CONDUCTIVE GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc. Even tiny amounts (that you can barely see) will create minimal electrical resistance, so be careful with this stuff around capacitors and such. It gets everywhere, will stain your hands and clothing and take three days to wash off, and smells like some of the worst goop you've ever smelled. Use a toothpick for application. Don't eat it. Wear gloves. 2-gram pouch goes a long way.
    $ 6.95
    cps2) Aftermarket high-quality CROCUS CLOTH. Unlike sandpaper or emery paper, crocus cloth is a super-fine, cloth-backed soft abrasive that doesn’t “shed” particles during use, and is just the thing for burnishing and polishing of copper electrical contact, like the alternator rotor and starter motor commutators. Sold in a 2” wide x 1-foot long strip, enough for polishing many a commutator or contact.
    HCP21378 Aftermarket strip of CROCUS CLOTH, measures 12” x 2”. Each:
    $ 4.95
    NOTE: the following 3 product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10493 Aftermarket battery post TERMINAL SEALER helps keep corrosion from forming on the battery terminals. Fast drying and leaves no residue. Comes in a 6-ounce aerosol can.
    $ 12.95
    HCP9762 Aftermarket miracle-goo black LIQUID ELECTRICAL TAPE is easier to use than traditional tape products, especially in close-in locations. Great for sealing crimped wire terminal ends to the wire and serves as a good alternative or supplement to shrink tubing. Just brush it on and let it dry! Comes in a 4-ounces brush-top can.
    $12.95
    HCP10508 Aftermarket electrical CONTACT CLEANER is a good general purpose cleaner and de-greaser. Will not harm plastic terminal connector blocks. Fast drying and leaves no residue. Comes in a 16-ounce aerosol can.
    $ 14.95
    HCP12923 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 20-foot roll.
    $ 8.95
    HCP13134 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 66-foot roll, almost enough to do one complete harness.
    $ 16.95
    Additionally, most harnesses had a few short turns of COLORED VINYL ELECTRICAL TAPE WRAP to provide visual identification of "what connector goes where?" during harness assembly and installation. Always located just by the connector shell, about 3-4 turns of this tape was used to both tape off any vinyl sleeve and to properly identify what the connector plugged into. Used primarily at the TCI connector (from the pick-up coils) and at the various small "cube" style relays (headlight relays, sidestand safety switch relays, etc.). Since all of these harness connector shells are the same style and type (4-position, horizontally oriented 2-over-2), this small tape wrap served as a way of indicating which of these many identical connectors went to which component.
    HCP13130 Aftermarket harness bundle YELLOW VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on XJ700-X and XJ750-X models, and at the headlight relay connector on all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models.
    $ 7.95
    HCP13131 Aftermarket harness bundle RED VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on 1982-83 XJ650 Maxim models, all '81-83 XJ750 models, and all XJ700 non-X models, and at the fuel pump relay connector on all XJ650 Turbo models.
    $ 7.95
    HCP13132 Aftermarket harness bundle BLUE VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ550 models, at the emergency stop switch relay connector on all XJ650 Turbo models, and for the sidestand safety switch relay connector on all XJ550 models, all '82-83 XJ650 models, all XJ750 models, XJ900RK and XJ1100 models.
    $ 7.95
    HCP13133 Aftermarket harness bundle GREEN VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ650RJ Seca and XJ1100 models.
    $ 7.95
    et26) Aftermarket electrical device SWITCH LUBRICANT is a specially formulated, electrically non-conductive penetrating lube that is recommended on control switch turn signal contacts and headlight switching contacts. 10-gram squeeze tube has applicator tip for precision use.
    HCP14066 Aftermarket tube of electrical SWITCH LUBRICANT.
    $ 16.95
    et27) Aftermarket electrical INSTRUMENT OIL is a highly refined light oil for use on speedometer heads, tachometers, gauges, mechanical clocks, etc. Will not congeal even at 50-below-zero! Extra-slow rate of evaporation makes sure that it provides lubrication for a long, long time. 1-ounce pen has an applicator needle tip for precision use.
    HCP20852 Aftermarket hi-performance INSTRUMENT OIL, comes in a handy applicator pen. Oil-based triple-processed lubricant eliminates contaminants that would cause gumming or corrosion product is what we use and recommend for freeing stuck fork tube cap bolts.
    $ 37.95
    HCP10540 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery box with a sharp knife or a pair of scissors. For all XJ550, XJ650, XJ700, XJ750, and XJ900RK models.
    $ 9.95
    HCP10541 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery tray with a sharp knife or a pair of scissors. For all XJ1100 models.
    $ 13.95
    HCP10580 Aftermarket acid-neutralizing BATTERY TERMINAL PROTECTORS, thin, round felt mat circles are pressure-treated with a battery-acid neutralizing chemical. Placed under the battery terminal posts, they help prevents any spills or discharge from the battery from creating terminal corrosion. Trim and size to fit your battery posts with a sharp knife or a pair of scissors. Order 1 per terminal, 2 per battery. Each:
    $ 3.95
    r) Replacement 8-CIRCUIT ENCLOSED FUSEBOX. This small, weatherproof ATC (mini push-in blade style fuse) fusebox is the most popular replacement for the stock glass-tube fusebox and is the type that many owners use. Same as the HCP378 fusebox above, but with two extra slots for a total of 8 circuits, in case you need to add even more circuits. Includes a total of eight ATC push-in style fuses, 2 x 20A and 6 x 10A.
    Size: 4-1/2" long x 1-1/8" wide (not including the wire terminal spades) x 1-5/8" tall (including the clear cover). Note that this is a "bottom-terminal" design...the male spades point down towards the base of the fusebox, rather than out the sides. . THIS FEATURE CAN MAKE THE INSTALLATION OF THIS FUSEBOX TRICKY ON THESE BIKES, and the additional height of this box will cause interference problems between the fusebox cover and the bottom of the seat pan on stock bikes.
    HCP379BC Aftermarket FUSEBOX, 8-circuit with a full set of standard style ATC push-in style fuses (6 x 10A, and 2 x 20A).
    $ 16.95
    HCP379LF Aftermarket FUSEBOX, 8-circuit with a full set of "glow-when-blown" indicator style ATC push-in style fuses (6 x 10A, and 2 x 20A).
    $ 19.95
    In-Line Fuseholders:
    rf1) Aftermarket replacement individual INLINE FUSE HOLDER, heavy-duty waterproof style features a snap-close cap and accepts the standard or "glow-when-blown" type ATC/ATO push-in style fuses.
    NOTE: on all XJ models except XJ700, 1982 XJ750 Maxim, XJ750 Seca, and XJ1100 models, the original fusebox uses a 20A fuse for the main circuit, and 10A fuses for the headlight, turn signals, and ignition circuits. Upgrading to a larger capacity fuse HOLDER poses no problems or issues, but [/b]NEVER[/b] use a larger fuse than the original rated capacity of a circuit (regardless of what "size" fuseholder you use on the circuit).
    XJ700 models used a fuse panel (under the gauges) that already comes with ATC style fuses for the auxiliary circuits, and there is no need to upgrade that! However, the XJ700 models use a 30A main fuse in a separate in-line fuse holder that uses the old glass-style fuse, and that is certainly a candidate for updating with the 30A ATC style in-line fuse holder HCP6833 or HCP16777 listed below.
    XJ1100 models used a standard style glass-fuses panel along with a 30A main fuse in a separate in-line fuse holder that uses the old glass-style fuse, and that is certainly a candidate for updating with the 30A ATC style in-line fuse holder HCP6833 or HCP16777 listed below.
    HCP7122 Aftermarket standard IN-LINE FUSE HOLDER, solid colored thermoplastic housing, 6" long, 16-gauge wire leads, 10A capacity, each:
    $ 3.95
    HCP6833 Aftermarket standard IN-LINE FUSE HOLDER, solid colored thermoplastic housing, 6" long, 12-gauge wire leads, 30A capacity, each:
    $ 4.95
    HCP6833SET4 Aftermarket standard IN-LINE FUSE HOLDERS, solid colored thermoplastic housing, set of 4:
    $ 17.95
    HCP16777 Aftermarket MAIN FUSEHOLDER REPLACEMENT KIT, contains the weatherproof "blade" style HCP6833 main fuse holder with the white plastic connector shell that plugs into your main wiring harness (just like the original main fuseholder does).....no splicing, dicing, or harness chopping required! Includes 2 x 30A blade fuses (1 for use and 1 as a spare). Fits all XJ700, XJ750-X, XJ1100, and 1980-81 XS1100 models.
    $ 16.95
    HCP6834 Aftermarket see-through IN-LINE FUSE HOLDER, designed to be used with the "glow-when-blown" fuses, 4" long, 12-gauge wire leads, 20A capacity, each:
    $ 7.95
    HCP6834SET4 Aftermarket see-through IN-LINE FUSE HOLDERS, set of 4:
    $ 29.95
    Replacement Fuses:
    rf2) Aftermarket replacement ATC/ATO FUSES, for use with the above 6- or 8-circuit replacement fuseboxes or the in-line fuseholders. Both the standard style and "Glow-When-Blown" fuses are high quality products that meet or exceed current vehicle manufacturer specifications.
    HCP7149 Aftermarket standard type 5-AMP ATC/ATO FUSE, orange, push-in style, each:
    $ 0.95
    HCP7149SET5 Aftermarket standard type 5-AMP ATC/ATO FUSES, orange, push-in style, set of 5:
    $ 3.95
    HCP381 Aftermarket standard type 10-AMP ATC/ATO FUSE, red, push-in style, each:
    $ 0.95
    HCP381SET5 Aftermarket standard type 10-AMP ATC/ATO FUSES, red, push-in style, set of 5:
    $ 3.95
    HCP7150 Aftermarket standard type 15-AMP ATC/ATO FUSE, blue, push-in style, each:
    $ 0.95
    HCP7150SET5 Aftermarket standard type 15-AMP ATC/ATO FUSES, blue, push-in style, set of 5:
    $ 3.95
    HCP380 Aftermarket standard type 20-AMP ATC/ATO FUSE, yellow, push-in style, each:
    $ 0.95
    HCP380SET5 Aftermarket standard type 20-AMP ATC/ATO FUSES, yellow, push-in style, set of 5:
    $ 3.95
    HCP7151 Aftermarket standard type 30-AMP ATC/ATO FUSE, green, push-in style, each:
    $ 0.95
    HCP7151SET5 Aftermarket standard type 30-AMP ATC/ATO FUSES, green, set of 5:
    $ 3.95
    The following are innovative "Glow-When Blown" ATC/ATO mini-fuses that incorporate a small, bright indicator light that activates when the fuse blows, thus making the identification of a disrupted circuit easy to spot:
    HCP7147 Aftermarket "GLOW-WHEN-BLOWN" 5-AMP ATC/ATO FUSE, tan, push-in style, each:
    $ 2.95
    HCP7147SET5 Aftermarket "GLOW-WHEN-BLOWN" 5-AMP ATC/ATO FUSES, tan, push-in style, set of 5:
    $ 12.95
    HCP6832 Aftermarket "GLOW-WHEN-BLOWN" 10-AMP ATC/ATO FUSE, red, push-in style, each:
    $ 2.95
    HCP6832SET5 Aftermarket "GLOW-WHEN-BLOWN" 10-AMP ATC/ATO FUSES, red, push-in style, set of 5:
    $ 12.95
    HCP7148 Aftermarket "GLOW-WHEN-BLOWN" 15-AMP ATC/ATO FUSE, blue, push-in style, each:
    $ 2.95
    HCP7148SET5 Aftermarket "GLOW-WHEN-BLOWN" 15-AMP ATC/ATO FUSES, blue, push-in style, set of 5:
    $ 12.95
    HCP6831 Aftermarket "GLOW-WHEN-BLOWN" 20-AMP ATC/ATO FUSE, yellow, push-in style, each:
    $ 2.95
    HCP6831SET5 Aftermarket "GLOW-WHEN-BLOWN" 20-AMP ATC/ATO FUSES, yellow, push-in style, set of 5:
    $ 12.95
    HCP7146 Aftermarket "GLOW-WHEN-BLOWN" 30-AMP ATC/ATO FUSE, green, push-in style, each:
    $ 2.95
    HCP7146SET5 Aftermarket "GLOW-WHEN-BLOWN" 30-AMP ATC/ATO FUSES, green, push-in style, set of 5:
    $ 12.95[/i][/i]
  4. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Electrical System Wiring: Wiring harness components and related.
    ELECTRICAL WIRE HARNESS PARTS: INTRODUCTION:
    Wiring issues tend to cause quite a bit of confusion and distress to many people, for a variety of reasons, the foremost reason being that some electrical device isn't functioning properly, or at all! An that's when the intimidation starts to set in, staring at a maze of seemingly identical wires, connectors, terminals, etc............sometimes even hidden inside their protective sheathing.
    We're here to help............with the physical aspects of your wiring system components, at least! Don't ask us about the electricity that flows inside those wires and terminals, though, it's a complete mystery to us, too.......... :D
    As a more familiar and easily understandable introduction to the entire wiring subject, let's take the case of a typical household situation: your toaster.
    A toaster is what we will call a device. It is one of many types of devices that you can plug into the main electrical wiring harness that runs throughout your house (which starts at the fusebox or fuse panel located somewhere in your house). This main electrical wiring harness is normally hidden behind the sheetrock walls, and is normally only "visible" to you when an electrical outlet (or, a light switch, etc.) branches off of it and pokes thru the wall.
    At that point, you see a wall outlet, the common three-place receptacle that you could plug your device (toaster, TV, computer, etc.) into. This wall "outlet" is actually composed of a few component pieces though:
    - the wires that are part of that main wiring harness. In homes, which use AC current, you typically have 3 wires that go to each outlet: positive, negative, and a neutral. DC electrical systems, as used in most vehicles, typically only have a positive and a negative ("ground") wire as part of each circuit.
    - each of those wires has, on each of its ends, a metal wire-end terminal that allows the physical interaction between two wires that are being hooked into one another to be secure.
    - those three wires are all joined together, for organizational and safety purposes, into a plastic connector block or "shell". The wire, with their (typically, brass) metal end terminals, are placed within and permanently aligned and oriented in relation to one another within this connector block or shell.
    Okay, so good so far........
    But once you start thinking about it, that device that you want to power----the toaster, the TV, the whatever-----it also has a plastic connector block or shell on it, also. It's what we typically call a "plug", but once again, what we call a plug is really composed of the same three component parts: wires, a metal wire-end terminal which is attached to the end of each wire, and a plastic connector block or shell (called the "plug") that holds the wires and their end terminals in alignment.
    And notice, that the device (the toaster) may have a long length of wire from it to its connector block or shell (called a "plug"). This long run of wire(s), with their attached end plug, is what we refer to as a "lead-in harness", since it "leads into" the device.
    Now in order to get our Pop-tarts toasted, we must get power from the main wire harness to the toaster, and of course we do this by joining the connector block on the end of the toaster "lead-in" harness (the "plug") to the connector block on the end of the main house wire harness (the "outlet").
    In other words, we "plug" (or "join") the connector block on the end of the "device" into the connector block from the main house harness (the "outlet").
    Okay, I know the above explanation is kind of silly, but it's meant to help clarify what the descriptive terms are in a manner that is hopefully easy to understand. On your bike, there is a main wire harness, and this main harness has all types of branch circuits for each final-use device----such as your handlebar control switches, your headlight, each of your switches and relays, the regulator, each turn signal, the coils, etc.
    Each branch circuit has the appropriate wires for the device it is being connected to, each device (well, most of them!) has its own lead-in harness, and at the point of connection there are wires, each with a metal wire-end terminal, and all housed together in a plastic connector block or shell. There is a connector block or shell on the device side of the connection, and a mating version of it on the main harness side of the connection.
    Since the connector blocks are designed to "mate" together, there are both a "male" and "female" version of each style connector block that only mates into one of its own "kind" (unlike in your house, where most devices can plug into any main harness outlet). On your bike you want to plug in your coil connector only to its proper main harness circuit wiring, and thus different types (shapes, sizes, and colors) of connector blocks are used on each circuit. In this way, it insures that the handlebar switch (the device) can only be plugged into its proper main harness circuit mating connector shell that is on the main harness.
    So when you read the description below, and it says that a particular connector shell is used on:
    - Starter solenoid lead harness, on the main harness side of the connection: all XJ-series bikes (except all XJ700 and XJ750-X models).
    now you will understand what that means-----that the particular connector shell being referenced is used on this particular "device" (in the above example, for the starter solenoid), and, it is used on the main harness "side" of the connection of this device to the main wiring harness. The "other side" of this joint would use the opposite mate of this same style connector block, and would be described as:
    - Starter solenoid lead harness, on the solenoid lead-in harness side of the connection: all XJ-series bikes (except all XJ700 and XJ750-X models).
    ......and thus holds the wires and terminals that are on the short "lead-in" harness that actually goes into the starter solenoid (device) itself.
    Also note that in some situation, the same style connectors can be used on different circuits, and for different devices, but are color-coded differently so as to distinguish one circuit from another.
    Whew! Ain't electricity fun? If you get confused along the way, just holler, and we'll do our best to get you (and your harness) "connected" properly.
    ELECTRICAL HARNESS WIRE:
    But not just any kind of wire! We offer only the highest-quality GXL cross-linked PVC-coated wire in the correct gauge stranded copper core in both SOLID-COLOR and TRACER-STRIPE WIRE. This wire is far superior to common chain-store wire and is available in most of the original tracer-stripe color coding scheme so you can keep your harness original or build a new harness and still trace your circuits properly.
    A brief comparison illustrates the superiority of GXL wire versus standard wire: most "regular" automotive-grade wire is designated as a "GPT" grade of extruded PVC wire, and it is rated for -40 to +80-C temperatures. This type wire, if it gets hot enough, will not only melt, but it will also catch on fire.....a great way to ruin your day, your wire harness, your bike, etc. GPT grade wire is basically what was used originally by Yamaha in your harness, and is normally what you can buy in retail home-improvement and hardware stores. It is created by heating PVC and then quickly extruding it through a die over a particular size of stranded (or solid) wire core.
    GXL grade wire, although still a PVC-based product, is formed by extruding PVC through a tube, under intense heat and pressure, in order to 'cross-link' and change the molecular properties of the insulation to a much more durable state. This is why GXL wire is rated for use from -51 to +125-C (225-F) temperatures. Additionally, although GXL wire will still melt when its heat rating is exceeded, it is not flammable, and that may be a very important consideration for you should a short ever develop within your electrical system someday..........
    What size is my wire?:
    Unfortunately, factory wiring diagrams indicate almost every other parameter about your wiring harness----wire color, wire connector type, where it goes to and where it comes from and where it's spliced together, etc.-----but does not specify the wire gauge (or size) of the wires used.
    A little bit on wire "gauge" sizes. The gauge of a wire is basically what size the inner wire core is, and that size determines the wire current-carrying capacity. The lower the gauge number, the larger the wire size and thus current-handling capacity. Thus a 14-gauge wire is larger (physically and in current carrying capacity) than a 16-gauge, or an 18-gauge, or a 20-gauge, etc. size wire.
    Yes, we know that's "backwards", but that's the way it is. In fact, wire gauges (often noted as "AWG", which stands for American Wire Gauge Standard----and yes, there is also a metric wire sizing "standards", too!) are really a medieval sort of thing.....for example, you are holding a piece of wire in your hand----perhaps the solid white wire that goes to your alternator stator----and you're wondering "what gauge wire is this?" I mean, you really do want to know that information, since you want to replace it with that gauge wire or larger (meaning a "lower" number wire gauge size), but never a smaller (= a higher wire gauge size) wire, as the original wire is designed to carry a certain amount of electrical energy, and substituting a smaller wire size could cause voltage loss (think: dim headlights, overcharged batteries, overheated wires, melted connectors, a small fire starting somewhere near your gas tank, etc.-------all sorts of devastation, electrically-speaking).
    So how to you determine what size wire is in your hand? Well, this is kind of confusing, but here goes:
    - for stranded-core wire (which is what is used on most vehicular applications, including these bikes), you should do the following:
    * Make a small cut about 1/2" long and remove the insulation from the wire.
    * Then you will need to count the individual strands of copper....how many individual strands are there?
    * Next, use a micrometer and measure the thickness of any one single strand.
    * Then, look at the following information to determine the gauge of your automotive wire:
    # of strands / diameter of each wire strand
    7 x .028" = 20-gauge wire
    (this example means that a 20-gauge wire has 7 individual wire strands, each strand measuring .028" in diameter)
    16 x .030" =18-gauge wire
    19 x .029" =16-gauge wire
    19 x .027" =14-gauge wire
    19 x .025" =12-gauge wire
    19 x .023" =10-gauge wire
    19 x .021" = 08-gauge wire
    37 x .021" = 06-gauge wire
    Wow, that's a lot of work, isn't it?
    Here's the shortcut method that applies to your harness wires.........you measure the outside diameter of the wire in your hand (meaning, the O.D. of the insulation) and that measurement tells you what the AWG of the wire core is. NOTE: make sure that you measure the wire on a straight portion of the wire, and it's useful to take 2 or 3 different measurements to make sure you are not measuring a distorted, "egg-shaped" area of the insulation:
    If the wire OD is 2.03mm - 2.19mm (.0799 to .0862"), then it's 20-gauge (20g) AWG or 0.40mm squared (metric size).
    NOTE: 20g wire is rated for a maximum load of 11 amps of current at 12VDC.
    If the wire OD is 2.26mm - 2.42mm (.0890 to .0953"), then it's 18-gauge (18g) AWG or 0.75mm squared (metric size).
    NOTE: 18g wire is rated for a maximum load of 16 amps of current at 12VDC.
    If the wire OD is 2.48mm - 2.64mm (.0976 to .1039"), then it's 16-gauge (16g) AWG or 1.25mm squared (metric size).
    NOTE: 16g wire is rated for a maximum load of 22 amps of current at 12VDC.
    If the wire OD is 2.89mm - 3.05mm (.1138 to .1201"), then it's 14-gauge (14g) AWG or 2.00mm squared (metric size).
    NOTE: 14g wire is rated for a maximum load of 32 amps of current at 12VDC.
    NOTE: 14g wire is the largest size wire normally found in the wiring harnesses on these bikes. Battery cables and the solenoid-to-starter motor cable are larger, of course, but of all the main harness and accessory wiring, 14-gauge is the largest that you'll find.
    If the wire OD is 3.49mm - 3.65mm (.1374 to .1437"), then it's 12-gauge (12g) AWG or 3.00mm squared (metric size).
    NOTE: 12g wire is rated for a maximum load of 41 amps of current at 12VDC.
    If the wire OD is 4.32mm - 4.48mm (.1701 to .1764"), then it's 10-gauge (10g) AWG or 5.00mm squared (metric size).
    NOTE: 10g wire is rated for a maximum load of 55 amps of current at 12VDC.
    So, for example, if you measure your white alternator stator lead wires, you'll find them to be about .1015" in outer diameter, and referring to the chart above, you determine that they are thus 16-gauge wire. And therefore you should always replace them, if needed, with 16-gauge or larger wire (meaning 16-gauge, 14-gauge, 12-gauge, etc.).
    If you measure your solid red harness lead wire that comes off your solenoid or regulator unit----which is the main power supply for your harness-----you might find it measures about .1185" in diameter. Again referring to the chart above, it is therefore a 14-gauge wire.
    REMEMBER: always use the same-size (gauge) wire as original or a larger size (a numerically smaller gauge size) or otherwise you are setting yourself up for major problems and the risk of fire!
    What color is my wire?:
    There are two different formats of wire insulation colors in your harness:
    * solid colored wire, which is pretty self-explanatory, and.....
    * tracer wire, which is a solid color wire imprinted with a permanent, straight, contrasting-color stripe along its entire length. This "tracer stripe" makes it easy to identify any particular wire and what circuit it belongs to.
    For the sake of both clarity, future troubleshooting, and safety, we always strongly urge people to replace wires with the same color and format (solid color vs. tracer-stripe) wire as was originally used, or, if you're building your own custom harness, to follow the same color-coding standards as what was originally used by Yamaha (for example: the main power feed wire for the harness is a solid red wire; solid black wires are ground circuit wires; a solid yellow wire is the rear brake light wire; a horn wire is a solid pink wire; the coils are fed by a solid orange wire, a solid grey wire, and a red wire with a white tracer stripe, etc.).
    This attention to detail make for a professional harness build or repair, and greatly simplifies your life in the future!
    In your factory wire diagram, solid color wires are identified by their solid color abbreviation, which are:
    B = Black
    Br = Light Brown
    Ch = Chocolate Brown, which is a very dark brown, almost black.
    Dg = Dark green, which is a very dark green, almost black.
    Gr = Green, which could be a light or medium green color.
    Gy = Grey, which is a light grey color
    L = Blue, which could be a medium or a navy blue or even a very dark blue, almost black.
    P = Pink
    O = Orange, which is a bright orange
    R = Red
    Sb = Light Blue or "Sky" Blue, a very light, baby-blue color.
    W = White
    Y = Yellow, which is a bright yellow
    So a solid Black wire would be coded as "B", while a solid Light Brown wire appears as "Br", while a Dark "Chocolate" Brown wire is abbreviated as "Ch".
    Tracer wires are identified first by their primary wire color abbreviation (from the chart above), and then a slash mark (/), followed by the tracer stripe color abbreviation.
    So for instance, a Black (B) wire that has a thin Yellow (Y) tracer stripe will appear on the diagrams as B/Y or
    B/y (the lower case letter makes the identify of the "tracer" color more obvious).
    A Red (R) wire with a white tracer stripe would be labeled as R/W (or R/w), while a Red wire with a black tracer stripe would be R/B (or R/b).
    Be aware that some tracer stripe colors are very difficult to tell apart from each other (particularly white vs. yellow tracer stripes), while other tracer stripe colors are just hard to see because of the lack of color contrast (for instance, a dark blue wire with a black tracer stripe).
    Solid Black (B) Wire:
    Used for various harness ground wires, this wire can vary in size from 20-gauge (which is not available, use the next larger size 18-gauge instead) all the way down to 12-gauge, so make sure you measure the wire size you need and order the correct size. If in doubt, use the largest size possible!
    HCP1323 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1323SET5 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1323SET10 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1323SET25 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP12944 Aftermarket GPT SOLID BLACK CLOTH-COVERED WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge cloth-covered. This wire is used on the alternator rotor brushes lead harness on XJ1100 models only. Sold per foot:
    $ 2.95
    HCP12944SET5 Aftermarket GPT SOLID BLACK CLOTH-COVERED WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge, cloth-covered, 5-foot length:
    $ 12.95
    HCP9515 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 2.95
    HCP9515SET5 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP9515SET10 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP9515SET25 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    HCP9517 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 14-gauge. Sold per foot:
    $ 2.95
    HCP9517SET5 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 14-gauge, 5-foot length:
    $ 12.95
    HCP9517SET10 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 14-gauge, 10-foot length:
    $ 19.95
    HCP9517SET25 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 14-gauge, 25-foot length:
    $ 39.95
    HCP1324 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 12-gauge. Sold per foot:
    $ 2.95
    HCP1324SET5 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 12-gauge, 5-foot length:
    $ 12.95
    HCP1324SET10 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 12-gauge, 10-foot length:
    $ 19.95
    HCP1324SET25 Aftermarket GXL SOLID BLACK WIRE, abbreviated as "B" in factory wiring diagrams, 12-gauge, 25-foot length:
    $ 39.95
    Black Tracer Wire:
    Used in a variety of places---mostly for sensors and safety relays---are used throughout many harnesses. Please note that it is sometimes very difficult on original harnesses to visually tell the difference between a white and a yellow tracer stripe, so make sure you view it under s good light or consult a factory wiring diagram to be sure!
    NOTE: many of the original wires on your harness will be 20-gauge. We do not offer 20-gauge wire and recommend that you substitute the slightly larger 18-gauge wire in place of it.
    HCP1335 Aftermarket GXL BLACK with RED TRACER STRIPE WIRE, abbreviated as "B/R" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1335SET5 Aftermarket GXL BLACK with RED TRACER STRIPE WIRE, abbreviated as "B/R" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1335SET10 Aftermarket GXL BLACK with RED TRACER STRIPE WIRE, abbreviated as "B/R" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1335SET25 Aftermarket GXL BLACK with RED TRACER STRIPE WIRE, abbreviated as "B/R" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9519 Aftermarket GXL BLACK with WHITE TRACER STRIPE WIRE, abbreviated as "B/W" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP9519SET5 Aftermarket GXL BLACK with WHITE TRACER STRIPE WIRE, abbreviated as "B/W" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP9519SET10 Aftermarket GXL BLACK with WHITE TRACER STRIPE WIRE, abbreviated as "B/W" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP9519SET25 Aftermarket GXL BLACK with WHITE TRACER STRIPE WIRE, abbreviated as "B/W" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1336 Aftermarket GXL BLACK with YELLOW TRACER STRIPE WIRE, abbreviated as "B/Y" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1336SET5 Aftermarket GXL BLACK with YELLOW TRACER STRIPE WIRE, abbreviated as "B/Y" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1336SET10 Aftermarket GXL BLACK with YELLOW TRACER STRIPE WIRE, abbreviated as "B/Y" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1336SET25 Aftermarket GXL BLACK with YELLOW TRACER STRIPE WIRE, abbreviated as "B/Y" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Blue Wire:
    Although the factory wiring diagrams only specified the difference between the Sky Blue ("Sb") color and a generic Blue ("L") color in their wiring diagrams, there were in fact a number of different shades of "blue", with only the Sky Blue color being somewhat consistent.
    - Sky Blue (abbreviated as "Sb" in factory wire diagrams), which is a very pale baby blue color. Your neutral switch and starting circuit cut-off relay use this color wire.
    - Blue (abbreviated as "L" in factory wire diagrams), which may be either a:
    - Light Blue.
    - Medium Blue.
    - Dark Blue-------which is a very, very dark (almost black) shade of blue.
    We offer a "Light Blue" color which is slightly darker than the Sky Blue color, and a Dark Blue, which a very dark blue color.
    The solid blue wires (besides the Sky Blue) are normally used for the rear tail light circuit and some of the dash lighting circuits.
    HCP1332 Aftermarket GXL SOLID SKY BLUE WIRE, abbreviated as "Sb" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1332SET5 Aftermarket GXL SOLID SKY BLUE WIRE, abbreviated as "Sb" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1332SET10 Aftermarket GXL SOLID SKY BLUE WIRE, abbreviated as "Sb" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1332SET25 Aftermarket GXL SOLID SKY BLUE WIRE, abbreviated as "Sb" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1329 Aftermarket GXL SOLID DARK BLUE WIRE, abbreviated as "L" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1329SET5 Aftermarket GXL SOLID DARK BLUE WIRE, abbreviated as "L" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1329SET10 Aftermarket GXL SOLID DARK BLUE WIRE, abbreviated as "L" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1329SET25 Aftermarket GXL SOLID DARK BLUE WIRE, abbreviated as "L" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Blue Tracer Wire:
    Primarily found in switch or relay wiring circuits, most of these wires were originally 20-gauge. Since we do not offer 20-gauge wire, we recommend that you substitute the slightly larger 18-gauge wire in place of it.
    HCP9525 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP9525SET5 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP9525SET10 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP9525SET25 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1339 Aftermarket GXL DARK BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1339SET5 Aftermarket GXL DARK BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1339SET10 Aftermarket GXL DARK BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1339SET25 Aftermarket GXL DARK BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9520 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 2.95
    HCP9520SET5 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP9520SET10 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP9520SET25 Aftermarket GXL LIGHT BLUE with BLACK TRACER STRIPE WIRE, abbreviated as "L/B" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    HCP1340 Aftermarket GXL DARK BLUE with WHITE TRACER STRIPE WIRE, abbreviated as "L/W" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.975
    HCP1340SET5 Aftermarket GXL DARK BLUE with WHITE TRACER STRIPE WIRE, abbreviated as "L/W" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1340SET10 Aftermarket GXL DARK BLUE with WHITE TRACER STRIPE WIRE, abbreviated as "L/W" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1340SET25 Aftermarket GXL DARK BLUE with WHITE TRACER STRIPE WIRE, abbreviated as "L/W" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1341 Aftermarket GXL LIGHT BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge. NOTE: original harness wire color was always a dark blue, not this light blue color, when used with a yellow tracer stripe. Sold per foot:
    $ 1.95
    HCP1341SET5 Aftermarket GXL LIGHT BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1341SET10 Aftermarket GXL LIGHT BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1341SET25 Aftermarket GXL LIGHT BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9524 Aftermarket GPT DARK BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge. NOTE: original harness wire color was always a dark blue color when used with a yellow tracer stripe. This wire is the correct shade of blue, but it is formed using a lower grade of vinyl insulation (GPT) rather than the GXL wire used in most of the other wiring that we offer. Sold per foot:
    $ 1.95
    HCP9524SET5 Aftermarket GPT DARK BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP9524SET10 Aftermarket GPT DARK BLUE with YELLOW TRACER STRIPE WIRE, abbreviated as "L/Y" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 16.95
    $ 29.95
    Solid Brown Wire:
    Originally, there were 2 shades of brown wire used on original harnesses:
    - Light Brown (abbreviated as "Br" in factory wire diagrams), which is a light or medium shade of brown. This wire is used in a variety of places within the harness; it is one of the most commonly used wire colors. Note that the main power feed from the ignition switch to the fusebox is brown, and it is a 14-gauge wire.
    - Dark Brown (abbreviated as "Ch" in factory wire diagrams, for "Chocolate") and is a very, very dark----almost black----shade of brown). Your turn signal circuit uses this shade of brown wire.
    We offer a Light Tan colored GXL wire which can be substituted for the Light Brown (Br) wire, as well as an actual Light Brown (Br) colored GPT grade wire. The GPT grade wire is not as durable as the GXL wire, but it is a much closer match to the original in color.
    The Dark Brown colored wire is a very close to the original Dark "Chocolate" Brown (Ch) shade of brown.
    HCP12843 Aftermarket GXL SOLID TAN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge. Sold per foot:
    $ 2.95
    HCP12843SET5 Aftermarket GXL SOLID TAN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge, 5-foot length:
    $ 12.95
    HCP12843SET10 Aftermarket GXL SOLID TAN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge, 10-foot length:
    $ 19.95
    HCP12843SET25 Aftermarket GXL SOLID TAN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge, 25-foot length:
    $ 39.95
    HCP27174 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 1.95
    HCP27174SET5 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 8.95
    HCP27174SET10 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 16.95
    HCP27174SET25 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 29.95
    HCP392 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP392SET5 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP392SET10 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP392SET25 Aftermarket GXL SOLID TAN WIRE, slightly lighter in color as the wire that is abbreviated as "Br" (light brown) in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP15355 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge. Sold per foot:
    $ 2.95
    HCP15355SET5 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge, 5-foot length:
    $ 12.95
    HCP15355SET10 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge, 10-foot length:
    $ 19.95
    HCP15355SET25 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 14-gauge, 25-foot length:
    $ 39.95
    HCP15354 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP15354SET5 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP15354SET10 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP15354SET25 Aftermarket GPT LIGHT BROWN WIRE, abbreviated as "Br" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP27173 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 1.95
    HCP27173SET5 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 8.95
    HCP27173SET10 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 16.95
    HCP27173SET25 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 29.95
    HCP1325 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1325SET5 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1325SET10 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1325SET25 Aftermarket GXL SOLID DARK "CHOCOLATE" BROWN WIRE, abbreviated as "Ch" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP12943 Aftermarket GPT SOLID BROWN CLOTH-COVERED WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge cloth-covered. This wire is used only on the alternator rotor brushes lead harness on all bikes except XJ1100 models. Use with the HCP14154 harness sheathing. Sold per foot:
    $ 2.95
    HCP12943SET5 Aftermarket GPT SOLID BROWN CLOTH-COVERED WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge cloth-covered, 5-foot length:
    $ 12.95
    HCP12943SET10 Aftermarket GPT SOLID BROWN CLOTH-COVERED WIRE, abbreviated as "B" in factory wiring diagrams, 18-gauge cloth-covered, 10-foot length:
    $ 19.95
    Brown Tracer Wire:
    Used for the turn signal flasher circuit only, this light brown wire with a white tracer stripe was originally 20-gauge wire, and is only offered as an 18-gauge replacement wire.
    As noted above, we do not have the correct shade of the original Light Brown (Br) wire available, but offer this "Light Tan" wire color as a good substitute.
    HCP13007 Aftermarket GXL TAN with WHITE TRACER STRIPE WIRE, abbreviated as "Br/W" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP13007SET5 Aftermarket GXL TAN with WHITE TRACER STRIPE WIRE, abbreviated as "Br/W" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP13007SET10 Aftermarket GXL TAN with WHITE TRACER STRIPE WIRE, abbreviated as "Br/W" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP13007SET25 Aftermarket GXL TAN with WHITE TRACER STRIPE WIRE, abbreviated as "Br/W" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Green Wire:
    Originally, there were 2 shades of green wire used on original harnesses:
    - Green (abbreviated as "Gr" in factory wire diagrams), which may be either a:
    - Light Green wire.
    - Medium Green wire.
    The above colors are used for the headlight circuit and for the alternator rotor. Note that the solid green wires coming from the alternator rotor brush plate itself is a braided-cloth covered wire, and the standard plastic insulated wire that we offer should not be substituted for the cloth-covered wire.
    - Dark Green (abbreviated as "Dg" in factory wire diagrams) and is a very, very dark----almost black----shade of green). Your turn signal circuit uses this shade of green wire.
    The "Green" (G) wire could be either the Light or the Medium Green color. It is not unusual for an original harness to have multiple color variations of "Green" wire.
    HCP1327 Aftermarket GXL SOLID LIGHT GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1327SET5 Aftermarket GXL SOLID LIGHT GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1327SET10 Aftermarket GXL SOLID LIGHT GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1327SET25 Aftermarket GXL SOLID LIGHT GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1326 Aftermarket GXL SOLID MEDIUM GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1326SET5 Aftermarket GXL SOLID MEDIUM GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1326SET10 Aftermarket GXL SOLID MEDIUM GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1326SET25 Aftermarket GXL SOLID MEDIUM GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP28868 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge. This wire is used with the turn signal circuit on all models and is a very dark green (almost black). Sold per foot:
    $ 2.95
    HCP28868SET5 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 12.95
    HCP28868SET10 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 19.95
    HCP28868SET25 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 39.95
    HCP26178 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 16-gauge. This wire is used with the headlight circuit on models with analog gauges. Sold per foot:
    $ 2.95
    HCP26178SET5 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP26178SET10 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP26178SET25 Aftermarket GXL SOLID DARK GREEN WIRE, abbreviated as "G" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    HCP12942 Aftermarket GPT SOLID GREEN CLOTH-COVERED WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge cloth-covered. This wire is used only on the alternator rotor brushes lead harness on all bikes except XJ1100 models. Use with the HCP14154 harness sheathing. Sold per foot:
    $ 2.95
    HCP12942SET5 Aftermarket GPT SOLID GREEN CLOTH-COVERED WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge cloth-covered, 5-foot length:
    $ 12.95
    HCP12942SET10 Aftermarket GPT SOLID GREEN CLOTH-COVERED WIRE, abbreviated as "G" in factory wiring diagrams, 18-gauge cloth-covered, 10-foot length:
    $ 19.95
    Green Tracer Wire:
    Used for the clutch hand lever position switch circuit only, the green wire with a yellow tracer stripe was originally 20-gauge wire, and is only offered as an 18-gauge replacement wire.
    On some models, there is also a green wire with a blue tracer stripe used in the kickstand switch circuit; we do not have that color combination available, and offer the Green with Red Tracer stripe wire as a substitute.
    As noted above, any original Green (G) colored wire could be either a Light Green or a Medium Green color. The Light or Medium Green colored tracer wire that we offer below may or may not match your original "green" colored harness wire exactly.
    HCP12842 Aftermarket GXL LIGHT GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP12842SET5 Aftermarket GXL LIGHT GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP12842SET10 Aftermarket GXL LIGHT GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP12842SET25 Aftermarket GXL LIGHT GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9534 Aftermarket GXL MEDIUM GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP9534SET5 Aftermarket GXL MEDIUM GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP9534SET10 Aftermarket GXL MEDIUM GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP9534SET25 Aftermarket GXL MEDIUM GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP26179 Aftermarket GXL DARK GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 16-gauge. This wire is used with the headlight circuit on models with a "computer" dash. Sold per foot:
    $ 2.95
    HCP26179SET5 Aftermarket GXL DARK GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP26179SET10 Aftermarket GXL DARK GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP26179SET25 Aftermarket GXL DARK GREEN with RED TRACER STRIPE WIRE, abbreviated as "G/R" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    HCP1338 Aftermarket GXL LIGHT GREEN with YELLOW TRACER STRIPE WIRE, abbreviated as "G/Y" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1338SET5 Aftermarket GXL LIGHT GREEN with YELLOW TRACER STRIPE WIRE, abbreviated as "G/Y" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1338SET10 Aftermarket GXL LIGHT GREEN with YELLOW TRACER STRIPE WIRE, abbreviated as "G/Y" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1338SET25 Aftermarket GXL LIGHT GREEN with YELLOW TRACER STRIPE WIRE, abbreviated as "G/Y" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Grey (Gy) Wire:
    Used from the pick-up coils to the TCI, and from the TCI to the ignition coils, this wire was originally 18-gauge.
    NOTE: when reading a factory wire diagram, be careful not to confuse the abbreviation for this Solid Grey wire (Gy) with the abbreviation for a Green wire with a yellow tracer stripe (G/Y)!
    HCP1328 Aftermarket GXL SOLID GREY WIRE, abbreviated as "Gy" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1328SET5 Aftermarket GXL SOLID GREY WIRE, abbreviated as "Gy" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1328SET10 Aftermarket GXL SOLID GREY WIRE, abbreviated as "Gy" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1328SET25 Aftermarket GXL SOLID GREY WIRE, abbreviated as "Gy" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Orange (O) Wire:
    HCP1330 Aftermarket GXL SOLID ORANGE WIRE, abbreviated as "O" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1330SET5 Aftermarket GXL SOLID ORANGE WIRE, abbreviated as "O" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1330SET10 Aftermarket GXL SOLID ORANGE WIRE, abbreviated as "O" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1330SET25 Aftermarket GXL SOLID ORANGE WIRE, abbreviated as "O" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Pink (P) Wire:
    Used for the horn wiring, this wire was originally 18-gauge.
    HCP1331 Aftermarket GXL SOLID PINK WIRE, abbreviated as "P" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1331SET5 Aftermarket GXL SOLID PINK WIRE, abbreviated as "P" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1331SET10 Aftermarket GXL SOLID PINK WIRE, abbreviated as "P" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1331SET25 Aftermarket GXL SOLID PINK WIRE, abbreviated as "P" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Red (R) Wire:
    Used for the main harness power feed off of the battery positive cable or the solenoid, the solid red wire feeds thru the fusebox and the ignition switch, and also runs to the voltage regulator/rectifier unit. This wire was originally 14-gauge and you should never use any smaller size. We also offer it in a larger 12-gauge size.
    HCP9536 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 14-gauge. Sold per foot:
    $ 2.95
    HCP9536SET5 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 14-gauge, 5-foot length:
    $ 12.95
    HCP9536SET10 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 14-gauge, 10-foot length:
    $ 19.95
    HCP9536SET25 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 14-gauge, 25-foot length:
    $ 39.95
    HCP389 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 12-gauge. Sold per foot:
    $ 2.95
    HCP389SET5 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 12-gauge, 5-foot length:
    $ 128.95
    HCP389SET10 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 12-gauge, 10-foot length:
    $ 19.95
    HCP389SET25 Aftermarket GXL SOLID RED WIRE, abbreviated as "R" in factory wiring diagrams, 12-gauge, 25-foot length:
    $ 39.95
    Red Tracer Wire:
    Used in a variety of places on the harness, red wires with tracer colors are the power feeds for various circuits, including many of the safety relays, the ignition coils, the starter solenoid, and other devices.
    NOTE: many of the original wires on your harness will be 20-gauge. We do not offer 20-gauge wire and recommend that you substitute the slightly larger 18-gauge wire in place of it. The Red with yellow tracer stripe wire (R/Y) in most harness was originally 18-gauge, and we only have this color wire available in a larger 16-gauge replacement.
    HCP1342 Aftermarket GXL RED with BLACK TRACER STRIPE WIRE, abbreviated as "R/B" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1342SET5 Aftermarket GXL RED with BLACK TRACER STRIPE WIRE, abbreviated as "R/B" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1342SET10 Aftermarket GXL RED with BLACK TRACER STRIPE WIRE, abbreviated as "R/B" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1342SET25 Aftermarket GXL RED with BLACK TRACER STRIPE WIRE, abbreviated as "R/B" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP387 Aftermarket GXL RED with WHITE TRACER STRIPE WIRE, abbreviated as "R/W" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP387SET5 Aftermarket GXL RED with WHITE TRACER STRIPE WIRE, abbreviated as "R/W" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP387SET10 Aftermarket GXL RED with WHITE TRACER STRIPE WIRE, abbreviated as "R/W" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP387SET25 Aftermarket GXL RED with WHITE TRACER STRIPE WIRE, abbreviated as "R/W" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP390 Aftermarket GXL RED with YELLOW TRACER STRIPE WIRE, abbreviated as "R/Y" in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 2.95
    HCP390SET5 Aftermarket GXL RED with YELLOW TRACER STRIPE WIRE, abbreviated as "R/Y" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP390SET10 Aftermarket GXL RED with YELLOW TRACER STRIPE WIRE, abbreviated as "R/Y" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP390SET25 Aftermarket GXL RED with YELLOW TRACER STRIPE WIRE, abbreviated as "R/Y" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    Solid White Wire:
    Used for the alternator stator, regulator/rectifier, and the headlight relay and diode wiring, this wire was originally either 20-gauge (use 18-gauge instead) or 16-gauge (alternator wiring). Note that the solid white wires coming out of the stator itself is a braided-cloth covered wire, and the standard plastic insulated wire that we offer should not be substituted for the cloth-covered wire.
    HCP1333 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1333SET5 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1333SET10 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1333SET25 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9540 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 2.95
    HCP9540SET5 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP9540SET10 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP9540SET25 Aftermarket GXL SOLID WHITE WIRE, abbreviated as "W" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    HCP12941 Aftermarket GPT SOLID WHITE CLOTH-COVERED WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge cloth-covered. This wire is used on the alternator stator lead harness only on all models. Sold per foot:
    $ 2.95
    HCP12941SET5 Aftermarket GPT SOLID WHITE CLOTH-COVERED WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge cloth-covered, 5-foot length:
    $ 12.95
    HCP12941SET10 Aftermarket GPT SOLID WHITE CLOTH-COVERED WIRE, abbreviated as "WB" in factory wiring diagrams, 18-gauge cloth-covered, 10-foot length:
    $ 19.95
    HCP12941SET25 Aftermarket GPT SOLID WHITE CLOTH-COVERED WIRE, abbreviated as "W" in factory wiring diagrams, 18-gauge cloth-covered, 25-foot length:
    $ 39.95
    White Tracer Wire:
    Used in a variety of sensing or lighting circuits, most o these wires were originally a 20-gauge wire, and are only offered as an 18-gauge replacement wire.
    HCP1343 Aftermarket GXL WHITE with BLACK TRACER STRIPE WIRE, abbreviated as "W/B" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1343SET5 Aftermarket GXL WHITE with BLACK TRACER STRIPE WIRE, abbreviated as "W/B" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1343SET10 Aftermarket GXL WHITE with BLACK TRACER STRIPE WIRE, abbreviated as "W/B" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1343SET25 Aftermarket GXL WHITE with BLACK TRACER STRIPE WIRE, abbreviated as "W/B" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9542 Aftermarket GXL WHITE with BLUE TRACER STRIPE WIRE, abbreviated as "W/L" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP9542SET5 Aftermarket GXL WHITE with BLUE TRACER STRIPE WIRE, abbreviated as "W/L" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP9542SET10 Aftermarket GXL WHITE with BLUE TRACER STRIPE WIRE, abbreviated as "W/L" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP9542SET25 Aftermarket GXL WHITE with BLUE TRACER STRIPE WIRE, abbreviated as "W/L" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1344 Aftermarket GXL WHITE with DARK GREEN TRACER STRIPE WIRE, abbreviated as "W/G" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1344SET5 Aftermarket GXL WHITE with DARK GREEN TRACER STRIPE WIRE, abbreviated as "W/G" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1344SET10 Aftermarket GXL WHITE with DARK GREEN TRACER STRIPE WIRE, abbreviated as "W/G" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1344SET25 Aftermarket GXL WHITE with DARK GREEN TRACER STRIPE WIRE, abbreviated as "W/G" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP1345 Aftermarket GXL WHITE with RED TRACER STRIPE WIRE, abbreviated as "W/R" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1345SET5 Aftermarket GXL WHITE with RED TRACER STRIPE WIRE, abbreviated as "W/R" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1345SET10 Aftermarket GXL WHITE with RED TRACER STRIPE WIRE, abbreviated as "W/R" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1345SET25 Aftermarket GXL WHITE with RED TRACER STRIPE WIRE, abbreviated as "W/R" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Solid Yellow (Y) Wire:
    Used for the rear brake light and, on some models, the headlight wiring, this wire was originally either 20-gauge (use 18-gauge instead) or 16-gauge. Note that some models used a Yellow wire with a green tracer stripe (Y/G) for the headlight circuit (instead of a solid yellow wire).
    HCP1334 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP1334SET5 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP1334SET10 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP1334SET25 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP9544 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 16-gauge. This wire is used in the headlight circuit. Sold per foot:
    $ 2.95
    HCP9544SET5 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP9544SET10 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP9544SET25 Aftermarket GXL SOLID YELLOW WIRE, abbreviated as "Y" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    Yellow Tracer Wire:
    Used for the turn signal flasher and flasher canceller, and on some models, the headlight wiring, this wire was originally either 20-gauge (use 18-gauge instead) or 18-gauge. Note that some models used a Solid Yellow wire for the headlight circuit (instead of a yellow with green tracer stripe wire).
    NOTE: where used, most original models use a dark green tracer stripe on these yellow wires; our replacement wire has a light green tracer stripe instead.
    NOTE: where used, most original models use a red tracer stripe on these yellow wires; our replacement wire has an orange tracer stripe instead. The original yellow with red tracer wires were 18-gauge; the only replacement we have available is in a thicker 16-gauge wire.
    HCP8557 Aftermarket GXL YELLOW with LIGHT GREEN TRACER STRIPE WIRE, abbreviated as "Y/G" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP8557SET5 Aftermarket GXL YELLOW with LIGHT GREEN TRACER STRIPE WIRE, abbreviated as "Y/G" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP8557SET10 Aftermarket GXL YELLOW with LIGHT GREEN TRACER STRIPE WIRE, abbreviated as "Y/G" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP8557SET25 Aftermarket GXL YELLOW with LIGHT GREEN TRACER STRIPE WIRE, abbreviated as "Y/G" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    HCP12884 Aftermarket GXL YELLOW with ORANGE TRACER STRIPE WIRE, abbreviated as "Y/R" in factory wiring diagrams, 16-gauge. Sold per foot:
    $ 2.95
    HCP12884SET5 Aftermarket GXL YELLOW with ORANGE TRACER STRIPE WIRE, abbreviated as "Y/R" in factory wiring diagrams, 16-gauge, 5-foot length:
    $ 12.95
    HCP12884SET10 Aftermarket GXL YELLOW with ORANGE TRACER STRIPE WIRE, abbreviated as "Y/R" in factory wiring diagrams, 16-gauge, 10-foot length:
    $ 19.95
    HCP12884SET25 Aftermarket GXL YELLOW with ORANGE TRACER STRIPE WIRE, abbreviated as "Y/R" in factory wiring diagrams, 16-gauge, 25-foot length:
    $ 39.95
    HCP9546 Aftermarket GXL YELLOW with WHITE TRACER STRIPE WIRE, abbreviated as "Y/W" in factory wiring diagrams, 18-gauge. Sold per foot:
    $ 1.95
    HCP9546SET5 Aftermarket GXL YELLOW with WHITE TRACER STRIPE WIRE, abbreviated as "Y/W" in factory wiring diagrams, 18-gauge, 5-foot length:
    $ 8.95
    HCP9546SET10 Aftermarket GXL YELLOW with WHITE TRACER STRIPE WIRE, abbreviated as "Y/W" in factory wiring diagrams, 18-gauge, 10-foot length:
    $ 16.95
    HCP9546SET25 Aftermarket GXL YELLOW with WHITE TRACER STRIPE WIRE, abbreviated as "Y/W" in factory wiring diagrams, 18-gauge, 25-foot length:
    $ 29.95
    Accessory Color Wire:
    Sometimes, you'll want to add electrical accessory circuits to you bike.....a cigarette lighter, heated grips, perhaps a power port for a GPS unit, etc......and in such situations, it's best to run a separate circuit, with its own unique color-coded wiring, in order to keep things neat and orderly, electrically-speaking. We offer the following unique colors (not used anywhere else on your bike) to help you safely and accurately identify any new circuits that you add.
    HCP9547 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge. Sold per foot:
    $ 2.95
    HCP9547SET5 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge, 5-foot length:
    $ 12.95
    HCP9547SET10 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge, 10-foot length:
    $ 19.95
    HCP9547SET25 Aftermarket GXL PINK with BLACK TRACER STRIPE WIRE, abbreviated P/B, 16-gauge, 25-foot length:
    $ 39.95
    HCP9548 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge. Sold per foot:
    $ 2.95
    HCP9548SET5 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge, 5-foot length:
    $ 12.95
    HCP9548SET10 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge, 10-foot length:
    $ 19.95
    HCP9548SET25 Aftermarket GXL PURPLE with WHITE TRACER STRIPE WIRE, abbreviated Pu/W, 16-gauge, 25-foot length:
    $ 39.95
  5. chacal
    Wire Harness Tape:
    Factory wire harness bundles were taped with a black electrically-insulating protective VINYL ELECTRICAL TAPE WRAP to provide both an orderly routing of the main harness wires and for additional wire protection. We have the correct 19mm wide black, high-voltage, adhesive-backed, all-weather stretch tape to allow you to repair or re-tape your harness. NOTE: XJ750 Maxim models that used this hard-shell, plastic ribbed tubing to protect the wire bundles had the hard-shell tubing externally wrapped with this tape.
    HCP12923 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 20-foot roll.
    $ 8.95
    HCP13134 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 66-foot roll, almost enough to do one complete harness.
    $ 16.95
    Additionally, most harnesses had a few short turns of COLORED VINYL ELECTRICAL TAPE WRAP to provide visual identification of "what connector goes where?" during harness assembly and installation. Always located just by the connector shell, about 3-4 turns of this tape was used to both tape off any vinyl sleeve and to properly identify what the connector plugged into. Used primarily at the TCI connector (from the pick-up coils) and at the various small "cube" style relays (headlight relays, sidestand safety switch relays, etc.). Since all of these harness connector shells are the same style and type (4-position, horizontally oriented 2-over-2), this small tape wrap served as a way of indicating which of these many identical connectors went to which component.
    HCP13130 Aftermarket harness bundle YELLOW VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on XJ700-X and XJ750-X models, and at the headlight relay connector on all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models.
    $ 7.95
    HCP13131 Aftermarket harness bundle RED VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on 1982-83 XJ650 Maxim models, all '81-83 XJ750 models, and all XJ700 non-X models, and at the fuel pump relay connector on all XJ650 Turbo models.
    $ 7.95
    HCP13132 Aftermarket harness bundle BLUE VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ550 models, at the emergency stop switch relay connector on all XJ650 Turbo models, and for the sidestand safety switch relay connector on all XJ550 models, all '82-83 XJ650 models, all XJ750 models, XJ900RK and XJ1100 models.
    $ 7.95
    HCP13133 Aftermarket harness bundle GREEN VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ650RJ Seca and XJ1100 models.
    $ 7.95
    Individual Wire Sheathing:
    The main harness feed solid red wire (14-gauge) used a braided cloth-like sheathing over it to protect it from any chance of insulation breakage. Although the original material is no longer available, we offer an expandable polyester sheathing that is similar in appearance and serves the same function as the original. Sold in 1-foot lengths, more than enough for any of the main harness lead wires.
    HCP12921 Aftermarket red plastic protective WIRE SHEATH, 12" length.
    $ 5.95
    The pick-up coil harness lead wires and the alternator rotor brush-plate lead wires inside the engine cases use a thick, black heat-resistant sleeve over their wires to protect them from both the heat and pinching when the wire exit the engine cases. XJ550 models also use this type of thermal sheath over the kickstand switch lead wires. Sold in 1-foot lengths.
    HCP13326 Aftermarket black heat-resistant protective WIRE SHEATH, 12" length.
    $ 5.95
    Wire Harness Bundle Sheathing:
    Most factory wire harness bundles were taped with a black electrically-insulating protective tape to provide both an orderly routing of the main harness wires and for additional wire protection. In addition, the two forward branches of the main harness were further protected by a smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING, while other models used a flexible, black ribbed WIRE HARNESS BUNDLE HARD SHELL SPLIT-TUBE SHEATHING. NOTE: some models that used the hard-shell, plastic ribbed split-tubing to protect the wire bundles were then also externally wrapped with vinyl electrical tape.
    HCP14153 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly larger than stock size but fits and performs just fine. Used on a variety of different models, in different locations (control switch lead wires, sensor lead wires, etc.), 4.75mm internal diameter, holds two-wire lead harnesses. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 2.95
    HCP14154 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly larger than stock size but fits and performs just fine. Used on a variety of different models, in different locations (control switch lead wires, sensor lead wires, etc.), 6.35mm internal diameter, holds up to five-wire lead harnesses. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! This size sheath is the correct one to use when routing cloth-covered wires, such as for the alternator rotor harness. Sold per foot:
    $ 2.95
    HCP14155 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly larger than stock size but fits and performs just fine. Used on a variety of different models, in different locations (control switch lead wires, sensor lead wires, etc.), 8.00mm internal diameter, holds up to six-wire lead harnesses. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 2.95
    HCP14156 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly larger than stock size but fits and performs just fine. Used on a variety of different models, in different locations (control switch lead wires, sensor lead wires, etc.), 9.50mm internal diameter, holds up to eight-wire lead harnesses. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 2.95
    HCP14158 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly larger than stock size but fits and performs just fine. Used on a variety of different models, in different locations (control switch lead wires, sensor lead wires, etc.), 12.70mm internal diameter, holds up to fourteen-wire lead harnesses. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 3.95
    HCP12945 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly smaller (16mm ID) than stock size but fits and performs just fine. Used on all XJ550 and XJ650 (except Turbo) main forward harness branch "arms", approximately 2-feet per branch. Holds up to approximately 25 wires. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 4.95
    HCP12946 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Slightly smaller (19mm ID) than stock size but fits and performs just fine. Used on all XJ750 Seca models main forward harness branch "arms", approximately 2-feet per branch. Holds up to approximately 33 wires. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 5.95
    HCP14162 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Large size for custom harness construction, 22mm ID. Holds up to approximately 48 wires. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 6.95
    HCP14163 Aftermarket smooth, flexible black WIRE HARNESS BUNDLE VINYL SHEATHING. Large size for custom harness construction, 25mm ID. Holds up to approximately 58 wires. NOTE: wires must be routed through this sheathing before wire-end terminals are applied! Sold per foot:
    $ 7.95
    HCP13149 Aftermarket flexible, black ribbed WIRE HARNESS BUNDLE HARD SHELL SPLIT-TUBE SHEATHING. Slightly larger than stock size but fits and performs just fine. "Split" tube design allows completed wire bundle to be inserted into the tube even while the harness is fully assembled. Used on all 1982-3 XJ750 Maxim and Midnight Maxim models on the main harness bundle forward branch arms (approximately 2-feet per arm). Sold per foot:
    $ 4.95
    HCP12924 Aftermarket harness bundle flexible, black ribbed WIRE HARNESS BUNDLE HARD SHELL SPLIT-TUBE SHEATHING. Slightly larger than stock size but fits and performs just fine. "Split" tube design allows completed wire bundle to be inserted into the tube even while the harness is fully assembled. Use approximately 2-feet on all XJ700 non-X models, and approximately 1-foot on all 1985-86 XJ700 and XJ750-X models on the main harness bundle forward branch arm, just before the harness enters the headlight housing. Sold per foot:
    $ 4.95
  6. chacal
    WIRE-END TERMINALS and TERMINAL SHEATHS:
    The WIRE-END TERMINALS are the brass (or, for added corrosion resistance, tin-plated brass) metal ends that are used to actually "join" wires together at their mating point (usually within a plastic connector block or "shell") These terminals come in a variety of original shapes, styles, and sizes to allow you to properly replace the ones used on your harness, and are of the "OEM" (known as "open-arm" or "open barrel") style that allows both soldering and crimping of both the wire core and the wire insulation to the terminal, providing the ultimate in strain relief, security, and corrosion resistance.
    NOTE: these OEM style terminals require a special crimping tool to properly attach the terminal to the stripped wire end; regular "chain-store" terminal crimpers (for "closed barrel" style terminals) are designed to be used with those "chain-store" style terminals and will not work properly (nor will, for heaven's sake, pliers!) with these OEM style terminals! The crimping process and specialized tool required can be visualized here:
    http://www.xj4ever.com/crimping my style.pdf
    Additionally, it is strongly advised that you obtain a few extra terminals beyond whatever number you need for your project. It is very easy to burst the clamping arms on these open-barrel style terminals if you are inexperienced at using these types of terminals and their specialty crimping tool and procedures.
    The proper OEM "open-barrel" style crimping tools can be found further below in the "Electrical Tools" section, as can the terminal de-pinning tools (special flat-blade "picks" that are used to extract a terminal that has been inserted and locked into a connector shell).
    The ends of all wires are terminated either into a "device" (the oil sending unit, the brake switch unit, etc.) or with a metal WIRE-END TERMINAL. These metal terminals are normally made of solid brass, although some tin-plated brass terminals can also be found (and either type performs just as well as the other). End terminals come in a variety of different shapes, sizes, and styles, such as FLAT BLADES, ROUND PINS, RINGS or SPLIT-RINGS, and BULLETS are the most common. And of course, there are MALE and FEMALE versions of each terminal, and some types also are available in different sizes (small, medium, or large Flat Blade End Terminals, for example or configurations, such as the single, double, or triple female Bullet End Terminals.
    Wire-end terminal PROTECTIVE SHEATHS are used primarily with the round Bullet Wire-end Terminals, and usually on the female bullet terminal only. Some of the 90-degree end terminals (primarily at the horns) use a flexible black rubber sheath or cover to protect the bare end terminal.
    We offer both the original style end terminals, as well as some aftermarket, general-wiring style of BUTT CONNECTORS and standard FLAT BLADE WIRE-END TERMINALS for splicing or adding in non-stock connect/dis-connect features into your harness.
    ALL of our original-style terminals are the correct metric size terminals like the types used originally on your harness, and thus will properly fit (and lock into) the matching male or female terminal "mate" on your original harness, and will also fit and lock properly into your original plastic connector shells. Please note that there are a wide variety of wire-end terminal types available in the marketplace, and most "USA" (inch fractional sizes) will not mate with original terminals, nor do they have the correct retention tab needed to lock into original connector shells!
    On your original harness, each specific wire for a particular circuit not only used a designated size and color wire, but at least one end is terminated by a specific style and type of Wire-End Terminal.
    Original type Small Straight Flat Spade Wire-End Terminals:
    These original style "thin" straight flat blade terminals are tiny little things, and are approximately 3mm wide (side-to-side). Flat blade terminals are also referred to as "flat spade" or "tab" style terminals. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    HCP9362BR1418 Aftermarket original style "thin" straight MALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9362BR1822 Aftermarket original style "thin" straight MALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 18-22 gauge wires. Each:
    $ 1.25
    HCP9362TP1622 Aftermarket original style "thin" straight MALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style tin-plated solid brass terminal features a retention tab for insertion and positive locking into their connector shell. The tin plating gives an additional level of corrosion resistance to the brass terminal. Accepts 16-22 gauge wires. Each:
    $ 1.25
    HCP9363BRD1418 Aftermarket original style "thin" straight FEMALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. These terminals feature the original style locking "dimple" which gives an additional level of terminal-to-terminal locking ability when mated with its male counterpart. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9363BR1822 Aftermarket original style "thin" straight FEMALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 18-22 gauge wires. NOTE: will not fit any of the HCP9337xxxx series shells. Each:
    $ 1.25
    HCP9363BRD1822 Aftermarket original style "thin" straight FEMALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. These terminals feature the original style locking "dimple" which gives an additional level of terminal-to-terminal locking ability when mated with its male counterpart. Accepts 18-22 gauge wires. Each:
    $ 1.25
    HCP9363TP1622 Aftermarket original style "thin" straight FEMALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style tin-plated solid brass terminal features a retention tab for insertion and positive locking into their connector shell. The tin plating gives an additional level of corrosion resistance to the brass terminal. Accepts 16-22 gauge wires. NOTE: for use only with the HCP9359MFWHTWE male connector shell; will not fit any of the HCP9337xxxx series shells. Each:
    $ 1.25
    HCP28001 Aftermarket "trapezoid-shaped" FEMALE SMALL BRASS FLAT BLADE WIRE-END TERMINAL, correct style tin-plated solid brass terminal features a retention tab for insertion and positive locking into their connector shell. The tin plating gives an additional level of corrosion resistance to the brass terminal. Accepts 16-22 gauge wires. NOTE: this terminal only fits the original 9-place white connector shell used on all FJ600, XJ700, and the XJ750-X models at the large "consolidated" turn signal flasher and starting circuit safety relay assembly (located under the gas tank). Each:
    $ 1.50
    Original type Medium Straight Flat Blade Wire-End Terminals:
    These original style, "medium-width" straight flat spade terminals are the most common style of end terminal used on these bikes, and are slightly over 6mm wide (side-to-side). Flat blade terminals are also referred to as "flat spade" or "tab" style terminals. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    HCP9360BR1418 Aftermarket "medium-width" straight MALE MEDIUM BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP9361BR1418 Aftermarket "medium-width" straight FEMALE MEDIUM BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP9361TPDW1418 Aftermarket "medium-width" straight FEMALE MEDIUM TIN-PLATED BRASS FLAT BLADE WIRE-END TERMINAL, correct style tin-plated solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Slightly wider than the stock terminal, but still fits the mating male terminal (and the connector shell) properly. The tin plating gives an additional level of corrosion resistance to the brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.95
    Medium Flat Blade Terminal Protective Covers:
    HCP9325 Aftermarket original style, "medium-width" straight FEMALE FLAT-BLADE STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9361xx series of female wire-end terminals. Each:
    $ 1.25
    Original type Large Straight Flat Blade Wire-End Terminals:
    NOTE: these original style "large" straight flat spade terminals are used only on the main harness feed wire from the positive battery cable (or solenoid) lead pigtail, and are slightly over 6mm wide (side-to-side). Flat blade terminals are also referred to as "flat spade" or "tab" style terminals. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    HCP9371BR1418 Aftermarket original style "large" straight brass MALE LARGE FLAT BLADE TERMINAL. Used only within the main battery lead female connector shell HCP12837FMxx on all models except XJ1100. Each:
    $ 1.25
    HCP12898BR1418 Aftermarket original style "large" straight brass FEMALE LARGE FLAT BLADE TERMINAL. Used only within the main battery lead male connector shell HCP12837MFxx on all models except XJ1100. Each:
    $ 1.25
    Original type 90-Degree Flat Blade "Flag" Wire-End Terminals:
    These original style "flag" terminals make a 90-degree bend to the wire direction, and are normally used on the horn lead wires, inside the flasher relay connector shell, and inside some styles of the headlight plug connector shell. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    HCP9370BR1418 Aftermarket "medium-width" 90-degree FEMALE MEDIUM BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. Each:
    $ 1.75
    Original type Round-Pin Wire-End Terminals:
    NOTE: it is easy to confuse these round pin wire-end terminals with the similar "bullet" terminals listed elsewhere. Round Pin Wire-End Terminals are always used inside a hard plastic connector shell, while the "bullet" style terminals are never inserted into a hard-shell connector body, and are instead placed within a soft, flexible, clear plastic sheath. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    NOTE: we'll attempt a bit of clarity here, as we realize it's easy to get "in the weeds" over these different types of "round-pin" terminals.
    There were originally 2 different suppliers to Yamaha (and probably other Japanese motorcycle builders) of shells (and their matching terminals) which used "round-pin" terminals......note that about 80% of harness connector shells and their terminals are of the "flat blade" (in varying widths) style, and for the most part (but not absolutely!), such terminals and shells are both readily available and interchangeable.
    The rest of the hard plastic connector shells are of the less-common "round pin" style, and these types of shells/terminals come in two different flavors (manufacturers), and neither their shells nor their terminals are interchangeable. These 2 suppliers are Yazaki and Mitsubishi.
    Yazaki shells and terminals are much more common on the harnesses, and luckily, there are reproductions available of those shells. However, the repro Yazaki shells....while they will physically mate up with an original Yazaki shell...use unique terminals which will not interchange into original Yazaki shells (and vice-versa: original Yazaki terminals won't fit into the repro shells).
    The other type of "round pin" terminals and shells used on these era bike harnesses were made by Mitsubishi Electric, and were imprinted "SJD" on the terminal and this identifier was also cast into the plastic connector shell itself (note: male shells had the "SJD" cast onto the front "face' of the shell, and thus it's pretty easy to see.....small, but readable. Female shells have the SJD marking cast inside the terminal cavity, and thus it may be very difficult to see. Of course, if the male shell has SJD cast into it, then its matching female shell is also made by Mitsubishi, whether you can see the marking or not). Mitsubishi got out of the motorcycle terminal and shell business quite some time ago, and thus original shells and terminals are hard to come by. These Mitsubishi "SJD" shells were mainly used on the control switch harness connections and on XJ700 gauge cluster harnesses, and are 6-place shells with a "divider" or separator bar internal to shell that "divides" the shell into a 4-place and a 2-place section.
    The HCP28300TP and HCP28301TP terminals below are the correct terminals which will fit original "SJD" shells only. We do not currently have any original or reproduction "SJD" style shells, so these terminals can only be used to replace missing or damaged terminals used with your original SJD shells.
    The HCP24540TP and HCP24541TP terminals below are the correct terminals for the "repro" Yazaki round-pin style shells mentioned in their description . They will not fit the original Yazaki shells.
    The HCP9326TP and HCP9327TP terminals below are the correct terminals for the specific shells mentioned in their description. They will not fit any original "SJD" or Yazaki shells, and while the male pin terminal is a "round pin", the female receiver terminal is actually a somewhat "triangle" shaped terminal into which a round male pin will fit.
    Finally: some people wonder why one round-pin style terminal can't be stuffed into a shell from a different manufacturer. Basically, it's because the manufacturers of the shells (and their matching terminals) made their products just different enough so you had to use their complete suite of components (shells and terminals) to eliminate competitive substitution attempts. Typically, the differences involve how the metal terminal is designed and/or shaped, and specifically how the terminal is able to "latch" or "lock" into the plastic connector shell....and the unique style of "latching" also means that the internal cavity of the connector shell is unique, too (in order to accept the specialized terminal design).
    HCP28301TP OEM tin-plated brass FEMALE TRUE-ROUND PIN WIRE-END TERMINAL, used with the original Yamaha female "SJD" type connector shells. Mates into the HCP28300TP male terminal. Used primarily at the handlebar control switches and the gauge clusters (XJ700 models) and a few other locations. Tin-plated solid brass terminal features retention shoulder for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. NOTE: these HCP28301TP "round-pin" terminals is used in all original connector shells that used round-pin male terminals. These terminals will not fit into the aftermarket connector shells (listed above) that are designed to accept these round-pin male terminals…..those shells above must use the HCP24540TP terminals listed further below. These HCP28301TP terminals will only fit the original shells on your harness. Each:
    $ 2.95
    HCP28300TP OEM tin-plated brass MALE TRUE-ROUND PIN WIRE-END TERMINAL, used with the original Yamaha female "SJD" type connector shells. Mates into the HCP28301TP female terminal. Used primarily at the handlebar control switches and the gauge clusters (XJ700 models) and a few other locations. Tin-plated solid brass terminal features retention shoulder for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. NOTE: these HCP28300TP "round-pin" terminals is used in all original connector shells that used round-pin male terminals. These terminals will not fit into the aftermarket connector shells (listed above) that are designed to accept the aftermarket round-pin male terminals…..those shells above must use the HCP24541TP terminals listed further below. These HCP28300TP terminals will only fit the original shells on your harness. Each:
    $ 2.95
    HCP24540TP Aftermarket tin-plated brass MALE TRUE-ROUND PIN WIRE-END TERMINAL, used with the female HCP24542F, HCP24543F, HCP24544F, and HCP24545F connector shells only. Mates into the HCP24541TP female terminal. Tin-plated solid brass terminal features retention shoulder for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. NOTE: original connector shells use the HCP28301TP round-pin terminal, aa these HCP24540TP round-pin terminals will not fit into the original connector shells that used the round-pin male terminals. These terminals will only fit into the aftermarket connector shells (listed above) that are designed to accept these aftermarket round-pin male terminals. Each:
    $ 2.75
    HCP24541TP Aftermarket tin-plated brass FEMALE TRUE-ROUND PIN WIRE-END TERMINAL, used with the male HCP24542M, HCP24543M, HCP24544M, and HCP24545M connector shells only. Mates to the HCP24540TP male terminal. Used primarily in the main key switch, the handlebar control switches, brake light switches on some models, fuel sender unit circuits, and a few others. Correct style tin-plated solid brass terminal features retention shoulder for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. NOTE: original connector shells use the HCP28300TP round-pin terminal, and these HCP24540TP round-pin terminals will not fit into the original connector shells that used the round-pin male terminals. These terminals will only fit into the aftermarket connector shells (listed above) that are designed to accept these aftermarket round-pin male terminals. Each:
    $ 2.75
    HCP9326TP Aftermarket style tin-plated brass MALE ROUND PIN STYLE WIRE-END TERMINAL, used with the female HCP9330FMxx, HCP12881FMxx, HCP12882FMxxx, HCP12885FMxx, HCP12886FMxx, and HCP13164FMxx connector shells. Mates to the HCP9327TP female terminals. Used primarily in the main key switch, the handlebar control switches, brake light switches on some models, fuel sender unit circuits, and a few others. Correct style tin-plated solid brass terminal features retention dimples for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. NOTE: original harnesses used a true "round" opening terminal. These HCP9326TP "round pin style" terminals will accept the HCP9327TP female round-pin terminals (below), but will not fit original connector shells that used the truly round-pin female terminals. Each:
    $ 1.25
    HCP9327TP Aftermarket style tin-plated brass FEMALE ROUND PIN STYLE PIN WIRE-END TERMINAL, used with the male HCP12881MFxx connector shell. Mates to the HCP9326TP male terminals. Used primarily in the main key switch, the handlebar control switches, brake light switches on some models, fuel sender unit circuits, and a few others. Correct style tin-plated solid brass terminal features retention dimples for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. NOTE: most original harnesses used a true "round" opening terminal. These HCP9327TP "round pin style" terminals will accept the HCP9326TP male terminals (above), but will not fit original connector shells that used the true round-pin female terminals. They will only fit into the HCP12881MFxx connector shell which is designed to use this "triangulated" round-style female terminals. Each:
    $ 1.25
    Original type “Fork” (or “split-ring”) type Wire-End Terminals :
    These original style Bullet style Wire-End Terminals are some of the most commonly used style of connectors on your wiring harness, found on the end of brake and tail-light wire leads, turn signal leads, most of the small sending units (brake, oil, and battery fluid level sensors), brake light switches, sidestand switches, and others. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    HCP28305 Aftermarket original style solid brass ”FORK” STYLE WIRE-END TERMINAL is used at the neutral position switch (in the bottom of the crankcase). These “split ring” type terminal fits over the neutral switch threaded stud on all XJ650, XJ700, XJ750, and XJ900 models. Correct size and style 5mm solid brass terminal features. Accepts 14-18 gauge wires. Each:
    $ 1.95
    Original type Bullet Wire-End Terminals and Protective Sheathes:
    NOTE: it is easy to confuse these bullet style wire-end terminals with the similar "round pin" terminals listed above. The Female Bullet Wire-End Terminals are always used inside a soft, flexible, clear plastic sheath, while the "round pin" style terminals are always inserted into a hard-shell connector body. Male Bullet Wire-End Terminals are typically "bare", although they will, on occasion, have a small, clear protective sheath around them. In any case, just remember that bullet terminals are never found within a hard plastic connector shell.
    Note carefully that while the male bullet terminals are always a solitary terminal on the end of a single wire, the somewhat "promiscuous" female bullet terminals are designed to accept either one, two, or three individual male terminals. The dual- and triple-female bullet terminals are typically used to accumulate multiple smaller ground wires back into a single larger main ground wire.
    The clear protective SHEATH for these bullet terminals are located further below in the "Connector Block and Terminal Sheath" section of the catalog.
    HCP9364BR1418 Aftermarket original style solid brass MALE BULLET WIRE-END TERMINAL is used in a variety of different places on original harnesses. These male bullet terminals are sometimes protected by the transparent HCP9323 plastic sheath to prevent shorts and corrosion. Mates to the HCP9366xx, HCP9368xx, or HCP9328xx female bullet terminals. Correct size and style 4mm solid brass terminal features retention bulge for insertion and positive locking into their female mate. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP9364TP1418 Aftermarket original style tin-plated brass MALE BULLET WIRE-END TERMINAL is used in a variety of different places on original harnesses. The tin plating gives an additional level of corrosion resistance to the brass terminal. These male bullet terminals are sometimes protected by the transparent HCP9323 plastic sheath to prevent shorts and corrosion. Mates to the HCP9366xx, HCP9368xx, or HCP9328xx female bullet terminals. Correct size and style 4mm solid brass terminal features retention bulge for insertion and positive locking into their female mate. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9366BR1418 Aftermarket original style solid brass SINGLE FEMALE BULLET WIRE-END TERMINAL is used in a variety of different places on original harnesses, especially in the lighting and sender unit circuits. These single-opening female bullet terminals are always protected by the transparent HCP9322 plastic sheath to prevent shorts and corrosion. Mates with the HCP9364xx male bullet terminals. Correct style 4mm solid brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9366TP1418 Aftermarket original style tin-plated brass SINGLE FEMALE BULLET WIRE-END TERMINAL is used in a variety of different places on original harnesses, especially in the lighting and sender unit circuits. The tin plating gives an additional level of corrosion resistance to the brass terminal. These single-opening female bullet terminals are always protected by the transparent HCP9322 plastic sheath to prevent shorts and corrosion. Mates with the HCP9364xx male bullet terminals. Correct style 4mm tin-plated solid brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9368BR1418 Aftermarket original style solid brass DOUBLE FEMALE BULLET WIRE-END TERMINAL is used in a variety of different places on original harnesses, especially in the turn signal circuits. These dual-receiver female bullet terminals are always protected by the transparent HCP9324 plastic sheath to prevent shorts and corrosion. Mates with the HCP9364xx male bullet terminals. Correct style 4mm solid brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9368TP1418 Aftermarket original style tin-plated brass DOUBLE FEMALE BULLET WIRE-END TERMINAL is used in a variety of different places on original harnesses, especially in the turn signal circuits. The tin plating gives an additional level of corrosion resistance to the brass terminal. These dual-receiver female bullet terminals are always protected by the transparent HCP9324 plastic sheath to prevent shorts and corrosion. Mates with the HCP9364xx male bullet terminals. Correct style 4mm tin-plated solid brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9328BR1418 Aftermarket original style solid brass TRIPLE FEMALE BULLET WIRE-END TERMINAL is used on the rear tailight harness on XJ550 Maxim and 1982-83 XJ650 Maxim models only. These triple-hole female bullet terminals are always protected by the transparent HCP9329 plastic sheath to prevent shorts and corrosion. Mates with the HCP9364xx male bullet terminals. Correct style 4mm solid brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.25
    Bullet Terminal Clear Protective Sheaths:
    HCP9323 Aftermarket original style MALE BULLET STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9364 male wire-end terminal. Each:
    $ 1.25
    HCP9322 Aftermarket original style SINGLE FEMALE BULLET STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9366 female wire-end terminal. Each:
    $ 1.95
    HCP9324 Aftermarket original style DUAL FEMALE BULLET STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9368 female wire-end terminal. Each:
    $ 1.25
    HCP9329 Aftermarket original style TRIPLE FEMALE BULLET STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9328 female wire-end terminal. Each:
    $ 1.25
    Original type Closed Round Ring Terminals:
    These original style Round Closed Ring "Eye" Wire-End Terminals are primarily used on your wiring harness for frame grounding purposes. In many cases, a number of different harness ground wires (which are always black) come together and are terminated within a single closed ring "eye" style terminal. All of these "open-barrel" style terminals are designed to be both crimped onto the wire insulation and to the bare wire.
    HCP10093BR1214 Aftermarket original style brass CLOSED RING WIRE-END TERMINAL, for 12-14 gauge wires as used on most models, typically at the coil mounting bolt or at some other main harness-to-frame ground location. These wire-end terminals are NOT used on battery cables! Each:
    $ 1.25
    HCP10093BR1618 Aftermarket original style brass CLOSED RING WIRE-END TERMINAL, for 14-18 gauge wires as used on some ground positions on XJ750 Maxim and XJ1100 models. All other bikes use the larger 12-14 gauge version of this terminal (above). These wire-end terminals are NOT used on battery cables! Each:
    $ 1.25
    HCP14736 Aftermarket original style brass CLOSED RING WIRE-END TERMINAL, for 18-22 gauge wires as used on some wires inside the handlebar control switches. These very small terminals are used in different quantities depending on model and year of the bike. Each:
    $ 1.95
    Aftermarket Butt Connector Terminals:
    When you want to permanently join two pieces of wire that will not ever need to be disconnected at that joint, then a tubular BUTT CONNECTOR is the proper terminal style to use. Available in either un-insulated or fully insulated versions, there's a size and style for any situation you might encounter, including STEP-DOWN BUTT CONNECTORS when joining two wires of greatly differing sizes (for instance, joining a 12-gauge size wire to an 18-gauge size wire), as well as the latest technological miracle, the CRIMPABLE, HEAT-SHRINK, SOLDER-SLEEVE BUTT CONNECTOR.
    Please keep these definitions in mind when determining which type of connector is best suited for your needs:
    Crimpable means that you insert the bare wire end into the hollow central cavity of this tube-like butt connector terminal, and then crush the tube with a proper style "closed barrel" terminal crimper tool. This process mechanically captures the bare wire only (and not the insulation) securely inside the connector.
    Non-insulated means that the butt connector is a bare terminal; it has no protective sleeve over it, and thus should be covered with shrink tube or electrical tape of some type after the wire are installed and the connector crimped and soldered to the wires.
    An insulated connector, or the other hand, comes with a hard plastic outer insulation or, even better, with a heat-shrink material as part of the terminal, making the entire installation process that much simpler.
    Solder-sleeve means that the terminal has an internal slug of solder so that while you're heating the shrink sleeve, you'll also melt an internal solder ring that then flows and fills the internal cavity of the connector (and thus the bare wire) with a warm, solder-y goodness.
    Now, is this a great country, or what?
    Please note that each Butt Connector terminal only fits a certain range of wire sizes, so make sure you order the proper size for the wire(s) that you'll be joining. It's pretty useful to keep a variety of sizes available for use.
    All of these terminals are a "closed-barrel" style, and require a proper style crimping tool for such type connectors, which can be found further below in the "Electrical Tools" section.
    HCP13042 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTOR, for wires that are both 18-22 gauge. NOTE: the HCP13030, HCP13036, HCP13033, or HCP13038 insulating shrink-tube is the proper size to use with these butt connectors. Each:
    $ 0.95
    HCP13042SET10 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTORS, for wires that are both 18-22 gauge. Set of 10:
    $ 7.95
    HCP13045 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 18-22 gauge. Each:
    $ 1.95
    HCP13045SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTORS, for wires that are both 18-22 gauge. Set of 10:
    $ 16.95
    HCP13043 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTOR, for wires that are both 14-16 gauge. NOTE: the HCP13031, HCP13037, HCP13034, or HCP13039 insulating shrink-tube is the proper size to use with these butt connectors. Each:
    $ 1.95
    HCP13043SET10 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTORS, for wires that are both 14-16 gauge. Set of 10:
    $ 7.95
    HCP13046 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 14-16 gauge. Each:
    $ 1.95
    HCP13046SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTORS, for wires that are both 14-16 gauge. Set of 10:
    $ 16.95
    HCP13044 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTOR, for wires that are both 10-12 gauge. NOTE: the HCP13032 or HCP13035 insulating shrink-tube is the proper size to use with these butt connectors. Each:
    $ 1.95
    HCP13044SET10 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTORS, for wires that are both 10-12 gauge. Set of 10:
    $ 7.95
    HCP13047 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, BUTT CONNECTOR, for wires that are both 10-12 gauge. Each:
    $ 1.95
    HCP13047SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, BUTT CONNECTORS, for wires that are both 10-12 gauge. Set of 10:
    $ 16.95
    HCP13069 Aftermarket wire-joining CRIMPABLE, NON-INSULATED STEP-DOWN BUTT CONNECTOR, used for joining two significantly different size wires together. One "end" of the terminal accept wires that are 10-12 gauge, while the other end accepts 14-16 gauge wire. NOTE: the HCP13032 or HCP13035 insulating shrink-tube is the proper size to use with these butt connectors. Each:
    $ 1.95
    HCP13069SET10 Aftermarket wire-joining CRIMPABLE, NON-INSULATED STEP-DOWN BUTT CONNECTORS, One "end" of the terminal accept wires that are 10-12 gauge, while the other end accepts 14-16 gauge wire. Set of 10:
    $ 16.95
    HCP13070 Aftermarket wire-joining CRIMPABLE, INSULATED STEP-DOWN BUTT CONNECTOR, used for joining two significantly different size wires together. One "end" of the terminal accept wires that are 10-12 gauge, while the other end accepts 14-16 gauge wire. Each:
    $ 1.95
    HCP13070SET10 Aftermarket wire-joining CRIMPABLE, INSULATED STEP-DOWN BUTT CONNECTORS, One "end" of the terminal accept wires that are 10-12 gauge, while the other end accepts 14-16 gauge wire. Set of 10:
    $ 16.95
    HCP13071 Aftermarket wire-joining CRIMPABLE, NON-INSULATED STEP-DOWN BUTT CONNECTOR, used for joining two significantly different size wires together. One "end" of the terminal accept wires that are 14-16 gauge, while the other end accepts 18-22 gauge wire. NOTE: the HCP13031, HCP13037, HCP13034, or HCP13039 insulating shrink-tube is the proper size to use with these butt connectors. Each:
    $ 1.95
    HCP13071SET10 Aftermarket wire-joining CRIMPABLE, NON-INSULATED BUTT CONNECTORS, One "end" of the terminal accept wires that are 14-16 gauge, while the other end accepts 18-22 gauge wire. Set of 10:
    $ 16.95
    HCP13072 Aftermarket wire-joining CRIMPABLE, INSULATED STEP-DOWN BUTT CONNECTOR, used for joining two significantly different size wires together. One "end" of the terminal accept wires that are 14-16 gauge, while the other end accepts 18-22 gauge wire. Each:
    $ 1.95
    HCP13072SET10 Aftermarket wire-joining CRIMPABLE, INSULATED BUTT CONNECTORS, One "end" of the terminal accept wires that are 14-16 gauge, while the other end accepts 18-22 gauge wire. Set of 10:
    $ 16.95
    Aftermarket Insulation-Piercing Wire Tapping Connectors:
    These easy-to-use, "fold-over tab" wire splicing taps allow you to "tap into" an existing wire without cutting, splicing, or soldering. Guillotine blade will tap into an existing wire, and makes the connection to a new wire a snap. No crimping tool required; a standard set of pliers will work just fine.
    HCP14292 Aftermarket insulation-piercing WIRE TAP CONNECTOR, accepts 14-18 gauge wires. Standard style does not have moisture protection. Each:
    $ 2.95
    HCP14913 Aftermarket insulation-piercing WIRE TAP CONNECTOR, accepts 14-18 gauge wires. Moisture-proof style is filled with an insulating, protective gel that seals the wires. Each:
    $ 3.95
    Aftermarket Flat Blade Wire-End Terminals:
    When you want to join two pieces of wire that may or will need to be disconnected at that joint, then a matching set of male and female FLAT BLADE CONNECTORS are the terminal type to use. Although there are a number of different styles of these terminals available in the marketplace, we offer what we feel are the easiest and most secure style available, the infamous CRIMPABLE, HEAT-SHRINK, SOLDER-SLEEVE FLAT BLADE TERMINAL design which combines all of the necessary features of a proper terminal installation---it gets crimped tightly to the wire, the wire and the terminal are already covered with a heat-shrink tube for insulation, and the wire gets soldered to the terminal----all in one graceful and easy-to-use little package.
    Please note that Flat Blade Terminals properly fit only a certain range of wire sizes, so make sure you order the proper size for the wire(s) that you'll be joining. It's pretty useful to keep a variety of sizes available for use.
    All of these "closed-barrel" style terminals are designed to be crimped onto the bare wire core only.
    HCP13049 Aftermarket wire-end CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE MALE FLAT BLADE TERMINAL, for wires that are 18-22 gauge. Each:
    $ 3.95
    HCP13049SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE MALE FLAT BLADE TERMINALS, for wires that are 18-22 gauge. Set of 10:
    $ 29.95
    HCP13048 Aftermarket wire-end CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE FEMALE FLAT BLADE TERMINAL, for wires that are 18-22 gauge. Each:
    $ 3.95
    HCP13048SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE FEMALE FLAT BLADE TERMINALS, for wires that are 18-22 gauge. Set of 10:
    $ 29.95
    HCP13051 Aftermarket wire-end CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE MALE FLAT BLADE TERMINAL, for wires that are 14-16 gauge. Each:
    $ 3.95
    HCP13051SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE MALE FLAT BLADE TERMINALS, for wires that are 14-16 gauge. Set of 10:
    $ 29.95
    HCP13050 Aftermarket wire-end CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE FEMALE FLAT BLADE TERMINAL, for wires that are 14-16 gauge. Each:
    $ 3.95
    HCP13050SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE FEMALE FLAT BLADE TERMINALS, for wires that are 14-16 gauge. Set of 10:
    $ 27.95
    HCP13053 Aftermarket wire-end CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE MALE FLAT BLADE TERMINAL, for wires that are 10-12 gauge. Each:
    $ 3.95
    HCP13053SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE MALE FLAT BLADE TERMINALS, for wires that are 10-12 gauge. Set of 10:
    $ 27.95
    HCP13052 Aftermarket wire-end CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE FEMALE FLAT BLADE TERMINAL, for wires that are 10-12 gauge. Each:
    $ 3.95
    HCP13052SET10 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE FEMALE FLAT BLADE TERMINALS, for wires that are 10-12 gauge. Set of 10:
    $ 27.95
    Aftermarket 90-Degree Flat Blade "Flag" Wire-End Terminals:
    These "flag" style terminals allow a 90-degree bend to the wire direction, and are normally used on the horn lead wires, inside the flasher relay connector shell, and inside some styles of the headlight plug connector shell. They accept a bare wire input and allow attachment to a male “medium width” (.250”) flat blade terminal (this terminal has a female receiver).
    HCP24210 Aftermarket "medium-width" 90-degree FEMALE MEDIUM-WIDTH FLAT BLADE WIRE-END “FLAG” TERMINAL, tin-plated solid brass terminal features a blue nylon insulation shell. Accepts 14-16 gauge wires. Each:
    $ 2.95
    HCP24210SET5 Aftermarket "medium-width" 90-degree FEMALE MEDIUM-WIDTH FLAT BLADE WIRE-END “FLAG” TERMINAL, tin-plated solid brass terminal features a blue nylon insulation shell. Accepts 14-16 gauge wires. Set of 5:
    $ 12.95
    HCP24211 Aftermarket "medium-width" 90-degree FEMALE MEDIUM-WIDTH FLAT BLADE WIRE-END “FLAG” TERMINAL, tin-plated solid brass terminal features a red nylon insulation shell. Accepts 18-22 gauge wires. Each:
    $ 2.95
    HCP24211SET5 Aftermarket "medium-width" 90-degree FEMALE MEDIUM-WIDTH FLAT BLADE WIRE-END “FLAG” TERMINAL, tin-plated solid brass terminal features a red nylon insulation shell. Accepts 18-22 gauge wires. Set of 5:
    $ 12.95
    WIRE-END TERMINAL CONNECTOR BLOCKS:
    When a number of circuits (and thus their wires) all go to the same functional area......for instance, to the speedometer cluster.........then all of the particular wire end terminals are placed in specific locations within a plastic CONNECTOR SHELL or "BLOCK" that holds all of the end terminals in a particular orientation, and encased in a protective hard plastic, colored shell. These connector shells or "blocks" come in a variety of configurations, based on how many wire terminals they hold (1, 2, 3, all the way up to 9 positions), their physical configurations (straight across, T-shaped, rectangular, etc.), their color (most are white or off-white, but some are black, red, green, or even blue), and whether the connector shells have mechanical latches on them (most do not, but some of the most vital, "must not come part" connector blocks----such as the main power lead from the battery, and the coil primary input leads----have fail-safe latches to increase their security).
    The original style CONNECTOR BLOCKS listed below are sorted by how many wire end terminals they are capable of holding, and each is listed as to where it used on the each model bike harness, and on which side of the connection it is used on. They will correctly replace and mate with the stock connector shells already on your harness, eliminating the need (and temptation!) to fill up your harness with blue butt splices and bathroom caulking whenever a harness repair is needed........
    NOTE: all connectors shells and blocks listed below are for use with original style OEM "open barrel" wire end terminals listed above only! (unless otherwise specified)
    Single-terminal Connector Blocks:
    HCP12837FMOWT Aftermarket off-white plastic FEMALE CONNECTOR SHELL, single place, used on all of the following circuits listed below. Accepts the HCP9371BR1418 male flat-blade terminal. Each:
    $ 5.95
    * HCP12837FMOWT (the female shell with the male latching peg) is used on:
    - Main battery power lead-in harness, on the main harness side of the connection: all XJ models except XJ1100 models.
    HCP12837MFWHT Aftermarket white plastic MALE CONNECTOR SHELL, single place, used on all of the following circuits listed below. Accepts the HCP12898BR1418 female flat-blade terminal. Each:
    $ 5.95
    * HCP12837MFWHT (the male shell with the female latching peg) is used on:
    - Main battery power lead-in harness, on the positive battery cable harness side of the connection: all XJ models except XJ1100 models.
    HCP13489MNWHT Aftermarket white plastic MALE CONNECTOR SHELL, single place, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 5.95
    * HCP13489MNWHT (the male shell with the male latching peg) is used on:
    - Main battery power lead-in harness, on the main harness side of the connection: all XJ1100 models. NOTE: differ very slightly in configuration from original but will fit and function correctly.
    HCP13489FNWHT Aftermarket white plastic MALE CONNECTOR SHELL, single place, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP13489FNWHT (the female shell with the female latching peg) is used on:
    - Main battery power lead-in harness, on the positive battery cable harness side of the connection: all XJ1100 models. NOTE: differ very slightly in configuration from original but will fit and function correctly.
    Two-terminal Connector Blocks:
    HCP24542FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 2-place “flat” terminal orientation, used on all of the following circuits listed below. Accepts the HCP24540TP round-pin male terminal only (does not accept original terminals) Each:
    $ 8.95
    * HCP24542FMWHT (the female shell) is used on:
    - Emergency Stop Switch harness, on the main harness side of the connection: XJ650 Turbo and XJ1100 models.
    - Auxiliary Light Switch (under the right handlebar switch harness), on the main harness side of the connection: 1982 XJ750 Maxim models.
    - Front Brake Switch, on the main harness side of the connection: all 1985-1986 XJ700 models and XJ750-X models.
    - Main Switch, for battery fluid sensor, on the switch lead-in harness: XJ650 Turbo, 1982 XJ750 Maxim, 1981-83 XJ750 Seca models, and XJ1100 models.
    - Fuel level sensor (fuel tank sending unit), on the sender unit lead-in harness: 1985-1986 all XJ700 and XJ750-X models, and all XJ900 models.
    HCP24542MFWHT Aftermarket white plastic MALE CONNECTOR SHELL, 2-place “flat” terminal orientation, used on all of the following circuits listed below. Accepts the HCP24541TP round-pin female terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24542MFWHT (the male shell) is used on:
    - Emergency Stop Switch harness, on the switch lead-in harness: XJ650 Turbo and XJ1100 models.
    - Auxiliary Light Switch (under the right handlebar switch harness), on the switch lead-in harness: 1982 XJ750 Maxim models.
    - Front Brake Switch, on the switch lead-in harness: all 1985-1986 XJ700 models and XJ750-X models.
    - Main Switch, for battery fluid sensor, on the main harness side of the connection: XJ650 Turbo, 1982 XJ750 Maxim, 1981-83 XJ750 Seca models, and XJ1100 models.
    - Fuel level sensor (fuel tank sending unit), on the main harness side of the connection: 1985-1986 all XJ700 and XJ750-X models, and all XJ900 models.
    HCP13161FNWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 2-place, "T"-shaped (horizontal above vertical terminal orientation), used on all of the following circuits listed below. Accepts the HCP9360xx male terminal. Each:
    $ 5.95
    * HCP13161FNWHT (the female shell) is used on:
    - Horn lead harness, on the main harness side of the connection: all XJ900 models.
    HCP13161MNWHT Aftermarket white plastic MALE CONNECTOR SHELL, 2-place, "T"-shaped (horizontal above vertical terminal orientation), used on all of the following circuits listed below. Accepts the HCP9361xx female terminal. Each:
    $ 5.95
    * HCP13161MNWHT (the male shell) is used on:
    - Horn lead harness, on the horn harness side of the connection: all XJ900 models.
    HCP9331FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 2-place (horizontal above horizontal terminal orientation) with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 9.95
    * HCP9331FMWHT (the female shell with the male latching peg) is used on:
    - Alternator rotor lead harness, on the brush plate lead-in harness side of the connection: all XJ-series bikes (except XJ1100).
    - Alternator rotor lead harness, on the main harness side of the connection: all XJ1100 models.
    - Fan motor, on the fan motor lead-in harness side of the connection: all XJ700-X and XJ750-X models. NOTE: all XJ700-X and XJ750-X models used a black-colored version of this same connector shell which is not currently available.
    - Fuel pump circuit, on the fuel pump lead-in harness side of the connection: all XJ650 Turbo models.
    - Ignition Coils lead harness, on the main harness side of the connection: all XJ-series bikes. NOTE: all XJ700 models and the XJ750-X models used a yellow-colored version of this same connector shell which is not currently available.
    - Knock sensor circuit, on the main harness side of the connection: all XJ650 Turbo models.
    - Main system circuit (30A) fuseholder, on the fuseholder lead-in harness side of the connection: all XJ700, XJ750-X, and XJ1100 models.
    - Sidestand switch lead, on the main harness side of the connection: all XJ550, 1982-83 XJ650 Maxim, all XJ700, XJ750-X, and XJ900 models.
    - Starter solenoid lead harness, on the main harness side of the connection: all XJ-series bikes (except all XJ700 and XJ750-X models).
    HCP9331MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 2-place (horizontal above horizontal terminal orientation) with a female latch-peg receiver and side ear "tabs", used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP9331MFWHTWE (the male shell with the female latch-peg receiver and the side "ear" tabs) is used on:
    - Alternator rotor lead harness, on the main harness side of the connection: all XJ-series bikes (except XJ1100).
    - Alternator rotor lead harness, on the brush plate lead-in harness side of the connection: all XJ1100 models.
    - Fan motor, on the main harness side of the connection: all XJ700-X and XJ750-X models. NOTE: all XJ700-X and XJ750-X models used a black-colored version of this same connector shell which is not currently available.
    - Fuel pump circuit, on the main harness side of the connection: all XJ650 Turbo models.
    - Ignition Coils lead harness, on the ignition coils lead-in harness side of the connection: all XJ-series bikes. NOTE: all XJ700 models and the XJ750-X models used a yellow-colored version of this same connector shell which is not currently available.
    - Knock sensor circuit, on the sensor lead-in harness side of the connection: all XJ650 Turbo models.
    - Main system circuit (30A) fuseholder, on the main harness side of the connection: all XJ700, XJ750-X, and XJ1100 models.
    - Sidestand switch lead, on the sidestand switch lead-in harness side of the connection: all XJ550, 1982-83 XJ650 Maxim, all XJ700, XJ750-X, and XJ900 models.
    - Starter solenoid lead harness, on the solenoid lead-in harness side of the connection: all XJ-series bikes (except all XJ700 and XJ750-X models).
    Three-terminal Connector Blocks:
    HCP24543FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 3-place “T-shaped” terminal orientation, used on all of the following circuits listed below. Accepts the HCP24540TP round-pin male terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24543FMWHT (the female shell) is used on:
    - Left Handlebar Control Switch, on the main harness side of the connection: all XJ550 models, all XJ650, all XJ750 Maxim models, and aXJ1100 models.
    HCP24543MFWHT Aftermarket white plastic MALE CONNECTOR SHELL, 3-place “T-shaped” terminal orientation, used on all of the following circuits listed below. Accepts the HCP24541TP round-pin female terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24543MFWHT (the male shell) is used on:
    - Left Handlebar Control Switch, on the switch lead-in harness: all XJ550 models, all XJ650, all XJ750 Maxim models, and aXJ1100 models.
    HCP12838MNBLK Aftermarket black plastic MALE CONNECTOR SHELL, 3-place, "T"-shaped, used on all of the following circuits listed below. This shell has a hinged rear "flap" that covers the terminals after they are installed into the shell. Accepts the HCP9370BR1418 female 90-degree flat-blade terminal. Each:
    $ 7.95
    * HCP12838MNBLK (the male shell) is used on:
    - Flasher Relay, on the main harness side of the connection: all XJ models except all XJ700 models, XJ750-X models, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900 models.
    - Headlight, on the main harness side of the connection: all XJ models except 1983 XJ750 Maxim and Midnight Maxim models (although they can use this shell instead of the correct HCP13572MNBLK shell).
    HCP13572MNBLK Aftermarket black plastic MALE CONNECTOR SHELL, 3-place, "T"-shaped, used on all of the following circuits listed below. This shell does not have a hinged rear "flap". Accepts the HCP12898BR1418 female flat-blade terminal. Each:
    $ 7.95
    * HCP13572MNBLK (the male shell) is used on:
    - Flasher Relay, on the main harness side of the connection: all 1983 XJ750 Maxim and Midnight Maxim models, and XJ900 models.
    - Headlight, on the main harness side of the connection: all 1983 XJ750 Maxim and Midnight Maxim models.
    HCP13571 Aftermarket black plastic MALE CONNECTOR SHELL, 3-place, "T"-shaped, used on all of the following circuits listed below. This shell has a hinged rear "flap" that covers the terminals after they are installed into the shell. Includes the HCP9370BR1418 terminals already installed and a 12" wire lead of 16 AWG wire from each terminal. NOTE: on models using the "computer" dash, you will need to retain your original short jumper wire(s) from various lead(s) that are used to control the high-beam warning indicator light on the dash and splice them into the new leads. Each:
    $ 8.95
    * HCP13571 (the male shell) is used on:
    HCP13575 Aftermarket high-performance ceramic MALE CONNECTOR SHELL, 3-place, "T"-shaped, used on all of the following circuits listed below. This shell is made from a high-temp ceramic material for use when running high-wattage replacement headlight bulbs. Includes the HCP9370BR1418 terminals already installed and a 12" wire lead of 16 AWG wire from each terminal. NOTE: on models using the "computer" dash, you will need to retain your original short jumper wire(s) from various lead(s) that are used to control the high-beam warning indicator light on the dash and splice them into the new leads. Each:
    $ 19.95
    * HCP13575 (the male shell) is used on:
    HCP9333MFWHTNE Aftermarket white plastic MALE CONNECTOR SHELL, 3-place, "T"-shaped with a with a female latch-peg receiver, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    - Alternator stator lead harness, on the stator lead-in harness side of the connection: all XJ-series bikes (except XJ1100).
    - Tail Light Lead Harness, on the main harness side of the connection: all XJ550 Seca, all XJ650 Turbo, and all XJ900 models.
    HCP9333FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 3-place, "T"-shaped with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9333FMWHT (the female shell with the male latching peg) is used on:
    - Alternator stator lead harness, on the main harness side of the connection: all XJ-series bikes (except XJ1100).
    - Boost Pressure Sensor, on the sensor lead-in harness side of the connection: XJ650 Turbo models.
    - Boost Switch, on the sensor lead-in harness, main harness end: XJ1100 models.
    - Headlight extension harness, on the main harness side of the connection: all XJ550 and XJ650 (except Turbo) models.
    - Main Key Switch lead-in harness, on the main switch lead-in harness side of the connection: all XJ-series bikes (except XJ1100). NOTE: the wires in the above circuit are 14-gauge red, 14-gauge brown, and 18-gauge blue, so choose your terminals appropriately. Bikes that use the two red/white wires for the battery sensor have two additional 20-gauge wires.
    - Sidestand switch lead, on the main harness side of the connection: all XJ650RJ Seca, XJ650 Turbo, all 1981-83 XJ750 models, and XJ1100 models.
    - Tail Light Lead Harness, on the tail light side of the connection: all XJ550 Seca, all XJ650 Turbo, and all XJ900 models.
    HCP9333MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 3-place, "T"-shaped with a with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP9333MFWHTWE (the male shell with the female latch-peg receiver and side "ear" tabs) is used on:
    - Boost Pressure Sensor, on the main harness side of the connection: XJ650 Turbo models.
    - Boost Switch, on the main harness side of the connection: XJ1100 models.
    - Headlight extension harness, on the extension harness side of the connection: all XJ550 and XJ650 (except Turbo) models.
    - Main Key Switch lead-in harness, on the main harness side of the connection: all XJ-series bikes (except XJ1100). NOTE: the wires in the above circuit are 14-gauge red, 14-gauge brown, and 18-gauge blue, so choose your terminals appropriately. Bikes that use the two red/white wires for the battery sensor have two additional 20-gauge wires.
    - Sidestand switch lead, on the switch lead-in harness side of the connection: all XJ650RJ Seca, XJ650 Turbo, all 1981-83 XJ750 models, and XJ1100 models.
    NOTE: either of the following connector shells (HCP9337-series) below can be used in place of the original green shell used for the clutch hand lever switch (the original green shell is not available, but these shells are identical in size/shape/fit/etc.):
    HCP9337FNOWT Aftermarket off-white plastic FEMALE CONNECTOR SHELL, 3-place, horizontal, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9337FNOWT (the female shell) is used on:
    - Dash Turn Signal Indicator Lights harness, on the main harness side of the connection: XJ1100 models.
    - Fuel level sensor (in gas tank), on the main harness side of the connection: all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, 1981-83 XJ750 Seca, and XJ1100 models.
    - Tachometer harness, main harness side of the connection: all XJ550 Maxim, 1980-81 XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ750 Maxim, and 1981-83 XJ750 Seca models.
    - Terminal assembly harness, main harness side of the connection: XJ1100 models.
    - Clutch hand lever switch harness, main harness side of the connection, for all XJ550, XJ650, XJ750 (except Seca models), XJ700, XJ750-X, and XJ1100 models. Note that this shell was originally green in color, but this shell---although the wrong color----is the same size, shape, and fit.
    HCP9337MNOWTNE Aftermarket off-white plastic MALE CONNECTOR SHELL, 3-place, horizontal, used on all of the following circuits listed below. Accepts the HCP9363BRD1418 or HCP9363BRD1822 female flat-blade terminal. Each:
    $ 5.95
    * HCP9337MNOWTNE (the male shell) is used on:
    - Dash Turn light indicator harness, on the dash lights lead-in harness side of the connection: XJ1100 models.
    - Fuel level sensor (in gas tank), on the fuel sender unit lead-in harness side of the connection: all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, 1981-83 XJ750 Seca, and XJ1100 models.
    - Tachometer harness, on the tachometer lead-in harness side of the connection: all XJ550 Maxim, 1980-81 XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, 1982 XJ750 Maxim, and 1981-83 XJ750 Seca models.
    - Terminal assembly harness, on the terminal assembly lead-in harness side of the connection: XJ1100 models.
    - Clutch hand lever switch harness, clutch switch harness side of the connection, for all XJ550, XJ650, XJ750 (except Seca models), XJ700, XJ750-X, and XJ1100 models. Note that this shell was originally green in color, but this shell---although the wrong color----is the same size, shape, and fit.
    HCP9337FNYEL Aftermarket yellow plastic FEMALE CONNECTOR SHELL, 3-place, horizontal, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9337FNYEL (the female shell) is used on:
    - Dash Neutral and Turn Signal lights indicator harness, on the main harness side of the connection: all 1982 XJ750 Maxim and 1981-83 XJ750 Seca models.
    HCP9337MNYELNE Aftermarket yellow plastic MALE CONNECTOR SHELL, 3-place, horizontal, used on all of the following circuits listed below. Accepts the HCP9363BRD1418 or HCP9363BRD1822 female flat-blade terminal. Each:
    $ 5.95
    * HCP9337MNYELNE (the male shell) is used on:
    - Dash Neutral and Turn Signal lights indicator harness, on the dash indicator light lead-in harness side of the connection: all 1982 XJ750 Maxim and 1981-83 XJ750 Seca models.
    Four-terminal Connector Blocks:
    NOTE: all sidestand, starting circuit, headlamp, fuel pump, and emergency stop relay could have come either with or without a terminal latch shroud which surrounds the brass terminals on the relay. Although you can use either the HCP9334MNWHTNE (no latch) connector shell or the HCP9334MMWHTNE (with male latch) connector shell, if your relay has the terminal shroud on it (most original relays did not have the shroud, but most current replacement relays do have the shroud, whether or not the original relay did), then you should use the HCP9334MMWHTNE connector shell, as it has the proper style integral male latch that latches onto the female receiver that is part of (and the reason for!) that terminal "shroud" on the relay base.
    HCP24544FFWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 4-place square terminal orientation, used on all of the following circuits listed below. Accepts the HCP24540TP round-pin male terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24544FFWHT (the female shell) is used on:
    - Left Handlebar Control Switch, on the main harness side of the connection: 1981-1983 XJ750 Seca models.
    - Fusebox (in dash), on the fusebox lead-in harness: 1985-86 XJ700 all models and XJ750-X models.
    HCP24544MMWHT Aftermarket white plastic MALE CONNECTOR SHELL, 4-place square terminal orientation, used on all of the following circuits listed below. Accepts the HCP24541TP round-pin female terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24544MMWHT (the male shell) is used on:
    - Left Handlebar Control Switch, on the switch lead-in harness: 1981-1983 XJ750 Seca models.
    - Fusebox (in dash), on the main harness side of the connection: 1985-86 XJ700 all models and XJ750-X models.
    HCP9334MNWHTNE Aftermarket white plastic MALE CONNECTOR SHELL, 4-place, rectangular, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP9334MNWHTNE (the male shell) is used on:
    - Headlight Relay, on the main harness side of the connection: all XJ550 Seca, all XJ650 (except Turbo), 1982 XJ650RJ Seca, and 1981-83 XJ750 Seca models.
    - Sidestand Relay, on the main harness side of the connection: all XJ550 Seca, 1982-84 XJ650 Maxim, 1982 XJ650RJ Seca, and 1981-83 XJ750 Seca models.
    - Starting Circuit Cut-off Relay, on the main harness side of the connection: all XJ550 Seca, all XJ650 (except Turbo), 1982 XJ650RJ Seca, and 1981-83 XJ750 Seca models.
    - TCI unit, ignition coils output side, on the main harness side of the connection: all XJ650 (except Turbo), 1981-83 all XJ750, and XJ1100 models
    HCP9334MMWHTNE Aftermarket white plastic MALE CONNECTOR SHELL, 4-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP9334MMWHTNE (the male shell with the male latching peg) is used on:
    - Engine Emergency Stop Relay, on the main harness side of the connection: all XJ650 Turbo models.
    - Fuel Pump Relay, on the main harness side of the connection: all XJ650 Turbo models.
    - Headlight Relay, on the main harness side of the connection: all XJ550 Maxim models.
    - Sidestand Relay, on the main harness side of the connection: all XJ550 Maxim, XJ650 Turbo, all XJ700, 1982-83 XJ750 Maxim and Midnight Maxim, XJ750-X, and XJ1100 models.
    - Starting Circuit Cut-off Relay, on the main harness side of the connection: all XJ550 Maxim, XJ650 Turbo, 1982-83 XJ750 Maxim and Midnight Maxim, and XJ1100 models.
    - TCI unit, pick-up coils output side, on the pick-up coils lead-in harness side of the connection: all XJ700 and XJ750-X models.
    HCP9334MMBLKNE Aftermarket black plastic MALE CONNECTOR SHELL, 4-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP9334MMBLKNE (the male shell with the male latching peg) is used on:
    - Starting Circuit Cut-off Relay, on the main harness side of the connection: all XJ900 models.
    NOTE: these same connectors were used on the following models, but were colored blue (instead of black); however, even though the blue connector shell is not currently available, these black shells can be used as an exact substitute in the following applications:
    - Sidestand Relay, on the main harness side of the connection: all XJ900 models.
    HCP9334FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 4-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9334FMWHT (the female shell with the male latching peg) is used on:
    - Alternator stator lead harness, on the main harness side of the connection: all XJ1100 models. NOTE: the wires in the above circuit are 16-gauge, so choose your terminals appropriately.
    - Main Key Switch lead-in harness, on the switch lead-in harness side of the connection: all XJ1100 models. NOTE: the wires in the above circuit are 14-gauge red, 14-gauge brown, and 18-gauge blue, so choose your terminals appropriately. Bikes that use the two red/white wires for the battery sensor have two additional 20-gauge wires.
    - Main Key Switch lead-in harness, on the switch lead-in harness side of the connection: all XJ550 Euro (4V8) models, all XJ650 Euro (4K0 and 4K1 models), and some XJ750 Euro models (XJ750A and perhaps XJ750 E or E-II models).
    - Regulator/Rectifier unit, on the main harness side of the connection: all XJ1100 models. NOTE: the wires in the above circuit are 20-gauge (x 2) and 14-gauge (x 2), and 16-gauge (x 3), so choose your terminals appropriately.
    - TCI unit, ignition coils output side, on the main harness side of the connection: all XJ1100 models.
    - Tail and License Plate Light harness, on the lights lead-in harness side of the connection: all 1981-83 XJ750 Seca models.
    HCP9334MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 4-place, rectangular, with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 5.95
    * HCP9334MFWHTWE (the male shell with the female latch-peg receiver and side "ear" tabs) is used on:
    - Alternator stator lead harness, on the stator lead-in harness side of the connection: all XJ1100 models.
    - Main Key Switch lead-in harness, on the main harness side of the connection: all XJ1100 models.
    - Main Key Switch lead-in harness, on the main harness side of the connection: all XJ550 Euro (4V8) models, all XJ650 Euro (4K0 and 4K1 models), and some XJ750 Euro models (XJ750A and perhaps XJ750 E or E-II models).
    - Regulator/Rectifier unit, on the regulator lead-in harness side of the connection: all XJ1100 models.
    - Tail and License Plate Light harness, on the main harness side of the connection: all 1981-83 XJ750 Seca models.
    - TCI unit, ignition coils output side, on the main harness side of the connection: all XJ550 models and XJ1100 models.
    HCP9359MNOWTNE Aftermarket white plastic MALE CONNECTOR SHELL, 4-place, square, non-latching style, used on all of the following circuits listed below. Accepts the HCP9363BRD1418 or the HCP9363BRD1822 female flat-blade terminal. Each:
    $ 5.95
    * HCP9359MNOWTNE (the male shell) is used on:
    - Dash Warning Lights (turn signals and hi-beam indicator) harness, on the dash light lead-in harness side of the connection: all 1982 XJ750 Maxim models.
    - Dash Warning Lights harness, on the dash light lead-in harness side of the connection: all 1981-83 XJ750 Seca models.
    - Dash Warning Lights (oil, hi-beam, and neutral indicator) harness, on the main harness side of the connection: all XJ900RK Seca models.
    - Tachometer harness, on the tachometer lead-in harness side of the connection: all 1982-84 XJ650 Maxim, 1983-84 XJ750 Maxim and Midnight Maxim, and all XJ1100 models.
    - Turn Signal Warning Lights (on dash) harness, on the warning lights harness side of the connection: all XJ550 Seca models.
    HCP9359FNOWT Aftermarket off-white plastic FEMALE CONNECTOR SHELL, 4-place, square, non-latching style, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9359FNOWT (the female shell) is used on:
    - Dash Warning Lights (turn signals and hi-beam indicator) harness, on the main harness side of the connection: all 1982 XJ750 Maxim models.
    - Dash Warning Lights harness, on the main harness side of the connection: all 1981-83 XJ750 Seca models.
    - Dash Warning Lights (oil, hi-beam, and neutral indicator) harness, on the on the dash light lead-in harness side of the connection: all XJ900RK Seca models.
    - Tachometer harness, on the main harness side of the connection: all 1982-4 XJ650 Maxim, 1983-84 XJ750 Maxim and Midnight Maxim, and XJ1100 models.
    NOTE: this same connector was used on the following model, but is colored yellow (instead of off-white); however, even though the yellow connector shells are not currently available, these off-white shells can be used as an exact substitute in the following applications:
    - Turn Signal Warning Lights (on dash) harness, on the main harness side of the connection: all XJ550 Seca models.
    HCP9359FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 4-place, square, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9359FMWHT (the female shell with the male latching peg) is used on:
    - Left handlebar control switch turn signal circuit lead-in harness, on the switch lead-in harness side of the connection: all XJ700 models and the XJ750-X models.
    HCP9359MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 4-place, square, with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts only the HCP9363BR1812 or the HC9363TP1622 female flat-blade terminal. Each:
    $ 5.95
    * HCP9359MFWHTWE (the male shell with the female latch-peg receiver and side "ear" tabs) is used on:
    - Left handlebar control switch turn signal circuit lead-in harness, on the main harness side of the connection: all XJ700 models and the XJ750-X models.
  7. chacal
    Six-terminal Connector Blocks:
    HCP24545FFWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 6-place rectangle terminal orientation, used on all of the following circuits listed below. Accepts the HCP24540TP round-pin male terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24545FFWHT (the female shell) is used on:
    - Left Handlebar Control Switch, on the main harness side of the connection: XJ650 Turbo models, all XJ750 Maxim models, all XJ900 models, and XJ1100 models.
    - Left Handlebar Control Switch, on the switch lead-in harness: all XJ550 models, and all XJ650 (except Turbo) models.
    HCP24545MMWHT Aftermarket white plastic MALE CONNECTOR SHELL, 6-place rectangle terminal orientation, used on all of the following circuits listed below. Accepts the HCP24541TP round-pin female terminal only (does not accept original terminals). Each:
    $ 8.95
    * HCP24545MMWHT (the male shell) is used on:
    - Left Handlebar Control Switch, on the switch lead-in harness: XJ650 Turbo models, all XJ750 Maxim models, all XJ900 models, and XJ1100 models.
    - Left Handlebar Control Switch, on the main harness side of the connection: all XJ550 models, and all XJ650 (except Turbo) models.
    HCP12881FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 6-place, trapezoidal, with dual male latching pegs, used on all of the following circuits listed below. Accepts the HCP9326xx male round pin terminal. Each:
    $ 5.95
    * HCP12881FMWHT (the female shell with the dual male latching pegs) is used on:
    - Left handlebar control switch, on the control switch lead-in harness side of the connection: all XJ550 and all XJ650 (except Turbo) models.
    - Left handlebar control switch, on the main harness side of the connection: all XJ650 Turbo, all 1981-83 XJ750 models, and XJ900 models.
    - Left handlebar control switch, turn signal and horn lead-in harness, on the main harness side of the connection: all XJ1100 models.
    - NOTE: this white connector shell cannot be used in place of the black or brown connector shell that is used on the right side handlebar control switch on all XJ-series models, as those shells are a slightly different size. The right side switch connector shells are not currently available.
    HCP12881MFWHT Aftermarket white plastic MALE CONNECTOR SHELL, 6-place, trapezoidal, with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts the HCP9327xx female "triangular" round style pin terminal. NOTE: some models used true "round pin" style terminals and a matching connector shell that is no longer available. These HCP12881MFWHT shells, when used with the replacement HCP9327 "triangular" round-style pins, will properly mate up with their opposite original shell on your bike. Each:
    $ 5.95
    * HCP12881MFWHT (the male shell with the female latch-peg receiver and side "ear" tabs) is used on:
    - Left handlebar control switch, on the main harness side of the connection: all XJ550 and all XJ650 (except Turbo) models.
    - Left handlebar control switch, on the control switch lead-in side of the connection: all XJ650 Turbo, all 1981-83 XJ750 models, and XJ900 models.
    - Left handlebar control switch, turn signal and horn lead-in harness, on the control switch lead-in harness side of the connection: all XJ1100 models.
    HCP9335FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 6-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9335FMWHT (the female shell with the a male latching peg) is used on:
    - Computerized Dash Monitor lead-in harness, on the dash lead-in harness side of the connection: all XJ650 Turbo, 1982 XJ750 Maxim, 1981-83 XJ750 Seca, and XJ1100 models.
    - Regulator-Rectifier lead-in harness, on the regulator lead-in harness side of the connection: all XJ1100 models.
    HCP9335MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 6-place, rectangular, with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 6.95
    * HCP9335MFWHTWE (the male shell with the female latch-peg receiver and side "ear" tabs) is used on:
    - Computerized Dash Monitor lead-in harness, on the main harness side of the connection: all XJ650 Turbo, 1982 XJ750 Maxim, 1981-83 XJ750 Seca, and XJ1100 models.
    - TCI Unit, on the pick-up coils lead-in harness, where it plugs into the TCI unit: all XJ550, XJ650 (except Turbo), and all 1981-83 XJ750 models.
    - Regulator-Rectifier lead-in harness, on the main harness side of the connection: all XJ1100 models.
    HCP9335MMWHTNE Aftermarket white plastic MALE CONNECTOR SHELL, 6-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 6.95
    * HCP9335MMWHTNE (the male shell with the male latching peg) is used on:
    - TCI Unit, on the ignition coils side of the TCI, on the main harness side of the connection: all XJ700, XJ750-X, and all XJ900 models.
    HCP9338FNOWT Aftermarket off-white plastic FEMALE CONNECTOR SHELL, 6-place, rectangular, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9338FNOWT (the female shell) is used on:
    - Turn signal Flasher Self-Canceller Unit lead-in harness, on the main harness side of the connection: all XJ550 models, all XJ650 models, all 1981-84 XJ750 models, all XJ900 models, and all XJ1100 models.
    NOTE: this same connector is used on the following model, but is colored yellow (instead of off-white); however, even though the yellow connector shells are not currently available, these off-white shells can be used as an exact substitute in the following applications:
    - Dash Warning Lights lead-in harness, on the main harness side of the connection: all XJ550 Seca and XJ1100 models.
    HCP9338FNWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 6-place, rectangular, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 5.95
    * HCP9338FNWHT (the female shell) is used on:
    - Diode Block lead-in harness, on the diode block lead-in harness side of the connection: all XJ650 Turbo and XJ900 models.
    HCP9338MNWHTNE Aftermarket white plastic MALE CONNECTOR SHELL, 6-place, rectangular, used on all of the following circuits listed below. Accepts the HCP9363BRD1822 or the HCP9363BRD1418 female flat-blade terminal. Each::
    $ 6.95
    * HCP9338MNWHTNE (the male shell) is used on:
    - Diode Block lead-in harness, on the main harness side of the connection: all XJ650 Turbo and XJ900 models.
    - Dash Warning Lights lead-in harness, on the warning lights lead-in harness side of the connection: all XJ1100 models.
    HCP9338MNOWTNE Aftermarket off-white plastic MALE CONNECTOR SHELL, 6-place, rectangular, used on all of the following circuits listed below. Accepts the HCP9363BRD1822 or the HCP9363BRD1418 female flat-blade terminal. Each::
    $ 6.95
    * HCP9338MNOWTNE (the male shell) is used on:
    - Turn signal Flasher Self-Canceller Unit lead-in harness, on the flasher lead-in harness side of the connection: all XJ550 models, all XJ650 models, all 1981-84 XJ750 models, all XJ900 models, and all XJ1100 models.
    - Dash Warning Lights lead-in harness, on the warning lights lead-in harness side of the connection: all XJ550 Seca models.
    Eight-terminal Connector Blocks:
    HCP9336FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 8-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 6.95
    * HCP9336FMWHT (the female shell with the a male latching peg) is used on:
    - Regulator-Rectifier lead-in harness, on the regulator lead-in harness side of the connection: all XJ-series (except 1100) models. NOTE: this shell can be used on the XJ1100 models if the molded male latch is removed. NOTE: the wires in the above circuit are 20-gauge (x 2) and 14-gauge (x 2), and 16-gauge (x 3), so choose your terminals appropriately.
    - TCI unit, ignition coils output side, on the TCI lead-in harness side of the connection: all XJ650 Turbo models.
    HCP9336MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 8-place, rectangular, with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    $ 6.95
    * HCP9336MFWHTWE (the male shell with the female latch-peg receiver and side "ear" tabs) is used on:
    - Regulator-Rectifier lead-in harness, on the main harness side of the connection: all XJ-series (except 1100) models. NOTE: this shell can be used on the XJ1100 models if the molded female latch is removed. NOTE: the wires in the above circuit are 20-gauge (x 2) and 14-gauge (x 2), and 16-gauge (x 3), so choose your terminals appropriately.
    - TCI unit, ignition coils output side, on the main harness side of the connection: all XJ650 Turbo models.
    Nine-terminal Connector Blocks:
    HCP9339FNWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 9-place, rectangular, used on all of the following circuits listed below. Accepts the HCP9362xx male flat-blade terminal. Each:
    $ 6.95
    * HCP9339FNWHT (the female shell) is used on:
    - Dash Warning Lights (oil, hi-beam, neutral, and turn signal) harness, on the main harness side of the connection: all XJ550 Maxim, all XJ650 (except Turbo), and 1983 XJ750 Maxim and Midnight Maxim models.
    - Dash Main Display lead-in harness, on the cluster lead-in harness side of the connection: all XJ650 Turbo models.
    - Dash Main lead-in harness, on the cluster lead-in harness side of the connection: all XJ900 models.
    - Speedometer harness, on the speedometer lead-in harness side of the connection: all 1982 XJ750 Maxim models.
    HCP9339MNWHTNE Aftermarket white plastic MALE CONNECTOR SHELL, 9-place, square, used on all of the following circuits listed below. Accepts the HCP9363BRD1822 or the HCP9363BRD1418 female flat-blade terminal. Each:
    $ 6.95
    * HCP9339MNWHTNE (the male shell) is used on:
    - Dash Warning Lights (oil, hi-beam, neutral, and turn signal) harness, on the dash light lead-in harness side of the connection: all XJ550 Maxim, all XJ650 (except Turbo), and 1983 XJ750 Maxim and Midnight Maxim models.
    - Dash Main Display lead-in harness, on the main harness side of the connection: all XJ650 Turbo models.
    - Dash Main lead-in harness, on the main harness side of the connection: all XJ900 models.
    - Diode Block lead-in harness, on the main harness side of the connection: all XJ550 Seca, XJ700-X, and XJ750-X models.
    - Speedometer harness, on the main harness side of the connection: all 1982 XJ750 Maxim models.
  8. chacal
    WIRE ASSEMBLY and SOLDERING TOOLS:
    In order to properly attach a wire to another wire, or a wire to its end terminal, you will need to both CRIMP the wires together (or crimp the wire to the end terminal "arms"), and then apply SOLDER to the wire to insure both a mechanically strong and an electrically conductive connection. Additionally, you should apply either a SHRINK TUBE over the connection, or use a LIQUID ELECTRICAL TAPE sealer or wrap the connection with a VINYL ELECTRICAL TAPE product.
    Remember, corrosion is the big enemy of electrical connectors, and everything you can do to prevent moisture from entering the bare wire joint will save you untold amounts of electrical grief down the road!
    Of course, you'll need some professional-grade tools and supplies to produce professional-level results, starting with a precision WIRE CUTTER and STRIPPER TOOL, a WIRE TERMINAL CRIMPER TOOL, some low-temp SILVER SOLDER, and a SOLDERING GUN. We cannot over-emphasize that our experience shows that cheaply-made electrical system tools are simply not worth their "cheap" price....especially the wire crimper. The performance of the wire-to-terminal crimp is determined by the accuracy of the die profile of the tool jaws, and that's exactly where the cheap tool manufacturers cut corners. So don't scrimp on the crimp!
    Terminal Removal Tools:
    Once a wire-end terminal is inserted into its connector shell, a small metal "spring-tab" or "tongue" locks the terminal into a recess in the connector shell, thus preventing the terminal and wire from coming back out of the shell. Think of it as the terminal equivalent of the barb on the end of a fish-hook----easy going in, not so easy to get back out......
    Of course, if you want or need to extract a terminal from its connector shell....for repair or replacement, for instance.....then you'll find the use of these TERMINAL REMOVAL TOOLS to be greatest thing since sliced bread. Proper width flat spring-steel blades formed into a rising wedge shape allows you to quickly and easily depress the spring-tab "hook" back up and into the terminal, thus "un-locking" the locking tab from the connector shell, and a quicky tug on the wire now releases the terminal from the shell. Works on all small, medium, and wide flat-blade style terminals only! Not for use on the round pin terminals.
    HCP15686 Aftermarket small flat-blade TERMINAL REMOVAL TOOL, round plastic handle for ease of use.
    $ 21.95
    HCP15687 Aftermarket medium and large flat-blade TERMINAL REMOVAL TOOL, round plastic handle for ease of use. On some connector shells, this tool can also be used to release the small flat-blade terminals, too.
    $ 21.95
    Wire Cutter, Stripper, and Terminal Crimper Tools:
    NOTE: SOME OF THE FOLLOWING TOOLS ARE AVAILABLE FOR RENTAL!!: some tools are a one-time or infrequent use tool, so it may be more economical for you to rent them from us, rather than to purchase outright. Please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    These professional-grade tools put the chain-store variety to shame. If you want strong and secure connections when you're done, don't try to save a few dollars on inferior quality tools. There's absolutely nothing more frustrating than have a wire stripper that pulls the wire strands out (along with the insulation) because it's pivot point won't hold a setting, or because the round holes were not cut to the proper depths. And terminal crimper tools that have an incorrect or poor tolerance profile just won't ever crimp tightly enough, and then the wire will pull out of the terminal crimp----no matter how hard you squeeze!
