  1. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Gorgeous day today. 28 C, slight breeze and not a cloud in the sky. Went for a 350 KM ride to break in my new jacket I got for my birthday. Probably the nicest day I've spent on the road this year.
  2. RickCoMatic
    Oil Change.
    Added Black, reflective, YAMAHA Lettering to the sides of my Front Forks.
    Organized tool Pouch. Made a "Roll-up" from old beige Pool Table felt.
    Drilled the handle of my Rear Suspension Tool. Added lanyard.
    Bought spare inline Fuel Filter and stored it in the back.
  3. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Thats a smart move there Rick.
    I was riding home from work yesterday and my fuel filter gave it up.
    Fuel starvation
    wish I had had the forsight
  4. RangerG
    RangerG Member
    Oh yeah. Forgot to mention that I rolled my bike over 50,000 KM's today(31,068 miles).
  5. goser
    goser Member
    Waterloo, Ontario
    I upgraded my fuse box to an ATC 6 fuse block, repaired the twist-and-tape connections on the main battery line, and lubed up the seat lock.
    I also learned that this bike is just like my truck... every time you fix something you find three more things that need to be done!
  6. Ltdave
    Ltdave Member
    spent about an hour trying to trace a "no headlight on" fault...
    does it come on with "key on" or only with "engine running"?
    ive got to pull the carb/airbox boots off! my fuel line wont reach the petcock the way ive got it routed! :x
    im going out to try and route the cables and wire harnesses in the right places so i can button this thing up...
    d
  7. Sonwatcher
    Sonwatcher Member
    Central Pa
    I went with my middle son today to pick up his new bike. An '07 boulevard . We surprised my other son who owns an '86 Radian. Before we all went for a ride I "changed" my son's Radian oil and filter. Then I put new plugs in my Maxim. We went for a short ride and when we got back my son's Radian was leaking oil. I couldn't figure out what was wrong. There was a nice puddle under the bike. I came home and got on the forum and did a search. I found another person that had the same problem and it hit me like a ton of bricks ! In the midst of changing the oil and talking I completely forgot to take out the oil drain plug and drain the oil. I only drained the filter. Man I felt stupid. He has about 5qts of oil in the case. So tomorrow I get to do it all over again. Man I felt dumb.
  8. RickCoMatic
    Even when you thought you've heard 'em all ...
    Glad the Story has a Hollywood Ending.
  9. Maximator
    Maximator Member
    South Cariboo, B.C., Canada
    Oops! :lol:
    I met my brother in law for the second time last week. The first time I met him was over 10 years ago when I picked him up from the drunk tank one morning.
    This time around he's struggling to get out one of the spark plugs in some old beater he's picked up cheap. I head out to the driveway and persuade it to come out without much trouble. We chat for a few minutes, then I head into the house.
    About 10 minutes later I hear some excitement as he comes through the front door with his current girlfriend giving him shit for being a true blonde. Turns out he decided to check the oil while the car was parked facing uphill in the very steep driveway, and since nothing showed on the dipstick he was grumbling about having to buy more oil to put in it. I told him to just turn the car around so it faced downhill and he'd find there was too much oil in it, then he could just drain some out which would be cheaper! :p
    His excuse was "I'm a mechanic, I just know how to change parts, not check fluids". :roll:
    Hopefully I can break the 10 year mark before I have to spend time with him again...
  10. phillyturbo
    phillyturbo Member
    Philadelphia PA
    well got my bearings in and got it all buttoned up and OMG what a diffrence the bumps arent so bumpy and turnig is soooo much easier.
    Went for a ride and it was actually enjoyable again :lol: :lol:
    And with the brakes redone it actually stops now :!:
  11. PSteele
    PSteele Member
    Nova Scotia, Canada
    Finally replaced the generator brushes (first part bought, last part put on) and discovered that the attached harness has to go between the starter and the case. A much more involved job than I thought with lots of jumping from one side of the bike to the other. Did some cleaning while there and cleaned and greased the battery connections. Thought that running the harness would be a pain but two bolts and a wedge allowed just enough to squeeze through. Went for a ride and discovered two things - starts a lot better and there was no difference after changing the brushes in generator output. Below 1800 with lights and brakes applied, there is not enough juice to flash the turn signals. It is a start and lets me know that I have some connection cleaning and greasing to do over the winter. Never thought the battery connections would get loose and corroded so quickly, as the battery has been in and out at least 5 times in 8 weeks.
