XJ650 Fuel Tank Restoration. Cheap but effective.
Discussion in 'XJ DIY How-To Videos' started by taptapindustries, Jun 11, 2017.
  1. taptapindustries
    taptapindustries Member
    maroubra
  2. Anthony Byrne
    Anthony Byrne New Member
    Wexford
    Hi just looked at your video cleaning out your tank.im about to take mine off for respraying however it's your colour I want Burgundy have you any idea where I can get that paint colour or code,I'd really appreciate it tnx tony
  3. Anthony Byrne
    Wexford
    I just seen your video cleaning out your petrol tank.very good too.i want to paint my tank same colour as yours.do you have any idea how I can get that colour.id really appreciate it.tony
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  5. Chestballs
    Chestballs Member
    Albuquerque
    Any powedered laundry soap will work? Need to do my tank as well.
  6. Polock
  7. Nic
    Nic Member
    Philadelphia
  8. XJ550H
    just make a blocking plate for the petcock and sending unit
    Rodney Watson likes this.
  9. Nic
    Nic Member
    Philadelphia
    Ok I was thinking that I watched a video on u tube and the guy used vinegar to clean a tank and left the fuel sending unit on but he never coated the tank with anything thanks. Also I was thinking if since I have a 650 maxim and don't need the fuel sending unit I could make a blocking plate and seal it and pass the unit on to someone who needs it.
  10. Anthony Byrne
    Wexford
    Excellent you obviously did a great job cleaning the xj tank.
    I will need to try do the same soon.
    Thanks for doing this video.
    Tony in Ireland
  11. Franz
    What is the best way to de rust the inside of a tank without risking damage to the paintwork? What percentage strength of a chemical is strong enough to remove rust?
  12. XJ550H
    electrolisis or
    or the stuff they sell at the parts store you just pour it in your tank then rinse out evaporust i think it is called evaporust
    vineger will do the trick
  13. XJ550H
    from info overload
    - FUEL TANK INTERNAL RUST REMOVAL AND SEALING:
    For most owners, replacement fuel tanks are not available, and so the issue becomes "how to de-rust" an original tank. Although there are a variety of methods which can be used, there are plus-and-minus considerations to each method or technique.
    The following websites outline the most common methods used to de-rust iron or steel parts:
    http://www.mopedarmy.com/wiki/Removing_rust_from_a_gas_tank
    http://users.eastlink.ca/~pspencer/nsaeta/electrolysis.html
    http://www.moreg.org.au/dissolving_rust.htm
    http://www.htpaa.org.au/article-electro.php
    http://xjbikes.com/forums/index.php?threads/32838
    http://xjbikes.com/forums/index.php...val-no-frills-easiest-fastest-cheapest.48196/
    http://www.robertscycle.com/chrome-clean.html
    http://www.xjbikes.com/forums/threads/teds-2nd-82-xj750-maxim-bobber-project.47929/#post-478002
    http://www.practicalmachinist.com/vb/general-archive/rust-removal-using-molasses-90452/
  14. Franz
    Thanks XJ55oH good information here. I am hoping to get the rust out soon. Do you any information on using POR 15 Tank Sealer or Caswells I think it is called. Don't know about Red Kote but I don't think they sell it in the UK anyway.
  15. XJ550H
    I havent lined a tank ,but you do want the hard shell not a rubber bladder type
  16. Franz
    Yes I think I will use the Caswell or the POR 15. Rustbusters do a tank Sealer kit too that is meant to be very good. It is all about the preparation in using these products as some people have great results and others don't. Here is the link for the Slosh one which you probably know about.
    http://www.rust.co.uk/slosh-ethanol-resistant-petrol-tank-seal/p405062#
  17. Polock
    i'd rather see some rust in a tank than any kind of sealer
  18. Franz
    Thats the problem Polock messy if a sealer fails. The 900 tanks fail in the lower sections above the side panels as you know.
  19. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    In the process of using POR-15 3-step on my tank. Video soon.
  20. Franz
    That is what l am going to do l have heard good reports about POR 15.
  21. Ryengoth
    Wilmington, NC
    Yes, their sealant is the only one I'd ever trust on a fuel tank. It's a permanent solution used across the board for all sorts of fuel tanks by a lot of restoration shops. The cleaner and prep solutions in the kit are "meh". It's a nice all-in-one rusty tank kit for under $60 tho. Get a 5gal bucket of evapo-rust and dunk the entire tank and let it sit overnight. It works far better and is cheaper, same phos acid solution from what I can tell.
    Franz likes this.
  22. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Nice tips on the cleaning the tank!
  23. Mezzmo
    Mezzmo Active Member
    Hi guys, here is how I clean my tanks. Works great and especially good for rusty tanks.
    I also used POR15 once it was all clean. Not a quick process but very cheap and effective and does not eat into good metal like acids do.
  24. Polock
    the filler neck traps a bubble right around the gas cap, unless the tank is upside down. that area doesn't get de-rusted
    Franz likes this.