    HCP13112 Aftermarket standard-duty WIRE CUTTER and STRIPPER TOOL. Designed for 10-22 gauge stranded copper wire only, this tool features precision-cut holes for wire insulation stripping, as well as high-carbon steel precision scissors-type blades for straight-cut, flush end wire cutting. Highly visible AWG and mm wire gauge sizes are embossed into the handle as well as color-coded. The tapered end of the base allows you to pull and twist frayed wire ends back into a tight strand. Soft comfort handles.
    $ 39.95
    HCP13113 Aftermarket heavy-duty WIRE CUTTER and STRIPPER TOOL. Designed for 12-20 gauge stranded copper wire only, this tool features precision-cut holes for wire insulation stripping, as well as stainless steel, nick-resistant scissors-type blades for straight-cut, flush end wire cutting. AWG wire gauge sizes are embossed into the handle. The tapered end of the base allows you to pull and twist frayed wire ends back into a tight strand. Curved, soft comfort-grip handles.
    $ 59.95
    HCP13223 Aftermarket heavy-duty WIRE CRIMPER, STRIPPER, and CUTTER TOOL, professional grade for use with original style "open-barrel" wire terminals. Although this crimper is not a ratchet-design, its long lever arms produce enough force to properly secure the wire to the terminal, vastly simplifying its use and performance. For 14-22 gauge wire terminals. Although this tool is a bit more time-consuming to use (as you have to make 2 crimps instead of just one) compared to the HCP13065 ratchet-design tool below, it will produce much better/stronger crimps and is the easiest tool to use for a casual or new user of these “open-barrel” crimper tools.
    $ 159.95
    HCP13065 Aftermarket heavy-duty WIRE CRIMPER TOOL, designed for use with original style "open-barrel" wire terminals. This crimper is a ratchet-design that will not release until the crimp is fully completed, vastly simplifying its use and performance. For 12-22 gauge wire terminals.
    $ 109.95
    HCP14583 Aftermarket super-duty WIRE CRIMPER TOOL, for use with original style "open-barrel" wire terminals. This crimper is a ratchet-design that will not release until the crimp is fully completed. For 12-22 gauge wire terminals. A professional level tool, combines ease of use while achieving crisp and consistent final crimp quality.
    $ discontinued
    HCP13066 Aftermarket heavy-duty WIRE CRIMPER TOOL, designed for use with aftermarket style "closed-barrel" wire terminals (such as with butt connectors, or other style terminals with a hollow metal receiver tube that the wire fits into before crimping). This crimper is also a ratchet-design that will not release until the die set if fully closed, and thus the crimp is fully completed. For 10-22 gauge wire terminals.
    $ 69.95
    Wire Solder and Soldering Guns:
    While there is a unbelievably confusing array of solder choices, we've narrowed your choices down to one brand and type that we feel is the best: 3.5% SILVER BEARING, LEAD-FREE, ROSIN-CORE SOLDER. Let's go over those features one at a time:
    a) Silver is the best material to use for small-wire electrical soldering, due to both the high-strength of silver and the exceptional electrical conductivity of silver (as opposed to lead-content solder).
    b) Lead is a poisonous substance, and the soldering process has the potential to release lead fumes into the air....and into your eyes and lungs.....and that's just not a good thing, at all.
    c) In the old days, solder was "pure" solder (be it lead-based, silver, etc.) and the cleaning flux was a separate material that had to be applied by hand. Modern "solder" is available with a central, internal flux core so that the cleaning and de-oxidizing properties of the flux----which has a lower melting point than the solder itself----is released first and performs the cleaning task on the wires and terminals immediately before the solder itself melts and flows. The miracles of modern technology at its best..........
    NOTE: never use acid-core solder or an acid-based flux when performing electrical wire soldering! Acidic remnants of that type of flux will remain and eat away at your wires and terminals over time.
    Of course, you'll want to apply such solder with a professional-quality SOLDER GUN, and since you probably, just like the rest of us, only have two hands, then you'll quickly come to appreciate our super-handy WIRE HOLDER tool that allows you to clamp the wires properly in place before soldering, leaving your hands free for the solder feed and the handling of the gun.
    HCP13067 Aftermarket standard-duty SOLDERING GUN SET, 120-volt, dual 100-Watt and 140-Watts power settings, tip temperatures of 900-F and 1020-F. An excellent 8-piece kit which includes the gun, the tin-plated copper soldering tip, a plastics heat-cutting tip, a flux brush, all enclosed in a hard-shell protective carrying case.
    $ 89.95
    HCP13068 Aftermarket heavy-duty SOLDERING GUN SET, 120-volt, dual 200-Watt and 260-Watts power settings, tip temperatures of 900-F and 1100-F. An excellent 8-piece kit which includes the gun, the tin-plated copper soldering tip, a plastics heat-cutting tip, a flux brush, all enclosed in a hard-shell protective carrying case.
    $ 119.95
    HCP13108 Aftermarket 3.5% SILVER BEARING, LEAD-FREE, ROSIN-CORE SOLDER, 15-foot spool contains enough material to solder many, many wire joints! 430-F solder melt temperature, .032" diameter solder wire size is just right for the type of wires you'll be working on.
    $ 34.95
    HCP13111 Aftermarket magnetic WIRE HOLDER - CLAMPS TOOL, a very useful gadget when trying to manipulate 2 (or more) wires and trying to solder at the same time. Adjustable spring-loaded alligator clips hold the wires steady and in alignment while you do the soldering; both the tool base and the clips are magnetic so that you can the tool on a metal surface without it walking, or the hex-shaped tool base allows it to be clamped into a vice for complete restraint of movement. You'll be glad your bought it!
    $ 29.95
    Wire and Terminal Protection:
    You have a few choices here, with the only rule being: choose one! Protecting the crimped and/or soldered bare wire connection from moisture and oxygen is the only way to keep it from corroding, which causes all sorts of un-fun problems with your electrical system.
    The traditional method of sealing wire connections (wire-to-wire or wire-to-terminal) is to slather the finished joint generously with DI-ELECTRIC GREASE, and then, if space considerations permit, to cover the connection with either HEAT-SHRINK TUBE, ELECTRICAL TAPE, or both. "Electrical tape" in now available in both the traditional VINYL ELECTRICAL TAPE WRAP, or in a modern LIQUID ELECTRICAL TAPE form for ease of use and additional protection.
    Shrink tubing shrinks tightly when heat is applied; we recommend the use of our HCP9809 flameless heat gun, or a small butane torch or even a lighter.....just make sure you apply the heat evenly over the entire surface. NOTE: always remember to install your shrink tubing over the wire before you install your wire end terminals!
    NOTE that the very small flat spade terminals, pin terminals, and bullet terminals may not accept shrink tubing or electrical tape due to the small confines of their connector shells. In such situation, your best solution is to simply load up on the di-electric grease.......the more the merrier. It truly is advisable to fill the entire connector shell with di-electric grease to completely seal the wire, end terminals, and connection joint from any exposure to the atmosphere. Some people might consider this as anally-retentive behavior; we think of it as prudent.
    HCP13030 Aftermarket wire harness STANDARD BLACK HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. For use with 18-20 gauge wire. Each piece:
    $ 1.25
    HCP13036 Aftermarket wire harness DUAL-WALL BLACK HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 18-20 gauge wire. Each piece:
    $ 1.50
    HCP13033 Aftermarket wire harness STANDARD RED HEAT-SHRINK TUBING, this 2" length is just right for a wire-end to terminal joint or a butt connection. For use with 18-20 gauge wire. Each piece:
    $ 1.25
    HCP13038 Aftermarket wire harness DUAL-WALL RED HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 18-20 gauge wire. Each piece:
    $ 1.50
    HCP13031 Aftermarket wire harness STANDARD BLACK HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. For use with 14-16 gauge wire. Each piece:
    $ 1.25
    HCP28307 Aftermarket wire harness DUAL-WALL BLACK HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 14-16 gauge wire. Each piece:
    $ 1.50
    HCP13034 Aftermarket wire harness STANDARD RED HEAT-SHRINK TUBING, this 2" length is just right for a wire-end to terminal joint or a butt connection. For use with 14-16 gauge wire. Each piece:
    $ 1.25
    HCP28308 Aftermarket wire harness DUAL-WALL RED HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 14-16 gauge wire. Each piece:
    $ 1.50
    HCP13032 Aftermarket wire harness STANDARD BLACK HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. For use with 10-14 gauge wire. Each piece:
    $ 1.25
    HCP13037 Aftermarket wire harness DUAL-WALL BLACK HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 10-14 gauge wire. Each piece:
    $ 1.50
    HCP13035 Aftermarket wire harness STANDARD RED HEAT-SHRINK TUBING, this 2" length is just right for a wire-end to terminal joint or a butt connection. For use with 10-14 gauge wire. Each piece:
    $ 1.25
    HCP13039 Aftermarket wire harness DUAL-WALL RED HEAT-SHRINK TUBING, a 2" length is just right for a wire-end to terminal joint or a butt connection. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 10-14 gauge wire. Each piece:
    $ 1.50
    HCP13040 Aftermarket wire harness DUAL-WALL BLACK HEAT-SHRINK TUBING, this 6" length is just right for battery terminal wire-end connections. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 2-8 gauge battery or starter motor wire. Each piece:
    $ 6.95
    HCP13041 Aftermarket wire harness DUAL-WALL RED HEAT-SHRINK TUBING, this 6" length is just right for battery terminal wire-end connections. This dual-wall design tubing contains an internal adhesive coating that melts and flows when the heat is applied, adding additional strength and protection to the finished installation. For use with 2-8 gauge battery or starter motor wire. Each piece:
    $ 6.95
    HCP9809 Aftermarket 1100-F degree FLAMELESS HEAT GUN. This good quality, inexpensive heat gun is useful in a variety of situations. Great for helping to remove frozen carb and engine fasteners (it quickly heats up the metal surrounding the stuck fastener, helping to un-seize the fastener threads), applying electrical shrink tubing, removing decals and stripes, and other tasks. Two-speed/heat settings, 600-F and 1000-F. 120V. Can be used stand-alone with supporting clip or hand-held. Includes a air concentrator nozzle. For light-duty use only!
    $ 59.95
    Electrical System Chemicals and Supplies:
    NOTE: it’s important to understand the difference between the two types of greases used with electrical connectors. Di-electric grease acts as an electrical insulator: it does not allow current to flow through it easily, and is basically used to “waterproof” a connector assembly. Although it is an insulator, the act of engaging two electrical connectors together (i.e. pushing a male connector into a female connector) will push away the grease on the metal-to-metal contact portion of the terminals, so those remain electrically conductive (good) while also insulating all the other surfaces against moisture and oxygen intrusion (very good). This insulating property of di-electric grease makes it great for use in connector shells, etc. as terminal corrosion is one of the greatest contributors to electrical system problems in vehicles (especially older ones)……this is why most modern vehicles use “sealed” connector shells (the most popular is the Delphi Automotive brand called “weather pack” or “weatherpak”) to keep oxygen and moisture away from the metal terminals. Although you can retrofit these style connectors to older harnesses, it takes a LOT of time, money, and effort to do so.
    Now, contrast the insulating properties of di-electric grease to the electrically conductive properties of Conductive Grease, which, as its name implies, the grease itself (which contains many fine carbon particles) conducts electricity. Of course, being a “grease”, it too will also protect and insulate a terminal coated with it from moisture, corrosion, etc…..same as di-electric grease. But…it’s conductive, and if the terminal it coats is electrically “hot”, so is the grease (i.e. touching the grease alone will shock you!).
    So a conductive grease is great when you need protection plus current flow……ideal for frame (or battery) grounds to the frame, etc. You could---if you are totally anally-retentive---coat (for instance) a battery post internally with conductive grease, and then cover all of that with di-electric grease.
    So, think of these grease as two different electrical system “tools”, and use accordingly.
    et2) Aftermarket electrical connector DI-ELECTRIC GREASE coats, insulates, and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Smear some of this goo on each and every one of your electrical connectors (after you've cleaned them with some sandpaper or terminal cleaner) and you'll be doing yourself a big favor!
    HCP14059 Aftermarket packet of DI-ELECTRIC GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc.
    $ 4.95
    HCP7528 Aftermarket tube of DI-ELECTRIC GREASE, big 3-ounce squeeze tube.
    $ 21.95
    NOTE: the following 2 product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP20940 Aftermarket tube of DI-ELECTRIC GREASE, 3.3-ounce aerosol can of marine grade grease, with adjustable nozzle size to tailor the grease output bead size to minimize slop and waste and making application much easier. 1-2 cans will do all connectors on an entire bike harness.
    $ 24.95
    et14) Aftermarket electrical connector CONDUCTIVE GREASE coats and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Unlike the di-electric grease listed above, which is an insulator (non-conductive), this carbon-based grease is electrically conductive and has multiple applications (such as battery terminal posts (internally), frame grounds, etc.).
    HCP27923 Aftermarket packet of CONDUCTIVE GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc. Even tiny amounts (that you can barely see) will create minimal electrical resistance, so be careful with this stuff around capacitors and such. It gets everywhere, will stain your hands and clothing and take three days to wash off, and smells like some of the worst goop you've ever smelled. Use a toothpick for application. Don't eat it. Wear gloves. 2-gram pouch goes a long way.
    $ 6.95
    cps2) Aftermarket high-quality CROCUS CLOTH. Unlike sandpaper or emery paper, crocus cloth is a super-fine, cloth-backed soft abrasive that doesn’t “shed” particles during use, and is just the thing for burnishing and polishing of copper electrical contact, like the alternator rotor and starter motor commutators. Sold in a 2” wide x 1-foot long strip, enough for polishing many a commutator or contact.
    HCP21378 Aftermarket strip of CROCUS CLOTH, measures 12” x 2”. Each:
    $ 4.95
    NOTE: the following 3 product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10493 Aftermarket battery post TERMINAL SEALER helps keep corrosion from forming on the battery terminals. Fast drying and leaves no residue. Comes in a 6-ounce aerosol can.
    $ 12.95
    HCP9762 Aftermarket miracle-goo black LIQUID ELECTRICAL TAPE is easier to use than traditional tape products, especially in close-in locations. Great for sealing crimped wire terminal ends to the wire and serves as a good alternative or supplement to shrink tubing. Just brush it on and let it dry! Comes in a 4-ounces brush-top can.
    $12.95
    HCP10508 Aftermarket electrical CONTACT CLEANER is a good general purpose cleaner and de-greaser. Will not harm plastic terminal connector blocks. Fast drying and leaves no residue. Comes in a 16-ounce aerosol can.
    $ 14.95
    HCP12923 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 20-foot roll.
    $ 8.95
    HCP13134 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 66-foot roll, almost enough to do one complete harness.
    $ 16.95
    Additionally, most harnesses had a few short turns of COLORED VINYL ELECTRICAL TAPE WRAP to provide visual identification of "what connector goes where?" during harness assembly and installation. Always located just by the connector shell, about 3-4 turns of this tape was used to both tape off any vinyl sleeve and to properly identify what the connector plugged into. Used primarily at the TCI connector (from the pick-up coils) and at the various small "cube" style relays (headlight relays, sidestand safety switch relays, etc.). Since all of these harness connector shells are the same style and type (4-position, horizontally oriented 2-over-2), this small tape wrap served as a way of indicating which of these many identical connectors went to which component.
    HCP13130 Aftermarket harness bundle YELLOW VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on XJ700-X and XJ750-X models, and at the headlight relay connector on all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models.
    $ 7.95
    HCP13131 Aftermarket harness bundle RED VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on 1982-83 XJ650 Maxim models, all '81-83 XJ750 models, and all XJ700 non-X models, and at the fuel pump relay connector on all XJ650 Turbo models.
    $ 7.95
    HCP13132 Aftermarket harness bundle BLUE VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ550 models, at the emergency stop switch relay connector on all XJ650 Turbo models, and for the sidestand safety switch relay connector on all XJ550 models, all '82-83 XJ650 models, all XJ750 models, XJ900RK and XJ1100 models.
    $ 7.95
    HCP13133 Aftermarket harness bundle GREEN VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ650RJ Seca and XJ1100 models.
    $ 7.95
    et26) Aftermarket electrical device SWITCH LUBRICANT is a specially formulated, electrically non-conductive penetrating lube that is recommended on control switch turn signal contacts and headlight switching contacts. 10-gram squeeze tube has applicator tip for precision use.
    HCP14066 Aftermarket tube of electrical SWITCH LUBRICANT.
    $ 16.95
    et27) Aftermarket electrical INSTRUMENT OIL is a highly refined light oil for use on speedometer heads, tachometers, gauges, mechanical clocks, etc. Will not congeal even at 50-below-zero! Extra-slow rate of evaporation makes sure that it provides lubrication for a long, long time. 1-ounce pen has an applicator needle tip for precision use.
    HCP20852 Aftermarket hi-performance INSTRUMENT OIL, comes in a handy applicator pen. Oil-based triple-processed lubricant eliminates contaminants that would cause gumming or corrosion product is what we use and recommend for freeing stuck fork tube cap bolts.
    $ 37.95
    HCP10540 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery box with a sharp knife or a pair of scissors. For all XJ550, XJ650, XJ700, XJ750, and XJ900RK models.
    $ 9.95
    HCP10541 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery tray with a sharp knife or a pair of scissors. For all XJ1100 models.
    $ 13.95
    HCP10580 Aftermarket acid-neutralizing BATTERY TERMINAL PROTECTORS, thin, round felt mat circles are pressure-treated with a battery-acid neutralizing chemical. Placed under the battery terminal posts, they help prevents any spills or discharge from the battery from creating terminal corrosion. Trim and size to fit your battery posts with a sharp knife or a pair of scissors. Order 1 per terminal, 2 per battery. Each:
    $ 3.95
    WIRE HARNESS CLIPS:
    whc2) OEM wire harness wires, wire bundles, and control cable RETAINING CLIPS, CLAMPS, GROMMETS, AND BAND TIES help you to keep all the wires secure, routed correctly, and looking original. The various bands and ties are used in a variety of places throughout the bike frame, on the handlebars, and in other locations to help insure that things are kept out of harms way!
    Grommets:
    HCP2179 OEM tail light sub-harness GROMMET, oval "doughnut" wire lead grommet snaps into the hole near the tail light housing, and protects the tail light sub-harness where it enters before it goes under the rear fender. Use 1 on all of the following models: XJ550 Maxim, all XJ650 models (except XJ650RJ Seca), all XJ700 models, all XJ750 Maxim and Midnight Maxim, and all XJ1100 models. Each:
    $ 7.95
    HCP3455 OEM wire harness lead wire GROMMET, round "doughnut" wire lead grommet snaps into a hole near the front of the fender, and protects the tail light and turn signals sub-harness where it exit from under the rear fender. Use 1 on all of the following models: XJ550 Maxim, all XJ650 Maxim and Midnight Maxim models (except XJ650RJ Seca), and all XJ700 models. Each:
    $ 5.95
    Clips:
    HCP3463 OEM tail light and rear turn signals sub-harness SNAP-OVER CLIP, pegged clip that snaps over itself the rear fender and then snaps shut over the top of the harness, near the front of the fender, and route the tail light and rear turn signal lead wires as they run forward along the top of the fender. Use 1 on all of the following models: all XJ650 models, all XJ700 models, and all XJ750 Seca models. Use 2 on all of the following models: all XJ900RK, RL, N/FN, and F models. Each:
    $ 5.95
    HCP3464 OEM tail light and rear turn signals sub-harness SNAP-OVER CLAMP, "U"-shaped clip is pegged into the rear inner fender and has an arm that snaps shut over the top of the harness, located near the front of the inner fender, and routes the tail light and rear turn signal lead wires as they run forward along the top of the fender. Use 1 on all of the following models: all FJ600, XJ650, and XJ750 models. Each:
    $ 7.95
    HCP8663 OEM tail light and rear turn signals sub-harness SNAP-OVER CLAMP, "U"-shaped clip is pegged into the rear inner fender and has an arm that snaps shut over the top of the harness, located near the front of the inner fender, and routes the tail light and rear turn signal lead wires as they run forward along the top of the fender. Use 3 on all of the following models: all XJ1100 models. Each:
    $ 6.95
    Clamps:
    HCP3547 OEM main wire harness FRAME CLAMP, large double-armed, rubber-coated metal clamp supports and routes the main harness bundles near the steering tube. Use 1 on all XJ550 models. Each:
    $ discontinued
    HCP3548 OEM main wire harness FRAME CLAMP, smaller single open "c-hook" style, rubber-coated metal clamp supports and routes the main harness bundles near the steering tube. Use 2 on all XJ550 and FJ600 models. Each:
    $ 5.95
    Harness Band Ties:
    Shaped like large, wide wire ties, but sporting a much wider shaft and an even wider T-head, these black serrated toothed "ratchet clamps" are used in a variety of both visible locations on each bike (such as on the handlebars) and in hidden locations (such as down by the kickstand switch) to properly retain control cables and wire harness leads. Although standard issue electrical-department-at-home-depot wire ties are similar, they are not nearly as wide as these original band ties, and especially for the visible locations, these original style ties provide that correct "detailed-restoration" look.
    HCP3465 OEM black wire harness self-locking BAND TIE, 5" long by 5/16" wide, with large slotted T-head. Each:
    $ 7.95
    Used as follows:
    XJ550 Maxim: 4 on the handlebars.
    XJ550 Seca: 2 on the handlebars.
    FJ600 (1986 models): 2 on the rear turn signal harness.
    XJ650 Maxim/Midnight Maxim: 1 in the rear fender area, and 4 on the handlebars.
    XJ650RJ Seca: 2 on the handlebars.
    XJ650 Turbo: 2 on the handlebars.
    XJ700 all models: 2 on the handlebars.
    XJ750-X models: 2 on the handlebars.
    1983 XJ750 Maxim/Midnight Maxim: 4 on the handlebars.
    HCP3466 OEM black wire harness self-locking BAND TIE, 7" long by 3/8" wide, with large slotted T-head. Each:
    $ 4.95
    HCP18080 Aftermarket black wire harness self-locking BAND TIE, 7" long by 3/8" wide, with large slotted T-head. Each:
    $ 3.95
    The above straps are used as follows:
    XJ550 Maxim: 5 on the main wire harness.
    XJ550 Seca: 4 on the main wire harness.
    FJ600 all: 3 on the main wire harness.
    1980 XJ650 Maxim: 2 on the main wire harness.
    1981-83 XJ650 all Maxim and Midnight Maxim: 2 on the main wire harness.
    XJ650RJ Seca: 3 on the main wire harness.
    XJ650 Turbo: 3 on the main wire harness, and 1 with the turbocharger "power-up kit" used optionally on 1982 models and on all 1983 models.
    XJ700 all models: 2 on the main wire harness.
    XJ750-X models: 2 on the main wire harness.
    1981-83 XJ750 all models: 4 on the main wire harness.
    XJ750 Seca models: 4 on the handlebars.
    XJ900RK, RL, N/FN, and F models: 4-6 per bike, depending on specific model, on the main wire harness.
    XJ1100: 4 on the main wire harness.
    HCP3578 OEM black wire harness self-locking BAND TIE, 9" long by 3/8" wide, with large slotted T-head. Each:
    $ 7.95
    Used as follows:
    1980-81 XJ650 Maxim/Midnight Maxim models: 2 on the main wire harness.
    1982-83 XJ650 all Maxim models: 1 on the main wire harness.
    XJ650RJ Seca models: 1 on the main wire harness.
    XJ650 Turbo models: 1 on the main wire harness.
    XJ700 all models: 1 on the main wire harness.
    XJ750-X models: 1 on the main wire harness.
    1981-83 XJ750 all models: 1 on the main wire harness.
    XJ900RK, RL, and N/FN models: 1 on the main wire harness.
    XJ1100 model: 1 on the main wire harness.
  9. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Charging System: Overview, AC Alternator/Generator, Regulator/Rectifier, and related.
    CHARGING SYSTEM:
    CHARGING SYSTEM OVERVIEW:
    The following guide to understanding your charging system was contributed by Dwayne Verhey, extreme XJ-Wizard.
    There are two main types of alternator systems commonly used on motorcycles. Both types depend on a magnetic field, created by magnets in the alternator rotor, to induce an electrical voltage and current flow in a stationary coil of wires-----the alternator stator. If you ever get confused as to which is which, just remember that the rotating component is the "rotating rotor", and the spaghetti-like bundle of wires is the fixed-in-place, "stationary stator"......
    The first type is the permanent-magnet rotor system (used on Virago, V-max, and FJR models, among others). In these systems, the fixed-strength magnets in the spinning rotor generate a constant-strength magnetic field, and thus excite the stator coil constantly; thus the alternator puts out 100% current at all times and the voltage regulator merely serves to shunt any excess generated current to ground. The advantage of the permanent-magnet system is a reduced amount of system complexity, but at the cost of increased heat and power losses (since the alternator system is always generating maximum output, and thus using up engine horsepower, constantly).
    The XJ-series of bikes follows the more common automotive model, which employs variable-strength electro-magnets in the rotor. In these systems, the variable-strength magnets in the spinning rotor, when energized, are used to form the magnetic field which excite the stator. The voltage regulator controls the voltage output by varying the input voltage applied to the rotor's electro-magnets, and thus varies the strength of the magnetic field. If the system voltage drops, the voltage regulator increases the voltage fed into the rotor electro-magnets, thus increasing the strength of the magnetic field that the magnets produce, and therefore increasing the excitation (output) from the stator....and thus the alternator output voltage increases. This type of system is more complex, but has the advantage of using less power to operate, thus freeing up engine output for more admirable purposes.
    In both systems, the stator windings are 3-phase. Each stator wiring bundle (there are 3 of them, and each bundle is called a "leg") kicks out similar voltage, but 120-degrees out of phase with the adjacent leg(s). The resulting AC currents are then rectified (changed) to DC current via a 3-phase bridge rectifier, made up of 6 diodes, such that current in any leg flowing in either direction is directed back into the system as 12-volts DC (actually, around 13.5 to 14.5 volts DC, when everything is working properly).
    If you lose a leg, or even a single diode, it is possible to still achieve voltage if the load is minimal, but as current requirements increase, the alternator will not be able to meet the challenge and the battery will have to take up the slack. Of course, as the battery drains, the available voltage is reduced, so the maximum rotor field voltage is reduced, so the current output is reduced, so the battery has to take up more slack, so ....
    The end result is the battery discharges and the bike won't start.
    If you suspect alternator issues, do the following checks, in this order:
    - first check the resistance on the wires to the rotor. If resistances are out of spec, then check for dirty rotor commutator rings, corroded connections, etc.----all of these problems will reduce the available rotor field voltage.
    - next, check the condition of the connectors from the stator to the rectifier (the 3 white wires). There's usually 2 connectors -- one from the alternator, often hidden behind the battery box, and the other near the regulator. Corrosion in these spots will reduce the stator's outputted current (bad corrosion will often melt the connector, as the outputted current turns into heat rather than being delivered to the battery).
    - next, with the engine running, back-probe each of those 3 white wires at their connector to ensure voltage is being generated on each leg. NOTE: the voltage on those 3 white wires is AC, not DC, so be sure to set your voltmeter properly. AND, YOUR CHECK WILL BE BETWEEN WIRE PAIRS (wire #1 to #2, wire #2 to #3, and wire #1 to #3….and it doesn’t matter which one you consider wire #1 or #2 or #3 to be, as long as each wire’s output is checked)……AND NOT TO THE FRAME OR (GOD HELP YOU) TO THE BATTERY NEGATIVE. You should see some voltage (the actual amount is not meaningful, nor specified) on each test, and the voltages should be about the same on each leg.
    - finally, using your multi-meter and following the directions in the service manual, check the function of each of the 6 diodes in the rectifier to make sure the power is being properly rectified from AC to DC.
  10. chacal
    Alternator Stator:
    gp22) Aftermarket new or re-wound Alternator STATORS perfectly replace the originals. Rewound stator coils are sold on a "core charge" basis and you must return to us a usable, same-model stator core in order to receive your core charge refund. Re-wound stators will output at least the same current as an original stator, and comes with the wiring harness lead and connector but without the rubber insulator grommet that fits into the generator cover----so save your original grommet!
    Checking alternator stators:
    These tests should be taken while the components are at a temperature of about 70-F:
    a) with the engine off and key off, measure the resistance across each pair of the three white wires (white1, white2, and white3) --- thus you take a separate measurement for white1 to white2, white1 to white3, and white2 to white3 ---- at the connector should be as follows. This test is measuring whether there is any internal short within each wire bundle.
    0.50 ohms +/- 10% for all XJ550 models.
    0.46 ohms +/- 10% for all XJ650, all XJ700, all XJ750, and XJ900RK models.
    0.37 ohms +/- 10% for all XJ1100 models.
    0.40 ohms +/- 10% for all XS1100 models.
    b) with the engine off and key off, measure the continuity between each wire to ground (battery negative post or engine case, etc.). Thus white1 to ground, white2 to ground, and white3 to ground. This test is measuring whether there is any short within each wire bundle to the external world. There should not be any continuity.
    c) with the engine running, back-probe each of those 3 white wires at their connector to ensure voltage is being generated on each leg. NOTE: the voltage on those 3 white wires is AC, not DC, so be sure to set your voltmeter properly. AND, YOUR CHECK WILL BE BETWEEN WIRE PAIRS (white1 to white2, white2 to white3, and white1 to white3….and it doesn’t matter which one you consider wire #1 or #2 or #3 to be, as long as each wire’s output is checked)……AND NOT TO THE FRAME OR (GOD HELP YOU) TO THE BATTERY NEGATIVE. You should see some voltage (the actual amount is not meaningful, nor specified) on each test, and the voltages should be about the same on each leg.
    NOTE: for best performance, your alternator Stator and Rotor (or, the Field Coil on XS1100 models) should be replaced at the same time.
    HCP4148 Aftermarket rebuilt/re-wound ALTERNATOR STATOR, with lead wire harness and connector, fits all XJ550, 1984-85 FJ600, and 1986-88 YX600 Radian models. A $ 50.00 core charge applies to this item, and a re-usable, same-model stator must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and that none of the core ring plates are smashed or "separated" or splayed apart from each other.
    $ 209.95 + $ 50.00 refundable core charge
    HCP29211 Aftermarket brand new ALTERNATOR STATOR, with lead wire harness and connector, fits all 1989 YX600 Radian and 1989-91 XJ600 Euro models.
    $ 169.95
    HCP1679 Aftermarket rebuilt/re-wound 19-Amp ALTERNATOR STATOR, with lead wire harness and connector, fits all XJ650, XJ700 air-cooled, all XJ750 air-cooled, and XJ900RK, RL, N/FN, and F models. A $ 50.00 core charge applies to this item, and a re-usable, same-model stator must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and that none of the core ring plates are smashed or "separated" or splayed apart from each other.
    $ 169.95 + $ 50.00 refundable core charge
    HCP17868 Aftermarket brand new 19-Amp ALTERNATOR STATOR, with lead wire harness and connector, fits all XJ650, XJ700 air-cooled, all XJ750 air-cooled, and XJ900RK, RL, N/FN, and F models.
    $ 219.95
    HCP19795 Aftermarket brand new 19-Amp ALTERNATOR STATOR, with lead wire harness and connector, fits all XJ600 Seca II models.
    $ 229.95
    HCP4149 Aftermarket rebuilt/re-wound 26-Amp ALTERNATOR STATOR, with lead wire harness and connector, fits all XJ700-X, XJ750-X, and XJ750P (24L and 37H) models. A $ 50.00 core charge applies to this item, and a re-usable, same-model stator must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and that none of the core ring plates are smashed or "separated" or splayed from each other.
    $ 239.95 + $ 50.00 refundable core charge
    HCP4153 Aftermarket rebuilt/re-wound ALTERNATOR STATOR, with lead wire harness and connector, fits all XJ1100 models. A $ 50.00 core charge applies to this item, and a re-usable, same-model stator must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and that none of the core ring plates are smashed or "separated" or splayed from each other.
    HCP21758 Aftermarket rebuilt/re-wound ALTERNATOR STATOR, with lead wire harness and connector, fits all XS1100 models. A $ 50.00 core charge applies to this item, and a re-usable, same-model stator must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and that none of the core ring plates are smashed or "separated" or splayed from each other.
    HCP1462 OEM stator MOUNTING BOLT, black finish. Use 4 per stator on all XS1100 models to secure the stator to attach to cover.
    $ 5.95
    HCP2775 Aftermarket stator MOUNTING BOLT, 18-8 stainless steel with a bright finish. Use 4 per stator on all XS1100 models to secure the stator to attach to cover.
    $ 2.95
    HCP2787 Aftermarket stator MOUNTING BOLT, black-oxide coated alloy steel with self-locking threads. Use 4 per stator on all XS1100 models to secure the stator to attach to cover.
    $ 2.95
    HCP2788 Aftermarket stator MOUNTING BOLT, black-oxide coated alloy steel. Use 4 per stator on all XS1100 models to secure the stator to attach to cover.
    $ 1.95
    Alternator Rotors and Field Coils:
    gp2) OEM new and aftermarket re-wound Alternator ROTORS perfectly replace the originals. Rewound rotors are sold on a "core charge" basis and you must return to us a usable, same-model rotor core in order to receive your core charge refund. Re-wound rotors will output at least the same current as an original.
    Checking alternator rotors or field coil: the resistance across the two lead wires (usually brown and green) at the connector should be as follows. Note that worn or damaged alternator brushes can affect these readings, as can "dirty" copper commutator rings on the rotor face (where the brushes contact the rotor):
    http://xjbikes.com/forums/index.php?threads/27387
    4.5 ohms +/- 10% for all XJ550 models.
    4.0 ohms +/- 10% for all XJ650, all XJ700, all XJ750, XJ900RK, and XJ1100 models.
    3.5 ohms +/- 10% for all XS1100 models (field coil).
    HCP4150 Aftermarket rebuilt/re-wound ALTERNATOR ROTOR, fits all 1982-83 XS400, XJ550, 1984-85 FJ600, and 1986-88 YX600 Radian models. A $ 50.00 core charge applies to this item, and a re-usable, same-model rotor must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and has not been physically damaged in any way, the internal threads are not stripped, and the taper shaft bore is not gouged or distorted.
    HCP465 OEM original, brand new 19-Amp ALTERNATOR ROTOR, fits all XJ650, XJ700 non-X, all XJ750 non-X, and XJ900RK, RL, N/FN, and F models.
    $ 789.00
    HCP4151 Aftermarket rebuilt/re-wound 19-Amp ALTERNATOR ROTOR, fits all XJ650, XJ700 non-X, all XJ750 non-X, and XJ900RK, RL, N/FN, and F models. A $ 50.00 core charge applies to this item, and a re-usable, same-model rotor must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and has not been physically damaged in any way, the internal threads are not stripped, and the taper shaft bore is not gouged or distorted.
    HCP4152 Aftermarket rebuilt/re-wound 26-Amp ALTERNATOR ROTOR, fits all XJ700-X, XJ750-X, and XJ750P (24L and 37H) models. A $ 50.00 core charge applies to this item, and a re-usable, same-model rotor must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and has not been physically damaged in any way, the internal threads are not stripped, and the taper shaft bore is not gouged or distorted.
    $ 229.95 + $ 50.00 refundable core charge
    HCP4154 Aftermarket rebuilt/re-wound ALTERNATOR ROTOR, fits all XJ1100 models. A $ 50.00 core charge applies to this item, and a re-usable, same-model rotor must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and has not been physically damaged in any way, the internal threads are not stripped, and the taper shaft bore is not gouged or distorted.
    HCP21756 Aftermarket rebuilt/re-wound ALTERNATOR FIELD COIL, with lead wire harness and connector, fits all XS1100 models. A $ 50.00 core charge applies to this item, and a re-usable, same-model field coil unit must be returned for the core charge to be refunded. NOTE: "re-usable" means it is complete and that the wire harness has not been cut off.
    HCP3150 OEM field coin assembly MOUNTING BOLT, to secure the field coil. Use 3 per coil, for all XS1100 models. Each:
    $ 1.95
    HCP2559 OEM alternator rotor flanged RETAINING BOLT, correct high-strength, wide flange hex bolt that holds the rotor onto the alternator shaft. Fits all 1982-83 XS400, XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-88 YX600 Radian, all XJ650, all XJ700, all XJ750, and all XJ900 models.
    $ 9.95
    HCP2560 OEM alternator rotor RETAINING BOLT, correct high-strength hex bolt that holds the rotor onto the alternator shaft. Fits all XJ1100 and XS1100 models.
    $ 6.95
    HCP2230 OEM alternator rotor retaining bolt LOCK WASHER, use with the above mounting bolt. Fits all XJ1100 and XS1100 models.
    $ 7.95
    HCP22225 Aftermarket alternator rotor retaining bolt LOCK WASHER, use with the above mounting bolt. Zinc-plated alloy steel. Fits all XJ1100 and XS1100 models.
    $ 2.95
    HCP22227 Aftermarket alternator rotor retaining bolt LOCK WASHER, use with the above mounting bolt. 18/8 stainless steel. Fits all XJ1100 and XS1100 models.
    $ 3.95
    HCP2562 OEM alternator rotor retaining bolt FLAT WASHER, use with the above mounting bolt. Fits all XJ1100 and XS1100 models.
    $ 9.95
    Alternator Rotor Removal Tools:
    ap7) Aftermarket alternator ROTOR REMOVAL TOOLS, correct copy of the factory Yamaha tool needed to remove the alternator rotor from its mounting shaft (the rotor is a friction fit onto the tapered end of the alternator shaft). Designed to be used in conjunction with the HCP6495 rotor puller tool Attachment Tool listed below. The use of these two tools allows you to safely and properly remove your rotor without damaging either the rotor or the rotor shaft. For all XJ550, FJ600, XJ600 Seca II, XJ650, XJ700, XJ750, XJ900, and XJ1100 models.
    If you find that you need to "lock" the rotor to prevent it from turning while tightening or loosening the retainer bolt, and don’t have the special Yamah “rotor locking tool” (which, honestly, no one has….), as an alternate solution you can put the bike in gear (preferably 5th) to lock the engine and tranny together, put the bike on the centerstand, and then slide a 2 x 4 (or something similar, but it’s preferrable that it’s something “soft” like wood)) thru the rear wheel spokes so that the ends of the 2 x 4 will eventually come to rest on the swingarm after the wheel rotates a distance…….in this way, the engine/transmission (and thus the rotor) are now locked together, and you can proceed to apply torque to the rotor bolt, which will eventually pop free (sometimes with a rather loud “bang!”) once the rear wheel locks itself in place
    Or you can carefully employ this creative method of locking the rotor:
    http://xjbikes.com/forums/index.php?threads/22765
    HCP1404 Aftermarket ROTOR REMOVAL TOOL, screws into the threaded hub of the alternator, heavy-duty shop-grade tool.
    $ 19.95
    HCP21905 Aftermarket ROTOR REMOVAL TOOL, screws into the threaded hub of the alternator. Less expensive version than the shop-grade version tool HCP1404.
    $ 14.95
    HCP6495 Aftermarket ROTOR REMOVAL ATTACHMENT, slides into the end of the internally threaded alternator shaft and prevents the tip of the HCP1404 from "mushrooming" the end of the shaft.
    $ 7.95
    Alternator Brushes and Brush Holder Plate:
    Replacing worn or oil-soaked ALTERNATOR BRUSHES is your first step towards a healthy, capable electrical system. We offer the both the brushes (individually or with their holders) or complete brush plate kits to allow you to quickly and easily fix any problems in this critical area.
    Before you replace your alternator brushes, you should also check the condition of your alternator rotor and stator unit.
    You can do this by following the instructions below; however, be aware that worn or dirty brushes CAN affect the resistance measurements for the ROTOR (as the rotor is what the brushes actually contact), so it may be useful to check the rotor resistance via attaching the ohmmeter test leads directly to the copper commutator strips on the rotor itself (as well as checking the resistance at the wire harness connector).
    The alternator STATOR resistance tests should be taken at the wiring harness connector, although they can also be taken at the stator itself.
    The factory resistance readings listed below do take into account the resistance of the wire harness leads between the component and the end of the harness lead wire; however, the wire harness resistance SHOULD BE minimal. If any out-of-spec readings are noted, it's best to take readings both at the component and then again at the end of the harness leads, and draw conclusions and follow-up procedures (i.e. cleaning the harness terminals, checking for pinched or burned wires in the harness, etc.) based on such information, and perhaps re-checking measurements after corrective actions are taken.
    Checking alternator stators: the resistance across each pair (w1 to w2, w1 to w3, and w2 to w3) of the three white wires (w1, w2, and w3) at the alternator stator lead harness connector, on those three wires LEADING TO THE STATOR, should be as follows:
    Checking alternator rotors: the resistance across the two lead wires (usually red and green) at the alternator rotor lead harness connector, on those two wire LEADING TO THE ROTOR, should be as follows. Note that worn or damaged alternator brushes can affect these readings, as can "dirty" copper commutator strips on the rotor face (where the brushes contact the rotor):
    cps2) Aftermarket high-quality CROCUS CLOTH. Unlike sandpaper or emery paper, crocus cloth is a super-fine, cloth-backed soft abrasive that doesn't "shed" particles during use, and is just the thing for burnishing and polishing of copper electrical contact, like the alternator rotor and starter motor commutators. Sold in a 2" wide x 1-foot long strip, enough for polishing many a commutator or contact.
    HCP21378 Aftermarket strip of CROCUS CLOTH, measures 12" x 2". Each:
    $ 4.95
    s7) Aftermarket ALTERNATOR BRUSHES SET, matched pair of brushes are available either with or without the metal holders brackets. NOTE: Alternator brushes should be replaced whenever they are less than 11mm in overall length......the factory maintenance interval indicates that you should expect to replace these brushes every 8-10,000 miles. Factory brushes have "wear marks" (scribed lines) on the brush to indicate their wear limit.
    http://www.xjbikes.com/forums/threads/im-going-crazy.66888/page-4#post-466203
    HCP216 Aftermarket ALTERNATOR BRUSHES WITHOUT HOLDER BRACKETS SET. Has the brushes, springs, and lead wires, but your original brackets will need to be saved and re-used, and the lead wires from the brushes soldered to the holder brackets. An economy solution for the do-it-yourselfer! Fits all 1982-83 XS400, XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-88 YX600 Radian, all XJ650, all XJ700, all XJ750, all XJ900, and XJ1100 models. These brushes do not have the scribed “wear marks” as original. Overall length of these brushes are 15mm.
    $ 14.95 set
    HCP215 Aftermarket ALTERNATOR BRUSHES WITH HOLDER BRACKETS SET. Fits all 1982-83 XS400, XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-88 YX600 Radian, all XJ650, all XJ700, all XJ750, all XJ900, and XJ1100 models. These brushes do have the scribed “wear marks” as original. Overall length of these brushes are about 16mm, with 9mm of length from the wear bars to the contact end of the brushes
    $ 29.95 set
    abh9) OEM alternator BRUSH HOLDER PLATE, brown plastic plate that the alternator brushes actually attach to. Although this plate never "wears out", it may need replacing if you end up breaking it off while attempting to remove it. Includes the brush holder plate, both brushes, and the lead wires with the rubber generator cover grommet and the white plastic terminal connector. The appropriate hardware used to secure this plate to the generator cover is listed in the next section.
    HCP471 OEM alternator BRUSH HOLDER PLATE, fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. NOTE: the lead wires differ in length between different models; the wires that come with this replacement unit may be slightly longer than your originals on all except the XJ1100 engines......the XJ1100 models used a much longer wire harness than what is provided on this brush plate, and the end connector is a different type. XJ1100 owners can use the brush plate and the brushes only----you will have to re-use your original lead harness.
    Additionally, the molded rubber "dust seal" grommet on the wire harness is correct for all models except 700-X and 750-X models; the deeper cover on those models used a 1/4" longer grommet which is no longer available......so if you have a water-cooled model, you will have to carefully remove your original grommet and re-use it, or re-use your entire lead wire harness.
    $ discontinued
    abh7) Aftermarket ALTERNATOR BRUSHES HARDWARE, an assortment of the correct replacement screws and washers used to mount the brushes to the brush holder plate, and the brush holder plate to the alternator engine case cover.
    NOTE: the large brush plate-to-engine case cover screws are VERY hard to remove.....they tend to "weld" themselves to the case. Please make sure that you use an appropriate size (large tip) JIS phillips screwdriver when attempting to remove them, as they will strip out quite easily. Then you're left with the task of trying to get those tight screws out from a small recessed area, and you run the risk of breaking the brush holder plate!
    And, as always, when you go to replace these brush plate holder screws, make sure that you use some anti-seize compound on their threads!
    HCP1030 OEM brush holder plate-to-cover SCREW, dark finish alloy steel, panhead, phillips drive. This is the large screw that is very difficult to remove. Originally it had a captured lock washer and flat washer, and was yellow-cad plated; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 2 per bike. Each:
    $ 7.95
    HCP2922 Aftermarket brush holder plate-to-cover SCREW. This is the large screw that is very difficult to remove. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 2 per bike. Zinc-plated alloy steel, natural finish, panhead phillips-drive, each:
    $ 2.95
    HCP21362 Aftermarket brush holder plate-to-cover SCREW. This is the large screw that is very difficult to remove. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 2 per bike. 18/8 stainless steel, bright finish, panhead phillips-drive, each:
    $ 3.95
    HCP6714 Aftermarket brush holder plate-to-cover SCREW. This is the large screw that is very difficult to remove. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 2 per bike. Button head hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP6715 Aftermarket brush holder plate-to-cover SCREW. This is the large screw that is very difficult to remove. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 2 per bike. Socket head, hex-drive, black-oxide coated alloy steel, each:
    $ 2.95
    HCP6716 Aftermarket brush holder plate-to-cover SCREW. This is the large screw that is very difficult to remove. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 2 per bike. Socket head, hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP315 OEM brush holder plate-to-cover LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, brush holder plate-to-cover LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel brush holder plate-to-cover LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel brush holder plate-to-cover LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    HCP2173 OEM brush holder plate-to-cover FLAT WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, and XJ1100 models, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket brush holder plate-to-cover FLAT WASHER, zinc-plated alloy steel with a natural finish, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, and XJ1100 models, each:
    $ 1.95
    HCP6643 Aftermarket brush holder plate-to-cover FLAT WASHER, 18-8 stainless steel with a natural finish, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, and XJ1100 models, each:
    $ 2.95
    HCP25756 Aftermarket brush holder plate-to-cover FLAT WASHER, 316 stainless steel with a natural finish, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, and XJ1100 models, each:
    $ 3.95
    HCP14285 Aftermarket brush holder plate-to-cover FLAT WASHER, black oxide-coated 18-8 stainless steel, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, and XJ1100 models, each:
    $ 2.95
    HCP14284 Aftermarket brush holder plate-to-cover FLAT WASHER, black oxide-coated hardened alloy steel, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, and XJ1100 models, each:
    $ 2.95
    HCP4190 OEM brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Zinc-plated steel, panhead phillips-drive. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 6.95
    HCP6418 Aftermarket brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Zinc-plated steel, panhead phillips-drive like original. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 1.95
    HCP6420 Aftermarket brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless steel, panhead phillips. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 1.95
    HCP6421 Aftermarket brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless steel, small-head (JIS) panhead phillips-drive like original. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 3.95
    HCP14239 Aftermarket brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless-steel, polished button head, hex- drive. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 2.95
    HCP6422 Aftermarket brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Black-oxide coated 18-8 stainless steel, panhead phillips-drive screw. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 2.95
    HCP6644 Aftermarket brush holder-to-brush plate SCREW. This is the small screw that holds the brush metal bracket arm to the brush plate. Originally it had a captured lock washer and flat washer; these replacement screws come with the lock washer but without the flat washer, which must be ordered separate below. Yellow zinc-plated steel, panhead phillips-drive screw. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 1.95
    HCP326 OEM alloy-steel natural finish brush holder-to-brush plate screw LOCK WASHER, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 3.95
    HCP922 Aftermarket brush holder-to-brush plate screw LOCK WASHER, zinc-plated alloy steel, each:
    $ 1.95
    HCP336 Aftermarket brush holder-to-brush plate screw LOCK WASHER, 18-8 stainless-steel, each:
    $ 2.95
    HCP342 Aftermarket brush holder-to-brush plate screw LOCK WASHER, black oxide-coated steel, each:
    $ 1.95
    HCP328 OEM alloy-steel natural finish brush holder-to-brush plate screw FLAT WASHER, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per bike. Each:
    $ 3.95
    HCP924 Aftermarket brush holder-to-brush plate screw FLAT WASHER, zinc-plated alloy steel, each:
    $ 1.95
    HCP338 Aftermarket brush holder-to-brush plate screw FLAT WASHER, 18-8 stainless-steel, each:
    $ 2.95
    HCP28050 Aftermarket brush holder-to-brush plate screw FLAT WASHER, grade 316 stainless-steel, each:
    $ 3.95
    HCP1356 Aftermarket brush holder-to-brush plate screw FLAT WASHER, black oxide-coated steel, each:
    $ 1.95
    Alternator Shaft:
    The alternator rotor shaft is the same shaft that the starter motor drive operates. Where this shaft protrudes through the engine case, there is a bearing, a bearing housing, an o-ring for that housing, and an oil seal.....as well as three very special screws that hold the bearing housing to the engine case (you'll most likely need an impact driver tool, along with a properly fitting torx-screwdriver bit, to remove these screws).
    IF YOU FIND ENGINE OIL IN THE ALTERNATOR CAVITY when you remove the alternator engine case outer cover.....well, then you'll need to replace the either the oil spray nozzle O-ring, and/or the shaft bearing housing O-ring and the Oil Seal, the housing screws, and just for precautionary measures, I would also recommend replacing the shaft Bearing while you've got everything this far apart.
    NOTE: the alternator shaft bearing housing retaining screws HCP8492 listed below are special torx-drive screws, and require the use of an appropriate sized torx-drive socket or screwdriver. The original screws are installed with a thread-locking compound applied, and thus can be "frozen" in place and may require the use of heat to the surrounding engine case area (to expand the case slightly) and then may also require the use of an impact driver tool to break the screws loose. The screws should be re-installed with some semi-permanent thread-locking fluid applied.
    HCP10236 Aftermarket TORX-DRIVE SOCKET, fits standard 3/8"-drive ratchets. Has the proper size torx-driver bit included. NOTE: this socket can be used with a 3/8" drive impact driver (such as our HCP9706 impact wrench set) but it is not rated for impact wrench use. However, since you will most likely only be using the bit one time (to loosen the 3 bearing housing screws), then you should be able to accomplish the task, and purchase a replacement bit if necessary.
    $ 22.95
    HCP10237 Aftermarket replacement TORX-DRIVE BIT, fits the above socket.
    $ 9.95
    Here's a good write-up on changing the alternator shaft oil seal on a later model Yamaha (XJ600 Seca II).....although the procedure is not exactly the same on the 1980's XJ-series engines, it's close enough to show the entire process, and with very good pictures:
    http://www.xjrider.com/viewtopic.php?t=2101
    And here is the procedure shown on an XJ700 engine, other XJ engines of this era are very similar in procedure:
    http://www.xjbikes.com/forums/threads/replacing-alternator-seals-in-xj700n-with-pictures.108126/
    And here’s some good videos showing the proper method of installing ball bearings into engine cases and onto shafts:
    and
    For all XJ550 models:
    HCP11025 OEM alternator rotor SHAFT, brand new, includes the outer (left) bearing and the bearing housing O-ring, fits all XJ550 and 1984-85 FJ600 engines.
    $ discontinued
    HCP8612 OEM alternator shaft bearing HOUSING, brand new, fits all XJ550 and 1984-85 FJ600 engines.
    $ 29.95
    HCP8614 OEM alternator shaft bearing housing COVER PLATE, brand new, fits all XJ550 and 1984-85 FJ600 engines.
    $ 29.95
    HCP8492 OEM alternator bearing housing COUNTERSUNK SCREWS, use 3 per housing, torx-drive, fits all XJ550 and 1984-85 FJ600 engines. NOTE: these should be installed with 7.2 foot-pounds of torque. Each:
    $ 11.95
    HCP22177 Aftermarket alternator bearing housing COUNTERSUNK SCREWS, use 3 per housing, torx-drive, fits all XJ550 and 1984-85 FJ600 engines. NOTE: these should be installed with 7.2 foot-pounds of torque. Each:
    $ 8.95
    HCP8613 OEM alternator bearing housing O-RING, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-87 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 7.95
    HCP14393 Aftermarket alternator bearing housing O-RING, original Buna-N material, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-87 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 4.95
    HCP14394 Aftermarket alternator bearing housing O-RING, tougher Viton material, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-87 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 5.95
    HCP8610 OEM alternator bearing shaft OIL SEAL, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 13.95
    HCP8682 OEM alternator shaft O-RING, fits in-between the HCP8610 oil seal and the HCP8611 roller bearing, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 7.95
    HCP8611 OEM alternator shaft BEARING, left side (at bearing housing/rotor end of shaft), use 1 per engine, fits all XJ550, 1984-85 FJ600, and 1992-98 XJ600 Seca II models.
    $ 54.95
    HCP12765 OEM alternator shaft BEARING, right side (at end of alternator shaft, by starter clutch gear), use 1 per engine, fits all XJ550, 1984-85 FJ600, and 1992-98 XJ600 Seca II models.
    $ 56.95
    HCP19255 Aftermarket alternator shaft BEARING, right side (at end of alternator shaft, by starter clutch gear), use 1 per engine, fits all XJ550, 1984-85 FJ600, and 1992-98 XJ600 Seca II models.
    $ 29.95
    HCP8684 OEM alternator shaft PRIMARY DRIVE GEAR, right side (at end of alternator shaft, by starter clutch gear), 28-tooth, use 1 per engine, fits all XJ550 and 1984-85 FJ600 models.
    $ 79.95
    HCP8685 OEM alternator shaft LOCK WASHER, right side (at end of alternator shaft, retains the primary drive gear), use 1 per engine, fits all XJ550 and 1984-85 FJ600 models.
    $ 5.95
    HCP8686 OEM alternator shaft NUT, right side (at end of alternator shaft, retains the primary drive gear), use 1 per engine, fits all XJ550 and 1984-85 FJ600 models.
    $ 8.95
    HCP13969 OEM starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian engines. O-ring is not included and should be ordered separate.
    $ 139.95
    HCP25652 OEM starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all 1992-98 XJ600 Seca II engines. O-ring is not included and should be ordered separate.
    $ 44.95
    HCP5400 OEM starter chain and guide oil spray nozzle O-RING, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 7.95
    HCP20977 Aftermarket starter chain and guide oil spray nozzle O-RING, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 5.95
    For all XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models:
    HCP8490 OEM alternator shaft bearing HOUSING, brand new, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models.
    $ 28.95
    HCP8493 OEM alternator bearing housing COUNTERSUNK SCREWS, use 3 per housing, phillips-drive, fits all 1980-81 XJ650 Maxim models, each:
    $ 7.95
    HCP8492 OEM alternator bearing housing COUNTERSUNK SCREWS, use 3 per housing, torx-drive, for 1981 XJ650 Midnight Maxim models, all 1982-4 XJ650 models, all XJ700, all XJ750, and XJ900RK, RL, N/FN, and F models, each:
    $ 11.95
    HCP22177 Aftermarket alternator bearing housing COUNTERSUNK SCREWS, use 3 per housing, torx-drive, fits all XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. NOTE: these should be installed with 7.2 foot-pounds of torque. Each:
    $ 8.95
    NOTE: the HCP8492 and HCP8493 housing screws are identical in size and shape, and can be used interchangeably. The HCP8493 features a bright plated finish and has a phillips-drive screw slot, while the HCP8492 fastener features a dark oxide finish and uses a torx-drive head. They should be torqued to approximately 7.2 foot-pounds.
    HCP8491 OEM alternator bearing housing O-RING, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 13.95
    HCP14164 Aftermarket alternator bearing housing O-RING, original Buna-N material, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 10.95
    HCP14165 Aftermarket alternator bearing housing O-RING, tougher Viton material, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 11.95
    HCP8488 OEM alternator bearing shaft OIL SEAL, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. NOTE: the "open" side of this seal faces the engine!:
    $ 14.95
    HCP18145 Aftermarket alternator bearing shaft OIL SEAL, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. NOTE: the "open" side of this seal faces the engine!:
    $ 9.95
    HCP10232 OEM starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. O-ring is not included and should be ordered separate.
    $ 79.95
    HCP26174 Aftermarket starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Appearance is different than stock but fit and performance is the same as the HCP10232 spray nozzle. O-ring is not included and should be ordered separate.
    $ 59.95
    HCP10233 OEM starter chain and guide oil spray nozzle O-RING, use 1 per engine an all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 7.95
    HCP20976 Aftermarket starter chain and guide oil spray nozzle O-RING, use 1 per engine an all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 5.95
    HCP8487 OEM alternator shaft BEARING, left side (at bearing housing/rotor end of shaft), use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 59.95
    HCP19260 Aftermarket alternator shaft BEARING, left side (at bearing housing/rotor end of shaft), use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 39.95
    HCP8489 OEM alternator shaft BEARING, right side (at end of alternator shaft, by starter clutch gear), use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 39.95
    HCP11024 OEM alternator shaft END PLUG, right side (at end of alternator shaft, by starter clutch gear), use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models:
    $ 5.95
    For all XJ1100 models:
    HCP12707 OEM primary shaft BEARING, left side, use 1 per engine on all XS1100 and XJ1100 models:
    $ 29.95
    HCP7848 OEM primary shaft BEARING, right side, use 1 per engine on all XJ1100 models:
    $ 44.95
    Generator (alternator rotor and stator) Covers, Gaskets, and Hardware:
    ecc4) Engine GENERATOR COVER or alternator cover. Replacement covers, gaskets, and mounting hardware is listed below.
    NOTE: if the threaded holes in the engine case have minor damage, they can be easily salvaged with a thread-chaser/tap:
    HCP2399 Aftermarket THREAD CHASER AND CLEAN-UP TAP, made from a high-speed titanium nitride coated steel. For the following threaded holes listed below, as well as many other areas of the bike. This 6 x 1.00 pitch is a very common sized thread.
    $ 19.95
    - Hitachi HSC32 air compensator jet holes.
    - Hitachi lower carb rack mount screw holes.
    - Hitachi pilot and main air jets port holes (in carb throat, below vacuum piston).
    - Hitachi carb bowl drain screw hole.
    - All models: gas tank mounting holes for the petcock.
    - All models: gas tank fuel sending unit mounting holes.
    - Mikuni XJ550, FJ/FZ/YX600, XJ600 Seca Ii, XJ650 Turbo, XJ700-X, XJ750-X, XJ900, XJ1100, and XS1100 lower carb rack bracket screw holes.
    - All XJ550 - XJ900 models cylinder head exhaust port stud holes.
    - All XJ550 - XJ1100 models cylinder head valvecover mounting bolt holes.
    - All XJ550 - XJ1100 and XS1100 models cylinder head cam bearing cap bolt holes.
    - All XJ550 - XJ1100 and XS1100 models cylinder head intake manifold bolt holes.
    - All XJ550 - XJ1100 and XS1100 models cylinder head valvecover mounting bolt holes.
    - All XJ550 - XJ1100 and XS1100 models engine side covers mounting bolt holes.
    - All XJ550 - XJ1100 and XS1100 models engine oil pan mounting bolt holes.
    - All XJ550 - XJ1100 and XS1100 models engine upper-to-lower crankcase cinch bolt holes (note: some of the mounting holes are different size, and require the use of the larger HCP11028 tap below).
    - XJ700-X and XJ750-X cylinder heads and jugs coolant jacket bolt holes.
    - Some models: cylinder head cam chain tunnel-to-cylinder jugs cinching studs, for engines that have 2 studs on both the front and rear of the tunnel (models with a single tunnel stud use the HCP11028 tap listed further below).
    - Most models: upper crankcase to cylinder jugs stud.
    - All models: cam chain tensioner mounting bolt holes.
    - Some models: mechanical tachometer drive housing mounting hole.
    - exhaust headpipe gas test bolt threaded hole in the bottom of each header pipe.
    - exhaust collector input (from header pipe) pinch clamp.
    - collector chrome cover retaining bolt hole (XJ1100 models)
    - collector chrome cover rear retaining screw hole (XJ1100 models).
    - XJ650 Turbo models, turbo housing hole for the right muffler “joiner pipe” mounting bolt holes.
    HCP28170 Aftermarket thread tap or EZ-out extractor TAP HANDLE, featuring offset tap handles and fully adjustable head for all m3-m12 size taps and size 0 to ½” extractors. This is the proper way to hold a tap or extractor to insure that the force is directed straight down and doesn’t “wobble” as you are cutting, reaming, or extracting. Much better than using pliers or vise-grips to hold the tool……..
    $ 17.95
    NOTE: always use a proper thread-cutting oil or lubricant before using thread taps! Thin motor oils work fine when merely doing a "clean-up" thread chase; a real cutting fluid should be obtained if a threaded bore needs to be truly cut:
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP2402 Aftermarket machinist-grade professional THREAD CUTTING FLUID, for use when cutting into aluminum or other soft metal. 4-ounce non-aerosol can.
    $ 8.95
    HCP2403 Aftermarket machinist-grade professional THREAD CUTTING FLUID, for use when cutting into steel or other ferrous metals. 4-ounce non-aerosol can.
    $ 8.95
    HCP1050 OEM engine GENERATOR COVER. Bright natural finish. Correct appearance for the following models: all XJ650 models, 1985 XJ700 non-X models, XJ750 Maxim models, 1981-82 XJ750 Seca, and all XJ900RL, N/FN, and F engines. NOTE: this cover will physically fit all of the following engines, but is only correct in finish and color for the models listed previously: "fits" all XJ650, XJ700 air-cooled, XJ750 air-cooled, and XJ900 engines. Brand new:
    $ 179.95
    HCP1051 OEM engine GENERATOR COVER. Black painted finish. Correct appearance for the following models: all XJ650RJ and RJC Seca and XJ650 Turbo models, NOTE: this cover will physically fit all of the following engines, but is only correct in finish and color for the models listed previously: "fits" all XJ650, XJ700 air-cooled, XJ750 air-cooled, and XJ900 engines. Brand new:
    $ 189.95
    HCP1052 OEM engine GENERATOR COVER. Glossy black painted finish. Correct for the following models: XJ650 Midnight Maxim, 1986 XJ700 air-cooled engines, and 1983-84 XJ750 Midnight Maxims. NOTE: this cover will physically fit all of the following engines, but is only correct in finish and color for the models listed previously: "fits" all XJ650, XJ700 air-cooled, XJ750 air-cooled, and XJ900 engines. Brand new:
    $ 189.95
    HCP1054 OEM engine GENERATOR COVER. Bright center with black painted rim. Correct for the following models: 1983 XJ750 Seca and XJ900RK models. Brand new:
    $ 219.95
    ec3) OEM Generator Cover-to-Block GASKET. A great idea to replace these anytime you remove the cover for periodic cleaning, testing, or brush replacement.
    OEM generator cover gaskets are made from a standard duty, graphite impregnated paper material. We recommend the use of the aftermarket hi-performance paper gaskets which are designed to slightly swell in the presence of petroleum products (fuel or oil), thus creating a super-tight, leak-proof flange seal.
    HCP1056 OEM generator cover METAL GASKET, fits all XJ550, 1986-88 FZ600, 1984-86 XJ600 Euro, and 1989-90 YX600 Radian models. NOTE: although never originally fitted to 1984-85 FJ600 and 1986-88 YX600 engines, this gasket will also fit those models and it is recommended that they be used.
    $ 49.95
    HCP17994 Aftermarket generator cover METAL GASKET, fits all XJ550, 1986-88 FZ600, and 1989-90 YX600 Radian models. NOTE: although never originally fitted to 1984-85 FJ600 and 1986-88 YX600 engines, this gasket will also fit those models and it is recommended that they be used.
    $ 37.95
    HCP18434 Aftermarket generator cover hi-performance PAPER GASKET, fits all XJ550, 1986-88 FZ600, and 1989-90 YX600 Radian models. This is a paper-style gasket, unlike the original metal gasket. NOTE: although never originally fitted to 1984-85 FJ600 and 1986-88 YX600 engines, this gasket will also fit those models and it is recommended that they be used.
    $ 34.95
    HCP1057 OEM generator cover standard duty paper GASKET, fits all XJ650, XJ700 non-X, 1981-83 XJ750 models, XJ750RL, and all XJ900RK, RL, N/FN, and F models. NOTE: XJ700-X and XJ750-X (water-cooled) models originally used a metal gasket in this location, which is no longer available, and this paper gasket will serve as a suitable replacement.
    $ 32.95
    HCP18435 Aftermarket generator cover hi-performance GASKET, fits all XJ650, XJ700 non-X, 1981-83 XJ750 models, XJ750RL, and all XJ900RK, RL, N/FN, and F models. NOTE: XJ700-X and XJ750-X (water-cooled) models originally used a metal gasket in this location, which is no longer available, and this paper gasket will serve as a suitable replacement.
    $ 34.95
    HCP1059 OEM generator cover standard duty paper GASKET, fits all XJ1100 and XS1100 models.
    $ 59.95
    HCP18437 Aftermarket generator cover hi-performance GASKET, fits all XJ1100 and XS1100 models.
    $ 44.95
    cm72) OEM and aftermarket Generator Cover MOUNTING HARDWARE. Original style allen head, hex-drive bolts offered in both original and replacement style.
    For all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900 models:
    HCP1041 OEM generator cover MOUNTING BOLT, allen head hex-drive, natural finish. Uses 3 per cover. Correct finish for all XJ550, XJ650 Maxim, 1985 XJ700 non-X, 1981-82 XJ750 Seca, 1982-83 XJ750 Maxim, and XJ900RL, N/FN, and F models. Each:
    $ 8.95
    HCP1041SET3 OEM generator cover MOUNTING BOLTS, set of 3:
    $ 24.95
    HCP1061 OEM generator cover MOUNTING BOLT, allen head hex-drive, black finish. Uses 3 per cover. Correct finish for all 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650 Midnight Maxim, XJ650RJ Seca, XJ650 Turbo, 1986 XJ700 non-X, all XJ700-X and XJ750-X, 1983 XJ750 Seca, XJ750 Midnight Maxim, and XJ900RK models. Each:
    $ 5.95
    HCP1061SET3 OEM generator cover MOUNTING BOLTS, set of 3:
    $ 16.95
    HCP222 Aftermarket generator cover MOUNTING BOLT, allen head hex-drive, 18-8 stainless steel bright finish. Uses 3 per cover. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900 models. Each:
    $ 2.95
    HCP222SET3 Aftermarket generator cover MOUNTING BOLTS, set of 3:
    $ 7.95
    HCP223 Aftermarket generator cover MOUNTING BOLT, allen head hex-drive, black-oxide coated finish. Uses 3 per cover. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900 models. Each:
    $ 1.95
    HCP223SET3 Aftermarket generator cover MOUNTING BOLTS, set of 3:
    $ 5.75
    For all XJ1100 and XS1100 models:
    NOTE: XJ1100 and XS1100 models used a total of 5 bolts to retain the generator cover, 3 long bolts and 2 shorter bolts, and 2 locating dowel pins.
    HCP1043 OEM generator cover LONG MOUNTING BOLT, allen head hex-drive, zinc-plated. Fits all XJ1100, XS1100 Standard, and XS1100 Special models, use 3 per cover. Each:
    $ 9.95
    HCP1043SET3 OEM generator cover LONG MOUNTING BOLTS, set of 3:
    $ 27.95
    HCP966 OEM generator cover SHORT MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Fits all XJ1100, XS1100 Standard, and XS1100 Special models, use 2 per cover. Each:
    $ 9.95
    HCP966SET2 OEM generator cover SHORT MOUNTING BOLTS, set of 2:
    $ 18.95
    HCP9596 OEM generator cover LONG MOUNTING BOLT, allen head hex-drive, black finish. Fits all XS1100 Midnight Special models, use 3 per cover. Each:
    $ 9.95
    HCP9596SET3 OEM generator cover LONG MOUNTING BOLTS, set of 3:
    $ 27.95
    HCP971 OEM generator cover SHORT MOUNTING BOLT, allen head hex-drive, black finish. Fits all XS1100 Midnight Special models, use 2 per cover. Each:
    $ 9.95
    HCP971SET2 OEM generator cover SHORT MOUNTING BOLTS, set of 2:
    $ 18.95
    HCP26503 Aftermarket generator cover LONG MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Fits all XJ1100 and XS1100 models, use 3 per cover. Each:
    $ 4.95
    HCP26503SET3 Aftermarket generator cover LONG MOUNTING BOLTS, set of 3:
    $ 12.95
    HCP22253 Aftermarket generator cover SHORT MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Fits all XJ1100 and XS1100 models, use 2 per cover. Each:
    $ 3.95
    HCP22253SET2 Aftermarket oil pump covers MOUNTING BOLTS, set of 2:
    $ 6.95
    HCP2786 Aftermarket generator cover LONG MOUNTING BOLT, allen head hex-drive, black-oxide coated alloy steel. Fits all XJ1100 and XS1100 models, use 3 per cover. Each:
    $ 3.95
    HCP2786SET3 Aftermarket generator cover LONG MOUNTING BOLTS, set of 3:
    $ 9.95
    HCP228 Aftermarket generator cover SHORT MOUNTING BOLT, allen head hex-drive, black-oxide coated steel. Fits all XJ1100 and XS1100 models, use 2 per cover. Each:
    $ 2.95
    HCP228SET2 Aftermarket generator cover SHORT MOUNTING BOLT, set of 2:
    $ 4.95
    HCP2782 Aftermarket generator cover LONG MOUNTING BOLT, allen head hex-drive, black-oxide coated steel, self-locking threads. Fits all XJ1100 and XS1100 models, use 3 per cover. Each:
    $ 3.95
    HCP2782SET3 Aftermarket generator cover LONG MOUNTING BOLTS, set of 3:
    $ 9.95
    HCP2779 Aftermarket generator cover SHORT MOUNTING BOLT, allen head hex-drive, black-oxide finish, features self-locking threads. Fits all XJ1100 and XS1100 models, use 2 per cover. Each:
    $ 3.95
    HCP2779SET2 Aftermarket generator cover SHORT MOUNTING BOLTS, set of 2:
    $ 6.95
    HCP1242 Aftermarket generator cover LONG MOUNTING BOLT, allen head hex-drive, 18-8 stainless steel, bright finish. Fits all XJ1100 and XS1100 models, use 3 per cover. Each:
    $ 3.95
    HCP1242SET3 Aftermarket generator cover LONG MOUNTING BOLTS, set of 3:
    $ 9.95
    HCP226 Aftermarket generator cover SHORT MOUNTING BOLT, allen head hex-drive, 18-8 stainless steel, bright finish. Fits all XJ1100 and XS1100 models, use 2 per cover. Each:
    $ 3.95
    HCP226SET2 Aftermarket generator cover SHORT MOUNTING BOLTS, set of 2:
    $ 6.95
    HCP968 OEM generator cover locating DOWEL PIN , use 2 per cover. For all XJ1100 and all XS1100 models. Each:
    $ 8.95
    HCP30085 Aftermarket generator cover locating DOWEL PIN , use 2 per cover. For all XJ1100 and all XS1100 models. Each:
    $ 5.95
    Regulator/Rectifier and Related:
    er2) OEM and Aftermarket REGULATOR - RECTIFIER----this is the ribbed aluminum box with the multi-wire plug attached. It regulates the voltage from the alternator, and changes it ("rectifies") from AC to DC.
    There are a number of different tests that can be performed on the regulator and rectifier unit, and it is beyond the scope of this catalog to explain in detail what those tests are, and when and how to perform them. The regulator, in particular, stands "in-between" two of the main electrical components in the entire system----the battery and the alternator----and thus performance of those components must be evaluated before a faulty regulator is suspected. We strongly suggest the purchase of a factory or aftermarket service manual for your bike to be able to properly diagnose and perform electrical system problem solving and repairs!
    The guides below are pretty good basic how-to synopsis of all the tests that the factory service manual recommends when testing the regulator side of the regulator/rectifier unit (step 1) and the rectifier section of the regulator/rectifier unit (step 2):
    https://www.xjbikes.com/forums/threads/1983-xj900-not-charging.132038
    and
    http://www.xjcd.org/750RH_charging
    Regulator - Rectifier Units:
    HCP408 OEM factory REGULATOR - RECTIFIER, fits all 1982-83 XS400, XJ550, 1984-85 FJ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. NOTE: the lead wires coming off the rectifier have the wires arranged in a different order than the stock unit, but the wires ARE color-coded and clocked correctly into the original-style 8-space white plastic harness connector.....so it is a plug-in direct replacement, no mods are necessary!
    $ discontinued
    HCP1678 Aftermarket replacement REGULATOR - RECTIFIER, fits all 1982-83 XS400, XJ550, 1984-85 FJ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. Made by the original Yamaha supplier. NOTE: the lead wires coming off the rectifier have the wires arranged in a different order than the stock unit, but the wires ARE color-coded and clocked correctly into the original-style 8-space white plastic harness connector.....so it is a plug-in direct replacement, no mods are necessary. NOTE: this is not one of the common cheap China regulators that rarely perform correctly!
    $ 149.95
    HCP19747 Aftermarket replacement REGULATOR - RECTIFIER, fits all 1992-96 XJ600 Seca II models. Made by the original Yamaha supplier.
    $ 109.95
    HCP4147 Aftermarket replacement REGULATOR - RECTIFIER, fits all XJ1100 models. NOTE: this is a generic style regulator/rectifier unit that has the proper electrical specifications for these models. It comes with the lead wires but no harness connectors.....so you will have to order the terminal connectors below separate!
    $ 139.95
    HCP9335FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 6-place, rectangular, with a male latching peg, used on the XJ1100 regulator lead-in harness. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 4.95
    HCP9336FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 8-place, rectangular, with a male latching peg, can be used on the XJ1100 models if the molded male latch is removed. Accepts the HCP9360xx male flat-blade terminal. Each:
    $ 5.95
    HCP9360BR1418 Aftermarket "medium-width" straight MALE MEDIUM BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP21751 Aftermarket replacement REGULATOR - RECTIFIER, fits all XS1100 models. NOTE: the lead wires coming off the rectifier have the wires arranged in a different order than the stock unit, but the wires ARE color-coded and clocked correctly into the original-style 8-space white plastic harness connector.....so it is a plug-in direct replacement, no mods are necessary
    $ 169.95
    Voltage Regulator ID Decals:
    HCP15163 Aftermarket voltage regulator case ID DECAL, red foil decal with the brushed silver 12R-A0 wording. Used on the 1981-86 FJ600, XJ650, XJ700, XJ750, and XJ900 models.
    $ 11.95
    HCP15164 Aftermarket voltage regulator case ID DECAL, red foil decal with the brushed silver 10M-A0 wording. Used on the 1982-84 XJ1100 models.
    $ 11.95
    Regulator - Rectifier Mounting Hardware:
    er5) All of the little SCREWS, WASHERS, & NUTS needed to properly mount the regulator-rectifier and TCI units to their plastic foundation (which called the "bridge plate").
    HCP4251 OEM regulator-rectifier mounting SCREW, use 2 per unit. Fits all XJ550, FJ600, XJ650 (except Turbo) models, all 1985 XJ700 N/NC models, all XJ750 models, and all XJ1100 models. Each:
    $ 7.95
    HCP4252 OEM regulator-rectifier mounting SCREW, use 2 per unit. Fits all 1986 XJ700 (except N/NC) models. Each:
    $ 3.95
    HCP3926 OEM regulator-rectifier mounting SCREW, alloy steel, panhead, phillips-drive, black finish. Use 2 per unit. Fits all XJ650 Turbo models. Each:
    $ 7.95
    HCP3114 Aftermarket regulator-rectifier mounting SCREW, alloy steel, panhead, phillips-drive, bright finish. Use 2 per unit. Fits all XJ650 Turbo models. Each:
    $ 1.95
    HCP3115 Aftermarket regulator-rectifier mounting SCREW, 18-8 stainless steel, panhead, phillips-drive, bright finish. Use 2 per unit. Fits all XJ650 Turbo models. Each:
    $ 3.95
    HCP26199 Aftermarket regulator-rectifier mounting SCREW, 316 stainless steel, panhead, phillips-drive, black finish. Use 2 per unit. Fits all XJ650 Turbo models. Each:
    $ 3.95
    HCP4255 OEM regulator-rectifier mounting BOLT, use 2 per unit. Alloy steel hex-head bolt with a bright finish. Fits all XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP27641 Aftermarket regulator-rectifier mounting BOLT, use 2 per unit. Alloy steel hex-head bolt with a bright zinc-plated finish. Fits all XJ900RK, RL, N/FN, and F models. Each:
    $ 1.95
    HCP315 OEM regulator-rectifier mounting LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, regulator-rectifier mounting LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel regulator-rectifier mounting LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel regulator-rectifier mounting LOCK WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    HCP2173 OEM regulator-rectifier mounting FLAT WASHER, use 2 per unit. Fits all XJ550, 1984-85 FJ600, XJ650, XJ750, and all XJ900RK, RL, N/FN, and F models, original bright finish, each:
    $ 2.95
    HCP1869 OEM regulator-rectifier mounting screw FLAT WASHER, use 2 per unit. Fits all XJ700 and XJ750-X models, black-oxide finish, each:
    $ 2.95
    HCP6642 Aftermarket regulator-rectifier mounting screw FLAT WASHER, zinc-plated alloy steel with a bright finish, use 2 per unit. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 1.95
    HCP6643 Aftermarket regulator-rectifier mounting screw FLAT WASHER, 18-8 stainless steel with a bright finish, use 2 per unit. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP25756 Aftermarket regulator-rectifier mounting screw FLAT WASHER, 316 stainless steel, use 2 per unit. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 3.95
    HCP14285 Aftermarket regulator-rectifier mounting screw FLAT WASHER, black oxide-coated 18-8 stainless steel, use 2 per unit. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP14284 Aftermarket regulator-rectifier mounting screw FLAT WASHER, black oxide-coated hardened alloy steel, use 2 per unit. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP4254 OEM regulator-rectifier mounting FLAT WASHER, use 2 per unit. Fits all XJ900RK, RL, and N/FN models, front side of regulator unit. Each:
    $ 2.95
    HCP3996 OEM regulator-rectifier mounting NUT, alloy steel with a bright zinc-plated finish. Use 2 per unit. Fits all XJ650 (except Turbo) models, all XJ700 models, and all XJ750 models. Each:
    $ 8.95
    HCP16570 Aftermarket regulator-rectifier mounting NUT, 18/8 stainless steel with a bright zinc-plated finish. Use 2 per unit. Fits all XJ650 (except Turbo) models, all XJ700 models, and all XJ750 models. Each:
    $ 2.95
    HCP3047 OEM regulator-rectifier mounting LOCKING NUT, use 2 per unit. Black finish with a metal locker ring. Fits all XJ900RK, RL, N/FN, and F models. Each:
    $ 8.95
    HCP28870 Aftermarket regulator-rectifier mounting LOCKING NUT, use 2 per unit. Alloy steel with a black ultra-corrosion finish and a plastic locker insert. Fits all XJ900RK, RL, N/FN, and F models. Each:
    $ 5.95
    HCP17108 Aftermarket regulator-rectifier mounting LOCKING NUT, use 2 per unit. Made from 18/8 stainless steel with a bright finish and a plastic locker insert. Fits all XJ900RK, RL, N/FN, and F models. Each:
    $ 3.95
    HCP4247 OEM regulator-rectifier mounting NUT PLATE, use 2 per unit. Fits all XJ550 and XJ650 Turbo models. Each:
    $ discontinued
    HCP2264 OEM bridge plate-to-frame mounting SCREW, panhead phillips-drive alloy steel with a bright zinc-plated finish. Use 1 per bike on all XJ650 Turbo models, each:
    $ 7.95
    HCP2781N Aftermarket bridge plate-to-frame mounting SCREW, panhead phillips-drive alloy steel with a bright zinc-plated finish. Use 1 per bike on all XJ650 Turbo models, each:
    $ 2.95
    HCP231N Aftermarket bridge plate-to-frame mounting SCREW, panhead phillips-drive 18-8 stainless steel with a bright finish. Use 1 per bike on all XJ650 Turbo models, each:
    $ 4.95
    HCP24070 Aftermarket bridge plate-to-frame mounting SCREW, panhead phillips-drive 316 stainless steel with a bright finish. Use 1 per bike on all XJ650 Turbo models, each:
    $ 3.95
    HCP15738 OEM bridge plate-to-frame MOUNTING SCREW, black alloy steel with phillips-drive, panhead design, and captured flat washer. Fits all XJ700 and XJ750-X models. Use 2 per bike. Each:
    $ 7.95
    HCP2922 Aftermarket bridge plate-to-frame MOUNTING SCREW, bright zinc-plated steel with phillips-drive, panhead design. NOTE: this screw does not have a captured washer like the original screw, and thus the use of a separate flat washer (from the choices shown below) is necessary. Fits all XJ700 and XJ750-X models. Use 2 per bike. Each:
    $ 2.95
    HCP21362 Aftermarket bridge plate-to-frame MOUNTING SCREW, bright 18-8 stainless steel with phillips-drive, panhead design. NOTE: this screw does not have a captured washer like the original screw, and thus the use of a separate flat washer (from the choices shown below) is necessary. Fits all XJ700 and XJ750-X models. Use 2 per bike. Each:
    $ 3.95
    HCP1869 OEM bridge plate mounting screw FLAT WASHER, black-oxide finish, use 1 per screw along with either of the aftermarket screws above. Each:
    $ 2.95
    HCP2173 OEM bridge plate mounting screw FLAT WASHER, bright zinc-plated finish. use 1 per screw along with either of the aftermarket screws above. Each:
    $ 2.95
    HCP6642 Aftermarket bridge plate mounting screw FLAT WASHER, zinc-plated alloy steel with a bright finish. Use 1 per screw along with either of the aftermarket screws above. Each:
    $ 1.95
    HCP6643 Aftermarket bridge plate mounting screw FLAT WASHER, 18-8 stainless with a bright finish. Use 1 per screw along with either of the aftermarket screws above. Each:
    $ 2.95
    HCP25756 Aftermarket bridge plate mounting screw FLAT WASHER, 316 stainless steel. Use 1 per screw along with either of the aftermarket screws above. Each:
    $ 3.95
    HCP14285 Aftermarket bridge plate mounting screw FLAT WASHER, black oxide-coated 18-8 stainless steel. Use 1 per screw along with either of the aftermarket screws above. Each:
    $ 2.95
    HCP315 OEM bridge plate-to-frame mounting screw LOCK WASHER, for use with the HCP2264 screw above. Use 1 on all XJ650 Turbo models.
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, bridge plate-to-frame mounting screw LOCK WASHER, for use with the HCP2264 screw above. Use 1 on all XJ650 Turbo models.
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel bridge plate-to-frame mounting screw LOCK WASHER, for use with the HCP2264 screw above. Use 1 on all XJ650 Turbo models.
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel bridge plate-to-frame mounting screw LOCK WASHER, for use with the HCP2264 screw above. Use 1 on all XJ650 Turbo models.
    $ 1.95
    HCP2174 OEM bridge plate-to-frame mounting screw SPECIAL WASHER, use 1 on all XJ650 Turbo models. Each:
    $ 2.95
  11. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Ignition System: Ignition Switch, Keys, Pickup Coil, Ignition Coils, TCI-Igniter, Spark Plugs, Plug Caps, Diodes, and related hardware, etc.
    IGNITION SYSTEM PARTS:
    IGNITION MAIN SWITCH & KEYS:
    is4) OEM and aftermarket IGNITION MAIN SWITCH can be a cause of hard-to-diagnose electrical gremlins. Our brand new OEM and aftermarket replacement switches come complete, ready-to-install, with electrical harness and connector and a matched set of 2 keys. NOTE: replacement keys will not look like the original keys, and the "key position" decal differs slightly in appearance from original.
    For info on how to clean your original switch, please review this info:
    http://xjbikes.com/forums/index.php?threads/34810
    and this:
    http://www.xj4ever.com/clean%20and%20lu ... switch.pdf
    HCP447 OEM IGNITION MAIN SWITCH, with built-in steering lock mechanism. Fits all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1992-93 XJ600 Seca II, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim, XJ900RK, and 1978-79 XS1100 models, as well as all of the following models: 1979 RD400F, 1980-82 SR250, 1987 SRX250, 1978-81 XS400, 1980-82 XS400 SG/SH/SJ, 1982-83 XS400 RJ/RK, 1978-83 XS650 Specials, 1980-81 XS650 Standards, 1978-79 XS750 Specials, 1980-81 XS850 Specials, 1983 XV500, 1981-83 XV750, 1983 XV750MK Midnight Specials, 1981-82 XV920 RH/RJ, 1988-99 FZR600, 1987 FZ700, 1985-86 and 1988 FZ750, 1987-88 FZR750R, 1987-93 FZR1000, 1984-85 FJ1100, 1986-87 and 1989-93 FJ1200 models. Comes with two keys.
    $ discontinued
    HCP1546 Aftermarket IGNITION MAIN SWITCH, with built-in steering lock mechanism. Pretty much an exact reproduction of the original, includes the 3-wire harness with white connector. Fits all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1992-93 XJ600 Seca II, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim, XJ900RK, and 1978-79 XS1100 models, as well as all of the following models: 1979 RD400F, 1980-82 SR250, 1987 SRX250, 1978-81 XS400, 1980-82 XS400 SG/SH/SJ, 1982-83 XS400 RJ/RK, 1978-83 XS650 Specials, 1980-81 XS650 Standards, 1978-79 XS750 Specials, 1980-81 XS850 Specials, 1983 XV500, 1981-83 XV750, 1983 XV750MK Midnight Specials, 1981-82 XV920 RH/RJ, 1988-99 FZR600, 1987 FZ700, 1985-86 and 1988 FZ750, 1987-88 FZR750R, 1987-93 FZR1000, 1984-85 FJ1100, 1986-87 and 1989-93 FJ1200 models. Comes with two keys. NOTE: the key-position decal that comes with this switch is very close in appearance to original, but not exact. If you want the correct decal, order part HCP7281 from below.
    $ 44.95
    HCP1252 Aftermarket IGNITION MAIN SWITCH, with built-in steering lock mechanism. Pretty much an exact reproduction of the original, but has the added security feature of using round (rather than flat) keys, thus minimizing the change that anyone will ever pick the lock. Includes the 3-wire harness with white connector. Fits all XJ550 models, 1984-85 FJ600, 1986-88 FZ600, 1992-93 XJ600 Seca II, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim, XJ900RK, and 1978-79 XS1100 models, as well as all of the following models: 1979 RD400F, 1980-82 SR250, 1987 SRX250, 1978-81 XS400, 1980-82 XS400 SG/SH/SJ, 1982-83 XS400 RJ/RK, 1978-83 XS650 Specials, 1980-81 XS650 Standards, 1978-79 XS750 Specials, 1980-81 XS850 Specials, 1983 XV500, 1981-83 XV750, 1983 XV750MK Midnight Specials, 1981-82 XV920 RH/RJ, 1988-99 FZR600, 1987 FZ700, 1985-86 and 1988 FZ750, 1987-88 FZR750R, 1987-93 FZR1000, 1984-85 FJ1100, 1986-87 and 1989-93 FJ1200 models. Comes with two keys. NOTE: the key-position decal that comes with this switch is very close in appearance to original, but not exact. If you want the correct decal, order part HCP7281 from below.
    $ 44.95
    HCP9116 Aftermarket IGNITION MAIN SWITCH, with built-in steering lock mechanism. Pretty much an exact reproduction of the original; however, this version of the switch only includes a single 4-wire harness with the connector. Some original models would have also used a separate 2-wire harness from the switch that would run to the battery fluid level sensor, and this harness is not present on this switch (so you will lose that feature on your dash warning system). Fits all of the following EUROPEAN (non-North American) models only: XJ650 models, all XJ900, and all 1980-81 XS1100 models. Comes with two keys.
    $ 44.95
    HCP448 OEM IGNITION MAIN SWITCH, with built-in steering lock mechanism. Has 2 individual wire harnesses leads with correct color wires and plastic end connectors. Fits all XJ650 Turbo models and XJ750-D models. Comes with two keys. Brand new.
    $ 299.95
    HCP18168 OEM rebuilt IGNITION MAIN SWITCH, with built-in steering lock mechanism. Has 2 individual wire harnesses leads with correct color wires and plastic end connectors. Fits all XJ650 Turbo models and XJ750-D models. This unit has a brand new lock cylinder and housing and a rebuilt steering lock mechanism. Comes with two keys. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, same-model, complete main switch must be returned for the core charge to be refunded (key not required). This core charge will be refunded when an original core is returned.
    $ 169.95 + $ 50.00 refundable core charge
    HCP2914 OEM IGNITION MAIN SWITCH, with built-in steering lock mechanism. Has 2 individual wire harnesses leads with correct color wires and plastic end connectors. Fits 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Comes with two keys. Brand new.
    $ 279.95
    HCP18093 OEM rebuilt IGNITION MAIN SWITCH, with built-in steering lock mechanism. Has 2 individual wire harnesses leads with correct color wires and plastic end connectors. Fits 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. This unit has a brand new lock cylinder and housing and a rebuilt steering lock mechanism. Comes with two keys. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, same-model, complete main switch must be returned for the core charge to be refunded (key not required). This core charge will be refunded when an original core is returned.
    $ 179.95 + $ 50.00 refundable core charge
    HCP2916 OEM main IGNITION MAIN SWITCH, with built-in steering lock mechanism. Includes the 3-wire harness with white connector. Fits all 1985-86 XJ700 models, XJ750-X, 1984-87 XV700 Virago, and 1988-97 XV750 Virago models. Comes with two keys. Brand new.
    $ 289.95
    HCP18169 OEM rebuilt IGNITION MAIN SWITCH, with built-in steering lock mechanism. Has 3-wire harness with white plastic end connector. Fits all 1985-86 XJ700 models, XJ750-X, 1984-87 XV700 Virago, and 1988-97 XV750 Virago models. This unit has a brand new lock cylinder and housing and a rebuilt steering lock mechanism. Comes with two keys. NOTE: a $ 50.00 core charge applies to this item, and a re-usable, same-model, complete main switch must be returned for the core charge to be refunded (key not required). This core charge will be refunded when an original core is returned.
    $ 189.95 + $ 50.00 refundable core charge
    HCP2171 OEM ignition switch MOUNTING BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 3.95
    HCP24067 Aftermarket ignition switch MOUNTING BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 1.95
    HCP24077 Aftermarket ignition switch MOUNTING BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 2.95
    HCP24078 Aftermarket ignition switch MOUNTING BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 3.95
    HCP6639 Aftermarket ignition switch MOUNTING BOLT, socket head (hex-key drive) 18/8 stainless steel fastener with a bright finish, fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 2.95
    HCP24075 Aftermarket ignition switch MOUNTING BOLT, socket head (hex-key drive) 316 stainless steel fastener with a bright finish, fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 2.95
    HCP6640 Aftermarket ignition switch MOUNTING BOLT, socket head (hex-key drive) black oxide-coated alloy steel fastener. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, and N models, and all XS1100 models. Use 2 per switch. Each:
    $ 1.95
    HCP13724 OEM ignition switch MOUNTING BOLT, fits all XJ900 FN and F models. Use 2 per switch. Each:
    $ 4.95
    HCP2173 OEM ignition switch mounting bolt FLAT WASHER, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, and N models. Use 2 per switch, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket ignition switch mounting bolt FLAT WASHER, zinc-plated alloy steel with a natural finish, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, and N models. Use 2 per switch, each:
    $ 1.95
    HCP6643 Aftermarket ignition switch mounting bolt FLAT WASHER, 18-8 stainless steel with a natural finish, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, and N models. Use 2 per switch, each:
    $ 2.95
    HCP25756 Aftermarket ignition switch mounting bolt FLAT WASHER, 316 stainless steel with a natural finish, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, and N models. Use 2 per switch, each:
    $ 3.95
    HCP14285 Aftermarket ignition switch mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, and N models. Use 2 per switch, each:
    $ 2.95
    HCP14284 Aftermarket ignition switch mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, fits all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, and N models. Use 2 per switch, each:
    $ 2.95
    HCP2181 OEM ignition switch bracket-to-steering crown bracket mounting BOLT, alloy steel with a satin finish (original was bright polished), hex-head bolt. For all XJ1100 models. Use 2 per bike. Each:
    $ 2.95
    HCP17123 Aftermarket ignition switch bracket-to-steering crown bracket mounting BOLT, 18-8 stainless steel with a bright finish, hex-head bolt. For all XJ1100 models. Use 2 per bike. Each:
    $ 2.95
    HCP22191 Aftermarket ignition switch bracket-to-steering crown bracket mounting BOLT, 316 stainless steel with a bright finish, hex-head bolt. For all XJ1100 models. Use 2 per bike. Each:
    $ 3.95
    HCP22189 Aftermarket ignition switch bracket-to-steering crown bracket mounting BOLT, alloy steel with a yellow zinc-plated finish, hex-head bolt. For all XJ1100 models. Use 2 per bike. Each:
    $ 1.95
    HCP17122 Aftermarket ignition switch bracket-to-steering crown bracket mounting BOLT, alloy steel with a black finish, hex-head bolt. For all XJ1100 models. Use 2 per bike. Each:
    $ 1.95
    HCP2185 OEM ignition switch bracket-to-steering crown bracket mounting bolt LOCK WASHER, correct bright finish. For all XJ1100 models. Use 2 per bike. Each:
    $ 6.95
    HCP16209 Aftermarket ignition switch bracket-to-steering crown bracket mounting bolt LOCK WASHER, zinc-plated alloy steel. For all XJ1100 models. Use 2 per bike. Each:
    $ 2.95
    HCP16100 Aftermarket ignition switch bracket-to-steering crown bracket mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish. For all XJ1100 models. Use 2 per bike. Each:
    $ 3.95
    HCP16102 Aftermarket ignition switch bracket-to-steering crown bracket mounting bolt LOCK WASHER, black-oxide coated alloy steel. For all XJ1100 models. Use 2 per bike. Each:
    $ 3.95
    HCP17708 Aftermarket main switch lock cylinder wafer COMPRESSION SPRING. These tiny springs fit underneath each lock cylinder wafer and provides the proper tension to enable the wafer to pop "up" and provide the locking function between the cylinder plug and housing. Use one spring per wafer, six per lock cylinder. Each:
    $ 1.95
    HCP17708SET6 Aftermarket main switch lock cylinder wafer COMPRESSION SPRING, set of 6 springs:
    $ 9.95
    Ignition Switch ID Decals:
    This round switch bezel key-position identification DECAL help to restore that "brand-new" look to refinished original parts.
    HCP7281 Aftermarket ignition switch KEY POSITION ID DECAL, round hollow "ring" decal fits on the ignition switch bezel ring and identifies each key position: OFF, ON, LOCK, P (with is for "Park"), and IGNITION wording. Black decal with silvered lettering. Fits all XJ550, 1986-88 FZ600, FJ600, 1992-93 XJ600 Seca II, XJ650, XJ700, XJ750, XJ900, all XS1100 models, 1984-87 XV700 Virago, 1988-97 XV750 Virago, as well as all of the following models: 1979 RD400F, 1980-82 SR250, 1987 SRX250, 1978-81 XS400, 1980-82 XS400 SG/SH/SJ, 1982-83 XS400 RJ/RK, 1978-83 XS650 Specials, 1980-81 XS650 Standards, 1978-79 XS750 Specials, 1980-81 XS850 Specials, 1983 XV500, 1981-83 XV750, 1983 XV750MK Midnight Specials, 1981-82 XV920 RH/RJ, 1988-99 FZR600, 1987 FZ700, 1985-86 and 1988 FZ750, 1987-88 FZR750R, 1987-93 FZR1000, 1984-85 FJ1100, 1986-87 and 1989-93 FJ1200 models This is a high-quality reproduction of the original.
    $ 12.95
    KEY BLANKS:
    s) Yamaha KEY BLANKS.....please see the long NOTE at the end of this post for additional detail.
    All of the following are the correct blank (un-cut) style keys.
    The original keys that came with your bike has a small, truly rectangular head that has a black plastic head cap, and the word YAMAHA was cast into this head cap.
    The OEM replacement keys that we offer have the YAMAHA wording in the key head, but no black plastic head cap.
    Aftermarket keys are available either with or without the black plastic head cap....but do not have the word YAMAHA cast into them.
    The aftermarket plastic cap headed keys are very similar in shape to an original Yamaha key from this era, but are slight more trapezoidal than original (as opposed to being a true rectangle).
    The aftermarket metal-headed keys are approximately the same size and shape as original plastic-capped keys. Unlike the replacement keys that most lock shops have available for older Yamaha locks (which will work just fine, but usually have a huge, rather ugly head), our keys have the small rectangular head that is similar in size to original.
    NOTE: although we offer the following key BLANKS, we do not offer any pre-cut keys, since we have no way of translating your key code---should you even know it!---into a fully cut key. Nor do we have any method of translating your bike's VIN into the original key-code (some older Yamaha dealers MAY have this information, but don't count on it).
    As long as you have a key that fits your lock(s), anyone with a key-cutting machine will be able to copy your key pattern onto any of the following key blanks. Additionally, if you have a professional locksmith in your area.....and one that has been in business for a LONG time (and thus has the older conversion books available), then they may be able to convert your key code and cut a key without having a master key to copy from.
    P.S. If you lose your key(s), or obtain a used gas tank that still has a (locked) cap on it but with no key, then it may be time for you to learn the ancient art of lock-picking:
    http://www.capricorn.org/~akira/home/lockpick/
    All keys have to be ordered according to their Key Blank Style (A-F).
    NOTE ON KEY BLANK STYLES: Yamaha used 6 different key blank styles, designated as A, B, C, D, E, or F, and you can re-key an individual lock only to another pattern within the same key blank style.
    Originally, your bike came with two keys that were cut to the same pattern and fit ALL of the locks on your bike (ignition switch, gas cap, seat and/or helmet lock, Powerlock chain if so equipped, etc.). These keys were unique to your bike, and were cut to a specific pattern which was identified by a KEY CODE. This key code was stamped onto the key head, and also was either stamped into the base (bottom) of the ignition switch housing, or has a small metallic adhesive-backed tag that had the key code stamped into it and that was affixed to the bottom of the ignition lock housing. THERE IS NO OTHER PLACE ON YOUR BIKE WHERE THIS KEY CODE APPEARS!. None of the other locks on your bike have the key code impressed, stamped, or labeled upon them.
    In the old days, you could have Yamaha cut a new key for you by presenting your bike's VIN number to them, as they had VIN-to-Key Code translation information available to them. Few, if any, dealers still have such information still available for these older bikes.
    Key Blank Style Determination:
    Of course, if you have the original key that came with your bike, then the entire key code (letter and 5 numbers) is stamped onto the key head, right below the black plastic cap.
    If not, you can determine what key blank style you have by removing your ignition switch.......and the entire key code is either stamped into the bottom of the switch housing, or is printed or etched onto a paper or aluminum tag that is glued to the bottom of the ignition lock. The key number always starts with one of the letters A-F, followed by 5 or 6 numbers. The 5 or 6 numbers are actually the "serial number" of the individual lock. You can see what this code appears like here:
    www.xjbikes.com/forums/threads/no-key-questions-and-other-missing-parts.130762
    Note that some switches will have this code on a foil sticker, rather than stamped into the switch body (as shown above).
    Swapping Lock Mechanisms:
    The lock mechanism can always be removed from an individual component (ignition switch, gas cap, or seat/helmet lock unit) and swapped out from another similar unit. For example, if your bike originally uses locks that accept a "D" style key blank, then you can substitute another "D" style lock mechanism from a donor bike and then have that donor lock re-keyed to match all of your other original locks on your bike.....usually an expensive task at a real locksmith, but it can be done (or you can do it at home, if you have the patience of Job). However, if your bike originally uses locks with a "C" style key blank, and you buy a gas cap with a lock and that gas cap lock uses a "F" style key, you cannot have that "F" style lock mechanism re-keyed to accept the "C" style key.
    Hope that isn't too much info.....but when buying replacement parts that incorporate a lock mechanism, it's useful to keep the above in mind in case you want to have all your locks keyed the same.
    Finally, remember that except for the ignition switch, the key blank style and key code (A-F) is NOT stamped nor engraved or marked on any other lock mechanism. The only way to determine which key style (for example) another gas cap lock uses is to try a key into it (even a blank, un-cut key); an "A" style key won't fit into a B-F style lock, etc. (although we have found that "C" and "E" blanks will sometimes interchange......). If you're buying a used ignition switch, with or without the key, you'll have a good chance of knowing which key style it uses as there is a key code printed or engraved on the bottom of the switch housing (assuming the printed or engraved label has not gone bye-bye after all these years); all other locks (gas, helmet/seat, and powerlock) you must either have the original key or know the ignition switch key number of the bike that component came from.
    Key Blanks:
    HCP9186 OEM "A" style KEY BLANK with metal head, no cap
    $ 18.95
    HCP188 Aftermarket "A" style KEY BLANK with black plastic cap.
    $ 12.95
    HCP194 Aftermarket "A" style KEY BLANK with metal head; no cap
    $ 9.95
    HCP9187 OEM "B" style KEY BLANK with metal head, no cap
    $ 18.95
    HCP189 Aftermarket "B" style KEY BLANK with black plastic cap.
    $ 12.95
    HCP195 Aftermarket "B" style KEY BLANK with metal head; no cap
    $ 9.95
    HCP9188 OEM "C" style KEY BLANK with metal head, no cap.
    $ 29.95
    HCP190 Aftermarket "C" style KEY BLANK with black plastic cap
    $ 17.95
    HCP196 Aftermarket "C" style KEY BLANK with metal head; no cap
    $ 9.95
    HCP9189 OEM "D" style KEY BLANK with metal head, no cap.
    $ 29.95
    HCP191 Aftermarket "D" style KEY BLANK with black plastic cap.
    $ 17.95
    HCP197 Aftermarket "D" style KEY BLANK with metal head; no cap.
    $ 9.95
    HCP9190 OEM "E" style KEY BLANK with metal head, no cap.
    $ 12.95
    HCP192 Aftermarket "E" style KEY BLANK with black plastic cap.
    $ 10.95
    HCP198 Aftermarket "E" style KEY BLANK with metal head; no cap.
    $ 9.95
    HCP9191 OEM "F" style KEY BLANK with metal head, no cap.
    $ 18.95
    HCP193 Aftermarket "F" style KEY BLANK with black plastic cap.
    $ 12.95
    HCP199 Aftermarket "F" style KEY BLANK with metal head; no cap.
    $ 9.95
    HCP17031 Aftermarket replacement KEY used on the small locks fitted originally to all Yamaha models with factory saddlebags or trunk systems using the original Presto Lock Company locks. Already "cut", as these locks were standardized (universal) and did not use special coded keys. Each:
    $ 9.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
    IGNITION SYSTEM OVERVIEW:
    Before we get into the list of components within your ignition system, it may be useful to explore the basics of the ignition design used on these bikes, as this knowledge may help you to better recognize, troubleshoot, and repair performance problems with your engine that you think may be due to these components.
    The ignition system actually begins at the left end of your CRANKSHAFT, since the rotational position of the crankshaft determines the position of the pistons and of the camshafts. Obviously, since the purpose of the entire ignition system is to deliver a high-voltage spark at the plugs at exactly the proper instant----meaning, as the piston approaches Top Dead Center of the compression stroke----then the ignition system must "know" what the position of the crankshaft is in order to transfer that information (via electrical signals) to the major components: the PICK-UP COILS, then onto the TCI UNIT, to the IGNITION COILS, via the PLUG WIRES and through the PLUG CAPS and finally, onto the SPARK PLUGS.
    But it all begins at the crankshaft, which has a flat metal ROTOR DISC bolted onto the left side snout, and which hides under the left side, round "Oil Pump Cover" (also called a "YICS" cover on YICS-equipped engines). This spinning rotor disc has a small magnet embedded within it's outer tip, and as that outer tip rotates past the fixed magnets within the PICK-UP COILS, the interaction of magnetic fields triggers a small voltage in the pick-up coil wires that lead to the TCI UNIT.
    Note that since the rotor disc is fixed in position and spins along with the crankshaft, this rotor disc "knows" the position of the crankshaft at all times. And since the pick-up coils are bolted in place, and are thus stationary, whenever the spinning rotor passes by a fixed pick-up coil, and thus triggers it to send a voltage signal to the TCI, in this way the TCI unit thus also "knows" where the crankshaft is, rotationally-speaking, and thus where the pistons are in relation to Top Dead Center and when their spark plugs need to be fired.......
    Also note that since there are only two pick-up coils for your four-cylinder engine, that each pick-up coil is actually providing the "firing signal" to the TCI unit for two different cylinders. In these engines, one pick-up coil is responsible for sending the signal to the TCI that eventually leads to the spark plugs firing off for cylinders #1 and #4 at the same time, and the other pick-up coil sends the message to the TCI unit to fire off spark plugs #2 and #3, again, at the same time.
    Although this may seem odd at first, the mechanical arrangement within the engine of the crank throws, and thus the rods and pistons, as well as the camshaft timing, allow this situation to proceed without a problem; in fact, when one of these "paired" cylinders (for example, #1) is approaching Top Dead Center of it compression stroke----and thus is in need of a spark from its spark plug----it's "mated" cylinder (#4) is also approaching Top Dead Center, too.........but on its exhaust stroke.......and so even though cylinder #4 gets a spark at its spark plug, there's nothing in the cylinder to combust, and thus it's a "wasted" (yet harmless) spark that occurs in cylinder #4.
    Obviously, the exact same situation occurs in the mated pair of cylinders #2 and #3.
    In fact, the whole system is known as the "wasted spark" system, since one of the two sparks that always occur at the same time is "wasted" on a cylinder that is on its exhaust stroke............
    Anyway, to continue our journey: when a pick-up coil is energized by the passing magnetic field of the spinning rotor disc, it send an electrical impulse signal to the TCI. Therefore, the TCI unit now also "knows" the position of the crankshaft (and thus of the piston). Using other sensor information.....primarily, the rotational speed (RPM's) of the engine......the computer chip in the TCI is then responsible for calculating exactly when to send a "message" to the proper IGNITION COIL to release it's energy to the proper cylinders. And note that we said "cylinders" (plural), since just like the pick-up coils, one ignition coil also sparks two cylinders at once (part of the same "wasted spark" method discussed above).
    The ignition coils use a rather small (12V) input on their primary side to product a large (20,000V +) amount of electrical energy on their discharge (spark plug wires). When the TCI unit determines that "the time is right" for a particular coil to fire, it grounds that coil, which collapses the small magnetic field inside the primary side of the coil, which thus induces a large electrical field in the secondary (plug wires) side of the coil, which then rushes to ground. This electrical energy rushes down the non-resistive PLUG WIRES, through a resistor in the SPARK PLUG CAP, and finally jumps a small gap in the spark plug electrode on it's way to ground, and thus the spark occurs that fires the air-fuel mixture (in one of the two cylinders being sparked at the same time), things go boom, power gets produced, and you're on the way down the road........
    A great explanation and diagram---starting at the 4:15 mark in the video---explains all of the above in a very simplified, yet understandable detail:
    By the way, the firing order for the XJ550 thru XJ900 engines is 1-2-4-3, with the two center pistons coming up while the two outer pistons are going down, and the direction of engine rotation is in the same direction as your tires rotate when moving forward.
    Now, What Could Go Wrong?:
    Well, remember, all of these components are basically used to transmit knowledge of where the piston is within its four-stroke cycle, and to be able to deliver a spark at the appropriate time to each cylinder to take advantage of the compressed air-fuel mixture in the cylinder (during the compression stroke). So it sometimes help to understand these component pieces as being mainly responsible for providing this stream of precise information, and the electrical-spark making (at the spark plug gap) as merely being the natural (according to the laws of physics and electricity) end-result of all this information handling and processing.
    Now, unless your crankshaft was installed backwards (an impossibility, by the way!) or the camshaft was installed improperly (or if the camshaft drive chain has skipped a tooth----not a common occurrence, at all), then we can safely ignore all of these issues. And since the spinning rotor disc used to trigger the pick-up coils is bolted firmly in place at the end of the crankshaft, it can be ignored for troubleshooting issues.
    But the pick-up coils themselves can go bad over time, and even though it's rare, it can happen. No pick-up coil signal out----along their wires to the TCI unit-----means no signal into the TCI unit, and the whole system breaks down. Which means the small wires from the pick-up coils to the TCI had better not be pinched, shorted to ground, or broken internally, or the message just won't get through.
    NOTE: if you are having intermittent or difficult-to-diagnose ignition system problems, it may be that the wire leads from the pick-up coils (under the left round crank-end cover) have become pinched where they exit the cover and have worn through their insulation.
    Of course, if the TCI unit itself is defective, then even if it is getting a signal from the pick-up coils, it is unable or unwilling to process the signal, or the signal gets processed incorrectly, and either the signal doesn't get sent to the ignition coils at the proper time, or doesn't get sent at all.
    But even if the pick-up coils and the TCI are performing flawlessly---which they usually are----if the ignition coils are not getting enough voltage input to them, or, if they are not able to multiply the small incoming voltage into a much higher output voltage (that is, after all, their main purpose in life), then we have a problem.
    Worn-out ignition coils, or coils that perform poorly or get cracks in their outer cases (and thus short out when moisture enters their internal shells), are a common cause of ignition system problems.
    And even if the coils are performing properly, if the spark plug wires have an internal break, or an external break, and thus prevent the coil electrical output from reaching the plugs, then nothing good is going to come from all this activity.
    Of course, the spark plug Resistor Caps also play a role. They have a tiny resistor embedded within them, and the purpose of the resistor is to provide, of course, electrical resistance to the flow of electrical energy. There are a couple of reasons why some resistance is necessary-----it helps eliminate electrically-generated Radio Frequency Interference "noise" (RFI), it provides a "cushion" against instantaneous electrical energy pulses (which is really hard on small, fragile electrical components, such as the capacitors and transistors in the TCI unit), and it "slows down" the passage of the electricity through the spark plug, thus providing a sort of "electrical Viagra" to spark at the plugs, allowing the electrical discharge (and thus the spark) to last a bit longer (instead of being instantaneous), thus promoting more-better and fuller combustion of the air-fuel mixture.
    In fact, outside of the RFI suppression issues, it is the control of this "spark burn time" that is really the most critical issue, especially on bikes that are jetted a bit lean to begin with........as increased electrical resistance in the secondary circuit will increase the spark firing or "burn" time, and that longer burning spark assists in the more complete combustion of harder-to-fire lean fuel mixtures.
    But those resistors in the spark plug caps........or in the spark plugs themselves, for those engines that use resistor plugs........do wear out over time. And when they do, their resistance increases, which means that they provide more resistance to the flow of electricity than is needed. So that 20,000 volts of electrical energy, instead of being discharged at the spark plug gap in a rather short (10 milliseconds) amount of time, gets "spread out" over a much longer period of time, and gets reduced in voltage, too. So when plug caps or plugs "go bad", they rarely fail to the point where no spark occurs at all, it's just that the electrical output is being "spread out" over such a long period of time that the energy being created in the spark plug gap is so low that it's not enough to fire the fuel mixture completely (or at all)........and that's what leads to hard starts and poor performance (and reduced gas mileage, too).
    By the way, as you may have figured out by now, a spark plug that is contaminated ("fouled") by carbon or oil deposits, or one which has too large of a gap, fail to operate properly mainly because such situation can greatly increase the electrical resistance characteristics of such a plug.........and now you know why that's not a good thing.
    NOTE: some models specify a different (higher) plug cap resistance for the inner 2 cylinders vs. the outer cylinders. The probable reason for this is that the inner pair of cylinders may run a bit leaner (at least on some engines) since they run warmer, and also because the YICS system should allow the inner pair to “steal” more than the outer pair. If they’re really effectively leaner, they'll need a longer duration of a spark to ignite their charge, and of course the way to achieve that is: you guessed it, increased resistance on those inner cylinders!
    A very good review of the issue of electrical resistance in ignition systems can be found at:
    http://www.motorcycleproject.com/motorcycle/text/plugwiretech.html
    and
    http://www.ultralightnews.com/enginetroublshooting/resistorcapsandplugs.htm
    Although the above article references the ignition systems in ultra-light aircraft, the same concepts apply to all ignition systems.
    Okay, so that's your nickel tour, and although it's not as detailed as it could be, hopefully it's enough to get you started. A good voltmeter (also called an ohmmeter) is an invaluable friend when trying to track down ignition system problems, as you must make sure that the "information" between components is actually able to travel from Point A to Point B properly, and that the individual components are, electrically-speaking, able to process and transmit the electrical information properly.
    SO, WHY WON’T IT START?
    Well, in order for your engine to start and run, you’ve got to have fuel, spark, and enough engine compression.
    The following article is THE authoritative testing procedure if you suspect a no-start situation is due to ignition system issue. Obviously, it assumes that:
    a) you are getting fuel into the carbs (verify this by loosening one (or all of them, but one at a time!) of the carb bowl drain screws and see if some fuel leaks out. If so, you got fuel! If not, you’ll need to tackle this issue and figure out why.
    b) you have good engine compression. If you’re not sure, you’ll need to perform a compression test and verify that then engine is making enough compression.
    c) your battery should be fully charged:
    While the starter is engaged (but before the bike starts), the battery voltage should be 9.5 volts or greater. If not, then this signals either a bad battery, very dirty or weak electrical connections, or it could be an incredibly problematic starter motor (not likely; it's probably the battery!).
    A low voltage during cranking will prevent the ignition coils from getting enough voltage to charge themselves enough to deliver a good spark to the plugs.
    http://www.xjbikes.com/forums/threads/how-to-ignition-troubleshooting.21932/
    Ignition system firing order:
    It's 1-2-4-3 for all engines.
    Ignition system components resistance specifications:
    The following list also covers the resistance values of the spark plugs, plug caps, the ignition pick-up coils (which are located behind the left side round crankshaft end cover)m and the ignition coils. The resistance of the pick-up coils can be checked at their connector to the TCI box by measuring the resistance between the grey and the black wire (this checks the condition of the first pick-up coil) and then between the orange and the black wire (this is the resistance of the other pick-up coil).
    NOTE: "K" is abbreviation for a thousand units, so "5K" ohms = 5,000 ohms of resistance, etc.
    NOTE: some models within this era could have been fitted with "noise suppression" plug caps (these caps are evidenced by a metal "shield" wrapped around the plastic cap body) and such caps may have used a higher resistance rating as opposed to their stock ratings listed below (for non "noise suppression" style caps).
    XJ550 models:
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    XJ650 models:
    Pick-up coils:
    1980-81 XJ650 Maxim and Midnight Maxim: 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982 XJ650RJ Seca (non-yics engines): 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982-84 XJ650 Maxim: 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    1982 XJ650RJC Seca (yics engine): 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    1982-83 XJ650 Turbo: 120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    Ignition Coils:
    Spark plug caps:
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    XJ700 air-cooled models:
    Pick-up coils:
    Ignition Coils:
    2.7 ohms +/- 10% = 2.43 ohms - 2.97 ohms acceptable range
    12K ohms +/- 20% = 9,600 ohms - 14,400 ohms acceptable range
    Spark plug caps:
    1985 N/NC models: 5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    1986 S/SC models: 10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    1985 N/NC models: 0 ohms per plug
    1986 S/SC models: 5K ohms per plug
    XJ700-X water-cooled models:
    Pick-up coils:
    Ignition Coils:
    Spark plug caps:
    Spark plugs:
    1985 XN/XNC models: 0 ohms per plug
    1986 SX/SXC models: 5K ohms per plug
    XJ750 air-cooled models:
    Pick-up coils:
    Ignition Coils:
    Spark plug caps:
    1981-83 models: 5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    1984 RL models: 10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    XJ750-X water-cooled models:
    Pick-up coils:
    Ignition Coils:
    Spark plug caps:
    Spark plugs:
    5K ohms per plug
    XJ900RK, RL, N, FN, and F models:
    Pick-up coils:
    Ignition Coils:
    original coils, marked CM12-20: 2.7 ohms +/- 10% = 2.43 ohms - 2.97 ohms acceptable range
    replacement coils, marked CM12-09 or CM12-10: 2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    original coils, marked CM12-20: 13.2K ohms +/- 20% = = 10,560 ohms - 15,840 ohms acceptable range
    replacement coils, marked CM12-09 or CM12-10: 11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    RK and RL models: 5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    N, FN, and F models: 10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    S and SH models: 15K +/- 20% = 12,000 to 18,000 ohms per cap acceptable range
    Spark plugs:
    RK and RL models: 0 ohms per plug
    N, FN, and F models: 5K ohms per plug
    XJ1100 models:
    Pick-up coils:
    Ignition Coils:
    Spark plug caps:
    Spark plugs:
    0 ohms per plug
    XS1100 models:
    Pick-up coils:
    720 ohms +/- 20% = 576 ohms to 864 ohms acceptable range
    Ignition Coils:
    1.5 ohms +/- 10% = 1.35 ohms -1.65 ohms acceptable range
    15K ohms +/- 20% = 12,000 ohms - 18,000 ohms acceptable range
    Spark plug caps:
    Spark plugs:
    0 ohms per plug
    IGNITION PICK-UP COILS:
    One of the nice things about the stock XJ electrical systems is the transistorized (maintenance free) ignition systems.......no points to set or timing to adjust (except on 1986 XJ700-X models). All of those dreadful chores are handled for you, automatically, via the IGNITION PICK-UP COILS SYSTEM, and further down the line, via the TCI CONTROL MODULE. These components are generally very reliable, almost to the point of being bulletproof, and as mentioned, are truly "plug-and-play" devices that need no periodic maintenance once installed. However, they are quite susceptible to damage via electrical shorts or voltage surges (i.e. if you jumper the battery incorrectly, etc.).
    Checking pick-up coils:
    The resistance across each pair of lead wires (at the TCI) should be checked as shown in the following video……note that resistance valves specified in the service manual is for measurements taken at 70-F, and as the coils heat up, their resistance values will change, and the use of a hair dryer or heat gun to warm up the coils is simple way to see if values go way out of range as the coils heat up:
    Resistance values at 70-F are as follows:
    120 ohms +/- 10% for all XJ650 Turbo models, XJ700 all models and XJ750-X models, XJ900RK, RL, N/FN, and F models, and XJ1100 models.
    650 ohms +/- 20% for all XJ550 models, 1982-84 XJ650 Maxim, 1982 XJ650RJC Seca (Canadian, yics-engine), and all air-cooled XJ750 models.
    700 ohms +/- 20% for all 1980-81 XJ650 models and 1982 XJ650RJ (non-yics engine) models.
    720 ohms +/- 20% for all XS1100 models
    NOTE: if measuring the resistance when the pick-up coils are hot (i.e. after the engine has been running for 20 minutes or more, such that the pick-up coils are fully heat-saturated), then the resistance readings will be higher by 100 – 150 ohms than at the 70-F “cold” readings shown above.
    NOTE: if both coils are out of specifications, suspect a pinched or shorted black ground wire, which is a shared ground for both of the pick-up coils on most models. It is very unlikely (although not impossible, especially in a case of improper jump-starting, etc.) that BOTH pick-up coils would expire at the same time!
    A simple test to see if the coils are working, at all is to place a voltmeter (preferably an analog unit) across the Grey or the Orange wire to the Black wire. Energize the system and watch for voltage pulses as you rotate the reluctor past the pickup. This can be done by hand or with the starter.......we'd recommend using the hand method so that the pulses are slow enough to see. These "pulses" are what the TCI "black box" counts and interprets when "deciding" when to fire the ignition coils.
    NOTE: the orange lead wire is the trigger wire for the #1/#4 ignition coils, while the grey lead wire is the trigger for the #2/#3 ignition coils.
    Pick-Up Coils Baseplate and Lead Wire Harness:
    NOTE: whenever you remove or replace your pick-up coils Baseplate unit, it will be necessary to check and perhaps adjust the engine timing. See your factory service or workshop manual for the proper procedure to check and/or adjust your ignition timing!
    NOTE: the screws that hold the unit to the engine case are lock-tighted in place, and we strongly suggest that you use a proper-szie (#2) JIS screwdriver to remove them!
    HCP503 OEM pick-up coils COILS AND BASEPLATE UNIT, for all XJ700, XJ750-X, and XJ900RK, RL, N/FN, and F models.
    $ discontinued
    HCP15736 Aftermarket pick-up coils-to-baseplate MOUNTING SCREW, with integral lockwasher. For all XJ550, XJ650, XJ700, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per coil. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 1.95
    HCP4189 OEM pick-up coils pick-up coils baseplate LOCATING DOWEL PIN, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, use 1 per engine.
    $ 7.95
    HCP314 OEM pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. Zinc-plated alloy steel, panhead, phillips-drive. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 3.95
    HCP5335 OEM pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. Black alloy steel, panhead, phillips-drive. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 8.95
    HCP915 Aftermarket pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. Zinc-plated alloy steel, panhead, phillips-drive. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 1.95
    HCP316 Aftermarket pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. 18-8 stainless steel, panhead, phillips-drive. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 2.95
    HCP317 Aftermarket pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. 18-8 stainless steel with a polished button head, hex-drive. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 2.95
    HCP318 Aftermarket pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. 18-8 stainless steel with a smooth, polished socket head, hex-drive. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 2.95
    HCP320 Aftermarket pick-up coils baseplate MOUNTING SCREW, for all XJ550, 1984 FJ600 models, XJ650, XJ750, XJ900RK, RL, and N/FN models, and XJ1100 models, use 2 per base. Black-oxide coated alloy steel with a ribbed socket head. NOTE: these screws should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 1.95
    HCP4184 OEM pick-up coils baseplate MOUNTING SCREW, for all 1985 FJ600 models, XJ700, XJ750-X, and XJ900 N/FN models, use 2 per base. NOTE: these bolts should be installed with a low-strength thread locking fluid on their threads. Each:
    $ 2.25
    HCP3575 OEM pick-up coils baseplate FLAT WASHER, for all 1981-82 XJ550, 1980-82 XJ650 (except Turbo), 1981-82 XJ750 Seca, and 1982 XJ750 Maxim models, use 2 per base. Each:
    $ 6.95
    HCP2173 OEM pick-up coils baseplate FLAT WASHER, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket pick-up coils baseplate FLAT WASHER, zinc-plated alloy steel with a bright finish, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 1.95
    HCP6643 Aftermarket pick-up coils baseplate FLAT WASHER, 18-8 stainless steel with a bright finish, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 2.95
    HCP25756 Aftermarket pick-up coils baseplate FLAT WASHER, 316 stainless steel with a dull finish, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 3.95
    HCP14285 Aftermarket pick-up coils baseplate FLAT WASHER, black oxide-coated 18-8 stainless steel, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 2.95
    HCP14284 Aftermarket pick-up coils baseplate FLAT WASHER, black oxide-coated hardened alloy steel, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 2.95
    $ 2.95
    HCP6642 Aftermarket pick-up coils baseplate FLAT WASHER, zinc-plated alloy steel with a natural finish, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 1.95
    HCP6643 Aftermarket pick-up coils baseplate FLAT WASHER, 18-8 stainless steel with a natural finish, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 2.95
    HCP25756 Aftermarket pick-up coils baseplate FLAT WASHER, 316 stainless steel with a natural finish, for all 1983 XJ550, 1985 FJ600 models, 1983-4 XJ650 Maxim and all XJ650 Turbo, 1983 XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900RK, RL, N/FN, and F models, use 2 per base, each:
    $ 3.95
    $ 2.95
    $ 2.95
    HCP315 OEM pick-up coils baseplate LOCK WASHER, for all XJ1100 Maxim models, use 2 per base. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, pick-up coils baseplate LOCK WASHER, for all XJ1100 Maxim models, use 2 per base. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel pick-up coils baseplate LOCK WASHER, for all XJ1100 Maxim models, use 2 per base. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel pick-up coils baseplate LOCK WASHER, for all XJ1100 Maxim models, use 2 per base. Each:
    $ 1.95
    NOTE: make sure that you do NOT pinch the lead wire harness as it is routed in-between the rear pick-up coils engine cover and the front of the shifter cover.....it is a very tight, constrained space where this harness is routed, and it is easy to pinch the wires, especially when removing and replacing the shifter cover.
    HCP4180 OEM pick-up coils wiring lead harness CLAMP, u-shaped open clamp closest to the pick-up base. Use one on all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and two on XJ1100 models. Each:
    $ 8.95
    HCP4181 OEM pick-up coils wiring lead harness CLAMP, u-shaped open clamp farthest from the pick-up base. Use one on all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 7.95
    HCP4183 OEM pick-up coils wiring lead harness CLAMP, flat L-shaped clamp that is attached at the front lower shifter cover bolt. Use one on all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 6.95
    Pick-Up Coil Rotor ("Reluctor") Disc:
    HCP497 OEM pick-up coils ROTOR DISC, for all XJ700 non-X models.
    $ discontinued
    HCP498 OEM pick-up coils ROTOR DISC, for all XJ700-X, XJ750-X, and XJ900RK, RL, N/FN, and F models.
    $ discontinued
    NOTE: the bolt that hold the reluctor to the crankshaft is lock-tighted in place, and we strongly suggest that you use a bit of heat to "loosen" the lock-tight when removing it (and re-use lock-tight when re-installing).
    HCP505 OEM pick-up coils rotor disc MOUNTING BOLT, for all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK and RL models.
    $ 7.95
    HCP21944 Aftermarket pick-up coils rotor disc MOUNTING BOLT, alloy steel socket head cap screw with a black finish, For all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK and RL models.
    $ 1.95
    HCP21942 Aftermarket pick-up coils rotor disc MOUNTING BOLT, alloy steel socket head cap screw with a bright finish, For all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK and RL models.
    $ 1.95
    HCP23282 Aftermarket pick-up coils rotor disc MOUNTING BOLT, 18-8 stainless steel socket head cap screw with a bright finish, For all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK and RL models.
    $ 2.95
    HCP22203 Aftermarket pick-up coils rotor disc MOUNTING BOLT, 316 stainless steel socket head cap screw with a bright finish, For all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK and RL models.
    $ 3.95
    HCP23283 Aftermarket pick-up coils rotor disc MOUNTING BOLT, magni-coated (dull aluminum finish, ultra-corrosion resistance) alloy steel socket head cap screw. For all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK and RL models.
    $ 3.95
    Pick-Up Coil Timing Pointer:
    NOTE: you should not find it necessary to ever move or remove the pointer; however, if that is necessary, upon replacement you will need to check and perhaps adjust and set the TDC of the engine and/or the engine timing. See your factory service or workshop manual for the proper procedure to check and/or adjust your ignition timing!
    HCP314 OEM pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. Zinc-plated alloy steel, panhead, phillips-drive Each:
    $ 3.95
    HCP5335 OEM pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. Black alloy steel, panhead, phillips-drive. Each:
    $ 8.95
    HCP915 Aftermarket pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. Zinc-plated alloy steel, panhead, phillips-drive Each:
    $ 1.95
    HCP316 Aftermarket pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. 18-8 stainless steel, panhead, phillips-drive. Each:
    $ 2.95
    HCP317 Aftermarket pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. 18-8 stainless steel with a polished button head, hex-drive. Each:
    $ 2.95
    HCP318 Aftermarket pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. 18-8 stainless steel with a smooth, polished socket head, hex-drive. Each:
    $ 2.95
    HCP320 Aftermarket pick-up coils timing pointer MOUNTING SCREW, for all XJ550, XJ650, 1985 XJ700, XJ750 non-X, and XJ900RK models, use 1 per engine. Black-oxide coated alloy steel with a ribbed socket head. Each:
    $ 1.95
    HCP2173 OEM pick-up coils timing pointer FLAT WASHER, for all XJ550 models, use 1 per engine, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket pick-up coils timing pointer FLAT WASHER, zinc-plated alloy steel with a natural finish, for all XJ550 models, use 1 per engine, each:
    $ 1.95
    HCP6643 Aftermarket pick-up coils timing pointer FLAT WASHER, 18-8 stainless steel with a natural finish, for all XJ550 models, use 1 per engine, each:
    $ 2.95
    HCP25756 Aftermarket pick-up coils timing pointer FLAT WASHER, 316 stainless steel with a natural finish, for all XJ550 models, use 1 per engine, each:
    $ 3.95
    HCP14285 Aftermarket pick-up coils timing pointer FLAT WASHER, black oxide-coated 18-8 stainless steel, for all XJ550 models, use 1 per engine, each:
    $ 2.95
    HCP14284 Aftermarket pick-up coils timing pointer FLAT WASHER, black oxide-coated hardened alloy steel, for all XJ550 models, use 1 per engine, each:
    $ 2.95
    HCP3575 OEM pick-up coils timing pointer FLAT WASHER, for all XJ650, 1985 XJ700, XJ750, and XJ900RK, RL, and N/FN models, use 1 per engine. Each:
    $ 6.95
    HCP6642 Aftermarket pick-up coils timing pointer FLAT WASHER, zinc-plated alloy steel with a bright finish, for all XJ650, 1985 XJ700, XJ750, and XJ900RK, RL, and N/FN models, use 1 per engine. Each:
    $ 1.95
    HCP6643 Aftermarket pick-up coils timing pointer FLAT WASHER, 18-8 stainless steel with a bright finish, for all XJ650, 1985 XJ700, XJ750, and XJ900RK, RL, and N/FN models, use 1 per engine. Each:
    $ 2.95
    HCP25756 Aftermarket pick-up coils timing pointer FLAT WASHER, 316 stainless steel with a dull finish, for all XJ650, 1985 XJ700, XJ750, and XJ900RK, RL, and N/FN models, use 1 per engine. Each:
    $ 3.95
    HCP14285 Aftermarket pick-up coils timing pointer FLAT WASHER, black oxide-coated 18-8 stainless steel, for all XJ650, 1985 XJ700, XJ750, and XJ900RK, RL, and N/FN models, use 1 per engine. Each:
    $ 2.95
    HCP14284 Aftermarket pick-up coils timing pointer FLAT WASHER, black oxide-coated hardened alloy steel, for all XJ650, 1985 XJ700, XJ750, and XJ900RK, RL, and N/FN models, use 1 per engine. Each:
    $ 2.95
    HCP315 OEM pick-up coils timing pointer LOCK WASHER, for all XJ550 models, use 1 per engine. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, pick-up coils timing pointer LOCK WASHER, for all XJ550 models, use 1 per engine. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel pick-up coils timing pointer LOCK WASHER, for all XJ550 models, use 1 per engine. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel pick-up coils timing pointer LOCK WASHER, for all XJ550 models, use 1 per engine. Each:
    $ 1.95
    ec2) OEM oil pump/crankshaft end cover ("YICS covers" on models so equipped) COVER GASKET. A great idea to replace these if you remove the case covers. Although these gaskets don't seal any fluids, you don't really want grime and gunk and junk accumulating inside the covers.
    OEM oil pump cover gaskets are made from a standard duty, graphite impregnated paper material. We recommend the use of the aftermarket hi-performance paper gaskets which are designed to slightly swell in the presence of petroleum products (fuel or oil), thus creating a super-tight, leak-proof flange seal.