    Great day for a ride - 22 degrees C (72 degrees F), sunny with a cool breeze - gotta love September!
  12. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I know the forum topic asks what we did to our Yamahas TODAY, but I was so pooped after working on the two bikes all day I went straight to bed after coming in. So, I'm bending the rules a little.
    I worked on my wife's '82 XJ650 Maxim. The last time I rode her bike I noticed that the bike would stumble between idle and about 3000 rpm. I must note that I rode her bike about thirty minutes to work and had almost made it home after work before this mystery problem materialized. Hindsight being what it is, I think I now know why, but at the time I was in exploratory mode. I had just replaced her carbs with a used set I purchased from a local bike recycler, Bent Bike. I gave them a quick going over, but not as thorough as I should have. Keep in mind that I had not found this awesome resource (XJBikes.com), and I was totally oblivious to RickCoMatic's great tutorial on cleaning carbs. After reading that tutorial, I knew the carbs had to come back off!
    Anyway, I spent yesterday going through the carbs. I will mention that the carbs still had their mixture-screw caps in place, and since I don't own [yet] a Colortune kit, I left them in. Additionally, someone had already tried to remove the fuel bowl drain screws, so I'll be enlisting the help of gremlin484 with that project. Seeing as how I now have an extra set of carb bowls, I think I'll work on the set not on the bike. That way I can rotate through the two bikes and get both carb sets done at my leisure. (I "discovered" a pretty accurate way of setting the float levels before reinstalling the bowls... if anyone is interested.)
    After reinstalling the carbs and balancing them, I took the bike for an hour-long ride. I'm happy to report (fingers crossed) that the bike ran beautifully! I plan to ride that bike several times more before handing it over to my wife. I don't want it breaking down on her. If she's left walking, I fear it may put her off riding all together... and that would suck! Oh, did I mention she's going in this Thursday for the first part of her rider safety course?
    And now, my bike: on Friday I picked up a set of soft saddle bags for my bike. I've been using a backpack to transport my shoes, lunch, rain gear, and what-ever-else I could stuff into it for the trip back and forth to work. Cycle Barn had a special on saddle bags (I think for around $130), so I figured what the heck. The wife wants my backpack, I'd spend nearly that on another backpack, so it just made sense. I should mention that I've never installed saddle bags on a bike before. I ended up fabricating brackets for them to sit/hang on. That's what yesterday’s project was for my bike--finishing making brackets. All-in-all, I'm pretty happy with the way they turned out. (Sorry, no pics... yet). I may write a tutorial on the process as I know soft bags are a real bear to mount. We’ll see.
    Oh, and the mysterious stumbling problem with the wife's bike? On the way home about a week ago, one of the carb floats stuck, flooding the engine. It was so bad I literally had fuel running out of the air box puke tube. It never occurred to me at the time that the oil would become contaminated with the excess fuel. I hypothesize that the stumbling was caused when the oil temperature reached a point where the excess fuel began to quickly evaporate from the motor oil, thereby filling the air box with fuel vapor via the crankcase breather tube. This naturally would cause an overly-rich condition which appeared as a stumbling engine. The only way to correct the problem was the same basic way you clear any flooded engine: wide open throttle, i.e. lots of air to offset the fuel.
  13. PghXJ
    PghXJ Member
    Pittsburgh PA
    washed and polished it. Adjusted the steering head to make it tighter. Also lowered the forks about 1/2" lower than where they were.
    Gamuru, I'd be interested to hear what you "discovered" about the float levels.
  14. Gamuru
    Gamuru Guest
    Granite Falls, WA
    In tearing down the wife's new used carbs, I noticed on the sides of the floats a distinct "high water mark" left by the fuel in the carbs. A remembered seeing a dimension in my Yamaha Factory Service Manuel that showed the fuel bowl level should be about 3mm below the carburator mixing chamber body edge. I took a quick measurement and noted that the fuel level mark matched almost exactly with what the book called for...
    Then I compared that with how the float actually sat with respect to the carb's edge...
    After comparing this to the other three floats, I found that all were set essentially the same. Therefore, to set the float levels, all one needs to do is tweek their respective tangs until they line up evenly with the carburator's edge. Too much or too little would cause you problems.
    [​IMG] [​IMG]
    You can verify the setting by blowing into the fuel line with the carbs set upside-down and level. As you raise the float off the needle's plunger, you should hear and feel the air escaping...