    HCP998 OEM oil pump covers or "YICS" covers standard duty paper GASKET. Originally used under the left side cover only, but many people like to install one under the right side cover also, and they will fit either side properly. Fits all XJ550, FJ600, XJ650, 1981-83 all XJ750 models, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 14.95
    HCP998SET2 OEM oil pump covers or "YICS" covers standard duty paper GASKETS, set of 2:
    $ 27.95
    HCP18438 Aftermarket oil pump covers or "YICS" covers hi-performance GASKET. Originally used under the left side cover only, but many people like to install one under the right side cover also, and they will fit either side properly. Fits all XJ550, FJ600, XJ650, 1981-83 all XJ750 models, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 12.95
    HCP18438SET2 Aftermarket oil pump covers or "YICS" covers hi-performance GASKETS, set of 2:
    $ 24.95
    HCP999 OEM crankshaft end cover-to-block rubber RING GASKET, fits all 1986-88 FZ600, 1986-90 YX600 Radian, all XJ700, XJ750-X, 1984-85 FJ1100, and 1986-93 FJ1200 models. Right and left side are the same. Each:
    $ 32.95
    HCP999SET2 OEM crankshaft end cover-to-block RING GASKETS, set of 2:
    $ 62.95
    HCP25160 Aftermarket crankshaft end cover-to-block rubber RING GASKET, fits all 1986-88 FZ600, 1986-90 YX600 Radian, all XJ700, XJ750-X, 1984-85 FJ1100, and 1986-93 FJ1200 models. Right and left side are the same. Each:
    $ 19.95
    HCP25160SET2 Aftermarket crankshaft end cover-to-block RING GASKETS, set of 2:
    $ 37.95
    HCP5795 OEM "YICS" or "DOHC" cover-to-block rubber RING GASKET, fits all XJ750 Midnight Maxim, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Right and left side are the same. Each:
    $ 49.95
    HCP1001 OEM "YICS" cover-to-block standard duty paper GASKET, fits all XJ1100 and XS1100 models. Used on the left side only. Each:
    $ 29.95
    HCP18439 Aftermarket "YICS" cover-to-block hi-performance GASKET, fits all XJ1100 and XS1100 models. Used on the left side only. Each:
    $ 22.95
    TCI UNITS:
    Yamaha (thankfully!) used a TCI (which stands for Transistor Controlled Ignition) system on all XJ-series bikes to control the coils, timing, spark advance, etc. A TCI unit is an "early" version of the now-common electronic control systems that are used on virtually all modern vehicles of almost every type, and even these early versions are completely maintenance-free and very rarely cause problems...........which is a good thing, because original TCI boxes are no longer available new.
    When engine performance problems develops, many people immediately suspect that the cause may be within the "black box" workings of their TCI unit, which is unlikely. The factory service manual gives "instructions" for diagnosing TCI problems, and it basically says "test every other possible cause for your problem and if no other cause for the problem exists, only then should you "suspect" TCI failure, but before you buy a replacement, first try to find a known, working TCI unit from a similar bike and plug it in on the problem bike, and see if the problem goes away............"
    Well!
    There are four main problems that TCI units succumb to after years of reliable service:
    1) bad solder joints on some of the internal components (known as "cold solder joints") result in the component pieces coming loose from the circuit board, and thus they can no longer perform their function reliably (or at all).
    2) component failure......a blown-up transistor, a burned circuit trace, etc. This situation can develop if you have a short-circuit in your electrical system, or hook up your battery or jumper cables incorrectly, etc. TCI units do not like "big blue sparks" in the electrical system (except at the spark plugs, of course!).
    3) another common failure of these units occurs if the TCI is continuously grounding the ignition coil (i.e. its output driver is shorted). You can verify this situation with an ohmmeter with the following tests:
    - disconnect the 2-pin plug at the ignition coil and measure from the orange or grey wire to the chassis. You should see very high resistance. This should be pretty close on both the working and non-working channels.
    - if you read a few ohms of resistance or less, then the TCI is bad. A shorted driver will also make the ignition coil run very hot and may ruin the coil.
    4) dirty terminal connections.....clean them with electrical contact cleaner and/or miniature wire brushes or files. NOTE: sometimes the mere act of unplugging and plugging back in the connectors to the TCI unit can resolve a “dirty connectors” issue (at least, temporarily)
    Bad solder joints can be repaired by someone who is skilled at that sort of diagnosis and repair, and even individual circuit components can be replaced, but it's tough to find someone in the modern world of "pitch-and-plug" skill-sets who actually has the skill and patience to do this type of work. Yamaha gave absolutely "zero" electrical specifications for checking the condition of the TCI units, besides the afore-mentioned "check everything else first" type of diagnosis.
    But you can perform a simple set of tests to determine whether your TCI unit is good or not, without having a second, known good unit to install in place of the suspect unit. Although these instructions were written for XS owners, the exact same thoughts apply to the TCI units on the XJ-series of bikes:
    Whoops! Unfortunately the link to that page is dead, but here are the written instructions. It does require an analog meter, as digital multi-meters do not show the swing of the needle that is required to test it.
    "Using a voltmeter set on 12VDC, connect the positive meter lead to the Orange or the Grey pick-up coil lead at the TCI. Connect the negative meter lead to the black (negative) lead at the TCI. Turn on the ignition. Voltage should come right up to about 10 - 11VDC. Crank the ignition and observe the meter. Look for a wide voltage swing during cranking. A strong swing indicates that the pickups and TCI are working OK and your trouble is between the TCI and the plugs. Possibly a bad ballast resistor (XS1100 models only) , bad coil, bad plug cap or just corroded connections. Repeat this test for both Orange and Grey coil leads."
    Remember that the Red wire with the white tracer stripe should always be hot with the key on. The TCI unit grounds the gray and orange wires from the ignition coils. The ignition coils fire when the TCI interrupts the ground.
    The tricky part is the TCI un-grounds the gray and orange if there is no signal from the pick-up coils for a few seconds. This is to protect the coils from overheating if the key is on and the engine isn't running. So unless you check the Red/white wire to gray (or orange) really quickly, you might get false readings or a mis-diagnosis of the true nature of the problem.
    All of the XJ-series TCI units are of the "4R0" style as described in the above article.
    And if the above isn't enough, if you feel the need to get medieval with your TCI unit, well, then it doesn't get much better than this:
    http://www.jetav8r.com/Vision/IgnitionFAQ.html
    and this:
    http://xjbikes.com/forums/threads/old-yamaha-diodes.32519
    And for those who just can't resist a good Resistor (or transistor), here you go:
    http://xjbikes.com/forums/index.php?threads/37190
    and Holy Dark Mother of Fibre, don't try this at home kids!:
    http://xjbikes.com/forums/index.php?threads/38234
    One of the peculiarities of the TCI is the need to have at least one ground path for each secondary coil winding when checking for spark, or the TCI could (more like will) be damaged. For that reason you should never have more than one spark plug wire disconnected at any one time while cranking, and check for spark one plug at a time by grounding the plug to the head.
    In a situation where you would want all plugs out…….for example, compression testing of the engine……then it is recommended that the TCI be unplugged from the main harness before testing is undertaken.
    By the way, the TCI needs a minimum of about 10VDC to operate......and while the starter will spin the engine over like mad with low voltage, the TCI falls on its face at less than 10 volts.....which can lead to all sorts of confusion when a battery low-voltage condition occurs!
    TCI Case Hardware:
    Some TCI units have removable case covers to allow internal inspection of the circuit board. Over time these screws can get pretty foul-looking; if you want to restore the appearance of your unit, these (along with the replacement decal) will give your old unit and nice, "like-new" appearance. NOTE: not all TCI units had removable faceplates; it seems that sometime in the mid-80's, TCI units were produced with electronically welded cases, and not dis-assembly is possible (or at least "easy").
    HCP6111 OEM tci case self-tapping SCREW. Used to hold the TCI case cover to the main body of the case. Use 4 per TCI on all XJ550, FJ600, XJ650RJ Seca, XJ750, and XJ900 models. These screws have a black finish as original. Each:
    $ 4.95
    HCP6111SET4 OEM tci case self-tapping SCREWS, set of 4:
    $ 18.95
    HCP28331 Aftermarket tci case self-tapping SCREW. Used to hold the TCI case cover to the main body of the case. Use 4 per TCI on all XJ550, FJ600, XJ650RJ Seca, XJ750, and XJ900 models. These screws are made from 18-8 stainless steel and have a bright finish. Each:
    $ 2.95
    HCP28331SET4 OEM tci case self-tapping SCREWS, set of 4:
    $ 9.95
    HCP28329 Aftermarket tci case self-tapping SCREW. Used to hold the TCI case cover to the main body of the case. Use 4 per TCI on all 1980-81 XJ650 Maxim and Midnight Maxim models (with the black label that reads 4H7-10, Type TID14-02). These screws are made from 4140 stainless steel and have a bright finish. Each:
    $ 3.95
    HCP28329SET4 OEM tci case self-tapping SCREWS, set of 4:
    $ 14.95
    HCP28327 Aftermarket tci case self-tapping SCREW. Used to hold the TCI case cover to the main body of the case. Use 4 per TCI on all XJ650 Turbo models. These screws are made from 410 stainless steel and have a bright finish. Each:
    $ 3.95
    HCP28327SET4 OEM tci case self-tapping SCREWS, set of 4:
    $ 14.95
    HCP6113 OEM tci case self-tapping SCREW. Used to hold the TCI case cover to the main body of the case. Use 6 per TCI on all XJ1100 models. These screws have a bright finish as original. Each:
    $ 4.95
    HCP6113SET6 OEM tci case self-tapping SCREWS, set of 6:
    $ 27.95
    HCP28333 Aftermarket tci case self-tapping SCREW. Used to hold the TCI case cover to the main body of the case. Use 6 per TCI on all XJ1100 models. These screws have a bright finish as original. Each:
    $ 1.95
    HCP28333SET2 Aftermarket tci gauge cluster housing self-tapping SCREWS, set of 2:
    $ 2.95
    TCI Mounting Hardware:
    er5) All of the little SCREWS, WASHERS, & NUTS needed to properly mount the TCI units to their foundation.
    HCP314 OEM TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. Zinc-plated alloy steel, panhead, phillips-drive Each:
    $ 3.95
    HCP5335 OEM TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. Black alloy steel, panhead, phillips-drive. Each:
    $ 8.95
    HCP915 Aftermarket TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. Zinc-plated alloy steel, panhead, phillips-drive Each:
    $ 1.95
    HCP316 Aftermarket TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. 18-8 stainless steel, panhead, phillips-drive. Each:
    $ 2.95
    HCP317 Aftermarket TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. 18-8 stainless steel with a polished button head, hex-drive. Each:
    $ 2.95
    HCP318 Aftermarket TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. 18-8 stainless steel with a smooth, polished socket head, hex-drive. Each:
    $ 2.95
    HCP320 Aftermarket TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ550 and FJ600 models. Black-oxide coated alloy steel with a ribbed socket head. Each:
    $ 1.95
    HCP1030 OEM TCI - Igniter Unit mounting SCREW, dark finish alloy steel, panhead, phillips drive. Use 2 per unit. For all XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 7.95
    HCP2922 Aftermarket TCI - Igniter Unit mounting SCREW, use 2 per unit. For all XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. Zinc-plated alloy steel, natural finish, panhead phillips-drive, each:
    $ 2.95
    HCP21362 Aftermarket TCI - Igniter Unit mounting SCREW, use 2 per unit. For all XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. 18/8 stainless steel, bright finish, panhead phillips-drive, each:
    $ 3.95
    HCP6714 Aftermarket TCI - Igniter Unit mounting SCREW, use 2 per unit. For all XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. Button head hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP6715 Aftermarket TCI - Igniter Unit mounting SCREW, use 2 per unit. For all XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. Socket head, hex-drive, black-oxide coated alloy steel, each:
    $ 2.95
    HCP6716 Aftermarket TCI - Igniter Unit mounting SCREW, use 2 per unit. For all XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. Socket head, hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP3860 OEM TCI - Igniter Unit mounting SCREW, user 2 per unit. For all XJ1100 models. Each:
    $ 1.50
    HCP315 OEM TCI - Igniter mounting LOCK WASHER, use 2 per unit. Fits all FJ600, XJ650, XJ750, XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, TCI - Igniter mounting LOCK WASHER, use 2 per unit. Fits all XJ650, XJ750, XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel TCI - Igniter mounting LOCK WASHER, use 2 per unit. Fits all XJ650, XJ750, XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel TCI - Igniter mounting LOCK WASHER, use 2 per unit. Fits all XJ650, XJ750, XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    HCP2173 OEM TCI - Igniter mounting FLAT WASHER, use 2 per unit. Fits all XJ550, FJ600, XJ650 except 1983 XJ650 Turbo, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket TCI - Igniter mounting FLAT WASHER, zinc-plated alloy steel with a natural finish, use 2 per unit. Fits all XJ550, FJ600, XJ650 except 1983 XJ650 Turbo, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 1.95
    HCP6643 Aftermarket TCI - Igniter mounting FLAT WASHER, 18-8 stainless steel with a natural finish, use 2 per unit. Fits all XJ550, FJ600, XJ650 except 1983 XJ650 Turbo, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 2.95
    HCP25756 Aftermarket TCI - Igniter mounting FLAT WASHER, 316 stainless steel with a natural finish, use 2 per unit. Fits all XJ550, FJ600, XJ650 except 1983 XJ650 Turbo, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 3.95
    HCP14285 Aftermarket TCI - Igniter mounting FLAT WASHER, black oxide-coated 18-8 stainless steel, use 2 per unit. Fits all XJ550, FJ600, XJ650 except 1983 XJ650 Turbo, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 2.95
    HCP14284 Aftermarket TCI - Igniter mounting FLAT WASHER, black oxide-coated hardened alloy steel, use 2 per unit. Fits all XJ550, FJ600, XJ650 except 1983 XJ650 Turbo, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 2.95
    HCP4248 OEM TCI - Igniter mounting FLAT WASHER, bright zinc-plated alloy steel, use 2 per unit. Fits all 1983 XJ650 Turbo models. Each:
    $ 3.95
    HCP25871 Aftermarket TCI - Igniter mounting FLAT WASHER, bright zinc-plated alloy steel, use 2 per unit. Fits all 1983 XJ650 Turbo models. Each:
    $ 1.95
    HCP1903 OEM TCI - Igniter mounting FLAT WASHER, black oxide-coated alloy steel, use 2 per unit. Fits all XJ1100 models, front side of the TCI. Each:
    $ 3.95
    HCP25872 Aftermarket TCI - Igniter mounting FLAT WASHER, bright zinc-plated alloy steel, use 2 per unit. Fits all XJ1100 models, front side of the TCI. Each:
    $ 1.25
    HCP25873 Aftermarket TCI - Igniter mounting FLAT WASHER, bright 18/8 stainless steel, use 2 per unit. Fits all XJ1100 models, front side of the TCI. Each:
    $ 1.75
    HCP25875 Aftermarket TCI - Igniter mounting FLAT WASHER, black oxide-coated 18/8 stainless steel, use 2 per unit. Fits all XJ1100 models, front side of the TCI. Each:
    $ 1.95
    HCP25874 Aftermarket TCI - Igniter mounting FLAT WASHER, bright 316 stainless steel, use 2 per unit. Fits all XJ1100 models, front side of the TCI. Each:
    $ 2.95
    HCP3575 OEM ignition TCI - Igniter box mounting FLAT WASHER, use 2 per unit. Fits all XJ1100 models, rear side of the TCI. Each:
    $ 6.95
    HCP6642 Aftermarket ignition TCI - Igniter box mounting FLAT WASHER, zinc-plated alloy steel with a bright finish, use 2 per unit. Fits all XJ1100 models, rear side of the TCI. Each:
    $ 1.95
    HCP6643 Aftermarket ignition TCI - Igniter box mounting FLAT WASHER, 18-8 stainless steel with a bright finish, use 2 per unit. Fits all XJ1100 models, rear side of the TCI. Each:
    $ 2.95
    HCP25756 Aftermarket ignition TCI - Igniter box mounting FLAT WASHER, 316 stainless steel with a dull finish, use 2 per unit. Fits all XJ1100 models, rear side of the TCI. Each:
    $ 3.95
    HCP14285 Aftermarket ignition TCI - Igniter box mounting FLAT WASHER, black oxide-coated 18-8 stainless steel, use 2 per unit. Fits all XJ1100 models, rear side of the TCI. Each:
    $ 2.95
    HCP14284 Aftermarket ignition TCI - Igniter box mounting FLAT WASHER, black oxide-coated hardened alloy steel, use 2 per unit. Fits all XJ1100 models, rear side of the TCI. Each:
    $ 2.95
    HCP3996 OEM TCI - Igniter mounting NUT, alloy steel with a bright zinc-plated finish. Use 2 per unit. Fits all XJ650 (except Turbo) models, all XJ700 models, and all XJ750 models. Each:
    $ 8.95
    HCP16570 Aftermarket TCI - Igniter mounting NUT, 18/8 stainless steel with a bright zinc-plated finish. Use 2 per unit. Fits all XJ650 (except Turbo) models, all XJ700 models, and all XJ750 models. Each:
    $ 2.95
    HCP4247 OEM TCI - Igniter mounting NUT PLATE, use 2 per unit. Fits all XJ550, XJ650 Turbo, and all XJ900RK, RL, N/FN, and F models. Each:
    $ discontinued
    TCI (Igniter) Case ID Decals:
    HCP8107 Aftermarket TCI case ID DECAL, blue foil decal with TID14-05, 4U8-10 wording. Used on all XJ550 model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8108 Aftermarket TCI case ID DECAL, black foil decal with TID14-02, 4H7-10 wording. Used on all 1980-81 XJ650 Maxim and Midnight Maxim model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8109 Aftermarket TCI case ID DECAL, green foil decal with TID14-08, 5V2-10 wording. Used on all 1982 XJ650RJ Seca model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8111 Aftermarket TCI case ID DECAL, black foil decal with TID14-13, 16G-10 wording. Used on all 1982-83 XJ650 Turbo model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8110 Aftermarket TCI case ID DECAL, red foil decal with TID14-06, 5G2-10 wording. Used on all 1982-83 XJ650 Maxim and 1981-83 XJ750 models TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8112 Aftermarket TCI case ID DECAL, red foil decal with TID14-44, 1FG-10 wording. Used on all 1985-86 XJ700 air-cooled model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8113 Aftermarket TCI case ID DECAL, yellow foil decal with TID14-35, 1AA-10 wording. Used on all 1985-86 XJ700-X water-cooled model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8114 Aftermarket TCI case ID DECAL, black foil decal with TID14-19, 31A-10 wording. Used on all 1983-84 XJ900RK and RL model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
    HCP8115 Aftermarket TCI case ID DECAL, black foil decal with TID14-10, 10M-10 wording. Used on all 1982-84 XJ1100 Maxim and Midnight Maxim model TCI (igniter) boxes. NOTE: the silver "date code" box is left blank/unstamped.
    $ 12.95
  12. chacal
    IGNITION COILS AND RELATED:
    OEM and aftermarket IGNITION COILS replace damaged, cracked, or out-of-spec originals to help "light that XJ fire" under your...well, you know. Twenty-plus year old original coils can suffer from a variety of ailments that prevent them from doing their job, including burned or shorted internal windings, hairline cracks in the outer cases, or damaged and destroyed plug wire leads.
    NOTE: although all of the following is repeated below under the spark plug Caps section, it would be good to review it here, also. ALWAYS TEST YOUR COILS (as described below) BEFORE ASSUMING THEY ARE THE PROBLEM. AND ALWAYS TEST YOUR COILS IF YOU ARE HAVING MIS-FIRING, FOULED PLUGS, OR OTHER (POSSIBLY) IGNITION-RELATED ENGINE PERFORMANCE PROBLEMS.
    This will save you an incredible amount of time, effort, and $$$ and give you more quality riding time as opposed to a greater quantity of diagnostic time!
    And a final note: using hi-performance, aftermarket coils (like Dyna or Accel brand) will generally NOT "improve the performance" of your bike in any measurable, meaningful way if your factory coils are performing okay. But if your factory system (coils, plug wires, and plug caps) are not up to snuff, then certainly ANY replacement (stock or aftermarket) coils are going to eliminate such problems and "improve performance". Be aware, though, that aftermarket coils can take quite a bit of mounting bracket fabrication efforts to make them fit properly into these cramped XJ frames, and you will have to purchase the plug wires, boots, and caps separately also.
    Checking Factory Coils:
    Factory Yamaha coils need to "see" a total load resistance on the secondary side (the "going-to-the-plugs" side of the coil) of around 20-30K ohms (ohms being a measure of electrical resistance). Electrical resistance depends on a number of factors: wire size, type of material, length of material, ambient temperature, etc. etc. All readings are specified at 70-F.
    In any case, all factory XJ coils and wires combined---BUT WITHOUT THE CAPS OR PLUGS ATTACHED---have the following primary and secondary resistance ranges.
    Forget watching any other video on u-tube, etc. about how to test dual-lead ignition coils; this is the only one that shows how to properly test both the primary circuit (from the wire harness) and the secondary circuit (the "plug wires" side of the coil).......with the spark plug caps removed. You can ignore the actual readings that he is showing....the specs for XJ bikes are shown below.....but the method that he shows for testing the secondary circuit is the correct procedure:
    www.youtube.com/watch?v=I0TKybs6Rnw
    (skip to 3:55 for the dual-lead coil)
    or you can read all about it here:
    www.xjbikes.com/forums/threads/how-to-test-ignition-coils-and-plug-caps.130696
    For all XJ models except XJ700, XJ750-X, and XJ900 models:
    Primary (input from TCI): 2.5 ohms +/- 10%
    Secondary (output to spark plugs): 11K ohms +/- 20%
    For all XJ700 and XJ750-X models:
    Primary (input from TCI): 2.7 ohms +/- 10%
    Secondary (output to spark plugs): 12K ohms +/- 20%
    For all XJ900RK, RL, N, FN, and F models:
    Secondary (output to spark plugs): 13.2K ohms +/- 20%
    For all XS1100 models:
    Primary (input from TCI): 1.5 ohms +/- 10%
    = 1.35 ohms -1.85 ohms acceptable range
    Secondary (output to spark plugs): 15K ohms +/- 20%
    All models:
    Voltage at coil positive input terminal (the red wire with the white tracer stripe) with the engine running: 12+V This measurement should be taken at the back of the connector shell (stick the volt meter probe in thru the back of the connector) and the battery negative terminal. Compare this reading with the measured battery voltage (voltmeter connected between the battery negative and the battery positive terminals). Any significant difference or lack of voltage indicates corroded or broken connections in-between the fusebox and the ignition coils, and reduced voltage at the coil input will result in reduced coil output (at the spark plugs). Although reduced voltage input (and thus less coil output voltage) may not significantly affect engine performance once the engine is warmed up, it can and will result in "hard start" situations when the engine is cold and/or when the choke system is engaged (since richer fuel mixtures require a much stronger spark to create ignition of the fuel mixture).
    In order to help diagnosing engine performance problems that seem to be "plug-related", always measure the resistance of your coils, both primary and secondary sides, as well as the voltage at the coil input (primary) "hot lead" (the red/white stripe wire) before you start replacing parts. 20+ year old coils can and do fail regularly. If you need to replace your coils, and decide to buy used, original coils "sight unseen", always make sure that the seller checks them for you before you buy them!
    MANY 25+ YEAR OLD COILS ARE NOW OUT OF ELECTRICAL SPEC---so "buyer-beware" is the name of the game. And also note: most analog ("swinging needle") ohm meters require that the needle be "zeroed" manually before you check ohms each and every time! Digital ohm meters are usually self-zeroing.
    Factory coils can also suffer from tiny hairline cracks in their outer plastic housings, leading to electrical shorts which might only show up when the coils get hot, or when the ambient air has quite a bit of moisture (humidity) in it. Running your bike at night, with the tank off, in a VERY dark area will allow you to visually see if there are any tiny blue sparks occurring around the coils or lead wires, in which case the coils are in need of replacement.
    The spark plug WIRES on factory coils are sorta non-replaceable, at least not without a bit of precision surgery:
    http://xjbikes.com/forums/index.php?threads/11221
    Suffice it to say that if your coils measure out of specs for resistance (as described above), they're junk and should be replaced, either with another factory coil or a pair of the various aftermarket coils that are on the market (Dyna and Accel coils work, but are a challenge to mount correctly in these tight XJ frames). We do offer an NGK plug wire in-line splicer (HCP2789 listed further below) that will allow you to cut off and remove a bad factory wire and replace it with a length of aftermarket plug wire. Aftermarket 7mm stranded copper core plug wire is a good choice to use when replacing factory coil wires, as copper wire (in the lengths that are used on bikes) basically offer an amount of electrical resistance equal to zero, just like the stranded stainless steel core plug wires used originally.
    NOTE:
    * on the primary side of the coils, the proper colored leads from the TCI must be hooked up to the proper coil......see below. However, it does not matter which of these two wires go to either position on the coils.
    - the ignition coil for the #1/#4 spark plugs is mounted on the left side of the bike, and has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
    - the ignition coil for the #2/#3 spark plugs is mounted on the right side of the bike, and has the solid grey (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
    - thus, for the #1/#4 coil, you must use the wiring lead from the main harness (TCI) that has the has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wires, as these wires carry the timing trigger pulse to fire the #1/#4 plugs. However, it does not matter whether the orange wire is installed to the top input terminal of the #1/#4 coil, or to its bottom input terminal. In other words, there is no "polarity" to a coil's primary circuit.
    - also, on the secondary (output, spark plug lead wires) it also does not matter which plug wire goes to which cylinder (because they actually both fire at the same time). Thus, for the #1/#4 coil, you can hook either plug wire lead to the #1 or the #4 cylinder.
    Warning about coils and spark plug "testing":
    From one of the true technical experts, Dwayne Verhey:
    "Avoid disconnecting just one spark plug and cranking the engine, as this procedure can create permanent damage to a coil, as this procedure create a very high resistance in the entire secondary circuit of a coil. Voltage will rise inside the coil without a path for escape. Eventually it rises high enough to exceed the break-down voltage of the insulation within the coil, and then current will flow via this newly created path. In the process, it creates a "channel" or weak point through which the insulation value is reduced. Every time this occurs, the insulation value at that point is further reduced, until it drops to the air gap value of the distance between the two internal conductors.
    So long as this internal resistance is greater than the resistance of the spark plug gap, the coil will continue to function when the spark plug is reconnected. Bear in mind that the resistance of the spark plug gap increases when the gap is subjected to compression -- known as "spark quench" -- so the plug may still demonstrate a spark outside of the engine, but not inside, leaving one with the mistaken impression that the coil is fully functional. If the internal damage is severe enough of course, then we say the coil has failed and search for a replacement.
    The truth is that the coil didn't fail, it was destroyed by cranking or running the bike with one plug disconnected.
    Additionally, one of the peculiarities of the TCI is the need to have at least one ground path for each secondary coil winding when checking for spark, or the TCI could (more like will) be damaged. For that reason you should never have more than one spark plug wire disconnected at any one time while cranking, and check for spark one plug at a time by grounding the plug to the head.
    Fouled plugs are a different matter. Why do fouled plugs fail to spark? Because the carbon build-up on the plug electrodes is a conductor and the thus short-circuits the spark plug gap. Same with flooded plugs. Gasoline is also a conductor. So in these situation, we have not increased the resistance, we have actually lowered it, and therefore there is no great voltage build-up inside the coil to cause damage."
    An exceptional write-up in regards to the entire ignition system can be reviewed at:
    http://www.xjbikes.com/forums/index.php?threads/how-to-ignition-troubleshooting.21932
    ic2) OEM and aftermarket STANDARD-OUTPUT IGNITION COILS. NOTE: original coils were either for the #1/#4 cylinders or the #2/#3 cylinders, and differed ONLY in the length of the spark plug wire leads on each coil (the #2/#3 coil used slightly shorter length plug wires). The current replacement OEM coils have the same length plug wire leads for both cylinders, but fit and work just like originals. The coil for the #1/4 spark plugs is mounted on the left side of the bike and has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it, and the coil for the #2/3 spark plugs is mounted on the right side of the bike and has the solid grey (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
    XJ550 and 1986-90 YX600 models:
    Coils without plug caps:
    HCP420 OEM factory IGNITION COIL, fires either the #1/#4 or the #2/#3 cylinders. Fits all XJ550, 1986-90 YX600 Radian, all XJ650, XJ750 air-cooled models, XJ900RK, RL, N/FN, and F models, XJ1100, and all 1981 XS1100 models. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the left side #1/#4 coil had longer wires) and the color of the wire on the primary input. These HCP420 original coils are now only available in the "longer wire" version, and will work as either a #1/#4 coil or a #2/#3 coil. The coil bodies are a bit shorter than the originals, but the mounting points are the same, making them a bolt-on replacement. Electrical specs are as follows: 3.0 ohms on the primary side, and approximately 12.8K ohms on the secondary side. NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Primary wire colors are solid orange and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Secondary (plug) wires are 7mm diameter, black. Use 2 coils per bike. Each:
    $ 259.95
    HCP420SET2 OEM factory IGNITION COILS set of 2.
    $ 469.95
    HCP26825 Aftermarket IGNITION COIL fits both the #1/#4 and #2/#3 cylinders. Fits all XJ550, 1986-90 YX600 Radian, XJ650, XJ750 air-cooled models, XJ900RK, RL, N/FN, and F models, XJ1100, and all 1981 XS1100 models. Correct fitment as the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid gray and red/white tracer, which is correct for the #2/3 coil (right side), but of course makes no difference in actual use or installation. Use 2 coils per bike. Each:
    $ 69.95
    HCP26825SET2 Aftermarket IGNITION COILS set of 2.
    $ 119.95
    HCP28641BLK Aftermarket IGNITION COILS SET. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28641BLU Aftermarket IGNITION COILS SET. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28641YLW Aftermarket IGNITION COILS SET. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28641RED Aftermarket IGNITION COILS SET. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    Coil sets with plug caps:
    HCP27692 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all XJ550 all models and 1986-90 YX600 Radian models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included, as well as a set of 4 spark plug threaded terminal “stud nuts” (our part number HCP13518). These stud nuts are needed on most spark plugs used on these models to adapt correctly to the 10K ohm plug caps included with this set (if your spark plugs already have the smooth, hourglass-shaped stud nuts installed, then the included studs nuts can be saved as extras). Electrical specs are as follows: 3.0 ohms on the primary side, and approximately 12.8K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Primary wire colors are solid orange and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ 489.95
    HCP27675 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all XJ550 all models and 1986-90 YX600 Radian models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included, as well as a set of 4 spark plug threaded terminal “stud nuts” (our part number HCP13518). These stud nuts are needed on most spark plugs used on these models to adapt correctly to the 10K ohm plug caps included with this set (if your spark plugs already have the smooth, hourglass-shaped stud nuts installed, then the included studs nuts can be saved as extras). Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 12K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These aftermarket coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Primary wire colors are solid gray and red/white tracer, which is correct for the #2/3 coil (right side), but of course makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ 169.95
    HCP28642BLK Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28642BLU Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28642YLW Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28642RED Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ550 and 1986-90 YX600 Radian models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    1984-85 FJ600, 1986-88 FZ600, 1984-85 FJ1100, and 1986-87 FJ1200 models :
    Coil sets without plug caps:
    HCP421 OEM factory IGNITION COIL fits both the #1/#4 and #2/#3 cylinders. Fits all 1984-85 FJ600, 1986-88 FZ600, all XJ700 all models, 1985-86 XJ750-X water-cooled models, 1984-85 FJ1100, and 1986-87 FJ1200 models. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires). These original coils are now only available in the "longer wire" version, and will work as either a #1/#4 coil or a #2/#3 coil. Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 13.3K ohms on the secondary side. NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Primary wire colors are solid gray and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Use 2 coils per bike. Each:
    $ 289.95
    HCP421SET2 OEM factory IGNITION COILS set of 2.
    $ 579.95
    HCP24241SET Aftermarket IGNITION COILS SET fits both the #1/4 and #2/3 cylinders. Fits all 1984-85 FJ600, 1986-88 FZ600, 1984-85 FJ1100, and 1986-87 FJ1200 models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell -----so they are truly plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 15K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Each set has 2 coils, enough for 1 bike.
    $ discontinued
    HCP27690 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1984-85 FJ600 and 1986-88 FZ600 models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included, as well as a set of 4 spark plug threaded terminal “stud nuts” (our part number HCP13518). These stud nuts are needed on most spark plugs used on these models to adapt correctly to the 10K ohm plug caps included with this set (if your spark plugs already have the smooth, hourglass-shaped stud nuts installed, then the included studs nuts can be saved as extras). Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 13.3K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Primary wire colors are solid gray and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ discontinued
    HCP27671 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1984-85 FJ600 and 1986-88 FZ600 models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell -----so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included, as well as a set of 4 spark plug threaded terminal “stud nuts” (our part number HCP13518). These stud nuts are needed on most spark plugs used on these models to adapt correctly to the 10K ohm plug caps included with this set (if your spark plugs already have the smooth, hourglass-shaped stud nuts installed, then the included studs nuts can be saved as extras). Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 15K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Each set has 2 coils, enough for 1 bike.
    $ 189.95
    HCP27691 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1984-85 FJ1100, and 1986-87 FJ1200 models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included, as well as a set of 4 spark plug threaded terminal “stud nuts” (our part number HCP13518). These stud nuts are needed on most spark plugs used on these models to adapt correctly to the 10K ohm plug caps included with this set (if your spark plugs already have the smooth, hourglass-shaped stud nuts installed, then the included studs nuts can be saved as extras). Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 13.3K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Primary wire colors are solid gray and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ discontinued
    HCP27672 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1984-85 FJ1100, and 1986-87 FJ1200 models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell -----so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included, as well as a set of 4 spark plug threaded terminal “stud nuts” (our part number HCP13518). These stud nuts are needed on most spark plugs used on these models to adapt correctly to the 10K ohm plug caps included with this set (if your spark plugs already have the smooth, hourglass-shaped stud nuts installed, then the included studs nuts can be saved as extras). Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 15K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Each set has 2 coils, enough for 1 bike.
    $ 189.95
    1992-98 XJ600 Seca II models :
    HCP22652LH OEM factory IGNITION COIL for the left side (firing the #1 and #4 cylinders. NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 11.6K ohms on the secondary side. Fits all 1992-98 XJ600 Seca II models. Each:
    $ 139.95
    HCP22652RH OEM factory IGNITION COIL for the right side (firing the #2 and #3 cylinders. NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 11.6K ohms on the secondary side. Fits all 1992-98 XJ600 Seca II models. Each:
    $ 139.95
    HCP27702 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1992-98 XJ600 Seca II models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 11.6K ohms on the secondary side. Each set has 2 coils, enough for 1 bike.
    $ 259.95
    air-cooled XJ700 :
    $ 289.95
    $ 579.95
    HCP24270 Aftermarket IGNITION COILS SET fits both the #1/4 and #2/3 cylinders. Fits all XJ700 models and 1985-86 XJ750-X water-cooled models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell -----so they are truly plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 15K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). A set of spacers, new cover screws, and installation instructions are included to make a professional fitment possible. NOTE: the outer chromed-plastic coil covers will need to be slightly modified (on the bottom, where the plug wires exit the cover) to allow plug wire exit from the cover. This simple modification (i.e. a small file or a dremel tool, etc.) will not be outwardly visible once accomplished. NOTE: the spacers, cover screws, and install instructions are not needed for the water-cooled XJ700-X or XJ750-X engines. Each set has 2 coils, enough for 1 bike.
    $ 159.95
    HCP27689 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1985-86 XJ700 air-cooled models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 13.3K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid gray and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ discontinued
    HCP27670 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1985-86 XJ700 air-cooled models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell -----so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 15K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). A set of spacers, new cover screws, and installation instructions are included to make a professional fitment possible. NOTE: the outer chromed-plastic coil covers will need to be slightly modified (on the bottom, where the plug wires exit the cover) to allow plug wire exit from the cover. This simple modification (i.e. a small file or a dremel tool, etc.) will not be outwardly visible once accomplished. Each set has 2 coils, enough for 1 bike.
    $ 189.95
    water-cooled XJ700-X and XJ750-X:
    $ 289.95
    $ 579.95
    HCP24241SET Aftermarket IGNITION COILS SET fits both the #1/4 and #2/3 cylinders. Fits all 1985-86 XJ700-X water-cooled and XJ750-X water-cooled model.. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell -----so they are truly plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.9 ohms on the primary side, and approximately 15K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). NOTE: these coils, due to their design and shape, are a very tight fit into the original coil hanger bracket. These coils must be mounted "sideways" within the coil bracket (as opposed to the stock coils, which are mounted vertically....the "hump" of the coils points to the sky). On these coils, the hump fits horizontally into the bracket. You’ll find it easier to fit them into the coil hanger bracket if the mounting bolt "tubes" on the bracket (both front and rear tubes) are shaved down just a fraction......perhaps 1/16" on each end of each tube.....as this allows the coils to fit more properly into the bracket. Although this modification isn't absolutely necessary, as you are able to shoehorn a set of coils into the bracket (but it takes an extra set of hands). A hand file or a sanding disc (or, even better, a cut-off wheel) on a dremel tool would make quick work of the task of “shortening” the bracket tubes. I realize that all of the above may not make perfect sense to you without having the coils in your hand, but it all becomes immediately obvious as soon as you start the install. Each set has 2 coils, enough for 1 bike.
    $ discontinued
    XJ650, XJ750 air-cooled, and XJ900RK, RL, N/FN, and F models:
    $ 259.95
    $ 459.95
    $ 69.95
    HCP26825SET2 Aftermarket factory IGNITION COILS set of 2.
    $ 119.95
    HCP28644BLK Aftermarket IGNITION COILS SET. Fits all XJ650, all XJ750 air-cooled, all XJ900, XJ1100, and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28644BLU Aftermarket IGNITION COILS SET. Fits all XJ650, all XJ750 air-cooled, all XJ900, XJ1100, and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28644YLW Aftermarket IGNITION COILS SET. Fits all XJ650, all XJ750 air-cooled, all XJ900, XJ1100, and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28644RED Aftermarket IGNITION COILS SET. Fits all XJ650, all XJ750 air-cooled, all XJ900, XJ1100, and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP27693 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all XJ650 models, all XJ750 air-cooled models, and all XJ900RK, RL, F, N, and FN models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Electrical specs are as follows: 3.0 ohms on the primary side, and approximately 12.8K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid orange and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ 439.95
    HCP27676 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all XJ650 models, all XJ750 air-cooled models, and all XJ900RK, RL, F, N, and FN models. Correct profile and fitment as the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 12K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These aftermarket coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid gray and red/white tracer, which is correct for the #2/3 coil (right side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ 159.95
    HCP28645BLK Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ650 models, all XJ750 air-cooled models, and all XJ900 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 169.95
    HCP28645BLU Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ650 models, all XJ750 air-cooled models, and all XJ900 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 169.95
    HCP28645YLW Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ650 models, all XJ750 air-cooled models, and all XJ900 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 169.95
    HCP28645RED Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ650 models, all XJ750 air-cooled models, and all XJ900 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 169.95
    1978-80 XS1100 models:
    HCP27695 OEM factory IGNITION COILS SET, fires either the #1/#4 or the #2/#3 cylinders. Fits all 1978-80 XS1100 models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with bullet terminals ---- so they are truly plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Electrical specs are as follows: 3.0 ohms on the primary side, and approximately 12.8K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the left side #1/#4 coil had longer wires) and the color of the wire on the primary input. These original coils are now only available in the "longer wire" version, and will work as either a #1/#4 coil or a #2/#3 coil. The coil bodies are a bit shorter than the originals, but the mounting points are the same, making them a bolt-on replacement. Primary wire colors are solid orange and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. NOTE: the “ballast resistor” used on these models must be by-passed when using these coils, and instructions on how to do so are included. Also, a set of spacers are included to make a professional fitment possible. Each set has 2 coils, enough for 1 bike.
    $ 489.95
    HCP27032 Aftermarket IGNITION COILS SET fits both the #1/#4 and #2/#3 cylinders. Fits all 1978-80 XS1100 models. Correct profile and fitment as the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with bullet terminals ---- so they are truly plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Electrical specs as follows: 2.5 ohms on the primary side, and approximately 12K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These aftermarket coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid gray and red/white tracer, which is correct for the #2/3 coil (right side), but of course it makes no difference in actual use or installation. NOTE: the “ballast resistor” used on these models must be by-passed when using these coils, and instructions on how to do so are included. Also, a set of spacers are included to make a professional fitment possible. Each set has 2 coils, enough for 1 bike.
    $ 159.95
    HCP28647BLK Aftermarket IGNITION COILS SET. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28647BLU Aftermarket IGNITION COILS SET. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28647YLW Aftermarket IGNITION COILS SET. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP28647RED Aftermarket IGNITION COILS SET. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are not included and your original caps should be re-used or replacement caps ordered. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 139.95
    HCP27697 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1978-80 XS1100 models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Electrical specs are as follows: 3.0 ohms on the primary side, and approximately 12.8K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coil coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid orange and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. NOTE: the “ballast resistor” used on these models must be by-passed when using these coils, and instructions on how to do so are included. Also, a set of spacers are included to make a professional fitment possible. Each set has 2 coils, enough for 1 bike.
    $ 469.95
    HCP27678 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all 1978-80 XS1100 models. Correct profile and fitment as the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with bullet terminals-----so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 12K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These HCP27678 reproduction coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil). Primary wire colors are solid gray and red/white tracer, which is correct for the #2/3 coil (right side), but of course it makes no difference in actual use or installation. Fits all 1978-80 XS1100 models. NOTE: the “ballast resistor” used on these models must be by-passed when using these coils, and instructions on how to do so are included. Also, a set of spacers are included to make a professional fitment possible. Each set has 2 coils, enough for 1 bike.
    $ 169.95
    HCP28648BLK Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28648BLU Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28648YLW Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28648RED Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all 1978-80 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    XJ1100 and 1981 XS1100 models:
    $ 259.95
    $ 479.95
    $ 59.95
    $ 114.95
    $ 139.95
    $ 139.95
    $ 139.95
    $ 139.95
    HCP27694 OEM IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all XJ1100 and 1981 XS1100 models. These factory coils feature black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Electrical specs are as follows: 3.0 ohms on the primary side, and approximately 12.8K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Primary wire colors are solid orange and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ 489.95
    HCP27677 Aftermarket IGNITION COILS SET WITH PLUG CAPS fits both the #1/4 and #2/3 cylinders. Fits all XJ1100 and 1981 XS1100 models. Very similar profile to the original factory coils, complete with black 7mm copper-core plug wires and primary lead-in harness with connector shell ----- so they are truly plug-and-play! NOTE: aftermarket hard plastic resistive plug caps are included. Features the electrical specs as follows: 2.5 ohms on the primary side, and approximately 12K ohms on the secondary side. NOTE: originally, there were two separate coils that differed only in the length of their spark plug lead wires (the #1/#4 coil had longer wires) and the color of the wire on the primary input. These aftermarket coils are the "longer wire" version, and will thus work as either a #1/#4 coil or a #2/#3 coil (plug wires can be trimmed back, if desired, when used as the #2/3 right side coil. Primary wire colors are solid gray and red/white tracer, which is correct for the #1/4 coil (left side), but of course it makes no difference in actual use or installation. Each set has 2 coils, enough for 1 bike.
    $ 169.95
    HCP28649BLK Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ1100 and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable black 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28649BLU Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ1100 and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable blue 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28649YLW Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ1100 and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable yellow 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    HCP28649RED Aftermarket IGNITION COILS SET WITH PLUG CAPS. Fits all XJ1100 and 1981 XS1100 models. These aftermarket coils will perfectly replace the original factory coils, and are complete with replaceable red 8mm copper-core plug wires and primary lead-in harness with connector shell ---- plug-and-play! NOTE: the hard plastic resistive plug CAPS are included. Features the electrical specs as follows: 2.4 ohms on the primary side, and approximately 12K ohms on the secondary side (unlike most of the other aftermarket coils, which are actually designed for Honda or Kawasaki models, and have a much higher primary circuit resistance). NOTE: these coils mount “rotated” compared to original coils, but present no fitment issues. Each set:
    $ 159.95
    1984-85 FJ1100 and 1986-87 FJ1200 models:
    $ 289.95
    $ 579.95
    $ discontinued
    $ 589.95
    $ 189.95
    ic3) Aftermarket HIGH-OUTPUT IGNITION COILS, features a pair of high-output (40kV) replacement coils. With only 3.0 ohms of primary resistance, this means you won't be burning up your TCI box, while their secondary circuit design means you’ll get a much more serious spark than your 30-years-old original stock factory coil could ever hope to produce.
    Both the primary and high-voltage (output) terminals are brass, which means they'll never corrode; and each coil is fully and completely ultrasonically welded shut and encased in a tough thermoplastic shell to prevent any problems with moisture intrusion (a real problem with older factory coils). The output towers accept either 7mm or 8mm wires (please note that wires, output boots, mounting hardware, and spark plug caps are NOT included).
    The complete COIL KITS listed further below use these same high-output coils, and are specifically designed to properly fit your bike without any (or minimal, on some models) cutting, cussing, or modification…..and include all necessary hardware, brackets, and instructions, making them easy to install and ready to deliver their benefits.
    HCP12764 Aftermarket set of Dyna high-output IGNITION COILS, featuring integral input (primary) wire terminals. Does not include any plug wires, wire terminals, or coil mounting brackets. These coils are for use with all XJ550, all XJ700, and all XJ750-X (water-cooled) models. Set of 2 coils:
    $ 209.95
    HCP245 Aftermarket set of Dyna high-output IGNITION COILS, includes input (primary) wire terminals, screws, and nuts. Does not include any plug wires, wire terminals, or coil mounting brackets. These coils are for use with all XJ650, XJ750 air-cooled, XJ900, XJ1100, and all XS1100 models. Set of 2 coils:
    $ 209.95
    HCP20680 Aftermarket Dyna Coils MOUNTING KIT. This complete set of adapter brackets allows you to easily mount the HCP245 Dyna coils into the stock coil mounting forward tube and rear bracket that are welded to your frame. Without this kit, you'll spend a good 4-8 hours (at least) and a few very frustrating trips back-and-forth to the local hardware store to cobble together and fabricate the special brackets and hardware needed to shoe-horn these large Dyna coils into the tight, cramped confines of the frame. For use on all XJ650, all XJ750 air-cooled engines, and XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. Complete set includes 4 adapter brackets and coil-to-bracket hardware. You can re-use your original coil-to-frame hardware, or purchase new replacement hardware below, if desired. The installation procedures for Dyna coils can be reviewed at:
    http://www.xj4ever.com/dyna coils install.pdf
    NOTE: the installation of the Dyna coils requires the removal, on most models (except XJ/XS1100 models), of the flasher relay holder bracket that is tack-welded to the lower right side frame tube and which intrudes into the coil mounting area. The Dyna coils will not clear this bracket, and it must be cut away and ground off flush to the frame tube. A "universal" re-locator bracket is included with this kit which allows the re-positioning of that relay to an area where it fits properly.
    $ 59.95
    XS1100 owners may also need the following items:
    HCP27570 Aftermarket Dyna Coils MOUNTING SPACERS SET. This set of 4 spacers allow for the proper mounting of the Dyna Coils into 1979-80 XS1100 Special and Midnight Special models and should be used in conjunction with the HCP20680 kit above for use on these models. Includes illustrated instructions.
    $ 8.95
    HCP26984 Aftermarket Dyna Coils BALLAST RESISTOR BY-PASS INSTRUCTIONS. Needed for use on all 1978-80 XS1100 models.
    $ no charge when ordered with the HCP20680 or HCP27570 kit.
    HCP19287 Aftermarket Dyna Coils MOUNTING KIT. This complete set of adapter brackets allows you to easily mount the HCP245 Dyna coils into the stock coil mounting bracket. Without this kit, you'll spend a good 4-8 hours (at least) and a few very frustrating trips back-and-forth to the local hardware store to cobble together and fabricate the special brackets and hardware needed to shoe-horn these large Dyna coils into the tight, cramped confines of the original coil bracket. For use on all XJ700-X and XJ750-X models (water-cooled engines) only. Complete set includes 2 hanger brackets, coil mounting hardware, water recovery tank spacers and hardware, and 4 coil wire tower boots and wire-end terminals (plug wires are NOT included). You can cut and re-use your original plug wires, or purchase new replacement wires below (recommended).
    $ 49.95
    HIGH-OUTPUT IGNITION COIL KITS:
    ic33) Aftermarket HIGH-OUTPUT IGNITION COIL KITS includes a pair of high-output replacement coils, mounting hardware, and your choice of pre-made plug wires. Each coil can output up to 40kV of spark energy per cylinder, and the 3.0 ohms of primary resistance for each coil means you won't be burning up your TCI box.
    Both the primary and high-voltage (output) terminals are brass, which means they'll never corrode; no exposed laminations to rust or degrade over time; and each coil is fully and completely ultrasonically welded shut and encased in a tough thermoplastic shell to prevent any problems with moisture intrusion (a real problem with older factory coils).
    These kits are specifically designed to properly fit your bike without any cutting, cussing, or modification …..making them easy to install and ready to deliver their benefits.
    all XJ550 and YX600 Radian models:
    The following HIGH-OUTPUT IGNITION COIL KITS are designed to fit all XJ550 and YX600 Radian models without any frame modifications or cutting. Each kit features a pair of high-output coils sets, including the specially designed coil mounting brackets, illustrated instructions, and your choice of plug wire style and color, making these kits the finest bolt-on coil sets available.
    Coil Kits with bare plug wire ends (for use with stock type plug caps):
    All of the following kits come with a pair of coils, coil mounting hardware, and your choice of plug wires as outlined below. The front-of-coil rubber mounting dampers (HCP4245) are not included and should be ordered separate if your originals are damaged or missing.
    HCP21720BLK This kit comes complete with black 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included). Fits all XJ550 and YX600 Radian models.
    $ 319.95
    HCP21720BLU This kit comes complete with blue 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included). Fits all XJ550 and YX600 Radian models.
    $ 329.95
    HCP21720RED This kit comes complete with red 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included). Fits all XJ550 and YX600 Radian models.
    $ 329.95
    HCP21720YLW This kit comes complete with yellow 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included). Fits all XJ550 and YX600 Radian models.
    $ 329.95
    Coil Kits with non-resistive plug boots included:
    All of the following kits come with a pair of coils, coil mounting hardware, and your choice of plug wires with rubber, non-resistive plug-end wires as outlined below. In this situation, we suggest you change from your stock non-resistive spark plugs to aftermarket resistive plugs. The front-of-coil rubber mounting dampers (HCP4245) are not included and should be ordered separate if your originals are damaged or missing.
    HCP21721BLK This kit comes complete with black 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs or the HCP1297 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ550 and YX600 Radian models
    $ 329.95
    HCP21721BLU This kit comes complete with blue 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs or the HCP1297 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ550 and YX600 Radian models.
    $ 339.95
    HCP21721RED This kit comes complete with red 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs or the HCP1297 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ550 and YX600 Radian models.
    $ 339.95
    HCP21721YLW This kit comes complete with yellow 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs or the HCP1297 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ550 and YX600 Radian models.
    $ 339.95
    Coil Kits with resistive plug caps included:
    All of the following kits come with a pair of coils, coil mounting hardware, and your choice of plug wires with aftermarket resistive plug caps as outlined below. The front-of-coil rubber mounting dampers (HCP4245) are not included and should be ordered separate if your originals are damaged or missing.
    HCP21722BLK This kit comes complete with black 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1296 standard non-resistive spark plugs, or the HCP1297 hi-performance iridium resistive plugs (spark plugs are not included with the kit). Fits all XJ550 and YX600 Radian models.
    $ 339.95
    HCP21722BLU This kit comes complete with blue 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1296 standard non-resistive spark plugs, or the HCP1297 hi-performance iridium resistive plugs (spark plugs (spark plugs are not included with the kit). Fits all XJ550 and YX600 Radian models.
    $ 349.95
    HCP21722RED This kit comes complete with red 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1296 standard non-resistive spark plugs, or the HCP1297 hi-performance iridium resistive plugs (spark plugs are not included with the kit). Fits all XJ550 and YX600 Radian models.
    $ 349.95
    HCP21722YLW This kit comes complete with yellow 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1296 standard non-resistive spark plugs, or the HCP1297 hi-performance iridium resistive plugs (spark plugs are not included with the kit). Fits all XJ550 and YX600 Radian models.
    $ 349.95
    all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models:
    The following HIGH-OUTPUT IGNITION COIL KITS are designed to fit all XJ650, XJ750 air-cooled models, and all 1983-89 XJ900 models without any frame modification (NOTE: some models will require the flasher relay hanger bracket, which is welded onto the right side frame tube, to be removed and re-located or replaced with the universal relay mounting bracket included). Each kit features a pair of high-output coils sets, including the specially designed coil mounting brackets, illustrated instructions, and your choice of plug wire style and color, making these kits the finest bolt-on coil sets available.
    HCP22084BLK This kit comes complete with black 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 309.95
    HCP22084BLU This kit comes complete with blue 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 319.95
    HCP22084RED This kit comes complete with red 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 319.95
    HCP22084YLW This kit comes complete with yellow 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 319.95
    HCP22085BLK This kit comes complete with black 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (XJ650 and XJ750 models should use the HCP13513 standard resistive plugs or the HCP1293 hi-performance iridium resistive plugs, and XJ900 models should use the HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 319.95
    HCP22085BLU This kit comes complete with blue 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (XJ650 and XJ750 models should use the HCP13513 standard resistive plugs or the HCP1293 hi-performance iridium resistive plugs, and XJ900 models should use the HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 329.95
    HCP22085RED This kit comes complete with red 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (XJ650 and XJ750 models should use the HCP13513 standard resistive plugs or the HCP1293 hi-performance iridium resistive plugs, and XJ900 models should use the HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 329.95
    HCP22085YLW This kit comes complete with yellow 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (XJ650 and XJ750 models should use the HCP13513 standard resistive plugs or the HCP1293 hi-performance iridium resistive plugs, and XJ900 models should use the HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 329.95
    HCP22086BLK This kit comes complete with black 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 329.95
    HCP22086BLU This kit comes complete with blue 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 339.95
    HCP22086RED This kit comes complete with red 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 339.95
    HCP22086YLW This kit comes complete with yellow 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ650, XJ750 air-cooled, and 1983-89 XJ900 models.
    $ 339.95
    all 1978-80 XS1100 models:
    The following HIGH-OUTPUT IGNITION COIL KITS are designed to fit all 1978-80 XS1100 models without any frame modification Each kit features a pair of high-output coils sets, including the specially designed coil mounting brackets, illustrated instructions, and your choice of plug wire style and color, making these kits the finest bolt-on coil sets available.
    NOTE: 1978-80 models used individual “bullet” style electric terminals on the primary (input) wire harness (from the TCI to the coils), and used a ballast resistor within the main wire harness. 1981 XS1100 and all XJ1100 models used a more traditional 2-space white plastic connector shell (populated with flat-blade terminals), and no ballast resistor within the harness. XS1100 owners should verify which style your current system is using (things may have been swapped around by previous owners!) and order the appropriate 1978-80 or 1981 coil kit. If you system still has the ballast resistor, it must be bypassed (instructions are included) for the Dyna coils to perform properly.
    HCP25509BLK This kit comes complete with black 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 309.95
    HCP25509BLU This kit comes complete with blue 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 319.95
    HCP25509RED This kit comes complete with red 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 319.95
    HCP25509YEL This kit comes complete with yellow 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 319.95
    HCP25511BLK This kit comes complete with black 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 329.95
    HCP25511BLU This kit comes complete with blue 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 339.95
    HCP25511RED This kit comes complete with red 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 339.95
    HCP25511YEL This kit comes complete with yellow 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1978-80 XS1100 models.
    $ 339.95
    all 1981 XS1100 and 1982-84 XJ1100 models:
    The following HIGH-OUTPUT IGNITION COIL KITS are designed to fit all 1981 XS1100 and 1982-84 XJ1100 models without any frame modification Each kit features a pair of high-output coils sets, including the specially designed coil mounting brackets, illustrated instructions, and your choice of plug wire style and color, making these kits the finest bolt-on coil sets available.
    NOTE: 1978-80 XS1100 models used individual “bullet” style electric terminals on the primary (input) wire harness (from the TCI to the coils), and used a ballast resistor within the main wire harness. 1981 XS1100 and all XJ1100 models used a more traditional 2-space white plastic connector shell (populated with flat-blade terminals), and no ballast resistor within the harness. XS1100 owners should verify which style your current system is using (things may have been swapped around by previous owners!) and order the appropriate 1978-80 or 1981 coil kit. If you system still has the ballast resistor, it must be bypassed (instructions are included) for the Dyna coils to perform properly.
    HCP27030BLK This kit comes complete with black 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 309.95
    HCP27030BLU This kit comes complete with blue 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 319.95
    HCP27030RED This kit comes complete with red 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 319.95
    HCP27030YEL This kit comes complete with yellow 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 319.95
    HCP27026BLK This kit comes complete with black 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 319.95
    HCP27026BLU This kit comes complete with blue 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 339.95
    HCP27026RED This kit comes complete with red 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 339.95
    HCP27026YEL This kit comes complete with yellow 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the proper (for your engine) non-resistive spark plugs, or the correct hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all 1981 XS1100 and 1982-84 XJ1100 models.
    $ 339.95
    all XJ700 air-cooled models:
    The following HIGH-OUTPUT IGNITION COIL KITS are designed to fit all XJ700 models with the side-mounted coils, and installs without any frame modifications or cutting. Each kit features a pair of high-output coils sets, including the specially designed coil mounting brackets, illustrated instructions, and your choice of plug wire style and color, making these kits the finest bolt-on coil sets available.
    HCP22029BLK This kit comes complete with black 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700 air-cooled models.
    $ 319.95
    HCP22029BLU This kit comes complete with blue 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700 air-cooled models.
    $ 329.95
    HCP22029RED This kit comes complete with red 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700 air-cooled models.
    $ 329.95
    HCP22029YLW This kit comes complete with yellow 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700 air-cooled models.
    $ 329.95
    HCP22030BLK This kit comes complete with black 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ700 air-cooled models.
    $ 329.95
    HCP22030BLU This kit comes complete with blue 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you always use a set of resistive spark plugs (HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ700 air-cooled models.
    $ 339.95
    HCP22030RED This kit comes complete with red 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ700 air-cooled models.
    $ 339.95
    HCP22030YLW This kit comes complete with yellow 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP1295 standard resistive plugs or the HCP13515 hi-performance iridium resistive plugs). Spark plugs are not included with the kit. Fits all XJ700 air-cooled models.
    $ 339.95
    HCP22031BLK This kit comes complete with black 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1294 standard non-resistive spark plugs (1985) or resistive plugs HCP1295 (1986 models), or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ700 air-cooled models.
    $ 339.95
    HCP22031BLU This kit comes complete with blue 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1294 standard non-resistive spark plugs (1985) or resistive plugs HCP1295 (1986 models), or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ700 air-cooled models.
    $ 349.95
    HCP22031RED This kit comes complete with red 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1294 standard non-resistive spark plugs (1985) or resistive plugs HCP1295 (1986 models), or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ700 air-cooled models.
    $ 349.95
    HCP22031YLW This kit comes complete with yellow 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use either the HCP1294 standard non-resistive spark plugs (1985) or resistive plugs HCP1295 (1986 models), or the HCP13515 hi-performance iridium resistive plugs (spark plugs are not included with this kit). Fits all XJ700 air-cooled models.
    $ 349.95
    all XJ700-X water-cooled and XJ750-X water-cooled models:
    The following HIGH-OUTPUT IGNITION COIL KITS are designed to fit all XJ700-X water-cooled and XJ750-X water cooled models using the bracket-mounted coils, and installs without any frame modifications or cutting. Each kit features a pair of high-output coils sets, including the specially designed coil mounting bracket, illustrated instructions, and your choice of plug wire style and color, making these kits the finest bolt-on coil sets available. NOTE: each kit comes with a modified coil hanger bracket, and requires the deposit of a $ 50.00 core charge, which is fully refunded upon the return of your original coil-hanger bracket.
    HCP22032BLK This kit comes complete with black 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    $ 319.95 + $ 50.00 refundable coil bracket deposit
    HCP22032BLU This kit comes complete with blue 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    $ 329.95+ $ 50.00 refundable coil bracket deposit
    HCP22032RED This kit comes complete with red 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    HCP22032YLW This kit comes complete with yellow 8mm plug wires already installed; wires have bare ends for use with stock OEM or replacement style resistive plug caps (plug caps and spark plugs are not included). Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    HCP22033BLK This kit comes complete with black 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    $ 339.95 + $ 50.00 refundable coil bracket deposit
    HCP22033BLU This kit comes complete with blue 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    $ 349.95+ $ 50.00 refundable coil bracket deposit
    HCP22033RED This kit comes complete with red 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    HCP22033YLW This kit comes complete with yellow 8mm plug wires already installed; wires have black non-resistive plug boots installed. Since these plug boots replace the use of the stock resistive plug caps, it is recommended that you also purchase a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    HCP22034BLK This kit comes complete with black 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    $ 359.95+ $ 50.00 refundable coil bracket deposit
    HCP22034BLU This kit comes complete with blue 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    $ 369.95+ $ 50.00 refundable coil bracket deposit
    HCP22034RED This kit comes complete with red 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    HCP22034YLW This kit comes complete with yellow 8mm plug wires already installed; wires have aftermarket resistive plug caps installed. This set-up is the closest equivalent to the factory style set-up, and you should use a set of resistive spark plugs (HCP13514 standard resistive plugs for 1985 models or the HCP1298 standard resistive plugs for 1986 models, or the HCP1297 high-performance iridium plugs for either year models). Spark plugs are not included with the kit. Fits all XJ700-X water-cooled and XJ750-X water-cooled models.
    Stock Coil Mounting Hardware:
    HCP4245 OEM ignition coil front (into frame) RUBBER INSULATOR, this special square, flanged rubber insulator holds the front mounting bar of the original coils to the frame. Use 1 per coil on all XJ550, 1986-90 YX600 Radian, 1986-88 FZ600, 1987 FZ700, 1988 FZ750, 1993-94 GTS1000, 1984-85 FJ1100, and all 1986-87 and 1989-93 FJ1200 models. Each:
    $ 10.95
    HCP22654 OEM ignition coil MOUNTING WASHER, this special u-shaped "double-washer" is used with both the front and rear mounting bolts. Use 2 per coil on all 1992-98 XJ600 Seca II models. Each:
    $ 7.95
    HCP4242 OEM ignition coil rear (into frame tube bracket) MOUNTING BOLT, use one per coil on all XJ550 models. Each:
    $ 7.95
    HCP19943 OEM ignition coil rear (into frame tube bracket) MOUNTING BOLT, use one per coil on all 1984-85 FJ600 models. Each:
    $ 2.50
    HCP22653 OEM ignition coil rear (into frame tube bracket) MOUNTING BOLT, use one per coil on all 1992-98 XJ600 Seca II models. Each:
    $ 4.95
    HCP4241 OEM ignition coil MOUNTING BOLT, use 1 per coil in both the front and rear mounting positions, on all XJ650, XJ750 air-cooled, all XJ900RK, RL, N/FN, and F models, and 1981 XS1100 Standard models. Alloy steel, hex-headed bolt features a black finish. Each:
    $ 6.95
    HCP25471 Aftermarket ignition coil MOUNTING BOLT, use 1 per coil in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and 1981 XS1100 Standard models. Alloy steel, hex-headed bolt features a bright zinc-plated finish. Each:
    $ 1.95
    HCP21647 Aftermarket ignition coil MOUNTING BOLT, use 1 per coil in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and 1981 XS1100 Standard models. Grade 18-8 stainless steel, hex-headed bolt features a bright finish. Each:
    $ 2.95
    HCP25472 Aftermarket ignition coil MOUNTING BOLT, use 1 per coil in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, and 1981 XS1100 Standard models. Grade 316 stainless steel, hex-headed bolt features a bright finish. Each:
    $ 3.95
    HCP4243 OEM ignition coil MOUNTING BOLT, yellow zinc-plated hex-head alloy steel bolt, use 1 per coil in both the front and rear mounting positions, on all XJ1100 and all XS1100 models (except 1981 XS1100 Standard models). Each:
    $ discontinued
    HCP25526 Aftermarket ignition coil MOUNTING BOLT, bright zinc-plated hex-head alloy steel bolt, use 1 per coil in both the front and rear mounting positions, on all XJ1100 and all XS1100 models (except 1981 XS1100 Standard models). Each:
    $ 4.95
    HCP25476 Aftermarket ignition coil MOUNTING BOLT, black oxide coated sockethead (allen key drive) alloy steel bolt, use 1 per coil in both the front and rear mounting positions, on all XJ1100 and all XS1100 models (except 1981 XS1100 Standard models). Each:
    $ 3.95
    HCP3575 OEM ignition coil mounting bolt FLAT WASHER, use 1 per bolt in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Each:
    $ 6.95
    HCP6642 Aftermarket ignition coil mounting bolt FLAT WASHER, zinc-plated alloy steel with a bright finish, use 1 per bolt in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Each:
    $ 1.95
    HCP6643 Aftermarket ignition coil mounting bolt FLAT WASHER, 18-8 stainless steel with a bright finish, use 1 per bolt in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Each:
    $ 2.95
    HCP25756 Aftermarket ignition coil mounting bolt FLAT WASHER, 316 stainless steel with a dull finish, use 1 per bolt in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Each:
    $ 3.95
    HCP14285 Aftermarket ignition coil mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use 1 per bolt in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Each:
    $ 2.95
    HCP14284 Aftermarket ignition coil mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, use 1 per bolt in both the front and rear mounting positions, on all XJ650, XJ700, XJ750, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Each:
    $ 2.95
    HCP2173 OEM ignition coil mounting bolt FLAT WASHER, use 1 per bolt in both the front and rear mounting positions on all 1984-85 FJ600 models, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket ignition coil mounting bolt FLAT WASHER, zinc-plated alloy steel with a natural finish, use 1 per bolt in both the front and rear mounting positions on all 1984-85 FJ600 models, each:
    $ 1.95
    HCP6643 Aftermarket ignition coil mounting bolt FLAT WASHER, 18-8 stainless steel with a natural finish, use 1 per bolt in both the front and rear mounting positions on all 1984-85 FJ600 models, each:
    $ 2.95
    HCP25756 Aftermarket ignition coil mounting bolt FLAT WASHER, 316 stainless steel with a natural finish, use 1 per bolt in both the front and rear mounting positions on all 1984-85 FJ600 models, each:
    $ 3.95
    HCP14285 Aftermarket ignition coil mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use 1 per bolt in both the front and rear mounting positions on all 1984-85 FJ600 models, each:
    $ 2.95
    HCP14284 Aftermarket ignition coil mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, use 1 per bolt in both the front and rear mounting positions on all 1984-85 FJ600 models, each:
    $ 2.95
    HCP315 OEM ignition coil mounting bolt LOCK WASHER, use 1 per bolt in the rear mounting positions on all XJ550 models, and 1 per bolt in both the front and rear mounting positions on XJ1100 and all XS1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, ignition coil mounting bolt LOCK WASHER, use 1 per bolt in the rear mounting positions on all XJ550 models, and 1 per bolt in both the front and rear mounting positions on XJ1100 and all XS1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel ignition coil mounting bolt LOCK WASHER, use 1 per bolt in the rear mounting positions on all XJ550 models, and 1 per bolt in both the front and rear mounting positions on XJ1100 and all XS1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel ignition coil mounting bolt LOCK WASHER, use 1 per bolt in the rear mounting positions on all XJ550 models, and 1 per bolt in both the front and rear mounting positions on XJ1100 and all XS1100 models. Each:
    $ 1.95
    HCP2176 OEM ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all FJ600, XJ650, XJ750, XJ900RK, RL, and N/FN, models, XJ1100, and all XS1100 models. Each:
    $ 4.95
    HCP29085 Aftermarket ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all FJ600, XJ650, XJ750, XJ900RK, RL, and N/FN, models, XJ1100, and all XS1100 models. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP24059 Aftermarket ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all FJ600, XJ650, XJ750, XJ900RK, RL, and N/FN, models, XJ1100, and all XS1100 models. Black-oxide coated stainless steel. Each:
    $ 3.95
    HCP24035 Aftermarket ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all FJ600, XJ650, XJ750, XJ900RK, RL, and N/FN, models, XJ1100, and all XS1100 models. Made from 18/8 stainless steel. Each:
    $ 2.95
    HCP3968 OEM ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all XJ700-X and XJ750-X models. Each:
    $ 12.95
    HCP24059 Aftermarket ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all XJ700-X and XJ750-X models. Black-oxide coated stainless steel. Each:
    $ 3.95
    HCP29085 Aftermarket ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all XJ700-X and XJ750-X models. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP24035 Aftermarket ignition coil mounting bolt NUT, use 1 per bolt in both the front and rear mounting positions, on all XJ700-X and XJ750-X models. Made from 18/8 stainless steel. Each:
    $ 2.95
  13. chacal
    SPARK PLUG WIRES:
    spw2) Aftermarket SPARK PLUG WIRE, BOOTS, TERMINALS, and SHEATHING allow you to replace your old wire on your original coils, or create new wires for use with your replacement Dyna coils.
    Available in a variety of colors, all of our wire is silicone-jacketed, stranded core, non-resistance wire just like the original plug wire....but it's available in a variety of colors and in both the original 7mm size and the more modern 8mm diameter. Note that the larger 8mm wire will fit (tightly!) into the stock plug caps.
    Plug wire is sold in 15" lengths, which is more than enough to any of the four plug wires on all XJ models (whether you are splicing the wires onto an existing wire "stub", or going deep inside the coil). You will need to order 4 lengths to do a complete bike. If you wish to use these wires with aftermarket coils, then you can also choose from our selection of plug wire Terminals and Boots to complete the job.
    Introduction:
    If you've never really fiddled around with spark plug wires before, the terminology and the design of the replacement components can get a bit confusing, especially on these bikes, because what is termed a "coil" in Yamaha-speak is really a Coil Pack, and actually contains a variety of individual pieces all wrapped up together into one happy little black package. When creating your own system from the basic component pieces (as listed below), it really helps if you can visualize the separate, individual components of the system.......so here goes:
    Your stock factory "coils" are really:
    - a COIL,
    - with integrated PLUG WIRES,
    - and where the plug wires enter the coil body, there is a small, tightly-fitting insulating rubber BOOT,
    - and attached to the business end of each plug wire (and what actually fits onto the top of the spark plug) is the resistive PLUG CAP,
    - and unfortunately, many people call these resistive plug caps "BOOTS",
    - which is not really correct, since that object is both an electrically resistive CAP with removable upper and lower, water- and electrical-proofing, protective molded rubber BOOTS,
    On all engines besides the X models, the plug caps do come with small, black rubber insulating "boots", but for all practical purposes, the "cap" and the "boot" appear to be one and the same part (and the cap is the physically and visually larger part). On the water-cooled 700-X and 750-X models, there is no mistaking that there is a black CAP and a huge orange BOOT at the base of the cap.
    Confusion is likely to set in when trying to understand the component parts list below if you are used to visualizing and referring to the original spark plug CAP and it's little water-proofing BOOTS by the single term BOOT, because when you get into the "components" world, the word BOOT means just that, just the "boot", and they are now the large objects that cover and insulate the plug (and the coil output terminals), but there is no CAP involved anymore!
    If you study an original "coil" carefully, you will obviously note the actual coil, and exiting from the coil body thru a tightly fitting black rubber boot (the coil boot) is the spark plug wire, which runs down into the plug cap (thru a small, black rubber insulating boot at the top of the cap), and then at the bottom of the same cap, is another rubber insulating boot.
    Finally, there is one other thing in the component world that you don't have in the "integrated" world, and that is the wire end METAL TERMINALS....which are made from either brass or plated steel. On your original factory coils, there are metal terminals that are fixed into the coil body (internally) and into the top end of the resistive cap. These terminals are either pointed "spears" or "sheetmetal screw" type terminals, and the plug wires are pushed into the spear point (inside the coil body) or screwed onto the screw terminal (inside the resistive cap). In the component world of aftermarket wires, the wire-end terminals are attached to the wires......think of the wire at the end of your toaster at home; at the end of the wire there is a "plug" with two or three metal terminals sticking out of it. The terminals are made onto the end of the wires!. Not so on your original coils!! The wire has no end terminals on it; the wire is pressed onto and into fixed metal terminals inside the coil and the cap.
    If you cut off the plug from the end of your toaster, stripped the wires bare, and forced each wire into the wall sockets by hand.......well, now you have a better understanding of how Yamaha did it!
    The big questions that you'll have to answer when purchasing aftermarket plug wire components are the following:
    a) Will I be using the original or replacement spark plug CAPS at the spark plug end of the wires? If you do use the original or replacement CAPS, then you do NOT need to purchase the spark plug boot or the spark plug boot terminal.
    b) If you will not be using your original or replacement spark plug CAPS, then you will need to purchase replacement spark plug BOOTS and the metal TERMINALS for those boots.
    c) At the coil end of the spark plug wire: if your are still using factory coils, are you going to run the plug wire all the way into the body of the coil (in which case you'll be performing "coil surgery")? If so, then there are no other component parts that you'll need.
    If you don't want to perform surgery, then you will be cutting off the original plug wire after it exits the stock coil body, and then you will have to splice the new plug wire onto this existing "stub" of original wire. In this situation, you will need a way to join the "stub" wire to your new wires, and you'll need the HCP2789 plug wire joiners or "splicers".
    If you are using aftermarket coils (like the HCP245 Dyna coils), then at the coil end of the wire you will need a coil-end metal PLUG WIRE TERMINAL and a black rubber water-proofing BOOT.
    Finally, original plug wires had an external black RUBBER SLEEVE that ran almost the entire length of the plug wire, from where the plug wire enters the coil body, to approximately 2-3" before where the plug wire enters the spark plug cap. This tough, flexible, heat-resistant sheath provided additional protection and security for the plug wire against temperature and wire insulator damage.
    Typical Scenarios:
    When replacing the wires on an original coil, you have two choices of how to proceed:
    a: cut the original plug wire off just before it enters the coil body (leaving a 1" long "stub" to splice onto!), and splice the new wire onto this stud using the HCP2789 plug wire splicers listed further below, or.........
    b: perform coil surgery, which allows you to replace the entire length of the plug wire (the preferred solution), but it's a somewhat tedious process:
    http://xjbikes.com/forums/index.php?threads/11221
    Of course, you should only replace the wires on original ignition coils if the coils are still within electrical resistance specs; otherwise, you're wasting time and money! Please read the section further above on COILS to determine whether your coils are electrically sound, before you even consider replacing the wires.
    For the above reasons, we recommend either the use of the factory-style NGK plug caps, or, if you eliminate the plug caps from your system, then always use resistor plugs!
    It really all comes down to WHERE in the entire wire, cap/boot, or spark plugs will the circuit resistance be created?
    Most modern spark plug WIRE is resistance wire; each foot of wire has about 5,000 ohms of resistance in it because of the type of wire used. All of our wire is non-resistive wire (zero ohms of resistance----as is the original plug wires used on these bikes).
    So the circuit resistance can be either in a spark plug CAP---this is how the original system is configured, and also what the replacement NGK plug caps offer.........or, the resistance can be in the SPARK PLUG itself (non-resistive or resistive plugs).
    Of course, the total circuit resistance can actually be split up between any or all three of those components: the wire, the plug "cap" or "boot" (if it's resistive, it's typically called a "cap"; if it's non-resistive, it's usually called a "boot", but basically they are the same thing), or the spark plug.
    For most many engines, the circuit specification is for 5K total resistance, and it is accomplished via:
    - non-resistive wire
    - a 5K resistive CAP (boot)
    - non-resistive SPARK PLUG
    but you could do this:
    - a non-resistive CAP (boot)
    - a 5K resistive SPARK PLUG
    or this (although we don't offer resistive wire):
    - a 5K resistive wire
    you could actually do it this way, too, if such components were available:
    - a 2K resistive wire
    - a 2K resistive CAP (boot)
    - a 1K resistive SPARK PLUG
    Some of the XJ700-X and XJ750-X models, for instance, use:
    - a 10K resistive CAP (boot)
    for a total circuit resistance of 15K.
    Spark plugs are generally limited to being either non-resistive (zero ohms) or 5K (= 5,000 ohms) of resistance, and plug CAPS (boots) are either 0K, 5K, or 10K.
    One last insight: since the spark plugs are the most commonly replaced item in the entire wire > cap/boot > spark plug run of components, some people prefer to use zero-ohm wire, zero-ohm caps, and 5K plugs---since the plugs have to be replaced periodically anyway, and that way, the resistive level of the system gets automatically "refreshed" periodically also, with every plug change........
    By the way, all of our replacement spark plug resistive caps use the original style internal metal "threaded screw" method of retaining the plug wire to the spark plug cap......you simply "screw" or "spear" the central core of the plug wire onto the screw threads, making a simple yet effective and durable connection (we recommend a small amount of lubricant----our HCP1714 or HCP20861 silicone grease is perfect for this task-----or similar lubricant on the outer wire jacket end to simplify this procedure!).
    When creating or replacing the wires for use with an aftermarket coil, you again have two choices of how to proceed:
    a: buy a set of pre-made plug wires, such as our HCP4014 or HCP4015 sets, listed further below, or.........
    b: roll your own, baby!: buy the wire, and 4 of the coil boots and their metal terminals, and use either your existing plug caps (or OE-style replacement plug caps), or aftermarket plug boots and their terminals (we recommend that you stick with the original OE-style plug caps, for reasons outlined above).
    This illustrated guide can help you understand better what you'll need to do.......the plug wire creation instructions starts on page 15:
    PLUG-AND-PLAY SPARK PLUG WIRE SETS:
    spw32) Aftermarket pre-assembled PLUG-AND-PLAY SPARK PLUG WIRE SETS feature copper-core, non-suppression (0 ohms resistance) high-performance 7mm or 8mm plug wires, and are ready to install on some stock Yamaha coils or most of our aftermarket performance ignition coils. A variety of plug-end wire configurations let you choose what is right for your needs.
    For use with stock Yamaha ignition coils:
    for all 1984-85 FJ600, all XJ700 models, and XJ750-X models using the stock Yamaha ignition coils:
    NOTE: stock coil plug wires are not replaceable on any other model original coils besides these.
    HCP27201BLK Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all 1984-5 FJ600, XJ700 (air-cooled and water-cooled models), and the XJ750-X water-cooled models using the stock Yamaha coils. Both ends of the wires are bare, and ready for installation into the stock Yamaha coils and into stock or aftermarket resistive plugs caps. Resistive caps are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 22.95
    HCP27201YEL Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all 1984-5 FJ600, XJ700 (air-cooled and water-cooled models), and the XJ750-X water-cooled models using the stock Yamaha coils. Both ends of the wires are bare, and ready for installation into the stock Yamaha coils and into stock or aftermarket resistive plugs caps. Resistive caps are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike..
    $ 24.95
    HCP27202BLK Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for 1984-85 FJ600 and 1986-88 FZ600 models using the stock Yamaha coils. Plug-end of the wires have the aftermarket 10K-ohms resistive plug caps already installed, and are ready for installation into the original coil bodies and onto the spark plugs. Spark plugs are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 41.95
    HCP27202YEL Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for 1984-85 FJ600 and 1986-88 FZ600 models using the stock Yamaha coils. Plug-end of the wires have the aftermarket 10K-ohms resistive plug caps already installed, and are ready for installation into the original coil bodies and onto the spark plugs. Spark plugs are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 44.95
    HCP27203BLK Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE CAPS, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for 1985-86 XJ700 air-cooled models using the stock Yamaha coils. Plug-end of the wires have the aftermarket 5K-ohms resistive plug caps already installed, and are ready for installation into the original coil bodies and onto the spark plugs. NOTE: these wires include aftermarket 5K resistive plug caps, which is correct for the 1985-86 XJ700 air-cooled models. The 1986 XJ700 air-cooled models originally also used 5K resistive spark plugs, so for those 1986 models, you should also continue to use resistive spark plugs (HCP1295 standard or HCP13515 Iridium) when using this wire-and-caps set to maintain the 10K (per plug) resistance specifications. Spark plugs are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 49.95
    HCP27203YEL Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE CAPS, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for 1985-86 XJ700 air-cooled models using the stock Yamaha coils. Plug-end of the wires have the aftermarket 5K-ohms resistive plug caps already installed, and are ready for installation into the original coil bodies and onto the spark plugs. NOTE: these wires include aftermarket 5K resistive plug caps, which is correct for the 1985-86 XJ700 air-cooled models. The 1986 XJ700 air-cooled models originally also used 5K resistive spark plugs, so for those 1986 models, you should also continue to use resistive spark plugs (HCP1295 standard or HCP13515 Iridium) when using this wire-and-caps set to maintain the 10K (per plug) resistance specifications. Spark plugs are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 51.95
    HCP27204BLK Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE CAPS, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for 1985-86 XJ700-X and XJ750-X water-cooled models using the stock Yamaha coils. Plug-end of the wires have the aftermarket 5K-ohms resistive plug caps already installed, and are ready for installation into the original coil bodies and onto the spark plugs. The 1985 XJ700-X water-cooled models originally also used 10K resistive caps and non-resistive spark plugs. The 10K caps are not available, so for the 1985 models, you should also use resistive spark plugs (HCP1298 standard or HCP1297 Iridium) when using this wire-and-caps set to maintain the 10K (per plug) resistance specifications. The 1986 XJ700-X and all XJ750-X models originally used 10K caps and 5K resistive spark plugs, and since 10K caps are not available, you will not be able to reach the total 15K resistance per wire/cap/plug as originally used. 1986 owners will have to use the stock 5K resistive spark plugs (HCP1298 standard or HCP1297 Iridium), which will give you 10K resistance per wire/cap/plug (same as on the 1985 models), and this is a suitable solution. Spark plugs are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 47.95
    HCP27204YEL Aftermarket pre-assembled 7mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE CAPS, includes individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for 1985-86 XJ700-X and XJ750-X water-cooled models using the stock Yamaha coils. Plug-end of the wires have the aftermarket 5K-ohms resistive plug caps already installed, and are ready for installation into the original coil bodies and onto the spark plugs. The 1985 XJ700-X water-cooled models originally also used 10K resistive caps and non-resistive spark plugs. The 10K caps are not available, so for the 1985 models, you should also use resistive spark plugs (HCP1298 standard or HCP1297 Iridium) when using this wire-and-caps set to maintain the 10K (per plug) resistance specifications. The 1986 XJ700-X and all XJ750-X models originally used 10K caps and 5K resistive spark plugs, and since 10K caps are not available, you will not be able to reach the total 15K resistance per wire/cap/plug as originally used. 1986 owners will have to use the stock 5K resistive spark plugs (HCP1298 standard or HCP1297 Iridium), which will give you 10K resistance per wire/cap/plug (same as on the 1985 models), and this is a suitable solution. Spark plugs are not included. NOTE: you should retain and re-use the original plug wire outer sleeve from your original plug wires, as it has the molded insulating “boot” that slips over the coil towers where each wire enters the coil body. One set does one bike.
    $ 49.95
    For use with our aftermarket high-performance ignition coils:
    for all XJ550 and YX600 Radian models using our aftermarket performance Dyna Coils :
    HCP21463BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 49.95
    HCP21463BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21463RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21463YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP22453BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 59.95
    HCP22453BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 64.95
    HCP22453RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 64.95
    HCP22453YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ550 and YX600 Radian models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 64.95
    for all XJ650, 1981-84 XJ750, XJ900, and XJ1100 models using the HCP245 aftermarket performance Dyna Coils:
    HCP21465BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 49.95
    HCP21465BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21465RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21465YLW Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP22451BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include the stock style resistive plug caps, you should use the stock non-resistive spark plugs when using this wire set. One set does one bike.
    $ 69.95
    HCP22451BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include the stock style resistive plug caps, you should use the stock non-resistive spark plugs when using this wire set. One set does one bike.
    $ 74.95
    HCP22451RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include the stock style resistive plug caps, you should use the stock non-resistive spark plugs when using this wire set. One set does one bike.
    $ 74.95
    HCP22451YLW Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include the stock style resistive plug caps, you should use the stock non-resistive spark plugs when using this wire set. One set does one bike.
    $ 74.95
    HCP21491BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 59.95
    HCP21491BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 64.95
    HCP21491RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. [/u]NOTE[/u]: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 64.95
    HCP21491YLW Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ650, XJ750, XJ900, and XJ1100 models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 64.95
    for all XJ700 air-cooled models using our aftermarket performance Dyna Coils:
    HCP21463BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 49.95
    HCP21463BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21463RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21463YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP22452BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 59.95
    HCP22452BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 64.95
    HCP22452RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 64.95
    HCP22452YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700 air-cooled models using our performance Dyna Coils. Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto stock or aftermarket resistive plugs caps. One set does one bike.
    $ 64.95
    for all XJ700-X and XJ750-X models using the large HCP245 aftermarket performance Dyna Coils:
    HCP21467BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 49.95
    HCP21467BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21467RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21467YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP22455BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use (or switch to) resistive spark plugs when using this wire set. One set does one bike.
    $ 69.95
    HCP22455BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use (or switch to) resistive spark plugs when using this wire set. One set does one bike.
    $ 74.95
    HCP22455RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use (or switch to) resistive spark plugs when using this wire set. One set does one bike.
    $ 74.95
    HCP22455YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use (or switch to) resistive spark plugs when using this wire set. One set does one bike.
    $ 74.95
    HCP22454BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 74.95
    HCP22454BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 79.95
    HCP22454RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 79.95
    HCP22454YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH NON-RESISTIVE RUBBER BOOTS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the green Dyna Coils (our part number HCP245). Plug-end of wires are terminated with flexible rubber non-resistive boots, and ready for installation onto spark plugs. NOTE: since these wires replace/eliminate the stock style resistive plug caps, you should use resistive spark plugs in place of the original non-resistive spark plugs. One set does one bike.
    $ 79.95
    for all XJ700-X and XJ750-X models using the aftermarket performance Dyna Mini-Coils:
    HCP21581BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 49.95
    HCP21581BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21581RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21581YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires are bare, and ready for installation on stock or aftermarket resistive plugs caps. One set does one bike.
    $ 52.95
    HCP21576BLK Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) BLACK SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use resistive spark plugs when using this wire set. One set does one bike.
    $ 59.95
    HCP21576BLU Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) DARK BLUE SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use resistive spark plugs when using this wire set. One set does one bike.
    $ 64.95
    HCP21576RED Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) RED SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use resistive spark plugs when using this wire set. One set does one bike.
    $ 64.95
    HCP21576YEL Aftermarket pre-assembled 8mm copper-core, non-suppression (zero ohms resistance) YELLOW SPARK PLUG WIRE SET WITH RESISTIVE PLUG CAPS, with coil-end terminals already crimped, and includes the rubber boot at the coil-end of the wires, as well as individual plug wire number tags (1, 2, 3, and 4). Pre-cut to correct length for all XJ700-X and XJ750-X water-cooled models using the performance Dyna Mini-Coils (our part number HCP12764). Plug-end of the wires have the aftermarket resistive plug caps already installed, and are ready for installation onto spark plugs. NOTE: since these wires include aftermarket 5K resistive plug caps, you should continue to use resistive spark plugs when using this wire set. One set does one bike.
    $ 64.95
    SPARK PLUG WIRE COMPONENTS a/k/a Build-Your-Own Plug Wires:
    Zero-Resistance Spark Plug Wire:
    HCP2790 Aftermarket original type BLACK SPARK PLUG WIRE, 7mm silicone-jacketed stranded copper core wire, non-suppression (0 ohms), 15" length. NOTE: original plug wire uses stainless steel (rather than copper) wire, such as the HCP10694 wire listed below. This stranded copper wire is offered as a less expensive alternative. Each:
    $ 3.95
    HCP2790SET4 Aftermarket original type BLACK SPARK PLUG WIRES, 7mm silicone-jacketed stranded copper core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 13.95
    HCP10694 Aftermarket original type BLACK SPARK PLUG WIRE, 7mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), 15" length. Each:
    $ 4.95
    HCP10694SET4 Aftermarket original type BLACK SPARK PLUG WIRES, 7mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 17.95
    HCP10671 Aftermarket high-performance BLACK SPARK PLUG WIRE, 8mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), 15" length. Each:
    $ 5.95
    HCP10671SET4 Aftermarket high-performance BLACK SPARK PLUG WIRES, 8mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 19.95
    HCP10672 Aftermarket high-performance BLUE SPARK PLUG WIRE, 8mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), 15" length. Each:
    $ 5.95
    HCP10672SET4 Aftermarket high-performance BLUE SPARK PLUG WIRES, 8mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 19.95
    HCP10673 Aftermarket high-performance RED SPARK PLUG WIRE, 8mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), 15" length. Each:
    $ 5.95
    HCP10673SET4 Aftermarket high-performance RED SPARK PLUG WIRES, 8mm silicone-jacketed stranded stainless steel core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 19.95
    HCP12636 Aftermarket standard-performance YELLOW SPARK PLUG WIRE, 7mm silicone-jacketed stranded copper core wire, non-suppression (0 ohms), 15" length. Each:
    $ 4.95
    HCP12636SET4 Aftermarket standard-performance YELLOW SPARK PLUG WIRES, 7mm silicone-jacketed stranded copper core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 17.95
    HCP10701 Aftermarket high-performance YELLOW SPARK PLUG WIRE, 8mm silicone-jacketed stranded copper core wire, non-suppression (0 ohms), 15" length. Each:
    $ 5.95
    HCP10701SET4 Aftermarket high-performance YELLOW SPARK PLUG WIRES, 8mm silicone-jacketed stranded copper core wire, non-suppression (0 ohms), set of 4 pieces, each 15" long:
    $ 19.95
    Spark Plug Wire Splicer:
    pw1) Aftermarket NGK-brand SPARK PLUG WIRE SPLICER. This handy little device allows you to cut off a bad original plug wire and splice in a replacement piece, which is really handy, since the plug wires on the original factory coils are basically non-replaceable......so if a plug wire goes bad, unless you are willing to perform "coil surgery", then the whole coil is junk!
    This plug wire splicer or "joiner" allows you to extend or replace a damaged or bad plug wire, just like you would splice into a piece of electrical wire. The watertight, screw-on design is made from a high-impact plastic material and adds no resistance (0 ohms) to the circuit. Will accept either 7mm or 8mm plug wire (but no larger).....meaning you can also use this to splice original 7mm plug wires to aftermarket 8mm wires. A very handy and practical solution!
    HCP2789 Aftermarket SPARK PLUG WIRE SPLICER, fits up to 8mm plug wire. Each:
    $ 22.95
    HCP2789SET4 Aftermarket SPARK PLUG WIRE SPLICERS, fits up to 8mm plug wire, set of 4:
    $ 79.95
    Spark Plug Wire Sleeve:
    Whether you're building your own wires from scratch, replacing wire on an original coil, or just refreshing original wires on your bike, this flexible black rubber sleeving fits semi-snugly over the outer insulation of the plug wires and adds an additional level of heat and sharp-edge protection for the plug wires.
    HCP13147 Aftermarket black PLUG WIRE SLEEVING, flexible heat-resistant neoprene rubber sleeve correct replaces original sleeving on all models or for use when building your own wires. Fits all original or aftermarket 7mm plug wires. Most models use 12-16" of sleeving per plug wire. Sold per foot:
    $ 4.95
    HCP13123 Aftermarket black PLUG WIRE SLEEVING, flexible heat-resistant neoprene rubber sleeve looks like the original sleeving used on all models, and is recommended when building your own wires. Fits all aftermarket 8mm plug wires. Most models use 12-16" of sleeving per plug wire. Sold per foot:
    $ 5.95
    Spark Plug Wire Accessories:
    When you create your own plug wires, it's very useful to use these handy wire number markers to designate which wire goes to which cylinder, so in case all of your wires are removed from the plugs at one time, you'll know exactly which cylinder to install them back onto!
    HCP9740 Aftermarket spark plug wire NUMBER TAGS, labeled 1, 2, 3, and 4, clip-on design has black numbers on a white background. Complete set comes with one of each number.
    $ 13.95
    HCP10670 Aftermarket spark plug wire NUMBER TAGS, labeled 1, 2, 3, and 4, heat-shrink design has white numbers on a black background. Complete set comes with one of each number.
    $ 11.95
    Spark Plug Wire Boots, Terminals, and Tools:
    Although we offer the replacement NGK resistive plug CAPS further below, some people may desire or need to replace them with these high-quality aftermarket PLUG BOOTS and PLUG-END METAL TERMINALS, and if you're replacing your original coils with Dyna coils, then you'll also need the COIL BOOTS and COIL-END METAL TERMINALS.
    We offer a variety of high quality, high performance components to allow you to create complete, customized plug wires. However, be aware that the wire-end metal terminals should always be both crimped and soldered onto the plug wire ends, in order to maintain electrical integrity and prevent voltage leaks. A proper crimping tool is available, but it's not cheap!
    But, if you decide to go full custom, we have all of the proper and necessary plug boot, coil boots, and metal terminals necessary to do the job correctly.
    All boots and terminals will fit either 7mm or 8mm plug wire.
    The 90- and 135-degree plug-end boots are approximately 1.5" tall and "reach" 1-3/4" towards the plug wire.
    The 180-degree ("straight") plug-end boots are approximately 3.25" tall.
    Plug-End Wire Boots and Terminals:
    NOTE: original ignition systems depend on having a certain amount of "total system electrical resistance" to operate properly, and the original spark plug CAPS are part of that total system resistance. The replacement spark plug TERMINALS and BOOTS below have zero resistance, and thus using these components to terminate your plug wires will reduce that "total system resistance" by the amount of resistance that the original plug caps provided.
    In such a situation, we suggest gaining back the amount of resistance provided by the original plug caps by using resistor plugs in place of the stock non-resistor plugs in those models in which it is possible to do so.
    HCP10811 Aftermarket molded BLACK SPARK PLUG BOOT, 90-degree angle. Use with the HCP9750 brass terminals listed below. Each:
    $ 4.95
    HCP9747 Aftermarket molded BLUE SPARK PLUG BOOT, 90-degree angle. Use with the HCP9750 brass terminals listed below. Each:
    $ 4.95
    HCP10674 Aftermarket molded GREY SPARK PLUG BOOT, 90-degree angle. Use with the HCP9750 brass terminals listed below. Each:
    $ 4.95
    HCP10812 Aftermarket molded BLACK SPARK PLUG BOOT, 135-degree angle. Use with the HCP9751 brass terminals listed below. Each:
    $ 4.95
    HCP9748 Aftermarket molded BLUE SPARK PLUG BOOT, 135-degree angle. Use with the HCP9751 brass terminals listed below. Each:
    $ 4.95
    HCP10675 Aftermarket molded GREY SPARK PLUG BOOT, 135-degree angle. Use with the HCP9751 brass terminals listed below. Each:
    $ 4.95
    HCP10813 Aftermarket molded BLACK SPARK PLUG BOOT, 180-degree, straight boot (no bend). Use with the HCP9752 brass terminals listed below. Each:
    $ 4.95
    HCP9749 Aftermarket molded BLUE SPARK PLUG BOOT, 180-degree, straight boot (no bend). Use with the HCP9752 brass terminals listed below. Each:
    $ 4.95
    HCP10676 Aftermarket molded GREY SPARK PLUG BOOT, 180-degree, straight boot (no bend). Use with the HCP9752 brass terminals listed below. Each:
    $ 4.95
    HCP9750 Aftermarket spark plug wire-end METAL TERMINAL, used at the spark plug end of the wire, 90-degree bend. Use with any of the 90-degree plug boots listed above. Each:
    $ 3.95
    HCP9751 Aftermarket spark plug wire-end METAL TERMINAL, used at the spark plug end of the wire, 135-degree bend. Use with any of the 135-degree plug boots listed above. Each:
    $ 3.95
    HCP9752 Aftermarket spark plug wire-end METAL TERMINAL, used at the spark plug end of the wire, straight (no bend). Use with any of the straight plug boots listed above. Each:
    $ 3.95
    Coil-End Wire Boots and Terminals:
    HCP9741 Aftermarket rubber BLACK COIL BOOT, 90-degree angle. Use with the HCP9745 terminals listed below. Each:
    $ 4.95
    HCP9742 Aftermarket rubber BLACK COIL BOOT, straight. Use with the HCP9746 terminals listed below. Each:
    $ 4.95
    HCP9745 Aftermarket coil-end wire METAL TERMINAL, used at the coil end of the wire, 90-degree bend. Use with the 90-degree coil boot HCP9741 listed above. Each:
    $ 3.95
    HCP9746 Aftermarket coil-end wire METAL TERMINAL, used at the coil end of the wire, straight (no bend). Use with the straight coil boot HCP9742 listed above. Each:
    $ 3.95
    NOTE ON COIL BOOTS: all XJ550, XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, and XJ1100 models can use either the straight or the 90-degree angle coil boots when retro-fitting aftermarket Dyna coils. The XJ700-X and XJ750-X models should use the straight boots and terminals on the front coil output towers, and use the 90-degree boots and terminals on the rear coil output towers.
    Spark Plug Wire Assembly Service:
    Order whatever combination of raw plug wires, terminals, boots or plug caps, wire sleeve, wire markers, etc. from the above choices and we will be glad to assemble the wires for you, saving you the cost of purchasing either of the wire crimper tools below.
    WIRE-ASSEMBLE Spark plug WIRE ASSEMBLY SERVICE, covers the cost of doing all four plug wires and any combo of accessories from above.
    $ 19.95
    Spark Plug Wire Terminal Crimping Tools:
    NOTE: THE FOLLOWING TOOLS ARE AVAILABLE FOR RENTAL!!: some tools are a one-time or infrequent use tool, so it may be more economical for you to rent them from us, rather than to purchase outright. Please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP20451 Aftermarket spark plug wire terminal CRIMPING TOOL. This basic, 7-function hand-crimp tool incorporates wire cutter, terminal crimper, and wire stripper functions into one handy tool. Black anodized finish with insulated hand grips, crimp slot on end of tool secures most ignition terminals including "W" type, right angle and "High Tower" terminals. Will crimp 7mm to 8.5mm plug wire, and works with 10- to 22-gauge solderless terminals.
    $ 49.95
    HCP9739 Aftermarket spark plug wire terminal CRIMPING TOOL. This high-quality, professional grade ratcheting tool is easy-to-use feel, but will still achieve a complete and thorough crimp of the wire terminals to the plug wire, preventing future separation or electrical resistance issues. The right tool for the job makes life easier......
    $ 99.95
  14. chacal
    SPARK PLUG CAPS:
    pc2) Original TD (Tokia-Denso) and aftermarket NGK SPARK PLUG CAPS are available in a variety of styles and configurations. All plug caps include their upper and lower rubber end boots.
    Okay, before we get going, let's quickly review a little bit about the original Yamaha COILS, PLUG WIRES, PLUG CAPS, and the SPARK PLUGS used on these bikes.
    NOTE: there is a a lot of information below about a sometimes mystifying topic….electricity, and electrical resistance (and how it can make your life better……) below. Please ask questions if there’s anything that you don’t understand in relation to selecting the correct components for your bike!
    Factory ignition systems are designed to operate properly with a total system resistance on the secondary side (the "going-to-the-spark-plugs" side) of the ignition coils of around 20-30K ohms (ohms being a measure of electrical resistance). Electrical resistance depends on a number of factors: wire size, type of material, length of material, age of material, ambient temperature, etc. etc. In any case, most factory XJ coils and plug wires combined --- BUT WITHOUT THE CAPS OR PLUGS ATTACHED --- are specified to have a resistance of around 11K ohms (+/- 20%) at 68-degrees Fahrenheit. Please see the complete list of specifications in the "COILS" section above.
    Plug WIRES on factory coils are non-replaceable, at least not without a bit of surgery. Suffice it to say that if your coils measure out of specs for resistance (as described above), they're junk and should be replaced, either with another factory coil, one of our aftermarket coils, or a pair of the HCP245 Dyna aftermarket coils.
    We do offer an NGK plug wire in-line splicer (HCP2789) that will allow you to cut off and remove a bad factory wire and replace it with a length of our aftermarket plug wire, in cases where the wire itself gets damaged, but the coil itself is still in good shape (physically and electrically).
    The original spark plug wire resistive CAPS---mistakenly called "boots" by some people---are the hard plastic insulators that fit onto the spark plug threaded stud, and accept the plug wire from the coil on their other end via a simple "twist-on" method------yes, the plug wire end of the cap has a metal screw that bites into and "screws" onto the end of the plug wire, penetrating the plug wire inner metal core and making a mechanical connection.
    Plug caps use a small internal ceramic resistor, and the resistance of each cap should be checked with an ohmmeter on a periodic basis. Caps that are +/- 20% resistance from specified levels are considered bad, and should be replaced:
    NOTE: "K" is abbreviation for a thousand units, so "5K" ohms = 5,000 ohms of resistance, etc.
    NOTE: some models within this era could have been fitted with "noise suppression" plug caps (these caps are evidenced by a metal "shield" wrapped around the plastic cap body) and such caps may have used a higher resistance rating as opposed to their stock ratings listed below (for non "noise suppression" style caps).
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range:
    all XJ650 models
    1985 XJ700 air-cooled models
    all 1981-84 XJ750 (except XJ750RL) models
    all 1983-84 XJ900RK and RL models
    all XJ1100 models
    all XS1100 models
    NOTE: some sources specify that XJ650 models, XJ750 air-cooled models, and XJ900, XJ1100 and XS1100 models used 5K caps on the outer plug (#1 and #4), and 10K caps on the inner plugs (cylinders #2 and #3). Other sources say that all 4 caps were 5K ohms. And other sources say that 10K caps were used on the outer cylinders (#1 and #4), while the two center cylinders use 10K caps…….whew! Our recommendation is to use the 5K caps on all 4 cylinders.
    10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range:
    all XJ550 models
    all XJ700-X water-cooled models
    all XJ750-X water-cooled models
    1984 XJ750RL models
    all 1985-up XJ900F, N, and FN models
    15K +/- 20% = 12,000 to 18,000 ohms per cap acceptable range:
    all XJ900S and SH models
    Spark plug "boots", typically seen on automotive engine plug wires, are usually only a protective (insulating) rubber cover........there is no internal resistor (as with plug "caps") since there is an internal direct-connection from the spark plug wire to the spark plug top terminal stud. Automotive ignition systems take care of system resistance via the spark plug itself, and the spark plug wire (which is resistive, unlike on these bikes, which use non-resistive wire), and thus do not rely on a resistive plug "cap" to regulate the resistance of the ignition secondary circuit. Yamaha chose to go with non-resistive plug wire, resistive plug caps, and (on most models) non-resistive spark plugs....thus allowing the resistive plug "cap" to handle the entire resistive load for the secondary circuit.
    So don’t resist (ha-ha), go ahead and read this and become an electrical-resistance genius:
    http://www.motorcycleproject.com/text/plugwiretech.html
    A variety of different size and shape plug caps are listed below, in both their original Tokai Denso ("TD") brand and replacement NGK brand. The replacement NGK caps come in a variety of original configurations and can be safely used to replace broken, missing, damaged, or out-of-spec original caps. And all original and replacement caps will accept up to 8mm spark plug wires easily.
    NOTE: all original and replacement spark plug caps are designed to be used on spark plugs that have their screw-on threaded stud topper “nut” removed. All of the original TD and most of the NGK replacement plug caps are designed to be used on spark plugs without this “stud nut”. All replacement 12mm NGK plugs come with a nut, while most 14mm NGK plus have the removable stud nut included, but it must be removed before use. Note that the HCP13192 and HCP19193 plug caps (10K) do require the use of the stud nut (available separately as part HCP13518), and owners of all XJ550 models, 1986 XJ700 air-cooled models, all XJ700-X water-cooled models, all XJ750-X water-cooled models, 1984 XJ750RL models, and all 1985-up XJ900F, N, and FN models should salvage the stud nuts off of their original spark plugs (if purchasing new NGK spark plugs), or, purchase a set of the HCP13518 nuts (which can be re-used indefinitely by transferring it from plug to plug).
    It is important to remember that you should strive to keep the ignition coil secondary circuit (plug wire, plug cap, and spark plug) total resistance as close as possible to original specifications, which are:
    - 15K ohms per cylinder on all 1986 XJ700-X, XJ750-X, and XJ900 S/SH models.
    - 10K ohms per cylinder on all XJ550, 1985 XJ700-X models, 1986 XJ700 non-X, XJ750RL, and XJ900 N/FN and F models.
    - 5K ohms per cylinder on all XJ650, 1985 XJ700 non-X, all 1981-83 XJ750 models, XJ750-D, XJ900RK and RL models, and XJ1100 models.
    NOTE: some sources specify that XJ650 models, XJ750 air-cooled models, and XJ900, XJ1100 and XS1100 models used 5K caps on the outer plug (#1 and #4), and 10K caps on the inner plugs (cylinders #2 and #3). Additionally, it is noted that non-North American models would indeed use 5K caps on all four cylinders. This conflicting information from a variety of sources can lead to quite a bit of confusion. Our recommendation is to use 5K caps on all 4 cylinders. Of course, if you wish to experiment (to see if there is any meaningful performance enhancements in doing so) and increase the resistance (from 5K to 10K) on the two center cylinders, you can do so by the following methods:
    a) use the stock non-resistive spark plugs on all 4 cylinders, and use 5K caps on the outer cylinders and 10K caps on the inner cylinders.
    b) use stock non-resistive spark plugs on the outer cylinders, and resistive (5K) spark plugs on the center cylinders, and then use 5K caps on all plug wires.
    NOTE: there may be some benefit to reducing your plug cap resistance by 5K from stock values, and increasing the spark plug resistance by 5K from stock, since spark plugs normally need to be changed every 7,500 miles or so, and when changing the spark plugs, you are also automatically "re-setting" its resistance value. Otherwise, in most stock configurations, your 0K (non-resistive) plugs gets changed frequently, but your plug caps are retained, even though their resistance ratings are deteriorating over time. By "transferring" the resistive load from the very infrequently replaced plug caps to the rather regularly replaced spark plugs, you then get to take advantage of the regular replacement cycle that naturally occurs with spark plug changes. On the other hand, plug caps tend to retain their resistance value for a long time, and it will typically take many years/miles before plug caps get outside of their +/-20% resistance values…………
    Just remember to add up the resistance of your plug wires (original wires and all of our replacement wires are 0K ohms, non-resistance wire), the spark plugs (0K for non-resistive plugs, 5K for resistive plugs), and of your plug caps (which can be varied as outlined above) to arrive at the correct total resistance value for each plug!
    EXAMPLE: 1982 XJ650 Maxim models originally used the HCP1292 non-resistive (zero ohms) BP7ES spark plugs, along with 5,000 (5K) ohm plug caps on each plug. If you substitute a resistive plug (such as the HCP1293 Iridium plugs, or any other resistive plug) for the original non-resistive plug, then your spark plug + plug cap total resistance will increase from the original 5,000 (5K) ohms to 10,000 (10K) ohms. Therefore, you should reduce the resistance in the plug cap to zero ohms to keep the system at the same total resistance levels as original.
    The key to remember is that you simply want to maintain the TOTAL system resistance at whatever the factory rating is. You can't do much about what the coils themselves are rated at, so outside of the coils, you have three choices of where the resistance can be added:
    a) the plug wires
    b) the plug caps
    c) the plugs
    For example, the XJ550's require 10K (10,000) ohms of resistance in each plug wire + plug cap + spark plug (these 3 components are the “secondary” ignition coil circuit (outside of the ignition coil itself). . You can achieve this specified 10K of resistance thru any combination of component pieces; however, it may be simpler to use zero-resistance wires, and then use either:
    1) 10K plug caps and 0-ohm (non-resistive) spark plugs (this is the method that was originally used).
    2) 5K aftermarket NGK plug caps and 5K aftermarket resistor plugs.
    Finally, always check --- with an ohmmeter --- the coil primary and secondary resistance, your plug cap resistance, and your spark plug resistance and condition before you start "throwing money" at engine performance problems that seem to be electrically-related!
    Spark Plug Resistor Caps:
    All original Tokia Denso SPARK PLUG CAPS come fully assembled and include both the upper plug-wire black rubber boot and the large lower plug-body black rubber boot (orange on XJ700-X and XJ750-X models) as original. All original caps will accept the original 7mm plug wire or our replacement 8mm plug wires. Although there were specific models which may have used different resistance ratings at different cylinder positions (outer vs. inner cylinders) and different resistance ratings between models, all caps can be used on any cylinder position on any bike from a physical-fitment and orientation standpoint...........except for the special extra-tall plug caps used on the XJ700-X and XJ750-X models, which are unique and should not be substituted for by any other original caps.
    Although not the original supplier to Yamaha in the era of XJ models, NGK offers an affordable line of quality constructed SPARK PLUG CAPS that will properly replace the original Tokia Denso ("TD") caps that your bike came equipped with from the factory. NGK caps are available in a variety of different styles (height, resistive value, and upper end bend-angles, etc.) that are summarized below.
    Most NGK caps have a shiny black thermo-plastic housing, which of course makes them easy to distinguish from the original dull-black Tokia Denso ("TD") plugs caps.
    XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, XJ700-X, XJ750-X, and XJ900 S/SH models:
    NOTE: all XJ700-X, XJ750-X, and XJ900 S/SH models used extra-tall "skyscraper” plug caps on all 4 cylinders, while XJ550 and 600cc engines used "short" or "medium" height caps on the outer (#1 and #4) cylinders and"taller" caps on the inner (#2 and #3) cylinders.
    XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II Outer (#1 & #4) Cylinders:
    NOTE: all XJ550 and 600cc engines originally used 10K resistance value plug caps on all four cylinders. You can use either the OEM or replacement 10K resistive caps and non-resistive plugs, or 5K caps along with 5K resistive plugs in order to maintain the original 10K per plug + cap resistance rating.
    HCP7441 OEM SPARK PLUG CAP, bent-tip T-135 caps for 12mm "D" plugs with a threaded stud on top. These are the original 10K ohm, 1-3/4" tall caps with the 90-degree bent tip and include the black rubber wire and base boot. Correct for use on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models on the outer cylinders (#1 and #4), and on all four cylinders on 1992-98 XJ600 Seca II models, but can actually be used on all models in any position. Each:
    $ 59.95
    HCP7441SET2 OEM SPARK PLUG CAPS, set of 2.
    $ 114.95
    HCP7441SET4 OEM SPARK PLUG CAPS, set of 4.
    $ 219.95
    HCP1316 Aftermarket NGK SPARK PLUG CAP, 5K ohms, short 90-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Great replacement for the stock plug caps on the outer (#1 and #4) cylinders on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Shorter than original caps (1.50" tall for these replacements versus 2.50" tall for the original caps). NOTE:: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is recommended when using these caps. Each:
    $ 22.95
    HCP1316SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1322 Aftermarket NGK SPARK PLUG CAP, 5K ohms, medium 120-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Suitable replacement for the stock plug caps on the outer (#1 and #4) cylinders on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Slightly taller than the original caps, the 120-degree angled plug wire end offers some additional clearance as compared to the stock 60-degree right-angled caps. NOTE: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is recommended when using these caps on these models. Each:
    $ 22.95
    HCP1322SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP13192 Aftermarket NGK SPARK PLUG CAP, 10K ohms, short 90-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Suitable replacement for the stock plug caps on the outer (#1 and #4) cylinders on XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models, and on all four cylinders on 1992-98 XJ600 Seca II models. Shorter than original caps (1.60" tall for these replacements versus 2.50" tall for the original caps) but with a deeper reach than original caps, they will fit and perform properly, and the 90-degree angled plug wire end offers some additional reach as compared to the stock 60-degree right-angled caps. NOTE: these plug caps require the use of an hourglass shaped “terminal nut” on the top threaded stud of the spark plug. Since 10mm and 12mm spark plugs do not include this terminal nut, you will need to purchase the HCP13518 adapter nuts listed below when using these plug caps on nay of these models. Each:
    $ 22.95
    HCP13192SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP13192SET4 Aftermarket NGK SPARK PLUG CAPS, set of 4.
    $ 79.95
    HCP13518 Aftermarket spark plug threaded top stud ADAPTER NUT, hour-glass shaped aluminum nut attaches to the threaded stud on the top of the spark plug. Needed when using plug caps designed for 14mm spark plugs on any 12mm "D" series plugs. Use 1 per plug. Can be re-used almost indefinitely from one spark plug to the next. Each:
    $ 1.95
    HCP13518SET4 Aftermarket spark plug threaded top stud ADAPTER NUTS, set of 4:
    $ 4.95
    HCP1676 Aftermarket NGK SPARK PLUG CAP, non-resistive (0 ohms), 90-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Can be used as a replacement for applications that require the use of a zero-ohm cap (for example, changing from original non-resistor plugs to resistor plugs). Much shorter (about half the height) of the originals, and especially on the outer (#1 and #4) cylinders, stock plug wires may need to be extended in order to be able to reach these caps. NOTE: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is required when using these caps. Each:
    $ 11.95
    HCP1676SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 22.95
    HCP1676SET4 Aftermarket NGK SPARK PLUG CAPS, set of 4.
    $ 44.95
    HCP29947 Aftermarket SPARK PLUG CAP, non-resistive (0 ohms), 90-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Can be used as a replacement for applications that require the use of a zero-ohm cap (for example, changing from original non-resistor plugs to resistor plugs). Much shorter (about half the height) of the originals, and especially on the outer (#1 and #4) cylinders, stock plug wires may need to be extended in order to be able to reach these caps. NOTE: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is required when using these caps. Each:
    $ 9.95
    HCP29947SET2 Aftermarket SPARK PLUG CAPS, set of 2.
    $ 17.95
    HCP29947SET4 Aftermarket SPARK PLUG CAPS, set of 4.
    $ 34.95
    XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models Inner (#2 & #3) Cylinders:
    HCP7440 OEM SPARK PLUG CAP, 10K ohms, bent-tip T-131 caps for 12mm "D" plugs with a threaded stud on top. These are the original 10K ohm, 2-1/2" tall caps with the 60-degree bent tip and include the black rubber wire and base boot. Correct for use on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models on all the outer cylinders (#1 and #4), and all XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models on all four cylinders, but can actually be used on all models in any position. Each:
    $ 37.95
    HCP7440SET2 OEM SPARK PLUG CAPS, set of 2.
    $ 67.95
    HCP7440SET4 OEM SPARK PLUG CAPS, set of 4.
    $ 119.95
    HCP1312 Aftermarket NGK SPARK PLUG CAPS, 5K ohms, straight, for 12mm "D" plugs with a threaded stud on top. Recommended as a suitable replacement for all four XJ700-X and XJ750-X plug caps, as the straight-up design helps keep the plug wires off the valve covers, unlike the angled-tip configuration of the original. Can be used on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models on the inner cylinders (#2 and #3), and on all four cylinders on all XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models (especially when using aftermarket plug wires and coils). Approximately 3-3/4" tall vs. the 2-3/8" tall originals. NOTE: these caps have less resistance than the stock plug caps used on some models, and the use of resistive plugs is recommended when using these caps. Each:
    $ 22.95
    HCP1312SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1312SET4 Aftermarket NGK SPARK PLUG CAPS, set of 4.
    $ 79.95
    HCP1318 Aftermarket NGK SPARK PLUG CAP, 5K ohms, tall 102-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Although similar in configuration to the original XJ700-X and XJ750-X original plug caps, with the bent-up plug wire tip design, these are much shorter, and thus not recommended for those models. Can be used on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models on the inner cylinders (#2 and #3), and on all four cylinders on all XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models (especially when using aftermarket plug wires and coils). Approximately 3-1/4" tall vs. the 2-3/8" tall originals. NOTE: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is recommended when using these caps. Each:
    $ 22.95
    HCP1318SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1318SET4 Aftermarket NGK SPARK PLUG CAPS, set of 4.
    $ 79.95
    HCP13193 Aftermarket NGK SPARK PLUG CAP, 10K ohms, short 90-degree angled boot, for 12mm "D" plugs with a threaded stud on top. Suitable replacement for the stock plug caps on the inner (#2 and #3) cylinders on XJ550 and 1984-85 FJ600 models, and on all four cylinders on 1992-98 XJ600 Seca II, XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models on all cylinders. Slightly shorter and less deep than original caps, they will fit and perform well and the 90-degree angled plug wire end offers enough clearance as compared to the stock 60-degree right-angled caps. NOTE: these plug caps require the use of an hourglass shaped “terminal nut” on the top threaded stud of the spark plug. Since 10mm and 12mm spark plugs do not include this terminal nut, you will need to purchase the HCP13518 adapter nuts listed below when using these plug caps. Each:
    $ 22.95
    HCP13193SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP13193SET4 Aftermarket NGK SPARK PLUG CAPS, set of 4.
    $ 79.95
    $ 2.95
    $ 4.95
    $ 11.95
    $ 22.95
    $ 44.95
    $ 9.95
    $ 17.95
    $ 34.95
    all XJ700-X, XJ750-X models on all cylinders:
    NOTE: all XJ700-X and XJ750-X models originally used 10K resistance value plug caps on all four cylinders. You can use either the OEM 10K resistive caps and non-resistive plugs, or 5K caps along with 5K resistive plugs in order to maintain the original 10K per plug + cap resistance rating.
    HCP3168 OEM SPARK PLUG CAP, 10K ohms, straight, for 12mm "D" plugs with a threaded stud on top. These are the original TD-140 10K ohm, extra-tall 5-1/4" caps with the 120-degree bent tip and the distinctive orange rubber base boot as used on all XJ700-X and XJ750-X models, on all four cylinders. Also fits the following models: 1987 FZ700, 1986-87 FZX700 Fazer, 1985-86 and 1988 FZ750, 1987-88 FZR750R, 1994 1996-98 YZF750R, 1987-95 FZR1000, and 1993-94 GTS1000 models. Each:
    $ 119.95
    HCP3168SET2 OEM OEM SPARK PLUG CAPS, set of 2.
    $ 229.95
    HCP3168SET4 OEM OEM SPARK PLUG CAPS, set of 4.
    $ 429.95
    $ 7.95
    $ 14.95
    $ 26.95
    XJ900 S/SH models on all cylinders]:
    NOTE: all XJ900 S/SH models originally used 10K resistance value plug caps on all four cylinders. You can use either the OEM or replacement 10K resistive caps and non-resistive plugs, or 5K caps along with 5K resistive plugs in order to maintain the original 10K per cylinder (plug + cap) resistance rating.
    $ 37.95
    $ 67.95
    $ 119.95
    HCP1312 Aftermarket NGK SPARK PLUG CAPS, 5K ohms, straight, for 12mm "D" plugs with a threaded stud on top. Recommended as a suitable replacement for all four XJ700-X and XJ750-X plug caps, as the straight-up design helps keep the plug wires off the valve covers, unlike the angled-tip configuration of the original. Can be used on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models on the inner cylinders (#2 and #3), and on all four cylinders on all XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models (especially when using aftermarket plug wires and coils). Approximately 3-3/4" tall vs. the 2-1/2" tall originals. NOTE: these caps have less resistance than the stock plug caps used on some models, and the use of resistive plugs is recommended when using these caps. Each:
    $ 7.95
    $ 14.95
    $ 24.95
    $ 14.95
    $ 27.95
    $ 49.95
    $ 2.95
    $ 4.95
    1984-85 FJ1100 and 1986-87 FJ1200 models:
    $ 37.95
    $ 67.95
    $ 119.95
    $ 7.95
    $ 14.95
    $ 26.95
    $ 14.95
    $ 27.95
    $ 49.95
    $ 1.95
    $ 4.95
    all XJ650, XJ700 non-X, XJ750 non-X all, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models:
    NOTE: all of these models used "short" or "medium" height caps on the outer (#1 and #4) cylinders and the "tall" caps on the inner (#2 and #3) cylinders.
    NOTE: all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models originally used 5K resistance value plug caps on all four cylinders. You can use either the OEM or replacement 5K resistive caps and non-resistive plugs, or 0K non-resistive caps along with 5K resistive plugs in order to maintain the original 5K per cylinder (plug + cap) resistance rating
    NOTE: some sources specify that XJ650 models, XJ750 air-cooled models, and XJ900, XJ1100 and XS1100 models used 5K caps on the outer plug (#1 and #4), and 10K caps on the inner plugs (cylinders #2 and #3). Other sources say that all 4 caps were 5K ohms. And other sources say that 10K caps were used on the outer cylinders (#1 and #4), while the two center cylinders use 10K caps…….whew! This conflicting information from a variety of sources can lead to quite a bit of confusion. Our recommendation is to use 5K caps on all 4 cylinders.
    Of course, if you wish to experiment (to see if there is any meaningful performance enhancements in doing so) and increase the resistance (from 5K to 10K) on the two center cylinders (or the two outer cylinders, depending on who you choose to believe…..), you can do so by the following methods:
    all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 outer (#1 & #4) Cylinders:
    HCP7437 OEM SPARK PLUG CAP, bent-tip T-134 caps for 14mm "B" plugs with a threaded stud on top. These are the original 5K ohm, 1-3/8" tall caps with the 90-degree bent tip and include the black rubber wire and base boot. Correct for use on all air-cooled XJ650, XJ700, 1981-83 XJ750, XJ750-D, XJ750RL, XJ900 RK, RL, N/FN, and F models, XJ1100, and all XS1100 models on the outer cylinders (#1 and #4), but can actually be fitted on all models in any position. Each:
    $ discontinued
    HCP7437SET2 OEM SPARK PLUG CAPS, set of 2.
    $ discontinued
    HCP1304 Aftermarket NGK SPARK PLUG CAPS, 5K ohms, short 90-degree angled boot, for 14mm "B" plugs with a threaded stud on top. Great replacement for the stock plug caps on the outer (#1 and #4) cylinders. Slightly taller than original caps (1.5" tall for these replacements versus 1.3" tall for the originals). Each:
    $ 22.95
    HCP1304SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1308 Aftermarket NGK SPARK PLUG CAPS, 5K ohms, short 120-degree angled boot, for 14mm "B" plugs with a threaded stud on top. Suitable replacement for the stock plug caps on the outer (#1 and #4) cylinders. Slightly taller than original caps (2.0" tall for these replacements versus 1.3" tall for the originals), and the 120-degree angled plug wire end offers some additional clearance as compared to the stock 90-degree right-angled caps. Each:
    $ 22.95
    HCP1308SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1310 Aftermarket NGK SPARK PLUG CAP, 5K ohms, medium 120-degree angled boot, for 14mm "B" plugs with a threaded stud on top. Suitable replacement for the stock plug caps on the outer (#1 and #4) cylinders. Slightly taller than original caps (2.4" tall for these replacements versus 1.3" tall for the originals), and the 120-degree angled plug wire end offers some additional clearance as compared to the stock 90-degree right-angled caps. Each:
    $ 22.95
    HCP1310SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1676 Aftermarket NGK SPARK PLUG CAP, non-resistive (0 ohms), 90-degree angled boot, for 14mm "B" plugs with a threaded stud on top. Can be used as a replacement for applications that require the use of a zero-ohm cap (for example, changing from original non-resistor plugs to resistor plugs). Much shorter (about half the height) of the originals, and especially on the outer (#1 and #4) cylinders, stock plug wires may need to be extended in order to be able to reach these caps. NOTE: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is required when using these caps. Each:
    $ 11.95
    $ 22.95
    $ 44.95
    HCP29947 Aftermarket SPARK PLUG CAP, non-resistive (0 ohms), 90-degree angled boot, for 14mm "B" plugs with a threaded stud on top. Can be used as a replacement for applications that require the use of a zero-ohm cap (for example, changing from original non-resistor plugs to resistor plugs). Much shorter (about half the height) of the originals, and especially on the outer (#1 and #4) cylinders, stock plug wires may need to be extended in order to be able to reach these caps. NOTE: these caps have less resistance than the stock plug caps used on these models, and the use of resistive plugs is required when using these caps. Each:
    $ 9.95
    $ 17.95
    $ 34.95
    all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 inner (#2 & #3) Cylinders:
    NOTE: all XJ650, XJ700 non-X, XJ750 non-X, XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models originally used 5K resistance value plug caps on all four cylinders. You can use either the OEM or replacement 5K resistive caps and non-resistive plugs, or 0K non-resistive caps along with 5K resistive plugs in order to maintain the original 5K per plug + cap resistance rating.
    HCP7436 OEM SPARK PLUG CAP, bent-tip T-133 caps for 14mm "B" plugs with a threaded stud on top. These are the original 5K ohm, 2-1/2" tall caps with the 90-degree bent tip and include the black rubber wire and base boot. Correct for use on all air-cooled XJ650, XJ700, 1981-83 XJ750, XJ750-D, XJ750RL, XJ900 RK, RL, N/FN, and F models, XJ1100, and all XS1100 models on the inner cylinders (#2 and #3), but can actually be fitted on all models in any position. Each:
    $ 99.95
    HCP7436SET2 OEM SPARK PLUG CAPS, set of 2.
    $ 179.95
    HCP7440 OEM SPARK PLUG CAP, 10K ohms, bent-tip T-131 caps for spark plugs with a threaded stud on top. These are the original 10K ohm, 2-1/2" tall caps with the 60-degree bent tip and include the black rubber wire and base boot. Correct for use on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models on all the outer cylinders (#1 and #4), and all XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models on all four cylinders, but can actually be used on all models in any position. NOTE: some sources specify that XJ650 models, XJ750 air-cooled models, and XJ900, XJ1100 and XS1100 models used 5K caps on the outer plug (#1 and #4), and 10K caps on the inner plugs (cylinders #2 and #3). Additionally, it is noted that non-North American models would indeed use 5K caps on all four cylinders. This conflicting information from a variety of sources can lead to quite a bit of confusion. Our recommendation is to use 5K caps on all 4 cylinders. Of course, if you wish to experiment (to see if there is any meaningful performance enhancements in doing so) and increase the resistance (from 5K to 10K) on the two center cylinders, you can do so by using these caps on the inner cylinders. Each:
    $ 37.95
    $ 67.95
    HCP13193 Aftermarket NGK SPARK PLUG CAP, 10K ohms, short 90-degree angled boot, for spark plugs with a threaded stud on top. Suitable replacement for the stock plug caps on the inner (#2 and #3) cylinders on XJ550 and 1984-85 FJ600 models, and on all four cylinders on 1992-98 XJ600 Seca II, XJ900 S/SH, 1984-85 FJ1100, and 1986-87 FJ1200 models on all cylinders. Slightly shorter and less deep than original caps, they will fit and perform well and the 90-degree angled plug wire end offers enough clearance as compared to the stock 60-degree right-angled caps. NOTE: some sources specify that XJ650 models, XJ750 air-cooled models, and XJ900, XJ1100 and XS1100 models used 5K caps on the outer plug (#1 and #4), and 10K caps on the inner plugs (cylinders #2 and #3). Additionally, it is noted that non-North American models would indeed use 5K caps on all four cylinders. This conflicting information from a variety of sources can lead to quite a bit of confusion. Our recommendation is to use 5K caps on all 4 cylinders. Of course, if you wish to experiment (to see if there is any meaningful performance enhancements in doing so) and increase the resistance (from 5K to 10K) on the two center cylinders, you can do so by using these caps on the inner cylinders. Each:
    $ 22.95
    $ 44.95
    HCP1306 Aftermarket NGK SPARK PLUG CAP, 5K ohms, tall 102-degree angled boot, for 14mm "B" plugs with a threaded stud on top. Recommended on the inner cylinders (#2 and #3) as replacements for the non-available tall 90-degree tip caps. Approx. 3.25" tall vs. the 2.5" tall originals. Each:
    $ 22.95
    HCP1306SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    HCP1300 Aftermarket NGK SPARK PLUG CAP, 5K ohms, straight, for 14mm "B" plugs with a threaded stud on top. Can be used on inner cylinders (#2 and #3) as replacements, especially when using aftermarket plug wires and coils. Approx. 3" tall vs. the 2.5" tall originals. Each:
    $ 22.95
    HCP1300SET2 Aftermarket NGK SPARK PLUG CAPS, set of 2.
    $ 44.95
    $ 11.95
    $ 22.95
    $ 44.95
    $ 9.95
    $ 17.95
    $ 34.95
    Replacement Rubber Boots for Original Tokia Denso ("TD") Spark Plug Caps:
    For rebuilding purposes, we have the original style black rubber PLUG-WIRE BOOTS and CAP BASE-TO-SPARKPLUG-BODY BOOTS that fit onto the original Tokia Denso spark plug caps and seal (both against the environment and "electrically") the plug wire from the coils (this is the "plug-wire" boot, at the upper end of the plug cap) and the plug cap to the spark plug body (this is the "plug-end" boot at the lower end of the plug cap).
    HCP13508 Aftermarket black rubber PLUG-WIRE BOOTS, almost identical in appearance to the original boot used on all XJ-series original plug caps except on the HCP7437 cap (which uses the HCP13509 boot below). Will accept up to 8mm plug wire, and is molded from a very dense, thick-walled rubber material like original. Can also be used on the HCP7437 cap if desired. Each:
    $ 4.95
    HCP13509 Aftermarket black rubber PLUG-WIRE BOOT, almost identical in appearance to the original boot used on the HCP7437 cap. Will accept up to 8mm plug wire, and is molded from a thin-wall rubber material like original. Can also be used on the HCP7436, HCP7440, HCP7441, and HCP3168 original caps if desired. Each:
    $ 4.95
    HCP13501 Aftermarket black rubber CAP BASE-TO-SPARK PLUG BOOT, very similar in appearance to the original boot used on all XJ-series original plug caps except on the HCP3168 cap (XJ700-X and XJ750-X). Although the original plug-body boots actually came in a variety of similar-but-different sizes and configurations, this replacement is molded from a very dense, thick-walled rubber material like original, and will fit and seal like an original. Each:
    $ 4.95
    HCP13510 Aftermarket black rubber CAP BASE-TO-SPARK PLUG BOOT, will fit on all original plug caps used on all XJ-series models except on the HCP3168 cap (XJ700-X and XJ750-X). This replacement is smaller and is molded from a thinner-walled rubber material than original, but it will fit and seal as tightly as an original. Each:
    $ 4.95
    Replacement Resistors for Original Tokia Denso Spark Plug Caps:
    If you would like to keep your (otherwise) good condition original plug caps, you can rebuild the ones which are marked TD-131, TD-135, and TD-140 (the TD-133 caps can be rebuilt, but we do not have the correct 5K ohm resistor to fit it, and the TD-134 caps cannot be rebuilt) by replacing the internal RESISTOR CORE, the thin resistor SPRING SEAT DISC, and cleaning the TENSION SPRING and the screw-in brass cap PLUG.
    http://faq.f650.com/FAQs/Photos/ElecPhotos/PlugCapUndone.jpg
    http://faq.f650.com/FAQs/Photos/ElecPhotos/PlugCapUndo.jpg
    Always remember, that if you replace an original resistor with a core of lesser-value resistance, you should "make-up" the difference in electrical resistance via the use of resistor plugs.
    HCP13232 Aftermarket 5K ohm CERAMIC RESISTOR, can be used to replace the original internal plug cap resistor on all TD-140 plug caps. This replacement resistor is slightly longer (5mm) than an original resistor, and thus the tension spring or the brass screw-in brass cap plug will need to be shortened by an equal amount for proper fitment. If using this resistor on XJ700-X and XJ750-X models---which originally used a 10K resistor---you should also switch from non-resistor spark plugs to resistor plugs to make up the difference in total system resistance. Use 1 per cap. Each:
    $ 12.95
    HCP13233 Aftermarket 10K ohm CERAMIC RESISTOR, can be used to replace the original internal plug cap 10K resistor on all TD-140 plug caps on XJ700-X and XJ750-X models. This replacement resistor is slightly longer (5mm) than an original resistor, and thus the tension spring or the brass screw-in brass cap plug will need to be shortened by an equal amount for proper fitment. Use 1 per cap. Each:
    $ 13.95
    HCP13604 Aftermarket 10K ohm CERAMIC RESISTOR, can be used to replace the original internal plug cap 10K resistor on all T-131, T-135, and T-140 plug caps on XJ550, XJ700-X, and XJ750-X models. This replacement resistor is 3.5mm shorter than an original resistor, and thus the HCP16191 spacer below will need to be used to take up the extra distance for proper fitment. Use 1 per cap. Each:
    $ 12.95
    HCP16191 Aftermarket plug cap resistor SPACER DISC, this 3.5mm thick, non-resistive copper disc should be used with the HCP13604 resistor above in order to create a proper fit within the cap. Use 1 per cap. Each:
    $ 6.95
    HCP13115 Aftermarket plug cap resistor SPRING SEAT DISC, this thin, non-resistive copper disc fits between the end of the resistor and the tension spring. Even in otherwise "good" original caps, this disc can become "eaten away" over time due to the large current passing through it, and should be replaced, as it (rather than the resistor) may be the cause of an "out-of-spec" plug cap resistance reading. Use 1 per cap. Each:
    $ 5.95
    HCP13105 Aftermarket plug cap RESISTOR ELIMINATOR. This solid, zero-resistance, oxygen-free copper rod replaces the original resistor, thus creating a zero-resistance cap that will last "almost forever" at this level of electrical resistance. When using this resistor-eliminator rod, you should also switch from non-resistor spark plugs to resistor plugs to make up the difference in total system resistance. Since you normally replace spark plugs fairly regularly anyway, it can make sense to use a zero-resistance cap and resistor plugs, rather than a 5K resistor cap and zero-resistance plugs. For use in all of the following original style caps:
    T-131: used on all XJ550 models on all the inner cylinders (#2 and #3), and on all XJ900 S/SH models on all four cylinders.
    T-133: used on all air-cooled XJ650, XJ700, 1981-83 XJ750, XJ750-D, XJ750RL, XJ900 RK, RL, N/FN, and F models, and XJ1100 models on the inner cylinders (#2 and #3).
    T-135: used on all XJ550 models on all the outer cylinders (#1 and #4).
    T-140: used on all XJ700-X and XJ750-X models on all fours cylinders.
    $ 9.95
    SPARK PLUGS AND PLUG TOOLS:
    Spark Plugs:
    Original SPARK PLUGS on all XJ-series bike were the NGK brand. Although many other brands of plugs can be cross-referenced to the originals, NGK plugs offer both value and performance that is quite satisfactory, in both the original stock performance configurations, and in replacement standard or high-performance, platinum-tipped IRIDIUM IX resistive design plugs. All non-resistor plugs have zero ohms resistance, while all resistor plugs.....those with the letter "R" in their part number.....have a resistance rating of 5K (5,000) ohms.
    Although spark plugs are pretty cheap (and thus it's not too hard on the wallet to replace plugs with new ones as part of an ignition system troubleshooting routine), if you want to actually check their condition, here's how you do it:
    NOTE 1: some original and replacement plug caps are designed to be used on spark plugs that have their screw-on insulator stud top cap NUT removed, while other caps require that the cap nut remain in place. The following NGK plugs that we offer come with the threaded top cap installed onto the upper terminal (HCP1290, HCP1291, HCP1292, HCP1293, HCP1294, HCP1295, HCP13512, and HCP13515) and it may need to be removed before installation (depending on which plug caps you are using). You may find that you'll need a pair of pliers to grip the outside of the "nut" to break it loose, and then just unscrew it.
    If your plug caps DO require the use of a cap nut, and your plugs do NOT come with a cap nut, you can either remove (and re-use) the cap nuts from your old plugs, or purchase replacement cap nuts from us using part number HCP13518:
    $ 1.25
    $ 3.75
    NOTE 2: NGK plugs that begin with the letter "B" are 14mm plugs. Plugs that begin with the letter "D" are 12mm plugs. If the letter "R" appears within the plug model code, then it is a resistive plug, with resistive values being 5K ohms. When replacing an original non-resistive plug with any type of resistive plug, it is advisable to make a likewise reduction in the value of the resistive spark plug caps so that the entire plug circuit retains the same resistance as original.
    EXAMPLE: 1982 XJ650 Maxim models originally used the HCP1292 non-resistive (zero ohms) BP7ES spark plugs, along with 5,000 (5K) ohm plug caps on each plug. If you substitute a resistive plug (such as the HCP1293 Iridium plugs, or any other resistive plug) for the original non-resistive plug, then your spark plug + plug cap total resistance will increase from the original 5,000 (5K) ohms to 10,000 (10K) ohms. Either level of resistance will work okay; in fact, some engines were originally equipped with 5K resistance ca[s on the outer cylinders, and 10K resistance caps on the inner 2 cylinders, with the theory being that since the center cylinders run a bit hotter than the outer cylinders, the extra resistance (which creates a longer spark discharge time) will help to fire those hotter cylinders more reliably under high loads.....but the difference is basically un-noticeable under most street-driven conditions. Our recommendation, for a variety of reasons, is to achieve the same secondary resistance across all 4 cylinders, whether it is via the stock set-up (resistive caps and non-resistive spark plugs) or for some engines, a combination of resistive caps and resistive plugs (for example, 1986 XJ700 engines and 1985-up XJ900 engines).
    Recommended spark plug gaps:
    NOTE: you should never gap nor re-gap the high-performance Iridium spark plugs! All of the gapping information below pertains only to standard spark plugs. On Iridium plugs, always leave their gap "as-is" when they are removed from their box and for evermore!!
    On all engines equipped with non-Iridium plugs, you can experiment with plug gaps to try and increase performance slightly. Typically, opening up the gap slightly improves high-load and high-rpm performance; in fact, the ability to run larger plug gaps is the real reason why you should consider using high-output ignition coils…..they have the extra voltage needed to successfully bridge larger plug gaps than the stock coils do.
    http://www.motorcycleproject.com/text/high_perf_ignition_coils.html
    The stock gaps are given below. One user reports better overall performance on their XJ700-X (water-cooled engine) with the gap set at .048” (rather than the stock .028”).
    0.60 - 0.70mm (0.024 - 0.028")
    - all XJ550 engines
    - all XJ700-X and XJ750-X engines
    0.70 - 0.80mm (0.028 - 0.032")
    - all XJ650 engines
    - all XJ700 air-cooled engines
    - all XJ750 air-cooled engines
    - all XJ900 engines
    - all XJ1100 engines
    The recommended service interval for spark plugs calls for their replacement every 7,500 miles. Spark plugs should be torqued to 14 foot-pounds on all XJ models except the water-cooled XJ700-X and XJ750-X models, which only require 12 foot-pounds of torque.
    Spark plug knowledge you can use:
    Reading spark plugs:
    http://www.motorcycleproject.com/text/reading_plugs.html
    and
    http://www.wallaceracing.com/plug-reading-lm.html
    Spark plug heat ranges and plug etiquette:
    http://www.motorcycleproject.com/text/spark_plug_facts.html
    Believe it or not, there’s actually quite a bit of information on the proper installation and use of spark plugs that is not generally known or appreciated. A few minutes review can prevent a world of hurt, aka Don’t Lose Your Head!:
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 engines:
    HCP1296 Original D8EA NGK SPARK PLUG, stock non-resistive plug is correct for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1985 XJ700-X models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 9.95
    HCP1296SET4 Original D8EA NGK SPARK PLUGS, set of 4.
    $ 38.95
    HCP13514 Standard replacement DR8EA NGK SPARK PLUG, 5K ohms resistive plug for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    HCP13514SET4 Standard replacement DR8EA NGK SPARK PLUGS, set of 4.
    $ 24.95
    HCP1297 High-performance replacement NGK IRIDIUM SPARK PLUG, DR8EIX 5K ohms resistive plug for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ700-X, and XJ750-X models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and may result in electrode breakage! However, users have reported slightly increased performance when the cap on these type plugs is set to about .055". Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. . NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    HCP1297SET4 High-performance replacement NGK IRIDIUM SPARK PLUGS, set of 4.
    $ 57.95
    XJ600 Seca II engines:
    HCP20107 Original CR8E NGK SPARK PLUG, stock resistive plug is correct for all XJ600 Seca II models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 7.95
    HCP20107SET4 Original CR8E NGK SPARK PLUGS, set of 4.
    $ 29.95
    HCP20355 High-performance replacement NGK IRIDIUM SPARK PLUG, CR8EIX 5K ohms resistive plug for all XJ600 Seca II models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    HCP20355SET4 High-performance replacement NGK IRIDIUM SPARK PLUGS, set of 4.
    $ 57.95
    XJ650 engines:
    HCP1292 Original BP7ES NGK SPARK PLUG, stock non-resistive plug is correct for all XJ650 (except Turbo) models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 11.95
    HCP1292SET4 Original BP7ES NGK SPARK PLUGS, set of 4.
    $ 44.95
    HCP13513 Standard replacement BPR7ES NGK SPARK PLUG, 5K ohms resistive plug for all XJ650 (except Turbo) models. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. NOTE: this spark plug has a non-removable "cap nut" which restricts its use to only certain spark plug caps. Each:
    $ 6.95
    HCP13513SET4 Standard replacement BPR7ES NGK SPARK PLUGS, set of 4.
    $ 24.95
    HCP1293 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR7EIX 5K ohms resistive plug for all XJ650 (except Turbo) models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    HCP1293SET4 High-performance replacement NGK IRIDIUM SPARK PLUGS, set of 4.
    $ 58.95
    HCP1294 Original BP8ES NGK SPARK PLUG, stock non-resistive plug is correct for all XJ650 Turbo models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 10.95
    HCP1294SET4 Original BP8ES NGK SPARK PLUGS, set of 4.
    $ 39.95
    HCP1295 Standard replacement BPR8ES NGK SPARK PLUG, 5K ohms resistive plug for all XJ650 Turbo models. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    HCP1295SET4 Standard replacement BPR8ES NGK SPARK PLUGS, set of 4.
    $ 24.95
    HCP13515 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR8EIX 5K ohms resistive plug for all XJ650 Turbo models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    HCP13515SET4 High-performance replacement NGK IRIDIUM SPARK PLUGS, set of 4.
    $ 58.95
    XJ700 engines:
    HCP1294 Original BP8ES NGK SPARK PLUG, stock non-resistive plug is correct for all 1985 XJ700 non-X models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 10.95
    $ 39.95
    HCP1295 Original BPR8ES NGK SPARK PLUG, stock 5K ohms resistive plug is correct for all 1986 XJ700 non-X models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 4695
    HCP1295SET4 Original BPR8ES NGK SPARK PLUGS, set of 4.
    $ 24.95
    HCP13515 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR8EIX 5K ohms resistive plug for all XJ700 non-X models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs on 1985 model engines (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    $ 58.95
    $ 6.95
    $ 24.95
    HCP1298 Original DR8ESL NGK SPARK PLUG, stock 5K ohms resistive plug is correct for all 1986 XJ700-X and XJ750-X models. NOTE: it is recommended that when you use these resistive plugs on 1985 model XJ700-X engines (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    HCP1298SET4 Original DR8ESL NGK SPARK PLUGS, set of 4.
    $ 24.95
    HCP13514 Standard replacement DR8EA NGK SPARK PLUG, 5K ohms resistive plug for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    $ 24.95
    HCP1297 High-performance replacement NGK IRIDIUM SPARK PLUG, DR8EIX 5K ohms resistive plug for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ700-X, and XJ750-X models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and may result in electrode breakage! However, users have reported slightly increased performance when the cap on these type plugs is set to about .055". Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs on 1985 model XJ700-X engines (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    $ 58.95
    XJ750 engines:
    HCP1292 Original BP7ES NGK SPARK PLUG, stock non-resistive plug is correct for all 1981-83 XJ750 models, XJ750-D models, and all XJ750 Police (24L and 37H) models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 11.95
    $ 44.95
    HCP13513 Standard replacement BPR7ES NGK SPARK PLUG, 5K ohms resistive plug for all 1981-83 XJ750 models, XJ750-D models, and all XJ750 Police (24L and 37H) models. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. NOTE: this spark plug has a non-removable "cap nut" which restricts its use to only certain spark plug caps. Each:
    $ 6.95
    $ 24.95
    HCP1293 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR7EIX 5K ohms resistive plug for all 1981-83 XJ750 models, XJ750-D models, and all XJ750 Police (24L and 37H) models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    $ 58.95
    HCP1294 Original BP8ES NGK SPARK PLUG, stock non-resistive plug is correct for all XJ750RL models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 10.95
    $ 39.95
    HCP1295 Standard replacement BPR8ES NGK SPARK PLUG, 5K ohms resistive plug for XJ750RL models. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    $ 24.95
    HCP13515 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR8EIX 5K ohms resistive plug for XJ750RL models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    $ 58.95
    HCP1298 Original DR8ESL NGK SPARK PLUG, stock 5K ohms resistive plug is correct for all XJ750-X models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    $ 24.95
    HCP1297 High-performance replacement NGK IRIDIUM SPARK PLUG, DR8EIX 5K ohms resistive plug for all XJ750-X models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    $ 58.95
    XJ900 engines:
    HCP1294 Original BP8ES NGK SPARK PLUG, stock non-resistive plug is correct for all XJ900RK and RL models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 10.95
    $ 39.95
    HCP1295 Original BPR8ES NGK SPARK PLUG, stock 5K ohms resistive plug is correct for all XJ900 N/FN and F models. This plug can also be used as a substitute for the non-resistive plug on XJ900RK and RL engines. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs on XJ900RK and RL engines) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    $ 24.95
    HCP13515 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR8EIX 5K ohms resistive plug for all XJ900RK, RL, N/FN, and F models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs on XJ900RK and RL engines) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    $ 58.95
    XJ1100 and all XS1100 engines:
    HCP1290 Original BP6ES NGK SPARK PLUG, stock non-resistive plug is correct for all XS1100 and XJ1100 models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 11.95
    HCP1290SET4 Original BP6ES NGK SPARK PLUGS, set of 4.
    $ 44.95
    HCP13512 Standard replacement BPR6ES NGK SPARK PLUG, 5K ohms resistive plug for all XS1100 and XJ1100 models. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    HCP13512SET4 Standard replacement BPR6ES NGK SPARK PLUGS, set of 4.
    $ 24.95
    HCP1291 High-performance replacement NGK IRIDIUM SPARK PLUG, BPR6EIX 5K ohms resistive plug for all XS1100 and XJ1100 models. NOTE: Iridium plugs should not be gapped, they are designed to be used "as is" out of the box. Attempting to gap/re-gap these plugs can and will likely result in electrode breakage! Also, because of their design, the color of the ceramic insulator around the center electrode will typically not show much color change as is common on standard plugs, and thus the ceramic color cannot be counted on to reveal mixture condition (i.e. lean or rich) accurately. NOTE: it is recommended that when you use these resistive plugs (in place of the stock non-resistive plugs) that you also reduce the resistance value of the spark plug CAP by 5K ohms in order to keep your total secondary path resistance at the original value. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 14.95
    HCP1291SET4 High-performance replacement NGK IRIDIUM SPARK PLUGS, set of 4.
    $ 58.95
    FZ700, FZX700, FZ750, FZR750, FZR1000, FJ1100, and FJ1200 engines:
    HCP27698 Original DP9EA-0 NGK SPARK PLUG, stock non-resistive plug is correct for all of the following models: 1987 FZ700, 1986-87 FZX700 Fazer, 1985-86 and 1988 FZ750, 1987-88 FZR750R, 1987-90 and 1994-95 FZR1000, 1984-85 FJ1100, 1986-87 and 1989-93 FJ1200, 1986 SRX600, and 1984-89 XT600 models. This spark plug has a threaded stud on top and will accept any of the spark plug caps that we offer. Each:
    $ 6.95
    HCP27698SET4 Original BP7ES NGK SPARK PLUGS, set of 4.
    $ 24.95
    Spark Plug Tools:
    HCP8674 Aftermarket deep-reach thinwall SPARK PLUG SOCKET, copy of the original tool used on XJ550 and 1984-85 FJ600 models. Includes the short "breaker bar".
    $ 24.95
    HCP9721 Aftermarket deep-reach thinwall SPARK PLUG SOCKET, copy of the original tool used on all XJ650, XJ700 air-cooled, all XJ750 air-cooled, XJ900RK, RL, N, F, and FN models, and all XJ1100 models. Includes the short "breaker bar".
    $ 24.95
    The following aftermarket PLUG SOCKETS are special deep-reach, thin wall design tools that are specially designed to allow use on XJ700-X and XJ750-X models, where the spark plug lives deep inside a recessed well on the cam cover. Typical plug socket tools are far too big in their outside diameter to fit into this well. Although not necessary, these sockets will also work fine on all XJ550, 1984-85 FJ600, 1992-98 XJ600 Seca II, and XJ900 S/SH model spark plugs also.
    HCP9691 Aftermarket deep-reach thinwall SPARK PLUG SOCKET, copy of the original tool used on all XJ700-X water-cooled and XJ750-X water-cooled models models. Has a 17mm hex at the top end of a tool to accept a socket or wrench.
    $ 24.95
    HCP8552 Aftermarket deep-reach thinwall SPARK PLUG SOCKET, 3/8" square drive, needs to be used with a 3" extension to clear the valve cover on all "X" models.
    $ 32.95
    HCP9123 Aftermarket 3" socket EXTENSION BAR, chrome plated, 3/8" drive, for use with the HCP8552 socket above. Each:
    $ 14.95
    HCP8430 Aftermarket deep-reach thinwall SPARK PLUG SOCKET, 3/8" square drive, 13/16" hex wrench drive, or can be used with a straight round breaker bar, requires the use of a 1"-to-1.75" extension to clear the valve cover on all "X" models.
    $ 39.95
    HCP9124 Aftermarket 1-3/4" socket EXTENSION BAR, chrome plated, 3/8" drive, for use with the HCP8430 socket above. Each:
    $ 14.95
    HCP28131 Aftermarket THREAD CHASER AND CLEAN-UP TAP, made from a high-speed uncoated steel. For the following holes:
    - 12mm spark plug holes on all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600, XJ700-X, XJ750-X, 1987 FZ700, 1986-87 FZX700 Fazer, 1985-86 and 1988 FZ750, 1987 FZR750R, and 1987-88 FZR1000 engines. This deep-reach tap has a socket-drive head for constricted-space clearance, and will allow access to the plug hole even in the recessed XJ700-X / XJ750-X heads.
    $ 27.95
    HCP6378 Aftermarket THREAD CHASER AND CLEAN-UP TAP, made from a high-speed uncoated steel. For the following holes:
    - 14mm spark plug holes on all XJ650, XJ700 air-cooled heads, all XJ750 air-cooled heads, XJ900, XJ1100, and all XS1100 engines. For use by hand or with a 13/16" socket. Each:
    $ 16.95
    HCP28170 Aftermarket thread tap or EZ-out extractor TAP HANDLE, featuring offset tap handles and fully adjustable head for all m3-m12 size taps and size 0 to ½” extractors. This is the proper way to hold a tap or extractor to insure that the force is directed straight down and doesn’t “wobble” as you are cutting, reaming, or extracting. Much better than using pliers or vise-grips to hold the tool……..
    $ 17.95
    NOTE: always use a proper thread-cutting oil or lubricant before using thread taps! Thin motor oils work fine when merely doing a "clean-up" thread chase; a real cutting fluid should be obtained if a threaded bore needs to be truly cut:
    HCP2402 Aftermarket machinist-grade professional THREAD CUTTING FLUID, for use when cutting into aluminum or other soft metal. 4-ounce non-aerosol can.
    $ 8.95
    HCP2403 Aftermarket machinist-grade professional THREAD CUTTING FLUID, for use when cutting into steel or other ferrous metals. 4-ounce non-aerosol can.
    $ 8.95
    spt22) Spark plug drain well BRUSH and BLOCK-OFF PLUGS allow you to clean out the water-drain wells in the cylinder heads on all XJ700-X and XJ750-X (water-cooled) engines. These drain passages are only accessible by removing the cylinder head decorative, ribbed side covers (which will expose the small, center well drain-hole on the side of the head). This passage hole is used to drain water and associated grit and gunk from the spark plug wells on each side of the head (i.e. the left side hole drains plugs #1 and #2; the right side hole drains wells on the #3 and #4 plugs). Clogged drain ports allow water and other junk to build up in the plug wells, with predictable results. Our extra-long WIRE-BRISTLE BRUSH is the correct size and depth to purge these passages, while the BLOCK-OFF PLUGS replace the spark plugs while the cleaning procedure is being performed (the spark plugs must be removed to allow the brush clearance to pass all the way thru the passage).
    The procedure to clean these wells ---- which, by the way, is not mentioned at all in the service manual ---- is as follows:
    1) remove the decorative head side cover.
    2) remove the spark plug cap/boot…….leave the spark plugs in for now.
    3) using compressed air, blow out any debris in the wells.
    4) remove the two spark plugs on that “side” of the head you are working on.
    5) install the low-profile block-off plugs into the two spark plug holes.
    6) use the wire-bristle brush to clean out the drain passage completely. Any debris will be “pushed” into the plug wells (that’s why you need to install the block-off plugs!).
    7) using compressed air, blow out any debris in the wells.
    8) remove the low-profile block-off plugs, and re-install the spark plugs, plug cap/boot, and decorative side cover.
    9) repeat steps 1-8 for the other side.
    10) this procedure should be done once every few years or so.
    HCP21394 Aftermarket STAINLESS STEEL WIRE-BRISTLE CLEANING BRUSH, perfect size for cleaning out the spark plug well drain passage in the cylinder head of all the built-up gunk and debris. For use on all XJ700-X and XJ750-X engines..
    $ 9.95
    HCP21367SET2 Aftermarket spark plug hole BLOCK-OFF PLUGS, these low-profile plugs are the correct size to replace the spark plugs while cleaning out the spark plug well drain passage in the cylinder head. For use on all XJ700-X and XJ750-X engines.. Set of 2 plugs:
    $ 13.95
    HCP21444 Aftermarket spark plug well drain passages CLEAN-OUT KIT, contains the HCP21394 brush and two of the HCP21367 plugs, everything you’ll need to perform the cleaning procedure.
    $ 21.95
  15. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Starting System: Battery, Battery Cables, Solenoid, Starter Motor, Starter Switch, Relay, and related hardware, etc.
    STARTING SYSTEM PARTS:
    BATTERIES:
    Brand new OEM and replacement batteries will certainly solve those slow or no-start problems, but before you buy a battery............read on to determine whether you really need a battery, or whether your situation is due to some other cause.
    Of course, if you determine that your battery is ready to take that trip to the great lead-acid Heaven in the sky......or, actually, to a recycling center, such as a local auto parts store........then we have a variety of choices for your specific bike.
    How do I know if my battery is good?:
    Is it your battery, or your charging system, or something in-between?
    The best way to know for sure is to use a multimeter (voltmeter) attached directly to your battery positive and negative terminals, and observe the following:
    1) with the engine and all electrical accessories off, the battery should read a minimum of 12.8 volts DC. If not, the battery is either not fully charged, or it is bad (it is incapable of holding a full charge). Charge the battery fully and check again; if the reading is less than 12.8 volts, the battery is bad and should be replaced.
    NOTE: most manuals describe checking the specific gravity of each battery cell electrolyte (fluid) as the preferred method of checking the condition of the battery. This reading should be between 1.2650 - 1.280 per cell. If a fully charged battery cannot reach these levels in all cells, then that cell is bad and the battery should be replaced.
    2) If the first test above passes, leave the multimeter hooked up to the battery terminals, and press the starter button. While the starter is engaged (but before the bike starts), the battery voltage should be 9.5 volts or greater. If not, then this signals either a bad battery, very dirty or weak electrical connections, or it could be a incredibly problematic starter motor (not likely; it's probably the battery!).
    3) if you run into this specific problem:
    * "There were a few times when I cranked it, that it ALMOST started. It would start to fire immediately as I let off the start button. But it just wouldn't catch.
    Then this is a symptom of a weak battery, due to any number of causes.......
    What happens is that as the starter is being engaged, it gobbles up battery voltage. As soon as the start button is released, you now have full battery voltage available TO THE IGNITION CIRCUIT (including the pick-ups, the TCI, and especially the coils), and in that instant when you release the starter button, the coils get enough voltage to produce an adequate spark while the motor is still (by inertia) turning over. If everything is in a great state of tune, the bike will normally kick over. If not, you get the "almost fires" situation explained above, so.........
    Test the battery voltage WHILE THE STARTER IS ENGAGED (a voltmeter across the + and - terminals of the battery is all that's needed). It should remain above 9.5 volts while the starter motor is engaged but without the engine running. If it drops below that level while the starter is active, then that's the "problem", and the cause of that problem must be determined and remedied (usually a sign of a bad battery, or it could be a incredibly problematic starter motor).
    4) Your charging system output VOLTAGE should be checked, again at the battery terminals, while the engine is running. The measured voltage should be:
    * 14.2 - 14.8 Volts at about 2,000 rpms for all non-X models, and the same voltage for "X" models, but at about 3,000 rpms. Again, you would measure these voltages at the battery terminals with your voltmeter.
    NOTE: If your alternator is outputting more than 14.8 volts to the battery, your regulator-rectifier unit is bad and should be replaced. Over-charging a battery will quickly ruin it, and may cause severe damage or failure of other electrical components, such as the TCI or the computer monitor system (on bikes so equipped).
    Here's your cheat sheet on all of the above:
    Static Battery Voltage Test
    Prior to conducting this test, make sure the battery has not been
    recently charged. You must wait at least one hour after charging
    your battery to conduct this test.
    a) Adjust voltmeter to DC volts (20 volt range).
    b) Place voltmeter leads to the battery terminals (positive to positive and negative to negative).
    c) Read voltage and refer to the chart below.
    State of Charge:
    100% Charged with Sulfate Stop:
    Using a syringe Hydrometer: 1.280
    Using a Digital Voltmeter: 12.80 volts
    Using a Floating-Ball Hydrometer: 5 balls floating
    100% Charged:
    Using a syringe Hydrometer: 1.265
    Using a Digital Voltmeter: 12.60 volts
    Using a Floating-Ball Hydrometer: 4 balls floating
    75% Charged:
    Using a syringe Hydrometer: 1.210
    Using a Digital Voltmeter: 12.40 volts
    Using a Floating-Ball Hydrometer: 3 balls floating
    50% Charged:
    Using a syringe Hydrometer: 1.160
    Using a Digital Voltmeter: 12.10 volts
    Using a Floating-Ball Hydrometer: 2 balls floating
    25% Charged:
    Using a syringe Hydrometer: 1.120
    Using a Digital Voltmeter: 11.90 volts
    Using a Floating-Ball Hydrometer: 1 ball floating
    0% Charged:
    Using a syringe Hydrometer: less than 1.100
    Using a Digital Voltmeter: less than 11.80 volts
    Using a Floating-Ball Hydrometer: 0 balls floating
    Starting Load Test:
    b) Place voltmeter leads to the battery terminals (positive to positive and negative to negative) .
    c) Watch the voltmeter as you start your motorcycle, but before the engine is running.
    d) If the voltage drops below 9.5 volts, the battery has very low capacity and should be replaced.
    Basic System Operation Test:
    To test and see if the alternator is actually getting power to it (along the brown and green wires) you verify whether a magnetic field is being created inside the rotor and stator. Be sure to use a thin feeler gauge when performing this test, since the magnetic field being created is not all that strong outside the generator cover….but it will exist if the system is performing.
    or
    Hold the extended feeler gauge blade and 1/4” away from the AC generator cover and when the key is turned on the feeler gauge should pull towards the cover. The rotor should be receiving maximum excitation when the engine is not running. You should be able to measure about 12-volts on the brown wire, and approximately 1.8-volts on the green wire. The voltage regulator controls the low side (green wire) and will raise and lower the voltage based on internal voltage sensing within the regulator.
    Charging System Tests:
    c) Start the engine.
    d) Bring engine up to approximately 2,500 rpm's.
    e) Compare the voltage reading to the specification given below:
    For all XJ-series models, the maximum available charging output VOLTAGE should be as follows (all values are approximate):
    * approximately 500-2000 rpms: 12.6 volts gradually increasing to 14.2 volts
    * 2000+ rpms: 14.2 volts up to about 14.8 volts, with a maximum of 14.8 volts (all models except XJ700-X and XJ750-X)
    * 3000+ rpms: 14.2 volts up to about 14.8 volts, with a maximum of 14.8 volts (all XJ700-X and XJ750-X)
    NOTE: the voltage reading must be approximately 14.0 - 14.5 volts to properly charge an AGM battery......anything less, and you will quickly kill these type batteries!
    If your charging voltages are too low, suspect the alternator brushes first, then perform the alternator stator and rotor checks as described in the Alternator Section elsewhere in the catalog.
    If your charging voltages are too high, suspect your Regulator - Rectifier unit first, and perhaps dirty or corroded electrical terminals. The procedure for checking these is too detailed to describe here, and you should consult your service manual for additional details.
    5) Check the condition of your main circuit terminals.....they should be zestfully clean and un-corroded, or you're primed for a variety of problems......not only will your circuits not be getting full power out of your battery, but to add insult to injury, your charging system may think that the battery needs more juice, and so it starts cranking out amps like there's no tomorrow. It's pretty safe to say that neither of those two occurrences qualify as a Good Thing (tm), so...........start at the beginning, and inspect and clean (and then protect, like with di-electric grease or equivalent) all the terminal connection points:
    * the positive battery post connection to the positive battery cable.
    * the positive battery cable connection to the starter relay (or "solenoid").
    * the main harness terminal connector from the starter relay.
    * the main lead from the starter relay to the starter motor (both ends).
    * the "main fuse" contacts inside the fusebox.
    * the battery ground cable contacts at both the engine case and at the negative battery post (poor ground are just as bad as poor positive feeds; after all, it takes two to tango, or to complete a circuit, and electricity doesn't care where the restriction occurs).
    Battery and Charging System Results:
    Okay, now with all of the above out of the way, you should be able to determine whether you need a new battery, or not. There's no need to waste money on a replacement battery if it's not the root cause of your problems. If your battery is good, but your charging system or electrical system isn't, then spend your time and money on fixing the root causes of the problem........such efforts will also help prevent you from murdering your otherwise good battery.
    But assuming that your battery is ready to be retired, the question then becomes, which battery?----as they come in a variety of types and price ranges (and, as with most things in life, the more you spend, typically, the better quality you'll get when it comes to a "commodity" product such as a battery).
    Basically, motorcycle batteries are of two basic types, the flooded cell type (sometimes called a "wet cell" or "conventional" battery) and the AGM or "absorbed glass mat" type.
    Your original-style, Yuasa-brand battery was a "conventional" type, and these are now available in both their original configuration, or in a high-performance version that can output more amperage than the standard style-----and this is typically a cost-effective upgrade.
    AGM batteries feature cell separators made of fiberglass mats that minimize the movement of electrolyte (acid), and prevent spillage if tipped over on their side. The acid formulation in these also typically a bit stronger compared to flooded cell batteries, which accounts for their typically higher output. AGM batteries are of the permanently sealed, "maintenance-free" design, thus never requiring the further addition of water or acid.
    The charging system of many modern motorcycles that come factory-equipped with an AGM type battery uses a regulator/rectifier that outputs a slightly higher voltage than a flooded cell battery requires. Using an AGM in almost any motorcycle will usually work well, while using a flooded cell battery in a bike designed for an AGM type will often result in overcharging and quick boiling of the electrolyte solution -- it isn't long before the battery is dry and possibly ruined. Of course, all of our XJ-series bikes came originally with a conventional wet ("flooded") type battery, so replacing them with the AGM types is not a problem or issue.
    AGM type batteries are also more tolerant of sitting for long periods with minimum formation of lead sulfate (sulfation) on the plates. They can usually be charged at a slightly higher rate and in general provide better performance over the long haul. However, once AGM batteries are "dead"; they're dead, and cannot usually be brought back to life (even for a short amount of time) like a conventional battery can.
    Finally, be aware that while AGM batteries are sometimes incorrectly called "gel cells batteries", a true "gel cell" type of battery is quite a different animal, and is actually not recommended for motorcycle use.
    Battery FAQ's:
    What is a conventional (or "wet" or "flooded") battery?:
    These are the standard automotive type design battery, with individual push-in or screw-in battery cell access caps, a vented design, also referred to as a "lead-acid" design, and need the periodic addition of distilled water to "top up" the fluid level.
    What is a "maintenance-free" battery?:
    Maintenance-free batteries do not require the addition of water after their initial fill of their water/acid electrolytic solution. It means that it is a "sealed" battery, with no filler caps. Note that while conventional "wet" batteries may be available in a sealed, maintenance-free variety, AGM batteries are always of this sealed, maintenance-fee type.
    What is a "high-performance" battery?:
    Due to plate design and other factors, high-performance batteries have a denser charge ability and will output more amps for a longer period of time (this is the so-called *CCA rating number that is used to describe a battery) before full discharge. Although there have been some interesting technological "enhancements" to the basic conventional battery design over the years, almost all "high-performance" (meaning, higher-capacity) batteries rely on more lead material in their plates, resulting in a physically heavier battery. More lead = more money to manufacture and transport the battery, which is why these batteries cost more.
    *NOTE: CCA (Cold Cranking Amperes) is the most popular industry rating and is a measurement of the current a fully charged battery can deliver for 30 seconds and maintain a voltage of 7.2 volts (12 volt battery) at a temperature of -18*-C (0* F).
    What is an AGM battery?:
    AGM is an abbreviation for "absorbed glass mat", and the liquid electrolyte contains high purity sulfuric acid and totally demineralized, deionized water (no phosphoric acid).
    In this battery design, almost all of the battery sulphuric acid solution --- which, by the way, is typically also at a higher concentration level than of what is used in conventional "wet-cell" batteries --- is absorbed into glass mat separators which are sandwiched between the lead plates. It's a totally sealed and maintenance free design. There are no discharge tubes or fillers caps, which eliminates the need to maintain water levels and offers no concern about acid leaks on valuable parts and accessories.
    AGM batteries offer the following advantages over conventional batteries because:
    a) their sealed, maintenance-free design means you never have to worry about checking nor maintaining their fluid levels.
    b) AGM batteries, unless physically damaged, will not leak or corrode your paint and chrome.
    c) they have less internal resistance which offers more cranking amperage than wet batteries.
    d) their lower self-discharge rate means they can sit for extended periods of time without constant monitoring. A conventional wet battery discharges 15% a month, whereas AGM batteries discharge only 2-3% a month.
    e) a longer service life be expected from an AGM battery-----the main reason conventional wet batteries fail is due to water levels that are not properly monitored and maintained. Conventional batteries are also not very heat nor vibration resistant. AGM batteries are much more heat and vibration resistant than conventional batteries, and of course are maintenance-free, all of which contribute to their longer service life.
    f) however, AGM batteries are more sensitive to both undercharge and overcharge conditions than conventional wet-cell, lead-acid batteries. They must be maintained correctly, and use a quality "smart" charger that does not stray too much, or too long, into the "overcharge" range of charging.
    What is a gel-cell battery?:
    Gel batteries contain a gelled electrolyte which is “Thixotropic”. This Thixotropic gelled electrolyte contains sulfuric acid, fumed silica, pure demineralized and deionized water, and a phosphoric acid. The electrolyte in Gel batteries does not flow like a normal liquid; it has the consistency and look of petroleum jelly.
    AGM and Gel batteries compared:
    Because of the physical properties of the Thixotropic gelled electrolyte in Gel batteries, Gel batteries tend to lose power faster than AGM batteries in temperatures below 32°F. AGM batteries, on the other hand, excel in high current and high power applications as well as extremely cold environments, making them ideal for cold weather riding or snowmobiling and also for running juice-drawing aftermarket accessories.
    Another key difference between AGM and Gel batteries is depth of discharge. Gel batteries are more acid starved than AGM batteries, which better protects Gel batteries’ plates, making these types of batteries best suited for deep discharge applications. Although deep discharge is rarely necessary in powersports riding, however, and Gel batteries have drawbacks for powersports starting applications. Gel batteries typically have a higher price point, shorter life span and less size compatibility than their AGM counterparts.
    In the spectrum of conventional lead acid, AGM and Gel batteries, AGM batteries typically offer the best starting power, durability and value for powersports applications such as motorcycles, ATVs and snowmobiles.
    What is a lithium battery?:
    Advantages Of Li-iron-phosphate (LiFePO4) Batteries:
    Slow Discharge Rate: lithium-iron batteries have a huge advantage here because of its very slow discharge rate.
    Weight (and thus size): Li-iron batteries have very low weights when compared to lead-acid batteries of the same specification. Because of this, they are preferred in racing bikes or in any case when the rider needs to achieve high performance from their bikes.
    Design: LiFePO4 batteries can be fitted anywhere onto the bike, such as upside down or under seats, wherever the rider wants according to their needs.
    Warranty: Li-iron batteries often have longer warranties than any other batteries. Some bike manufacturers even provide between three and five-year warranties if the battery is installed during the manufacturing process.
    Disadvantages of Li-iron (LiFePO4) batteries:
    Usage Limitations: LiFePO4 batteries cannot be used in conjunction with a total loss ignition system.
    Charging System: the charging system used with the this type battery should be capable of maintaining a steady charging rate within the range of 13.6 to 14.4 volts. In the case of old or classic bikes, those that do not have such a charging capacity need extra upgrades. This can be costly and not always successful as it may, in certain cases, cause damage to the original parts.
    Water: Li-iron batteries can handle only a small amount of water spray. They are not suitable when there is a significant danger of water ingress.
    Discharge problem: if the lithium-iron battery is completely discharged, it will need to be charged fully before the next use using the charger supplied by the manufacturer. If it is not charged fully, the battery may sustain damage and its efficiency will start to degrade, reducing the life and use cycle of the battery.
    Cold Temperatures: one of the most overlooked disadvantages of the Li-iron battery in relation to motorcycles is its performance in low temperatures. During the colder seasons, lithium batteries can take longer to work, the bike requiring some time to start. When this happens the rider must first warm up the engine by leaving it on for some time and then click on the starter. The Li-ion battery will only be able to supply proper voltage once it is heated to the required level.
    Cost: lithium-iron batteries cost 30-200% more than a high-quality conventional or AGM battery, and their advantages must be weighed against their initial higher cost. Also, the quality of Lithium-Iron batteries varies somewhat dramatically depending on cost; the cheaper ones don’t have the internal safeguards and Battery Management Systems within their circuitry, which can lead to shortened life/failures.
    Final Thoughts:
    Our take is that unless you have extraordinary power or design demands, etc. then a good lead-acid battery (such as an permanently-sealed/maintenance-free AGM battery) is typically the better (and less-expensive) way to go:
    https://advrider.com/f/threads/moto...el-wet-lithium-iron-phosphate-lifepo4.757934
    What are the electrical specifications for an original battery?:
    all XJ550 and XJ650 models:
    Capacity: 12ah
    Charging rate: 10 hours @ 1.2A
    CCA's: 113
    all XJ700, XJ750, and XJ900RK models:
    Capacity: 14ah
    Charging rate: 10 hours @ 1.4A
    CCA's: approximately 130
    XJ1100 and XS1100 models:
    Capacity: 20ah
    Charging rate: 10 hours @ 2.0A
    CCA's: 260
    How should a battery be maintained?:
    Good battery maintenance allows you to get the maximum power and life from your battery:
    a) always keep the acid level between lower and upper lines on front side of the container (for conventional type batteries that are not sealed).
    b) do not let the battery remain in a discharged condition for any length of time. Discover and remedy the cause of such a condition immediately.
    c) when a bike is stored for over 30 days at a time, use an automatic battery charger to maintain a proper storage charge.
    d) keep the top of the battery case clean, dry, and free of dirt or moisture.
    e) clean the battery terminals to prevent corrosion, and treat them to some anti-corrosion spray or coat their exposed areas with di-electric grease. Do not over-tighten the terminal cinch bolts!
    f) inspect the battery vent tube regularly, ensuring that it is not bent, twisted or clogged, especially at the bottom of the tube, where it discharges towards the ground......this is the most common place where the tube will get clogged via road debris, etc.
    g) protect the battery from strong impacts or shocks.
    How long will my new battery live?:
    Regardless of battery type or manufacture, you can expect a properly activated, and properly maintained battery (meaning it's neither overcharged nor overly or repeatedly allowed to become fully discharged) to give you 2-4 solid years of life.
    Heat is the big enemy of motorcycle batteries----they'll last much longer in a cool climate than a hot one. The self-discharge rate of a battery can run as high as 3% a day in hot weather with a flooded cell battery to about 1% or less per day with an AGM type. Overcharging a battery also overheats a battery---a double whammy! Make sure your charging system is in good order to get the maximum life from your battery.
    Constant, repeated complete discharges of a battery will also reduce their lifespan. There's only so many times you can "drain the well" before a battery electrically gives up the ghost.
    What are some of the best ways to kill a battery?:
    a) Let a discharged battery freeze. Fully discharged batteries freeze at about +25-F, or just below the freezing temperature of water. Fully charged batteries freeze at about 75-F below zero. 'Nuff said........
    b) Let a battery overheat.
    c) Overcharge the battery........either via the use of an incorrect (or poor quality or defective battery charger), a charging system regulator gone bad, or highly corroded (high resistance) wiring harness connections within the system.
    d) "Quick-charge" the battery using an incorrect style battery charger.
    e) Allow the fluid level (for wet or conventional batteries) to get too low. This exposes the plates to air, which cause the plates to "sulfate", which leads to increased electrical resistance and a drop in power output.
    f) Run a battery down into deep-discharge. Each full discharge event causes sulfate build-up on the lead plates. Do this enough times.....like when your charging system isn't outputting properly........and you'll kill a battery pretty quickly.
    g) On conventional batteries, do not use regular tap water to fill or re-fill the battery. Tap water contains minerals and metals that will shorten the life of a battery. Always use distilled or de-mineralized water to fill a battery.
    What about my original battery fluid level sensor?:
    Some original models with the "computer" dashboard monitor system (1982 XJ750 Maxim, 1981-83 XJ750 Seca, and XJ1100 models) had a low-battery-fluid warning light on the dash, triggered by a fluid-level sensor which replaced one of the battery cell screw-in caps. If the fluid level in that battery cell was too low to trigger the sensor, the circuit in the computer dash warning system would read that as a low-voltage condition and would then illuminate the warning light.
    So of course, the first issue in regards to these sensors is: if the light is on, first check your fluid level!
    But other issues arise: it could be that the tip of the sensor has become dirty, or encrusted with deposits, in which case even if the fluid level is fine, it will still sense a low-voltage condition. This can be remedied with a gentle cleaning of the sensor tip (steel wool, brass bristle brush, etc.).
    Also, the sensor reads voltage, and without enough voltage to trigger the computer system, the light illuminates. The wire path from the sensor goes through your ignition switch and if this switch has electrically "dirty" internal contacts, then that can add enough resistance to cut the voltage signal enough to trigger the dash "low Batt" warning light or display, even though the sensor is fine and the fluid level is okay! So: remove the ignition switch, and its bottom plate, and clean the copper contacts inside the ignition switch.
    Finally: a few issues arise with replacement batteries in regards to the use of sensors:
    a) some batteries are designed to allow you to re-use your original sensor (we also offer a replacement sensor in case your original is missing or damaged). These conventional-style batteries will feature screw-in caps and your original sensor will screw right in place (by the way, the sensor must be installed in the 4th cell over from the negative post or it will not work correctly and may damage your dash computer!).
    b) but some aftermarket batteries, even though they have screw-in caps, have a different "plate depth" internally, and even though the original sensor will screw into the cell port, the sensor tip will be too deep and contact the lead plates in the battery which will cause battery, sensor, and dash computer damage! Thus you must be careful with aftermarket batteries, and measure the depth of the cell, and if it's shorter than that of an original battery, you must use plastic spacer shims (washers) to space an original sensor "upwards" to the proper depth for such batteries, or carefully trim the sensor tip shorter so that it does not ever contact the internal plates.
    c) other aftermarket batteries will have push-in rather than screw-in caps. An original sensor will not fit into these batteries unless that one cell port is "threaded" to accept the sensor. This can be best accomplished by gently screwing into the cell port a proper sized and thread steel bolt, and thus "cutting threads" of the proper size into that cell port opening. Now your original screw-in sensor can be properly installed; however, the same warnings as in issue "b" above (in regards to the depth of the cell) must be observed and remedied, if necessary. Of course, make sure that as you cut these new threads into the battery case, that any plastic "shavings" that are created by this threading process do not get into (or are removed) the battery cell.
    d) some of the replacement Yuasa batteries that we offer come with a replacement sensor.......in which case, you discard (or save) your original sensor and just hook up your sensor wire lead to this new sensor.
    e) some aftermarket batteries.....such as the replacement "maintenance-free" (sealed) and all AGM batteries......have no "cell caps" and thus are not going to accept a sensor, at all. This present a problem, since the lack of voltage to the dash computer makes it think that there is a battery problem, and the red warning light or display message is always on or blinking at you. Although you can "reset" this annoyance away, there are two other solutions available to you in order to disable or bypass this function:
    i) on models that use a warning light, you can simply remove the bulb from your dash! No more "warning" of a low battery fluid condition (except on the LCD display screen), but no more annoying blinking light, either.
    ii) on all models, you can install our HCP28592 sensor bypass wire that duplicates the function of the original sensor.
    What are the best battery myths?:
    a) that putting a battery on a cement floor will cause it to discharge. This may have been true a long time ago, when the battery case was made of a rubber material, which would develop hairline cracks and thus allow moisture to permeate into the case, opening up an electrical circuit which would quickly discharge a battery. Modern batteries use molded plastic cases that do not suffer from such a fate.
    b) that bringing a battery inside during the winter will prolong its life. Batteries produce electricity via a chemical reaction, and the chemical reaction results in the production of sulfate deposits on the lead plates within the battery, and these sulfate deposits act as electrical insulators----thus reducing the power output and the overall life of the battery. These chemical reactions slow down dramatically with lower temperatures. As long as your battery does not freeze, the lower the temperature, the less the amount of chemical reactions taking place, thus prolonging the life of the battery!
    Remember, heat is one of the things that wears out batteries, because they speed up the amount and intensity of these chemical reactions that creates the sulfate deposition on the lead plates.....and those deposits are what really "kills" the battery.
    By the way, the main reason why your car or bike cranks over so slowly during winter is not due to "thicker oil" (multi-viscosity oils took care of that issue a long time ago), but because of the decreased chemical reactions (meaning less electrical output generation) within the battery due to those lower temperatures.
    Can I jump-start my dead motorcycle battery from a car battery?:
    Yes, BUT.................
    a) you need to make sure that you are using the proper gauge jumper cables.
    b) hook the jumper cables up incorrectly (+ to -) and if you're lucky, you'll just burn up your TCI unit. If you're unlucky, you'll blow up your battery, your bike, or yourself.
    c) make sure that your key switch and all electrical power drains are OFF before you hook up the jumper cables.
    d) the best sequence of battery connection is to hook up both jumper cables onto the dead battery first, and then connect the positive lead to the good battery, and finally the negative lead to the good battery (or a good ground on the donor battery frame, etc.).
    Your quest for more battery knowledge may still remains unsatisfied; if so, a great battery tutorial can be found at:
    http://www.batteryfaq.org
    and
    http://www.dansmc.com/batteries.htm
  16. chacal
    BATTERIES:
    All of the following batteries are high-quality, the correct size to fit into your battery box, and have the proper terminal orientations for your bike.
    All batteries can be shipped only with the USA, and can be shipped either via ground or air delivery. However, due to the weight of the batteries, the free or reduced shipping discounts do not apply to these items!
    NOTE: all batteries come with cable terminal attaching bolts and nuts; all non-sealed batteries have the overflow tube included; and all batteries come with charging instructions which must be followed exactly in order to not damage the battery during initial charging! AGM batteries come charged, but you should check the voltage and slowly (meaning with the use of a "trickle charger") bring the battery back to full charge before first use.....doing otherwise will void any manufacturer's warranty!
    NOTE: on all non-sealed ("wet" or "conventional" style batteries) always be sure to remove the small red seal from the overflow vent tube when installing the battery. Never put this red tube back on to the battery after it is activated. Gases built up in a battery that is not allowed to vent can cause serious damage, and possible serious injury, if the battery bursts.
    for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and XJ650 models:
    NOTE: also fits all of the following models: 1970-72 XS1, XS1B, and XS2 models; 1977-83 XS400 all models, 1980-82 SR250, 1987 SRX250, 1911 XS360, 1980 SR500, 1983-84 XV500, 1973 TX650, 1983 XS650, and 1983 XV920MK Midnight Virago models.
    HCP1425 OEM original style STANDARD-PERFORMANCE WET-CELL BATTERY, genuine Yuasa brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 12 amp-hours, 113 CCA rating.
    $ 59.95
    HCP28140 Aftermarket original style STANDARD-PERFORMANCE WET-CELL BATTERY. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 12 amp-hours, 113 CCA rating.
    $ 59.95
    HCP10455 OEM replacement style HI-PERFORMANCE WET-CELL BATTERY, genuine Yuasa Yumicron brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 12 amp-hours, 165 CCA rating.
    $ 79.95
    HCP28141 Aftermarket replacement style HI-PERFORMANCE WET-CELL BATTERY. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 12 amp-hours, 135 CCA rating.
    $ 67.95
    HCP28143 Aftermarket AGM BATTERY. This is an Absorbed Glass Mat type battery and is already filled with the acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. Comes with a set of terminal installation bolts and nuts. 12 volts, 12 amp-hours, 120 CCA rating.
    $ discontinued
    HCP28142 Aftermarket HIGH-PERFORMANCE AGM BATTERY. This is an Absorbed Glass Mat type battery and is already filled with the acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. Comes with a set of terminal installation bolts and nuts. 12 volts, 15 amp-hours, 160 CCA rating.
    $ 109.95
    HCP28592 Aftermarket battery fluid level SENSOR BY-PASS / REPLACEMENT, for all XJ650 Police, XJ650 Turbo, 1981-83 XJ750 Seca, 1982 XJ750 Maxim, XJ750 Euro (11M) models, XJ750 Police, 1982 XV920J Virago, and XJ1100 models. This updated version of our popular HCP9982 kit completely replaces the original sensor with this bypass sub-harness. Typically needed when using a replacement battery that does not accept an original style screw-in sensor. Tuned resistance level allows the display and warning light to still warn you of a low battery voltage condition, but no longer tells you anything about the fluid level (of course, a low voltage condition could be caused by a low fluid level, among other things). Simple plug-in installation to the original main harness sensor lead wire; contains an extra male bullet terminal for the main harness wire, in case someone cut it off in the distant past (a common problem with previous owners!). You can review the installation procedure for this product at: http://www.xj4ever.com/HCP14180 battery sensor bypass.pdf
    $ 39.95
    for all 1992-98 XJ600 Seca II and 1990-95 XT600 models:
    HCP27716 OEM original style STANDARD-PERFORMANCE WET-CELL BATTERY, genuine Yuasa brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 12 amp-hours, 113 CCA rating.
    $ 94.95
    HCP20121 Aftermarket original style STANDARD-PERFORMANCE BATTERY. This is a maintenance-free battery. Standard-performance design.
    $ discontinued
    HCP28144 Aftermarket AGM BATTERY. This is an Absorbed Glass Mat type battery and is already filled with the acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. 12 volts, 8 amp-hours, 90 CCA rating.
    $ 69.95
    HCP28145 Aftermarket HIGH-PERFORMANCE AGM BATTERY. This is an Absorbed Glass Mat style battery and is already filled with the acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. 12 volts, 8 amp-hours, 160 CCA rating.
    $ 89.95
    for all XJ650 Police models, all XJ700 models, 1983 XJ750 Maxim and Midnight Maxim, XJ750 Police models, XJ750-X models, and XJ900RK, RL, and N/FN models:
    NOTE: these batteries will also fit all of the following models if the battery sensor system is disabled using our HCP28592 battery sensor bypass device: 1982 XJ750 Maxim and 1981-83 XJ750 Seca models. If you want a battery that comes with or accommodates the original low-fluid level sensor, then see battery HCP10457 in the next section below.
    $ 39.95
    NOTE: these batteries also fit all of the following models: 1973-74 TX500, 1974 TX650, 1982 XT550, 1982-83 XZ550 RJ/RK Vision, 1975-78 XS500, 1975-83 XS650 all models, 1977-79 XS750, 1980-81 XS850, 1987 FZ700, 1986-87 FZX700 Fazer, 1985-86 and 1988 FZ750, 1987 FZR750R, 1987-90 FZR1000, 1984-85 FJ1100, and 1986-90 FJ1200 models.
    NOTE: some replacement batteries for these models are just slightly taller than the original batteries, and because of the cramped spaces in the battery box area, beware of the positive or negative terminal contacting the bottom of a frame tube. Such a situation is extremely dangerous and can lead to fire, explosion, injury, or death! You should always observe whether such a condition exists in these models, and if so, take preventative steps to prevent any contact of the battery terminals with the bike's frame! (especially when the bike is in motion, going over bumps, etc.). One possible solution is to WRAP THE FRAME RAIL WITH A PIECE OF PLASTIC TUBE, HOSE, OR MULTIPLE LAYERS OF ELECTRICAL TAPE DIRECTLY ABOVE THE BATTERY TERMINALS TO PREVENT ANY DIRECT CONTACT FROM OCCURRING!!
    HCP10409 OEM original style STANDARD-PERFORMANCE WET-CELL BATTERY, genuine Yuasa brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 14 amp-hours, 128 CCA rating.
    $ discontinued
    HCP28146 Aftermarket original style STANDARD-PERFORMANCE WET-CELL BATTERY. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 14 amp-hours, 128 CCA rating.
    $ 69.95
    HCP1427 OEM replacement style HI-PERFORMANCE WET-CELL BATTERY, genuine Yuasa Yumicron brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow screw-in style filler caps, terminal bolts and nuts, and overflow tubing. No fluid level sensor is included, and please note that the plate depth in this battery will REQUIRE modification (shortening) of an original screw-in sensor in order to avoid "bottoming" of the sensor probe onto the cell plate. 12 volts, 14 amp-hours, 190 CCA rating.
    $ 89.95
    HCP28147 Aftermarket replacement style HI-PERFORMANCE WET-CELL BATTERY. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow screw-in style filler caps, terminal bolts and nuts, and overflow tubing. No fluid level sensor is included, and please note that the plate depth in this battery will REQUIRE modification (shortening) of an original screw-in sensor in order to avoid "bottoming" of the sensor probe onto the cell plate. 12 volts, 14 amp-hours, 160 CCA rating.
    $ 89.95
    HCP28149 Aftermarket AGM BATTERY. This is an Absorbed Glass Mat type battery and is already filled with an acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. No fluid level sensor is included nor can be used (you will have to disable or bypass your low-fluid-sensor). Comes with a set of terminal installation bolts and nuts. 12 volts, 14 amp-hours, 160 CCA rating.
    $ 119.95
    HCP28150 Aftermarket HIGH-PERFORMANCE AGM BATTERY. This is an Absorbed Glass Mat type battery and is already filled with an acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. No fluid level sensor is included nor can be used (you will have to disable or bypass your low-fluid-sensor). NOTE: this battery is approximately 2mm taller than an original battery, and may require some slight modification to your original battery box for terminal attachment clearance on some models. Comes with a set of terminal installation bolts and nuts. 12 volts, 16.5 amp-hours, 210 CCA rating.
    $ 124.95
    for all 1982 XJ750 Maxim and 1981-83 XJ750 Seca models:
    NOTE: all of the batteries listed in the section above (for all XJ650 Police models, all XJ700 models, 1983 XJ750 Maxim and Midnight Maxim, XJ750 Police models, XJ750-X models, and XJ900RK, RL, and N/FN models) will also fit these models (they are the same physical size and orientation), but of course will not have a provision for the original low-fluid-level battery sensor. Our HCP28592 battery sensor by-pass allows you to properly eliminate the sensor device from the system and thus use any of those batteries.
    NOTE: the 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models used a battery sensor device in the 4th cell over from the negative terminal. Do not place the sensor in any other cell, or it could damage the microprocessor in your dash!
    NOTE: the following battery comes with a low-fluid level sensor already installed in the battery. Bikes that originally used these sensors can also use any of the non-sensor style batteries (listed in the section above) but you will either have to re-use your factory sensor (on battery HCP1427 above) or disable or bypass the factory low-fluid circuit if using the HCP10456 maintenance-free or the HCP10402 agm style batteries listed above. Our HCP28592 battery sensor by-pass allows you to properly eliminate the sensor device from the system.
    NOTE: some replacement batteries for these models are just slightly taller than the original batteries, and because of the cramped spaces in this area, beware of the positive or negative terminal contacting the bottom of the frame rail. Such a situation is extremely dangerous and can lead to fire, explosion, injury, or death! You should always observe whether such a condition exists in these models, and if so, take preventative steps to prevent any contact of the battery terminals with the bike's frame! (especially when the bike is in motion, going over bumps, etc.). One possible solution is to WRAP THE FRAME RAIL WITH A PIECE OF PLASTIC TUBE, HOSE, OR MULTIPLE LAYERS OF ELECTRICAL TAPE DIRECTLY ABOVE THE BATTERY TERMINALS TO PREVENT ANY DIRECT CONTACT FROM OCCURRING!!
    HCP10457 OEM replacement style HI-PERFORMANCE WET-CELL BATTERY, genuine Yuasa Yumicron brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow screw-in style filler caps, terminal bolts and nuts, and overflow tubing. A replacement style fluid level sensor IS included. Note that this battery is the only replacement battery available that accepts/uses a fluid level sensor. 12 volts, 14 amp-hours, 190 CCA rating. All other replacement batteries (ours or anyone else’s) will require the use of our HCP28592 battery sensor replacement kit to keep the digital display working properly.
    $ 209.95
    for all XJ1100 and XS1100 models:
    NOTE: the XJ1100 Maxim and 1983 XV920MK Midnight Virago models used a battery low-fluid level sensor device. The HCP10458 and HCP28153 batteries listed below are the only batteries that comes with a sensor, and no other batteries comes with nor can accept a fluid level sensor. For these models, you can use any of the non-sensor style batteries but you must bypass the factory low-fluid level circuit. Our HCP28592 battery sensor by-pass device allows you to properly eliminate the sensor device from the system.
    $ 39.95
    NOTE: these batteries also fit all of the following models: 1981-83 XV920 Virago models (see note above about sensor use on 1983 XV920MK model), 1984-85 XV1000 Virago, 1986-99 XV1100 Virago, 1983-85 XVZ1200, 1986-88 XVZ13, 1988-89 XVZ13 Venture Royal, and 1990-93 XVZ13 models.
    HCP10583 OEM original style STANDARD-PERFORMANCE WET-CELL BATTERY, genuine Yuasa brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. 12 volts, 20 amp-hours, 220 CCA rating.
    $ discontinued
    HCP28151 Aftermarket original style STANDARD-PERFORMANCE WET-CELL BATTERY. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Standard-performance with removable filler caps, terminal bolts and nuts, and overflow tubing. No fluid level sensor is included nor can be used (you will have to disable or bypass your low-fluid-sensor). 12 volts, 20 amp-hours, 220 CCA rating.
    $ 99.95
    HCP28152 Aftermarket original style STANDARD-PERFORMANCE, LOW-MAINTENANCE, WET-CELL BATTERY. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Re-absorbtion technology controls fluid evaporation, resulting in much reduced frequency to check and re-fill battery with water. Standard-performance with removable filler caps, terminal bolts and nuts, and overflow tubing. No fluid level sensor is included nor can be used (you will have to disable or bypass your low-fluid-sensor). 12 volts, 20 amp-hours, 220 CCA rating.
    $ discontinued
    HCP10458 OEM replacement style HI-PERFORMANCE WET-CELL BATTERY, genuine Yuasa Yumicron brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. Fluid level sensor and adapter harness IS included. 12 volts, 20 amp-hours, 260 CCA rating.
    $ 139.95
    HCP28153 Aftermarket replacement style HI-PERFORMANCE WET-CELL BATTERY, genuine Yuasa Yumicron brand. This is a "conventional" or "wet/flooded" style battery and must be filled with an acid-and-water mix before initial charging. The acid is not included and must be purchased by you at a local automotive parts store. Higher-performance designs features 30% greater cold-cranking amp capacity than standard (original) battery, and comes with the removable yellow push-in style filler caps, terminal bolts and nuts, and overflow tubing. Fluid level sensor and adapter harness IS included. 12 volts, 20 amp-hours, 220 CCA rating.
    $ 159.95
    HCP28154 Aftermarket AGM BATTERY. This is an Absorbed Glass Mat style battery and is already filled with an acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. No fluid level sensor is included nor can be used (you will have to disable or bypass your low-fluid-sensor). Comes with a set of terminal installation bolts and nuts. 12 volts, 20 amp-hours, 230 CCA.
    $ 149.95
    HCP28155 Aftermarket HIGH-PERFORMANCE AGM BATTERY. This is an Absorbed Glass Mat style battery and is already filled with an acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. No fluid level sensor is included nor can be used (you will have to disable or bypass your low-fluid-sensor). Comes with a set of terminal installation bolts and nuts. 12 volts, 25 amp-hours, 300 CCA.
    $ 169.95
    Battery Tools, Testers, Chargers, and Hardware:
    HCP10448 Aftermarket battery testing HYDROMETER. This is a real hydrometer, not the cheapo 4-dollar special you usually see at the auto parts store. It measure the specific gravity of the electrolytic fluid, which is the proper way to test its condition. Those little "floating balls" testers are barely worth the plastic that they're made of! This professional hydrometer gives you temperature-adjusted specific gravity readings, which is the only accurate method of measurement. And yes, you can use these on your car or tractor or boat battery, too........
    $ 18.95
    HCP10542 Aftermarket battery testing MINI-HYDROMETER. This is a cheapy, "floating ball" style hydrometer, but it's small size makes it easier to use on motorcycle batteries. It's better than not having one at all! And yes, you can use these on your car or tractor or boat battery, too........
    $ 14.95
    fbc3) Aftermarket automatic BATTERY CHARGERS. A fully automatic battery charger is the best type to use to provide "trickle charge" to deep-cycle batteries, as it prevents the overcharge conditions that dramatically reduce the life of a battery.
    HCP9962 Aftermarket automatic BATTERY CHARGER, standard bench-top style. Features that a 1.5A charger rate can be used to re-charge a dead battery quickly or maintain a trickle-charge for batteries that see infrequent use. Automatically changes from full-charge to float-mode monitoring for the extended battery life and no worries about over-charging. Reverse-hookup protection, LED power-on/charging/charged indicator lights, CSA-certified, and comes with both 50A standard spring clamps or the easy-to-use permanent plug-in connector to permanently attach a charging "pigtail" connector to the battery for instant access. Can be safely used on conventional and AGM style batteries; not recommended for gel-cell batteries.
    $ 79.95
    HCP28172 Aftermarket fully automatic BATTERY MAINTAINER-CHARGER. This compact wall-transformer style 6V and 12V charger features the latest solid-state, intelligent technology that allows quick, safe, and efficient charging of all battery types: conventional lead acid, maintenance-free lead acid, marine deep-cycle, AGM, gel-cell, and even lithium-ion. Features include: will safely charge even a fully dead battery (one that reads 0 volts), an automatic “de-sulphation” mode that can rescue and extend the life of older batteries, a thermal compensation sensor to prevent under- or over-charging, short-circuit protection, open-circuit protection, over-heat protection, over-charge protection, reverse-hookup protection, and spark protection. Can be hooked directly to the battery terminals with included ring terminals (a water-proof disconnect port is built into the 9-foot long lead wires), or you can use it with the included thin, “needle-nose” style clamps. Automatically changes from full-charge to float-mode monitoring for extended battery life and no worries about over-charging…..you can actually leave this charger hooked up to your battery 24/7 for as long as you want (like, all winter long……..) without risking battery damage (in fact, for all conventional lead-acid batteries, you should attempt to maintain it at 100% charge to maximize the battery life). Works on 110-240V AC current, 1-amp (max.15W) charging current, water-proof housing, 3-year warranty. This is most affordable and best “home-use” battery charger on the market/
    $ 49.95
    HCP28173 Aftermarket fully automatic BATTERY SUPER-CHARGER, all the same features as the HCP28172 above, but this charger feature more power output (2A, max. 30W charging current) and is a “mini-tabletop” design…..about 5.5” x 2.5”….no bigger than a typical computer mouse!
    $ 79.95
    HCP10449 Aftermarket automatic BATTERY CHARGER, compact wall-transformer style. Features that a 1.3A "pulse-mode" charger that can be used to re-charge a dead battery or maintain a trickle-charge for batteries that see infrequent use. Automatically changes from full-charge to float-mode monitoring for the extended battery life and no worries about over-charging. Comes with both alligator clips or the easy-to-use permanent plug-in connector to permanently attach a charging "pigtail" connector to the battery for instant access. Can be safely used on conventional and AGM style batteries; not recommended for gel-cell batteries.
    $ 89.95
    HCP10451 Aftermarket automatic BATTERY MAINTENANCE CHARGER, compact wall-transformer style. Features that a 800ma (0.8A) charger rate, perfect for maintaining a trickle-charge for batteries that see infrequent use. Automatically changes from full-charge to float-mode monitoring for the extended battery life and no worries about over-charging. Reverse-hookup and short-circuit protection, LED power-on/charging/charged indicator lights, waterproof, and comes with both alligator clips or the easy-to-use permanent plug-in connector to permanently attach a charging "pigtail" connector to the battery for instant access. No bigger than a typical computer "mouse"! Can be safely used on conventional and AGM style batteries; not recommended for gel-cell batteries.
    $ 69.95
    HCP10452 Aftermarket battery charger EXTENSION CABLE, 12-foot length. Don't want to bring your bike over to your charger? Then this set of 12-foot long charger-to-battery leads extender cable allows you to leave the battery charger close to a wall outlet, and extend the power leads to wherever your bike is located! Quick-connect feature allows plug-and-play installation with all of the above chargers. Very convenient.
    $ 24.95
    et3) Aftermarket motorcycle-sized BATTERY JUMPER CABLES. Small sized end clips more easily reach into the cramped areas where your battery lives, making it somewhat easier to jump-start a dead bike. NOTE: NEVER attach jumper cables to your battery unless your ignition key is OFF......or your risk frying a lot of expensive electrical components!
    HCP1608 Aftermarket 5-foot long standard duty JUMPER CABLES, with alligator clip ends.
    $ 37.95
    Battery Sensors:
    eb1) OEM Battery LOW FLUID SENSOR---this one battery cap is used in the #3 cell from the positive terminal (or, if you prefer, the 4th cell from the negative terminal) and reports a low battery fluid (water) condition to the dash warning lights. Without this sensor present, or if it malfunctions, the "low battery" warning light will always be lit. With harness pigtail. NOTE: these sensors are the correct depth to fit the original Yuasa batteries. Other manufacture batteries may require a shorter sensor depth, and you must measure and then trim the sensor tip shorter (if necessary) to insure that the tip does not bottom out in the battery! If your battery does not have screw-in style cell caps, you will have to use our thread-cutting bolt, such as our HCP10474, to forcibly "cut" threads in the proper cell to allow the original style threaded sensor to screw in.
    Of course, these sensors will not fit nor work in any type of AGM or "maintenance-free" style sealed batteries.
    NOTE: HCP1449 and HCP1450 original battery sensors differ from each other only in the length of their probe tip underneath the screw head…..with the HCP1450 being slightly shorter (33mm, and thus extends less deep into the battery) than the HCP1449 (39mm, and thus extends deeper into the battery cell). Due to the many varieties of batteries which may differ from the original battery that was fitted to the bike, we suggest you measure the depth of the cell to make sure you order the correct one…..based on tip depth……rather than by the specific applications listed.
    HCP1449 OEM Battery LOW FLUID SENSOR, for all XJ750 Seca, 1982 XJ750 Maxim, and XJ1100 models, blue, screw-in type, with wire lead. End of sensor tip is 39mm until the screw head.
    $ 59.95
    HCP1450 OEM Battery LOW FLUID SENSOR, for all XJ650 Turbo models, blue, screw-in type, with wire lead. End of sensor tip is 33mm until the screw head.
    $ 69.95
    HCP10581 Aftermarket battery sensor SHIMMING WASHER, for use with the HCP1449 or HCP1450 fluid sensor when installing it into a replacement battery.
    $ 1.95
    HCP10474 Aftermarket battery sensor THREAD-CUTTING BOLT, allows for the use of the original screw-in HCP1449 or HCP1450 fluid sensor when installing it into an aftermarket wet-cell battery that do not have threaded cell port holes.
    $ 1.95
    $ 39.95
    Electrical System Tools:
    et1) Aftermarket electrical test MULTIMETERS, the most useful tool you'll ever own for working on electrical systems. High quality test instruments make your life easier, and give you the accurate measurements needed to diagnose and track down electrical system issues.
    http://nadp.sws.uiuc.edu/cal/PDF/MulltimeterUse.pdf
    https://learn.sparkfun.com/tutorials/how-to-use-a-multimeter?_ga=1.238289411.262114863.1436923213
    http://www.masonmonitoring.com/pdf/support/UsingMultimeter.pdf
    https://learn.sparkfun.com/tutorials/how-to-read-a-schematic
    HCP7135 Aftermarket ANALOG (moving needle) MULTIMETER, more accurate than digital meters but a bit less user-friendly. These 6-function meters measure DC voltages (0-100), AC voltages (0-750), Resistance (0-10 megaohms), DC Current (0-10A), and has a small battery testing dial. NOTE: this multimeter does NOT have the capability to perform diode-checking, which can be a useful function when working on these bikes (although, to be honest, a diode failure is a rare event).
    $ 79.95
    HCP7136 Aftermarket DIGITAL (numerical LCD display) MULTIMETER, less accurate than analog meters but a bit more user-friendly. This 5-function meters measure DC voltages (0-1000), AC voltages (0-700), Resistance (0-2 megaohms), DC Current (0-10A), and Diode Checking. NOTE: this multimeter DOES have the capability to perform diode-checking, which can be a useful function when working on these bikes (although, to be honest, a diode failure is a rare event). Accuracy: DC voltage +/- 0.7%, AC voltage +/- 1.2%, DC current +/- 1%, Resistance +/-1%.
    $ 69.95
    eb4) OEM original battery DRAIN - OVERFLOW HOSE, fits onto the drain nipple on the battery and routes battery fluid and gases underneath the bike.
    HCP16153 OEM black battery DRAIN - OVERFLOW HOSE, fits all XJ models, trim to proper length as described below.
    $ 6.95
    Drain hose routing and length:
    - on 550 all models the original hose is approximately 23" long and is routed out of the battery vent, slides down the inside of the frame rail, and goes thru a hole in the "ear" of the welded-to-the-frame brake light switch bracket. From there, it routes forward of the swingarm, then snakes down rearward and forward again against the back of the motor and passes in front of the centerstand cross-tube.
    - on 650 (except Turbo) models, all 1981-83 XJ750 models, and all XJ900 models, the original hose is approximately 24" long and is routed out of the battery vent, through the battery box bottom access hole, and then forward of the lower frame cross brace, and then through a welded clamp at the center of the frame cross tube.
    - on XJ650 Turbo models, the original hose is approximately 24" long and is routed out of the battery vent, then straight down thru battery box, then behind the footpeg, outside of the frame tube, and the through a welded clamp on the centerstand mounting bracket.
    - on all XJ700 and XJ750-X models, the original hose is approximately 18" long and is routed out of the battery vent, through the tool caddy bottom hole and then forward of the frame cross brace, through a welded clamp on frame cross tube, where airbox drain tube also lives.
    - on XJ1100 all the original hose is approximately 22" long and is routed out of the battery vent, and comes straight down the side of the battery and then turns 90-degrees towards the center of the bike. There are two clamps that guide the hose along the forward edge of the battery tray, and then in the center of the bike, the hose takes a 90-degree turn straight down, where it goes thru a welded-on clip on the front of the lower frame cross-tube and then hangs down, towards the ground.
    Battery Warning and Maintenance ID Decals:
    These decals are typically found attached inside the frame side cover panels (or, on some models, attached to the bottom of the seat pan) and illustrate proper battery vent hose installation and routing, battery sensor warnings, and battery removal information.
    HCP15127 Aftermarket battery VENT TUBE WARNING, white decal with orange wording and illustration warns the user to remove the vent tube block-off before battery installation. This small paper decal is used on all models and it is typically located on the top of the battery case next to the vent hose opening.
    $ 11.95
    HCP8122 Aftermarket battery REMOVAL/INSTALLATION PROCEDURE DECAL, silver decal with black wording cautions the user on proper battery removal and installation. This rectangular foil decal (about 2-1/2” wide x 1-5/8” tall) is used on all XJ550 models and is typically located inside the left side frame cover.
    $ 12.95
    HCP8124 Aftermarket CAUTION BATTERY REMOVAL/INSTALLATION PROCEDURE DECAL. This small, rectangular (2-1/2” wide x 1-1/4” tall) clean vinyl decal has white lettering and cautions the user on proper battery removal and installation. Used on all XJ650 models, XJ700, XJ750-X, some XJ750 Seca models, and all 1983-89 XJ900 models. It is located inside the right side frame cover (all models except XJ650 Turbo) or on the seat pan (XJ650 Turbo) and inside the left frame cover on XJ900 models. NOTE: XJ750 Seca models may have used this decal or the HCP8123 decal below, as we have seen examples of both types on original covers.
    $ 12.95
    HCP8123 Aftermarket CAUTION BATTERY REMOVAL/INSTALLATION PROCEDURE DECAL. This small, rectangular (2-1/2” wide x 1-1/4” tall) clean vinyl decal has white lettering and cautions the user on proper battery removal and installation. Used on all 1981-84 XJ750 Maxim models, some XJ750 Seca models, and XJ1100 models. It is located inside the right side frame cover on XJ750 models, and inside the left cover on XJ1100 models. NOTE: XJ750 Seca models may have used this decal or the HCP8124 decal above, as we have seen examples of both types on original covers.
    $ 12.95
    HCP8119 Aftermarket battery SENSOR INSTALLATION DECAL, silver decal with black wording and graphics cautions the user on proper battery sensor position. This foil decal is used on all 1982-83 XJ650 Turbo models (on the seat pan), inside the right frame cover on 1981-83 XJ750 Seca models, and inside the left frame cover on XJ1100 models.
    $ 12.95
    HCP15457 Aftermarket battery SENSOR INSTALLATION/DRAIN HOSE ROUTING DECAL, large silver decal with black wording and graphics cautions the user on proper battery sensor position and battery drain hose routing. This foil decal is used on all 1982 XJ750 Maxim models inside the right frame cover.
    $ 14.95
    HCP8152 Aftermarket battery DRAIN HOSE ROUTING DECAL, silver decal with black wording and graphics illustrate the proper battery breather "pipe" (hose) routing. This foil decal is used on all XJ550 models inside the left frame cover.
    $ 12.95
    HCP8151 Aftermarket battery DRAIN HOSE ROUTING DECAL, large silver decal with black wording and graphics illustrate the proper battery breather "pipe" (hose) routing. This foil decal is used on all XJ650 (except Turbo) models and 1981-83 XJ750 Seca inside the right frame cover.
    $ 12.95
    HCP15134 Aftermarket battery DRAIN HOSE ROUTING DECAL, large silver decal with black wording and graphics illustrate the proper battery breather "pipe" (hose) routing. This foil decal is used on all XJ650 Turbo models on the seat pan.
    $ 12.95
    HCP15124 Aftermarket battery DRAIN HOSE ROUTING DECAL, silver decal with black wording and graphics illustrate the proper battery breather "pipe" (hose) routing. This foil decal is used on all XJ700 and XJ750-X models inside the right frame cover.
    $ 12.95
    HCP15126 Aftermarket battery DRAIN HOSE ROUTING DECAL, large silver decal with black wording and graphics illustrate the proper battery breather "pipe" (hose) routing. This foil decal is used on all XJ900 models inside the leftt frame cover.
    $ 12.95
    HCP15125 Aftermarket battery DRAIN HOSE ROUTING DECAL, silver decal with black wording and graphics illustrate the proper battery breather "pipe" (hose) routing. This foil decal is used on all XJ1100 models inside the right frame cover.
    $ 12.95
    Battery System Chemicals:
    HCP14059 Aftermarket packet of DI-ELECTRIC GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc.
    $ 4.95
    HCP7528 Aftermarket tube of DI-ELECTRIC GREASE, big 3-ounce squeeze tube.
    $ 21.95
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP20940 Aftermarket tube of DI-ELECTRIC GREASE, 3.3-ounce aerosol can of marine-grade grease, featuring an adjustable nozzle which allows you to tailor the grease output bead size to minimize slop and waste, while also making application much easier. 1-2 cans will do all connectors on an entire bike harness.
    $ 24.95
    HCP10493 Aftermarket battery post TERMINAL SEALER helps keep corrosion from forming on the battery terminals. Fast drying and leaves no residue. Comes in a 6-ounce aerosol can.
    $ 12.95
    HCP9762 Aftermarket miracle-goo black LIQUID ELECTRICAL TAPE is easier to use than traditional tape products, especially in close-in locations. Great for sealing crimped wire terminal ends to the wire and serves as a good alternative or supplement to shrink tubing. Just brush it on and let it dry! Comes in a 4-ounces brush-top can.
    $ 12.95
    HCP10508 Aftermarket electrical CONTACT CLEANER is a good general purpose cleaner and de-greaser. Will not harm plastic terminal connector blocks. Fast drying and leaves no residue. Comes in a 16-ounce aerosol can.
    $ 14.95
    et14) Aftermarket electrical connector CONDUCTIVE GREASE coats and protects metal terminal connectors from exposure to air, thus preventing oxidation, the killer of electrical systems. Unlike the di-electric grease listed above, which is an insulator (non-conductive), this carbon-based grease is electrically conductive and has multiple applications (such as battery terminal posts (internally), frame grounds, etc.).
    HCP27923 Aftermarket packet of CONDUCTIVE GREASE, single use 2-gram packet, enough to do a few light bulbs, terminals, etc. Even tiny amounts (that you can barely see) will create minimal electrical resistance, so be careful with this stuff around capacitors and such. It gets everywhere, will stain your hands and clothing and take three days to wash off, and smells like some of the worst goop you've ever smelled. Use a toothpick for application. Don't eat it. Wear gloves. 2-gram pouch goes a long way.
    $ 6.95
    $ 12.95
    $ 14.95
    HCP12923 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 20-foot roll.
    $ 8.95
    HCP13134 Aftermarket harness bundle VINYL ELECTRICAL TAPE WRAP, black, 66-foot roll, almost enough to do one complete harness.
    $ 16.95
    Additionally, most harnesses had a few short turns of COLORED VINYL ELECTRICAL TAPE WRAP to provide visual identification of "what connector goes where?" during harness assembly and installation. Always located just by the connector shell, about 3-4 turns of this tape was used to both tape off any vinyl sleeve and to properly identify what the connector plugged into. Used primarily at the TCI connector (from the pick-up coils) and at the various small "cube" style relays (headlight relays, sidestand safety switch relays, etc.). Since all of these harness connector shells are the same style and type (4-position, horizontally oriented 2-over-2), this small tape wrap served as a way of indicating which of these many identical connectors went to which component.
    HCP13130 Aftermarket harness bundle YELLOW VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on XJ700-X and XJ750-X models, and at the headlight relay connector on all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models.
    $ 7.95
    HCP13131 Aftermarket harness bundle RED VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on 1982-83 XJ650 Maxim models, all '81-83 XJ750 models, and all XJ700 non-X models, and at the fuel pump relay connector on all XJ650 Turbo models.
    $ 7.95
    HCP13132 Aftermarket harness bundle BLUE VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ550 models, at the emergency stop switch relay connector on all XJ650 Turbo models, and for the sidestand safety switch relay connector on all XJ550 models, all '82-83 XJ650 models, all XJ750 models, XJ900RK and XJ1100 models.
    $ 7.95
    HCP13133 Aftermarket harness bundle GREEN VINYL ELECTRICAL TAPE WRAP, 20-foot roll. Used by the pick-up coil harness connector (at the TCI) on all XJ650RJ Seca and XJ1100 models.
    $ 7.95
    HCP10540 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery box with a sharp knife or a pair of scissors. For all XJ550, XJ650, XJ700, XJ750, and XJ900RK models.
    $ 9.95
    HCP10541 Aftermarket acid-neutralizing BATTERY MAT, thin felt mat with pressure-treated with a battery-acid neutralizing chemical. Easily placed directly under the battery, it prevents any spills or discharge from the battery from doing damage to your paint, frame, etc. Trim to fit your battery tray with a sharp knife or a pair of scissors. For all XJ1100 models.
    $ 13.95
    HCP10580 Aftermarket acid-neutralizing BATTERY TERMINAL PROTECTORS, thin, round felt mat circles are pressure-treated with a battery-acid neutralizing chemical. Placed under the battery terminal posts, they help prevents any spills or discharge from the battery from creating terminal corrosion. Trim and size to fit your battery posts with a sharp knife or a pair of scissors. Order 1 per terminal, 2 per battery. Each:
    $ 3.95
    Battery Box:
    HCP1436 OEM original black plastic BATTERY BOX, bare, does contain any hardware or accessory pieces. Fits all 1981-83 XJ750 models.
    $ 139.95
    eb1) OEM battery RETAINING STRAP AND PADS---the short, flat, black "bungee cord" tension strap that holds the battery firmly in place within the battery box. Some models also use a white, hard plastic strap extension "hook" that attaches the upper end of the strap to the battery box.
    HCP1442 OEM battery box CUSHION PAD, round black rubber pad fits into the back of the battery box and cushions the battery from movement. For all XJ550 and FJ600 models. Use 2 per bike. Each:
    $ 8.95
    HCP5789 OEM battery box CUSHION PAD, rectangular flat rubber pad fits into the bottom of the battery box and cushions the battery from movement. For all XJ700 and XJ750-X models. Use 1 per bike. NOTE: this pad is slightly smaller and thinner than the original. The aftermarket HCP16546 pad below is the current original size. Each:
    $ 7.95
    HCP16546 Aftermarket battery box CUSHION PAD, rectangular flat rubber pad fits into the bottom of the battery box and cushions the battery from movement. For all XJ700 and XJ750-X models. Use 1 per bike. NOTE: this pad is the correct original size and thickness. Each:
    $ 4.95
    Battery Retaining Straps:
    HCP29086-VGU OEM battery box BATTERY RETAINING STRAP, short flat black rubber strap with d-hooks on each end. For all XJ650 models (except Turbo), all 1981-83 XJ750 models, and XJ900RK, RL, N/FN, and F models. NOTE: this is a used original-length strap, approximately 1.5” longer than the supersedel HCP1448 or HCP26229 straps below, and thus it will fit properly when using a stock depth battery. Each:
    $ pricing varies with availability; inquire.
    HCP1448 OEM battery box BATTERY RETAINING STRAP, short flat black rubber strap with d-hooks on each end. For all XJ650 models (except Turbo), all 1981-83 XJ750 models, and XJ900RK, RL, N/FN, and F models. NOTE: this superseded strap is approximately 1.5” shorter than the original HCP29086 strap, and thus it will be quite difficult to use with a stock depth battery…..in which case, we suggest using the stock length strap (HCP29086). Each:
    $ 21.95
    HCP26229 Aftermarket battery box BATTERY RETAINING STRAP, short flat black rubber strap with d-hooks on each end. For all XJ650 models (except Turbo), all 1981-83 XJ750 models, and XJ900RK, RL, N/FN, and F models. NOTE: this is a copy of the superseded HCP1448 strap, and is also approximately 1.5” shorter than the original HCP29086 strap, and thus it will be quite difficult to use with a stock depth battery…..in which case, we suggest using the stock length strap (HCP29086). Each:
    $ 16.95
    HCP1444 OEM battery box BATTERY RETAINING STRAP, short flat black rubber strap with d-hooks on each end. For all XJ650 Turbo models. Each:
    $ 33.95
    HCP26228 Aftermarket battery box BATTERY RETAINING STRAP, short flat black rubber strap with d-hooks on each end. For all XJ650 Turbo models. Each:
    $ 22.95
    HCP1445 OEM battery box BATTERY RETAINING STRAP, short flat black rubber strap runs front to back over the top of the battery. For all XJ700 and XJ750-X models. Each:
    $ 12.95
    HCP1446 OEM battery box BATTERY RETAINING STRAP, short flat black rubber strap runs around the bottom and over the top of the battery making it possible to easily remove the battery from the depths of the battery box. For all XJ700 and XJ750-X models. Each:
    $ discontinued
    HCP29034 Aftermarket battery box BATTERY RETAINING STRAP, short flat black rubber strap runs around the bottom and over the top of the battery making it possible to easily remove the battery from the depths of the battery box. Made from a slightly thicker material from the original so It won’t snap/break as easily as the original did. For all XJ700 and XJ750-X models. Each:
    $ 19.95
    HCP1540 OEM battery box BATTERY RETAINING STRAP, short flat black rubber strap with metal hooks on each end. For all XJ1100 models. NOTE: this superseded strap now has a rubber “loop” in the center of the band which was not present on the original, however it does not affect the fit or function. Each:
    Each:
    $ 11.95
    HCP8602 OEM battery box retaining strap EXTENSION HOOK, short flat white plastic strap runs from the top end of the battery retaining strap to the battery box. Used on all XJ650 models (except Turbo), all 1981-83 XJ750 models, and XJ900RK, RL, N/FN, and F models. Each:
    $ 29.95
    Battery Box Cover-to-Box Hardware:
    HCP1030 OEM battery box cover-to-box SCREW, dark finish alloy steel, panhead, phillips drive. Use 2 per cover, for use on all XJ550 models, each:
    $ 7.95
    HCP2922 Aftermarket battery box cover-to-box SCREW, use 2 per cover, for use on all XJ550 models. Zinc-plated alloy steel, natural finish, panhead phillips-drive, each:
    $ 2.95
    HCP21362 Aftermarket battery box cover-to-box SCREW, use 2 per cover, for use on all XJ550 models. 18/8 stainless steel, bright finish, panhead phillips-drive, each:
    $ 3.95
    HCP6714 Aftermarket battery box cover-to-box SCREW, use 2 per cover, for use on all XJ550 models. Button head hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP6715 Aftermarket battery box cover-to-box SCREW, use 2 per cover, for use on all XJ550 models. Socket head, hex-drive, black-oxide coated alloy steel, each:
    $ 2.95
    HCP6716 Aftermarket battery box cover-to-box SCREW, use 2 per cover, for use on all XJ550 models. Socket head, hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP315 OEM battery box cover-to-box screw LOCK WASHER, use 2 per cover, for use on all XJ550 models, each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, battery box cover-to-box screw LOCK WASHER, use 2 per cover, for use on all XJ550 models, each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel battery box cover-to-box screw LOCK WASHER, use 2 per cover, for use on all XJ550 models, each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel battery box cover-to-box screw LOCK WASHER, use 2 per cover, for use on all XJ550 models, each:
    $ 1.95
    HCP4248 OEM battery box cover-to-box screw FLAT WASHER, bright zinc-plated alloy steel, use 2 per per cover, for use on all XJ550 models, each:
    $ 3.95
    HCP25871 Aftermarket battery box cover-to-box screw FLAT WASHER, bright zinc-plated alloy steel, use 2 per cover, for use on all XJ550 models, each:
    $ 1.95
    Battery Box-to-Frame Upper Mounting Hardware:
    HCP4242 OEM battery box upper mounting BOLT, use 3 per box on all XJ550 and FJ600 models, each:
    $ 7.95
    HCP3029 OEM battery box upper mounting BOLT, standard 6-point hex-head alloy steel bolt with a dark finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP14007 Aftermarket battery box upper mounting BOLT, standard 6-point hex-head alloy steel bolt with a yellow zinc-plated finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, black-oxide coated alloy steel. Each:
    $ 1.95
    HCP22249 Aftermarket battery box upper mounting BOLT, standard 6-point hex-head 18/8 stainless steel bolt with a bright finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, bright polished 18-8 stainless steel. Each:
    $ 2.95
    HCP14008 Aftermarket battery box upper mounting BOLT, standard 6-point hex-head 316 stainless steel bolt with a bright finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, bright polished 18-8 stainless steel. Each:
    $ 3.95
    HCP22253 Aftermarket battery box upper mounting BOLT, socket head (allen-key drive) alloy steel with a zinc-plated finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, bright polished 18-8 stainless steel. Each:
    $ 1.95
    HCP228 Aftermarket battery box upper mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, bright polished 18-8 stainless steel. Each:
    $ 1.95
    HCP2779 Aftermarket battery box upper mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish, features self-locking threads. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, bright polished 18-8 stainless steel. Each:
    $ 2.95
    HCP226 Aftermarket battery box upper mounting BOLT, socket head (allen-key drive) 18/8 stainless steel with a bright finish. Use 1 per box on all XJ650 models, all 1981-83 XJ750, and all XJ900RK, RL, and N/FN models; and use 2 per box on all XJ700 and XJ750-X models, bright polished 18-8 stainless steel. Each:
    $ 2.95
    HCP13753 OEM battery box upper mounting BOLT, use 1 per box on all XJ900 F models. Each:
    $ 1.50
    HCP315 OEM battery box upper mounting bolt LOCK WASHER, use 3 per bike on all XJ550 and FJ600 models, use 1 per box on all XJ650, XJ750, XJ900RK, RL, and N/FN models, and use 2 per box on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, battery box upper mounting bolt LOCK WASHER, use 3 per bike on all XJ550 and FJ600 models, use 1 per box on all XJ650, XJ750, XJ900RK, RL, and N/FN models, and use 2 per box on all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel battery box upper mounting bolt LOCK WASHER, use 3 per bike on all XJ550 and FJ600 models, use 1 per box on all XJ650, XJ750, XJ900RK, RL, and N/FN models, and use 2 per box on all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel battery box upper mounting bolt LOCK WASHER, use 3 per bike on all XJ550 and FJ600 models, use 1 per box on all XJ650, XJ750, XJ900RK, RL, and N/FN models, and use 2 per box on all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP4614 OEM battery box cover-to-box screw FLAT WASHER, use 3 per bike on all XJ550 and FJ600 models. Each:
    $ 5.95
    HCP10615 OEM battery box cover-to-box screw FLAT WASHER, use 1 per bike on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, and N/FN models, each:
    $ 7.95
    HCP3156 OEM battery box upper mounting bolt COLLAR, use 3 per box on all XJ550 and FJ600 models, and 1 per box on all XJ650 models, all 1981-83 XJ750 models, and all XJ900RK, RL, N/FN, and F models, each:
    $ 11.95
    HCP5792 OEM battery box upper mounting bolt COLLAR, use 2 per box on all XJ700 and XJ750-X models, each:
    $ 7.95
    HCP1947 OEM battery box upper mounting bolt GROMMET, use 3 per box on all XJ550 and FJ600 models, and 1 per box on all XJ650 models, all 1981-83 XJ750 models, and all XJ900RK, RL, N/FN, and F models, each:
    $ 7.95
    HCP5791 OEM battery box upper mounting bolt GROMMET, use 2 per box on all XJ700 and XJ750-X models, each:
    $ 8.95
    HCP26224 Aftermarket battery box upper mounting bolt GROMMET, use 2 per box on all XJ700 and XJ750-X models, each:
    $ 5.95
    Battery Box-to-Frame Lower Mounting Hardware:
    HCP3925 OEM battery box lower mounting BOLT, alloy steel hex-head bolt with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 7.95
    HCP17143 Aftermarket battery box lower mounting BOLT, alloy steel hex-head bolt with a bright silver-zinc finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 1.95
    HCP22195 Aftermarket battery box lower mounting BOLT, alloy steel hex-head bolt with a bright yellow-zinc finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 1.95
    HCP17144 Aftermarket battery box lower mounting BOLT, alloy steel hex-head bolt with a black finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 1.95
    HCP17145 Aftermarket battery box lower mounting BOLT, 18-8 stainless steel hex-head bolt with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 2.95
    HCP22198 Aftermarket battery box lower mounting BOLT, 316 stainless steel hex-head bolt with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 3.95
    HCP22200 Aftermarket battery box lower mounting BOLT, high-strength alloy steel socket head (hex-key) bolt with a black finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 3.95
    HCP22201 Aftermarket battery box lower mounting BOLT, alloy steel socket head (hex-key) bolt with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 1.95
    HCP22202 Aftermarket battery box lower mounting BOLT, 18-8 stainless steel socket head (hex-key) bolt with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 2.95
    HCP24125 Aftermarket battery box lower mounting BOLT, 316 stainless steel socket head (hex-key) bolt with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 3.95
    HCP3029 OEM battery tray lower mounting BOLT, standard 6-point hex-head alloy steel bolt with a dark finish. Use 2 per tray on all XJ1100 models, each:
    $ 3.95
    HCP14007 Aftermarket battery tray lower mounting BOLT, standard 6-point hex-head alloy steel bolt with a yellow zinc-plated finish. Use 2 per tray on all XJ1100 models, each:
    $ 1.95
    HCP22249 Aftermarket battery tray lower mounting BOLT, standard 6-point hex-head 18/8 stainless steel bolt with a bright finish. Use 2 per tray on all XJ1100 models, each:
    $ 2.95
    HCP14008 Aftermarket battery tray lower mounting BOLT, standard 6-point hex-head 316 stainless steel bolt with a bright finish. Use 2 per tray on all XJ1100 models, each:
    $ 3.95
    HCP22253 Aftermarket battery tray lower mounting BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Use 2 per tray on all XJ1100 models, each:
    $ 1.95
    HCP228 Aftermarket battery tray lower mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish. Use 2 per tray on all XJ1100 models, each:
    $ 1.95
    HCP2779 Aftermarket battery tray lower mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish, features self-locking threads. Use 2 per tray on all XJ1100 models, each:
    $ 2.95
    HCP226 Aftermarket battery tray lower mounting BOLT, socket head (allen-key drive) 18/8 stainless steel with a bright finish. Use 2 per tray on all XJ1100 models, each:
    $ 2.95
    HCP2185 OEM battery tray lower mounting bolt LOCK WASHER, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 6.95
    HCP16209 Aftermarket battery tray lower mounting bolt LOCK WASHER, zinc-plated alloy steel, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 2.95
    HCP16100 Aftermarket battery tray lower mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 3.95
    HCP16102 Aftermarket battery tray lower mounting bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 3.95
    HCP315 OEM battery tray lower mounting bolt LOCK WASHER, use 2 per tray on all XJ1100 models, each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, battery tray lower mounting bolt LOCK WASHER, use 2 per tray on all XJ1100 models, each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel battery tray lower mounting bolt LOCK WASHER, use 2 per tray on all XJ1100 models, each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel battery tray lower mounting bolt LOCK WASHER, use 2 per tray on all XJ1100 models, each:
    $ 1.95
    HCP10062 OEM battery box lower mounting bolt COLLAR, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 7.95
    HCP6271 OEM battery tray lower mounting bolt COLLAR, use 2 per tray on all XJ1100 models, each:
    $ 6.95
    HCP10063 OEM battery box lower mounting bolt GROMMET, use 1 per box on all XJ650, 1981-83 XJ750, and all XJ900RK, RL, N/FN, and F models, each:
    $ 17.95
    HCP10061 OEM battery box lower oval back GROMMET, use 1 per box on all XJ650 and 1981-83 XJ750 models. The rear mounting "tab" of the chain lock storage box fits into this grommet. Each:
    $ 6.95
    HCP5790 OEM battery box lower mounting bolt GROMMET, use 1 per box on all XJ700 and XJ750-X models, each:
    $ 7.95
    BATTERY CABLES AND RELATED:
    Battery Cables:
    eb3) OEM and aftermarket replacement BATTERY CABLES correctly replace worn, frayed, damaged, or missing original positive or negative battery cables.
    Original cables, terminal bars, and main harness lead wires come in the original lengths and configurations, either as stand-alone units or are integrated cable-and-lead wire units depending on model.
    Aftermarket replacement cables are made from a heavy-duty 6-gauge wire, covered in either a red or black thermal- and fuel-resistant sheath, with crimped and soldered 1/4" closed-ring end terminals (note that the either or both end terminal are round ring terminals, rather than the original square peg terminal used on some models, but these will still fit onto the original battery posts or ground points just fine.....the ring terminals are easily bent to a 45-degree or 90-degree angle to accommodate the needed configurations for each bike). These cables are much-needed upgrade over corroded, damaged, or missing original cables.
    Models that originally used an integrated cables can use these aftermarket cables as the battery cable only and make the suggested modifications listed below to retain or replace the "integrated" additional leads found on some original cables.
    Positive (red) Battery Cables:
    All OEM cable come complete with the battery post rubber cover and the solenoid-end protective rubber boot cap. Aftermarket cables do not feature the rubber caps or boots at either end.
    NOTE: on XJ550 models, the original positive (+) battery lead from the battery to the starter relay ("solenoid") is a black-sheathed, braided wire cable. Why the factory choose to use a black cable for a positive battery lead is beyond me, but there it is.....
    If you want to keep that as a black cable, you can use the HCP1605 black negative cable in it's place.....but we suggest that if you do replace this cable, you use the red-sheathed positive cable as is traditional for hot leads.
    NOTE: on all XJ550, XJ650 Turbo, XJ700, XJ750, XJ900RK, and XJ1100 models, the main harness lead wire and connector is built into the positive battery cable. These replacement battery cables are just the heavy-gauge cable, and do not include the main harness lead. There are two solutions available to you:
    1) if your original main harness lead wire is still in good condition, you can cut it off from your original battery cable, strip the cut end, and install one of the closed ring terminals listed below onto this end, which then allows you to install this connector onto the solenoid stud (XJ650 models used this method originally, using a separate battery cable which did not have the main harness lead wire integrated into the battery cable itself).
    2) if you main harness lead wire is damaged, missing, or not re-usable, then you can purchase the separate HCP395 solenoid-to-main harness lead wire, complete with the ring terminal and the large white plastic connector block already installed.....ready to plug and play!
    HCP2580 OEM POSITIVE BATTERY TERMINAL BAR. Fits all XJ650 models (except Turbo). Unlike a traditional battery cable, these models used a solid metal "bus bar" to connect the battery positive post to the solenoid, and then used the HCP395 solenoid-to-main harness lead wire.
    $ 33.95
    HCP23574 Aftermarket POSITIVE BATTERY TERMINAL BAR. Fits all XJ650 models (except Turbo). Unlike a traditional battery cable, these models used a solid metal "bus bar" to connect the battery positive post to the solenoid, and then used the HCP395 solenoid-to-main harness lead wire. Correct tin-plated reproduction of original.
    $ 22.95
    HCP21324 Aftermarket positive battery terminal bar RUBBER COVER. This odd “L” shaped rubber sanps onto and covers the HCP2580 or HCP23594 terminal bar and prevents all sorts of very bad things (i.e. big electrical shorts) from happening. Use on all XJ650 (except Turbo) models.
    $ 21.95
    HCP395 OEM solenoid-to-main harness POSITIVE WIRE LEAD, for all XJ650 (except Turbo) models, from the solenoid to the main harness. Includes the ring terminal for the solenoid end and plastic harness connector at the harness end already installed.
    $ 32.95
    HCP2938 OEM POSITIVE BATTERY CABLE, fits all XJ650 Turbo models, with integrated harness lead wire and connector. NOTE: this cable differs in overall length (it's longer), end terminal configuration, and post cover type. It will fit and work properly.
    $ discontinued
    HCP398 OEM POSITIVE BATTERY CABLE, fits all XJ700 and XJ750-X models, with integrated harness lead wire and connector.
    $ discontinued
    HCP396 OEM POSITIVE BATTERY CABLE, fits all XJ750 Seca and XJ900RK, RL, N/FN, and F models. Has the integrated main harness lead wire and connector. NOTE: this cable can be used as a suitable replacement for the original XJ550 positive cable, but this cable has a red cable rather than the original black cable used on the XJ550 models.
    $ discontinued
    HCP1600 Aftermarket red 6-gauge POSITIVE BATTERY CABLE, 4" long, can be used as a substitute for the original metal positive battery "bar" used on all XJ650 (except Turbo) models.........however, it will be a tight fit. Each:
    $ 11.95
    HCP1601 Aftermarket red 6-gauge POSITIVE BATTERY CABLE, 6" long. This cable can be used to replace the original black-sheathed positive battery cable on all XJ550 models, and the original metal terminal bar on all XJ650 models (except Turbo). XJ550 owners will either have to save and modify/re-use their main harness connector lead wire off of your original cable, or use the HCP395 solenoid-to-main harness lead wire, while the XJ650 crowd (except Turbo) can re-use their original separate solenoid-to-main harness lead wire. Each:
    $ 12.95
    HCP11428 Aftermarket black 6-gauge POSITIVE BATTERY CABLE, 6" long. This cable can be used to replace the original black-sheathed positive battery cable on all XJ550 and XJ1100 models. You will need to save and re-use the main harness plastic connector lead wire off of your original cable....or use our HCP12837MFWHT replacement connector below... as this cable comes with a red harness lead wire, but it is terminated with a sheathed female bullet connector instead of the proper large plastic connector shell. XJ1100 owners can modify your existing wire harness by removing the white connector shell and substituting a male bullet terminal on that wire, then it will integrate with the HCP11428 harness properly.
    Each:
    $ 21.95
    HCP9364BR1418 Aftermarket MALE BULLET STYLE WIRE-END TERMINAL, correct size and style solid brass terminal features retention bulge for insertion and positive locking into the female mate. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP1605 Aftermarket black 6-gauge BATTERY CABLE, 6" long. This cable can be used to replace the original black-sheathed, integrated positive battery cable on all XJ550 models. You will either have to save and modify/re-use the main harness connector lead wire off of your original cable, or use the HCP395 solenoid-to-main harness lead wire. Each:
    $ 12.95
    HCP1602 Aftermarket red 6-gauge POSITIVE BATTERY CABLE, 8" long. This cable can be used to replace the original integrated positive battery cable on all XJ650 Turbo, XJ750 non-X, and XJ900RK models. You will either have to save and modify/re-use the main harness connector lead wire off of your original cable, or use the HCP395 solenoid-to-main harness lead wire. Each:
    $ 13.95
    HCP1603 Aftermarket red 6-gauge POSITIVE BATTERY CABLE, 10" long. This cable can be used to replace the original integrated positive battery cable on all XJ700-X and XJ750-X models. You will either have to save and modify/re-use the main harness connector lead wire off of your original cable, or use the HCP395 solenoid-to-main harness lead wire. Each:
    $ 13.95
    HCP395 OEM POSITIVE WIRE LEAD, from the solenoid to the main wire harness connector.
    $ 32.95
    Battery Cable Terminal Covers and Boots:
    Since the positive battery cable is always "hot", all exposed ends of these cables are protected by rubber COVERS or BOOTS. Over time, these flexible rubber protective pieces get ripped, torn, or lost, leaving a live positive terminal just waiting to cause a short, a spark, or a fire!
    HCP11318 OEM positive battery cable COVER, at the battery post. For all XJ700 and XJ750-X models.
    $ 27.95
    HCP11321 OEM positive battery cable COVER, at the battery post. For all XJ900RK, RL, N/FN, and F models.
    $ discontinued
    HCP11431 Aftermarket positive battery cable (at solenoid) RUBBER TERMINAL BOOT, use 1 per cable. Fits over the end terminal and covers the solenoid terminal stud. Slightly smaller than original and will require some "persuasion" (and lubrication) to fit over the battery cable end terminal properly. Fits all XJ550, FJ600, XJ650 Turbo, XJ700, XJ750, XJ900RK, and XJ1100 models. Can be used on XJ650 Maxim, Midnight Maxim, and RJ Seca models, but this is just the small end cover for the stud and is not a "full-length" cover as originally used on these models. Each:
    $ 11.95
    Negative (black) Battery and Frame Ground Cables:
    NOTE: on all XJ550, XJ700, and XJ750-X models, the negative battery cable is "integrated" with a separate, small gauge harness ground lead wire. These replacement battery cables are just the heavy-gauge cable, and do not include the smaller accessory lead wire. These models will require you to salvage the accessory wire cut it off from your original battery cable, strip the cut end, and install one of the closed ring terminals listed below onto this end, which then allows you to install that original wire onto it's main harness mating terminal or connector.
    HCP2937 OEM black NEGATIVE BATTERY CABLE, fits all XJ1100 models.
    $ discontinued
    HCP1604 Aftermarket black 6-gauge NEGATIVE BATTERY CABLE, 4" long. Each:
    $ 12.95
    HCP1605 Aftermarket black 6-gauge NEGATIVE BATTERY CABLE, 6" long. This cable can be used as a replacement negative battery cable on all XJ1100 models. Each:
    $ 13.95
    HCP11429 Aftermarket black 6-gauge NEGATIVE BATTERY CABLE, 7" long. This cable can be used as a replacement negative battery cable on all XJ1100 models. Each:
    $ 12.95
    HCP1606 Aftermarket black 6-gauge NEGATIVE BATTERY CABLE, 8" long. This cable can be used to replace the original TCI-to-frame ground cable on all XJ650 (except Turbo), XJ750 Maxim and XJ750 Midnight Maxim models. Each:
    $ 13.95
    HCP1607 Aftermarket black 6-gauge NEGATIVE BATTERY CABLE, 10" long. This cable can be used as a direct replacement for the original negative battery cable on all XJ650 models (except Turbo), and also to replace the original integrated negative battery cable on all XJ550, XJ700, and XJ750-X models. You will have to save, modify, and re-use the additional ground wire off of your original cable. NOTE: this cable will be a tight fit on some of these models, but it will reach! Each:
    $ 14.95
    Battery Cable Terminals and Hardware:
    As mentioned previously, when replacing an "integrated" style original battery cable to an aftermarket cable, if your original positive cable has the main harness lead wire integrated into the battery cable, you will either have to salvage the main harness lead off of your original cable, and then add a proper sized RING TERMINAL to the end of it (and attach this ring terminal to the solenoid "hot" stud, same as what the positive battery cable is attached to), or, you will need to replace your original main harness lead wire with our HCP395 solenoid-to-main harness POSITIVE WIRE LEAD unit, which is ready to plug-and-play and has both wire ends properly terminated.
    Some negative battery cables also were of the "integrated" type, with an additional small-gauge ground wire lead that plugged into a matching main harness connector. For such models, when using our replacement ground cables, you should cut off the small secondary wire and terminate it with a ring connector, and then install it along with the battery ground cable at it's original location.
    HCP395 OEM solenoid-to-main harness POSITIVE WIRE LEAD, for use on all on the following models either as an original replacement, or as a plug-and-play replacement when using an aftermarket positive battery cable to replace an original "integrated" positive cable. Can be used as a replacement on all XJ550 models, XJ650 Turbo, XJ700, XJ750, and XJ900RK models. Includes the ring terminal for the solenoid end and plastic harness connector at the main harness end already installed.
    $ 32.95
    HCP12837MFWHT Aftermarket white plastic MALE CONNECTOR SHELL, single place, used on all of the following circuits listed below. Accepts the HCP12898BR1418 female flat-blade terminal. Each:
    $ 5.95
    * HCP12837MFWHT (the male shell with the female latching peg) is used on:
    - Main battery power lead-in harness, on the positive battery cable harness side of the connection: all XJ models except XJ1100 models.
    HCP12898BR1418 Aftermarket original style "large" straight brass FEMALE LARGE FLAT BLADE TERMINAL. Used only within the main battery lead male connector shell HCP12837MFxx on all models except XJ1100. Each:
    $ 1.25
    HCP10092TP1218 Aftermarket brass closed RING TERMINAL, original crimp-on style connector (we recommend soldering as well as crimping for electrical integrity of the connection). Proper size for the hot solenoid stud, or for use with any of the engine case ground bolts. Terminal only, no insulation included. Each:
    $ 0.95
    HCP11134BRK Aftermarket brass closed RING TERMINAL, original crimp-on style connector (we recommend soldering as well as crimping for electrical integrity of the connection). Proper size for the hot solenoid stud, or for use with any of the engine case ground bolts. Terminal with clear insulating sleeve included. Each:
    $ 1.95
    HCP2582 OEM battery post EXTENSION TERMINAL. Used only on XJ750 Maxim and Midnight Maxim models, this “zig-zag” shaped bent metal extension bar acts as the positive battery “cable” for all XJ750 Maxim and Midnight Maxim models. Uses the standard battery post phillips-drive hex screw to secure the cable to this terminal. These models also use the HCP11317 negative post extension terminal on the negative post. Each:
    $ 34.95
    HCP11317 OEM battery post EXTENSION TERMINAL. Used only on XJ750 air-cooled models and on the XJ900RK models, this L-shaped bent metal extension bar converts the battery post from a “top post” to a "side post" to accept the ring terminal on the end of the battery cable. Uses the standard battery post phillips-drive hex screw to secure the cable to this terminal. XJ750 Seca models and XJ900RK, RL, N/FN, and F models use this extender terminal on both the negative and positive battery posts, while the 1982-83 XJ750 Maxim and Midnight Maxim models use this extender only on the negative post. Each:
    $ 34.95
    HHCP11322 OEM battery post SCREW. Used on all XJ models, this is the special hex-head bolt with a phillips-drive screw slot. Used to secure the positive or negative battery cable to the battery posts when used with the original rectangular post nut. Each:
    $ 3.95
    HCP11444 Aftermarket battery post screw special thin WASHER, used under the head of the HCP11322 screw on both the positive or negative battery cables. Made of standard carbon steel. Each:
    $ 1.75
    HCP11445 Aftermarket battery post screw special thin WASHER, used under the head of the HCP11322 screw on both the positive or negative battery cables. Made of 18/8 stainless steel. Each:
    $ 1.95
    HCP11443 Aftermarket battery post screw special rectangular POST NUT, tall and narrow, it's designed to fit inside the post (regular nuts are too wide to fit). Use on both the positive or negative battery cables. Made of standard carbon steel. Each:
    $ 3.95
    HCP29029 Aftermarket battery post HARDWARE KIT. Used on all XJ models, this kit contains the screw, special flat thin flat washer, and the special rectangular nut used to secure the positive or negative battery cable to the battery posts. Each:
    $ 8.95
  17. chacal
    STARTER RELAY - SOLENOID AND RELATED:
    ep6) OEM and Aftermarket STARTER RELAY and SOLENOID. This round canister style solenoid has two terminal studs, the wire harness pigtail and connector, and is mounted into a rubber insulator.
    Your positive battery cable connects to one terminal on the solenoid, and the other terminal feeds the cable to the starter motor. The wire harness pigtail goes to your "start" push-button.
    HINTS: be aware that the blue/white wire coming off of the starter solenoid is what leads to the push-switch on your handlebar control unit, and provides the GROUND circuit for the solenoid........in other words, when you push the "start" button on the handlebar switch, all that does is complete the solenoid circuit (it provides the ground path). Thus, if the switch internals (on the start button switch) or the handlebar control switch ground is not secure, clean, etc. that may be the real problem with the solenoid.
    You can verify whether this is the problem by jumping the blue/white wire off of the solenoid directly to battery terminal negative........if the solenoid works properly, then the problem is not (fully) with the solenoid, but with something else in the ground path for the solenoid.
    If your starter motor doesn't work, and all you hear is a "click" when you press the starter button, either your battery is dead or this relay - solenoid unit is the culprit. If your starter button doesn't operate the starter ("click"), but you can short across the two big terminal studs on the front of this solenoid and engage the starter motor, then the relay within the solenoid is probably bad and this solenoid needs to be replaced.
    Here's a good overview of the diagnosis process for problems with a "no-start" condition:
    http://www.xjbikes.com/forums/threads/won’t-start-1983-yamaha-xj750-maxim.118050/#post-591103
    and
    https://www.xjbikes.com/forums/threads/help-me-plz.125369
    HCP449 OEM starter Relay - SOLENOID, fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. NOTE: this relay is slightly smaller in the diameter of the can (about 1/4" smaller), and it is also about 2" shorter, end-to-end; however, it will fit into the original rubber insulator/holder and will perform as original. Correct colored lead wires off the solenoid have the correct white plastic 2-space wiring harness connector. Includes the rubber mounting grommet: Also fits all of the following models: 1983 XV500 Virago, 1987-00 XV535 Virago, 1982-83 XZ550 Vision, 1981-82 XV920 RH/RJ (chain-drive), 1983-85 XV12, 1984-85 XVZ1200 Venture Royale, 1984 XVZ1200 Venture, and 1984-85 XVZ12D Venture Royale models. Each:
    $ 129.95
    HCP1680R Aftermarket starter Relay - SOLENOID, fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. NOTE: this relay is slightly smaller in the diameter of the can (about 1/4" smaller), and it is also about 2" shorter, end-to-end; however, it will fit into the original rubber insulator/holder and will perform as original. Correct colored lead wires off the solenoid have the correct white plastic 2-space wiring harness connector. Includes the rubber mounting grommet: Also fits all of the following models: 1983 XV500 Virago, 1987-00 XV535 Virago, 1982-83 XZ550 Vision, 1981-82 XV920 RH/RJ (chain-drive), 1983-85 XV12, 1984-85 XVZ1200 Venture Royale, 1984 XVZ1200 Venture, and 1984-85 XVZ12D Venture Royale models. Each:
    $ 79.95
    HCP22645 OEM starter Relay - SOLENOID, fits all 1992-98 XJ600 Seca II models, each:
    $ 139.95
    HCP2572 OEM starter Relay - SOLENOID, fits all XJ700 and XJ750-X models. Includes the rubber mounting grommet: Also fits all of the following models: 1984-85 FJ1100, 1986-93 FJ1200, 1988-90 FZR400, 1986-88 FZ600, 1989-99 FZR600, 1987 FZ700, 1987 FZX700 Fazer, 1985-86 and 1988 FZ750, 1989-90 and 1994-95 FZR1000, 1985-88 VMX12 V-Max, 1986-93 XVZ1300, 1986 XV250 Route 66. 1995-07 XV250 Virago, 2008-11 XV250 V-Star, and 1992-93 TDM850. Each:
    $ 149.95
    HCP1681K Aftermarket starter Relay - SOLENOID, fits all XJ700 and XJ750-X models. Correct colored lead wire off the solenoid has the correct "bullet" wiring harness connector. Includes the rubber mounting grommet: Also fits all of the following models: 1984-85 FJ1100, 1986-93 FJ1200, 1988-90 FZR400, 1986-88 FZ600, 1989-99 FZR600, 1987 FZ700, 1987 FZX700 Fazer, 1985-86 and 1988 FZ750, 1989-90 and 1994-95 FZR1000, 1985-88 VMX12 V-Max, 1986-93 XVZ1300, 1986 XV250 Route 66. 1995-07 XV250 Virago, 2008-11 XV250 V-Star, and 1992-93 TDM850. Each:
    $ 89.95
    HCP1682 Aftermarket starter Relay - SOLENOID, fits all XS1100 models. Correct colored lead wires off the solenoid have the correct white plastic 2-space wiring harness connector. Includes the rubber mounting grommet: Also fits all of the following models: 1980-82 SR250, 1976-77 XS360, 1977-79 XS400, 1980-81 XS400 Special-II, 1982-83 XS400, 1980-81 XS400 SG/SH Special, 1978 XS500, 1980-81 XS850 all, and 1977-79 XS750 models. Each :
    $ 69.95
    NOTE: the following terminal stud nut and lock washers come with all of the above complete solenoids. They are offered separate here for those people repairing or replacing missing components on original solenoids:
    HCP3996 OEM starter solenoid terminal stud NUT, alloy steel with a bright zinc-plated finish. Use 2 per unit. Fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 8.95
    HCP16570 Aftermarket starter solenoid terminal stud NUT, 18/8 stainless steel with a bright zinc-plated finish. Use 2 per unit. Fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 2.95
    HCP3703 OEM starter solenoid terminal stud NUT, use 2 per unit. Bright zinc-plated steel. Fits all 1992-94 XJ600 Seca II, and XJ900 F models. Each:
    $ 2.95
    HCP10962 Aftermarket starter solenoid terminal stud NUT, use 2 per unit. Yellow zinc-plated steel. Fits all 1992-94 XJ600 Seca II, and XJ900 F models. Each:
    $ 1.95
    HCP3704 OEM starter solenoid terminal stud NUT, use 2 per unit. Black plated alloy steel. Fits all 1995-98 XJ600 Seca II models. Each:
    $ 2.95
    HCP28898 Aftermarket starter solenoid terminal stud NUT, use 2 per unit. Black alloy steel with smooth flange as original. Fits all 1995-98 XJ600 Seca II models. Each:
    $ 1.95
    HCP10001 Aftermarket starter solenoid terminal stud NUT, use 2 per unit. Black alloy steel with serrated (locking) flange. Fits all 1995-98 XJ600 Seca II models. Each:
    $ 1.95
    HCP315 OEM starter solenoid terminal stud LOCK WASHER, use 2 per unit. Fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, starter solenoid terminal stud LOCK WASHER, use 2 per unit. Fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Eachch:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel starter solenoid terminal stud LOCK WASHER, use 2 per unit. Fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel starter solenoid terminal stud LOCK WASHER, use 2 per unit. Fits all XJ550, 1984-85 FJ600, 1986-88 YX600 Radian XJ650, 1981-84 XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Each:
    $ 1.95
    Solenoid-to-Starter Motor Cable:
    HCP11430 Aftermarket solenoid-to-starter motor CABLE, fits all XJ550 and FJ600 models. Slightly shorter than original, but will reach if the cable installation by-passes the lower frame band-strap (by the battery ground cable location on the engine block). Correct soldered and crimped terminals. End boots are included. Each:
    $ 14.95
    HCP11426 OEM solenoid-to-starter motor CABLE, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, and N/FN models. Correct soldered and crimped terminals. End boots are not included and must be re-used or purchased separate. Each:
    $ 17.95
    HCP2951 OEM solenoid-to-starter motor cable RUBBER TERMINAL BOOT, use 2 per cable. Fits over the end terminals and covers the solenoid terminal stud and the starter brush stud, protecting from moisture and shorts. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models. Each:
    $ discontinued
    HCP11431 Aftermarket solenoid-to-starter motor cable RUBBER TERMINAL BOOT, use 2 per cable. Fits over the end terminals and covers the solenoid terminal stud and the starter brush stud, protecting from moisture and shorts. Slightly smaller than original and will require some "persuasion" (and lubrication) to fit over the starter motor stud boss fitting properly. Fits all XJ550, FJ600, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models. Each:
    $ 17.95
  18. chacal
    STARTER MOTORS:
    gp2) OEM new and aftermarket re-wound STARTER MOTORS perfectly replace the originals. Rewound starters are sold on a "core charge" basis and you must return to us a usable, same-model starter motor core in order to receive your core charge refund.
    Checking Starter Motors:
    As far as checking your starter motor, the only tests that you can do are on the commutator (the segmented "snout" of the entire armature) and the brushes, and are as follows:
    a) if the surface is commutator is dirty, clean it with 800-grit or finer sandpaper or crocus cloth. Make sure that any dust generated by this process is completely removed.
    b) the mica insulation on the armature.....in between each of the raised "segments"......should be:
    * 0.8mm (.03") below the level of adjoining segments on XJ550, FJ600, FZ600, and YX600 starter motors.
    * 0.6mm (.025") below the level of adjoining segments on all XJ650, XJ700, XJ750, and XJ900 starter motors.
    If the depth of this mica insulation below the level of the segments is less than the specifications given above, you should scrape away the insulation until that depth is reached (a hacksaw blade or similar tool can be shaped to fit), or take the armature to an electrical service shop to have them undercut the mica to the appropriate depth.
    c) check the raised segments for continuity between each individual segment and each and every other segments. There should be continuity.
    d) check for continuity between every segment (assuming the test in "c" above has already been performed) and the shaft of the armature. There should not be any continuity. Note that shorted commutator rings can also cause a reverse-direction (“backwards”) motor spin….. the correct direction of rotation would be in the same direction as your tires rotate when moving forward (orientation as when the starter motor is installed on the bike; thus, when viewing the starter motor from the butt end-----not the gear end----that would be counter-clockwise.)
    e) check the resistance of the internal coil windings of the armature. You do this via measuring the resistance across every two adjoining segments. It should be:
    * 0.012 ohms +/- 6% at 70-degrees F. for all XJ550, FJ600, FZ600, and YX600 starter motors.
    * 0.014 ohms +/- 6% at 70-degrees F. for all XJ650, XJ700, XJ750, and XJ900 starter motors.
    f) measure the outside diameter of the segments. The minimum acceptable diameter is 27.00mm.
    If any of the above tests (c-f) fails, then the armature is bad and needs to be replaced.
    g) measure the length of the brushes. The minimum acceptable length is:
    * 5.00mm for all XJ550, FJ600, FZ600, and YX600 starter motors.
    * 8.50mm for all XJ650, XJ700, XJ750, and XJ900 starter motors.
    h) check for continuity between each brush and the brush plate. There should be continuity.
    i) check for continuity between each brush and its terminal bolt. There should be continuity.
    j) check the condition of the shaft end bushings or bearings in the case. If they are worn, then they needs to be replaced.
    k) check the condition of the ring and planetary gears. If they are worn or chipped, then they need to be replaced.
    l) the only other procedure that is mentioned in the factory manual is to check the condition of the brush springs, and you are supposed to do that by comparing them to new ones.....which is kind of hard to do! The springs should be considered serviceable if they snap the brushes firmly back into position when released from tension. The exact specification is:
    * 550 +/- 50 grams (18.5 +/- 1.5 ounces) of pressure, measured via the use of a spring gauge, for all XJ550, FJ600, FZ600, and YX600 starter motors.
    * 800 +/- 150 grams (28.22 +/- 5.29 ounces) of pressure, measured via the use of a spring gauge, for all XJ650, XJ700, XJ750, and XJ900 starter motors.
    Also, be very careful when re-assembling a starter motor. There is an alignment notch in the brush plate that must be aligned with the case properly, as well as alignment notches on the outside of the main case to the end caps. Failure to install the brushes and brush plate in their proper orientation can cause the starter motor to not work at all, or to even spin backwards! The correct rotation of the starter motor is counter-clockwise, looking at the butt-end of the motor (as it is installed on the engine); or, clockwise if you're looking the starter drive gear dead in its eye..........
    Another simple check is to rotate the external toothed gear with your hand clockwise (as viewed from gear end of the starter motor). Place a voltmeter positive lead (the red probe) on the large terminal of the starter motor (the one that the battery cable is normally attached to), and place the voltmeter negative lead (the black probe) grounded somewhere on the engine case or frame. You should see about a positive 0.3 volts (DC) being generated when you rotate the gear.
    Finally, always be sure to use a premium, high-temperature grease to lubricate the internal gears and bearings, and do not attempt to clean the armature via the use of strong solvent sprays (brake cleaner, carb cleaner, etc.) as the solvents may break down the insulation on the coil windings, causing an internal short.
    Complete Starter Motors:
    HCP4155 Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and *1986-90 YX600 Radian models. This unit has the silver finish and is correct only for XJ550 models, but will fit all of the above models. *NOTE: these are the 4-brush Mitsuba style motors which were originally supplied on the 1986-88 YX600 engines; 1989-90 models used a 2-brush motor which is not available. The 4-brush motor will fit and work properly as a direct replacement for the original 2-brush motor. A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    $ 199.95 + $ 115.00 core charge
    HCP20068 OEM original, brand new STARTER MOTOR fits all 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. This unit has a black finish and is correct only for the FJ600, FZ600, and YX600 models, but will also fit XJ550 models. A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    $ 499.95 + $ 115.00 core charge
    HCP20435 Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and *1986-90 YX600 Radian models. This unit has a black finish and is correct only for the FJ600, FZ600, and YX600 models, but will also fit XJ550 models. *NOTE: these are the 4-brush Mitsuba style motors which were originally supplied on the 1986-88 YX600 engines; 1989-90 models used a 2-brush motor which is not available. The 4-brush motor will fit and work properly as a direct replacement for the original 2-brush motor. A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    HCP19794 Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ600 Seca II models, this version features the silver end cap (at the cable end) which is correct for 1992-95 models (1996-98 models used the same motor, but with a black-painted end cap). A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    $ 219.95 + $ 95.00 core charge
    HCP19794BLK Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ600 Seca II models, this version features the black end cap (at the cable end) which is correct for 1996-98 models (1992-95 models used the same motor, but with a silver-painted end cap). A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    $ 229.95 + $ 115.00 core charge
    HCP476 OEM original, brand new STARTER MOTOR fits all XJ650, XJ700, XJ750, and XJ900 models. Features the correct silver finish on the case, which is correct for all of the following models: XJ650 Maxim, 1985 XJ700 N/NC air-cooled models, 1981-84 XJ750 Maxim, 1981-82 XJ750 Seca, and XJ900F, N, and FN models.
    $ 399.95
    HCP29058SIL Aftermarket brand new STARTER MOTOR fits all XJ650, XJ700, XJ750, and XJ900 models. Features the correct silver finish on the case, which is correct for all of the following models: XJ650 Maxim, 1985 XJ700 N/NC air-cooled models, 1981-84 XJ750 Maxim, 1981-82 XJ750 Seca, and XJ900F, N, and FN models.
    $ 199.95
    HCP4156 Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ650, XJ700, XJ750, and XJ900 models. Features the correct silver finish on the case, which is correct for all of the following models: XJ650 Maxim, 1985 XJ700 N/NC air-cooled models, 1981-84 XJ750 Maxim, 1981-82 XJ750 Seca, and XJ900F, N, and FN models.
    $ 179.95
    HCP477 OEM original, brand new STARTER MOTOR fits all XJ650, XJ700, XJ750, and XJ900 models. Features the correct black finish on the case, which is correct for all of the following models: XJ650 Midnight Maxim, XJ650 Turbo, XJ650RJ Seca, XJ700 all (except 1985 N/NC air-cooled) models, XJ750 Midnight Maxim, 1983 XJ750 Seca, XJ750RL Seca, XJ750-X, and XJ900RK and RL models.
    $ discontinued
    HCP29058BLK Aftermarket brand new STARTER MOTOR fits all XJ650, XJ700, XJ750, and XJ900 models. Features the correct black finish on the case, which is correct for all of the following models: XJ650 Midnight Maxim, XJ650 Turbo, XJ650RJ Seca, XJ700 all (except 1985 N/NC air-cooled) models, XJ750 Midnight Maxim, 1983 XJ750 Seca, XJ750RL Seca, XJ750-X, and XJ900RK and RL models.
    $ 199.95
    HCP4156BLK Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ650, XJ700, XJ750, and XJ900 models. Features the correct black finish on the case, which is correct for all of the following models: XJ650 Midnight Maxim, XJ650 Turbo, XJ650RJ Seca, XJ700 all (except 1985 N/NC air-cooled) models, XJ750 Midnight Maxim, 1983 XJ750 Seca, XJ750RL Seca, XJ750-X, and XJ900RK and RL models.
    $ discontinued
    HCP4157 Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ1100 and XS1100 models. Silver finish on the end cap, which is correct for all XJ1100 and XS1100 Standard and Special (except Midnight Special) models.. A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    $ 219.95.00 + $ 115.00 core charge
    HCP4157BLK Aftermarket rebuilt/re-wound STARTER MOTOR fits all XJ1100 and XS1100 models. Black finish on the end cap, which is correct for all XS1100 Midnight Special models.. A $ 115.00 core charge applies to this item, and a re-usable, re-buildable, same-model starter motor must be returned for the core charge to be refunded. NOTE: "re-usable" and “re-buildable” means it is complete and has not been physically damaged in any way, in particular the end caps and case, and all of the gears cannot be damaged or chewed up in any way, and the armature must be fully intact and un-damaged physically.
    Starter Motor Rebuild Parts:
    sms3) An assortment or original OEM and aftermarket starter motor rebuild parts are available----BRUSHES, O-RINGS, GASKETS, ETC. See the complete list of items available below.
    This information should assist you in visualizing what the starter motor rebuild process will involve. Although shown is the XJ650/700/750/900 type starter motor, the same process applies to all XJ models:
    http://xjbikes.com/forums/index.php?threads/45727
    and a great video of the entire process from start (no pun intended) to finish:
    And though you may not have your own personal growler, follow these basic tips anyway while you have your starter motor apart for the rebuild:
    https://www.xjbikes.com/forums/threads/tackling-starter-rebuild-this-weekend.123652
    XJ550, 1984-85 FJ600, 1986-88 FZ600, and *1986-90 YX600 Radian models:
    *NOTE: while most of the models listed here use the tried-and-true 4-brush (2 positive brushes and 2 negative brushes) Mitsuba starter motors, some 1989-90 YX600 models were fitted with 2-brush motors (a single positive and single negative brush), and as such any electrically-related rebuild parts and rebuild kits listed below are not correct and will not work in such 2-brush motors. While the 2-brush and 4-brush motors used on these models will physically interchange with each other as a complete unit, their internals are different and will not interchange. Owners with the 2-brush motors can use the HCP27307 brushes-and-plate set listed further below for the 1992-98 XJ600 Seca II models, but that is the only rebuild part we have available for the 2-brush motors (although that brush plate assembly for the Seca II starter will work on these earlier 2-brush Mitsuba starter motors, none of the other components will interchange, as they are completely different design motors).
    It is also possible that if your original starter motor was replaced at some time in the dim-and-distant past, the replacement motor (whether new or rebuilt) may have been a 2-brush or a 4-brush version, so you should check carefully before ordering. Obviously, due to the much broader original usage of the 4-brush motors, they are much more common than the 2-brush motors.
    HCP4020 Aftermarket starter motor BRUSHES SET, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-88 YX600 Radian models. Set of four brushes, two positive and two negative. Order one set to do one starter. NOTE: you must be able to fabricate a method of attaching the brush leads to your original brush plate. Original leads are attached using special equipment which is not possible to duplicate using common methods (soldering, etc.). A much better solution is to replace the entire brush plate assembly with one of part numbers below.
    $ 22.95
    HCP485 OEM starter motor BRUSHES AND PLATE SET, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-88 YX600 Radian models. Contains the negative brushes and their mounting plate, and the positive brushes and their holder "band". NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors.
    $ 129.95
    HCP4160 Aftermarket starter motor BASIC REBUILD KIT, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-88 YX600 Radian models. This basic rebuild kit includes the negative brushes and their mounting plate, the positive brushes and their holder "band", the end cap rubber ring gaskets, a positive post stud, the stud insulator, and stud hardware. NOTE: brushes and plate differ in appearance and fitment from original but are designed to work properly in original starter motors. There is a molded plastic insulator “shroud” (not used in original starter motors) that must be used with the components in this kit.