    What I found was that as I blew air past the needle, it would cease the moment the float came to rest at it's level position relative to the carb's edge. Unfortunately, I don't possess a single carb bowl with a working drain screw (yet), so I can't verify my findings. However, if anyone wishes to test my observations and get back to us, I'd be interested to hear your results.
  15. Timetonut
    Timetonut Member
    Philadelphia, PA
    Flooded it.
  16. PghXJ
    PghXJ Member
    Pittsburgh PA
    <nevermind>
  17. kickstand
    kickstand Member
    North Western Pa
    Put the head back on and now im trying to find out the way to time it.
    OBTW it a 84 fj600
  18. southern750xj
    southern750xj New Member
    new zealand
    Today I paid for my registration on my bike and took it for a legal ride through town . Heaps of people stare at it , i guess they are wondering what sort of bike it is or who is the stupid rider. Who cares it was a great ride on a great day with lots more to follow. Magic
  19. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Do they not have motorcycles in New Zealand? Or do you have a dead cat tied to the handle bars?
    Sorry, I just couldn't resist...
    My apologies to those I most assuredly have offended.
  20. schmuckaholic
    California
    Today it was replace the busted-up handlebar grips. Day before yesterday (Labor Day), I labored on the bike changing the oil (local Kragen had a discount on Castrol GTX, so I had picked up a case of 20/50). It was whining at me that it wanted some; I guess my fears that the oil level sensor had been gunked up and rendered inoperative proved unfounded.
    Problem being, yesterday I went down and sat at the DMV for half an hour; took the bike. Partway down there the bike seemed like it got louder all of a sudden, and it almost kindasorta felt like the engine was straining. Get there, do my business, go to hit the starter, and it cranks for half a second then starts grinding like mad. Made a couple other pit stops on the way back home, and it did the same thing at every stop. Haven't tried it yet today.
    I don't know if it's battery or, as a quick search of the forums turned up, the oil was too thin for the starter clutch to grab. Funny thing is, the last oil change I did was also 20/50, but I think it was the Wally-Mart brand, and I had zero problems. No, the Castrol doesn't have the "energy conserving" bit on the bottle.
    :shrug:
  21. MiCarl
    I'd be curious for a measurement from the bottom of the float to the carb body edge with the carbs inverted. Mine are at 9/16"
    If you've still got them off will you measure that for me?
    Thanx.
  22. beeker73
    beeker73 New Member
    Calgary, AB, CAN
    Yesterday I removed the tank, air filter and battery and got everything ready to go for today.
    Today I drained the tank, swished some carb cleaner around and drained that as well. Didn't notice any rust or discolouration coming out. Removed the fuel level gauge and confirmed that it works. Sprayed fogging oil into the tank and set it aside.
    I removed the carbs from the bike and began the Whole Nine Yards Carb Cleaning process. Right off the bat the head of the Main Jet broke off, leaving the body of the jet in the post!:(
    I finished removing all the float bowls, jets, floats... and left them to soak in Seafoam until tomorrow.
    If anyone knows how to get a broken jet body out of a post, PLEASE let me know.
    Yeehaw! First gear!
  23. Maximator
    Maximator Member
    Installed a new GT501 rear tire, then the bike crapped out when I went out to gently break it in. After a great deal of confusion I found I'd fallen victim to the dreaded gas in oil fiasco.
    Once the bike warmed up the mixture was screwy due to the gas evaporating in the crankcase and vapors being drawn into the airbox through the breather tube.
    I guess my next post in this thread will be about pulling my carbs to fix the float valve...
  24. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I installed a fuel filter and fuse box on my bike and a fuse box on my wife's bike. I also wrote two tutorials documenting the procedures on how to do both for future XJers. They're posted here and here.
    (h/t to RickCoMatic for the inspiration. :D )
  25. RickCoMatic
    Thats not a Post.
    That's the Bottom of the Emulsion Tube.
    Take off the Top of the Carb and pull-out the Diaphragm Assembly.
    That part will Drive right out of there through the Top side of the Carb.
    With it Out ... You should be able to wrap it in some Duct tape, stick it in a vice and Easy-out that Jet Fragment if it isn't falling out of there before you get it Driven-out the top.
  26. Rettic
    Rettic Member
    Boone, NC
    Oil change, rear gear oil changed (both to AMSOIL), and put in an inline fuel filter.