    $ 49.95
    HCP18273 Aftermarket starter motor COMPLETE REBUILD KIT, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-88 YX600 Radian models. Complete rebuild kit contains the negative brushes and their mounting plate, the positive brushes and their holder "band", a nose o-ring, the end cap rubber ring gaskets, the shaft end bushing, that shaft center support bushing, the shaft bearing, shaft oil seal, reduction gear bushings, circlips, positive post stud, stud insulator, and stud hardware. All the items necessary to do a complete starter motor overhaul. NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors. This is the only complete kit on the market, as all other “complete” rebuild kits out there do not include the positive stud, and your original stud will not fit the positive brushes holder included in aftermarket rebuild kits!
    $ 69.95
    HCP478 OEM starter motor snout-to-engine case O-RING, fits all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, and 1986-90 YX600 Radian models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 19.95
    HCP2321 Aftermarket starter motor snout-to-engine case O-RING, fits all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, and 1986-90 YX600 Radian models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 12.95
    HCP4845 OEM starter motor END GEAR CIRCLIP, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Use 1 per starter. . NOTE: this is the smaller of the two circlips, located on the very end of the shaft
    $ 7.95
    HCP22885 Aftermarket starter motor END GEAR CIRCLIP, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Black phosphate coated spring steel. Use 1 per starter. NOTE: on XJ550, FJ600, FZ600, and YX600 starter motors, this is the smaller of the two circlips, located on the very end of the shaft (retaining the drive gear). On XJ650-900 models, it is the only circlip used, and it too is on the very end of the shaft (retaining the drive gear).
    $ 4.95
    HCP23688 Aftermarket starter motor END GEAR CIRCLIP, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Passivated 400-series stainless spring steel. Use 1 per starter. NOTE: on XJ550, FJ600, FZ600, and YX600 starter motors, this is the smaller of the two circlips, located on the very end of the shaft (retaining the drive gear). On XJ650-900 models, it is the only circlip used, and it too is on the very end of the shaft (retaining the drive gear).
    $ 5.95
    HCP23677 Aftermarket starter motor SHAFT CIRCLIP, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Black phosphate coated spring steel. Use 1 per starter. NOTE: this is the larger of the two circlips, located midway down the shaft, below the drive gear and above the ball bearing.
    $ 5.95
    HCP2568 OEM starter motor positive brush lead stud INNER NUT, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models, not the same in appearance as original but will work properly. This flanged nut secures the positive brush stud to the motor case.
    $ 8.95
    HCP315 OEM starter motor positive brush lead stud LOCK WASHER, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models, not the same in appearance as original but will work properly.
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, starter motor positive brush lead stud LOCK WASHER, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models.
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel starter motor positive brush lead stud LOCK WASHER, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models.
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel starter motor positive brush lead stud LOCK WASHER, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models.
    $ 1.95
    HCP2176 OEM starter motor positive brush lead stud OUTER NUT, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, and all XJ900 models, not the same in appearance as original but will work properly. This nut secures the starter motor power cable to the positive brush lead wire stud.
    $ 4.95
    HCP29085 Aftermarket starter motor positive brush lead stud OUTER NUT, bright zinc-plated alloy steel, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, and all XJ900 models. This nut secures the starter motor power cable to the positive brush lead wire stud.
    $ 1.95
    HCP24059 Aftermarket starter motor positive brush lead stud OUTER NUT, black-oxide coated stainless steel. fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, and all XJ900 models. This nut secures the starter motor power cable to the positive brush lead wire stud.
    $ 3.95
    HCP24035 Aftermarket starter motor positive brush lead stud OUTER NUT, made from 18/8 stainless steel, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, XJ750, and all XJ900 models. This nut secures the starter motor power cable to the positive brush lead wire stud.
    $ 2.95
    HCP2563 OEM starter motor MAIN CASE GASKET, seals the end caps to the center case. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-88 YX600 Radian models. Use 2 per starter on all 4-brush motors, and use 1 per starter (at the “engine end” cap) on 2-brush motors (primarily 1989-90 YX600 Radian models). Each:
    $ discontinued
    HCP27301 OEM starter motor MAIN CASE GASKET, seals the end caps to the center case. Use 2 per starter on all 1992-98 XJ600 Seca II, 1988-90 FZR400, 1989-99 FZR600R, and 1995-07 YZF600R engines. Use 1 per starter (at the “outer end” cap) on 2-brush motors (primarily 1989-90 YX600 Radian models). Each:
    $ 47.95
    NOTE: the following bolts secure and "cinch together" one end cap to the other end cap, holding them tight to the central starter motor main body:
    HCP14288 Aftermarket starter motor CASE BOLT, cinches the end caps together to the center case. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. This allen-drive, socket head cap screw replaces the original phillips-drive, panhead screw, and is made from a bright-finish 18-8 stainless steel material. Use with the HCP319 lockwasher below. Use 2 per starter. Each:
    $ 3.95
    HCP14289 Aftermarket starter motor CASE BOLT, cinches the end caps together to the center case. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. This allen-drive, socket head cap screw replaces the original phillips-drive, panhead screw, and is made from a black-oxide coated alloy steel material. Use with the HCP321 lockwasher below. Use 2 per starter. Each:
    $ 4.95
    HCP319 Aftermarket starter motor case bolt LOCK WASHER, 18-8 stainless steel. Use with the HCP14288 case bolt above. Each.
    $ 2.95
    HCP321 Aftermarket starter motor case bolt LOCK WASHER, black-oxide coated alloy steel. Use with the HCP14289 case bolt above. Each.
    $ 1.95
    NOTE: the following are the two forward bolts (at the 7- and 11-o’clock positions) that secure the starter motor end cap to the engine:
    HCP3197 OEM starter motor mounting FLANGE BOLT, to attach the starter motor end case to the engine. Black finish. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models. Use 2 per starter. Each:
    $ 8.95
    HCP21306 Aftermarket starter motor mounting FLANGE BOLT, to attach the starter motor end case to the engine. Black finish. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1996-98 XJ600 Seca II models. Use 2 per starter. Each:
    $ 2.95
    HCP27308 Aftermarket starter motor mounting FLANGE BOLT, to attach the starter motor end case to the engine. Bright finish. Fits all 1992-95 XJ600 Seca II models. Use 2 per starter. Each:
    $ 2.95
    NOTE: the following is used to secure the starter motor end cap at the rear (4-o’clock position) to the shifter case cover:
    HCP966 OEM starter motor mounting MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Correct for all XJ550 models. Each:
    $ 7.95
    HCP971 OEM starter motor mounting MOUNTING BOLT, allen head hex-drive, black finish. Correct for all 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Each:
    $ 7.95
    HCP22253 Aftermarket starter motor mounting MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Each:
    $ 1.95
    HCP228 Aftermarket starter motor mounting MOUNTING BOLT, allen head hex-drive, black-oxide coated steel. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models. Each:
    $ 1.95
    HCP2779 Aftermarket starter motor mounting MOUNTING BOLT, allen head hex-drive, black-oxide finish, features self-locking threads. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models. Each:
    $ 2.95
    HCP226 Aftermarket starter motor mounting MOUNTING BOLT, allen head hex-drive, bright 18-8 stainless steel finish. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian models. Each:
    $ 2.95
    1992-98 XJ600 Seca II models:
    HCP27307 OEM starter motor BRUSH AND PLATE SET, fits all 1992-98 XJ600 Seca II models. Complete set of brushes with the mounting plate, positive stud, and stud hardware. NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors.
    $ 219.95
    HCP27294 Aftermarket starter motor COMPLETE REBUILD KIT, fits all 1992-98 XJ600 Seca II models. Complete set of two brushes with the mounting plate, nose o-ring, end cap gaskets, needle bearing and oil seal, armature shaft bushing and shim washers, positive post stud insulator and associated hardware. All the items necessary to do a complete starter motor overhaul. NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors.
    $ 59.95
    HCP22538 OEM starter motor snout-to-engine case O-RING, fits all 1992-98 XJ600 Seca II models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 10.95
    HCP1536 Aftermarket starter motor snout-to-engine case O-RING, fits all 1992-98 XJ600 Seca II models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 9.95
    $ 39.95
    HCP2568 OEM starter motor positive brush lead stud INNER NUT, fits all 1992-98 XJ600 Seca II models. This flanged nut secures the positive brush stud to the motor case. Use 2 per motor. Each
    $ 8.95
    HCP27302 OEM starter motor CASE BOLT, cinches the end caps together to the center case. Fits all 1992-98 XJ600 Seca II, 1988-90 FZR400, 1989-99 FZR600R, and 1995-07 YZF600R engines. Use 2 per starter. Each:
    $ 23.95
    $ 8.95
    $ 2.95
    $ 2.95
    XJ650, XJ700, XJ750, and XJ900RK models:
    HCP486 Aftermarket starter motor BRUSH HOLDER, fits all XJ650, XJ700, XJ750, and all XJ900 models. Use one per starter, does not include the brushes.
    $ 49.95
    HCP480 OEM starter motor POSITIVE BRUSH, fits all XJ650, XJ700, XJ750, and all XJ900 models.
    $ 21.50
    HCP482 OEM starter motor NEGATIVE BRUSH, fits all XJ650, XJ700, XJ750, and all XJ900 models.
    $ 21.50
    HCP4158 Aftermarket starter motor BRUSH SET, fits all XJ650, XJ700, XJ750, and all XJ900 models. Order one set to do one starter.
    $ 21.95
    HCP4159 Aftermarket starter motor BRUSH AND PLATE SET, fits all XJ650, XJ700, XJ750, and all XJ900 models. Complete set of two brushes with the mounting plate. Includes the stud insulator bushings set. NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors.
    $ 47.95
    HCP18274 Aftermarket starter motor COMPLETE REBUILD KIT, fits all XJ650, XJ700, XJ750, and all XJ900 models. Complete set of two brushes with the mounting plate, nose o-ring, case o-rings (2), drive gear bearing and oil seal, end cap bronze bushing, positive post stud insulators and hardware. All of the items necessary to do a complete starter motor overhaul. NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors.
    $ 69.95
    HCP6375 Aftermarket starter motor positive brush wiring lead STUD BUSHINGS SET, fits all XJ650, XJ700, XJ750, and all XJ900 models. Complete set of two plastic bushings that insulate the positive brush stud where it goes through the starter case. One set does one starter. NOTE: bushings may differ in appearance from original but are designed to work properly in original starter motors. These bushings are already included in the HCP4159 Brush and Plate Set and the HCP18274 Complete Rebuild Kit listed above.
    $ 13.95
    HCP3072 OEM starter motor END GEAR CIRCLIP, fits all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F models, XJ1100, and all XS1100 models. Use 1 per starter.
    $ 9.95
    $ 4.95
    $ 5.95
    HCP4976 OEM starter motor armature shaft SPACER WASHER, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 1 per starter. This ultra-thin shim “washer” fits on the armature at brush-plate end of the shaft. The larger, thicker washer that fits onto the armature shaft at the “gear end” of the shaft is different and is not currently available.
    $ 7.95
    HCP2568 OEM starter motor positive brush lead stud INNER NUT, fits all XJ650, XJ700, XJ750, and all XJ900 models. This flanged nut secures the positive brush stud to the motor case.
    $ 8.95
    HCP315 OEM starter motor positive brush lead stud LOCK WASHER, fits all XJ650, XJ700, XJ750, and XJ900 models.
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, motor positive brush lead stud LOCK WASHER, fits all XJ650, XJ700, XJ750, and XJ900 models.
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel motor positive brush lead stud LOCK WASHER, fits all XJ650, XJ700, XJ750, and XJ900 models.
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel motor positive brush lead stud LOCK WASHER, fits all XJ650, XJ700, XJ750, and XJ900 models.
    $ 1.95
    $ 4.95
    $ 1.95
    $ 3.95
    $ 2.95
    HCP479 OEM starter motor snout-to-engine case O-RING, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 14.95
    HCP2320 Aftermarket starter motor snout-to-engine case O-RING, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 9.95
    HCP2564 OEM starter motor END CAP O-RING, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per starter.
    $ 21.95
    HCP18663 Aftermarket starter motor END CAP O-RING, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 2 per starter.
    $ 14.95
    HCP3079 OEM starter motor CASE BOLT, cinches the end caps together to the center case. Fits all XJ650, XJ700, XJ750, and all XJ900 N, FN, and F models. Use 2 per starter. Bright plated. Some models used black finished bolts. Each:
    $ 33.95
    HCP15324 Aftermarket starter motor CASE BOLT, cinches the end caps together to the center case. Fits all XJ650, XJ700, XJ750, and all XJ900 N, FN, and F models. This allen-drive, socket head cap screw replaces the original phillips-drive, panhead screw, and is made from a black-oxide coated alloy steel material. Use with the HCP59 lockwasher below. Use 2 per starter. Each:
    $ 9.95
    HCP59 Aftermarket starter motor case bolt LOCK WASHER, black-oxide coated steel. Use with the HCP15324 case bolt above. Each.
    $ 1.95
    HCP3080 OEM starter motor-to-engine case SHORT BOLT, to attach the starter motor outer end to the engine case boss, rear position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. Black, flanged hex-head bolt. Some models used natural finished bolts. Each:
    $ 3.95
    HCP14280 Aftermarket starter motor-to-engine case SHORT BOLT, to attach the starter motor outer end to the engine case boss, rear position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. 18-8 stainless steel, bright finish, hex-head bolt. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 2.95
    HCP14281 Aftermarket starter motor-to-engine case SHORT BOLT, to attach the starter motor outer end to the engine case boss, rear position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. 18-8 stainless steel, bright finish, allen-drive bolt matches the style of the side cover bolts. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 1.95
    HCP14282 Aftermarket starter motor-to-engine case SHORT BOLT, to attach the starter motor outer end to the engine case boss, rear position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. Black-oxide coated alloy steel, allen-drive bolt matches the style of the side cover bolts. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 1.95
    HCP14287 Aftermarket starter motor-to-engine case LONG BOLT, to attach the starter motor outer end to the engine case boss, forward position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. 18-8 stainless steel, bright finish, hex-head bolt. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 3.95
    HCP28070 Aftermarket starter motor-to-engine case LONG BOLT, to attach the starter motor outer end to the engine case boss, forward position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. Class 10.0 alloy steel, black finish, hex-head bolt. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 3.95
    HCP14288 Aftermarket starter motor-to-engine case LONG BOLT, to attach the starter motor outer end to the engine case boss, forward position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. 18-8 stainless steel, bright finish, allen-drive bolt matches the style of the side cover bolts. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 3.95
    HCP14289 Aftermarket starter motor-to-engine case LONG BOLT, to attach the starter motor outer end to the engine case boss, forward position. Fits all XJ650, XJ700, XJ750, and XJ900RK and RL models. Use 1 per starter. Black-oxide coated alloy steel, allen-drive bolt matches the style of the side cover bolts. Note that the original bolt has a flanged head, which is not present on this replacement bolt, so you will need to use one of the washers listed below with this bolt. Each:
    $ 4.95
    HCP6642 Aftermarket starter motor-to-engine case mounting bolt FLAT WASHER, required for use with any of the aftermarket mounting bolts listed above. Zinc-plated steel. Use 1 per long or short aftermarket bolts. Each:
    $ 1.95
    HCP6643 Aftermarket starter motor-to-engine case mounting bolt FLAT WASHER, required for use with any of the aftermarket mounting bolts listed above. 18-8 stainless steel with a natural finish. Use 1 per long or short aftermarket bolts. Each:
    $ 2.95
    HCP25756 Aftermarket starter motor-to-engine case mounting bolt FLAT WASHER, required for use with any of the aftermarket mounting bolts listed above. 316 stainless steel with a natural finish. Use 1 per long or short aftermarket bolts. Each:
    $ 3.95
    HCP14285 Aftermarket starter motor-to-engine case mounting bolt FLAT WASHER, required for use with any of the aftermarket mounting bolts listed above. Black-oxide coated 18-8 stainless steel. Use 1 per long or short aftermarket bolts. Each:
    $ 2.95
    HCP14284 Aftermarket starter motor-to-engine case mounting bolt FLAT WASHER, required for use with any of the aftermarket mounting bolts listed above. Black-oxide coated hardened alloy steel. Use 1 per long or short aftermarket bolts. Each:
    $ 2.95
    XJ1100 and XS1100 models:
    HCP481 OEM starter motor POSITIVE BRUSH, fits all XJ1100 and XS1100 models.
    $ 34.00
    HCP483 OEM starter motor NEGATIVE BRUSH, fits all XJ1100 and XS1100 models.
    $ 34.00
    HCP4908 Aftermarket starter motor BRUSH SET, fits all XJ1100 and XS1100 models. Order one set to do one starter.
    $ 24.95
    HCP18275 Aftermarket starter motor COMPLETE REBUILD KIT, fits all XJ1100 and XS1100 models. Complete set of four brushes with the mounting plate, brush springs, nose o-ring, end cap o-ring, case gasket, bearing and oil seals, bushing, collars, positive post stud insulator and washers. All the items necessary to do a complete starter motor overhaul. NOTE: brushes and plate may differ in appearance from original but are designed to work properly in original starter motors.
    $ 59.95
    HCP2566 OEM starter motor snout-to-engine case O-RING, fits all XJ1100 and XS1100 models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 25.95
    HCP21661 Aftermarket starter motor snout-to-engine case O-RING, fits all XJ1100 and XS1100 models. It's a good idea to replace this o-ring whenever the starter motor is removed from the engine before re-installation.
    $ 14.95
    HCP6841 Aftermarket starter motor END CAP O-RING, fits all XJ1100 and XS1100 models, as well as all of the following engines: 1976-77 XS360 C/D, 1977 XS400 D, 1978-81 XS400 D/E/F/G/SG//H/SH, 1975-76 XS500 B/C, 1977-78 XS500 D/E, 1973-74 TX500, 1977-79 XS750 D/2D/E/SE-31/E_227/SF, 1980-81 XS850 G/SG/LG/H/SH/LH, 1984-87 XV700 Virago, 1981-83, 1988-89 XV750 Virago, 1984-89 XV1100 Virago, 1981-82 XV920 RH/RJ, 1982-83 XV920 J/K/MK, 1984-85 FJ1100, 1986-87, 1989-90 FJ1200, 1985-86 and 1988--92 VMX12 V-Max, 1983-84 and 1989 XVZ12, and 1986-89 XVZ13 models. Use 1 per starter.
    $ discontinued
    $ 4.95
    $ 5.95
    HCP3996 OEM starter motor positive stud NUT, alloy steel with a bright zinc-plated finish, use 2 per starter motor or all XJ1100 and all XS1100 engines. Each:
    $ 8.95
    HCP16570 Aftermarket starter motor positive stud NUT, 18/8 stainless steel with a bright zinc-plated finish, use 2 per starter motor or all XJ1100 and all XS1100 engines. Each:
    $ 2.95
    HCP3077 OEM starter motor case LONG BOLT, cinches the end caps together to the center case. Fits all XJ1100 models. Use 2 per starter. Each:
    $ 12.95
    HCP3701 OEM starter motor cover mounting BOLT, use 2 on all XJ1100 models. Originals were bright plated, these replacements feature a dark phosphate plating. Each:
    $ 3.95
    HCP13157 Aftermarket starter motor cover mounting BOLT, use 2. Bright plated hex-head 18/8 stainless steel bolt is correct for all for all XJ1100 models. Each:
    $ 2.95
    HCP13158 Aftermarket starter motor cover mounting BOLT, use 2. Black-oxide coated hex-head 18/8 stainless steel bolt is correct for all for all XJ1100 models. Each:
    $ 2.95
    HCP2533 OEM starter motor cover mounting BOLT, use 1 on all XJ1100 models. The original alloy steel hex-head bolt featured a bright zinc plating, but this superseded version has a black oxide coating. If you desire the original appearance, select either the HCP17146 or HCP17148 bolts below. Each:
    $ 3.95
    HCP17146 Aftermarket starter motor cover mounting BOLT, use 1 on all XJ1100 models. Zinc-plated alloy steel hex-head bolt. Each:
    $ 1.95
    HCP17148 Aftermarket starter motor cover mounting BOLT, use 1 on all XJ1100 models. Bright finish 18-8 stainless steel hex-head bolt. Each:
    $ 2.95
    HCP17147 Aftermarket starter motor cover mounting BOLT, use 1 on all XJ1100 models. Black-oxide coated alloy steel hex-head bolt as original. Each:
    $ 1.95
    HCP2424 Aftermarket starter motor cover mounting BOLT, use 1 on all XJ1100 models. Black oxide coated alloy steel socket head, allen-key drive bolt. Each:
    $ 1.95
    HCP80 Aftermarket starter motor cover mounting BOLT, use 1 on all XJ1100 models. Black oxide coated alloy steel socket head, allen-key drive bolt. Features a small nylon thread patch, making this a self-locking bolt. Each:
    $ 2.95
    HCP2423 Aftermarket starter motor cover mounting BOLT, use 1 on all XJ1100 models. Bright 18-8 stainless steel socket head, allen-key drive bolt. Each:
    $ 2.95
    HCP2173 OEM starter motor cover mounting bolt FLAT WASHER, use a total of 3 on all XJ1100 models, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket starter motor cover mounting bolt FLAT WASHER, zinc-plated alloy steel with a natural finish, use a total of 3 on all XJ1100 models, each:
    $ 1.95
    HCP6643 Aftermarket starter motor cover mounting bolt FLAT WASHER, 18-8 stainless steel with a natural finish, use a total of 3 on all XJ1100 models, each:
    $ 2.95
    HCP25756 Aftermarket starter motor cover mounting bolt FLAT WASHER, 316 stainless steel with a natural finish, use a total of 3 on all XJ1100 models, each:
    $ 3.95
    HCP14285 Aftermarket starter motor cover mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use a total of 3 on all XJ1100 models, each:
    $ 2.95
    HCP14284 Aftermarket starter motor cover mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, use a total of 3 on all XJ1100 models, each:
    $ 2.95
    Starter Motor ID Decals:
    HCP15132 Aftermarket starter motor case ID DECAL, black foil decal with the brushed silver 4K0-81800-50 wording. This decal is used on all models that have black-painted starter motors. Used on the XJ650, XJ700, XJ750, and XJ900 models.
    $ 12.95
    HCP15189 Aftermarket starter motor case ID DECAL, black foil decal with the brushed silver 4H7-81800-50 wording. This decal is used on all models that have silver-painted starter motors. Used on the XJ650, XJ700, XJ750, and XJ900 models.
    $ 12.95
    Starter Motor Rebuild Supplies:
    HCP8608 Aftermarket gear and bearing synthetic RED MOLY GREASE. High temperature, water resistant, extreme pressure and high-load strength synthetic organic moly grease is far superior to black moly disulfide (petroleum-based) products. Use on steering neck bearings, wheel bearings, starter motor gears, driveshaft splines, swingarm and final drive bearings. 14 oz. tube.
    $ 29.95
    cps2) Aftermarket high-quality CROCUS CLOTH. Unlike sandpaper or emery paper, crocus cloth is a super-fine, cloth-backed soft abrasive that doesn't "shed" particles during use, and is just the thing for burnishing and polishing of copper electrical contact, like the alternator rotor and starter motor commutators. Sold in a 2" wide x 1-foot long strip, enough for polishing many a commutator or contact.
    HCP21378 Aftermarket strip of CROCUS CLOTH, measures 12" x 2". Each:
    $ 4.95
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP12352 Aftermarket water-soluble (rinse-off) AEROSOL ENGINE DEGREASER and CLEANER, in a handy 13-ounce aerosol can. Each:
    $ 44.95
    HCP12354 Aftermarket water-soluble (rinse-off) ENGINE DEGREASER and CLEANER, in a 16-ounce non-aerosol can. Best to transfer into an old windex spray bottle (etc.) and use with a spray nozzle. Each:
    $ 42.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
  19. chacal
    STARTER CLUTCH REBUILD PARTS:
    sms6) OEM and aftermarket parts to rebuild your STARTER MOTOR CLUTCH DRIVE. Yamaha used a "centrifugal clutch" type of drive system to engage and disengage the starter motor drive from the engine:
    and over time the springs, spring caps, and roller pins that provide the engagement action can fail....which is terrible, as these are a real pain to replace, and always requires the dis-assembly of the upper and lower engine cases:
    http://xjbikes.com/forums/threads/xj750-engine-removal-and-split-pictures.38545/
    However, there are a few alternative methods that might (or might not) save you some incredible effort and allow you to "dodge a bullet" and repair your starter clutch system in an easier manner; but, the success of such methods really depends upon whether the clutch failure is due to mechanical wear or damage to the pins, caps, or springs (in which case, you MUST somehow get in there and replace those items), or, if the caps and pins are merely "seized" in the starter clutch hub due to accumulated varnish and sludge, etc.----and in such a situation, then you might be able to clean out the mess and restore the clutch to an operational condition.
    Methods a) and b) below address the problem of "sludge-seized" component pieces. Method c) deals with the problem of damaged parts. Note that if any of the major components are damaged---the clutch hub, or any idle gears or sprockets---then the engine is going to have to come out and taken apart to allow access to such larger pieces.
    a) Pull the starter motor.....or, even better, the alternator shaft housing.......and shoot lots of solvent (seafoam, carb or brake cleaner, etc.) directly onto and into the Starter Clutch Assembly. Then, drain all of your engine oil and refill with fresh oil. Run the engine while on the centerstand until it's warmed up, drain the oil again, and fill with fresh oil. If the starter clutch was just sticking, this method may wash away enough of the accumulated gunk and set you on your way.
    b) which in turn spins the another INTERMEDIATE IDLER GEAR attached to the rear side of the STARTER CLUTCH ASSEMBLY.
    By the way, if your engine is locked up for some reason (carbs flooded and hydrolocked a cylinder, for example), it's possible that a starter motor in good shape---and backed up by a good battery---can strip out the above two gears, as seen in this very nice thread:
    https://www.xjrider.com/viewtopic.php?t=6298
    A starter motor that spins, without turning over the engine, is symptomatic of this type of (fortunately) rare problem.
    c) This entire "starter clutch assembly" consists of the above intermediate idler gear and a CENTRAL HUB UNIT which contains the centrifugally-operated springs, caps, and roller pins which lock the starter clutch operation to the starter motor. Failure of both the hub unit itself (it can develop hairline---or larger----cracks over time) as well as wear or seizure of the springs, caps, or roller pins accounts for 99.9% of all starter clutch problems and failures.
    AND, be aware that a failing battery and/or a starter motor with a shorted winding or excessive carbon build-up on the commutator, or even burnt contacts in the starter solenoid, can reduce current to the starter motor to a point where it can't produce enough torque upon the starter clutch, and thus mimic starter clutch failure symptoms (that "bag of rocks" sound and an engine that doesn't turn over), so be sure to eliminate those as potential problems before digging into your engine!
    A Handy Guide to not Rebuilding your Starter Clutch:
    https://www.xjbikes.com/forums/thre...ebuilding-your-slipping-starter-clutch.130438
    ALSO, TAKE NOTE OF THIS EXPERIENCE FROM ANOTHER XJ-OWNER:
    "If there is not enough grip between the plunger and the roller, it can skip, causing the grinding, clacking noises you hear. I have been told by a Yamaha mechanic with over 20 years experience that it is very possible for some synthetics to greatly increase the chances that this will occur......"
    So this weekend I drained the synthetic out, put some cheap 20W50 in, and rode it for a little while. Then I drained the cheap oil out and put Castrol GTX 20W50 in and the starter does not malfunction anymore, not even once! I can't believe it! I guess these bikes were not made to run synthetic---I'm sticking with conventional oil from now on."
    c) If none of the above solutions work, then it might be time to do the dirty deed.....the engine will need to come out of the frame and be dis-assembled to access this area. If you read this thread:
    http://xjbikes.com/forums/index.php?threads/1700
    you'll get a good idea of what challenges you're up against.
    By the way, if you do decide to split the engine open and perform open-heart surgery, you might as well replace the primary chain and guide while you're in there, as those are also "wear items" and will cause problems if and when they start failing!
    Starter Clutch Components and Operation:
    The general layout of the starter motor clutch system is as follows (it differs slightly between the various engine types, but overall, here is what is happening):
    a) the starter motor gear operates upon a PRIMARY IDLER GEAR (which is supported on its own shaft)....
    d) The "central hub unit" is attached via rubber ABSORBERS operating on the STARTER WHEEL to the starter clutch OUTER COVER, and this outer cover has a DRIVEN GEAR which is operated by the PRIMARY CHAIN, referred to in technical manuals as the "Hy-Vo" chain. Hy-Vo Chain is a unique type of Silent Chain. Hy-Vo stands for High Capacity, High Velocity, and Involute Tooth, and it is a registered trademark of Borg-Warner Automotive, Inc.
    http://chain-guide.com/applications/1-6 ... chain.html
    e) The starter clutch assembly rides upon the same shaft that drives the alternator.
    f) If you are going to have the starter clutch assembly out of the engine and available for rebuild, we suggest that the central hub unit be inspected carefully for any damage or cracks, and replaced if needed. Here is a common problem that you need to look for (scroll down for the image of the cracked hub):
    http://xjbikes.com/forums/index.php?threads/starter-clutch.14924/
    Also take note that if the hub is not cracked, there is some good advice about re-conditioning the hub that you may wish to follow.
    If the hub is secure, then always replace the springs, caps, and pins, as well as the rubber absorbers used within the starter wheel.
    http://www.xjbikes.com/forums/threads/complete-xj650-rebuild.81981/page-2#post-500076
    Starter Clutch Primary Idler Gear:
    HCP8687 OEM starter clutch system PRIMARY IDLER GEAR, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 52.95
    HCP18661 OEM starter clutch system primary idler gear SHAFT, for all FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 23.95
    HCP8688 OEM starter clutch system primary idler gear shaft RETAINER PLATE, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 2.95
    HCP2171 OEM starter clutch system primary idler gear shaft retainer plate BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 3.95
    HCP24067 Aftermarket starter clutch system primary idler gear shaft retainer plate BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 1.95
    HCP24077 Aftermarket starter clutch system primary idler gear shaft retainer plate BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 2.95
    HCP24078 Aftermarket starter clutch system primary idler gear shaft retainer plate BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 3.95
    HCP6639 Aftermarket starter clutch system primary idler gear shaft retainer plate BOLT, socket head (hex-key drive) 18/8 stainless steel fastener with a bright finish, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 2.95
    HCP24075 Aftermarket starter clutch system primary idler gear shaft retainer plate BOLT, socket head (hex-key drive) 316 stainless steel fastener with a bright finish, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 2.95
    HCP6640 Aftermarket starter clutch system primary idler gear shaft retainer plate BOLT, socket head (hex-key drive) black oxide-coated alloy steel fastener. Fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 1.95
    HCP8689 OEM starter clutch system primary idler gear shaft retainer plate bolt LOCK WASHER, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 4.95
    HCP3144 OEM starter clutch system primary idler gear shaft retaining CIRCLIP, for all XJ1100 engines.
    $ 8.95
    HCP12791 OEM starter clutch bearing housing cover O-RING, for all XJ1100 engines. Use 2 per cover. Each:
    $ 5.95
    HCP966 OEM starter clutch bearing housing cover MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Use 3 per cover on all XJ1100 engines. Use 3 per cover. Each:
    $ 7.95
    HCP22253 Aftermarket starter clutch bearing housing cover MOUNTING BOLT, alloy-steel, zinc-plated allen head hex-drive screw. Use 3 per cover on all XJ1100 engines. Each:
    $ 1.95
    HCP228 Aftermarket starter clutch bearing housing cover MOUNTING BOLT, allen head hex-drive, black-oxide coated. Uses 3 per cover. Fits all XJ1100 models. Each:
    $ 1.95
    HCP2779 Aftermarket starter clutch bearing housing cover MOUNTING BOLT, allen head hex-drive, black-oxide finish, features self-locking threads. Uses 3 per cover. Fits all XJ1100 models. Each:
    $ 2.95
    HCP226 Aftermarket starter clutch bearing housing cover MOUNTING BOLT, allen head hex-drive, bright 18-8 stainless steel finish. Uses 3 per cover. Fits all XJ1100 models. Each:
    $ 2.95
    Starter Clutch Intermediate Idler Gear:
    HCP8695 OEM starter clutch system INTERMEDIATE IDLER GEAR, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines. Comes with the internal bronze bushing.
    $ 149.95
    HCP8700 OEM starter clutch system intermediate idler gear COLLAR, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ discontinued
    Starter Clutch Complete Hub Unit:
    HCP8667 OEM starter clutch complete CENTRAL HUB UNIT, includes the compression springs, caps, and roller pins. For all XJ550 and FJ600 engines.
    $ 299.95
    HCP8690 OEM starter clutch complete CENTRAL HUB UNIT, this outer housing unit includes the compression springs, caps, and roller pins. For all XJ650 and 1981-83 XJ750 air-cooled engines. NOTE: you can use the stronger XJ700/XJ750-X/XJ900 unit in place of this one for increased durability and more reliable performance.
    $ 179.95
    HCP23830 Aftermarket starter clutch complete CENTRAL HUB UNIT, this outer housing unit includes the compression springs, caps, and roller pins. For all XJ650 and 1981-83 XJ750 air-cooled engines. NOTE: you can use the stronger XJ700/XJ750-X/XJ900 unit in place of this one for increased durability and more reliable performance.
    $ 129.95
    HCP8691 OEM starter clutch complete CENTRAL HUB UNIT, this outer housing unit includes the compression springs, caps, and roller pins. For all XJ700, XJ750-X, and all XJ900RK, RL, N/FN, and F engines. NOTE: you can use this unit in place of the stock XJ650 / 1981-83 XJ750 version for increased durability and more reliable performance
    $ 259.95
    HCP24017 Aftermarket starter clutch complete CENTRAL HUB UNIT, this outer housing unit includes the compression springs, caps, and roller pins. For all XJ700, XJ750-X, and all XJ900RK, RL, N/FN, and F engines. NOTE: you can use this unit in place of the stock XJ650 / 1981-83 XJ750 version for increased durability and more reliable performance.
    $ 169.95
    HCP8707 OEM starter clutch complete CENTRAL HUB UNIT, this outer housing unit includes the compression springs, caps, and roller pins. For all XJ1100 and XS1100 engines.
    $ 399.95
    Starter Clutch Hub Rebuild Kit:
    These oem-quality replacements give you all of the parts needed to restore the central hub unit.
    Each basic rebuild kit contains 3 each of the clutch hub springs, spring caps, and rollers, while the full rebuild kits also includes the rubber starter wheel absorbers, and the inner-to-outer clutch hub cinching bolts.
    HCP29301 Aftermarket starter clutch hub BASIC REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers. Fits XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, 1982-83 XS400, 1982-83 XZ550 Vision, 1988-95 XV535 Virago, 1994-97 YZF750R, 1989-95 FZR1000, 1986-98 VMX12, 1983-84 XVZ12, 1985-93 XVZ13, and 1997 YZF1000R models. Each kit:
    $ 69.95
    HCP29342 Aftermarket starter clutch hub FULL REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers, 4 of the rubber absorbers, and 3 of the inner-to-outer hub retaining bolts. Fits XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Each kit:
    $ 124.95
    HCP29334 Aftermarket starter clutch hub BASIC REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers. Fits all XJ650 and all XJ750 air-cooled models. Each kit:
    $ 69.95
    HCP29343 Aftermarket starter clutch hub FULL REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers, 4 of the rubber absorbers, and 3 of the inner-to-outer hub retaining bolts. Fits all XJ650 and all XJ750 air-cooled models. Each kit:
    $ 119.95
    HCP29308 Aftermarket starter clutch hub BASIC REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers. Fits all XJ700, XJ750-X, and all 1983-89 XJ900 models. NOTE: this kit can be used as an “upgrade” kit for the XJ650 and all XJ750 air-cooled engines. Each kit:
    $ 79.95
    HCP29344 Aftermarket starter clutch hub FULL REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers, 4 of the rubber absorbers, and 3 of the inner-to-outer hub retaining bolts. Fits all XJ700, XJ750-X, and all 1983-89 XJ900 models. NOTE: this kit can be used as an “upgrade” kit for the XJ650 and all XJ750 air-cooled engines. Each kit:
    $ 124.95
    HCP29300 Aftermarket starter clutch hub REBUILD KIT, contains 3 each of the clutch hub springs, spring caps, and rollers. Fits all of the following models: XS1100 all models, XS850 all models, 1984-85 FJ1100, and 1986-93 FJ1200 models. Each kit:
    $ 59.95
    Starter Clutch Hub Compression Spring:
    HCP8670 OEM starter clutch hub COMPRESSION SPRING, use 3 per clutch, for all XJ550 and FJ600 models, each:
    $ 8.95
    HCP8692 OEM starter clutch hub COMPRESSION SPRINGS, use 3 per clutch, for all XJ650 and XJ750 models, each:
    $ 9.95
    HCP8693 OEM starter clutch hub COMPRESSION SPRINGS, use 3 per clutch, for all XJ700, all XJ900RK, RL, N/FN, and F engines, XJ1100, and all XS1100 models. Each: NOTE: you can use this spring in place of the stock XJ650 / 1981-83 XJ750 spring for increased durability and more reliable performance
    $ 9.95
    Starter Clutch Hub Spring End Cap:
    HCP8669 OEM starter clutch hub compression spring END CAP, use 1 per spring, 3 per clutch, for all XJ550, FJ600, XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, and F engines, XJ1100, and all XS1100 models. Each:
    $ 18.95
    Starter Clutch Hub Roller:
    HCP8668 OEM starter clutch hub compression spring ROLLER, use 3 per clutch, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines, each:
    $ 8.95
    HCP8708 OEM starter clutch hub compression spring ROLLER, use 3 per clutch, for all XJ1100 and XS1100 models, each:
    $ 14.95
    Starter Clutch Hub Mounting Bolt:
    HCP8672 OEM starter clutch hub MOUNTING BOLT, use 3 per clutch, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines, each:
    $ 7.95
    HCP10474 Aftermarket starter clutch hub MOUNTING BOLT, use 3 per clutch, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines, each:
    $ 4.95
    Starter Clutch Starter Wheel Components:
    HCP8673 OEM starter clutch system starter wheel ABSORBER, use 4 per wheel, for all XJ550 and FJ600 engines. Each:
    $ 15.95
    HCP8697 OEM starter clutch system starter wheel ABSORBER, use 4 per wheel, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines. Each:
    $ 12.95
    Starter Clutch Driven Gear:
    HCP8698 OEM starter clutch cover DRIVEN GEAR, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ discontinued
    HCP3144 OEM starter clutch cover driven gear CIRCLIP, for all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 8.95
    Starter Clutch Primary Drive Chain:
    Referred to in the service manuals as "Hy-Vo Chain, the primary drive chains is a unique type of silent-running chain. Hy-Vo stands for High Capacity, High Velocity, and Involute Tooth, and it is a registered trademark of Borg-Warner Automotive, Inc.
    http://chain-guide.com/applications/1-6-3-inverted-tooth-chain.html
    These chains…..although stout and practically bullet-proof in regards to breakage…….can and will eventually stretch to the point where they will destroy their rubber GUIDE (HCP7551) and/or chew away at the oil spray NOZZLE (HCP10232)….which then only accelerates the wear on the chain. Unfortunately, Yamaha never provided any specs on how to determine whether the chain is stretched, or how much stretch is allowable. Experience provides a general rule of thumb, though: if your engine has more than 50,000 miles on it, and you need to “go inside” the engine for any other reason, we suggest replacing the chain and the guide (and rebuild or replace the starter clutch hub unit) “just to be sure”.
    https://www.xjbikes.com/forums/threads/xj750-engine-removal-and-split-pictures.38545
    and
    https://www.xjbikes.com/forums/thre...ld-primary-chain-free-play-measurement.132826
    HCP7874 OEM starter clutch PRIMARY CHAIN, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models.
    $ 349.95
    HCP29331 Aftermarket starter clutch PRIMARY CHAIN, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models.
    $ 219.95
    HCP22540 OEM starter clutch PRIMARY CHAIN, for all 1992-98 XJ600 Seca II models.
    $ 139.95
    HCP7197 OEM starter clutch PRIMARY CHAIN, for all XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models.
    $ 299.95
    HCP29332 Aftermarket starter clutch PRIMARY CHAIN, for all XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models.
    $ 159.95
    HCP8640 OEM starter clutch PRIMARY CHAIN, for all XJ1100 and XS1100 models.
    $ 399.95
    HCP29333 Aftermarket starter clutch PRIMARY CHAIN, for all XJ1100 and XS1100 models.
    $ 339.95
    Starter Clutch Primary Chain Guide:
    This plastic chain guide should always be replaced when the engine is apart. Similar in design and concept to the camshaft drive chain guides, as it ages it gets hard and starts shedding small (or large) chunks of plastic into the engine, some of which invariably end up in the gear shifter drum assembly.....causing you to lose the ability to upshift or downshift into some (or all) of your gears. In fact, if you experience such a shifting problem, and remove the shifter drum and dig out hunks of plastic, this is a sure sign of impending starter primary chain guide failure (followed closely by the failure of the primary chain). Pieces of hard plastic discovered during an oil change may also point to the same problem.
    A great visual of this "problem child" part can be seen on the 2nd image down on this page (visual is correct for XJ650-XJ900 engines):
    http://www.xjbikes.com/forums/threads/bks-winter-restomod-project-82-xj650-seca.72850/page-7
    To get a better understanding of what is happening and what will be involved in solving the issue, this excellent illustrated guide on how to temporarily solve the problem of a disintegrating chain guide (and it locking up your shifter) you can review this guide from the xjcd.org website on how to do an “emergency” fix to the problem (i.e. when you're a million miles away from home):
    https://www.xjcd.org/emergency_guidectomy
    HCP18662 OEM starter primary chain plastic GUIDE, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian engines.
    $ 259.95
    HCP22539 OEM starter primary chain plastic GUIDE, for all 1992-98 XJ600 Seca II models. NOTE: some original versions of this guide used three mounting bolt "tabs" (and required 3 mounting bolts). This replacement versions only uses two mounting tabs, and thus two mounting bolts (one at each end).
    $ 199.95
    HCP7551 OEM starter primary chain plastic GUIDE, for all XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. NOTE: some original versions of this guide used three mounting bolt "tabs" (and required 3 mounting bolts). This replacement versions only uses two mounting tabs, and thus two mounting bolts (one at each end). NOTE: the guide is installed with the “teeth” facing “up” (towards the upper engine case), and the smooth side facing the chain.
    $ 39.95
    HCP8641 OEM starter primary chain plastic GUIDE, for all XJ1100 and XS1100 models.
    $ discontinued
    NOTE: these chain guide retaining bolts should be installed using a low-strength thread-locker and torqued to 5.8 ft. -lbs.
    HCP4791 OEM starter primary chain plastic guide RETAINING BOLT, use 3 per guide, for all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. NOTE: some original versions of the guide may have had three mounting bolt "tabs" (and required 3 mounting bolts). The replacement HCP7551 guide only uses two mounting tabs, and thus only two of these mounting bolts are required. Hex-head, black-oxide coated bolt. Each:
    $ 4.95
    HCP6715 Aftermarket starter primary chain plastic guide RETAINING BOLT, use 3 per guide, for all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. NOTE: some original versions of the guide may have had three mounting bolt "tabs" (and required 3 mounting bolts). The replacement HCP7551 guide only uses two mounting tabs, and thus only two of these mounting bolts are required. Socket head, hex-drive, black-oxide coated alloy steel, each:
    $ 2.95
    HCP6716 starter primary chain plastic guide RETAINING BOLT, use 3 per guide, for all XJ550, FJ600, XJ650, XJ700, XJ750, and XJ900RK, RL, N/FN, and F models. NOTE: some original versions of the guide may have had three mounting bolt "tabs" (and required 3 mounting bolts). The replacement HCP7551 guide only uses two mounting tabs, and thus only two of these mounting bolts are required. Socket head, hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP2171 OEM starter primary chain plastic guide RETAINING BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish. Use 2 per guide, for all XJ1100 models, each:
    $ 3.95
    HCP24067 Aftermarket starter primary chain plastic guide RETAINING BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish. Use 2 per guide, for all XJ1100 models, each:
    $ 1.95
    HCP24077 Aftermarket starter primary chain plastic guide RETAINING BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish. Use 2 per guide, for all XJ1100 models, each:
    $ 2.95
    HCP24078 Aftermarket starter primary chain plastic guide RETAINING BOLT, 6-point hex head 316 stainless steel fastener with a bright finish. Use 2 per guide, for all XJ1100 models, each:
    $ 3.95
    HCP6639 Aftermarket starter primary chain plastic guide RETAINING BOLT, socket head (hex-key drive) 18/8 stainless steel fastener with a bright finish. Use 2 per guide, for all XJ1100 models, each:
    $ 2.95
    HCP24075 Aftermarket starter primary chain plastic guide RETAINING BOLT, socket head (hex-key drive) 316 stainless steel fastener with a bright finish. Use 2 per guide, for all XJ1100 models, each:
    $ 2.95
    HCP6640 Aftermarket starter primary chain plastic guide RETAINING BOLT, socket head (hex-key drive) black oxide-coated alloy steel fastener. Use 2 per guide, for all XJ1100 models, each:
    $ 1.95
    Starter Clutch Primary Chain Tensioner and Lubrication:
    NOTE: XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, and 1986-90 YX600 Radian engines can make a particular type of “quiet” rhythmic, metallic knocking sound from the top end, which will disappear as rpm’s increase………..this is typically caused by the primary chain (inside the engine) which can “flop” around a bit at low rpm’s due to low oil pressure (oil pressure is used to tension this chain). It’s nothing to worry about.
    HCP13969 OEM starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian engines. O-ring is not included and should be ordered separate.
    $ 139.95
    HCP25652 OEM starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all 1992-98 XJ600 Seca II engines. O-ring is not included and should be ordered separate.
    $ 39.95
    HCP5400 OEM starter chain and guide oil spray nozzle O-RING, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 7.95
    HCP20977 Aftermarket starter chain and guide oil spray nozzle O-RING, use 1 per engine, fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models.
    $ 5.95
    HCP20306 OEM primary chain TENSIONER, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian engines.
    $ discontinued
    HCP13977 OEM primary chain tensioner OIL DELIVERY PIPE, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II engines.
    $ 32.95
    HCP16825 OEM primary chain tensioner SPRING, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II engines.
    $ discontinued
    HCP23512 OEM primary chain tensioner PLUNGER, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II engines.
    $ discontinued
    HCP10233 OEM primary chain tensioner oil delivery pipe O-RING, use 1 per pipe on all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, and 1992-2002 XJ600 Euro engines.
    $ 7.95
    HCP20976 Aftermarket primary chain tensioner oil delivery pipe O-RING,use 1 per pipe on all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, and 1992-2002 XJ600 Euro engines.
    $ 5.95
    HCP3412 OEM primary chain tensioner oil delivery pipe copper CRUSH WASHER. Use 2 per tube on all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, and 1992-2002 XJ600 Euro engines. Each:
    $ 2.95
    HCP21341 Aftermarket primary chain tensioner oil delivery pipe copper CRUSH WASHER . Use 2 per tube on all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, and 1992-2002 XJ600 Euro engines. Each:
    $ 2.95
    HCP10232 OEM starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. O-ring is not included and should be ordered separate.
    $ 79.95
    HCP26174 Aftermarket starter chain and guide OIL SPRAY NOZZLE, use 1 per engine, fits all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Appearance is different than stock but fit and performance is the same as the HCP10232 spray nozzle. O-ring is not included and should be ordered separate.
    $ 59.95
    HCP10233 OEM starter chain and guide oil spray nozzle O-RING, use 1 per engine an all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 7.95
    HCP20976 Aftermarket starter chain and guide oil spray nozzle O-RING, use 1 per engine an all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F engines.
    $ 5.95
  20. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Chassis Electrical System: Control Switches, Headlight, Relays, Horns, and related hardware, etc.
    CHASSIS ELECTRICAL SYSTEM PARTS:
    HANDLEBAR CONTROL SWITCHES:
    css3) OEM and aftermarket handlebar-mounted CONTROL SWITCHES are now available to restore the function of these key components. The left (clutch lever) side switch controls the headlights, turn signals, horn, and mounts the choke lever. The right (brake lever) side switch operates the engine kill switch and operates the starter motor.
    Right Side Handlebar Control Switches:
    for all XJ550, XJ650 (except Turbo), and 1979-81 XS1100 Standard models:
    HCP28280 OEM right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Finished in the original low-gloss-black paint. Wiring harness is included, equipped with the correct 6-place trapezoidal style connector shell as original. Fits with no connector modifications on all XJ550 North American models, all XJ650 (except Turbo) North American models, 1980-82 XS400 North American models, 1981-83 XV750 Virago North American models, 1982 XV750MK Midnight Virago model, and all 1979-81 XS1100 Standard North American models.
    $ 299.95
    HCP30244 Aftermarket right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Finished in the original low-gloss-black paint. Wiring harness is included, equipped with the correct 6-place trapezoidal style connector shell as original. Fits with no connector modifications needed on all XJ550 North American models, all XJ650 (except Turbo) North American models, 1980-82 XS400 North American models, 1981-83 XV750 Virago North American models, 1982 XV750MK Midnight Virago model, and all 1979-81 XS1100 Standard North American models. NOTE: you must return an original control switch with an un-cut, un-damaged switch harness. NOTE: wire harness is approximately 2" shorter than original harness on XJ models.
    $ 189.95 + $ 50.00 refundable core charge
    HCP455 OEM right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Finished in the original low-gloss-black paint. Wiring harness is included, but it uses a different style connector shell than original (it comes with a matching main-harness side connector shell and terminals, if you want to (cringe! covers eyes and ears!!) cut your original main harness and replace that original connector with the provided connector and terminals. then you’ll be ready to ride. There are two other solutions for using this switch outlined further below.....both of which sound difficult when you read the procedures below, but neither of which will take over 10 minutes to perform (you'll need a wire cutter/stripper and a proper terminal crimper tool to perform either procedure). Fits with connector modifications on all XJ550 North American models, all XJ650 (except Turbo) North American models, 1980-82 XS400 North American models, 1981-83 XV750 Virago North American models, and all 1979-81 XS1100 North American models. This switch will work as is (no connector replacement needed) on all of the following North American models: 1979 XS400, 1979 XS650 and XS650-2 models, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, and 1983-84 XS650 Heritage Special models.
    $ 119.95
    HCP7375 Aftermarket right side CONTROL SWITCH, brand new original replacement unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Finished in the original low-gloss-black paint. Wiring harness is included, but it uses a different style connector shell than original, and thus requires one of two different solutions for the use of this switch.....both of which sound difficult when you read the procedures below, but neither of which will take over 10 minutes to perform (you'll need a wire cutter/stripper and a proper terminal crimper tool to perform either procedure). Fits with connector modifications on all XJ550 North American models, all XJ650 (except Turbo) North American models, 1980-82 XS400 North American models, 1981-83 XV750 Virago North American models, and all 1979-81 XS1100 North American models. This switch will work as is (no connector replacement needed) on all of the following North American models: 1979 XS400, 1979 XS650 and XS650-2 models, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, and 1983-84 XS650 Heritage Special models.
    $ 89.95
    HCP14919 Aftermarket right side CONTROL SWITCH, brand new original replacement unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Beautiful chrome-plated finish. Wiring harness is included, but it uses a different style connector shell than original, and thus requires one of two different solutions for the use of this switch.....both of which sound difficult when you read the procedures below, but neither of which will take over 10 minutes to perform (you'll need a wire cutter/stripper and a proper terminal crimper tool to perform either procedure). Fits with connector modifications on all XJ550 North American models, all XJ650 (except Turbo) North American models, 1980-82 XS400 North American models, 1981-83 XV750 Virago North American models, and all 1979-81 XS1100 North American models. This switch will work as is (no connector replacement needed) on all of the following North American models: 1979 XS400, 1979 XS650 and XS650-2 models, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, and 1983-84 XS650 Heritage Special models.
    $ 119.95
    HCP28401 Aftermarket right side CONTROL SWITCH, brand new original replacement unit features the starter push-button, the ignition cut-out OFF-RUN-OFF rotary selector lever, and the LIGHTS ON-OFF toggle switch.. Finished in the original low-gloss-black paint. Wiring harness is included, equipped with the correct 6-place trapezoidal style connector shell as original. Fits with connector modifications on all XJ550 Euro and all XJ650 4K0 and 4K1 models. NOTE: the LIGHTS switch only has an ON and OFF position, and no “PO” (Parking Only) switch position as was featured on some models.
    $ 159.95
    HCP455, HCP7375, and HCP14919 Switch Modification Options for use on XJ550, all XJ650 (except Turbo), 1980-82 all XS400, and all 1981-83 XV750 Virago models:
    Method A: modify this switch by adding your original control switch harness connector shell onto the end of the wiring harness that comes with this switch. You will cut off the connector from this switch, cut off your existing connector from your original control switch harness (control switch side), and splice the wires together, leaving your original connector on the end of this switch. We recommend the use of our HCP13045 insulated, solder-sleeve butt connectors to join the wires together.
    Wire color coding:
    - on this switch: Red/white tracer, Brown solid (for the OFF-RUN-OFF switch), and Blue/white tracer, and Black solid.
    You will splice the same-color wires together, with the only difference being that your original control switch harness has two of the Red/white tracer wires (this switch has only one), and this control switch harness has only one Red/white tracer wire. The other Red/white tracer wire from your original connector shell will be joined to the Brown solid wire on this switch.
    Method B: you will retain the connector on this switch harness as-is, and replace the connector on your main wiring harness. You'll need to cut off the original trapezoidal-shaped, black, 6-place connector shell and replace it with a HCP9334FNWHT connector shell along with four of the HCP9360BR1418 male flat blade terminals. As discussed above in "Method A", note the orientation of wires colors and make sure they line up correctly........and the brown wire on the switch side plug goes to one of the Red/white wires on the main harness side.
    HCP13045 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 18-22 gauge. You'll need four of these for use with the HCP455, HCP7375 or HCP14919 control switch above when using "Method A". Each:
    $ 1.95
    HCP9334FNWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 4-place, rectangular, for use with the HCP455, HCP7375 or HCP14919 control switch above when using "Method B". Accepts the HCP9360BR1418 male flat-blade terminal. Each:
    $ 3.95
    HCP9360BR1418 Aftermarket "medium-width" straight MALE MEDIUM BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. You'll need four of these for use with the HCP455, HCP7375 or HCP14919 control switch above when using "Method B". Each:
    $ 1.95
    HCP455, HCP7375, and HCP14919 Switch Modification Options for use on 1979-81 XS1100 Standard models:
    $ 1.95
    HCP24544MMWHT Aftermarket white plastic MALE CONNECTOR SHELL, 4-place square terminal orientation, used on all of the following circuits listed below. Accepts the HCP24541TP round-pin female terminal only (does not accept original round-pin terminals). Each:
    $ 7.95
    HCP24541TP Aftermarket original style tin-plated brass FEMALE TRUE ROUND PIN WIRE-END TERMINAL, used with the male HCP24542M, HCP24543M, HCP24544M, and HCP24545M connector shells only. Accepts 14-18 gauge wires. You'll need four of these for use with the HCP455, HCP7375 or HCP14919 control switch above when using "Method B". Each Each:
    $ 2.75
    for all XJ700 and XJ750-X models:
    HCP456 OEM right side CONTROL SWITCH, brand new original units features the starter push-button and the ignition cut-out ON-OFF toggle switch. Included is the wiring harness with proper end connector, and it's finished with the original low-gloss-black paint. Fits all XJ700 and XJ750-X models.
    $ 349.95
    for all 1982-83 XJ650 Turbo and 1982-83 XJ750 Maxim models:
    HCP3400 OEM right side CONTROL SWITCH, brand new original switch features the starter push-button and the ignition cut-out ON-OFF toggle switch. Included is the wiring harness with proper end connector, and it's finished with the original low-gloss-black paint. Fits all XJ650 Turbo and 1983 XJ750 Maxim models, and will also fit all of the following models: 1982-1983 XS400 Maxim and Seca models, 1983 XV500, and 1983 XVZ1200TK Venture. Will also fit 1982 XJ750 Maxim models, but the wiring harness is almost 9” shorter than the original harness on that model.
    $ 349.95
    for all 1981-83 XJ750 Seca models:
    HCP3401 OEM right side CONTROL SWITCH, brand new original switch features the starter push-button and the ignition cut-out ON-OFF toggle switch. Included is the wiring harness with proper end connector, and it's finished with the original low-gloss-black paint. Brake cable adjuster hardware, brake hand lever, and hand lever position switch/harness are not included. Fits all 1981-83 XJ750 Seca models, but is "correct" for 1981 models only (it has the wording FOG LAMP on the outer shell, which is correct for 1981 models only; 1982-83 models says "AUX LAMP").
    $ 369.95
    for all 1984 XJ750RL and XJ900 models:
    HCP457 OEM right side CONTROL SWITCH, brand new original units features the starter push-button and the ignition cut-out ON-OFF toggle switch. Included is the wiring harness with proper end connector, and it's finished with the original low-gloss-black paint. Brake hand lever and hand lever position switch/harness are not included. Fits all 1984-85 FJ600, XJ750RL, and XJ900RK models.
    $ 389.95
    for 1978 XS1100 Standard and all XS1100 Special and Midnight Special models:
    NOTE: 1979-81 XS1100 Standard models see the XJ550 / XJ650 section above.
    HCP24573 OEM right side CONTROL SWITCH, brand new original unit features the starter push-button, headlight ON-OFF switch, and the ignition cut-out OFF-RUN-OFF selector lever. Included is the wiring harness with the proper end connector, and it's finished with the original low-gloss-black paint. Fits all 1978 XS1100 Standard models.
    $ 399.95
    HCP24575 OEM right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Included is the wiring harness with the proper end connector, and it's finished with the original low-gloss-black paint. Fits all 1979-81 XS1100 Special and Midnight Special models, and 1981-82 XV920 RH/RJ Virago models.
    $ discontinued
    HCP27935 OEM right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Finished in the original low-gloss-black paint. Wiring harness is included, and it has been modified with the correct style connector shell as original, and is thus plug-and-play! Fits with no modifications on all 1979-81 XS1100 Special and Midnight Special models, and 1981-82 XV920 RH/RJ Virago models.
    $139.95
    HCP27861 Aftermarket right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Finished in the original low-gloss-black paint. Wiring harness is included, and it has been modified with the correct style connector shell as original, and is thus plug-and-play! Fits with no modifications on all 1979-81 XS1100 Special and Midnight Special models, and 1981-82 XV920 RH/RJ Virago models.
    $ 109.95
    HCP28003 Aftermarket right side CONTROL SWITCH, brand new original unit features the starter push-button and the ignition cut-out OFF-RUN-OFF selector lever. Has a beautiful chrome-plated finish. Wiring harness is included, and it has been modified with the correct style connector shell as original, and is thus plug-and-play! Fits with no modifications on all 1979-81 XS1100 Special and Midnight Special models, and 1981-82 XV920 RH/RJ Virago models.
    $ 129.95
    Left Side Handlebar Control Switches:
    NOTE: If you are having to manually hold the signal lever fully over to the left or right position (in order for the signals to flash), this could be an indication that the internal contacts (within the switch housing) may be wonky. There is a "two-armed" contact that can get bent, or, the slider contacts may have gotten dirty and/or the solder connections to the slider contacts have broken or become loose:
    http://www.xjbikes.com/forums/threads/turn-signal-switch-question-w-photo.61051/#post-453580
    and
    http://www.xjbikes.com/forums/threads/electrical-challenges.53983/page-2
    The first link above has a good image of the copper contact "arms" that can get bent, and will thus no longer make contact with the brass "button" contact on the bottom of the pivoting lever arm (one button contact on each side of the lever arm), while the second link has some good images of the slider assembly.
    for all XJ550 and XJ650 (except Turbo) models:
    HCP27143 Aftermarket left side CONTROL SWITCH, brand new original unit features the horn push-button, the turn signal selector, the headlight hi-lo beam selector switch, and the choke swivel lever. Finished in the original low-gloss-black paint. Fits all XJ550 models, all XJ650 (except Turbo) models, 1981-83 XV750 Virago, and 1983 XV750 Virago Midnight Special models. This switch has the proper connector shells already installed on its sub-harnesses, making it plug-and-play. NOTE: this reproduction switch features a a mixture of new original parts and re-furbished used original parts (the bottom bowl and the choke control thumb lever). NOTE: requires a $ 25.00 core charge, refundable upon the return of an undamaged, complete, same-model, control switch (complete with the choke control thumb lever).
    $ 199.95 + $ 25.00 refundable core charge
    HCP458 OEM left side CONTROL SWITCH, brand new original unit features the horn push-button, the turn signal selector, the headlight hi-lo beam selector switch, and the choke swivel lever. Finished in the original low-gloss-black paint. Fits all XJ550 North American models, all XJ650 (except Turbo) North American models, 1981-83 XV750 Virago, and 1983 XV750 Virago Midnight Special models. See NOTE below regarding the wiring harness that comes with this control switch.
    $ discontinued
    NOTE: the wiring harness that comes with the HCP458 switch above does NOT come with the correct molded plastic harness terminal connectors.
    It has the full complement of nine, correctly color-coded wires, but each wire is terminated with an individual male bullet connector....the two original plastic terminal connector "shells" are not included. The switch comes with matching female bullet connectors and their protective plastic sheaths, and it is intended that you cut your original main harness-side terminal connectors off, and then install the crimp-on female bullet terminals instead. We do not recommend doing this!....but, it is a “solution” Leaving your main wiring harness intact is an important issue, in our opinion, and so that will be our recommended optimal solution-----but doing so will take some extra effort on your part! (meaning: about 30 minutes of time, a wire cutter/stripper tool, and a proper open-barrel terminal crimping tool).
    You actually have three options:
    Method A: cut up your main harness, and use the female bullets supplied with this switch to terminate the wires on your main harness (after you---cringe---cut off your original main harness plastic connector blocks), or........
    Method B: you could cut off your original switch plastic connector blocks---leaving some wire length coming off the connectors----and then crimp the female bullets to these lead wires to those terminals, and plug the male bullets into those newly added female bullets. This method re-uses your original (proper) connector shells and attaches them to this switch harness.
    Method C: similar to the above method, you could cut off your original plastic connector blocks---leaving some wire length coming off the connector----and then use our HCP13045 insulated, solder-sleeve butt connectors to join the wires together, thus re-using your original (proper) connector shells and attaching them to this switch harness.
    HCP13045 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 18-22 gauge. You'll need eight of these for use with the HCP458 control switch above when using "Method C". Each:
    $ 1.95
    HCP13046 Aftermarket wire-joining CRIMPABLE, HEAT-SHRINK INSULATED, SOLDER-SLEEVE BUTT CONNECTOR, for wires that are both 14-16 gauge. You'll need one of these for use with the yellow wire on the HCP458 control switch above when using "Method C". Each:
    $ 1.95
    Now, all of that sure sounds like a lot of fun, doesn't it? Helps you become a wire harness builder in a hurry!
    For a simpler solution, we'll do the dirty work for you by attaching the proper 3-postion and 6-position connector shells with their round-pin terminals installed onto the HCP458 lead harness, thus giving you’re a plug-and-play solution that will install just like an original switch did! Order part number HCP458MOD below:
    HCP458MOD OEM left side CONTROL SWITCH, brand new original unit features the horn push-button, the turn signal selector, the headlight hi-lo beam selector switch, and the choke swivel lever. Finished in the original low-gloss-black paint. Fits all XJ550 models and all XJ650 (except Turbo) models. This switch has the proper connector shells already installed on its sub-harnesses, making it plug-and-play.
    $ discontinued
    for Euro XJ650 Turbo (11T) models:
    HCP29675 OEM left side CONTROL SWITCH, brand new original unit features the horn push-button, the turn signal selector, the headlight hi-lo beam selector switch, the “PASS” momentary switch (to flash the high beam), and the choke swivel lever. Included is the wiring harness with proper end connectors. The c(clutch lever switch is not included. Finished with the original low-gloss-black paint. Fits all XJ650 Turbo (11T) models. NOTE: does not interchange with the North American models, as they did not have the “PASS” feature.
    $ 399.95
    HCP29676 OEM right side CONTROL SWITCH, brand new original units features the starter push-button, the Parking Light ON-OFF slider switch, and the ignition cut-out ON-OFF toggle switch. Included is the wiring harness with proper end connectors, and it's finished with the original low-gloss-black paint. Fits all XJ650 Turbo (11T) models. . NOTE: does not interchange with the North American models, as they did not have the “Parking Lights” feature.
    $ 369.95
    $ 349.95
    HCP3277 OEM left side CONTROL SWITCH, brand new original switch features the horn push-button, headlight hi-lo beam selector switch, turn signal switch, choke control knob, and the wiring harness with proper end connector. Finished with the original low-gloss-black paint. Clutch cable adjuster hardware, clutch hand lever, and hand lever position switch/harness are not included. Fits all 1981-83 XJ750 Seca models.
    $ 379.95
    HCP460 OEM left side CONTROL SWITCH, brand new original switch features the horn push-button, headlight hi-lo beam selector switch, turn signal switch, choke control knob, and the wiring harness with proper end connector. Finished with the original low-gloss-black paint. Clutch cable adjuster hardware, clutch hand lever, and hand lever position switch/harness are not included. Fits all 1981-83 XJ750 Seca models.
    $ discontinued
    for all XJ1100 models:
    HCP3535 OEM left side CONTROL SWITCH, brand new original switch features the horn push-button, headlight hi-lo beam selector switch, turn signal switch, choke control knob, and the wiring harness with proper end connector. Finished with the original low-gloss-black paint. Clutch cable adjuster hardware, clutch hand lever, and hand lever position switch/harness are not included. Fits all XJ1100 models.
    $ 299.95
    Control Switch Repair and Rebuild Parts:
    HCP18684 Aftermarket control switch REBUILD KIT. Makes a professional repair or refurbishment of your right side control switch a breeze! Contains all the internal and external screws, internal wire terminals, speedo cable holder, red Stop-Run-Stop pointer, detent ball, START button/spring repair kit, the three external function decals, a sheet of ultra-fine sandpaper (for cleaning the electrical terminals and ground points), and a small packet of electrical grease. Do it once and do it right! For exterior restoration of the switch, we recommend the use of our HCP7906SP original finish Code 98 LGB spray paint to achieve the correct low-gloss black appearance. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago right side control switches. NOTE: the LIGHTS ON-OFF decal (1978 XS1100 models) is not included.
    $ 47.95
    HCP18685 Aftermarket control switch REBUILD KIT. Makes a professional repair or refurbishment of your left side control switch a breeze! Contains all the internal and most external screws, internal wire terminals, choke lever arm to housing screw, button-to-shaft screws, horn button/spring repair kit, the six external function decals, a sheet of ultra-fine sandpaper (for cleaning the electrical terminals and ground points), and a small packet of electrical grease. Do it once and do it right! For exterior restoration of the switch, we recommend the use of our HCP7906SP original finish Code 98 LGB spray paint to achieve the correct low-gloss black appearance. For use on all XJ550, XJ650 (except Turbo), and all XS1100 models. NOTE: the HAZARD ON-OFF decal (1980-81 XS1100 models) is not included.
    $ 49.95
    The replacement of the switch button is pretty straightforward:
    HCP1072 Aftermarket control switch STARTER OR HORN PUSH-BUTTON & SPRING SET. This round black plastic button correctly replaces broken or missing original starter push-button (on the right side control switch) and horn push-button (on the LH control switch). Comes with the contact spring. Slightly longer than stock but fits and looks just great once installed. NOTE: there is a longer end and shorter end of the brass stud. The shorter side is the side that is the visible side on most models; the longer end fits up inside the pushbutton. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago control switches.
    $ 11.95
    HCP21606 OEM control switch STARTER OR HORN PUSH-BUTTON ASSEMBLY. Contains the entire switch assembly: the black plastic button, the contact spring, and the metal cage that houses the whole unit. NOTE: control switch must be opened up to replace this part, and you will need to solder the lead wire onto the back of the contact plate. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago right side control switches.
    $ 49.95
    HCP24399 Aftermarket control switch STARTER OR HORN PUSH-BUTTON ASSEMBLY. Contains the entire switch assembly: the black plastic button, the contact spring, and the metal cage that houses the whole unit. NOTE: control switch must be opened up to replace this part, and you will need to solder the lead wire onto the back of the contact plate. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago right side control switches.
    $ 33.95
    HCP24453 Aftermarket control switch HORN PUSH-BUTTON ASSEMBLY with WIRE LEAD. Contains the entire switch assembly: the black plastic button, the contact spring, the pink lead wire (already soldered on), and the metal cage that houses the whole unit. This replacement switch will fit OEM switches and function properly. NOTE: control switch must be opened up to replace this part, and wire lead re-routed thru the vinyl sheath/sleeve that surrounds the wire harness bundle from the switch assembly to the main harness. The end of the wire must be hooked up to its respective connector shell wire, and a butt connector is included for this purpose. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches.
    $ 44.95
    HCP11104 Aftermarket handlebar right-side control switch RED POINTER, correct red plastic indicator fits within the OFF-RUN-OFF rotary switch and replaces your faded, broken, or missing original. NOTE: this pointer has two mounting pegs molded into the back side of it (as original), and these pegs fit into matching recesses in the rotary switch knob. However, original pointers have at least two different sizes of these pegs (and thus matching hole sizes in the rotary switch), and thus certain original switches may require a small wipe of glue (clear silicone caulk work well) applied to the recess in order to get a secure fit of the pointer to the rotary switch. Fits all XJ550, XJ650 (except Turbo), and all XS1100 models. Each:
    $ 12.95
    HCP27113 Aftermarket left control switch COMPLETE WIRE HARNESS, includes all of the internal switch plates, wiring, and both the 6-place and the 3-place wiring connector shells, making it a true plug-and-play replacement. If your control switch is complete, but just suffers from cut or missing wiring, then this complete replacement harness is for you. Fits all XJ550, XJ650 (except Turbo), and all XS1100 models control switches.
    $ 99.95
    HCP25228 Aftermarket left control switch BLACK GROUND WIRE with ring terminal (attaches inside the control switch housing). This replacement switch will fit OEM switches and function properly. NOTE: control switch must be opened up to replace this part, and wire leads re-routed thru the vinyl sheath/sleeve that surrounds the wire harness bundle from the switch assembly to the main harness. The end of the wire must be hooked up to its respective connector shell wire, and a butt connector is included for this purpose. Fits all XJ550, XJ650 (except Turbo), and all XS1100 models control switches.
    $ 11.95
    HCP24452 Aftermarket left control switch HEADLIGHT HI/LO BEAM SELECTOR KNOB with SCREW. This is the black plastic triangle-shaped “”thumb knob” that attaches to the selector arm (below). This plastic knob is commonly missing or badly faded from exposure. This replacement knob comes with its retaining screw. NOTE: if the selector arm (“stalk”) that this knob attaches onto has a split, crack, or broken end, then this knob will have nothing to attach to, or not be able to be retained to the arm via the screw. In such a situation, you will need to replace the arm (below) also. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 24.95
    HCP24450 Aftermarket left control switch HEADLIGHT HI/LO BEAM SELECTOR ARM. This is the plastic “stalk” that the position selector knob above is attached onto. This plastic arm is commonly broken and the selector knob can no longer be attached to it. This replacement comes with the copper contact plate and the spring-loaded detent ball. Easy replacement and solution to a common problem. NOTE: control switch must be opened up to replace this part. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 37.95
    HCP24451 Aftermarket left control switch HEADLIGHT HI-LO BEAM SELECTOR TERMINAL BOARD with WIRE LEADS. This is the black plastic “crescent moon” shaped terminal plate with wire leads. It fits inside the upper shell of the control switch, and has the wire bundle which is routed to the main harness connector shell(s). This replacement terminal board is configured slightly different than original (more terminal pads), but will fit and function properly. NOTE: control switch must be opened up to replace this part, and wire leads re-routed thru the vinyl sheath/sleeve that surrounds the wire harness bundle from the switch assembly to the main harness. The ends of the wires must be hooked up to their respective connector shell wires, and a set of 3 butt connectors are included for this purpose. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 37.95
    HCP24579 Aftermarket left control switch HEADLIGHT SELECTOR SWITCH REBUILD KIT. This set contains the headlight selector knob and screw (HCP24452), the selector arm (HCP24450), and the terminal board with wire leads (HCP24451). Allows you to completely rebuild/replace the headlight beam control portion of the complete control switch. NOTE: control switch must be opened up to replace this part. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 79.95
    HCP24455 Aftermarket left control switch TURN SIGNAL ACTUATING SELECTOR ARM ASSEMBLY. This is the metal selector arm that the thumb knob is attached onto. It fits inside the lower shell of the control switch, and includes the arm, its brass pivot bushing, the flat washer (retaining screw is not included), and the triangle-shaped plastic “thumb knob” with the white directional wording “L <-> R and OFF”. NOTE: control switch must be opened up to replace this part. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 34.95
    HCP24458 Aftermarket left control switch TURN SIGNAL SLIDE SWITCH ASSEMBLY with WIRE LEADS. This is sliding switch assembly, complete in its metal cage and with the terminal plate with wire leads. It fits inside the lower shell of the control switch, and has the lead wires that are routed to the main harness connector shells. This replacement switch will fit OEM switches and function properly. NOTE: control switch must be opened up to replace this part, and wire leads re-routed thru the vinyl sheath/sleeve that surrounds the wire harness bundle from the switch assembly to the main harness. The ends of the wires must be hooked up to their respective connector shell wires, and a set of 3 butt connectors are included for this purpose. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 49.95
    HCP24457 Aftermarket left control switch TURN SIGNAL SWITCH ASSEMBLY RETAINER BLOCK. This is the black (original may have been black or white) plastic “cube” that retains the switch assembly and has the detent ball which allows the proper cancelling of the signal switch.. It fits inside the lower shell of the control switch. This replacement switch will fit OEM switches and function properly. NOTE: control switch must be opened up to replace this part. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 24.95
    HCP24454 Aftermarket left control switch TURN SIGNAL CONTACTS PLATE with WIRE LEAD. This is the square, flat contacts board that creates the circuit for the turn signal switch assembly. The two long, thin copper “leaf” terminal arms are responsible for insuring proper operation of the signal operation. It fits inside the lower shell of the control switch, and has the lead wire that are routed to the main harness connector shell. This replacement switch will fit OEM switches and function properly. NOTE: control switch must be opened up to replace this part, and the wire lead re-routed thru the vinyl sheath/sleeve that surrounds the wire harness bundle from the switch assembly to the main harness. The end of the wire must be hooked up to its respective connector shell wire, and a butt connector is included for this purpose. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 34.95
    HCP24580 Aftermarket left control switch TURN SIGNAL SWITCH REBUILD KIT. This set contains the selector arm assembly (HCP24455), the switch assembly with wire leads (HCP24458), the retainer block (HCP24457), and the contacts plate with wire lead (HCP24454) Allows you to completely rebuild/replace the turn signal control portion of the complete control switch. NOTE: control switch must be opened up to replace this part. For use on all XJ550, XJ650 (except Turbo and Police models), all XS1100 models, 1979-82 XS400, 1979 XS650 and XS650-2, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago left side control switches. Each:
    $ 79.95
    Choke/Starter/Enrichment Circuit Control Levers & Hardware:
    Mounted onto the left side handlebar control switch is the black plastic choke cable control LEVER which allows you to control the choke system, and if it's missing or broken, here's your chance to replace them with brand new parts and restore their proper function and appearance.
    HCP2687 OEM choke LEVER, round plastic lever unit with finger knob, does not include any mounting hardware. Fits all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models:
    $ 39.95
    HCP268 OEM choke LEVER, round plastic lever unit with finger knob, does not include any mounting hardware. Fits all XJ650 Turbo models, all XJ700, XJ750 Maxim and Midnight Maxim, and XJ1100 models:
    $ 29.95
    HCP3567 OEM choke lever HOUSING, round plastic bracket attaches to the bottom of the control switch housing and holds the actual choke lever and routes the starter cable. Fits all XJ700 models:
    $ 42.95
    HCP3565 OEM choke lever RING, round plastic lever unit with finger knob, does not include any mounting hardware. Fits all XJ900RK, RL, and N/FN models:
    $ 59.95
    HCP3568 OEM choke lever SPRING WASHER, special flat washer that mounts underneath the choke lever (between the lever and the control switch housing). Used on all XJ550, XJ650, XJ750, and XJ1100 models.
    $ 11.95
    HCP3570 OEM choke lever MOUNTING SCREW, holds the lever to the control switch housing. Natural finish. Used on all XJ550, all XJ650 models, all XJ700, all XJ750 Seca, and XJ750-X models.
    $ 2.95
    HCP3571 OEM choke lever MOUNTING SCREW, holds the lever to the control switch housing. Black finish. Used on all XJ750 Maxim and Midnight Maxim models, and XJ1100 models.
    $ 7.95
    HCP14462 Aftermarket choke lever MOUNTING SCREW, holds the lever to the control switch housing. Alloy steel with a bright zinc-plated finish. Used on all XJ550, all XJ650 models, all XJ700, all XJ750 models, and XJ1100 models.
    $ 1.95
    HCP27196 Aftermarket choke lever MOUNTING SCREW, holds the lever to the control switch housing. Made from 18-8 stainless steel with a bright finish. Used on all XJ550, all XJ650 models, all XJ700, all XJ750 models, and XJ1100 models.
    $ 2.95
    HCP27197 Aftermarket choke lever MOUNTING SCREW, holds the lever to the control switch housing. Made from 316 stainless steel with a dull finish. Used on all XJ550, all XJ650 models, all XJ700, all XJ750 models, and XJ1100 models.
    $ 3.95
    HCP3575 OEM choke lever mounting screw FLAT WASHER, used under the screw listed above. Used on all XJ550, XJ650, and XJ750 Seca models.
    $ 6.95
    HCP6642 Aftermarket choke lever mounting screw FLAT WASHER, zinc-plated alloy steel with a bright finish, use on all XJ550, XJ650, and XJ750 Seca models, each:
    $ 1.95
    HCP6643 Aftermarket choke lever mounting screw FLAT WASHER, 18-8 stainless steel with a bright finish, use on all XJ550, XJ650, and XJ750 Seca models, each:
    $ 2.95
    HCP25756 Aftermarket choke lever mounting screw FLAT WASHER, 316 stainless steel with a dull finish, use on all XJ550, XJ650, and XJ750 Seca models, each:
    $ 3.95
    HCP14285 Aftermarket choke lever mounting screw FLAT WASHER, black oxide-coated 18-8 stainless steel, use on all XJ550, XJ650, and XJ750 Seca models, each:
    $ 2.95
    HCP14284 Aftermarket choke lever mounting screw FLAT WASHER, black oxide-coated hardened alloy steel, use on all XJ550, XJ650, and XJ750 Seca models, each:
    $ 2.95
    HCP315 OEM choke lever mounting screw LOCK WASHER, used under the screw listed above on all XJ700, all XJ750 (except Seca), and XJ1100 models.
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, choke lever mounting screw LOCK WASHER, used under the screw listed above on all XJ700, all XJ750 (except Seca), and XJ1100 models.
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel choke lever mounting screw LOCK WASHER, used under the screw listed above on all XJ700, all XJ750 (except Seca), and XJ1100 models.
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel choke lever mounting screw LOCK WASHER, used under the screw listed above on all XJ700, all XJ750 (except Seca), and XJ1100 models.
    $ 1.95
    Control Switch Hardware:
    All of the following screws are used to secure the top and bottom of the control switch housings together.
    The following screws fit all of the following models and positions:
    - XJ650 Turbo models, use 2 on the right control switch.
    - XJ650 Turbo models, use 2 on the left control switch.
    - XJ750 all Maxim and Midnight Maxim, use 2 on the right control switch.
    - XJ750 all Maxim and Midnight Maxim, use 2 on the left control switch.
    - XJ1100 all models, use 2 on the right control switch.
    - XJ1100 all models, use 2 on the left control switch
    HCP3288 OEM handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 7.95
    HCP26435 Aftermarket handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP24144 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 2.95
    HCP26425 Aftermarket handlebar control switch HOUSING SCREW, black, alloy steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26426 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 4.95
    - use 1 on the right control switch on: XJ550 all models, XJ650 all (except Turbo) models, 1979-81 XS1100 all models, 1979-82 XS400, 1979 XS650 and XS650-2 models, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago models.
    - use 2 on the left control switch on: XJ550 all models, XJ650 all (except Turbo) models, and all 1979-81 XS1100 models.
    HCP3291 OEM handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 7.95
    HCP26505 Aftermarket handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP6661 Aftermarket handlebar control switch HOUSING SCREW, bight 18-8 stainless steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP6663 Aftermarket handlebar control switch HOUSING SCREW, black, alloy steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP6664 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 4.95
    - FJ600 models, use 1 on the right control switch.
    - FJ600 models, use 2 on the left control switch.
    - XJ700 models, use 2 on the left control switch.
    - XJ750-X models, use 2 on the left control switch.
    - XJ750 Seca models, use 2 on the right control switch.
    - XJ750 Seca models, use 3 on the left control switch.
    - XJ900RK, RL, N/FN, and F models, use 1 on the right control switch.
    - XJ900RK, RL, N/FN, and F models, use 2 on the left control switch.
    HCP3292 OEM handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 7.95
    HCP26506 Aftermarket handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26512 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.955
    HCP26427 Aftermarket handlebar control switch HOUSING SCREW, black, alloy steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26428 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 4.95
    The following screws fit all of the following models and use 1 of these screws on the right hand control switch:
    - XJ550 all models, XJ650 all (except Turbo) models, 1979-81 XS1100 all models, 1979-82 XS400, 1979 XS650 and XS650-2 models, 1979-81 XS650 Specials, 1980-81 XS650 Special II, 1982 XS650 Heritage, 1983-84 XS650 Heritage Special, 1981-83 XV750 Virago, and 1981-82 XV920 RH/RJ Virago models.
    HCP3289 OEM handlebar control switch HOUSING SCREW, correct black panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 7.95
    HCP26507 Aftermarket handlebar control switch HOUSING SCREW, correct black panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26513 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26429 Aftermarket handlebar control switch HOUSING SCREW, black, alloy steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26430 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 4.95
    - XJ700 all models, use 1 on the right control switch.
    - XJ750-X all models, use 1 on the right control switch.
    - XJ900 F models, use 1 on the right control switch
    HCP3290 OEM handlebar control switch HOUSING SCREW, correct black-oxide, alloy-steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 7.95
    HCP26508 Aftermarket handlebar control switch HOUSING SCREW, correct black-oxide,,alloy-steel panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26514 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26431 Aftermarket handlebar control switch HOUSING SCREW, black, alloy steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 3.95
    HCP26432 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications above. Each:
    $ 4.95
    - XJ750 Seca models, use 1 on the right control switch
    HCP3295 OEM handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications below. Each:
    $ 2.95
    HCP26509 Aftermarket handlebar control switch HOUSING SCREW, correct black-oxide, alloy steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications below. Each:
    $ 1.95
    HCP26515 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, panhead phillips-drive screw used to secure the top and bottom of the control switch housings together. See applications below. Each:
    $ 1.95
    HCP26433 Aftermarket handlebar control switch HOUSING SCREW, black, alloy steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications below. Each:
    $ 1.95
    HCP26434 Aftermarket handlebar control switch HOUSING SCREW, bright 18-8 stainless steel, hex-drive socket head screw is used to secure the top and bottom of the control switch housings together. See applications below. Each:
    $ 2.95
    Control Switch ID Decals:
    These small identification DECALS allow you to restore that brand-new look to refinished original parts.
    Handlebar Control Switch Decals for all XJ550, XJ650 (except Turbo), and all XS1100 models:
    HCP7289 Aftermarket right side handlebar control switch OFF RUN OFF decal, featuring a red square on a black background with silver lettering. Use on all XJ550, XJ650 (except Turbo), and all XS1100 models.
    $ 7.95
    HCP7291 Aftermarket right side handlebar control switch ENGINE STOP rectangular decal, black background with silver lettering. Use on all XJ550, XJ650 (except Turbo), and all XS1100 models. NOTE: some models used a decal that was slightly (about 1mm) narrower than this version that we supply. You will have to trim this decal slightly to insure proper fit on those models.
    $ 5.95
    HCP7287 Aftermarket right side handlebar control switch START rectangular decal, black background with silver lettering. Use on all XJ550, XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP15392 Aftermarket right side handlebar control switch DECALS SET complete set of the 3 decals used on the right handlebar switch. Use on all XJ550, all XJ650 (except Turbo), and 1979-81 XS1100 models.
    $ 22.95
    HCP25692 Aftermarket right side handlebar control switch DECALS SET complete set of the 4 decals used on the right handlebar switch. Use on all 1978 XS1100 models. NOTE: includes the LIGHTS ON-OFF decal.
    $ 24.95
    HCP7282 Aftermarket left side handlebar control switch LIGHTS DECAL rectangular decal, black background with silver lettering. Use on all XJ550, XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP7283H Aftermarket left side handlebar control switch HI DECAL square decal (for headlight switch high-beam position), black background with silver lettering. Use on all XJ550, XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP7283L Aftermarket left side handlebar control switch LO DECAL square decal (for headlight switch low-beam position), black background with silver lettering. Use on all XJ550 and XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP7284 Aftermarket left side handlebar control switch TURN DECAL rectangular decal, black background with silver lettering. Use on all XJ550 and XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP7285 Aftermarket left side handlebar control switch HORN DECAL square decal, black background with silver lettering. Use on all XJ550 and XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP7286 Aftermarket left side handlebar control switch <____ CHOKE DECAL rectangular decal, black background with silver lettering. Use on all XJ550 and XJ650 (except Turbo), and all XS1100 models.
    $ 5.95
    HCP15391 Aftermarket left side handlebar control switch DECALS SET is a complete set of the 6 decals used on the left handlebar switch. Use on all XJ550 and all XJ650 (except Turbo) models.
    $ 24.95
    HCP27995 Aftermarket left side handlebar control switch DECALS SET is a complete set of the 5 decals used on the left handlebar switch. Does not include the HAZARD ON-OFF decal. Use on all 1978-79 XS1100 models.
    $ 23.95
    HCP25693 Aftermarket left side handlebar control switch DECALS SET is a complete set of the 6 decals used on the left handlebar switch. Includes the HAZARD ON-OFF decal. Use on all 1980-81 XS1100 models.
    $ 23.95
    Handlebar Control Switch Decals for XJ650 Turbo, all XJ750 Maxim, and XJ1100 models:
    NOTE: the lettering on these control switches were originally pad-printed onto the painted metal (or plastic) control switch housing surface, and thus the lettering was basically "flush" with the black-painted housing. All of the "wording" decals contained in the following sets are actual thin-film decals, and as such will stand up off the painted surface ever-so-slightly. To an expert this may be noticed, but 99.9% of people will never notice the difference, and it will certainly look much better than faded of erased original lettering!
    After 24 hours from the application of the decals, you may apply a satin clear-coat to the switch housing to both protect and slightly "flush-up" the decals with the painted housing surface, all but eliminating the raised surface of the decals.
    HCP10791LH Aftermarket left side handlebar control switch DECALS SET complete set of the 5 decals (LIGHTS, HI, LO, < CHOKE, and L < TURN > R) decals used on the left switch. Use on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models.
    $ 14.95
    HCP10791RH Aftermarket right side handlebar control switch DECALS SET complete set of the 4 decals (ENGINE STOP, OFF, RUN< and the red STRIPE used at the bottom of the rocker switch) decals used on the right switch. Use on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models. NOTE: this set does not contain the decals for the secondary light control switch as used on the 1982 XJ750 Maxim models (AUX. LAMP, ON, OFF) or the XJ1100 models (HAZARD, ON, OFF).
    $ 17.95
    HCP10791 Aftermarket left and right side handlebar control switch DECALS SET complete set of the decals used on the both the left and right handlebar switches. For use on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models. NOTE: this set does not contain the decals for the secondary light control switch as used on the 1982 XJ750 Maxim models (AUX. LAMP, ON, OFF) or the XJ1100 models (HAZARD, ON, OFF).
    $ 29.95
    HCP27997 Aftermarket right side handlebar control switch AUX. LAMP ON OFF DECALS SET, contain the decals for the secondary light control switch as used on the 1982 XJ750 Maxim models.
    $ 8.95
    HCP27998 Aftermarket right side handlebar control switch HAZARD ON OFF DECALS SET, contain the decals for the hazard lights control switch as used on the XJ1100 models.
    $ 8.95
    HCP14984 Aftermarket right side handlebar control switch WHITE/RED REFLECTIVE DECAL. Used on all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models. NOTE: this white and red reflective, rectangular decal fits on the lower face of the stop/run rocker switch, and is only visible when the rocker switch is pressed down into the OFF position (i.e. this decal is visible only when the bottom/run part of the rocker switch is lifted).
    $ 6.95
    Handlebar Control Switch Decals for 1981-83 XJ750 Seca and XJ750 Euro models:
    HCP20515SET Aftermarket left side handlebar control switch DECALS SET is a complete set of all the decals used on the left handlebar switch. For use on all 1981-83 XJ750 Seca models.....includes 1 each of the white LIGHT, HI, LO, <CHOKE, and TURN self-adhesive decals.
    $ 21.95
    HCP20489SET Aftermarket right side handlebar control switch DECALS SET used on the right handlebar switch on all 1981-83 XJ750 Seca models.....includes 1 each of the white ENGINE STOP, OFF, RUN, and both the FOG LAMP / ON OFF (1981) and the AUX. LAMP ON OFF (1982-83) self-adhesive decals. NOTE: this set does not include the L-shaped HCP8098 brake cable warning decal, and that decal should be ordered separate if needed.
    $ 24.95
    HCP8098 Aftermarket right side handlebar control switch BRAKE CABLE WARNING DECAL, L-shaped, black decal with white lettering. Use on all XJ750 Euro and XJ750 Seca models. NOTE: this decal fits on the upper section of the switch, and specifies brake cable free play specs.
    $ 12.95
    Handlebar Control Switch Decals for FJ600, all XJ700, XJ750-X, 1984 XJ750RL, and XJ900 models:
    HCP20545SET Aftermarket left side handlebar control switch DECALS SET is a complete set of all the decals used on the left handlebar switch. For use on all FJ600 and XJ900 models.....includes 1 each of the white LIGHT, HI, LO, <CHOKE, and <L TURN R> self-adhesive decals.
    $ discontinued
    HCP20492SET Aftermarket left side handlebar control switch DECALS SET is a complete set of all the decals used on the left handlebar switch. For use on all XJ700 and XJ750-X models.....includes 1 each of the white LIGHT, HI, LO, <CHOKE, and <L TURN R> self-adhesive decals.
    $ discontinued
    HCP14469SET Aftermarket right side handlebar control switch DECALS SET used on the right handlebar switch on all FJ600, XJ700, XJ750-X, and XJ900 models.....includes 1 each of the white ENGINE STOP, OFF, and RUN self-adhesive decals. NOTE: this set does not include the HCP14983 rectangular "OFF" decal that is located on the bottom face of the stop/run rocker switch, and that decal should be ordered separate if needed.
    $ discontinued
    HCP14983 Aftermarket right side handlebar control switch "OFF" DECAL, white reflective wording on a black background. Used on all FJ600, XJ700, XJ750-X, and XJ900 models. NOTE: this black rectangular decal fits on the lower face of the stop/run rocker switch, and is only visible when the rocker switch is pressed down into the OFF position (i.e. this decal is visible only when the bottom/run part of the rocker switch is lifted).
    $ 5.95
    Additionally, you will also want (or need) to "re-white" the recessed, embossed lettering that occurs on many control switch function buttons....such as the "START" and "HORN" and “TURN” button lettering on some models. This can be best accomplished with our white LACQUER PAINT STICK, which is soft enough to be pressed into the lettering cavities and then the excess is wiped away, leaving a fresh, bright, white lettering image.
    HCP20579 Aftermarket recessed letter WHITE PAINT STICK, perfect size and consistency for use with embossed lettering pushbuttons and function switch knobs. Use on all models that have recessed switch lettering.
    $ 8.95
    Finally, you'll want to re-color the faded plastic function buttons (start, horn, on-off rotary or rocker switches, turn signal and headlight position knobs, etc.). The best way to accomplish this is to use an industrial-grade permanent ink marker pen, as these plastic knobs don't like standard paint products. Note that some buttons, such as START or HORN on some models, will require the use of the HCP20579 white lacquer paint (to re-white the recessed lettering) and then a careful and steady hand application of the permanent-ink marker to re-color the button itself. Do NOT re-color the plastic button first; the lacquer paint stick will "pick-up" this ink as it is being applied, and your white letters will then end up with a black, grey, or red tint to them! (and then you will curse and have to start the entire process over.......).
    HCP20575 Aftermarket plastic switch BLACK PERMANENT INK marker, for re-coloring black plastic buttons and function switch knobs. Use on all models which have black plastic pushbuttons, knobs, or function switches. The ultra-fine tip on this marker allows you to easily get around the embossed letter that you've already "re-whited" using the HCP20579 lacquer paint stick, while the wider fine-point tip allows you to re-color the broader areas more quickly and evenly.
    $ 7.95
    HCP20577 Aftermarket plastic switch RED PERMANENT INK marker, for re-coloring red plastic buttons and function switch knobs. Use on all models which have red plastic pushbuttons, knobs, or function switches. The ultra-fine tip on this marker allows you to easily get around the embossed letter that you've already "re-whited" using the HCP20579 lacquer paint stick, while the wider fine-point tip allows you to re-color broader areas more quickly and evenly.
    $ 7.95
    HCP20573 Aftermarket plastic switch GREY PAINT MARKER, for re-coloring grey plastic buttons and function switch knobs. Use on all models which have grey plastic pushbuttons, knobs, or function switches. The medium tip on this marker allows you to apply color to the smaller surface areas of pushbuttons, while the larger broad tip allows you to re-color the broader areas of rocker switches more quickly and evenly.
    $ 7.95
    HCP20582 Aftermarket control switch RE-COLOR KIT contains all of the necessary markers to re-color the pushbuttons and switches on your control switches. Contains one each of the HCP20575 black permanent ink pen and HCP20579 white paint stick. Will do both the right and left switches on all XJ550 models, all XJ650 models, XJ750 Maxim and Midnight Maxim models, and XJ1100 models. NOTE: XJ550 and XJ650 (except Turbo models) may wish to order the HCP20583 kit below if they wish to re-color the OFF-RUN-OFF knob red pointer on the right control switch.
    $ 14.95
    HCP20583 Aftermarket control switch RE-COLOR KIT contains all of the necessary markers to re-color the pushbuttons and switches on your control switches. Contains one each of the HCP20575 black permanent ink pen, the HCP20577 red permanent ink pen, and the HCP20579 white paint stick. Will do both the right and left switches on all XJ550 models, all XJ650 models, and 1981-83 XJ750 Seca models.
    $ 22.95
    HCP20584 Aftermarket control switch RE-COLOR KIT contains all of the necessary markers to re-color the pushbuttons and switches on your control switches. Contains one each of the HCP20573 grey paint marker, HCP20575 black permanent ink pen, HCP20577 red permanent ink pen, and the HCP20579 white paint stick. Will do both the right and left switches on all FJ600 models, all XJ700 models, XJ750-X, and XJ900 models.
    $ 27.95
    To fully restore your control switch appearance, we offer the correct Low Gloss Black (LGB) paint in aerosol cans so you can re-finish the housings before the application of the new decals.
    Control Switch Refinishing Paints:
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP11196 Aftermarket light tan BULLETPROOF EPOXY 2-STAGE PRIMER - SEALER. Unique 2-stage aerosol design can allows at-home results that can normally only be achieved via application with an air gun. Once activated, via the release of an internal catalyst supply, this primer has a shelf life of only 4 days, so it's a use-it-or-lose-it type of affair! But, it provides a tough-as-nails primer coat on all metals, and can also be safely used on all plastics. Safe to use under any of our frame and body paints. NOTE: this primer is not rated for ultra high-heat applications on exhaust systems or brake rotors. 14-ounce spray can.
    $ discontinued
    HCP11424 Aftermarket light grey BULLETPROOF URETHANE 2-STAGE PRIMER. Unique 2-stage aerosol design can allows at-home results of what is normally sprayed through an air gun. Once activated, via the release of an internal catalyst supply, this primer has a shelf life of only 4 days, so it's a use-it-or-lose-it type of affair! It provides a tough-as-nails primer coat on all metals and plastics. The epoxy-based primer HCP11196 should be used under this urethane primer if you a spraying over old paint or old primer of any type; otherwise, there may be a compatibility issue that may cause paint crazing, peeling, or flaking. Safe to use under any of our frame and body paints. NOTE: this primer is not rated for high-heat applications on engines, brake calipers, or brake rotors. 14-ounce spray can.
    $ discontinued
    HCP7906SP Aftermarket urethane based X-ACT MATCH FRAME AND COMPONENTS PAINT features the correct Yamaha Code 98 LGB low-gloss black finish as used on a variety of components (see list above for guidance). Requires no special surface preparation (besides absolute cleanliness!) and cures without heat or hardeners. Primer is required. This "low-gloss black" is as close as possible to the original Yamaha color. Each aerosol can contains 12 ounces, enough to do both control switches. Each can:
    $ discontinued
    HCP11291 Aftermarket standard-grade LOW-GLOSS FAST-DRYING CLEAR-COAT. Once fully cured this clear-coat is ideal for use on rear grab bars, steering crown brackets, fork tubes, or other items that are not subject to fuel or oil contact or high-heat conditions. Lacquer-based formula should not be used over any enamel paint. Although nowhere near as durable as our Bulletproof products below, this is a good quality, affordable clear coat for items that do not require a professionally-sprayed appearance. 16-ounce spray can.
    $ discontinued
    HCP8037 Aftermarket standard-grade HIGH-GLOSS FAST-DRYING CLEAR-COAT. Once fully cured this clear-coat is ideal for use on rear grab bars, steering crown brackets, fork tubes, or other items that are not subject to fuel or oil contact or high-heat conditions. Enamel-based formula can be safely used over most other paint coatings, including over lacquer paints. Although nowhere near as durable as our Bulletproof products below, this is a good quality, affordable clear coat for items that do not require a professionally-sprayed appearance. NOTE: this clear-coat is not rated for high-heat applications on engines, brake calipers, or brake rotors. 16-ounce spray can.
    $ discontinued
    HCP11032 Aftermarket BULLETPROOF HIGH-GLOSS, 2-STAGE, CLEAR-COAT WITH HARDENER. Unique 2-stage aerosol design can allows at-home use of what is normally required to be sprayed through an air gun. Once activated via the release of an internal hardener supply, this clear-coat has a shelf life of only 24 hours (1 day), so it's a use-it-or-lose-it type of affair! But, it provides a tough-as-nails urethane protection over all types of materials. Safe to use over any of our frame and body paints. 12-hours drying time to handle, and requires 30-60 days to fully cure. Once fully cured this clear-coat is fully chemical, oil, and fuel resistant, making it ideal for use on gas tanks. NOTE: this clear coat is not rated for high-heat applications on engines, brake calipers, or brake rotors. 12-ounce spray can.
    $ discontinued
    HCP11198 Aftermarket BULLETPROOF HIGH-GLOSS, 2-STAGE, FAST-DRYING CLEAR-COAT WITH HARDENER. Same features and benefits as the HCP11032 clear-coat above, but in a much faster-drying formula that only requires 2-hours drying time to handle, and requiring just 18-24 days to fully cure. Once fully cured this clear-coat is chemical, oil, and fuel resistant, making it ideal for use on gas tanks. NOTE: this clear coat is not rated for high-heat applications on engines, brake calipers, or brake rotors. 12-ounce spray can.
    $ discontinued
    Control Switch Lubricants:
    et26) Aftermarket electrical device SWITCH LUBRICANT is a specially formulated, electrically non-conductive penetrating lube that is recommended on control switch turn signal contacts and headlight switching contacts. 10-gram squeeze tube has applicator tip for precision use.
    HCP14066 Aftermarket tube of electrical SWITCH LUBRICANT.
    $ 16.95
    et27) Aftermarket electrical INSTRUMENT OIL is a highly refined light oil for use on speedometer heads, tachometers, gauges, mechanical clocks, etc. Will not congeal even at 50-below-zero! Extra-slow rate of evaporation makes sure that it provides lubrication for a long, long time. 1-ounce pen has an applicator needle tip for precision use.
    HCP20852 Aftermarket hi-performance INSTRUMENT OIL, comes in a handy applicator pen. Oil-based triple-processed lubricant eliminates contaminants that would cause gumming or corrosion product is what we use and recommend for freeing stuck speedo or tacho drive mechanisms.
    $ 37.95
  21. chacal
    SAFETY SWITCHES, SENSORS, AND RELAYS:
    An useful review of all the various relays and other components used on your bike can be found at:
    http://xjbikes.com/forums/index.php?threads/the-ultimate-relay-switch-sensor-and-diodes-guide.27543/
    and
    http://www.xjbikes.com/forums/threads/how-to-test-a-relay.6809/#post-57590
    srs2) OEM kickstand or sidestand SAFETY SWITCH, with plunger, bellows, and wire harness and connector. Prevents the engine from running if the sidestand is down AND the bike is in gear. An important part of the entire complicated but very useful and effective safety system on these bikes. NOTE: used on all XJ-series bikes except for 1980-81 XJ650 Maxim and Midnight Maxim models.
    HCP3262 OEM kickstand or sidestand SAFETY SWITCH, with plunger, bellows, and wire lead harness and connector. Fits all XJ550, 1984-85 FJ600, and 1986-90 YX600 Radian models. Does not include the HCP29499 extension harness below. Each:
    $ 129.95
    HCP29499 Aftermarket kickstand or sidestand switch EXTENSION WIRE HARNESS. This 36” sub-harness plugs into the kickstand switch lead wires and attaches to the main wire harness at the other end. Correct reproduction has original wire colors, terminals, and 2-place connector shell. Used on all XJ550, 1984-85 FJ600, 1986-90 YX600 Radian, and 1986-88 FZ600 models. Each:
    $ 39.95
    HCP22650 OEM kickstand or sidestand SAFETY SWITCH, with plunger, bellows, and wire harness and connector. Fits all 1992-98 XJ600 Seca II models.
    $ 89.95
    HCP450 OEM kickstand or sidestand SAFETY SWITCH, with plunger, bellows, and wire harness and connector. Fits all 1982-83 XJ650 Maxim models.
    $ 159.95
    HCP3259 OEM kickstand or sidestand SAFETY SWITCH, with plunger, bellows, and wire harness and connector. Fits all 1985-86 XJ700 and XJ750-X models.
    $ 149.95
    HCP3261 OEM kickstand or sidestand SAFETY SWITCH, with plunger, bellows, and wire harness and connector. Fits all XJ900RK and F models.
    $ 189.95
    HCP19358 Aftermarket kickstand or sidestand safety switch RUBBER BELLOWS BOOT, perfectly replaces your ripped, torn or degraded original boot, keeping dirt/grit/fluids out of your switch. This tri-bellows boot Is retained by dual circlips at the end of the shaft. Fits all XJ550, FJ600, 1982-3 XJ650 Maxim, all XJ700, XJ750-X, and XJ1100 models.
    $ 27.95
    HCP19359 Aftermarket kickstand or sidestand safety switch RUBBER BELLOWS BOOT, perfectly replaces your ripped, torn or degraded original boot, keeping dirt/grit/fluids out of your switch. This 8-bellows boot covers both the short switch plunger and most of the "extension rod" used on all XJ650RJ Seca, XJ650 Turbo, XJ650 Euro, XJ750 Seca, XJ750 Maxim, XJ750 Euro, and XJ900 models.
    $ 27.95
    HCP29089 OEM kickstand or sidestand safety switch MOUNTING SCREW, correct flathead style screw used to mount the sidestand safety switch. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and XJ900RK and F models. Use 2 per switch. Each:
    $ 7.95
    HCP6265 Aftermarket kickstand or sidestand safety switch MOUNTING SCREW, correct flathead style, zinc-plated alloy steel screw used to mount the sidestand safety switch. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and XJ900RK and F models. Use 2 per switch. Each:
    $ 1.95
    HCP6267 Aftermarket kickstand or sidestand safety switch MOUNTING SCREW, correct flathead style, bright 18-8 stainless steel screw used to mount the sidestand safety switch. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and XJ900RK and F models. Use 2 per switch. Each:
    $ 2.95
    HCP29090 Aftermarket kickstand or sidestand safety switch MOUNTING SCREW, correct flathead style, black-oxide 18-8 stainless steel screw used to mount the sidestand safety switch. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and XJ900RK and F models. Use 2 per switch. Each:
    $ 3.95
    HCP22651 OEM kickstand or sidestand safety switch MOUNTING SCREW, correct style screw used to mount the sidestand safety switch. Fits all 1992-98 XJ600 Seca II models. Use 2 per switch. Each:
    $ 1.95
    HCP3260 OEM kickstand or sidestand safety switch MOUNTING SCREW, correct flathead style screw used to mount the sidestand safety switch. Fits all XJ1100 models. Use 2 per switch. Each:
    $ 0.95
    srs2) OEM safety system DIODE BLOCK, with wire harness and connector. This is sort of the "brains" of the entire safety system for the bike, and prevents various elements of the entire system from grounding through one another.
    And here we'll find all of their dirty little internal secrets exposed:
    http://xjbikes.com/forums/threads/diode-block.47628
    HCP436 OEM main harness wiring DIODE BLOCK, 7-wire design, with harness lead and connector. Fits all XJ550 models, FJ600, all 1982-83 XJ650 Maxims, and all XJ700 models. Each:
    $ 67.95
    HCP434 OEM main harness wiring DIODE BLOCK, 5-wire design, with harness lead and connector. Fits all 1980-81 XJ650 Maxim and Midnight Maxim models, all 1983 XJ750 Maxim and Midnight Maxims, all XJ750 Seca models, and XJ900RK and F models. Each:
    $ 77.95
    HCP13735 OEM main harness wiring DIODE BLOCK, 3-wire design, with harness lead and connector. Fits all 1981 XJ550 Euro (4V8 model), 1980 XJ650 Euro (4K0 model), XJ900RL, XJ900 N/FN, and XJ900 1FW models, and 1983 XVZ12 models. Each:
    $ 79.95
    HCP435 OEM main harness wiring SINGLE DIODE, with harness lead and connector, located under the fuel tank within the main harness. Fits all 1982 XJ750 Maxim and XJ1100 models. Each:
    $ 23.95
    srs2) OEM safety system NEUTRAL POSITION SWITCH. This switch is fitted up inside the engine case, behind the shifter cover, on XJ550 models, or into the bottom or the crankcase on all XJ650-up models, just to the left of the oil pan, and determines whether the transmission is in neutral. On the XJ650-up models, it is very difficult to access (or even see) this switch when the engine is in the bike and/or with the exhaust system in place:
    http://www.xjbikes.com/forums/threads/xj650-neutral-switch-location.75495/
    HCP3580 OEM gear selector NEUTRAL POSITION SWITCH. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models. The terminal screw and lockwasher are included, but the mounting o-ring and screws (3) are not included and should be ordered separate. Each:
    $ 44.95
    HCP28974 Aftermarket gear selector NEUTRAL POSITION SWITCH. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models. The mounting o-ring and screws (3) are included.. Each:
    $ 37.95
    HCP443 OEM gear selector NEUTRAL POSITION SWITCH. Fits all XJ650, XJ700, XJ750, XJ900RK, RL, and N/FN models, XJ1100, and XS1100 models. The terminal screw and lockwasher are already included, but the sealing crush washer is not and should be ordered separate. Each:
    $ 44.95
    HCP15671 Aftermarket gear selector NEUTRAL POSITION SWITCH. Fits all XJ650, XJ700, XJ750, XJ900RK, RL, and N/FN models, XJ1100, and XS1100 models. NOTE: uses a nut-and-washer to retain the ring terminal to the switch post instead of the original phillips-drive screw. The terminal nut and its lockwasher are already included, but the sealing crush washer is not and should be ordered separate. Each:
    $ 34.95
    HCP3581 OEM gear selector neutral position switch O-RING. Seals the switch to the engine case, preventing oil leaks. Fits all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, and 1992-2002 XJ600 Euro models. Each:
    $ 8.95
    HCP21660 Aftermarket gear selector neutral position switch O-RING. Seals the switch to the engine case, preventing oil leaks. Fits all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, and 1992-2002 XJ600 Euro models. Each:
    $ 5.95
    HCP3412 OEM gear selector neutral position switch copper CRUSH WASHER. Seals the switch to the engine case, preventing oil leaks. Fits all XJ650, XJ700, XJ750, XJ900RK, RL, and N/FN models, XJ1100, and XS1100 models. Each:
    $ 4.95
    HCP21341 Aftermarket gear selector neutral position switch copper CRUSH WASHER. Seals the switch to the engine case, preventing oil leaks. Fits all XJ650, XJ700, XJ750, XJ900RK, RL, and N/FN models, XJ1100, and XS1100 models. Each:
    $ 2.95
    HCP6780 OEM gear selector neutral position switch MOUNTING SCREW. Attaches the switch to the engine case. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-97 XJ600 Seca II models, use 3 per switch. Each:
    $ 2.95
    HCP28882 Aftermarket gear selector neutral position switch MOUNTING SCREW. Black oxide-coated 18-8 stainless steel. Attaches the switch to the engine case. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-97 XJ600 Seca II models, use 3 per switch. Each:
    $ 2.95
    HCP28883 Aftermarket gear selector neutral position switch MOUNTING SCREW. Bright 18-8 stainless steel. Attaches the switch to the engine case. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-97 XJ600 Seca II models, use 3 per switch. Each:
    $ 2.95
    HCP24586 Aftermarket gear selector neutral position switch TERMINAL SCREW. Secures the lead-in wire terminals to the switch. For use with the HCP443 neutral switch. Use with the HCP336 lockwasher below. Phillips drive, made from 18-8 stainless-steel. Each:
    $ 4.95
    HCP326 OEM gear selector neutral position switch terminal screw LOCK WASHER, bright zinc-plated alloy steel. For use with the HCP443 neutral switch, each:
    $ 3.95
    HCP922 Aftermarket gear selector neutral position switch terminal screw LOCK WASHER, bright zinc-plated alloy steel. For use with the HCP443 neutral switch, each:
    $ 1.95
    HCP336 Aftermarket gear selector neutral position switch terminal screw LOCK WASHER, 18-8 stainless-steel. For use with the HCP443 neutral switch, each:
    $ 2.95
    HCP342 Aftermarket gear selector neutral position switch terminal screw LOCK WASHER, black oxide-coated alloy steel. For use with the HCP443 neutral switch, each:
    $ 1.95
    NOTE: THE FOLLOWING TOOLS ARE AVAILABLE FOR RENTAL!!: since this tool is a one-time or infrequent use tool, it may be more economical for you to rent it from us, rather than to purchase it outright. Please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    HCP15718 Aftermarket neutral position switch REMOVAL SOCKET. On many models, it's almost a physical impossibility to remove the HCP443 (or the aftermarket version, HCP15671) neutral switch from the crankcase "well" without removing the exhaust system or removing the engine from the frame.....the left lower frame tube conspires with the exhaust system to make it unbelievably difficult to access the switch. This special "open side" socket is the proper size to squirm through those restricted spaces and make it possible to remove and re-install the position switch without going through a tremendous amount of effort. Standard 1/4" drive socket should be used with a 3" extension bar, or, it's even easier to use when attached to the HCP13516 flexible shaft driver listed below. NOTE: this tool will not help you on XJ650 Maxim models with the stock exhaust system, as the crossover pipe is in the way and prevents access of even this tool.
    $ 34.95
    HCP13516 Aftermarket flexible "spring shaft" 1/4" SOCKET DRIVER TOOL, just the thing to use with the HCP15718 socket above to reach the neutral switch. Large plastic handle with 6" long flexible shaft.
    $ 24.95
    ssr1) OEM safety system SIDESTAND SAFETY SWITCH RELAY.
    Identification: the Sidestand Safety Switch Relay is a small square metal "cube" relay, has a blue paint "dot" by the locking tab, and has the following 4 wires connected to it:
    - XJ550 all models, 1982-84 XJ650 all model, XJ700 all models, XJ750 all models, XJ900RK Seca models, and XJ1100 models: a solid black wire, a red wire with a white tracer stripe, a black wire with a white tracer stripe, and a blue wire with a yellow tracer stripe.
    NOTE: original relays were always a square metal cube style, although they may have been replaced by an plastic-cased cube relay.
    HCP18083 OEM safety system SIDESTAND SAFETY SWITCH RELAY. For all XJ550, FJ600, 1982-84 all XJ650 models, all XJ750, XJ900RK and F models, and XJ1100 models. Small metal "cube" type relay has 4U8 inked on the top face and has a blue-painted locking tab for identification. NOTE: this is the original relay with a metal lid. The superseded relay (HCP433 below) have a plastic case, but function the same. Rubber mounting grommet is included.
    $ 159.95
    HCP433 OEM safety system SIDESTAND SAFETY SWITCH RELAY. For all XJ550, FJ600, 1982-84 all XJ650 models, all XJ700 models, all XJ750, XJ900RK and F models, and XJ1100 models. Small plastic "cube" type relay has 4U8 inked on the top face and has a blue-painted locking tab for identification. NOTE: original relay has a metal lid; these superseded relays have a plastic case, but function the same. Rubber mounting grommet is included.
    $ 109.95
    nss1) OEM safety system NEUTRAL SAFETY SWITCH RELAY. This relay is also called a starting circuit cut-off relay or an ignition cut-off relay, depending which manual you are reading!
    Identification: the Neutral Safety Switch Relay is a small square metal "cube" relay, has no paint "dot" by the locking tab, and has the following 4 wires connected to it:
    - XJ550 all models, XJ650 all model, XJ750 all models, and XJ1100: a solid light blue wire, a red wire with a white tracer stripe, another red wire with a white tracer stripe, and a black wire with a yellow tracer stripe.
    - XJ900 models: two solid light blue wires ganged together into one terminal slot, two red wires with a white tracer stripe ganged together into one terminal slot, a white wire with a red tracer stripe, and a black wire with a yellow tracer stripe.
    NOTE: original relays were always a square metal cube style, although they may have been replaced by a plastic-case relay. THIS RELAY IS A SPECIALIZED DESIGN AND THE USE OF A STANDARD RELAY IS DANGEROUS!-----it will allow the safety function to be defeated and could result in different operation from what is intended.
    HCP431 OEM safety system NEUTRAL SAFETY SWITCH RELAY. For all XJ550, XJ650, XJ750, all XJ900RK, RL, and N/FN models, and XJ1100 models. The original style metal "cube" type relay has 4H7 inked on the top face and has an un-marked (no paint color) locking tab for identification; this later-style replacement has a plastic body and is marked 12R-01 on the top face. Rubber mounting grommet is included.
    $ 89.95
    ess1) OEM safety system EMERGENCY STOP SWITCH and RELAY. This special position-sensitive switch and its associated relay are designed to shut off the ignition switch if the bike is laid down. Used only on XJ650 Turbo and XJ1100 models.
    HCP3588 OEM safety system EMERGENCY STOP SWITCH. For use on all XJ650 Turbo, XJ1100, all XS1100 models, 1983-85 and 1989 XVZ12, and 1986-93 XVZ13 models
    $ 129.95
    HCP18083 OEM safety system EMERGENCY STOP SWITCH RELAY. For all XJ650 Turbo models only. Small metal "cube" type relay has 4U8 inked on the top face and has a blue-painted locking tab for identification. NOTE: this is the original relay with a metal lid. The superseded relay (HCP433 below) have a plastic case, but function the same. Rubber mounting grommet is included.
    $ 159.95
    HCP433 OEM safety system EMERGENCY STOP SWITCH RELAY. For all XJ650 Turbo models only. Small plastic "cube" type relay has 4U8 inked on the top face and has a blue-painted locking tab for identification. NOTE: original relay has a metal lid; these superseded relays have a plastic case, but function the same. Rubber mounting grommet is included
    $ 139.95
    ess12) OEM safety system FUEL PUMP RELAY. This special relay is used only on XJ650 Turbo models. The original style metal "cube" type relay has 5A8 inked on the top face and has a red-painted locking tab for identification; this later-style replacement is marked 25G on the top face.
    HCP12648 OEM safety system FUEL PUMP RELAY. For use on all XJ650 Turbo models.
    $ 89.95
    RELAY HOLDERS:
    These stretchy rubber relay HOLDER GROMMETS replace missing or damaged originals, and help keep your cube relays firmly in place where they belong. Slotted top edge slips over original metal bracket.
    HCP11105 Aftermarket rubber RELAY HOLDER for original metal-lid "cube" type safety system, headlight, sidestand, fuel pump, etc. relays. This grommet has a square opening (it's a copy of the original grommet), and molded of a thick-wall rubber compound. NOTE: does not fit the later style plastic-lid cube relays. Each:
    $ 14.95
    HCP15149 Aftermarket rubber RELAY HOLDER for original metal rectangular "cube" type safety system, headlight, sidestand, fuel pump, etc. relays. NOTE: the original relay holders have a square opening (which matches the shape of the original square "cube" relays); these replacements have a round opening, however, they will flex and fit the original metal "rectangular" lid relays properly, but will not fit the later-style plastic-lid "cube" relays. Will also fit any round "can" style relay up to 32mm OD. Each:
    $ 11.95
    TURBOCHARGER KNOCK SENSOR HARNESS:
    HCP10912 OEM knock sensor WIRE HARNESS, from the sensor to the main wiring harness. The knock sensor is located on the front of the cylinder jugs and “listens” for telltale vibrations (sound pressure waves) from the cylinders, indicating pre-ignition and potentially damage to the engine. This special harness takes the signal from the sensor and inputs it to the TCI, which will then retard timing when pinging or knocking is detected. Use 1 per bike. Each:
    $ 79.95
    MASTER CYLINDER FLUID LEVEL SENSOR:
    HCP3022 OEM master cylinder FLUID LEVEL SENSOR. This is the complete low-brake-fluid sensor switch assembly: float, post, lead wires and connectors. For all 1982 XJ750 Maxim front and XJ1100 front master cylinders.
    $ 129.95
    HCP3025 OEM master cylinder FLUID LEVEL SENSOR. This is the complete low-brake-fluid sensor switch assembly: float, post, lead wires and connectors. For all XJ750 Seca front and XJ1100 rear master cylinders.
    $ 149.95
    HCP19573 Aftermarket LOW-FLUID SENSOR BY-PASS WIRE, for low-brake fluid sensor. If your sensor is not functioning or missing, you'll need to by-pass the sensor so that the computer is fooled into thinking there is plenty of fluid in the reservoir. (and to stop flashing the dash warning light at you!). For use on all XJ650 Turbo models, 1981-83 XJ750 Seca models and XJ750 Euro models, and 1982 XJ750 Maxim models. Simple plug-and-play operation.
    $ 12.95
    HCP3023 OEM front master cylinder reservoir float sensor shaft O-RING, where the fluid level sensor wires exit the reservoir chamber, for all XJ650 Turbo, XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, XJ750-D, XJ750P (24L and 37H) models, and XJ1100 front and rear master cylinders. Use 1 per master cylinder.
    $ 12.95
    HCP16194 Aftermarket front master cylinder reservoir float sensor shaft O-RING, where the fluid level sensor wires exit the reservoir chamber, for all XJ650 Turbo, XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, XJ750-D, XJ750P (24L and 37H) models, and XJ1100 front and rear master cylinders. Buna-N material like original. Use 1 per master cylinder.
    $ 6.95
    HCP16193 Aftermarket front master cylinder reservoir float sensor shaft O-RING, where the fluid level sensor wires exit the reservoir chamber, for all XJ650 Turbo, XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, XJ750-D, XJ750P (24L and 37H) models, and XJ1100 front and rear master cylinders. Tough Viton material. Use 1 per master cylinder.
    $ 9.95
    HCP4257 OEM front master cylinder fluid level sensor retaining E-CLIP, for all XJ750 Seca and XJ750 Euro models. This is the large circlip on the bottom of the reservoir.
    $ 2.95
    HCP22312 Aftermarket front master cylinder fluid level sensor retaining E-CLIP, for all XJ750 Seca and XJ750 Euro models. This is the large circlip on the bottom of the reservoir. Black oxide coated alloy steel. Each:
    $ 1.25
    HCP22313 Aftermarket front master cylinder fluid level sensor retaining E-CLIP, for all XJ750 Seca and XJ750 Euro models. This is the large circlip on the bottom of the reservoir. Bright 18-8 stainless steel. Each:
    $ 1.95
    HCP6836 OEM front master cylinder fluid level sensor retaining E-CLIP, bright plated spring steel. This is the small clip that retains the float, at the very top of the shaft. For all XJ650 Turbo, XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, XJ750-D, XJ750P (24L and 37H) models, and XJ1100 front and rear master cylinders.
    $ 7.95
    HCP905 Aftermarket master cylinder fluid level sensor retaining E-CLIP, black-phosphate coated spring steel as original. This is the small clip that retains the float, at the very top of the shaft. For all XJ650 Turbo, XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, XJ750-D, XJ750P (24L and 37H) models, and XJ1100 front and rear master cylinders.
    $ 47.95
    HCP2909 Aftermarket master cylinder fluid level sensor retaining E-CLIP, type 420 stainless spring steel. This is the small clip that retains the float, at the very top of the shaft. For all XJ650 Turbo, XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, XJ750-D, XJ750P (24L and 37H) models, and XJ1100 front and rear master cylinders.
    $ 6.95
    HCP4190 OEM brake fluid level sensor MOUNTING SCREW. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Zinc-plated steel, panhead phillips-drive. Use 1 on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders. Each:
    $ 6.95
    HCP6418 Aftermarket brake fluid level sensor MOUNTING SCREW. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Zinc-plated steel, panhead phillips-drive. Use 1 on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders. Each:
    $ 1.95
    HCP6420 Aftermarket brake fluid level sensor MOUNTING SCREW. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless steel, panhead phillips-drive like original. Use 1 on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders. Each:
    $ 1.95
    HCP6421 Aftermarket brake fluid level sensor MOUNTING SCREW. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless steel, small-head (JIS) panhead phillips-drive like original. Use 1 on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders. Each:
    $ 3.95
    HCP6422 Aftermarket brake fluid level sensor MOUNTING SCREW. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Black-oxide coated 18-8 stainless steel, panhead phillips-drive screw. Use 1 on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders. Each:
    $ 2.95
    HCP6644 Aftermarket brake fluid level sensor MOUNTING SCREW. Originally it had a captured lock washer and flat washer; these replacement screws come with the lock washer but without the flat washer, which must be ordered separate below. Yellow zinc-plated steel, panhead phillips-drive screw. Use 1 on all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders. Each:
    $ 1.95
    HCP326 OEM brake fluid level sensor mounting screw LOCK WASHER, for all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders.
    $ 3.95
    HCP922 Aftermarket brake fluid level sensor mounting screw LOCK WASHER. Zinc-plated alloy steel, each:
    $ 1.95
    HCP336 Aftermarket brake fluid level sensor mounting screw LOCK WASHER. 18-8 stainless-steel, each:
    $ 2.95
    HCP342 Aftermarket brake fluid level sensor mounting screw LOCK WASHER. Black oxide-coated steel, each:
    $ 1.95
    HCP328 OEM brake fluid level sensor mounting screw FLAT WASHER, for all XJ650 Turbo, 1982 XJ750 Maxim, and XJ750P (24L), XJ750P (37H), and XJ1100 front master cylinders.
    $ 3.95
    HCP924 Aftermarket brake fluid level sensor mounting screw FLAT WASHER. Zinc-plated, alloy steel, each:
    $ 1.95
    HCP338 Aftermarket brake fluid level sensor mounting screw FLAT WASHER. 18-8 stainless-steel, each:
    $ 2.95
    HCP28050 Aftermarket brake fluid level sensor mounting screw FLAT WASHER. Grade 316 stainless-steel, each:
    $ 3.95
    HCP1356 Aftermarket brake fluid level sensor mounting screw FLAT WASHER. Black oxide-coated steel, each:
    $ 1.95
    FRONT MASTER CYLINDER BRAKE LIGHT SWITCH:
    NOTE: except on the XJ750 Seca models, the removal of these switches from the master cylinder housing seems like a trick Chinese puzzle, until you figure it out.....there is small, round hole (about 2mm diameter) on the forward side of the housing where this switch plugs in. Using a small screwdriver or other such object, gently push in through this hole onto the plastic "tooth" that is part of the switch housing, while also pulling back on the switch. Releasing this ratchet tooth will release the switch from the housing, and out it comes! Here's a good image of it:
    http://xjbikes.com/forums/index.php?threads/38144
    HCP441 OEM front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch snaps into the master cylinder housing and includes the correctly colored wire harness leads and connector. Fits all of the following models using original master cylinders: XJ550 all models, XJ650 all models, XJ750 Maxim and Midnight Maxim models, XJ750P (37H model), all XJ900RK and RL models, XJ1100, and all XS1100 models, and also fits our aftermarket HCP3063WO and HCP1808WO master cylinders.
    $ 69.95
    HCP3522 Aftermarket front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch snaps into the master cylinder housing and includes the correctly colored wire harness leads and connector. For the following models: XJ550 all models, XJ650 all models, XJ750 Maxim and Midnight Maxim models, XJ750P (37H model), XJ900RK and RL models, XJ1100, and all XS1100 models, as well as our aftermarket HCP1808WO and HCP3063WO master cylinders . A very nice reproduction of the original. NOTE: the length of the lead wires on this switch are 9" shorter than on the original HCP441 switch.....please determine whether this difference in length is going to cause any problems with proper installation or use on your model bike (especially at the full left or right handlebar lock positions).
    $ 39.95
    HCP19392 OEM front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch snaps into the master cylinder housing and includes the correctly colored wire harness leads and connector. For the following models: all 1992-98 XJ600 Seca II models.
    $ 34.95
    HCP442 OEM front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch snaps into the master cylinder housing and includes the correctly colored wire harness leads and connector. For the following models: all XJ700 and XJ750-X models.
    $ 43.95
    HCP3413 OEM front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch screws into the brake lever housing and includes the correctly colored wire harness leads and connector. For the following models: XJ750 Seca models.
    $ 79.95
    HCP13777 OEM front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch screws into the brake lever housing and includes the correctly colored wire harness leads and connector. For the following models: FJ600 and all XJ900 N, FN, and F models.
    $ 37.95
    HCP3556 OEM brake light switch MOUNTING SCREW, for use on all XJ750 Seca and Euro models, use 1 per bike, each:
    $ 2.95
    HCP2908 Aftermarket brake light switch MOUNTING SCREW, black-oxide coated steel, for use on all XJ750 Seca and Euro models, use 1 per bike, each:
    $ 1.95
    HCP13788 OEM brake light switch MOUNTING SCREW, for use on all 1984-85 FJ600 models, use 1 per bike, each:
    $ 7.95
    HCP3633 OEM brake light switch MOUNTING SCREW, for use on all XJ900 N, FN, and F models, use 1 per bike, each:
    $ 2.95
    HCP23024 Aftermarket brake light switch MOUNTING SCREW, for use on all XJ900 N, FN, and F models, use 1 per bike, zinc-plated alloy steel as original, each:
    $ 1.95
    HCP23025 Aftermarket brake light switch MOUNTING SCREW, for use on all XJ900 N, FN, and F models, use 1 per bike, 18-8 stainless steel, each:
    $ 2.95
    HCP4458 OEM brake light switch screw FLAT WASHER, for use on all XJ900 N, FN, and F models, use 1 per bike, each:
    $ 2.95
    HCP924 Aftermarket brake light switch screw FLAT WASHER. Zinc-plated, alloy steel, each:
    $ 1.95
    HCP338 Aftermarket brake light switch screw FLAT WASHER. 18-8 stainless-steel, each:
    $ 2.95
    HCP28050 Aftermarket brake light switch screw FLAT WASHER. Grade 316 stainless-steel, each:
    $ 3.95
    HCP1356 Aftermarket brake light switch screw FLAT WASHER. Black oxide-coated steel, each:
    $ 1.95
    REAR BRAKE LIGHT SWITCH:
    bls1) OEM and aftermarket REAR BRAKE LIGHT SWITCH, actuated by the rear brake pedal via a pull rod/tension spring assembly. Mounted down on the frame by the rear brake lever, these replacement switches include the spring and wiring leads and connectors.
    HCP2946 OEM rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and plastic nut. Fits the following models: XJ550 all models.
    $ 37.95
    HCP17681 Aftermarket rear brake pedal brake light switch RETURN SPRING, spring only. Fits the following models: XJ550 all models.
    $ 17.95
    HCP19170 Aftermarket rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and mounting nuts. Fits the following models: XJ550 all models. NOTE: this switch comes with a pair of metal nuts (rather than the original plastic retainer nut). You can retain and use your original plastic retaining nut if desired (the two metal nuts provided will allow you to mount this switch in the frame tab, but the original plastic nut is a much more, ummm, "elegant" method of mounting this switch!).
    $ 29.95
    HCP22660 OEM rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and plastic nut. Fits the following models: all 1992-98 XJ600 Seca II models.
    $ discontinued
    HCP445 OEM rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and plastic nut. Fits the following models: XJ650 all models except Turbo, XJ750 all models (except 1984 XJ750RL or 1985-86 XJ750-X), and all XJ900RK, RL, N/FN, and F models.
    $ 69.95
    HCP17682 Aftermarket rear brake pedal brake light switch RETURN SPRING, spring only. Fits the following models: XJ650 all models except Turbo, XJ750 all models (except 1984 XJ750RL or 1985-86 XJ750-X), and all XJ900RK, RL, N/FN, and F models.
    $ 19.95
    HCP19171 Aftermarket rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and mounting nuts. Fits the following models: XJ650 all models except Turbo, XJ750 all models (except 1984 XJ750RL or 1985-86 XJ750-X), and all XJ900RK, RL, N/FN, and F models. NOTE: this switch comes with a pair of metal nuts (rather than the original plastic retainer nut). You can retain and use your original plastic retaining nut if desired (the two metal nuts provided will allow you to mount this switch in the frame tab, but the original plastic nut is a much more, ummm, "elegant" method of mounting this switch!).
    $ 52.95
    HCP446 OEM rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and plastic nut. Fits all XJ650 Turbo models.
    $ 69.95
    HCP17683 Aftermarket rear brake pedal brake light switch RETURN SPRING, spring only. Fits the following models: all XJ650 Turbo models.
    $ 29.95
    HCP19173 Aftermarket rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and mounting nuts. Fits the following models: all XJ650 Turbo models. NOTE: this switch comes with a pair of metal nuts (rather than the original plastic retainer nut). You can retain and use your original plastic retaining nut if desired (the two metal nuts provided will allow you to mount this switch in the frame tab, but the original plastic nut is a much more, ummm, "elegant" method of mounting this switch!).
    $ 49.95
    HCP2947 OEM rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and plastic nut. Fits the following models: all XJ700 and XJ750-X models.
    $ 24.95
    HCP17684 Aftermarket rear brake pedal brake light switch RETURN SPRING, spring only. Fits the following models: all XJ700 and XJ750-X models.
    $ 17.95
    HCP19172 Aftermarket rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and mounting nuts. Fits the following models: all XJ700 and XJ750-X models. NOTE: this switch comes with a pair of metal nuts (rather than the original plastic retainer nut). You can retain and use your original plastic retaining nut if desired (the two metal nuts provided will allow you to mount this switch in the frame tab, but the original plastic nut is a much more, ummm, "elegant" method of mounting this switch!).
    $ 21.95
    HCP2948 OEM rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and plastic nut. Fits the following models: XJ1100 and XS1100 all models.
    $ 69.95
    HCP1250 Aftermarket rear brake pedal BRAKE LIGHT SWITCH, complete with lead harness, return spring, and a pair of metal nuts (instead of the original plastic nut-and-retainer). NOTE: this switch comes with a pair of metal nuts (rather than the original plastic retainer nut). You can retain and use your original plastic retaining nut if desired (the two metal nuts provided will allow you to mount this switch in the frame tab, but the original plastic nut is a much more, ummm, "elegant" method of mounting this switch!).
    $ 44.95
    CLUTCH HAND LEVER SWITCH:
    hl18) OEM clutch lever SAFETY SWITCH pops into the clutch lever holder bracket and comes with the correctly colored wire harness leads and connector.
    http://xjbikes.com/forums/index.php?threads/34244
    and
    http://www.xjbikes.com/forums/threa...ed-a-new-clutch-switch-by-just-looking.30354/
    HCP452 OEM clutch hand lever SAFETY SWITCH, complete with lead harness. Fits all of the following models: XJ550 all models, XJ650 all models, XJ700 all models, XJ750 Maxim and Midnight Maxim models, XJ1100, and 1981 XS1100 models. NOTE: wires and connector shell color differ from originals, but it does not matter which way the wires are installed, as these are merely "on-off" switches. Wire leads are approximately 6" shorter than originals. Also, if using this switch with the HCP3284 clutch lever holder bracket, one of the alignment tabs will need to be broken off (as the HCP3284 no longer has slots for both of the original alignment tabs).
    $ 36.95
    HCP11619 Aftermarket clutch hand lever SAFETY SWITCH, complete with lead harness. Fits all of the following models: XJ550 all models, XJ650 all models, XJ700 all models, XJ750 Maxim and Midnight Maxim models, XJ1100, and 1981 XS1100 models. NOTE: wires and connector shell color differ from originals, but it does not matter which way the wires are installed, as these are merely "on-off" switches. Wire leads are approximately 6" shorter than originals.
    $ 27.95
    HCP454 OEM clutch hand lever SAFETY SWITCH. Fits all 1984-85 FJ600, XJ750RL, and all XJ900RK, RL, N/FN, and F models.
    $ 69.95
    HCP453 OEM clutch hand lever SAFETY SWITCH. Fits all 1981-83 XJ750 Seca and XJ750 Euro models.
    $ 79.95
    HCP29174 OEM clutch hand lever switch MOUNTING SCREW, for use on all XJ750 Seca and Euro models, use 1 per bike, each:
    $ 1.95
    - the XJ750 Seca brake hand lever position switch (HCP3413) can be modified to be used in place of the no-longer-available XJ750 Seca clutch hand lever position switch (HCP453). The brake hand lever switch will need to be modified in the following manner:
    1) One of the male bullet wire-end terminals will need to be cut off, and a female wire-end terminal (HCP9366BR) and matching sheath (HCP9322) will need to be installed in place of the removed male bullet terminal.
    NOTE: to perform this modification, you will need the following tools: wire cutters, wire crimpers, solder, soldering iron, electrical tape. The modification will require about 15-30 minutes time, depending on your level of skill!
    2) Although the lead-wire colors will be different from original, this will not be a problem as long as you properly attach the modified clutch hand switch lead wires to their proper leads inside the headlight housing (the clutch hand switch lead wires from the main harness, located inside the main headlight bucket, are a Black with a yellow tracer stripe wire with a sheathed female bullet wire-end terminal, and a Bright Blue with a yellow tracer stripe wire with a male bullet wire-end terminal. It does matter which of the two switch lead wires that you modify (by removing the male bullet terminal and replacing it with a female bullet terminal).
    HCP3413 OEM front master cylinder BRAKE LIGHT SWITCH, complete with lead harness. This small black plastic cylinder plunger switch screws into the brake lever housing and includes the correctly colored wire harness leads and connector. For the following models: XJ750 Seca and Euro models.
    $ 79.95
    HCP3556 OEM clutch lever safety switch RETAINING SCREW. Holds the switch to the bracket. Use 1 per switch on all 1984-85 FJ600, XJ750 Seca and Euro, and all XJ900RK, RL, N/FN, and F models.
    $ 2.95
    HCP2908 Aftermarket clutch lever safety switch RETAINING SCREW. black-oxide coated steel. Holds the switch to the bracket. Use 1 per switch on all 1984-85 FJ600, XJ750 Seca and Euro, and all XJ900RK, RL, N/FN, and F models:
    $ 1.95
    HCP9366BR1418 Aftermarket SINGLE FEMALE BULLET STYLE WIRE-END TERMINAL, correct style solid brass terminal. Accepts 14-18 gauge wires. Each:
    $ 1.25
    HCP9322 Aftermarket SINGLE FEMALE BULLET STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9366 female wire-end terminal. Each:
    $ 1.95
    3) If you wish for us to perform the modification, we can offer the HCP3413 switch already modified with the proper sheathed, female bullet wire-end terminal installed onto one of the lead wires:
    HCP17365 OEM clutch hand lever SWITCH, complete with lead harness. This small black plastic cylinder plunger switch screws into the brake lever housing and includes the correctly modified wire harness leads and connector. For the following models: XJ750 Seca models.
    $ 59.95
    OIL LEVEL SENDING UNIT:
    aa) OEM and aftermarket OIL LEVEL SENDING UNITS & PARTS. The oil level sending unit is located in the center of the oil pan, secured by two small bolts, and has a lead wire coming out of it. Its purpose is to trigger a dash light if it senses a low oil LEVEL (not oil pressure, but merely the oil level in the pan). It is common for the oil sender to trigger the dash warning light very briefly during a cold start, hard acceleration, or going up a steep hill......especially if the amount of oil in the engine is slightly below full. These sending units contain a float inside a metal can, and over time, the float can become jammed or sluggish in its movement due to oil sludge accumulation.......many "bad" oil level senders can be re-habilitated by a thorough flush with a solvent such as kerosene, etc. If you find oil leaking from around this unit, you will need to replace the o-ring seal (which requires removal of the exhaust system). NOTE: all original and replacement oil level sending units have a small alignment mark case into the base of the housing, and the sending units needs to be installed with that mark aligned with a similar cast mark on the crankcase opening.
    NOTE: when swapping engines (or oil pans/sensors) beware of these differences:
    - the HCP700 (analog gauge) sensor is a N.C. (normally closed) style switch when the oil level is at a correct level, while the HCP701 (computer dash) sensor is a N.O. (normally open) switch when the oil level is at a correct level. Thus these sensors, If swapped between bikes, will not give proper signaling to their warning lights or read-outs!
    HCP699 OEM new OIL LEVEL SENDING UNIT, for all XJ550, 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian engines.
    $ 299.95
    HCP22658 OEM new OIL LEVEL SENDING UNIT, for all 1992-98 XJ600 Seca II engines.
    $ 279.95
    HCP700 OEM new OIL LEVEL SENDING UNIT, for all XJ650 (except Turbo), all XJ700 except XS/XSC models, all 1983 XJ750 Maxim and Midnight Maxim, and all XJ900RK, RL, N/FN, F, and S/SH model engines.
    $ 189.95
    HCP701 OEM new OIL LEVEL SENDING UNIT, for all XJ650 Turbo, all 1982 XJ750 Maxim and all XJ750 Seca engines.
    $ 249.95
    HCP1536 Aftermarket oil sender unit-to-oil sump pan O-RING, fits all XJ550, 1984-85 FJ600, 1984-91 XJ600 Euro, 1986-88 FZ600, 1986-90 YX600 Radian, 1992-98 XJ600 Seca II, 1992-2002 XJ600 Euro, all XJ650, XJ700, XJ750, all XJ900RK, RL, N/FN, F, and S/SH models, and all XJ1100 models.
    $ 6.95
    HCP2533 OEM oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. The original alloy steel hex-head bolt featured a bright zinc plating, but this superseded version has a black oxide coating. If you desire the original appearance, select either the HCP17146 or HCP17148 bolts below. Each:
    $ 3.95
    HCP17146 Aftermarket oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. Zinc-plated alloy steel hex-head bolt. Each:
    $ 1.95
    HCP17148 Aftermarket oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. Bright finish 18-8 stainless steel hex-head bolt. Each:
    $ 2.95
    HCP17147 Aftermarket oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. Black-oxide coated alloy steel hex-head bolt as original. Each:
    $ 1.95
    HCP2424 Aftermarket oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. Black oxide coated alloy steel socket head, allen-key drive bolt. Each:
    $ 1.95
    HCP80 Aftermarket oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. Black oxide coated alloy steel socket head, allen-key drive bolt. Features a small nylon thread patch, making this a self-locking bolt. Each:
    $ 2.95
    HCP2423 Aftermarket oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ550, 1984-85 FJ600, XJ650, XJ750, all XJ900RK and RL models, and XJ1100 models only. Bright 18-8 stainless steel socket head, allen-key drive bolt. Each:
    $ 2.95
    HCP3255 OEM oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all 1992-98 XJ600 Seca II, XJ700, and XJ750-X models only. Each:
    $ 8.95
    HCP13733 OEM oil level sending unit-to-oil pan MOUNTING BOLT, use 2 per sending unit. For all XJ900 N, FN, and F models only. Each:
    $ 7.95
    HCP315 OEM oil level sending unit-to-oil pan mounting bolt LOCK WASHER, use 2 per sending unit. For all XJ550, FJ600, XJ650, XJ750, XJ900RK and RL models, and XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, oil level sending unit-to-oil pan mounting bolt LOCK WASHER, use 2 per sending unit. For all XJ550, XJ650, XJ750, XJ900RK and RL models, and XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel oil level sending unit-to-oil pan mounting bolt LOCK WASHER, use 2 per sending unit. For all XJ550, XJ650, XJ750, XJ900RK and RL models, and XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel oil level sending unit-to-oil pan mounting bolt LOCK WASHER, use 2 per sending unit. For all XJ550, XJ650, XJ750, XJ900RK and RL models, and XJ1100 models. Each:
    $ 1.95
    HCP2173 OEM oil level sending unit-to-oil pan mounting bolt FLAT WASHER, use 2 per sending unit. For all XJ700, XJ750-X, and XJ900RK and RL models only, original bright finish, each:
    $ 2.95
    HCP6642 Aftermarket oil level sending unit-to-oil pan mounting bolt FLAT WASHER, zinc-plated alloy steel with a natural finish, use 2 per sending unit. For all XJ700, XJ750-X, and XJ900RK and RL models only, each:
    $ 1.95
    HCP6643 Aftermarket oil level sending unit-to-oil pan mounting bolt FLAT WASHER, 18-8 stainless steel with a natural finish, use 2 per sending unit. For all XJ700, XJ750-X, and XJ900RK and RL models only, each:
    $ 2.95
    HCP25756 Aftermarket oil level sending unit-to-oil pan mounting bolt FLAT WASHER, 316 stainless steel with a natural finish, use 2 per sending unit. For all XJ700, XJ750-X, and XJ900RK and RL models only, each:
    $ 3.95
    HCP14285 Aftermarket oil level sending unit-to-oil pan mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use 2 per sending unit. For all XJ700, XJ750-X, and XJ900RK and RL models only, each:
    $ 2.95
    HCP14284 Aftermarket oil level sending unit-to-oil pan mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, use 2 per sending unit. For all XJ700, XJ750-X, and XJ900RK and RL models only, each:
    $ 2.95
    HCP9125 OEM oil level sending unit-to-oil pan mounting bolt FLAT WASHER, use 2 per sending unit. For all 1984-85 FJ600 models only. Each:
    $ 7.95
    HCP23513 Aftermarket oil level sending unit-to-oil pan mounting bolt FLAT WASHER, use 2 per sending unit. For all 1984-85 FJ600 models only. Each:
    $ 2.95
    FUEL SENDING UNITS:
    fsu3) OEM fuel tank FUEL SENDING UNIT, brand new sender comes with the wiring harness leads. Mounting gasket and hardware is not included and should be ordered separate.
    The secret life of fuel sending units is explained here:
    HCP680 OEM in-tank FUEL SENDING UNIT, for XJ550 Seca and XJ550 Euro models,.
    $ 389.95
    HCP19948 OEM in-tank FUEL SENDING UNIT, for 1984-85 FJ600 and 1984-89 XJ600 Euro models,.
    $ 369.95
    HCP682 OEM in-tank FUEL SENDING UNIT, for 1982 XJ750 Maxim models,.
    $ 389.95
    HCP683 OEM in-tank FUEL SENDING UNIT, for 1981-83 XJ750 Seca and XJ750 Euro (except 1984 XJ750RL) models,.
    $ 399.95
    HCP685 OEM in-tank FUEL SENDING UNIT, for all XJ700 and XJ750-X models. NOTE: the thermistor "can" that controls the signaling circuit is located about 3/4" higher on this replacement sending unit than on the original unit.....meaning, your fuel gauge will alert you to a low fuel condition sooner than the original unit did.
    $ 89.95
    HCP684 OEM in-tank FUEL SENDING UNIT, for XJ750RL and all XJ900RK, RL, FN, and F models.
    $ 389.95
    f1) Fuel tank SENDING UNIT MOUNTING GASKET. Molded rubber gasket fits between the sending unit mounting plate and the tank, preventing leaks. A great idea to replace this gasket whenever you pull the sending unit out.
    HCP687 OEM fuel tank sending mounting GASKET. Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, all XJ750 Seca models, XJ1100, and all XS1100 models.
    $ 18.95
    HCP688 OEM fuel tank sending unit mounting O-RING. This is the original style molded oval “o-ring”. Fits all XJ700 and XJ750-X models.
    $ 17.95
    HCP28935 Aftermarket fuel tank sending unit mounting O-RING. This reproduction is a standard round o-rings, but will fit as original when installed into the oval-shaped groove. Fits all XJ700 and XJ750-X models.
    $ 9.95
    HCP3081 OEM fuel tank sending unit mounting GASKET. Fits FJ600, XJ750RL, and all XJ900RK, RL, FN, and F models.
    $ 16.95
    f3) Fuel tank Sending Unit mounting BOLT. Flanged shoulder hex-head bolts attach the fuel sending unit to the tank.
    HCP1241 OEM fuel tank sending unit mounting BOLT. Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, all XJ750 Seca, XJ1100, and all XS1100 Standard models. Each:
    $ 7.95
    HCP2745 Aftermarket fuel tank sending unit mounting BOLT, black-oxide coated alloy steel 10mm hex-head bolt has a serrated flange that acts as a lock washer (OEM bolts do not have a serrated flange nor do they use a lock washer). Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, all XJ750 Seca, XJ1100, and XS1100 Standard models. Each:
    $ 2.95
    HCP118 OEM fuel tank sending unit MOUNTING SCREW, grey-phosphate coated alloy steel, panhead, phillips drive. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 7.95
    HCP2922 Aftermarket fuel tank sending unit mounting MOUNTING SCREW, bright zinc-plated steel with phillips-drive, panhead design. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 2.95
    HCP21362 Aftermarket fuel tank sending unit mounting MOUNTING SCREW, bright 18/8 stainless steel with a phillips-drive, panhead design. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 3.95
    HCP6714 Aftermarket fuel tank sending unit mounting MOUNTING SCREW, button head hex-drive, 18-8 stainless steel, bright finish. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 3.95
    HCP6715 Aftermarket fuel tank sending unit mounting MOUNTING SCREW, socket head, hex-drive, black-oxide coated alloy steel. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 2.95
    HCP6716 Aftermarket fuel tank sending unit mounting MOUNTING SCREW, socket head, hex-drive, 18-8 stainless steel, bright finish. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 3.95
    HCP2923 Aftermarket fuel sender-to-tank MOUNTING SCREW, bright 18-8 stainless steel with phillips-drive, panhead design. Fits all XJ700 and XJ750-X models. NOTE: these screws are slightly longer (2mm) than stock but it makes no difference in fit and function. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 3.95
    HCP2924 Aftermarket fuel sender-to-tank MOUNTING SCREW, black-oxide coated 18-8 stainless steel with phillips-drive, pan-headed design. Fits all XJ700 and XJ750-X models. NOTE: these screws are slightly longer (2mm) than stock but it makes no difference in fit and function. Fits all XJ700 and XJ750-X models. Use 2 screw per sender, each:
    $ 3.95
    HCP3082 OEM fuel tank sending unit mounting BOLT. Fits FJ600, XJ750RL, and all XJ900RK, RL, FN, and F models. Use 4 per tank. Each:
    $ 8.95
    HCP15716 Aftermarket fuel tank sending unit mounting BOLT. Fits all FJ600, XJ750RL, and XJ900RK, RL, FN, and F models. Use 4 per tank. Each:
    $ 2.95
    f4) Fuel tank sending unit-to-tank mounting bolt SEALING WASHER. These washers are made from a fuel-resistant hard fiber material and need to be replaced every so often, and certainly every time you remove the fuel sender from the tank.
    HCP2743 OEM fuel sender-to-tank mounting screw SEALING WASHER. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, XJ1100, and XS1100 Standard models. Use 1 gasket per bolt, each:
    $ 7.95
    HCP21352 Aftermarket fuel sender-to-tank mounting screw SEALING WASHER. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, XJ1100, and XS1100 Standard models. Use 1 gasket per bolt, each:
    $ 5.95
    Fuel Sender Block-Off Plates:
    t2) Aftermarket tank fuel sender opening BLOCK-OFF PLATE AND GASKET ---- this die-cut metal plate and matching rubber gasket, exactly the same size as the fuel sender opening, allows you to easily block-off the opening in situations where you are missing the sending unit, etc. Each kit contains the block-off plate, gasket, mounting bolts, and sealing washers.
    HCP2738SET Aftermarket fuel sending unit BLOCK-OFF PLATE AND GASKET. Fits all XJ550 Seca, XJ650 Turbo, XJ750 Seca, 1982 XJ750 Maxim, XJ1100, and XS1100 Standard model tanks.
    $ 27.95
    HCP6371SET Aftermarket fuel sending unit BLOCK-OFF PLATE AND GASKET. Fits all XJ700 and XJ750-X tanks.
    $ 24.95
    HCP6373SET Aftermarket fuel sending unit BLOCK-OFF PLATE AND GASKET. Fits all 1984-85 FJ600, 1984 XJ750RL, and XJ900 tanks.
    $ 24.95
    COOLING SYSTEM MOTORS AND SENDING UNITS:
    HCP4891 OEM radiator fan MOTOR. For all XJ700-X and XJ750-X models.
    $ discontinued
    HCP4892 OEM radiator fan BLADES. For all XJ700-X and XJ750-X models.
    $ discontinued
    HCP3276 OEM temperature gauge SENDING UNIT, also known as the "thermo unit" in Yamaha-speak. This is the single terminal sensor that screws into the thermostat housing and which relays information to the temp gauge. NOTE: this sensor uses teflon tape on its threads for sealing, rather than an o-ring.. For all XJ700-X and XJ750-X models.
    $ 119.95
    HCP3275 OEM fan motor CONTROL SWITCH, also known as the "thermoswitch" in Yamaha-speak. This is the dual terminal switch that screws into the thermostat housing and which relays information to the fan, controlling when it turns on and off. Includes its sealing o-ring. For all XJ700-X and XJ750-X models. NOTE: due to the larger-than-original hex on the body of this switch, it will be necessary to file or grind away (dremel “drum” sander or the like) a tiny portion of material around the “curve” of the housing by the switch port……otherwise the switch body will “bottom” on this “curve” before the switch is fully seated and sealed and a small leak will occur. We also suggest that the threads of this switch be wrapped with Teflon tape before installation.
    $ 99.95
    HCP20496 Aftermarket fan motor CONTROL SWITCH, also known as the "thermoswitch" in Yamaha-speak. This is the dual terminal switch that screws into the thermostat housing and which relays information to the fan, controlling when it turns on and off. This unit has approximately the same fan-turns-on trigger point as the stock control switch. NOTE: due to the larger-than-original hex on the body of this switch, it will be necessary to file or grind away (dremel “drum” sander or the like) a tiny portion of material around the “curve” of the housing by the switch port……otherwise the switch body will “bottom” on this “curve” before the switch is fully seated and sealed and a small leak will occur. For all XJ700-X and XJ750-X models.
    $ 74.95
    HCP20487 Aftermarket fan motor CONTROL SWITCH, also known as the "thermoswitch" in Yamaha-speak. This is the dual terminal switch that screws into the thermostat housing and which relays information to the fan, controlling when it turns on and off. This unit has an approximately 20-degree lower fan-turns-on trigger point than the stock control switch, and will therefore turn on your fan at a lower coolant temperature (and thus, in hotter environments, more frequently). Highly recommended for people who live in hotter climates and/or do a lot of city (stop-and-go) operation in warmer climates. This switch has two short wire leads that plug into the connector shell on your main harness…and note, it does not matter which wire terminal is fitted into which port in the connector shell. NOTE: due to the larger-than-original hex on the body of this switch, it will be necessary to file or grind away (dremel “drum” sander or the like) a tiny portion of material around the “curve” of the housing by the switch port……otherwise the switch body will “bottom” on this “curve” before the switch is fully seated and sealed and a small leak will occur. For all XJ700-X and XJ750-X models.
    $ 79.95
    HCP30272 Aftermarket fan motor CONTROL SWITCH, also known as the "thermoswitch" in Yamaha-speak. This is the dual terminal switch that screws into the thermostat housing and which relays information to the fan, controlling when it turns on and off. This unit has an approximately 25-degree lower fan-turns-on trigger point than the stock control switch, and will therefore turn on your fan at a lower coolant temperature (and thus, in hotter environments, more frequently). Highly recommended for people who live in very hot climates and do a lot of city (stop-and-go) operation. Note that the use of this switch in cooler operating environments will cause your fan to run almost constantly once the engine has reached normal operating temperatures…..which is not necessary and not advisable! This switch has two short wire leads that plug into the connector shell on your main harness…and note, it does not matter which wire terminal is fitted into which port in the connector shell. NOTE: due to the larger-than-original hex on the body of this switch, it will be necessary to file or grind away (dremel “drum” sander or the like) a tiny portion of material around the “curve” of the housing by the switch port……otherwise the switch body will “bottom” on this “curve” before the switch is fully seated and sealed and a small leak will occur. For all XJ700-X and XJ750-X models.
    $ 79.95
    HCP20488 Aftermarket fan motor control switch O-RING, seals the thermo-switch to the thermostat housing. Fits all original or aftermarket thermoswitches. Use 1 per switch on all XJ700-x and XJ750-X models.
    $ 4.95
  22. chacal
    HORNS:
    hn1) OEM and aftermarket HORNS allow you to get the attention of the cute young thing walking down the street (or the fool that's about to pull out in front of you) in a clear, strong voice.
    Original Horns:
    HCP2373 OEM original style HORN, low note, for all XJ550 Seca models. Brand new. This is the "30" horn, and is normally (but not always!) located on the right side of the bike.
    $ 219.95
    HCP2374 OEM original style HORN, high note, for all XJ550 Seca models. Brand new. This is the "20" horn, and is normally (but not always!) located on the left side of the bike.
    $ 219.95
    HCP2371 OEM original style HORN, low note, right side, for all XJ700 non-X (air-cooled) models. See NOTE below in regards to using this horn on XJ750 models.
    $ 209.95
    HCP2372 OEM original style HORN, high note, left side, for all XJ700 non-X (air-cooled) models. See NOTE below in regards to using this horn on XJ750 models.
    $ 209.95
    NOTE: the above horns (HCP2371 and HCP2372) can be used as substitutes for all XJ750 Seca, XJ750 Maxim, and XJ750 Midnight Maxim horns. The outer decorative cover, and the mounting brackets differ between all these horns, but the sounder mechanism is the same.
    Thus you can use these XJ700 non-X horns "as is" on any 1981-83 XJ750 model as long as you swap out the curved mounting brackets from your original horn onto these horns. Or, you can also remove just the decorative outer cover from these new horns, and install your original black decorative covers (and mounting brackets) onto these horns, and thus have "brand new" original-appearing horns for your XJ750 models.
    HCP2375 OEM original style "corkscrew" HORN, low note, for all XJ700-X and XJ750-X models. This is the "30" horn, and is normally (but not always!) located on the right side of the bike.
    $ 209.95
    HCP2376 OEM original style "corkscrew" HORN, high note, for all XJ700-X and XJ750-X models. This is the "20" horn, and is normally (but not always!) located on the left side of the bike.
    $ 209.95
    HCP2367 OEM original style HORN, high note, for all 1981-83 XJ750 Seca (without the touring fairing) and XJ750 Euro models. This is the "20" horn, and is normally (but not always!) located on the right side of the bike.
    $ 199.95
    HCP2385 OEM original style HORN, low note, for all FJ600 and XJ900RK, RL, and FN models. This is the "30" horn, and is normally (but not always!) located on the left side of the bike.
    $ 209.95
    HCP2386 OEM original style HORN, high note, for all XJ900RK, RL, and FN models. This is the "40" horn, and is normally (but not always!) located on the right side of the bike.
    $ 209.95
    HCP2368 OEM original style HORN, low note, for all XJ1100 models. This is the "20" horn, and is normally (but not always!) located on the left side of the bike.
    $ 209.95
    HCP2369 OEM original style HORN, high note, for all XJ1100 models. This is the "30" horn, and is normally (but not always!) located on the right side of the bike.
    $ 209.95
    Horn Support Bracket ID Decals:
    The small decals are attached to the short metal bracket that attaches the horn body to the frame. On bikes with dual horns, there is a separate decal for the low vs. high tone horns.
    HCP8167 Aftermarket left horn mounting bracket ID DECAL, blue foil decal with the bright silver 4G0-30 wording. Used on the 1981-83 XJ550 Seca model low-note horn.
    $ 9.95
    HCP8168 Aftermarket right horn mounting bracket ID DECAL, blue foil decal with the bright silver 4G0-20 wording. Used on the 1981-83 XJ550 Seca model high-note horn.
    $ 9.95
    HCP8167-68 Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1981-83 XJ550 Seca models.
    $ 16.95
    HCP8153 Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 2H9-30 Low Tone wording. Used on the 1982 XJ650RJ Seca model low-note horn.
    $ 9.95
    HCP8154 Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 2H9-20 High Tone wording. Used on the 1982 XJ650RJ Seca model high-note horn.
    $ 9.95
    HCP8153-54 Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1982 XJ650RJ Seca models.
    $ 16.95
    HCP15026L Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 16G-30 Low Tone wording. Used on the 1982 XJ650 Turbo model low-note horn.
    $ 9.95
    HCP15026H Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 16G-20 High Tone wording. Used on the 1982 XJ650 Turbo model high-note horn.
    $ 9.95
    HCP15026H-L Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1982 XJ650 Turbo models.
    $ 14.95
    HCP15733L Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 11T-30 Low Tone wording. Used on the 1983 XJ650 Turbo model low-note horn.
    $ 9.95
    HCP15733H Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 11T-20 High Tone wording. Used on the 1983 XJ650 Turbo model high-note horn.
    $ 9.95
    HCP15733H-L Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1983 XJ650 Turbo models.
    $ 16.95
    HCP8157 Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 1AA-30 Low Tone wording. Used on the 1985-86 XJ700-X and XJ750-X models.
    $ 9.95
    HCP8158 Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 1AA-20 High Tone wording. Used on the 1985-86 XJ700-X and XJ750-X models.
    $ 9.95
    HCP8157-58 Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1985-86 XJ700-X and XJ750-X models.
    $ 16.95
    HCP8165 Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 26H-30 Low Tone wording. Used on the 1985-86 XJ700 air-cooled models.
    $ 9.95
    HCP8166 Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 26H-20 High Tone wording. Used on the 1985-86 XJ700 air-cooled models.
    $ 9.95
    HCP8165-66 Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1985-86 XJ700 air-cooled models.
    $ 16.95
    HCP8159 Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 15R-30 Low Tone wording. Used on the 1982-83 XJ750 Maxim and Midnight Maxim models.
    $ 9.95
    HCP8160 Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 15R-20 High Tone wording. Used on the 1982-83 XJ750 Maxim and Midnight Maxim models.
    $ 9.95
    HCP8159-60 Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1982-83 XJ750 Maxim and Midnight Maxim models.
    $ 16.95
    HCP8161 Aftermarket left horn mounting bracket ID DECAL, black foil decal with the brushed silver 4L0-30 Low Tone wording. Used on FJ600 and 1983-86 XJ900 RK, RL, and FN models.
    $ 9.95
    HCP8162 Aftermarket right horn mounting bracket ID DECAL, black foil decal with the brushed silver 4L0-20 High Tone wording. Used on the 1983-86 XJ900 RK, RL, and FN models.
    $ 9.95
    HCP8161-62 Aftermarket horn mounting bracket ID DECALS, set of both the high-note and low-note decals. Used on the 1983-86 XJ900 RK, RL, and FN models.
    $ 16.95
    Aftermarket Standard Replacement Horns:
    Aftermarket replacement horns are at least the same loudness as original horns.
    HCP1685 Aftermarket standard replacement HORN, made by the original supplier to Yamaha of XJ-era horns. Chrome diaphram with black rim and back, single-tone, with original length bracket (bracket no longer has the locating notch on the end of it). 2.5 amp, 105-decibel sound pressure is the same as original ratings. Same as the original horn used on all XJ550 Maxim and XJ650 Maxim and Midnight Maxim models (except the center diaphram is chrome, rather than black as on the originals).
    $ 49.95
    HCP1686 Aftermarket standard replacement HORN, made by the original supplier to Yamaha of XJ-era horns. Chrome diaphram with chrome rim and black back, single-tone, with original length bracket (bracket no longer has the locating notch on the end of it). 3.0 amp, extra-loud 110-decibel sound pressure is the same as original ratings. Similar to the original horn used on all XJ650 Seca models, except that this horn is single-tone, rather the low-tone and high-tone versions as on the originals. If you replace both horns, there will not be a problem with sound quality. Each:
    $ 54.95
    HCP27122 Aftermarket standard replacement MINI-HORNS SET, this matched pair of lo- and hi-note horns are small and loud!.....at least as loud as stock horns, and maybe a bit more (they seem to have a slightly higher overall pitch than the stock horns set, and thus sound louder). Both horns feature a black diaphram with a black housing, and come with a with 2-3/4” mounting bracket…..which can be used as-is, or the bracket can be removed and you can then use your stock horn bracket “arms” on all original dual-horn bikes. This is also a great replacement set of horns for use on original single-horn model bikes (XJ550 Maxim and XJ650 Maxim models), as they’ll increase the sound level over the original horns, and their small footprint makes locating them easy. Fits all XJ- and XS-series models (and many others). NOTE: when converting a bike from single horns, we strongly suggest the use of the HCP27124 splitter harness and the appropriate mounting hardware kit listed below, which makes the installation a plug-and-play operation!
    $ 49.95
    HCP27124 Aftermarket dual mini-horns ADAPTER HARNESS, for use when converting a single-horn bike (XJ550 Maxim and XJ650 Maxim models) to dual horns. Plugs directly into the factory single-horn harness lead wires and “splits” them to allow hook-up to dual horns.
    $ 17.95
    HCP27144 Aftermarket dual mini-horns MOUNTING HARDWARE, contains the bolts and nuts needed to mount the HCP27122 mini-horns to the XJ550 Maxim models (which used a single horn originally). This kit is intended to allow mounting to the frame lateral cross-brace (just below the steering stem headpipe), as this is the ideal forward-facing location for the mini-horns.
    $ 11.95
    HCP27145 Aftermarket dual mini-horns MOUNTING HARDWARE, contains the bolts and nuts needed to mount the HCP27122 mini-horns to the XJ650 Maxim and Midnight Maxim models (which used a single horn originally). This kit is intended to allow mounting to the frame lateral cross-brace (just below the steering stem headpipe), as this is the ideal forward-facing location for the mini-horns.
    $ 11.95
    HCP27147 Aftermarket dual mini-horns COMPLETE CONVERSION KIT, for all XJ550 Maxim models. Contains all that you’ll need to convert your bike to dual horns: a set of the HCP27122 mini-horns, the HCP27124 adapter harness, and the HCP27144 mounting hardware kit.
    $ 64.95
    HCP27148 Aftermarket dual mini-horns COMPLETE CONVERSION KIT, for all XJ650 Maxim or Midnight Maxim models. Contains all that you’ll need to convert your bike to dual horns: a set of the HCP27122 mini-horns, the HCP27124 adapter harness, and the HCP27145 mounting hardware kit.
    $ 64.95
    Aftermarket Super-duty Replacement Horns:
    Loud pipes may save lives, but so will these super-duty horns, and without making you go deaf or getting tickets!
    HCP13488 Aftermarket freight-train LOW-NOTE HORN, incredibly loud, high-amp, low-note horn will make you the life of any party. These 6-amp, 111-decibel horns have a massive black metal body with a slotted black "microphone" style removable grill and a 67mm long mounting bracket. Will fit all original XJ-models when used with the special mounting brackets listed below.....otherwise, fitment can be tricky and on an "experimental" basis. NOTE: because of the high current draw of these horns, you must use our HCP14747 (single horn) or HCP14748 (dual horns) relay wire harness listed below (or otherwise, your horns won't work and you'll burn up your horn button switch pretty rapidly!).
    $ discontinued
    HCP13691 Aftermarket freight-train HIGH-NOTE HORN, incredibly loud, high-amp, high-note horn will make you the life of any party. These 6-amp, 111-decibel horns have a massive black metal body with a slotted black "microphone" style removable grill and a 67mm long mounting bracket. Will fit all original XJ-models when used with the special mounting brackets listed below.....otherwise, fitment can be tricky and on an "experimental" basis. NOTE: because of the high current draw of these horns, you must use our HCP14747 (single horn) or HCP14748 (dual horns) relay wire harness listed below (or otherwise, your horns won't work and you'll burn up your horn button switch pretty rapidly!).
    $ discontinued
    HCP14916 Aftermarket freight-train DUAL-HORNS SET, matched set of the HCP13488 and HCP13691 horns above. Will fit all original XJ-models when used with the special mounting brackets listed below.....otherwise, fitment can be tricky and on an "experimental" basis. NOTE: because of the high current draw of these horns, you must use our HCP14748 horn relay harness below (or otherwise, your horns won't work and you'll burn up your horn button switch pretty rapidly!).
    $ discontinued
    HCP14916NB Aftermarket freight-train DUAL-HORNS SET, matched set of the HCP13488 and HCP13691 horns above with the riveted mounting brackets removed---ready for use with our special mounting brackets listed below. NOTE: because of the high current draw of these horns, you must use our HCP14748 horn relay harness below (or otherwise, your horns won't work and you'll burn up your horn button switch pretty rapidly!).
    $ discontinued
    HCP13487 Aftermarket riot-control DUAL-HORNS SET, incredibly loud, high-amp, dual-horn sets will make you presence known! These 5.5-amp, 118-decibel horns come in matched high- and low-note set. Large black metal bodies with bright red "spider-web" cage grills come with a standard 63mm long mounting bracket. Will fit all original XJ-models when used with the special mounting brackets listed below.....otherwise, fitment will be very tricky and on an "experimental" basis. NOTE: because of the high current draw of these horns, you must use our HCP14748 horn relay harness below (or otherwise, your horns won't work and you'll burn up your horn button switch pretty rapidly!).
    $ discontinued
    Horn Relay Wire Harnesses:
    In order to take full advantage of either stock or aftermarket horns, full battery voltage must be available at the horn terminals. The long run of under-sized factory wiring, and the stock horn push-button contact, will not allow your horn to receive a full dose of current, and thus your horn---a critical safety component----will be suffocated for amperage and will barely squawk. The solution is a professionally assembled, plug-and-play RELAY-CONTROLLED HORN HARNESS that uses your horn button to actuate an electrical switch (the relay), which then allows full battery power to your horn(s).....allowing them to sing their song at full voice. All of our aftermarket super-duty replacement horns require the use of a relay-controlled horn harness; at best, your aftermarket horns will simply not function at all without one; at worst, they'll burn up your stock wiring and perhaps weld the push-button switch contacts together!
    These horn relay wire harnesses are simple to install-----even for the most electrically-challenged mechanics-----and come with extra terminals, cable ties, illustrated instructions, and do not require cutting your original wiring harness at all. Your stock horn switch push-button now powers the relay, rather than the horns, and thus no new switch is needed. Installation time varies, but normally requires 30 minutes or less to install (mostly involving the removal and replacement of your seat and gas tank, and the routing of the wire harness), and absolutely no soldering is required.
    HCP14747 Aftermarket single-horn RELAY-CONTROLLED HORN HARNESS, for use with a single horn.
    $ 54.95
    HCP14748 Aftermarket dual-horn RELAY-CONTROLLED HORN HARNESS, for use with dual horns.
    $ 64.95
    Horn Body Hardware:
    hh41) Aftermarket horn housing and body hardware needed to properly rebuild your original XJ700 non-X and all XJ750 model horns includes the special diaphram spacer gaskets and the special housing screws.
    HCP6710 Aftermarket horn body-to-decorative cover SCREW, 18/8 black-oxide coated stainless steel, use 3 per horn body. These are the short screws used in the non-bracket positions. Original screws had integral lockwashers; these replacement screws do not and you will need to order the HCP336 lockwashers listed below. For XJ700 non-X and all XJ750 model horns. Each:
    $ 2.95
    HCP10018 Aftermarket horn body-to-decorative cover SCREW, 18/8 black-oxide coated stainless steel, use 2 per horn body. These are the long screws used in the bracket positions. Original screws had integral lockwashers; these replacement screws do not and you will need to order the HCP336 lockwashers listed below. For XJ700 non-X and all XJ750 model horns. Each:
    $ 3.955
    HCP326 OEM horn body-to-decorative cover screw LOCK WASHER, bright zinc-plated alloy steel, use 5 per horn body in all positions. Original screws had integral lockwashers; the replacement screws do not and you will need to order these lockwashers for proper installation. For XJ700 non-X and all XJ750 model horns. Each:
    $ 3.95
    HCP922 Aftermarket horn body-to-decorative cover screw LOCK WASHER, bright zinc-plated alloy steel, use 5 per horn body in all positions. Original screws had integral lockwashers; the replacement screws do not and you will need to order these lockwashers for proper installation. For XJ700 non-X and all XJ750 model horns. Each::
    $ 1.95
    HCP336 Aftermarket horn body-to-decorative cover screw LOCK WASHER, 18/8 bright stainless steel, use 5 per horn body in all positions. Original screws had integral lockwashers; the replacement screws do not and you will need to order these lockwashers for proper installation. For XJ700 non-X and all XJ750 model horns. Each:
    $ 2.95
    HCP342 Aftermarket headlight outer bezel-to-retaining ring screw LOCK WASHER, black oxide-coated alloy steel, use 5 per horn body in all positions. Original screws had integral lockwashers; the replacement screws do not and you will need to order these lockwashers for proper installation. For XJ700 non-X and all XJ750 model horns. Each
    $ 1.95
    HCP10019 Aftermarket horn diaphram GASKET. Use 2 per horn body, on both sides of the diaphram. These gaskets serve both to waterproof the internal mechanism and provide the proper air space gap between the diaphram and the cover. Original gaskets very with round or "wavy round" in shape; these replacement round gaskets correctly replace either style. For XJ700 non-X and all XJ750 model horns. NOTE: due to the difference in thickness between the original and these aftermarket gaskets, it will be necessary to adjust the "torn control screw" on the horn body to achieve the proper original tone. Each:
    $ 4.25
    HCP105 Aftermarket horn tone adjuster SCREW, 18-8 stainless steel phillips head screw is used to adjust the horn tonal frequency. Use an all XJ series original horns. Requires the use of the HCP7794 nut below. Use 1 per horn.
    $ 2.95
    HCP7794 Aftermarket horn tone adjuster screw NUT, 18-8 stainless steel nut is used along with the HCP105 screw above. Use an all XJ series original horns. Use 1 per horn.
    $ 1.95
    Horn Mounting Hardware:
    hn3) Mounting hardware needed to attach an original horn's flat support arm to its horn frame bracket.
    HCP2388 OEM horn support arm MOUNTING BOLT, for all XJ550, 1984-85 FJ600, all XJ700-X and XJ750-X models. Use 1 per horn. Originally, this bolt had a black hex-head bolt with a captured lockwasher; this OEM replacement bolt no longer has this feature and a separate lockwasher (listed further below) should also be ordered.
    $ 6.95
    HCP24810 Aftermarket horn support arm MOUNTING BOLT, for all XJ550, 1984-85 FJ600, all XJ700-X and XJ750-X models, bright zinc-plated hex-head bolt. Use 1 per horn.
    $ 1.95
    HCP16099 Aftermarket horn support arm MOUNTING BOLT, for all XJ550, 1984-85 FJ600, all XJ700-X and XJ750-X models, bright 18-8 stainless steel hex-head bolt. Use 1 per horn. Each:
    $ 2.95
    HCP29253 Aftermarket horn support arm MOUNTING BOLT, for all XJ550, 1984-85 FJ600, all XJ700-X and XJ750-X models, black alloy steel hex-head bolt. Use 1 per horn. Each:
    $ 2.95
    HCP24663 Aftermarket horn support arm MOUNTING BOLT, for all XJ550, 1984-85 FJ600, all XJ700-X and XJ750-X models, black socket-head cap bolt. Use 1 per horn.
    $ 1.95
    HCP4208 OEM horn support arm MOUNTING BOLT, alloy steel with a black finish, hex-head bolt fits all XJ650, XJ750 air-cooled, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn.
    $ 7.95
    HCP18159 Aftermarket horn support arm MOUNTING BOLT, 18-8 stainless steel with a bright finish, hex-head bolt fits all XJ650, XJ750 air-cooled, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn.
    $ 2.95
    HCP16101 Aftermarket horn support arm MOUNTING BOLT, alloy steel with a black finish, hex-head bolt fits all XJ650, XJ750 air-cooled, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn.
    $ 1.95
    HCP4235 OEM horn support arm flanged MOUNTING BOLT, bright finish, for all XJ700 non-X models. Attaches the horn mounting “leaves stack” to the horn frame bracket. This bolt has a flat or slightly “domed” head as original. Use 1 per horn. New. Each:
    $ 7.95
    HCP30034 Aftermarket horn support arm flanged MOUNTING BOLT, bright finish, for all XJ700 non-X models. Attaches the horn mounting “leaves stack” to the horn frame bracket. This bolt has a recessed or “indented” head, unlike the original domed head version, and the flange is slightly wider than original. Use 1 per horn. New. Each:
    $ 4.95
    HCP2391 OEM horn support arm mounting bolt LOCK WASHER, for all XJ550, FJ600, XJ650, XJ700-X, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn.
    $ 7.95
    HCP16209 Aftermarket horn support arm mounting bolt LOCK WASHER, zinc-plated alloy steel, for use on all XJ550, FJ600, XJ650, XJ700-X, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn. Each:
    $ 2.95
    HCP16100 Aftermarket horn support arm mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, for use on for use on all XJ550, FJ600, XJ650, XJ700-X, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn. Each:
    $ 3.95
    HCP16102 Aftermarket brake caliper mounting bolt upper LOCK WASHER, black-oxide coated alloy steel, for use for use on all XJ550, FJ600, XJ650, XJ700-X, XJ750, all XJ900RK, RL, N/FN, and F models, and XJ1100 models. Use 1 per horn. Each:
    $ 3.95
    HCP4239 OEM horn support arm mounting bolt FLAT WASHER, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 7.95
    HCP3945 OEM horn support arm mounting bolt FLAT WASHER, alloy steel, black finish, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 4.95
    HCP26192 Aftermarket horn support arm mounting bolt FLAT WASHER, bright zinc-plated alloy steel, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 1.95
    HCP26193 Aftermarket horn support arm mounting bolt FLAT WASHER, bright 18/8 stainless steel, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 2.95
    HCP17110 Aftermarket horn support arm mounting bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 3.95
    HCP26189 Aftermarket horn support arm mounting bolt FLAT WASHER, black oxide-coated alloy steel, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 3.95
    HCP4240 OEM horn support arm mounting bolt CROWN NUT, alloy steel, dark finish, for all XJ550 Seca models. Use 1 per horn.
    $ 8.95
    HCP4528 OEM horn support arm mounting bolt CROWN NUT, alloy steel, bright finish, for all XJ550 Euro models. Use 1 per horn. Each:
    $ 8.95
    HCP10959 Aftermarket horn support arm mounting bolt CROWN NUT, alloy steel, bright finish, same height as the HCP4240 and HCP4528 crown nuts. Each:
    $ 3.95
    HCP21940 Aftermarket horn support arm mounting bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 5.95
    HCP21941 Aftermarket horn support arm mounting bolt CROWN NUT, chromed steel, bright finish. The rounded dome head is slightly taller (3mm) than the originals. Each:
    $ 8.95
    hn4) Mounting hardware needed to attach an original horn frame bracket to the bike's frame.
    HCP2388 OEM horn bracket-to-frame MOUNTING BOLT, for all XJ550 Maxim models. Use 1 per horn. Originally, this bolt had a black hex-head bolt with a captured lockwasher; this OEM replacement bolt no longer has this feature and a separate lockwasher (listed further below) should also be ordered.
    $ 6.95
    HCP24810 Aftermarket horn bracket-to-frame MOUNTING BOLT, bright zinc-plated hex-head bolt. Unlike the original fastener, this bolt does not have a captive lock-washer, and a separate lock-washer should be used. Use 1 per side on all 1981-83 XJ550 Seca models. Each:
    $ 1.95
    HCP16099 Aftermarket horn bracket-to-frame MOUNTING BOLT, bright 18-8 stainless steel hex-head bolt. Unlike the original fastener, this bolt does not have a captive lock-washer, and a separate lock-washer should be used. Use 1 per side on all 1981-83 XJ550 Seca models. Each:
    $ 2.95
    HCP29253 Aftermarket horn bracket-to-frame MOUNTING BOLT, black alloy steel hex-head bolt. Unlike the original fastener, this bolt does not have a captive lock-washer, and a separate lock-washer should be used. Use 1 per side on all 1981-83 XJ550 Seca models. Each:
    $ 2.95
    HCP24663 Aftermarket horn bracket-to-frame MOUNTING BOLT, black socket-head cap bolt. Unlike the original fastener, this bolt does not have a captive lock-washer, and a separate lock-washer should be used. Use 1 per side on all 1981-83 XJ550 Seca models. Each:
    $ 1.95
    HCP4208 OEM horn bracket-to-frame MOUNTING BOLT, alloy steel with a black finish, hex-head bolt for all XJ650 (except Turbo) models. Use 2 per bike. Each:
    $ 7.95
    HCP18159 Aftermarket horn bracket-to-frame MOUNTING BOLT, 18/8 stainless steel with a bright finish, hex-head bolt fits all XJ650 (except Turbo) models. Use 2 per bike. Each:
    $ 2.95
    HCP16101 Aftermarket horn bracket-to-frame MOUNTING BOLT, alloy steel with a black finish, hex-head bolt fits all XJ650 (except Turbo) models. Use 2 per bike. Each:
    $ 1.95
    HCP3927 OEM horn bracket-to-frame MOUNTING BOLT, alloy steel with a black finish, hex-head bolt, for all XJ700 air-cooled models. Use 2 per bike.
    $ 8.95
    HCP17123 Aftermarket horn bracket-to-frame MOUNTING BOLT, 18-8 stainless steel with a bright finish, hex-head bolt, use 1 per handle (for the rear mounting location), for all XJ550 Seca models:
    $ 2.95
    HCP22191 Aftermarket horn bracket-to-frame MOUNTING BOLT, 316 stainless steel with a bright finish, hex-head bolt, use 1 per handle (for the rear mounting location), for all XJ550 Seca models:
    $ 3.95
    HCP22189 Aftermarket horn bracket-to-frame MOUNTING BOLT, alloy steel with a yellow zinc-plated finish, hex-head bolt, use 1 per handle (for the rear mounting location), for all XJ550 Seca models:
    $ 1.95
    HCP17122 Aftermarket horn bracket-to-frame MOUNTING BOLT, alloy steel with a black finish, hex-head bolt, use 1 per handle (for the rear mounting location), for all XJ550 Seca models:
    $ 1.95
    HCP4258 OEM horn / coil bracket-to-frame FLANGED MOUNTING BOLT, for all XJ700-X and XJ750-X models. Use 2 per bike. Each:
    $ 7.95
    HCP22181 Aftermarket horn and coil bracket-to-frame FLANGED MOUNTING BOLT, for all XJ700-X and XJ750-X models. 6-point hex head alloy steel fastener has a serrated flange (which eliminates the need for using a lockwasher) and features a dark finish. Use 2 per bike. Each:
    $ 2.95
    HCP4211 OEM horn bracket-to-frame MOUNTING BOLT, for all XJ1100 models. Use 2 per bike.
    $ 3.50
    HCP2185 OEM horn bracket-to-frame mounting bolt LOCK WASHER, for all XJ550 Maxim models (use 1 per bike), all XJ650 (except Turbo) models (use 2 per bike), all XJ700 non-X models (use 2 per bike), and all XJ1100 models (use 2 per bike). Each:
    $ 6.95
    HCP16209 Aftermarket horn bracket-to-frame mounting bolt LOCK WASHER, zinc-plated alloy steel, for all XJ550 Maxim models (use 1 per bike), all XJ650 (except Turbo) models (use 2 per bike), all XJ700 non-X models (use 2 per bike), and all XJ1100 models (use 2 per bike). Each:
    $ 2.95
    HCP16100 Aftermarket horn bracket-to-frame mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, for all XJ550 Maxim models (use 1 per bike), all XJ650 (except Turbo) models (use 2 per bike), all XJ700 non-X models (use 2 per bike), and all XJ1100 models (use 2 per bike). Each:
    $ 3.95
    HCP16102 Aftermarket horn bracket-to-frame mounting bolt LOCK WASHER, black-oxide coated alloy steel, for all XJ550 Maxim models (use 1 per bike), all XJ650 (except Turbo) models (use 2 per bike), all XJ700 non-X models (use 2 per bike), and all XJ1100 models (use 2 per bike). Each:
    $ 3.95
    HCP21946 Aftermarket horn bracket-to-frame mounting bolt LOCK WASHER, zinc-plated alloy steel with a bright finish. Use 1 per bolt on all XJ550 Seca models. Each:
    $ 1.25
    HCP21947 Aftermarket horn bracket-to-frame mounting bolt LOCK WASHER, 18/8 stainless steel with a bright finish. Use 1 per bolt on all XJ550 Seca models. Each:
    $ 1.25
    HCP21948 Aftermarket horn bracket-to-frame mounting bolt LOCK WASHER, black oxide-coated alloy steel. Use 1 per bolt on all XJ550 Seca models. Each:
    $ 1.25
    HCP3945 OEM horn bracket-to-frame mounting bolt FLAT WASHER, alloy steel, black finish. For all XJ700 non-X models. Use 2 per bike. Each:
    $ 4.95
    HCP26192 Aftermarket horn bracket-to-frame mounting bolt FLAT WASHER, alloy steel, bright finish. For all XJ700 non-X models. Use 2 per bike. Each:
    $ 1.95
    HCP26193 Aftermarket horn bracket-to-frame mounting bolt FLAT WASHER, 18/8 stainless steel, bright finish. For all XJ700 non-X models. Use 2 per bike. Each:
    $ 2.95
    HCP17110 Aftermarket horn bracket-to-frame mounting bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models. Use 1 per horn. Each:
    $ 3.95
    HCP26189 Aftermarket horn bracket-to-frame mounting bolt FLAT WASHER, alloy steel, black finish. For all XJ700 non-X models. Use 2 per bike. Each:
    $ 3.95
  23. chacal
    HEADLIGHTS:
    Let there be Light!.........
    Enough of it, that is. Motorcycles, suffering from only having a single headlight, tend to have woefully inadequate lighting for night-time driving, especially on unfamiliar roads or during "spirited" riding. We're going to try to help you understand why, and then offer you a variety of solutions. Here goes............
    What most people call a "headlight" is really three separate functional components: the glass LENSE, a highly polished REFLECTOR, and the electrically operated light-producing BULB.
    In some cases, the glass LENSE and the polished REFLECTOR are formed and molded as one unit, and are inseparable from each other. On other models (primarily with the square lights, such as the XJ750 Seca models, etc.), the reflector is actually a metal housing with a non-removable (unless you try really hard!) flat front glass lense.
    Additionally, some bikes (XJ550 models and XJ650 Maxim and Midnight Maxim models) are factory-supplied with a SEALED-BEAM type of headlight, where the bulb is part-and-parcel of the lense and reflector assembly, and not removable nor replaceable. All other XJ models use a MODULAR headlight system, which means that the bulb CAN be removed from the lense/reflector unit....and thus if the bulb burns out (or an upgraded wattage or style of bulb is desired), then only the bulb needs to be replaced; the glass lense and reflector unit lives on, basically forever.
    Although most people feel that the BULB is greatest determinant of a headlight's light output, this isn't really the case. Although sealed-beam headlights and modular bulbs are available in a variety of wattage ratings, the amount of USABLE LIGHT (meaning: "how much?" and, especially, "where?") are controlled as much by the LENSE and REFLECTOR DESIGN as by the bulb's rated wattage.....
    And lets talk about those rated wattages for a moment, because that's an important issue: almost all automotive headlight bulbs (and, really, all others bulbs too) are rated for output at a current draw of 12.8 volts DC (12 VDC).
    But are you actually getting 12.8 VDC at your headlight?. If you want to check for yourself, hook up a voltmeter and read the voltage drops while the engine is running at various speeds. Do you get 12.8 VDC (or above)? Probably not. And that's where the problems begin.........
    http://www.motorcycleproject.com/text/volt_drop_test.html
    and here’s an easy-to-understand guide to how to perform a voltage-drop test:
    http://www.agcoauto.com/content/news/p2_articleid/330
    The best way to upgrade the power of your headlight is to use a relay (and special harness). The light output from incandescent (non-LED) bulbs varies significantly depending on the input voltage...and this is true whether it's a super-duper halogen bulb or otherwise.
    Most standard headlight bulbs are rated at 55/60W (low/high beam) output at 12.8 VDC....which is actually pretty bright. The problem is that all the connectors and contacts between your battery and the headlight bulbs "steals' (drops) voltage...and that's true even when your bike is brand new, never mind the corrosion that has built up in all those connectors over the 40+ years of unprotected exposure to the elements......and voltage drop vs. light output is NOT a straight-line relationship. A 10% voltage drop (from 12.8 to 11.5 VDC) reduces light output by about 30% (so your 55/60W bulb becomes a 38/42W bulb)!
    A headlight relay harness connects your headlight directly to the battery, and the handlebar switch just controls the relay (whether the relay sends battery voltage to the low- or high-beam terminal of the bulb), and relays can be switched with very low voltage inputs....so even if the voltage coming out of the headlight switch is 11.8 (or 9.4, or....you get it), the relay gets switched and provides full battery voltage to the headlight.
    This is why the condition of your wiring system is so critical to proper lighting. But that's only part "A" of the story............
    Here's part B: your glass LENSE. Whatever amount of light your BULB is outputting---dependent upon the bulb's wattage rating and the capability of your electrical system, as outlined above----the "how much?" of the available bulb output and, more importantly, the "where?" of that light output is controlled by the lense.
    You see all those raised ribs (called "fluting") on the glass lense? The light comes from the bulb, then it bounces off the reflector, and is then finally concentrated or diffused ("spread out") according to what and how that lens fluting has been designed. The fluting can be designed to give a broad, spread out pattern of light, and perhaps with a narrow, focused "pencil beam" of the available light output all going straight ahead----or anywhere in-between. Reflector and fluting design elements are what really make the difference between "standard", run-of-the-mill headlights and high-performance headlight manufacturers (such as Cibie, Hella, Marchal, etc.)....after all, a 55/60W bulb is basically going to output the same amount of light whether it's installed in a No-Name brand headlight lense/reflector, or whether it's installed in a Hella Euro Vision Plus headlight. It's what the headlight lense/reflector DESIGN does with that available light that determines whether, or how far away, you see that deer that is about to jump out into the road in front of you......or not.
    There, you're almost an optical expert. You can now hopefully make a better, informed decision as to what you want and need, and how much that is worth to you.
    Let's now review the standard headlights that came on these bikes:
    All XJ550 and XJ650 Maxim and Midnight Maxim models used a 7" round SEALED-BEAM headlight with an integrated bulb-reflector-lense assembly and a non-replaceable bulb. These stock bulbs are rated at 40W low beam and 50W high beam current draw. This is basically 1940's technology and about the worst headlight performance you could ever imagine, just one step above using a candle in place of the electrical bulb. The good news here is that you can upgrade these headlights to a slightly higher wattage modern sealed-beam bulb (35W low-beam, 60W high-beam) or just completely ditch the sealed beam and go with a modular headlight system.
    All XJ650RJ Seca, XJ650 Euro models, and XJ900N models used a big, beautiful 8" round modular headlight. I really love the way this slightly over-sized headlight makes these bikes look so much more "old-school aggressive". The good news is that it takes a regular, easily-located replacement bulb; the bad news is, if the lense/reflector assembly is cracked or damaged in any way, you're going to look long and really hard to find a replacement, since no one seems to be making 8" round headlight units anymore. Stock bulb rating is 55W low beam, 60W high beam.
    The XJ650 Turbo, the 1982 XJ750 Maxim, all XJ750 Seca models, and the XJ900RK, RL, FN, and F models all used a rectangular, modular headlight system, with an easy-to-find and replace bulb. Again, the stock bulb rating is 55W low beam, 60W high beam.
    The 1983 XJ750 Maxim and Midnight Maxim models, as well as the XJ1100 models, used a 7" round modular headlight system. Bulbs and lense units alike are easy to locate. Like all the other modular headlights, the stock bulb rating is 55W low beam, 60W high beam.
    Next, all the XJ700 and XJ750-X models used a smaller 5-3/4" round modular headlight system. The bulb is rated at the tried-and-true 55W low beam, 60W high beam.
    Finally, the XJ750 Seca and 1982 XJ750 Maxim models used a smaller, rectangular "driving light" below the main headlight, and this too is a modular designed light, with a replaceable bulb, although the bulb used in these lights are only a 35W output from the factory, and are a different style bulb than the headlight uses. Bulbs are readily available for these driving lights.
    So there you have it.
    Now, a couple of question always arise, the first always being:
    Q1) Should I upgrade to a much higher wattage BULB?
    A1) In a nutshell, NO. The problem is not the bulb's light output, it's the compromised electrical system on these bikes that restricts the voltage available to the bulb that is mainly responsible for the poor lighting, along with the somewhat poor design of standard factory or low-cost aftermarket headlight lense/reflector units.
    Q2) How to I remedy the "compromised electrical system" on my bike?
    A2) First, make sure that ALL---meaning every last one---of the electrical connections in your headlight system are clean and un-corroded.
    This means starting from the fusebox forward---and while you're at, replace your stock fusebox, as it's usually a huge source of electrical resistance in your system (more resistance = less voltage across the connection).
    This also means the contacts inside your left side handlebar switch should be squeaky clean (electrically-speaking), gunk-and-corrosion free. You'll have to take apart your switch and clean all the contacts internally, which isn't a bad idea to do anyway.
    And of course, make sure that your battery and your alternator (those brushes) are in great shape, and actually capable of outputting the proper voltage into your electrical system to begin with.
    Q3) Why don't I just install a higher wattage bulb, even with a compromised, ritually-unclean electrical system?
    A3) Because it doesn't work that way. I would suggest reading Section 8 on this excellent article about XJ electrical systems (heck, you should actually memorize the whole article) and you'll begin to see how "going bigger" is not only NOT better, but could be a whole lot worse, economically and otherwise:
    http://web.archive.org/web/200712140435 ... aqbig.html
    Q4) Should I use the "whiter" or "daylight" or "blue" or "purple" or "whatever" modular bulbs that are advertised as producing "better light" or "whiter light" or "more light" or "bigger light" or blah-blah-blah?
    A4) You can, but it's mostly hooey that you're buying. Again, the problem isn't the light output of the BULB, it's the electrical system and the design of the reflector and lense that are the real issues. A great in-depth, easy-to-understand review of these issues can be found at:
    http://www.danielsternlighting.com
    Go and read the "TECH" section of the website "bulb articles". You might be in for a surprise.........but at least you'll know the truth, and that's supposed to set you free.
    Q5) So what do I do?
    A5) First: make sure your electrical system is in tip-top shape: alternator, battery wiring, connectors, switches should all be operating properly and all of your the connectors are going to have to be cleaned. This is cheap but time-consuming to do.....but, it produces the best results. Like love, there's some things that money just can't buy.........
    Even better, update your headlight system to modern standards by using our easy-to-install HEADLIGHT RELAY HARNESS that allows you to pump pure, fresh, full battery voltage directly to your headlight.....the way nature intended it to be! :D
    Second: If you've got a sealed-beam system, upgrade to a modular headlight system....it's a bolt-in replacement.
    Third: For those models with round headlights, upgrade them to a higher-performance modular system, such as the Hella Vision Plus systems below. The better optical design on these lense/reflector units put more light, and better light, WHERE YOU NEED IT, rather than scattering the light somewhat uselessly like most standard headlights do.
    For those people with the rectangular headlights, well.......make sure your electrical system is up to snuff (because there are no upgraded-design modular lense/reflector units available for your bike!).
    Main Headlights:
    NOTE: all headlights.....OEM or aftermarket....can achieve increased headlight bulb output (brightness) through the use of our HCP14749 headlight-relay harness.
    HCP4574 OEM round 7" SEALED-BEAM HEADLIGHT, 50/60W bulb rating, original application for all XJ550 models and all XJ650 Maxim and Midnight Maxim models. Can be used on all 1983 XJ750 Maxim and Midnight Maxim models, and XJ1100 models, but those models originally had a modular headlight, and you will be "down-grading" those models. This is the lowest-performance solution available to you, but it's cheap! Light output can be increased through the installation of our HCP14749 headlight relay harness.
    $ discontinued
    HCP242 Aftermarket round 7" SEALED-BEAM HEADLIGHT, 50/60W bulb rating, original application for all XJ550 models and all XJ650 Maxim and Midnight Maxim models. Can be used on all 1983 XJ750 Maxim and Midnight Maxim models, and XJ1100 models, but those models originally had a modular headlight, and you will be "down-grading" those models. This is the lowest-performance solution available to you, but it's cheap! Light output can be increased through the installation of our HCP14749 headlight relay harness.
    $ 49.95
    HCP9314 Aftermarket halogen round 7" SEALED-BEAM HEADLIGHT, 35/60W bulb rating, original application for all XJ550 models and all XJ650 Maxim and Midnight Maxim models. Can be used on all 1983 XJ750 Maxim and Midnight Maxim models, and XJ1100 models, but those models originally had a modular headlight, and you will be "down-grading" those models. Halogen bulbs produce brighter light, and have a longer average life, than standard tungsten (original style) sealed beam units.
    $ discontinued
    HCP3594 OEM round 8" MODULAR HEADLIGHT LENSE & REFLECTOR ONLY, bulb not included. Fits all 1982 XJ650RJ Seca and RJC Seca models, XJ650 Euro, 1981-82 XV920 RH/RJ Virago, XJ900N (naked---no fairing) models, 1981-86 XV1000 Euro, and 1981-86 TR1 Euro models. Bulb and bulb socket rubber cover are not included. NOTE: this headlight is the North American rather than the Euro-spec version and may not pass safety or other inspection checks outside of North America.
    $ 479.95
    HCP4578 OEM round 8" MODULAR HEADLIGHT ASSEMBLY, for all XJ650RJ Seca, XJ650 Euro, and XV920RJ models. This is a complete assembly which includes the large 8” headlight lense, the bulb retainer, the bulb socket rubber cover, the lense retaining ring, the chrome bezel, and associated hardware fasteners. Neither the black-painted headlight housing (the “bucket”) nor the headlight bulb are included. NOTE: this headlight is the North American rather than the Euro-spec version and may not pass safety or other inspection checks outside of North America.
    $ 899.95
    HCP3602 OEM round 5-3/4" MODULAR LENSE & REFLECTOR ONLY, bulb not included. For all XJ700 and XJ750-X models.
    $ 229.95
    HCP4498 OEM round 5-3/4" MODULAR HEADLIGHT ASSEMBLY. This complete unit includes the lense/reflector housing, the chrome outer bezel, lense retaining ring, adjuster hardware, bulb locking collar, and rubber bulb socket cover. The plastic headlight housing and the bulb are not included. For all XJ700 and XJ750-X models.
    $ discontinued
    HCP3600 OEM main headlight 7" x 5" MODULAR HEADLIGHT LENSE & REFLECTOR ONLY. Chrome outer bezel, lense rim, adjuster hardware, bulb, bulb locking collar, and rubber bulb socket cover are not included….this is the glass lense and metal reflector housing only. For all XJ750 Seca models, with or without factory fairings, all XJ750 Euro models and XJ650 or XJ750 Police bikes, and all models using the stock Yamaha "X-1" front fairing.
    $ 349.95
    HCP4556 OEM main headlight 7" x 5" MODULAR HEADLIGHT ASSEMBLY. This complete unit includes the lense/reflector housing, the chrome outer bezel, lense rim, adjuster hardware, bulb locking collar, and rubber bulb socket cover. The plastic headlight housing and the bulb are not included. For all XJ750 Seca models, with or without factory fairings, all XJ750 Euro models and XJ650 or XJ750 Police bikes, and all models using the stock Yamaha "X-1" front fairing.
    $ 429.95
    HCP3592 OEM round 7" MODULAR HEADLIGHT LENSE & REFLECTOR ONLY, bulb not included. Fits all 1983 XJ750 Maxim and Midnight Maxim models, all XJ1100 models, 1979-81 XS1100 Specials, 1979 XS750, 1980-81 XS850 all models, 1986 SRX600, and 2015-18 SR400 models. NOTE: will also fit Midnight or Midnight Special models, but will have the silver chrome (rather than the golden chrome) headlight bezel. NOTE: can also be fitted onto all XJ550 and XJ650 Maxim and Midnight Maxim models as well, to replace the original sealed beam type headlight lense/reflector unit The use of a modular lense and reflector unit allows you to use the high-wattage H2 or H4 bulbs.
    $ 79.95
    HCP4584 OEM round 7" MODULAR HEADLIGHT ASSEMBLY, for all 1983-84 XJ750 Maxim, 1982-84 XJ1100 Maxim, 1979 XS750 all models, 1980-81 XS850 Standard & Special (except Midnight Special), 1979-81 XS1100 Special (except Midnight Special), 1986 SRX600, and 2015 -18 SR400 models. NOTE: will also fit Midnight or Midnight Special models, but will have the silver chrome (rather than the golden chrome) headlight bezel. NOTE: can also be fitted onto all XJ550 and XJ650 Maxim and Midnight Maxim models as well, to replace the original sealed beam type headlight lense/reflector unit The use of a modular lense and reflector unit allows you to use the high-wattage H2 or H4 bulbs. This is a complete assembly which includes the modular headlight lense/reflector, the chrome bezel, the thin lense retaining ring, the backing plate, the bulb locking ring, the bulb socket rubber cover, the adjusting screw, spring, and nut, and the bezel and retaining ring screws. Neither the chrome-plated headlight housing (the “bucket”) nor the headlight bulb are included.
    $ discontinued
    HCP3598 OEM rectangular 7" MODULAR HEADLIGHT LENSE & REFLECTOR ONLY, bulb not included. Fits all 1982-83 XJ650 Turbo, 1982 XJ750 Maxim, 1984-85 FJ600, 1984 XJ750RL Seca, 1983-84 XJ900 RK/RL, 1985-87 XJ900 F, N, and FN models, and 1982-83 XZ550R Vision models. NOTE: this headlight is the North American rather than the Euro-spec version and may not pass safety or other inspection checks outside of North America.
    $ discontinued
    HCP4555 OEM rectangular 7" x 5" MODULAR HEADLIGHT ASSEMBLY. This complete unit includes the lense/reflector housing, the chrome outer bezel, lense retaining ring, adjuster hardware, bulb locking collar, and rubber bulb socket cover. The plastic headlight housing and the bulb are not included. For all XJ650 Turbo models.
    $ discontinued
    HCP4557 OEM main headlight 7" x 5" MODULAR HEADLIGHT ASSEMBLYY. This complete unit includes the lense/reflector housing, the chrome outer bezel, lense rim, adjuster hardware, bulb locking collar, and rubber bulb socket cover. The plastic headlight housing and the bulb are not included. For all 1982 XJ750 Maxim models.
    $ 399.95
    HCP4571 OEM rectangular 7" x 5" MODULAR HEADLIGHT ASSEMBLY. This complete unit includes the lense/reflector housing, the chrome outer bezel, lense rim, adjuster hardware, bulb locking collar, and rubber bulb socket cover. The plastic headlight housing and the bulb are not included. For all 1984-85 FJ600 , 1984 XJ750RL Seca, 1983 XJ900RK/RL Seca, and 1985-87 XJ900 F, N, and FN models. NOTE: this headlight is the North American rather than the Euro-spec version and may not pass safety or other inspection checks outside of North America.
    $ 399.95
    Aftermarket Modular Headlight Systems:
    Now you can upgrade your headlight to the latest standards and technological advances in reflector and lense designs by upgrading to the Hella Vision fluted-glass LENSE-REFRACTED series of modular headlight system, allowing you to take advantage of the most modern high-performance lighting technologies available, and putting a bright beam of light where you want and need it to be, while punching a bright white hole into the darkness of night.
    All of these high-performance modular headlights are complete with the bulb socket rubber cover and a high-quality, high-performance H2/H4 style replaceable 55/60W Halogen or Xenon gas bulb.....making them ready to drop right into your stock headlight housing. A true plug-and-play installation, using your stock wiring harness plug and all headlight mounting hardware and components. Remember.......it's not just the increased wattage of these bulbs over stock that matters, but rather it's the design of the lense and reflectors that makes these units a far superior replacement to your stock headlamp.
    NOTE 1: all replacement modular headlights are slightly deeper, front-to-back, than stock lense/reflector units, and may produce a very cramped "wiring rats-nest" in the back of your headlight housing!
    NOTE 2: do not use a higher wattage bulb than the specified 55/60W rating in these headlights. And do not waste your money (nor void the factory warranty on these headlights) by using any type of tinted (blue, purple, any kind) bulb in these lights, even if the bulb is advertised as being "super white" or any other such marketing nonsense.....
    NOTE 3: on all stock or aftermarket "modular" headlights, you need to observe the following precaution, and always make sure you properly install (or re-install) the protective rubber "socket cover" over the large plug-in terminal connector shell:
    - modular headlight lamps, under certain conditions, can and will fog up internally. Although we cannot list all of the conditions that can lead to such a situation, here are a few of the common causes that you can prevent (and, what to do if such a situation occurs):
    a) If you wash your bike while the headlight is still hot.
    b) if there is a lot of humidity in the air and if you wash your bike with hot water.
    Because modular headlights these are not sealed units, they can suck moisture from the environment inside the lamp. Most of the moisture will stay on the lens unless you turn the lamps back on; then the moisture will migrate to the reflector, and that is not a good thing.
    You want to clean the headlight out while the fog is still on the lens. This is best accomplished by using a 50/50 mixture of denatured alcohol (only) and distilled water.
    Remove the bulb and fill the lamp with the above mixture, then swirl it around several times to clean the lens, and then blow it dry. Make sure to remove all the mixture or it will move to your reflector and make a rainbow spot when you turn your light on.
    Replacement bulbs are the same as the bulbs listed above for stock modular headlight systems. And your existing headlight harness plug (connector) will fit onto these bulbs properly.
    The 5-3/4" round high-performance headlights will fit the following models:
    - as a standard drop-in replacement for all original modular headlights on all XJ700 models.
    HCP8615 Aftermarket HELLA brand Euro Vision+ DOT-approved round 5-3/4" MODULAR HEADLIGHT SYSTEM, includes the lense/reflector unit, a 55/60W Halogen bulb, and the bulb socket cover. So let there be even better light! The Hella Euro-design lense---which is street-legal for motorcycles in the USA---puts more light where you need it (in front of you and off to the right side) while minimizing the "wasted' overhead light dispersion that DOT rules require for automotive headlights. More light, less glare to oncoming traffic, everyone wins. Not legal for use on automobiles. NOTE: aftermarket modular headlights are slightly deeper, front-to-back, than stock lense/reflector units, and may produce a very cramped "wiring rats-nest" in the back of the housing!
    $ discontinued
    These 7" round high-performance headlight systems will fit all of the following models:
    - as an upgrade over the original sealed-beam units in all XJ550 models and all XJ650 Maxim and Midnight Maxim models.
    - as a standard drop-in replacement for all original modular headlights on all 1983 XJ750 Maxim and Midnight Maxim models, as well as all XJ1100 models.
    Hella traditional-style "fluted-lense" headlights:
    Hella has long been one of the technological leaders in high-performance lighting systems, and their latest Euro Vision+ Series of headlights makes no exception to that tradition. Bringing the traditional fluted-lense style of headlight to the cutting edge of perfection, these lights provide a sharp, accurate beam pattern that strongly illuminates both the road in front of you and the right side of your path, putting the light where you want it and not wasting any precious photons in an "upward" direction, nor uselessly blinding oncoming drivers with a light beam pattern that strays over to the left. This type of beam pattern is the "European" style beam pattern, legal in Euroland but long shunned in the North American markets (for reasons we can barely fathom.........).
    However, Euro beam-pattern headlights are street legal (DOT approved) for "single-track" vehicles in the USA and Canada.....and of course, your motorcycle nicely fits into that definition, so you can luckily and legally use these incredible high-performance lights on your bike without any inspection worries.
    HCP8567 Aftermarket HELLA brand EURO Vision+ DOT-approved round 7" MODULAR HEADLIGHT SYSTEM, includes the lense/reflector unit, a 55/60W Halogen bulb, and the bulb socket cover. So let there be even better light! The Hella Euro-design lense puts more light where you need it (in front of you and off to the right side) while minimizing the "wasted' overhead light dispersion that DOT rules require for automotive headlights. More light, less glare to oncoming traffic, everyone wins. Not street-legal for use on automobiles, trucks, vans, etc.
    $ 79.95
    Modular Headlight Bulbs:
    These modular headlight bulbs will fit both the OEM and aftermarket modular headlight systems for these bikes.
    HCP3595 OEM modular headlight system HALOGEN BULB, rated at 55/60W output, for all models that use a modular (replaceable bulb) headlight system. This is a standard-duty bulb, unlike the original heavy-duty “anti-vibratory” bulb that models were originally equipped with.
    $ 79.95
    HCP8569 Aftermarket modular headlight system HALOGEN BULB, rated at 55/60W output, for all models that use a modular (replaceable bulb) headlight system. This is a standard-duty bulb, unlike the original heavy-duty “anti-vibratory” bulb that models were originally equipped with.
    $ 29.95
    HCP8570 Aftermarket modular headlight system HALOGEN BULB, rated at 80/100W output, for all models that use a modular (replaceable bulb) headlight system. This is a standard-duty bulb, unlike the original heavy-duty “anti-vibratory” bulb that models were originally equipped with. I cannot tell you how much we urge you to NOT upgrade to this rating bulb....but for the "bigger is always better crowd" well, here it is. Don't be surprised if you melt your wiring, or catch your headlight housing on fire, or fry your computer-controlled dash if your electrical system isn't up to snuff, though. Or even if it is..........
    $ 29.95
    HCP28252 Aftermarket modular headlight system HALOGEN BULB, rated at 55/60W output, for all models that use a modular (replaceable bulb) headlight system. This is an original style heavy-duty “anti-vibratory” bulb, with thicker filaments and additional filament supports, similar to what was used by Yamaha originally on all of their modular headlight systems.
    $ 59.95
    Headlight Parking Light Bulbs:
    Many non-North American XJ-series bikes are equipped with a small "park light" illumination bulb within the main headlight housing. These tiny wedge-based bulbs are the correct style and intensity for all XJ-series bikes that use these headlight "parking light" bulb system.
    HCP3609 OEM headlight "parking-light" BULB, for all XJ bikes that use this system. Use 1 bulb per housing. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. Each:
    $ 4.95
    HCP3609LL OEM headlight "parking-light" BULB, for all XJ bikes that use this system. Use 1 bulb per housing. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. Each:
    $ 3.95
    HCP3609DL40 OEM headlight "parking-light" BULB, for all XJ bikes that use this system. Use 1 bulb per housing. These SUPER-DUTY ULTRA-BRIGHT bulbs last for a mean average of 1000 running hours and are approximately 40% brighter than the standard or long-life bulbs. Each:
    $ 4.95
    Headlight Bulb Parts:
    Unless otherwise noted, the following minor parts are for the original Yamaha headlights and may not work with any aftermarket brand replacement headlights.
    HCP3597 OEM modular headlight BULB RETAINING SPRING PLATE.....the spring-clip that holds the modular bulb firmly in place in the back of the headlight lense-reflector unit. Fits all models that use a factory modular headlight: FJ600, XJ650RJ Seca, XJ650 Turbo, all XJ700 models, all XJ750 models (main headlight), all XJ900RK, RL, FN, and F models, all XJ1100 models, and all models using the factory Yamaha "X-1" fairing.
    $ 24.95
    HCP4562 OEM modular headlight BULB RETAINING SPRING PLATE.....the spring-clip that holds the modular bulb firmly in place in the back of the auxiliary headlight lense-reflector unit. Fits all models that use the factory modular auxiliary (driving) light: 1982 XJ750 Maxim and all XJ750 Seca models.
    $ 29.95
    HCP3604 OEM headlight bulb triangular TERMINAL or SOCKET COVER. This is the large molded rubber "boot" that covers the electrical terminal and plug-in connector from the wire harness, where it plugs into the bulb at the rear of the headlight. A necessary piece to protect the electrical terminals from moisture. For all XJ550 models, and all XJ650 Maxim and Midnight Maxim models using a stock type sealed-beam headlight.
    $ 29.95
    HCP3599 OEM headlight bulb round TERMINAL or SOCKET COVER. This is the large molded rubber "boot" that covers the electrical terminal and plug-in connector from the wire harness, where it plugs into the bulb at the rear of the headlight. A necessary piece to protect the electrical terminals from moisture. For all FJ600, XJ650RJ Seca, XJ650 Turbo, all XJ700 models, all XJ750 models, all XJ900RK, RL, FN, and F models, all XJ1100 models, and all models using the factory Yamaha "X-1" fairing.
    $ 31.95
    HCP21828 OEM headlight bulb round TERMINAL or SOCKET COVER. This is the large molded rubber "boot" that covers the electrical terminal and plug-in connector from the wire harness, where it plugs into the bulb at the rear of the headlight. A necessary piece to protect the electrical terminals from moisture. For all XS1100 Standard models.
    $ 34.95
    Headlight Warning ID Decal:
    HCP8091 Aftermarket headlight bucket BULB WARNING DECAL, black rectangle decal with white wording. This foil decal is used on all XJ650RJ Seca models on the top rear side of the headlight housing (bucket).
    $ 12.95
    HCP15024 Aftermarket headlight bulb COVER SETTING DECAL, small white decal with maroon wording and diagram. This paper decal is used on all FJ600, XJ650RJ Seca, XJ650 Turbo, XJ700, XJ750, and XJ900 models on the back of the glass headlight reflector unit (near where the bulb is inserted into the headlight lense).
    $ 7.95
    HCP10779 Aftermarket headlight bucket HEADLIGHT RIM DECAL, small rectangular decal with black wording. This bright yellow decal is used on all XJ650 Turbo models and is mounted on the bottom edge of the black metal headlight retaining rim (or “bezel”, just under the left side headlight adjuster (phillips-drive) screw.
    $ 9.95
    Headlight Latching Relays:
    hlr1) OEM headlight system HEADLIGHT RELAY. This relay prevents the headlight from coming on while the starter motor is being engaged, thus allowing maximum battery voltage to be used by the starter and the ignition system. However, it is dependent on voltage draw in order to energize and "latch" into the on position, and thus if the engine gets spinning fast enough during the starting process (whether the engine fires or not), enough voltage will be produced by the alternator (which increases its output with RPM's) to clamp this relay, and thus pass current to the headlamp. Also, once latched on, the headlight circuit remains on until the ignition switch is turned fully off.....thus, if you (for example) stall the bike, and hit the starter button, this relay will remain latched and the headlight WILL remain lit during the starting process. Only by turning the key to the off position can you de-energize this relay (and thus turn the headlight off).
    Identification: The Headlight Relay is a small square metal "cube" relay, and has a small yellow paint "dot" or yellow locking tab, and has the following 4 wires connected to it:
    - XJ550 all models and XJ650 all models except Turbo: a solid black wire, a solid white wire, a blue wire with a black tracer stripe, and a red wire with a yellow tracer stripe.
    - XJ750 Seca models: a solid black wire, a white wire with a blue tracer stripe, a blue wire with a black tracer stripe, and a red wire with a yellow tracer stripe.
    NOTE: original relays were always a square metal cube style, although they may have been replaced by an plastic-cased cube relay.
    Due to many variations in design and the need for visual reference, you should check your service manual for the proper testing procedures. There are at least three checks that are necessary to perform: a relay coil resistance check, and a relay coil function (powered vs. unpowered) check, and a diode function test. Here's what it looks like inside:
    For an on-bike test, you can:
    - disconnect the White with blue tracer stripe wire at the headlight relay.
    - turn on the ignition - the headlight should be off.
    - momentarily jumper 12V to the pin on the relay where the white/blue wire was connected, and the headlight should come on and stay on.
    HCP429 OEM main HEADLIGHT RELAY. For all XJ550, XJ650 (except Turbo), 1981-83 XJ750 Seca and XJ750 Euro models, and all 1980-81 XS1100 models. Also fits the following models: 1980-82 XS400 H/SH/G/SG/SJ models, all 1981-83 XV750 Virago, all 1980-81 XS850, and 1981-82 XV920 RH/RJ models. This small metal "cube" type relay has 3H5 inked on the top face and has a yellow-painted locking tab for identification.
    $ discontinued, but please inquire about the availability of used original relays.
    HCP16240 Aftermarket main HEADLIGHT RELAY. For all XJ550, XJ650 (except Turbo), 1981-83 XJ750 Seca and XJ750 Euro models, and all 1980-81 XS1100 models. Also fits the following models: 1980-82 XS400 H/SH/G/SG/SJ models, all 1981-83 XV750 Virago, all 1980-81 XS850, and 1981-82 XV920 RH/RJ models. This small plastic "cube" type relay fits properly and functions like the original, but it will not "latch" like the original....meaning, if the engine dies, the headlight goes off. If that feature is not important to you (and many people do not even realize that the original relay has such a feature!), then this lower-cost substitute is for you.
    $ 29.95
    HCP11105 Aftermarket rubber RELAY HOLDER for original metal-lid "cube" type safety system, headlight, sidestand, fuel pump, etc. relays. This grommet has a square opening (it's a copy of the original grommet), and molded of a thick-wall rubber compound. NOTE: does not fit the later style plastic-lid cube relays. Each:
    $ 12.95
    HCP15149 Aftermarket rubber RELAY HOLDER for original metal rectangular "cube" type safety system, headlight, sidestand, fuel pump, etc. relays. NOTE: the original relay holders have a square opening (which matches the shape of the original square "cube" relays); these replacements have a round opening, however, they will flex and fit the original metal "rectangular" lid relays properly, but will not fit the later-style plastic-lid "cube" relays. Will also fit any round "can" style relay up to 32mm OD. Each:
    $ 11.95
    HCP3589 OEM headlight RESERVE LIGHTING MODULE, fits all XJ1100 models as well as 1983-85 XVZ1200 and 1986-93 XVZ1200 models. This unit is part of the headlight “safety” system, and if one headlight filament (either the high- or the low-beam filament) burns out, it will automatically re-direct power to the other remaining (working) filament without operator intervention.
    $ 139.95
    HEADLIGHT RELAY-CONTROLLED WIRING HARNESS:
    Headlight Relay Wire Harnesses:
    In order to take full advantage of either stock or aftermarket headlights, full battery voltage must be available at the headlight terminals. The long run of under-sized factory wiring, and the stock headlight toggle switch, will not allow your headlight to receive a full dose of current, and thus your headlight---the most critical safety component on your bike----will be suffocated for voltage and will be far less brighter than it could be. The solution is a professionally assembled, plug-and-play RELAY-CONTROLLED HEADLIGHT HARNESS that uses your headlight switch to actuate an electrical switch (the relay), which then allows full battery power to your headlight.....allowing it to shine like the sun!
    REMEMBER, as per the discussion previously, that headlights are rated at 12.8 volts, but typically receive a lot less......and that's the main reason why your headlight is so dim.
    These headlight relay wire harnesses are simple to install-----even for the most electrically-challenged mechanics-----and come with extra terminals, cable ties, illustrated instructions, and do not require cutting your original wiring harness at all. Your stock headlight switch now powers the relays, rather than the headlight, and thus no new switch is needed. Installation time varies, but normally requires 30 minutes or less to install (mostly involving the removal and replacement of your seat and gas tank, and the routing of the wire harness), and absolutely no soldering is required.
    NOTE: when installing a headlight relay harness on any model which utilizes a "computer display" gauge package (XJ750 Seca, XJ750 Euro, 1982 XJ750 Maxim, and XJ650 Turbo models) which have a headlight "testing" circuit built into it will experience a HEAD warning on the LCD display screen, and the flashing red WARNING light will blink every time the bike is started! There is no way to overcome this issue when using a headlight relay harness on these models. Depressing the right-side rectangular WARNING CONTROL button TWICE on the gauge cluster will eliminate the red flashing warning light for the headlight issue, but this must be done every time the bike is started. The HEAD display on the LCD screen will remain illuminated, and cannot be eliminated.
    HCP14749 Aftermarket headlight RELAY-CONTROLLED HEADLIGHT HARNESS, with plastic headlight socket.
    $ 119.95
    HCP14750 Aftermarket headlight RELAY-CONTROLLED HEADLIGHT HARNESS, with hi-temp, hi-performance ceramic headlight socket.
    $ 129.95
    HEADLIGHT OUTPUT MODULATOR UNIT:
    Safety first!
    Too many people, who are too busy twiddling their radio dials or shuffling their iPod controls or twittering or texting silly, trivial messages and thus have no time, to, like, actually pay attention to the world outside of them while hurtling down the road, are a horrible accident just waiting to happen.....to you. And in a collision between car and bike, bike and rider are typically the big loser.
    So be seen by being obnoxious! This solid-state HEADLIGHT OUTPUT MODULATOR will "pulse" the headlight high-beam circuit 4 times per second (240 cycles per minute), gently modulating the circuit voltage from 20% to 100%, thus creating that pulsing "emergency-vehicle" appearance from your headlight that is seen on many late-model bikes. You've noticed those, haven't you? Well, so does everyone else.............and that's the whole point.
    These durable electronic control units are easy to install (15 minutes or less, once you pull your stock headlight out of its bucket), and are truly a plug-and-play operation: disconnect your original headlight socket plug, plug in the modulator unit, attach the headlight plug onto the modulator, route the wires, and ......go riding!.
    All modulators come complete with "daylight sensor" device, and are thus DOT-approved, which makes them completely street-legal in all 50 states. The sensor device, which is at the end of a thin wire, can be easily mounted in a number of different locations.....on your handlebars, besides your gauge cluster, or with a little bit of extra effort, inside the headlight bucket, making it almost "invisible" and completely self-contained. A small rubber mounting grommet is included with the modulator should you decide to mount the sensor in this manner, as well as black nylon cable ties for handlebar mounting. Illustrated usage and mounting instructions are also included.
    The HCP13317 remote-mounted headlight modulator has a fixed level of sensitivity of this daylight sensor device, while the "in-bucket", direct-mount HCP16722 and HCP16723 headlight modulators have a user-adjustable level of sensitivity, which can be a very useful feature.
    All of these units will fit and work on all XJ-series bikes.
    NOTE: all models which utilize a "computer display" gauge package have a headlight "testing" circuit built into it that draws its power supply for the blue "HI BEAM" warning light through the high-beam circuit. The installation of these modulators will thus not only cause the headlight to "pulse", but will also cause the blue hi-beam indicator light to pulse, too!
    However, since the modulators are only designed for day-time use, and since the blue HI-BEAM warning light is barely visible during such daytime operation, this should be a non-issue for most riders. The pulsation of this HI -BEAM warning light will stop when the headlight no longer pulses (during night-time operation, or whenever the headlight switch is selected to the low-beam position).
    HCP13317 Aftermarket day-time REMOTE-MOUNT HEADLIGHT OUTPUT MODULATOR, fits all XJ-series bikes. Comes with installation instructions and sensor mounting accessories. Can also be used on any bike with a single H4 (3-pin) headlight plug, 12v DC current headlight system, up to 115-watts of current. Because of the larger size of this modulator control unit, it typically requires remote mounting, outside of the headlight bucket, in most applications. A special mounting bracket is included for ease of installation. The sensitivity level of the daylight sensor unit of this modulator is NOT adjustable.
    $ 99.95
    HCP16722 Aftermarket day-time DIRECT BULB-MOUNT HEADLIGHT OUTPUT MODULATOR, fits all XJ-series bikes. Comes with installation instructions and sensor mounting accessories. Can also be used on any bike with a single H4 (3-pin) headlight plug, 12v DC current headlight system, up to 115-watts of current. Will fit neatly and directly inside a stock headlight bucket. The sensitivity level of the daylight sensor unit of this modulator IS user-adjustable.
    $ 119.95
    HCP16723 Aftermarket day-time DIRECT BULB-MOUNT HEADLIGHT OUTPUT MODULATOR, fits all XJ-series bikes. Comes with installation instructions and sensor mounting accessories. Can also be used on any bike with a single H4 (3-pin) headlight plug, 12v DC current headlight system, up to 115-watts of current. Will fit neatly and directly inside a stock headlight bucket. The sensitivity level of the daylight sensor unit of this modulator IS user-adjustable. This version is the same as the HCP16722 modulator above, but has a 6" long headlight plug extension harness, which provides additional clearance and fitment options if your stock headlight bucket is too small to allow the direct-plug HCP16722 version above.
    $ 119.95
    AUXILIARY HEADLIGHT AND MOUNTING HARDWARE:
    HCP3601W OEM auxiliary driving light 5" x 3" MODULAR LENSE & REFLECTOR, consists of the clear lense and the reflector body only. The chrome lense bezel, the anti-rattle springs, metal housing, hardware, bulb, and bulb locking ring are not included. For 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models.
    $ 99.95
    HCP3601A OEM auxiliary driving light 5" x 3" MODULAR LENSE & REFLECTOR, consists of the amber (yellow) lense and the reflector body only. The chrome lense bezel, the anti-rattle springs, metal housing, hardware, bulb, and bulb locking ring are not included. For 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Note that the yellow/amber lense was standard on early 1981 XJ750 Seca models imported into North America, and then was quickly deemed non-compliant with DOT regs and a clear lense unit was provided to previous buyers, and all subsequent models came with the clear lense. The amber lense is legal for most of the non-North American models. Fits 1982 XJ750 Maxim and all XJ750 Seca models.
    $ 99.95
    HCP4567 OEM auxiliary headlight lense chrome outer BEZEL, this is the decorative outer ring that finishes the front of the small auxiliary headlight lense. Fits all 1981-83 XJ750 Seca and 1982 XJ750 Maxim models.
    $ 79.95
    HCP4563 OEM auxiliary headlight outer chrome bezel RETAINIG SPRING. holds the chrome bezel to the aux .light body. Use 1 on each side, 2 per unit. Fits all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 19.95
    HCP4560 OEM front auxiliary driving light black metal LIGHT HOUSING, for all 1982 XJ750 Maxim and 1981-83 XJ750 Seca models. This is for the smaller "auxiliary" headlight. Includes the swivel mounting bracket. Auxiliary light lense and bulb is NOT included.
    $ 129.95
    HCP16982 OEM front auxiliary driving light black metal light housing mounting stud u-bracket MOUNTING BOLT, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ discontinued
    HCP13157 Aftermarket front auxiliary driving light black plastic light housing mounting stud u-bracket MOUNTING BOLT, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Bright plated hex-head 18/8 stainless steel. Each:
    $ 2.95
    HCP13158 Aftermarket front auxiliary driving light black plastic light housing mounting stud u-bracket MOUNTING BOLT, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Black-oxide coated hex-headed alloy steel. Each:
    $ 2.95
    HCP315 OEM front auxiliary driving light black plastic light housing mounting stud u-bracket bolt LOCK WASHER, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 3.95
    HCP916 Aftermarket front auxiliary driving light black plastic light housing mounting stud u-bracket bolt LOCK WASHER, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP319 Aftermarket front auxiliary driving light black plastic light housing mounting stud u-bracket bolt LOCK WASHER, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Bright 18-8 stainless steel. Each:
    $ 2.95
    HCP321 Aftermarket front auxiliary driving light black plastic light housing mounting stud u-bracket bolt LOCK WASHER, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Black oxide-coated alloy steel. Each:
    $ 1.95
    HCP2185 OEM front auxiliary driving light black plastic light housing threaded mounting stud (to headlight bracket) LOCK WASHER, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 6.95
    HCP16209 Aftermarket front auxiliary driving light black plastic light housing threaded mounting stud (to headlight bracket) LOCK WASHER, zinc-plated alloy steel, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 2.95
    HCP16100 Aftermarket front auxiliary driving light black plastic light housing threaded mounting stud (to headlight bracket) LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 3.95
    HCP16102 Aftermarket front auxiliary driving light black plastic light housing threaded mounting stud (to headlight bracket) LOCK WASHER, black-oxide coated alloy steel, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 3.95
    HCP3494 OEM front auxiliary driving light black plastic light housing mounting stud (to headlight bracket) NUT, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 3.95
    HCP24037 Aftermarket front auxiliary driving light black plastic light housing mounting stud (to headlight bracket) NUT, made from 18/8 stainless steel, use 1 per bike. For the following models: 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Each:
    $ 2.95
    HCP4561 OEM headlight bezel ring mounting SCREW, used to secure the chrome front rim to the housing, use 1 per rim on the lower auxiliary light on all 1982 XJ750 Maxim models, and all 1981-83 XJ750 Seca models. Each:
    $ 7.95
    HCP911 Aftermarket headlight bezel ring mounting SCREW, used to secure the chrome front rim to the housing, use 1 per rim on the lower auxiliary light on all 1982 XJ750 Maxim models, and all 1981-83 XJ750 Seca models. Zinc-plated alloy steel. Each:
    $ 1.95
    HCP307 Aftermarket headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 on all of the following bikes: all XJ650 Turbo models, 1982 XJ750 Maxim, and all 1981-83 XJ750 Seca models. 18-8 stainless steel. Each:
    $ 2.95
    Auxiliary Driving Light Bulbs:
    HCP8571 Aftermarket modular "auxiliary" light HALOGEN BULB, stock replacement standard white-light bulb is rated at 35W output, used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Please see the NOTE below regarding the use of this bulb.
    $ 8.95
    HCP13482 Aftermarket modular "auxiliary" light HALOGEN BULB, higher-output than stock, this standard halogen-filled, white-light bulb is rated at 55W, used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Unlike with the main headlight bulb, upgrading the low-wattage 35W oem bulb to the 55W rating of this bulb will not jeopardize your electrical system, switches, etc. This bulb has the correct original type "bullet" connector on the wire end, making it "plug-and-play" with your original lead-in wire.
    $ 11.95
    HCP8572 Aftermarket modular "auxiliary" light HALOGEN BULB, higher-output than stock, this standard halogen-filled, white-light bulb is rated at 55W output, used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Unlike with the main headlight bulb, upgrading the low-wattage 35W oem bulb to the 55W rating of this bulb will not jeopardize your electrical system, switches, etc. Please see the NOTE below regarding the use of this bulb.
    $ 9.95
    HCP13483 Aftermarket modular "auxiliary" light LONG-LIFE HALOGEN BULB, higher-output than stock, this standard halogen-filled, white-light bulb is rated at 55W output, used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Unlike with the main headlight bulb, upgrading the low-wattage 35W oem bulb to the 55W rating of this bulb will not jeopardize your electrical system, switches, etc. Please see the NOTE below regarding the use of this bulb.
    $ 14.95
    HCP13485 Aftermarket modular "auxiliary" light HALOGEN BULB, higher-output than stock, this halogen-filled, amber "fog" light bulb is rated at 55W output and has a yellow-amber tint to it, allowing you to become more visible to on-coming traffic, especially during night operation. Used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Unlike with the main headlight bulb, upgrading the low-wattage 35W oem bulb to the 55W rating of this bulb will not jeopardize your electrical system, switches, etc. Please see the NOTE below regarding the use of this bulb.
    $ 14.95
    HCP13486 Aftermarket modular "auxiliary" light HALOGEN BULB, higher-output than stock, this halogen-filled, "extreme-white" light bulb is rated at 55W output and uses a blue-tinted bulb to produce an extreme white light, allowing you to become more visible to on-coming traffic, especially during night operation. Used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models. Unlike with the main headlight bulb, upgrading the low-wattage 35W oem bulb to the 55W rating of this bulb will not jeopardize your electrical system, switches, etc. Please see the NOTE below regarding the use of this bulb.
    $ 27.95
    NOTE: the original Yamaha bulb that is used with the driving or "auxiliary" headlight on the 1982 XJ750 Maxim and all 1981-83 XJ750 Seca models has a short wire that is terminated with a male "bullet" style connector terminal, and this male bullet terminal plugs into a matching female bullet terminal that is on the end of the black-with-red-tracer-stripe power feed wire coming off the intermediate lead harness (this connection occurs inside the auxiliary light housing; you never see it until you remove the light from the housing in order to access and remove or replace the bulb).
    However, almost all replacement style bulbs are terminated with a male "flat blade (or spade)" terminal.....which obviously will not plug into that female "bullet" terminal. This leaves you with a couple of options:
    A) you can cut off and replace the flat blade terminal on the end of the replacement bulb's lead wire with an HCP9364BR1418 male bullet terminal and matching HCP9323 protective sheath. Now, the bulb's wiring will plug directly into the stock wiring's female bullet terminal.
    While this option allows you to keep the stock arrangement intact, it also requires you to perform this same procedure each time you need to replace the auxiliary light bulb, since the next replacement bulb that you buy will also be terminated with a male flat blade terminal.......
    If you wish for us to perform this surgery for you, please include the following part number with your order:
    ABTREPLACE Auxiliary driving light bulb TERMINAL REPLACEMENT.
    $ 2.50
    Note that you still must order and pay for the HCP9364BR1418 male bullet terminal and matching HCP9323 protective sheath. The $ 2.50 fee listed above is for the installation of these components onto the bulb you purchase.
    B) so the other option is to leave the male flat blade terminal on the replacement bulb's wire, and cut off the female "bullet" terminal from the connecting black-with-red-tracer-stripe power feed wire, and replace it with a female flat blade terminal HCP9361BRD and matching protective sheath HCP9325, so that any future bulb replacement procedures will be "plug-and-play".
    If you choose option "A" from above, you will need to purchase one each of the following items, and of course, as with all wire end terminals, recommend that they be properly crimped and soldered to their stripped wire end:
    HCP9364BR1418 Aftermarket MALE BULLET STYLE WIRE-END TERMINAL, correct size and style solid brass terminal features retention bulge for insertion and positive locking into the female mate. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP9323 Aftermarket MALE BULLET STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9364 male wire-end terminal. Each:
    $ 1.25
    If you choose option "B" from above, you will need to purchase one each of the following items, and of course, as with all wire end terminals, recommend that they be properly crimped and soldered to their stripped wire end:
    HCP9361BR1418 Aftermarket "medium-width" straight FEMALE MEDIUM BRASS FLAT BLADE WIRE-END TERMINAL, correct style solid brass terminal features a retention tab for insertion and positive locking into their connector shell. Accepts 14-18 gauge wires. Each:
    $ 1.95
    HCP9325 Aftermarket "medium-width" straight FEMALE FLAT-BLADE STYLE WIRE-END TERMINAL PROTECTIVE SHEATH, correct size and length transparent sheath fits the HCP9361xx series of female wire-end terminals. Each:
    $ 1.25
    HCP14660 Aftermarket auxiliary (driving) light housing wire harness SEAL. This black rubber sealing grommet fits into the outer housing and seals the wiring harness where it passes thru the housing. Unlike the original seal, this is a flat grommet and does not have the external "funnel cone" extension; however, once installed properly (instructions included) it will provide a nice tight, weatherproof seal, preventing corrosion inside the housing.
    $ 1.95
    HCP406 Aftermarket modular "auxiliary" light WIRE HARNESS, used in the smaller auxiliary driving light on all 1982 XJ750 Maxim and all 1981-83 XJ750 Seca and XJ750 Euro models. Includes the rubber boot seal.
    $ 39.95
  24. chacal
    MAIN HEADLIGHT MOUNTING COMPONENTS:
    Although it varies slightly by model, most bikes use a headlight HOUSING (usually called the "bucket") that the headlight LENSE sits within. On round headlight models, the back of the headlight is supported by a headlight MOUNTING PLATE or RING. The headlight lense has a thin metal RETAINING RING that holds the headlight lense to the mounting ring, and then a bright chrome BEZEL RING is the decorative front outer piece.
    Rectangular headlight systems are similar, but they dispense with the rear headlight mounting ring.
    The entire headlight assembly (housing/bucket, lense, and all the internal mounting pieces and hardware) is held to the bike's front steering brackets via the headlight STAY BRACKET or "mounting ears" as they are sometimes referred to.
    Beginning from the inside and working our way outside, we have:
    Headlight Mounting Plate and Hardware:
    HCP4588 OEM headlight MOUNTING PLATE or RING, for all XJ550 models, all XJ650 Maxim and Midnight Maxims, 1983 XJ750 Maxim and Midnight Maxims, and XJ1100 models.
    $ 29.95
    Headlight Thin Retaining Ring and Hardware:
    The thin headlight mounting ring uses tiny screws and fasteners to retain it to the headlight mounting plate (round headlight models) or the modular headlight unit (rectangular headlight models). These fasteners almost always needs replacing when they are removed.
    HCP4587 OEM headlight lense outer RETAINING RING, this thin metal band snugs around the very outer lip of the glass lense, for all XJ550 models, all XJ650 Maxim and Midnight Maxims, 1983 XJ750 Maxim and Midnight Maxim models.
    $ 59.95
    HCP4580 OEM headlight lense outer RETAINING RING, this thin metal band snugs around the very outer lip of the glass lense, all XJ650RJ Seca, XJ650 Euro, and XJ900N models.
    $ 149.95
    HCP4500 OEM headlight lense outer RETAINING RING, this thin metal band snugs around the very outer lip of the glass lense, all XJ700 and XJ750-X models.
    $ 52.95
    HCP322 OEM headlight thin mounting rim SCREW, use 3 per headlight (one each at the 2-, 5-, and 11-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 6.95
    HCP918 Aftermarket headlight thin mounting rim SCREW, zinc-plated alloy-steel, panhead, phillips-drive, each:
    $ 1.95
    HCP1355 Aftermarket headlight thin mounting rim SCREW, 18-8 stainless-steel, panhead, phillips-drive, each:
    $ 2.95
    HCP25913 Aftermarket headlight thin mounting rim SCREW, bright zinc-plated alloy steel, panhead, phillips drive, JIS small-head design as original, each:
    $ 3.95
    HCP326 OEM headlight outer bezel-to-retaining ring screw LOCK WASHER, use 3 per headlight (one each at the 2-, 5-, and 11-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 6.95
    HCP922 Aftermarket zinc-plated alloy-steel, natural finish headlight outer bezel-to-retaining ring screw LOCK WASHER, use 3 per headlight (one each at the 2-, 5-, and 11-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 2.95
    HCP336 Aftermarket 18-8 stainless-steel polished finish headlight outer bezel-to-retaining ring screw LOCK WASHER, use 3 per headlight (one each at the 2-, 5-, and 11-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 3.95
    HCP342 Aftermarket black oxide-coated steel finish headlight outer bezel-to-retaining ring screw LOCK WASHER, use 3 per headlight (one each at the 2-, 5-, and 11-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 2.95
    HCP4564 OEM headlight RIM RETAINING SPRING.....this spring-clip holds the rectangular headlight firmly in place onto the headlight housing. Use 1 per light, front upper position, fits all FJ600, XJ650 Turbo, XJ750 Seca models (main headlight), 1982 XJ750 Maxim (main headlight), and all XJ900RK, RL, FN, and F models.
    $ 11.95
    HCP4505 OEM headlight RIM RETAINING SPRING.....this spring-clip holds the round headlight firmly in place onto the headlight ring. Use 1 per light, fits all XJ700 models.
    $ 8.95
    Main Headlight Outer Chrome Bezel and Hardware:
    The thick, chrome headlight housing front bezel uses screws and fasteners to retain it to the headlight housing (bucket) on round headlight models, and also has the "pivot" provisions for securing the headlight mounting plate. These fasteners almost always needs replacing when they are removed.
    HCP4582 OEM headlight lense silver chrome outer BEZEL RING, this is the decorative metal ring that finishes the front of the headlight housing. Fits all XJ550 models, all XJ650 Maxim and Midnight Maxim, 1983-84 XJ750 Maxim and Midnight Maxim, 1982-84 XJ1100 Maxim and Midnight Maxim, and all XS1100 Special models. NOTE: original bezel rings for the Midnight models was a golden chrome, rather than the standard bright silver chrome as provided with this part. It will also fit all of the following models: 2015-16 SR400, 1978-81 SR500, 1973-74 TX500, 1986 SRX600, 1973-74 TX750, 1975-78 XS500, 1978 XS650 SE/SE-11, 1979 XS650 2F/SF, 1980-83 XS650 G/SG/H/SH/SJ/SK, 1977 XS750 D/2D, 1978 XS750 E/E_227/SE/SE-31, 1979 XS750 F/SF, and 1980-81 XS850 all models. Each:
    $ 149.95
    HCP11516 Aftermarket headlight lense silver chrome outer BEZEL RING, this is the decorative metal ring that finishes the front of the headlight housing. Fits all XJ550 models, all XJ650 Maxim and Midnight Maxim, 1983-84 XJ750 Maxim and Midnight Maxim, 1982-84 XJ1100 Maxim and Midnight Maxim, and all XS1100 Special models. NOTE: original bezel rings for the Midnight models was a golden chrome, rather than the standard bright silver chrome as provided with this part. It will also fit all of the following models: 2015-16 SR400, 1978-81 SR500, 1973-74 TX500, 1986 SRX600, 1973-74 TX750, 1975-78 XS500, 1978 XS650 SE/SE-11, 1979 XS650 2F/SF, 1980-83 XS650 G/SG/H/SH/SJ/SK, 1977 XS750 D/2D, 1978 XS750 E/E_227/SE/SE-31, 1979 XS750 F/SF, and 1980-81 XS850 all models. Each:
    $ 119.95
    HCP21393 Aftermarket headlight lense golden chrome outer BEZEL RING, this is the decorative metal ring that finishes the front of the headlight housing. Correct appearance for 1981 XJ650 Midnight Maxim, 1983-84 XJ750 Midnight Maxim, 1982-84 XJ1100 Midnight Maxim, and 1980-81 XS1100 Midnight Special models. NOTE: this bezel ring will also fit all XJ550, XJ650 Maxim, and 1983-84 XJ750 Maxim, and 1982-83 XJ1100 Maxim models in place of the bright chrome bezel as originally used on those models. It will also fit all of the following models: 2015-16 SR400, 1978-81 SR500, 1973-74 TX500, 1986 SRX600, 1973-74 TX750, 1975-78 XS500, 1978 XS650 SE/SE-11, 1979 XS650 2F/SF, 1980-83 XS650 G/SG/H/SH/SJ/SK, 1977 XS750 D/2D, 1978 XS750 E/E_227/SE/SE-31, 1979 XS750 F/SF, and 1980-81 XS850 all models. Each:
    $ 299.95
    HCP4581 OEM headlight lense chrome outer BEZEL RING, this is the decorative metal ring that finishes the front of the headlight housing. Fits all XJ650RJ Seca, XJ650 Euro, XJ900N, and 1981-86 Euro XV1100 / TR1 models.
    $ 299.95
    HCP4499 OEM headlight lense chrome outer BEZEL RING, this is the decorative metal ring that finishes the front of the headlight housing. Fits all XJ700 and XJ750-X models.
    $ 129.95
    HCP4568 OEM main headlight lense chrome outer BEZEL, this is the decorative metal ring that finishes the front of the large main headlight lense. Fits all XJ750 Seca and XJ750 Euro models.
    $ 179.95
    HCP4572 OEM headlight lense chrome outer BEZEL, this is the decorative metal ring that finishes the front of the headlight lense. Fits all 1984-85 FJ600 and XJ900RK, RL, FN, and F models.
    $ 129.95
    As mentioned earlier, the bright chrome outer bezel on the headlight assembly is attached both to the rear retaining ring (on round headlight models) and to the headlight housing (or "bucket") itself (on all models). A variety of hardware pieces are needed to secure this bezel, and they are listed below.
    HCP60 OEM headlight outer bezel-to-retaining ring SCREW, zinc-plated alloy-steel, panhead, phillips-drive, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 3.95
    HCP910 Aftermarket headlight outer bezel-to-retaining ring SCREW, zinc-plated alloy-steel, panhead, phillips-drive, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 1.95
    HCP62 Aftermarket headlight outer bezel-to-retaining ring SCREW, 18-8 stainless-steel, panhead, phillips-drive, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 2.95
    HCP308 Aftermarket headlight outer bezel-to-retaining ring SCREW, 18-8 stainless-steel, polished button head, hex-drive, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 2.95
    HCP310 Aftermarket headlight outer bezel-to-retaining ring SCREW, 18-8 stainless steel, smooth polished socket head, hex-drive, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 2.95
    HCP64 Aftermarket headlight outer bezel-to-retaining ring SCREW, black oxide-coated steel, ribbed socket head, hex-drive, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 1.95
    HCP55 OEM headlight outer bezel-to-retaining ring screw LOCK WASHER, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 1.95
    HCP913 Aftermarket zinc-plated alloy steel with a natural finish, headlight outer bezel-to-retaining ring screw LOCK WASHER, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 1.75
    HCP57 Aftermarket 18-8 stainless steel, headlight outer bezel-to-retaining ring screw LOCK WASHER, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 2.95
    HCP59 Aftermarket black oxide-coated alloy steel, headlight outer bezel-to-retaining ring screw LOCK WASHER, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, XJ900N model, and all XJ1100 models. Each:
    $ 1.95
    HCP3632 OEM headlight outer bezel-to-retaining ring screw NUT, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 8.95
    HCP24055 Aftermarket headlight outer bezel-to-retaining ring screw NUT, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Bright zinc-plated steel. Each:
    $ 1.95
    HCP24056 Aftermarket headlight outer bezel-to-retaining ring screw NUT, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Bright 18/8 stainless steel. Each:
    $ 2.95
    HCP24057 Aftermarket headlight outer bezel-to-retaining ring screw NUT, use 2 (one each at the 6- and 12-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Bright 316 stainless steel. Each:
    $ 3.95
    HCP4648 OEM headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 (one each at the 4- and 8-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 3.95
    HCP22229 Aftermarket headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 (one each at the 4- and 8-o'clock positions) on all of the following bikes: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 2.95
    HCP304 OEM headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 (one each at the 4- and 8-o'clock positions) on all of the following bikes: all 1985 XJ700 models. Each:
    $ 7.95
    HCP4619 OEM headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 (one each at the 4- and 8-o'clock positions) on all of the following bikes: all 1986 XJ700 models. Each:
    $ 4.95
    HCP4561 OEM headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 on all of the following bikes: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 7.95
    HCP911 Aftermarket headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, zinc-plated alloy steel, use 2 on all of the following bikes: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 1.95
    HCP307 Aftermarket headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, 18-8 stainless steel, use 2 on all of the following bikes: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 2.95
    HCP4640 OEM headlight outer bezel-to-headlight housing ("bucket") retaining SCREW, use 2 on all of the following bikes: all XJ900RK, RL, FN, and F models. Each:
    $ 5.95
    HCP4620 OEM headlight outer bezel-to-headlight housing ("bucket") retaining screw COLLAR, use 2 on all of the following bikes: all XJ650 Turbo models, and all XJ750 Seca models. Each:
    $ 2.95
    Main Headlight Housing ("Bucket") and Mounting Hardware:
    The main headlight housing (or "bucket") retains the headlight and all the related internal components.
    If you headlight shakes, rattles, and rolls and appears to oncoming drivers like some kind of disco strobe-light, well, it just may be that all of your headlight mounting hardware----the BOLTS, SCREWS RUBBER DAMPERS, PLASTIC COLLARS, and related WASHERS and NUTS----is all worn out (or missing altogether!). No worries, we've got what it takes to restore and replace these items correctly.
    The headlight housing or "bucket" attaches to the headlight "ears" (called a "stay bracket" by Yamaha) via an assortment of fasteners and rubber insulators. Working our way from the outside in, we have a BOLT, then (on some models) a WASHER, a thin or thick rubber DAMPER, an internal plastic COLLAR (and maybe another DAMPER, on some models), and then a variety of WASHERS and a retaining NUT to hold the contraption together. The hardware generally becomes a rusty, frozen mess after a few years, while years of vibration takes its toll on those rubber dampers.
    The bottom of most housings have a welded tab bracket that is attached to the lower steering underbracket to prevent vertical housing rotation.
    HCP6210 OEM front headlight black HEADLIGHT BUCKET, for all XJ650RJ Seca, XJ650 Euro, and XJ900N models. This is a bare bucket, and does not included the headlight or any internal parts or hardware.. This bucket has some scratches from handling and shelf storage, but it is brand new.
    $ 199.95
    HCP6210RF OEM refinished HEADLIGHT BUCKET for all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Beautiful and durable powder-coated, medium-gloss black finish as original. This is the large, bad-boy bucket that accepts the original 8” diameter headlight used only on these models. Includes the headlight warning decal. NOTE: a $ 75.00 core charge applies to this item, and a re-usable, same-model headlight bucket must be returned for the core charge to be refunded. “Re-usable" means it is not bent, dinged, damaged, twisted, modified, or dented, and has no rust holes or deep metal pitting.
    $ 249.95 + $ 75.00 refundable core charge
    HCP6207 OEM front headlight chrome HEADLIGHT BUCKET, for all 1980-84 XJ650 Maxim, 1983 XJ750 Maxim, 1980-81 XS1100 Special, and 1980-81 XS850 Special models. This is a bare bucket, and does not included the headlight or any internal parts or hardware.
    $ 169.95
    HCP4573 OEM front headlight chrome HEADLIGHT BUCKET, for all 1980-84 XJ650 Maxim, 1983 XJ750 Maxim, 1980-81 XS1100 Special, and 1980-81 XS850 Special models. This is the bucket with the rubber mounting grommets and plastic grommet collars. Does not included the headlight or any internal parts or hardware.
    $ 199.95
    HCP6209 OEM front headlight black HEADLIGHT BUCKET, for all 1981 XJ650 Midnight Maxim and 1983-84 XJ750 Midnight Maxim models. This is a bare bucket, and does not included the headlight or any internal parts or hardware.
    $ 199.95
    HCP4503 OEM front headlight chromed plastic HEADLIGHT BUCKET, for all 1985-86 XJ700 and XJ750-X models, includes the internal damper bushing and lower pivot bushings and collars. Headlight lense and bulb is NOT included.
    $ 149.95
    HCP6216 OEM front headlight chrome HEADLIGHT BUCKET, for all XJ1100 Maxim models. This is the chrome bucket only. Does not included the headlight or any internal parts or hardware.
    $ 199.95
    HCP4558 OEM front headlight black plastic HEADLIGHT HOUSING, for all XJ750 Seca models, with the damper bushings and plastic collars. This is for the main headlight, and includes both the main housing and the ribbed lower section directly below the light housing. Headlight lense and bulb is NOT included.
    $ 379.95
    HCP6215 OEM front headlight black plastic HEADLIGHT HOUSING, for all 1982 XJ750 Maxim models, bar housing only. This is for the main headlight. Headlight lense bulb, damper bushings and collars are NOT included.
    $ 339.95
    HCP4559 OEM front headlight black plastic HEADLIGHT HOUSING, for all 1982 XJ750 Maxim models, with the damper bushings and plastic collars. This is for the main headlight. Headlight lense and bulb is NOT included.
    $ 389.95
    HCP9149 Aftermarket headlight housing wire access openings protective RUBBER GROMMET. Never used by the factory, but maybe it should have been! Thin, black rubber grommet neatly snaps onto the housing and completely surrounds the wire access openings, preventing wire insulation chafing and shorts. Gives a nice finished look to the housing. Fits the smaller openings where the instrument cluster wires enter the headlight housing. Fits all XJ550 models, all XJ650 (except Turbo) models, all 1983 XJ750 Maxim and Midnight Maxim models, and XJ900 N models.
    $ 2.95
    HCP9150 Aftermarket headlight housing wire access openings protective RUBBER GROMMET. Never used by the factory, but maybe it should have been! Thin, black rubber grommets neatly snaps onto the housing and completely surrounds the wire access openings, preventing wire insulation chafing and shorts. Gives a nice finished look to the housing. Fits the single larger opening where the main harness lead wires enter the headlight housing. Fits all XJ550 models, all XJ650 (except Turbo) models, all 1983 XJ750 Maxim and Midnight Maxim models, and XJ900 N models. Each:
    $ 3.95
    HCP22010 Aftermarket headlight housing (“bucket”) SEALING GASKET, for use on XJ550 Seca models with the front fairing (1981-82). This rubber “damper” (as it is called in Yamaha-speak) prevents moisture and dust intrusion thru the gap which exists between the headlight bucket and the round headlight opening in the fairing, as well as dampening the vibrations between the bucket and the fairing shell. The smaller diameter end of this 2” wide gasket fits tightly around the flange (or “lip” of the headlight opening on the fairing (inside the fairing), and the larger diameter of the gasket then slips over the outside of the front of the headlight housing, thus sealing off that area. Fits all 1981-82 XJ550 Seca models with the factory fairing. Perfectly replaces what is a commonly missing or damaged part.
    $ 79.95
    HCP9595 OEM headlight housing SCREW, used to secure the upper main housing to the lower ribbed section, use 2 per housing, for all XJ750 Seca main headlight housing. Each:
    $ 7.95
    HCP4623 OEM headlight stay bracket-to-headlight housing ("bucket") mounting BOLT, use 1 on each side for all of the following models: all XJ550 models, all XJ650 Maxim, all XJ750 air-cooled, and XJ900N models. This bolt was originally black on some models, and bright-plated on others. This current bolt has a dark plating. NOTE: 1980 XJ650 Maxim models originally used a bolt and a separate flat washer; those items are no longer available individually and this washer-based bolt can be used in its place. Each:
    $ 4.95
    HCP4639 OEM headlight stay bracket-to-headlight housing ("bucket") mounting BOLT, use 1 on each side for all of the following models: all XJ650 Turbo models. Each:
    $ 7.95
    HCP4628 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt FLAT WASHER, use 1 on each side, directly under the mounting bolt (external to the housing), for all of the following models: all XJ650 Turbo and 1982 XJ750 Maxim models. Each:
    $ 7.95
    HCP2185 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, use 1 on each side, external to the housing, for all of the following models: all XJ650 Turbo models. Each:
    $ 6.95
    HCP16209 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, zinc-plated alloy steel, use 1 on each side, external to the housing, for all of the following models: all XJ650 Turbo models. Each:
    $ 2.95
    HCP16100 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 on each side, external to the housing, for all of the following models: all XJ650 Turbo models. Each:
    $ 3.95
    HCP16102 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, black-oxide coated alloy steel, use 1 on each side, external to the housing, for all of the following models: all XJ650 Turbo models. Each:
    $ 3.95
    HCP4638 OEM headlight stay bracket-to-headlight housing ("bucket") rubber DAMPER, this large, round square-holed grommet snaps into the bucket where the mounting bolt passes through. Use 1 on each side for all of the following models: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and XJ900N model. Each:
    $ 13.95
    HCP4635 OEM headlight stay bracket-to-headlight housing ("bucket") rubber DAMPER, this large, round square-holed grommet snaps into the bucket where the mounting bolt passes through. Use 1 on each side for all of the following models: Use 1 per side on all XJ1100 models. NOTE: XJ1100 models use this grommet in the opening of the bucket, and uses the HCP3666 damper below in the "arms" of the stay brackets. Each:
    $ discontinued
    HCP3666 OEM headlight housing stay bracket RUBBER DAMPER, fits onto the ends of the headlight bucket support "arms". Use 1 per side on all XJ1100 models. The turn signals pass thru this bushing. Each:
    $ 11.95
    HCP4637 OEM headlight stay bracket-to-headlight housing rubber DAMPER, this thin, pear shaped insulator fits on the outside surface of the housing where the mounting bolt passes through. Use 1 on each side for all of the following models: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 10.95
    HCP4626 OEM headlight stay bracket-to-headlight housing rubber DAMPER, this thin, pear shaped insulator fits on the inside surface of the housing where the mounting bolt passes through. Use 1 on left side on all of the following models: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 17.95
    HCP4627 OEM headlight stay bracket-to-headlight housing rubber DAMPER, this thin, pear shaped insulator fits on the inside surface of the housing where the mounting bolt passes through. Use 1 on right side on all of the following models: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 49.95
    HCP10562 OEM headlight stay bracket-to-headlight housing ("bucket") housing rubber DAMPER, use 1 for all of the following models: all XJ700 and XJ750-X models. Each:
    $ 21.95
    HCP4636 OEM headlight stay bracket-to-headlight housing ("bucket") rubber damper COLLAR, this large, round square-holed plastic washer fits inside the damper bushing. Use 1 on each side for all of the following models: all XJ550 models, all XJ650 models (except Turbo), all 1983 XJ750 Maxim and Midnight Maxim models, and XJ900N model. Each:
    $ 26.95
    HCP4633 OEM headlight stay bracket-to-headlight housing rubber damper COLLAR, this large, pear-shaped plastic collar fits on the inside surface of the housing where the mounting bolt passes through. Use 1 on left side on all of the following models: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 18.95
    HCP4634 OEM headlight stay bracket-to-headlight housing rubber damper COLLAR, this large, pear-shaped plastic collar fits on the inside surface of the housing where the mounting bolt passes through. Use 1 on right side on all of the following models: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
    $ 49.95
    HCP4631 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt FLAT WASHER, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, and all XJ650 models (except Turbo), and XJ900N models. Each:
    $ 8.95
    HCP4628 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt FLAT WASHER, use 1 on each side, internal to the housing, for all of the following models: all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 7.95
    HCP2185 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, and all XJ650 models (except Turbo). Each:
    $ 6.95
    HCP16209 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, zinc-plated alloy steel, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, and all XJ650 models (except Turbo). Each:
    $ 2.95
    HCP16100 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, and all XJ650 models (except Turbo). Each:
    $ 3.95
    HCP16102 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, black-oxide coated alloy steel, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, and all XJ650 models (except Turbo). Each:
    $ 3.95
    HCP3494 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt NUT, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, all XJ650 models, all XJ750 models, and XJ900N models. Each:
    $ 3.95
    HCP24037 Aftermarket headlight stay bracket-to-headlight housing ("bucket") mounting bolt NUT, made from 18/8 stainless steel, use 1 on each side, internal to the housing, for all of the following models: all XJ550 models, all XJ650 models, all XJ750 models, and XJ900N models. Each:
    $ 2.95
    HCP315 OEM headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, use 1 on each side on XJ900N models.
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, use 1 on each side on XJ900N models.
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WASHER, use 1 on each side on XJ900N models.
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel headlight stay bracket-to-headlight housing ("bucket") mounting bolt LOCK WA9HER, use 1 on each side on XJ900N models.
    $ 1.95
    HCP2171 OEM headlight housing-to-lower steering bracket MOUNTING BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 3.95
    HCP24067 Aftermarket headlight housing-to-lower steering bracket MOUNTING BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 1.95
    HCP24077 Aftermarket headlight housing-to-lower steering bracket MOUNTING BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 2.95
    HCP24078 Aftermarket headlight housing-to-lower steering bracket MOUNTING BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 3.95
    HCP6639 Aftermarket headlight housing-to-lower steering bracket MOUNTING BOLT, socket head (hex-key drive) 18/8 stainless steel fastener with a bright finish, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 2.95
    HCP24075 Aftermarket headlight housing-to-lower steering bracket MOUNTING BOLT, socket head (hex-key drive) 316 stainless steel fastener with a bright finish, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 2.95
    HCP6640 Aftermarket headlight housing-to-lower steering bracket MOUNTING BOLT, socket head (hex-key drive) black oxide-coated alloy steel fastener, secures the bucket to the bracket from inside the bucket. Fits all XJ700 and XJ750-X models, use 1 per headlight.
    $ 1.95
    HCP315 OEM headlight housing-to-lower steering bracket retaining bolt LOCK WASHER, use 1 on all XJ700 and XJ750-X models.
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, headlight housing-to-lower steering bracket retaining bolt LOCK WASHER, use 1 on all XJ700 and XJ750-X models.
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel headlight housing-to-lower steering bracket retaining bolt LOCK WASHER, use 1 on all XJ700 and XJ750-X models.
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel headlight housing-to-lower steering bracket retaining bolt LOCK WASHER, use 1 on all XJ700 and XJ750-X models.
    $ 1.95
    HCP4504 OEM headlight housing-to-lower steering bracket retaining bolt FLAT WASHER, use 1 on all XJ700 and XJ750-X models.
    $ 7.95
    HCP10562 OEM headlight housing-to-lower steering bracket retaining bolt rubber DAMPER, use 1 on all XJ700 and XJ750-X models.
    $ 21.95
    Main Headlight Housing Stay Bracket and Hardware:
    On all round headlight models, the headlight housing mounting bracket (termed a “stay” in Yamaha-speak) mounts to the lower area of the headlight housing ("bucket") via a single screw and assorted hardware. This slotted bracket secures the vertical (up-and-down) alignment of the entire headlight housing/bucket assembly within the stay bracket.
    The upper arms of the stay bracket, on some models, is bolted to the upper steering bracket and/or gauge cluster mounting studs using a variety of hardware.
    On rectangular headlight models, it can get a bit more complicated, so in order to prevent (or, possibly cause……..  ) confusion, we offer this short guide on the various hardware bits and pieces used to mount the main headlight housing support bracket to the bike on 1981-83 XJ750 Seca/XJ750 Euro models, and to 1982 XJ750 Maxim models. Both models are basically the same in the parts and pieces used to do so, with one exception: while the XJ750 Seca/Euro models integrated the auxiliary “driving light” mounting bracket into the main headlight housing mounting bracket, the XJ750 Maxim models used a separate, small, odd-shaped, bolt-on additional bracket for the auxiliary light mounting, and this additional bracket attaches onto the main headlight housing bracket……..and thus doubling the amount of hardware pieces needed to mount the whole shooting match to the bike.
    It’s rather odd that Yamaha choose to do things on the XJ750 Maxim model in this 2-step manner, especially considering they had already developed the simpler (less parts needed) method of integrating the two brackets together into one unit just one year previously (on the 1981 XJ750 Seca bikes), but hey, I’m sure they had a good reason for doing so……….
    1) on 1981-83 XJ750 Seca and XJ750 Euro models, the headlight housing mounting bracket is integrated into the auxiliary driving light mounting bracket, and the following grommets and hardware pieces are used to mount the headlight stay bracket assembly to the lower steering bracket. The following pieces should be used to mount the main/auxiliary (combined) mounting bracket to the fork tube brackets:
    1981-83 750 Seca uses:
    2 x HCP5791 (or aftermarket version) grommets
    2 x HCP4608 grommet collars
    2 x HCP1903 flat washers
    2 x HCP315 (or aftermarket versions) lock washers
    2 x HCP3701 (or aftermarket version) bolts.
    NOTE: 1983 models are not specified to use the 2 x HCP1903 flat washers in the parts catalog, but original bikes that we have seen do use them.
    2) on 1982 XJ750 Maxim models, the auxiliary driving light mounting bracket is a separate bolt-on piece, so there are extra hardware pieces used to: a) attach the auxiliary driving light bracket to the main headlight housing bracket, and then to mount the entire combined assembly to the lower steering bracket.
    *auxiliary “driving light” bracket to the lower steering bracket:
    2 x HCP5792 grommet collars
    2 x HCP1902 (or aftermarket versions) lock washers
    *auxiliary “driving light” bracket to chrome headlight mounting bracket:
    1 x HCP5791 (or aftermarket version) grommet
    1 x HCP5792 grommet collar
    1 x HCP1902 (or aftermarket versions) lock washe
    1 x HCP3029 (or aftermarket version) bolt.
    *chrome headlight housing mounting bracket to lower steering bracket:
    1 x HCP5791 (or aftermarket version) grommet,
    1 x HCP1902 (or aftermarket versions) lock washer
    HCP4594 OEM front headlight housing assembly chrome STAY BRACKET, for all XJ550 Seca models, left side.
    $ 219.95
    HCP4593 OEM front headlight housing assembly chrome STAY BRACKET, for all XJ550 Seca models, right side.
    $ 219.95
    HCP4590 OEM front headlight housing assembly chrome STAY BRACKET, for all XJ650 Maxim and 1983 XJ750 Maxim models.
    $ 219.95
    HCP4591 OEM front headlight housing assembly black STAY BRACKET, for all XJ650 Midnight Maxim and 1983-84 XJ750 Midnight Maxim models.
    $ 219.95
    HCP4602 OEM front headlight bucket mounting black STAY BRACKET, for all XJ650RJ Seca, XJ650 Euro, and XJ900N models.
    $ 399.95
    HCP4602RF OEM refinished headlight bucket mounting STAY BRACKET for all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Beautiful and durable powder-coated, low-gloss black finish as original. These mounting ears fit the large, bad-boy bucket that accepts the original 8” diameter headlight used only on these models. NOTE: a $ 75.00 core charge applies to this item, and a re-usable, same-model stay bracket must be returned for the core charge to be refunded. “Re-usable" means it is not bent, dinged, damaged, twisted, modified, or road-rashed, and has no rust holes or deep metal pitting.