    Rode 50 miles yesterday. 221N from Blowing Rock, NC to Grandfather Mountain, then parkway back to Boone, NC.
    I have to say, 221 for that stretch is great fun. Lots of banked turns, no speed limit, little traffic. :-D
  27. beeker73
    beeker73 New Member
    Calgary, AB, CAN
    Took off the top of the carb and the diaphragm assembly, tapped out the emulsion tube, taped it up, put it in a vice and used a drill-out to get the broken body of the main jet out of the tube.
    Thanks for all the advice guys. It worked like a charm!:)
  28. Ltdave
    Ltdave Member
    picked up some exhaust gaskets at the yamaha house (along with some proper headpipe collar nuts) for a total of $105 OUCH!
    im getting more and more wrapped up in this bike every day. im HOPING im all done buying for it. other than the tank that got knocked over somehow and got DENTED :evil:
    d
  29. PghXJ
    PghXJ Member
    Pittsburgh PA
    kicked the wheel because the tach drive is leaking AGAIN!!
  30. RickCoMatic
    Degreased the Engine.
    Scrubbed my GOLD Wheels with the Tooth-brushes I ripped-off from the Men's Room at the Dentist Office.
    Sprayed STP Degreaser on a nicely warmed-up engine.
    Followed-up the Degreaser with some 60-Percent Lestoil Solution.
    Soaked the warm block with it.
    Rinsed.
    Started it up and dried the CLEAN-O-Matic Engine until dried.
    Looks New!
  31. Maximator
    Maximator Member
    Dang Rick, your dentist is going to have to start adding a fee to your bills for miscellanious dental supplies to cover all the stuff ending up in your toolbox! ;)
  32. dead_cafe
    dead_cafe New Member
    omaha,ne
    Painted the tank and side covers. Removed the stock air box. Soon to be replaced with pod filters and also a new exhaust.
  33. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Well... Today I plan to reassemble to do a test ride to see if the issues are all gone (re:XS400 sputtering after short run thread).
    Since getting the bike earlier this summer, in non running condition (some parts in a box, and wires hanging everywhere) After getting her home, I loosely assembled and took some before pics.....
    So I first needed to get thing working, cleaned the carbs up good, drained the old gas and cleaned up the tank. Replaced the old fusebox with inlines.
    New box in place, repaired signals with a new electronic flasher and bulbs, tracked down some disconnected wiring and replaced a missing diode, brake light switch was no connected to the spring clip, and repaired broken clutch safety switch.
    After that...dremel out stripped oi filter bolt and replaced it with a new EMGO with a 17mm head...new filter and oil, new for seals and raised them back to original position as a PO thought it was a good idea to drop them down abour 3-4 incches in the tree...ack!!...
    Repainted flat black, fabbed up a side panel to replace a lost one. Installed an inline filter, New headlight bulb and modify screwed holder to make it work properly...replaced broken signal lens.
    After a test ride, and many issuse, blown diode, and such, replaced diode with a stronger one and found a few loose connections, chassis ground being the biggie....
    Anyways...here's what it looks like now....
    To do list, get MVI, replace or mod sidestand (PO had this cut and welded fter lowering the bike.....) and track down a no charge issue (regulator???)
    Valves check, new turn signals, new grips and maybe clubman bars...
    (cosmetic stuff after fuction is done)
  34. Tracker797
    Tracker797 New Member
    Vancouver, Wa.
    Well, Yesterday I was on a little camping trip when my bike decided it was too hot and stopped running. So today I'm going to tare it apart to find the problem. :twisted:
  35. Sonwatcher
    Sonwatcher Member
    Central Pa
    Today my son (new Boulevard) and I and my little girl went on a Benefit ride for about 130-140 miles total. It was nice. It was my boy's first big ride and he ended up leading our group most of the way. The squirt even won a door prize at the end ! :) He really enjoyed it. My XJ650 tooled right along with my daughter and I. Long trip for a little 10 year old . She's a real trooper and loves to ride.
  36. PghXJ
    PghXJ Member
    Pittsburgh PA
    I gave my bike a bath of road spray and it is now gray. I'll have to clean that up. Great 250 mile ride in spite of the little rain shower I ran into.
  37. Donophan
    Donophan Member
    Chestertown, MD
    take a look at my gallery. I've added a couple pics. I totally stripped the bike to the frame. Those damn engines are pretty heavy, but I managed to get it out on my own. I'll need someone to help put it back in though. Oh well.
  38. Gamuru
    Gamuru Guest
    Granite Falls, WA
    "What did you do to your Yamaha today?" That's not quite right for this post. Hmmm... Let's see. How about, "What did you do for your Yamaha today? Yeah, that's better. My wife's motorcycle didn't have a home of its own, so I decided to spend the last of my vacation putting together a parking place for her. She just passed her BRC and I wanted to do something special for her.
    I tell you what, I'm pooped! And I'm not quite done yet. :cry: Here's a little animated picture showing four stages of progress...
      File size:
      202.8 KB
      28,853
  39. ZaGhost
    ZaGhost Member
    Gamuru, cool idea..... I like it.
  40. RickCoMatic
    I lubed my throttle cable.
    Much better; now!
  41. Stooge
    Stooge Member
    Northeast US
    Installed my new 4-2 mac exhaust. A wee bit louder than I hoped for, but no leaks!
  42. kickstand
    kickstand Member
    North Western Pa
    I also lubed my cables today and got the inline fuel filter in and took it for a short ride to find out that the filter has a lot of crap in it when I got back. I took the cap off and use a flash light to see in the tank and found some rust and water in the bottom of the tank so I took the petcock off and threw in a hand full of nuts and shook the hell out of it and flushed it with gas. I had to do this a few time till it was clean. Put the tank back on the bike and cleaned out the filter and drained the fuel bowls. Now she runs great and not much crap in the filter but Im going to get another one tomarrow to just have on hand.
  43. MiCarl
    I picked up an organ donor for mine today.
  44. ZaGhost
    ZaGhost Member
    Nice looking Donor... seen worse on the streets :)
  45. RickCoMatic
    I second that motion.
    That ought to clean-up very nicely.
  46. MiCarl
    Thanks guys.
    Close up isn't as good though. Lots of missing fastners, broken switches, crap like that. It leaks oil. Tank rusty inside, looks like it might have been previously been coated. No center stand. Extra outlet holes added to the mufflers.
    Some of the bits are in nicer shape than on my current ride. Will swap them in over the winter. I'll decide at some future date whether to get it on the road or just part it out.
  47. smokamoto40
    smokamoto40 Member
    sacramento, ca
    Changed the oil & filter, drained the middle gear (piece of cake w/Mac 4-1 pipe), changed the rear end oil, synch the carbs, colortuned. Went about 1/2 turn leaner than yellow, instead of just back to blue. Seems to run cleaner, it felt rich...
    Riding the Seca to Laguna Seca tomorrow for the AMA Superbike races, camping on turn 10. Anybody there, look for my silver Seca 750 and stop by for a chat.
  48. RickCoMatic
    Started the Rev Limiter Project on the 750.
    It's going behind the Cross Member behind the Airbox below the seat.
    All I did was position the thing and see how if fits there ... and if I can Tweak the little Pot that Dials-in the Cut-out.
    Yes, I can.
    So, I guess I start wiring it up ... after I use some of the Gas that I got ... without thinking I'd have to pull the tank ... before I got home with the Heat Shrink I ran over to Radio Shack to get.
    I have the DYNA-300 and the Resistors needed to make the Limiter work on Yamaha Ignition all laid-out and ready to be soldered in place.
    Should be a neat little Weekend Project.
    Anticipated Upcoming Ride Route:
    Billerica to
    Manchester VT
    Summit MT Equinox
    Mt Equinox to
    Lake George NY to
    Hadley NY to
    Corinth NY to
    Saratoga Springs NY
    (Lay-over)
    Saratoga Springs NY to
    Boston MA
    Anybody want to go?
    I have FREE "Crash, Get-cleaned-up & sleep indoors space" in Saratoga.
    Most of the ride is through New England Dairy Farm Country.
    It will be fun.
  49. danno
    danno Member
    Union Springs,New York
    I put a Maxim X rear rim on my '82 Maxim 650 bobber project. Looks sweet,and has a bigger brake drum than the stock rim.
    Anybody got a 550 Seca front rim for sale?...It would be the perfect mate for the X rear rim!
    Pix to follow.
  50. PghXJ
    PghXJ Member
    Pittsburgh PA
    Rick, I'd go, but I have to leave right now to make it there by about 5pm tonight. It's about 10 hours from here to Boston...
    I think I'll have to pass. Have a great ride though!