    $ 239.95 + $ 75.00 refundable core charge
    HCP4595 OEM front headlight bucket mounting black STAY BRACKET, for all 1981-82 XJ750 Seca and XJ750 Euro models. This bracket has the headlight housing mounting “arms” and the lower plate where the “remote” master cylinder is mounted
    $ 239.95
    HCP1030 OEM headlight housing-to-stay bracket pivot bracket retaining SCREW, dark finish alloy steel, panhead, phillips drive. Use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. Each:
    $ 7.95
    HCP2922 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. Zinc-plated alloy steel, natural finish, panhead phillips-drive, each:
    $ 2.95
    HCP21362 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. 18/8 stainless steel, bright finish, panhead phillips-drive, each:
    $ 3.95
    HCP6714 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. Button head hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP6715 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. Socket head, hex-drive, black-oxide coated alloy steel, each:
    $ 2.95
    HCP6716 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. Socket head, hex-drive, 18-8 stainless steel, bright finish, each:
    $ 3.95
    HCP1901 OEM headlight housing-to-stay bracket pivot bracket retaining SCREW, use one on all XJ650 Midnight Maxim models and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP21363 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, zinc-plated alloy-steel, panhead, phillips-drive, use one on all XJ650 Midnight Maxim models and all XJ750 Midnight Maxim models. Each:
    $ 1.95
    HCP2923 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, 18-8 stainless-steel, panhead, phillips-drive, use one on all XJ650 Midnight Maxim models and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP2924 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, black-oxide coated 18-8 stainless steel phillips-drive, panhead screw, use one on all XJ650 Midnight Maxim models and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP3926 OEM headlight housing-to-stay bracket pivot bracket retaining SCREW, alloy steel, panhead, phillips-drive, black finish. Use 1 on all XJ650RJ Seca models. Each:
    $ 7.95
    HCP3114 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, alloy steel, panhead, phillips-drive, bright finish. Use 1 on all XJ650RJ Seca models. Each:
    $ 1.95
    HCP3115 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, 18-8 stainless steel, panhead, phillips-drive, bright finish. Use 1 on all XJ650RJ Seca models. Each:
    $ 3.95
    HCP26199 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, 316 stainless steel, panhead, phillips-drive, black finish. Use 1 on all XJ650RJ Seca models. Each:
    $ 3.95
    HCP4946 OEM headlight housing-to-stay bracket pivot bracket retaining BOLT, use one on all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP2264 OEM headlight housing-to-stay bracket pivot bracket retaining SCREW, panhead phillips-drive alloy steel with a bright zinc-plated finish. Use 1 on all XJ1100 models. Each:
    $ 7.95
    HCP2781N Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, panhead phillips-drive alloy steel with a bright zinc-plated finish. Use 1 on all XJ1100 models. Each:
    $ 2.95
    HCP231N Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, panhead phillips-drive 18-8 stainless steel with a bright finish. Use 1 on all XJ1100 models. Each:
    $ 4.95
    HCP24070 Aftermarket headlight housing-to-stay bracket pivot bracket retaining SCREW, panhead phillips-drive 316 stainless steel with a bright finish. Use 1 on all XJ1100 models. Each:
    $ 3.95
    HCP9596 OEM headlight housing-to-stay bracket pivot bracket retaining BOLT, for all XJ900N models. Each:
    $ 4.95
    HCP1242 Aftermarket headlight housing-to-stay bracket pivot bracket retaining BOLT, allen head hex-drive design, 18-8 stainless steel, with a bright finish. Use on all XJ900N models. Each:
    $ 2.95
    HCP2782 Aftermarket headlight housing-to-stay bracket pivot bracket retaining BOLT, allen head hex-drive, black-oxide coated alloy steel with self-locking threads. Use on all XJ900N models. Each:
    $ 2.95
    HCP2786 Aftermarket headlight housing-to-stay bracket pivot bracket retaining BOLT, allen head hex-drive design, alloy steel, with a black-oxide coated finish. Use on all XJ900N models. Each:
    $ 1.95
    HCP315 OEM headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, use one on all XJ550 models, all XJ650 Maxim models, all 1983 XJ750 Maxim models, and all XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, use one on all XJ550 models, all XJ650 Maxim models, all 1983 XJ750 Maxim models, and all XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, use one on all XJ550 models, all XJ650 Maxim models, all 1983 XJ750 Maxim models, and all XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, use one on all XJ550 models, all XJ650 Maxim models, all 1983 XJ750 Maxim models, and all XJ1100 models. Each:
    $ 1.95
    HCP1902 OEM headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, black oxide-coated alloy steel, use one on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 6.95
    HCP916 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, zinc-plated alloy steel with a bright finish, use one on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 1.95
    HCP319 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, 18-8 stainless steel, use one on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP321 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw LOCK WASHER, black oxide-coated alloy steel, use one on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 1.95
    HCP4254 OEM headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, use one on all XJ550 models, all XJ650 Maxim models, and all 1983 XJ750 Maxim models. Each:
    $ 2.95
    HCP4614 OEM headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, use one on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 5.95
    HCP1903 OEM headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, black oxide-coated alloy steel, use 1 on all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 3.95
    HCP25872 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, bright zinc-plated alloy steel, use 1 on all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 1.25
    HCP25873 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, bright 18/8 stainless steel, use 1 on all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 1.75
    HCP25875 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, black oxide-coated 18/8 stainless steel, use 1 on all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 1.95
    HCP25874 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, bright 316 stainless steel, use 1 on all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 2.95
    HCP10825 OEM headlight housing-to-stay bracket pivot bracket retaining screw FLAT WASHER, use one on all XJ1100 models. Each:
    $ 7.95
    HCP4617 OEM headlight housing-to-stay bracket pivot bracket retaining screw SPECIAL WASHER, use one on all XJ550 Seca, all XJ650RJ Seca, XJ650 Euro, XJ900N models, and XJ1100 models. Each:
    $ 12.95
    HCP5792 OEM headlight housing-to-stay bracket pivot bracket retaining screw COLLAR, use 1 on all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 7.95
    HCP4600 OEM headlight housing-to-stay bracket pivot bracket retaining bolt COLLAR, use two on all XJ700 and XJ750-X models. Each:
    $ 18.95
    HCP4616 OEM headlight housing-to-stay bracket pivot bracket retaining screw COLLAR, use two on all XJ1100 models. Each:
    $ 7.95
    HCP5791 OEM headlight housing-to-stay bracket pivot bracket retaining screw rubber DAMPER, use 1 on all XJ650RJ Seca and XJ900N models. Each:
    $ 8.95
    HCP26224 Aftermarket headlight housing-to-stay bracket pivot bracket retaining screw rubber DAMPER, use 1 on all XJ650RJ Seca and XJ900 N models. Each:
    $ 5.95
    HCP10477 OEM headlight housing-to-stay bracket pivot bracket retaining bolt rubber DAMPER, use 2 on all XJ700 and XJ750-X models. Each:
    $ 7.95
    HCP4615 OEM headlight housing-to-stay bracket pivot bracket retaining screw rubber DAMPER, use 1 on all XJ1100 models. Each:
    $ 4.95
    HCP4528 OEM headlight housing-to-stay bracket pivot bracket retaining bolt CROWN NUT, alloy steel, bright finish, use one on all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP10959 Aftermarket headlight housing-to-stay bracket pivot bracket retaining bolt CROWN NUT, alloy steel, bright finish. The rounded dome head is slightly taller than the originals. Use one on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP21940 Aftermarket headlight housing-to-stay bracket pivot bracket retaining bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller than the originals. Use one on all XJ700 and XJ750-X models. Each:
    $ 5.95
    HCP21941 Aftermarket headlight housing-to-stay bracket pivot bracket retaining bolt CROWN NUT, polished chrome-plated alloy steel. The rounded dome head is slightly taller than the originals. Use one on all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP3029 OEM headlight stay bracket-to-lower steering bracket mounting BOLT, standard 6-point hex-head alloy steel bolt with a dark finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 3.95
    HCP14007 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, standard 6-point hex-head alloy steel bolt with a yellow zinc-plated finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 1.95
    HCP22249 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, standard 6-point hex-head 18/8 stainless steel bolt with a bright finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 2.95
    HCP14008 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, standard 6-point hex-head 316 stainless steel bolt with a bright finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 3.95
    HCP22253 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, socket head (allen-key drive) alloy steel with a yellow zinc-plated finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 1.95
    HCP228 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 1.95
    HCP2779 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish, features self-locking threads. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 2.95
    HCP226 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, socket head (allen-key drive) 18/8 stainless steel with a bright finish. Use 1 each for all of the following models: all XJ550 Maxim, all XJ550 Seca (right side only), all XJ650 (except Turbo) models, 1983 XJ750 Maxim and Midnight Maxim. Use 2 each on: 1982 XJ750 Maxim models (for attaching the main stay bracket to the smaller lower stay bracket). Each:
    $ 2.95
    HCP4599 OEM headlight stay bracket-to-lower steering bracket mounting BOLT, use 2 on all XJ700 and XJ750-X models. Each:
    $ 7.95
    HCP3701 OEM headlight stay bracket-to-lower steering bracket mounting BOLT, use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Originals were bright plated, these replacements feature a dark phosphate plating. Each:
    $ 3.95
    HCP11357 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Correct bright finish, 18/8 stainless steel bolt. Each:
    $ 2.95
    HCP11358 Aftermarket headlight stay bracket-to-lower steering bracket mounting BOLT, use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Black-oxide coated hex-head 18/8 stainless steel bolt. Each:
    $ 2.95
    HCP2173 OEM headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, use 1 on all XJ650 Maxim and all 1983 XJ750 Maxim and Midnight Maxim models, original bright finish, each:
    $ 2.95
    HCP1869 OEM headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, use 1 on all XJ550 Maxim and XJ650 Midnight Maxim models, black-oxide finish, each:
    $ 2.95
    HCP6642 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, zinc-plated alloy steel with a bright finish, use 1 on all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 1.95
    HCP6643 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, 18-8 stainless steel with a bright finish, use 1 on all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 2.95
    HCP25756 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, 316 stainless steel, use 1 on all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 3.95
    HCP14285 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use 1 on all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 2.95
    HCP14284 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, use 1 on all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 2.95
    HCP1903 OEM headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Each:
    $ 3.95
    HCP25872 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, bright zinc-plated alloy steel, ], use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Each:
    $ 1.25
    HCP25873 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, bright 18/8 stainless steel, ], use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Each:
    $ 1.75
    HCP25875 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, black oxide-coated 18/8 stainless steel, ], use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Each:
    $ 1.95
    HCP25874 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt FLAT WASHER, bright 316 stainless steel, ], use 2 on all 1982 XJ750 Maxim (for the lower bracket to the steering underbracket) and all XJ750 Seca models. Each:
    $ 2.95
    HCP315 OEM headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, use 2 on all XJ650RJ Seca and all XJ750 Seca models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, use 2 on all XJ650RJ Seca and all XJ750 Seca models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, use 2 on all XJ650RJ Seca and all XJ750 Seca models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, use 2 on all XJ650RJ Seca and all XJ750 Seca models. Each:
    $ 1.95
    HCP1902 OEM headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, black oxide-coated alloy steel, use a total of 4 on all 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 6.95
    HCP916 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, zinc-plated alloy steel with a bright finish, use a total of 4 on all 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 1.95
    HCP319 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, 18-8 stainless steel, use a total of 4 on all 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 2.95
    HCP321 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt LOCK WASHER, black oxide-coated alloy steel, use a total of 4 on all 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 1.95
    HCP5792 OEM headlight stay bracket-to-lower steering bracket mounting bolt COLLAR, use 1 each for all of the following models: all XJ550 Maxim, all XJ650 Maxim and Midnight Maxim, and 1983 XJ750 Maxim and Midnight Maxim models. Use 2 each on: all XJ550 Seca. Use 4 on 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 4.95
    HCP4608 OEM headlight stay bracket-to-lower steering bracket mounting bolt COLLAR, use 2 each for all of the following models: all XJ650RJ Seca and all XJ750 Seca models. Each:
    $ 7.95
    HCP10679 OEM headlight stay bracket-to-lower steering bracket mounting bolt COLLAR, use 2 each for all of the following models: all XJ900 N models. Each:
    $ 7.95
    HCP5791 OEM headlight stay bracket-to-lower steering bracket mounting bolt rubber GROMMET, use 1 each for all of the following models: all XJ550 Maxim, all XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, XJ650 Euro, 1983 XJ750 Maxim and Midnight Maxim, and XJ900N models. Use 2 each on: all XJ550 Seca, XJ750 Seca, and XJ750 Euro models. Use 4 on 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 8.95
    HCP26224 Aftermarket headlight stay bracket-to-lower steering bracket mounting bolt rubber GROMMET, use 1 each for all of the following models: all XJ550 Maxim, all XJ650 Maxim and Midnight Maxim, XJ650RJ Seca, XJ650 Euro, 1983 XJ750 Maxim and Midnight Maxim, and XJ900N models. Use 2 each on: all XJ550 Seca, XJ750 Seca, and XJ750 Euro models. Use 4 on 1982 XJ750 Maxim models (2 each on the main stay bracket to the lower bracket, and also 2 on the lower bracket to the steering underbracket). Each:
    $ 5.95
    HCP4224 OEM fairing / headlight main bracket-to-frame (headpipe) mounting FLANGED BOLT. Hex-head, bright finish. Use 2 on all XJ650 Turbo and XJ750-D models. Each:
    $ discontinued
    HCP24416 Aftermarket front upper engine mounting bracket-to-frame FLANGED BOLT. Alloy steel with a bright zinc-plated finish. Use 2 on all XJ650 Turbo and XJ750-D models. Each:
    $ 3.95
    HCP24417 Aftermarket front upper engine mounting bracket-to-frame FLANGED BOLT. Alloy steel with a black-phosphate finish. Use 2 on all XJ650 Turbo and XJ750-D models. Each:
    $ 4.95
    HCP9760 OEM fairing / headlight main bracket-to-frame (headpipe) mounting FLANGED NUT, use 2 on all XJ650 Turbo and XJ750-D models. Alloy steel with a dark phosphate-coated finish. Each:
    $ 8.95
    HCP16246 Aftermarket fairing / headlight main bracket-to-frame (headpipe) mounting FLANGED NUT, use 2 on all XJ650 Turbo models. High-strength alloy steel with a dark phosphate-coated finish. Each:
    $ 3.95
    HCP24413 Aftermarket fairing / headlight main bracket-to-frame (headpipe) mounting FLANGED NUT, use 2 on all XJ650 Turbo models. High-strength alloy steel with a bright zinc-plated finish. Each:
    $ 2.95
    HCP24414 Aftermarket fairing / headlight main bracket-to-frame (headpipe) mounting FLANGED NUT, use 2 on all XJ650 Turbo models. High-strength 18/8 stainless steel with a bright finish. Each:
    $ 2.95
    HCP24415 Aftermarket fairing / headlight main bracket-to-frame (headpipe) mounting FLANGED NUT, use 2 on all XJ650 Turbo models. High-strength, ultra-corrosion-resistant 316 stainless steel with a dull finish. Each:
    $ 3.95
    HCP6093 OEM headlight stay bracket-to-steering crown mounting BOLT, use 1 per bike on all XJ650 Maxim and Midnight Maxim and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 3.95
    HCP6095 OEM headlight stay bracket-to-steering crown mounting bolt COLLAR, use 1 per bike on all XJ550 models, FJ600, all XJ650 models (except Turbo), all XJ700 models, all XJ750 models, XJ900 N model, and all XJ1100 models. Each:
    $ 7.95
    HCP4254 OEM headlight stay bracket-to-steering crown mounting bolt FLAT WASHER, use 1 per bike on all FJ600, XJ650 Maxim and Midnight Maxim models, all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 2.95
    HCP1902 OEM headlight stay bracket-to-steering crown mounting bolt LOCK WASHER, black oxide-coated alloy steel, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 6.95
    HCP916 Aftermarket headlight stay bracket-to-steering crown mounting bolt LOCK WASHER, zinc-plated alloy steel with a bright finish, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 1.95
    HCP319 Aftermarket headlight stay bracket-to-steering crown mounting bolt LOCK WASHER, 18-8 stainless steel, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 2.95
    HCP321 Aftermarket headlight stay bracket-to-steering crown mounting bolt LOCK WASHER, black oxide-coated alloy steel, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 1.95
    Main Headlight Adjuster Hardware:
    These long, unique SCREWS, SPRINGS, and special plastic NUTS are what allow you to adjust the horizontal aim of the headlight (vertical adjustment is controlled via the mounting hardware of the headlight housing ("bucket") to the stay bracket). These pieces rarely get used, and as such, tend to seize up and then the tiny screw-head slots strip out when you finally do attempt to adjust them. Make sure you install them with some anti-seize lube on the threads!
    HCP4642 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Each:
    $ 7.95
    For all the following models use 1 screw:
    XJ550 all models
    XJ650 Maxim
    1983 XJ750 Maxim
    XJ1100
    For all the following models use 2 screws:
    XJ650 Turbo (1982)
    XJ750 Seca (main headlight)
    The above screw can also be used on XJ650 Midnight Maxim and XJ750 Midnight Maxim models, but the finish is incorrect.
    HCP20023 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Use 2, for all FJ600 models. Each:
    $ 5.95
    HCP4641 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Use 1, for all XJ650RJ Seca, XJ650 Euro, and XJ900N models. Each:
    $ 9.95
    HCP4646 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Use 2, for all 1983 XJ650 Turbo models. Each:
    $ 7.95
    HCP4501 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Use 2, for all XJ700 and XJ750-X models. Each:
    $ 6.95
    HCP4647 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Use 2, for all FJ600 and XJ900RK, RL, FN, and F models. Each:
    $ 3.95
    HCP21823 OEM headlight ADJUSTER SCREW, the long phillips-drive, panhead screw that controls the left-right alignment of the headlight assembly within the housing bucket. Use 2, for all XS1100 Standard models. Each:
    $ 8.95
    HCP4643 OEM headlight adjuster screw WASHER, used under the head of the screw. Use 1, for all XJ650 Midnight Maxim models. Each:
    $ 3.95
    HCP328 OEM headlight adjuster screw WASHER, used under the head of the screw. Use 1 per adjuster screw, for all XS1100 Standard models. Each:
    $ 3.95
    HCP924 Aftermarket zinc-plated, alloy-steel, natural finish headlight adjuster screw WASHER, used under the head of the screw. Use 1 per adjuster screw, for all XS1100 Standard models. Each:
    $ 1.95
    HCP338 Aftermarket 18-8 stainless-steel polished finish front headlight adjuster screw WASHER, used under the head of the screw. Use 1 per adjuster screw, for all XS1100 Standard models. Each:
    $ 2.95
    HCP28050 Aftermarket grade 316 stainless-steel polished finish front headlight adjuster screw WASHER, used under the head of the screw. Use 1 per adjuster screw, for all XS1100 Standard models. Each:
    $ 3.95
    HCP1356 Aftermarket black oxide-coated steel finish headlight adjuster screw WASHER, used under the head of the screw. Use 1 per adjuster screw, for all XS1100 Standard models. Each:
    $ 1.95
    HCP4644 OEM headlight adjuster screw SPRING, the long skinny spring used with the above adjuster screws. Each:
    $ 7.95
    For all the following models use 1 spring:
    XJ550 all models
    XJ1100
    For all the following models use 2 springs:
    FJ600 all models
    XJ650 Turbo
    HCP4645 OEM headlight adjuster screw SPRING, the long skinny spring used with the above adjuster screws. Use 1 for all XJ650RJ Seca, XJ650 Euro, and XJ900N models, and 2 for all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP21825 OEM headlight adjuster screw SPRING, the long skinny spring used with the above adjuster screws. Use 2, for all 1979-81 XS1100 Standard models. Each:
    $ 17.95
    HCP4649 OEM headlight adjuster screw NUT, the square white plastic locking nut that the screw enters and holds the alignment. Each:
    $ 7.95
    For all the following models use 1 nut:
    XJ550 all models
    XJ650 Maxim, Midnight Maxim, and Seca
    XJ1100
    For all the following models use 2 nuts:
    FJ600 all models
    XJ650 Turbo
    1982 XJ750 Maxim (main headlight)
    HCP21826 OEM headlight adjuster screw NUT, the square white plastic locking nut that the screw enters and holds the alignment. Use 2, for all XS1100 Standard models. Each:
    $ 7.95
  25. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Chassis Electrical System: Turn Signals, Side Reflectors, Rear Reflectors, Tail Lights, Brake Lights, License Plate Lights, Lenses, Bulbs, Flashers, and related hardware, etc.
    FRONT SIDE and REAR REFLECTORS:
    Your front SIDE REFLECTORS, although not electrically powered, serve a vital and valuable function----they let people approaching from the side see you, and hopefully take enough notice to avoid plowing into you (or scaring you half to death, thinking that they're about to!).
    Your REAR REFLECTOR is an "always-there" helper for your brake light, and make you much more visible and less likely to be run over.
    Make sure your reflectors are up to their task, as age, heat, and solvents can migrate down behind the lense unit and discolor or darken the reflector significantly.
    Front Side Reflectors:
    HCP706 OEM front SIDE REFLECTOR, this rectangular yellow reflector lense comes with the chrome metal surround bezel, and fits either side on all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, all XJ750 models, and XJ1100 models. Each:
    $ 64.95
    HCP3627SS OEM front SIDE REFLECTOR, this round yellow reflector lense fits either side on all XJ550 Seca models without a fairing (on the lower steering bracket), and all XJ650RJ Seca models (on the headlight bucket), and on 1979 XS1100 Special models. This replacement unit is the same shape and style as the original, but has a black outer rim instead of the brightly plated rim as originally used. Each:
    $ 32.95
    HCP11513 Aftermarket front SIDE REFLECTOR, this round yellow reflector lense fits either side on all XJ550 Seca models without a fairing (on the lower steering bracket), and all XJ650RJ Seca models (on the headlight bucket), and 1979 XS1100 Special models. Measures approximately 57mm in diameter, slightly smaller than original, has a bright rim, and comes with the mounting stud flat washer and nut. Each:
    $ 23.95
    HCP11512 Aftermarket front SIDE REFLECTOR, this round yellow reflector lense fits either side on all XJ550 Seca models without a fairing (on the lower steering bracket), and all XJ650RJ Seca models (on the headlight bucket), and 1979 XS1100 Special models. Measures approximately 57mm in diameter, slightly smaller than original, has a black rim, and comes with the mounting stud flat washer and nut. Each:
    $ 12395
    HCP708 OEM front SIDE REFLECTORS, this square yellow reflector lense fits either side on all XJ550 Seca models with a fairing, all FJ600, XJ650 Turbo models, XJ750 Seca models using the optional factory "touring package" front fairing, and all XJ900RK models with the fairing. Has a bright outer rim. Each:
    $ 59.95
    HCP11473 Aftermarket front SIDE REFLECTORS, square yellow reflector lense fits either side on all XJ550 Seca models with a fairing, all FJ600, XJ650 Turbo models, XJ750 Seca models using the optional factory "touring package" front fairing, and all XJ900RK models with the fairing. Has a black outer rim. Includes mounting nut and washer. Each:
    $ 37.95
    HCP707 OEM front SIDE REFLECTORS, this rectangular yellow reflector lense fits down on the lower fork tube on either side on all XJ700 and XJ750-X models. Each:
    $ 49.95
    Front Side Reflector Hardware:
    HCP3638 OEM front side reflector MOUNTING BRACKET, fits either side, for all XJ900RK models. Each:
    $ 29.95
    HCP3696 OEM front side reflector lense short mounting SCREW, bright plated finish phillips-drive. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each:
    $ 7.95
    HCP5482 Aftermarket front side reflector lense short mounting SCREW, zinc-plated alloy steel, phillips-drive panhead screw. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP21356 Aftermarket front side reflector lense short mounting SCREW, 18-8 stainless steel, phillips-drive panhead screw. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP5486 Aftermarket front side reflector lense short mounting SCREW, phillips-drive panhead screw with gold chromate finish. Has an integral lockwasher. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP5483 Aftermarket front side reflector lense short mounting SCREW, socket head cap screw (hex-drive), 18-8 stainless steel with a bright polished finish. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP5484 Aftermarket front side reflector lense short mounting SCREW, socket head cap screw (hex-drive), black-oxide coated steel finish. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP5485 Aftermarket front side reflector lense short mounting SCREW, button head cap screw (rounded head hex-drive), 18-8 stainless steel with a bright polished finish. Use one per reflector on the following models: 1981 XJ550 Maxim and XJ1100 models. Each
    $ 2.95
    HCP3633 OEM front side reflector lense short mounting SCREW, phillips-drive. Used one per reflector on the following models: 1982-3 XJ550 Maxim, all XJ650 Maxim and Midnight Maxim models, and all XJ750 non-X models. Each:
    $ 2.95
    HCP23024 Aftermarket front side reflector lense short mounting SCREW, phillips-drive. Used one per reflector on the following models: 1982-3 XJ550 Maxim, all XJ650 Maxim and Midnight Maxim models, and all XJ750 non-X models, zinc-plated alloy steel as original, each:
    $ 1.95
    HCP23025 Aftermarket front side reflector lense short mounting SCREW, phillips-drive. Used one per reflector on the following models: 1982-3 XJ550 Maxim, all XJ650 Maxim and Midnight Maxim models, and all XJ750 non-X models, 18-8 stainless steel, each:
    $ 2.95
    HCP3629 OEM front side reflector lense long mounting SCREW, bright plated finish phillips-drive. Used one per reflector on the following models: 1981 XJ550 Maxim, all XJ650 Maxim models, and all XJ750 non-X models. Each:
    $ 6.95
    HCP23033 Aftermarket front side reflector lense long mounting SCREW, zinc-plated alloy steel with correct JIS small phillips-drive panhead design. Used one per reflector on the following models: 1981 XJ550 Maxim, all XJ650 Maxim models, and all XJ750 non-X models. Each:
    $ 2.95
    HCP23034 Aftermarket front side reflector lense long mounting SCREW, zinc-plated alloy steel with phillips-drive panhead design. Used one per reflector on the following models: 1981 XJ550 Maxim, all XJ650 Maxim models, and all XJ750 non-X models. Each:
    $ 1.95
    HCP23035 Aftermarket front side reflector lense long mounting SCREW, 18-8 stainless steel with phillips-drive panhead design. Used one per reflector on the following models: 1981 XJ550 Maxim, all XJ650 Maxim models, and all XJ750 non-X models. Each:
    $ 2.95
    HCP3956 OEM front side reflector lense long mounting SCREW, bright plated phillips-drive panhead machine screw. Used one per reflector on the following models: 1982-3 XJ550 Maxim models. Each:
    $ 7.95
    HCP23031 Aftermarket front side reflector lense long mounting SCREW, zinc-plated alloy steel with phillips-drive panhead design. Used one per reflector on the following models: 1982-3 XJ550 Maxim models. Each:
    $ 1.95
    HCP23030 Aftermarket front side reflector lense long mounting SCREW, 18-8 stainless steel phillips-drive with correct JIS small panhead design. Used one per reflector on the following models: 1982-3 XJ550 Maxim models. Each:
    $ 3.95
    HCP23032 Aftermarket front side reflector lense long mounting SCREW, 18-8 stainless steel with phillips-drive panhead design. Used one per reflector on the following models: 1982-3 XJ550 Maxim models. Each:
    $ 2.95
    HCP7532 OEM front side reflector lense long mounting SCREW, bright plated finish phillips-drive. Used one per reflector on the following models: XJ1100 models. Each:
    $ 8.95
    HCP23026 Aftermarket front side reflector lense long mounting SCREW, zinc-plated alloy steel with correct JIS small phillips-drive panhead design. Used one per reflector on the following models: XJ1100 models. Each:
    $ 2.95
    HCP23027 Aftermarket front side reflector lense long mounting SCREW, zinc-plated alloy steel, phillips-drive panhead design. Used one per reflector on the following models: XJ1100 models. Each:
    $ 1.95
    HCP23028 Aftermarket front side reflector lense long mounting SCREW, 18-8 stainless steel, phillips-drive panhead design. Used one per reflector on the following models: XJ1100 models. Each:
    $ 2.95
    HCP328 OEM front side reflector lense mounting screw FLAT WASHER, use one each on both the upper and lower screws on the following models: all XJ550 Maxim models, XJ650 Maxim and Midnight Maxims models, all XJ750 non-X models, and all XJ1100 models. Each:
    $ 3.95
    HCP924 Aftermarket zinc-plated, alloy-steel, natural finish front side reflector lense mounting screw FLAT WASHER, use one each on both the upper and lower screws on the following models: all XJ550 Maxim models, XJ650 Maxim and Midnight Maxims models, all XJ750 non-X models, and all XJ1100 models. Each:
    $ 1.95
    HCP338 Aftermarket 18-8 stainless-steel polished finish front side reflector lense mounting screw FLAT WASHER, use one each on both the upper and lower screws on the following models: all XJ550 Maxim models, XJ650 Maxim and Midnight Maxims models, all XJ750 non-X models, and all XJ1100 models. Each:
    $ 2.95
    HCP28050 Aftermarket grade 316 stainless-steel polished finish front side reflector lense mounting screw FLAT WASHER, use one each on both the upper and lower screws on the following models: all XJ550 Maxim models, XJ650 Maxim and Midnight Maxims models, all XJ750 non-X models, and all XJ1100 models. Each:
    $ 3.95
    HCP1356 Aftermarket black oxide-coated steel finish front side reflector lense mounting screw FLAT WASHER, use one each on both the upper and lower screws on the following models: all XJ550 Maxim models, XJ650 Maxim and Midnight Maxims models, all XJ750 non-X models, and all XJ1100 models. Each:
    $ 1.95
    HCP3625 OEM front side reflector lense mounting screw FLAT WASHER, bright zinc-plated alloy steel. Use one on each reflector stud on the following models: all XJ550 Seca models, XJ650RJ Seca and Turbo models, all XJ900 models, and 1979 XS1100 models. Each:
    $ 4.95
    HCP914 Aftermarket front side reflector lense mounting screw FLAT WASHER, bright zinc-plated alloy steel. Use one on each reflector stud on the following models: all XJ550 Seca models, XJ650RJ Seca and Turbo models, all XJ900 models, and 1979 XS1100 models. NOTE: this washer is slightly smaller and thinner than the original washer, but this change will make no difference in fitment nor function. Each:
    $ 1.95
    HCP1353 Aftermarket front side reflector lense mounting screw FLAT WASHER, bright 18/8 stainless steel. Use one on each reflector stud on the following models: all XJ550 Seca models, XJ650RJ Seca and Turbo models, all XJ900 models, and 1979 XS1100 models. NOTE: this washer is slightly smaller and thinner than the original washer, but this change will make no difference in fitment nor function. Each:
    $ 2.95
    HCP65 Aftermarket front side reflector lense mounting screw FLAT WASHER, black oxide-coated stainless steel. Use one on each reflector stud on the following models: all XJ550 Seca models, XJ650RJ Seca and Turbo models, all XJ900 models, and 1979 XS1100 models. NOTE: this washer is slightly smaller and thinner than the original washer, but this change will make no difference in fitment nor function. Each:
    $ 2.95
    HCP55 OEM front side reflector lense mounting screw LOCK WASHER, use one on each reflector stud on the following models: all XJ550 Seca models,1984-85 FJ600, XJ650RJ Seca and XJ650 Turbo models, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP913 Aftermarket zinc-plated alloy steel with a natural finish, front side reflector lense mounting screw LOCK WASHER, use one on each reflector stud on the following models: all XJ550 Seca models,1984-85 FJ600, XJ650RJ Seca and XJ650 Turbo models, and 1979 XS1100 Special models. Each:
    $ 1.75
    HCP57 Aftermarket 18-8 stainless steel, front side reflector lense mounting screw LOCK WASHER, use one on each reflector stud on the following models: all XJ550 Seca models,1984-85 FJ600, XJ650RJ Seca and XJ650 Turbo models, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP59 Aftermarket black oxide-coated alloy steel, front side reflector lense mounting screw LOCK WASHER, use one on each reflector stud on the following models: all XJ550 Seca models,1984-85 FJ600, XJ650RJ Seca and XJ650 Turbo models, and 1979 XS1100 Special models. Each:
    $ 1.95
    HCP3632 OEM front side reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ550 Seca models, FJ600, XJ650RJ Seca and XJ650 Turbo models. Each:
    $ 8.95
    HCP24055 Aftermarket front side reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ550 Seca models, FJ600, XJ650RJ Seca and XJ650 Turbo models. Bright zinc-plated steel. Each:
    $ 1.95
    HCP24056 Aftermarket front side reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ550 Seca models, FJ600, XJ650RJ Seca and XJ650 Turbo models. Bright 18/8 stainless steel. Each:
    $ 2.95
    HCP24057 Aftermarket front side reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ550 Seca models, FJ600, XJ650RJ Seca and XJ650 Turbo models. Bright 316 stainless steel. Each:
    $ 3.95
    HCP3635 OEM front side reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP3636 OEM front side reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ900RK models. Each:
    $ 8.95
    Rear Reflectors:
    HCP710 OEM rear REFLECTOR, this rectangular red reflector lense is used on all FJ600, XJ650RJ Seca models, all XJ650 Turbo models, all XJ750 Maxim, and all XJ1100 models. Each:
    $ 29.95
    HCP11474 Aftermarket rear REFLECTOR, this rectangular red reflector lense fits on the rear grab bar on all XJ700 and XJ750-X models. Black outer rim. Each:
    $ 29.95
    HCP13739 OEM rear REFLECTOR, this rectangular red reflector lense fits on all FJ600 and XJ900RL, N/FN, and F models. Each:
    $ 27.95
    HCP13667 OEM rear fender reflector MOUNTING BRAKET, this is the “Z-shaped” stamped metal bracket that attaches to the reflector lense. For allXJ650 Turbo models Each:
    $ 37.95
    Rear Reflector Hardware:
    HCP10845 OEM rear reflector base mounting BOLT, secures the base housing to the fender. Used two per base on XJ1100 Maxim models. Each:
    $ 3.95
    HCP3625 OEM rear reflector lense stud FLAT WASHER, bright zinc-plated alloy steel. Use one on the reflector stud on the following models: all XJ900RL, N/FN, and F models, and XJ1100 models. Each:
    $ 4.95
    HCP914 Aftermarket rear reflector lense stud FLAT WASHER, bright zinc-plated alloy steel. Use one on the reflector stud on the following models: all XJ900RL, N/FN, and F models, and XJ1100 models. NOTE: this washer is slightly smaller and thinner than the original washer, but this change will make no difference in fitment nor function. Each:
    $ 1.95
    HCP1353 Aftermarket rear reflector lense stud FLAT WASHER, bright 18/8 stainless steel. Use one on the reflector stud on the following models: all XJ900RL, N/FN, and F models, and XJ1100 models. NOTE: this washer is slightly smaller and thinner than the original washer, but this change will make no difference in fitment nor function. Each:
    $ 2.95
    HCP65 Aftermarket rear reflector lense stud FLAT WASHER, black oxide-coated stainless steel. Use one on the reflector stud on the following models: all XJ900RL, N/FN, and F models, and XJ1100 models. NOTE: this washer is slightly smaller and thinner than the original washer, but this change will make no difference in fitment nor function. Each:
    $ 2.95
    HCP55 OEM rear reflector lense mounting LOCK WASHER, use as specified on the following models: all FJ600, all XJ650 Turbo models on the reflector stud (1) and on the reflector support bracket stud to the upper bracket (1), all XJ750 Maxim models on the reflector stud (1), and on all XJ1100 models for the reflector base housing to fender mounting bolts (2) and on the reflector stud (1). Each:
    $ 1.95
    HCP913 Aftermarket zinc-plated alloy steel with a natural finish, rear reflector lense mounting LOCK WASHER, use as specified on the following models: all FJ600, all XJ650 Turbo models on the reflector stud (1) and on the reflector support bracket stud to the upper bracket (1), all XJ750 Maxim models on the reflector stud (1), and on all XJ1100 models for the reflector base housing to fender mounting bolts (2) and on the reflector stud (1). Each:
    $ 1.75
    HCP57 Aftermarket 18-8 stainless steel, rear reflector lense mounting LOCK WASHER, use as specified on the following models: all FJ600, all XJ650 Turbo models on the reflector stud (1) and on the reflector support bracket stud to the upper bracket (1), all XJ750 Maxim models on the reflector stud (1), and on all XJ1100 models for the reflector base housing to fender mounting bolts (2) and on the reflector stud (1). Each:
    $ 2.95
    HCP59 Aftermarket black oxide-coated alloy steel, rear reflector lense mounting LOCK WASHER, use as specified on the following models: all FJ600, all XJ650 Turbo models on the reflector stud (1) and on the reflector support bracket stud to the upper bracket (1), all XJ750 Maxim models on the reflector stud (1), and on all XJ1100 models for the reflector base housing to fender mounting bolts (2) and on the reflector stud (1). Each:
    $ 1.95
    HCP3624 OEM rear reflector mounting NUT, use one on the reflector stud on XJ650RJ Seca models. Each:
    $ 8.95
    HCP3632 OEM rear reflector lense mounting stud NUT, use one on the reflector stud to secure it to the bracket on the following models: all 1984-85 FJ600, XJ650 Turbo, XJ750 Maxim, and XJ1100 models. Each:
    $ 8.95
    HCP24055 Aftermarket rear reflector lense mounting stud NUT, use one on the reflector stud to secure it to the bracket on the following models: all 1984-85 FJ600, XJ650 Turbo, XJ750 Maxim, and XJ1100 models. Bright zinc-plated steel. Each:
    $ 1.95
    HCP24056 Aftermarket rear reflector lense mounting stud NUT, use one on the reflector stud to secure it to the bracket on the following models: all 1984-85 FJ600, XJ650 Turbo, XJ750 Maxim, and XJ1100 models. Bright 18/8 stainless steel. Each:
    $ 2.95
    HCP24057 Aftermarket rear reflector lense mounting stud NUT, use one on the reflector stud to secure it to the bracket on the following models: all 1984-85 FJ600, XJ650 Turbo, XJ750 Maxim, and XJ1100 models. Bright 316 stainless steel. Each:
    $ 3.95
    HCP3635 OEM rear reflector lense mounting NUT, use one on the reflector stud on the following models: all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP3636 OEM rear reflector lense mounting screw NUT, use one on each reflector stud on the following models: all XJ900RL, N/FN, and F models. Each:
    $ 8.95
  26. chacal
    TURN SIGNALS:
    The stock Yamaha turn signals on these bikes are a "beauty in the eye of the beholder" kind of thing: either you love 'em or hate 'em. Most people don't object to the size of them....in fact, when it comes to turn signals, you want the cager who's heading towards you---you know, the one who is on the cellphone who's also fiddling with the radio dial and swilling coffee at the same time---to NOTICE you, and a large, bright turn signal is a big advantage here. But they do stick out quite a bit more than most people would prefer, looking like big alien ears of some kind........well, nothing's perfect, is it?
    We can help restore your flashing bunny ears with a variety of high-quality OEM or aftermarket parts.
    Complete Turn Signal Assembly:
    Brand new, OEM and reproduction front or rear TURN SIGNAL ASSEMBLY units are now available. Finished in the correct mirror-polished chrome plating, or the smooth-textured, low gloss black finish, these complete, assembled, pre-wired DOT-approved assemblies bolt up directly in place of your stock unit, using the same hardware and mounting points as the originals. Lead wire colors are different from original, but the wires include the correct male bullet connectors so that they will plug directly into your existing main harness terminals.
    Most aftermarket turn signals are available in both a two-wire and a three-wire design. Two-wire signals operate only as flashers (turn signals), while the 3-wire design signals operate both as running lights and as flashers (3-wire signals were originally used only on the front of XJ700 and XJ1100 models). If you desire, you can upgrade your standard 2-wire "flashers-only" to the three-wire design and have your turn signals also function as running lights (check with your local laws to determine legality of doing such a modification).
    All turn signals are complete assembled units, and contain the housing, the wire harness, the lense, lense gasket, and a 23W (turn signal only) or an 8W/23W (on the running light/turn signal light versions) standard incandescent bulb. NOTE: original turn signal bulbs are 27W, and the use of the 23W bulbs that come with all of the replacement turn signals may not allow your stock turn signal flasher to perform properly, or at all. If this situation arises, you will need to replace the supplied 23W bulbs with standard original style 27W bulbs.
    NOTE: all turn signals below do not include the metal or rubber-coated signal housing mounting shaft (also called a stalk or "stay").
    XJ550 Maxim, XJ650 Maxim, XJ650RJ Seca, 1983 XJ750 Maxim, XJ1100 models:
    HCP20791LH OEM complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 2-wire design (flashers only), with "squared-top" round orange lense is correct for all of the following models: XJ550 Maxim front or rear, XJ650 Maxim front or rear, XJ650RJ Seca front or rear, 1983 XJ750 Maxim front or rear, and XJ1100 models rear only. Has the brown "hot" wire and black ground wire as original. Owners wishing to have glossy black housing signal units (as used on Midnight Maxim models) should use the HCP20792 listed below. See the NOTES below regarding these turn signals. Each:
    $ 139.95
    HCP20791RH OEM complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 2-wire design (flashers only), with "squared-top" round orange lense is correct for all of the following models: XJ550 Maxim front or rear, XJ650 Maxim front or rear, XJ650RJ Seca front or rear, 1983 XJ750 Maxim front or rear, and XJ1100 models rear only. Has the dark green “hot” wire and black ground wire as original. Owners wishing to have glossy black housing signal units (as used on Midnight Maxim models) should use the HCP20792 listed below. See the NOTES below regarding these turn signals. Each:
    $ 139.95
    NOTES ON HCP20791 SIGNAL UNITS:
    a) these turn signals are also the correct shape and fitment for the XJ650 and XJ750 Midnight Maxim models, but these units have the chrome housing rather than the black housing used on Midnight versions.
    b) 1980-81 XJ650 Maxim and Midnight Maxim models used a single-wire (positive only) design front and rear turn signal, which used the turn signal stalk as the bulb socket ground. The above HCP20791 turn signals are a 2-wire (positive and ground) design and require the use of the ground wire to operate properly. Original rear turn signals on these models actually used a separate ground wire from the stalk to the sub-harness, and the ground wire on these replacement units will fit directly in place to that terminal. On the front turn signals, you will have to locate and terminate the turn signal ground wires to a suitable frame (or other harness) black ground wire.
    HCP20792 OEM complete TURN SIGNAL ASSEMBLY, glossy black round housings, 1-wire design (flashers only), with "squared-top" round orange lense is correct for all of the following models: 1981 XJ650 Midnight Maxim front or rear. See the NOTES below regarding these turn signals. Each:
    $ 99.95
    HCP20792SET2 OEM complete TURN SIGNAL ASSEMBLIES, set of 2:
    $ 189.95
    HCP20792SET4 OEM complete TURN SIGNAL ASSEMBLIES, set of 4:
    $ 359.95
    NOTES ON HCP20792 SIGNAL UNITS:
    a) 1981 XJ650 Midnight Maxim models used a single-wire (positive only) design front and rear turn signal, which used the turn signal stalk as the bulb socket ground. The above HCP20792 turn signals are of the same design and do not use a separate ground wire. HOWEVER, this is a kinda hoary way to provide a ground path, and we would recommend the use of the HCP20792-2W signals (below) which use the more useful 2-wire (positive and negative) design.
    b) These signal units no longer have the correct color code hot wires to distinguish the left (dark brown) from the right (dark green) signal units as original.
    HCP20792-2W OEM complete TURN SIGNAL ASSEMBLY, glossy black round housings, 2-wire design (flashers only), with "squared-top" round orange lense is correct for all of the following models: 1983 XJ750 Midnight Maxim front or rear. These units can also be used as a direct substitute for the chrome signals originally used on all XJ550 Maxim, XJ650 Maxim, XJ650RJ Seca, and 1983 XJ750 Maxim models. See the NOTES below regarding these turn signals. Each:
    $ 99.95
    HCP20792-2WSET2 OEM complete TURN SIGNAL ASSEMBLIES, set of 2:
    $ 189.95
    HCP20792-2WSET4 OEM complete TURN SIGNAL ASSEMBLIES, set of 4:
    $ 359.95
    NOTES ON HCP20792-2W SIGNAL UNITS:
    a) these turn signals are also the correct shape and fitment for the XJ550 Maxim, XJ650 Maxim, XJ650RJ Seca, and XJ750 Maxim models, but these have the painted black housing rather than the chrome housing used on those models.
    b) 1981 XJ650 Midnight Maxim models used a single-wire (positive only) design front and rear turn signal, which used the turn signal stalk as the bulb socket ground. The above HCP20792-2W turn signals are a 2-wire (positive and ground) design and require the use of the ground wire to operate properly (they are no longer grounded thru the stalk). On the front turn signals, you will have to locate and terminate the turn signal ground wires into the un-used "dual-female terminal" black ground wire receiver inside the headlight bucket. Original rear turn signals on these models actually used a separate ground wire from the stalk to the sub-harness, and the ground wire on these replacement units will fit directly in place to that terminal.
    c) These signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive lead is a solid black wire (odd, but true……) and the ground wire is a black wire with a white tracer stripe. Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    HCP1683 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 2-wire design (flashers only), with "squared-top" round orange lense is correct for all of the following models: XJ550 Maxim front or rear, XJ650 Maxim front or rear, XJ650RJ Seca front or rear, 1983 XJ750 Maxim front or rear, and XJ1100 models rear only. Also fits all of the following models: 1988-90 XV250 rear, 1983 XV500 Virago front or rear, 1987-88 XV535 Virago front or rear, 1981-83 XV750 Virago front or rear, 1981-82 XV920 RH/RJ Virago front or rear, 1983 XV920K front or rear, and 1983 XV920MK rear. See the NOTES below regarding these turn signals. Each:
    $ 47.95
    HCP1683SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 89.95
    HCP1683SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 169.95
    NOTES ON HCP1683 SIGNAL UNITS:
    a) these turn signals have the correct shape and fitment for the XJ650 Midnight Maxim, XJ750 Midnight Maxim, and XV920 Midnight Virago models, but they have the chrome housing rather than the black housing used on Midnight versions.
    b) 1980-81 XJ650 Maxim and XJ650 Midnight Maxim models (and some XV535 and XV750 Virago models) used a single-wire (positive only) design on both the front and rear turn signals, and that style signal used the turn signal housing and mounting stalk as the bulb socket ground. The above HCP1683 turn signals are a 2-wire (positive and ground) design and require the use of the ground wire to operate properly. Original rear turn signals on these models actually used a separate ground wire from the stalk to the sub-harness, and the ground wire on these replacement units will fit directly in place to that terminal (i.e. you will eliminate the separate ground wire, and plug the ground wire on this signal unit into the same place that the original separate wire was plugged into). On the front turn signals, you will have to locate and terminate the turn signal ground wires to a suitable location. Most XJ650 Maxim models have an un-used, double-female ground (black) wire terminal inside the headlight housing (bucket), and if your bike has that un-used terminal, that would be the ideal place to install the ground wires on these signal units for the front signals. Otherwise, you will need to find another place/method of locating a suitable ground.
    HCP7556 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 3-wire design (flashers and running lights), with "squared-top" round orange lense is correct for all of the following models: XJ1100 models front only. Also used on following models: 1988-90 XV250 front. Can also be used to convert the stock “flashers only” front signal lights to the later type “flashers and always-on running lights” style signals on all the following models: XJ550 Maxim front, XJ650 all (except Turbo models) front, 1983 XJ750 Maxim front, 1983 XV500 Virago front, 1987-88 XV535 Virago front, 1981-83 XV750 Virago front, 1981-82 XV920 RH/RJ Virago front, and 1983 XV920K front. See the NOTES below regarding these turn signals. Each:
    $ 47.95
    HCP7556SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 89.95
    HCP7556SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 169.95
    NOTES ON HCP7556 SIGNAL UNITS:
    a) these turn signals are the same design and style of the original signal units used on all of the following bikes: XJ550 Maxim front and rear, XJ650 Maxim front and rear, XJ650RJ Seca front and rear, 1983 XJ750 Maxim front and rear, and XJ1100 front and rear, 1983 XV500 Virago front and rear, 1987-88 XV535 Virago front and rear, 1981-83 XV750 Virago front and rear, 1981-82 XV920 RH/RJ Virago front and rear, and 1983 XV920K and MK front and rear. Their 3-wire design allows them to be used as both “always-on” running lights as well as performing the flasher function. Models not originally using their turn signals as running lights can be converted by tapping into the rear brake system running light circuit (usually a blue wire) and running that wire to the running light wire lead (the red wire) on these turn signals. Note that REAR signals on these models can also be modified to perform this same “flashers + running lights” function via the use of these signal units, but originally rear signal lights were never allowed to operate as “running” (always-on) lights, and in most (perhaps all) states, this restriction still applies for street-legal bikes. You should check your local laws for the use of these style signals on the rear of any bike (typically, they are always legal for use on the front of a bike).
    b) these turn signals have the correct shape and fitment for the XJ650 Midnight Maxim, XJ750 Midnight Maxim, and XV920 Midnight Virago models, but they have the chrome housing rather than the black housing used on Midnight versions.
    c) 1980-81 XJ650 Maxim and XJ650 Midnight Maxim models (and some XV535 and XV750 Virago models) used a single-wire (positive only) design on both the front and rear turn signals, and that style signal used the turn signal housing and mounting stalk as the bulb socket ground. The above HCP1683 turn signals are a 2-wire (positive and ground) design and require the use of the ground wire to operate properly. Original rear turn signals on these models actually used a separate ground wire from the stalk to the sub-harness, and the ground wire on these replacement units will fit directly in place to that terminal (i.e. you will eliminate the separate ground wire, and plug the ground wire on this signal unit into the same place that the original separate wire was plugged into). On the front turn signals, you will have to locate and terminate the turn signal ground wires to a suitable location. Most XJ650 Maxim models have an un-used, double-female ground (black) wire terminal inside the headlight housing (bucket), and if your bike has that un-used terminal, that would be the ideal place to install the ground wires on these signal units for the front signals. Otherwise, you will need to find another place/method of locating a suitable ground.
    d) these signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive signaling lead is a solid black wire (odd, but true……) and the ground wire is a black wire with a white tracer stripe. The positive lead for the “always-on” running light is a solid red wire. Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    XJ600 Seca II models:
    HCP22740 OEM complete FRONT TURN SIGNAL ASSEMBLY, black rectangular housings, 3-wire design (flashers and running light), with a rounded rectangular orange lense and the black mounting stem. Original for use on the left front position on all of the following models: 1992-98 XJ600 Seca II, 1987 FZ700, 1986 and 1988 FZ750, 1987 FZR750R, 1987-95 FZR1000, and 1993 TDM850 models. Each:
    $ 139.95
    HCP22741 OEM complete FRONT TURN SIGNAL ASSEMBLY, black rectangular housings, 3-wire design (flashers and running light), with a rounded rectangular orange lense and the black mounting stem. Original for use on the right front position on all of the following models: 1992-98 XJ600 Seca II, 1987 FZ700, 1986 and 1988 FZ750, 1987 FZR750R, 1987-95 FZR1000, and 1993 TDM850 models. Each:
    $ 139.95
    HCP30062 Aftermarket DOT-approved complete FRONT TURN SIGNAL ASSEMBLY, black rectangular housings, 3-wire design (flashers and running light)), with a rounded rectangular orange lense, the black mounting stem, and the stem nut. Original for use on either the right or left front position on all of the following models: 1992-98 XJ600 Seca II, 1987 FZ700, 1986 and 1988 FZ750, 1987 FZR750R, 1987-95 FZR1000, and 1993 TDM850 models. NOTE: wire colors differ from originals, see below. Each:
    $ 29.95
    HCP22742 OEM complete REAR TURN SIGNAL ASSEMBLY, black rectangular housings, 2-wire design (flashers only), with a rounded rectangular orange lense and the black mounting stem. Original for use on the left rear position on all of the following models: 1992-98 XJ600 Seca II, 1986-90 YX600 Radian, 1988 and 1990 FZR400, 1986 SRX600, 1986-88 FZ600, 1989-94 and 1996-99 FZR600, 1986-87 FZX700 Fazer, 1987 FZR750R, 1987-95 FZR1000, 1986-1987 and 1989-93 FJ1200, and 1990-95 XT600 models. Each:
    $ 149.95
    HCP22743 OEM complete REAR TURN SIGNAL ASSEMBLY, black rectangular housings, 2-wire design (flashers only), with a rounded rectangular orange lense and the black mounting stem. Original for use on the right rear position on all of the following models: 1992-98 XJ600 Seca II, 1986-90 YX600 Radian, 1988 and 1990 FZR400, 1986 SRX600, 1986-88 FZ600, 1989-94 and 1996-99 FZR600, 1986-87 FZX700 Fazer, 1987 FZR750R, 1987-95 FZR1000, 1986-1987 and 1989-93 FJ1200, and 1990-95 XT600 models. Each:
    $ 149.95
    HCP10011 Aftermarket DOT-approved complete REAR TURN SIGNAL ASSEMBLY, black rectangular housings, 2-wire design (flashers only), with a rounded rectangular orange lense, the black mounting stem, and the stem nut. Original for use on either the left or right rear positions on all of the following models: 1992-98 XJ600 Seca II, 1986-90 YX600 Radian, 1988 and 1990 FZR400, 1986 SRX600, 1986-88 FZ600, 1989-94 and 1996-99 FZR600, 1986-87 FZX700 Fazer, 1987 FZR750R, 1987-95 FZR1000, 1986-1987 and 1989-93 FJ1200, and 1990-95 XT600 models. NOTE: wire colors differ from originals, see below. Each:
    $ 49.95
    NOTES on the HCP10011 and HCP30062 TURN SIGNAL UNITS:
    a) These signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive lead is a solid black wire (odd, but true……) and the ground wire is a black wire with a white tracer stripe. Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    XJ650 Turbo and XJ750-D models, front:
    HCP2051LH OEM complete front TURN SIGNAL ASSEMBLY, left side of fairing, contains the black plastic base housing, the orange lense, bulb socket and wiring lead-in harness. Fits all 1982-83 XJ650 Turbo models and XJ750-D models. Each:
    $ 489.95
    HCP2051RH OEM complete front TURN SIGNAL ASSEMBLY, right side of fairing, contains the black plastic base housing, the orange lense, bulb socket and wiring lead-in harness. Fits all 1982-83 XJ650 Turbo models and XJ750-D models. Each:
    $ 429.95
    FJ600, XJ650 Turbo (rear), XJ750 Seca and XJ750 Euro, XJ900 models:
    HCP7557 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, low gloss black rectangular housings, 2-wire design (flashers only), with "wrap-around" rectangular orange lense is correct for all of the following models: FJ600 front or rear, XJ650 Turbo rear, XJ750 Seca front or rear, XJ750-P Police (37H) front or rear, and some XJ900 models (some XJ900 models were equipped with chromed-housing units). Also fits all of the following models: 1982-83 XZ550 Vision front or rear, and 1984-85 FJ1100 front or rear. See the NOTES below regarding these turn signals. Each:
    $ 44.95
    HCP7557SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 82.95
    HCP7557SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 159.95
    NOTES ON HCP7557 SIGNAL UNITS:
    a) these turn signals are also the same shape and fitment for the XJ650 Turbo rear, XJ750 Seca front or rear, and XJ750-P Police (37H) models, 1982-83 XZ550 Vision front or rear, and 1984-85 FJ1100 front or rear. These signal units feature the low-gloss black housing rather than the chrome housing used originally on some of these models. For the chrome-housing version of these same lights, see part HCP7559 below.
    b) if you wish to convert the front signal lights to be used as both “always-on” running lights as well as performing the flasher function, you can use part HCP7558 (black housing) or HCP7562 (chrome housing). Models not originally using their turn signals as running lights can be converted by using either of those signal units, and then tapping into the rear brake system running light circuit (usually a blue wire) and running that wire to the running light wire lead (the red wire) on these turn signals. Note that REAR signals on these models can also be modified to perform this same “flashers + running lights” function via the use of these signal units, but originally rear signal lights were never allowed to operate as “running” (always-on) lights, and in most (perhaps all) states, this restriction still applies for street-legal bikes. You should check your local laws for the use of these style signals on the rear of any bike (typically, they are always legal for use on the front of a bike).
    HCP7559 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housings, 2-wire design (flashers only), with "wrap-around" rectangular orange lense is correct for all of the following models: some XJ900 models (some XJ900 models were equipped with flat black finished housings). Also fits all of the following models: 1982-83 XZ550 Vision front or rear, and 1984-85 FJ1100 front or rear. See the NOTES below regarding these turn signals. Each:
    $ 44.95
    HCP7559SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 82.95
    HCP7559SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 159.95
    NOTES ON HCP7559 SIGNAL UNITS:
    a) these turn signals are also the same shape and fitment for the XJ650 Turbo rear, XJ750 Seca front or rear, and XJ750-P Police (37H) models, 1982-83 XZ550 Vision front or rear, and 1984-85 FJ1100 front or rear. These signal units feature the shiny chrome housing rather than the low gloss black housing used originally on some of these models. For the low-gloss black housing version of these same lights, see part HCP7557 above.
    HCP7558 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, low gloss black rectangular housings, 3-wire design (flashers and running lights), with "wrap-around" rectangular orange lense can be used to upgrade the stock “flashers only” signal units on all of the following models: FJ600 front, XJ750 Seca front, and XJ750-P Police (37H) front, most XJ900 models front, 1982-83 XZ550 Vision front, and 1984-85 FJ1100 front. See the NOTES below regarding these turn signals. Each:
    $ 44.95
    HCP7558SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 82.95
    HCP7558SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 159.95
    NOTES ON HCP7558 SIGNAL UNITS:
    a) these turn signals are the same design and style and will fit all of the following bikes: FJ600 front or rear, XJ650 Turbo rear, XJ750 Seca front or rear, and XJ750-P Police (37H) front or rear, most XJ900 models front or rear, 1982-83 XZ550 Vision front or rear, and 1984-85 FJ1100 front or rear. The 3-wire design of these signal units allows them to be used as both “always-on” running lights as well as performing the flasher function. Models not originally using their turn signals as running lights can be converted by tapping into the rear brake system running light circuit (usually a blue wire) and running that wire to the running light wire lead (the red wire) on these turn signals. Note that REAR signals on these models can also be modified to perform this same “flashers + running lights” function via the use of these signal units, but originally rear signal lights were never allowed to operate as “running” (always-on) lights, and in most (perhaps all) states, this restriction still applies for street-legal bikes. You should check your local laws for the use of these style signals on the rear of any bike (typically, they are always legal for use on the front of a bike).
    b) For the chrome-housing version of these same lights, see part HCP7562 below.
    c) these turn signals come with a flexible black plastic protective sheathing over the wire harness lead wires. However, this sheathing is difficult, if not impossible, to force through the rubber turn signal mounting stays as used on the these models. Thus, we recommend that you remove the sheathing from the wire harness lead (it slides off) before installation. However, be aware that once the sheathing is removed from the wire leads, it is very difficult (if not impossible) to re-install it! The sheathing will fit through the front (only) turn signal mounting "covers" used on the XJ750 Seca models.
    HCP7562 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housings, 3-wire design (flashers and running lights), with "wrap-around" rectangular orange lense can be used to upgrade the stock “flashers only” signal units on all of the following models: FJ600 front, XJ750 Seca front, and XJ750-P Police (37H) front, most XJ900 models front, 1982-83 XZ550 Vision front, and 1984-85 FJ1100 front. See the NOTES below regarding these turn signals. Each:
    $ 44.95
    HCP7562SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 82.95
    HCP7562SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 159.95
    NOTES ON HCP7562 SIGNAL UNITS:
    b) For the low-gloss black housing version of these same lights, see part HCP7558 above.
    XJ550 Seca and 1982 XJ750 Maxim models:
    HCP7568 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housings, 2-wire design (flashers only), with a flat rectangular orange lense. Original for use on either the left or right side on all of the following models: XJ550 Seca front or rear, 1982 XJ750 Maxim front or rear, and 1982 XV920 J Virago rear. Will also fit 1982 XV920J Virago models in the front, but the will not have the “running lights” feature as originally used on the front signals of this model (use HCP7569 for the correct application). Each:
    $ 44.95
    HCP7568SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 82.95
    HCP7568SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 159.95
    NOTES ON HCP7568 SIGNAL UNITS:
    XJ700 all and XJ750-X models:
    HCP2053 OEM complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 3-wire design (flashers and running lights), with "bevel-top" round orange lense is correct for all of the following models: XJ700 and XJ750-X all models front. Also fits all of the following models: 1990, 1993, 1995-97, 1999-2000 XV535 Virago front, 1984-87 XV700 front, 1988-97 XV750 front, 1986-99 XV1100 front, 1984-86 and 1988-2004 VMX12 V-Max front, and 1999-02 XV1600 Road Star front. See the NOTES below regarding these turn signals. Each:
    $ 69.95
    HCP7560SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 129.95
    HCP7560 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 3-wire design (flashers and running lights), with "bevel-top" round orange lense is correct for all of the following models: XJ700 and XJ750-X all models front. Also fits all of the following models: 1990, 1993, 1995-97, 1999-2000 XV535 Virago front, 1984-87 XV700 front, 1988-97 XV750 front, 1986-99 XV1100 front, 1984-86 and 1988-2004 VMX12 V-Max front, and 1999-02 XV1600 Road Star front. See the NOTES below regarding these turn signals. Each:
    $ 54.95
    $ 99.95
    NOTES ON HCP2053 and HCP7560 SIGNAL UNITS:
    a) these turn signals are the same design and style as the stock signal units for the models listed above, which were originally a 3-wire (flashers and always-on running lights) design. The following models, which do not originally use their front turn signals as running lights, can be converted by tapping into the rear brake system running light circuit (usually a blue wire) and running that wire to the running light wire lead (the red wire) on these turn signals: 1995-2010 and 2012-19 XV250 Virago front and rear, 1990, 1993, 1995-97, 1999-2000 XV535 Virago rear, 1984-87 XV700 rear, 1988-97 XV750 rear, 1986-99 XV1100 rear, 2000-03 XVS1100 front (some were 2-wire, some 3-wire originally), 2000-03 XVS1100 rear (some were 2-wire, some 3-wire originally), 1984-86 VMX12 V-Max rear, 1988-04 VMX12 V-Max rear, and 1999-02 XV1600 Road Star rear. Note that REAR signals on these models can also be modified to perform this same “flashers + running lights” function via the use of these signal units, but originally rear signal lights were never allowed to operate as “running” (always-on) lights, and in most (perhaps all) states, this restriction still applies for street-legal bikes. You should check your local laws for the use of these style signals on the rear of any bike (typically, they are always legal for use on the front of a bike).
    b) these turn signals come with a flexible black plastic protective sheathing over the wire harness lead wires. However, this sheathing is difficult, if not impossible, to force through the rubber turn signal mounting stays as used on the XJ700 and XJ750-X (front and rear) models. Thus, we recommend that you remove the sheathing from the wire harness lead (it slides off) before installation. However, be aware that once the sheathing is removed from the wire leads, it is very difficult (if not impossible) to re-install it!
    c) these signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive signaling lead is a solid black wire (odd, but true……) and the ground wire is a black wire with a white tracer stripe. The positive lead for the “always-on” running light is a solid red wire. Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    HCP2046 OEM complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 2-wire design (flashers only), with "bevel-top" round orange lense is correct for all of the following models: XJ700 and XJ750-X all models rear. Also fits all of the following models: 1995-2010 2012-19 XV250 Virago front or rear, 1990, 1993, 1995-97, 1999-2000 XV535 rear, 1984-87 XV700 rear, 1988-97 XV750 rear, 1986-99 XV1100 rear, 1984-86 and 1988-2004 VMX12 V-Max rear, and 1999-02 XV1600 Road Star rear. See the NOTES below regarding these turn signals. Each:
    $ 139.95
    HCP2046SET2 OEM TURN SIGNAL ASSEMBLIES, set of 2:
    $ 249.95
    HCP7561 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome round housings, 2-wire design (flashers only), with "bevel-top" round orange lense is correct for all of the following models: XJ700 and XJ750-X all models rear. Also fits all of the following models: 1995-2010 2012-19 XV250 Virago front or rear, 1990, 1993, 1995-97, 1999-2000 XV535 rear, 1984-87 XV700 rear, 1988-97 XV750 rear, 1986-99 XV1100 rear, 1984-86 and 1988-2004 VMX12 V-Max rear, and 1999-02 XV1600 Road Star rear. See the NOTES below regarding these turn signals. Each:
    $ 69.95
    HCP7561SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 119.95
    NOTES ON HCP2046 and HCP7561 SIGNAL UNITS:
    a) these turn signals are also the same design and style as the front turn signals used on all of the models listed above, which were originally a 3-wire (flashers and running lights) design. The 2-wire design of these signals allows them to be used as flasher light only. They are the same housing style and design as the HCP2053 or HCP7560 lights listed above (3-wire, flashers and always-on running lights) front turn signal, and can be used as front lights on all of these bikes, but you will lose the running lights feature.
    b) These signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive lead is a solid black wire (odd, but true……) and the ground wire is a black wire with a white tracer stripe. Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    XS1100 models:
    HCP27535 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housing, 2-wire design (hot wires only; the bulb socket grounds through the support post), with a rectangular orange lense. Correct for all XS1100 Standard models front. See the NOTES below regarding these turn signals. Each:
    $ 49.95
    HCP27536SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 94.95
    NOTES ON HCP27535 SIGNAL UNITS:
    a) these turn signals are the same design and style as the front turn signals originally used on all XS1100 Standard models, which originally is a 2-wire design (with separate hot wires for the signaling and the “park” light feature), and used the turn signal mounting stalk as the bulb socket ground.
    b) these signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive signaling lead is a solid black wire (odd, but true……) and the “park” light function is the red wire (which is the blue wire on your original signal harness). Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    HCP27536 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housing, 1-wire design (hot wire only; the bulb socket grounds through the support post), with a rectangular orange lense. Correct for all XS1100 Standard models rear. See the NOTES below regarding these turn signals. Each:
    $ 49.95
    $ 94.95
    NOTES ON HCP27536 SIGNAL UNITS:
    a) these turn signals are the same design and style as the front turn signals originally used on all XS1100 Standard models, which originally a 1-wire (hot wire only) design, and used the turn signal stalk and a separate ground wire from the stalk to the sub-harness as the bulb socket ground.
    b) these signal units do not have the correct color-coded hot wires to distinguish the left (originally: dark brown) from the right (originally: dark green) signal units as original. Wire colors on these replacement turn signals are as follows: the positive signaling lead is a solid black wire (odd, but true……). Just make sure that you hook up your left turn signal positive lead (the solid black wire coming out of the signal assy.) to the DARK BROWN wire on your main harness, and for the right side turn signal, use the positive lead coming out of the signal assy. (again, the solid black wire) to the DARK GREEN wire on your main harness. NOTE: the original DARK brown and DARK green wires are just that: DARK......very, very dark colors, that can easily appear as black wires in poor lighting and years of accumulated grunge and dirt on them, so please make sure to check the wire colors carefully during the wire hook-up process.
    HCP27537 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housing, 1-wire design (hot wire only; the bulb socket grounds through the support post), with the unique “bullet nose” round orange lense. Original for all of the following models: all XS1100 Special models front, left or right sides. Can also be used on the front of all XS1100 Midnight Special models, 1980-81 XS850 Midnight Special, and 1982 SX650 SJ models, but the housing is chrome rather than black. Is also correct for all of the following models: 1979-81 XS400 all models front left or right, 1980-81 XS400 Special front left or right, 1975-1978 XS500 front left or right, 1977-1979 XS650 front left or right, 1980-1981 XS650 Special II front left or right, 1978-1981 XS650S Special front left or right, 1982 XS650 Heritage Special front left or right, 1977-79 XS750 all models front left or right, 1980-81 XS850 all Standard and Special models front left or right, 1978-81 SR500 front left or right, 1973-74 TX650 front left or right, and 1974 TX750 front left or right. Each:
    $ 39.95
    HCP27537SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 74.95
    NOTES ON HCP27537 SIGNAL UNITS:
    a) these turn signals are the same design and style as the front turn signals originally used on all XS1100 Special models, which originally a 1-wire (hot wire only) design, and used the turn signal stalk and a separate ground wire from the stalk to the sub-harness as the bulb socket ground.
    HCP27538 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housing, 1-wire design (hot wire only; the bulb socket grounds through the support post), with the unique “bullet nose” round orange lense. Original for all of the following models: all XS1100 Special models rear, left or right sides. Can also be used on the rear of all XS1100 Midnight Special models, 1980-81 XS850 Midnight Special, and 1982 SX650 SJ models, but the housing is chrome rather than black. Is also correct for all of the following models: 1979-81 XS400 all models front left or right, 1980-81 XS400 Special front left or right, 1975-1978 XS500 front left or right, 1977-1979 XS650 front left or right, 1980-1981 XS650 Special II front left or right, 1978-1981 XS650S Special front left or right, 1982 XS650 Heritage Special front left or right, 1977-79 XS750 all models front left or right, 1980-81 XS850 all Standard and Special models front left or right, 1978-81 SR500 front left or right, 1973-74 TX650 front left or right, and 1974 TX750 front left or right. Each:
    $ 39.95
    HCP27538SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 74.95
    NOTES ON HCP27538 SIGNAL UNITS:
    a) these turn signals are the same design and style as the rear turn signals originally used on all XS1100 Special models, which originally a 1-wire (hot wire only) design, and used the turn signal stalk and a separate ground wire from the stalk to the sub-harness as the bulb socket ground.
    other models:
    HCP7569 Aftermarket DOT-approved complete TURN SIGNAL ASSEMBLY, polished chrome rectangular housings, 3-wire design (flashers and running lights), with a flat rectangular orange lense. Correct for 1982 XJ920J Virago models in the front. See the NOTES below regarding these turn signals. Each:
    $ 44.95
    HCP7569SET2 Aftermarket TURN SIGNAL ASSEMBLIES, set of 2:
    $ 82.95
    HCP7569SET4 Aftermarket TURN SIGNAL ASSEMBLIES, set of 4:
    $ 159.95
    NOTES ON HCP7569 SIGNAL UNITS:
    a) these turn signals are the same design and style as the stock signal units for the 1982 XV920J model, which were originally a 3-wire (flashers and always-on running lights) design. The following models, which do not originally use their front turn signals as running lights and were originally a 2-wire (flashers only) design, can be converted “flashers and always-on running lights” type of signal by tapping into the rear brake system running light circuit (usually a blue wire) and running that wire to the running light wire lead (the red wire) on these turn signals: XJ550 Seca front, 1982 XJ750 Maxim front, and 1982 XV920 J Virago. Note that REAR signals on these models can also be modified to perform this same “flashers + running lights” function via the use of these signal units, but originally rear signal lights were never allowed to operate as “running” (always-on) lights, and in most (perhaps all) states, this restriction still applies for street-legal bikes. You should check your local laws for the use of these style signals on the rear of any bike (typically, they are always legal for use on the front of a bike).
    b) these turn signals come with a flexible black plastic protective sheathing over the wire harness lead wires. However, this sheathing is difficult, if not impossible, to force through the rubber turn signal mounting stays as used on the XJ550 Seca (front and rear) and XJ750 Maxim (rear) models. Thus, we recommend that you remove the sheathing from the wire harness lead (it slides off) before installation. However, be aware that once the sheathing is removed from the wire leads, it is very difficult (if not impossible) to re-install it! The sheathing will fit through the front (only) turn signal mounting "covers" used on the XJ750 Maxim models.
    TURN SIGNAL LENSE:
    HCP712 OEM front or rear turn signal rectangular flat orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ550 Seca and 1982 XJ750 Maxim models. Also fits the following models: 1982 XS400 RJ/RK front or rear, 1982 XV920J Virago front or rear, 1984 Riva 50 front or rear, and 1984-87 Riva 80 front or rear. Each:
    $ 16.95
    HCP712SET4 OEM front or turn signal LENSES, set of 4:
    $ 64.95
    HCP7567 Aftermarket front or rear turn signal rectangular flat orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ550 Seca and 1982 XJ750 Maxim models. Also fits the following models: 1982 XS400 RJ/RK front or rear, 1982 XV920J Virago front or rear, 1984 Riva 50 front or rear, and 1984-87 Riva 80 front or rear. Each:
    $ 14.95
    HCP7567SET4 Aftermarket front or turn signal LENSES, set of 4:
    $ 49.95
    HCP10012 Aftermarket front or rear turn signal rectangular flat orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fit the following models: 1992-98 XJ600 Seca II front and rear, 1986-90 YX600 Radian rear, 1988 and 1990 FZR400 rear, 1986 SRX600 rear, 1986-88 FZ600 rear, 1989-94 and 1996-99 FZR600 rear, 1989-94 and 1996-99 FZR600 rear, 1987 FZ700 front, 1986-87 FZX700 Fazer rear, 1986 and 1988 FZ750 front, 1987 FZR750R front and rear, 1993 TDM850 front, 1987-95 FZR1000 front and rear, 1986-1987 and 1989-93 FJ1200 rear, and 1990-95 XT600 rear. Each:
    $ 11.95
    HCP10012SET4 Aftermarket front or turn signal LENSES, set of 4:
    $ 39.95
    HCP713 OEM front or rear turn signal round "flat-top" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ550 Maxims, all XJ650 (except Turbo) models, all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Also fits the front and rear signals of all of the following models: 1988-90 XV250 Route 66, 1983 XV500 Virago, 1987-88 XV535 Virago, 1981-83 XV750 Virago, 1981-82 XV920 RH/RJ Virago, 1983 XV920K, 1983 XV920MK, and 1982-83 XS400 J/K.models. Each:
    $ 13.95
    HCP713SET4 OEM front or turn signal LENSES, set of 4:
    $ 49.95
    HCP7564 Aftermarket front or rear turn signal round "flat-top" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ550 Maxims, all XJ650 (except Turbo) models, all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Also fits the front and rear signals of all of the following models: 1988-90 XV250 Route 66, 1983 XV500 Virago, 1987-88 XV535 Virago, 1981-83 XV750 Virago, 1981-82 XV920 RH/RJ Virago, 1983 XV920K, 1983 XV920MK, and 1982-83 XS400 J/K.models. Each:
    $ 11.95
    HCP7564ET4 Aftermarket front or turn signal LENSES, set of 4:
    $ 39.95
    HCP2777 OEM front wedge-shaped orange plastic turn signal LENSE. Brand new, correct orange color, DOT-approved. Fits the right side on all XJ650 Turbo models. Each:
    $ 239.95
    HCP2778 OEM front wedge-shaped orange plastic turn signal LENSE. Brand new, correct orange color, DOT-approved. Fits the left side on all XJ650 Turbo models. Each:
    $ 249.95
    HCP22747 OEM left front or right rear turn signal rectangular orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits all 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models. Also fits all of the following models: 1988-90 FZR400 1988-1990 front and rear, 1989 FZR600 front and rear, 1989-99 FZR600R front and rear, 1986-87 FZX700 Fazer front and rear, 1988 FZ750 1988 front and rear, 1987-88 FZR750R front and rear, 1987-95 FZR1000 front and rear, 1986-87 FJ1200 rear only, 1987 SRX250 front and rear, 1992-93 TDM850 front and rear, 1987-05 TW200 and TW200 Trailway front and rear, XT225 1992-2005 front and rear, 1992-05 XT225 Serow front and rear, 1990-95 XT600E front and rear, 1987-92 YSR50 front and rear. Eac:
    $ 12.95
    HCP22748 OEM right front or left rear turn signal rectangular orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits all 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models. Also fits all of the following models: 1988-90 FZR400 1988-1990 front and rear, 1989 FZR600 front and rear, 1989-99 FZR600R front and rear, 1986-87 FZX700 Fazer front and rear, 1988 FZ750 1988 front and rear, 1987-88 FZR750R front and rear, 1987-95 FZR1000 front and rear, 1986-87 FJ1200 rear only, 1987 SRX250 front and rear, 1992-93 TDM850 front and rear, 1987-05 TW200 and TW200 Trailway front and rear, XT225 1992-2005 front and rear, 1992-05 XT225 Serow front and rear, 1990-95 XT600E front and rear, 1987-92 YSR50 front and rear. Each:
    $ 12.95
    HCP27556 Aftermarket front or rear turn signal orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all 1986-88 FZ600, 1986-90 YX600 Radian, and 1992-98 XJ600 Seca II models. Also fits all of the following models: 1988-90 FZR400 1988-1990 front and rear, 1989 FZR600 front and rear, 1989-99 FZR600R front and rear, 1986-87 FZX700 Fazer front and rear, 1988 FZ750 1988 front and rear, 1987-88 FZR750R front and rear, 1987-95 FZR1000 front and rear, 1986-87 FJ1200 rear only, 1987 SRX250 front and rear, 1992-93 TDM850 front and rear, 1987-05 TW200 and TW200 Trailway front and rear, XT225 1992-2005 front and rear, 1992-05 XT225 Serow front and rear, 1990-95 XT600E front and rear, 1987-92 YSR50 front and rear. Each:
    $ 11.95
    HCP27556SET4 Aftermarket front or rear turn signal orange plastic LENSE, set of 4:
    $ 39.95
    HCP714 OEM front or rear turn signal round "beveled-top" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ700 and XJ750-X models. Also fits all of the following models: 1999-05 XV250 Virago models front and rear, 1987, 1990, 1993-99 XV535 Virago and XV535 Special models front and rear, 1999-04 XVS650 V-Star Custom and Classic models front and rear, 2003-04 XVS650 V-Star Silverado models front and rear, 1984-87 and 1997 XV700 Virago models front and rear, 1985-97 XV750 Virago models front and rear, 1984-85 and 1989-96 XV1000 Virago models front and rear, 1986-88 and 1996-98 XV1100S Virago Special models front and rear, 1985-86 and 1988 VMX12 V-Max models front and rear, and 1984-86 and 1998-04 VMX1200 V-Max models front and rear. Each:
    $ 14.95
    HCP714SET4 OEM front or turn signal LENSES, set of 4:
    $ 54.95
    HCP7566 Aftermarket front or rear turn signal round "beveled-top" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ700 and XJ750-X models. Also fits all of the following models: 1999-05 XV250 Virago models front and rear, 1987, 1990, 1993-99 XV535 Virago and XV535 Special models front and rear, 1999-04 XVS650 V-Star Custom and Classic models front and rear, 2003-04 XVS650 V-Star Silverado models front and rear, 1984-87 and 1997 XV700 Virago models front and rear, 1985-97 XV750 Virago models front and rear, 1984-85 and 1989-96 XV1000 Virago models front and rear, 1986-88 and 1996-98 XV1100S Virago Special models front and rear, 1985-86 and 1988 VMX12 V-Max models front and rear, and 1984-86 and 1998-04 VMX1200 V-Max models front and rear. Each:
    $ 11.95
    HCP7566SET4 Aftermarket front or turn signal LENSES, set of 4:
    $ 39.95
    HCP715 OEM front or rear turn signal rectangular "wrap-around" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits front and rear on FJ600 models, the rear turn signals on all XJ650 Turbo models, and both the front and rear signal lights on all XJ750 Seca, XJ750-P Police (37H), and all XJ900RK, RL, N/FN, and F models. Also fits the following models: 1982-83 XZ550 RJ/RK Vision front or rear, and 1984-1985 FJ1100 front or rear. Each:
    $ 19.95
    HCP715SET4 OEM front or turn signal LENSES, set of 4:
    $ 72.95
    HCP7565 Aftermarket front or rear turn signal rectangular "wrap-around" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits front and rear on FJ600 models, the rear turn signals on all XJ650 Turbo models, and both the front and rear signal lights on all XJ750 Seca, XJ750-P Police (37H), and all XJ900RK, RL, N/FN, and F models. Also fits the following models: 1982-83 XZ550 RJ/RK Vision front or rear, and 1984-1985 FJ1100 front or rear. Each:
    $ 16.95
    HCP7565SET4 Aftermarket front or turn signal LENSES, set of 4:
    $ 59.95
    HCP27546 OEM front or rear turn signal round rectangular orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ1100 Standard models. Each:
    $ discontinued
    HCP27546SET4 OEM front or rear turn signal round rectangular orange plastic LENSE. Set of 4:
    $ discontinued
    HCP27545 Aftermarket front or rear turn signal round rectangular orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ1100 Standard models. Each:
    $ 12.95
    HCP27545SET4 Aftermarket front or rear turn signal round "bevel-top" orange plastic LENSE. Set of 4:
    $ 39.95
    HCP27544 OEM front or rear turn signal round "bullet nose" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ1100 Special models. Each:
    $ 19.95
    HCP27544SET4 OEM front or rear turn signal round "bullet nose" orange plastic LENSE. Set of 4:
    $ 74.95
    HCP27554 OEM front or rear turn signal round "bullet nose" orange plastic LENSE. Brand new, correct orange color, DOT-approved. Fits both the front and rear flasher lights on all XJ1100 Special models. Also fits all of the following models: 1970 XS1/1B front and rear, 1972 XS2 front and rear, 1976-77 XS360 front and rear, 1979-81 XS400 all models front and rear, 1980-81 XS400 Special models front and rear, 1975-78 XS500 models front and rear, 1975 XS650 front and rear, 1977-83 XS650 D/SE/SE_11/SF/2F/G/SG/H/SH/SJ/SK front and rear, 1977-79 XS650 front and rear, 1980-81 XS650 Special II models front and rear, 1978-81 XS650S Special models front and rear, 1977-79 XS750 all models front and rear, 1980-81 XS850 all models front and rear, 1974-83 DT100 models front and rear, 1974-80 DT125 models front and rear, 1974-81 DT175 models front and rear, 1974 1976-79 DT250 models front and rear, 1974 DT360 models front and rear, 1976-78 DT400 models front and rear, 1980-83 XT250 models front and rear, 1976-81 XT500 models front and rear, 1973-75 RD250 models front and rear, 1973-75 RD350 models front and rear, 1976-79 RD400 models front and rear, 1978-81 SR500 models front and rear, 1973-74 TX500 models front and rear, 1973-74 TX650 models front and rear, and 1974 TX750 models front and rear. Each:
    $ 11.95
    HCP27554SET4 OEM front or rear turn signal round "bullet nose" orange plastic LENSE. Set of 4:
    $ 42.95
    Turn Signal Lense Gasket:
    These die-cut rubber or foam gaskets prevents moisyure intrusion into the signal housing, preventing cloudiness on the reflector and and rust on the bulb socket.
    HCP1968 OEM front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all XJ550 Maxims, all XJ650 (except Turbo) models, all XJ700 models, all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Also fits all of the following models: 1988-90 XV250 Route 66 front and rear, 1983 XV500 Virago front and rear, 1987-88 XV535 Virago front and rear, 1981-83 XV750 Virago front and rear, 1981-82 XV920 RH/RJ Virago front and rear, 1983 XV920K front and rear, 1983 XV920MK rear, and 1982-83 XS400 J/K front and rear. Each:
    $ 8.95
    HCP1968SET4 OEM front or turn signal GASKETS, set of 4:
    $ 34.95
    HCP18359 Aftermarket front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all XJ550 Maxims, all XJ650 (except Turbo) models, all XJ700 models, all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Also fits all of the following models: 1988-90 XV250 Route 66 front and rear, 1983 XV500 Virago front and rear, 1987-88 XV535 Virago front and rear, 1981-83 XV750 Virago front and rear, 1981-82 XV920 RH/RJ Virago front and rear, 1983 XV920K front and rear, 1983 XV920MK rear, and 1982-83 XS400 J/K front and rear. Each:
    $ 6.95
    HCP18359SET4 Aftermarket front or rear turn signal GASKETS, set of 4:
    $ 24.95
    HCP15588 Aftermarket front turn signal lense adhesive-backed, foam rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits triangular-shaped, left front flasher lense housing on all XJ650 Turbo, XJ750-D, and XJ750D-II models only. Each:
    $ 12.95
    HCP15589 Aftermarket front turn signal lense adhesive-backed, foam rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits triangular-shaped right front flasher lense housing on all XJ650 Turbo, XJ750-D, and XJ750D-II models only. Each:
    $ 12.95
    HCP16362-13 OEM front turn signal housing upper edge black rubber EDGE TRIM, enough material to cover the entire upper edge length of one housing, correct for all XJ650 Turbo, XJ750-D, and XJ750D-II models only.
    $ 9.95
    HCP16362-26 OEM front turn signal housing upper edge black rubber EDGE TRIM, enough material to cover the entire upper edge length of both the left and right turn signal housings, correct for all XJ650 Turbo, XJ750-D, and XJ750D-II models only.
    $ 16.95
    HCP678SET3 Aftermarket front turn signal housing upper edge flexible plastic EDGE TRIM, gloss black finish. A 3-foot length which is enough to cover the entire upper edge length of both the left and right turn signal housings, correct for all XJ650 Turbo, XJ750-D, and XJ750D-II models only.
    $ 13.95 per 3-foot length
    HCP1972 OEM front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits front and rear on 1982-83 XZ550RJ/RK Vision, 1984-85 FJ600 models, the rear turn signals on all XJ650 Turbo models, front and rear signal lights on all 1981-83 XJ750 Seca, XJ750-P Police (37H), all XJ900RK, RL, N/FN, and F models, and 1984-85 FJ1100 front and rear.. Each:
    $ 11.95
    HCP1972SET4 OEM front or turn signal GASKETS, set of 4:
    $ 44.95
    HCP17562 Aftermarket front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits front and rear on 1982-83 XZ550RJ/RK Vision, 1984-85 FJ600 models, the rear turn signals on all XJ650 Turbo models, front and rear signal lights on all 1981-83 XJ750 Seca, XJ750-P Police (37H), all XJ900RK, RL, N/FN, and F models, and 1984-85 FJ1100 front and rear.. Each:
    $ 9.95
    HCP17562SET4 Aftermarket front or turn signal GASKETS, set of 4:
    $ 29.95
    HCP1969 OEM front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits the front or rear turn signals on all XJ550 Seca and 1982 XJ750 Maxim models. Also fits the following models: 1982 XS400RJ/RK Seca front or rear, 1982 XV920K Virago front or rear, 1984 Riva 50 front or rear, and 1984-87 Riva 80 front or rear. Each:
    $ discontinued
    HCP1969SET4 OEM front or turn signal GASKETS, set of 4:
    $ discontinued
    HCP8581 Aftermarket front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits the front or rear turn signals on all XJ550 Seca and 1982 XJ750 Maxim models. Also fits the following models: 1982 XS400RJ/RK Seca front or rear, 1982 XV920K Virago front or rear, 1984 Riva 50 front or rear, and 1984-87 Riva 80 front or rear. Each:
    $ 5.95
    HCP8581SET4 Aftermarket front or turn signal GASKETS, set of 4:
    $ 21.95
    HCP27547 OEM front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all XS1100 Standard models. Each:
    $ discontinued
    HCP27547SET4 OEM front or turn signal GASKETS, set of 4:
    $ discontinued
    HCP27548 Aftermarket front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all XS1100 Standard models. Each:
    $ 5.95
    HCP27548SET4 Aftermarket front or rear turn signal GASKETS, set of 4:
    $ 21.95
    HCP27543 OEM front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all XJ1100 Special models. Also fits all of the following models: 1970 XS1/1B front and rear, 1972 XS2 front and rear, 1976-77 XS360 front and rear, 1979-81 XS400 all models front and rear, 1980-81 XS400 Special models front and rear, 1975-78 XS500 models front and rear, 1975 XS650 front and rear, 1977-83 XS650 D/SE/SE_11/SF/2F/G/SG/H/SH/SJ/SK front and rear, 1977-79 XS650 front and rear, 1980-81 XS650 Special II models front and rear, 1978-81 XS650S Special models front and rear, 1977-79 XS750 all models front and rear, 1980-81 XS850 all models front and rear, 1974-83 DT100 models front and rear, 1974-80 DT125 models front and rear, 1974-81 DT175 models front and rear, 1974 1976-79 DT250 models front and rear, 1974 DT360 models front and rear, 1976-78 DT400 models front and rear, 1980-83 XT250 models front and rear, 1976-81 XT500 models front and rear, 1973-75 RD250 models front and rear, 1973-75 RD350 models front and rear, 1976-79 RD400 models front and rear, 1978-81 SR500 models front and rear, 1973-74 TX500 models front and rear, 1973-74 TX650 models front and rear, and 1974 TX750 models front and rear. Each:
    $ discontinued
    HCP27543SET4 OEM front or turn signal GASKETS, set of 4:
    $ discontinued
    HCP27555 Aftermarket front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all XJ1100 Special models. Also fits all of the following models: 1970 XS1/1B front and rear, 1972 XS2 front and rear, 1976-77 XS360 front and rear, 1979-81 XS400 all models front and rear, 1980-81 XS400 Special models front and rear, 1975-78 XS500 models front and rear, 1975 XS650 front and rear, 1977-83 XS650 D/SE/SE_11/SF/2F/G/SG/H/SH/SJ/SK front and rear, 1977-79 XS650 front and rear, 1980-81 XS650 Special II models front and rear, 1978-81 XS650S Special models front and rear, 1977-79 XS750 all models front and rear, 1980-81 XS850 all models front and rear, 1974-83 DT100 models front and rear, 1974-80 DT125 models front and rear, 1974-81 DT175 models front and rear, 1974 1976-79 DT250 models front and rear, 1974 DT360 models front and rear, 1976-78 DT400 models front and rear, 1980-83 XT250 models front and rear, 1976-81 XT500 models front and rear, 1973-75 RD250 models front and rear, 1973-75 RD350 models front and rear, 1976-79 RD400 models front and rear, 1978-81 SR500 models front and rear, 1973-74 TX500 models front and rear, 1973-74 TX650 models front and rear, and 1974 TX750 models front and rear. Each:
    $ 6.95
    HCP27555SET4 Aftermarket front or rear turn signal GASKETS, set of 4:
    $ 22.95
    HCP27628 Aftermarket front or rear turn signal lense rubber GASKET. Keeps moisture out, prevents socket corrosion and bulb failure. Fits both the front and rear flasher lights on all 1977-83 DT100, 1978-81 DT125, 1978-81 DT175, 1977-79 DT250, 1977-78 DT400, 1980-83 XT250, and 1977-81 XT500 models. Each:
    $ 7.95
    HCP27628SET4 Aftermarket front or rear turn signal GASKETS, set of 4:
    $ 24.95
    Turn Signal Lense Screws:
    tsl4) OEM and aftermarket turn signal lense MOUNTING SCREWS perfectly replaces rusted or stripped originals for the factory-new look.
    HCP3700 OEM turn signal lense SCREW, dark grey phosphate finish phillips-drive screws. Used on the following models: XJ550 Maxim front and rear, XJ650 Maxim and Midnight Maxim front and rear, XJ650RJ Seca front and rear, 1983 XJ750 Maxim and Midnight Maxim front and rear, and XJ1100 models front and rear. NOTE: original screws were bright plated. Each:
    $ 1.95
    HCP6667 Aftermarket turn signal lense SCREW, bright zinc-plated alloy steel, phillips-drive screws. Used on the following models: XJ550 Maxim front and rear, XJ650 Maxim and Midnight Maxim front and rear, XJ650RJ Seca front and rear, 1983 XJ750 Maxim and Midnight Maxim front and rear, and XJ1100 models front and rear. NOTE: original screws were bright plated. Each:
    $ 1.95
    HCP6669 Aftermarket turn signal lense SCREW, bright plated, 18-8 stainless steel, phillips-drive screws. Used on the following models: XJ550 Maxim front and rear, XJ650 Maxim and Midnight Maxim front and rear, XJ650RJ Seca front and rear, 1983 XJ750 Maxim and Midnight Maxim front and rear, and XJ1100 models front and rear. NOTE: original screws were bright plated. Each:
    $ 2.95
    HCP6670 Aftermarket turn signal lense SCREW, black oxide-coated alloy steel, socket-head (hex-drive) screws. Used on the following models: XJ550 Maxim front and rear, XJ650 Maxim and Midnight Maxim front and rear, XJ650RJ Seca front and rear, 1983 XJ750 Maxim and Midnight Maxim front and rear, and XJ1100 models front and rear. Each:
    $ 1.95
    HCP6671 Aftermarket turn signal lense SCREW, bright plated, 18-8 stainless steel, socket-head (hex-drive) screws. Used on the following models: XJ550 Maxim front and rear, XJ650 Maxim and Midnight Maxim front and rear, XJ650RJ Seca front and rear, 1983 XJ750 Maxim and Midnight Maxim front and rear, and XJ1100 models front and rear. Each:
    $ 1.95
    HCP22749 OEM turn signal lense SCREW Used on the following models: all 1992-98 XJ600 Seca II models, use 1 screw per lense. Each:
    $ 1.95
    HCP6113 OEM front turn signal lense SCREW. Use 3 per lense on all XJ650 Turbo models. Each:
    $ 4.95
    HCP6113SET3 OEM front turn signal lense SCREWS, set of 3:
    $ 27.95
    HCP28333 Aftermarket front turn signal lense SCREW. Use 3 per lense on all XJ650 Turbo models. These screws have a bright finish as original. Each:
    $ 1.95
    HCP28333SET3 Aftermarket front turn signal lense SCREWS, set of 3:
    $ 5.75
    HCP4172 OEM front turn signal housing-to-fairing hood RETAINING SCREW, panhead phillips-drive, alloy steel with a bright zinc-plated finish, secures the front turn signal housing to the fairing hood. NOTE: the original screw has a dark finish with an integral flat washer. This replacement screw no longer has the captured washer, and a replacement washer should be ordered from the choices below. Fits all XJ650 Turbo models, use 2 per housing, each:
    $ 2.95
    HCP6566 Aftermarket front turn signal housing-to-fairing hood RETAINING SCREW, panhead phillips-drive, alloy steel with a bright zinc-plated finish, secures the front turn signal housing to the fairing hood. NOTE: the original screw has a dark finish with an integral flat washer. This replacement screw no longer has the captured washer, and a replacement washer should be ordered from the choices below. Fits all XJ650 Turbo models, use 2 per housing, each:
    $ 1.95
    HCP6568 Aftermarket front turn signal housing-to-fairing hood RETAINING SCREW, panhead phillips-drive, 18/8 stainless steel with a bright zinc-plated finish, secures the front turn signal housing to the fairing hood. NOTE: the original screw has a dark finish with an integral flat washer. This replacement screw no longer has the captured washer, and a replacement washer should be ordered from the choices below. Fits all XJ650 Turbo models, use 2 per housing, each:
    $ 2.95
    HCP2512 OEM front turn signal housing-to-fairing hood mounting screw FLAT WASHER, dark finish, alloy steel, use 2 per housing, for all XJ650 Turbo models, each:
    $ 3.95
    HCP914 Aftermarket front turn signal housing-to-fairing hood mounting screw FLAT WASHER, zinc-plated alloy steel, use 2 per housing, for all XJ650 Turbo models, each:
    $ 1.95
    HCP1353 Aftermarket front turn signal housing-to-fairing hood mounting screw FLAT WASHER, bright 18/8 stainless steel, use 2 per housing, for all XJ650 Turbo models, each:
    $ 2.95
    HCP65 Aftermarket front turn signal housing-to-fairing hood mounting screw FLAT WASHER, black oxide-coated stainless steel, use 2 per housing, for all XJ650 Turbo models, each:
    $ 2.95
    HCP3699 OEM front turn signal housing-to-fairing hood mounting screw NUT, used to secure the turn signal housing to the hood. Black alloy steel, correct for the front signal housings on XJ650 Turbo models, use 2 per housing, each:
    $ 8.95
    HCP10961 Aftermarket front turn signal housing-to-fairing hood mounting screw NUT, used to secure the turn signal housing to the hood. Yellow zinc-plated alloy steel, correct size for the front signal housings on XJ650 Turbo models, use 2 per housing, each:
    $ 2.95
    HCP3696 OEM turn signal lense SCREW, bright plated finish phillips screws. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 7.95
    HCP5482 Aftermarket turn signal lense SCREW, zinc-plated alloy steel, phillips-drive panhead screw. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 1.95
    HCP21356 Aftermarket turn signal lense SCREW, 18-8 stainless steel, phillips-drive panhead screw. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 2.95
    HCP5486 Aftermarket turn signal lense SCREW, phillips-drive panhead screw with gold chromate finish. Has an integral lockwasher. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 2.95
    HCP5483 Aftermarket turn signal lense SCREW, socket head cap screw (hex-drive), 18-8 stainless steel with a bright polished finish. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 2.95
    HCP5484 Aftermarket turn signal lense SCREW, socket head cap screw (hex-drive), black-oxide coated steel finish. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 1.95
    HCP5485 Aftermarket turn signal lense SCREW, button head cap screw (rounded head hex-drive), 18-8 stainless steel with a bright polished finish. Use on the following models: 1984-85 FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each
    $ 2.95
    HCP3691 OEM turn signal lense SCREW, bright finish phillips screws. Used on the following models: FJ600 front and rear, XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK, RL, N/FN, and F models front and rear. Use 1 per lense, for the outer position (self-tapping screw). Each:
    $ 10.95
    HCP6062 Aftermarket turn signal lense SCREW, zinc plated finish alloy steel phillips screws. Used on the following models: XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 1.95
    HCP6062SET4 Aftermarket turn signal lense SCREWS, set of 4:
    $ 6.95
    HCP6064 Aftermarket turn signal lense SCREW, bright plated finish 18-8 stainless steel phillips screws. Used on the following models: XJ650 Turbo models rear, XJ750 Seca front and rear, and all XJ900RK front and rear. Use 1 per lense, on the inner position (machine threaded). Each:
    $ 2.95
    HCP6064SET4 Aftermarket turn signal lense SCREWS, set of 4:
    $ 11.25
    HCP21710 Aftermarket turn signal lense SCREW, bright plated finish 18-8 stainless steel phillips-drive screws. Used on the following models: XJ550 Seca models front and rear, and 1982 XJ750 Maxim model front and rear. Use 2 per lense. Each:
    $ 2.95
    HCP21710SET4 Aftermarket turn signal lense SCREWS, set of 4:
    $ 9.95
    HCP9140 OEM turn signal lense SCREW, bright plated finish phillips screws. Used on the following models: all XJ700 and XJ750-X models. Use 2 per lense. Each:
    $ 8.95
    HCP20962 Aftermarket turn signal lense SCREW, bright plated 18-8 stainless steel phillips-drive screws. Used on the following models: all XJ700 and XJ750-X models. Use 2 per lense. Each:
    $ 2.95
    HCP9141 OEM turn signal lense screw WASHER, molded clear plastic. Used on the following models: all XJ700 and XJ750-X models. Use 2 per lense. Each:
    $ 8.95
    tsl17) OEM and aftermarket turn signal bulb socket retaining strap MOUNTING SCREWS perfectly replaces rusted or stripped originals. Note that these screws are inside the housing. NOTE: some original (and many aftermarket) turn signals use "self-tapping" style screws to retain the bulb socket to the signal housing.........self-tapping screws look like wood or sheetmetal screws, they have rather widely spacer, deeply grooved threads. We do not have that style (self-tapping) screw available, and you cannot use these fine-threaded screws in place of self-tappers.
    HCP104 OEM turn signal bulb socket MOUNTING SCREW, alloy steel, phillips-drive, panhead screw. Use with original turn signals that have fine-threaded "real" screw threads. Use 2 per bulb socket, fits all XJ models. Each:
    $ 2.95
    HCP2907 Aftermarket turn signal bulb socket MOUNTING SCREW, zinc-plated alloy steel, phillips-drive, panhead screw. Use with original turn signals that have fine-threaded "real" screw threads. Use 2 per bulb socket, fits all XJ models. Each:
    $ 1.95
    HCP105 Aftermarket turn signal bulb socket MOUNTING SCREW, 18-8 stainless steel phillips-drive, panhead screw. Use with original turn signals that have fine-threaded "real" screw threads. Use 2 per bulb socket, fits all XJ models. Each:
    $ 2.95
    HCP2908 Aftermarket turn signal bulb socket MOUNTING SCREW, black-oxide coated alloy steel, phillips-drive, panhead screw. Use with original turn signals that have fine-threaded "real" screw threads. Use 2 per bulb socket, fits all XJ models. Each:
    $ 1.95
  27. chacal
    Turn Signal Mounting: Stalks, Stems, and Bushings:
    tsm1) OEM and aftermarket replacement turn signal-to-frame MOUNTING STAYS perfectly replaces missing, worn, or incorrect stalks, stems, and bushings. All items work with both our original or reproduction turn signal units.
    NOTE: the signal STAY is the chrome or black rubber stalk or stem that attaches to both the turn signal housing "neck" and runs to the adapter bracket or directly to the frame mounting point. These stays are hollow, and thus allow the signal wires to pass through them. The CINCH BOLT and related hardware items, listed in the next section, are what attach the above stay to the turn signal housing to lock the stay to the turn signal.
    HCP1985 OEM turn signal STAY, bright chrome mounting stalk with the hollow threaded mounting collar used on turn signals for these models: 1982-83 XJ650 Maxim models rear, XJ650RJ Seca front or rear, and XJ1100 models front or rear. Also fits the following models: 1982-83 XS400 Maxim front or rear, 1983 XV500 Virago front or rear, 1981-83 XV750 Virago front or rear, 1982 XV920RJ Virago rear, and 1983 XV920K Virago front. Each:
    $ 44.95
    HCP1985SET2 OEM turn signal STAYS, set of 2:
    $ 82.95
    HCP1985SET4 OEM turn signal STAYS, set of 4:
    $ discontinued
    HCP1684 Aftermarket turn signal STAY, bright chrome mounting stalk with the hollow threaded mounting collar used on turn signals for these models: 1982-83 XJ650 Maxim models rear, XJ650RJ Seca front or rear, and XJ1100 models front or rear. Also fits the following models: 1982-83 XS400 Maxim front or rear, 1983 XV500 Virago front or rear, 1981-83 XV750 Virago front or rear, 1982 XV920RJ Virago rear, and 1983 XV920K Virago front. Each:
    $ 27.95
    HCP1684SET2 Aftermarket turn signal STAYS, set of 2:
    $ 49.95
    HCP1684SET4 Aftermarket turn signal STAYS, set of 4:
    $ 89.95
    HCP1978 OEM turn signal STAY, black rubber mounting stalk with the hollow threaded mounting collar used on turn signals for these models: XJ550 Maxim front or rear, 1983 XJ750 Maxim and Midnight Maxim rear, and all XJ700 and XJ750-X models front. Also fits all of the following models: 1988-90 and 1995-98 XV250 Route 66 front or rear, 1999-2007 XV250 Virago front or rear, 2008-13 XV250 V-Star 250 front or rear, 1987-88, 1990, and 1993-99 XV535 Virago front or rear, 1999-2003 XVS650 V-Star Custom rear, 2003-04 XVS650 V-Star Silverado rear, 2004 XVS65 Star Custom Star Classic rear, 1984-87 XV700 Virago front or rear, 1983 XV750 Virago front, 1983 XV750MK Midnight Virago rear, 1988-97 XV750 Virago front or rear, 1983 XV92 K Virago rear, 1983 XV920MK Midnight Virago rear, 1984-03 XV1000 Virago front or rear, 1984-86 and 1988-2004 VMX12 V-Max front or rear. Each:
    $ 36.95
    HCP1978SET2 OEM turn signal STAYS, set of 2:
    $ 69.95
    HCP1978SET4 OEM turn signal STAYS, set of 4:
    $ 134.95
    HCP7563 Aftermarket turn signal STAY, black rubber mounting stalk with the hollow threaded mounting collar used on turn signals for these models: XJ550 Maxim front or rear, 1983 XJ750 Maxim and Midnight Maxim rear, and all XJ700 and XJ750-X models front. Also fits all of the following models: 1988-90 and 1995-98 XV250 Route 66 front or rear, 1999-2007 XV250 Virago front or rear, 2008-13 XV250 V-Star 250 front or rear, 1987-88, 1990, and 1993-99 XV535 Virago front or rear, 1999-2003 XVS650 V-Star Custom rear, 2003-04 XVS650 V-Star Silverado rear, 2004 XVS65 Star Custom Star Classic rear, 1984-87 XV700 Virago front or rear, 1983 XV750 Virago front, 1983 XV750MK Midnight Virago rear, 1988-97 XV750 Virago front or rear, 1983 XV92 K Virago rear, 1983 XV920MK Midnight Virago rear, 1984-03 XV1000 Virago front or rear, 1984-86 and 1988-2004 VMX12 V-Max front or rear. Each:
    $ 27.95
    HCP7563SET2 Aftermarket turn signal STAYS, set of 2:
    $ 49.95
    HCP7563SET4 Aftermarket turn signal STAYS, set of 4:
    $ 89.95
    HCP1981 OEM turn signal STAY, flanged black rubber mounting stalk with the hollow threaded mounting collar used on turn signals for these models: XJ550 Seca front or rear, 1984-85 FJ600 rear, 1984-85 FJ600 rear, XJ650 Turbo rear, 1982 XJ750 Maxim rear, 1981-83 XJ750 Seca rear, XJ900RK front, and all XJ900RK, RL, N/FN, and F models rear. Also fits all of the following models: 1982-83 XZ550RJ/RK Vision front or rear, and 1984-85 FJ1100 front or rear. Each:
    $ 59.95
    HCP1981SET2 OEM turn signal STAYS, set of 2:
    $ 114.95
    HCP1981SET4 OEM turn signal STAYS, set of 4:
    $ discontinued
    HCP6434 Aftermarket turn signal STAY, flanged black rubber mounting stalk with the hollow, threaded mounting stud used to mount the turn signals for these models: XJ550 Seca front or rear, 1984-85 FJ600 rear, 1984-85 FJ600 rear, XJ650 Turbo rear, 1982 XJ750 Maxim rear, 1981-83 XJ750 Seca rear, XJ900RK front, and all XJ900RK, RL, N/FN, and F models rear. Also fits all of the following models: 1982-83 XZ550RJ/RK Vision front or rear, and 1984-85 FJ1100 front or rear. NOTE: compared to the original HCP1981 stays, these are a nice reproduction which will fit and function correctly, and unlike the other reproduction stems on the market, ours are rigid along their entire length and will not flop around during riding. Additionally, the stem has a large-enough internal diameter to allow passage of either 2- or 3-wire signal harnesses. Each:
    $ 39.95
    HCP6434SET2 Aftermarket turn signal STAYS, set of 2:
    $ 74.95
    HCP6434SET4 Aftermarket turn signal STAYS, set of 4:
    $ 129.95
    HCP13783 OEM turn signal STAY, flanged mounting stalk with the hollow threaded mounting collar used on turn signals for these models: 1982 XJ920K Virago front or rear and XJ900 N models front. Each:
    $ discontinued
    HCP13783SET2 OEM turn signal STAYS, set of 2:
    $ discontinued
    HCP3653 OEM turn signal STAY BUSHING, flanged black rubber hollow "bullet" fits over the front turn signal housing cover stem and adapts the stem to the turn signal housing neck. Used on these models: 1984-85 FJ600 front, 1982 XJ750 Maxim front, all XJ750 Seca front, and 1984-85 RZ350 rear. Each:
    $ 22.95
    HCP3653SET2 OEM turn signal STAY BUSHINGS, set of 2:
    $ 43.95
    HCP26226 Aftermarket turn signal STAY BUSHING, flanged black rubber hollow "bullet" fits over the front turn signal housing cover stem and adapts the stem to the turn signal housing neck. Used on these models: 1984-85 FJ600 front, 1982 XJ750 Maxim front, all XJ750 Seca front, and 1984-85 RZ350 rear. Each:
    $ 17.95
    HCP26226SET2 Aftermarket turn signal STAY BUSHINGS, set of 2:
    $ 32..95
    HCP7350 OEM turn signal STAY BRACKET, chrome double-flanged bracket mounts the front turn signal stays. For all XJ700 and XJ750-X models as well as 1984-88 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, 1984-99 XV1100 Virago, and 1996-98 XV1100 Virago Special models.
    $ 99.95
    HCP1982 OEM turn signal STAY, flanged black rubber mounting stalk with the hollow threaded mounting collar used on turn signals for these models: XJ700 and XJ750-X models rear. NOTE: a common question arises, which is "Why can't I use the seemingly "identical" front turn signal mounting stalks?" Answer: because the threaded stud used on the front signal stays, which is used to attach the signal stay to the frame of the bike, is not long enough to be used as a rear signal stay....the threaded stud will not reach through the rear stay mounting hole (on the side grab bar) to be able to secure a nut to it! Also fits all of the following models: 1983 XV750 Virago rear, 1983 XV750MK Midnight Virago rear, 1983 XV920K Virago rear, 1983 XV920MK Midnight Virago rear, and 2015-17 SR400 front and rear. Each:
    $ 59.95
    HCP1980 OEM turn signal STAY BRACKET, black-flanged bracket adapts the rear turn signal stays to the frame. For all XJ550 Maxim models, right rear.
    $ 89.95
    HCP3719 OEM turn signal STAY BRACKET, black-flanged bracket adapts the rear turn signal stays to the frame. For all XJ650RJ Seca models, left rear.
    $ discontinued
    HCP3720 OEM turn signal STAY BRACKET, black-flanged bracket adapts the rear turn signal stays to the frame. For all XJ650RJ Seca models, right rear.
    $ discontinued
    Turn Signal Housing-to-Stay Bracket Hardware:
    tsm2) OEM and aftermarket replacement turn signal-to-stay MOUNTING HARDWARE perfectly replaces missing, worn, or incorrect fasteners. All items work with both our original or reproduction turn signal units.
    NOTE: these CINCH BOLTS and related hardware items are what attach the signal stalk or "stay" to the turn signal housing neck, thus locking the stay to the turn signal housing.
    HCP3701 OEM turn signal housing-to-stalk or stem CINCH BOLT, use 1 per housing (front and rear) on all XJ550 Maxim, all XJ650 models (except Turbo), 1985 XJ700 all models, 1983 XJ750 Maxim, and XJ1100 models. Originals were bright plated, these replacements feature a dark phosphate plating. Each:
    $ 3.95
    HCP13157 Aftermarket turn signal housing-to-stalk or stem CINCH BOLT, use 1 per housing (front and rear) on all XJ550 Maxim, all XJ650 models (except Turbo), 1985 XJ700 all models, 1983 XJ750 Maxim, and XJ1100 models. Bright plated hex-head 18/8 stainless steel bolt. Each:
    $ 2.95
    HCP13158 Aftermarket turn signal housing-to-stalk or stem CINCH BOLT, use 1 per housing (front and rear) on all XJ550 Maxim, all XJ650 models (except Turbo), 1985 XJ700 all models, 1983 XJ750 Maxim, and XJ1100 models. Black-oxide coated hex-head 18/8 stainless steel bolt. Each:
    $ 2.95
    HCP4251 OEM turn signal housing CINCH SCREW, used to secure the turn signal housing to its mounting stem or stalk. Fits all 1986 XJ700 models front or rear. Use with the HCP3703 style flanged nut listed below. Each:
    $ 5.95
    HCP1869 OEM turn signal housing cinch bolt FLAT WASHER, used to secure the turn signal housing to its mounting stem or stalk. Black-oxide finished alloy steel, correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Use with the HCP3701 bolt above, each:
    $ 2.95
    HCP6642 Aftermarket turn signal housing cinch bolt FLAT WASHER, zinc-plated alloy steel with a bright finish, for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 1.95
    HCP6643 Aftermarket turn signal housing cinch bolt FLAT WASHER, 18-8 stainless steel with a bright finish, for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP25756 Aftermarket turn signal housing cinch bolt FLAT WASHER, 316 stainless steel, for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP14285 Aftermarket turn signal housing cinch bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP14284 Aftermarket turn signal housing cinch bolt FLAT WASHER, black oxide-coated hardened alloy steel, correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP3703 OEM turn signal housing cinch bolt FLANGED NUT, used to secure the turn signal housing to its mounting stem or stalk. Bright plated alloy steel. For all XJ550 Maxim front or rear, XJ650 Maxim front or rear, XJ650RJ Seca front or rear, all XJ700 front or rear, 1983 XJ750 Maxim front or rear, 1985-86 XJ750-X front or rear, and XJ1100 models front or rear. Can also be used on XJ650 and XJ750 Midnight Maxim models, but those nuts were originally provided in a black finish rather than bright plating. Use with the HCP3701 or HCP13157 bolt above. Each:
    $ 2.95
    HCP3704 OEM turn signal housing cinch bolt FLANGED NUT, used to secure the turn signal housing to its mounting stem or stalk. Black alloy steel with smooth flange, correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Use with the HCP13158 bolt above. Each:
    $ 2.95
    HCP10962 Aftermarket turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Yellow zinc-plated alloy steel. Use with the HCP3701, HCP13157, or HCP13158 bolt above. Each:
    $ 1.95
    HCP28898 Aftermarket turn signal housing cinch bolt FLANGED NUT, used to secure the turn signal housing to its mounting stem or stalk. Black alloy steel with smooth flange. Use with the HCP3701, HCP13157, or HCP13158 bolt above. Each:
    $ 1.95
    HCP10001 Aftermarket starter solenoid terminal stud FLANGED NUT, use 2 per unit. Black alloy steel with serrated (locking) flange. Use with the HCP3701, HCP13157, or HCP13158 bolt above. Each:
    $ 1.95
    $ 2.95
    HCP28898 Aftermarket turn signal housing cinch bolt FLANGED NUT, used to secure the turn signal housing to its mounting stem or stalk. Black alloy steel with smooth flange as original, correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Use with the HCP13158 bolt above. Each:
    $ 1.95
    HCP10001 Aftermarket turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Black alloy steel, correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Use with the HCP13158 bolt above. Each:
    $ 1.95
    HCP3685 OEM turn signal housing CINCH BOLT, used to secure the turn signal housing to its mounting stem or stalk. Bright plated domed-head alloy steel bolt with a square shank under the dome head and either a rounded or squared shaft (they came in either configuration). For all XJ550 Seca front or rear, 1982 XJ750 Maxim front or rear, and all XJ900RK, RL, N/FN, and F models front or rear. Can also be used on XJ650 Turbo rear and XJ750 Seca models, but those bolts were originally provided in a black finish and a fully squared shaft. Use with the appropriate washers and nuts as listed below. Each:
    $ 14.95
    HCP3685SET2 OEM turn signal housing CINCH BOLTS, set of 2:
    $ 27.95
    HCP3685SET4 OEM turn signal housing CINCH BOLTS, set of 4:
    $ 49.95
    HCP3686 OEM turn signal housing CINCH BOLT, used to secure the turn signal housing to its mounting stem or stalk. Black-plated domed-head alloy steel bolt with a square shank under the dome head and either a rounded or squared shaft (they came in either configuration). Fits all XJ650 Turbo rear, XJ750 Seca and XJ750 Euro models front or rear. Can also be used on all XJ550 Seca front or rear, 1982 XJ750 Maxim front or rear, and all XJ900RK, RL, N/FN, and F models front or rear, but those bolts were originally provided in a bright silver-zinc finish. Use with the appropriate washers and nuts as listed below. Each:
    $ 14.95
    $ 27.95
    $ 49.95
    HCP306 OEM turn signal housing cinch bolt FLAT WASHER, bright zinc-plated alloy steel, used to secure the turn signal housing to its mounting stem or stalk. Use on all XJ550 Seca, 1982 XJ750 Maxim, and all XJ900RK, RL, N/FN, and F models front or rear. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 2.95
    HCP914 Aftermarket turn signal housing cinch bolt FLAT WASHER, bright zinc-plated alloy steel, used to secure the turn signal housing to its mounting stem or stalk. Correct for all XJ550 Seca, 1982 XJ750 Maxim, and all XJ900RK, RL, N/FN, and F models front or rear. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 1.95
    HCP1353 Aftermarket turn signal housing cinch bolt FLAT WASHER, bright 18/8 stainless steel, used to secure the turn signal housing to its mounting stem or stalk. Correct for all XJ550 Seca, 1982 XJ750 Maxim, and all XJ900RK, RL, N/FN, and F models front or rear. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 2.95
    HCP65 Aftermarket turn signal housing cinch bolt FLAT WASHER, black oxide-coated stainless steel, used to secure the turn signal housing to its mounting stem or stalk. Correct for XJ650 Turbo rear, and all XJ750 Seca rear signals. Can also be used on all XJ550 Seca, 1982 XJ750 Maxim, and all XJ900RK, RL, N/FN, and F models front or rear. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 2.95
    HCP2512 OEM turn signal housing cinch bolt FLAT WASHER, dark finish, alloy steel, used to secure the turn signal housing to its mounting stem or stalk. Use on all 1984-85 FJ600 models, front or rear. Each:
    $ 3.95
    HCP914 Aftermarket turn signal housing cinch bolt FLAT WASHER, zinc-plated alloy steel, used to secure the turn signal housing to its mounting stem or stalk. Use on all 1984-85 FJ600 models, front or rear. Each:
    $ 1.95
    HCP1353 Aftermarket turn signal housing cinch bolt FLAT WASHER, bright 18/8 stainless steel, used to secure the turn signal housing to its mounting stem or stalk. Use on all 1984-85 FJ600 models, front or rear. Each:
    $ 2.95
    HCP65 Aftermarket turn signal housing cinch bolt FLAT WASHER, black oxide-coated stainless steel, used to secure the turn signal housing to its mounting stem or stalk. Use on all 1984-85 FJ600 models, front or rear. Each:
    $ 2.95
    HCP55 OEM turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to its mounting stem or stalk. Bright plated alloy steel, correct for all XJ550 Seca and 1982 XJ750 Maxim models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 1.95
    HCP913 OEM turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to its mounting stem or stalk. Bright plated alloy steel, correct for all XJ550 Seca and 1982 XJ750 Maxim models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 1.75
    HCP57 Aftermarket turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to its mounting stem or stalk. Bright plated 18-8 stainless steel, correct for all XJ550 Seca and 1982 XJ750 Maxim models. Can also be used for XJ650 Turbo rear, and all XJ750 Seca rear signals, but is not the correct black finish. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 2.95
    HCP59 Aftermarket turn signal housing cinch bolt LOCK WASHER, used to secure the turn signal housing to its mounting stem or stalk. Black plated alloy steel is correct for all XJ650 Turbo rear and all XJ750 Seca rear signals. Use with the HCP3685 or HCP3686 cinch bolt above. Each:
    $ 1.95
    HCP3688 OEM turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Black alloy steel, correct for the rear signals on all FJ600, XJ650 Turbo, and XJ750 Seca models. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 2.95
    HCP24054 Aftermarket turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Black-oxide coated alloy steel, correct for the rear signals on all FJ600, XJ650 Turbo, and XJ750 Seca models. . Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 1.95
    HCP3699 OEM turn signal housing cinch bolt FLANGED NUT, used to secure the turn signal housing to its mounting stem or stalk. Black alloy steel, correct for the front signals on 1982 XJ750 Maxim and all XJ750 Seca models. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 8.95
    HCP10961 Aftermarket turn signal housing cinch bolt FLANGED NUT, used to secure the turn signal housing to its mounting stem or stalk. Yellow zinc-plated alloy steel, correct for the front signals on 1982 XJ750 Maxim and all XJ750 Seca models. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 2.95
    HCP3632 OEM turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Bright plated steel, correct for the following models: XJ550 Seca front and rear, 1982 XJ750 Maxim front signals, and all XJ900RK, RL, N/FN, and F models front or rear. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 8.95
    HCP24055 Aftermarket turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Bright zinc-plated steel, correct for the following models: XJ550 Seca front and rear, 1982 XJ750 Maxim front signals, and all XJ900RK, RL, N/FN, and F models front or rear. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 1.95
    HCP24056 Aftermarket turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Bright 18/8 stainless steel, correct for the following models: XJ550 Seca front and rear, 1982 XJ750 Maxim front signals, and all XJ900RK, RL, N/FN, and F models front or rear. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 2.95
    HCP24057 Aftermarket turn signal housing cinch bolt NUT, used to secure the turn signal housing to its mounting stem or stalk. Bright 316 stainless steel, correct for the following models: XJ550 Seca front and rear, 1982 XJ750 Maxim front signals, and all XJ900RK, RL, N/FN, and F models front or rear. Use with the HCP3685 or HCP3686 bolt above. Each:
    $ 3.95
    HCP18010 Aftermarket turn signal housing-to-stay bracket mounting bolt hex head protective CAP. Black plastic pebble-grain finish cap snaps onto the hex head of the mounting bolts, giving them a very "modern" look, protecting the head from rust. Fits all models using a 10mm hex head bolt. Each:
    $ 3.50
    tsmf4) OEM and aftermarket front turn signal COVERS. On certain models, the front turn signal housing was mounted to a half-circular lower steering bracket "cover", which is basically a bracket with a stem growing off of it (the stem is what the turn signal actually mounts onto). Although the cover brackets are no longer available, the mounting hardware is available below.
    HCP3652 OEM front turn signal cover-to-lower steering bracket BOLT, use 2 per side. For the following models: all XJ650 Maxim models (front) and all XJ750 Maxim models (front). Each:
    $ 9.95
    HCP3647 OEM front turn signal cover-to-lower steering bracket BOLT, black alloy steel, socket head (hex key) fastener, use 2 per side. For the following models: all XJ750 Seca models front. Each:
    $ 5.95
    HCP21432 Aftermarket front turn signal cover-to-lower steering bracket BOLT, black alloy steel, socket head (hex key) fastener, use 2 per side. For the following models: all XJ750 Seca models front. Each:
    $ 2.95
    HCP2185 OEM front turn signal cover-to-lower steering bracket bolt LOCK WASHER, use 2 per side. For the following models: all XJ750 Seca models (front). Each:
    $ 6.95
    HCP16209 Aftermarket front turn signal cover-to-lower steering bracket bolt LOCK WASHER, zinc-plated alloy steel, use 2 per side. For the following models: all XJ750 Seca models (front). Each:
    $ 2.95
    HCP16100 Aftermarket front turn signal cover-to-lower steering bracket bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 2 per side. For the following models: all XJ750 Seca models (front). Each:
    $ 3.95
    HCP16102 Aftermarket front turn signal cover-to-lower steering bracket bolt LOCK WASHER, black-oxide coated alloy steel, use 2 per side. For the following models: all XJ750 Seca models (front). Each:
    $ 3.95
    Turn Signal Stay Bracket-to-Frame Mounting Hardware:
    tsm13) OEM and aftermarket replacement turn signal stay-to-frame MOUNTING HARDWARE perfectly replaces missing, worn, or incorrect fasteners. All items work with both our original or reproduction turn signal stays.
    NOTE: these hardware items are what attach the signal stalk or "stay" to the bike's frame or other bracket, thus attaching the stay to the bike itself.
    HCP4208 OEM rear turn signal mounting bracket-to-frame BOLT, alloy steel with a black finish, hex-head bolt. Use one per side on all 1984-85 FJ600 models, each:
    $ 7.95
    HCP18159 Aftermarket rear turn signal mounting bracket-to-frame BOLT, 18/8 stainless steel with a bright finish, hex-head bolt. Use one per side on all 1984-85 FJ600 models, each:
    $ 2.95
    HCP16101 Aftermarket rear turn signal mounting bracket-to-frame BOLT, alloy steel with a black finish, hex-head bolt. Use one per side on all 1984-85 FJ600 models, each:
    $ 1.95
    HCP4279 OEM front turn signal stay bracket mounting BOLT, for all 1994-96 XJ600 Seca II models. Attaches the bracket frame. Use 2 per bike. Each:
    $ 7.95
    HCP1902 OEM front turn signal housing stay bracket bolt LOCK WASHER, black oxide-coated alloy steel. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above. Each:
    $ 6.95
    HCP916 Aftermarket front turn signal housing stay bracket bolt LOCK WASHER, zinc-plated alloy steel with a bright finish. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above. Each:
    $ 1.95
    HCP319 Aftermarket front turn signal housing stay bracket bolt LOCK WASHER, 18-8 stainless steel. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above. Each:
    $ 2.95
    HCP321 Aftermarket front turn signal housing stay bracket bolt LOCK WASHER, black oxide-coated alloy steel. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above. Each:
    $ 1.95
    HCP1869 OEM front turn signal housing stay bracket bolt FLAT WASHER. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above, black-oxide finish, each:
    $ 2.95
    HCP6642 Aftermarket front turn signal housing stay bracket bolt FLAT WASHER, zinc-plated alloy steel with a natural finish. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above, each:
    $ 1.95
    HCP6643 Aftermarket front turn signal housing stay bracket bolt FLAT WASHER, 18-8 stainless steel with a natural finish. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above, each:
    $ 2.95
    HCP25756 Aftermarket front turn signal housing stay bracket bolt FLAT WASHER, 316 stainless steel with a natural finish. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above, each:
    $ 3.95
    HCP14285 Aftermarket front turn signal housing stay bracket bolt FLAT WASHER, black oxide-coated 18-8 stainless steel. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above, each:
    $ 2.95
    HCP14284 Aftermarket front turn signal housing stay bracket bolt FLAT WASHER, black oxide-coated hardened alloy steel. Fits all 1994-96 XJ600 Seca II models. Use 1 with each HCP4279 bolt above, each:
    $ 2.95
    HCP3668 OEM rear turn signal mounting bracket-to-frame BOLT, use one per side on all XJ650 Turbo and all XJ750 Seca models. Each:
    $ 7.95
    HCP7575 OEM turn signal housing stay bracket CINCH BOLT, used to secure the turn signal rear stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear. Alloy steel, dark finish. Use 1 per side. Each:
    $ 3.95
    HCP27630 Aftermarket turn signal housing stay bracket CINCH BOLT, used to secure the turn signal rear stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear. Zinc-plated alloy steel, bright finish. Use 1 per side. Each:
    $ 1.95
    HCP27631 Aftermarket turn signal housing stay bracket CINCH BOLT, used to secure the turn signal rear stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear. Bright 18-8 stainless steel. Use 1 per side. Each:
    $ 2.95
    HCP27632 Aftermarket turn signal housing stay bracket CINCH BOLT, used to secure the turn signal rear stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear. Super corrosion-resistant 316 stainless steel, dull gray finish. Use 1 per side. Each:
    $ 3.95
    HCP1902 OEM turn signal housing stay bracket bolt LOCK WASHER, black oxide-coated alloy steel, used to secure the turn signal stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear Use with any of the bolts listed above. Each:
    $ 6.95
    HCP916 Aftermarket turn signal housing stay bracket bolt LOCK WASHER, zinc-plated alloy steel with a bright finish, used to secure the turn signal stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear Use with any of the bolts listed above. Each:
    $ 1.95
    HCP319 Aftermarket turn signal housing stay bracket bolt LOCK WASHER, 18-8 stainless steel, used to secure the turn signal stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear Use with any of the bolts listed above. Each:
    $ 2.95
    HCP321 Aftermarket turn signal housing stay bracket bolt LOCK WASHER, black oxide-coated alloy steel, used to secure the turn signal stay bracket to the frame. Fits all XJ900RL, N/FN, and F models rear Use with any of the bolts listed above. Each:
    $ 1.95
    HCP3663 OEM turn signal stay FITTING BOLT----actually, it's a hollow threaded stud that screws into the HCP1985 or the HCP1684 turn signal stays listed above, and thus allows the stay to be bolted to the bike frame. Use 1 per stay for the following models: all 1982-84 XJ650 Maxim rear, 1982 XJ650RJ Seca rear, XJ900 N front, and all XJ1100 models front. Each:
    $ 14.95
    HCP3666 OEM turn signal stay RUBBER DAMPER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above, and insulates and cushions the stay from the bike frame. Use 1 per stay for the following models: all XJ650 Maxim and Midnight Maxim models rear, 1982 XJ650RJ Seca front or rear, XJ900 N front, and all XJ1100 models front. Each:
    $ 11.95
    HCP3665 OEM turn signal stay RUBBER DAMPER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above, and insulates and cushions the stay from the bike frame. Use 1 per stay for the following models: all XJ1100 models rear. Each:
    $ 11.95
    HCP3670 OEM turn signal stay PLATE WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. Use 1 per stay for the following models: all 1980-81 XJ650 Maxim rear. Each:
    $ 4.95
    HCP3669 OEM turn signal stay PLATE WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. Use 1 per stay for the following models: all 1982-84 XJ650 Maxim rear, 1982 XJ650RJ Seca rear, and XJ900 N front. Each:
    $ 6.95
    HCP2391 OEM turn signal stay mounting bolt LOCK WASHER, use 1 per bike on all 1984-84 FJ600 models.
    $ 7.95
    HCP16209 Aftermarket turn signal stay mounting bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on all 1984-84 FJ600 models. Each:
    $ 2.95
    HCP16100 Aftermarket turn signal stay mounting bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on all 1984-84 FJ600 models. Each:
    $ 3.95
    HCP16102 Aftermarket turn signal stay mounting bolt LOCK WASHER, black-oxide coated alloy steel, for use 1 per bike on all 1984-84 FJ600 models. Each:
    $ 3.95
    HCP2230 OEM turn signal stay LOCK WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. Use 1 per stay for the following models: all 1980-81 XJ650 Maxim rear. Each:
    $ 7.95
    HCP22225 Aftermarket turn signal stay LOCK WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. Zinc-plated alloy steel. Use 1 per stay for the following models: all 1980-81 XJ650 Maxim rear. Each:
    $ 2.95
    HCP22227 Aftermarket turn signal stay LOCK WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. 18/8 stainless steel. Use 1 per stay for the following models: all 1980-81 XJ650 Maxim rear. Each:
    $ 3.95
    HCP3497 OEM turn signal stay LOCK WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. Black finish. Use 1 per stay for the following models: all 1981 XJ650 Midnight Maxim rear. Each:
    $ 7.95
    HCP22226 Aftermarket turn signal stay LOCK WASHER, fits onto the ends of the HCP1985 or the HCP1684 turn signal stays listed above. Black finish. Use 1 per stay for the following models: all 1981 XJ650 Midnight Maxim rear. Each:
    $ 2.95
    HCP3655 OEM turn signal stalk FLANGED NUT, to secure the stay to the frame, frame bracket, or headlight bracket (depending on model). Fits all XJ550 models front or rear, 1984-85 FJ600 models rear, 1992-98 XJ600 Seca II rear, all 1982-83 XJ650 Maxim rear, 1982 XJ650RJ Seca front or rear, XJ650 Turbo models rear, all XJ700 and XJ750-X models front or rear, all XJ750 Maxim and Midnight Maxim rear, all XJ750 Seca rear, XJ900RK and N models front, all XJ900RK, RL, N/FN, and F models rear, and all XJ1100 models front. Black-plated flange nut (note that some models may have used a bright-plated nut originally; those models should use part HCP3798 instead). Each:
    $ 7.95
    HCP3798 OEM turn signal stalk FLANGED NUT, to secure the stay to the frame, frame bracket, or headlight bracket (depending on model). Fits all XJ550 models front or rear, all 1982-83 XJ650 Maxim rear, 1982 XJ650RJ Seca front or rear, XJ650 Turbo models rear, all XJ700 and XJ750-X models front or rear, all XJ750 Maxim and Midnight Maxim rear, all XJ750 Seca rear, XJ900RK and N models front, all XJ900RK, RL, N/FN, and F models rear, and all XJ1100 models front. Bright-plated flange nut (note that some models may have used a black-plated nut originally; those models should use part HCP3655 instead). Each:
    $ 6.95
    HCP28610 Aftermarket turn signal stalk FLANGED NUT, to secure the stay to the frame, frame bracket, or headlight bracket (depending on model). Fits all XJ550 models front or rear, 1984-85 FJ600 models rear, 1992-98 XJ600 Seca II rear, all 1982-83 XJ650 Maxim rear, 1982 XJ650RJ Seca front or rear, XJ650 Turbo models rear, all XJ700 and XJ750-X models front or rear, all XJ750 Maxim and Midnight Maxim rear, all XJ750 Seca rear, XJ900RK and N models front, all XJ900RK, RL, N/FN, and F models rear, and all XJ1100 models front. Bright silver zinc-plated flange nut (note that some models may have used a bright-plated nut originally). Each::
    $ 1.95
    HCP16248 Aftermarket turn signal stalk FLANGED NUT, to secure the stay to the frame, frame bracket, or headlight bracket (depending on model). Fits all XJ550 models front or rear, 1984-85 FJ600 models rear, 1992-98 XJ600 Seca II rear, all 1982-83 XJ650 Maxim rear, 1982 XJ650RJ Seca front or rear, XJ650 Turbo models rear, all XJ700 and XJ750-X models front or rear, all XJ750 Maxim and Midnight Maxim rear, all XJ750 Seca rear, XJ900RK and N models front, all XJ900RK, RL, N/FN, and F models rear, and all XJ1100 models front. Black-plated finish (note that some models may have used a bright-plated nut originally). Each:
    $ 2.95
    HCP16249 Aftermarket turn signal stalk FLANGED NUT, to secure the stay to the frame, frame bracket, or headlight bracket (depending on model). Fits all XJ550 models front or rear, all 1982-83 XJ650 Maxim rear, 1982 XJ650RJ Seca front or rear, XJ650 Turbo models rear, all XJ700 and XJ750-X models front or rear, all XJ750 Maxim and Midnight Maxim rear, all XJ750 Seca rear, XJ900RK and N models front, all XJ900RK, RL, N/FN, and F models rear, and all XJ1100 models front. Yellow zinc-plated finish (note that some models may have used a bright zinc-plated or a black-plated nut originally). Each:
    $ 2.95
    HCP22884 OEM front turn signal stalk NUT, to secure the signal stay to the frame bracket. Fits all 1992-94 XJ600 Seca II models. Each:
    $ 8.95
    HCP22744 OEM front turn signal stalk NUT, to secure the signal stay to the frame bracket. Fits all 1995-98 XJ600 Seca II models. Each:
    $ 4.95
    HCP22745 OEM front turn signal stalk nut and wire harness COVER, protects and seals off the opening to the turn signal stalk at the frame bracket. Use 1 per front signal. Fits all 1992-94 XJ600 Seca II models. Each:
    $ 5.95
    HCP3678 OEM turn signal stalk NUT, to secure the stay to the frame. Fits all 1980-81 XJ650 Maxim or Midnight Maxim rear. Black-oxide coated finish as originally used on Midnight Maxim models only. Each:
    $ 8.95
    HCP9925 Aftermarket turn signal stalk NUT, to secure the stay to the frame. Fits all 1980-81 XJ650 Maxim or Midnight Maxim rear. Zinc-plated alloy steel. Each:
    $ 1.95
    HCP9926 Aftermarket turn signal stalk NUT, to secure the stay to the frame. Fits all 1980-81 XJ650 Maxim or Midnight Maxim rear. 18/8 stainless steel. Each:
    $ 3.95
    Turn Signal Bulbs:
    Believe it or not, there's even something special about your turn signal bulbs.
    If you are using the stock mechanical turn signal flasher unit, it requires a rather large current to flow through it in order for the mechanical contact points to heat up enough to make the flasher "flash". It's heat-dependent to keep the on-off-on-off cycle going. The only way to build up that heat is to have a large enough current coming INTO the flasher is to have a large enough current going OUT of the flasher......to your bulbs. Thus the turn signal bulbs you use must be close enough to the factory specified 27W rating (watts is a measure of current draw) in order for the flasher to work correctly (or even at all).
    These replacement bulbs are available in a variety of high-quality, versions and all will allow your stock flasher to work properly.
    HCP3606 Aftermarket single-filament turn signal BULB. Fits all XJ550, 1984-85 FJ600, XJ650, 1981-84 XJ750, and XJ900 front and rear turn signals, and all 1992-98 XJ600 Seca II, XJ700, XJ750-X, and XJ1100 rear turn signals. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. Each:
    $ 2.95
    HCP3606SET2 Aftermarket 32cp turn signal BULBS, set of 2:
    $ 5.75
    HCP3606SET4 Aftermarket 32cp turn signal BULBS, set of 4:
    $ 9.95
    HCP3606SET10 Aftermarket 32cp turn signal BULBS, set of 10:
    $ 22.95
    HCP3606LL Aftermarket single-filament turn signal BULB. Fits all XJ550, 1984-85 FJ600, XJ650, 1981-84 XJ750, and XJ900 front and rear turn signals, and all 1992-98 XJ600 Seca II, XJ700, XJ750-X, and XJ1100 rear turn signals. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. Each:
    $ 3.95
    HCP3606LLSET2 Aftermarket 32cp turn signal BULBS, set of 2:
    $ 7.50
    HCP3606LLSET4 Aftermarket 32cp turn signal BULBS, set of 4:
    $ 13.95
    HCP3606LLSET10 Aftermarket 32cp turn signal BULBS, set of 10:
    $ 29.95
    HCP3606DL40 Aftermarket single-filament turn signal BULB. Fits all XJ550, 1984-85 FJ600, XJ650, 1981-84 XJ750, and XJ900 front and rear turn signals, and all 1992-98 XJ600 Seca II, XJ700, XJ750-X, and XJ1100 rear turn signals. These SUPER-DUTY ULTRA-BRIGHT bulbs last for a mean average of 1000 running hours and are approximately 40% brighter than the standard or long-life bulbs. Each:
    $ 4.95
    HCP3606DL40SET2 Aftermarket 32cp turn signal BULBS, set of 2:
    $ 9.75
    HCP3606DL40SET4 Aftermarket 32cp turn signal BULBS, set of 4:
    $ 17.95
    HCP3606DL40SET10 Aftermarket 32cp turn signal BULBS, set of 10:
    $ 36.95
    NOTE: when using LED signal bulbs on bikes with a single dash indicator bulb for the turn signals (XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and 1983-84 XJ750 Maxim and Midnight Maxim), it will be necessary to install a DIODE WIRES KIT in order to isolate the flasher circuits and prevent all four flashers from operating all at once!
    HCP28634 Aftermarket DIODE WIRES KIT provides an easy-to-install solution whenever you install LED bulbs into the signal flashers unit (note: this change is required when LED bulbs are used in the left and right, front and/or rear flasher themselves, but is not required if you are only replacing the indicator light on the dash and still retaining incandescent bulbs in the actual signal housings). This small harness fits inside the headlight bucket, has all the connectors already installed, and requires just a standard terminal crimper (“crusher”) to install. Use on all XJ550 Maxim, all XJ650 Maxim/Midnight Maxim, and 1983-84 XJ750 Maxim/Midnight Maxim models.
    $ 14.95
    HCP25330A Aftermarket single-intensity turn signal LED BULB. Fits all XJ550, 1984-85 FJ600, XJ650, 1981-84 XJ750, and XJ900 front and rear turn signals, and all 1992-98 XJ600 Seca II, XJ700, XJ750-X, and XJ1100 rear turn signals. These SUPER-BRIGHT LED bulbs use multiple SMD led’s and will last for a mean average of 30,000 running hours, and will reduce current draw by about 26W per bulb, or a total of 100W+ reduction in power requirements per bike (4) (almost 8 amps!). NOTE: the use of LED bulbs will require you to use one of our solid state signal flasher units, as their minimal power draw will not be able to trigger the stock signal flasher. See the next section below for further information regarding signal flashers. Each:
    $ 14.95
    HCP25330ASET2 Aftermarket turn signal LED BULBS, set of 2:
    $ 27.95
    HCP25330ASET4 Aftermarket turn signal LED BULBS, set of 4:
    $ 49.95
    HCP17093 Aftermarket single-filament turn signal MODULAR BULB and BASE SET, single filament. Fits all XJ550, 1984-85 FJ600, XJ650, 1981-84 XJ750, and XJ900 front and rear turn signals, and all 1992-98 XJ600 Seca II, XJ700, XJ750-X, and XJ1100 rear turn signals. These ULTRA-DUTY, ULTRA-BRIGHT HALOGEN bulbs fit into a specially constructed base, and the bulbs will last for a mean average of 2000 running hours and are approximately 80% brighter than any other conventional incandescent bulb. Draws 20W at 14.5V. Each:
    $ 12.95
    HCP17093SET2 Aftermarket ultra-duty halogen MODULAR BULB and BASE SETS, set of 2:
    $ 22.95
    HCP17093SET4 Aftermarket ultra-duty halogen MODULAR BULB and BASE SETS, set of 4:
    $ 39.95
    HCP16728 Aftermarket ultra-duty halogen BULB. Use this super-bright halogen bulb with the HCP17093 bulb kits above. Each:
    $ discontinued
    HCP3607 Aftermarket dual-filament turn signal BULB. Fits all 1992-98 XJ600 Seca II front signals, all XJ700 and XJ750-X front turn signals, and all XJ1100 front turn signals models, or any other model converted to a 3-wire (running light) turn signal system. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. NOTE: these bulbs can also be used as tail/brake light bulbs. Each:
    $ 12.95
    HCP3607SET2 Aftermarket 32cp turn signal BULBS, set of 2:
    $ 24.95
    HCP3607SET4 Aftermarket 32cp turn signal BULBS, set of 4:
    $ 47.95
    HCP3607SET10 Aftermarket 32cp turn signal BULBS, set of 10:
    $ 99.95
    HCP3607LL Aftermarket dual-filament turn signal BULB. Fits all 1992-98 XJ600 Seca II front signals, all XJ700 and XJ750-X front turn signals, and all XJ1100 front turn signals models, or any other model converted to a 3-wire (running light) turn signal system. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. NOTE: these bulbs can also be used as tail/brake light bulbs. Each:
    $ 3.95
    HCP3607LLSET2 Aftermarket 32cp turn signal BULBS, set of 2:
    $ 7.50
    HCP3607LLSET4 Aftermarket 32cp turn signal BULBS, set of 4:
    $139.95
    HCP3607LLSET10 Aftermarket 32cp turn signal BULBS, set of 10:
    $ 29.95
    HCP3607DL40 Aftermarket dual-filament turn signal BULB. Fits all 1992-98 XJ600 Seca II front signals, all XJ700 and XJ750-X front turn signals, and all XJ1100 front turn signals models, or any other model converted to a 3-wire (running light) turn signal system. These SUPER-DUTY ULTRA-BRIGHT bulbs last for a mean average of 1000 running hours and are approximately 40% brighter than the standard or long-life bulbs. NOTE: these bulbs can also be used as tail/brake light bulbs. Each:
    $ 6.95
    HCP3607DL40SET2 Aftermarket 32cp turn signal BULBS, set of 2:
    $ 11.95
    HCP3607DL40SET4 Aftermarket 32cp turn signal BULBS, set of 4:
    $ 22.95
    HCP3607DL40SET10 Aftermarket 32cp turn signal BULBS, set of 10:
    $ 54.95
    HCP25370A Aftermarket dual-intensity turn signal LED BULB. Fits all 1992-98 XJ600 Seca II front signals, all XJ700 and XJ750-X front turn signals, and all XJ1100 front turn signals models, or any other model converted to a 3-wire (running light) turn signal system. These SUPER-BRIGHT LED bulbs use multiple SMD led’s and will last for a mean average of 30,000 running hours, and will reduce current draw by about 26W per bulb, or a total of 100W+ reduction in power requirements per bike (4) (almost 8 amps!). NOTE: the use of LED bulbs will require you to use one of our solid state signal flasher units, as their minimal power draw will not be able to trigger the stock signal flasher. See the next section below for further information regarding signal flashers. NOTE: on some models the water-proofing rubber grommet which seals the bulb base into the signal socket must be trimmed down flush to the “top” of the socket in order for these bulbs to fit. Each:
    $ 14.95
    HCP25370ASET2 Aftermarket turn signal LED BULBS, set of 2:
    $ 27.95
    HCP25370ASET4 Aftermarket turn signal LED BULBS, set of 4:
    $ 47.95
    HCP17175 Aftermarket turn signal MODULAR BULB and BASE SET. Fits all 1992-98 XJ600 Seca II front signals, all XJ700 and XJ750-X front turn signals, and all XJ1100 front turn signals models, or any other model converted to a 3-wire (running light) turn signal system. These ULTRA-DUTY, ULTRA-BRIGHT HALOGEN bulbs fit into a specially constructed base, and the bulbs will last for a mean average of 2000 running hours and are approximately 80% brighter than any other conventional incandescent bulb. Draws 20W at 14.5V. NOTE: these bulbs can also be used as tail/brake light bulbs. Replacement bulbs for these kits are available as part HCP16728. Each:
    $ discontinued
    HCP17175SET2 Aftermarket ultra-duty halogen MODULAR BULB and BASE SETS, set of 2:
    $ discontinued
    HCP17175SET4 Aftermarket ultra-duty halogen MODULAR BULB and BASE SETS, set of 4:
    $ discontinued
    HCP16728 Aftermarket ultra-duty halogen BULB. Use this super-bright halogen bulb with the HCP17175 bulb kits above. Each:
    $ discontinued
  28. chacal
    TURN SIGNAL FLASHER RELAY ("FLASHER") and SELF-CANCELLER:
    tsrs1) OEM turn signal system FLASHER and SELF-CANCELLER RELAY. In order to design a "self-canceling" turn signal system, Yamaha chose to use a simple but very different style turn signal Flasher than what is used in almost all other vehicle applications. Of course, the unique design of this flasher unit makes it, let's say, "pricey" to say the least! However, if you want your self-canceling feature to work then you'll have to use this original flasher. NOTE: most aftermarket mechanical or solid-state flashers will not function (at all) in place of the original flasher, and even the ones that do (see below) will disable the use of the self-canceller feature from operating.
    Also, if you substitute LED bulbs in your turn signals for the standard incandescent bulbs, then the stock flasher (which is mechanical) will not see enough of an electrical load to be able to flash correctly, if at all. In such a situation, the stock flasher is not defective, it is just designed to operate at a much higher voltage draw than LED lights provide, and you will need to replace the stock flasher with an aftermarket solid-state flasher. NOTE: the use of most aftermarket, solid-state flasher relays will defeat the self-canceller feature of the original system.
    NOTE: All of the following information applies to all models except 1984-85 FJ600, all XJ700, and XJ750-X models.....those models use an "integrated relay" unit that combines the flasher relay and self-canceller into one device.
    Identification: The FLASHER is contained in a large, rectangular black hard-plastic "box" housing, and has the following 3 wires connected to it: a solid brown wire, a brown wire with a white tracer stripe, and a yellow wire with a green tracer stripe.
    The SELF-CANCELLER UNIT is a rectangular, sealed, rubber-coated box with 6 wires coming out of it into a connector: a solid tan wire, two (2) white wires with a green tracer stripe, a yellow wire with a green tracer stripe, a yellow wire with a red tracer stripe, and a white wire with a red tracer stripe.
    By the way, the self-canceller operates off both time AND distance measurements to determine when it should cancel the flashers.....a minimum of 10 seconds time and 150 meters (about 400 feet) distance. BOTH criteria must be met before the canceller releases the signal flasher:
    http://www.xjbikes.com/forums/threads/help-with-automatic-cancel.81440/
    NOTE: the signal system is designed so that it will still operate if the self-canceller module fails; of course, in such a situation, you will have to cancel the signals manually (by pushing straight “in” on the thumb lever after it has returned to the center position). To diagnose problems with your signal system, you should follow these steps:
    1) unplug the self-canceller from the main harness.
    2) identify the following wire on the main harness side of the plug: white with green tracer stripe wire and the solid black wire.
    3) using a volt/ohm meter set on the ohms x 100 range, probe those two wires and then spin the front wheel. The ohms reading should shuttle back and forth between 0 and infinity
    4) if the above is good, now identify the yellow with red tracer stripe wire. Hook one lead of your ohm meter to it, and the other to a good chassis grounding point. Now, with the flasher switch on the handlebars OFF (center position), the meter should read infinity. With the lever moved to either the left or right signal engagement position, the ohm meter should read 0 ohms.
    If the signals work properly when the self-canceller is disconnected from the system, then you know that the flasher relay, the bulbs, and the handlebar switch circuit (inside the control switch on the handlebars) is okay. If the signals won't operate properly, even with the self-canceller removed from the system, then it may be a problem within your control switch itself, the flasher relay, the signal bulbs, wiring, etc. The movement of the thumb lever fully to one side, AND THEN RELEASING THE LEVER, should:
    a) allow the lever to return to center, and
    b) keep the turn signals ON (flashing) in whichever direction you had chosen, until either:
    i) the self-canceller, if plugged in the system, cancels the flashers, or......
    ii) if the self-canceller is un-plugged from the system, then the flasher will not cancel until you push "in" (or "down" depending on which model bike you have) on the lever, while the lever is in the center position.
    Having to hold the lever fully over to the left or right position is an indication that the internal contacts (within the switch housing) may be wonky. There is a "two-armed" contact that can get bent, or, the slider contacts may have gotten dirty and/or the solder connections to the slider contacts have broken or become loose:
    http://www.xjbikes.com/forums/threads/turn-signal-switch-question-w-photo.61051/#post-453580
    and
    http://www.xjbikes.com/forums/threads/electrical-challenges.53983/page-2
    The first link above has a good image of the copper contact "arms" that can get bent, and will thus no longer make contact with the brass "button" contact on the bottom of the pivoting lever arm (one button contact on each side of the lever arm), while the second link has some good images of the slider assembly.
    HCP29765 OEM turn signal FLASHER. For all all 1981-84 XS400, all XJ550, all XJ650, all air-cooled XJ750, all XJ900RK, RL, N, and FN models, 1981-83 XV750 Virago, 1981-83 XV920 Virago, XJ1100, and 1981 XS1100 models. Also fits the following non-XJ models: 1984-85 RZ350 and 1986 SRX600 models. Will also functionally (electrically) to replace the original round-can flasher relay as used on the following models: all 1978-80 XS1100 models, 1976-77 XS360, 1976-79 RD400, 1978-80 SR500, 1978-80 XS400, 1976-78 XS500, 1977-80 XS650 Standards, 1978-80 XS650 Specials, and all 1977-79 XS750 models. The rubber mounting grommet is not included (so save the one off your original relay!). These units will not work with LED bulbs.
    $ 199.95
    HCP423 OEM turn signal FLASHER. For all XJ550, XJ1100, and all 1981 XS1100 models, as well as 1981-82 XS400 Standard and Specials, 1981-83 XV750 Virago, and all 1981-83 XV920 Virago models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ discontinued, replaced by HCP29765 above
    HCP424 OEM turn signal FLASHER. For all XJ650, all XJ750 non-X, and all XJ900RK, RL, and N/FN models as well as 1984-85 RZ350, 1982-83 XS400 Maxim and Seca models, and 1986 SRX600 models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 189.95
    HCP22647 OEM turn signal FLASHER. For all 1992-96 XJ600 Seca II models, as well as the following non-XJ bikes: 1992-93 TDM850, 1994 YZF750R, 1993-94 GTS1000, 1991-93 FZR1000, and 1991-93 FJ1200A models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 119.95
    HCP22648 OEM turn signal FLASHER. For all 1997-98 XJ600 Seca II models, as well as the following non-XJ bikes: 1996-2007 XV250 Virago, 2008-16 XV250 V-Star, 1995-96 YZF600R, 1996-98 YZF750R, 1997 YZF1000R, 1994-95 FZR1000, 2004-10 FJR1300, 2002-12 XVZ13 ROYAL STAR VENTURE, 2004-05 FZ1, and 2009-16 FZ6 / FZR6 models. Comes with a mounting grommet. These units will not work with LED bulbs.
    $ 179.95
    HCP425 OEM turn signal FLASHER, CANCELLER, AND RELAY MODULE UNIT. For all 1984-85 FJ600, 1987 FZ600, 1986 YX600 Radian, all XJ700 models, XJ750-X. as well as the following non-XJ bikes: 1987-99 XV535 Virago, 1984-87 XV700 Virago, 1989-94 XV750 Virago, 1984-85 XV1000 Virago, 1986-94 XV1100 Virago, 1984-85 and 1989 XVZ12, 1986-93 XVZ13, 1988-90 FZR400, 1987 FZX700 Fazer, 1985-87 FZ750, 1987 FZR750R, 1987-88 FZR1000, 1984-85 FJ1100, 1986-87 FJ1200, and 1985-86 and 1989 VMX12 V-Max models.
    $ 199.95
    NOTE: when using any of the following aftermarket flasher units on bikes with a single dash indicator bulb for the turn signals (XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and 1983-84 XJ750 Maxim and Midnight Maxim), it will be necessary to replace the stock incandescent dash indicator bulb with a polarized LED bulb (HCP361NW or HCP359NW listed below).
    In addition, if you are replacing the actual turn signal indicator (dash) light with an LED bulb, then a DIODE WIRES KIT will be needed in order to isolate the flasher circuits and prevent all four flashers from operating all at once!
    $ 14.95
    HCP14788 Aftermarket solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will not work with LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the use of the HCP11105 or HCP15149 mounting grommet.
    $ 24.95
    HCP16921 Aftermarket solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the use of the HCP11105 or HCP15149 mounting grommet.
    $ 22.95
    HCP353 Aftermarket heavy-duty, solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the fabrication of a mounting method as the original size grommet will not work.
    $ 23.95
    HCP353A Aftermarket heavy-duty, solid-state turn signal ADJUSTABLE-SPEED FLASHER. Same as the HCP353 above, but this unit has an adjuster screw that allows you to set the frequency of the flasher on/off performance. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit will not operate properly with this style flasher, and it must be by-passed via the use of the HCP16880 adapter plug below. Will require the fabrication of a mounting method as the original size grommet will not work.
    $ 27.95
    HCP25332 Aftermarket solid-state turn signal FLASHER. For all XJ550, XJ650, all XJ750 non-X, all XJ900RK, RL, and N/FN models, and XJ1100 models. These units will work with both incandescent and LED signal bulbs. Plugs directly into the stock wiring harness 3-place flasher connector plug. Your original turn signal canceller unit WILL operate properly with this style flasher, and this unit does not require the use of the HCP16880 adapter plug. Will require the fabrication of a mounting method as the original size grommet will not work.
    $ 39.95
    HCP16880 Aftermarket turn signal flasher self-canceller ADAPTER PLUG for use with our aftermarket turn signal flasher relays. The use of solid state aftermarket turn signal flasher units will defeat the original self-canceller unit, and in order for the aftermarket flasher relays to operate properly, you must bypass the original self-canceller unit. This completely "plug-and-play" adapter provides the proper ground path for the flasher relay, which the original self-canceller will not. Each:
    $ 17.95
    HCP361NW Aftermarket turn signal warning WHITE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models, for use with any of our aftermarket turn signal flasher units above. Slightly brighter than stock incandescent bulb. Each:
    $ 2.50
    HCP356NW Aftermarket turn signal warning WHITE LED BULB, for all 1981-83 XJ550 Maxim, 1982-83 XJ650 Maxim, and 1983 XJ750 Maxim and Midnight Maxim models, for use with any of our aftermarket turn signal flasher units above. Slightly brighter than stock incandescent bulb. Each:
    $ 7.95
    HCP11105 Aftermarket rubber RELAY HOLDER for original metal-lid "cube" type safety system, headlight, sidestand, fuel pump, etc. relays. This grommet has a square opening (it's a copy of the original grommet), and molded of a thick-wall rubber compound. NOTE: does not fit the later style plastic-lid cube relays or the HCP353, HCP353A, or HCP25332 aftermarket relays. Each:
    $ 12.95
    HCP28736 Aftermarket rubber RELAY HOLDER fits the HCP353, HCP353A, or HCP25332 aftermarket relays. Original style with the “slot” at the top which fits onto the metal bracket, but has the much larger opening required for these aftermarket relay. Will not fit original metal or plastic cube style relays (the opening is too large). Each:
    $ 11.95
    HCP15149 Aftermarket rubber RELAY HOLDER for original metal rectangular "cube" type safety system, headlight, sidestand, fuel pump, etc. relays. NOTE: the original relay holders have a square opening (which matches the shape of the original square "cube" relays); these replacements have a round opening, however, they will flex and fit the original metal "rectangular" lid relays properly, but will not fit the later style plastic-lid cube relays or some of the aftermarket relays. Will also fit any round "can" style relay up to 32mm OD. Each:
    $ 11.95
    HCP9321 Aftermarket headlight or turn signal flasher TERMINAL CONNECTOR, black plastic molded 3-position terminal housing replaces missing or damaged original. Comes with terminals and lead wires already installed, although the lead wire colors (blue, green, and white) will not match the original lead wire colors. Fits all XJ series model flashers except for 1985-86 XJ700 and XJ750-X models.
    $ 6.95
    TAIL LIGHTS:
    Tail Light Assemblies:
    HCP23860 Aftermarket rear tail light ASSEMBLY, complete unit includes the lense, housing, bulb, socket, and lead wires. Very nice reproduction of the original. Fits all XJ650RJ Seca and XJ650 Euro models.
    $ 69.95
    HCP1420 Aftermarket rear tail light ASSEMBLY, complete unit includes the lense, housing, bulb, socket, and lead wires. Very nice reproduction of the original. Fits all 1982-83 XJ750 Maxim and 1982-84 XJ1100 Maxim models.
    $ 469.95
    Tail Light Lenses:
    tll2) OEM rear tail light LENSES, GASKETS, and HARDWARE perfectly replace damaged, missing, cracked, or faded originals.
    HCP719 OEM rear tail light LENSE, for all XJ550 Maxim, 1982-83 XJ650 Maxim, 1983 XJ750 Midnight Maxim, and XJ750-P Police (37H) models. Does not include the gasket. Each:
    $ 139.95
    HCP20165 OEM rear tail light LENSE, for all FJ600 models. Does not include the gasket. Each:
    $ 69.95
    HCP720 OEM rear tail light LENSE, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Does not include the gasket. Each:
    $ 119.95
    HCP722 OEM rear tail light LENSE, for all 1982 XJ650RJ Seca models. Does not include the gasket. Each:
    $ 47.95
    HCP721 OEM rear tail light LENSE, for all 1982 XJ650 Turbo models. Does not include the gasket. Each:
    $ 179.95
    HCP725 OEM rear tail light LENSE, for all XJ700, XJ750-X, and 1981 XV750 Virago models. Does not include the gasket. Each:
    $ 119.95
    HCP727 OEM rear tail light LENSE, for all 1981-83 XJ750 Seca and XJ750 Euro models. Does not include the gasket. Each:
    $ 199.95
    HCP724 OEM rear tail light LENSE, for all 1984 XJ750RL Seca and 1983 XJ900RK models. Does not include the gasket. Each:
    $ 249.95
    Tail Light Lens Gaskets:
    HCP15070 Aftermarket rear tail light lense GASKET, for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, 1983 XJ750 Midnight Maxim, and XJ750-P Police (37H) models. Each:
    $ 14.95
    HCP1973 Aftermarket rear tail light lense GASKET, for all FJ600 models. Each:
    $ 19.95
    HCP3621 OEM rear tail light lense GASKET, for all XJ650RJ Seca models. Each:
    $ 16.95
    HCP16540 Aftermarket rear tail light lense GASKET, for all XJ700 and XJ750-X models, thin sponge-foam strip seals the lense to the white plastic internal housing. Pressure-sensitive adhesive backing. Each:
    $ 19.95
    HCP29999 Aftermarket rear tail light lense GASKET, for all 1982 XJ750 Maxim and XJ1100 models, thin sponge-foam strip seals the lense to the tail light housing. Each:
    $ 19.95
    HCP4161 OEM rear tail light lense GASKET, for all XJ750 Seca and XJ750 Euro models. Each:
    $ 69.95
    Tail Light Lens Hardware:
    HCP3956 OEM rear tail light lense SCREW, bright plated phillips-drive panhead machine screw. For all 1980-81 XJ650 Maxim and Midnight Maxim models, as well as the 1982 XJ650RJ Seca model. Use 2 per lense. Each:
    $ 7.95
    HCP23031 Aftermarket rear tail light lense SCREW, zinc-plated alloy steel phillips-drive panhead design. For all 1980-81 XJ650 Maxim and Midnight Maxim models, as well as the 1982 XJ650RJ Seca model. Use 2 per lense. Each:
    $ 1.95
    HCP23030 Aftermarket rear tail light lense SCREW, 18-8 stainless steel phillips-drive with correct JIS small panhead design. For all 1980-81 XJ650 Maxim and Midnight Maxim models, as well as the 1982 XJ650RJ Seca model. Use 2 per lense. Each:
    $ 3.95
    HCP23032 Aftermarket rear tail light lense SCREW, 18-8 stainless steel with phillips-drive panhead design. For all 1980-81 XJ650 Maxim and Midnight Maxim models, as well as the 1982 XJ650RJ Seca model. Use 2 per lense. Each:
    $ 2.95
    HCP20166 OEM rear tail light lense SCREW, bright plated phillips-drive panhead thread-forming screw. For all 1984-85 FJ600 models. Use 2 per lense. Each:
    $ 7.95
    HCP3957 OEM rear tail light lense SCREW, bright plated, phillips-drive panhead screw. For all XJ550 Maxim models, all 1982-3 XJ650 Maxim models, as well as the 1983 XJ750 Midnight Maxim model. Use 2 per lense. Each:
    $ 9.95
    HCP3959 OEM rear tail light lense SCREW, bright plated, phillips-drive pan head thread-forming screw. For all XJ650 Turbo models. Use 2 per lense. Each:
    $ 7.95
    HCP21391 Aftermarket rear tail light lense SCREW, 18-8 stainless steel, phillips-drive panhead thread-forming screw properly replaces the original. For all XJ650 Turbo models. Use 2 per lense. Each:
    $ 2.95
    HCP3961 OEM rear tail light lense SCREW, bright plated, phillips-drive panhead thread-forming screw. For all XJ700 and XJ750-X models. Use 2 per lense. Each:
    $ 7.95
    HCP3958 OEM rear tail light lense SCREW, bright plated, phillips-drive panhead thread-forming. For all XJ750 Maxim and XJ1100 models. Use 2 per lense. Each:
    $ 7.95
    Tail Light Lense/Housing Mounting Hardware:
    HCP2171 OEM tail light housing-to-fender mounting BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP24067 Aftermarket tail light housing-to-fender mounting BOLT, 6-point hex head alloy steel fastener with a bright zinc-plated finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 1.95
    HCP24077 Aftermarket tail light housing-to-fender mounting BOLT, 6-point hex head 18/8 stainless steel fastener with a bright finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP24078 Aftermarket tail light housing-to-fender mounting BOLT, 6-point hex head 316 stainless steel fastener with a bright finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP6639 Aftermarket tail light housing-to-fender mounting BOLT, socket head (hex-key drive) 18/8 stainless steel fastener with a bright finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP24075 Aftermarket tail light housing-to-fender mounting BOLT, socket head (hex-key drive) 316 stainless steel fastener with a bright finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 2.95
    HCP6640 Aftermarket tail light housing-to-fender mounting BOLT, socket head (hex-key drive) black oxide-coated alloy steel fastener, secures the bucket to the bracket from inside the bucket. Use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim models, and all XJ750 Midnight Maxim models. Each:
    $ 1.95
    HCP3029 OEM tail light housing-to-fender mounting BOLT, standard 6-point hex-head alloy steel bolt with a dark finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 3.95
    HCP14007 Aftermarket tail light housing-to-fender mounting BOLT, standard 6-point hex-head alloy steel bolt with a yellow zinc-plated finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP22249 Aftermarket tail light housing-to-fender mounting BOLT, standard 6-point hex-head 18/8 stainless steel bolt with a bright finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP14008 Aftermarket tail light housing-to-fender mounting BOLT, standard 6-point hex-head 316 stainless steel bolt with a bright finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 3.95
    HCP22253 Aftermarket tail light housing-to-fender mounting BOLT, socket head (allen-key drive) alloy steel with a yellow zinc-plated finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP228 Aftermarket tail light housing-to-fender mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP2779 Aftermarket tail light housing-to-fender mounting BOLT, socket head (allen-key drive) alloy steel with a black-oxide finish, features self-locking threads. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP226 Aftermarket tail light housing-to-fender mounting BOLT, socket head (allen-key drive) 18/8 stainless steel with a bright finish. Use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP3701 OEM tail light housing-to-cowling mounting BOLT, use 2 per housing for all XJ750 Seca models. Originals were bright plated, these replacements feature a dark phosphate plating. Each:
    $ 3.95
    HCP13157 Aftermarket tail light housing-to-cowling mounting BOLT, use 2 per housing. Bright plated hex-head 18/8 stainless steel bolt is correct for all for all XJ750 Seca models. Each:
    $ 2.95
    HCP13158 Aftermarket tail light housing-to-cowling mounting BOLT, use 2 per housing. Black-oxide coated hex-head 18/8 stainless steel bolt is correct for all for all XJ750 Seca models. Each:
    $ 2.95
    HCP9319 OEM tail light housing-to-fender mounting BOLT WITH WASHER, use 3 per housing for all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP17613 Aftermarket rear tail light housing SCREW, bright plated phillips head perfectly replaces the originals. For all 1985-86 XJ700 and XJ750-X models. Use 3 each to secure the housing mounting plate to the housing, and to secure the bulb reflector unit to the housing. Each:
    $ 0.95
    HCP20167 OEM tail light lense assembly RUBBER DAMPER WASHER, for the tail light lense housing mounting studs to the frame bracket, use 3 for all FJ600 models. Each:
    $ 8.95
    HCP3962 OEM tail light lense assembly RUBBER DAMPER WASHER, for the tail light lense housing mounting studs to the frame bracket, use 2 for all XJ650 Turbo models. Each:
    $ discontinued
    HCP7536 OEM tail light lense assembly RUBBER DAMPER WASHER, for the tail light lense housing mounting bolts through the rear storage box, use 2 for all XJ650RJ Seca models. Each:
    $ 7.95
    HCP7537 OEM tail light lense assembly RUBBER DAMPER WASHER, for the tail light lense housing mounting bolts through the rear storage box, use 2 for all XJ650RJ Seca models. Each:
    $ 7.95
    HCP9317 OEM tail light housing-to-fender mounting GROMMET, use 3 per housing for all XJ700, XJ750-X, XJ750 Maxim, and XJ1100 models. Each:
    $ 7.95
    HCP6271 OEM tail light housing-to-fender mounting bolt COLLAR, use 3 per housing for all FJ600 models. Each:
    $ 6.95
    HCP2986 OEM tail light lense assembly SPACER COLLAR, for the tail light lense housing mounting studs to the frame bracket, use 2 for all 1982 XJ650 Turbo models. Each:
    $ 7.95
    HCP3693 OEM tail light lense assembly SPACER COLLAR, for the tail light lense housing mounting studs to the frame bracket, use 2 for all 1983 XJ650 Turbo models. Each:
    $ 14.95
    HCP9318 OEM tail light housing-to-fender mounting bolt COLLAR, use 3 per housing for all XJ700 and XJ750-X models. Each:
    $ 7.95
    HCP9320 OEM tail light housing-to-fender mounting bolt COLLAR, use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 7.95
    HCP3960 OEM tail light lense assembly FLAT WASHER, for the tail light lense housing mounting studs to the frame bracket, use 2 for all XJ650 Turbo models. Each:
    $ 7.95
    HCP2173 OEM tail light housing-to-fender mounting bolt FLAT WASHER, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Midnight Maxim models, each:
    $ 2.95
    HCP6642 Aftermarket tail light housing-to-fender mounting bolt FLAT WASHER, zinc-plated alloy steel with a natural finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Midnight Maxim models, each:
    $ 1.95
    HCP6643 Aftermarket tail light housing-to-fender mounting bolt FLAT WASHER, 18-8 stainless steel with a natural finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Midnight Maxim models, original bright finish, each:
    $ 2.95
    HCP25756 Aftermarket tail light housing-to-fender mounting bolt FLAT WASHER, 316 stainless steel with a natural finish, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Midnight Maxim models, each:
    $ 3.95
    HCP14285 Aftermarket tail light housing-to-fender mounting bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Midnight Maxim models, each:
    $ 2.95
    HCP14284 Aftermarket tail light housing-to-fender mounting bolt FLAT WASHER, black oxide-coated hardened alloy steel, use 3 per housing for all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Midnight Maxim models, each:
    $ 2.95
    HCP4254 OEM tail light housing-to-fender mounting bolt FLAT WASHER, use 3 per housing for all FJ600, XJ750 Maxim, and XJ1100 models. Each:
    $ 2.95
    HCP315 OEM tail light housing-to-fender mounting bolt LOCK WASHER, use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, tail light housing-to-fender mounting bolt LOCK WASHER, use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel tail light housing-to-fender mounting bolt LOCK WASHER, use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel tail light housing-to-fender mounting bolt LOCK WASHER, use 3 per housing for all XJ750 Maxim and XJ1100 models. Each:
    $ 1.95
    HCP2176 OEM tail light lense assembly MOUNTING NUT, retains the tail light lense housing mounting studs to the license plate or frame bracket, for all XJ550 Seca and FJ600 models (use 3) and XJ650 Turbo (use 2) models. Each:
    $ 4.95
    HCP29085 Aftermarket tail light lense assembly MOUNTING NUT, bright zinc-plated alloy steel, retains the tail light lense housing mounting studs to the license plate or frame bracket, for all XJ550 Seca and FJ600 models (use 3) and XJ650 Turbo (use 2) models. Each:
    $ 1.95
    HCP24059 Aftermarket tail light lense assembly MOUNTING NUT, black-oxide coated stainless steel, retains the tail light lense housing mounting studs to the license plate or frame bracket, for all XJ550 Seca and FJ600 models (use 3) and XJ650 Turbo (use 2) models. Each:
    $ 3.95
    HCP24035 Aftermarket tail light lense assembly MOUNTING NUT, made from 18/8 stainless steel, retains the tail light lense housing mounting studs to the license plate or frame bracket, for all XJ550 Seca and FJ600 models (use 3) and XJ650 Turbo (use 2) models. Each:
    $ 2.95
    Tail Light - Brake Light Bulbs:
    HCP3607 Aftermarket dual-filament tail - brake light BULB. Use 1 on all 1980-81 XJ650 Maxim and Midnight Maxim models, and 2 each on all other models of XJ-series bikes and FJ600 models. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. NOTE: these bulbs are also used on XJ700, XJ750-X, and XJ1100 front turn signals. Each:
    $ 2.50
    $ 4.75
    $ 9.25
    $ 16.95
    HCP3607LL Aftermarket dual-filament tail - brake light BULB. Use 1 on all 1980-81 XJ650 Maxim and Midnight Maxim models, and 2 each on all other models of XJ-series bikes and FJ600 models. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. NOTE: these bulbs are also used on XJ700, XJ750-X, and XJ1100 front turn signals. Each:
    $ 3.00
    $ 5.75
    $ 9.95
    $ 18.95
    HCP3607DL40 Aftermarket dual-filament tail - brake light BULB. Use 1 on all 1980-81 XJ650 Maxim and Midnight Maxim models, and 2 each on all other models of XJ-series bikes and FJ600 models. These SUPER-DUTY ULTRA-BRIGHT bulbs last for a mean average of 1000 running hours and are approximately 40% brighter than the standard or long-life bulbs. NOTE: these bulbs are also used on XJ700, XJ750-X, and XJ1100 front turn signals. Each:
    $ 6.95
    $ 12.75
    $ 23.95
    $ 54.95
    HCP17175 Aftermarket dual-filament, tail/brake light MODULAR BULB and BASE SET. Use 1 on all 1980-81 XJ650 Maxim and Midnight Maxim models, and 2 each on all other models of XJ-series bikes and FJ600 models. These ULTRA-DUTY, ULTRA-BRIGHT HALOGEN bulbs fit into a specially constructed base, and the bulbs will last for a mean average of 2000 running hours and are approximately 80% brighter than any other conventional incandescent bulb. Draws 20W at 14.5V. NOTE: these bulbs are also used on XJ700, XJ750-X, and XJ1100 front turn signals. Replacement bulbs for these kits are available as part HCP16728. Each:
    $ discontinued
    $ discontinued
    $ discontinued
    $ discontinued
    BRAKE LIGHT FLASHER UNIT:
    Safety first!
    Too many people, who are too busy twiddling their radio dials or shuffling their iPod controls or twittering or texting silly, trivial messages and thus have no time, to, like, actually pay attention to the world outside of them while hurtling down the road, are a horrible accident just waiting to happen.....to you. And in a collision between car and bike, bike and rider are typically the big loser.
    So be seen by being obnoxious! These solid-state BRAKE LIGHT FLASHER units will "strobe" the tail light bulbs by interrupting and then returning power to the tail-light circuit, thus creating a pulsing appearance from your tail-light that you see on many late-model bikes. You've noticed those, haven't you? Well, so does everyone else.............and that's the whole point.
    The rapid pulsing effect starts immediately every time you apply the brakes (front or rear), and then the flash rate decays over a period of about 4 seconds until the brake light is fully on, and remains that way until the brake is released and re-applied. This configuration makes the flasher units street-legal in all 50 states.
    These durable electronic control units are easy to install (30 minutes or less) and are truly a plug-and-play operation. All of our modulator units can be used on all XJ-series bikes, including those with the "computer monitor" system in the gauge cluster. Brake-light flasher units are available in two different primary types, which differ from each other in their installation and design:
    - a remote-mounted unit that can be located anywhere on the bike, and integrates easily into your bike's stock wire harness with their included harness adapter wires and plugs. Although these remotely mounted units can be used on any XJ-series bike, they are most typically used when you either want to retain the use of your stock incandescent tail- and brake-light bulbs, or, if you are using aftermarket LED style tail- and brake-light bulbs. Some versions (as specified below) of these units are not compatible with bikes that have the "bulb monitoring" system in gauge cluster (XJ650 Turbo, XJ750 Seca, and XJ1100 models) nor for use with bikes using LED bulbs, while a more sophisticated version of the remote flasher unit accommodates all model bikes and can be used with LED bulbs. Available in both a value-priced and a heavy-duty, premium version, these units require no harness cutting or splicing, and can be easily installed on most models within simple hand tools.
    - a bulb-replacement version that simply replaces your original tail- and brake-light bulb(s)....how's that for an easy performance upgrade? These modulators look just like a standard tail-light bulb, with their dual-pin 1157 style cylinder base, and contain all their solid-state electronics within the base of the bulb unit, and then use a replaceable, plug-in, super-bright, long-life (2000+ hours) halogen bulb. Use one of these units on all 1980-81 XJ650 Maxim and Midnight Maxim models, and XJ650RJ Seca models. Use two of these units on all other models: XJ550 models, XJ650 Turbo, 1982-84 XJ650 Maxim, all XJ700 models, all XJ750 models, all XJ900 models, and all XJ1100 models. These units are "tuned" to modulate in unison with each other when used in the multi-bulb systems.
    Remote-Mounted Brake Light Modulator Units:
    The following value-priced remote-mounted brake light flasher units cannot be used on any bike that has the "bulb monitoring" circuitry. The use of the HCP16884 adapter wire is required for use on any bike that is equipped with LED type tail- and brake-light bulbs.
    Style A: this style flasher will flash continuously, at a rate of about 2 flashes-per-second, as long as the brake pedal or brake lever are applied. This style flasher is NOT street-legal in California.
    Style B: this style flasher will flash for the first 8 seconds after the initial application of the brakes, and then end the flashing and leave the brake light fully on (no flashing) for as long as the brakes are left applied. If the brakes are released and then re-applied within the next 30 seconds (after the initial application of the brakes), the brakes lights will flash for a shorter period of time, and then stay on continuously. This process will be repeated over and over, with each subsequent application of the brakes resulting in a shorter "flash time" before the brake light stays on continuously. After a full 30 seconds from the last time the brake is applied, the cycle will re-start at the "8-seconds of flash time". The purpose of this sequence is to prevent an almost continual flashing of the brake lights in stop-and-go traffic (or while waiting at a traffic stop) situation, when a continuous, never-ending flashing of a brake light is unnecessary and very annoying to the people behind you. This style flasher IS street-legal in California.
    Each of the kits listed below contains a brake light flasher unit, all necessary adapter harnesses, and includes illustrated mounting location and wiring connection instructions. For most bikes this will be a 20-30 minute installation!
    HCP14587KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650 Maxim, and 1983-84 XJ750 Maxim and Midnight Maxim models. Comes with wire harness adapters and installation instructions. This is the "Style A, always-flashing" unit as described above, and is NOT legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 89.95
    HCP14593KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ550 Maxim, and 1983-4 XJ750 Maxim and Midnight Maxim models. Comes with wire harness adapters and installation instructions. This is the "Style B, intermittent-flashing" unit as described above, and IS legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 99.95
    HCP14585KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ550 Seca, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Comes with wire harness adapter and installation instructions. This is the "Style A, always-flashing" unit as described above, and is NOT legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 99.95
    HCP14591KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ550 Seca, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Comes with wire harness adapter and installation instructions. This is the "Style B, intermittent-flashing" unit as described above, and IS legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 99.95
    HCP14588KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650 Maxim and Midnight Maxim models. Comes with wire harness adapters and installation instructions. This is the "Style A, always-flashing" unit as described above, and is NOT legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 89.95
    HCP14594KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650 Maxim and Midnight Maxim models. Comes with wire harness adapters and installation instructions. This is the "Style B, intermittent-flashing" unit as described above, and IS legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 99.95
    HCP14589KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650RJ Seca and all XJ650 Euro (4K0) models. Comes with installation instructions. NOTE: requires drilling a small 1/4" wiring harness access hole in the rear tool kit "storage compartment". This is the "Style A, always-flashing" unit as described above, and is NOT legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 87.95
    HCP14595KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650RJ Seca and all XJ650 Euro (4K0) models. Comes with installation instructions. NOTE: requires drilling a small 1/4" wiring harness access hole in the rear tool kit "storage compartment". This is the "Style B, intermittent-flashing" unit as described above, and IS legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 89.95
    HCP14590KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650 Euro (4K1), all XJ700, and XJ750-X models. Comes with wire harness adapter and installation instructions. This is the "Style A, always-flashing" unit as described above, and is NOT legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 89.95
    HCP14596KIT Aftermarket STANDARD BRAKE LIGHT FLASHER unit, fits all XJ650 Euro (4K1), all XJ700, and XJ750-X models. Comes with wire harness adapter and installation instructions. This is the "Style B, intermittent-flashing" unit as described above, and IS legal for street use in California. Will not work with LED brake light bulbs unless the HCP16884 adapter wire listed below is used.
    $ 99.95
    HCP16884 Aftermarket standard brake light flasher LED ADAPTER WIRE HARNESS, allows the use of LED tail- and brake-light bulbs with the use of any of our standard style brake light flashers. Simple plug-and-play operation.
    $ 17.95
    The following premium remote-mounted brake light flasher units can be used on any bike that has the "bulb monitoring" circuitry. Each of the kits listed below contains a heavy-duty, remote-mount brake light modulator unit, all necessary wiring adapter harnesses (no harness cutting or wire splicing needed!), and includes illustrated mounting location and wiring connection instructions. For most bikes this will be a 20-30 minute installation. Can be used on all XJ-series models, including models with "computer display" gauge clusters that have the bulb-monitoring function, as well as bikes equipped with LED tail- and brake-lights.
    HCP16741KIT Aftermarket PREMIUM BRAKE LIGHT FLASHER unit, fits all XJ650 Maxim and Midnight Maxim models, XJ650RJ Seca, and XJ650 Euro 4K0 models. Comes with wire harness adapters and installation instructions. NOTE: requires drilling a small 1/4" wiring harness access hole in the rear tool kit "storage compartment" on XJ650RJ Seca and XJ650 Euro 4K0 models. Will work with stock incandescent or aftermarket LED brake light bulbs. Bulbs are not included.
    $ 109.95
    HCP16742KIT Aftermarket PREMIUM BRAKE LIGHT FLASHER unit, fits all XJ550 Maxim models, XJ650 Euro 4K1 models, all XJ700 models, XJ750-X models, and 1983-84 XJ750 Maxim and Midnight Maxim models. NOTE: requires drilling a small 1/4" wiring harness access hole in the rear tool kit "storage compartment" on XJ650 Euro 4K1 models. Comes with wire harness adapters and installation instructions. Will work with stock incandescent or aftermarket LED brake light bulbs. Bulbs are not included.
    $ 109.95
    HCP16743KIT Aftermarket PREMIUM BRAKE LIGHT FLASHER unit, fits all XJ550 Seca models, XJ550 Euro models, XJ750RL, and all XJ900 models. Comes with wire harness adapters and installation instructions. Will work with stock incandescent or aftermarket LED brake light bulbs. Bulbs are not included.
    $ 109.95
    HCP16744KIT Aftermarket PREMIUM BRAKE LIGHT FLASHER unit, fits all XJ650-P (Police) models, 1982 XJ750 Maxim models, XJ750-P (Police) models, and all XJ1100 models. Comes with wire harness adapters and installation instructions. Will work with stock incandescent or aftermarket LED brake light bulbs. Bulbs are not included.
    $ 109.95
    HCP16745KIT Aftermarket PREMIUM BRAKE LIGHT FLASHER unit, fits all XJ650 Turbo and XJ750-D models. Comes with wire harness adapters and installation instructions. Will work with stock incandescent or aftermarket LED brake light bulbs. Bulbs are not included.
    $ 109.95
    HCP16746KIT Aftermarket PREMIUM BRAKE LIGHT FLASHER unit, fits all 1981-83 XJ750 Seca models, and XJ750 Euro models. Comes with wire harness adapters and installation instructions. Will work with stock incandescent or aftermarket LED brake light bulbs. Bulbs are not included.
    $ 109.95
    Bulb-Replacement Brake Light Modulator Bulb:
    Each of the kits listed below contains a bulb-replacement brake light modulator bulb unit and a bulb. Can be used on all XJ-series models, including models with "computer display" gauge clusters that have the bulb-monitoring function. For most bikes this will be a 5 minute installation.
    Use one of these direct-replacement bulb units on all 1980-81 XJ650 Maxim and Midnight Maxim models, and XJ650RJ Seca models. Use two of these units on all other models: XJ550 models, XJ650 Turbo, 1982-84 XJ650 Maxim, all XJ700 models, all XJ750 models, all XJ900 models, and all XJ1100 models. These units are "tuned" to modulate in unison with each other when used in the multi-bulb systems.
    HCP16726 Aftermarket plug-in BULB REPLACEMENT BRAKE LIGHT MODULATOR. Simply twist your original 1157 style tail/brake light bulb out, twist these units in place, plug in the super-bright halogen bulb (included), and ride! Single unit:
    $ 49.95
    HCP16726SET Aftermarket plug-in BULB REPLACEMENT BRAKE LIGHT MODULATOR. Simply twist your original 1157 style tail/brake light bulb out, twist these units in place, plug in the super-bright halogen bulb (included), and ride! Set of 2 modulator bulb units:
    $ 89.95
    HCP16728 Aftermarket plug-in brake light modulator BULB. Use this super-bright halogen bulb with the HCP16726 modulator unit above. Each:
    $ discontinued
    LICENSE PLATE LIGHTS:
    License Plate Lenses:
    If your license plate bulb is out, the cops can't get your tag number so easily!
    Or maybe he'll just pull you over simply because of that fact. It is a ticket-able offense.
    The reflective license plate also helps to present a much bigger, much more visible image to people behind you.....an important safety consideration, much more so that on a 2-ton rolling cage.
    Here the parts you'll need for this often neglected area:
    HCP716 OEM rear license plate crystal-clear plastic LENSE. Fits all XJ550 models, all XJ650 Maxim and Midnight Maxim, and all XJ750 Midnight Maxim models.
    $ 39.95
    HCP1965 OEM rear license plate complete LENSE ASSEMBLY. Fits all XJ650 Turbo models.
    $ discontinued
    HCP1966 OEM rear license plate complete LENSE HOUSING. Fits all XJ650 Turbo models.
    $ discontinued
    HCP10052 OEM rear license plate lense RUBBER GASKET. Fits all XJ550 models, all XJ650 Maxim and Midnight Maxim, and all XJ750 Midnight Maxim models.
    $ 24.95
    HCP1964 OEM rear license plate lense MOUNTING SCREW. Fits all XJ550 models, all XJ650 Maxim and Midnight Maxim, and all XJ750 Midnight Maxim models. Use 2 per lense. Each:
    $ 8.95
    HCP1963 OEM rear license plate lense MOUNTING SCREW. Fits all XJ750 Seca models. Use 2 per lense. Each:
    $ 6.95
    HCP2336 OEM rear license plate lense assembly mounting SPECIAL WASHER, use 2 per housing on all XJ650 Turbo models. Each:
    $ 1.95
    HCP2334 OEM rear license plate lense assembly rubber mounting GROMMET, use 2 per housing on all XJ650 Turbo models. Each:
    $ discontinued
    License Plate Bulbs:
    HCP3610 Aftermarket rear license plate illumination BULB, correct wattage and bullet base for the following models: all XJ550, all XJ650 except Turbo, all XJ750 Seca and XJ750 Midnight Maxim models. Use 1 per bike. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. Each:
    $ 9.95
    HCP3610LL Aftermarket rear license plate illumination BULB, correct wattage and bullet base for the following models: all XJ550, all XJ650 except Turbo, all XJ750 Seca and XJ750 Midnight Maxim models. Use 1 per bike. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. Each:
    $ 5.95
    HCP3611 Aftermarket rear license plate illumination BULB, correct wattage and base for the following models: all XJ650 Turbo models. Use 2 per bike. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. Each:
    $ 11.95
    HCP3611LL Aftermarket rear license plate illumination BULB, correct wattage and base for the following models: all XJ650 Turbo models. Use 2 per bike. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. Each:
    $ 6.95
  29. chacal
    SECTION D:
    ELECTRICAL SYSTEM:
    --Chassis Electrical System: Gauges and related hardware, etc.
    GAUGES:
    Keeping up with the vital information is the responsibility of your gauges and instruments, and whether your bike uses the classic round analog gauges, or Yamaha's first attempt at "computer monitor" type of instrument clusters, we've got a selection of replacement parts for your devices.
    Here is a good review of how to actually get to your bulbs so you can replace them! Although shown on an XJ550 model, the basic process is the same on all clusters:
    https://www.xjbikes.com/forums/threads/bigfitzs-seca-550-instrument-cluster-teardown.116027/
    XJ750 Maxim and XJ750 Seca clusters are illustrated here:
    http://www.xj4ever.com/gauge cluster breakdown.pdf
    And the XJ700 style gauges are shown here:
    http://www.xj4ever.com/repairing your 700 gauges.pdf
    Instrument Cluster Gauge & Warning Lights Bulbs:
    1980-81 XJ650 Maxim and Midnight Maxim Dash Gauges, Turn Signal, and Warning Light Bulbs:
    incan1) These tiny can-based METER BULBS are the correct style and intensity for all 1980-81 XJ650 Maxim and Midnight Maxim models, and all 1978-81 XS1100 models. Use in the following positions and quantities:
    1980-81 XJ650 Maxim/Midnight Maxim gauges:
    use 1 per tacho
    use 1 per speedo
    use 4 per pilot box
    1978-81 XS1100 Standard models gauges:
    use 2 per tachometer
    use 2 per speedometer
    use 6 per warning light “pilot” box
    1978-81 XS1100 Special/MS gauges:
    use 4 per tachometer
    use 4 per warning light “pilot” box
    HCP3609 OEM meter illumination and warning BULB. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. Each:
    $ 4.95
    HCP3609SET6 OEM meter illumination and warning BULBS, set of 6:
    $ 27.95
    HCP3609SET10 OEM meter illumination and warning BULBS, set of 10:
    $ 39.95
    HCP3609LL OEM meter illumination and warning BULB. These LONG-LIFE, HEAVY-DUTY bulbs last for a mean average of 800 running hours. Each:
    $ 3.95
    HCP3609LLSET6 OEM meter illumination and warning BULBS, set of 6:
    $ 19.95
    HCP3609LLSET10 OEM meter illumination and warning BULBS, set of 10:
    $ 27.95
    HCP3609DL40 OEM meter illumination and warning BULB. These SUPER-DUTY ULTRA-BRIGHT bulbs last for a mean average of 1000 running hours and are approximately 40% brighter than the standard or long-life bulbs. Each:
    $ 4.95
    HCP3609DL40SET6 OEM meter illumination and warning BULBS, set of 6:
    $ 27.95
    HCP3609DL40SET10 OEM meter illumination and warning BULBS, set of 10:
    $ 37.95
    led1) Well, ain't technology great? They look brighter, are more efficient, and thus use alot less wattage to produce the same amount of light output, and thus these LED DASH GAUGE BULBS save you a bit of horsepower (less alternator output needed), and of course they'll basically outlive you and your bike!
    These direct replacement bulbs install just like the original socket base (1980-81 XJ650 Maxim and Midnight Maxim) or wedge-base bulbs (all other XJ models), and have been evaluated and tested to provide the proper level of illumination without creating a night-time glare condition. NOTE: bulbs listed as being "much brighter than stock" means just that......and something to keep in mind when ordering. Typically, bulbs that are typically "always on" during night-time riding (such as the speedo and tacho faceplate illumination, and the blue high-beam warning indicator light) can be very distracting if you choose the "much brighter than stock" option, so choose wisely --- bigger isn't always better!
    NOTE: when used for speedometer and tachometer face illumination, all LED bulbs listed as "slightly brighter than stock incandescent bulbs" will create a small "hot spot" at the top center of the speedo and tach faceplate.
    HCP360NW Aftermarket meter illumination and warning WHITE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Use a total of 6 bulbs per entire instrument cluster. Suitable for use in the following locations:
    - Speedometer and tachometer illumination (use 1 per gauge), slightly brighter than stock incandescent bulb.
    - Turn signal warning indicator yellow light (use 1), slightly brighter than stock incandescent bulb.
    - Neutral position warning indicator green light (use 1), slightly brighter than stock incandescent bulb.
    - High-beam warning indicator blue light (use 1), same brightness as the stock incandescent bulb.
    - Oil level warning indicator red light (use 1), same brightness as the stock incandescent bulb.
    Each:
    $ 3.95
    HCP360NWSET6 Aftermarket meter illumination and warning WHITE LED BULBS, set of 6:
    $ 18.95
    HCP14795NW Aftermarket meter illumination and warning WHITE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Use a total of 6 bulbs per entire instrument cluster. Suitable for use in the following locations:
    - Speedometer and tachometer faceplate illumination (use 1 per gauge), same brightness as the stock incandescent bulb.
    Each:
    $ 3.95
    HCP14795NWSET6 Aftermarket meter illumination and warning WHITE LED BULBS, set of 6:
    $ 22.95
    HCP361NW Aftermarket meter illumination and warning WHITE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Use a total of 6 bulbs per entire instrument cluster. Suitable for use in the following locations:
    - Speedometer and tachometer faceplate illumination (use 1 per gauge), same brightness as the stock incandescent bulb, slightly yellowed tint.
    - Neutral position warning indicator green light (use 1), much brighter than stock incandescent bulb.
    - High-beam warning indicator blue light (use 1), slightly brighter than stock incandescent bulb.
    - Oil level warning indicator red light (use 1), slightly brighter than stock incandescent bulb.
    Each:
    $ 4.95
    HCP361NWSET6 Aftermarket meter illumination and warning WHITE LED BULBS, set of 6:
    $ 27.95
    HCP14441NW Aftermarket meter illumination and warning WHITE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Use a total of 6 bulbs per entire instrument cluster. Suitable for use in the following locations:
    - Speedometer and tachometer faceplate illumination (use 1 per gauge), slightly brighter than stock incandescent bulb.
    - Turn signal warning indicator yellow light (use 1), much brighter than stock incandescent bulb.
    - Neutral position warning indicator green light (use 1), blindingly brighter than stock incandescent bulb.
    Each:
    $ 3.50
    HCP14441NWSET6 Aftermarket meter illumination and warning WHITE LED BULBS, set of 6:
    $ 19.95
    * To change the color of your speedometer and tachometer illumination, we recommend the following bulbs:
    HCP360A Aftermarket meter illumination and warning YELLOW LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 2.50
    HCP360ASET2 Aftermarket meter illumination and warning YELLOW LED BULBS, set of 2:
    $ 4.50
    HCP14441A Aftermarket meter illumination and warning YELLOW LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 2.95
    HCP14441ASET2 Aftermarket meter illumination and warning YELLOW LED BULBS, set of 2:
    $ 5.50
    HCP360B Aftermarket meter illumination and warning BLUE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 2.50
    HCP360BSET2 Aftermarket meter illumination and warning BLUE LED BULBS, set of 2:
    $ 4.50
    HCP14441B Aftermarket meter illumination and warning BLUE LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 3.50
    HCP14441BSET2 Aftermarket meter illumination and warning BLUE LED BULBS, set of 2:
    $ 6.50
    HCP361G Aftermarket meter illumination and warning GREEN LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 2.50
    HCP361GSET2 Aftermarket meter illumination and warning GREEN LED BULBS, set of 2:
    $ 4.50
    HCP14798G Aftermarket meter illumination and warning GREEN LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 3.50
    HCP14798GSET2 Aftermarket meter illumination and warning GREEN LED BULBS, set of 2:
    $ 6.50
    HCP361R Aftermarket meter illumination and warning RED LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 2.50
    HCP361RSET2 Aftermarket meter illumination and warning RED LED BULBS, set of 2:
    $ 4.50
    HCP14798R Aftermarket meter illumination and warning RED LED BULB, for all 1980-81 XJ650 Maxim and Midnight Maxim models. Suitable for use in the following locations:
    Each:
    $ 3.95
    HCP14798RSET2 Aftermarket meter illumination and warning RED LED BULBS, set of 2:
    $ 7.50
    All models EXCEPT 1980-81 XJ650 Maxim and Midnight Maxim Incandescent Dash Gauges, Turn Signal, and Warning Light Bulbs:
    incan1) These tiny wedge-based METER BULBS are the correct style and intensity for all XJ-bikes except the 1980-81 XJ650 Maxim and Midnight Maxim models.
    HCP3619 OEM meter illumination and warning BULB. Fits the following models and in the following quantity to do the entire cluster (illumination and warning lights).
    1981-83 XJ550 Maxim (6)
    1984-85 FJ600 (11)
    1981-83 XJ550 Seca (7)
    1982-3 XJ650 Maxim (6)
    1982 XJ650RJ Seca (7)
    1982-83 XJ650 Turbo (7)
    1982 XJ750 Maxim (7)
    1983 XJ750 Maxim and Midnight Maxim (6)
    1981-83 XJ750 Seca (7)
    XJ900RK, RL, FN, and F models (11)
    XJ900N model (7)
    1982 XJ1100 Maxim (9)
    HCP3619 OEM meter illumination and warning BULB, these STANDARD-DUTY bulbs last for a mean average of 500 running hours. each:
    $ discontinued
    HCP3619SET6 OEM meter illumination and warning BULBS, set of 6 bulbs:
    $ discontinued
    HCP3619SET12 OEM meter illumination and warning BULBS, set of 12 bulbs:
    $ discontinued
    HCP28999 Aftermarket meter illumination and warning BULB. Correctly replace the original HCP3619 bulbs, made by the original Yamaha supplier. Fits the following models and in the following quantity to do the entire cluster (illumination and warning lights).
    1984-85 FJ600 (11)
    XJ900N model (7)
    HCP28999 Aftermarket meter illumination and warning BULB, these STANDARD-DUTY bulbs last for a mean average of 500 running hours. each:
    $ 3.95
    HCP28999SET6 Aftermarket meter illumination and warning BULBS, set of 6 bulbs:
    $ 17.95
    HCP28999SET12 Aftermarket meter illumination and warning BULBS, set of 12 bulbs:
    $ 27.95
    HCP3618A OEM meter illumination and warning BULB, for all XJ700 and XJ750-X models. Use a total of 10 bulbs per entire instrument cluster in non-X models, and 11 bulbs per cluster in the X-models. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. NOTE: these bulbs have a tiny head, and over each head a separate green "tube filter" is required to gives the gauge light and face its greenish tint. The soft rubber filters are very fragile and generally need to be replaced whenever the light bulb is changed. The bulbs do not include these filters, and the HCP10235 filters should be ordered separate if needed. Each:
    $ 7.95
    HCP3618ASET6 OEM meter illumination and warning BULBS, set of 6:
    $ 44.95
    HCP3618ASET12 OEM meter illumination and warning BULBS, set of 12:
    $ 79.95
    HCP3618B Aftermarket indicator warning BULB, for all XJ700 and XJ750-X models. Use a total of 4 bulbs per instrument cluster in non-X models, and 5 bulbs per cluster in the X-models. These STANDARD-DUTY bulbs last for a mean average of 500 running hours. NOTE: the original bulbs have a tiny head, and these replacement heads have a slightly bigger, more bulbous head, but they will fit fine for the warning indicator lights. And although they will also fit as replacement meter lights, their larger head will prevent the use of the original green tube filter (HCP10235). The soft rubber filters are very fragile and generally need to be replaced whenever the light bulb is changed. Each:
    $ 4.95
    HCP3618BSET6 Aftermarket meter illumination and warning BULBS, set of 6:
    $ 27.95
    HCP3618BSET12 Aftermarket meter illumination and warning BULBS, set of 12:
    $ 44.95
    HCP10235 OEM meter illumination green BULB FILTER, this small green rubber filter fits over the end of the meter bulbs and gives the gauge light and face its greenish tint. These soft rubber filters are very fragile and generally need to be replaced whenever the light bulb is changed. NOTE: these filters will only fit the HCP3618A oem bulbs, and will not fit the aftermarket replacement bulbs HCP3618B. Use 4 on XJ700 non-X models, and 5 on all XJ700-X and XJ750-X models. Each:
    $ 8.95
    HCP10235SET4 Aftermarket meter illumination green rubber TUBE FILTER, set of 4:
    $ 32.95
    HCP10235SET6 Aftermarket meter illumination green rubber TUBE FILTER, set of 6:
    $ 44.95
    All models except 1980-81 XJ650 Maxim and Midnight Maxim LED Dash Gauges, Turn Signal, and Warning Light Bulbs:
    These direct replacement bulbs install just like the original wedge-base bulbs (all models other than 1980-81 XJ650 Maxim/Midnight Maxim models), and have been evaluated and tested to provide the proper level of illumination without creating a night-time glare condition. NOTE: bulbs listed as being "much brighter than stock" means just that......and something to keep in mind when ordering. Typically, bulbs that are typically "always on" during night-time riding (such as the speedo and tacho faceplate illumination, and the blue high-beam warning indicator light) can be very distracting if you choose the "much brighter than stock" option, so choose wisely --- bigger isn't always better! On the other hand, must-get-your-attention lights (neutral, oil, warning, turn signals) can use the "much brighter than stock" bulbs if you are so inclined (but, be aware, when we say "much brighter than stock", we aren't kidding!).
    Although there are a great variety of bulbs that are available for each bike/light position, you should choose the ones that match your level of illumination needs, and mix-or-match as needed. Pricing for each bulb is listed at the end of this section. And yes, you can use our white LED's even under the colored warning light plastic filters and still end up with the proper warning color (i.e. blue for high beam, yellow for turns, green for neutral, red for oil or warning).
    NOTE: when used for speedometer and tachometer face illumination, all LED bulbs listed as "slightly brighter than stock incandescent bulbs" will create a small "visual hot spot" on the speedo and tach faceplate directly above the bulb location.
    XJ550 Maxim models:
    1982-83 XJ650 Maxim models:
    1983 XJ750 Maxim and Midnight Maxim models:
    Speedometer and tachometer illumination:
    HCP356CW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP356NW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP356WW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP356A is the same brightness as a stock incandescent bulb and provides a slight yellowish glow.
    HCP356B is the same brightness as a stock incandescent bulb and provides a slight bluish glow.
    HCP356G is the same brightness as a stock incandescent bulb and provides a slight greenish glow.
    HCP356R is the same brightness as a stock incandescent bulb and provides a slight reddish glow.
    HCP359NW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP359G is slightly brighter than a stock incandescent bulb and provides a slight greenish glow.
    HCP359R is slightly brighter than a stock incandescent bulb and provides a slight reddish glow.
    HCP359A is slightly brighter than a stock incandescent bulb and provides a slight yellowish glow.
    Turn signal indicator light:
    HCP356A is the same brightness as a stock incandescent bulb.
    HCP355A is slightly brighter than a stock incandescent bulb.
    HCP355CW is slightly brighter than a stock incandescent bulb.
    HCP357NW is slightly brighter than a stock incandescent bulb.
    HCP358A is slightly brighter than a stock incandescent bulb.
    HCP14797A is slightly brighter than a stock incandescent bulb.
    Oil light:
    HCP354R is the same brightness as a stock incandescent bulb.
    HCP356R is the same brightness as a stock incandescent bulb.
    HCP357WW is the same brightness as a stock incandescent bulb.
    HCP14797R is the same brightness as a stock incandescent bulb.
    HCP357R is slightly brighter than a stock incandescent bulb.
    HCP358R is slightly brighter than a stock incandescent bulb.
    HCP359R is slightly brighter than a stock incandescent bulb.
    Neutral light:
    HCP355G is slightly brighter than a stock incandescent bulb.
    HCP354G is slightly brighter than a stock incandescent bulb.
    HCP356G is slightly brighter than a stock incandescent bulb.
    HCP357G is slightly brighter than a stock incandescent bulb.
    HCP358G is slightly brighter than a stock incandescent bulb.
    HCP359G is slightly brighter than a stock incandescent bulb.
    HCP14797G is slightly brighter than a stock incandescent bulb.
    High-beam indicator:
    HCP354B is the same brightness as a stock incandescent bulb.
    HCP356CW is the same brightness as a stock incandescent bulb.
    HCP356NW is the same brightness as a stock incandescent bulb.
    HCP356WW is the same brightness as a stock incandescent bulb.
    HCP356B is slightly brighter than a stock incandescent bulb.
    HCP357B is slightly brighter than a stock incandescent bulb.
    HCP357CW is slightly brighter than a stock incandescent bulb.
    HCP357WW is slightly brighter than a stock incandescent bulb.
    HCP358B is slightly brighter than a stock incandescent bulb.
    HCP359B is slightly brighter than a stock incandescent bulb.
    HCP359NW is slightly brighter than a stock incandescent bulb.
    HCP14797B is slightly brighter than a stock incandescent bulb.
    HCP14797CW is slightly brighter than a stock incandescent bulb.
    XJ550 Seca models:
    HCP356A is the same brightness as a stock incandescent bulb and provides a yellowish glow.
    HCP356G is the same brightness as a stock incandescent bulb and provides a greenish glow.
    HCP359G is the same brightness as a stock incandescent bulb and provides a greenish glow.
    HCP356R is the same brightness as a stock incandescent bulb and provides a reddish glow.
    HCP359R is the same brightness as a stock incandescent bulb and provides a reddish glow.
    HCP356NW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP356WW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP359A is slightly brighter than a stock incandescent bulb and provides a yellowish glow.
    HCP355A is much brighter than a stock incandescent bulb.
    HCP356NW is much brighter than a stock incandescent bulb.
    HCP356WW is much brighter than a stock incandescent bulb.
    HCP357A is much brighter than a stock incandescent bulb.
    HCP359A is much brighter than a stock incandescent bulb.
    HCP359NW is much brighter than a stock incandescent bulb.
    Oil light:
    HCP359NW is the same brightness as a stock incandescent bulb.
    HCP14797CW is the same brightness as a stock incandescent bulb.
    HCP356R is slighter brighter than a stock incandescent bulb.
    HCP14797R is slightly brighter than a stock incandescent bulb.
    HCP355R is much brighter than a stock incandescent bulb.
    Neutral light:
    HCP354G is the same brightness as a stock incandescent bulb.
    HCP354CW is the same brightness as a stock incandescent bulb.
    HCP357G is much brighter than a stock incandescent bulb.
    HCP357CW is much brighter than a stock incandescent bulb.
    HCP357NW is much brighter than a stock incandescent bulb.
    HCP357WW is much brighter than a stock incandescent bulb
    HCP355B is much brighter than a stock incandescent bulb.
    1982 XJ650RJ Seca and XJ900N models:
    HCP357CW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP357NW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP357WW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP359R is slightly brighter than a stock incandescent bulb and provides a reddish glow.
    HCP359G is slightly brighter than a stock incandescent bulb and provides a greenish glow.
    Turn signal indicator lights:
    HCP14797A is the same brightness as a stock incandescent bulb.
    HCP356NW is slightly brighter than a stock incandescent bulb.
    HCP356WW is slightly brighter than a stock incandescent bulb.
    HCP357A is slightly brighter than a stock incandescent bulb.
    HCP359A is slightly brighter than a stock incandescent bulb.
    Oil light:
    HCP355R is slightly brighter than a stock incandescent bulb.
    Neutral light:
    HCP354CW is slightly brighter than a stock incandescent bulb.
    XJ650 Turbo models:
    HCP356B is the same brightness as a stock incandescent bulb and provides a bluish glow.
    HCP356R is slightly brighter than a stock incandescent bulb and provides a reddish glow.
    Fuel gauge illumination:
    HCP356CW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP358A is the same brightness as a stock incandescent bulb.
    HCP357WW is much brighter than a stock incandescent bulb.
    Warning light:
    HCP354R is slightly brighter than a stock incandescent bulb.
    HCP356R is slightly brighter than a stock incandescent bulb.
    HCP357R is much brighter than a stock incandescent bulb.
    Neutral light:
    HCP355G is much brighter than a stock incandescent bulb.
    HCP354B is slightly brighter than stock incandescent bulb.
    HCP356B is slightly brighter than stock incandescent bulb.
    HCP357B is much brighter than a stock incandescent bulb.
    XJ700 and XJ750-X models:
    not currently available.
    1982 XJ750 Maxim models:
    HCP357NW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP356G is slightly brighter than a stock incandescent bulb and provides a greenish glow.
    HCP359G slightly brighter than a stock incandescent bulb and provides a greenish glow.
    HCP359R slightly brighter than a stock incandescent bulb and provides a reddish glow.
    HCP359A slightly brighter than a stock incandescent bulb and provides a yellowish glow.
    HCP355A is slightly brighter than stock incandescent bulb.
    Warning light:
    HCP355R is much brighter than stock incandescent bulb.
    Neutral light:
    HCP355G is much brighter than stock incandescent bulb.
    HCP355B is slightly brighter than stock incandescent bulb.
    HCP354CW is slightly brighter than stock incandescent bulb.
    1981-83 XJ750 Seca models:
    HCP14797CW is the same brightness as a stock incandescent bulb and provides a white glow.
    HCP357G is the same brightness as a stock incandescent bulb and provides a greenish glow.
    HCP358G is the same brightness as a stock incandescent bulb and provides a greenish glow.
    HCP358R is the same brightness as a stock incandescent bulb and provides a reddish glow.
    HCP14797R is the same brightness as a stock incandescent bulb and provides a reddish glow.
    HCP358A is the same brightness as a stock incandescent bulb and provides a yellowish glow.
    HCP357CW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP357WW is slightly brighter than a stock incandescent bulb and provides a white glow.
    HCP356A is slightly brighter than a stock incandescent bulb.
    HCP355A is much brighter than stock incandescent bulb.
    Warning light:
    HCP356R is much brighter than a stock incandescent bulb.
    HCP359R is much brighter than a stock incandescent bulb.
    HCP14797R is much brighter than a stock incandescent bulb.
    Neutral light:
    HCP14797CW is much brighter than a stock incandescent bulb.
    1984-5 FJ600, 1984 XJ750RL Seca, and all XJ900 (except XJ900N) models:
    HCP359B is the same brightness as a stock incandescent bulb and provides a bluish glow.
    HCP359A is the same brightness as a stock incandescent bulb and provides a yellowish glow.
    HCP357A is the same brightness as a stock incandescent bulb.
    HCP355CW is slightly brighter than stock incandescent bulb.
    Oil light:
    HCP355R is the same brightness as a stock incandescent bulb.
    HCP358R is the same brightness as a stock incandescent bulb.
    Neutral light:
    HCP355G is slightly brighter than stock incandescent bulb.
    HCP357G is the slightly brighter than a stock incandescent bulb.
    HCP356B is the same brightness as a stock incandescent bulb.
    XJ1100 models:
    HCP359R is slightly brighter than a stock incandescent bulb and provides a greenish glow.
    HCP357A is slightly brighter than a stock incandescent bulb..
    Warning light:
    HCP356R is much brighter than stock incandescent bulb.
    HCP358R is much brighter than a stock incandescent bulb.
    Neutral light:
    Headlamp indicator:
    LED Bulb Pricing:
    HCP354A Aftermarket amber 1-LED BULB:
    $ 2.50 each
    $ 12.95 set of 6
    HCP354B Aftermarket blue 1-LED BULB:
    $ 2.95 each
    $ 16.95 set of 6
    HCP354G Aftermarket green 1-LED BULB:
    $ 2.95 each
    $ 16.95 set of 6
    HCP354R Aftermarket red 1-LED BULB:
    $ 2.95 each
    $ 16.95 set of 6
    HCP354CW Aftermarket white 1-LED BULB:
    $ 2.95 each
    $ 16.95 set of 6
    HCP355A Aftermarket amber 4-LED BULB:
    $ 3.95 each
    $ 19.95 set of 6
    HCP355B Aftermarket blue 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
    HCP355G Aftermarket green 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
    HCP355R Aftermarket red 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
    HCP355CW Aftermarket white 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
    HCP356A Aftermarket amber 5-LED BULB:
    $ 5.95 each
    $ 34.95 set of 6
    HCP356B Aftermarket blue 5-LED BULB:
    $ 6.95 each
    $ 38.95 set of 6
    HCP356G Aftermarket green 5-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP356R Aftermarket red 5-LED BULB:
    $ 5.95 each
    $ 34.95 set of 6
    HCP356CW Aftermarket white 5-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP356NW Aftermarket white 5-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP356WW Aftermarket white 5-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP357A Aftermarket amber 6-LED BULB:
    $ 5.95 each
    $ 34.95 set of 6
    HCP357B Aftermarket blue 6-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP357G Aftermarket green 6-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP357R Aftermarket red 6-LED BULB:
    $ 5.95 each
    $ 34.95 set of 6
    HCP357CW Aftermarket white 6-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP357NW Aftermarket white 6-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP357WW Aftermarket white 6-LED BULB:
    $ 7.95 each
    $ 44.95 set of 6
    HCP358A Aftermarket amber hi-power 1-LED BULB:
    $ 9.95 each
    $ 54.95 set of 6
    HCP358B Aftermarket blue hi-power 1-LED BULB:
    $ 9.95 each
    $ 54.95 set of 6
    HCP358G Aftermarket green hi-power 1-LED BULB:
    $ 9.95 each
    $ 54.95 set of 6
    HCP358R Aftermarket red hi-power 1-LED BULB:
    $ 9.95 each
    $ 54.95 set of 6
    HCP359A Aftermarket amber hi-power 5-LED BULB:
    $ 11.95 each
    $ 67.95 set of 6
    HCP359B Aftermarket blue hi-power 5-LED BULB:
    $ 11.95 each
    $ 67.95 set of 6
    HCP359G Aftermarket green hi-power 5-LED BULB:
    $ 11.95 each
    $ 67.95 set of 6
    HCP359R Aftermarket red hi-power 5-LED BULB:
    $ 11.95 each
    $ 67.95 set of 6
    HCP359NW Aftermarket white hi-power 5-LED BULB:
    $ 11.95 each
    $ 67.95 set of 6
    HCP14797A Aftermarket amber 4-LED 4-LED BULB:
    $ 3.95 each
    $ 19.95 set of 6
    HCP14797B Aftermarket blue 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
    HCP14797G Aftermarket green 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
    HCP14797R Aftermarket red 4-LED BULB:
    $ 3.95 each
    $ 19.95 set of 6
    HCP14797CW Aftermarket white 4-LED BULB:
    $ 4.95 each
    $ 27.95 set of 6
  30. chacal
    Instrument Cluster Gauge Needle Paint:
    gp6) Aftermarket high-performance FLUORESCENT NEEDLE PAINT will restore the night-time visibility and the day-time appearance of your speedometer, tachometer, or other gauge indicator needles. This is a true fluorescent paint, not just a metallic paint (which will not "glow" at night). Shake well before use. Comes in a 1-ounce bottle (must be applied by brush), enough to do many, many needles!
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP14540 Aftermarket FLUORESCENT NEEDLE PAINT, bright orange color is correct for most speedometer and tachometer needles as used on all XJ550, XJ650, 1981-83 XJ750, and XJ1100 models.
    $ 7.95
    HCP14541 Aftermarket FLUORESCENT NEEDLE PAINT, bright red-orange color. Although this color is much "redder" than original, it matches the rd color of the redline markings on the gauge faces much better than then HCP14540 orange paint above. For use on all speedo and tach needles on XJ550, XJ650, 1981-83 XJ750, and XJ1100 models.
    $ 7.95
    HCP14544 Aftermarket FLUORESCENT NEEDLE PAINT, bright yellow color is correct for most the fuel level and voltage meter needles used on XJ550 Seca models.
    $ 7.95
    HCP14543 Aftermarket FLUORESCENT NEEDLE PAINT, bright medium-blue color. Although this color is not correct for any needles, it's a neat way to personalize your gauges if so desired on all XJ550, XJ650, 1981-83 XJ750, and XJ1100 models.
    $ 7.95
    HCP14542 Aftermarket FLUORESCENT NEEDLE PAINT, bright lime-green color. Although this color is not correct for any needles, it's a neat way to personalize your gauges if so desired on all XJ550, XJ650, 1981-83 XJ750, and XJ1100 models.
    $ 7.95
    GAUGES:
    Most original gauges are remarkably reliable and accurate, especially considering they are precise mechanical or electrical instruments that are exposed to the weather constantly. Gauge face fading is a common problem, and unfortunately is not an issue that we have a current solution for.
    The other common issue with the main gauges (speedometer and tachometer) is noise or erratic performance:
    Q: "While I was riding last Saturday, my speedometer started to make a squealing nose and the needle started to bounce at the 55-60 mph mark. What is the procedure for a cable fix, or do I just replace the whole cable? Or what are my other options?"
    A: This type of problem could be caused by the speedo drive hub (on the wheel), the cable, or the speedo head unit.
    You can try lubricating the drive cable (remove it from the bike, hold or hang it vertically, use brake clearer to blast all the old gunk out, and then re-lubricate it with motor oil). Once the “cable” is off the bike, then the inner drive cable (the actual drive cable) can usually be slipped out of the outer plastic sheath to make cleaning easier.
    While the cable is off, you can test the speedo head itself using an drill with a proper size square drive socket (which will be the same size as the speedo cable squared drive end) and operate the speedo in this manner ---- the drill should be set to run in reverse, as the cable rotates CCW as you are looking at the back of the speedo (from the front of the bike looking backwards). Note that it may be difficult to reach the speedo drive input while the gauges and/or the headlight assembly are still on the bike.
    Yamaha speedometers take a 2240:60 ratio to work properly. The 2240 = 60 MPH means that the cable spinning at 2240 rpm’s will read 60MPH. So you’ll need a drill capable of that speed.
    If the speedo works properly when testing it in the above manner, then the issue resides with either the speedo cable (which, if not regularly cleaned internally and re-lubricated, will fail after several years) or the drive hub at the wheel. If the problem goes away, then you can move on to further testing of the cable itself. If the problem persists, the the internal mechanism needs servicing.
    You can perform the same "drill test" as described above, but with the speedo drive cable connected at the speedo head, and disconnected at the wheel hub......and the far end of the speedo cable itself chucked into the drill (at the wheel hub end) and running the test again.
    If the problem goes away, then you need to service or replace the speedo drive hub. If the problem continues, then it’s probably the internal gauge mechanism that needs cleaning or lubrication. This can be a tedious task and no guarantee of success. Here’s a useful guide; although shown on an XJ550 speedo head unit, they are all very similar, although the dis-assembly procedure may differ
    Gauge mechanism servicing:
    Cluster teardown:
    https://www.xjbikes.com/forums/threads/seca-550-instrument-cluster-teardown-with-pics.14948
    Head lubrication:
    https://www.xjbikes.com/forums/threads/speedo-and-tach-dissection-with-pics.15303
    NOTE: we strongly recommend that you do not remove (nor try to do so) the needle assembly from the gauge unit……it is clocked into a certain position, and removing the needle shaft almost always results in a non-operational gauge upon re-assembly.
    For testing cable-driven instruments with a drill (as described above), the following tools may prove to be useful:
    HCP29267 Aftermarket SQUARE DRIVE BIT, proper size to fit into the drive housing at the head unit for testing mechanical (cable-driven) speedometers and tachometers. 1/4" shank fits into standard power drill chucks. 2" overall length. On many models, to perform testing with this bit, you may need to remove the cluster from the bike, or remove the headlight bucket from the bike for access to the gauge cluster, and may need to use one of the flexible extension below to reach the back of the instrument.
    $ 5.95
    HCP29268 Aftermarket FLEXIBLE DRIVE EXTENSION, tightly-wound spring wire extension has 1/4" male and female square drive ends, so the male end can be fitted into a drill chuck and the female end accepts the HCP29267 bit above. Flexible shaft allows you freedom to maneuver around obstructions. 4" length.
    $ 27.95
    HCP29269 Aftermarket FLEXIBLE DRIVE EXTENSION, tightly-wound spring wire extension has 1/4" male and female square drive ends, so the male end can be fitted into a drill chuck and the female end accepts the HCP29267 bit above. Flexible shaft allows you freedom to maneuver around obstructions. 6" length.
    $ 34.95
    HCP29268 Aftermarket FLEXIBLE DRIVE EXTENSION, tightly-wound spring wire extension has 1/4" male and female square drive ends, so the male end can be fitted into a drill chuck and the female end accepts the HCP29267 bit above. Flexible shaft allows you freedom to maneuver around obstructions. 10" length.
    $ 39.95
    Electronic tachometer testing and servicing:
    https://www.xjbikes.com/forums/threads/xj900f-tachometer-electrical.116090
    Complete gauge units:
    NOTE: we recommend that all new speedometers and tachometers be re-lubricated before use, as the 40+ year old shaft bearing lube may have degraded or dissipated over time.
    HCP20852 Aftermarket hi-performance INSTRUMENT OIL, comes in a handy applicator pen. Oil-based triple-processed lubricant eliminates contaminants that would cause gumming or corrosion product is what we use and recommend for freeing stuck speedo or tacho drive mechanisms.
    $ 37.95
    HCP5917MPH OEM complete SPEEDOMETER, for all 1981-83 XJ550 Seca models. Primary face reading is in MPH. Lighting wire harness is not included.
    $ 399.95
    HCP5917KPH OEM complete SPEEDOMETER, for all 1981-83 XJ550 Seca models. Face reading is in KPH (0-200). Can be used as a direct substitute for USA MPH speedometers. Lighting wire harness is not included.
    $ 399.95
    HCP5911MPH OEM complete SPEEDOMETER, for all 1980-81 XJ650 Maxim/Midnight Maxim models.
    $ 399.95
    HCP5916MPH OEM complete SPEEDOMETER, for all 1982-83 XJ550 Maxim, 1982-83 XJ650 Maxim/Midnight Maxim, and 1983 XJ750 Maxim/Midnight Maxim models.
    $ 399.95
    HCP5930MPH OEM complete SPEEDOMETER, for all 1982-83 XJ650 Turbo models.
    $ 399.95
    HCP29677KPH OEM complete SPEEDOMETER , for all XJ650RJ Seca Euro (4K0 and 4K1) models. This meter is calibrated in KPH (0 – 220) and had no MPH markings at all. Outer chrome or black gauge “bucket” and rubber mounting ring is not included, nor is the lighting wire harness or bulb socket.
    $ 449.95
    HCP5910MPH OEM complete SPEEDOMETER, for all 1981-83 XJ750 Seca USA models (will fit Canadian and Euro models, but the face is marked primarily in PH with smaller KPH markings). 85mph scale with silly 55mph “redline”.
    $ 379.95
    HCP5927MPH OEM complete SPEEDOMETER, for all 1982-84 XJ1100 models.
    $ 599.95
    HCP5935 OEM speedometer WIRE HARNESS, includes the harness connector and the reed switch unit. Use the BA9 style “glove” incandescent bulb as used on 1980-81 XJ650 Maxi, and 1980-81 XJ650 Euro models. NOTE: this harness will also fit all of the following models, but the bulb socket is configured to accept the earlier style “globe” (push-down and twist-into-place) bulb rather than the later-style T10 “wedge-base” bulb: 1981-83 XJ550 Maxim, 1982-83 XJ650 Maxim, 1982 XJ650 RJ Seca,1983-84 XJ750 Maxim, and XJ1100 models. Use 1 per gauge set. Each:
    $ 29.95
    HCP5919 OEM complete CABLE-DRIVEN TACHOMETER, for all 1981-83 XJ550 Seca models. 10,000 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 429.95
    HCP5915 OEM complete CABLE-DRIVEN TACHOMETER, for all 1981-83 XJ550 Maxim and 1980-81 XJ650 Maxim or Midnight Maxim models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 399.95
    HCP5914 OEM complete ELECTRICALLY-DRIVEN TACHOMETER , for all 1982-83 XJ650 Maxim/Midnight Maxim and 1983 XJ750 Maxim/Midnight Maxim models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 449.95
    HCP14094 OEM complete CABLE-DRIVEN TACHOMETER , for all non-North American XJ650 models. 10,000 rpm redline on 12,000 rpm scale. This unit can also be used on North American XJ650RJ Seca models. Lighting wire harness is not included.
    $ 499.95
    HCP6038 OEM complete CABLE-DRIVEN TACHOMETER , for all North American XJ650RJ Seca models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 439.95
    HCP6037 OEM complete ELECTRICALLY-DRIVEN TACHOMETER , for all XJ650 Turbo models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 399.95
    HCP6004 OEM complete ELECTRICALLY-DRIVEN TACHOMETER, for all 1984-85 FJ600 and 1983-91 XJ900 models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 399.95
    HCP5920 OEM complete ELECTRICALLY-DRIVEN TACHOMETER, for all XJ750 Seca and XJ750 Euro models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 399.95
    HCP5928 OEM complete ELECTRICALLY-DRIVEN TACHOMETER, for all 1982 XJ750 Maxim models. 9,500 rpm redline on 12,000 rpm scale. Lighting wire harness is not included.
    $ 399.95
    HCP5929 OEM complete ELECTRICALLY-DRIVEN TACHOMETER, for all XJ1100 Maxim models., 8500 rpm redline of 10,000 rpm’s scale.
    $ 599.95
    HCP10017 Aftermarket mechanical-to-electrical TACHOMETER WIRING CONVERSION KIT contains an easy-to-install conversion harness, a tach drive housing block-off cap (HCP7521), and instructions, giving you all the parts you'll need to make a professional and correct change-over. Note that the electrically-driven tachometer is not included!
    $ 49.95
    HCP5936 OEM tachometer WIRE HARNESS, contains the lead wires, the main harness connector shell, and the light bulb socket. Note this harness has a bulb socket that accepts the original “globe” style bulb as used on bikes with cable-driven tachometers. Fits 1980-81 XJ650 Maxim and Midnight Maxim models and 1980-81 XJ650 Euro models.
    $ 39.95
    HCP5939 OEM tachometer WIRE HARNESS, contains the lead wires, the main harness connector shell, and the light bulb socket. Note this harness has a bulb socket that accepts the original “wedge-base” style bulb as used on bikes with cable-driven tachometers. Fits 1981-83 XJ550 Maxim models.
    $ 39.95
    HCP6051M OEM complete GAUGE ASSEMBLY, with white primary (outer) speedo readings in MPH (0-150, and does not have the red square on the 55mph position) and 240kph as yellow secondary (inner) markings, the 12,000 rpm tachometer (with 9.5K redline), fuel gauge, clock, warning lights, harnesses, etc. Correct replacement for all 1983- 91 XJ900 models, but has the speedometer indications correctly only for USA models (with the primary----outer----markings in MPH). Non-USA clusters, depending on year and model, may have had KPH (0-240) indications only on the speedo face, but this cluster will fit and function correctly on those models, too.. Brand new.
    $ 899.95
    HCP6005 OEM complete FUEL GAUGE, for all FJ600 and XJ900RK, RL, FN, and F models.
    $ discontinued
    HCP26152 Aftermarket handlebar-mount VOLTMETER, this compact unit bolts onto to your stock handlebars and add three very useful features: a real-time digital voltmeter, a 12V plug for a GPS unit, radar detector, charger, etc., and two (2) USB charging ports (each one is 2.1A at 5VDC). A very handy temporary or permanent addition. 3” wide x 1-1/4” tall x 2-1/2” deep. Wire harness (4-1/2’) has ring terminals for easy installation onto + and - battery posts. Fits all bikes.
    $ 29.95
    Instrument Cluster Gauges, Covers, and Lenses:
    Cluster breakdown and service can be seen at the following links:
    Although shown on an XJ550 Seca model, the basic process is the same on all clusters:
    HCP5973 OEM instrument cluster upper GAUGE HOUSING COVER AND LENSE, plastic upper cover fits above the gauges and has the clear lenses and the colored indicator light filter in-between the clear gauge lenses, all integrated into one unit. For all XJ550 Maxim, all XJ650 Maxim and Midnight Maxim, and 1983-84 XJ750 Maxim and Midnight Maxim models.
    $ 199.95
    HCP5971 OEM instrument cluster WARNING LIGHTS HOUSING GASKET, fits in-between the cover/lense unit and the warning light panel. For all XJ550 Seca and XJ550 Euro models.
    $ 24.95
    HCP29110 Aftermarket instrument cluster WARNING LIGHTS HOUSING GASKET, fits in-between the cover/lense unit and the warning light panel. Slightly thicker than original, providing a better seal. For all XJ550 Seca and XJ550 Euro models.
    $ 14.95
    HCP5987 OEM instrument cluster GAUGE LENSE, fits above the gauges and has the clear lenses. For XJ650 Turbo models.
    $ 199.95
    HCP8439 Aftermarket glass speedometer or tachometer gauge LENSE, crystal-clear flat glass lense replaces cracked or damaged original. Fits all 1980-82 XJ650 Euro, XJ650RJ Seca, and XJ900N models. NOTE: these gauges are very difficult to take fully apart to the extent necessary to replace this lense, and original lenses are slightly concave (pointed) in the center. These replacements are cut from flat glass, and it is recommended that both gauge units have their lenses replaced at the same time in order to avoid a mis-matched appearance. Each:
    $ discontinued
    HCP8435 Aftermarket glass speedometer or tachometer gauge LENSE, crystal-clear flat glass lense replaces cracked or damaged original. Fits all 1985-86 XJ700 and XJ750-X models. NOTE: these gauges are very difficult to take fully apart to the extent necessary to replace this lense, and original lenses are slightly concave (pointed) in the center. These replacements are cut from flat glass, and it is recommended that all gauge units have their lenses replaced at the same time in order to avoid a mis-matched appearance. Each:
    $ discontinued
    HCP8436 Aftermarket glass temperature gauge LENSE, crystal-clear flat glass lense replaces cracked or damaged original. Fits all 1985-86 XJ700 and XJ750-X models. NOTE: these gauges are very difficult to take fully apart to the extent necessary to replace this lense, and original lenses are slightly concave (pointed) in the center. These replacements are cut from flat glass, and it is recommended that all gauge units have their lenses replaced at the same time in order to avoid a mis-matched appearance. Each:
    $ discontinued
    HCP8432 Aftermarket glass gauge cluster LENSE, crystal-clear flat glass lense replaces cracked or damaged original. Fits all 1982 XJ750 Maxim models. NOTE: gauge clusters are very difficult to take fully apart to the extent necessary to replace this lense.
    $ discontinued
    HCP8433 Aftermarket glass gauge cluster LENSE, crystal-clear flat glass lense replaces cracked or damaged original. Fits all 1982 XJ750 Seca and XJ750 Euro models. NOTE: gauge clusters are very difficult to take fully apart to the extent necessary to replace this lense.
    $ discontinued
    HCP5980 OEM instrument cluster face GAUGE HOUSING COVER AND LENSE, black plastic cover its above the gauges and has the clear lenses for the speedo and tach, as well as the colored indicators lenses for the turn signals, the “Warning” indicator light, the Headlight, the Neutral light, and the openings for the Warning Control and Check buttons. Correct for all XJ1100 models.
    $ 229.95
    HCP5965 OEM speedometer bottom CHROME HOUSING, bright polished chrome bottom cover really brightens up a typically damaged or dull area on your bike. Fits all XJ650RJ Seca models. NOTE: can also be used on XJ900N models, although those gauge housings were painted black, rather than chromed.
    $ 49.95
    HCP5966 OEM tachometer bottom CHROME HOUSING, bright polished chrome bottom cover really brightens up a typically damaged or dull area on your bike. Fits all XJ650RJ Seca models. NOTE: can also be used on XJ900N models, although those gauge housings were painted black, rather than chromed.
    $ 49.95
    HCP5964 OEM gauge bottom housing MOUNTING RING, round rubber ring seals the gauge lense/cover to the chrome housing. Fits both the speedometer or the tachometer on all XJ650RJ Seca, XJ900 N, all X1100 Specials, as well as all of the following models: 1980-82 XS400 standard and Specials, 1976-78 XS500, 1976-81 XS650 Standards, 1978-83 XS650 Specials, 1977-78 XS750 all models, 1980-81 XS850 all models, 1981-82 XV920 H/RJ models, 1979 RD400, 2015-18 SR400, 1978-79 and 1981 SR500 models. Use 1 per gauge. Each:
    $ 39.95
    HCP5967 OEM instrument cluster rear/lower CHROME HOUSING, bright polished chrome plastic cluster cover really brightens up a typically damaged or dull area on your bike. Fits all XJ550 Maxim, XJ650 Maxim, and 1983 XJ750 Maxim models.
    $ 199.95
    HCP5968 OEM instrument cluster rear/lower BLACK HOUSING, polished black plastic cluster cover perfectly replaces a typically damaged or dull area on your bike. Correct for all XJ650 Midnight Maxim and XJ750 Midnight Maxim clusters, but will also fit all XJ550 Maxim, XJ650 Maxim, and 1983 XJ750 Maxim models.
    $ 219.95
    HCP6021 OEM speedometer rear "bullet" CHROME HOUSING, bright polished chrome plastic gauge bottom cover really brightens up a typically damaged or dull area on your bike. Fits all XJ700, XJ750-X, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-99 XV1100 Virago models.
    $ 89.95
    HCP6022 OEM tachometer rear "bullet" CHROME HOUSING, bright polished chrome plastic gauge bottom cover really brightens up a typically damaged or dull area on your bike. Fits all XJ700, XJ750-X, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-99 XV1100 Virago models.
    $ 89.95
    HCP6029 OEM temperature gauge rear "bullet" CHROME HOUSING, bright polished chrome plastic gauge bottom cover really brightens up a typically damaged or dull area on your bike. Fits all XJ700-X and XJ750-X models.
    $ 69.95
    HCP6024 OEM instrument cluster rear/lower CHROME HOUSING, bright polished chrome plastic cluster bottom/rear cover really brightens up a typically damaged or dull area on your bike. Fits all XJ700 non-X models.
    $ 149.95
    HCP6025 OEM gauge cluster METER COVER GASKET, extended v-shaped thick black rubber seal fits over the rear of the bottom chrome housing and acts as a waterproofing seal. Our experience shows that it is not always there on original clusters. It can be seem in the Yamaha parts diagram as item #30 (1985 models) or item #31 (1986 models) in the METER diagram, as a "meter cover 2". Fits all XJ700-X and XJ750-X models.
    $ 39.95
    HCP29109 Aftermarket gauge cluster METER COVER GASKET, extended v-shaped thick black rubber seal fits over the rear of the bottom chrome housing and acts as a waterproofing seal. Our experience shows that it is not always there on original clusters. It can be seem in the Yamaha parts diagram as item #30 (1985 models) or item #31 (1986 models) in the METER diagram, as a "meter cover 2". Fits all XJ700-X and XJ750-X models.
    $ 19.95
    HCP5984 OEM instrument cluster rear BLACK HOUSING, black plastic gauge rear cover replaces a commonly damaged or faded original. Fits all 1982 XJ750 Maxim models.
    $ 99.95
    HCP5976 OEM instrument cluster rear BLACK HOUSING, black plastic gauge rear cover replaces a commonly damaged or faded original. Fits all XJ750 Seca models.
    $ 99.95
    HCP5977 OEM instrument cluster inner GAUGE HOUSING, plastic gauge mounting "platform" fits inside the case, below the gauges. For all XJ750 Seca models.
    $ discontinued
    HCP6007 OEM instrument cluster GAUGES UPPER HOUSING COVER AND LENSE, plastic upper cover that fits above the gauges. For all XJ900RK, RL, FN, and F models.
    $ 299.95
    HCP6011 OEM instrument cluster GAUGE REFLECTOR RING, fits below the housing cover and surrounds the gauge faces. Use 3 per cluster. For all XJ900RK, RL, FN, and F models. Each:
    $ 69.95
    HCP6008 OEM instrument cluster INNER GAUGE HOUSING, plastic gauge mounting "platform" fits inside the case, below the gauges. For all FJ600 and XJ900RK, RL, FN, and F models.
    $ discontinued
    HCP6009 OEM instrument cluster REAR / LOWER HOUSING, black plastic gauge bottom cover replaces a commonly damaged or faded original. Fits all FJ600 and XJ900RK, RL, FN, and F models.
    $ 89.95
    HCP6012 OEM instrument cluster WARNING LIGHTS HOUSING, plastic housing for the indicator lights. Fits all XJ900RK, RL, FN, and F models.
    $ 99.95
    HCP14914 OEM instrument cluster HOOD / SHIELD. This factory-optional molded black plastic “hood” covers the entire top of the gauge cluster, and extends a few inches backwards towards the driver, providing both a bit of weather (rain) protection for the gauges and reducing sun glare on the gauge faces at certain times. Very rare and surprisingly useful. Fits all 1981-83 XJ550 Maxim, all 1980-84 XJ650 Maxim / Midnight Maxim, and all 1983-84 XJ750 Maxim / Midnight Maxim clusters. Includes mounting hardware and installation instructions.
    $ 219.95
    HCP20941 OEM instrument cluster HOOD / SHIELD. This factory-optional molded black plastic “hood” covers the entire top of the gauge cluster, and extends a few inches backwards towards the driver, providing both a bit of weather (rain) protection for the gauges and reducing sun glare on the gauge faces at certain times. Very rare and surprisingly useful. Fits all 1982 XJ750 Maxim models. Includes mounting hardware and installation instructions.
    $ 199.95
    HCP29796 OEM instrument cluster HOOD / SHIELD. This factory-optional molded black plastic “hood” covers the entire top of the gauge cluster, and extends a few inches backwards towards the driver, providing both a bit of weather (rain) protection for the gauges and reducing sun glare on the gauge faces at certain times. Very rare and surprisingly useful. Fits all 1979-81 XS1100 Specials, all XS400, all XS650, all XS750, and all XS850 models. Includes mounting hardware and installation instructions.
    $ 199.95
    HCP29797 OEM instrument cluster HOOD / SHIELD. This factory-optional molded black plastic “hood” covers the entire top of the gauge cluster, and extends a few inches backwards towards the driver, providing both a bit of weather (rain) protection for the gauges and reducing sun glare on the gauge faces at certain times. Very rare and surprisingly useful. Fits all 1978-81 XS1100 Standard models. Includes mounting hardware and installation instructions. [/u]NOTE[/u]: if installing this hood on 1980-81 models with factory fairing, it will be necessary to remount the entire instrument cluster on top of the fork crown to prevent interference between the hood and the fairing.
    $ 179.95
    Instrument Gauges Housing Hardware:
    The housings and covers on many of the instrument panels are held together with very small, self-tapping screws designed to cut their own threads into the plastic housings.
    HCP6097 OEM gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the cluster lense to the gauge body, and/or to retain the cluster housing to the gauges. Use 10 per cluster on all XJ550 Maxim models, XJ650 Maxim and Midnight Maxim models, and 1983 XJ750 Maxim and Midnight Maxim models. Use 12 per cluster on all XJ550 Seca models. Each:
    $ 3.95
    HCP6097SET12 OEM gauge cluster housing self-tapping SCREWS, set of 12:
    $ 44.95
    HCP6111 OEM gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the cluster lense to the gauge body, and/or to retain the cluster housing to the gauges. Use 3 per cluster on all FJ600, XJ650 Turbo, and XJ900RK, RL, FN, and F models. These are the smaller of the two different styles of these screws that are used on these clusters. Each:
    $ 1.95
    HCP28331 OEM gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the cluster lense to the gauge body, and/or to retain the cluster housing to the gauges. Use 3 per cluster on all FJ600, XJ650 Turbo, and XJ900RK, RL, FN, and F models. These are the smaller of the two different styles of these screws that are used on these clusters. These screws are made from 18/8 stainless steel and have a bright finish. Each:
    $ 1.25
    HCP6112 OEM gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the cluster lense to the gauge body, and/or to retain the cluster housing to the gauges. Use 9 per cluster on all FJ600 models, 4 per cluster on all XJ650 Turbo models, and 7 per cluster on all XJ900RK, RL, FN, and F models. These are the larger of the two different styles of these screws that are used on these clusters. Use 10 per cluster on all XJ750 Seca models, and 6 per cluster on all 1982 XJ750 Maxim models. Each:
    $ 5.95
    HCP6112SET4 OEM gauge cluster housing self-tapping SCREWS, set of 4:
    $ 22.95
    HCP6112SET6 OEM gauge cluster housing self-tapping SCREWS, set of 6:
    $ 33.95
    HCP6112SET10 OEM gauge cluster housing self-tapping SCREWS, set of 10:
    $ 49.95
    HCP6113 OEM gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the cluster lense to the gauge body, and/or to retain the cluster housing to the gauges. Use 2 per cluster on all XJ650RJ Seca and XJ900N models, 8 per cluster on all XJ750 Seca models, and 6 per cluster on all XJ1100 Maxim models. Each:
    $ 4.95
    HCP6113SET2 OEM gauge cluster housing self-tapping SCREWS, set of 2:
    $ 8.95
    HCP6113SET6 OEM gauge cluster housing self-tapping SCREWS, set of 6:
    $ 25.95
    HCP6113SET8 OEM gauge cluster housing self-tapping SCREWS, set of 8:
    $ 33.95
    HCP28333 Aftermarket gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the cluster lense to the gauge body, and/or to retain the cluster housing to the gauges. Use 2 per cluster on all XJ650RJ Seca and XJ900N models, 8 per cluster on all XJ750 Seca models, and 6 per cluster on all XJ1100 Maxim models. These screws have a bright finish as original. Each:
    $ 1.95
    HCP28333SET2 Aftermarket gauge cluster housing self-tapping SCREWS, set of 2:
    $ 2.95
    HCP28333SET6 Aftermarket gauge cluster housing self-tapping SCREWS, set of 6:
    $ 8.75
    HCP28333SET8 Aftermarket gauge cluster housing self-tapping SCREWS, set of 8:
    $ 10.95
    HCP6114 OEM gauge cluster housing self-tapping SCREW. Used in a variety of locations and quantities to retain the gauge covers to the gauge body. Use 6 per cluster on all XJ700 non-X models, and 8 per cluster on all XJ700-X and XJ750-X models. Each:
    $ 6.95
    HCP6114SET6 OEM gauge cluster housing self-tapping SCREWS, set of 6:
    $ 39.95
    HCP6114SET8 OEM gauge cluster housing self-tapping SCREWS, set of 8:
    $ 49.95
    HCP328 OEM gauge cluster housing self-tapping screw FLAT WASHER. Used with the HCP6113 or HCP6114 screws above; use 4 per cluster on all XJ700 non-X models and XJ750 Seca models. Each:
    $ 3.95
    HCP924 Aftermarket zinc-plated, alloy-steel, natural finish gauge cluster housing self-tapping screw FLAT WASHER. Used with the HCP6113 or HCP6114 screws above; use 4 per cluster on all XJ700 non-X models and XJ750 Seca models. Each:
    $ 1.95
    HCP338 Aftermarket 18-8 stainless-steel polished finish gauge cluster housing self-tapping screw FLAT WASHER. Used with the HCP6113 or HCP6114 screws above; use 4 per cluster on all XJ700 non-X models and XJ750 Seca models. Each:
    $ 2.95
    HCP28050 Aftermarket grade 316 stainless-steel polished finish gauge cluster housing self-tapping screw FLAT WASHER. Used with the HCP6113 or HCP6114 screws above; use 4 per cluster on all XJ700 non-X models and XJ750 Seca models. Each:
    $ 3.95
    HCP1356 Aftermarket black oxide-coated steel finish gauge cluster housing self-tapping screw FLAT WASHER. Used with the HCP6113 or HCP6114 screws above; use 4 per cluster on all XJ700 non-X models and XJ750 Seca models. Each:
    $ 1.95
    HCP4190 OEM warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Zinc-plated steel, panhead phillips-drive. Each:
    $ 6.95
    HCP6418 Aftermarket warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Zinc-plated steel, panhead phillips-drive like original. Each:
    $ 1.95
    HCP6420 Aftermarket warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless steel, panhead phillips-drive like original. Each:
    $ 1.95
    HCP6421 Aftermarket warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Bright 18-8 stainless steel, small-head (JIS) panhead phillips-drive like original. Each:
    $ 3.95
    HCP6422 Aftermarket warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Originally it had a captured lock washer and flat washer; these replacement screws come without the lock washer or the flat washer, which must be ordered separate below. Black-oxide coated 18-8 stainless steel, panhead phillips-drive screw. Each:
    $ 2.95
    HCP6644 Aftermarket warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Originally it had a captured lock washer and flat washer; these replacement screws come with the lock washer but without the flat washer, which must be ordered separate below. Yellow zinc-plated steel, panhead phillips-drive screw. Each:
    $ 1.95
    HCP6099 OEM warning lights housing LOCK WASHER. Used with the HCP4190 screw above; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Each:
    $ 7.95
    HCP922 Aftermarket warning lights housing LOCK WASHER. Zinc-plated alloy steel, each:
    $ 1.95
    HCP336 Aftermarket warning lights housing LOCK WASHER. 18-8 stainless-steel, each:
    $ 2.95
    HCP342 Aftermarket warning lights housing LOCK WASHER. Black oxide-coated steel, each:
    $ 1.95
    HCP4458 OEM warning lights housing FLAT WASHER. Used with the HCP4190 screw above; use 2 per cluster on all XJ650RJ Seca and XJ900N models. Each:
    $ 2.95
    HCP924 Aftermarket warning lights housing FLAT WASHER. Zinc-plated, alloy steel, each:
    $ 1.95
    HCP338 Aftermarket warning lights housing FLAT WASHER. 18-8 stainless-steel, each:
    $ 2.95
    HCP28050 Aftermarket warning lights housing FLAT WASHER. Grade 316 stainless-steel, each:
    $ 3.95
    HCP1356 Aftermarket warning lights housing FLAT WASHER. Black oxide-coated steel, each:
    $ 1.95
    HCP322 OEM gauge warning lights housing SCREW. Used to retain the warning lights upper housing to the lower housing; use 4 per cluster on all XJ700 and XJ750-X models. Each:
    $ 6.95
    HCP918 Aftermarket gauge warning lights housing SCREW, zinc-plated alloy-steel, panhead, phillips-drive, each:
    $ 1.95
    HCP1355 Aftermarket gauge warning lights housing SCREW, 18-8 stainless-steel, polished panhead, phillips-drive, each:
    $ 2.95
    HCP25913 Aftermarket gauge warning lights housing SCREW, bright zinc-plated alloy steel, panhead, phillips drive, JIS small-head design as original, each:
    $ 3.95
    HCP328 OEM gauge warning lights housing FLAT WASHER. Used with the screws above; use 1 per screw on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP924 Aftermarket zinc-plated, alloy-steel, natural finish gauge warning lights housing FLAT WASHER. Used with the screws above; use 1 per screw on all XJ700 and XJ750-X models. Each:
    $ 1.95
    HCP338 Aftermarket 18-8 stainless-steel polished finish gauge warning lights housing FLAT WASHER. Used with the screws above; use 1 per screw on all XJ700 and XJ750-X models. Each:
    $ 2.95
    HCP28050 Aftermarket grade 316 stainless-steel polished finish gauge warning lights housing FLAT WASHER. Used with the screws above; use 1 per screw on all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP1356 Aftermarket black oxide-coated steel finish gauge warning lights housing FLAT WASHER. Used with the screws above; use 1 per screw on all XJ700 and XJ750-X models. Each
    $ 1.95
    Instrument Gauges and Cluster Mounting Brackets:
    These stamped metal brackets hold either an individual gauge or the entire cluster unit to the steering crown. Normally painted black, these brackets can get bent in cases where a bike gets dropped and will need to be replaced to insure proper alignment and fit of the instruments.
    HCP10653 OEM gauge cluster MOUNTING BRACKET, holds the entire cluster. For all XJ550 Seca models.
    $ 59.95
    HCP20031 OEM gauge cluster MOUNTING BRACKET, holds the entire cluster. For all FJ600 models.
    $ 79.95
    HCP5960 OEM tachometer MOUNTING BRACKET, holds the tachometer unit. For all XJ650 Maxim and Midnight Maxim models, and all XJ750 Maxim and Midnight Maxim models.
    $ 37.95
    HCP6020 OEM gauges cluster MOUNTING BRACKET, holds the entire cluster. For all XJ700 non-X models.
    $ 79.95
    HCP6030 OEM temperature gauge MOUNTING BRACKET, holds just the temperature gauge. For all XJ700-X and XJ750-X models.
    $ 14.95
    HCP5958 OEM gauges cluster MOUNTING BRACKET, holds the entire cluster. For all XJ750 Seca models.
    $ 49.95
    Speedometer and Tachometer head unit-to-Gauge Housing Hardware:
    HCP322 OEM speedometer or tachometer head unit-to-housing mounting SCREW, use two per gauge. Fits all XJ550, XJ650, and 1981-83 XJ750 models. Each:
    $ 6.95
    HCP918 Aftermarket speedometer or tachometer head unit-to-housing mounting SCREW, use two per gauge. Fits all XJ550, XJ650, and 1981-83 XJ750 models. Zinc-plated alloy-steel, panhead, phillips-drive, each:
    $ 1.95
    HCP1355 Aftermarket speedometer or tachometer head unit-to-housing mounting SCREW, use two per gauge. Fits all XJ550, XJ650, and 1981-83 XJ750 models. 18-8 stainless-steel, polished panhead, phillips-drive, each:
    $ 2.95
    HCP25913 Aftermarket speedometer or tachometer head unit-to-housing mounting SCREW, use two per gauge. Fits all XJ550, XJ650, and 1981-83 XJ750 models. 18-8 stainless-steel, polished panhead, phillips-drive, each:
    $ 3.95
    HCP328 OEM speedometer or tachometer head unit-to-housing mounting FLAT WASHER. Used with the screws above, each: Each:
    $ 3.95
    HCP924 Aftermarket zinc-plated, alloy-steel, natural finish speedometer or tachometer head unit-to-housing mounting FLAT WASHER. Used with the screws above, each:
    $ 1.95
    HCP338 Aftermarket 18-8 stainless-steel polished finish speedometer or tachometer head unit-to-housing mounting FLAT WASHER. Used with the screws above, each:
    $ 2.95
    HCP28050 Aftermarket grade 316 stainless-steel polished finish speedometer or tachometer head unit-to-housing mounting FLAT WASHER. Used with the screws above, each:
    $ 3.95
    HCP1356 Aftermarket black oxide-coated steel finish speedometer or tachometer head unit-to-housing mounting FLAT WASHER. Used with the screws above, each:
    $ 1.95
    HCP326 OEM alloy-steel natural finish speedometer or tachometer head unit-to-housing mounting LOCK WASHER, used with the screws above, each:
    $ 3.95
    HCP922 Aftermarket speedometer or tachometer head unit-to-housing mounting screw LOCK WASHER, zinc-plated alloy steel, used with the screws above, each:
    $ 1.95
    HCP336 Aftermarket speedometer or tachometer head unit-to-housing mounting screw LOCK WASHER, 18-8 stainless-steel, used with the screws above, each:
    $ 2.95
    HCP342 Aftermarket speedometer or tachometer head unit-to-housing mounting screw LOCK WASHER, black oxide-coated steel, used with the screws above, each:
    $ 1.95
    Instrument Gauges-to-Mounting Bracket Hardware:
    The instrument gauges or cluster are bolted to their main mounting bracket(s) via a variety of BOLTS, DAMPERS, WASHERS and NUTS. Some models do not use the bolts, as the instrument meter has a built-in threaded stud that eliminates the need for a separate bolt.
    HCP6089 OEM gauge-to-mounting bracket BOLT, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 6.95
    HCP6172 OEM gauge-to-mounting bracket bolt FLAT WASHER, use 2 per cluster on all FJ900 models. Each:
    $ 2.25
    HCP3575 OEM gauge-to-mounting bracket bolt FLAT WASHER, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 6.95
    HCP6642 Aftermarket gauge-to-mounting bracket bolt FLAT WASHER, zinc-plated alloy steel with a bright finish, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 1.95
    HCP6643 Aftermarket gauge-to-mounting bracket bolt FLAT WASHER, 18-8 stainless steel with a bright finish, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 2.95
    HCP25756 Aftermarket gauge-to-mounting bracket bolt FLAT WASHER, 316 stainless steel with a dull finish, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 3.95
    HCP14285 Aftermarket gauge-to-mounting bracket bolt FLAT WASHER, black oxide-coated 18-8 stainless steel, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 2.95
    HCP14284 Aftermarket gauge-to-mounting bracket bolt FLAT WASHER, black oxide-coated hardened alloy steel, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 2.95
    HCP6091 OEM gauge-to-mounting bracket bolt SPECIAL WASHER, use 2 per gauge on all XJ550 models, all XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 8.95
    HCP2174 OEM gauge-to-mounting bracket bolt SPECIAL WASHER, use 4 per cluster on all XJ650 Turbo models, and 3 per cluster on all XJ750 Seca models. Each:
    $ 2.95
    HCP315 OEM gauge-to-mounting bracket bolt LOCK WASHER, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, gauge-to-mounting bracket bolt LOCK WASHER, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel gauge-to-mounting bracket bolt LOCK WASHER, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel gauge-to-mounting bracket bolt LOCK WASHER, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 1.95
    HCP13873 OEM gauge mounting rubber DAMPER. This rubber damper goes inside the gauge cover. Use 2 per gauge (speedometer or tachometer) on all XJ650 Euro, XJ650RJ Seca, and XJ900N models. Each:
    $ 10.95
    HCP6100 OEM gauge-to-mounting bracket rubber insulator mounting DAMPER. Use 4 per cluster on XJ650 Turbo models, and 3 per cluster on all XJ750 Seca models. Each:
    $ 14.95
    HCP26223 Aftermarket gauge-to-mounting bracket rubber insulator mounting DAMPER. Use 4 per cluster (2 per instrument) on all XJ550, XJ650 Maxim, and 1983 XJ750 Maxim models. Each:
    $ 6.95
    HCP9768 OEM gauge-to-mounting bracket rubber insulator mounting DAMPER. Use 4 per cluster on 1982 XJ750 Maxim models. Each:
    $ 13.95
    HCP6128 OEM gauge mounting rubber DAMPER. This square rubber damper goes inside the gauge cover. Use 2 per gauge (speedometer or tachometer) on all XJ700 and XJ750-X models. Each:
    $ 8.95
    HCP6040 OEM gauge mounting rubber DAMPER. This round rubber ring insulator cushions the mounting of the temperature gauge within its housing. For all XJ700-X and XJ750-X models.
    $ 14.95
    HCP6027 OEM gauge mounting bracket rubber DAMPER. This round rubber insulator cushions the mounting of the speedometer and tachometer bodies to their mounting brackets. For all XJ700 non-X models (use 1) and XJ700-X and XJ750-X models (use 3). Each:
    $ 6.95
    HCP6129 OEM gauge mounting bracket damper FLAT WASHER, use 1 per stud on speedometer and tachometer on all XJ700, XJ750-X, and XJ900N models. Each:
    $ 7.95
    HCP3632 OEM gauge-to-mounting bracket bolt NUT, use 2 per gauge on all XJ550 models, all XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 8.95
    HCP24055 Aftermarket gauge-to-mounting bracket bolt NUT, use 2 per gauge on all XJ550 models, all XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP24056 Aftermarket gauge-to-mounting bracket bolt NUT, use 2 per gauge on all XJ550 models, all XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Bright 18/8 stainless steel. Each:
    $ 2.95
    HCP24057 Aftermarket gauge-to-mounting bracket bolt NUT, use 2 per gauge on all XJ550 models, all XJ650 Maxim and Midnight Maxim models, and all 1983 XJ750 Maxim and Midnight Maxim models. Bright 316 stainless steel. Each:
    $ 3.95
    HCP3968 OEM gauge-to-mounting bracket bolt NUT, use 2 per gauge on all 1984-85 FJ600 models. Each:
    $ 12.95
    HCP24059 Aftermarket gauge-to-mounting bracket bolt NUT, use 2 per gauge on all 1984-85 FJ600 models. Black-oxide coated stainless steel. Each:
    $ 3.95
    HCP29085 Aftermarket gauge-to-mounting bracket bolt NUT, use 2 per gauge on all 1984-85 FJ600 models. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP24035 Aftermarket gauge-to-mounting bracket bolt NUT, use 2 per gauge on all 1984-85 FJ600 models. Made from 18/8 stainless steel. Each:
    $ 2.95
    HCP6090 OEM gauge-to-mounting bracket bolt CROWN NUT, use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 6.95
    HCP24044 Aftermarket gauge-to-mounting bracket bolt CROWN NUT, 18/8 stainless steel, bright finish. The rounded dome head is slightly taller than the originals. Use 2 per gauge on all XJ650RJ Seca and XJ900 N models. Each:
    $ 3.95
    HCP3996 OEM gauge-to-mounting bracket bolt NUT, alloy steel with a bright zinc-plated finish, use 4 per cluster on all XJ650 Turbo and 3 per cluster on all XJ750 Seca models. Each:
    $ 8.95
    HCP16570 Aftermarket gauge-to-mounting bracket bolt NUT, 18/8 stainless steel with a bright zinc-plated finish, use 4 per cluster on all XJ650 Turbo and 3 per cluster on all XJ750 Seca models. Each:
    $ 2.95
    Instrument Gauges and Clusters-to-Steering Crown Bracket Mounting Hardware:
    The instrument cluster are bolted to the upper steering crown bracket via a variety of BOLTS, DAMPERS, COLLARS, and associated WASHERS and NUTS. These rubber insulators ("dampers") tend to harden and deteriorate after some time, and don't "dampen" the cluster anymore, turning your speedo and tach faces into a blurry, vibrating, and buzzing mess! Anytime you remove your cluster, you should consider replacing the dampers, as well as any rusted, frozen, or incorrect hardware and fasteners that you might come across.
    HCP6094 OEM gauge bracket-to-steering crown mounting BOLT, use 1 per gauge bracket (2 per bike) on all XJ550RJ Seca and FJ600 models. Each:
    $ 8.95
    HCP6093 OEM gauge bracket-to-steering crown mounting BOLT, use 1 per gauge bracket (2 per bike) on all XJ650 Maxim and Midnight Maxim and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 3.95
    HCP6095 OEM gauge bracket-to-steering crown mounting bolt COLLAR, use 1 per gauge bracket (2 per bike) on all XJ550 models, FJ600, all XJ650 models (except Turbo), all XJ700 models, all XJ750 models, XJ900 N model, and all XJ1100 models. Each:
    $ 7.95
    HCP4254 OEM gauge bracket-to-steering crown mounting bolt FLAT WASHER, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all 1983 XJ750 Maxim and Midnight Maxim models, and all XJ1100 models. Each:
    $ 2.95
    HCP1902 OEM gauge bracket-to-steering crown mounting bolt LOCK WASHER, black oxide-coated alloy steel, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 6.95
    HCP916 Aftermarket gauge bracket-to-steering crown mounting bolt LOCK WASHER, zinc-plated alloy steel with a bright finish, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 1.95
    HCP319 Aftermarket gauge bracket-to-steering crown mounting bolt LOCK WASHER, 18-8 stainless steel, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 2.95
    HCP321 Aftermarket gauge bracket-to-steering crown mounting bolt LOCK WASHER, black oxide-coated alloy steel, use 1 per gauge bracket (2 per bike) on all FJ600, XJ650 Maxim and Midnight Maxim models, all XJ700 and XJ750-X models, and all 1983 XJ750 Maxim and Midnight Maxim models. Each:
    $ 1.95
    HCP315 OEM gauge bracket-to-steering crown mounting bolt LOCK WASHER, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, XJ900 N model, and all XJ1100 models. Each:
    $ 3.95
    HCP916 Aftermarket zinc-plated alloy steel with a natural finish, gauge bracket-to-steering crown mounting bolt LOCK WASHER, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, XJ900 N model, and all XJ1100 models. Each:
    $ 1.95
    HCP319 Aftermarket 18-8 stainless steel gauge bracket-to-steering crown mounting bolt LOCK WASHER, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, XJ900 N model, and all XJ1100 models. Each:
    $ 2.95
    HCP321 Aftermarket black oxide-coated alloy steel gauge bracket-to-steering crown mounting bolt LOCK WASHER, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, XJ900 N model, and all XJ1100 models. Each:
    $ 1.95
    HCP18010 Aftermarket gauge cluster mounting bolt hex head protective CAP. Black plastic pebble-grain finish cap snaps onto the 10mm hex head of the mounting bolts, giving them a very "modern" look, protecting the head from rust. Fits all models using 10mm hex head bolts. Each:
    $ 3.50
    HCP6096 OEM gauge bracket-to-steering crown mounting bolt rubber insulating DAMPER. Each:
    $ 8.95
    Fits the following models:
    XJ550 all models, use 2 per bracket stud, 4 per bike.
    FJ600 all models, use 2 per bracket stud, 4 per bike.
    XJ650 all models except Turbo, use 2 per bracket bolt, 4 per bike.
    XJ700 all models, use 2 per bracket stud, 4 per bike.
    XJ750 all models, use 2 per bracket stud, 4 per bike.
    XJ1100 all models, use 2 per bracket stud, 4 per bike.
    HCP26225 Aftermarket gauge bracket-to-steering crown mounting bolt rubber insulating DAMPER.
    Each:
    $ 5.95
    HCP6014 OEM gauge cluster mounting stud rubber DAMPER. This round rubber insulator cushions the gauge housing mounting peg to the steering crown. Use 2 per cluster on all XJ900RK, RL, FN, and F models. This is the "upper" bushing. Each:
    $ 14.95
    HCP6015 OEM gauge cluster mounting stud rubber DAMPER. This round rubber insulator cushions the gauge housing mounting peg to the steering crown. Use 2 per cluster on all XJ900RK, RL, FN, and F models. This is the "lower" bushing. Each:
    $ 19.95
    HCP13874 OEM gauge housing mounting screw rubber DAMPER. This round rubber insulator cushions the gauge housing screw to the gauge. Use 2 per gauge on all XJ900N models. Each:
    $ 7.95
    HCP2176 OEM gauge bracket-to-steering crown mounting bolt NUT, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, all XJ750 Seca models, all XJ900RK, RL, N/FN, and F models, and all XJ1100 models. Each:
    $ 4.95
    HCP29085 Aftermarket gauge bracket-to-steering crown mounting bolt NUT, bright zinc-plated alloy steel, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, all XJ750 Seca models, all XJ900RK, RL, N/FN, and F models, and all XJ1100 models. Each:
    $ 1.95
    HCP24059 Aftermarket gauge bracket-to-steering crown mounting bolt NUT, black-oxide coated stainless steel, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, all XJ750 Seca models, all XJ900RK, RL, N/FN, and F models, and all XJ1100 models. Each:
    $ 3.95
    HCP24035 Aftermarket gauge bracket-to-steering crown mounting bolt NUT, made from 18/8 stainless steel, use 1 per gauge bracket (2 per bike) on all XJ550 models, all XJ650RJ Seca models, all 1982 XJ750 Maxim models, all XJ750 Seca models, all XJ900RK, RL, N/FN, and F models, and all XJ1100 models. Each:
    $ 2.95
    HCP3968 OEM gauge bracket-to-steering crown mounting bolt NUT, use 1 per gauge bracket (2 per bike) on all XJ700 and XJ750-X models. Each:
    $ 12.95
    HCP24059 Aftermarket gauge bracket-to-steering crown mounting bolt NUT, use 1 per gauge bracket (2 per bike) on all XJ700 and XJ750-X models. Black-oxide coated stainless steel. Each:
    $ 3.95
    HCP29085 Aftermarket gauge bracket-to-steering crown mounting bolt NUT, use 1 per gauge bracket (2 per bike) on all XJ700 and XJ750-X models. Bright zinc-plated alloy steel. Each:
    $ 1.95
    HCP24035 Aftermarket gauge bracket-to-steering crown mounting bolt NUT, use 1 per gauge bracket (2 per bike) on all XJ700 and XJ750-X models. Made from 18/8 stainless steel. Each:
    $ 2.95
    Speedometer Trip Meter Rewind Knob:
    The knurled knobs allow you to rewind the trip odometer back to the zero position. On most models, these knobs are removed by GENTLY rotating them in the opposite direction from their normal function. On the 1982 XJ750 Maxim models, there is a tiny screw that retains the knob to its internal stem.
    HCP5923 OEM trip odometer black plastic REWIND KNOB, fits all XJ550, all XJ650 (except Turbo), all XJ750 Seca, 1983 XJ750 Maxim and Midnight Maxim models, and XJ900 N model.
    $ 39.95
    HCP5922 OEM trip odometer black plastic REWIND KNOB, fits all 1982 XJ750 Maxim models.
    $ 39.95
    HCP9690 OEM trip odometer black plastic rewind knob SCREW, fits all 1982 XJ750 Maxim models.
    $ 6.95
    HCP6013 OEM trip odometer black plastic REWIND KNOB, fits all FJ600 and XJ900RK, RL, FN, and F models.
    $ 24.95
  31. chacal
    xxx.
  32. chacal
    xxx..
  33. chacal
    xxx...
  34. chacal
    xxx.v
  35. chacal
    xxxv
  36. chacal
    xxxv.
  37. chacal
    xxxv..
  38. chacal
    xxxv...
  39. chacal
    xxx.x
  40. chacal
    xxxx
  41. chacal
    xxxxxx.
  42. chacal
    xxxx..
  43. chacal
    xxxx...
  44. chacal
    xxxx.v
  45. chacal
    xxxxv
  46. chacal
    xxxxv.
  47. chacal
    xxxxv..
  48. chacal
    xxxxv...
  49. chacal
    xxxx.x
  50. chacal
    xxxxx
Thread Status:
Not open for further replies.
